Other Parts Discussed in Thread: TWL6030, TMP105
Hi, I am trying to boot 4AI.1.3 release on a blaze board (NOT blaze tablet). What I see is that the kernel gets booted but the it seems like the board gets stuck. i.e. I can see the android logo at the touch screen but never shows me the desktop (android never starts). Is it a known issue? should I be able to use 4AI.1.3 release on a blaze board. I did follow the release notes for building the source code. Thanks in advance!
Texas Instruments Inc X-Loader 1.41.0-g68844632 (Apr 18 2012 - 12:20:51)
Starting OS Bootloader from EMMC ...
U-Boot 1.1.4-g90d3cc44 (Apr 18 2012 - 12:24:42)
Load address: 0x80e80000
DRAM: 1024 MB
Flash: 0 kB
Using default environment
In: serial
Out: serial
Err: serial
efi partition table:
ptbl slot: EMMC:(1).
256 128K xloader
512 256K bootloader
1024 128K misc
2048 16M efs
34816 16K crypto
34848 8M recovery
51232 8M boot
67616 512M system
1116192 256M cache
1640480 6774M userdata
Net: KS8851SNL
Hit any key to stop autoboot: 0
kernel @ 80008000 (4165248)
ramdisk @ 81000000 (164716)
I2C read: I/O error
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.0.21-00002-OMAP-Android+ (alireza@ubuntu) (gcc version 4.4.1 (Sourcery G++ Lite 2010q1-202) ) #2 SMP PREEMPT Wed Apr 18 14:09:53 PDT 2012
[ 0.000000] CPU: ARMv7 Processor [411fc093] revision 3 (ARMv7), cr=10c5387d
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: OMAP4 blaze board
[ 0.000000] Reserving 16777216 bytes SDRAM for VRAM
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] OMAP4430 ES2.3
[ 0.000000] SRAM: Mapped pa 0x40300000 to va 0xfe400000 size: 0xd000
[ 0.000000] On node 0 totalpages: 172032
[ 0.000000] free_area_init_node: node 0, pgdat c080b860, node_mem_map c1029000
[ 0.000000] Normal zone: 256 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 32512 pages, LIFO batch:7
[ 0.000000] HighMem zone: 1792 pages used for memmap
[ 0.000000] HighMem zone: 137472 pages, LIFO batch:31
[ 0.000000] PERCPU: Embedded 7 pages/cpu @c1834000 s7072 r8192 d13408 u32768
[ 0.000000] pcpu-alloc: s7072 r8192 d13408 u32768 alloc=8*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 169984
[ 0.000000] Kernel command line: console=ttyO2,115200n8 mem=1G vmalloc=768M androidboot.console=ttyO2 omap_wdt.timer_margin=30 no_console_suspend androidboot.serialno=3124002600000001 androidboot.bootloader=U-Boot_1.1.4-g90d3cc44
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 512MB 160MB = 672MB total
[ 0.000000] Memory: 669976k/669976k available, 378600k reserved, 557056K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
[ 0.000000] vmalloc : 0xc8800000 - 0xf8000000 ( 760 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc8000000 ( 128 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .init : 0xc0008000 - 0xc004f000 ( 284 kB)
[ 0.000000] .text : 0xc004f000 - 0xc079e000 (7484 kB)
[ 0.000000] .data : 0xc079e000 - 0xc080c3c0 ( 441 kB)
[ 0.000000] .bss : 0xc080c3e4 - 0xc095cc80 (1347 kB)
[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:410
[ 0.000000] omap_hwmod: dpll_mpu_m2_ck: missing clockdomain for dpll_mpu_m2_ck.
[ 0.000000] OMAP clockevent source: GPTIMER1 at 32768 Hz
[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms
[ 0.000091] Calibrating delay loop... 1194.24 BogoMIPS (lpj=4665344)
[ 0.015686] pid_max: default: 32768 minimum: 301
[ 0.015686] Mount-cache hash table entries: 512
[ 0.071777] Initializing cgroup subsys debug
[ 0.071777] Initializing cgroup subsys cpuacct
[ 0.071777] Initializing cgroup subsys freezer
[ 0.071777] CPU: Testing write buffer coherency: ok
[ 0.072509] L310 cache controller enabled
[ 0.072509] l2x0: 16 ways, CACHE_ID 0x410000c4, AUX_CTRL 0x5e470000, Cache size: 1048576 B
[ 0.150665] CPU1: Booted secondary processor
[ 0.166259] Brought up 2 CPUs
[ 0.181945] SMP: Total of 2 processors activated (2388.48 BogoMIPS).
