Other Parts Discussed in Thread: TVP5158
TI8148DMEO board TVP5158 use McAsp0, and our board used McAsp1, the hope can someone help me, I now thought other solution.
I use 8148 platform, packages version number is DVRRDK_02. 00.00.23. Use TVP5158 recorded in files.Our tvp5158 is taken up in McAsp1 it.
Error information:
1: Set Audio Storage Path
2: Start Audio Capture
3: Stop Audio Capture
4: Start Audio Playback
5: Stop Audio Playback
6: Set Audio Capture Configuration
p: Previous Menu
Enter Choice: 1
Enter file write path : /home
Selected file write path [/home]
Store path set to /home
Trying to set storage path to /home
Audio Settings Menu
p: Previous Menu
Enter Choice: 2
Select AUDIO CAPTURE CH ID [0 .. 3] : 0
Selected CH ID = 0
Removing /home/01/record01.pcm
Removing /home/01/record02.pcm
Removing /home/01/record03.pcm
Removing /home/01/record04.pcm
Removing /home/01/record05.pcm
Removing /home/01/record06.pcm
Removing /home/01/record07.pcm
Removing /home/01/record08.pcm
Removing /home/01/record09.pcm
Removing /home/01/record10.pcm
AUDIO >> opened plughw:1,0 device
[ SOUND ] set codec DAI configuration: sound/soc/davinci/davinci-evm.c : evm_hw_params : 102 name[TVP5158AUDIO]
[ SOUND ] set cpu DAI configuration: sound/soc/davinci/davinci-evm.c : evm_hw_params : 119 name[TVP5158AUDIO]
Audio Settings Menu
p: Previous Menu
Enter Choice: Opened /home/01/ [ SOUND ] : sound/soc/davinci/davinci-mcasp.c : davinci_mcasp_start : 410
[ SOUND ] : sound/soc/davinci/davinci-mcasp.c : mcasp_start_rx : 352
[ AUDIO ] : sound/core/pcm_lib.c : 1733 : name=subdevice #0
record01.pcm for recording..
capture write error (DMA or IRQ trouble?)
AUDIO >> read f [ SOUND ] : sound/soc/davinci/davinci-mcasp.c : davinci_mcasp_stop : 440
[ SOUND ] : sound/soc/davinci/davinci-mcasp.c : mcasp_stop_rx : 426
rom audio interface failed (Input/output error)
AUDIO >> CAPTURE ERROR Input/output error, capture wont continue...
AUDIO >> Device closed
Below is my fix:
1. arch/arm/mach-omap2/devices.c static struct snd_platform_data ti8148_evm_snd_data_tvp5158 = {
- .tx_dma_offset = 0x46000000,
- .rx_dma_offset = 0x46000000,
+ .tx_dma_offset = 0x46400000,
+ .rx_dma_offset = 0x46400000,
.op_mode = DAVINCI_MCASP_IIS_MODE,
.num_serializer = ARRAY_SIZE(ti8148_iis_serializer_direction_tvp5158),
.tdm_slots = 4, /* Number of channels in TVP5158 - Set 16 for 16 channel capture */
+static struct resource ti81xx_mcasp1_resource[] = {
+ .name = "mcasp1",
+ .start = TI81XX_ASP1_BASE,
+ .end = TI81XX_ASP1_BASE + (SZ_1K * 12) - 1,
+ .flags = IORESOURCE_MEM,
+ /* TX event */
+ .start = TI81XX_DMA_MCASP1_AXEVT,
+ .end = TI81XX_DMA_MCASP1_AXEVT,
+ .flags = IORESOURCE_DMA,
+ /* RX event */
+ .start = TI81XX_DMA_MCASP1_AREVT,
+ .end = TI81XX_DMA_MCASP1_AREVT,
+static struct platform_device ti81xx_mcasp1_device = {
+ .name = "davinci-mcasp",
+ .id = 1,
+ .num_resources = ARRAY_SIZE(ti81xx_mcasp1_resource),
+ .resource = ti81xx_mcasp1_resource,
void __init ti81xx_register_mcasp(int id, struct snd_platform_data *pdata)
ti81xx_mcasp_device.dev.platform_data = pdata;
platform_device_register(&ti81xx_mcasp_device);
- ti81xx_mcasp0_device.dev.platform_data = &ti8148_evm_snd_data_tvp5158;
- platform_device_register(&ti81xx_mcasp0_device);
+ ti81xx_mcasp1_device.dev.platform_data = &ti8148_evm_snd_data_tvp5158;
+ platform_device_register(&ti81xx_mcasp1_device);
2 . sound/soc/davinci/davinci-evm.c
static struct snd_soc_dai_link ti81xx_evm_dai_tvp5158 = {
.name = "TVP5158AUDIO",
.stream_name = "TVP-PCM",
- .cpu_dai_name= "davinci-mcasp.0",
+ .cpu_dai_name= "davinci-mcasp.1",
.codec_dai_name = "tvp5158-hifi",
.platform_name ="davinci-pcm-audio",
.codec_name = "tvp5158-codec.1-0058",
3 sound/soc/davinci/davinci-mcasp.c
static struct snd_soc_dai_driver davinci_mcasp_dai[] = {
- .name = "davinci-mcasp.0",
+ .name = "davinci-mcasp.1",
.playback = {
.channels_min = 2,
.channels_max = 2,
@@ -974,7 +980,7 @@ static struct snd_soc_dai_driver davinci_mcasp_dai[] = {
- "davinci-mcasp.1",
+ "davinci-mcasp.0",
.playback = {
.channels_min = 1,
.channels_max = 384,
