Other Parts Discussed in Thread: OMAP3530
http://processors.wiki.ti.com/index.php/GSG:_OMAP35x_DVEVM_Software_Setup#Installing_the_software
GSG: OMAP35x DVEVM Software Setup
Rebuilding the DVSDK software for the target
7. While in the same directory that contains Rules.make, use the following commands to build the DVSDK demo applications and put the resulting binaries on the target file system specified by EXEC_DIR.
host $ make clean
host $ make all
host $ make install
Note : The make all command builds only the DVSDK demos, its dependent components and DVTB
I try it make clean & make all.
But I get a error during the compile this.
My error message is
Linking interface from dec.o enc.o encdec.o main.o menu.o start.o tparty.o ../keypad.o ../uibuttons.o interface_config/linker.cmd.. make[3]: Leaving directory `/home/won/dvsdk/dvsdk_3_01_00_06/dvsdk_demos_3_01_00_09/omap3530/interface' make[2]: Leaving directory `/home/won/dvsdk/dvsdk_3_01_00_06/dvsdk_demos_3_01_00_09/omap3530' make[1]: Leaving directory `/home/won/dvsdk/dvsdk_3_01_00_06/dvsdk_demos_3_01_00_09' make -C /home/won/dvsdk/dvsdk_3_01_00_06/dvtb_4_20_04 omap3530 CODECS=TSPA make[1]: Entering directory `/home/won/dvsdk/dvsdk_3_01_00_06/dvtb_4_20_04' ******************************************** Building DVTB for omap3530... ******************************************** cd packages/ti/sdo/dvtb/omap3530/linux && make make[2]: Entering directory `/home/won/dvsdk/dvsdk_3_01_00_06/dvtb_4_20_04/packages/ti/sdo/dvtb/omap3530/linux' XDCPATH="/home/won/dvsdk/dvsdk_3_01_00_06/cs1omap3530_1_01_00 /packages;/home/won/dvsdk/dvsdk_3_01_00_06/framework_components_2_25_01_05/packages;/home/won/dvsdk/dvsdk_3_01_00_06/codec_engine_2_25_01_06/packages;/home/won/dvsdk/dvsdk_3_01_00_06/dsplink_linux_1_65_00_01/packages;/home/won/dvsdk/dvsdk_3_01_00_06/xdais_6_25_01_08/packages;/home/won/dvsdk/dvsdk_3_01_00_06/linuxutils_2_25_01_06/packages;/home/won/dvsdk/dvsdk_3_01_00_06/linuxlibs_3_01/include;/home/won/dvsdk/dvsdk_3_01_00_06/local_power_manager_linux_1_24_01/packages;/home/won/dvsdk/dvsdk_3_01_00_06/bios_5_41_00_06/packages;/home/won/dvsdk/dvsdk_3_01_00_06/bios_5_41_00_06/packages/ti/bios/include;/home/won/dvsdk/dvsdk_3_01_00_06/bios_5_41_00_06/packages;" /home/won/dvsdk/dvsdk_3_01_00_06/xdctools_3_16_01_27/xs xdc.tools.configuro -c /home/won/toolchain/arm-2008q1 -o dvtb_omap3530 -t gnu.targets.arm.GCArmv5T -p ti.platforms.evm3530 -b config.bld dvtb_omap3530.cfg /home/won/dvsdk/dvsdk_3_01_00_06/xdctools_3_16_01_27/packages/xdc/bld/xdc_rules.mak:161: *** The macro XDCPATH must not contain any spaces in pathnames. stop. Warning: directory "/home/won/dvsdk/dvsdk_3_01_00_06/cs1omap3530_1_01_00 /packages" on package path does not exist js: "/home/won/dvsdk/dvsdk_3_01_00_06/xdctools_3_16_01_27/packages/xdc/tools/Cmdr.xs", line 51: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted. make[2]: *** [dvtb_omap3530] error 1 make[2]: Leaving directory `/home/won/dvsdk/dvsdk_3_01_00_06/dvtb_4_20_04/packages/ti/sdo/dvtb/omap3530/linux' make[1]: *** [OMAP3530_BUILD] error 2 make[1]: Leaving directory `/home/won/dvsdk/dvsdk_3_01_00_06/dvtb_4_20_04' make: *** [dvtb] error 2
How can I correct this error.
Help me.
