This application is flashed and operates well on NON-secure C6748.
Now, I am trying to run it on SECURE C6748.
Firstly, compose an ini file, where genKeyHeaderFileName is not specified, on attached file.
Then create secure AIS with SecureHexAIS_OMAP-L138.exe.
Finally, I used GenericSecureUartHost.exe to boot that AIS file, and it seemed completed successfully as following log. However, the application does not operate.
What's wrong with my process!!!???
(File IO): Read 398648 bytes from file E:\secure\pack\CAM_ext.ais.
(Serial Port): Opening COM3 at 115200 baud...
(AIS Parse): Read magic word 0x41504954.
(AIS Parse): Waiting for BOOTME... (power on or reset target now)
(AIS Parse): BOOTME received!
(AIS Parse): Performing Start-Word Sync...
(AIS Parse): Performing Ping Opcode Sync...
(AIS Parse): Processing command 0: 0x58535920.
(AIS Parse): Performing Opcode Sync...
(AIS Parse): Secure key loading, entering secure mode.
(AIS Parse): Processing command 1: 0x58535923.
(AIS Parse): Setting boot exit mode...
(AIS Parse): Set exit mode to 0x00000000.
(AIS Parse): Processing command 2: 0x5853590D.
(AIS Parse): Executing function...
(AIS Parse): Secure mode; sending signature.
(AIS Parse): Processing command 3: 0x5853590D.
(AIS Parse): Processing command 4: 0x5853590D.
(AIS Parse): Processing command 5: 0x5853590D.
(AIS Parse): Processing command 6: 0x5853590D.
(AIS Parse): Processing command 7: 0x5853590D.
(AIS Parse): Processing command 8: 0x5853590D.
(AIS Parse): Processing command 9: 0x5853590D.
(AIS Parse): Processing command 10: 0x5853590D.
(AIS Parse): Processing command 11: 0x58535921.
(AIS Parse): Loading encoded section...
(AIS Parse): Loaded 216-Byte section to address 0xC0000000.
(AIS Parse): Processing command 12: 0x58535921.
(AIS Parse): Loaded 24-Byte section to address 0xC0AA3EC8.
(AIS Parse): Processing command 13: 0x58535921.
(AIS Parse): Loaded 992-Byte section to address 0xC0ADBC20.
(AIS Parse): Processing command 14: 0x58535921.
(AIS Parse): Loaded 363392-Byte section to address 0xC0ADC000.
(AIS Parse): Processing command 15: 0x58535921.
(AIS Parse): Loaded 27272-Byte section to address 0xC0B43B80.
(AIS Parse): Processing command 16: 0x58535921.
(AIS Parse): Loaded 512-Byte section to address 0xC0B4BC00.
(AIS Parse): Processing command 17: 0x58535921.
(AIS Parse): Loaded 1224-Byte section to address 0xC0B4BE00.
(AIS Parse): Processing command 18: 0x58535921.
(AIS Parse): Loaded 4364-Byte section to address 0xC0B4C480.
(AIS Parse): Processing command 19: 0x58535906.
(AIS Parse): Performing jump and close...
(AIS Parse): AIS complete. Jump to address 0xC0B30D60.
(AIS Parse): Waiting for DONE...
(AIS Parse): Boot completed successfully.
(Serial Port): Closing COM3.
Thank you very much in advance for you help!
An.
http://e2e.ti.com/cfs-file.ashx/__key/communityserver-discussions-components-files/115/1616.OMAP_2D00_L138_5F00_generic_5F00_secure.ini
