I am working on a product using OMAP3630 with Gingerbread rowboat 2.3.4. The SGX works fine on our product except that sometimes we meet “User requested SGX debug info” or “HWRecoveryResetSGX: SGX Hardware Recovery triggered” and then the whole UI is hang. I attach the bootlog and logcat.Do you have any suggestion?
Here is the SGX info I got from out product:
.... Hardware core designer: 0, HW core revision: 1.2.5
.... Hardware core ID: 112, name: SGX 520/530
.... SGX microkernel DDK version: 1.7.17.4352
.... SGX microkernel software core ID: SGX 530, revision: 10205
Here is the bootlog and logcat:
OMAP3630-GP ES2.1, CPU-OPP2 L3-200MHz
Honeywell D7800 board + LPDDR/NAND
I2C: ready
DRAM: 256 MiB
NAND: 4 BIT SW ECC selected
512 MiB
In: serial
Out: serial
Err: serial
Die ID #7aa600029ff80000016858031300d027
invalid serial number, use the default serial number.
pcbver: MP
boot reason number is 1
Device 0: nand0, partition main is already the current ubi partition.
UBIFS: recovery needed
UBIFS: recovery deferred
UBIFS: mounted UBI device 0, volume 1, name "cache"
UBIFS: mounted read-only
UBIFS: file system size: 19935232 bytes (19468 KiB, 19 MiB, 157 LEBs)
UBIFS: journal size: 1015809 bytes (992 KiB, 0 MiB, 8 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: LZO
UBIFS: reserved for root: 985215 bytes (962 KiB)
Hit any key to stop autoboot: 3 2 1
Booting from nand ...
NAND read: device 0 offset 0x840000, size 0x400000
err_loc=1054
4194304 bytes read: OK
## Booting kernel from Legacy Image at 82000000 ...
Image Name: D7800 Android
Image Type: ARM Linux Multi-File Image (uncompressed)
Data Size: 3488799 Bytes = 3.3 MiB
Load Address: 80008000
Entry Point: 80008000
Contents:
Image 0: 3339684 Bytes = 3.2 MiB
Image 1: 149103 Bytes = 145.6 KiB
Verifying Checksum ... OK
## Loading init Ramdisk from multi component Legacy Image at 82000000 ...
Loading Multi-File Image ... OK
OK
Starting kernel ...
[ 0.000000] Linux version 2n6.37-00048-g456b2a0 (bsquare@ubuntu) (gcc version 4.4.3 (GCC) ) #76 Thu Apr 12 10:14:40 CST 2012
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: HONEYWELL D7800
[ 0.000000] Reserving 8388608 bytes SDRAM for VRAM
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] OMAP3630 ES1.2 (l2cache sgx neon isp 192mhz_clk )
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xfe400000 size: 0x10000
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 62976
[ 0.000000] Kernel command line: console=ttyO0,115200n8 no_console_suspend MEM=256M omap_vout.vid1_static_vrfb_alloc=y omapfb.vram=0:8M loglevel=7 pcbversion=MP productSN=D7800-A5A5 mpurate=800 vram=8M omapfb.mode=lcd:640x480-16@60 omapdss.def_disp=lcd ubi.mtd=main,2048 init=/init rootwait
[ 0.000000] D7800_Rev: 4
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 248MB = 248MB total
[ 0.000000] Memory: 243992k/243992k available, 18152k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
[ 0.000000] vmalloc : 0xd0800000 - 0xf8000000 ( 632 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .init : 0xc0008000 - 0xc003c000 ( 208 kB)
[ 0.000000] .text : 0xc003c000 - 0xc062d000 (6084 kB)
[ 0.000000] .data : 0xc062e000 - 0xc0678100 ( 297 kB)
[ 0.000000] NR_IRQS:409
[ 0.000000] Clocking rate (Crystal/Core/MPU): 13.0/400/800 MHz
[ 0.000000] Reprogramming SDRC clock to 400000000 Hz
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] GPMC revision 5.0
[ 0.000000] Trying to install interrupt handler for IRQ402
[ 0.000000] Trying to install interrupt handler for IRQ403
[ 0.000000] Trying to install interrupt handler for IRQ404
[ 0.000000] Trying to install interrupt handler for IRQ405
[ 0.000000] Trying to install interrupt handler for IRQ406
[ 0.000000] Trying to install interrupt handler for IRQ407
[ 0.000000] Trying to install interrupt handler for IRQ408
[ 0.000000] Trying to install type control for IRQ409
[ 0.000000] Trying to set irq flags for IRQ409
[ 0.000000] OMAP clockevent source: GPTIMER1 at 32768 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Calibrating delay loop... 799.29 BogoMIPS (lpj=3121152)
[ 0.000000] pid_max: default: 32768 minimum: 301
[ 0.000000] Security Framework initialized
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] regulator: core version 0.5
[ 0.000000] regulator: dummy:
[ 0.000000] NET: Registered protocol family 16
[ 0.000000] OMAP GPIO hardware version 2.5
[ 0.000000] omap_mux_init: Add partition: #1: core, flags: 0
[ 0.000000] i2c_register: Register I2C port1/2/3
[ 0.000000] spi_register: Register SPI port1
[ 0.000000] Audio GPIO init OK
[ 0.000000] bt_wlan_init: Power on/off and enable/disable
[ 0.000000] cam_img_init: Power on/off and I2C3 switch on/off
[ 0.000000] Honeywell d7800 setting NAND access to BCH4.
[ 0.000000] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.000000] Switched to new clocking rate (Crystal/Core/MPU): 13.0/400/800 MHz
[ 0.000000] OMAP DMA hardware revision 5.0
[ 0.020751] bio: create slab <bio-0> at 0
[ 0.021728] regulator: vwl1271: 1800 mV
[ 0.023040] SCSI subsystem initialized
[ 0.024963] usbcore: registered new interface driver usbfs
[ 0.025268] usbcore: registered new interface driver hub
[ 0.025451] usbcore: registered new device driver usb
[ 0.038238] omap_i2c omap_i2c.1: bus 1 rev4.0 at 2600 kHz
[ 0.039581] twl: cfg_boot 6
[ 0.054565] twl4030: PIH (irq 7) chaining IRQs 368..375
[ 0.054565] twl4030: power (irq 373) chaining IRQs 376..383
[ 0.055053] twl4030: gpio (irq 368) chaining IRQs 384..401
[ 0.057800] regulator: VUSB1V5: 1500 mV normal standby
[ 0.058288] regulator: VUSB1V8: 1800 mV normal standby
[ 0.058776] regulator: VUSB3V1: 3100 mV normal standby
[ 0.060150] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[ 0.062347] regulator: VIO: 1800 mV normal standby
[ 0.062957] regulator: VMMC1: 1850 <--> 3150 mV at 3150 mV normal standby
[ 0.063537] regulator: VDAC: 1800 mV normal standby
[ 0.064086] regulator: VAUX2_4030: 2800 mV normal standby
[ 0.064819] regulator: VINTDIG: 1500 mV normal standby
[ 0.065063] omap_i2c omap_i2c.2: bus 2 rev4.0 at 400 kHz
[ 0.077301] omap_i2c omap_i2c.3: bus 3 rev4.0 at 400 kHz
[ 0.078857] Advanced Linux Sound Architecture Driver Version 1.0.23.
[ 0.079528] Bluetooth: Core ver 2.15
[ 0.079681] NET: Registered protocol family 31
[ 0.079711] Bluetooth: HCI device and connection manager initialized
[ 0.079711] Bluetooth: HCI socket layer initialized
[ 0.080200] cfg80211: Calling CRDA to update world regulatory domain
[ 0.081298] Switching to clocksource 32k_counter
[ 0.202423] WL1271: BT_EN GPIO initialized
[ 0.202636] musb-hdrc: version 6.0, otg (peripheral+host), debug=0
[ 0.202728] musb-hdrc musb-hdrc.0: dma type: dma-inventra
[ 0.203002] musb-hdrc musb-hdrc.0: USB OTG mode controller at fa0ab000 using DMA, IRQ 92
[ 0.203491] NET: Registered protocol family 2
[ 0.203674] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.204010] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.204132] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.204223] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.204223] TCP reno registered
[ 0.204254] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.204284] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.204437] NET: Registered protocol family 1
[ 0.204620] Unpacking initramfs...
[ 0.214813] Freeing initrd memory: 144K
[ 0.214813] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.215270] omap_init_opp_table: no hwmod or odev for iva, [5] cannot add OPPs.
[ 0.216094] MSP430_MCU_MUX spi1.0: d7800 mcu mux, irq 197
[ 0.268157] send_sync_request()
[ 0.273040] omap-iommu omap-iommu.0: isp registered
[ 0.273284] AM37x/DM37x Linux PSP version 04.02.00.07 (PLATFORM)
[ 0.378479] ashmem: initialized
[ 0.378875] VFS: Disk quotas dquot_6.5.2
[ 0.378936] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.379302] msgmni has been set to 476
[ 0.380401] io scheduler noop registered
[ 0.380432] io scheduler deadline registered
[ 0.380493] io scheduler cfq registered (default)
[ 0.441009] OMAP DSS rev 2.0
[ 0.441009] omapdss supply vdds_dsi not found, using dummy regulator
[ 0.441070] OMAP DISPC rev 3.0
[ 0.441101] OMAP VENC rev 2
[ 0.441375] OMAP DSI rev 1.0
[ 0.606170] LCD backlight PWM output Timer register success !
[ 0.607543] ..entering gps_serial_init
[ 0.607574] Registering 0xc0247498 for event 0x04 callback
[ 0.607574] ..entering gps_serial_register_driver
[ 0.607879] ..register_early_suspend
[ 0.607879] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.609466] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 72) is a OMAP UART0
[ 1.360931] console [ttyO0] enabled
[ 1.364959] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 73) is a OMAP UART1
[ 1.372680] omap_uart.2: ttyO2 at MMIO 0x49020000 (irq = 74) is a OMAP UART2
[ 1.380371] omap_uart.3: ttyO3 at MMIO 0x49042000 (irq = 80) is a OMAP UART3
[ 1.392395] loop: module loaded
[ 1.397491] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 1.404296] omap2-nand driver initializing
[ 1.408630] Honeywell d7800 setting NAND access to BCH4.
[ 1.414520] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xbc (Micron )
[ 1.422821] Creating 9 MTD partitions on "omap2-nand.0":
[ 1.428436] 0x000000000000-0x000000080000 : "X-Loader-NAND"
[ 1.435729] Honeywell d7800 setting NAND access to 2.
[ 1.560546] Honeywell d7800 setting NAND access to 3.
[ 1.675292] 0x000000080000-0x000000180000 : "U-Boot-NAND"
[ 1.682830] 0x000000200000-0x000000220000 : "U-Boot Env-NAND"
[ 1.690155] 0x000000240000-0x000000260000 : "MFG Data-NAND"
[ 1.697235] 0x000000260000-0x000000280000 : "MFG Data R-NAND"
[ 1.704528] 0x000000280000-0x000000340000 : "Reserved"
[ 1.711456] 0x000000340000-0x000000840000 : "Recovery-NAND"
[ 1.720611] 0x000000840000-0x000000c40000 : "Kernel-NAND"
[ 1.729217] 0x000000c40000-0x00001ff20000 : "main"
[ 1.941589] UBI: attaching mtd9 to ubi0
[ 1.945617] UBI: physical eraseblock size: 131072 bytes (128 KiB)
[ 1.952209] UBI: logical eraseblock size: 126976 bytes
[ 1.957855] UBI: smallest flash I/O unit: 2048
[ 1.962799] UBI: sub-page size: 512
[ 1.967620] UBI: VID header offset: 2048 (aligned 2048)
[ 1.973937] UBI: data offset: 4096
[ 3.411682] UBI: max. sequence number: 29636
[ 3.427276] UBI: attached mtd9 to ubi0
[ 3.431182] UBI: MTD device name: "main"
[ 3.436340] UBI: MTD device size: 498 MiB
[ 3.441558] UBI: number of good PEBs: 3991
[ 3.446472] UBI: number of bad PEBs: 0
[ 3.451141] UBI: number of corrupted PEBs: 0
[ 3.455780] UBI: max. allowed volumes: 128
[ 3.460632] UBI: wear-leveling threshold: 4096
[ 3.465545] UBI: number of internal volumes: 1
[ 3.470214] UBI: number of user volumes: 5
[ 3.474853] UBI: available PEBs: 105
[ 3.479705] UBI: total number of reserved PEBs: 3886
[ 3.484893] UBI: number of PEBs reserved for bad PEB handling: 39
[ 3.491302] UBI: max/mean erase counter: 310/8
[ 3.495941] UBI: image sequence number: 831647594
[ 3.501007] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.507965] UBI: background thread "ubi_bgt0d" started, PID 570
[ 3.514343] Initializing USB Mass Storage driver...
[ 3.519683] usbcore: registered new interface driver usb-storage
[ 3.525939] USB Mass Storage support registered.
