HDMI Display issue with omap4460 running ICS
I am currently running ICS on omap4460 Panda Board.Everything works fine apart from the fact that when even i connect a display to HDMI then i see UI being centered and top and bottom few inches of the display are blacked out.This happens only with HDMI not with DVI. I have tried changing everything from u-boot parameters to harcoding display width and height in hdmi driver but nothing has worked for me. Can you please help me out on this.
Vinay
  • Hi Vinay,
    As per my understanding on ICS , when HDMI TV is connected UI gets cloned. The hardware composer would automatically pick the best timings based on the current resolution of the frame buffer content and centers it accordingly over the HDMI TV. If the frame buffer/UI content resolution matches with the HDMI timings chosen, then you would see UI occupying the full screen dimensions of the HDMI TV.
    If you can modify the Hardware Composer to pick the timings matching with the resolution of UI, then it would occupy full screen. Other option is to scale the output by configuring the overlay parameters to match with the HDMI TV resolution chosen.
    Thanks & Best Regards,
    Venkat
    Can you specify where exactly i can change the overlay parameters so that i can scale the output?
    Vinay
  • What is the resolution of HDMI TV you are using?
    The DSS related parameters are available under path /sys/devices/platform/omapdss. You may want to change these parameters as per your requirement.
    I am using View sonic VA1912wb monitor with which has 1440x900 resolution.
    It would be helpful if you can specify the exact parameter to change as i am new to video drivers .
    Vinay
  • Hi Vinay,
    Could you please provide us the output of the following sysfs commands to exactly understand the current configuration of the overlays in your set up so that we can suggest appropriately?
    Run the following commands and share the output.
    cat /sys/devices/platform/omapdss/overlay2/*
    cat /sys/devices/platform/omapdss/overlay0/*
    cat /sys/devices/platform/omapdss/overlay1/*
    cat /sys/devices/platform/omapdss/display0/*
    cat /sys/devices/platform/omapdss/display1/*
    Venkat
  • Hi ,
    Below is the output
    root@android:/ # cat /sys/devices/platform/omapdss/overlay2/*
    1
    255
    1280,672
    tv
    vid2
    640,336
    0,60
    0
    1280
    1..255
    1..255
    2
    root@android:/ # cat /sys/devices/platform/omapdss/overlay0/*
    1
    255
    1280,720
    lcd2
    gfx
    1280,720
    0,0
    1
    0
    1..255
    1..255
    1
    root@android:/ # cat /sys/devices/platform/omapdss/overlay1/*
    1
    255
    1280,672
    lcd2
    vid1
    1280,672
    0,0
    0
    1280
    1..255
    1..255
    0
    root@android:/ # cat /sys/devices/platform/omapdss/display0/*
    /sys/devices/platform/omapdss/display0/driver: invalid length
    1
    /sys/devices/platform/omapdss/display0/mirror: invalid length
    dvi
    /sys/devices/platform/omapdss/display0/power: invalid length
    /sys/devices/platform/omapdss/display0/rotate: invalid length
    /sys/devices/platform/omapdss/display0/subsystem: invalid length
    0
    76800,1280/110/20/40,720/5/20/5
    DRIVER=generic_dpi_panel
    1
    1|root@android:/ # cat /sys/devices/platform/omapdss/display1/*
    0
    /sys/devices/platform/omapdss/display1/mirror: invalid length
    hdmi
    /sys/devices/platform/omapdss/display1/power: invalid length
    /sys/devices/platform/omapdss/display1/rotate: invalid length
    0
    frame_packing
    /sys/devices/platform/omapdss/display1/subsystem: invalid length
    0
    25175,640/16/48/96,480/10/33/2
    DRIVER=hdmi_panel
    1
    /sys/devices/platform/omapdss/display1/wss: invalid length
  • Vinay,
    Looks like the aspect ratio of your framebuffer and your TV doesnt match.
    Framebuffer resolution aspect ration seems to be 1280/720 = 1.777
    The TV resolution aspect ratio is 1440/900 = 1.6
  • Can you type the following command on your terminal and let us know the output?
    #getprop persist.hwc.mirroring.region
    I do not see any output, seems to be null.
    Vinay
  • I am surprised to see that the HDMI timings picked for your TV is VGA. Try running the following command on your terminal and let us the values as suggested by Venkat again.
    # stop
    # setprop persist.hwc.mirroring.region "0:0:1280:720"
    # start
  • Here is the output
    1
    255
    1280,672
    tv
    vid2
    640,336
    0,60
    0
    1280
    1..255
    1..255
    2
    1
    255
    1280,720
    lcd2
    gfx
    1280,720
    0,0
    1
    0
    1..255
    1..255
    1
    1
    255
    1280,672
    lcd2
    vid1
    1280,672
    0,0
    0
    1280
    1..255
    1..255
    0
    1
    dvi
    0
    1
    0
    hdmi
    0
    frame_packing
    0
    DRIVER=hdmi_panel
    1
    1|root@android:/ #
  • Hi Vinay,
    Can you tell me if it is in cloning mode or docking mode for you? What I mean is that all the content including status bar which is shown on DVI is being shown even on HDMI TV for you?
    If so, can you also provide the output of cat /sys/devices/platform/omapdss/overlay3/* . Also, share the logcat output with us.
    Venkat
  • Provide us the output of logcat after booting the board.
    #logcat
  • Here is the output of overlay3
    1
    255
    1280,720
    tv
    vid3
    640,360
    0,60
    1
    0
    1..255
    1..255
    output of logcat
    root@android:/ #
    root@android:/ #
    root@android:/ # logcat
    --------- beginning of /dev/log/main
    I/DEBUG   (   84): debuggerd: Mar 29 2012 01:55:41
    E/uim-sysfs(   81): uim: Inside main
    E/uim-sysfs(   81): uim:BT/FM/GPS would be unavailable on system
    --------- beginning of /dev/log/system
    I/Vold    (   78): Vold 2.1 (the revenge) firing up
    D/Vold    (   78): Volume external_sdcard state changing -1 (Initializing) -> 0 (No-Media)
    D/Vold    (   78): Volume external_usb_disk state changing -1 (Initializing) -> 0 (No-Media)
    I/Netd    (   83): Netd 1.0 starting
    D/Vold    (   78): Volume external_sdcard state changing 0 (No-Media) -> 2 (Pending)
    D/Vold    (   78): Volume external_sdcard state changing 2 (Pending) -> 1 (Idle-Unmounted)
    I/        (   88): ServiceManager: 0x3ee910
    I/SurfaceFlinger(   86): SurfaceFlinger is starting
    I/SurfaceFlinger(   86): SurfaceFlinger's main thread ready to run. Initializing graphics H/W...
    I/        (   89): ServiceManager: 0x655958
    D/skia    (   87): SkGraphics::Init() - BLTsville (CPU) dlopen success
    D/AndroidRuntime(   87):
    D/AndroidRuntime(   87): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<<<<
    D/AndroidRuntime(   87): CheckJNI is ON
    I/AudioFlinger(   89): Loaded primary audio interface from Blaze audio HW HAL (audio)
    I/AudioFlinger(   89): Using 'Blaze audio HW HAL' (audio.primary) as the primary audio interface
    I/AudioFlinger(   89): Loaded a2dp audio interface from A2DP Audio HW HAL (audio)
    I/CameraService(   89): CameraService started (pid=89)
    D/libEGL  (   86): loaded /system/lib/egl/libGLES_android.so
    D/libEGL  (   86): loaded /vendor/lib/egl/libEGL_POWERVR_SGX540_120.so
    D/libEGL  (   86): loaded /vendor/lib/egl/libGLESv1_CM_POWERVR_SGX540_120.so
    D/libEGL  (   86): loaded /vendor/lib/egl/libGLESv2_POWERVR_SGX540_120.so
    W/SurfaceFlinger(   86): ro.sf.lcd_density not defined, using 160 dpi by default.
    I/SurfaceFlinger(   86): EGL informations:
    I/SurfaceFlinger(   86): # of configs : 33
    I/SurfaceFlinger(   86): vendor    : Android
    I/SurfaceFlinger(   86): version   : 1.4 Android META-EGL
    I/SurfaceFlinger(   86): extensions: EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_base EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_KHR_fence_sync EGL_ANDROID_image_native_buffer EGL_ANDROID_image_native_buffer
    I/SurfaceFlinger(   86): Client API: OpenGL ES
    I/SurfaceFlinger(   86): EGLSurface: 8-8-8-8, config=0x1
    I/SurfaceFlinger(   86): OpenGL informations:
    I/SurfaceFlinger(   86): vendor    : Imagination Technologies
    I/SurfaceFlinger(   86): renderer  : PowerVR SGX 540
    I/SurfaceFlinger(   86): version   : OpenGL ES-CM 1.1
    I/SurfaceFlinger(   86): extensions: GL_OES_byte_coordinates GL_OES_fixed_point GL_OES_single_precision GL_OES_matrix_get GL_OES_read_format GL_OES_compressed_paletted_texture GL_OES_point_sprite GL_OES_point_size_array GL_OES_matrix_palette GL_OES_draw_texture GL_OES_query_matrix GL_OES_texture_env_crossbar GL_OES_texture_mirrored_repeat GL_OES_texture_cube_map GL_OES_blend_subtract GL_OES_blend_func_separate GL_OES_blend_equation_separate GL_OES_stencil_wrap GL_OES_extended_matrix_palette GL_OES_framebuffer_object GL_OES_rgb8_rgba8 GL_OES_depth24 GL_OES_stencil8 GL_OES_compressed_ETC1_RGB8_texture GL_OES_mapbuffer GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_multi_draw_arrays GL_OES_required_internalformat GL_IMG_read_format GL_IMG_texture_compression_pvrtc GL_IMG_texture_format_BGRA8888 GL_EXT_texture_format_BGRA8888 GL_OES_egl_sync GL_IMG_vertex_array_object
    I/SurfaceFlinger(   86): GL_MAX_TEXTURE_SIZE = 2048
    I/SurfaceFlinger(   86): GL_MAX_VIEWPORT_DIMS = 2048 x 2048
    I/SurfaceFlinger(   86): flags = 00010000
    I/ti_hwc  (   86): clone region is set to (0,0) to (1280,720)
    D/ti_hwc  (   86): #0: 640x480 59Hz
    D/ti_hwc  (   86): #1: 640x480 72Hz
    D/ti_hwc  (   86): #2: 640x480 75Hz
    D/ti_hwc  (   86): #3: 800x600 56Hz
    D/ti_hwc  (   86): #4: 800x600 60Hz
    D/ti_hwc  (   86): #5: 800x600 72Hz
    D/ti_hwc  (   86): #6: 800x600 75Hz
    D/ti_hwc  (   86): #7: 1024x768 60Hz
    D/ti_hwc  (   86): #8: 1024x768 70Hz
    D/ti_hwc  (   86): #9: 1024x768 75Hz
    D/ti_hwc  (   86): #10: 1280x1024 75Hz
    D/ti_hwc  (   86): #11: 1280x1024 60Hz
    D/ti_hwc  (   86): #12: 1280x960 60Hz
    D/ti_hwc  (   86): #13: 1152x864 75Hz
    D/ti_hwc  (   86): #14: 1024x768 85Hz
    D/ti_hwc  (   86): #15: 800x600 85Hz
    D/ti_hwc  (   86): picking #0
    D/DOMX    (   89): hardware/ti/domx/domx/omx_rpc/src/omx_rpc.c:334    RPC_CallbackThread()
    D/DOMX    (   89): ERROR: failed check:0 - returning error: 0x81009 - Remote processor fatal error
    E/CameraHal(   89): (65db88)   hardware/ti/omap4xxx/camera/OMXCameraAdapter/OMXCameraAdapter.cpp:3889 processEvent - Waiting for state switch has been aborted
    D/DOMX    (   89): hardware/ti/domx/domx/omx_proxy_common/src/omx_proxy_common.c:1229    __PROXY_SetParameter()
    D/DOMX    (   89): ERROR: failed check:(eError == OMX_ErrorNone) || (eError == OMX_ErrorNoMore) - returning error: 0x80001009 - Error returned from OMX API in ducati
    D/DOMX    (   89): hardware/ti/domx/omx_proxy_component/omx_camera/src/omx_proxy_camera.c:407    CameraSetParam()
    D/DOMX    (   89): ERROR:  CameraSetParam: Error in SetParam 0x80001009
    D/DOMX    (   89): hardware/ti/domx/domx/omx_rpc/src/omx_rpc_stub.c:275    RPC_FreeHandle()
    D/DOMX    (   89): ERROR: DOMX Write failed 0xffffffff -1
    D/DOMX    (   89): ERROR: failed check:status >= 0 && errno != ENXIO - returning error: 0x81009 - Write failed due ducati in faulty state
    D/DOMX    (   89): hardware/ti/domx/domx/omx_proxy_common/src/omx_proxy_common.c:1936    PROXY_ComponentDeInit()
    D/DOMX    (   89): ERROR: RPC function returned error 0x81009
    D/DOMX    (   89): ERROR: failed check:(eError == OMX_ErrorNone) - returning error: 0x80001009 - Error returned from OMX API in ducati
    D/DOMX    (   89): hardware/ti/domx/omx_core/src/OMX_Core.c:392    OMX_FreeHandle()
    D/DOMX    (   89): ERROR: Error From ComponentDeInit..
