Ata fs problem
I'm using EZDSP5535.
I try to write a file in an sdcard using ATAFS library, the problem is that I can execute the ATA_write function only one time. So I am unable to write several times in the same file, I can not open it with a hex editor to view its contents.
 When i plug the sdcard on the pc, a message informed me that the file is damaged.
I want to know if anyone has had this problem. If it does, can you explain the process to me?
Thanks a lot.