[ 3.530975] usbcore: registered new interface driver usbtest
[ 3.536926] android init
[ 3.539611] android_probe pdata: c063e6b0
[ 3.544006] android_bind
[ 3.547180] android_usb gadget: android_usb ready
[ 3.552154] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[ 3.557769] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
[ 3.565612] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.572753] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.580322] usb usb1: Product: MUSB HDRC host driver
[ 3.585540] usb usb1: Manufacturer: Linux 2.6.37-00048-g456b2a0 musb-hcd
[ 3.592559] usb usb1: SerialNumber: musb-hdrc.0
[ 3.598022] hub 1-0:1.0: USB hub found
[ 3.601959] hub 1-0:1.0: 1 port detected
[ 3.606750] f_adb init
[ 3.609222] android_register_function adb
[ 3.613433] f_mass_storage init
[ 3.616760] fsg_probe pdev: c063df40, pdata: c063e6d4
[ 3.622253] android_register_function usb_mass_storage
[ 3.627624] adb_bind_config
[ 3.631408] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 3.638641] android_usb gadget: Number of LUNs=1
[ 3.643493] lun0: LUN: removable file: (no medium)
[ 3.648956] f_mtp init
[ 3.651428] android_register_function mtp
[ 3.656158] mice: PS/2 mouse device common for all mice
[ 3.664520] d7800_kp_probe: keypad type=24, keymap base addr=c063ecf0,offset=80, size=80
[ 3.673370] input: d7800-numeric-keypad as /devices/platform/omap/omap_i2c.1/i2c-1/1-004a/D7800_keypad/input/input0
[ 3.686187] Registering 0xc02e9eb4 for event 0x01 callback
[ 5.695373] input: TSC2007 Touchscreen as /devices/virtual/input/input1
[ 5.703796] input: twl4030_pwrbutton as /devices/platform/omap/omap_i2c.1/i2c-1/1-0049/twl4030_pwrbutton/input/input2
[ 5.715942] input: twl4030:vibrator as /devices/platform/omap/omap_i2c.1/i2c-1/1-004a/input/input3
[ 5.727966] using rtc device, twl_rtc, for alarms
[ 5.732788] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
[ 5.740722] i2c /dev entries driver
[ 5.745635] Linux media interface: v0.10
[ 5.749908] Linux video capture interface: v2.00
[ 5.755584] usbcore: registered new interface driver uvcvideo
[ 5.761627] USB Video Class driver (v1.0.0)
[ 5.766021] Driver for 1-wire Dallas network protocol.
[ 5.771881] omap_hdq omap_hdq.0: OMAP HDQ Hardware Rev 0.5. Driver in Interrupt mode
[ 5.972961] charger_ic_aat3620 charger_ic_aat3620: probe OK, irq registered 221
[ 5.981811] mma7660_init: i2c and INT_G_SENS init
[ 5.986755] mma7660 3-004c: gpio = 199, irq = 391
[ 5.995117] bq27000-battery bq27000-battery.1: probe OK, irqs registered 323, 274
[ 6.104003] mma7660 3-004c: mode_backup 0x51
[ 6.209289] mma7660 3-004c: build time Apr 11 2012 14:02:40
[ 6.215179] mma7660 3-004c: alloc poll device!!!
[ 6.220397] input: mma7660 as /devices/platform/omap/omap_i2c.3/i2c-3/3-004c/input/input4
[ 6.229583] mma7660 3-004c: register poll device!!!
[ 6.235534] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 6.242248] device-mapper: uevent: version 1.0.3
[ 6.247558] device-mapper: ioctl: 4.18.0-ioctl (2010-06-29) initialised: dm-devel@redhat.com
[ 6.256469] Bluetooth: HCI UART driver ver 2.2
[ 6.261138] Bluetooth: HCI H4 protocol initialized
[ 6.266143] Bluetooth: HCILL protocol initialized
[ 6.271179] cpuidle: using governor ladder
[ 6.275451] cpuidle: using governor menu
[ 6.280395] mmci-omap-hs.0 supply vmmc_aux not found, using dummy regulator
[ 6.289215] mmci-omap-hs.2 supply vmmc not found, using dummy regulator
[ 6.296173] mmci-omap-hs.2 supply vmmc_aux not found, using dummy regulator
[ 6.305541] usbcore: registered new interface driver usbhid
[ 6.311401] usbhid: USB HID core driver
[ 6.316131] logger: created 64K log 'log_main'
[ 6.321014] logger: created 256K log 'log_events'
[ 6.326202] logger: created 64K log 'log_radio'
[ 6.331176] logger: created 64K log 'log_system'
[ 6.337860] usbcore: registered new interface driver snd-usb-audio
[ 6.345306] HONEYWELL D7800 SoC init
[ 6.457824] asoc: rt5630-hifi <-> omap-mcbsp-dai.1 mapping ok
[ 6.464569] asoc: rt5630-voice <-> omap-mcbsp-dai.2 mapping ok
[ 6.478363] ALSA device list:
[ 6.481506] #0: RT5630 CARD
[ 6.484619] oprofile: hardware counters not available
[ 6.489929] oprofile: using timer interrupt.
[ 6.494506] nf_conntrack version 0.5.0 (3814 buckets, 15256 max)
[ 6.501129] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 6.506835] TCP cubic registered
[ 6.510223] Initializing XFRM netlink socket
[ 6.514709] NET: Registered protocol family 17
[ 6.519409] NET: Registered protocol family 15
[ 6.524169] Bluetooth: L2CAP ver 2.15
[ 6.528045] Bluetooth: L2CAP socket layer initialized
[ 6.533325] Bluetooth: SCO (Voice Link) ver 0.6
[ 6.538085] Bluetooth: SCO socket layer initialized
[ 6.543304] Bluetooth: RFCOMM TTY layer initialized
[ 6.548431] Bluetooth: RFCOMM socket layer initialized
[ 6.553833] Bluetooth: RFCOMM ver 1.11
[ 6.557739] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.563323] Bluetooth: BNEP filters: protocol multicast
[ 6.568786] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 6.575317] Registering the dns_resolver key type
[ 6.580261] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 6.588623] ThumbEE CPU extension supported.
[ 6.595825] Power Management for TI OMAP3.
[ 6.602264] smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver initialized
[ 6.610504] smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver initialized
[ 6.618865] SmartReflex Class3 initialized
[ 6.626464] clock: disabling unused clocks to save power
[ 6.632629] platform mpu.0: omap_voltage_scale: Already at the requestedrate 800000000
[ 6.640960] platform mpu.0: omap_voltage_scale: Already at the requestedrate 800000000
[ 6.651153] omapfb omapfb: cannot parse default modes
[ 6.808563] mmci-omap-hs mmci-omap-hs.2: could not set regulator OCR (-22)
[ 6.855560] regulator_init_complete: incomplete constraints, leaving VAUX2_4030 on
[ 6.863769] regulator_init_complete: incomplete constraints, leaving VDAC on
[ 6.876190] twl_rtc twl_rtc: setting system clock to 2012-04-12 10:59:28 UTC (1334228368)
[ 6.884918] omap_vout omap_vout: Buffer Size = 3686400
[ 6.902374] omap_vout omap_vout: : registered and initialized video device 0
[ 6.909820] omap_vout omap_vout: Buffer Size = 3686400
[ 6.916229] omap_vout omap_vout: : registered and initialized video device 1
[ 6.924224] Freeing init memory: 208K
[ 7.309997] UBIFS: mounted UBI device 0, volume 0, name "system"
[ 7.316314] UBIFS: file system size: 166465536 bytes (162564 KiB, 158 MiB, 1311 LEBs)
[ 7.324707] UBIFS: journal size: 9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
[ 7.332366] UBIFS: media format: w4/r0 (latest is w4/r0)
[ 7.338470] UBIFS: default compressor: lzo
[ 7.342773] UBIFS: reserved for root: 0 bytes (0 KiB)
[ 7.359924] UBIFS: default file-system created
[ 7.395843] UBIFS: mounted UBI device 0, volume 2, name "data"
[ 7.401977] UBIFS: file system size: 229318656 bytes (223944 KiB, 218 MiB, 1806 LEBs)
[ 7.410369] UBIFS: journal size: 11427840 bytes (11160 KiB, 10 MiB, 90 LEBs)
[ 7.418334] UBIFS: media format: w4/r0 (latest is w4/r0)
[ 7.424438] UBIFS: default compressor: lzo
[ 7.428741] UBIFS: reserved for root: 4952683 bytes (4836 KiB)
[ 7.456085] UBIFS: recovery needed
[ 7.495941] UBIFS: recovery completed
[ 7.499786] UBIFS: mounted UBI device 0, volume 1, name "cache"
[ 7.506011] UBIFS: file system size: 19935232 bytes (19468 KiB, 19 MiB, 157 LEBs)
[ 7.514038] UBIFS: journal size: 1015809 bytes (992 KiB, 0 MiB, 8 LEBs)
[ 7.521514] UBIFS: media format: w4/r0 (latest is w4/r0)
[ 7n527648] UBIFS: default compressor: lzo
[ 7.531921] UBIFS: reserved for root: 941589 bytes (919 KiB)
[ 11.666351] UBIFS: recovery needed
[ 11.699829] UBIFS: recovery completed
[ 11.703674] UBIFS: mounted UBI device 0, volume 4, name "ipsm"
[ 11.709808] UBIFS: file system size: 65773568 bytes (64232 KiB, 62 MiB, 518 LEBs)
[ 11.717834] UBIFS: journal size: 8888320 bytes (8680 KiB, 8 MiB, 70 LEBs)
[ 11.725494] UBIFS: media format: w4/r0 (latest is w4/r0)
[ 11.731628] UBIFS: default compressor: lzo
[ 11n735900] UBIFS: reserved for root: 0 bytes (0 KiB)
[ 11.762847] enabling adb
[ 11.813018] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
[ 11.831878] adb_open
sh: can't access tty; job control turned off
$ [ 12.015228] ..entering gps_serial_open
[ 12.019226] TTY Open: up semaphore for workqueue.
[ 12.040496] GPS DRIVER - enter in GPS POWER ON
[ 12n075958] CMD_SET_VCOM_BAUD ok
[ 12.123779] set_GPS_power ok
[ 12.147796] set_VCOM_enable ok
[ 12.599609] * WorkItem: handle_event - Event code: 1 (0x01) - Event type :"Com event"
[ 12.607940] GPS DRIVER - get_GPS_data() - ENTRY
[ 12.656188] get datalen = 164
[ 12.659301] GPS DRIVER: more data avail - going to loop on another CMD_SERIAL_DATA request
[ 12.667968] GPS driver - inserting data size 164
[ 12.672821] GPS DRIVER free space is 8192
[ 12n745635] MSP430_MCU_MUX spi1.0: DMA RX last word empty
[ 12.761718] get datalen = 162
[ 12.765014] GPS DRIVER: more data avail - going to loop on another CMD_SERIAL_DATA request
[ 12.773712] GPS driver - inserting data size 162
[ 12.778533] GPS DRIVER free space is 8028
[ 12.825378] get datalen = 83
[ 12.828399] GPS driver - inserting data size 83
[ 12.833160] GPS DRIVER free space is 7866
[ 12.837341] GPS DRIVER - gps_receive_data() - ENTRY
[ 12.842468] buffer pool have 7783 bytes data,tty free room is 4095
[ 12.848968] GPS DRIVER - gps_receive_data() - EXIT
[ 12.853973] GPS DRIVER - get_GPS_data() - EXIT
[ 12.884735] GPS_power_down
[ 12.902954] set_VCOM_enable ok
[ 12.928009] set_GPS_power ok
[ 12.949035] ..entering gps_serial_close
[ 12.953033] TTY Close:down semaphore for workqueue.
[ 28.071868] warning: `zygote' uses 32-bit capabilities (legacy support in use)
[ 34.451538] er.ServerThread (1185): /proc/1172/oom_adj is deprecated, please use /proc/1172/oom_score_adj instead.
[ 35.112792] request_suspend_state: wakeup (3->0) at 35468963625 (2012-04-12 10:59:56.732116700 UTC)
[ 35.156738] mma7660: mma7660_enable 1
[ 39.120788] ..entering gps_serial_open
[ 39.124725] TTY Open: up semaphore for workqueue.
[ 39.353881] [GPS]:GPS driver room need not to support it!!!
