How do I swap AM33X WEC7 BSP WAVEDEV2 driver to McASP0 w/ TLV320AIC3106 codec?
Other Parts Discussed in Thread: TLV320AIC3106, TLV320AIC3100
On TI AM335x EVM, McASP1 is interfaced with the codec TLV320AIC3106. But we have Beaglebone McASP0 connected to same codec on a customerized 'CAPE' board.
Could someone give some points to swap the driver to McASP0?
We already completed similar job on TI AM335X-LINUX-PSP-04.06.00.03 -->http://e2e.ti.com/support/embedded/linux/f/354/t/158851.aspx?pi239031352=1
  • To enable McASP0, today I tried AM3xx BSP on my Beaglebone Rev. A3 with following WAVEDEV2 code changes:
    1. D:\WINCE700\platform\AM33X_BSP\SRC\DRIVERS\WAVEDEV2\am33x_wavedev2.reg
    IF BSP_WAVEDEV2
    [HKEY_LOCAL_MACHINE\Drivers\BuiltIn\WaveDev2]
       "Prefix"="WAV"
       "Dll"="am33x_wavedev2drvr.dll"
       "Order"=dword:5
       "Class"=dword:04
       "SubClass"=dword:01
       "IClass"=multi_sz:"{E92BC203-8354-4043-A06F-2A170BF6F227}",
                         "{37168569-61C4-45fd-BD54-9442C7DBA46F}",
                         "{A32942B7-920C-486b-B0E6-92A702A99B35}"
       "AudioCntrlRegAddr"=dword:48038000
       "EventIdRx"=dword:09
       "EventIdTx"=dword:08
       "Priority256"=dword:46
       "IrqTx"=dword:50
       "IrqRx"=dword:51
       "EdmaEventQueue"=dword:0
    [HKEY_CURRENT_USER\ControlPanel\Volume]
        "Key"=dword:10002       ; Keyclicks: 1=soft, 0x10002=loud
        "Screen"=dword:10002    ; ScreenTaps: 1=soft, 0x10002=loud
        "Mute"=dword:7          ; 7=Enable all sounds (1=Notifications, 2=Apps, 4=Events.)
        "Volume"=dword:FFFFFFFF ; Set the default volume to maximum
    ENDIF BSP_WAVEDEV2
    2. D:\WINCE700\platform\AM33X_BSP\SRC\DRIVERS\WAVEDEV2\hwctxt.cpp
    Function:               PowerUp()
    Description:            Powers up the audio codec chip.
    Returns:                Boolean indicating success
    void HardwareContext::PowerUp()
        // Power on the codec
        m_pCodec->PowerOff(FALSE);
        // Power on the McASP
        if (FALSE == EnableDeviceClocks(AM_DEVICE_MCASP0, TRUE))
            // Failed
            DEBUGMSG (ZONE_ERROR, (TEXT("HardwareContext::PowerUp: Failed to power on McASP\r\n")));
        RequestDevicePads(AM_DEVICE_MCASP0);
    // Setup the TX DMA
        m_pDmaTx = new AudioDma(m_DMAOutBufPhysAddr.LowPart, AM33X_MCASP0_DATA_REGS_PA,
                        AUDIO_DMA_BUFFER_SIZE, m_ulEventIdTx, ulEdmaEventQueue, CHANNEL_XMIT);
        if (!m_pDmaTx)
            goto Exit;
        if (!m_pDmaTx->Init(&m_hAudioInterrupt))
            goto Exit;
        // Setup the RX DMA
        m_pDmaRx = new AudioDma(AM33X_MCASP0_DATA_REGS_PA, m_DMAInBufPhysAddr.LowPart,
                        AUDIO_DMA_BUFFER_SIZE, m_ulEventIdRx, ulEdmaEventQueue, CHANNEL_RCV);
    I can hear 'kada' noise when driver was doing codec intialization. But definately mouse and touch screen do not work any more after kernel up. GUI hangs on touch screen calibration thread. Is there any conflict between WAVEDEV2 audio driver and touch screen driver or USB mouse driver?
    BTW, same problem when I run the kernel with default EVM configuration(McASP1).
    Here is logs:
    +OEMMultiBinNotify(0x8feb2398 -> 1)
    Download file information:
    [0]: Address=0x80002000  Length=0x03b8aee0  Save=0x80002000
    Download file type: 1
    +OEMIsFlashAddr(0x80002000) g_eboot.type 1
    ...................................................................................................................................................................................................................................................................................................................................................rom_offset=0x0.
