_p674.h
Other Parts Discussed in Thread: MATHLIB
I'm migrating from CCS v4 to CCs v5. After migrating a project from 4 to 5 (using the migration tool to convert .tcf to cfg), I'm getting the following error when I compile my new CCS v5 project:
fatal error #5: could not open source file "C:/Users/mask01/Documents/CCSWorkspace1/%CCSv5_PROJECT%/Debug/configPkg/package/cfg/%SOURCE_FILE_DIRECTORY%_p674.h"
where CCSv5_PROJECT and SOURCE_FILE_DIRECTORY are specific to my file path.
When I go to the above path in Windows 7, I find these two files:
%PROJECTNAME%_x674.cfg
%PROJECTNAME%_x674.mak
Where/what is this file: %SOURCE_FILE_DIRECTORY%_p674.h?
  • I've tried doing this:
    go to xdctools_3_22_04_46\packages\xdc\tools\configuro\template
    - saved a copy of package.bld.xdt so you I go back to its original content if needed
    - open package.bld.xdt
    - look for the line 124, which should contain:
      var suffix = '.p' + targ.suffix;
    - replace '.p' with '.x'
    in file package.xs.xdt. Find the line 31:
    base + '_p' + suffix + '.o' + suffix,
    and made the same change again, where 'p' is replaced by 'x', so the line becomes:
    base + '_x' + suffix + '.o' + suffix,
    Built the project again but get the same error. I'm using CCS vVersion: 5.1.1.00031, and XDC Tools xdctools_3_23_02_47.
  • This file %SOURCE_FILE_DIRECTORY%_p674.h does not exist. Is it supposed to before the project is compiled? Little help anyone? Thanks.
  • If you have only two files in the directory package/cfg. that indicates that your build already failed earlier. Can you post the whole console output, after you clean and rebuild the project?
  • Hi Sasha,
    After I clean and rebuild the project I get this output in the Problem window:
    Can't load platform definition 'ti.platforms.evm6748': Error: Can't load ti.bios.tci :Error: Can't find import file: 'ti/bios/bios.tci' (not found along 'C:\TI\xdctools_3_23_02_47\packages\ti\platforms\evm6748/;.;C:/TI/biospsp_03_00_01_00/drivers;C:/TI/dsplib_c674x_3_1_0_0/packages;C:/TI/edma3_lld_02_11_04_01/packages;C:/TI/ipc_1_23_05_40/packages;C:/TI/mathlib_c674x_3_0_1_1/packages;C:/TI/bios_6_33_04_39/packages;C:/TI/uia_1_00_03_25/packages;C:/TI/xdais_7_21_01_07/packages;C:/TI/xdais_7_21_01_07/examples;C:/TI/xdctools_3_23_02_47/packages;..;C:/TI/xdctools_3_23_02_47;C:/TI/xdctools_3_23_02_47/etc;C:/TI/bios_6_33_04_39/packages/ti/bios/include;C:\TI\xdctools_3_23_02_47/include;C:\TI\xdctools_3_23_02_47/packages')
    and this console output:
    **** Build of configuration Debug for project VibrationMonitorRTSC2 ****
    C:\TI\ccsv5\utils\bin\gmake -k all
    'Building file: ../VibrationMonitor.cfg'
    'Invoking: XDCtools'
    "C:/TI/xdctools_3_23_02_47/xs" --xdcpath="C:/TI/biospsp_03_00_01_00/drivers;C:/TI/dsplib_c674x_3_1_0_0/packages;C:/TI/edma3_lld_02_11_04_01/packages;C:/TI/ipc_1_23_05_40/packages;C:/TI/mathlib_c674x_3_0_1_1/packages;C:/TI/bios_6_33_04_39/packages;C:/TI/uia_1_00_03_25/packages;C:/TI/xdais_7_21_01_07/packages;C:/TI/xdais_7_21_01_07/examples;" xdc.tools.configuro -o configPkg -t ti.targets.C674 -p ti.platforms.evm6748 -r release -b "C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/RTSCpackage/config.bld" -c "C:/TI/ccsv5/tools/compiler/c6000_7.3.5" --tcf "../VibrationMonitor.cfg"
    making package.mak (because of package.bld) ...
    generating interfaces for package configPkg (because package/package.xdc.inc is older than package.xdc) ...
    configuring VibrationMonitor.x674 from package/cfg/VibrationMonitor_x674.cfg ...