    E/CameraHal(   89): num_cameras = 0
    I/AudioFlinger(   89): AudioFlinger's thread 0x65c280 ready to run
    W/AudioFlinger(   89): Thread AudioOut_1 cannot connect to the power manager service
    I/AudioPolicyService(   89): Loaded audio policy from LEGACY Audio Policy HAL (audio_policy)
    I/ti_hwc  (   86): external display changed (state=1, mirror={enabled tform=0deg}, dock={enabled tform=0deg}, tv=1
    I/ti_hwc  (   86): omap4_hwc_device_open(rgb_order=1 nv12_only=0)
    I/ti_hwc  (   86): Unable to open gc-core device (2), blits disabled
    D/libEGL  (  143): loaded /system/lib/egl/libGLES_android.so
    D/libEGL  (  143): loaded /vendor/lib/egl/libEGL_POWERVR_SGX540_120.so
    D/libEGL  (  143): loaded /vendor/lib/egl/libGLESv1_CM_POWERVR_SGX540_120.so
    D/libEGL  (  143): loaded /vendor/lib/egl/libGLESv2_POWERVR_SGX540_120.so
    I/SamplingProfilerIntegration(   87): Profiling disabled.
    I/Zygote  (   87): Preloading classes...
    D/dalvikvm(   87): GC_EXPLICIT freed 36K, 84% free 409K/2560K, paused 0ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 4K, 82% free 474K/2560K, paused 0ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 20K, 81% free 509K/2560K, paused 0ms+0ms
    D/dalvikvm(   87): GC_EXPLICIT freed 27K, 80% free 537K/2560K, paused 0ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 15K, 78% free 576K/2560K, paused 0ms+0ms
    D/dalvikvm(   87): GC_EXPLICIT freed 27K, 77% free 603K/2560K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 30K, 76% free 636K/2560K, paused 1ms+1ms
    D/TextLayoutCache(   87): Using debug level: 0 - Debug Enabled: 0
    W/Zygote  (   87): Class not found for preloading: android.media.AudioManager$2
    I/dalvikvm(   87): threadid=1: recursive native library load attempt (/system/lib/libmedia_jni.so)
    D/MtpDeviceJNI(   87): register_android_mtp_MtpDevice
    W/Zygote  (   87): Class not found for preloading: android.media.IRemoteControlClientDispatcher
    W/Zygote  (   87): Class not found for preloading: android.media.IRemoteControlClientDispatcher$Stub
    D/dalvikvm(   87): GC_EXPLICIT freed 20K, 74% free 674K/2560K, paused 1ms+1ms
    D/dalvikvm(   87): GC_FOR_ALLOC freed 218K, 63% free 967K/2560K, paused 6ms
    D/dalvikvm(   87): GC_EXPLICIT freed 42K, 60% free 1025K/2560K, paused 0ms+0ms
    D/dalvikvm(   87): GC_EXPLICIT freed 27K, 59% free 1054K/2560K, paused 1ms+0ms
    E/uim-sysfs(  151): uim: Inside main
    E/uim-sysfs(  151): uim:BT/FM/GPS would be unavailable on system
    D/dalvikvm(   87): GC_EXPLICIT freed 8K, 57% free 1102K/2560K, paused 2ms+2ms
    D/dalvikvm(   87): GC_EXPLICIT freed 23K, 55% free 1168K/2560K, paused 2ms+3ms
    D/dalvikvm(   87): GC_EXPLICIT freed 48K, 44% free 1447K/2560K, paused 1ms+1ms
    W/Zygote  (   87): Class not found for preloading: android.text.TextDirectionHeuristics$CharCount
    W/Zygote  (   87): Class not found for preloading: android.text.method.WordIterator$1
    D/dalvikvm(   87): GC_EXPLICIT freed 34K, 43% free 1481K/2560K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 32K, 42% free 1503K/2560K, paused 1ms+1ms
    I/dalvikvm(   87): threadid=1: recursive native library load attempt (/system/lib/libwebcore.so)
    D/dalvikvm(   87): No JNI_OnLoad found in /system/lib/libchromium_net.so 0x0, skipping init
    D/dalvikvm(   87): GC_EXPLICIT freed 26K, 40% free 1552K/2560K, paused 3ms+3ms
    W/Zygote  (   87): Class not found for preloading: android.widget.EdgeGlow
    D/dalvikvm(   87): GC_EXPLICIT freed 25K, 39% free 1581K/2560K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 71K, 37% free 1626K/2560K, paused 1ms+1ms
    E/PhonePolicy(   87): Could not preload class for phone policy: com.android.internal.policy.impl.PhoneWindow$ContextMenuCallback
    D/dalvikvm(   87): GC_EXPLICIT freed 33K, 36% free 1648K/2560K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 28K, 35% free 1676K/2560K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 26K, 34% free 1707K/2560K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 32K, 33% free 1733K/2560K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 31K, 32% free 1761K/2560K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 71K, 30% free 1816K/2560K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 39K, 29% free 1832K/2560K, paused 1ms+1ms
    I/System  (   87): Loaded time zone names for  in 333ms (330ms in ICU)
    I/System  (   87): Loaded time zone names for en_US in 235ms (231ms in ICU)
    D/dalvikvm(   87): GC_EXPLICIT freed 325K, 25% free 1942K/2560K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 15K, 22% free 2003K/2560K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 51K, 21% free 2034K/2560K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 28K, 20% free 2065K/2560K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 37K, 19% free 2081K/2560K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 32K, 18% free 2103K/2560K, paused 1ms+1ms
    I/Zygote  (   87): ...preloaded 2297 classes in 2833ms.
    D/dalvikvm(   87): GC_EXPLICIT freed 22K, 18% free 2108K/2560K, paused 1ms+1ms
    I/Zygote  (   87): Preloading resources...
    D/dalvikvm(   87): GC_EXPLICIT freed 1K, 16% free 2163K/2560K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 1K, 14% free 2214K/2560K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 3K, 12% free 2261K/2560K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 3K, 10% free 2308K/2560K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 4K, 8% free 2356K/2560K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 5K, 6% free 2407K/2560K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 4K, 7% free 2454K/2627K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 5K, 5% free 2499K/2627K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 4K, 6% free 2548K/2691K, paused 2ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 4K, 6% free 2598K/2755K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 5K, 4% free 2658K/2755K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 2K, 4% free 2708K/2819K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 3K, 5% free 2754K/2883K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 6K, 5% free 2802K/2947K, paused 1ms+2ms
    D/dalvikvm(   87): GC_EXPLICIT freed 7K, 4% free 2849K/2947K, paused 1ms+2ms
    D/dalvikvm(   87): GC_EXPLICIT freed 4K, 4% free 2897K/3011K, paused 1ms+2ms
    D/dalvikvm(   87): GC_EXPLICIT freed 9K, 3% free 2941K/3011K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 8K, 2% free 3020K/3075K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 5K, 3% free 3065K/3139K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 4K, 1% free 3115K/3139K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 4K, 2% free 3162K/3203K, paused 2ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 5K, 1% free 3238K/3267K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 4K, 3% free 3553K/3651K, paused 1ms+2ms
    D/dalvikvm(   87): GC_EXPLICIT freed 7K, 2% free 3606K/3651K, paused 1ms+2ms
    D/dalvikvm(   87): GC_EXPLICIT freed 2K, 2% free 3656K/3715K, paused 1ms+2ms
    D/dalvikvm(   87): GC_EXPLICIT freed 5K, 1% free 3705K/3715K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 4K, 1% free 3879K/3907K, paused 1ms+2ms
    D/dalvikvm(   87): GC_EXPLICIT freed 3K, 2% free 3926K/3971K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 5K, 2% free 4986K/5059K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 5K, 3% free 6007K/6147K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 4K, 2% free 6056K/6147K, paused 2ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 7K, 1% free 6100K/6147K, paused 1ms+2ms
    D/dalvikvm(   87): GC_EXPLICIT freed 6K, 2% free 6148K/6211K, paused 1ms+2ms
    D/dalvikvm(   87): GC_EXPLICIT freed 5K, 1% free 6195K/6211K, paused 1ms+2ms
    D/dalvikvm(   87): GC_EXPLICIT freed 2K, 1% free 6247K/6275K, paused 2ms+2ms
    D/dalvikvm(   87): GC_EXPLICIT freed 4K, 1% free 6295K/6339K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 6K, 1% free 6356K/6403K, paused 1ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed 3K, 1% free 6421K/6467K, paused 1ms+2ms
    I/Zygote  (   87): ...preloaded 379 resources in 1084ms.
    D/dalvikvm(   87): GC_EXPLICIT freed 20K, 2% free 6455K/6531K, paused 1ms+2ms
    I/Zygote  (   87): ...preloaded 31 resources in 26ms.
