Other Parts Discussed in Thread: 4430, TWL6030
Hi
I am using custom tablet board with 4430. When it uses L27.IS.1 release, there is no problem. After I move to 4AI.i.3, I2C 2 can't work and the tablet automatically reboots after a while.
I can see the error message such as :
omap_i2c omap_i2c.2: controller timed out
CUSTOM SRESP error with SOURCE:L4 PER2
here is my error log:
Texas Instruments Inc X-Loader 1.41.0 (Apr 27 2012 - 09:25:39)
Starting OS Bootloader from EMMC ...
U-Boot 1.1.4 (Apr 27 2012 - 09:25:08)
Load address: 0x80e80000
DRAM: 1024 MB
Flash: 0 kB
Reserving 10240k for LCD Framebuffer at: 80db7000
Using default environment
Video: 1024x768x32 11kHz 14Hz
32
pGD->frameAdrs 817B7000
The omap register is 0x0
OMAP DSS rev 4.0
OMAP DISPC rev 4.0
OMAP DSI rev 3.0
=====omap_pre_init_dispc===464
=====omap_pre_init_dispc===465
timing_h is 32577797 timing_v is 15732487
Should be run the 38400000 case
The cinfo->dsi_pll_dispc_fclk is 132715748l
The cinfo->dsi_pll_dsi_fclk is 132715748l
L_dsi_pll_dispc_fclk is 132715748
ddr_clk_pre 24, ddr_clk_post 16
enter_hs_mode_lat 14, exit_hs_mode_lat 15
LP_CLK_DIV 5, LP_CLK 8847716
STOP_STATE_COUNTER 4096 ticks (0x1000) = 46545 ns
TA_TO 1048448 ticks (0x1fff x8 x16) = 11914181 ns
LP_RX_TO 524224 ticks (0x1fff x4 x16) = 5957090 ns
HS_TX_TO 524224 ticks (0x1fff x4 x16) = 10698448 ns
TEST THE VALUE 64
TEST THE VALUE 0
TEST THE VALUE 64
TEST THE VALUE41 0
>>>omapdss_dsi_display_enable Success<<<
>>>Start configure the panel d2l<<<
>>>Turn on the LCD out<<<
>>>The LCD should be show<<<
Video: Drawing the logo ...
timed out in wait_for_pin: I2C_STAT=0
I2C write: I/O error
** Unable to use mmc 0:1 for fatload **
In: serial
Out: serial
Err: serial
Initializing SD(0) Slot.
ptbl slot: SD:(0).
Read not permitted as Card on SLOT-0 not Initialized
efi partition table not found
efi partition table:
ptbl slot: EMMC:(1).
256 128K xloader
512 256K bootloader
1024 128K misc
2048 16M efs
34816 16K crypto
34848 8M recovery
51232 8M boot
67616 512M system
1116192 256M cache
1640480 6830M userdata
Net: KS8851SNL
=default=bootcmd=booti mmc0
=changed=bootcmd=booti mmc1
Hit any key to stop autoboot: 0
kernel @ 80008000 (4155360)
ramdisk @ 81000000 (165280)
I2C read: I/O error
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.0.21-00002-OMAP-Android+ (root@linuxserver) (gcc version 4.4.1 (Sourcery G++ Lite 2010q1-202) ) #4 SMP PREEMPT Thu May 17 11:45:27 CST 2012
[ 0.000000] CPU: ARMv7 Processor [411fc093] revision 3 (ARMv7), cr=10c5387d
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: OMAP4 blaze board
[ 0.000000] Ignoring unrecognised tag 0x54410008
[ 0.000000] Reserving 16777216 bytes SDRAM for VRAM
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] OMAP4430 ES2.3
[ 0.000000] SRAM: Mapped pa 0x40300000 to va 0xfe400000 size: 0xd000
[ 0.000000] On node 0 totalpages: 174080
[ 0.000000] free_area_init_node: node 0, pgdat c0804b00, node_mem_map c1029000
[ 0.000000] Normal zone: 256 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 32512 pages, LIFO batch:7
[ 0.000000] HighMem zone: 1792 pages used for memmap
[ 0.000000] HighMem zone: 139520 pages, LIFO batch:31
[ 0.000000] PERCPU: Embedded 7 pages/cpu @c1834000 s7072 r8192 d13408 u32768
[ 0.000000] pcpu-alloc: s7072 r8192 d13408 u32768 alloc=8*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 172032
[ 0.000000] Kernel command line: console=ttyO2,115200n8 mem=1G vmalloc=768M androidboot.console=ttyO2 omap_wdt.timer_margin=30 androidboot.serialno=4C56002600000001 androidboot.bootloader=U-Boot_1.1.4
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 512MB 168MB = 680MB total
[ 0.000000] Memory: 678196k/678196k available, 370380k reserved, 565248K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
[ 0.000000] vmalloc : 0xc8800000 - 0xf8000000 ( 760 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc8000000 ( 128 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .init : 0xc0008000 - 0xc004f000 ( 284 kB)
[ 0.000000] .text : 0xc004f000 - 0xc0798000 (7460 kB)
[ 0.000000] .data : 0xc0798000 - 0xc0805660 ( 438 kB)
[ 0.000000] .bss : 0xc0805684 - 0xc0955f60 (1347 kB)
[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:410
[ 0.000000] omap_hwmod: dpll_mpu_m2_ck: missing clockdomain for dpll_mpu_m2_ck.
[ 0.000000] OMAP clockevent source: GPTIMER1 at 32768 Hz
[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms
[ 0.000061] Calibrating delay loop... 1194.24 BogoMIPS (lpj=4665344)
[ 0.015655] pid_max: default: 32768 minimum: 301
[ 0.015655] Mount-cache hash table entries: 512
[ 0.071746] Initializing cgroup subsys debug
[ 0.071746] Initializing cgroup subsys cpuacct
[ 0.071746] Initializing cgroup subsys freezer
[ 0.071746] CPU: Testing write buffer coherency: ok
[ 0.072448] L310 cache controller enabled
[ 0.072448] l2x0: 16 ways, CACHE_ID 0x410000c4, AUX_CTRL 0x5e470000, Cache size: 1048576 B
[ 0.150604] CPU1: Booted secondary processor
[ 0.166198] Brought up 2 CPUs
[ 0.181884] SMP: Total of 2 processors activated (2388.48 BogoMIPS).