    ..ImageStart = 0x80002000, ImageLength = 0x3b8aee0, LaunchAddr = 0x8000b6a0
    Completed file(s):
    [0]: Address=0x80002000  Length=0x3b8aee0  Name="" Target=RAM
    ROMHDR at Address 80002044h
    Launch Windows CE image by jumping to 0x8000b6a0...
    Windows CE Kernel for ARM (Thumb Enabled)
    CPU CP15 Control Register = 0xc5387f
    CPU CP15 Auxiliary Control Register = 0x42
            Board Name: A335BONE
            Board Ver : 00A3
            Board Ser : 4611BB000080
            Board Type:
    +OALTimerInit(1, 24000, 200)
    --- High Performance Frequecy is 24 MHz---
    PID:00400002 TID:00410002 SetOpp to 3
    PID:00400002 TID:012D0006 CM3: input file [\windows\firmware.bin] is 9932 bytes long
    PID:00400002 TID:012D0006 CM3: firmware file read ok!
    PID:00400002 TID:012D0006 WAVEDEV: IO Base = 0x48038000
    PID:00400002 TID:012D0006 WAVEDEV: TX Irq = 0x50
    PID:00400002 TID:012D0006 WAVEDEV: RX Irq = 0x51
    PID:00400002 TID:012D0006 WAVEDEV: Thread priority = 0x46
    PID:00400002 TID:012D0006 WAVEDEV: Event ID TX = 0x8
    PID:00400002 TID:012D0006 WAVEDEV: Event ID RX = 0x9
    PID:00400002 TID:012D0006 TLV320AIC3106CodecConfig
    PID:00400002 TID:012D0006 +TLV320AIC3106CodecConfig::CodecInit
    PID:00400002 TID:012D0006 +EnableHPOut_PLL fs_ref=48kHz, sample_rate_div=1 (0x00), lVol=0x00, rVol=0x00
    PID:00400002 TID:012D0006 -TLV320AIC3106CodecConfig::EnableHPOut_PLL
    PID:00400002 TID:012D0006 +TLV320AIC3106CodecConfig::EnableLine1: lVol=0x30 rVol=0x30
    PID:00400002 TID:012D0006 -TLV320AIC3106CodecConfig::EnableLine1
    PID:00400002 TID:012D0006 -TLV320AIC3106CodecConfig::CodecInit
    PID:00400002 TID:023E0002 HardwareContext::McASPInterruptThread: Running...
    PID:00400002 TID:02410002 HardwareContext::McASPInterruptThread: Running...
    PID:00400002 TID:012D0006 McASP::Init: Initialising McASP
    PID:00400002 TID:01510006 WAVE: IOCTL_POWER_CAPABILITIES = 0x11
    PID:00400002 TID:0129000E WAV2: WIDM_SETPROP
    PID:00400002 TID:0129000E HandleWaveMessage: Setting output volume to 0xffffffff for device 0
    PID:00400002 TID:0129000E TLV320AIC3106CodecConfig::SetOutputVolume: 0xffffffff L=0x0 R=0x0
    PID:00400002 TID:0129000E MXDM_GETNUMDEVS
    PID:00400002 TID:012D0006 Cpsw3g_InitializeAdapter: mode=1, port=1, txCh=0, rxChMask=0x01, ActiveCpgmac=1
    PID:00400002 TID:012D0006 SDHC: CPU revision 0xffffffff
    PID:00400002 TID:012D0006 SDHC host controller initialize: m_fastPathSDIO:1 m_fastPathSDMEM:0
    PID:00400002 TID:012D0006 -PRU_Init: rc=1
    PID:00400002 TID:012D0006 CAM3xxOTG::Init DEVCTL 80
    PID:00400002 TID:02C80042 PVR:getCpuFamily: 5
    PID:00400002 TID:02C80042 PVR:omapsgxddgpe getCpuFamily: 5
    PID:00400002 TID:02C80042 KeybdDriverInitializeEx: Layout Manager successfully initialized to  1
    PID:00400002 TID:02C80042 LayoutMgrActivateKeyboardLayout: Called with hkl = 0x00000409
    PID:0163000E TID:0590000A MSIM: IM_ReadRegistry read KB 5
    PID:0592000A TID:054E003A Explorer(V2.0) taskbar thread started.
