DM8148 USB port connecting to USB3.0 HDD issue
Our customer use DM8148 (S/W: RFX_RDK0.4) to connecting to USB3.0 HDD,
They use
  1. TOSHIBA Canvio USB3.0 750GB
  2. ADATA HD710 USB3.0 750GB
But only ADATA can mount to system, the Toshiba willbe reset by driver.
Attached file is the system log file.
BR,
Shine
Ubuntu 11.04 ubuntu-dm814x-evm ttyO0
ubuntu-dm814x-evm login: user
Password:
Welcome to Ubuntu 11.04 (GNU/Linux 2.6.37 armv7l)
 * Documentation:  https://help.ubuntu.com/
user@ubuntu-dm814x-evm:~$ df
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/root              3747580   1268472   2288740  36% /
devtmpfs                294284       292    293992   1% /dev
none                    294376         0    294376   0% /dev/shm
tmpfs                   294376        28    294348   1% /tmp
none                    294376        56    294320   1% /var/run
none                    294376         0    294376   0% /var/lock
tmpfs                   294376         0    294376   0% /var/tmp
tmpfs                   294376       124    294252   1% /var/log
/dev/mmcblk0p1           71133      8187     62946  12% /media/boot
user@ubuntu-dm814x-evm:~$ top
top - 04:16:41 up 1 min,  1 user,  load average: 1.77, 0.79, 0.30
Tasks: 127 total,   1 running, 126 sleeping,   0 stopped,   0 zombie
Cpu(s):  1.6%us,  1.6%sy,  0.0%ni,  0.0%id, 96.7%wa,  0.0%hi,  0.0%si,  0.0%st
Mem:    588756k total,   147196k used,   441560k free,     4912k buffers
Swap:        0k total,        0k used,        0k free,    65620k cached
  PID USER      PR  NI  VIRT  RES  SHR S %CPU %MEM    TIME+  COMMAND
  220 root      20   0  1668  620  516 S  1.3  0.1   0:01.61 udevadm
  692 user      20   0  2208 1064  792 R  1.3  0.2   0:00.20 top
  373 root      20   0 20776 6716 1628 S  0.3  1.1   0:00.59 python
  458 root      20   0 11452 7080 3096 S  0.3  1.2   0:00.72 python
    1 root      20   0  3060 1488 1016 S  0.0  0.3   0:01.45 init
    2 root      20   0     0    0    0 S  0.0  0.0   0:00.00 kthreadd
    3 root      20   0     0    0    0 S  0.0  0.0   0:00.14 ksoftirqd/0
    4 root      20   0     0    0    0 S  0.0  0.0   0:00.13 kworker/0:0
    5 root      20   0     0    0    0 S  0.0  0.0   0:00.00 kworker/u:0
    6 root       0 -20     0    0    0 S  0.0  0.0   0:00.00 khelper
    7 root     -51   0     0    0    0 S  0.0  0.0   0:00.06 irq/72-serial i
    8 root     -51   0     0    0    0 S  0.0  0.0   0:00.00 irq/73-serial i
    9 root     -51   0     0    0    0 S  0.0  0.0   0:00.00 irq/74-serial i
   10 root     -51   0     0    0    0 S  0.0  0.0   0:00.00 irq/44-serial i
   11 root     -51   0     0    0    0 S  0.0  0.0   0:00.00 irq/45-serial i
   12 root     -51   0     0    0    0 S  0.0  0.0   0:00.00 irq/46-serial i
   13 root       0 -20     0    0    0 S  0.0  0.0   0:00.00 mboxd
user@ubuntu-dm814x-evm:~$ dmesg
Linux version 2.6.37 (johnson@PC) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #30 Thu Apr 5 16:50:41 CST 2012
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: ti8148evm
TI81xx: reserved VRAM size = 106954752 at -1385168896
Memory policy: ECC disabled, Data cache writeback
OMAP chip is TI8148 2.0
On node 0 totalpages: 150016
free_area_init_node: node 0, pgdat c052a748, node_mem_map c0565000
  Normal zone: 728 pages used for memmap
  Normal zone: 0 pages reserved
  Normal zone: 92456 pages, LIFO batch:31
  HighMem zone: 930 pages used for memmap
  HighMem zone: 55902 pages, LIFO batch:15
pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: [0] 0
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 148358
Kernel command line: console=ttyO0,115200n8 serialtty=ttyO0 root=/dev/mmcblk0p2 rw mem=364M mem=324M@0x9F900000 earlyprink notifyk.vpssm3_sva=0xBF900000 vmalloc=500M vram=102M  noinitrd rootfstype=ext3 ip=off rootwait