    D/dalvikvm(   87): GC_EXPLICIT freed 14K, 2% free 6458K/6531K, paused 1ms+2ms
    D/dalvikvm(   87): GC_EXPLICIT freed 6K, 2% free 6452K/6531K, paused 1ms+2ms
    D/dalvikvm(   87): GC_EXPLICIT freed <1K, 2% free 6452K/6531K, paused 1ms+3ms
    I/dalvikvm(   87): System server process 152 has been created
    I/Zygote  (   87): Accepting command socket connections
    E/BatteryService(  152): acOnlinePath not found
    E/BatteryService(  152): usbOnlinePath not found
    E/BatteryService(  152): batteryStatusPath not found
    E/BatteryService(  152): batteryHealthPath not found
    E/BatteryService(  152): batteryPresentPath not found
    E/BatteryService(  152): batteryCapacityPath not found
    E/BatteryService(  152): batteryVoltagePath not found
    E/BatteryService(  152): batteryTemperaturePath not found
    E/BatteryService(  152): batteryTechnologyPath not found
    I/sysproc (  152): Entered system_init()
    I/sysproc (  152): ServiceManager: 0xb378c0
    D/SensorService(  152): nuSensorService starting...
    E/SensorService(  152): couldn't load sensors module (No such file or directory)
    I/sysproc (  152): System server: starting Android runtime.
    I/sysproc (  152): System server: starting Android services.
    I/sysproc (  152): System server: entering thread pool.
    I/SystemServer(  152): Entered the Android system server!
    I/SystemServer(  152): Entropy Service
    I/SystemServer(  152): Power Manager
    I/SystemServer(  152): Activity Manager
    I/ActivityManager(  152): Memory class: 48
    E/BatteryStatsImpl(  152): problem reading network stats
    E/BatteryStatsImpl(  152): java.lang.IllegalStateException: problem parsing idx 1
    E/BatteryStatsImpl(  152):     at com.android.internal.net.NetworkStatsFactory.readNetworkStatsDetail(NetworkStatsFactory.java:300)
    E/BatteryStatsImpl(  152):     at com.android.internal.net.NetworkStatsFactory.readNetworkStatsDetail(NetworkStatsFactory.java:250)
    E/BatteryStatsImpl(  152):     at com.android.internal.os.BatteryStatsImpl.getNetworkStatsDetailGroupedByUid(BatteryStatsImpl.java:5736)
    E/BatteryStatsImpl(  152):     at com.android.internal.os.BatteryStatsImpl.access$100(BatteryStatsImpl.java:78)
    E/BatteryStatsImpl(  152):     at com.android.internal.os.BatteryStatsImpl$Uid.computeCurrentTcpBytesReceived(BatteryStatsImpl.java:2459)
    E/BatteryStatsImpl(  152):     at com.android.internal.os.BatteryStatsImpl$Uid.getTcpBytesReceived(BatteryStatsImpl.java:2448)
    E/BatteryStatsImpl(  152):     at com.android.internal.os.BatteryStatsImpl.writeSummaryToParcel(BatteryStatsImpl.java:5439)
    E/BatteryStatsImpl(  152):     at com.android.internal.os.BatteryStatsImpl.writeLocked(BatteryStatsImpl.java:4838)
    E/BatteryStatsImpl(  152):     at com.android.internal.os.BatteryStatsImpl.writeAsyncLocked(BatteryStatsImpl.java:4820)
    E/BatteryStatsImpl(  152):     at com.android.server.am.ActivityManagerService.<init>(ActivityManagerService.java:1489)
    E/BatteryStatsImpl(  152):     at com.android.server.am.ActivityManagerService.<init>(ActivityManagerService.java:150)
    E/BatteryStatsImpl(  152):     at com.android.server.am.ActivityManagerService$AThread.run(ActivityManagerService.java:1390)
    E/BatteryStatsImpl(  152): Caused by: java.io.FileNotFoundException: /proc/net/xt_qtaguid/stats: open failed: ENOENT (No such file or directory)
    E/BatteryStatsImpl(  152):     at libcore.io.IoBridge.open(IoBridge.java:406)
    E/BatteryStatsImpl(  152):     at java.io.FileInputStream.<init>(FileInputStream.java:78)
    E/BatteryStatsImpl(  152):     at com.android.internal.net.NetworkStatsFactory.readNetworkStatsDetail(NetworkStatsFactory.java:269)
    E/BatteryStatsImpl(  152):     ... 11 more
    E/BatteryStatsImpl(  152): Caused by: libcore.io.ErrnoException: open failed: ENOENT (No such file or directory)
    E/BatteryStatsImpl(  152):     at libcore.io.Posix.open(Native Method)
    E/BatteryStatsImpl(  152):     at libcore.io.BlockGuardOs.open(BlockGuardOs.java:110)
    E/BatteryStatsImpl(  152):     at libcore.io.IoBridge.open(IoBridge.java:390)
    E/BatteryStatsImpl(  152):     ... 13 more
    D/dalvikvm(  152): GC_CONCURRENT freed 162K, 5% free 6698K/6983K, paused 1ms+2ms
    I/SystemServer(  152): Telephony Registry
    I/ActivityManager(  152): Enabled StrictMode logging for AThread's Looper
    I/SystemServer(  152): Package Manager
    D/dalvikvm(  152): GC_CONCURRENT freed 491K, 8% free 6732K/7303K, paused 1ms+1ms
    E/StrictMode(  152): A resource was acquired at attached stack trace but never released. See java.io.Closeable for information on avoiding resource leaks.
    E/StrictMode(  152): java.lang.Throwable: Explicit termination method 'close' not called
    E/StrictMode(  152):     at dalvik.system.CloseGuard.open(CloseGuard.java:184)
    E/StrictMode(  152):     at java.io.FileInputStream.<init>(FileInputStream.java:80)
    E/StrictMode(  152):     at com.android.server.pm.UserManager.readUserList(UserManager.java:114)
    E/StrictMode(  152):     at com.android.server.pm.UserManager.<init>(UserManager.java:81)
    E/StrictMode(  152):     at com.android.server.pm.UserManager.<init>(UserManager.java:85)
    E/StrictMode(  152):     at com.android.server.pm.PackageManagerService.<init>(PackageManagerService.java:923)
    E/StrictMode(  152):     at com.android.server.pm.PackageManagerService.main(PackageManagerService.java:833)
    E/StrictMode(  152):     at com.android.server.ServerThread.run(SystemServer.java:163)
    D/StrictMode(  152): No activity manager; failed to Dropbox violation.
    D/dalvikvm(  152): GC_CONCURRENT freed 339K, 7% free 6827K/7303K, paused 1ms+1ms
    W/PackageManager(  152): Running ENG build: no pre-dexopt!
    W/PackageManager(  152): Library not found: /system/framework/com.ti.s3d.jar
    D/dalvikvm(  152): GC_CONCURRENT freed 192K, 5% free 7045K/7367K, paused 2ms+3ms
    E/uim-sysfs(  172): uim: Inside main
    E/uim-sysfs(  172): uim:BT/FM/GPS would be unavailable on system
    W/PackageParser(  152): Problem in package /system/app/Board_id.apk:
    W/PackageParser(  152): Unknown element under <activity>: service at /system/app/Board_id.apk Binary XML file line #11
    D/dalvikvm(  152): GC_CONCURRENT freed 174K, 4% free 7343K/7623K, paused 1ms+4ms
    W/PackageParser(  152): No actions in intent filter at /system/app/Contacts.apk Binary XML file line #525
    W/PackageParser(  152): No actions in intent filter at /system/app/Bluetooth.apk Binary XML file line #125
    W/PackageManager(  152): Package com.android.gallery3d desires unavailable shared library com.google.android.media.effects; ignoring!
    W/PackageManager(  152): Package com.ti.omap4.android.camera desires unavailable shared library com.google.android.media.effects; ignoring!
    D/dalvikvm(  152): GC_CONCURRENT freed 245K, 5% free 7529K/7879K, paused 2ms+4ms
    W/PackageManager(  152): Package com.android.camera desires unavailable shared library com.google.android.media.effects; ignoring!
    W/PackageParser(  152): Problem in package /system/app/sensor.test.apk:
    W/PackageParser(  152): Unknown element under <activity>: action at /system/app/sensor.test.apk Binary XML file line #27
    W/PackageParser(  152): Unknown element under <activity>: category at /system/app/sensor.test.apk Binary XML file line #28
    D/PackageManager(  152): No files in app dir /vendor/app
    I/installd(   91): new connection
    I/Installer(  152): connecting...