    PID:00400002 TID:0594000A HardwareContext::StartAudioOutput
    PID:00400002 TID:0594000A McASP::StartAudioTX: Starting McASP
    PID:00400002 TID:016E0006 kernel PVRSRV_IOCTL_POWER_SET setting state 1
    PID:00400002 TID:016E0006 PddUpdateBacklight: 1+
    PID:00400002 TID:016E0006 PddUpdateBacklight-
    PID:00400002 TID:016E0006 kernel PVRSRV_IOCTL_POWER_SET setting state 2
    PID:00400002 TID:016E0006 PddUpdateBacklight: 2+
  • We forgot to add macro define for McASP0 pin mux:
    3. D:\WINCE700\platform\AM33X_BSP\SRC\INC\bsp_padcfg.h
    #define MCASP0_PADS \
        PAD_ENTRY(MCASP0_ACLKX,     MODE(0) | AM335X_PIN_INPUT_PULLDOWN)            \
        PAD_ENTRY(MCASP0_FSX,       MODE(0) | AM335X_PIN_INPUT_PULLDOWN)            \
        PAD_ENTRY(MCASP0_AHCLKR,    MODE(2) | AM335X_PIN_OUTPUT)                    \
        PAD_ENTRY(MCASP0_AHCLKX,    MODE(2) | AM335X_PIN_INPUT_PULLDOWN)            \
    After that touch calibration issue went away. The driver initialization success but we still can not hear sound from wince desktop.
     Some buffer under run and DMA errors observed from log. Should we do additional change to EDMA configuration? Right now we just keep same setting as McASP1.
    Here is log:
    ..ImageStart = 0x80002000, ImageLength = 0x3b8aee8, LaunchAddr = 0x8000b6c0
    Completed file(s):
    [0]: Address=0x80002000  Length=0x3b8aee8  Name="" Target=RAM
    Launch Windows CE image by jumping to 0x8000b6c0...
            Board Ver : 00A3
            Board Type:
    PID:00400002 TID:012E0006 CM3: input file [\windows\firmware.bin] is 9932 bytes long
    PID:00400002 TID:012E0006 CM3: firmware file read ok!
    PID:00400002 TID:012E0006 WAVEDEV: IO Base = 0x48038000
    PID:00400002 TID:012E0006 WAVEDEV: TX Irq = 0x50
    PID:00400002 TID:012E0006 WAVEDEV: RX Irq = 0x51
    PID:00400002 TID:012E0006 WAVEDEV: Thread priority = 0x46
    PID:00400002 TID:012E0006 WAVEDEV: Event ID TX = 0x8
    PID:00400002 TID:012E0006 WAVEDEV: Event ID RX = 0x9
    PID:00400002 TID:012E0006 TLV320AIC3106CodecConfig
    PID:00400002 TID:012E0006 +TLV320AIC3106CodecConfig::CodecInit
    PID:00400002 TID:012E0006 +EnableHPOut_PLL fs_ref=48kHz, sample_rate_div=1 (0x00), lVol=0x00, rVol=0x00
    PID:00400002 TID:012E0006 -TLV320AIC3106CodecConfig::EnableHPOut_PLL
    PID:00400002 TID:012E0006 +TLV320AIC3106CodecConfig::EnableLine1: lVol=0x30 rVol=0x30
    PID:00400002 TID:012E0006 -TLV320AIC3106CodecConfig::EnableLine1
    PID:00400002 TID:012E0006 -TLV320AIC3106CodecConfig::CodecInit
    PID:00400002 TID:012E0006 McASP::Init: Initialising McASP
    PID:00400002 TID:01520006 WAVE: IOCTL_POWER_CAPABILITIES = 0x11
    PID:00400002 TID:012A000E WAV2: WIDM_SETPROP
    PID:00400002 TID:012A000E HandleWaveMessage: Setting output volume to 0xffffffff for device 0
    PID:00400002 TID:012A000E TLV320AIC3106CodecConfig::SetOutputVolume: 0xffffffff L=0x0 R=0x0
    PID:00400002 TID:012A000E MXDM_GETNUMDEVS
    PID:00400002 TID:012E0006 Cpsw3g_InitializeAdapter: mode=1, port=1, txCh=0, rxChMask=0x01, ActiveCpgmac=1
    PID:00400002 TID:012E0006 SDHC: CPU revision 0xffffffff
    PID:00400002 TID:012E0006 SDHC host controller initialize: m_fastPathSDIO:1 m_fastPathSDMEM:0
    PID:00400002 TID:012E0006 -PRU_Init: rc=1
    PID:00400002 TID:012E0006 CAM3xxOTG::Init DEVCTL 80
    PID:00400002 TID:03450042 PVR:getCpuFamily: 5
    PID:00400002 TID:03450042 PVR:omapsgxddgpe getCpuFamily: 5
    PID:00400002 TID:03450042 KeybdDriverInitializeEx: Layout Manager successfully initialized to  1
    PID:00400002 TID:03450042 LayoutMgrActivateKeyboardLayout: Called with hkl = 0x00000409
    PID:0164000E TID:0590000A MSIM: IM_ReadRegistry read KB 5
    PID:0592000A TID:0591003A Explorer(V2.0) taskbar thread started.