    js: "C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/VibrationMonitor.tcf", line 2: Error: Can't load platform definition 'ti.platforms.evm6748': Error: Can't load ti.bios.tci :Error: Can't find import file: 'ti/bios/bios.tci' (not found along 'C:\TI\xdctools_3_23_02_47\packages\ti\platforms\evm6748/;.;C:/TI/biospsp_03_00_01_00/drivers;C:/TI/dsplib_c674x_3_1_0_0/packages;C:/TI/edma3_lld_02_11_04_01/packages;C:/TI/ipc_1_23_05_40/packages;C:/TI/mathlib_c674x_3_0_1_1/packages;C:/TI/bios_6_33_04_39/packages;C:/TI/uia_1_00_03_25/packages;C:/TI/xdais_7_21_01_07/packages;C:/TI/xdais_7_21_01_07/examples;C:/TI/xdctools_3_23_02_47/packages;..;C:/TI/xdctools_3_23_02_47;C:/TI/xdctools_3_23_02_47/etc;C:/TI/bios_6_33_04_39/packages/ti/bios/include;C:\TI\xdctools_3_23_02_47/include;C:\TI\xdctools_3_23_02_47/packages')
        "./package/cfg/VibrationMonitor_x674.cfg", line 257
        "./package/cfg/VibrationMonitor_x674.cfg", line 180
    gmake.exe: *** [package/cfg/VibrationMonitor_x674.xdl] Error 1
    js: "C:/TI/xdctools_3_23_02_47/packages/xdc/tools/Cmdr.xs", line 51: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted.
    gmake: *** [configPkg/compiler.opt] Error 1
    gmake: Target `all' not remade because of errors.
    **** Build Finished ****
    If I rebuild again, I can get back to the 27 problems (all the same) I've been seeing in the Problem window:
    fatal error #5: could not open source file "C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug/configPkg/package/cfg/VibrationMonitor_x674.h"
    and the corresponding output:
    'Building file: ../FlashHWUnitTest.cpp'
    'Invoking: C6000 Compiler'
    "C:/TI/ccsv5/tools/compiler/c6000_7.3.5/bin/cl6x" -mv6740 -g --rtti --define=_DEBUG --define=BUILD_NUM_MANUAL_INC=1 --define=BUILD_NUMBER=0 --define=DEVELOPER_BASE=6000 --define=Spi_EDMA_ENABLE --define=C6748 --include_path="C:/TI/ccsv5/tools/compiler/c6000_7.3.5/include" --include_path="C:/TI/dsplib_c674x_3_1_0_0/inc" --include_path="C:/TI/mathlib_c674x_3_0_1_1/inc" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Common" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Protocol_Buf_Lite" --include_path="C:/TI/biospsp_03_00_01_00" --include_path="C:/TI/edma3_lld_02_11_04_01" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug" --include_path="C:/TI/bios_6_33_04_39/packages/ti/bios/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Shared" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/libs/boost_1_45_0_ti" --diag_error=225 --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="FlashHWUnitTest.pp" --cmd_file="./configPkg/compiler.opt"  "../FlashHWUnitTest.cpp"
    "C:/TI/xdctools_3_23_02_47/packages/xdc/cfg/global.h", line 39: fatal error #5: could not open source file "C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug/configPkg/package/cfg/VibrationMonitor_x674.h"
    1 fatal error detected in the compilation of "../FlashHWUnitTest.cpp".
    Compilation terminated.
    >> Compilation failure
    gmake: *** [FlashHWUnitTest.obj] Error 1
    'Building file: ../HWTestRunner.cpp'
    "C:/TI/ccsv5/tools/compiler/c6000_7.3.5/bin/cl6x" -mv6740 -g --rtti --define=_DEBUG --define=BUILD_NUM_MANUAL_INC=1 --define=BUILD_NUMBER=0 --define=DEVELOPER_BASE=6000 --define=Spi_EDMA_ENABLE --define=C6748 --include_path="C:/TI/ccsv5/tools/compiler/c6000_7.3.5/include" --include_path="C:/TI/dsplib_c674x_3_1_0_0/inc" --include_path="C:/TI/mathlib_c674x_3_0_1_1/inc" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Common" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Protocol_Buf_Lite" --include_path="C:/TI/biospsp_03_00_01_00" --include_path="C:/TI/edma3_lld_02_11_04_01" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug" --include_path="C:/TI/bios_6_33_04_39/packages/ti/bios/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Shared" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/libs/boost_1_45_0_ti" --diag_error=225 --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="HWTestRunner.pp" --cmd_file="./configPkg/compiler.opt"  "../HWTestRunner.cpp"
    1 fatal error detected in the compilation of "../HWTestRunner.cpp".