[ 0.186218] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for emif_fw
[ 0.186218] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l3_instr
[ 0.186248] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l3_main_1
[ 0.186248] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l3_main_2
[ 0.186248] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_abe
[ 0.186309] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_cfg
[ 0.186309] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_per
[ 0.186309] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_wkup
[ 0.186340] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for mpu_private
[ 0.186340] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for sl2if
[ 0.186462] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for usbhs_ohci
[ 0.186462] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for usbhs_ehci
[ 0.186767] omap_hwmod: l3_div_ck: missing clockdomain for l3_div_ck.
[ 0.192169] _omap4_module_wait_ready: Timeout waiting for module enable (mcpdm_fck: clkctrl = 0x30002)
[ 0.195220] omap_hwmod: mcpdm: cannot be enabled (3)
[ 0.197692] print_constraints: dummy:
[ 0.197692] NET: Registered protocol family 16
[ 0.198730] GPMC revision 6.0
[ 0.198730] EMIF0 is enabled with IRQ142
[ 0.198730] EMIF1 is enabled with IRQ143
[ 0.198730] Last reset was cold reset (PRM_RSTST=0x1)
[ 0.198730]
[ 0.200653] OMAP GPIO hardware version 0.1
[ 0.203613] omap_mux_init: Add partition: #1: core, flags: 2
[ 0.203613] omap_mux_init: Add partition: #2: wkup, flags: 2
[ 0.206237] omap_mux_get_by_name: Could not find signal uart1_cts.uart1_cts
[ 0.207061] omap_hwmod_mux_init: Could not allocate device mux entry
[ 0.439727] Modem NOT detected
[ 0.439727] Modem state properly updated to state 0
[ 0.442565] omap_disp_led_init: Configuring as one display LED
[ 0.567962] HSI: skipping omap_device registration
[ 0.568145] OMAP DMA hardware revision 0.0
[ 0.568145] omap_rproc_get_pool: ipu - carveout memory is unavailable: 0x0, 0x0
[ 0.580566] bio: create slab <bio-0> at 0
[ 0.580841] print_constraints: vwl1271: 1800 mV
[ 0.580841] i2c-core: driver [twl] using legacy suspend method
[ 0.580841] i2c-core: driver [twl] using legacy resume method
[ 0.581878] SCSI subsystem initialized
[ 0.583801] usbcore: registered new interface driver usbfs
[ 0.583801] usbcore: registered new interface driver hub
[ 0.584075] usbcore: registered new device driver usb
[ 0.584899] omap_i2c omap_i2c.1: bus 1 rev4.0 at 400 kHz
[ 0.584899] Skipping twl internal clock init and using bootloader value (unknown osc rate)
[ 0.589477] twl6030: PIH (irq 39) chaining IRQs 368..387
[ 0.592468] print_constraints: VUSB: 3300 mV normal standby
[ 1.611602] PC detected
[ 1.619964] twl6030_usb twl6030_usb: Initialized TWL6030 USB module
[ 1.620788] print_constraints: VMMC: 1200 <--> 3000 mV at 1800 mV normal standby
[ 1.621612] print_constraints: VPP: 1800 <--> 2500 mV at 1900 mV normal standby
[ 1.622558] print_constraints: VUSIM: 1200 <--> 2900 mV at 1800 mV normal standby
[ 1.623962] print_constraints: VCXIO: 1800 mV normal standby
[ 1.625213] print_constraints: VDAC: 1800 mV normal standby
[ 1.625823] print_constraints: VAUX1_6030: 1000 <--> 3000 mV at 2800 mV normal standby
[ 1.626434] print_constraints: VAUX2_6030: 1200 <--> 2800 mV at 1800 mV normal standby
[ 1.627349] print_constraints: VAUX3_6030: 1000 <--> 3000 mV at 1200 mV normal standby
[ 1.628906] print_constraints: VDD1:
[ 1.630310] print_constraints: VDD2:
[ 1.631835] print_constraints: V2V1: at 2100 mV
[ 1.633148] print_constraints: VANA: 2100 mV normal standby
[ 1.634063] print_constraints: CLK32KG:
[ 1.635040] print_constraints: CLK32KAUDIO:
[ 1.636352] print_constraints: SYSEN:
[ 1.637725] print_constraints: REGEN1:
[ 1.637725] print_constraints: VOUT: 4075 <--> 4950 mV at 3825 mV normal standby
[ 1.638916] tps6130x 1-0033: Revision 5
[ 1.639434] omap_i2c omap_i2c.2: bus 2 rev4.0 at 400 kHz
[ 1.639892] omap_i2c omap_i2c.3: bus 3 rev4.0 at 400 kHz
[ 1.640502] omap_i2c omap_i2c.4: bus 4 rev4.0 at 400 kHz
[ 1.641082] omap-rproc omap-rproc.0: dsp is available
[ 1.641082] omap-rproc omap-rproc.1: ipu is available
[ 1.642059] Advanced Linux Sound Architecture Driver Version 1.0.24.
