Unable to start Matrix UI with EZSDK (5.03.01.15) & PSP (4.04.00.01)
Dear EZSDK Team,
    While trying to integrate the latest EZSDK with latest PSP for DM8148, we are encountering error while creating /dev/fb0. We have modified Rules.make file with appropriate paths & did make clean; make all; sudo make install. We have copied the generated file system to SD card. I also verified the bootargs & it seems to be fine. Please refer to the attached log file.
U-Boot 2010.06 (Apr 19 2012 - 16:14:05)
TI8148-GP rev 2.1
ARM clk: 600MHz
DDR clk: 300MHz, M2  = 600
DRAM:  2 GiB
MMC:   OMAP SD/MMC: 0
Using default environment
The 2nd stage U-Boot will now be auto-loaded
Please do not interrupt the countdown till MultiBBWT prompt if 2nd stage is already flashed
Hit any key to stop autoboot:  0
reading u-boot.bin
184312 bytes read
## Starting application at 0x80800000 ...
U-Boot 2010.06 (Apr 19 2012 - 16:14:31)
TI8148-GP rev 2.1
ARM clk: 600MHz
I2C:   ready
DRAM:  2 GiB
NAND:  HW ECC BCH8 Selected
128 MiB
MMC:   OMAP SD/MMC: 0
*** Warning - bad CRC or NAND, using default environment
Net:   <ethaddr> not set. Reading from E-fuse
Detected MACID:40:5f:c2:7:ef:63
cpsw
Hit any key to stop autoboot:  3  2  1  0
Please set bootargs and bootcmd before booting the kernel
If that has already been done please ignore this message
BBWT-UBOOT#
TI8148-GP rev 2.1
ARM clk: 600MHz
DRAM:  2 GiB
MMC:   OMAP SD/MMC: 0
reading u-boot.bin
184312 bytes read
TI8148-GP rev 2.1
ARM clk: 600MHz
I2C:   ready
DRAM:  2 GiB
128 MiB
MMC:   OMAP SD/MMC: 0
cpsw
BBWT-UBOOT#print
bootcmd=if mmc init; then if run loadbootscript; then run bootscript; else echo In case ENV on MMC/SD is required; echo Please put a valid script named boot.scr on the card; echo Refer to the User Guide on how to generate the image; fi; else echo Please set bootargs and bootcmd before booting the kernel; echo If that has already been done please ignore this message; fi
bootdelay=3
baudrate=115200
autoload=yes
verify=yes
bootfile=uImage
ramdisk_file=ramdisk.gz
loadaddr=0x81000000
script_addr=0x80900000
loadbootscript=fatload mmc 1 ${script_addr} boot.scr
bootscript= echo Running bootscript from MMC/SD to set the ENV...; source ${script_addr}
stdin=serial
stdout=serial
stderr=serial
ethaddr=40:5f:c2:07:ef:63
ethact=cpsw
Environment size: 728/8188 bytes
BBWT-UBOOT#fatload mmc 1         s
usage: fatls <interface> <dev[:part]> [directory]
BBWT-UBOOT#mc
Unknown command '' - try 'help'
BBWT-UBOOT#
BBWT-UBOOT#
BBWT-UBOOT#
BBWT-UBOOT#fatls mmc 0
** Unable to use mmc 0:1 for fatls **
BBWT-UBOOT#mmc init
BBWT-UBOOT#mmc resca         fatls mmc 0
mmc_send_cmd: timedout waiting for cmddis!