    >> Compilation failure
    gmake: *** [HWTestRunner.obj] Error 1
    'Building file: ../MfgTest.cpp'
    "C:/TI/ccsv5/tools/compiler/c6000_7.3.5/bin/cl6x" -mv6740 -g --rtti --define=_DEBUG --define=BUILD_NUM_MANUAL_INC=1 --define=BUILD_NUMBER=0 --define=DEVELOPER_BASE=6000 --define=Spi_EDMA_ENABLE --define=C6748 --include_path="C:/TI/ccsv5/tools/compiler/c6000_7.3.5/include" --include_path="C:/TI/dsplib_c674x_3_1_0_0/inc" --include_path="C:/TI/mathlib_c674x_3_0_1_1/inc" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Common" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Protocol_Buf_Lite" --include_path="C:/TI/biospsp_03_00_01_00" --include_path="C:/TI/edma3_lld_02_11_04_01" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug" --include_path="C:/TI/bios_6_33_04_39/packages/ti/bios/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Shared" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/libs/boost_1_45_0_ti" --diag_error=225 --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="MfgTest.pp" --cmd_file="./configPkg/compiler.opt"  "../MfgTest.cpp"
    1 fatal error detected in the compilation of "../MfgTest.cpp".
    >> Compilation failure
    gmake: *** [MfgTest.obj] Error 1
    'Building file: ../UmmBncController.cpp'
    "C:/TI/ccsv5/tools/compiler/c6000_7.3.5/bin/cl6x" -mv6740 -g --rtti --define=_DEBUG --define=BUILD_NUM_MANUAL_INC=1 --define=BUILD_NUMBER=0 --define=DEVELOPER_BASE=6000 --define=Spi_EDMA_ENABLE --define=C6748 --include_path="C:/TI/ccsv5/tools/compiler/c6000_7.3.5/include" --include_path="C:/TI/dsplib_c674x_3_1_0_0/inc" --include_path="C:/TI/mathlib_c674x_3_0_1_1/inc" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Common" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Protocol_Buf_Lite" --include_path="C:/TI/biospsp_03_00_01_00" --include_path="C:/TI/edma3_lld_02_11_04_01" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug" --include_path="C:/TI/bios_6_33_04_39/packages/ti/bios/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Shared" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/libs/boost_1_45_0_ti" --diag_error=225 --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="UmmBncController.pp" --cmd_file="./configPkg/compiler.opt"  "../UmmBncController.cpp"
    1 fatal error detected in the compilation of "../UmmBncController.cpp".
    >> Compilation failure
    gmake: *** [UmmBncController.obj] Error 1
    'Building file: ../UmmPacketModifier.cpp'
    "C:/TI/ccsv5/tools/compiler/c6000_7.3.5/bin/cl6x" -mv6740 -g --rtti --define=_DEBUG --define=BUILD_NUM_MANUAL_INC=1 --define=BUILD_NUMBER=0 --define=DEVELOPER_BASE=6000 --define=Spi_EDMA_ENABLE --define=C6748 --include_path="C:/TI/ccsv5/tools/compiler/c6000_7.3.5/include" --include_path="C:/TI/dsplib_c674x_3_1_0_0/inc" --include_path="C:/TI/mathlib_c674x_3_0_1_1/inc" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Common" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Protocol_Buf_Lite" --include_path="C:/TI/biospsp_03_00_01_00" --include_path="C:/TI/edma3_lld_02_11_04_01" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug" --include_path="C:/TI/bios_6_33_04_39/packages/ti/bios/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Shared" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/libs/boost_1_45_0_ti" --diag_error=225 --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="UmmPacketModifier.pp" --cmd_file="./configPkg/compiler.opt"  "../UmmPacketModifier.cpp"
    1 fatal error detected in the compilation of "../UmmPacketModifier.cpp".