[ 39.416473] binder: release 1299:1299 transaction 952 out, still active
[ 39.703552] binder: 1172:1337 transaction failed 29189, size 14628-0
[ 39.710266] binder: send failed reply for transaction 952, target dead
[ 68.269317] PVR_K: User requested SGX debug info
[ 68.274169] PVR_K: SGX debug (1.7.17.4352)
[ 68.278503] PVR_K: Flip Command Complete Data 0 for display device 1:
[ 68.285278] PVR_K: SRC 0: (Not in use)
[ 68.289276] PVR_K: SRC 1: (Not in use)
[ 68.293304] PVR_K: SGX Host control:
[ 68.297058] PVR_K: (HC-0) 0x00000001 0x00000000 0x00000000 0x00000001
[ 68.303924] PVR_K: (HC-10) 0x00000000 0x00000000 0x0000000A 0x00030D40
[ 68.310852] PVR_K: (HC-20) 0x00000065 0x00000000 0x00000000 0x00000000
[ 68.317810] PVR_K: (HC-30) 0x00000001 0x00006800 0xEFD75844 0x00000000
[ 68.324737] PVR_K: (HC-40) 0x00000000 0x00000000 0x00000000 0x00000000
[ 68.331695] PVR_K: SGX TA/3D control:
[ 68.335510] PVR_K: (T3C-0) 0x0F003000 0x0F003120 0x0F002000 0x00000000
[ 68.342468] PVR_K: (T3C-10) 0x00000000 0x00000000 0x00000002 0x00000000
[ 68.349487] PVR_K: (T3C-20) 0x00000000 0x00000000 0x00000000 0x00000000
[ 68.356536] PVR_K: (T3C-30) 0x00000000 0x00000000 0x00000000 0x00000000
[ 68.363586] PVR_K: (T3C-40) 0x00000000 0x00000000 0x00000000 0x00000000
[ 68.370605] PVR_K: (T3C-50) 0x00000000 0x00000000 0x00000000 0x00000000
[ 68.377624] PVR_K: (T3C-60) 0x00000000 0x00000000 0x00000000 0x00000000
[ 68.384674] PVR_K: (T3C-70) 0x00000000 0x00000000 0x00000000 0x00000000
[ 68.391693] PVR_K: (T3C-80) 0x00000000 0x0F0E14F8 0x00000000 0x0F000000
[ 68.398742] PVR_K: (T3C-90) 0x8EB8D000 0x0F0CFE40 0x0F0E14F8 0x0F09DA20
[ 68.405761] PVR_K: (T3C-A0) 0x0F0BF4C0 0x0F00AF94 0x0F09D420 0x00000000
[ 68.412811] PVR_K: (T3C-B0) 0x0F09C180 0x00000003 0x00000000 0x00000000
[ 68.419830] PVR_K: (T3C-C0) 0x00000000 0x00000000 0x2DA20000 0x00000000
[ 68.426879] PVR_K: (T3C-D0) 0x00000000 0x00000000 0x00000000 0x00000000
[ 68.433898] PVR_K: (T3C-E0) 0x000000AF 0x000000B0 0x0F000000 0x8000B000
[ 68.440948] PVR_K: (T3C-F0) 0x8004B000 0x0F004000 0x0F00A420 0x0F00A740
[ 68.447967] PVR_K: (T3C-100) 0x0F09D600 0x0F09D600 0x00000000 0x0000049F
[ 68.455078] PVR_K: (T3C-110) 0x00000494 0x00000000 0x00000000 0x00000000
[ 68.462188] PVR_K: SGX Kernel CCB WO:0xA8 RO:0xA8
[ 73.558258] PVR_K: User requested SGX debug info
[ 73.563079] PVR_K: SGX debug (1.7.17.4352)
[ 73.567443] PVR_K: Flip Command Complete Data 0 for display device 1:
[ 73.574188] PVR_K: SRC 0: (Not in use)
[ 73.578216] PVR_K: SRC 1: (Not in use)
[ 73.582244] PVR_K: SGX Host control:
[ 73.585998] PVR_K: (HC-0) 0x00000001 0x00000000 0x00000000 0x00000001
[ 73.592834] PVR_K: (HC-10) 0x00000000 0x00000000 0x0000000A 0x00030D40
[ 73.599792] PVR_K: (HC-20) 0x00000065 0x00000000 0x00000000 0x00000000
[ 73.606750] PVR_K: (HC-30) 0x00000001 0x000075C5 0xEFD75844 0x00000000
[ 73.613677] PVR_K: (HC-40) 0x00000000 0x00000000 0x00000000 0x00000000
[ 73.620605] PVR_K: SGX TA/3D control:
[ 73.624450] PVR_K: (T3C-0) 0x0F003000 0x0F003120 0x0F002000 0x00000000
[ 73.631408] PVR_K: (T3C-10) 0x00000000 0x00000000 0x00000002 0x00000000
[ 73.638427] PVR_K: (T3C-20) 0x00000000 0x00000000 0x00000000 0x00000000
[ 73.645477] PVR_K: (T3C-30) 0x00000000 0x00000000 0x00000000 0x00000000
[ 73.652496] PVR_K: (T3C-40) 0x00000000 0x00000000 0x00000000 0x00000000
[ 73.659515] PVR_K: (T3C-50) 0x00000000 0x00000000 0x00000000 0x00000000
[ 73.666564] PVR_K: (T3C-60) 0x00000000 0x00000000 0x00000000 0x00000000
[ 73.673583] PVR_K: (T3C-70) 0x00000000 0x00000000 0x00000000 0x00000000
[ 73.680633] PVR_K: (T3C-80) 0x00000000 0x0F0E14F8 0x00000000 0x0F000000
[ 73.687652] PVR_K: (T3C-90) 0x8EB8D000 0x0F0CFE40 0x0F0E14F8 0x0F09DA20
[ 73.694702] PVR_K: (T3C-A0) 0x0F0BF4C0 0x0F00AF94 0x0F09D420 0x00000000
[ 73.701721] PVR_K: (T3C-B0) 0x0F09C180 0x00000003 0x00000000 0x00000000
[ 73.708770] PVR_K: (T3C-C0) 0x00000000 0x00000000 0x37320000 0x00000000
[ 73.715789] PVR_K: (T3C-D0) 0x00000000 0x00000000 0x00000000 0x00000000
[ 73.722839] PVR_K: (T3C-E0) 0x000000AF 0x000000B0 0x0F000000 0x8000B000
[ 73.729858] PVR_K: (T3C-F0) 0x8004B000 0x0F004000 0x0F00A420 0x0F00A740
[ 73.736877] PVR_K: (T3C-100) 0x0F09D600 0x0F09D600 0x00000000 0x0000049F
[ 73.743988] PVR_K: (T3C-110) 0x00000494 0x00000000 0x00000000 0x00000000
[ 73.751129] PVR_K: SGX Kernel CCB WO:0xAD RO:0xAD
[ 78.854064] PVR_K: User requested SGX debug info
[ 78.858978] PVR_K: SGX debug (1.7.17.4352)
[ 78.863281] PVR_K: Flip Command Complete Data 0 for display device 1:
[ 78.870025] PVR_K: SRC 0: (Not in use)
[ 78.874084] PVR_K: SRC 1: (Not in use)
[ 78.878082] PVR_K: SGX Host control:
[ 78.881866] PVR_K: (HC-0) 0x00000001 0x00000000 0x00000000 0x00000001
[ 78.888702] PVR_K: (HC-10) 0x00000000 0x00000000 0x0000000A 0x00030D40
[ 78.895660] PVR_K: (HC-20) 0x00000065 0x00000000 0x00000000 0x00000000
[ 78.902587] PVR_K: (HC-30) 0x00000001 0x00008390 0xEFD75844 0x00000000
[ 78.909515] PVR_K: (HC-40) 0x00000000 0x00000000 0x00000000 0x00000000
[ 78.916473] PVR_K: SGX TA/3D control:
[ 78.920318] PVR_K: (T3C-0) 0x0F003000 0x0F003120 0x0F002000 0x00000000
[ 78.927246] PVR_K: (T3C-10) 0x00000000 0x00000000 0x00000002 0x00000000
[ 78.934295] PVR_K: (T3C-20) 0x00000000 0x00000000 0x00000000 0x00000000
[ 78.941314] PVR_K: (T3C-30) 0x00000000 0x00000000 0x00000000 0x00000000
[ 78.948333] PVR_K: (T3C-40) 0x00000000 0x00000000 0x00000000 0x00000000
[ 78.955383] PVR_K: (T3C-50) 0x00000000 0x00000000 0x00000000 0x00000000
[ 78.962402] PVR_K: (T3C-60) 0x00000000 0x00000000 0x00000000 0x00000000
[ 78.969451] PVR_K: (T3C-70) 0x00000000 0x00000000 0x00000000 0x00000000
[ 78.976470] PVR_K: (T3C-80) 0x00000000 0x0F0E14F8 0x00000000 0x0F000000
[ 78.983520] PVR_K: (T3C-90) 0x8EB8D000 0x0F0CFE40 0x0F0E14F8 0x0F09DA20
[ 78.990539] PVR_K: (T3C-A0) 0x0F0BF4C0 0x0F00AF94 0x0F09D420 0x00000000
[ 78.997589] PVR_K: (T3C-B0) 0x0F09C180 0x00000003 0x00000000 0x00000000
[ 79.004608] PVR_K: (T3C-C0) 0x00000000 0x00000000 0x40C60000 0x00000000
[ 79.011657] PVR_K: (T3C-D0) 0x00000000 0x00000000 0x00000000 0x00000000
[ 79.018676] PVR_K: (T3C-E0) 0x000000AF 0x000000B0 0x0F000000 0x8000B000
[ 79.025695] PVR_K: (T3C-F0) 0x8004B000 0x0F004000 0x0F00A420 0x0F00A740
[ 79.032745] PVR_K: (T3C-100) 0x0F09D600 0x0F09D600 0x00000000 0x0000049F
[ 79.039855] PVR_K: (T3C-110) 0x00000494 0x00000000 0x00000000 0x00000000
[ 79.046997] PVR_K: SGX Kernel CCB WO:0xB2 RO:0xB2
[ 79.052001] PVR_K: User requested SGX debug info
[ 79.056823] PVR_K: SGX debug (1.7.17.4352)
[ 79.061157] PVR_K: Flip Command Complete Data 0 for display device 1:
[ 79.067901] PVR_K: SRC 0: (Not in use)
[ 79.071929] PVR_K: SRC 1: (Not in use)
[ 79.075958] PVR_K: SGX Host control:
[ 79.079681] PVR_K: (HC-0) 0x00000001 0x00000000 0x00000000 0x00000001
[ 79.086547] PVR_K: (HC-10) 0x00000000 0x00000000 0x0000000A 0x00030D40
[ 79.093505] PVR_K: (HC-20) 0x00000065 0x00000000 0x00000000 0x00000000
[ 79.100433] PVR_K: (HC-30) 0x00000001 0x00008413 0xEFD75844 0x00000000
[ 79.107391] PVR_K: (HC-40) 0x00000000 0x00000000 0x00000000 0x00000000
[ 79.114318] PVR_K: SGX TA/3D control:
[ 79.118164] PVR_K: (T3C-0) 0x0F003000 0x0F003120 0x0F002000 0x00000000
[ 79.125091] PVR_K: (T3C-10) 0x00000000 0x00000000 0x00000002 0x00000000
[ 79.132141] PVR_K: (T3C-20) 0x00000000 0x00000000 0x00000000 0x00000000
[ 79.139160] PVR_K: (T3C-30) 0x00000000 0x00000000 0x00000000 0x00000000
[ 79.146209] PVR_K: (T3C-40) 0x00000000 0x00000000 0x00000000 0x00000000
[ 79.153259] PVR_K: (T3C-50) 0x00000000 0x00000000 0x00000000 0x00000000
[ 79.160278] PVR_K: (T3C-60) 0x00000000 0x00000000 0x00000000 0x00000000
[ 79.167297] PVR_K: (T3C-70) 0x00000000 0x00000000 0x00000000 0x00000000
[ 79.174346] PVR_K: (T3C-80) 0x00000000 0x0F0E14F8 0x00000000 0x0F000000
[ 79.181365] PVR_K: (T3C-90) 0x8EB8D000 0x0F0CFE40 0x0F0E14F8 0x0F09DA20
[ 79.188415] PVR_K: (T3C-A0) 0x0F0BF4C0 0x0F00AF94 0x0F09D420 0x00000000
[ 79.195434] PVR_K: (T3C-B0) 0x0F09C180 0x00000003 0x00000000 0x00000000
[ 79.202484] PVR_K: (T3C-C0) 0x00000000 0x00000000 0x41220000 0x00000000
[ 79.209503] PVR_K: (T3C-D0) 0x00000000 0x00000000 0x00000000 0x00000000
[ 79.216552] PVR_K: (T3C-E0) 0x000000AF 0x000000B0 0x0F000000 0x8000B000
[ 79.223571] PVR_K: (T3C-F0) 0x8004B000 0x0F004000 0x0F00A420 0x0F00A740
[ 79.230621] PVR_K: (T3C-100) 0x0F09D600 0x0F09D600 0x00000000 0x0000049F
[ 79.237762] PVR_K: (T3C-110) 0x00000494 0x00000000 0x00000000 0x00000000
[ 79.244842] PVR_K: SGX Kernel CCB WO:0xB2 RO:0xB2
[ 84.503448] PVR_K: User requested SGX debug info
[ 84.508300] PVR_K: SGX debug (1.7.17.4352)
[ 84.512603] PVR_K: Flip Command Complete Data 0 for display device 1:
[ 84.519378] PVR_K: SRC 0: (Not in use)
[ 84.523406] PVR_K: SRC 1: (Not in use)
[ 84.527435] PVR_K: SGX Host control:
[ 84.531188] PVR_K: (HC-0) 0x00000001 0x00000000 0x00000000 0x00000001
[ 84.538024] PVR_K: (HC-10) 0x00000000 0x00000000 0x0000000A 0x00030D40
[ 84.544982] PVR_K: (HC-20) 0x00000065 0x00000000 0x00000000 0x00000000
[ 84.551940] PVR_K: (HC-30) 0x00000001 0x00009246 0xEFD75844 0x00000000
[ 84.558868] PVR_K: (HC-40) 0x00000000 0x00000000 0x00000000 0x00000000
[ 84.565795] PVR_K: SGX TA/3D control:
[ 84.569641] PVR_K: (T3C-0) 0x0F003000 0x0F003120 0x0F002000 0x00000000
[ 84.576599] PVR_K: (T3C-10) 0x00000000 0x00000000 0x00000002 0x00000000
[ 84.583618] PVR_K: (T3C-20) 0x00000000 0x00000000 0x00000000 0x00000000
[ 84.590667] PVR_K: (T3C-30) 0x00000000 0x00000000 0x00000000 0x00000000
[ 84.597686] PVR_K: (T3C-40) 0x00000000 0x00000000 0x00000000 0x00000000
[ 84.604705] PVR_K: (T3C-50) 0x00000000 0x00000000 0x00000000 0x00000000
[ 84.611724] PVR_K: (T3C-60) 0x00000000 0x00000000 0x00000000 0x00000000
[ 84.618774] PVR_K: (T3C-70) 0x00000000 0x00000000 0x00000000 0x00000000
[ 84.625793] PVR_K: (T3C-80) 0x00000000 0x0F0E14F8 0x00000000 0x0F000000
[ 84.632843] PVR_K: (T3C-90) 0x8EB8D000 0x0F0CFE40 0x0F0E14F8 0x0F09DA20
[ 84.639892] PVR_K: (T3C-A0) 0x0F0BF4C0 0x0F00AF94 0x0F09D420 0x00000000
[ 84.646911] PVR_K: (T3C-B0) 0x0F09C180 0x00000003 0x00000000 0x00000000
[ 84.653930] PVR_K: (T3C-C0) 0x00000000 0x00000000 0x4AFD0000 0x00000000
[ 84.660980] PVR_K: (T3C-D0) 0x00000000 0x00000000 0x00000000 0x00000000
[ 84.667999] PVR_K: (T3C-E0) 0x000000AF 0x000000B0 0x0F000000 0x8000B000
[ 84.675018] PVR_K: (T3C-F0) 0x8004B000 0x0F004000 0x0F00A420 0x0F00A740
[ 84.682067] PVR_K: (T3C-100) 0x0F09D600 0x0F09D600 0x00000000 0x0000049F
[ 84.689178] PVR_K: (T3C-110) 0x00000494 0x00000000 0x00000000 0x00000000
[ 84.696319] PVR_K: SGX Kernel CCB WO:0xB2 RO:0xB2
[ 103.320953] request_suspend_state: sleep (0->3) at 103677124051 (2012-04-12 11:01:04.940277126 UTC)
[ 103.331665] ..entering gps_serial_early_suspend
[ 103.336395] tsc2007_early_suspend
[ 103.341033] mma7660: mma7660_enable 0
[ 103.468109] d7800_kp_early_suspend
[ 104.464447] stop_drawing_early_suspend: timeout waiting for userspace to stop drawing
k&6鎣Fv6vV?硴洆砙k?&+c{ {s颢??&s;+c2+{s&?c{"枂6薻r鰶{兯3搟k珱+?j
[ 213.761657] omaplfb: no symbol version for __tracepoint_module_get
[ 213.768127] omaplfb: Unknown symbol __tracepoint_module_get (err -22)
? permission denied
$ [0G$ ?[0K[0G[3C
? permission denied
$ logcat
--------- beginning of /dev/log/system
I/Vold ( 1070): Vold 2.1 (the revenge) firing up
D/Vold ( 1070): Volume sdcard_ext state changing -1 (Initializing) -> 0 (No-Media)
D/Vold ( 1070): Volume sdcard_ext state changing 0 (No-Media) -> 1 (Idle-Unmounted)
I/SystemServer( 1172): Entered the Android system server!