** Can't read from device 0 **
BBWT-UBOOT#fatls mmc 1
MMC Device 1 not found
** Invalid boot device **
BBWT-UBOOT#
BBWT-UBOOT#
BBWT-UBOOT#mmc init
BBWT-UBOOT#mc rescan
Unknown command 'mc' - try 'help'
BBWT-UBOOT#mmc rescan
BBWT-UBOOT#fatload     s mm 0:1
BBWT-UBOOT#fatls mmc 0:1
BBWT-UBOOT#fatload mmc 1 0 0x80900000 boot.scr
** Unable to use mmc 0:1 for fatload **
BBWT-UBOOT#
BBWT-UBOOT#
BBWT-UBOOT#fatk    fal toad   load mmc 1 0x80900000 boot.scr
BBWT-UBOOT#
TI8148-GP rev 2.1
ARM clk: 600MHz
DRAM:  2 GiB
MMC:   OMAP SD/MMC: 0
reading u-boot.bin
184312 bytes read
TI8148-GP rev 2.1
ARM clk: 600MHz
I2C:   ready
DRAM:  2 GiB
128 MiB
MMC:   OMAP SD/MMC: 0
cpsw
Hit any key to stop autoboot:  3  0
BBWT-UBOOT#print
bootdelay=3
baudrate=115200
autoload=yes
verify=yes
bootfile=uImage
loadaddr=0x81000000
stdin=serial
stdout=serial
stderr=serial
ethact=cpsw
BBWT-UBOOT#
TI8148-GP rev 2.1
ARM clk: 600MHz
DRAM:  2 GiB
MMC:   OMAP SD/MMC: 0
reading u-boot.bin
185812 bytes read
U-Boot 2010.06 (Apr 16 2012 - 15:55:16)
TI8148-GP rev 2.1
ARM clk: 600MHz
DDR clk: 400MHz
I2C:   ready
DRAM:  2 GiB
128 MiB
MMC:   OMAP SD/MMC: 0
*** Warning - bad CRC or MMC, using default environment
                          .:;rrr;;.
                    ,5#@@@@#####@@@@@@#2,
                 ,A@@@hi;;;r5;;;;r;rrSG@@@A,
               r@@#i;:;s222hG;rrsrrrrrr;ri#@@r
             :@@hr:r;SG3ssrr2r;rrsrsrsrsrr;rh@@:
            B@H;;rr;3Hs;rrr;sr;;rrsrsrsrsrsr;;H@B
           @@s:rrs;5#;;rrrr;r#@H:;;rrsrsrsrsrr:s@@
          @@;;srs&X#9;r;r;;,2@@@rrr:;;rrsrsrsrr;;@@
         @@;;rrsrrs@MB#@@@@@###@@@@@@#rsrsrsrsrr;;@@
        G@r;rrsrsr;#X;SX25Ss#@@#M@#9H9rrsrsrsrsrs;r@G
        @9:srsrsrs;2@;:;;:.X@@@@@H::;rrsrsrsrsrsrr:3@
       X@;rrsrsrsrr;XAi;;:&@@#@Bs:rrsrsrsrsrsrsrsrr;@X
       @#;rsrsrsrsrr;r2ir@@@###::rrsrsrsrsrsrsrsrsr:@@
       @A:rrsrsrsrr;:2@29@@M@@@;:;rrrrsrsrsrsrsrsrs;H@
       @&;rsrsrsrr;A@@@@@@###@@@s::;:;;rrsrsrsrsrsr;G@
       @#:rrsrsrsr;G@5Hr25@@@#@@@#9XG9s:rrrrsrsrsrs:#@
       M@;rsrsrsrs;r@&#;::S@@@@@@@M@@@@Grr:;rsrsrsr;@#
       :@s;rsrsrsrr:M#Msrr;;&#@@@@@@@@@@H@@5;rsrsr;s@,
        @@:rrsrsrsr;S@rrrsr;:;r3MH@@#@M5,S@@irrsrr:@@
         @A:rrsrsrsrrrrrsrsrrr;::;@##@r:;rH@h;srr:H@
         ;@9:rrsrsrsrrrsrsrsrsr;,S@Hi@i:;s;MX;rr:h@;
          r@B:rrrrsrsrsrsrsrr;;sA@#i,i@h;r;S5;r:H@r
           ,@@r;rrrsrsrsrsrr;2BM3r:;r:G@:rrr;;r@@,
             B@Mr;rrrrsrsrsr@@S;;;rrr:5M;rr;rM@H
              .@@@i;;rrrrsrs2i;rrrrr;r@M:;i@@@.