    PID:00400002 TID:0594000A McASP::StartAudioTX: McASP started
    PID:00400002 TID:0499003E HardwareContext::StartAudioOutput
    PID:00400002 TID:02350012 NDISPWR:: Found adapter [CPSW3G2]
    PID:00400002 TID:023E0002 WARNING: McASPTX::HandleInterrupt: Buffer underun.
    PID:00400002 TID:023E0002 WARNING: McASPTX::HandleInterrupt: DMA error.
    PID:00400002 TID:02390002 HardwareContext::StopAudioOutput
    PID:00400002 TID:02390002 McASP::StopAudio: Stopping McASP
    PID:00400002 TID:053C0002 HardwareContext::StartAudioOutput
    PID:00400002 TID:053C0002 McASP::StartAudioTX: Starting McASP
    PID:00400002 TID:053C0002 McASP::StartAudioTX: McASP started
    PID:00400002 TID:016F0006 kernel PVRSRV_IOCTL_POWER_SET setting state 1
    PID:00400002 TID:016F0006 PddUpdateBacklight: 1+
    PID:00400002 TID:016F0006 PddUpdateBacklight-
  • Today we made some progress with this. After some serialiser parameter adjusting, WEC7 can play sound on Beaglebone board now!
    Here are addtional code changes we made upon TI WEC7 BSP 2.30(Note you ***MAY NOT*** need this change, if you have same scheme of serialiser configuration as TI AM3XX EVM board):
    4. D:\WINCE700\platform\AM33X_BSP\SRC\DRIVERS\WAVEDEV2\hwctxt.cpp
      Init configuration for mcasp device - DMA mode
      See also Tx/Rx serializer no. #defines in audio_mcasp.cpp
    static McaspHwSetup g_McaspHwSetup =
            /* .pfunc    = */ 0x00000000,                /* all mcasp pin */
            /* .pdir     = */ 0x00000008,                /* only pin-3 is output */
            /* .gblctl   = */ 0x00000000,                /* ctrl clk, hclk, statem - reset,release - driver ctrl */
            /* .ditctl   = */ 0x00000000,                /* DIT mode seting */
            /* .dlbctl   = */ 0x00000000,                /* loop back mode setting */
            /* .amute    = */ 0x00000000,                /* Amute setting */
            /* .srctl0   = */ 0x00000000,                /* serialiser 0 */
            /* .srctl1   = */ 0x00000000,                /* serialiser 1 */
            /* .srctl2   = */ 0x0000000E,                /* serialiser 2 Rx */
            /* .srctl3   = */ 0x0000000D,                /* serialiser 3 Tx */
            /* .srctl4   = */ 0x00000000,                /* serialiser 4 */
            /* .srctl5   = */ 0x00000000,                /* serialiser 5 */
            /* .srctl6   = */ 0x00000000,                /* serialiser 6 */
            /* .srctl7   = */ 0x00000000,                /* serialiser 7 */
            /* .srctl8   = */ 0x00000000,                /* serialiser 8 */
            /* .srctl9   = */ 0x00000000,                /* serialiser 9 */
            /* .srctl10   = */ 0x00000000,               /* serialiser 10 */
            /* .srctl11   = */ 0x00000000,               /* serialiser 11 */
            /* .srctl12   = */ 0x00000000                /* serialiser 12 */
    5. D:\WINCE700\platform\AM33X_BSP\SRC\DRIVERS\audio_mcasp.cpp
    #define MAX_NUMBER_SERIALIZER     6
    // See also corresponding tx/rx serializer config in hwctxt.cpp/g_McaspHwSetup
    #define SERIALIZER_XMTER          SERIALIZER_3
    #define SERIALIZER_RCVER          SERIALIZER_2
  • Hi
    We are interfacing AIC3106 codec to mcasp0 interface(am335x) and we are getting the same errors as you have posted.