I/SystemServer( 1172): Entropy Service
W/EntropyService( 1172): unable to load initial entropy (first boot?)
W/EntropyService( 1172): java.io.FileNotFoundException: /data/system/entropy.dat (No such file or directory)
W/EntropyService( 1172): at org.apache.harmony.luni.platform.OSFileSystem.open(Native Method)
W/EntropyService( 1172): at dalvik.system.BlockGuard$WrappedFileSystem.open(BlockGuard.java:232)
W/EntropyService( 1172): at java.io.FileInputStream.<init>(FileInputStream.java:80)
W/EntropyService( 1172): at java.io.FileInputStream.<init>(FileInputStream.java:132)
W/EntropyService( 1172): at com.android.server.RandomBlock.fromFile(RandomBlock.java:45)
W/EntropyService( 1172): at com.android.server.EntropyService.loadInitialEntropy(EntropyService.java:99)
W/EntropyService( 1172): at com.android.server.EntropyService.<init>(EntropyService.java:86)
W/EntropyService( 1172): at com.android.server.EntropyService.<init>(EntropyService.java:76)
W/EntropyService( 1172): at com.android.server.ServerThread.run(SystemServer.java:149)
I/SystemServer( 1172): Power Manager
I/SystemServer( 1172): Activity Manager
I/ActivityManager( 1172): Memory class: 48
I/SystemServer( 1172): Telephony Registry
I/SystemServer( 1172): Package Manager
I/Installer( 1172): connecting...
W/PackageManager( 1172): Got execption parsing permissions.
W/PackageManager( 1172): org.xmlpull.v1.XmlPullParserException: Error parsing document. (position:line -1, column -1) caused by: org.apache.harmony.xml.ExpatParser$ParseException: At line 67, column 39: not well-formed (invalid token)
W/PackageManager( 1172): at org.apache.harmony.xml.ExpatPullParser$CharDocument.flush(ExpatPullParser.java:930)
W/PackageManager( 1172): at org.apache.harmony.xml.ExpatPullParser$Document.pump(ExpatPullParser.java:769)
W/PackageManager( 1172): at org.apache.harmony.xml.ExpatPullParser$Document.dequeue(ExpatPullParser.java:813)
W/PackageManager( 1172): at org.apache.harmony.xml.ExpatPullParser.next(ExpatPullParser.java:302)
W/PackageManager( 1172): at com.android.internal.util.XmlUtils.beginDocument(XmlUtils.java:775)
W/PackageManager( 1172): at com.android.server.PackageManagerService.readPermissionsFromXml(PackageManagerService.java:1128)
W/PackageManager( 1172): at com.android.server.PackageManagerService.readPermissions(PackageManagerService.java:1106)
W/PackageManager( 1172): at com.android.server.PackageManagerService.<init>(PackageManagerService.java:802)
W/PackageManager( 1172): at com.android.server.PackageManagerService.main(PackageManagerService.java:694)
W/PackageManager( 1172): at com.android.server.ServerThread.run(SystemServer.java:164)
I/PackageManager( 1172): No settings file; creating initial state
W/PackageManager( 1172): Running ENG build: no pre-dexopt!
I/PackageManager( 1172): Time to scan packages: 5.622 seconds
I/PackageManager( 1172): Platform changed from 0 to 10; regranting permissions for internal storage
W/PackageManager( 1172): Unknown permission android.permission..MASTER_CLEAR in package com.honeywell.resetservice
W/PackageManager( 1172): Unknown permission com.google.android.gm.permission.WRITE_GMAIL in package com.android.settings
W/PackageManager( 1172): Unknown permission com.google.android.gm.permission.READ_GMAIL in package com.android.settings
W/PackageManager( 1172): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.settings
W/PackageManager( 1172): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.contacts
W/PackageManager( 1172): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cp in package com.android.providers.contacts
W/PackageManager( 1172): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.contacts
W/PackageManager( 1172): Unknown permission android.permission.ADD_SYSTEM_SERVICE in package com.android.phone
W/PackageManager( 1172): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.calendar
W/PackageManager( 1172): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cl in package com.android.providers.calendar
W/PackageManager( 1172): Unknown permission com.google.android.googleapps.permission.ACCESS_GOOGLE_PASSWORD in package com.android.development
W/PackageManager( 1172): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.development
W/PackageManager( 1172): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.ALL_SERVICES in package com.android.development
W/PackageManager( 1172): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.YouTubeUser in package com.android.development
W/PackageManager( 1172): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.calendar
W/PackageManager( 1172): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.browser (protectionLevel=2 flags=0x9be45)
W/PackageManager( 1172): Unknown permission android.permission.READ_OWNER_DATA in package com.android.email
W/PackageManager( 1172): Not granting permission android.permission.DEVICE_POWER to package com.android.deskclock (protectionLevel=2 flags=0x8be45)
I/SystemServer( 1172): Account Manager
I/SystemServer( 1172): Content Manager
I/SystemServer( 1172): System Content Providers
I/SystemServer( 1172): Battery Service
I/SystemServer( 1172): Lights Service
I/SystemServer( 1172): D7800 Led Service
I/SystemServer( 1172): Vibrator Service
V/PowerManagerService( 1172): updateSettingsValues(): mShortKeylightDelay now 6000
D/PowerManagerService( 1172): updateSettingsValues(): mKeepAwakeOnMotion now 0
D/PowerManagerService( 1172): updateSettingsValues(): mWakeUpOnMotion now 0
I/SystemServer( 1172): Alarm Manager
I/SystemServer( 1172): Init Watchdog
I/SystemServer( 1172): Window Manager
I/InputManager( 1172): Initializing input manager
I/InputManager( 1172): Starting input manager
I/SystemServer( 1172): Bluetooth Service
I/InputManager-Callbacks( 1172): No input device calibration properties found for device twl4030_pwrbutton.
I/InputManager-Callbacks( 1172): No input device calibration properties found for device d7800-numeric-keypad.
I/InputManager-Callbacks( 1172): No input device calibration properties found for device TSC2007 Touchscreen.
--------- beginning of /dev/log/main
I/BluetoothProfileState( 1172): Message:Entering Stable State
I/SystemServer( 1172): Device Policy
W/ResourceType( 1172): Failure getting entry for 0x7f060000 (t=5 e=0) in package 0 (error -75)
I/SystemServer( 1172): Status Bar
I/SystemServer( 1172): Clipboard Service
I/SystemServer( 1172): Input Method Service
D/D7800SensorHelper( 1172): notifyNativeWakeSettings called.
E/D7800SensorHelper( 1172): notifyNativeWakeSettings got IO exception java.io.FileNotFoundException: /data/system/accelerometer/wakesettings (No such file or directory)
I/InputManagerService( 1172): Enabled input methods: com.android.inputmethod.pinyin/.PinyinIME:jp.co.omronsoft.openwnn/.OpenWnnJAJP:com.android.inputmethod.latin/.LatinIME
I/InputManagerService( 1172): Enabled input methods or default IME has not been set, enabling all
I/InputManagerService( 1172): Adding: com.android.inputmethod.pinyin/.PinyinIME
I/InputManagerService( 1172): Adding: jp.co.omronsoft.openwnn/.OpenWnnJAJP
I/InputManagerService( 1172): Adding: com.android.inputmethod.latin/.LatinIME
I/InputManagerService( 1172): Selected default: com.android.inputmethod.latin/.LatinIME
I/SystemServer( 1172): NetStat Service
I/SystemServer( 1172): NetworkManagement Service
I/SystemServer( 1172): Connectivity Service
I/WifiService( 1172): WifiService starting up with Wi-Fi disabled
D/NetworkManagmentService( 1172): Registering observer
I/SystemServer( 1172): Throttle Service
I/SystemServer( 1172): Accessibility Manager
I/SystemServer( 1172): Mount Service
I/SystemServer( 1172): Notification Manager
I/SystemServer( 1172): Device Storage Monitor
I/SystemServer( 1172): Location Manager
I/SystemServer( 1172): Search Service
I/SystemServer( 1172): DropBox Service
I/SystemServer( 1172): Wallpaper Service
W/WallpaperService( 1172): failed parsing /data/system/wallpaper_info.xml java.io.FileNotFoundException: /data/system/wallpaper_info.xml (No such file or directory)
I/SystemServer( 1172): Audio Service
I/PackageManager( 1172): Updating external media status from unmounted to unmounted
D/VoldCmdListener( 1070): volume list
D/VoldCmdListener( 1070): share status ums
W/AudioPolicyManagerALSA( 1076): setPhoneState() setting same state 0
W/UsbDeviceSettingsManager( 1172): settings file not found
I/SystemServer( 1172): Headset Observer
W/HeadsetObserver( 1172): This kernel does not have wired headset support
I/SystemServer( 1172): HDMI Observer
W/HDMIObserver( 1172): This kernel does not have hdmi support
I/SystemServer( 1172): Dock Observer
W/DockObserver( 1172): This kernel does not have dock station support
I/SystemServer( 1172): USB Service
I/SystemServer( 1172): UI Mode Manager Service
I/SystemServer( 1172): Backup Service
V/BackupManagerService( 1172): No ancestral data
I/BackupManagerService( 1172): Backup enabled => false
I/SystemServer( 1172): AppWidget Service
I/SystemServer( 1172): Recognition Service
I/SystemServer( 1172): DiskStats Service
I/WindowManager( 1172): SAFE MODE not enabled
D/dalvikvm( 1172): JIT started for system_server
D/PowerManagerService( 1172): enableMotionSensor false
I/power ( 1172): *** set_screen_state 1
D/PowerManagerService( 1172): system ready!
I/ActivityManager( 1172): Sending system update to: ComponentInfo{com.android.providers.contacts/com.android.providers.contacts.ContactsUpgradeReceiver}
D/d7800Sensors( 1172): sensors_poll_context_t::activate, handle = 0, enabled = 1, index = 0
D/Sensors ( 1172): AccelSensor - enable, flags = 1, mEnabled = 0
D/Sensors ( 1172): AccelSensor - enable, Wake on Motion Flag = 0
D/Sensors ( 1172): AccelSensor - setFsVal pathid = 2; val = 1
D/d7800Sensors( 1172): sensors_poll_context_t::activate sending WAKE_MESSAGE.
I/Zygote ( 1172): Process: zygote socket opened
I/ActivityManager( 1172): Sending system update to: ComponentInfo{com.android.providers.calendar/com.android.providers.calendar.CalendarUpgradeReceiver}
D/Sensors ( 1172): AccelSensor - setDelay, ns = 200000000
D/Sensors ( 1172): AccelSensor - setDelay, delay_time is 200
D/Sensors ( 1172): AccelSensor - setFsVal pathid = 1; val = 200
D/Sensors ( 1172): AccelSensor - setFsVal wrote 200
D/Sensors ( 1172): to path /sys/devices/platform/mma7660/poll_path/poll
I/ActivityManager( 1172): Start proc android.process.acore for broadcast com.android.providers.contacts/.ContactsUpgradeReceiver: pid=1253 uid=10004 gids={3003, 1015}
I/ActivityManager( 1172): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000000 cmp=com.android.provision/.DefaultActivity } from pid 0
E/lights ( 1172): write_int failed to open /sys/class/leds/battery-led/brightness
I/SystemServer( 1172): Enabled StrictMode for system server main thread.
I/ActivityManager( 1172): Launching preboot mode app: ProcessRecord{4093ccc8 1253:android.process.acore/10004}
D/installd( 1078): DexInv: --- BEGIN '/system/app/ContactsProvider.apk' ---
D/dalvikvm( 1172): GC_CONCURRENT freed 197K, 50% free 3924K/7751K, external 716K/1038K, paused 3ms+15ms
D/dalvikvm( 1266): creating instr width table
D/dalvikvm( 1266): DexOpt: load 9ms, verify+opt 148ms
D/installd( 1078): DexInv: --- END '/system/app/ContactsProvider.apk' (success) ---
I/ContactsUpgradeReceiver( 1253): Creating or opening contacts database
I/ContactsDatabaseHelper( 1253): Bootstrapping database
D/dalvikvm( 1253): GC_CONCURRENT freed 404K, 51% free 2785K/5639K, external 716K/1038K, paused 2ms+2ms
I/ContactsProviderV1( 1253): Bootstrapping database legacy support
D/dalvikvm( 1253): GC_CONCURRENT freed 375K, 50% free 2852K/5703K, external 716K/1038K, paused 2ms+2ms
I/ActivityManager( 1172): Start proc com.android.providers.calendar for broadcast com.android.providers.calendar/.CalendarUpgradeReceiver: pid=1271 uid=10027 gids={3003}
D/installd( 1078): DexInv: --- BEGIN '/system/app/CalendarProvider.apk' ---
I/ActivityManager( 1172): Launching preboot mode app: ProcessRecord{407e1e60 1271:com.android.providers.calendar/10027}
D/dalvikvm( 1280): creating instr width table
D/dalvikvm( 1280): DexOpt: load 43ms, verify+opt 300ms
D/installd( 1078): DexInv: --- END '/system/app/CalendarProvider.apk' (success) ---
I/CalendarUpgradeReceiver( 1271): Creating or opening calendar database
D/dalvikvm( 1271): GC_CONCURRENT freed 415K, 51% free 2780K/5639K, external 716K/1038K, paused 3ms+12ms
I/CalendarDatabaseHelper( 1271): Bootstrapping database
I/Process ( 1172): Sending signal. PID: 1253 SIG: 9
I/Process ( 1172): Sending signal. PID: 1271 SIG: 9
I/ActivityManager( 1172): Writing new set of last done pre-boot receivers...