                .A@@#5r;;;r;;;rrr;r:r#AsM@@H.
                   ;&@@@@MhXS5i5SX9B@@@@G;
                       :ihM#@@@@@##hs,
cpsw
reading boot.scr
300 bytes read
## Executing script at 80900000
reading uImage
2718504 bytes read
## Booting kernel from Legacy Image at 80009000 ...
   Image Name:   Linux-2.6.37
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2718440 Bytes = 2.6 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.37 (sai@sai-desktop) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #3 Thu Apr 19 16:06:53 IST 2012
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: ti8148evm
vram size = 52428800 at 0x0
reserved size = 52428800 at 0x0
FB: Reserving 52428800 bytes SDRAM for VRAM
Memory policy: ECC disabled, Data cache writeback
OMAP chip is TI8148 2.0
SRAM: Mapped pa 0x402f1000 to va 0xfe400000 size: 0xf000
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 52224
Kernel command line: console=ttyO0,115200n8 rootwait root=/dev/mmcblk0p2 rw mem=256M earlyprink notifyk.vpssm3_sva=0xBF900000 vram=50M ti814xfb.vram=0:16M,1:16M,2:6M ip=off noinitrd
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 206MB = 206MB total
Memory: 202840k/202840k available, 59304k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
    vmalloc : 0xd0800000 - 0xf8000000   ( 632 MB)
    lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .init : 0xc0008000 - 0xc003c000   ( 208 kB)
      .text : 0xc003c000 - 0xc0524000   (5024 kB)
      .data : 0xc0524000 - 0xc056f500   ( 302 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:407
IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
Total of 128 interrupts on 1 active controller
GPMC revision 6.0
Trying to install interrupt handler for IRQ400
Trying to install interrupt handler for IRQ401
Trying to install interrupt handler for IRQ402
Trying to install interrupt handler for IRQ403
Trying to install interrupt handler for IRQ404
Trying to install interrupt handler for IRQ405
Trying to install interrupt handler for IRQ406
Trying to install type control for IRQ407
Trying to set irq flags for IRQ407
OMAP clockevent source: GPTIMER1 at 20000000 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 598.01 BogoMIPS (lpj=2990080)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
omap_voltage_early_init: voltage driver support not added
regulator: core version 0.5
regulator: dummy:
NET: Registered protocol family 16
omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting!
omap_voltage_add_dev: VDD specified does not exist!
bus: 'platform': really_probe: probing driver omap_gpio with device omap_gpio.0
OMAP GPIO hardware version 0.1
bus: 'platform': really_probe: probing driver omap_gpio with device omap_gpio.1
bus: 'platform': really_probe: probing driver omap_gpio with device omap_gpio.2
bus: 'platform': really_probe: probing driver omap_gpio with device omap_gpio.3
omap_mux_init: Add partition: #1: core, flags: 4
hsmmic init
name mmc1slot1
NOR: Can't request GPMC CS
Debugfs: Only enabling/disabling deep sleep and wakeup timer is supported now
registered ti81xx_vpss device
registered ti81xx_vidout device
registered ti81xx on-chip HDMI device
registered ti81xx_fb device
registered ti81xx_vin device
bus: 'platform': really_probe: probing driver edma with device edma
bus: 'platform': really_probe: probing driver ti81xx_pcie with device ti81xx_pcie.0
ti81xx_pcie: Invoking PCI BIOS...
ti81xx_pcie: Setting up Host Controller...
ti81xx_pcie: Register base mapped @0xd0820000
ti81xx_pcie: Starting PCI scan...