    >> Compilation failure
    gmake: *** [UmmPacketModifier.obj] Error 1
    'Building file: ../UmmRuntimeModule.cpp'
    "C:/TI/ccsv5/tools/compiler/c6000_7.3.5/bin/cl6x" -mv6740 -g --rtti --define=_DEBUG --define=BUILD_NUM_MANUAL_INC=1 --define=BUILD_NUMBER=0 --define=DEVELOPER_BASE=6000 --define=Spi_EDMA_ENABLE --define=C6748 --include_path="C:/TI/ccsv5/tools/compiler/c6000_7.3.5/include" --include_path="C:/TI/dsplib_c674x_3_1_0_0/inc" --include_path="C:/TI/mathlib_c674x_3_0_1_1/inc" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Common" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Protocol_Buf_Lite" --include_path="C:/TI/biospsp_03_00_01_00" --include_path="C:/TI/edma3_lld_02_11_04_01" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug" --include_path="C:/TI/bios_6_33_04_39/packages/ti/bios/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Shared" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/libs/boost_1_45_0_ti" --diag_error=225 --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="UmmRuntimeModule.pp" --cmd_file="./configPkg/compiler.opt"  "../UmmRuntimeModule.cpp"
    1 fatal error detected in the compilation of "../UmmRuntimeModule.cpp".
    >> Compilation failure
    gmake: *** [UmmRuntimeModule.obj] Error 1
    'Building file: ../dma_ping_pong_test.cpp'
    "C:/TI/ccsv5/tools/compiler/c6000_7.3.5/bin/cl6x" -mv6740 -g --rtti --define=_DEBUG --define=BUILD_NUM_MANUAL_INC=1 --define=BUILD_NUMBER=0 --define=DEVELOPER_BASE=6000 --define=Spi_EDMA_ENABLE --define=C6748 --include_path="C:/TI/ccsv5/tools/compiler/c6000_7.3.5/include" --include_path="C:/TI/dsplib_c674x_3_1_0_0/inc" --include_path="C:/TI/mathlib_c674x_3_0_1_1/inc" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Common" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Protocol_Buf_Lite" --include_path="C:/TI/biospsp_03_00_01_00" --include_path="C:/TI/edma3_lld_02_11_04_01" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug" --include_path="C:/TI/bios_6_33_04_39/packages/ti/bios/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Shared" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/libs/boost_1_45_0_ti" --diag_error=225 --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="dma_ping_pong_test.pp" --cmd_file="./configPkg/compiler.opt"  "../dma_ping_pong_test.cpp"
    1 fatal error detected in the compilation of "../dma_ping_pong_test.cpp".
    >> Compilation failure
    gmake: *** [dma_ping_pong_test.obj] Error 1
    'Building file: ../main.cpp'
    "C:/TI/ccsv5/tools/compiler/c6000_7.3.5/bin/cl6x" -mv6740 -g --rtti --define=_DEBUG --define=BUILD_NUM_MANUAL_INC=1 --define=BUILD_NUMBER=0 --define=DEVELOPER_BASE=6000 --define=Spi_EDMA_ENABLE --define=C6748 --include_path="C:/TI/ccsv5/tools/compiler/c6000_7.3.5/include" --include_path="C:/TI/dsplib_c674x_3_1_0_0/inc" --include_path="C:/TI/mathlib_c674x_3_0_1_1/inc" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Common" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Protocol_Buf_Lite" --include_path="C:/TI/biospsp_03_00_01_00" --include_path="C:/TI/edma3_lld_02_11_04_01" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug" --include_path="C:/TI/bios_6_33_04_39/packages/ti/bios/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Shared" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/libs/boost_1_45_0_ti" --diag_error=225 --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="main.pp" --cmd_file="./configPkg/compiler.opt"  "../main.cpp"
    1 fatal error detected in the compilation of "../main.cpp".
    >> Compilation failure
    gmake: *** [main.obj] Error 1
    'Building file: ../SignalProcessing/AxialPositionBlock.cpp'
    "C:/TI/ccsv5/tools/compiler/c6000_7.3.5/bin/cl6x" -mv6740 -g --rtti --define=_DEBUG --define=BUILD_NUM_MANUAL_INC=1 --define=BUILD_NUMBER=0 --define=DEVELOPER_BASE=6000 --define=Spi_EDMA_ENABLE --define=C6748 --include_path="C:/TI/ccsv5/tools/compiler/c6000_7.3.5/include" --include_path="C:/TI/dsplib_c674x_3_1_0_0/inc" --include_path="C:/TI/mathlib_c674x_3_0_1_1/inc" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Common" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Protocol_Buf_Lite" --include_path="C:/TI/biospsp_03_00_01_00" --include_path="C:/TI/edma3_lld_02_11_04_01" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug" --include_path="C:/TI/bios_6_33_04_39/packages/ti/bios/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Shared" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/libs/boost_1_45_0_ti" --diag_error=225 --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="SignalProcessing/AxialPositionBlock.pp" --obj_directory="SignalProcessing" --cmd_file="./configPkg/compiler.opt"  "../SignalProcessing/AxialPositionBlock.cpp"
    1 fatal error detected in the compilation of "../SignalProcessing/AxialPositionBlock.cpp".