[ 0.182159] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for emif_fw
[ 0.186248] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l3_instr
[ 0.186279] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l3_main_1
[ 0.186279] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l3_main_2
[ 0.186309] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_abe
[ 0.186309] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_cfg
[ 0.186340] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_per
[ 0.186340] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_wkup
[ 0.186340] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for mpu_private
[ 0.186431] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for sl2if
[ 0.186431] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for usbhs_ohci
[ 0.186431] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for usbhs_ehci
[ 0.186798] omap_hwmod: l3_div_ck: missing clockdomain for l3_div_ck.
[ 0.193756] omap_hwmod: dss_rfbi: softreset failed (waited 10000 usec)
[ 0.213104] print_constraints: dummy:
[ 0.213714] NET: Registered protocol family 16
[ 0.213714] GPMC revision 6.0
[ 0.213714] EMIF0 is enabled with IRQ142
[ 0.215515] EMIF1 is enabled with IRQ143
[ 0.215515] Last reset was cold reset (PRM_RSTST=0x1)
[ 0.215515]
[ 0.216186] OMAP GPIO hardware version 0.1
[ 0.217712] omap_mux_init: Add partition: #1: core, flags: 2
[ 0.220184] omap_mux_init: Add partition: #2: wkup, flags: 2
[ 0.220916] omap_mux_get_by_name: Could not find signal c2c_data15.gpio104
[ 0.220916] omap_mux_get_by_name: Could not find signal c2c_data11.gpio100
[ 0.223083] omap_mux_get_by_name: Could not find signal uart1_cts.uart1_cts
[ 0.223510] omap_hwmod_mux_init: Could not allocate device mux entry
[ 0.231140] HSI: skipping omap_device registration
[ 0.231628] OMAP DMA hardware revision 0.0
[ 0.231628] omap_rproc_get_pool: dsp - no carveout memory is available at all
[ 0.232238] omap_rproc_get_pool: ipu - carveout memory is unavailable: 0x0, 0x0
[ 0.242919] bio: create slab <bio-0> at 0
[ 0.243316] i2c-core: driver [twl] using legacy suspend method
[ 0.244018] i2c-core: driver [twl] using legacy resume method
[ 0.244354] SCSI subsystem initialized
[ 0.245483] usbcore: registered new interface driver usbfs
[ 0.245941] usbcore: registered new interface driver hub
[ 0.246093] usbcore: registered new device driver usb
[ 0.246917] omap_i2c omap_i2c.1: bus 1 rev4.0 at 400 kHz
[ 0.246917] Skipping twl internal clock init and using bootloader value (unknown osc rate)
[ 0.251647] twl6030: PIH (irq 39) chaining IRQs 368..387
[ 0.254211] print_constraints: VUSB: 3300 mV normal standby
[ 1.283386] PC detected
[ 1.283996] twl6030_usb twl6030_usb: Initialized TWL6030 USB module
[ 1.284820] print_constraints: VMMC: 1200 <--> 3000 mV at 3000 mV normal standby
[ 1.285614] print_constraints: VPP: 1800 <--> 2500 mV at 1900 mV normal standby
[ 1.286468] print_constraints: VUSIM: 1200 <--> 2900 mV at 1800 mV normal standby
[ 1.287872] print_constraints: VCXIO: 1800 mV normal standby
[ 1.289184] print_constraints: VDAC: 1800 mV normal standby
[ 1.289611] print_constraints: VAUX1_6030: 1000 <--> 3000 mV at 2800 mV normal standby
[ 1.290283] print_constraints: VAUX2_6030: 1200 <--> 2800 mV at 1800 mV normal standby
[ 1.291198] print_constraints: VAUX3_6030: 1000 <--> 3000 mV at 1200 mV normal standby
[ 1.292694] print_constraints: VDD1:
[ 1.294128] print_constraints: VDD2:
[ 1.295501] print_constraints: V2V1: at 2100 mV
[ 1.296936] print_constraints: VANA: 2100 mV normal standby
[ 1.297790] print_constraints: CLK32KG:
[ 1.298797] print_constraints: CLK32KAUDIO:
[ 1.300109] print_constraints: SYSEN:
[ 1.301452] print_constraints: REGEN1:
[ 1.301452] print_constraints: VOUT: 4075 <--> 4950 mV at 3825 mV normal standby
[ 1.302520] tps6130x 1-0033: Revision 5
[ 1.303039] omap_i2c omap_i2c.2: bus 2 rev4.0 at 400 kHz
[ 1.303924] omap_i2c omap_i2c.3: bus 3 rev4.0 at 400 kHz
[ 1.304321] omap_i2c omap_i2c.4: bus 4 rev4.0 at 400 kHz
[ 1.305236] omap-rproc omap-rproc.0: dsp is available
[ 1.305236] omap-rproc omap-rproc.1: ipu is available
[ 1.305236] Advanced Linux Sound Architecture Driver Version 1.0.24.
[ 1.305236] Bluetooth: Core ver 2.16
[ 1.306427] NET: Registered protocol family 31
[ 1.306427] Bluetooth: HCI device and connection manager initialized
[ 1.306457] Bluetooth: HCI socket layer initialized
[ 1.306488] Bluetooth: L2CAP socket layer initialized
[ 1.306488] Bluetooth: SCO socket layer initialized
[ 1.306823] Switching to clocksource 32k_counter
[ 1.309204] musb-hdrc: version 6.0, musb-dma, otg (peripheral+host)
[ 1.314636] Switched to NOHz mode on CPU #0
[ 1.314666] Switched to NOHz mode on CPU #1
[ 1.605041] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 1.605041] musb-hdrc: MHDRC RTL version 2.0
[ 1.608917] musb-hdrc: setup fifo_mode 4
[ 1.608917] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 1.608947] musb-hdrc musb-hdrc: USB OTG mode controller at fc0ab000 using DMA, IRQ 124
[ 1.609619] NET: Registered protocol family 2
[ 1.609619] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 1.610229] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 1.611785] TCP bind hash table entries: 16384 (order: 6, 393216 bytes)
[ 1.611785] TCP: Hash tables configured (established 16384 bind 16384)
[ 1.611785] TCP reno registered
[ 1.612915] UDP hash table entries: 64 (order: 0, 4096 bytes)
[ 1.612976] UDP-Lite hash table entries: 64 (order: 0, 4096 bytes)
[ 1.613616] NET: Registered protocol family 1
[ 1.613983] RPC: Registered named UNIX socket transport module.
[ 1.614196] RPC: Registered udp transport module.
[ 1.614227] RPC: Registered tcp transport module.
[ 1.614227] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.614227] Trying to unpack rootfs image as initramfs...
[ 1.619445] Freeing initrd memory: 160K
[ 1.744415] omap_init_opp_table: no hwmod or odev for hsi, [18] cannot add OPPs.