PCI: bus0: Fast back to back transfers enabled
bio: create slab <bio-0> at 0
vgaarb: loaded
SCSI subsystem initialized
bus: 'platform': really_probe: probing driver omap2_mcspi with device omap2_mcspi.1
bus: 'platform': really_probe: probing driver omap2_mcspi with device omap2_mcspi.2
bus: 'platform': really_probe: probing driver omap2_mcspi with device omap2_mcspi.3
bus: 'platform': really_probe: probing driver omap2_mcspi with device omap2_mcspi.4
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
bus: 'platform': really_probe: probing driver ti81xx-usbss with device ti81xx-usbss
USBSS revision 4ea2080b
registerd cppi-dma Intr @ IRQ 17
Cppi41 Init Done
bus: 'platform': really_probe: probing driver omap_i2c with device omap_i2c.1
omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
bus: 'i2c': really_probe: probing driver pcf857x with device 1-0021
pcf857x: probe of 1-0021 failed with error -121
bus: 'i2c': really_probe: probing driver tps65910 with device 1-002d
bus: 'platform': really_probe: probing driver tps65910-pmic with device tps65910-pmic
tps65910 1-002d: read from reg 3f failed
tps65910 1-002d: read from reg 1e failed
set_machine_constraints: failed to enable VRTC
tps65910 1-002d: failed to register tps65910-pmic regulator
tps65910-pmic: probe of tps65910-pmic failed with error -121
tps65910 1-002d: No interrupt support, no core IRQ
bus: 'platform': really_probe: probing driver omap_i2c with device omap_i2c.3
omap_i2c omap_i2c.3: bus 3 rev4.0 at 100 kHz
P:bus_reg mmc
P:bus_reg sdio
Advanced Linux Sound Architecture Driver Version 1.0.23.
Switching to clocksource gp timer
musb-hdrc: version 6.0, host, debug=0
bus: 'platform': really_probe: probing driver musb-hdrc with device musb-hdrc.0
musb-hdrc musb-hdrc.0: dma type: dma-cppi41
bus: 'platform': really_probe: probing driver nop_usb_xceiv with device nop_usb_xceiv.0
MUSB controller-0 revision 4ea20800
musb-hdrc musb-hdrc.0: MUSB HDRC host driver
musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: MUSB HDRC host driver
usb usb1: Manufacturer: Linux 2.6.37 musb-hcd
usb usb1: SerialNumber: musb-hdrc.0
bus: 'usb': really_probe: probing driver usb with device usb1
bus: 'usb': really_probe: probing driver hub with device 1-0:1.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
musb-hdrc musb-hdrc.0: USB Host mode controller at d081e000 using DMA, IRQ 18
bus: 'platform': really_probe: probing driver musb-hdrc with device musb-hdrc.1
musb-hdrc musb-hdrc.1: dma type: dma-cppi41
bus: 'platform': really_probe: probing driver nop_usb_xceiv with device nop_usb_xceiv.1
MUSB controller-1 revision 4ea20800
musb-hdrc musb-hdrc.1: MUSB HDRC host driver
musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: MUSB HDRC host driver
usb usb2: Manufacturer: Linux 2.6.37 musb-hcd
usb usb2: SerialNumber: musb-hdrc.1
bus: 'usb': really_probe: probing driver usb with device usb2
bus: 'usb': really_probe: probing driver hub with device 2-0:1.0
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
musb-hdrc musb-hdrc.1: USB Host mode controller at d0826800 using DMA, IRQ 19
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NetWinder Floating Point Emulator V0.97 (double precision)
bus: 'platform': really_probe: probing driver arm-pmu with device arm-pmu.0
PMU: registered new PMU device of type 0
bus: 'platform': really_probe: probing driver omap2_elm with device omap2_elm.1
bus: 'platform': really_probe: probing driver omap-mailbox with device omap-mailbox
bus: 'platform': really_probe: probing driver omap-iommu with device omap-iommu.0
omap-iommu omap-iommu.0: ducati registered
bus: 'platform': really_probe: probing driver omap-iommu with device omap-iommu.1
omap-iommu omap-iommu.1: sys registered
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 396
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
bus: 'platform': really_probe: probing driver serial8250 with device serial8250
bus: 'platform': really_probe: probing driver omap_uart with device omap_uart.0
omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
console [ttyO0] enabled
bus: 'platform': really_probe: probing driver omap_uart with device omap_uart.1
omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