    Should we need to change any configuration in EDMA...?
    I need your support....
  • Hi All,
    I would like to share with you my experience with exactly the same problem/error as described above.
    I was working with am335x processor and tlv320aic3100 audio codec and I was trying to use wavedev2 audio codec on Windows CE 7.
    I have setup audio serial interface in the master mode - WCLK and BCLK generated by the audio codec, 48kHz sample rate.
    I could play the music well but from time to time there were jitters and particles heard.
    In the debbug mode it was reported as:
    - Buffer underrun
    - or DMA error
    on the beginning I thought it is a problem with my code, I thought my code works too slow therefore the processor cannot fill in the buffer on time and buffer underrun is reported.
     So. I have spent some time to make it faster but it didn't help. Still there were jitters and particles heard.
    After some time spent on it I found that all of these problems are caused by the world lock generated by the codec which is also used as a frame synchronization in MCASP.
    It was unstable, sometimes the frame was too short - buffer underrun, and sometimes too long - dma error.
    Must probably caused by other interrupts.
    The solution was to change master audio interface  to SLAVE mode.
    So all - MCLK, WCLK, BCLK are generated by the processor and they are the inputs to the audio codec.
    In this case even if it is not stable the delay will done in all three clocks and you will not hear any jitters or particles anymore.
    So what you need to do is:
    - change pads configuration - codec WCLK and BCLK should be an output from mcasp
    - change mcasp register setting in the hardware context
    - .pdir - AFSX, AHCLK, AHCLKX pins  as an output (slave mode)
    - all afs clocks internally generated
    - all aclk, ahclk clocks internally generated
    - setup dividers well to get the right fs/wclk sample rate and the right bit lock frequency
    - change audio codec configuration - init to receive wclk and bclk from the processor (slave mode)
    I hope it helps!
    Regards!
    Bartosz
  • hi Bartosz
    could you tell me how do it?and now i can hear sound,but the sound is not right .ido not know where is wrong,and where i need to change?
  • Qiming,
    no problem, I can try to help you however I need more details about your current problem.
    I do not know what does it mean that the sound is not right.
    Do you hear any jitters or particles? Or the sound is too fast or too slow?
    I need to know what the desired configuration is - for instance sample rate, PLL usage, number of channels, mono or stereo sound, your clocks frequency, is it i2s  etc.
    It would be good if you can share you current configuration of:
    - audio codec registry setup
    - host processor registry setup especially related to the audio port chosen by you
    - your current  pads configuration
    - any change in windows registry
    Can you share any error log as you can see in previous messages on this blog?
    if you can already hear the sound but it is not right in most of cases it is related to the frequency of MCLK, WCLK or BCLK or the synchronization of these clock between audio codec and the host processor.
    Regards!
    Bartosz
  • hi Bartosz Utrata
    thanks for your replay!
    Now i can hear sounds ,but the sounds hearded were too slow,and some noise just like 'zi~zi~zi~zi~ were heard.
    The cpu is seted slave mode ,the TLV320AIC3106 codec is seted master mode.
    Here are addtional code changes i made upon TI WEC7 BSP.