I/ActivityManager( 1172): Removing system update proc: ProcessRecord{4093ccc8 1253:android.process.acore/10004}
I/ActivityManager( 1172): Removing system update proc: ProcessRecord{407e1e60 1271:com.android.providers.calendar/10027}
I/ActivityManager( 1172): System now ready
I/SystemServer( 1172): Making services ready
I/StatusBarManagerService( 1172): Starting service: ComponentInfo{com.android.systemui/com.android.systemui.statusbar.StatusBarService}
I/ActivityManager( 1172): Start proc com.android.systemui for service com.android.systemui/.statusbar.StatusBarService: pid=1282 uid=1000 gids={3002, 3001, 3003}
I/ActivityManager( 1172): Config changed: { scale=1.0 imsi=0/0 loc=en_US touch=0 keys=0/0/0 nav=0/0 orien=0 layout=0 uiMode=17 seq=2}
W/RecognitionManagerService( 1172): no available voice recognition services found
I/UsbService( 1172): Device not provisioned, skipping USB broadcast
I/ActivityManager( 1172): Start proc com.android.inputmethod.latin for service com.android.inputmethod.latin/.LatinIME: pid=1286 uid=10028 gids={}
E/ThrottleService( 1172): Could not open GPS configuration file /etc/gps.conf
I/ActivityManager( 1172): Start proc com.android.phone for added application com.android.phone: pid=1291 uid=1001 gids={3002, 3001, 3003, 1015}
E/ThrottleService( 1172): Error reading data file
I/ActivityManager( 1172): Start proc com.android.systemui for added application com.android.systemui: pid=1295 uid=1000 gids={3002, 3001, 3003}
I/ActivityManager( 1172): Start proc com.android.provision for activity com.android.provision/.DefaultActivity: pid=1299 uid=10015 gids={}
D/dalvikvm( 1172): GC_EXTERNAL_ALLOC freed 277K, 49% free 4028K/7751K, external 716K/1038K, paused 41ms
D/D7800SensorHelper( 1172): updateWakeData() wrote 0:0 to path /data/system/accelerometer/wakesettings
D/D7800SensorHelper( 1172): updateWakeData() wrote 1 to path /data/system/accelerometer/wakeupdate
I/Process ( 1172): Sending signal. PID: 1282 SIG: 9
D/installd( 1078): DexInv: --- BEGIN '/system/app/Provision.apk' ---
W/ActivityManager( 1172): No pending application record for pid 1282 (IApplicationThread android.app.ApplicationThreadProxy@409820e0); dropping process
D/dalvikvm( 1334): creating instr width table
I//system/bin/tc( 1071): Cannot find device "rmnet0"
I/logwrapper( 1071): /system/bin/tc terminated by exit(1)
D/dalvikvm( 1334): DexOpt: load 4ms, verify+opt 2ms
I//system/bin/tc( 1071): Cannot find device "ifb0"
D/installd( 1078): DexInv: --- END '/system/app/Provision.apk' (success) ---
I/ActivityManager( 1172): Config changed: { scale=1.0 imsi=0/0 loc=en_US touch=3 keys=2/1/2 nav=1/1 orien=1 layout=268435475 uiMode=17 seq=3}
D/Sensors ( 1172): AccelSettings::parseSettingsData parsing string '0:0'.
D/Sensors ( 1172): AccelSettings::parseSettingsData char at index 0 is '0'
D/Sensors ( 1172): AccelSettings::parseSettingsData char at index 1 is ':'
D/Sensors ( 1172): AccelSettings::parseSettingsData setting 0 value is 0.
D/Sensors ( 1172): AccelSettings::parseSettingsData char at index 2 is '0'
D/Sensors ( 1172): AccelSettings::parseSettingsData char at index 3 is '
D/Sensors ( 1172): AccelSettings::parseSettingsData setting 1 value is 0.
D/installd( 1078): DexInv: --- BEGIN '/system/app/LatinIME.apk' ---
D/dalvikvm( 1346): creating instr width table
D/dalvikvm( 1346): DexOpt: load 18ms, verify+opt 152ms
D/installd( 1078): DexInv: --- END '/system/app/LatinIME.apk' (success) ---
D/dalvikvm( 1172): GREF has increased to 201
D/installd( 1078): DexInv: --- BEGIN '/system/app/SystemUI.apk' ---
D/dalvikvm( 1349): creating instr width table
D/dalvikvm( 1286): GC_CONCURRENT freed 410K, 51% free 2818K/5639K, external 716K/1038K, paused 2ms+12ms
D/dalvikvm( 1349): DexOpt: load 66ms, verify+opt 71ms
D/installd( 1078): DexInv: --- END '/system/app/SystemUI.apk' (success) ---
D/installd( 1078): DexInv: --- BEGIN '/system/app/TelephonyProvider.apk' ---
D/dalvikvm( 1350): creating instr width table
D/dalvikvm( 1295): GC_CONCURRENT freed 377K, 51% free 2805K/5639K, external 885K/1038K, paused 2ms+12ms
D/dalvikvm( 1350): DexOpt: load 3ms, verify+opt 153ms
D/installd( 1078): DexInv: --- END '/system/app/TelephonyProvider.apk' (success) ---
D/installd( 1078): DexInv: --- BEGIN '/system/app/Phone.apk' ---
D/dalvikvm( 1353): creating instr width table
D/dalvikvm( 1353): DexOpt: load 44ms, verify+opt 313ms
D/installd( 1078): DexInv: --- END '/system/app/Phone.apk' (success) ---
I/StatusBarManagerService( 1172): registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@40836c48
W/GpsLocationProvider( 1172): Could not open GPS configuration file /etc/gps.conf
D/StorageNotification( 1295): Startup with UMS connection false (media state unmounted)
W/ActivityManager( 1172): Unable to start service Intent { act=@0 }: not found
W/BackupManagerService( 1172): dataChanged but no participant pkg='com.android.providers.settings' uid=10015
D/dalvikvm( 1299): GC_CONCURRENT freed 332K, 51% free 2769K/5575K, external 716K/1038K, paused 3ms+12ms
D/dalvikvm( 1291): GC_CONCURRENT freed 405K, 50% free 2823K/5639K, external 716K/1038K, paused 2ms+21ms
D/dalvikvm( 1172): GC_CONCURRENT freed 347K, 48% free 4088K/7751K, external 1316K/1828K, paused 5ms+4ms
I/StorageNotification( 1295): UMS connection changed to false (media state unmounted)
I/ActivityThread( 1291): Pub mms: com.android.providers.telephony.MmsProvider
I/ActivityManager( 1172): Start proc com.android.settings for broadcast com.android.settings/.widget.SettingsAppWidgetProvider: pid=1374 uid=1000 gids={3002, 3001, 3003}
I/ActivityManager( 1172): Start proc android.process.acore for content provider com.android.providers.userdictionary/.UserDictionaryProvider: pid=1375 uid=10004 gids={3003, 1015}
I/ActivityManager( 1172): Force stopping package com.android.provision uid=10015
I/Process ( 1172): Sending signal. PID: 1299 SIG: 9
D/dalvikvm( 1172): GC_EXPLICIT freed 444K, 48% free 4093K/7751K, external 1316K/1828K, paused 112ms
I/ActivityThread( 1291): Pub sms: com.android.providers.telephony.SmsProvider
I/ActivityThread( 1291): Pub telephony: com.android.providers.telephony.TelephonyProvider
I/ActivityManager( 1172): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000000 cmp=com.android.launcher/com.android.launcher2.Launcher } from pid 0
I/ActivityThread( 1291): Pub icc: com.android.phone.IccProvider
I/ActivityThread( 1291): Pub mms-sms: com.android.providers.telephony.MmsSmsProvider
D/dalvikvm( 1075): GC_EXPLICIT freed 10K, 50% free 2721K/5379K, external 716K/1038K, paused 178ms
D/dalvikvm( 1075): GC_EXPLICIT freed <1K, 50% free 2721K/5379K, external 716K/1038K, paused 39ms
D/dalvikvm( 1075): GC_EXPLICIT freed <1K, 50% free 2721K/5379K, external 716K/1038K, paused 25ms
I/ActivityManager( 1172): Start proc com.android.launcher for activity com.android.launcher/com.android.launcher2.Launcher: pid=1392 uid=10011 gids={}
D/installd( 1078): DexInv: --- BEGIN '/system/app/Settings.apk' ---
D/dalvikvm( 1286): GC_EXTERNAL_ALLOC freed 55K, 49% free 2897K/5639K, external 1020K/1038K, paused 87ms
D/dalvikvm( 1393): creating instr width table
D/dalvikvm( 1393): DexOpt: load 75ms, verify+opt 389ms
D/installd( 1078): DexInv: --- END '/system/app/Settings.apk' (success) ---
D/installd( 1078): DexInv: --- BEGIN '/system/app/ApplicationsProvider.apk' ---
D/dalvikvm( 1402): creating instr width table
D/dalvikvm( 1402): DexOpt: load 5ms, verify+opt 77ms
D/dalvikvm( 1374): GC_CONCURRENT freed 408K, 50% free 2819K/5639K, external 716K/1038K, paused 2ms+10ms
D/installd( 1078): DexInv: --- END '/system/app/ApplicationsProvider.apk' (success) ---
D/installd( 1078): DexInv: --- BEGIN '/system/app/UserDictionaryProvider.apk' ---
D/dalvikvm( 1403): creating instr width table
D/dalvikvm( 1403): DexOpt: load 2ms, verify+opt 13ms
D/installd( 1078): DexInv: --- END '/system/app/UserDictionaryProvider.apk' (success) ---
D/installd( 1078): DexInv: --- BEGIN '/system/app/Launcher2.apk' ---
I/ActivityThread( 1375): Pub com.android.social: com.android.providers.contacts.SocialProvider
I/ActivityThread( 1375): Pub applications: com.android.providers.applications.ApplicationsProvider
D/dalvikvm( 1404): creating instr width table
D/dalvikvm( 1375): GC_CONCURRENT freed 415K, 51% free 2803K/5639K, external 716K/1038K, paused 2ms+12ms
D/dalvikvm( 1404): DexOpt: load 42ms, verify+opt 177ms
D/installd( 1078): DexInv: --- END '/system/app/Launcher2.apk' (success) ---
I/ActivityThread( 1375): Pub contacts;com.android.contacts: com.android.providers.contacts.ContactsProvider2
I/ActivityManager( 1172): Start proc com.android.voicedialer for broadcast com.android.voicedialer/.VoiceDialerReceiver: pid=1410 uid=10010 gids={3002}
D/CallManager( 1291): registerPhone(GSM Handler{407b0ea8})
I/ActivityThread( 1392): Pub com.android.launcher2.settings: com.android.launcher2.LauncherProvider
D/installd( 1078): DexInv: --- BEGIN '/system/app/VoiceDialer.apk' ---
D/dalvikvm( 1422): creating instr width table
D/dalvikvm( 1422): DexOpt: load 12ms, verify+opt 99ms
D/installd( 1078): DexInv: --- END '/system/app/VoiceDialer.apk' (success) ---
W/AudioPolicyManagerALSA( 1076): AudioPolicyManagerALSA::getStrategyForStream() Stub Called...