    >> Compilation failure
    gmake: *** [SignalProcessing/AxialPositionBlock.obj] Error 1
    'Building file: ../SignalProcessing/ChargeDischargePeak.cpp'
    "C:/TI/ccsv5/tools/compiler/c6000_7.3.5/bin/cl6x" -mv6740 -g --rtti --define=_DEBUG --define=BUILD_NUM_MANUAL_INC=1 --define=BUILD_NUMBER=0 --define=DEVELOPER_BASE=6000 --define=Spi_EDMA_ENABLE --define=C6748 --include_path="C:/TI/ccsv5/tools/compiler/c6000_7.3.5/include" --include_path="C:/TI/dsplib_c674x_3_1_0_0/inc" --include_path="C:/TI/mathlib_c674x_3_0_1_1/inc" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Common" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Protocol_Buf_Lite" --include_path="C:/TI/biospsp_03_00_01_00" --include_path="C:/TI/edma3_lld_02_11_04_01" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug" --include_path="C:/TI/bios_6_33_04_39/packages/ti/bios/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Shared" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/libs/boost_1_45_0_ti" --diag_error=225 --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="SignalProcessing/ChargeDischargePeak.pp" --obj_directory="SignalProcessing" --cmd_file="./configPkg/compiler.opt"  "../SignalProcessing/ChargeDischargePeak.cpp"
    1 fatal error detected in the compilation of "../SignalProcessing/ChargeDischargePeak.cpp".
    >> Compilation failure
    gmake: *** [SignalProcessing/ChargeDischargePeak.obj] Error 1
    'Building file: ../SignalProcessing/DataSource.cpp'
    "C:/TI/ccsv5/tools/compiler/c6000_7.3.5/bin/cl6x" -mv6740 -g --rtti --define=_DEBUG --define=BUILD_NUM_MANUAL_INC=1 --define=BUILD_NUMBER=0 --define=DEVELOPER_BASE=6000 --define=Spi_EDMA_ENABLE --define=C6748 --include_path="C:/TI/ccsv5/tools/compiler/c6000_7.3.5/include" --include_path="C:/TI/dsplib_c674x_3_1_0_0/inc" --include_path="C:/TI/mathlib_c674x_3_0_1_1/inc" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Common" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Protocol_Buf_Lite" --include_path="C:/TI/biospsp_03_00_01_00" --include_path="C:/TI/edma3_lld_02_11_04_01" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug" --include_path="C:/TI/bios_6_33_04_39/packages/ti/bios/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Shared" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/libs/boost_1_45_0_ti" --diag_error=225 --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="SignalProcessing/DataSource.pp" --obj_directory="SignalProcessing" --cmd_file="./configPkg/compiler.opt"  "../SignalProcessing/DataSource.cpp"
    1 fatal error detected in the compilation of "../SignalProcessing/DataSource.cpp".
    >> Compilation failure
    gmake: *** [SignalProcessing/DataSource.obj] Error 1
    'Building file: ../SignalProcessing/DecimationFilter.cpp'
    "C:/TI/ccsv5/tools/compiler/c6000_7.3.5/bin/cl6x" -mv6740 -g --rtti --define=_DEBUG --define=BUILD_NUM_MANUAL_INC=1 --define=BUILD_NUMBER=0 --define=DEVELOPER_BASE=6000 --define=Spi_EDMA_ENABLE --define=C6748 --include_path="C:/TI/ccsv5/tools/compiler/c6000_7.3.5/include" --include_path="C:/TI/dsplib_c674x_3_1_0_0/inc" --include_path="C:/TI/mathlib_c674x_3_0_1_1/inc" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Common" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Protocol_Buf_Lite" --include_path="C:/TI/biospsp_03_00_01_00" --include_path="C:/TI/edma3_lld_02_11_04_01" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug" --include_path="C:/TI/bios_6_33_04_39/packages/ti/bios/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Shared" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/libs/boost_1_45_0_ti" --diag_error=225 --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="SignalProcessing/DecimationFilter.pp" --obj_directory="SignalProcessing" --cmd_file="./configPkg/compiler.opt"  "../SignalProcessing/DecimationFilter.cpp"
    1 fatal error detected in the compilation of "../SignalProcessing/DecimationFilter.cpp".