[ 1.642852] Bluetooth: Core ver 2.16
[ 1.642974] NET: Registered protocol family 31
[ 1.642974] Bluetooth: HCI device and connection manager initialized
[ 1.643005] Bluetooth: HCI socket layer initialized
[ 1.643005] Bluetooth: L2CAP socket layer initialized
[ 1.643035] Bluetooth: SCO socket layer initialized
[ 1.643035] Switching to clocksource 32k_counter
[ 1.645538] musb-hdrc: version 6.0, musb-dma, otg (peripheral+host)
[ 1.650665] Switched to NOHz mode on CPU #0
[ 1.650665] Switched to NOHz mode on CPU #1
[ 1.945404] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 1.945404] musb-hdrc: MHDRC RTL version 2.0
[ 1.945404] musb-hdrc: setup fifo_mode 4
[ 1.945404] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 1.945770] musb-hdrc musb-hdrc: USB OTG mode controller at fc0ab000 using DMA, IRQ 124
[ 1.946228] NET: Registered protocol family 2
[ 1.946807] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 1.948028] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 1.948455] TCP bind hash table entries: 16384 (order: 6, 393216 bytes)
[ 1.949554] TCP: Hash tables configured (established 16384 bind 16384)
[ 1.949554] TCP reno registered
[ 1.949584] UDP hash table entries: 64 (order: 0, 4096 bytes)
[ 1.949676] UDP-Lite hash table entries: 64 (order: 0, 4096 bytes)
[ 1.949676] NET: Registered protocol family 1
[ 1.950622] RPC: Registered named UNIX socket transport module.
[ 1.950836] RPC: Registered udp transport module.
[ 1.950866] RPC: Registered tcp transport module.
[ 1.950866] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.951141] Trying to unpack rootfs image as initramfs...
[ 1.968017] Freeing initrd memory: 160K
[ 2.026275] omap_init_opp_table: no hwmod or odev for hsi, [18] cannot add OPPs.
[ 2.026275] omap_init_opp_table: no hwmod or odev for hsi, [19] cannot add OPPs.
[ 2.026794] ram_console: got buffer at a0000000, size 200000
[ 2.028228] ram_console: found existing buffer, size 31517, start 31517
[ 2.159271] console [ram-1] enabled
[ 2.159271] omap-iommu omap-iommu.0: ducati registered
[ 2.160217] omap-iommu omap-iommu.1: tesla registered
[ 2.175659] highmem bounce pool size: 64 pages
[ 2.175659] ashmem: initialized
[ 2.187133] fuse init (API version 7.16)
[ 2.187133] msgmni has been set to 220
[ 2.187133] Registering char device tf_driver (122:0)
[ 2.187133] SMCAG01.06.0 D
[ 2.191284] io scheduler noop registered
[ 2.191284] io scheduler deadline registered
[ 2.191436] io scheduler cfq registered (default)
[ 2.191436] start plist test
[ 2.191436] end plist test
[ 2.199768] OMAP DSS rev 4.0
[ 2.220397] dsscomp: initializing.
[ 2.220947] misc dsscomp: display0=taal
[ 2.220947] misc dsscomp: display1=hdmi_panel
[ 2.220947] misc dsscomp: found 2 displays and 4 overlays
[ 2.221740] could not allocate slot
[ 2.221771] omap-rproc omap-rproc.1: powering up ipu
[ 2.222778] virtio_rpmsg_bus virtio0: rpmsg backend virtproc probed successfully
[ 2.223876] virtio_rpmsg_bus virtio1: rpmsg backend virtproc probed successfully
[ 2.223876] omap-rproc omap-rproc.0: powering up dsp
[ 2.224700] virtio_rpmsg_bus virtio2: rpmsg backend virtproc probed successfully
[ 2.226287] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 104) is a OMAP UART0
[ 2.226776] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 105) is a OMAP UART1
[ 2.227416] omap_uart.2: ttyO2 at MMIO 0x48020000 (irq = 106) is a OMAP UART2
[ 3.386505] console [ttyO2] enabled
[ 3.390777] omap_uart.3: ttyO3 at MMIO 0x4806e000 (irq = 102) is a OMAP UART3
[ 3.399749] omap_ion_probe: adding heap secure_input of type 2 with ba300000@5a00000
[ 3.399749] omap_ion_probe: adding heap tiler of type 4 with ada00000@6000000
[ 3.416625] omap_ion_probe: adding heap nonsecure_tiler of type 4 with a0200000@2000000
[ 3.425964] brd: module loaded
[ 3.425964] loop: module loaded
[ 3.445831] (stk) :sysfs entries created
[ 3.445831] (stk) : debugfs entries created
[ 3.455474] No CPUfreq policy at this point.