bus: 'platform': really_probe: probing driver omap_uart with device omap_uart.2
omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
bus: 'platform': really_probe: probing driver omap_uart with device omap_uart.3
omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
bus: 'platform': really_probe: probing driver omap_uart with device omap_uart.4
omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
bus: 'platform': really_probe: probing driver omap_uart with device omap_uart.5
omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
brd: module loaded
loop: module loaded
bus: 'platform': really_probe: probing driver ahci with device ahci.0
ahci ahci.0: forcing PORTS_IMPL to 0x1
ahci ahci.0: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
ahci ahci.0: flags: ncq sntf pm led clo only pmp pio slum part ccc apst
scsi0 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a150fff] port 0x100 irq 16
bus: 'spi': really_probe: probing driver m25p80 with device spi1.0
omap2-nand driver initializing
bus: 'platform': really_probe: probing driver omap2-nand with device omap2-nand.0
ONFI flash detected
ONFI param page 0 valid
NAND device: Manufacturer ID: 0x20, Chip ID: 0xf1 (ST Micro NAND 128MiB 3,3V 8-bit)
Creating 6 MTD partitions on "omap2-nand.0":
0x000000000000-0x000000020000 : "U-Boot-min"
0x000000020000-0x000000260000 : "U-Boot"
0x000000260000-0x000000280000 : "U-Boot Env"
0x000000280000-0x0000006c0000 : "Kernel"
0x0000006c0000-0x00000cee0000 : "File System"
mtd: partition "File System" extends beyond the end of device "omap2-nand.0" -- size truncated to 0x7940000
0x000008000000-0x000008000000 : "Reserved"
mtd: partition "Reserved" is out of reach -- disabled
bus: 'platform': really_probe: probing driver davinci_mdio with device davinci_mdio.0
davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
davinci_mdio davinci_mdio.0: detected phy mask fffffffc
davinci_mdio.0: probed
davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver unknown
CAN device driver interface
CAN bus driver for Bosch D_CAN controller 1.0
bus: 'platform': really_probe: probing driver d_can with device d_can
d_can d_can: d_can device registered (irq=52, irq_obj=53)
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver dm9601
usbcore: registered new interface driver cdc_acm
cdc_acm: v0.26:USB Abstract Control Model driver for USB modems and ISDN adapters
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
bus: 'i2c': really_probe: probing driver qt602240_ts with device 1-004a
qt602240_ts 1-004a: __qt602240_read_reg: i2c transfer failed
qt602240_ts: probe of 1-004a failed with error -5
bus: 'platform': really_probe: probing driver omap_rtc with device omap_rtc
omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
i2c /dev entries driver
Linux video capture interface: v2.00
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v1.0.0)
bus: 'platform': really_probe: probing driver omap_wdt with device omap_wdt
OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
mmcblk: success
P:Reg MMC driver
bus: 'platform': really_probe: probing driver mmci-omap-hs with device mmci-omap-hs.0
slots 1
irq 28
GPIO_1
GPIO_4
GPIO_5
GPIO_7
GB: mc_alloc_host
hostirq 28
mmc_add_host
mmc probe success
P:rescan
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
notify_init : notify drivercreated  for  remote proc id 2 at physical Address 0xbf900000
usbcore: registered new interface driver snd-usb-audio
bus: 'i2c': really_probe: probing driver tlv320aic3x-codec with device 1-0018
bus: 'platform': really_probe: probing driver davinci-pcm-audio with device davinci-pcm-audio
bus: 'platform': really_probe: probing driver davinci-mcasp with device davinci-mcasp.2
bus: 'platform': really_probe: probing driver soc-audio with device soc-audio.0
asoc: tlv320aic3x-hifi <-> davinci-mcasp.2 mapping ok
ALSA device list:
  #0: TI81XX EVM
TCP cubic registered
NET: Registered protocol family 17
can: controller area network core (rev 20090105 abi 8)
NET: Registered protocol family 29
can: raw protocol (rev 20090105)
can: broadcast manager protocol (rev 20090105 t)
Registering the dns_resolver key type
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
omap_voltage_late_init: Voltage driver support not added
Power Management for TI81XX.