    I/PackageManager(  152): Time to scan packages: 2.567 seconds
    W/PackageManager(  152): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.contacts
    W/PackageManager(  152): Unknown permission android.permission.ADD_SYSTEM_SERVICE in package com.android.phone
    W/PackageManager(  152): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.calendar
    W/PackageManager(  152): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cl in package com.android.providers.calendar
    W/PackageManager(  152): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.calendar
    W/PackageManager(  152): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.browser (protectionLevel=2 flags=0x9be45)
    W/PackageManager(  152): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.contacts
    W/PackageManager(  152): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cp in package com.android.providers.contacts
    W/PackageManager(  152): Unknown permission android.permission.READ_EXTERNAL_STORAGE in package com.android.videoeditor
    W/PackageManager(  152): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.settings
    W/PackageManager(  152): Unknown permission archos.permission.FULLSCREEN.FULL in package com.redirectin.rockplayer.android.unified
    W/PackageManager(  152): Unknown permission com.google.android.googleapps.permission.ACCESS_GOOGLE_PASSWORD in package com.android.development
    W/PackageManager(  152): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.development
    W/PackageManager(  152): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.ALL_SERVICES in package com.android.development
    W/PackageManager(  152): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.YouTubeUser in package com.android.development
    W/PackageManager(  152): Not granting permission android.permission.DEVICE_POWER to package com.android.deskclock (protectionLevel=2 flags=0x8be45)
    D/dalvikvm(  152): GC_CONCURRENT freed 325K, 6% free 7626K/8071K, paused 2ms+3ms
    D/dalvikvm(  152): GC_EXPLICIT freed 130K, 8% free 7496K/8071K, paused 3ms+3ms
    I/SystemServer(  152): Account Manager
    D/PackageManager(  152): generateServicesMap(android.accounts.AccountAuthenticator): 2 services unchanged
    I/SystemServer(  152): Content Manager
    D/PackageManager(  152): generateServicesMap(android.content.SyncAdapter): 4 services unchanged
    I/SystemServer(  152): System Content Providers
    I/ActivityThread(  152): Pub settings: com.android.providers.settings.SettingsProvider
    D/SettingsProvider(  152): cache for settings table 'secure' rows=35; fullycached=true
    D/SettingsProvider(  152): cache for settings table 'system' rows=52; fullycached=true
    I/SystemServer(  152): Lights Service
    I/SystemServer(  152): Battery Service
    E/BatteryStatsImpl(  152):     at com.android.internal.os.BatteryStatsImpl.doUnplugLocked(BatteryStatsImpl.java:1420)
    E/BatteryStatsImpl(  152):     at com.android.internal.os.BatteryStatsImpl.setOnBatteryLocked(BatteryStatsImpl.java:4337)
    E/BatteryStatsImpl(  152):     at com.android.internal.os.BatteryStatsImpl.setBatteryState(BatteryStatsImpl.java:4396)
    E/BatteryStatsImpl(  152):     at com.android.server.am.BatteryStatsService.setBatteryState(BatteryStatsService.java:434)
    E/BatteryStatsImpl(  152):     at com.android.server.BatteryService.processValues(BatteryService.java:252)
    E/BatteryStatsImpl(  152):     at com.android.server.BatteryService.update(BatteryService.java:234)
    E/BatteryStatsImpl(  152):     at com.android.server.BatteryService.<init>(BatteryService.java:148)
    E/BatteryStatsImpl(  152):     at com.android.server.ServerThread.run(SystemServer.java:196)
    E/BatteryStatsImpl(  152):     ... 10 more
    E/BatteryStatsImpl(  152):     ... 12 more
    I/SystemServer(  152): Vibrator Service
    I/power   (  152): *** set_screen_state 1
    D/dalvikvm(  152): GC_CONCURRENT freed 402K, 7% free 7636K/8135K, paused 1ms+3ms
    D/AlarmManagerService(  152): Kernel timezone updated to 480 minutes west of GMT
    I/SystemServer(  152): Alarm Manager
    I/SystemServer(  152): Init Watchdog
    I/SystemServer(  152): Window Manager
    I/InputManager(  152): Initializing input manager
    W/StatusBarManager(  152): warning: no STATUS_BAR_SERVICE
    E/ASFDummyExtractor(   89): isASFParserAvailable
    W/ASFDummyExtractor(   89): ASF parser is not available
    I/WindowManager(  152): Enabled StrictMode for PolicyThread's Looper
    I/InputManager(  152): Starting input manager
    E/EventHub(  152): could not get driver version for /dev/input/mice, Not a typewriter
    W/bluedroid(  152): open(/sys/class/rfkill/rfkill0/type) failed: No such file or directory (2)
    I/BluetoothProfileState(  152): Message:Entering Stable State
    I/SystemServer(  152): Bluetooth Service
    I/WindowManager(  152): Enabled StrictMode logging for WMThread's Looper
    I/AudioPlayer(   89): TimeInterpolator::seek(media_time=0)
    I/AudioPlayer(   89): mLatencyUs = 0
    I/AudioPlayer(   89): TimeInterpolator state STOPPED -> FIRST_ROLLING (input: POST_BUFFER)
    I/AudioPlayer(   89): TimeInterpolator FIRST_ROLLING frame_usecs=23219
    I/SystemServer(  152): Input Method Service
    W/InputManagerService(  152): Couldn't create dir.: /data/system/inputmethod
    I/AudioPlayer(   89): void omap_enhancement::TimeInterpolator::pause(bool)()
    I/AudioPlayer(   89): TimeInterpolator state FIRST_ROLLING -> STOPPED (input: STOP)
    I/AudioPlayer(   89): TimeInterpolator::seek(media_time=139314)
    I/AudioPlayer(   89): TimeInterpolator state STOPPED -> STOPPED (input: STOP)
    E/AudioPlayer(   89): TimeInterpolator calling set_state() should actually change a state.
    E/AudioPlayer(   89): TimeInterpolator this state should not be reachable.
    W/ResourceType(  152): Failure getting entry for 0x7f060000 (t=5 e=0) in package 0 (error -75)
    I/SystemServer(  152): Accessibility Manager
    D/PermissionCache(   86): checking android.permission.ACCESS_SURFACE_FLINGER for uid=1000 => granted (335 us)
    I/Display (  152): Mirroring region is Rect(0, 0 - 1280, 720)
    I/ActivityManager(  152): Config changed: {1.0 0mcc0mnc en_US layoutdir=0 sw720dp w1280dp h672dp lrg long land ?uimode ?night -touch -keyb/v/h -nav/h s.2}
    I/SystemServer(  152): Device Policy
    I/SystemServer(  152): Status Bar
    I/SystemServer(  152): Clipboard Service
    I/SystemServer(  152): NetworkManagement Service
    I/SystemServer(  152): Text Service Manager Service
    I/SystemServer(  152): NetworkStats Service
    I/SystemServer(  152): NetworkPolicy Service
    I/SystemServer(  152): Wi-Fi P2pService
    I/SystemServer(  152): Wi-Fi Service
    D/EventHub(  152): No input device configuration file found for device 'Panda Headset Jack'.
    I/EventHub(  152): New device: id=1, fd=127, path='/dev/input/event1', name='Panda Headset Jack', classes=0x80, configuration='', keyLayout='', keyCharacterMap='', builtinKeyboard=false
    E/CommandListener(   83): Failed to open /proc/sys/net/ipv6/conf/wlan0/disable_ipv6: No such file or directory
    E/WifiStateMachine(  152): Failed to disable IPv6: java.lang.IllegalStateException: Unable to communicate to native daemon for disabling ipv6
    I/SystemServer(  152): Connectivity Service
    D/ConnectivityService(  152): ConnectivityService starting up
    I/EventHub(  152): New device: id=2, fd=128, path='/dev/input/event0', name='cyttsp4-i2c', classes=0x15f, configuration='/system/usr/idc/cyttsp4-i2c.idc', keyLayout='/system/usr/keylayout/Generic.kl', keyCharacterMap='/system/usr/keychars/Generic.kcm', builtinKeyboard=false
    E/EventHub(  152): could not get driver version for /dev/input/mouse0, Not a typewriter
    D/NetworkManagementService(  152): rsp <213 6e:00:f9:d7:90:20 0.0.0.0 0 [down broadcast multicast]>
    D/NetworkManagementService(  152): flags <[down broadcast multicast]>
    D/NetworkManagementService(  152): Registering observer
    E/MobileDataStateTracker(  152): default: Ignoring feature request because could not acquire PhoneService
    E/MobileDataStateTracker(  152): default: Could not enable APN type "default"
    I/WifiService(  152): WifiService starting up with Wi-Fi enabled
    W/CommandListener(   83): Failed to retrieve HW addr for wlan0 (No such device)
    I/SystemServer(  152): Throttle Service
    I/SystemServer(  152): Mount Service
    D/dalvikvm(  152): GC_CONCURRENT freed 224K, 5% free 7899K/8263K, paused 2ms+3ms
    D/CommandListener(   83): Setting iface cfg
    D/NetworkManagementService(  152): rsp <213 00:00:00:00:00:00 0.0.0.0 0 [down]>
    D/NetworkManagementService(  152): flags <[down]>
    E/WifiStateMachine(  152): Unable to change interface settings: java.lang.IllegalStateException: Unable to communicate with native daemon to interface setcfg - com.android.server.NativeDaemonConnectorException: Cmd {interface setcfg wlan0 0.0.0.0 0 [down]} failed with code 400 : {Failed to set address (No such device)}
    D/MountService(  152): got storage path: /mnt/sdcard description: Internal Storage primary: true removable: false emulated: true mtpReserve: 0 allowMassStorage: false maxFileSize: 0
    D/MountService(  152): got storage path: /mnt/external_sd description: SD Card primary: false removable: true emulated: false mtpReserve: 0 allowMassStorage: false maxFileSize: 0
    D/MountService(  152): got storage path: /mnt/usb_storage description: USB storage primary: false removable: true emulated: false mtpReserve: 0 allowMassStorage: false maxFileSize: 0
    I/InputReader(  152):   Touch device 'cyttsp4-i2c' could not query the properties of its associated display 0.  The device will be inoperable until the display size becomes available.
    I/InputReader(  152): Device added: id=2, name='cyttsp4-i2c', sources=0x01003513
    I/InputReader(  152): Device added: id=1, name='Panda Headset Jack', sources=0x80000000
    I/InputReader(  152): Reconfiguring input devices.  changes=0x00000004
    I/InputReader(  152): Device reconfigured: id=2, name='cyttsp4-i2c', surface size is now 1280x720, mode is 1
    D/MountService(  152): using emulated external storage
    I/ActivityManager(  152): Config changed: {1.0 0mcc0mnc en_US layoutdir=0 sw720dp w1280dp h672dp lrg long land ?uimode ?night finger qwerty/v/v -nav/h s.3}
    I/SystemServer(  152): Notification Manager
    I/SystemServer(  152): Device Storage Monitor
    I/SystemServer(  152): starting SUPL Service (SystemServer)
    I/SystemServer(  152): Location Manager
    D/VoldCmdListener(   78): volume list
    I/SystemServer(  152): Country Detector
    D/MountService(  152): volume state changed for /mnt/external_sd (null -> unmounted)
    D/MountService(  152): volume state changed for /mnt/usb_storage (null -> removed)
    I/SystemServer(  152): Search Service
    I/SystemServer(  152): DropBox Service
    I/SystemServer(  152): Wallpaper Service
    I/wpa_supplicant(  235): rfkill: Cannot open RFKILL control device
    E/wpa_supplicant(  235): Could not read interface wlan0 flags: No such device
    I/SystemServer(  152): Audio Service
    I/AudioService(  152):   Remote Control   registerMediaButtonIntent() for PendingIntent{41216440: PendingIntentRecord{411cadd8 android broadcastIntent}}
    I/SystemServer(  152): Dock Observer
    W/DockObserver(  152): This kernel does not have dock station support
    I/SystemServer(  152): Wired Accessory Observer
    I/SystemServer(  152): USB Service
    I/SystemServer(  152): UI Mode Manager Service
    I/SystemServer(  152): Backup Service
    V/BackupManagerService(  152): Initializing package tracking
    V/BackupManagerService(  152): No ancestral data
    V/BackupManagerService(  152): addPackageParticipantsLocked: null
    I/BackupManagerService(  152): New app android never backed up; scheduling
    D/dalvikvm(  152): GC_CONCURRENT freed 217K, 5% free 8167K/8519K, paused 1ms+2ms
    I/BackupManagerService(  152): New app com.android.browser never backed up; scheduling
    I/BackupManagerService(  152): New app com.android.calendar never backed up; scheduling
    I/BackupManagerService(  152): New app com.android.inputmethod.latin never backed up; scheduling
    I/BackupManagerService(  152): New app com.android.providers.settings never backed up; scheduling
    I/BackupManagerService(  152): New app com.android.providers.userdictionary never backed up; scheduling
    I/BackupManagerService(  152): New app com.android.sharedstoragebackup never backed up; scheduling
    V/BackupManagerService(  152): Registering transport android/com.android.internal.backup.LocalTransport = com.android.internal.backup.LocalTransport@410e0da0
    V/BackupManagerService(  152): Starting with transport android/com.android.internal.backup.LocalTransport
    V/BackupManagerService(  152): Google transport not present
    I/BackupManagerService(  152): Found stale backup journal, scheduling
    I/BackupManagerService(  152):   android
    I/BackupManagerService(  152):   com.android.browser
    I/BackupManagerService(  152):   com.android.calendar
    I/BackupManagerService(  152):   com.android.inputmethod.latin
    I/BackupManagerService(  152):   com.android.providers.settings
    I/BackupManagerService(  152):   com.android.providers.userdictionary
    I/BackupManagerService(  152):   com.android.sharedstoragebackup
    I/BackupManagerService(  152): Backup enabled => false
    I/BackupManagerService(  152): Opting out of backup
    I/SystemServer(  152): AppWidget Service
    I/SystemServer(  152): Recognition Service
    I/SystemServer(  152): DiskStats Service
    I/SystemServer(  152): SamplingProfiler Service
    I/WindowManager(  152): SAFE MODE not enabled
    D/dalvikvm(  152): JIT started for system_server
    I/SystemServer(  152): NetworkTimeUpdateService
    D/PowerManagerService(  152): system ready!