[ 1.744415] omap_init_opp_table: no hwmod or odev for hsi, [19] cannot add OPPs.
[ 1.753967] ram_console: got buffer at a0000000, size 200000
[ 1.753967] ram_console: uncorrectable error in header
[ 1.753967] ram_console: no valid data in buffer (sig = 0x53470264)
[ 1.775207] console [ram-1] enabled
[ 1.776000] omap-iommu omap-iommu.0: ducati registered
[ 1.776367] omap-iommu omap-iommu.1: tesla registered
[ 1.791687] highmem bounce pool size: 64 pages
[ 1.791687] ashmem: initialized
[ 1.802185] fuse init (API version 7.16)
[ 1.803619] msgmni has been set to 220
[ 1.803619] Registering char device tf_driver (122:0)
[ 1.803619] SMCAG01.06.0 D
[ 1.806762] io scheduler noop registered
[ 1.806762] io scheduler deadline registered
[ 1.807128] io scheduler cfq registered (default)
[ 1.807128] start plist test
[ 1.807128] end plist test
[ 1.815338] OMAP DSS rev 4.0
[ 1.818542] tc358765_i2c 4-000f: D2L i2c initialized
[ 1.819091] tc358765 display0: tc358765_probe
[ 1.819305] tc358765 display0: tc358765_probe done
[ 1.819305] dsscomp: initializing.
[ 1.819305] misc dsscomp: display0=tc358765
[ 1.819946] misc dsscomp: display1=hdmi_panel
[ 1.820251] misc dsscomp: found 2 displays and 4 overlays
[ 1.820861] could not allocate slot
[ 1.821472] omap-rproc omap-rproc.1: powering up ipu
[ 1.821929] virtio_rpmsg_bus virtio0: rpmsg backend virtproc probed successfully
[ 1.822052] virtio_rpmsg_bus virtio1: rpmsg backend virtproc probed successfully
[ 1.823974] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 104) is a OMAP UART0
[ 1.824859] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 105) is a OMAP UART1
[ 1.825408] omap_uart.2: ttyO2 at MMIO 0x48020000 (irq = 106) is a OMAP UART2
[ 2.981475] console [ttyO2] enabled
[ 2.985626] omap_uart.3: ttyO3 at MMIO 0x4806e000 (irq = 102) is a OMAP UART3
[ 2.994689] omap_ion_probe: adding heap secure_input of type 2 with ba300000@5a00000
[ 3.003295] omap_ion_probe: adding heap tiler of type 4 with ada00000@6000000
[ 3.009735] omap_ion_probe: adding heap nonsecure_tiler of type 4 with a0200000@2000000
[ 3.027130] brd: module loaded
[ 3.033477] loop: module loaded
[ 3.040283] (stk) :sysfs entries created
[ 3.040283] (stk) : debugfs entries created
[ 3.049987] No CPUfreq policy at this point.
[ 3.063690] twl: i2c_write failed to transfer all messages (addr 0x004b, reg 4, len 2)
[ 3.075378] PPP generic driver version 2.4.2
[ 3.081604] PPP Deflate Compression module registered
[ 3.081604] PPP BSD Compression module registered
[ 3.093872] PPP MPPE Compression module registered
[ 3.099365] NET: Registered protocol family 24
[ 3.104370] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.114624] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 3.121093] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
[ 3.127227] ehci-omap ehci-omap.0: irq 109, io mem 0x4a064c00
[ 3.150726] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 3.150726] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.164855] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.172973] usb usb1: Product: OMAP-EHCI Host Controller
[ 3.178894] usb usb1: Manufacturer: Linux 3.0.21-00002-OMAP-Android+ ehci_hcd
[ 3.186889] usb usb1: SerialNumber: ehci-omap.0
[ 3.191986] hub 1-0:1.0: USB hub found
[ 3.191986] hub 1-0:1.0: 3 ports detected
[ 3.242462] usbcore: registered new interface driver cdc_acm
[ 3.242462] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 3.257934] Initializing USB Mass Storage driver...
[ 3.263641] usbcore: registered new interface driver usb-storage
[ 3.263641] USB Mass Storage support registered.
[ 3.270324] usbcore: registered new interface driver usbserial
[ 3.282257] usbserial: USB Serial Driver core
[ 3.588470] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 3.596130] android_usb gadget: Number of LUNs=1
[ 3.596130] lun0: LUN: removable file: (no medium)
[ 3.606842] android_usb gadget: android_usb ready
[ 3.606842] musb-hdrc musb-hdrc: MUSB HDRC host driver
[ 3.618164] musb-hdrc musb-hdrc: new USB bus registered, assigned bus number 2
[ 3.626373] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.634033] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.642150] usb usb2: Product: MUSB HDRC host driver
[ 3.642150] usb usb2: Manufacturer: Linux 3.0.21-00002-OMAP-Android+ musb-hcd
[ 3.655700] usb usb2: SerialNumber: musb-hdrc
[ 3.661163] hub 2-0:1.0: USB hub found
[ 3.665466] hub 2-0:1.0: 1 port detected
[ 3.968627] mousedev: PS/2 mouse device common for all mice
[ 3.975677] gpio-keys gpio-keys: failed to request GPIO 104, error -16
[ 3.983154] gpio-keys: probe of gpio-keys failed with error -16
[ 3.990417] [egalax_i2c]: /proc/egalax_dbg created
[ 3.990417] [egalax_i2c]: Driver init done!
[ 3.990417] [egalax_i2c]: Start probe
[ 4.005004] input: eGalax_Touch_Screen as /devices/virtual/input/input0
[ 4.005004] [egalax_i2c]: Register input device done
[ 4.018768] [egalax_i2c]: Request irq(312) gpio(152) with result:0
[ 4.025939] [egalax_i2c]: Get Device type=0
[ 4.030822] [egalax_i2c]: Register early_suspend done
[ 4.036804] [egalax_i2c]: I2C probe done
[ 4.036804] twl6030_pwrbutton_probe: Enter
[ 4.046997] input: twl6030_pwrbutton as /devices/platform/omap/omap_i2c.1/i2c-1/1-0049/twl6030_pwrbutton/input/input1
[ 4.060791] input: cwmi_acc as /devices/virtual/input/input2
[ 4.060791] input: cwmi_orientation as /devices/virtual/input/input3
[ 4.060791] cwmi_acc i2c device created (Interruptible=0).
[ 4.081207] input: cwmi_mag as /devices/virtual/input/input4
[ 4.087768] cwmi_mag i2c device created (Interruptible=0).
