Other Parts Discussed in Thread: DM3730
Hi everyone,
I'm using DM3730 with Android in a DevKit from LogicPD. I want to use an USB webcam but I can't. I have a Logitech c910 and it is an UVC camera:
I have followed many links and I can't find someone with same error. I just prove cam with froyo and gingerbread and I receive different errors. Obviously, I have built the kernel in both OS.
* (1) FROYO
It detects UVC cam and it creates /dev/video0: (shell)
usb 2-1.1: New USB device found, idVendor=046d, idProduct=0821
usb 2-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
usb 2-1.1: SerialNumber: BE66D3D0
PM: Adding info for usb:2-1.1
PM: Adding info for usb:2-1.1:1.0
PM: Adding info for No Bus:card1
PM: Adding info for No Bus:pcmC1D0c
PM: Adding info for No Bus:controlC1
PM: Adding info for usb:2-1.1:1.1
PM: Adding info for usb:2-1.1:1.2
uvcvideo: Found UVC 1.00 device <unnamed> (046d:0821)
PM: Adding info for No Bus:video0
PM: Adding info for No Bus:input3
input: UVC Camera (046d:0821) as /devices/platform/isp1763/usb2/2-1/2-1.1/2-1.1:1.2/input/input3
PM: Adding info for No Bus:event3
PM: Adding info for No Bus:ep_87
PM: Adding info for usb:2-1.1:1.3
PM: Adding info for No Bus:usbdev2.3
PM: Adding info for No Bus:ep_00
when I run camera app from Android I see in logcat this error:
01-01 07:21:05.742: DEBUG/dalvikvm(264): GC_EXTERNAL_ALLOC freed 9890 objects / 481936 bytes in 141ms
01-01 07:21:09.148: INFO/ActivityManager(190): Starting activity: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.android.camera/.Camera }
01-01 07:21:09.210: INFO/ActivityManager(190): Start proc com.android.camera for activity com.android.camera/.Camera: pid=438 uid=10004 gids={1006, 1015}
01-01 07:21:09.523: DEBUG/CameraHardware(58): Set Parameter...!!
01-01 07:21:09.523: DEBUG/CameraHardware(58): preview width:320,height:240
01-01 07:21:09.523: DEBUG/CameraHardware(58): Validating 1600, 320 and 1200, 240
01-01 07:21:09.523: DEBUG/CameraHardware(58): Validating 1024, 320 and 768, 240
01-01 07:21:09.531: DEBUG/CameraHardware(58): Validating 640, 320 and 480, 240
01-01 07:21:09.531: DEBUG/CameraHardware(58): Validating 352, 320 and 288, 240
01-01 07:21:09.531: DEBUG/CameraHardware(58): Validating 320, 320 and 240, 240
01-01 07:21:09.531: DEBUG/CameraHardware(58): picture width:320,height:240
01-01 07:21:09.531: DEBUG/CameraHardware(58): Validating 1600, 320 and 1200, 240
01-01 07:21:09.531: DEBUG/CameraHardware(58): Validating 1024, 320 and 768, 240
01-01 07:21:09.531: DEBUG/CameraHardware(58): Preview Format:yuv422sp,Picture Format:jpeg
01-01 07:21:09.570: DEBUG/Camera(438): app passed NULL surface
01-01 07:21:09.585: DEBUG/CameraHardware(58): Set Parameter...!!