[ 3.472229] ks8851 spi1.0: message enable is 0
[ 3.482727] ks8851 spi1.0: eth0: revision 1, MAC ee:21:ac:fe:57:25, IRQ 194
[ 3.490661] PPP generic driver version 2.4.2
[ 3.495819] PPP Deflate Compression module registered
[ 3.501586] PPP BSD Compression module registered
[ 3.507812] PPP MPPE Compression module registered
[ 3.513336] NET: Registered protocol family 24
[ 3.518432] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 4.531921] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 4.538482] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
[ 4.546966] ehci-omap ehci-omap.0: irq 109, io mem 0x4a064c00
[ 4.557556] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 4.557556] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.571716] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.571716] usb usb1: Product: OMAP-EHCI Host Controller
[ 4.585784] usb usb1: Manufacturer: Linux 3.0.21-00002-OMAP-Android+ ehci_hcd
[ 4.585784] usb usb1: SerialNumber: ehci-omap.0
[ 4.598876] hub 1-0:1.0: USB hub found
[ 4.599578] hub 1-0:1.0: 3 ports detected
[ 4.646972] usbcore: registered new interface driver cdc_acm
[ 4.646972] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 4.662261] Initializing USB Mass Storage driver...
[ 4.667938] usbcore: registered new interface driver usb-storage
[ 4.674652] USB Mass Storage support registered.
[ 4.674652] usbcore: registered new interface driver usbserial
[ 4.686676] usbserial: USB Serial Driver core
[ 4.992980] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 5.000640] android_usb gadget: Number of LUNs=1
[ 5.005950] lun0: LUN: removable file: (no medium)
[ 5.011474] android_usb gadget: android_usb ready
[ 5.016998] musb-hdrc musb-hdrc: MUSB HDRC host driver
[ 5.016998] musb-hdrc musb-hdrc: new USB bus registered, assigned bus number 2
[ 5.031005] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 5.038696] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.038696] usb usb2: Product: MUSB HDRC host driver
[ 5.052337] usb usb2: Manufacturer: Linux 3.0.21-00002-OMAP-Android+ musb-hcd
[ 5.060333] usb usb2: SerialNumber: musb-hdrc
[ 5.065856] hub 2-0:1.0: USB hub found
[ 5.065856] hub 2-0:1.0: 1 port detected
[ 5.373321] mousedev: PS/2 mouse device common for all mice
[ 5.381103] input: omap4-keypad as /devices/platform/omap/omap4-keypad/input/input0
[ 5.396209] tm12xx_ts: Synaptic TM12xx Touchscreen Driver found man id 1 (1)
[ 5.409515] tm12xx_ts 2-004b: resetting device (reg 0x62)
[ 5.551940] tm12xx_ts 2-004b: no button capabilities found
[ 5.558776] tm12xx_ts: Synaptic TM12xx Touchscreen Driver found man id 1 (1)
[ 5.567260] tm12xx_ts: product ID: TM1217 family:1 fw:9
[ 5.573181] input: syn_tm12xx_ts_1 as /devices/platform/omap/omap_i2c.2/i2c-2/2-004b/input/input1
[ 5.585021] tm12xx_ts 2-004b: device status: 0x0, no error
[ 5.594665] tm12xx_ts 3-004b: resetting device (reg 0x62)
[ 5.736724] tm12xx_ts 3-004b: no button capabilities found
[ 5.749786] CMA3000 Acclerometer : Revision 10
[ 5.755371] tm12xx_ts: product ID: TM1217 family:1 fw:9
[ 5.761291] input: syn_tm12xx_ts_2 as /devices/platform/omap/omap_i2c.3/i2c-3/3-004b/input/input2
[ 5.772888] tm12xx_ts 3-004b: device status: 0x0, no error
[ 5.807830] input: cma3000-acclerometer as /devices/virtual/input/input3
[ 5.892791] bh1780 3-0029: Ambient Light Sensor, Rev : 1
[ 5.898742] input: bh1780gli as /devices/virtual/input/input4
[ 5.906768] bmp085 4-0077: BMP085 ver. 2.0 found.