bus: 'platform': really_probe: probing driver cpsw with device cpsw.0
Detected MACID=40:5f:c2:7:ef:63
omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
P:root_delay 0
ata1: SATA link down (SStatus 0 SControl 300)
P:root_devname mmcblk0p2
Waiting for root device /dev/mmcblk0p2...
GB: in mmc_attach_sd
P:cardid 3534453
In mmc_add_card
mmc0: new SDHC card at address fac8
bus: 'mmc': really_probe: probing driver mmcblk with device mmc0:fac8
mmcblk0: mmc0:fac8 SD16G 14.8 GiB
 mmcblk0: p1 p2
dr_pr_done 0 , ROOT_DEV 187695106
EXT3-fs: barriers not enabled
kjournald starting.  Commit interval 5 seconds
EXT3-fs (mmcblk0p2): using internal journal
EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode
VFS: Mounted root (ext3 filesystem) on device 179:2.
devtmpfs: mounted
Freeing init memory: 208K
INIT: version 2.86 booting
Error opening /dev/fb0: No such file or directory
Please wait: booting...
Starting udev
udevd (78): /proc/78/oom_adj is deprecated, please use /proc/78/oom_score_adj instead.
Remounting root file system...
Caching udev devnodes
Undefined users:
Skipping /etc/default/volatiles/99_hal
ALSA: Restoring mixer settings...
No state is present for card EVM
Found hardware: "" "" "" "" ""
Hardware is initialized using a generic method
Configuring update-modules.
Configuring omap3-sgx-modules.
Configuring hicolor-icon-theme.
# GdkPixbuf Image Loader Modules file
# Automatically generated file, do not edit
# Created by gdk-pixbuf-query-loaders from gtk+-2.20.1
g_module_open() failed for /--update-cache: /--update-cache.so: cannot open shared object file: No such file or directory
Configuring pango-module-basic-x.
Configuring pango-module-basic-fc.
Configuring ttf-dejavu-common.
Configuring ttf-dejavu-sans.
Configuring gdk-pixbuf-loader-png.
Configuring gdk-pixbuf-loader-jpeg.
Configuring gdk-pixbuf-loader-gif.
Configuring gdk-pixbuf-loader-xpm.
Configuring dbus.
 Adding system startup for /etc/init.d/dbus-1.
Configuring hal.
Configuring policykit.
Configuring gnome-keyring.
Configuring ti-cmem-module.
Configuring ti-syslink-module.
Configuring kernel-module-aes-generic.
Configuring kernel-module-tunnel4.
Configuring kernel-module-sit.
Configuring kernel-module-xfrm6-mode-beet.
Configuring kernel-module-xfrm6-mode-tunnel.
Configuring kernel-module-xfrm6-mode-transport.
Configuring kernel-module-scsi-wait-scan.
Configuring kernel-module-ssb.
Configuring kernel-module-vpss.
Configuring kernel-module-ti81xxhdmi.
Configuring kernel-module-tlc59108.
Configuring kernel-module-ti81xxfb.
Configuring kernel-module-tvp7002.
Configuring kernel-module-ti81xxvo.
Configuring kernel-module-ti81xxvin.
Configuring kernel-image-2.6.37.
NET: Registered protocol family 10
Configuring network interfaces...
CPSW phy found : id is : 0x70431
ADDRCONF(NETDEV_UP): eth0: link is not ready
udhcpc (v1.13.2) started
Sending discover...
PHY: 0:01 - Link is Up - 0/Half
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
PHY: 0:01 - Link is Down
Sending discover...