01-01 07:21:09.585: DEBUG/CameraHardware(58): preview width:320,height:240
01-01 07:21:09.585: DEBUG/CameraHardware(58): Validating 1600, 320 and 1200, 240
01-01 07:21:09.585: DEBUG/CameraHardware(58): Validating 1024, 320 and 768, 240
01-01 07:21:09.585: DEBUG/CameraHardware(58): Validating 640, 320 and 480, 240
01-01 07:21:09.585: DEBUG/CameraHardware(58): Validating 352, 320 and 288, 240
01-01 07:21:09.585: DEBUG/CameraHardware(58): Validating 320, 320 and 240, 240
01-01 07:21:09.585: DEBUG/CameraHardware(58): picture width:1600,height:1200
01-01 07:21:09.585: DEBUG/CameraHardware(58): Validating 1600, 1600 and 1200, 1200
01-01 07:21:09.585: DEBUG/CameraHardware(58): Preview Format:yuv422sp,Picture Format:jpeg
01-01 07:21:09.585: VERBOSE/camera(438): startPreview
01-01 07:21:09.585: DEBUG/CameraHardware(58): startPreview :opening device!!!!,width:320,height:240
01-01 07:21:09.640: ERROR/V4L2Camera(58): StartStreaming: Unable to start capture: Broken pipe
01-01 07:21:09.640: ERROR/CameraHardware(58): Camera StartStreaming fail: Broken pipe
01-01 07:21:09.648: WARN/dalvikvm(438): threadid=8: thread exiting with uncaught exception (group=0x4001d7c8)
01-01 07:21:09.648: ERROR/AndroidRuntime(438): FATAL EXCEPTION: Thread-9
01-01 07:21:09.648: ERROR/AndroidRuntime(438): java.lang.RuntimeException: startPreview failed
01-01 07:21:09.648: ERROR/AndroidRuntime(438): at com.android.camera.Camera.startPreview(Camera.java:1677)
01-01 07:21:09.648: ERROR/AndroidRuntime(438): at com.android.camera.Camera.access$61(Camera.java:1655)
01-01 07:21:09.648: ERROR/AndroidRuntime(438): at com.android.camera.Camera$4.run(Camera.java:930)
01-01 07:21:09.648: ERROR/AndroidRuntime(438): at java.lang.Thread.run(Thread.java:1096)
01-01 07:21:09.648: ERROR/AndroidRuntime(438): Caused by: java.lang.RuntimeException: startPreview failed
01-01 07:21:09.648: ERROR/AndroidRuntime(438): at android.hardware.Camera.startPreview(Native Method)
01-01 07:21:09.648: ERROR/AndroidRuntime(438): at com.android.camera.Camera.startPreview(Camera.java:1674)
01-01 07:21:09.648: ERROR/AndroidRuntime(438): ... 3 more
01-01 07:21:09.671: WARN/ActivityManager(190): Force finishing activity com.android.camera/.Camera
01-01 07:21:09.851: DEBUG/dalvikvm(190): GC_FOR_MALLOC freed 7822 objects / 638632 bytes in 64ms
01-01 07:21:10.179: WARN/ActivityManager(190): Activity pause timeout for HistoryRecord{442181c0 com.android.camera/.Camera}
01-01 07:21:13.765: INFO/Process(438): Sending signal. PID: 438 SIG: 9
01-01 07:21:13.781: INFO/ActivityManager(190): Process com.android.camera (pid 438) has died.
01-01 07:21:13.906: WARN/InputManagerService(190): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@440276b8
01-01 07:21:20.273: WARN/ActivityManager(190): Activity destroy timeout for HistoryRecord{442181c0 com.android.camera/.Camera}
and in the shell I have seen:
PM: Adding info for No Bus:ep_81
PIPE_ISOCHRONOUS ain't supported
uvcvideo: Failed to submit URB 0 (-32).
Could you explain me why I have this error? I was seen in other post (http://e2e.ti.com/support/dsp/sitara_arm174_microprocessors/f/416/t/157015.aspx) that I should see v4l in /dev but I haven't seen it yet.
* (2) GINGERBREAD
It detects UVC cam and it creates /dev/video0 too: (shell)
[ 5.577484] platform mpu.0: omap_voltage_scale: Already at the requestedrate 600000000
<4>mmc0: host does not support reading read-only switch. assuming write-enable.
[ 5.601440] mmc0: host does not support reading read-only switch. assuming write-enable.