    I/ActivityManager(  152): System now ready
    I/SystemServer(  152): Making services ready
    D/SystemServer(  152): Starting service: Intent { cmp=com.android.systemui/.SystemUIService }
    V/TransportControlView(  152): Create TCV com.android.internal.widget.TransportControlView@412a29d8
    I/Zygote  (  152): Process: zygote socket opened
    I/ActivityManager(  152): Start proc com.android.systemui for service com.android.systemui/.SystemUIService: pid=256 uid=1000 gids={1015, 3002, 3001, 3003}
    D/NetworkManagementService(  152): not enabling bandwidth control
    W/NetworkStats(  152): problem reading network stats: java.lang.IllegalStateException: problem parsing idx 1
    I/ActivityManager(  152): Start proc android.process.media for broadcast com.android.providers.media/.UsbReceiver: pid=270 uid=10003 gids={1015, 1023, 1024, 2001, 3003, 3007}
    I/ActivityManager(  152): Config changed: {1.0 0mcc0mnc en_US layoutdir=0 sw720dp w1280dp h672dp lrg long land finger qwerty/v/v -nav/h s.4}
    D/SystemUIService(  256): loading: class com.android.systemui.statusbar.tablet.TabletStatusBar
    D/SystemUIService(  256): running: com.android.systemui.statusbar.tablet.TabletStatusBar@411088d8
    D/dalvikvm(  152): GC_CONCURRENT freed 253K, 5% free 8411K/8775K, paused 3ms+3ms
    W/RecognitionManagerService(  152): no available voice recognition services found
    I/Display (  256): Mirroring region is Rect(0, 0 - 1280, 720)
    I/StatusBar.HeightReceiver(  256): Resizing status bar plugged=true height=48 old=0
    I/ActivityThread(  270): Pub media: com.android.providers.media.MediaProvider
    D/libEGL  (  152): loaded /system/lib/egl/libGLES_android.so
    D/libEGL  (  152): loaded /vendor/lib/egl/libEGL_POWERVR_SGX540_120.so
    D/libEGL  (  152): loaded /vendor/lib/egl/libGLESv1_CM_POWERVR_SGX540_120.so
    D/libEGL  (  152): loaded /vendor/lib/egl/libGLESv2_POWERVR_SGX540_120.so
    I/ActivityManager(  152): Start proc com.android.wallpaper for service com.android.wallpaper/.fall.FallWallpaper: pid=290 uid=10040 gids={1006}
    W/InputManagerService(  152): Ignoring setImeWindowStatus of uid 1000 token: null
    D/dalvikvm(  256): GC_CONCURRENT freed 91K, 3% free 6751K/6919K, paused 2ms+2ms
    I/ActivityManager(  152): Start proc com.android.inputmethod.latin for service com.android.inputmethod.latin/.LatinIME: pid=304 uid=10033 gids={}
    D/OpenGLRenderer(  152): Enabling debug mode 0
    W/ThrottleService(  152): unable to find stats for iface rmnet0
    I/ActivityManager(  152): Start proc com.android.phone for added application com.android.phone: pid=326 uid=1001 gids={3002, 3001, 3003, 1015}
    I/ActivityManager(  152): START {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000000 cmp=com.android.launcher/com.android.launcher2.Launcher} from pid 0
    I/ActivityManager(  152): Start proc com.android.launcher for activity com.android.launcher/com.android.launcher2.Launcher: pid=342 uid=10013 gids={}
    I/SystemServer(  152): Enabled StrictMode for system server main thread.
    D/dalvikvm(  152): GREF has increased to 201
    W/NetworkManagementSocketTagger(  152): setKernelCountSet(10013, 1) failed with errno -2
    D/dalvikvm(  256): GC_CONCURRENT freed 32K, 3% free 7136K/7303K, paused 1ms+1ms
    D/dalvikvm(  270): GC_CONCURRENT freed 324K, 6% free 6564K/6983K, paused 2ms+1ms
    I/ActivityThread(  326): Pub mms: com.android.providers.telephony.MmsProvider
    I/ActivityThread(  342): Pub com.android.launcher2.settings: com.android.launcher2.LauncherProvider
    D/dalvikvm(  152): GC_CONCURRENT freed 257K, 5% free 8636K/9031K, paused 2ms+4ms
    I/ActivityThread(  270): Pub downloads: com.android.providers.downloads.DownloadProvider
    I/ActivityThread(  326): Pub sms: com.android.providers.telephony.SmsProvider
    V/RenderScript(  290): rsContextCreateGL dev=0xb32898
    I/ActivityThread(  326): Pub telephony: com.android.providers.telephony.TelephonyProvider
    V/RenderScript(  290): 0xb37340 Launching thread(s), CPUs 2
    V/RenderScript(  290): 0xb37340 initEGL start
    W/TelephonyProvider(  326): onCreate: confFile=/system/etc/apns-conf.xml oldCheckSum=-1
    D/libEGL  (  290): loaded /system/lib/egl/libGLES_android.so
    D/libEGL  (  290): loaded /vendor/lib/egl/libEGL_POWERVR_SGX540_120.so
    I/ActivityThread(  326): Pub icc: com.android.phone.IccProvider
    I/ActivityThread(  326): Pub mms-sms: com.android.providers.telephony.MmsSmsProvider
    D/libEGL  (  290): loaded /vendor/lib/egl/libGLESv1_CM_POWERVR_SGX540_120.so
    D/libEGL  (  290): loaded /vendor/lib/egl/libGLESv2_POWERVR_SGX540_120.so
    I/ActivityThread(  270): Pub drm: com.android.providers.drm.DrmProvider
    I/DownloadManager(  270): in removeSpuriousFiles
    E/BinaryDictionaryGetter(  304): Could not find a dictionary pack
    E/ActivityThread(  304): Failed to find provider info for com.android.inputmethod.latin.dictionarypack
    D/dalvikvm(  304): GC_CONCURRENT freed 146K, 4% free 6791K/7047K, paused 2ms+23ms
    D/dalvikvm(  342): GC_CONCURRENT freed 226K, 5% free 6658K/6983K, paused 2ms+29ms
    I/ActivityManager(  152): Start proc android.process.acore for content provider com.android.providers.userdictionary/.UserDictionaryProvider: pid=391 uid=10009 gids={3003, 1015}
    V/RenderScript(  290): 0xb37340 initGLThread end
    V/RenderScript(  290): 0xb37340 rsContextCreateGL ret
    I/StatusBarManagerService(  152): registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@412b3118
    I/TabletStatusBar(  256): DISABLE_CLOCK: yes
    D/dalvikvm(  326): GC_CONCURRENT freed 219K, 5% free 6640K/6983K, paused 2ms+1ms
    I/ActivityThread(  391): Pub com.android.voicemail: com.android.providers.contacts.VoicemailContentProvider
    I/ActivityManager(  152): Start proc com.android.smspush for service com.android.smspush/.WapPushManager: pid=413 uid=10020 gids={}
    D/dalvikvm(  256): GC_CONCURRENT freed 52K, 2% free 7540K/7687K, paused 1ms+8ms
    E/wpa_supplicant(  235): nl80211: Could not set interface 'wlan0' UP
    E/wpa_supplicant(  235): wlan0: Failed to initialize driver interface
    D/        (  326): [ApnContext] set reason as dataEnabled, for type default,current state IDLE
    D/SystemUIService(  256): loading: class com.android.systemui.power.PowerUI
    D/SystemUIService(  256): running: com.android.systemui.power.PowerUI@411ea5b8
    D/        (  326): [ApnContext] set reason as dataEnabled, for type mms,current state IDLE
    D/        (  326): [ApnContext] set reason as dataEnabled, for type supl,current state IDLE
    D/        (  326): [ApnContext] set reason as dataEnabled, for type hipri,current state IDLE
    D/        (  326): [ApnContext] set reason as dataEnabled, for type fota,current state IDLE
    D/        (  326): [ApnContext] set reason as dataEnabled, for type ims,current state IDLE
    D/        (  326): [ApnContext] set reason as dataEnabled, for type cbs,current state IDLE
    D/CAT     (  326): CatService: Is running
    D/CAT     (  326): CatService: NEW sInstance
    D/CallManager(  326): registerPhone(GSM Handler (com.android.internal.telephony.PhoneProxy) {41138b70})
    I/StatusBar.HeightReceiver(  256): Resizing status bar plugged=true height=48 old=48
    D/WifiService(  152): New client listening to asynchronous messages
    I/ActivityThread(  391): Pub com.android.social: com.android.providers.contacts.SocialProvider
    I/ActivityThread(  391): Pub applications: com.android.providers.applications.ApplicationsProvider
    W/ActivityManager(  152): Unable to start service Intent { act=com.android.ussd.IExtendedNetworkService }: not found
    V/ScriptC (  290): Create script for resource = fall
    I/bcc     (  290): LIBBCC build time: 2012/03/29 02:44:52
    I/bcc     (  290): LIBBCC build revision: 0164f4647511a71f5b495a3bef156e3ac4e6c6b3 (git)
    I/ActivityThread(  391): Pub contacts;com.android.contacts: com.android.providers.contacts.ContactsProvider2
    D/dalvikvm(  391): GC_CONCURRENT freed 348K, 7% free 6624K/7047K, paused 1ms+9ms
    D/dalvikvm(  326): GC_CONCURRENT freed 290K, 6% free 6752K/7175K, paused 2ms+2ms
    D/StopWatch(  290): StopWatch calcFileSHA1 time (us): 122985
    I/ActivityThread(  391): Pub call_log: com.android.providers.contacts.CallLogProvider
    I/ActivityThread(  391): Pub user_dictionary: com.android.providers.userdictionary.UserDictionaryProvider
    D/dalvikvm(  152): GC_CONCURRENT freed 409K, 6% free 8812K/9287K, paused 2ms+5ms
    D/StopWatch(  290): StopWatch calcFileSHA1 time (us): 143096
    D/dalvikvm(  152): GREF has increased to 301
    D/bcc     (  290): Read object file size 7232
    D/Bluetooth HSHFP(  326): Starting BluetoothHeadsetService
    I/SearchManagerService(  152): Building list of searchable activities
    D/dalvikvm(  342): GC_CONCURRENT freed 229K, 5% free 6983K/7303K, paused 1ms+2ms
    D/StopWatch(  290): StopWatch bcc: PrepareExecutable time (us): 81054
    D/dalvikvm(  290): GC_CONCURRENT freed 203K, 5% free 6645K/6983K, paused 2ms+1ms
    V/SipBroadcastReceiver(  326): start auto registration
    D/dalvikvm(  152): GC_EXPLICIT freed 194K, 7% free 8816K/9415K, paused 2ms+6ms
    D/dalvikvm(  290): GC_FOR_ALLOC freed 154K, 7% free 6538K/6983K, paused 15ms
    I/dalvikvm-heap(  290): Grow heap (frag case) to 6.958MB for 524304-byte allocation
    D/dalvikvm(  152): GC_FOR_ALLOC freed 34K, 7% free 8790K/9415K, paused 26ms
    I/dalvikvm-heap(  152): Grow heap (frag case) to 8.793MB for 134426-byte allocation
    D/dalvikvm(  290): GC_CONCURRENT freed <1K, 7% free 7050K/7559K, paused 1ms+1ms
    D/dalvikvm(  290): GC_FOR_ALLOC freed 512K, 14% free 6539K/7559K, paused 10ms
    I/dalvikvm-heap(  290): Grow heap (frag case) to 9.388MB for 3072016-byte allocation
    D/dalvikvm(  152): GC_FOR_ALLOC freed 88K, 9% free 8832K/9607K, paused 33ms
    D/dalvikvm(  290): GC_CONCURRENT freed <1K, 10% free 9539K/10567K, paused 2ms+2ms
    D/libEGL  (  342): loaded /system/lib/egl/libGLES_android.so
    D/libEGL  (  342): loaded /vendor/lib/egl/libEGL_POWERVR_SGX540_120.so
    D/libEGL  (  342): loaded /vendor/lib/egl/libGLESv1_CM_POWERVR_SGX540_120.so
    D/libEGL  (  342): loaded /vendor/lib/egl/libGLESv2_POWERVR_SGX540_120.so
    D/OpenGLRenderer(  342): Enabling debug mode 0
    D/dalvikvm(  391): GC_CONCURRENT freed 227K, 5% free 6869K/7175K, paused 2ms+4ms
    D/dalvikvm(  342): GC_FOR_ALLOC freed 194K, 5% free 7147K/7495K, paused 14ms
    D/dalvikvm(  342): GC_FOR_ALLOC freed 9K, 6% free 7288K/7687K, paused 12ms
    D/dalvikvm(  342): GC_FOR_ALLOC freed 1K, 6% free 7437K/7879K, paused 13ms
    E/uim-sysfs(  451): uim: Inside main
    E/uim-sysfs(  451): uim:BT/FM/GPS would be unavailable on system
    I/SurfaceFlinger(   86): Boot is finished (12690 ms)
    V/OtaStartupReceiver(  326): onReceive: intent action=android.intent.action.BOOT_COMPLETED  mOtaspMode=-1
    D/OtaStartupReceiver(  326): OTASP not supported, nothing to do.