[ 4.087768] i2c-core: driver [cwmi] using legacy suspend method
[ 4.087768] i2c-core: driver [cwmi] using legacy resume method
[ 4.107269] CyWee CWGD 3-axis digital Gyroscope: probe start.
[ 4.114196] i2c Device detected!
[ 4.118072] tony: cwgd_probe(): =0xd3 WHOAMI_CWGD=0xd3
[ 4.123901] tony: cwgd_probe(): sensor->client->irq=0
[ 4.129730] input: CyWee CWGD 3-axis digital Gyroscope as /devices/platform/omap/omap_i2c.2/i2c-2/2-0069/input/input5
[ 4.141784] tony: cwgd_probe(): ok
[ 4.145935] CyWee CWGD 3-axis digital Gyroscope probed: device created successfully: interruptible: 0 irq=0
[ 4.160369] using rtc device, twl_rtc, for alarms
[ 4.160858] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
[ 4.173278] i2c /dev entries driver
[ 4.177368] lirc_dev: IR Remote Control driver registered, major 249
[ 4.177368] IR NEC protocol handler initialized
[ 4.190551] IR RC5(x) protocol handler initialized
[ 4.190551] IR RC6 protocol handler initialized
[ 4.195983] IR JVC protocol handler initialized
[ 4.206207] IR Sony protocol handler initialized
[ 4.206207] IR RC5 (streamzap) protocol handler initialized
[ 4.211364] IR LIRC bridge handler initialized
[ 4.217559] Linux video capture interface: v2.00
[ 4.227783] dmm: probe base: fd300000, irq 145
[ 4.518280] [egalax_i2c]: Close egalax_i2c_wq_loopback work
[ 4.524963] [egalax_i2c]: Get Device type=2
[ 5.987030] Invalid Device Structure
[ 5.987030] Failed: change interconnect bandwidth to 0
[ 6.174133] omap_i2c omap_i2c.2: controller timed out
[ 7.174163] omap_i2c omap_i2c.2: controller timed out
[ 9.168518] omap_i2c omap_i2c.2: controller timed out
[ 10.166259] omap_i2c omap_i2c.2: controller timed out
[ 11.167022] omap_i2c omap_i2c.2: controller timed out
[ 13.685516] omap_i2c omap_i2c.2: controller timed out
[ 14.682189] omap_i2c omap_i2c.2: controller timed out
[ 16.675964] omap_i2c omap_i2c.2: controller timed out
[ 16.683715] ltr328 init start......
[ 16.687713] [ LTR328 ] LTR328 probe
[ 16.692077] input: LTR328 Light Sensor as /devices/platform/omap/omap_i2c.2/i2c-2/2-0029/input/input6
[ 16.692077] [ LTR328 ] input_register_device err = 0
[ 16.708526] [ LTR328 ] ltr328_add_fs ret = 0
[ 16.713409] i2c-core: driver [ltr328] using legacy suspend method
[ 16.720336] i2c-core: driver [ltr328] using legacy resume method
[ 16.727844] OMAP Watchdog Timer Rev 0x00: initial timeout 30 sec
[ 16.736419] device-mapper: uevent: version 1.0.3
[ 16.742034] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
[ 16.751525] Bluetooth: HCI UART driver ver 2.2
[ 16.756530] Bluetooth: HCI H4 protocol initialized
[ 16.761993] Bluetooth: Bluetooth Driver for TI WiLink - Version 1.0
[ 16.770751] (stc): st_register(2)
[ 16.774505] (stc): chnl_id list empty :2
[ 16.779113] cpuidle: using governor ladder
[ 16.783721] cpuidle: using governor menu
[ 16.789367] (stk) : st_kim_start
[ 16.798126] omap4430_sdp_display_probe:Enter
[ 16.803405] Registered led device: lcd-backlight
[ 16.890869] mmc0: new high speed DDR MMC card at address 0001
[ 16.897796] mmcblk0: mmc0:0001 M8G2FA 7.45 GiB
[ 16.897827] (stk) :ldisc_install = 1
[ 16.907012] mmcblk0boot0: mmc0:0001 M8G2FA partition 1 512 KiB
[ 16.914031] mmcblk0boot1: mmc0:0001 M8G2FA partition 2 512 KiB
[ 16.924774] Alternate GPT is invalid, using primary GPT.
[ 16.930786] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10
[ 16.939788] mmcblk0boot1: unknown partition table
[ 16.946350] mmcblk0boot0: unknown partition table
[ 17.025665] omap4430_sdp_display_probe:Exit
[ 17.033172] usbcore: registered new interface driver usbhid
[ 17.039398] usbhid: USB HID core driver
[ 17.044311] logger: created 256K log 'log_main'
[ 17.049530] logger: created 256K log 'log_events'
[ 17.054992] logger: created 256K log 'log_radio'
[ 17.060333] logger: created 256K log 'log_system'
[ 17.065826] thermal_governor_dev_register:Adding omap_ondie_governor governor
[ 17.074920] OMAP HSI: HSI driver version 0.4.3
[ 17.080230] OMAP HSI: Platform DRIVER register FAILED: -19
[ 17.086944] usbcore: registered new interface driver snd-usb-audio
[ 17.097381] SDP4430 SoC init
[ 17.136840] asoc: null-codec-dai <-> MultiMedia1 mapping ok
[ 17.144622] asoc: null-codec-dai <-> MultiMedia2 mapping ok
[ 17.153106] asoc: null-codec-dai <-> Voice mapping ok
[ 17.160400] asoc: null-codec-dai <-> Tones mapping ok
[ 17.167724] asoc: null-codec-dai <-> Vibra mapping ok
[ 17.174407] asoc: null-codec-dai <-> MODEM mapping ok
[ 17.180999] asoc: null-codec-dai <-> MultiMedia1 LP mapping ok
[ 17.189605] asoc: FM Digital <-> omap-mcbsp-dai.1 mapping ok
[ 17.197601] asoc: twl6040-dl1 <-> mcpdm-dl mapping ok
[ 17.205596] asoc: dmic-hifi <-> omap-dmic-dai-0 mapping ok
[ 17.213958] twl6040-codec twl6040-codec: ASoC: Failed to create Aux/FM Stereo In debugfs file
[ 17.224670] asoc: twl6040-dl1 <-> mcpdm-dl1 mapping ok
[ 17.231597] asoc: twl6040-ul <-> mcpdm-ul1 mapping ok
[ 17.238311] asoc: twl6040-dl2 <-> mcpdm-dl2 mapping ok
[ 17.245208] asoc: twl6040-vib <-> mcpdm-vib mapping ok
[ 17.252044] asoc: Bluetooth <-> omap-mcbsp-dai.0 mapping ok
[ 17.259368] asoc: Bluetooth <-> omap-mcbsp-dai.0 mapping ok
[ 17.266723] asoc: FM Digital <-> omap-mcbsp-dai.1 mapping ok
[ 17.274200] asoc: MODEM <-> omap-mcbsp-dai.1 mapping ok
[ 17.281219] asoc: dmic-hifi <-> omap-dmic-abe-dai-0 mapping ok
[ 17.288818] asoc: dmic-hifi <-> omap-dmic-abe-dai-1 mapping ok
[ 17.296478] asoc: dmic-hifi <-> omap-dmic-abe-dai-2 mapping ok
[ 17.304107] asoc: null-codec-dai <-> omap-abe-vxrec-dai mapping ok
[ 17.313964] input: Tablet44xx Headset Jack as /devices/platform/soc-audio/sound/card0/input7
[ 17.327453] asoc: hdmi-audio-codec <-> hdmi-audio-dai mapping ok
[ 17.334838] ALSA device list:
[ 17.338287] #0: TI OMAP4 Board
[ 17.341918] #1: OMAP4HDMI
[ 17.345245] GACT probability NOT on
[ 17.349212] Mirror/redirect action on
[ 17.353393] u32 classifier
[ 17.356475] Actions configured
[ 17.360321] Netfilter messages via NETLINK v0.30.