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 364MB 222MB = 586MB total
Memory: 588568k/588568k available, 115944k reserved, 227328K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
    vmalloc : 0xd7000000 - 0xf8000000   ( 528 MB)
    lowmem  : 0xc0000000 - 0xd6c00000   ( 364 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .init : 0xc0008000 - 0xc0037000   ( 188 kB)
      .text : 0xc0037000 - 0xc04e6000   (4796 kB)
      .data : 0xc04e6000 - 0xc052b380   ( 277 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:375
IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
Total of 128 interrupts on 1 active controller
GPMC revision 6.0
Trying to install interrupt handler for IRQ368
Trying to install interrupt handler for IRQ369
Trying to install interrupt handler for IRQ370
Trying to install interrupt handler for IRQ371
Trying to install interrupt handler for IRQ372
Trying to install interrupt handler for IRQ373
Trying to install interrupt handler for IRQ374
Trying to install type control for IRQ375
Trying to set irq flags for IRQ375
OMAP clockevent source: GPTIMER1 at 20000000 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 598.01 BogoMIPS (lpj=2990080)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
omap_voltage_early_init: voltage driver support not added
regulator: core version 0.5
regulator: dummy:
NET: Registered protocol family 16
OMAP GPIO hardware version 0.1
ver. 2012.0405-01 (Johnson)
omap_mux_init: Add partition: #1: core, flags: 4
_omap_mux_get_by_name: Could not find signal i2c2_scl.i2c2_scl
_omap_mux_get_by_name: Could not find signal i2c2_sda.i2c2_sda
registered ti814x_vpss device
registered TI814x on-chip HDMI device
DEBUG: 00000630 0000e90c 00000634 da321800
registered ti81xx_vidout device
Debugfs: Only enabling/disabling deep sleep and wakeup timer is supported now
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
registerd cppi-dma Intr @ IRQ 17
Cppi41 Init Done
omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
omap_i2c omap_i2c.2: bus 2 rev4.0 at 100 kHz
omap_i2c omap_i2c.3: bus 3 rev4.0 at 100 kHz
Advanced Linux Sound Architecture Driver Version 1.0.23.
Switching to clocksource gp timer
musb-hdrc: version 6.0, host, debug=0
musb-hdrc musb-hdrc.0: dma type: dma-cppi41
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
musb-hdrc musb-hdrc.0: MUSB HDRC host driver
musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: MUSB HDRC host driver
usb usb1: Manufacturer: Linux 2.6.37 musb-hcd
usb usb1: SerialNumber: musb-hdrc.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
musb-hdrc musb-hdrc.0: USB Host mode controller at d701e000 using DMA, IRQ 18
Registered /proc/driver/musb_hdrc.0
musb-hdrc musb-hdrc.1: dma type: dma-cppi41
musb-hdrc musb-hdrc.1: MUSB HDRC host driver
musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: MUSB HDRC host driver
usb usb2: Manufacturer: Linux 2.6.37 musb-hcd
usb usb2: SerialNumber: musb-hdrc.1
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
musb-hdrc musb-hdrc.1: USB Host mode controller at d7028800 using DMA, IRQ 19
Registered /proc/driver/musb_hdrc.1
NET: Registered protocol family 2
IP route cache hash table entries: 16384 (order: 4, 65536 bytes)
TCP established hash table entries: 65536 (order: 7, 524288 bytes)
TCP bind hash table entries: 65536 (order: 6, 262144 bytes)
TCP: Hash tables configured (established 65536 bind 65536)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NetWinder Floating Point Emulator V0.97 (double precision)
PMU: registered new PMU device of type 0
omap-iommu omap-iommu.0: ducati registered
omap-iommu omap-iommu.1: sys registered
highmem bounce pool size: 64 pages
NTFS driver 2.1.29 [Flags: R/W].