    D/PowerManagerService(  152): bootCompleted
    V/DevicePolicyManagerService(  152): Sending password expiration notifications for action android.intent.action.BOOT_COMPLETED
    D/VoldCmdListener(   78): volume mount /mnt/external_sd
    I/Vold    (   78): /dev/block/vold/16777215:255 being considered for volume external_sdcard
    D/Vold    (   78): Volume external_sdcard state changing 1 (Idle-Unmounted) -> 3 (Checking)
    D/MountService(  152): volume state changed for /mnt/external_sd (unmounted -> checking)
    D/MountService(  152): sendStorageIntent Intent { act=android.intent.action.MEDIA_CHECKING dat=file:///mnt/external_sd (has extras) }
    I/ActivityManager(  152): Start proc com.android.contacts for broadcast com.android.contacts/.calllog.CallLogReceiver: pid=454 uid=10009 gids={3003, 1015}
    V/WiredAccessoryObserver(  152): init()
    V/WiredAccessoryObserver(  152): newState = 1, headsetState = 1,mHeadsetState = 0
    W/WiredAccessoryObserver(  152): This kernel does not have wired headset support
    I//system/bin/fsck_msdos(   78): ** /dev/block/vold/16777215:255
    I//system/bin/fsck_msdos(   78): Can't open: No such file or directory
    I/logwrapper(   78): /system/bin/fsck_msdos terminated by exit(8)
    E/Vold    (   78): Filesystem check failed (unknown exit code 8)
    E/Vold    (   78): /dev/block/vold/16777215:255 failed FS checks (I/O error)
    D/Vold    (   78): Volume external_sdcard state changing 3 (Checking) -> 1 (Idle-Unmounted)
    D/MountService(  152): volume state changed for /mnt/external_sd (checking -> unmounted)
    D/MountService(  152): volume state changed for /mnt/external_sd (unmounted -> unmountable)
    V/WiredAccessoryObserver(  152): newState = 17, headsetState = 17,mHeadsetState = 1
    V/WiredAccessoryObserver(  152): Intent.ACTION_HEADSET_PLUG: state: 1 name: h2w mic: 1
    D/MountService(  152): sendStorageIntent Intent { act=android.intent.action.MEDIA_UNMOUNTED dat=file:///mnt/external_sd (has extras) }
    D/dalvikvm(   87): GC_EXPLICIT freed 33K, 5% free 6464K/6787K, paused 2ms+1ms
    D/MountService(  152): sendStorageIntent Intent { act=android.intent.action.MEDIA_UNMOUNTABLE dat=file:///mnt/external_sd (has extras) }
    E/MountService(  152): Boot-time mount failed (-4)
    W/MountService(  152): Duplicate state transition (mounted -> mounted) for /mnt/sdcard
    D/MountService(  152): sendStorageIntent Intent { act=android.intent.action.MEDIA_MOUNTED dat=file:///mnt/sdcard (has extras) }
    I/AudioPlayer(   89): TimeInterpolator::seek(media_time=46438)
    D/dalvikvm(   87): GC_EXPLICIT freed <1K, 5% free 6464K/6787K, paused 2ms+1ms
    D/dalvikvm(   87): GC_EXPLICIT freed <1K, 5% free 6464K/6787K, paused 1ms+2ms
    I/AudioPlayer(   89): TimeInterpolator::seek(media_time=116095)
    D/dalvikvm(  342): GC_CONCURRENT freed 59K, 4% free 7816K/8071K, paused 2ms+3ms
    I/AudioPlayer(   89): TimeInterpolator::seek(media_time=301847)
    I/AudioPlayer(   89): TimeInterpolator::seek(media_time=185752)
    I/RecoverySystem(  152): No recovery log file
    D/dalvikvm(  342): GC_FOR_ALLOC freed 11K, 4% free 7965K/8263K, paused 25ms
    I/dalvikvm-heap(  342): Grow heap (frag case) to 8.206MB for 372116-byte allocation
    W/ActivityManager(  152): Permission Denial: receiving Intent { act=android.intent.action.BOOT_COMPLETED flg=0x10 } to com.android.musicfx requires android.permission.RECEIVE_BOOT_COMPLETED due to sender null (uid 1000)
    I/ActivityManager(  152): Start proc com.android.email for broadcast com.android.email/.service.EmailBroadcastReceiver: pid=498 uid=10006 gids={3003, 1015}
    I/AudioPlayer(   89): TimeInterpolator state FIRST_ROLLING -> ROLLING (input: COUNTDOWN_0)
    I/AudioPlayer(   89): @countdown end e=13427 (resetting to 0)
    D/dalvikvm(  342): GC_FOR_ALLOC freed 0K, 4% free 8328K/8647K, paused 27ms
    I/AudioPlayer(   89): TimeInterpolator state ROLLING -> STOPPED (input: STOP)
    I/AudioPlayer(   89): TimeInterpolator::seek(media_time=371504)
    D/dalvikvm(  454): GC_CONCURRENT freed 189K, 5% free 6657K/6983K, paused 1ms+1ms
    D/dalvikvm(  152): GC_CONCURRENT freed 444K, 7% free 8985K/9607K, paused 1ms+4ms
    I/AccountTypeManager(  454): Loaded meta-data for 1 account types, 0 accounts in 137ms(wall) 10ms(cpu)
    E/DefaultVoicemailNotifier(  454): No voicemails to notify about: clear the notification.
    I/ActivityThread(  498): Pub com.android.email.provider;com.android.email.notifier: com.android.email.provider.EmailProvider
    I/ActivityThread(  498): Pub com.android.email.attachmentprovider: com.android.email.provider.AttachmentProvider
    D/dalvikvm(  342): GC_FOR_ALLOC freed 773K, 10% free 8022K/8903K, paused 42ms
    D/dalvikvm(  152): GC_CONCURRENT freed 470K, 7% free 9123K/9735K, paused 1ms+3ms
    I/ActivityManager(  152): Start proc com.android.exchange for service com.android.exchange/.ExchangeService: pid=515 uid=10016 gids={3003, 1015}
    I/BootReceiver(  152): Copying /proc/last_kmsg to DropBox (SYSTEM_LAST_KMSG)
    D/dalvikvm(  152): GC_FOR_ALLOC freed 78K, 6% free 9343K/9927K, paused 28ms
    I/ActivityManager(  152): Start proc com.android.deskclock for broadcast com.android.deskclock/.AlarmInitReceiver: pid=531 uid=10007 gids={}
    D/dalvikvm(  342): GC_CONCURRENT freed 302K, 9% free 8158K/8903K, paused 1ms+2ms
    I/ActivityThread(  531): Pub com.android.deskclock: com.android.deskclock.AlarmProvider
    I/ActivityThread(  515): Pub com.android.exchange.directory.provider: com.android.exchange.provider.ExchangeDirectoryProvider
    D/ExchangeService(  515): !!! EAS ExchangeService, onCreate
    D/ExchangeService(  515): !!! EAS ExchangeService, onStartCommand, startingUp = false, running = false
    D/Eas Debug(  515): Logging:
    D/ExchangeService(  515): Received deviceId from Email app: android946685596540
    D/ExchangeService(  515): Reconciling accounts...
    D/ExchangeService(  515): !!! EAS ExchangeService, onStartCommand, startingUp = true, running = false
    D/dalvikvm(  342): GC_FOR_ALLOC freed 103K, 6% free 8395K/8903K, paused 21ms
    I/dalvikvm-heap(  342): Grow heap (frag case) to 8.742MB for 493268-byte allocation
    V/AudioService(  152): Broadcast Receiver: Got ACTION_HDMI_AUDIO_PLUG, state = 1
    V/WiredAccessoryObserver(  152): Intent.ACTION_USB_HEADSET_PLUG: state: 1 name: hdmi
    D/dalvikvm(  342): GC_FOR_ALLOC freed 2K, 6% free 8874K/9415K, paused 28ms
    V/AlarmClock(  531): AlarmInitReceiver finished
    I/ActivityManager(  152): Start proc com.android.providers.calendar for broadcast com.android.providers.calendar/.CalendarReceiver: pid=563 uid=10046 gids={3003, 1015}
    I/ActivityThread(  563): Pub com.android.calendar: com.android.providers.calendar.CalendarProvider2
    D/dalvikvm(  498): GC_CONCURRENT freed 235K, 6% free 6684K/7047K, paused 3ms+3ms
    I/ActivityManager(  152): Start proc com.ti.server for broadcast com.ti.server/.BootReceiver: pid=578 uid=10005 gids={}
    D/dalvikvm(  152): GC_FOR_ALLOC freed 523K, 10% free 9152K/10119K, paused 38ms
    I/BootReceiver(  578): Starting FM service
    I/ActivityManager(  152): Start proc com.android.music for broadcast com.android.music/.MediaAppWidgetProvider: pid=596 uid=10022 gids={3003, 1015}
    I/dalvikvm(  596): Turning on JNI app bug workarounds for target SDK version 9...