[ 5.906768] input: bmp085 as /devices/virtual/input/input5
[ 5.918701] bmp085 4-0077: Succesfully initialized bmp085!
[ 5.918701] twl6030_pwrbutton_probe: Enter
[ 5.930419] input: twl6030_pwrbutton as /devices/platform/omap/omap_i2c.1/i2c-1/1-0049/twl6030_pwrbutton/input/input6
[ 5.943786] input: hmc5843 as /devices/virtual/input/input7
[ 5.943786] sfh7741_probe: Proximity sensor
[ 5.955383] input: sfh7741 as /devices/platform/sfh7741.1/input/input8
[ 5.967041] using rtc device, twl_rtc, for alarms
[ 5.967529] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
[ 5.980102] i2c /dev entries driver
[ 5.980102] lirc_dev: IR Remote Control driver registered, major 249
[ 5.992156] IR NEC protocol handler initialized
[ 5.997253] IR RC5(x) protocol handler initialized
[ 5.997253] IR RC6 protocol handler initialized
[ 6.007781] IR JVC protocol handler initialized
[ 6.012908] IR Sony protocol handler initialized
[ 6.012908] IR RC5 (streamzap) protocol handler initialized
[ 6.012908] IR LIRC bridge handler initialized
[ 6.024383] Linux video capture interface: v2.00
[ 6.034851] dmm: probe base: fd300000, irq 145
[ 6.071441] twl6030_bci twl6030_bci: Battery Voltage at Bootup is 3715 mV
[ 6.091552] lm75 3-0048: hwmon0: sensor 'tmp105'
[ 6.100860] OMAP Watchdog Timer Rev 0x00: initial timeout 30 sec
[ 6.109405] device-mapper: uevent: version 1.0.3
[ 6.115020] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
[ 6.124572] Bluetooth: HCI UART driver ver 2.2
[ 6.129547] Bluetooth: HCI H4 protocol initialized
[ 6.135009] Bluetooth: Bluetooth Driver for TI WiLink - Version 1.0
[ 6.143920] (stc): st_register(2)
[ 6.147735] (stc): chnl_id list empty :2
[ 6.152343] (stk) : st_kim_start
[ 6.155853] cpuidle: using governor ladder
[ 6.160858] cpuidle: using governor menu
[ 6.170989] Registered led device: omap4:green:debug0
[ 6.176818] Registered led device: omap4:green:debug1
[ 6.182678] Registered led device: omap4:green:debug2
[ 6.188446] Registered led device: omap4:green:debug3
[ 6.194580] Registered led device: omap4:green:debug4
[ 6.200378] Registered led device: omap4:blue:user
[ 6.205993] Registered led device: omap4:red:user
[ 6.211364] Registered led device: omap4:green:user
[ 6.217468] Registered led device: omap4:green:chrg
[ 6.226348] omap4430_sdp_display_probe:Enter
[ 6.231323] Registered led device: lcd-backlight
[ 6.237152] omap4430_sdp_display_probe:Exit
[ 6.242065] omap4430_keypad_led_probe:Enter
[ 6.247009] Registered led device: keyboard-backlight
[ 6.253356] omap4430_keypad_led_probe:Exit
[ 6.263885] usbcore: registered new interface driver usbhid
[ 6.270202] usbhid: USB HID core driver
[ 6.271331] (stk) :ldisc_install = 1
[ 6.278839] logger: created 256K log 'log_main'
[ 6.284484] logger: created 256K log 'log_events'
[ 6.289916] logger: created 256K log 'log_radio'
[ 6.295349] logger: created 256K log 'log_system'
[ 6.300842] thermal_governor_dev_register:Adding omap_ondie_governor governor
[ 6.310028] OMAP HSI: HSI driver version 0.4.3
[ 6.315399] OMAP HSI: Platform DRIVER register FAILED: -19
[ 6.322082] usbcore: registered new interface driver snd-usb-audio
[ 6.333007] SDP4430 SoC init
[ 6.363800] mmc0: new high speed DDR MMC card at address 0001
[ 6.371643] mmcblk0: mmc0:0001 SEM08G 7.39 GiB
[ 6.377197] mmcblk0boot0: mmc0:0001 SEM08G partition 1 1.00 MiB
[ 6.386718] mmcblk0boot1: mmc0:0001 SEM08G partition 2 1.00 MiB
[ 6.397430] asoc: null-codec-dai <-> MultiMedia1 mapping ok
[ 6.405792] asoc: null-codec-dai <-> MultiMedia2 mapping ok
[ 6.414733] asoc: null-codec-dai <-> Voice mapping ok
[ 6.421356] Alternate GPT is invalid, using primary GPT.