W/AudioPolicyManagerALSA( 1076): redirecting AudioPolicyManagerALSA::getStrategy()
W/ActivityManager( 1172): Unable to start service Intent { act=com.android.ussd.IExtendedNetworkService }: not found
V/ContactsProvider( 1375): Importing legacy contacts
I/ActivityThread( 1375): Pub call_log: com.android.providers.contacts.CallLogProvider
I/ActivityThread( 1375): Pub user_dictionary: com.android.providers.userdictionary.UserDictionaryProvider
I/ContactsDatabaseHelper( 1375): Switching to locale en_US
D/VoiceDialerReceiver( 1410): onReceive Intent { act=android.intent.action.PACKAGE_CHANGED dat=package:com.android.provision flg=0x10000000 cmp=com.android.voicedialer/.VoiceDialerReceiver (has extras) }
V/RecognizerEngine( 1410): deleteCachedGrammarFiles /data/data/com.android.voicedialer/files/openentries.txt
I/TelephonyRegistry( 1172): notifyServiceState: 1 home null null null Unknown CSS not supported -1 -1RoamInd: -1DefRoamInd: -1EmergOnly: false
I/TelephonyRegistry( 1172): notifyDataConnection: state=0 isDataConnectivityPossible=false reason=radioTurnedOff interfaceName=null networkType=0
I/TelephonyRegistry( 1172): notifyDataConnection: state=0 isDataConnectivityPossible=false reason=gprsDetached interfaceName=null networkType=0
D/BT HSHFP( 1291): Starting BluetoothHeadsetService
D/dalvikvm( 1392): GC_CONCURRENT freed 507K, 51% free 2858K/5831K, external 1032K/1038K, paused 2ms+2ms
D/dalvikvm( 1172): GC_CONCURRENT freed 547K, 47% free 4136K/7751K, external 1316K/1828K, paused 3ms+16ms
D/dalvikvm( 1172): GC_EXTERNAL_ALLOC freed 32K, 48% free 4103K/7751K, external 1316K/1828K, paused 64ms
D/dalvikvm( 1392): GC_EXTERNAL_ALLOC freed 4K, 52% free 2854K/5831K, external 1032K/1038K, paused 86ms
D/dalvikvm( 1375): GC_CONCURRENT freed 302K, 48% free 3008K/5767K, external 716K/1038K, paused 2ms+3ms
D/dalvikvm( 1172): GC_EXTERNAL_ALLOC freed <1K, 48% free 4103K/7751K, external 2516K/3142K, paused 125ms
D/dalvikvm( 1172): GC_EXPLICIT freed <1K, 48% free 4103K/7751K, external 2516K/3716K, paused 110ms
I/ActivityManager( 1172): Displayed com.android.launcher/com.android.launcher2.Launcher: +3s587ms (total +7s971ms)
I/ContactsDatabaseHelper( 1375): Locale change completed in 1183ms
D/PowerManagerService( 1172): bootCompleted
I/SurfaceFlinger( 1172): Boot is finished (15043 ms)
D/VoldCmdListener( 1070): volume mount /mnt/sdcard
I/Vold ( 1070): /dev/block/vold/7:0 being considered for volume sdcard_ext
D/Vold ( 1070): Volume sdcard_ext state changing 1 (Idle-Unmounted) -> 3 (Checking)
I/StorageNotification( 1295): Media {/mnt/sdcard} state changed from {unmounted} -> {checking}
W/logwrapper( 1443): Unable to background process (No such file or directory)
I/SearchManagerService( 1172): Building list of searchable activities
I//system/bin/fsck_msdos( 1070): ** /dev/block/vold/7:0
D/OtaStartupReceiver( 1291): Not a CDMA phone, no need to process OTA
I/LegacyContactImporter( 1375): Legacy contacts database does not exist at /data/data/com.android.providers.contacts/databases/contacts.db
I/ActivityManager( 1172): Start proc com.android.deskclock for broadcast com.android.deskclock/.AlarmInitReceiver: pid=1447 uid=10001 gids={}
I//system/bin/fsck_msdos( 1070): ** Phase 1 - Read and Compare FATs
I//system/bin/fsck_msdos( 1070): Attempting to allocate 14 KB for FAT
I/RecoverySystem( 1172): Deleted: /cache/recovery/log
I//system/bin/fsck_msdos( 1070): ** Phase 2 - Check Cluster Chains
I//system/bin/fsck_msdos( 1070): ** Phase 3 - Checking Directories
I//system/bin/fsck_msdos( 1070): ** Phase 4 - Checking for Lost Files
I//system/bin/fsck_msdos( 1070): 19 files, 57136 free (7142 clusters)
V/ContactsProvider( 1375): Completed import of legacy contacts
I/Vold ( 1070): Filesystem check completed OK
I/ActivityManager( 1172): Start proc android.process.media for content provider com.android.providers.downloads/.DownloadProvider: pid=1452 uid=10000 gids={1015, 2001, 3003}
D/dalvikvm( 1172): GREF has increased to 301
D/installd( 1078): DexInv: --- BEGIN '/system/app/DeskClock.apk' ---
I/Vold ( 1070): Device /dev/block/vold/7:0, target /mnt/sdcard mounted @ /mnt/secure/staging
D/Vold ( 1070): Volume sdcard_ext state changing 3 (Checking) -> 4 (Mounted)
I/PackageManager( 1172): Updating external media status from unmounted to mounted
D/dalvikvm( 1465): creating instr width table
D/dalvikvm( 1465): DexOpt: load 23ms, verify+opt 83ms
D/installd( 1078): DexInv: --- END '/system/app/DeskClock.apk' (success) ---
D/installd( 1078): DexInv: --- BEGIN '/system/app/MediaProvider.apk' ---
I/PackageManager( 1172): No secure containers on sdcard
D/VoldCmdListener( 1070): asec list
I/PackageManager( 1172): Platform changed from 0 to 10; regranting permissions for external storage
D/dalvikvm( 1467): creating instr width table
D/dalvikvm( 1467): DexOpt: load 3ms, verify+opt 60ms
D/installd( 1078): DexInv: --- END '/system/app/MediaProvider.apk' (success) ---
D/installd( 1078): DexInv: --- BEGIN '/system/app/DownloadProvider.apk' ---
I/ActivityThread( 1447): Pub com.android.deskclock: com.android.deskclock.AlarmProvider
D/dalvikvm( 1468): creating instr width table
D/dalvikvm( 1468): DexOpt: load 49ms, verify+opt 256ms
D/installd( 1078): DexInv: --- END '/system/app/DownloadProvider.apk' (success) ---
D/installd( 1078): DexInv: --- BEGIN '/system/app/DrmProvider.apk' ---
D/dalvikvm( 1469): creating instr width table
D/dalvikvm( 1469): DexOpt: load 1ms, verify+opt 8ms
D/installd( 1078): DexInv: --- END '/system/app/DrmProvider.apk' (success) ---
I/StorageNotification( 1295): Media {/mnt/sdcard} state changed from {checking} -> {mounted}
W/Resources( 1392): Converting to int: TypedValue{t=0x3/d=0x10 "4" a=-1}
W/Resources( 1392): Converting to int: TypedValue{t=0x3/d=0xe "1" a=-1}
I/ActivityThread( 1452): Pub media: com.android.providers.media.MediaProvider
V/MediaProvider( 1452): Attached volume: internal
V/MediaProvider( 1452): /mnt/sdcard volume ID: -381546224
W/BackupManagerService( 1172): dataChanged but no participant pkg='com.android.providers.settings' uid=10001
I/ActivityManager( 1172): Start proc com.android.email for broadcast com.android.email/.service.EmailBroadcastReceiver: pid=1473 uid=10007 gids={3003, 1015}
I/MediaProvider( 1452): Upgrading media database from version 63 to 100, which will destroy all old data
D/dalvikvm( 1392): GC_EXTERNAL_ALLOC freed 124K, 51% free 2897K/5831K, external 1561K/1572K, paused 147ms
D/installd( 1078): DexInv: --- BEGIN '/system/app/Email.apk' ---
V/MediaProvider( 1452): Attached volume: external
I/ActivityThread( 1452): Pub downloads: com.android.providers.downloads.DownloadProvider
I/ActivityThread( 1452): Pub drm: com.android.providers.drm.DrmProvider
D/dalvikvm( 1481): creating instr width table
D/dalvikvm( 1481): DexOpt: load 57ms, verify+opt 589ms
D/installd( 1078): DexInv: --- END '/system/app/Email.apk' (success) ---
I/DownloadManager( 1452): Upgrading downloads database from version 0 to version 106, which will destroy all old data
I/ActivityThread( 1473): Pub com.android.email.provider: com.android.email.provider.EmailProvider
I/ActivityThread( 1473): Pub com.android.email.attachmentprovider: com.android.email.provider.AttachmentProvider
I/ActivityThread( 1473): Pub com.android.exchange.provider: com.android.exchange.provider.ExchangeProvider
D/VoiceDialerReceiver( 1410): onReceive Intent { act=android.intent.action.BOOT_COMPLETED cmp=com.android.voicedialer/.VoiceDialerReceiver }
I/ActivityManager( 1172): Start proc com.android.bluetooth for broadcast com.android.bluetooth/.opp.BluetoothOppReceiver: pid=1485 uid=10012 gids={3003, 3002, 3001, 1015}
D/EAS SyncManager( 1473): !!! EAS SyncManager, onCreate
D/installd( 1078): DexInv: --- BEGIN '/system/app/Bluetooth.apk' ---
D/EmailProvider( 1473): Creating EmailProvider database
D/dalvikvm( 1473): GC_CONCURRENT freed 507K, 51% free 2911K/5831K, external 716K/1038K, paused 3ms+10ms
D/dalvikvm( 1172): GC_CONCURRENT freed 792K, 46% free 4222K/7751K, external 1916K/2516K, paused 3ms+25ms
D/Eas Debug( 1473): Logging:
D/dalvikvm( 1497): creating instr width table
D/Email ( 1473): BOOT_COMPLETED
I/Email ( 1473): Onetime initialization: 1
I/Email ( 1473): Onetime initialization: completed.
D/EmailProvider( 1473): Creating EmailProviderBody database
D/dalvikvm( 1497): DexOpt: load 35ms, verify+opt 210ms
D/installd( 1078): DexInv: --- END '/system/app/Bluetooth.apk' (success) ---
D/EAS SyncManager( 1473): !!! EAS SyncManager, onDestroy
D/EAS SyncManager( 1473): !!! EAS SyncManager, onStartCommand
D/EAS SyncManager( 1473): !!! EAS SyncManager, stopping self
I/ActivityThread( 1485): Pub com.android.bluetooth.opp: com.android.bluetooth.opp.BluetoothOppProvider
I/ActivityManager( 1172): Start proc com.honeywell.factoryresettest for broadcast com.honeywell.factoryresettest/.BootReceiver: pid=1501 uid=10018 gids={1015}
D/installd( 1078): DexInv: --- BEGIN '/system/app/FactoryResetTest.apk' ---
D/MediaScannerService( 1452): start scanning volume internal
D/dalvikvm( 1514): creating instr width table
D/dalvikvm( 1514): DexOpt: load 13ms, verify+opt 34ms
D/installd( 1078): DexInv: --- END '/system/app/FactoryResetTest.apk' (success) ---
I/FactoryResetTest( 1501): onReceive the BOOTCOMPLETE!
I/FactoryResetTest( 1501): Disable keyguard
D/dalvikvm( 1452): GC_CONCURRENT freed 519K, 52% free 2843K/5831K, external 716K/1038K, paused 2ms+3ms
E/MetadataRetrieverClient( 1076): failed to extract an album art
W/BackupManagerService( 1172): dataChanged but no participant pkg='com.android.providers.settings' uid=10000
D/dalvikvm( 1452): GC_CONCURRENT freed 325K, 51% free 2908K/5831K, external 716K/1038K, paused 2ms+3ms
D/MediaScanner( 1452): prescan time: 152ms
D/MediaScanner( 1452): scan time: 2325ms
D/MediaScanner( 1452): postscan time: 0ms
D/MediaScanner( 1452): total time: 2477ms
D/MediaScannerService( 1452): done scanning volume internal
I/FactoryResetTest( 1501): Got flag!
I/FactoryResetTest( 1501): Got count = [I@407f5108
I/FactoryResetTest( 1501): Total > Current,Continue!
I/FactoryResetTest( 1501): Succesful in last time !
I/FactoryResetTest( 1501): Start alert!
I/ActivityManager( 1172): Starting: Intent { flg=0x10000000 cmp=com.honeywell.factoryresettest/.WarningDialogActivity (has extras) } from pid 1501
W/SurfaceFlinger( 1172): closeGlobalTransaction timed out!
I/ActivityManager( 1172): Start proc com.honeywell.touchcalibration for broadcast com.honeywell.touchcalibration/.BootReceiver: pid=1523 uid=10019 gids={}
D/installd( 1078): DexInv: --- BEGIN '/system/app/TouchScreenCalibration.apk' ---
D/dalvikvm( 1531): creating instr width table
D/dalvikvm( 1531): DexOpt: load 6ms, verify+opt 15ms
D/installd( 1078): DexInv: --- END '/system/app/TouchScreenCalibration.apk' (success) ---
I/TouchScreenCalibration( 1523): (BootReceiver)onReceive the BOOTCOMPLETE!
V/TouchScreenCalibration( 1523): Service loaded at start
I/ActivityManager( 1172): Start proc com.android.mms for broadcast com.android.mms/.transaction.MmsSystemEventReceiver: pid=1532 uid=10026 gids={3003, 1015}
I/native_tscalibrate( 1523): JNI_OnLoad
I/TouchCalService( 1523): (BootReceiver)No CAL file,launch the calibrate activity!