    I/FmService(  578): onCreate called
    I/JFmRx   (  578): Loading libfmradio.so
    D/JFmRxNative(  578): OnLoad
    D/JFmRxNative(  578): nativeJFmRx_ClassInitNative: Entered
    I/JFmRxNative(  578): nativeJFmRx_ClassInitNative: Obtaining method IDs
    D/JFmRxNative(  578): nativeJFmRx_ClassInitNative:Exiting
    D/JFmTxNative(  578): nativeJFmTx_ClassInitNative: Entered
    D/JFmTxNative(  578): nativeJFmTx_ClassInitNative: Initializing FMTX callback structure
    D/JFmTxNative(  578): nativeJFmTx_ClassInitNative: Obtaining method IDs
    D/JFmTxNative(  578): nativeJFmTx_ClassInitNative:Exiting
    I/ActivityManager(  152): Start proc com.android.settings for broadcast com.android.settings/.widget.SettingsAppWidgetProvider: pid=614 uid=1000 gids={1015, 3002, 3001, 3003}
    I/SqliteDatabaseCpp(  270): sqlite returned: error code = 14, msg = cannot open file at line 27701 of [8609a15dfa], db=/data/data/com.android.providers.media/databases/external.db
    I/SqliteDatabaseCpp(  270): sqlite returned: error code = 14, msg = os_unix.c: open() at line 27701 - "" errno=5 path=/data/data/com.android.providers.media/databases/internal.db-journal, db=/data/data/com.android.providers.media/databases/external.db
    I/SqliteDatabaseCpp(  270): sqlite returned: error code = 14, msg = statement aborts at 1: [PRAGMA journal_mode=TRUNCATE] , db=/data/data/com.android.providers.media/databases/external.db
    E/MediaProvider(  270): failed to open database internal.db
    E/MediaProvider(  270): android.database.sqlite.SQLiteCantOpenDatabaseException: error code 14: unable to open database file
    E/MediaProvider(  270):     at android.database.sqlite.SQLiteStatement.native_1x1_string(Native Method)
    E/MediaProvider(  270):     at android.database.sqlite.SQLiteStatement.simpleQueryForString(SQLiteStatement.java:161)
    E/MediaProvider(  270):     at android.database.DatabaseUtils.stringForQuery(DatabaseUtils.java:812)
    E/MediaProvider(  270):     at android.database.DatabaseUtils.stringForQuery(DatabaseUtils.java:800)
    E/MediaProvider(  270):     at android.database.sqlite.SQLiteDatabase.setJournalMode(SQLiteDatabase.java:1060)
    E/MediaProvider(  270):     at android.database.sqlite.SQLiteDatabase.openDatabase(SQLiteDatabase.java:996)
    E/MediaProvider(  270):     at android.database.sqlite.SQLiteDatabase.openOrCreateDatabase(SQLiteDatabase.java:1051)
    E/MediaProvider(  270):     at android.app.ContextImpl.openOrCreateDatabase(ContextImpl.java:770)
    E/MediaProvider(  270):     at android.content.ContextWrapper.openOrCreateDatabase(ContextWrapper.java:221)
    E/MediaProvider(  270):     at android.database.sqlite.SQLiteOpenHelper.getWritableDatabase(SQLiteOpenHelper.java:157)
    E/MediaProvider(  270):     at com.android.providers.media.MediaProvider$DatabaseHelper.getWritableDatabase(MediaProvider.java:323)
    E/MediaProvider(  270):     at android.database.sqlite.SQLiteOpenHelper.getReadableDatabase(SQLiteOpenHelper.java:231)
    E/MediaProvider(  270):     at com.android.providers.media.MediaProvider.query(MediaProvider.java:1902)
    E/MediaProvider(  270):     at android.content.ContentProvider$Transport.query(ContentProvider.java:178)
    E/MediaProvider(  270):     at android.media.MediaScanner.prescan(MediaScanner.java:985)
    E/MediaProvider(  270):     at android.media.MediaScanner.scanDirectories(MediaScanner.java:1172)
    E/MediaProvider(  270):     at com.android.providers.media.MediaScannerService.scan(MediaScannerService.java:104)
    E/MediaProvider(  270):     at com.android.providers.media.MediaScannerService.access$300(MediaScannerService.java:49)
    E/MediaProvider(  270):     at com.android.providers.media.MediaScannerService$ServiceHandler.handleMessage(MediaScannerService.java:261)
    E/MediaProvider(  270):     at android.os.Handler.dispatchMessage(Handler.java:99)
    E/MediaProvider(  270):     at android.os.Looper.loop(Looper.java:137)
    E/MediaProvider(  270):     at com.android.providers.media.MediaScannerService.run(MediaScannerService.java:183)
    E/MediaProvider(  270):     at java.lang.Thread.run(Thread.java:856)
    E/MediaProvider(  270):     at android.media.MediaScanner.prescan(MediaScanner.java:1023)
    D/LocalBluetoothProfileManager(  614): LocalBluetoothProfileManager construction complete
    I/ActivityManager(  152): Start proc com.android.calendar for broadcast com.android.calendar/.widget.CalendarAppWidgetProvider: pid=627 uid=10042 gids={3003}
    E/MediaProvider(  270):     at com.android.providers.media.MediaProvider.insertInternal(MediaProvider.java:2981)
    E/MediaProvider(  270):     at com.android.providers.media.MediaProvider.insert(MediaProvider.java:2478)
    E/MediaProvider(  270):     at android.content.ContentProvider$Transport.insert(ContentProvider.java:189)
    E/MediaProvider(  270):     at android.media.MediaScanner$MyMediaScannerClient.endFile(MediaScanner.java:875)
    E/MediaProvider(  270):     at android.media.MediaScanner$MyMediaScannerClient.doScanFile(MediaScanner.java:558)
    E/MediaProvider(  270):     at android.media.MediaScanner$MyMediaScannerClient.scanFile(MediaScanner.java:525)
    E/MediaProvider(  270):     at android.media.MediaScanner.processDirectory(Native Method)
    E/MediaProvider(  270):     at android.media.MediaScanner.scanDirectories(MediaScanner.java:1181)
    I/ActivityThread(  627): Pub com.android.calendar.CalendarRecentSuggestionsProvider: com.android.calendar.CalendarRecentSuggestionsProvider
    E/MediaProvider(  270):     at com.android.providers.media.MediaProvider.insertFile(MediaProvider.java:2601)
    E/MediaProvider(  270):     at com.android.providers.media.MediaProvider.insertInternal(MediaProvider.java:3135)
    E/MediaScannerJNI(  270): An exception was thrown by callback 'scanFile'.
    D/dalvikvm(  342): GREF has increased to 201
    E/MediaScannerJNI(  270): java.lang.NullPointerException
    E/MediaScannerJNI(  270):     at com.android.providers.media.MediaProvider.getParent(MediaProvider.java:2563)
    E/MediaScannerJNI(  270):     at com.android.providers.media.MediaProvider.insertFile(MediaProvider.java:2798)
    E/MediaScannerJNI(  270):     at com.android.providers.media.MediaProvider.insertInternal(MediaProvider.java:3135)
    E/MediaScannerJNI(  270):     at com.android.providers.media.MediaProvider.insert(MediaProvider.java:2478)
    E/MediaScannerJNI(  270):     at android.content.ContentProvider$Transport.insert(ContentProvider.java:189)
    E/MediaScannerJNI(  270):     at android.media.MediaScanner$MyMediaScannerClient.endFile(MediaScanner.java:875)
    E/MediaScannerJNI(  270):     at android.media.MediaScanner$MyMediaScannerClient.doScanFile(MediaScanner.java:558)
    E/MediaScannerJNI(  270):     at android.media.MediaScanner$MyMediaScannerClient.scanFile(MediaScanner.java:525)
    E/MediaScannerJNI(  270):     at android.media.MediaScanner.processDirectory(Native Method)
    E/MediaScannerJNI(  270):     at android.media.MediaScanner.scanDirectories(MediaScanner.java:1181)
    E/MediaScannerJNI(  270):     at com.android.providers.media.MediaScannerService.scan(MediaScannerService.java:104)
    E/MediaScannerJNI(  270):     at com.android.providers.media.MediaScannerService.access$300(MediaScannerService.java:49)
    E/MediaScannerJNI(  270):     at com.android.providers.media.MediaScannerService$ServiceHandler.handleMessage(MediaScannerService.java:261)
    E/MediaScannerJNI(  270):     at android.os.Handler.dispatchMessage(Handler.java:99)
    E/MediaScannerJNI(  270):     at android.os.Looper.loop(Looper.java:137)
    E/MediaScannerJNI(  270):     at com.android.providers.media.MediaScannerService.run(MediaScannerService.java:183)
    E/MediaScannerJNI(  270):     at java.lang.Thread.run(Thread.java:856)
    E/MediaScannerJNI(  270): An error occurred while scanning directory '/system/media'.