[ 6.427459] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10
[ 6.434112] asoc: null-codec-dai <-> Tones mapping ok
[ 6.444305] asoc: null-codec-dai <-> Vibra mapping ok
[ 6.450775] mmcblk0boot1: unknown partition table
[ 6.456878] asoc: null-codec-dai <-> MODEM mapping ok
[ 6.463409] mmcblk0boot0: unknown partition table
[ 6.463592] asoc: null-codec-dai <-> MultiMedia1 LP mapping ok
[ 6.466033] asoc: FM Digital <-> omap-mcbsp-dai.1 mapping ok
[ 6.467712] asoc: twl6040-dl1 <-> mcpdm-dl mapping ok
[ 6.470275] asoc: dmic-hifi <-> omap-dmic-dai-0 mapping ok
[ 6.493743] twl6040-codec twl6040-codec: ASoC: Failed to create Aux/FM Stereo In debugfs file
[ 6.504516] asoc: twl6040-dl1 <-> mcpdm-dl1 mapping ok
[ 6.511596] asoc: twl6040-ul <-> mcpdm-ul1 mapping ok
[ 6.518402] asoc: twl6040-dl2 <-> mcpdm-dl2 mapping ok
[ 6.525421] asoc: twl6040-vib <-> mcpdm-vib mapping ok
[ 6.532440] asoc: Bluetooth <-> omap-mcbsp-dai.0 mapping ok
[ 6.540008] asoc: Bluetooth <-> omap-mcbsp-dai.0 mapping ok
[ 6.547515] asoc: FM Digital <-> omap-mcbsp-dai.1 mapping ok
[ 6.555206] asoc: MODEM <-> omap-mcbsp-dai.1 mapping ok
[ 6.562255] asoc: dmic-hifi <-> omap-dmic-abe-dai-0 mapping ok
[ 6.570068] asoc: dmic-hifi <-> omap-dmic-abe-dai-1 mapping ok
[ 6.577758] asoc: dmic-hifi <-> omap-dmic-abe-dai-2 mapping ok
[ 6.585601] asoc: null-codec-dai <-> omap-abe-vxrec-dai mapping ok
[ 6.595367] input: SDP4430 Headset Jack as /devices/platform/soc-audio/sound/card0/input9
[ 6.608520] asoc: hdmi-audio-codec <-> hdmi-audio-dai mapping ok
[ 6.609069] mmc2: card claims to support voltages below the defined range. These will be ignored.
[ 6.625793] ALSA device list:
[ 6.628723] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 6.629486] mmc2: new high speed SDIO card at address 0001
[ 6.641540] #0: TI OMAP4 Board
[ 6.645172] #1: OMAP4HDMI
[ 6.648529] GACT probability NOT on
[ 6.652496] Mirror/redirect action on
[ 6.656707] u32 classifier
[ 6.659790] Actions configured
[ 6.663604] Netfilter messages via NETLINK v0.30.
[ 6.669067] nf_conntrack version 0.5.0 (10470 buckets, 41880 max)
[ 6.677520] ctnetlink v0.93: registering with nfnetlink.
[ 6.684051] xt_time: kernel timezone is -0000
[ 6.692474] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 6.698699] arp_tables: (C) 2002 David S. Miller
[ 6.703948] TCP cubic registered
[ 6.708618] NET: Registered protocol family 10
[ 6.724395] Mobile IPv6
[ 6.727203] IPv6 over IPv4 tunneling driver
[ 6.741149] NET: Registered protocol family 17
[ 6.746276] NET: Registered protocol family 15
[ 6.751434] Bluetooth: RFCOMM TTY layer initialized
[ 6.756927] Bluetooth: RFCOMM socket layer initialized
[ 6.762847] Bluetooth: RFCOMM ver 1.11
[ 6.767059] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.773071] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 6.779876] NET: Registered protocol family 35
[ 6.785552] NET: Registered protocol family 37
[ 6.790527] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 6.799255] ThumbEE CPU extension supported.