[ 17.365753] nf_conntrack version 0.5.0 (10599 buckets, 42396 max)
[ 17.374114] ctnetlink v0.93: registering with nfnetlink.
[ 17.380584] xt_time: kernel timezone is -0000
[ 17.388885] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 17.395080] arp_tables: (C) 2002 David S. Miller
[ 17.400329] TCP cubic registered
[ 17.404968] NET: Registered protocol family 10
[ 17.418792] Mobile IPv6
[ 17.421600] IPv6 over IPv4 tunneling driver
[ 17.434997] NET: Registered protocol family 17
[ 17.440124] NET: Registered protocol family 15
[ 17.445220] Bluetooth: RFCOMM TTY layer initialized
[ 17.450714] Bluetooth: RFCOMM socket layer initialized
[ 17.456634] Bluetooth: RFCOMM ver 1.11
[ 17.460815] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 17.466857] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 17.473663] NET: Registered protocol family 35
[ 17.479339] NET: Registered protocol family 37
[ 17.484313] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 17.493041] ThumbEE CPU extension supported.
[ 17.497833] Registering SWP/SWPB emulation handler
[ 17.509307] Reprogramming LPDDR2 timings to 400000000 Hz
[ 17.515625] sr_init: No PMIC hook to init smartreflex
[ 17.521575] smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver initialized
[ 17.530517] smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver initialized
[ 17.539398] smartreflex smartreflex.2: omap_sr_probe: SmartReflex driver initialized
[ 17.548400] SmartReflex class 1.5 driver: initialized (86400000ms)
[ 17.555419] thermal_cooling_dev_register:Found cpu cpu
[ 17.562103] Power Management for TI OMAP4.
[ 17.566986] OMAP4 PM: Static dependency added between MPUSS <-> EMIF, MPUSS <-> L4_PER/CFG MPUSS <-> L3_MAIN_1.
[ 17.577941] OMAP4 PM: Static dependency added between DUCATI <-> L4_PER/CFG and DUCATI <-> L3.
[ 17.597564] clock: disabling unused clocks to save power
[ 17.650756] sr_class1p5_calib_work: mpu: Calibration complete: Voltage Nominal=1200000Calib=1088800 margin=0
[ 17.661437] sr_class1p5_calib_work: core: Calibration complete: Voltage Nominal=1127000Calib=1038160 margin=0
[ 17.672180] sr_class1p5_calib_work: iva: Calibration complete: Voltage Nominal=950000Calib=860920 margin=0
[ 17.775787] sr_class1p5_calib_work: core: Calibration complete: Voltage Nominal=962000Calib=886240 margin=0
[ 17.786590] sr_class1p5_calib_work: mpu: Calibration complete: Voltage Nominal=1025000Calib=924220 margin=0
[ 17.839752] cannot apply mgr(lcd) on inactive device
[ 17.845703] omapfb omapfb: failed to apply dispc config
[ 17.851745] cannot apply mgr(tv) on inactive device
[ 17.857604] omapfb omapfb: failed to apply dispc config
[ 17.863311] cannot apply mgr(lcd2) on inactive device
[ 17.868774] omapfb omapfb: failed to apply dispc config
[ 17.874450] tc358765 display0: enable
[ 17.878387] tc358765 display0: power_on
[ 18.025878] omapdss DSI error: rx fifo not empty when sending BTA, dumping data:
[ 18.034118] omapdss DSI error: rawval 0x17000202
[ 18.039581] omapdss DSI error: ACK with ERROR (0x2):
[ 18.045257] omapdss DSI error: SoT Sync Error
[ 18.049224] (stk) :ldisc installation timeout
[ 18.049255] (stk) :ldisc_install = 0
[ 18.096038] tc358765 display0: power_on done
[ 18.106079] twl_rtc twl_rtc: setting system clock to 2000-02-05 07:51:35 UTC (949737095)
[ 18.116607] Freeing init memory: 284K
[ 18.130828] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[ 18.273071] EXT4-fs (mmcblk0p8): INFO: recovery required on readonly filesystem
[ 18.281707] EXT4-fs (mmcblk0p8): write access will be enabled during recovery
[ 18.297515] EXT4-fs (mmcblk0p8): recovery complete
[ 18.314697] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: (null)
[ 19.205444] (stk) : timed out waiting for ldisc to be un-installed
[ 19.275665] sr_class1p5_calib_work: mpu: Calibration complete: Voltage Nominal=1388000Calib=1240720 margin=0
[ 19.318572] omap-rproc omap-rproc.1: Loaded BIOS image ducati-m3.bin, size 5756300
[ 19.326721] omap-rproc omap-rproc.1: BIOS image version is 2
[ 19.331359] (stk) :ldisc_install = 1
[ 19.387847] omap_hwmod: ipu: failed to hardreset
[ 19.393157] omap-iommu omap-iommu.0: ducati: version 2.1
[ 19.405975] omap-rproc omap-rproc.1: remote processor ipu is now up
[ 19.419403] omap_rpmsg_mbox_callback: received echo reply from ipu !
[ 19.426269] omap_rpmsg_mbox_callback: received echo reply from ipu !