I/ActivityManager( 1172): Starting: Intent { flg=0x10000000 cmp=com.honeywell.touchcalibration/.TouchCalibrationActivity } from pid 1523
D/installd( 1078): DexInv: --- BEGIN '/system/app/Mms.apk' ---
D/dalvikvm( 1540): creating instr width table
W/ActivityManager( 1172): Activity pause timeout for HistoryRecord{409352f8 com.android.launcher/com.android.launcher2.Launcher}
D/dalvikvm( 1540): DexOpt: load 78ms, verify+opt 277ms
D/installd( 1078): DexInv: --- END '/system/app/Mms.apk' (success) ---
I/TouchScreenCalibration( 1523): (Activity)onCreate
D/native_tscalibrate( 1523): sysfile is : 0
D/native_tscalibrate( 1523): (getValue)sysfile is :0 ;val_buffer: 0
D/native_tscalibrate( 1523): ;
D/native_tscalibrate( 1523): sysfile is : 1
D/native_tscalibrate( 1523): (getValue)sysfile is :1 ;val_buffer: 4095
D/native_tscalibrate( 1523): sysfile is : 2
D/native_tscalibrate( 1523): (getValue)sysfile is :2 ;val_buffer: 0
D/native_tscalibrate( 1523): sysfile is : 3
D/native_tscalibrate( 1523): (getValue)sysfile is :3 ;val_buffer: 4095
D/TouchScreenCalibration( 1523): (Activity)touchboundaryArrary is :0
D/TouchScreenCalibration( 1523): (Activity)touchboundaryArrary is :4095
D/TouchScreenCalibration( 1523): (Activity)x_scale is :8.53125; y_scale is :6.3984375
D/TouchScreenCalibration( 1523): (init)parameter is [0,1,0,0,0,1,1]
I/native_tscalibrate( 1523): Set Touch Parameter,The Jarray[0] = 0
I/native_tscalibrate( 1523): Set Touch Parameter,The Jarray[1] = 1
I/native_tscalibrate( 1523): Set Touch Parameter,The Jarray[2] = 0
I/native_tscalibrate( 1523): Set Touch Parameter,The Jarray[3] = 0
I/native_tscalibrate( 1523): Set Touch Parameter,The Jarray[4] = 0
I/native_tscalibrate( 1523): Set Touch Parameter,The Jarray[5] = 1
I/native_tscalibrate( 1523): Set Touch Parameter,The Jarray[6] = 1
I/native_tscalibrate( 1523): (SetTouchParameter)Start to set Touch Parameter
I/native_tscalibrate( 1523): (SetTouchParameter)Finish to set Touch Parameter
I/TouchScreenCalibration( 1523): (Activity)onStart
I/ActivityThread( 1532): Pub com.android.mms.SuggestionsProvider: com.android.mms.SuggestionsProvider
D/dalvikvm( 1291): GC_CONCURRENT freed 203K, 47% free 3030K/5703K, external 716K/1038K, paused 2ms+3ms
I/ActivityManager( 1172): Start proc com.android.providers.calendar for broadcast com.android.providers.calendar/.CalendarReceiver: pid=1552 uid=10027 gids={3003}
D/dalvikvm( 1532): GC_CONCURRENT freed 558K, 51% free 2860K/5831K, external 716K/1038K, paused 3ms+9ms
I/ActivityThread( 1552): Pub com.android.calendar: com.android.providers.calendar.CalendarProvider2
D/dalvikvm( 1291): GREF has increased to 201
I/ActivityManager( 1172): Start proc com.cooliris.media for broadcast com.cooliris.media/com.cooliris.cache.BootReceiver: pid=1564 uid=10002 gids={1015, 3003}
D/dalvikvm( 1075): GC_EXPLICIT freed 10K, 50% free 2721K/5379K, external 716K/1038K, paused 119ms
D/installd( 1078): DexInv: --- BEGIN '/system/app/Gallery3D.apk' ---
D/dalvikvm( 1172): GREF has increased to 401
D/dalvikvm( 1172): GC_CONCURRENT freed 748K, 46% free 4233K/7751K, external 1916K/2516K, paused 3ms+22ms
D/dalvikvm( 1075): GC_EXPLICIT freed <1K, 50% free 2721K/5379K, external 716K/1038K, paused 82ms
D/dalvikvm( 1075): GC_EXPLICIT freed <1K, 50% free 2721K/5379K, external 716K/1038K, paused 57ms
D/dalvikvm( 1572): creating instr width table
D/Calendar( 1552): missed alarms found: 0
D/dalvikvm( 1572): DexOpt: load 23ms, verify+opt 252ms
D/installd( 1078): DexInv: --- END '/system/app/Gallery3D.apk' (success) ---
I/ActivityThread( 1564): Pub com.cooliris.picasa.contentprovider: com.cooliris.picasa.PicasaContentProvider
D/dalvikvm( 1564): GC_CONCURRENT freed 610K, 52% free 2808K/5831K, external 716K/1038K, paused 2ms+3ms
I/BootReceiver( 1564): Got intent with action android.intent.action.MEDIA_MOUNTED
I/ActivityManager( 1172): Start proc com.android.quicksearchbox for broadcast com.android.quicksearchbox/.SearchWidgetProvider: pid=1576 uid=10021 gids={3003}
D/installd( 1078): DexInv: --- BEGIN '/system/app/QuickSearchBox.apk' ---
D/MediaScannerService( 1452): start scanning volume external
D/dalvikvm( 1584): creating instr width table
D/dalvikvm( 1584): DexOpt: load 75ms, verify+opt 306ms
D/installd( 1078): DexInv: --- END '/system/app/QuickSearchBox.apk' (success) ---
I/ActivityThread( 1576): Pub com.android.quicksearchbox.google: com.android.quicksearchbox.google.GoogleSuggestionProvider
I/ActivityThread( 1576): Pub com.android.quicksearchbox.shortcuts: com.android.quicksearchbox.ShortcutsProvider
I/ActivityManager( 1172): Start proc com.android.protips for broadcast com.android.protips/.ProtipWidget: pid=1585 uid=10032 gids={}
D/installd( 1078): DexInv: --- BEGIN '/system/app/Protips.apk' ---
D/dalvikvm( 1593): creating instr width table
D/dalvikvm( 1593): DexOpt: load 1ms, verify+opt 5ms
D/installd( 1078): DexInv: --- END '/system/app/Protips.apk' (success) ---
V/MediaScanner( 1452): pruneDeadThumbnailFiles... android.database.sqlite.SQLiteCursor@407ef8e0
V/MediaScanner( 1452): /pruneDeadThumbnailFiles... android.database.sqlite.SQLiteCursor@407ef8e0
D/dalvikvm( 1452): GC_CONCURRENT freed 424K, 50% free 2922K/5831K, external 716K/1038K, paused 3ms+2ms
D/MediaScanner( 1452): prescan time: 165ms
D/MediaScanner( 1452): scan time: 3ms
D/MediaScanner( 1452): postscan time: 49ms
D/MediaScanner( 1452): total time: 217ms
D/MediaScannerService( 1452): done scanning volume external
I/ActivityManager( 1172): Start proc com.android.music for broadcast com.android.music/.MediaAppWidgetProvider: pid=1594 uid=10003 gids={3003, 1015}
D/installd( 1078): DexInv: --- BEGIN '/system/app/Music.apk' ---
D/dalvikvm( 1602): creating instr width table
D/dalvikvm( 1602): DexOpt: load 35ms, verify+opt 130ms
D/installd( 1078): DexInv: --- END '/system/app/Music.apk' (success) ---
I/BootReceiver( 1564): Got intent with action android.intent.action.MEDIA_SCANNER_FINISHED
D/VoiceDialerReceiver( 1410): onReceive Intent { act=android.intent.action.PACKAGE_CHANGED dat=package:com.android.email flg=0x10000000 cmp=com.android.voicedialer/.VoiceDialerReceiver (has extras) }
I/TouchScreenCalibration( 1523): (Activity)position is :0
W/InputManagerService( 1172): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@408f6fb0 (uid=10011 pid=1392)
I/Launcher( 1392): setLoadOnResume
I/ActivityManager( 1172): Displayed com.honeywell.touchcalibration/.TouchCalibrationActivity: +5s590ms
D/dalvikvm( 1392): GC_CONCURRENT freed 192K, 48% free 3078K/5831K, external 1809K/2091K, paused 2ms+3ms
D/dalvikvm( 1552): GC_CONCURRENT freed 544K, 52% free 2807K/5767K, external 716K/1038K, paused 3ms+3ms
D/dalvikvm( 1392): GC_EXTERNAL_ALLOC freed 125K, 49% free 3026K/5831K, external 2084K/2091K, paused 30ms
D/dalvikvm( 1392): GC_EXPLICIT freed 48K, 49% free 2999K/5831K, external 2097K/2515K, paused 29ms
W/SharedBufferStack( 1295): waitForCondition(LockCondition) timed out (identity=5, status=0). CPU may be pegged. trying again.
W/SharedBufferStack( 1172): waitForCondition(LockCondition) timed out (identity=2, status=0). CPU may be pegged. trying again.
I/power ( 1172): *** set_screen_state 0
D/d7800Sensors( 1172): sensors_poll_context_t::activate, handle = 0, enabled = 0, index = 0
D/Sensors ( 1172): AccelSensor - enable, flags = 0, mEnabled = 1
D/Sensors ( 1172): AccelSensor - setFsVal pathid = 1; val = 0
D/Sensors ( 1172): AccelSensor - setFsVal wrote 0
D/Sensors ( 1172): AccelSensor - setFsVal pathid = 2; val = 0
D/SurfaceFlinger( 1172): About to give-up screen, flinger = 0x186f48
I/Process ( 1172): Sending signal. PID: 1295 SIG: 3
I/dalvikvm( 1295): threadid=4: reacting to signal 3
I/dalvikvm( 1295): Wrote stack traces to '/data/anr/traces.txt'
W/ActivityManager( 1172): Timeout of broadcast BroadcastRecord{40818660 android.intent.action.TIME_TICK} - receiver=android.os.BinderProxy@40957510, started 10001ms ago
W/ActivityManager( 1172): Receiver during timeout: BroadcastFilter{40957868 ReceiverList{409577f0 1295 com.android.systemui/1000 remote:40957510}}
D/PowerManagerService( 1172): SuspendReceiver got action android.intent.action.SCREEN_OFF
I/Process ( 1172): Sending signal. PID: 1172 SIG: 3
I/dalvikvm( 1172): threadid=4: reacting to signal 3
I/dalvikvm( 1172): Wrote stack traces to '/data/anr/traces.txt'
I/Process ( 1172): Sending signal. PID: 1291 SIG: 3
I/dalvikvm( 1291): threadid=4: reacting to signal 3
I/dalvikvm( 1291): Wrote stack traces to '/data/anr/traces.txt'
D/dalvikvm( 1172): GC_CONCURRENT freed 686K, 44% free 4410K/7751K, external 1916K/2516K, paused 3ms+4ms
D/dalvikvm( 1172): GC_EXPLICIT freed 64K, 44% free 4409K/7751K, external 1916K/2516K, paused 44ms
I/Process ( 1172): Sending signal. PID: 1295 SIG: 9
E/ActivityManager( 1172): ANR in com.android.systemui
E/ActivityManager( 1172): Reason: Broadcast of Intent { act=android.intent.action.TIME_TICK flg=0x40000004 (has extras) }
E/ActivityManager( 1172): Load: 1.28 / 0.57 / 0.21
E/ActivityManager( 1172): CPU usage from 4998ms to -850ms ago:
E/ActivityManager( 1172): 6.3% 1172/system_server: 4.1% user + 2.2% kernel / faults: 485 minor
E/ActivityManager( 1172): 0.6% 7/kworker/u:1: 0% user + 0.6% kernel
E/ActivityManager( 1172): 0.6% 520/kworker/0:1: 0% user + 0.6% kernel
E/ActivityManager( 1172): 0% 1071/netd: 0% user + 0% kernel / faults: 40 minor 1 major
E/ActivityManager( 1172): 0.1% 1295/com.android.systemui: 0.1% user + 0% kernel / faults: 13 minor
E/ActivityManager( 1172): 7.8% TOTAL: 4.7% user + 3% kernel
E/ActivityManager( 1172): CPU usage from 316ms to 832ms later:
E/ActivityManager( 1172): 3.8% 1172/system_server: 1.9% user + 1.9% kernel
E/ActivityManager( 1172): 3.8% 1186/ActivityManager: 1.9% user + 1.9% kernel
E/ActivityManager( 1172): 3.9% TOTAL: 1.9% user + 1.9% kernel
E/InputDispatcher( 1172): channel '4093d158 StatusBar (server)' ~ Consumer closed input channel or an error occurred. events=0x8
E/InputDispatcher( 1172): channel '4093d158 StatusBar (server)' ~ Channel is unrecoverably broken and will be disposed!
E/InputDispatcher( 1172): channel '4082fff0 TrackingView (server)' ~ Consumer closed input channel or an error occurred. events=0x8
E/InputDispatcher( 1172): channel '4082fff0 TrackingView (server)' ~ Channel is unrecoverably broken and will be disposed!
E/InputDispatcher( 1172): channel '4095e1e0 StatusBarExpanded (server)' ~ Consumer closed input channel or an error occurred. events=0x8
E/InputDispatcher( 1172): channel '4095e1e0 StatusBarExpanded (server)' ~ Channel is unrecoverably broken and will be disposed!
I/WindowManager( 1172): WINDOW DIED Window{4093d158 StatusBar paused=false}
I/WindowManager( 1172): WINDOW DIED Window{4082fff0 TrackingView paused=false}
I/ActivityManager( 1172): Process com.android.systemui (pid 1295) has died.
W/ActivityManager( 1172): Scheduling restart of crashed service com.android.systemui/.statusbar.StatusBarService in 5000ms
I/WindowManager( 1172): WIN DEATH: Window{4095e1e0 StatusBarExpanded paused=false}
I/ActivityManager( 1172): Start proc com.android.systemui for restart com.android.systemui: pid=1711 uid=1000 gids={3002, 3001, 3003}
D/dalvikvm( 1172): GC_FOR_MALLOC freed 346K, 45% free 4310K/7751K, external 1916K/2516K, paused 62ms
I/StatusBarManagerService( 1172): registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@40996fe8
D/StorageNotification( 1711): Startup with UMS connection false (media state mounted)
I/StorageNotification( 1711): UMS connection changed to false (media state mounted)
D/dalvikvm( 1711): GC_CONCURRENT freed 488K, 51% free 2874K/5831K, external 956K/1038K, paused 2ms+4ms
W/SharedBufferStack( 1711): waitForCondition(LockCondition) timed out (identity=11, status=0). CPU may be pegged. trying again.
W/SharedBufferStack( 1711): waitForCondition(LockCondition) timed out (identity=11, status=0). CPU may b?pegged. trying again.
W/ActivityManager( 1172): Timeout of broadcast BroadcastRecord{40932870 android.intent.action.TIME_TICK} - receiver=android.os.BinderProxy@4081cbd0, started 10003ms ago
W/ActivityManager( 1172): Receiver during timeout: BroadcastFilter{40886a78 ReceiverList{408cbcf8 1711 com.android.systemui/1000 remote:4081cbd0}}
I/Process ( 1172): Sending signal. PID: 1711 SIG: 3
I/dalvikvm( 1711): threadid=4: reacting to signal 3
I/dalvikvm( 1711): Wrote stack traces to '/data/anr/traces.txt'
D/dalvikvm( 1172): GC_CONCURRENT freed 679K, 43% free 4432K/7751K, external 1916K/2516K, paused 3ms+4ms
D/dalvikvm( 1172): GC_EXPLICIT freed 11K, 43% free 4420K/7751K, external 1916K/2516K, paused 42ms
I/Process ( 1172): Sending signal. PID: 1711 SIG: 9
E/ActivityManager( 1172): Load: 0.47 / 0.47 / 0.2
E/ActivityManager( 1172): CPU usage from 5001ms to 0ms ago:
E/ActivityManager( 1172): 0.2% 520/kworker/0:1: 0% user + 0.2% kernel
E/ActivityManager( 1172): 0.2% 1172/system_server: 0.2% user + 0% kernel / faults: 5 minor
E/ActivityManager( 1172): +0% 1825/sh: 0% user + 0% kernel
E/ActivityManager( 1172): +0% 1831/sleep: 0% user + 0% kernel
E/ActivityManager( 1172): 1.1% TOTAL: 0.1% user + 0.9% kernel
E/ActivityManager( 1172): CPU usage from 272ms to 788ms later with 99% awake:
E/ActivityManager( 1172): 3.8% 1172/system_server: 3.8% user + 0% kernel
E/ActivityManager( 1172): 3.8% 1186/ActivityManager: 3.8% user + 0% kernel
E/ActivityManager( 1172): 3.9% TOTAL: 3.9% user + 0% kernel
E/InputDispatcher( 1172): channel '40862228 StatusBar (server)' ~ Consumer closed input channel or an error occurred. events=0x8
E/InputDispatcher( 1172): channel '40862228 StatusBar (server)' ~ Channel is unrecoverably broken and will be disposed!