[ 6.804077] Registering SWP/SWPB emulation handler
[ 6.815795] Reprogramming LPDDR2 timings to 400000000 Hz
[ 6.822113] sr_init: No PMIC hook to init smartreflex
[ 6.828063] smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver initialized
[ 6.837005] smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver initialized
[ 6.845886] smartreflex smartreflex.2: omap_sr_probe: SmartReflex driver initialized
[ 6.854888] SmartReflex class 1.5 driver: initialized (86400000ms)
[ 6.861907] thermal_cooling_dev_register:Found cpu cpu
[ 6.868408] Power Management for TI OMAP4.
[ 6.873504] OMAP4 PM: Static dependency added between MPUSS <-> EMIF, MPUSS <-> L4_PER/CFG MPUSS <-> L3_MAIN_1.
[ 6.884429] OMAP4 PM: Static dependency added between DUCATI <-> L4_PER/CFG and DUCATI <-> L3.
[ 6.903900] clock: disabling unused clocks to save power
[ 6.955993] sr_class1p5_calib_work: mpu: Calibration complete: Voltage Nominal=1200000Calib=1050820 margin=0
[ 6.966674] sr_class1p5_calib_work: core: Calibration complete: Voltage Nominal=1127000Calib=1038160 margin=0
[ 6.977416] sr_class1p5_calib_work: iva: Calibration complete: Voltage Nominal=950000Calib=860920 margin=0
[ 6.987426] Invalid Device Structure
[ 7.104522] sr_class1p5_calib_work: core: Calibration complete: Voltage Nominal=962000Calib=873580 margin=0
[ 7.115509] sr_class1p5_calib_work: mpu: Calibration complete: Voltage Nominal=1025000Calib=898900 margin=0
[ 7.129516] cannot apply mgr(lcd) on inactive device
[ 7.135284] omapfb omapfb: failed to apply dispc config
[ 7.141357] cannot apply mgr(tv) on inactive device
[ 7.146759] omapfb omapfb: failed to apply dispc config
[ 7.152435] cannot apply mgr(lcd2) on inactive device
[ 7.157989] omapfb omapfb: failed to apply dispc config
[ 7.307617] taal display0: taal panel revision e3.85.7d
[ 7.421813] twl_rtc twl_rtc: setting system clock to 2012-04-19 20:47:12 UTC (1334868432)
[ 7.424774] (stk) :ldisc installation timeout
[ 7.424804] (stk) :ldisc_install = 0
[ 7.441070] Freeing init memory: 284K
[ 7.448425] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[ 7.580047] keychord: using input dev omap4-keypad for fevent
[ 7.643676] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: (null)
[ 7.677490] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit
[ 7.696929] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: nomblk_io_submit
[ 7.719818] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: (null)
[ 8.093902] omap-rproc omap-rproc.1: Loaded BIOS image ducati-m3.bin, size 5852836
[ 8.102722] omap-rproc omap-rproc.1: BIOS image version is 2
[ 8.120391] omap-rproc omap-rproc.0: rproc_loader_cont: failed to load tesla-dsp.bin
[ 8.122070] init: cannot find '/system/bin/setup_fs', disabling 'setup_fs'
[ 8.124938] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
[ 8.174774] sr_class1p5_calib_work: mpu: Calibration complete: Voltage Nominal=1388000Calib=1253380 margin=0
[ 8.193298] omap_hwmod: ipu: failed to hardreset
[ 8.199127] omap-iommu omap-iommu.0: ducati: version 2.1
[ 8.203216] HDCP: failed to load keys
[ 8.218872] omap-rproc omap-rproc.1: remote processor ipu is now up
[ 8.233337] omap_rpmsg_mbox_callback: received echo reply from ipu !
[ 8.242553] omap_rpmsg_mbox_callback: received echo reply from ipu !
[ 8.249450] omap_rpmsg_mbox_callback: received echo reply from ipu !
[ 8.258911] omap_rpmsg_mbox_callback: received echo reply from ipu !
[ 8.268371] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x32
[ 8.278137] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x33
[ 8.287445] virtio_rpmsg_bus virtio0: creating channel rpmsg-omx addr 0x3c
[ 8.295776] rpmsg_omx rpmsg-omx0: new OMX connection srv channel: 1024 -> 60!
[ 8.296783] Compat-wireless backport release:
[ 8.296783] Backport based on wl12xx.git v3.1-rc6-14178-gfb320e3
[ 8.404754] virtio_rpmsg_bus virtio1: creating channel rpmsg-omx addr 0x3c
[ 8.415893] rpmsg_omx rpmsg-omx1: new OMX connection srv channel: 1024 -> 60!