<6>mmc0: new high speed SDHC card at address 0007
[ 5.626647] mmc0: new high speed SDHC card at address 0007
<6>mmcblk0: mmc0:0007 SD4GB 3.70 GiB
[ 5.636383] mmcblk0: mmc0:0007 SD4GB 3.70 GiB
<6> mmcblk0: p1 p2
[ 5.646331] mmcblk0: p1 p2
omap_hsmmc_235_set_power: power_on 1
[ 5.653533] omap_hsmmc_235_set_power: power_on 1
omap_hsmmc_235_set_power: power_on 0
[ 5.781982] omap_hsmmc_235_set_power: power_on 0
<6>usb 1-1.1: New USB device found, idVendor=046d, idProduct=0821
[ 5.876068] usb 1-1.1: New USB device found, idVendor=046d, idProduct=0821
<6>usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 5.889739] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
<6>usb 1-1.1: SerialNumber: BE66D3D0
[ 5.900817] usb 1-1.1: SerialNumber: BE66D3D0
<4>platform iva.0: omap_voltage_scale: Already at the requestedrate 520000000
[ 5.913940] platform iva.0: omap_voltage_scale: Already at the requestedrate 520000000
<4>platform mpu.0: omap_voltage_scale: Already at the requestedrate 600000000
[ 5.929351] platform mpu.0: omap_voltage_scale: Already at the requestedrate 600000000
<6>twl_rtc twl_rtc: setting system clock to 2000-01-01 07:33:43 UTC (946712023)
[ 5.953460] twl_rtc twl_rtc: setting system clock to 2000-01-01 07:33:43 UTC (946712023)
<6>omap_vout omap_vout: Buffer Size = 3686400
[ 5.966339] omap_vout omap_vout: Buffer Size = 3686400
<6>omap_vout omap_vout: : registered and initialized video device 0
[ 5.990661] omap_vout omap_vout: : registered and initialized video device 0
[ 6.002288] omap_vout omap_vout: Buffer Size = 3686400
<6>omap_vout omap_vout: : registered and initialized video device 1
[ 6.014831] omap_vout omap_vout: : registered and initialized video device 1
<6>uvcvideo: Found UVC 1.00 device <unnamed> (046d:0821)
[ 6.380706] uvcvideo: Found UVC 1.00 device <unnamed> (046d:0821)
<6>input: UVC Camera (046d:0821) as /devices/platform/isp1763/usb1/1-1/1-1.1/1-1.1:1.2/input/input3
[ 6.410461] input: UVC Camera (046d:0821) as /devices/platform/isp1763/usb1/1-1/1-1.1/1-1.1:1.2/input/input3
<6>EXT3-fs: barriers not enabled
I/ActivityManager( 234): Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.android.camera/.Camera } from pid 319
I/ActivityManager( 234): Start proc com.android.camera for activity com.android.camera/.Camera: pid=530 uid=10009 gids={1006, 1015}
V/CameraHolder( 530): open camera 0
V/Camera ( 530): connect
D/CameraHardwareStub( 79): initHeapLocked: preview size=320x240
I/StagefrightPlayer( 79): setDataSource('/system/media/audio/ui/camera_click.ogg')
I/StagefrightPlayer( 79): setDataSource('/system/media/audio/ui/VideoRecord.ogg')
V/Camera ( 530): getParameters
V/Camera ( 530): setPreviewDisplay
D/Camera ( 530): app passed NULL surface
V/Camera ( 530): sendCommand
V/Camera ( 530): setParameters
V/camera ( 530): startPreview
V/Camera ( 530): startPreview
D/dalvikvm( 234): GREF has increased to 401
I/ActivityManager( 234): Displayed com.android.camera/.Camera: +1s377ms
W/OrientationEventListener( 530): Cannot detect sensors. Not enabled
D/dalvikvm( 530): GC_CONCURRENT freed 467K, 51% free 2872K/5767K, external 901K/1038K, paused 2ms+2ms
E/SurfaceFlinger( 234): LayerBuffer::BufferSource::postBuffer() invalid buffer (offset=345600, size=153600, heap-size=462848
W/AudioPolicyManagerALSA( 79): AudioPolicyManagerALSA::getStrategyForStream() Stub Called...
W/AudioPolicyManagerALSA( 79): redirecting AudioPolicyManagerALSA::getStrategy()
D/libEGL ( 530): loaded /system/lib/egl/libGLES_android.so
D/libEGL ( 530): loaded /system/lib/egl/libEGL_POWERVR_SGX530_125.so
D/libEGL ( 530): loaded /system/lib/egl/libGLESv1_CM_POWERVR_SGX530_125.so
D/libEGL ( 530): loaded /system/lib/egl/libGLESv2_POWERVR_SGX530_125.so
V/GLRootView( 530): onSurfaceChanged: 355x266, gl10: com.google.android.gles_jni.GLImpl@406ce180
V/GLRootView( 530): layout content pane 355x266
D/dalvikvm( 234): GC_CONCURRENT freed 811K, 43% free 4392K/7687K, external 1775K/2975K, paused 2ms+10ms
V/camera ( 530): stopPreview
V/Camera ( 530): stopPreview
V/Camera ( 530): setPreviewCallbackFlags
V/Camera ( 530): disconnect
W/OrientationEventListener( 530): Cannot detect sensors. Invalid disable
E/dhcpcd ( 84): timed out
In this case, the app haven't broken and the error from SurfaceFlinger always appear.
I am seeing that many people use Logitech Webcam Pro 9000 and it runs well with froyo and gingerbread. But, I think that c910 don't have many differences with Pro 9000 and it could be used with Android...
Any suggestion are appreciate.