    I added macro define for McASP0 pin mux in  C:\WINCE700\platform\AM33X_BSP\SRC\INC\bsp_padcfg.h
    #define MCASP1_PADS \
    PAD_ENTRY(MCASP0_FSR, MODE(3) | AM335X_PIN_INPUT_PULLDOWN) \
    PAD_ENTRY(MCASP0_ACLKR, MODE(3) | AM335X_PIN_INPUT_PULLDOWN) \
    PAD_ENTRY(MCASP0_AXR1, MODE(3) | AM335X_PIN_INPUT_PULLDOWN) \
    PAD_ENTRY(MCASP0_AHCLKX, MODE(3) | AM335X_PIN_INPUT_PULLDOWN) \
     In C:\WINCE700\platform\AM33X_BSP\SRC\DRIVERS\WAVEDEV2\hwctxt.cpp
            /* .pdir     = */ 0x00000001,                /* only pin-1 is output */
            /* .srctl0   = */ 0x0000000D,                /* serialiser 0 */
            /* .srctl1   = */ 0x0000000E,                /* serialiser 1 */
            /* .srctl2   = */ 0x00000000,                /* serialiser 2 Tx */
            /* .srctl3   = */ 0x00000000,                /* serialiser 3 Rx */
            /* .rmask    = */ 0xFFFFFFFF,
            /* .rfmt     = */ 0x00018074,
            /* .afsrctl  = */ 0x00000112,
            /* .rtdm     = */ 0x00000003,
            /* .rintctl  = */ 0x00000000,
            /* .rstat    = */ 0x000001F7,
            /* .revtctl  = */ 0x00000000,
                /* .aclkrctl  = */ 0x000000AF,
                /* .ahclkrctl = */ 0x00000000,
                /* .rclkchk   = */ 0x00FF0008
            /* .xmask    = */ 0xFFFFFFFF,
            /* .xfmt     = */ 0x00018074,
            /* .afsxctl  = */ 0x00000110,
            /* .xtdm     = */ 0x00000003,
            /* .xintctl  = */ 0x00000000,
            /* .xstat    = */ 0x000001F7,
            /* .xevtctl  = */ 0x00000000,
                /* .aclkxctl 80  = */ 0x00000080,
                /* .ahclkxctl = */ 0x00000000,
                /* .xclkchk   = */ 0x00FF0008
        0x00000001              /*emu free*/
    McaspHwSetupData g_McAspXmtSetup =
        /* .xmask    = */ 0xFFFFFFFF,        // No padding used
        /* .xfmt     = */ 0x00018074,        // MSB first, 16bit, 1bit-delay, writ from DMA, Rot by 16bit pos
        /* .afsxctl  = */ 0x00000110,        // 2TDM, 1bit Rising, EXT FS, bit-width
        /* .xtdm     = */ 0x00000003,        // TDM slots 0 & 1 enabled
        /* .xintctl  = */ 0x0000000F,        // reset any existing status bits
        /* .xstat    = */ 0x000001F7,        // reset any existing status bits
        /* .xevtctl  = */ 0x00000000,        // Generate DMA events
             /* .aclkxctl  = */ 0x00000080,  // Rising, SYNC, EXT, /1 (ASYNC, Rising INTERNAL CLK, div-by-16)
             /* .ahclkxctl = */ 0x00000000,  // EXTERNAL CLK, div-by-1
             /* .xclkchk   = */ 0x00FF0008   // 255-MAX 0-MIN, div-by-256
    McaspHwSetupData g_McAspRcvSetup =
        /* .rmask    = */ 0xFFFFFFFF,        // No padding used
        /* .rfmt     = */ 0x00018074 ,       // MSB 16bit, 1-delay, no pad, CFGBus
        /* .afsrctl  = */ 0x00000110,        // 2TDM, 1bit Rising, INTERNAL FS, word
        /* .rtdm     = */ 0x00000003,        // Slots 0,1
        /* .rintctl  = */ 0x00000000,        // reset any existing status bits
        /* .rstat    = */ 0x000001F7,        // reset any existing status bits
        /* .revtctl  = */ 0x00000000,        // Generate DMA events
             /* .aclkrctl  = */ 0x0000008F,  // Rising INTERNAL CLK (from tx side)