Sending discover...
No lease, forking to background
done.
Setting up IP spoofing protection: rp_filter.
Fri Dec  9 18:22:00 UTC 2011
INIT: Entering runlevel: 5
Loading HDVICP2 Firmware
DM814X prcm_config_app version: 2.0.0.1
Doing PRCM settings...
	PRCM for IVHD0 is in Progress, Please wait.....
			BW Phy Addr : 0x48180600 Data : 0x00000001
			AW Phy Addr : 0x48180600 Data : 0x00000002
			Phy Addr : 0x48180c04 Data : 0x00000037
			BW Phy Addr : 0x48180620 Data : 0x00070000
			AW Phy Addr : 0x48180620 Data : 0x00070002
			BW Phy Addr : 0x48180624 Data : 0x00030000
			AW Phy Addr : 0x48180624 Data : 0x00010002
			Phy Addr : 0x48180600 Data : 0x00000102
			BW Phy Addr : 0x48180c10 Data : 0x00000007
			AW Phy Addr : 0x48180c10 Data : 0x00000003
			Phy Addr : 0x48180c14 Data : 0x00000004
			BW Phy Addr : 0x58088000 Data : 0x120834a3
			AW Phy Addr : 0x58088000 Data : 0xeafffffe
			BW Phy Addr : 0x58098000 Data : 0x0cf746f8
			AW Phy Addr : 0x58098000 Data : 0xeafffffe
			BW Phy Addr : 0x48180c10 Data : 0x00000003
			AW Phy Addr : 0x48180c10 Data : 0x00000000
			Phy Addr : 0x48180c14 Data : 0x00000007
	PRCM for IVHD0 is Done Successfully
PRCM Initialization completed
SysLink version : 2.00.05.85
SysLink module created on Date:Apr 19 2012 Time:16:07:39
FIRMWARE: Memory map bin file not passed
Usage : firmware_loader <Processor Id> <Location of Firmware> <start|stop> [Location of Mem map bin file]
FIRMWARE: Default memory configuration is used
MemCfg: DCMM (Dynamically Configurable Memory Map) Version :  2.1.1.1
FIRMWARE: Memory Configuration status : In Progress
FIRMWARE: 1 start Successful
Loading HDVPSS Firmware
FIRMWARE: 2 start Successful
bus: 'platform': really_probe: probing driver vpss with device vpss
VPSS_FVID2: M3 firmware version 0x1000133 is old,please update firmware version.
VPSS_CORE : Failed to init fvid2 interface,
vpss: probe of vpss failed with error -22
VPSS_CORE : failed to register ti81xx-vpss driver
FATAL: Error inserting vpss (/lib/modules/2.6.37/kernel/drivers/video/ti81xx/vpss/vpss.ko): No such device
FATAL: Error inserting ti81xxfb (/lib/modules/2.6.37/kernel/drivers/video/ti81xx/ti81xxfb/ti81xxfb.ko): No such device
Configuring fb0 to LCD
/etc/init.d/rc: /etc/rc5.d/S01load-hd-firmware.sh: line 55: can't create /sys/devices/platform/vpss/graphics0/nodes: nonexistent directory
/etc/init.d/rc: /etc/rc5.d/S01load-hd-firmware.sh: line 55: can't create /sys/devices/platform/vpss/display1/enabled: nonexistent directory
/etc/init.d/rc: /etc/rc5.d/S01load-hd-firmware.sh: line 55: can't create /sys/devices/platform/vpss/display1/timings: nonexistent directory
/etc/init.d/rc: /etc/rc5.d/S01load-hd-firmware.sh: line 55: can't create /sys/devices/platform/vpss/display1/output: nonexistent directory
open /dev/fb0: No such file or directory
FATAL: Error inserting ti81xxhdmi (/lib/modules/2.6.37/kernel/drivers/video/ti81xx/ti81xxhdmi/ti81xxhdmi.ko): No such device
bus: 'i2c': really_probe: probing driver tlc59108 with device 1-0040
Starting system message bus: dbus.