[ 19.433074] omap_rpmsg_mbox_callback: received echo reply from ipu !
[ 19.439971] omap_rpmsg_mbox_callback: received echo reply from ipu !
[ 19.446777] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x32
[ 19.455291] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x33
[ 19.463989] virtio_rpmsg_bus virtio0: creating channel rpmsg-omx addr 0x3c
[ 19.471740] rpmsg_omx rpmsg-omx0: new OMX connection srv channel: 1024 -> 60!
[ 19.907592] virtio_rpmsg_bus virtio1: creating channel rpmsg-omx addr 0x3c
[ 19.916473] rpmsg_omx rpmsg-omx1: new OMX connection srv channel: 1024 -> 60!
[ 19.929626] EXT4-fs (mmcblk0p10): recovery complete
[ 19.940399] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit
[ 19.972595] EXT4-fs (mmcblk0p9): recovery complete
[ 19.982513] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: nomblk_io_submit
[ 19.993743] EXT4-fs (mmcblk0p4): VFS: Can't find ext4 filesystem
[ 20.118255] HDCP: failed to load keys
[ 20.131164] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
[ 20.251525] compat: version magic '3.0.21-00002-OMAP-Android SMP preempt mod_unload ARMv7 ' should be '3.0.21-00002-OMAP-Android+ SMP preempt mod_unload ARMv7 '
[ 20.478912] (stk) :ldisc installation timeout
[ 20.483673] (stk) :ldisc_install = 0
[ 20.523284] PVR: PVRCore_Init
[ 20.532043] PVR: PVRSRVDriverProbe(pDevice=c78a4000)
[ 20.539855] PVR: SGX register base: 0x56000000
[ 20.547851] PVR: SGX register size: 65535
[ 20.552490] PVR: SGX IRQ: 53
[ 20.555969] PVR: EnableSystemClocks: Enabling System Clocks
[ 20.562500] PVR: PVRCore_Init: major device 247
[ 20.585571] omaplfbOMAPLFBInit: Blitsville gc2d not present, blits disabled
[ 20.593902] omaplfb OMAPLFBInitIonOmap: Device 0: Requesting 2 TILER 2D framebuffers
[ 20.598663] cfg80211: version magic '3.0.21-00002-OMAP-Android SMP preempt mod_unload ARMv7 ' should be '3.0.21-00002-OMAP-Android+ SMP preempt mod_unload ARMv7 '
[ 20.923065] mac80211: version magic '3.0.21-00002-OMAP-Android SMP preempt mod_unload ARMv7 ' should be '3.0.21-00002-OMAP-Android+ SMP preempt mod_unload ARMv7 '
[ 20.979675] EXT4-fs (mmcblk0p8): re-mounted. Opts: (null)
[ 21.117095] wl12xx: version magic '3.0.21-00002-OMAP-Android SMP preempt mod_unload ARMv7 ' should be '3.0.21-00002-OMAP-Android+ SMP preempt mod_unload ARMv7 '
[ 21.162780] android_usb: already disabled
[ 21.174743] mtp_bind_config
[ 21.178100] adb_bind_config
[ 21.179473] PVR: Installing MISR with cookie bf038728
[ 21.183197] PVR: Installing device LISR SGX ISR on IRQ 53 with cookie c72bdc00
[ 21.183258] PVR: OSUnMapPhysToLin: unmapping 65535 bytes from c8be0000
[ 21.183258] PVR: SysFinalise: Version string: SGX revision = 1.2.0
[ 21.190521] EXT4-fs (mmcblk0p8): re-mounted. Opts: (null)
[ 21.216827] warning: `adbd' uses 32-bit capabilities (legacy support in use)
[ 21.225921] adb_open
[ 21.597045] rpmsg_omx rpmsg-omx1: local addr assigned: 0x401
[ 21.604370] rpmsg_omx rpmsg6: conn rsp: status 0 addr 101
[ 21.643920] (stk) : timed out waiting for ldisc to be un-installed
[ 21.675415] android_work: sent uevent USB_STATE=CONNECTED
[ 21.693023] android_work: sent uevent USB_STATE=DISCONNECTED
[ 21.757019] (stk) :ldisc_install = 1
[ 21.813446] tc358765 display0: disable
[ 21.813537] misc dsscomp: [c7303800] ignoring set failure -22
[ 21.849029] tc358765 display0: enable
[ 21.849029] tc358765 display0: power_on
[ 21.879547] android_work: sent uevent USB_STATE=CONNECTED
[ 21.884368] rprm_gpio_request: error providing gpio 38
[ 21.884399] rprm_resource_alloc: request for 10 (GPIO) failed: -16
[ 21.884399] rpmsg_resmgr rpmsg2: resource allocation failed! ret -16
[ 21.886322] omap_rpmsg_mbox_callback: ipu has just crashed !
[ 21.886352] dump_ipu_registers: REGISTER DUMP FOR REMOTEPROC ipu
[ 21.886383] dump_ipu_registers: PC is at 00000000
[ 21.886383] dump_ipu_registers: LR is at 002d2fab
[ 21.886413] dump_ipu_registers: pc : [<00000000>] lr : [<002d2fab>] psr: 20000000
[ 21.886413] sp : 8510e410 ip : 8510e378 fp : 00000000
[ 21.886444] dump_ipu_registers: r10: 8513c9a8 r9 : 00000004 r8 : 851278a8
[ 21.886444] dump_ipu_registers: r7 : 8513e140 r6 : 00000000 r5 : 8513c9a8 r4 : 00000000
[ 21.886474] dump_ipu_registers: r3 : 00000000 r2 : 00000004 r1 : 00000000 r0 : 8513e0f8
[ 21.886474] dump_ipu_registers: Flags: nzCv IRQs on FIQs on
[ 21.887145] _event_notify: remoteproc: ipu has crashed
[ 21.887176] rpmsg_rproc_error: Fatal error in ipu
[ 21.887207] omap_rpmsg_mbox_callback: ipu has just crashed !