             /* .ahclkrctl = */ 0x00000000,  // INT CLK (from tx side)
             /* .rclkchk   = */ 0x00FF0008   // 255-MAX 0-MIN, div-by-256
     In C:\WINCE700\platform\AM33X_BSP\SRC\DRIVERS\WAVEDEV2\TLV320AIC3106.cpp
    WriteAIC(TLV320AIC3106_PAGESELECT, TLV320AIC3106_PAGESELECT_ZERO); // Select page 0
    WriteAIC(TLV320AIC3106_PAGESELECT_ONE, 0x80); // Reset AIC3106
    Sleep(2);
    WriteAIC( TLV320AIC3106_CDCSAMPRATE, SAMPLE_RATE_DIV); // 2 fs = FS_REF/SAMPLE_RATE_DIV
    WriteAIC( TLV320AIC3106_PLLPROGA, (0x80 | (P & 0x01))); // 3
    // WriteAIC( TLV320AIC3106_PLLPROGB, ((J & 0x3F) << 2)); // 4
    WriteAIC( TLV320AIC3106_PLLPROGB, 0x20); // 4 add by mr wang
    //WriteAIC( TLV320AIC3106_PLLPROGC, R5_VAL);
    // WriteAIC( TLV320AIC3106_PLLPROGD, R6_VAL);
    WriteAIC( TLV320AIC3106_PLLPROGC, 0x1E ); // 5 PLL C <- [D=1920] add by mr wang
    WriteAIC( TLV320AIC3106_PLLPROGD, 0x00 ); // 6 PLL D <- [D=1920] add by mr wang
    WriteAIC( TLV3201AIC3106_CODECDATPATH, (FS_REF|0x08|0x02) ); // 7
    WriteAIC( TLV320AIC3106_ASDICTRLA, (0x80|0x40|0x10)); // 8 0x80|0x40|0x10
    WriteAIC( TLV320AIC3106_ASDICTRLB, 0x00 ); // 9
    WriteAIC( TLV320AIC3106_ASDICTRLC, 0x00 ); // 10
    // WriteAIC( TLV320AIC3106_CDCOVRFLOWFLG, (R & 0x0F) ); // 11
    WriteAIC( TLV320AIC3106_CDCOVRFLOWFLG, 0x01 ); // 11
    // LINE1
    WriteAIC( TLV320AIC3106_LEFTADCPGAGAINCTL, 0 ); // 15
    WriteAIC( TLV320AIC3106_RIGHTADCPGAGAINCTL, 0 ); // 16
    WriteAIC( TLV320AIC3106_LINE1LADCLCTL, 0x04 ); // 19
    WriteAIC( TLV320AIC3106_LINE1RADCRCTL, 0x04 ); // 22
    WriteAIC( TLV320AIC3106_LEFTAGCCTLB, 0 ); // 27
    WriteAIC( TLV320AIC3106_RIGHTAGCCTLB, 0 ); // 30
    WriteAIC( TLV320AIC3106_DACPWROUTDRVCTRL, (0x80|0x40|0x20) ); // 37
    WriteAIC( TLV320AIC3106_HPRCOM_CTL, 0x10 ); // 38
    WriteAIC( TLV320AIC3106_LEFTDACVOLCTRL, leftVol ); // 43
    WriteAIC( TLV320AIC3106_RIGHTDACVOLCTRL, rightVol ); // 44
    // HPOut
    WriteAIC( TLV320AIC3106_DACL1TOHPLOUTCTRL, 0x80 );// 47
    WriteAIC( TLV320AIC3106_HPLOUTLVLCTRL, (0x08|0x01));// 51
    WriteAIC( TLV320AIC3106_DACR1HPROUTVOL, 0x80 );// 64
    WriteAIC( TLV320AIC3106_HPROUTLVLCTRL, (0x08|0x01));// 65
    WriteAIC( TLV320AIC3106_DACL1TOLEFTLOP, 0 ); // 82
    WriteAIC( TLV320AIC3106_LEFTLOPMLVLCTRL, 0 ); // 86
    WriteAIC( TLV320AIC3106_DACR1TORIGHTLOP, 0 ); // 92
    WriteAIC( TLV320AIC3106_RIGHTLOPMLVLCTRL, 0 ); // 93
    WriteAIC( TLV320AIC3106_HPLCOM_OUTPUTLVL_CTL, 0 ); // 58
    WriteAIC( TLV320AIC3106_HPRCOM_OUTPUTLVL_CTL, 0 ); // 72
    WriteAIC( TLV320AIC3106_ADDGPIOCTLB, R101_PLLDIV_OUT ); // 101
    WriteAIC( TLV320AIC3106_CLKGENCTL, R102_PLLCLK_IN_MCLK ); // 102
    m_OutputDevice = WAV_SET_OUTPUT_HDP;
    DEBUGMSG( ZONE_FUNCTION,
    (L"-TLV320AIC3106CodecConfig::EnableHPOut_PLL\r\n"));
    sorry Bartosz Utrata my english is not very good.
  • hi Bartosz Utrata
    sorry my english is not very good! I have boarding my changes in that two files!
    7127.tlv320aic3106.cpp
  • hi Bartosz Utrata
    7536.hwctxt.cpp
  • hi Bartosz Utrata
  • Qiming,
    it is still not enough information to help you. Don't worry about your English. Please try to answer my previous questions as you can.