JFFS2 version 2.2. (NAND) ? 2001-2006 Red Hat, Inc.
fuse init (API version 7.15)
msgmni has been set to 705
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
[drm] Initialized drm 1.1.0 20060810
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
console [ttyO0] enabled
omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
brd: module loaded
loop: module loaded
davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
davinci_mdio davinci_mdio.0: detected phy mask fffffffc
davinci_mdio.0: probed
davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver unknown
usbcore: registered new interface driver cdc_acm
cdc_acm: v0.26:USB Abstract Control Model driver for USB modems and ISDN adapters
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
i2c /dev entries driver
Linux video capture interface: v2.00
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v1.0.0)
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
notify_init : notify drivercreated  for  remote proc id 2 at physical Address 0xbf900000
usbcore: registered new interface driver snd-usb-audio
Failed to add route Mic Bias 2V->MIC3L
dapm: tlv320aic3x-codec.1-0018: configuring unknown pin MONO_LOUT
asoc: tlv320aic3x-hifi <-> davinci-mcasp.2 mapping ok
ALSA device list:
  #0: TI81XX EVM
TCP cubic registered
NET: Registered protocol family 17
Registering the dns_resolver key type
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
omap_voltage_late_init: Voltage driver support not added
Power Management for TI81XX.
cpsw: Disable CPRGMII internal delay.
Detected MACID=00:18:32:da:0c:e9
qrcode 001832da0ce9
omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:01 UTC (946684801)
Waiting for root device /dev/mmcblk0p2...
usb 1-1: new high speed USB device using musb-hdrc and address 2
mmc0: new high speed SDHC card at address 0002
mmcblk0: mmc0:0002 00000 3.70 GiB
 mmcblk0: p1 p2
EXT3-fs: barriers not enabled
kjournald starting.  Commit interval 5 seconds
EXT3-fs (mmcblk0p2): warning: mounting fs with errors, running e2fsck is recommended
usb 1-1: New USB device found, idVendor=05e3, idProduct=0608
usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
usb 1-1: Product: USB2.0 Hub
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
EXT3-fs (mmcblk0p2): using internal journal
EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode
VFS: Mounted root (ext3 filesystem) on device 179:2.
devtmpfs: mounted
Freeing init memory: 188K
usb 1-1.2: new high speed USB device using musb-hdrc and address 3
usb 1-1.2: New USB device found, idVendor=0480, idProduct=a006
usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-1.2: Product: External USB 3.0
usb 1-1.2: Manufacturer: Toshiba
usb 1-1.2: SerialNumber: 2010120606171
scsi0 : usb-storage 1-1.2:1.0
SysLink version : 2.00.05.85
SysLink module created on Date:Feb  6 2012 Time:17:53:17
scsi 0:0:0:0: Direct-Access     TOSHIBA  External USB 3.0 0001 PQ: 0 ANSI: 6
sd 0:0:0:0: Attached scsi generic sg0 type 0
sd 0:0:0:0: [sda] 1465149168 512-byte logical blocks: (750 GB/698 GiB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Mode Sense: 1f 00 00 08
sd 0:0:0:0: [sda] Assuming drive cache: write through
NET: Registered protocol family 10
<30>udev[131]: starting version 167
<30>udev[135]: renamed network interface eth0 to eth6
 sda: sda1
sd 0:0:0:0: [sda] Attached SCSI disk
ths8200: Unknown symbol TI81xx_un_register_display_panel (err 0)
ths8200: Unknown symbol TI81xx_register_display_panel (err 0)
usb 1-1.2: reset high speed USB device using musb-hdrc and address 3
fb0: ti81xxdrmfb frame buffer device
drm: registered panic notifier
[drm] Initialized ti81xx-drm 0.1.0 20110912 on minor 0
THS8200  : xxxxxx Enter THS8200 initial block. xxxxxx
THS8200  : xxx Set Common Registers. xxx
THS8200  : xxx Enter vga_set_timings. xxx
THS8200  : Timing info: 1920x1080 -> mode 8.