[ 21.887207] rpmsg_reset_work: reseting virtio device 0
[ 21.887420] rpmsg_resmgr rpmsg0: Enter rprm_remove
[ 21.887634] android_usb gadget: high speed config #1: android
[ 21.889892] rpmsg_omx rpmsg-omx0: rpmsg omx driver is removed
[ 21.890899] rpmsg_reset_work: reseting virtio device 1
[ 21.891021] rpmsg_resmgr rpmsg2: Enter rprm_remove
[ 21.892425] rpmsg_omx rpmsg-omx1: rpmsg omx driver is removed
[ 21.895050] rproc_reset_poolmem: invalid pool
[ 21.895294] omap-rproc omap-rproc.1: stopped remote processor ipu
[ 21.896240] omap-rproc omap-rproc.1: powering up ipu
[ 21.896453] android_work: sent uevent USB_STATE=CONFIGURED
[ 21.898742] virtio_rpmsg_bus virtio2: rpmsg backend virtproc probed successfully
[ 21.900360] virtio_rpmsg_bus virtio3: rpmsg backend virtproc probed successfully
[ 21.954681] omap-rproc omap-rproc.1: Loaded BIOS image ducati-m3.bin, size 5756300
[ 21.954681] omap-rproc omap-rproc.1: BIOS image version is 2
[ 21.987213] omapdss DSI error: rx fifo not empty when sending BTA, dumping data:
[ 21.987243] omapdss DSI error: rawval 0x17000202
[ 21.987243] omapdss DSI error: ACK with ERROR (0x2):
[ 21.987274] omapdss DSI error: SoT Sync Error
[ 22.018188] tc358765 display0: power_on done
[ 22.282348] omap_hwmod: ipu: failed to hardreset
[ 22.288116] omap-iommu omap-iommu.0: ducati: version 2.1
[ 22.301635] omap-rproc omap-rproc.1: remote processor ipu is now up
[ 22.315277] omap_rpmsg_mbox_callback: received echo reply from ipu !
[ 22.323150] omap_rpmsg_mbox_callback: received echo reply from ipu !
[ 22.330627] omap_rpmsg_mbox_callback: received echo reply from ipu !
[ 22.338043] omap_rpmsg_mbox_callback: received echo reply from ipu !
[ 22.345489] virtio_rpmsg_bus virtio2: creating channel rpmsg-client-sample addr 0x32
[ 22.354766] virtio_rpmsg_bus virtio2: creating channel rpmsg-client-sample addr 0x33
[ 22.364166] virtio_rpmsg_bus virtio2: creating channel rpmsg-omx addr 0x3c
[ 22.372985] rpmsg_omx rpmsg-omx0: new OMX connection srv channel: 1024 -> 60!
[ 22.651336] virtio_rpmsg_bus virtio3: creating channel rpmsg-omx addr 0x3c
[ 22.663452] rpmsg_omx rpmsg-omx1: new OMX connection srv channel: 1024 -> 60!
[ 22.916320] (stk) :ldisc installation timeout
[ 22.920867] (stk) :ldisc_install = 0
[ 23.541381] sr_class1p5_calib_work: mpu: Calibration complete: Voltage Nominal=1325000Calib=1177420 margin=0
[ 24.096038] (stk) : timed out waiting for ldisc to be un-installed
[ 24.243988] (stk) :ldisc_install = 1
[ 25.400726] (stk) :ldisc installation timeout
[ 25.405609] (stk) :ldisc_install = 0
[ 26.564788] (stk) : timed out waiting for ldisc to be un-installed
[ 26.701965] (stk) :ldisc_install = 1[ cwmi ] cwmi_acc_report_values, x -48, y -32, z-960
[ 26.901123] [ cwmi ] cwmi_acc_report_values, x -48, y -16, z-1088
[ 26.916687] [ cwmi ] cwmi_acc_report_values, x -48, y -32, z-1120
[ 26.932800] [ cwmi ] cwmi_acc_report_values, x -48, y -16, z-1104
[ 26.947967] [ cwmi ] cwmi_acc_report_values, x -48, y -32, z-1120
[ 26.963592] [ cwmi ] cwmi_acc_report_values, x -48, y -16, z-1088
[ 26.979522] [ cwmi ] cwmi_acc_report_values, x -48, y -16, z-1104
[ 26.994964] [ cwmi ] cwmi_acc_report_values, x -48, y -16, z-1120
[ 27.010528] [ cwmi ] cwmi_acc_report_values, x -48, y -16, z-1104
[ 27.026031] [ cwmi ] cwmi_acc_report_values, x -48, y -16, z-1120
[ 27.041717] [ cwmi ] cwmi_acc_report_values, x -48, y -16, z-1120
[ 27.057403] [ cwmi ] cwmi_acc_report_values, x -48, y -32, z-1088
[ 27.072937] [ cwmi ] cwmi_acc_report_values, x -48, y -32, z-1104
[ 27.088684] [ cwmi ] cwmi_acc_report_values, x -48, y -16, z-1104
[ 27.104248] [ cwmi ] cwmi_acc_report_values, x -48, y -16, z-1104
[ 27.119842] [ cwmi ] cwmi_acc_report_values, x -48, y -16, z-1088
[ 27.135681] [ cwmi ] cwmi_acc_report_values, x -48, y -16, z-1104
[ 27.151214] [ cwmi ] cwmi_acc_report_values, x -64, y -16, z-1120
[ 27.166839] [ cwmi ] cwmi_acc_report_values, x -64, y -16, z-1120
[ 27.182281] [ cwmi ] cwmi_acc_report_values, x -48, y -16, z-1120
[ 27.197937] [ cwmi ] cwmi_acc_report_values, x -48, y -16, z-1120
[ 27.213531] [ cwmi ] cwmi_acc_report_values, x -48, y -16, z-1104
[ 27.229217] [ cwmi ] cwmi_acc_report_values, x -64, y -16, z-1104
[ 27.244903] [ cwmi ] cwmi_acc_report_values, x -48, y -16, z-1104
[ 27.260528] [ cwmi ] cwmi_acc_report_values, x -48, y -16, z-1120
[ 27.276123] [ cwmi ] cwmi_acc_report_values, x -64, y -32, z-1120
[ 27.292053] [ cwmi ] cwmi_acc_report_values, x -48, y -16, z-1120
[ 27.307281] [ cwmi ] cwmi_acc_report_values, x -48, y -16, z-1104