    D/MediaScannerReceiver(  270): action: android.intent.action.MEDIA_UNMOUNTED path: /mnt/external_sd
    D/dalvikvm(  270): GC_CONCURRENT freed 359K, 7% free 6644K/7111K, paused 8ms+8ms
    E/SQLiteDatabase(  270): close() was never explicitly called on database '/data/data/com.android.providers.media/databases/internal.db'
    E/SQLiteDatabase(  270): android.database.sqlite.DatabaseObjectNotClosedException: Application did not close the cursor or database object that was opened here
    E/SQLiteDatabase(  270):     at android.database.sqlite.SQLiteDatabase.<init>(SQLiteDatabase.java:1943)
    E/SQLiteDatabase(  270):     at android.database.sqlite.SQLiteDatabase.openDatabase(SQLiteDatabase.java:1007)
    E/SQLiteDatabase(  270):     at android.database.sqlite.SQLiteDatabase.openDatabase(SQLiteDatabase.java:986)
    E/SQLiteDatabase(  270):     at android.database.sqlite.SQLiteDatabase.openOrCreateDatabase(SQLiteDatabase.java:1051)
    E/SQLiteDatabase(  270):     at android.app.ContextImpl.openOrCreateDatabase(ContextImpl.java:770)
    E/SQLiteDatabase(  270):     at android.content.ContextWrapper.openOrCreateDatabase(ContextWrapper.java:221)
    E/SQLiteDatabase(  270):     at android.database.sqlite.SQLiteOpenHelper.getWritableDatabase(SQLiteOpenHelper.java:157)
    E/SQLiteDatabase(  270):     at com.android.providers.media.MediaProvider$DatabaseHelper.getWritableDatabase(MediaProvider.java:323)
    E/SQLiteDatabase(  270):     at android.database.sqlite.SQLiteOpenHelper.getReadableDatabase(SQLiteOpenHelper.java:231)
    E/SQLiteDatabase(  270):     at com.android.providers.media.MediaProvider.query(MediaProvider.java:1902)
    E/SQLiteDatabase(  270):     at android.content.ContentProvider$Transport.query(ContentProvider.java:178)
    E/SQLiteDatabase(  270):     at android.media.MediaScanner.prescan(MediaScanner.java:985)
    E/SQLiteDatabase(  270):     at android.media.MediaScanner.scanDirectories(MediaScanner.java:1172)
    E/SQLiteDatabase(  270):     at com.android.providers.media.MediaScannerService.scan(MediaScannerService.java:104)
    E/SQLiteDatabase(  270):     at com.android.providers.media.MediaScannerService.access$300(MediaScannerService.java:49)
    E/SQLiteDatabase(  270):     at com.android.providers.media.MediaScannerService$ServiceHandler.handleMessage(MediaScannerService.java:261)
    E/SQLiteDatabase(  270):     at android.os.Handler.dispatchMessage(Handler.java:99)
    E/SQLiteDatabase(  270):     at android.os.Looper.loop(Looper.java:137)
    E/SQLiteDatabase(  270):     at com.android.providers.media.MediaScannerService.run(MediaScannerService.java:183)
    E/SQLiteDatabase(  270):     at java.lang.Thread.run(Thread.java:856)
    E/SQLiteDatabase(  270):     at android.media.MediaScanner.prescan(MediaScanner.java:1023)
    E/SQLiteDatabase(  270):     at com.android.providers.media.MediaProvider.insertInternal(MediaProvider.java:2981)
    E/SQLiteDatabase(  270):     at com.android.providers.media.MediaProvider.insert(MediaProvider.java:2478)
    E/SQLiteDatabase(  270):     at android.content.ContentProvider$Transport.insert(ContentProvider.java:189)
    E/SQLiteDatabase(  270):     at android.media.MediaScanner$MyMediaScannerClient.endFile(MediaScanner.java:875)
    E/SQLiteDatabase(  270):     at android.media.MediaScanner$MyMediaScannerClient.doScanFile(MediaScanner.java:558)
    E/SQLiteDatabase(  270):     at android.media.MediaScanner$MyMediaScannerClient.scanFile(MediaScanner.java:525)
    E/SQLiteDatabase(  270):     at android.media.MediaScanner.processDirectory(Native Method)
    E/SQLiteDatabase(  270):     at android.media.MediaScanner.scanDirectories(MediaScanner.java:1181)
    D/MediaScannerReceiver(  270): action: android.intent.action.MEDIA_MOUNTED path: /mnt/sdcard
    E/SQLiteDatabase(  270):     at com.android.providers.media.MediaProvider.insertFile(MediaProvider.java:2601)
    E/SQLiteDatabase(  270):     at com.android.providers.media.MediaProvider.insertInternal(MediaProvider.java:3135)
    D/dalvikvm(  152): GC_CONCURRENT freed 686K, 11% free 9076K/10119K, paused 2ms+6ms
    W/MediaScanner(  270): Error opening directory '/mnt/sdcard/', skipping: Permission denied.
    W/MediaScanner(  270): Error opening directory '/mnt/external_sd/', skipping: Permission denied.
    V/MediaScanner(  270): pruneDeadThumbnailFiles... android.database.sqlite.SQLiteCursor@4112fc20
    V/MediaScanner(  270): /pruneDeadThumbnailFiles... android.database.sqlite.SQLiteCursor@4112fc20
    I/CalendarProvider2(  563): Sending notification intent: Intent { act=android.intent.action.PROVIDER_CHANGED dat=content://com.android.calendar }
    W/ContentResolver(  563): Failed to get type for: content://com.android.calendar (Unknown URL content://com.android.calendar)
    E/uim-sysfs(  651): uim: Inside main
    E/uim-sysfs(  651): uim:BT/FM/GPS would be unavailable on system
    D/dalvikvm(  563): GC_CONCURRENT freed 329K, 7% free 6599K/7047K, paused 4ms+1ms
    E/Ethernet(  152): DHCP request error:Timed out waiting for dhcpcd to start
    E/WifiHW  (  152): Supplicant not running, cannot connect
    E/uim-sysfs(  653): uim: Inside main
    E/uim-sysfs(  653): uim:BT/FM/GPS would be unavailable on system
    E/WifiStateMachine(  152): Failed to setup control channel, restart supplicant
    E/uim-sysfs(  658): uim: Inside main
    E/uim-sysfs(  658): uim:BT/FM/GPS would be unavailable on system
    I/wpa_supplicant(  679): rfkill: Cannot open RFKILL control device
    E/wpa_supplicant(  679): Could not read interface wlan0 flags: No such device
    E/wpa_supplicant(  679): nl80211: Could not set interface 'wlan0' UP
    E/wpa_supplicant(  679): wlan0: Failed to initialize driver interface
    E/uim-sysfs(  705): uim: Inside main
    E/uim-sysfs(  705): uim:BT/FM/GPS would be unavailable on system
    E/uim-sysfs(  706): uim: Inside main
    E/uim-sysfs(  706): uim:BT/FM/GPS would be unavailable on system
    E/uim-sysfs(  707): uim: Inside main
    E/uim-sysfs(  707): uim:BT/FM/GPS would be unavailable on system
    E/uim-sysfs(  708): uim: Inside main
    E/uim-sysfs(  708): uim:BT/FM/GPS would be unavailable on system
    I/wpa_supplicant(  729): rfkill: Cannot open RFKILL control device
    E/wpa_supplicant(  729): Could not read interface wlan0 flags: No such device
    E/wpa_supplicant(  729): nl80211: Could not set interface 'wlan0' UP
    E/wpa_supplicant(  729): wlan0: Failed to initialize driver interface
    E/uim-sysfs(  755): uim: Inside main
    E/uim-sysfs(  755): uim:BT/FM/GPS would be unavailable on system
    E/uim-sysfs(  756): uim: Inside main
    E/uim-sysfs(  756): uim:BT/FM/GPS would be unavailable on system
    E/uim-sysfs(  757): uim: Inside main
    E/uim-sysfs(  757): uim:BT/FM/GPS would be unavailable on system
    E/uim-sysfs(  758): uim: Inside main
    E/uim-sysfs(  758): uim:BT/FM/GPS would be unavailable on system
    I/wpa_supplicant(  779): rfkill: Cannot open RFKILL control device
    E/wpa_supplicant(  779): Could not read interface wlan0 flags: No such device
  • Hi Vinay,
    From overlay3 output, it seems like you are having both the home screen and status bar getting cloned on to HDMI TV using overlay2 and overlay3.
    As far as HDMI timing selection is concerned, as per the logcat output, the Android HWC framework is picking VGA as the best resolution in your case as pointed in the output below.
    I/ti_hwc  (   86): clone region is set to (0,0) to (1280,720)
    D/ti_hwc  (   86): #0: 640x480 59Hz
    D/ti_hwc  (   86): #1: 640x480 72Hz
    D/ti_hwc  (   86): #2: 640x480 75Hz
    D/ti_hwc  (   86): #3: 800x600 56Hz
    D/ti_hwc  (   86): #4: 800x600 60Hz
    D/ti_hwc  (   86): #5: 800x600 72Hz
    D/ti_hwc  (   86): #6: 800x600 75Hz
    D/ti_hwc  (   86): #7: 1024x768 60Hz
    D/ti_hwc  (   86): #8: 1024x768 70Hz
    D/ti_hwc  (   86): #9: 1024x768 75Hz
    D/ti_hwc  (   86): #10: 1280x1024 75Hz
    D/ti_hwc  (   86): #11: 1280x1024 60Hz
    D/ti_hwc  (   86): #12: 1280x960 60Hz
    D/ti_hwc  (   86): #13: 1152x864 75Hz
    D/ti_hwc  (   86): #14: 1024x768 85Hz
    D/ti_hwc  (   86): #15: 800x600 85Hz
    D/ti_hwc  (   86): picking #0
    I actually tried to change the timings on Blaze Tablet 2 using the sysfs command but it does not allow to change.
    echo " 74250,1280/110/220/40,720/5/20/5" > /sys/devices/platform/omapdss/display1/timings
    You can give a try to change the timings on your board and see if it changes. Otherwise, the only way we can enforce different timings of HDMI is to modify the HWC framework wherein it chooses the HDMI timings based on some pre-defined criteria such as maintaining aspect ratio etc.,
    Thanks & Best Regards,
    Venkat
  • Vinay,
    Please attached to the post, rather than include in the body of a post such long logs. It makes for easier reading, and faster debugging!
    Magdalena
    Thanks for the input, i changed the Aspect ratio in cea_modes array in Modedb.c from 4:3 to 16:9 for 640 by 480  resolution and it worked for me.
    Vinay
  • Hi Vinay,
    That is good. With this change in kernel, the framework would pick the 720p timings so that your cloned UI content occupies the full screen. I guess this would be alternate way of forcing the framework to choose the timings of your choice.
    Venkat
  • Hi all,
    I modified something in hwc.c to force choosing a certain HDMI resolution.
    The resolution can be changed as expectation. But the OMAP temperature getting hotter.
    Anyone face the same issue?
    PS: For testing purpose, hwc.c will read a value setting in a file. Each setting value corresponding to a resolution. When I want to change the resolution, I change the value in file. So I wonder whether reading file continuously in hwc.c causes this issue?
    JPhan
  • Hi All,
    I m having the similar problem with my omap4430 based custom board.
    when i turn on the board, some distorted coloured bar is coming when home screen comes up.
    the LCD resolution aspect ratio is 854/480 = 1.779
    #cat /sys/devices/platform/omapdss/overlay0/*
    1
    255
    854,480
    lcd
    gfx
    854,480
    0,0
    1
    864
    1..255
    1..255
    0
    #cat /sys/devices/platform/omapdss/overlay1/*
    0
    255
    812,455
    lcd
    vid1
    812,455
    0,25
    1
    832
    1..255
    1..255
    1
    #cat /sys/devices/platform/omapdss/overlay2/*
    0
    255
    854,25
    lcd
    vid2
    854,25
    0,0
    1
    864
    1..255
    1..255
    2
    #cat /sys/devices/platform/omapdss/overlay3/*
    0
    255
    42,480,
    lcd
    vid3
    42,480
    812,0
    0
    64
    1..255
    1..255
    3
    #cat /sys/devices/platform/omapdss/display0/timings
    31866, 854/24/104/80, 480/3/7/9
    #getprop persist.hwc.mirroring.region ->seems showing null
    see the logcat as an attached doc.
    plz help me how to resolve the coloured bar screen..
    I want homescreen to be clear.
    with regards
    -Kaushal
    0880.console log for resolution.txt
    Can anyone reply me why am i getting the screen_width as 864 for overlay0 and overlay2 cases??
    why am i getting different screen_width from the pixel width in all the cases ??
    how can we change the screen_width value ?
    could anyone plz help me??
    with regards
    -Kaushal