THS8200  : xxx Set Unique Registers. xxx
THS8200  : Write 0xc0 to Reg 0x3 (err=0).
THS8200  : Write 0xc1 to Reg 0x3 (err=0).
THS8200  : xxxxxx Leave THS8200 initial block. xxxxxx
CMEMK module: built on Feb  6 2012 at 17:53:04
  Reference Linux version 2.6.37
  File /home/johnson/d510c/ezsdk5_03_01_15/component-sources/linuxutils_3_21_00_04/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
CMEM Range Overlaps Kernel Physical - allowing overlap
CMEM phys_start (0x96c00000) overlaps kernel (0x80000000 -> 0xa4a00000)
allocated heap buffer 0xe3000000 of size 0x1400000
heap fallback enabled - will try heap if pool buffer is not available
cmemk initialized
SDMAK module: built on Feb  6 2012 at 18:07:06
  File /home/johnson/d510c/ezsdk5_03_01_15/component-sources/omx_05_02_00_30/src/../examples/ti/omx/demos/rfxdec_tiling/rfxtiling.c
EDMAK Debug: rfxtiling registered major = 250
Creating mutex...
THS8200  :
THS8200  : xxx Enter vga_panel_disable. xxx
THS8200  : xxx Enter vga_panel_enable. xxx
VPSS_DCTRL: failed to set 65000KHz clock
Console: switching to colour frame buffer device 128x48
user@ubuntu-dm814x-evm:~$ sudo poweroff
Broadcast message from user@ubuntu-dm814x-evm
        (/dev/ttyO0) at 4:19 ...
The system is going down for power off NOW!
user@ubuntu-dm814x-evm:~$ udevd[131]: worker [135] did not accept message -1 (Connection refused), kill it
udevd[131]: worker [136] did not accept message -1 (Connection refused), kill it
udevd[131]: worker [137] did not accept message -1 (Connection refused), kill it
udevd[131]: worker [138] did not accept message -1 (Connection refused), kill it
udevd[131]: worker [139] did not accept message -1 (Connection refused), kill it
udevd[131]: worker [140] did not accept message -1 (Connection refused), kill it
udevd[131]: worker [141] did not accept message -1 (Connection refused), kill it
udevd[131]: worker [143] did not accept message -1 (Connection refused), kill it
udevd[131]: worker [155] did not accept message -1 (Connection refused), kill it
udevd[131]: worker [156] did not accept message -1 (Connection refused), kill it
udevd[131]: worker [157] did not accept message -1 (Connection refused), kill it
udevd[131]: worker [158] did not accept message -1 (Connection refused), kill it
udevd[131]: worker [159] did not accept message -1 (Connection refusinit: ssh main process (112) terminated with status 255
init: dbus main process (120) killed by TERM signal
init: tty4 main process (328) killed by TERM signal
init: tty5 main process (329) killed by TERM signal
init: tty2 main process (332) killed by TERM signal
init: tty3 main process (334) killed by TERM signal
init: tty6 main process (336) killed by TERM signal
init: ttyO0 main process (477) killed by TERM signal
init: tty1 main process (479) killed by TERM signal
init: Disconnected from system bus
init: plymouth-upstart-bridge main process (711) terminated with status 1
 * Stopping Citrix USB daemon [ OK ]
 * Stopping Network connection manager wicd                              [ OK ]
Checking for running unattended-upgrades:  * Asking all remaining processes to terminate...                                                              [ OK ]
 * Killing all remaining processes...                                    [fail]
 * Deconfiguring network interfaces...                                   [ OK ]
 * Unmounting temporary filesystems...                                   [ OK ]
 * Deactivating swap...                                                  [ OK ]
 * Unmounting local filesystems...                                       [ OK ]
 * Will now halt
PMIC Reg0x3F=
0x14