    If the sound is too slow most probably the frequency of your bit clock - BCLK is too low, try to increase it. How to do it? It depends what is the source frequency of your BCLK how the divider is setup etc.
    If you hear  "zi zi zi"  :-) must probably it is "buffer underrun" but it is hard to make sure about it if I do not see the error log.
    You can also try to setup audio codec as a slave and processor as master. See this documantation:
    http://www.ti.com/lit/an/slaa469/slaa469.pdf
    Regards!
    Bartosz
  • Bartosz Utrata
     thanks for your help!
    now i can understand how to set the master and slave mode . The code is provided by TI, the inside of the set ,cpu is slave mode and the audio is master mode .tomorrow i will try it as you say.
    Thanks again ! Can i know where are you from ?I am from china.
  • Qiming,
    I'm glad I could help you. I'm from Poland.
    Regards!
    Bartosz
  • Hi weidong zhou
    can you tell me the other changes of zhe codes?Now i can hear sounds,but the sounds heared slowly,and always heared "zi,zi,zi".
    please!!
  • Hi Bartosz Utrata
    I haved tested my development board.the BCLK = 48k HZ  MCLK = 1.56M HZ . but the sound is also slowly!
  • Hi Qiming,
    as I mentioned in one of my previous posts most probably it is related to BCLK clock which frequency defines how fast the data is being sent to the codec. Please check the frequency of your BLCK and BCLK divider set up. Try to increase the frequency.
    Regards!
    Bartosz
  • Qiming,
    and I don't think that the frequency of 48kHz is your BLCK.
    It is rather a sample rate - fs.
    Please check audio codec documantation and see how to calculate BCLK frequency.
    Regards!
    Bartosz
  • hi Bartosz Utrata
    This is my debugging information .
    2308.debuging information.txt
    please help me to have a look!!
  • Quming.
    as I predicted. This is related to your clocks and mode configuration:
    Buffer underrun - DMA buffer is empty when you try to send a data to the codec. The processor did not finish sending a data before WCLK frame finished.
    DMA error = buffer overflow - the processor tried to send more data in one WCLK frame than DMA capacity.
    There can be two possible reasons:
    1. WCLK and BCLK are not configured well
    2. There is a problem with clocks synchronization between a processor and audio codec
    I had exactly the same issue and in my case it was a problem with a synchronization. The clock bits were delayed from time to time and the reason were other interrupts - especially graphic interrupts that caused a delay.
    To solve it I have setup slave mode configuration - both WCLK and BCLK clock where generated by the processor not by the codec.
    Please see the following documents to setup slave mode well:
    1. Configuration of you host processor especially mcasp section to see how to setup registers to generate WCLK and MCLK with a desired frequency. Please note that you also need to activate more mcasp pins there to send a clock bit from a processor to the audio codec.
    2. See your audio codec documentation to change a registry, stop generating WCLK and BCLK and configure your audio codec to receive  WCLK and BCLK from the processor. As I remember it is only one register.
    By setting up a slave mode you prevent from de-synchronization of the WCLK and BCLK between processor and audio codec . It helped in my case.
    Regards!
    Bartosz
  • Qiming,
    sorry I have edited my previous post. I wrote master mode but I had in mind SLAVE mode.
    Slave = all three clocks MCLK, WCLK, BCLK are generated by the processor.
    Bartosz
  • Hi Bartosz:
    I set the cpu is master mode,and the codes as slave mode.but  i can not hear the sound.can you tell me how to do it .and i want to know where are you changed in the hwctxt .cpp .
  • Hi Bartosz:
    This is my changes.please help me to have a look.
    PAD_ENTRY(MCASP0_FSR, MODE(3) | AM335X_PIN_OUTPUT) \
    PAD_ENTRY(MCASP0_ACLKR, MODE(3) | AM335X_PIN_OUTPUT) \
    PAD_ENTRY(MCASP0_AXR1, MODE(3) | AM335X_PIN_OUTPUT) \
     /* .pdir     = */ 0x14000001,
    /* .afsxctl  = */ 0x00000112,
    /* .aclkxctl 80  = */ 0x000000AF,
  • you may try the similar mode settings as what Bartosz did. osc. on your codec may not work well and cause playback issue. clock feeding from CPU may improve it.