[ 27.322998] [ cwmi ] cwmi_acc_report_values, x -48, y -32, z-1120
[ 27.338592] [ cwmi ] cwmi_acc_report_values, x -64, y -32, z-1120
[ 27.354217] [ cwmi ] cwmi_acc_report_values, x -48, y -16, z-1120
[ 27.369873] [ cwmi ] cwmi_acc_report_values, x -64, y -16, z-1104
[ 27.385559] [ cwmi ] cwmi_acc_report_values, x -48, y -32, z-1104
[ 27.401123] [ cwmi ] cwmi_acc_report_values, x -48, y -16, z-1120
[ 27.416809] [ cwmi ] cwmi_acc_report_values, x -48, y -32, z-1104
[ 27.432434] [ cwmi ] cwmi_acc_report_values, x -48, y -16, z-1120
[ 27.447937] [ cwmi ] cwmi_acc_report_values, x -64, y -16, z-1120
[ 27.464996] [ cwmi ] cwmi_acc_report_values, x -48, y -16, z-1120
[ 27.487518] [ cwmi ] cwmi_acc_report_values, x -48, y -16, z-1120
[ 27.502593] [ cwmi ] cwmi_acc_report_values, x -48, y -16, z-1120
[ 27.518585] [ cwmi ] cwmi_acc_report_values, x -64, y -16, z-1120
[ 27.533935] [ cwmi ] cwmi_acc_report_values, x -64, y -16, z-1104
[ 27.549804] [ cwmi ] cwmi_acc_report_values, x -48, y -16, z-1120
[ 27.573059] [ cwmi ] cwmi_acc_report_values, x -48, y -16, z-1104
[ 27.588592] [ cwmi ] cwmi_acc_report_values, x -48, y -32, z-1104
[ 27.604248] [ cwmi ] cwmi_acc_report_values, x -64, y -16, z-1104
[ 27.611389] ------------[ cut here ]------------
[ 27.616363] WARNING: at arch/arm/mach-omap2/omap_l3_noc.c:135 l3_interrupt_handler+0x2e0/0x380()
[ 27.625762] CUSTOM SRESP error with SOURCE:L4 PER2
[ 27.630889] Modules linked in: omaplfb_sgx540_120 pvrsrvkm_sgx540_120
[ 27.638031] Backtrace:
[ 27.640777] [<c005a224>] (dump_backtrace+0x0/0x110) from [<c05db7a8>] (dump_stack+0x18/0x1c)
[ 27.649810] r6:00000087 r5:c007e91c r4:c7a65c08 r3:c7a64000
[ 27.656158] [<c05db790>] (dump_stack+0x0/0x1c) from [<c00a2b74>] (warn_slowpath_common+0x5c/0x6c)
[ 27.665649] [<c00a2b18>] (warn_slowpath_common+0x0/0x6c) from [<c00a2c28>] (warn_slowpath_fmt+0x38/0x40)
[ 27.675781] r8:00000002 r7:c8834b48 r6:00080003 r5:c07c8bd4 r4:c8834b00
[ 27.683074] r3:00000009
[ 27.686065] [<c00a2bf0>] (warn_slowpath_fmt+0x0/0x40) from [<c007e91c>] (l3_interrupt_handler+0x2e0/0x380)
[ 27.696380] r3:c070695c r2:c0706860
[ 27.700378] [<c007e63c>] (l3_interrupt_handler+0x0/0x380) from [<c00ea454>] (handle_irq_event_percpu+0x58/0x188)
[ 27.711242] [<c00ea3fc>] (handle_irq_event_percpu+0x0/0x188) from [<c00ea5c8>] (handle_irq_event+0x44/0x64)
[ 27.721649] [<c00ea584>] (handle_irq_event+0x0/0x64) from [<c00ecdd4>] (handle_fasteoi_irq+0xa4/0x10c)
[ 27.731597] r6:0000002a r5:c079bb8c r4:c079bb40 r3:c004d4f0
[ 27.737945] [<c00ecd30>] (handle_fasteoi_irq+0x0/0x10c) from [<c00e9f78>] (generic_handle_irq+0x40/0x48)
[ 27.748077] r5:c004deb0 r4:c07aa588
[ 27.752075] [<c00e9f38>] (generic_handle_irq+0x0/0x48) from [<c004f060>] (asm_do_IRQ+0x60/0xc0)
[ 27.761383] [<c004f000>] (asm_do_IRQ+0x0/0xc0) from [<c00559c8>] (__irq_svc+0x48/0xe0)
[ 27.769866] Exception stack(0xc7a65cf8 to 0xc7a65d40)
[ 27.775268] 5ce0: 00000080 00000028
[ 27.784027] 5d00: 00000028 00000000 c78f9c00 c079a080 c78f9c00 c7a65e40 0000601f c039aa0c
[ 27.792785] 5d20: ffff77cd c7a65d5c ffff77cd c7a65d40 c039a62c c039a6a8 40000113 ffffffff
[ 27.801483] r7:00000001 r6:0000002a r5:fa240100 r4:ffffffff
[ 27.807861] [<c039a614>] (omap_i2c_wait_for_bb+0x0/0xb4) from [<c039aad4>] (omap_i2c_xfer+0xc8/0x6b4)
[ 27.817718] r6:c78f9c00 r5:c060b374 r4:c78f9ca8 r3:000002fc
[ 27.824066] [<c039aa0c>] (omap_i2c_xfer+0x0/0x6b4) from [<c0398878>] (i2c_transfer+0xb8/0xec)
[ 27.833190] [<c03987c0>] (i2c_transfer+0x0/0xec) from [<c0398d14>] (i2c_smbus_xfer+0x3bc/0x61c)
[ 27.842498] [<c0398958>] (i2c_smbus_xfer+0x0/0x61c) from [<c0399024>] (i2c_smbus_read_i2c_block_data+0x54/0x78)
[ 27.853271] [<c0398fd0>] (i2c_smbus_read_i2c_block_data+0x0/0x78) from [<c0390194>] (cwmi_report_values+0x12c/0x7d4)
[ 27.864440] r6:c1838600 r5:c7a5a9c0 r4:c7a5a9c0
[ 27.869689] [<c0390068>] (cwmi_report_values+0x0/0x7d4) from [<c0390858>] (cwmi_work_func+0x1c/0x34)
[ 27.879455] r6:c1838600 r5:c7a5a9c0 r4:c7a5a9c8
[ 27.884613] [<c039083c>] (cwmi_work_func+0x0/0x34) from [<c00b9d8c>] (process_one_work+0x114/0x410)
[ 27.894287] r5:c18345c0 r4:c71e5f00
[ 27.898284] [<c00b9c78>] (process_one_work+0x0/0x410) from [<c00ba430>] (worker_thread+0x1a8/0x490)
[ 27.907958] [<c00ba288>] (worker_thread+0x0/0x490) from [<c00c1068>] (kthread+0x94/0x98)
[ 27.916625] [<c00c0fd4>] (kthread+0x0/0x98) from [<c00a7480>] (do_exit+0x0/0x720)
[ 27.924591] r7:00000013 r6:c00a7480 r5:c00c0fd4 r4:c783be94
[ 27.930969] ---[ end trace ec9bb1009c2cfb0a ]---
[ 27.935913] Master 0x0 MPU
[ 27.939544] L4 PER2 OPCODE 0x00000000