I/WindowManager( 1172): WINDOW DIED Window{40862228 StatusBar paused=false}
I/ActivityManager( 1172): Process com.android.systemui (pid 1711) has died.
W/ActivityManager( 1172): Scheduling restart of crashed service com.android.systemui/.statusbar.StatusBarService in 20000ms
I/WindowManager( 1172): WIN DEATH: Window{40957058 StatusBarExpanded paused=false}
E/InputDispatcher( 1172): channel '4092f120 TrackingView (server)' ~ Consumer closed input channel or an error occurred. events=0x8
E/InputDispatcher( 1172): channel '4092f120 TrackingView (server)' ~ Channel is unrecoverably broken and will be disposed!
E/InputDispatcher( 1172): Received spurious receive callback for unknown input channel. fd=172, events=0x8
I/WindowManager( 1172): WIN DEATH: Window{4092f120 TrackingView paused=false}
I/ActivityManager( 1172): Start proc com.android.systemui for restart com.android.systemui: pid=1835 uid=1000 gids={3002, 3001, 3003}
I/StatusBarManagerService( 1172): registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@408f4f80
D/StorageNotification( 1835): Startup with UMS connection false (media state mounted)
I/StorageNotification( 1835): UMS connection changed to false (media state mounted)
D/dalvikvm( 1835): GC_CONCURRENT freed 488K, 51% free 2875K/5831K, external 956K/1038K, paused 3ms+2ms
W/SharedBufferStack( 1835): waitForCondition(LockCondition) timed out (identity=13, status=0). CPU may be pegged. trying again.
W/ActivityManager( 1172): Timeout of broadcast BroadcastRecord{40810b48 android.intent.action.TIME_TICK} - receiver=android.os.BinderProxy@408bcc28, started 10003ms ago
W/ActivityManager( 1172): Receiver during timeout: BroadcastFilter{408f06a8 ReceiverList{408f1510 1835 com.android.systemui/1000 remote:408bcc28}}
I/Process ( 1172): Sending signal. PID: 1835 SIG: 3
I/dalvikvm( 1835): threadid=4: reacting to signal 3
I/dalvikvm( 1835): Wrote stack traces to '/data/anr/traces.txt'
D/dalvikvm( 1172): GC_CONCURRENT freed 965K, 44% free 4422K/7815K, external 1916K/2516K, paused 3ms+4ms
W/ProcessStats( 1172): Skipping unknown process pid 1949
W/ProcessStats( 1172): Skipping unknown process pid 1955
D/dalvikvm( 1172): GC_EXPLICIT freed 53K, 44% free 4423K/7815K, external 1916K/2516K, paused 43ms
I/Process ( 1172): Sending signal. PID: 1835 SIG: 9
E/ActivityManager( 1172): Load: 0.25 / 0.4 / 0.2
E/ActivityManager( 1172): CPU usage from 5007ms to 0ms ago:
E/ActivityManager( 1172): 0.5% 1172/system_server: 0.3% user + 0.1% kernel / faults: 7 minor
E/ActivityManager( 1172): 0.1% 520/kworker/0:1: 0% user + 0.1% kernel
E/ActivityManager( 1172): 0.1% 1835/com.android.systemui: 0.1% user + 0% kernel
E/ActivityManager( 1172): +0% 1949/sh: 0% user + 0% kernel
E/ActivityManager( 1172): +0% 1955/sleep: 0% user + 0% kernel
E/ActivityManager( 1172): 1.3% TOTAL: 0.1% user + 1.1% kernel
E/ActivityManager( 1172): CPU usage from 267ms to 784ms later:
E/ActivityManager( 1172): 3.8% 1172/system_server: 0% user + 3.8% kernel
E/ActivityManager( 1172): 1.9% 1186/ActivityManager: 0% user + 1.9% kernel
E/ActivityManager( 1172): 1.9% TOTAL: 0% user + 1.9% kernel
E/InputDispatcher( 1172): channel '408c1ac0 StatusBar (server)' ~ Consumer closed input channel or an error occurred. events=0x8
E/InputDispatcher( 1172): channel '408c1ac0 StatusBar (server)' ~ Channel is unrecoverably broken and will be disposed!
E/InputDispatcher( 1172): channel '40944818 TrackingView (server)' ~ Consumer closed input channel or an error occurred. events=0x8
E/InputDispatcher( 1172): channel '40944818 TrackingView (server)' ~ Channel is unrecoverably broken and will be disposed!
I/WindowManager( 1172): WINDOW DIED Window{408c1ac0 StatusBar paused=false}
I/WindowManager( 1172): WINDOW DIED Window{40944818 TrackingView paused=false}
I/WindowManager( 1172): WINDOW DIED Window{4095e1e0 StatusBarExpanded paused=false}
I/ActivityManager( 1172): Process com.android.systemui (pid 1835) has died.
W/ActivityManager( 1172): Scheduling restart of crashed service com.android.systemui/.statusbar.StatusBarService in 80000ms
I/ActivityManager( 1172): Start proc com.android.systemui for restart com.android.systemui: pid=1959 uid=1000 gids={3002, 3001, 3003}
D/dalvikvm( 1172): GC_FOR_MALLOC freed 414K, 45% free 4300K/7815K, external 1916K/2516K, paused 63ms
I/StatusBarManagerService( 1172): registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@409a2e00
D/StorageNotification( 1959): Startup with UMS connection false (media state mounted)
I/StorageNotification( 1959): UMS connection changed to false (media state mounted)
D/dalvikvm( 1959): GC_CONCURRENT freed 487K, 51% free 2876K/5831K, external 954K/1038K, paused 2ms+2ms
W/SharedBufferStack( 1959): waitForCondition(LockCondition) timed out (identity=15, status=0). CPU may be pegged. trying again.
W/ActivityManager( 1172): Timeout of broadcast BroadcastRecord{4091b970 android.intent.action.TIME_TICK} - receiver=android.os.BinderProxy@40890ac8, started 10004ms ago
W/ActivityManager( 1172): Receiver during timeout: BroadcastFilter{407f5238 ReceiverList{407f5648 1959 com.android.systemui/1000 remote:40890ac8}}
I/Process ( 1172): Sending signal. PID: 1959 SIG: 3
I/dalvikvm( 1959): threadid=4: reacting to signal 3
I/dalvikvm( 1959): Wrote stack traces to '/data/anr/traces.txt'
D/dalvikvm( 1172): GC_CONCURRENT freed 622K, 44% free 4439K/7815K, external 1916K/2516K, paused 3ms+4ms
D/dalvikvm( 1172): GC_EXPLICIT freed 12K, 44% free 4427K/7815K, external 1916K/2516K, paused 43ms
I/Process ( 1172): Sending signal. PID: 1959 SIG: 9
E/ActivityManager( 1172): Load: 0.1 / 0.28 / 0.18
E/ActivityManager( 1172): CPU usage from 5000ms to -761ms ago:
E/ActivityManager( 1172): 4.8% 1172/system_server: 3.6% user + 1.2% kernel / faults: 225 minor
E/ActivityManager( 1172): 0.1% 1291/com.android.phone: 0.1% user + 0% kernel / faults: 4 minor
E/ActivityManager( 1172): 0.1% 1959/com.android.systemui: 0.1% user + 0% kernel / faults: 15 minor
E/ActivityManager( 1172): +0% 2186/kworker/0:0: 0% user + 0% kernel
E/ActivityManager( 1172): 5.7% TOTAL: 3.4% user + 2.2% kernel
E/ActivityManager( 1172): CPU usage from 226ms to 744ms later:
E/ActivityManager( 1172): 5.7% 1172/system_server: 0% user + 5.7% kernel
E/ActivityManager( 1172): 3.8% 1186/ActivityManager: 0% user + 3.8% kernel
E/ActivityManager( 1172): 5.6% TOTAL: 0% user + 5.6% kernel
E/InputDispatcher( 1172): channel '40957058 StatusBarExpanded (server)' ~ Consumer closed input channel or an error occurred. events=0x8
E/InputDispatcher( 1172): channel '40957058 StatusBarExpanded (server)' ~ Channel is unrecoverably broken and will be disposed!
I/WindowManager( 1172): WINDOW DIED Window{4092f120 TrackingView paused=false}
I/WindowManager( 1172): WINDOW DIED Window{40957058 StatusBarExpanded paused=false}
I/ActivityManager( 1172): Process com.android.systemui (pid 1959) has died.
W/ActivityManager( 1172): Scheduling restart of crashed service com.android.systemui/.statusbar.StatusBarService in 320000ms
I/ActivityManager( 1172): Start proc com.android.systemui for restart com.android.systemui: pid=2199 uid=1000 gids={3002, 3001, 3003}
I/StatusBarManagerService( 1172): registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@4083dae0
D/StorageNotification( 2199): Startup with UMS connection false (media state mounted)
I/StorageNotification( 2199): UMS connection changed to false (media state mounted)
D/dalvikvm( 2199): GC_CONCURRENT freed 490K, 51% free 2875K/5831K, external 956K/1038K, paused 2ms+3ms
W/SharedBufferStack( 2199): waitForCondition(LockCondition) timed out (identity=17, status=0). CPU may be pegged. trying again.
W/ActivityManager( 1172): Timeout of broadcast BroadcastRecord{408f49f8 android.intent.action.TIME_TICK} - receiver=android.os.BinderProxy@40a0fe98, started 10004ms ago
W/ActivityManager( 1172): Receiver during timeout: BroadcastFilter{407b0498 ReceiverList{407b0420 2199 com.android.systemui/1000 remote:40a0fe98}}
I/Process ( 1172): Sending signal. PID: 2199 SIG: 3
I/dalvikvm( 2199): threadid=4: reacting to signal 3
I/dalvikvm( 2199): Wrote stack traces to '/data/anr/traces.txt'
D/dalvikvm( 1172): GC_CONCURRENT freed 971K, 45% free 4367K/7815K, external 1916K/2516K, paused 3ms+5ms
D/dalvikvm( 1172): GC_EXPLICIT freed 254K, 44% free 4439K/7815K, external 1916K/2516K, paused 46ms
I/Process ( 1172): Sending signal. PID: 2199 SIG: 9
E/ActivityManager( 1172): Load: 0.05 / 0.1 / 0.13
E/ActivityManager( 1172): CPU usage from 5001ms to -1ms ago:
E/ActivityManager( 1172): 0.6% 1172/system_server: 0.6% user + 0% kernel / faults: 5 minor
E/ActivityManager( 1172): 0.2% 2199/com.android.systemui: 0.2% user + 0% kernel
E/ActivityManager( 1172): 1% TOTAL: 0.2% user + 0.8% kernel
E/ActivityManager( 1172): CPU usage from 240ms to 756ms later:
E/ActivityManager( 1172): 1.9% 1186/ActivityManager: 1.9% user + 0% kernel
E/ActivityManager( 1172): +0% 2884/sh: 0% user + 0% kernel
E/ActivityManager( 1172): +0% 2890/sleep: 0% user + 0% kernel
E/ActivityManager( 1172): 11% TOTAL: 1.9% user + 9.6% kernel
E/InputDispatcher( 1172): channel '40a29418 StatusBar (server)' ~ Consumer closed input channel or an error occurred. events=0x8
E/InputDispatcher( 1172): channel '40a29418 StatusBar (server)' ~ Channel is unrecoverably broken and will be disposed!
E/InputDispatcher( 1172): channel '40907378 TrackingView (server)' ~ Consumer closed input channel or an error occurred. events=0x8
E/InputDispatcher( 1172): channel '40907378 TrackingView (server)' ~ Channel is unrecoverably broken and will be disposed!
I/WindowManager( 1172): WINDOW DIED Window{40a29418 StatusBar paused=false}
I/WindowManager( 1172): WINDOW DIED Window{40907378 TrackingView paused=false}
I/ActivityManager( 1172): Process com.android.systemui (pid 2199) has died.
W/ActivityManager( 1172): Scheduling restart of crashed service com.android.systemui/.statusbar.StatusBarService in 1280000ms
E/InputDispatcher( 1172): channel '409348a0 StatusBarExpanded (server)' ~ Consumer closed input channel or an error occurred. events=0x8
E/InputDispatcher( 1172): channel '409348a0 StatusBarExpanded (server)' ~ Channel is unrecoverably broken and will be disposed!
I/WindowManager( 1172): WINDOW DIED Window{409348a0 StatusBarExpanded paused=false}
I/ActivityManager( 1172): Start proc com.android.systemui for restart com.android.systemui: pid=2892 uid=1000 gids={3002, 3001, 3003}
W/WindowManager( 1172): Failed looking up window
W/WindowManager( 1172): java.lang.IllegalArgumentException: Requested window android.os.BinderProxy@40851f38 does not exist
W/WindowManager( 1172): at com.android.server.WindowManagerService.windowForClientLocked(WindowManagerService.java:8206)
W/WindowManager( 1172): at com.android.server.WindowManagerService.windowForClientLocked(WindowManagerService.java:8197)
W/WindowManager( 1172): at com.android.server.WindowManagerService$WindowState$DeathRecipient.binderDied(WindowManagerService.java:7056)
W/WindowManager( 1172): at android.os.BinderProxy.sendDeathNotice(Binder.java:381)
W/WindowManager( 1172): at dalvik.system.NativeStart.run(Native Method)
I/WindowManager( 1172): WIN DEATH: null
D/dalvikvm( 1172): GC_CONCURRENT freed 936K, 46% free 4292K/7815K, external 1916K/2516K, paused 3ms+4ms
Brs,
Gavin