[ 8.581695] (stk) : timed out waiting for ldisc to be un-installed
[ 8.615051] PVR: PVRCore_Init
[ 8.624511] PVR: PVRSRVDriverProbe(pDevice=c78a4800)
[ 8.630126] PVR: SGX register base: 0x56000000
[ 8.635620] PVR: SGX register size: 65535
[ 8.639984] PVR: SGX IRQ: 53
[ 8.643157] PVR: EnableSystemClocks: Enabling System Clocks
[ 8.650604] PVR: PVRCore_Init: major device 247
[ 8.721893] (stk) :ldisc_install = 1
[ 8.761840] omaplfbOMAPLFBInit: Blitsville gc2d not present, blits disabled
[ 8.769714] omaplfb OMAPLFBInitIonOmap: Device 0: Requesting 2 TILER 2D framebuffers
[ 8.781341] (stc): st_tty_open
[ 8.785369] (stk) :line discipline installed
[ 8.792205] (stk) :TIInit_10.6.15.bts
[ 8.855468] cfg80211: Calling CRDA to update world regulatory domain
[ 8.912506] cfg80211: World regulatory domain updated:
[ 8.919494] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 8.929901] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 8.939117] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 8.940704] EXT4-fs (mmcblk0p8): re-mounted. Opts: (null)
[ 8.958740] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 8.968963] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 8.977447] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 9.188873] (stc): add_channel_to_table: id 2
[ 9.193603] (stc): st_register(3)
[ 9.197204] (stc): add_channel_to_table: id 3
[ 9.201934] (stc): st_register(4)
[ 9.205535] (stc): add_channel_to_table: id 4
[ 9.440002] PVR: Installing MISR with cookie bf03c728
[ 9.446289] PVR: Installing device LISR SGX ISR on IRQ 53 with cookie c7348100
[ 9.455047] PVR: OSUnMapPhysToLin: unmapping 65535 bytes from c8be0000
[ 9.462646] PVR: SysFinalise: Version string: SGX revision = 1.2.0
[ 9.508148] EXT4-fs (mmcblk0p8): re-mounted. Opts: (null)
[ 9.794219] android_usb: already disabled
[ 9.800628] mtp_bind_config
[ 9.803680] adb_bind_config
[ 9.808319] warning: `adbd' uses 32-bit capabilities (legacy support in use)
[ 9.816497] adb_open
shell@android:/ $ [ 10.092895] android_work: sent uevent USB_STATE=CONNECTED
[ 10.100250] android_work: sent uevent USB_STATE=DISCONNECTED
[ 10.158721] android_work: sent uevent USB_STATE=CONNECTED
[ 10.278808] rpmsg_omx rpmsg-omx1: local addr assigned: 0x401
[ 10.286254] rpmsg_omx rpmsg8: conn rsp: status 0 addr 101
[ 10.447174] misc dsscomp: [c6ec8000] ignoring set failure -22
[ 10.831573] android_usb gadget: high speed config #1: android
[ 10.837982] android_work: sent uevent USB_STATE=CONFIGURED
[ 11.230834] (stc): remove_channel_from_table: id 2
[ 11.236053] (stc): remove_channel_from_table: id 3
[ 11.252807] (stc): remove_channel_from_table: id 4
[ 11.257965] (stc): all chnl_ids unregistered
[ 11.268463] (stk) :ldisc_install = 0
[ 11.272369] (stc): st_tty_close
[ 25.823211] sr_class1p5_calib_work: mpu: Calibration complete: Voltage Nominal=1325000Calib=1177420 margin=0
[ 44.519165] request_suspend_state: wakeup (3->0) at 44516357429 (2012-04-19 20:47:49.588531504 UTC)
[ 61.945251] NOHZ: local_softirq_pending 08
[ 61.955383] NOHZ: local_softirq_pending 08
[ 63.041595] NOHZ: local_softirq_pending 08
[ 64.421569] NOHZ: local_softirq_pending 08
[ 66.216033] NOHZ: local_softirq_pending 08
[ 70.466186] NOHZ: local_softirq_pending 08
[ 72.424713] eth0: no IPv6 routers present
[ 72.729949] NOHZ: local_softirq_pending 08
[ 75.691162] NOHZ: local_softirq_pending 08
[ 83.674530] NOHZ: local_softirq_pending 08
[ 85.486206] NOHZ: local_softirq_pending 08