Starting telnet daemon.
Starting syslogd/klogd: done
Starting thttpd.
expr: syntax error
Linux Frame Buffer Device Configuration Version 2.1 (23/06/1999)
(C) Copyright 1995-1999 by Geert Uytterhoeven
Usage: fbset [options] [mode]
Valid options:
  General options:
    -h, --help         : display this usage information
    --test             : don't change, just test whether the mode is valid
    -s, --show         : display video mode settings
    -i, --info         : display all frame buffer information
    -v, --verbose      : verbose mode
    -V, --version      : print version information
    -x, --xfree86      : XFree86 compatibility mode
    -a, --all          : change all virtual consoles on this device
  Frame buffer special device nodes:
    -fb <device>       : processed frame buffer device
                         (default is /dev/fb0)
  Video mode database:
    -db <file>         : video mode database file
                         (default is /etc/fb.modes)
  Display geometry:
    -xres <value>      : horizontal resolution (in pixels)
    -yres <value>      : vertical resolution (in pixels)
    -vxres <value>     : virtual horizontal resolution (in pixels)
    -vyres <value>     : virtual vertical resolution (in pixels)
    -depth <value>     : display depth (in bits per pixel)
    -nonstd <value>    : select nonstandard video mode
    -g, --geometry ... : set all geometry parameters at once
    -match             : set virtual vertical resolution by virtual resolution
  Display timings:
    -pixclock <value>  : pixel clock (in picoseconds)
    -left <value>      : left margin (in pixels)
    -right <value>     : right margin (in pixels)
    -upper <value>     : upper margin (in pixel lines)
    -lower <value>     : lower margin (in pixel lines)
    -hslen <value>     : horizontal sync length (in pixels)
    -vslen <value>     : vertical sync length (in pixel lines)
    -t, --timings ...  : set all timing parameters at once
  Display flags:
    -accel <value>     : hardware text acceleration enable (false or true)
    -hsync <value>     : horizontal sync polarity (low or high)
    -vsync <value>     : vertical sync polarity (low or high)
    -csync <value>     : composite sync polarity (low or high)
    -gsync <value>     : synch on green (false or true)
    -extsync <value>   : external sync enable (false or true)
    -bcast <value>     : broadcast enable (false or true)
    -laced <value>     : interlace enable (false or true)
    -double <value>    : doublescan enable (false or true)
    -rgba <r,g,b,a>    : recommended length of color entries
    -grayscale <value> : grayscale enable (false or true)
  Display positioning:
    -move <direction>  : move the visible part (left, right, up or down)
    -step <value>      : step increment (in pixels or pixel lines)
                         (default is 8 horizontal, 2 vertical)
Starting PVR
bus: 'platform': really_probe: probing driver pvrsrvkm with device pvrsrvkm
FATAL: Error inserting omaplfb (/lib/modules/2.6.37/kernel/drivers/gpu/pvr/omaplfb.ko): No such device
/dev/mem opened.
Memory mapped at address 0x402a6000.
Read at address  0x48180F04 (0x402a6f04): 0x00000001
Write at address 0x48180F04 (0x402a6f04): 0x00000000, readback 0x00000000
/dev/mem opened.
Memory mapped at address 0x4025b000.
Read at address  0x48180900 (0x4025b900): 0x00000102
Write at address 0x48180900 (0x4025b900): 0x00000002, readback 0x00000002
/dev/mem opened.
Memory mapped at address 0x4028a000.
Read at address  0x48180920 (0x4028a920): 0x00040002
Write at address 0x48180920 (0x4028a920): 0x00000002, readback 0x00000002
Calibrating touchscreen (first time only)ts_open: No such file or directory
Starting Matrix GUI application.
MultiBBWT ttyO0
Mad Cat 2012.04 MultiBBWT ttyO0
MultiBBWT login:
Thanks & Regards,
Amit