    >> Compilation failure
    gmake: *** [SignalProcessing/DecimationFilter.obj] Error 1
    'Building file: ../SignalProcessing/Demodulation.cpp'
    "C:/TI/ccsv5/tools/compiler/c6000_7.3.5/bin/cl6x" -mv6740 -g --rtti --define=_DEBUG --define=BUILD_NUM_MANUAL_INC=1 --define=BUILD_NUMBER=0 --define=DEVELOPER_BASE=6000 --define=Spi_EDMA_ENABLE --define=C6748 --include_path="C:/TI/ccsv5/tools/compiler/c6000_7.3.5/include" --include_path="C:/TI/dsplib_c674x_3_1_0_0/inc" --include_path="C:/TI/mathlib_c674x_3_0_1_1/inc" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Common" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Protocol_Buf_Lite" --include_path="C:/TI/biospsp_03_00_01_00" --include_path="C:/TI/edma3_lld_02_11_04_01" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug" --include_path="C:/TI/bios_6_33_04_39/packages/ti/bios/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Shared" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/libs/boost_1_45_0_ti" --diag_error=225 --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="SignalProcessing/Demodulation.pp" --obj_directory="SignalProcessing" --cmd_file="./configPkg/compiler.opt"  "../SignalProcessing/Demodulation.cpp"
    1 fatal error detected in the compilation of "../SignalProcessing/Demodulation.cpp".
    >> Compilation failure
    gmake: *** [SignalProcessing/Demodulation.obj] Error 1
    'Building file: ../SignalProcessing/IirFilter.cpp'
    "C:/TI/ccsv5/tools/compiler/c6000_7.3.5/bin/cl6x" -mv6740 -g --rtti --define=_DEBUG --define=BUILD_NUM_MANUAL_INC=1 --define=BUILD_NUMBER=0 --define=DEVELOPER_BASE=6000 --define=Spi_EDMA_ENABLE --define=C6748 --include_path="C:/TI/ccsv5/tools/compiler/c6000_7.3.5/include" --include_path="C:/TI/dsplib_c674x_3_1_0_0/inc" --include_path="C:/TI/mathlib_c674x_3_0_1_1/inc" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Common" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Protocol_Buf_Lite" --include_path="C:/TI/biospsp_03_00_01_00" --include_path="C:/TI/edma3_lld_02_11_04_01" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug" --include_path="C:/TI/bios_6_33_04_39/packages/ti/bios/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Shared" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/libs/boost_1_45_0_ti" --diag_error=225 --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="SignalProcessing/IirFilter.pp" --obj_directory="SignalProcessing" --cmd_file="./configPkg/compiler.opt"  "../SignalProcessing/IirFilter.cpp"
    1 fatal error detected in the compilation of "../SignalProcessing/IirFilter.cpp".
    >> Compilation failure
    gmake: *** [SignalProcessing/IirFilter.obj] Error 1
    'Building file: ../SignalProcessing/PtDataSource.cpp'
    "C:/TI/ccsv5/tools/compiler/c6000_7.3.5/bin/cl6x" -mv6740 -g --rtti --define=_DEBUG --define=BUILD_NUM_MANUAL_INC=1 --define=BUILD_NUMBER=0 --define=DEVELOPER_BASE=6000 --define=Spi_EDMA_ENABLE --define=C6748 --include_path="C:/TI/ccsv5/tools/compiler/c6000_7.3.5/include" --include_path="C:/TI/dsplib_c674x_3_1_0_0/inc" --include_path="C:/TI/mathlib_c674x_3_0_1_1/inc" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Common" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Protocol_Buf_Lite" --include_path="C:/TI/biospsp_03_00_01_00" --include_path="C:/TI/edma3_lld_02_11_04_01" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug" --include_path="C:/TI/bios_6_33_04_39/packages/ti/bios/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Shared" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/libs/boost_1_45_0_ti" --diag_error=225 --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="SignalProcessing/PtDataSource.pp" --obj_directory="SignalProcessing" --cmd_file="./configPkg/compiler.opt"  "../SignalProcessing/PtDataSource.cpp"
    1 fatal error detected in the compilation of "../SignalProcessing/PtDataSource.cpp".
    >> Compilation failure
    gmake: *** [SignalProcessing/PtDataSource.obj] Error 1
    'Building file: ../SignalProcessing/PtScalingBlock.cpp'
    "C:/TI/ccsv5/tools/compiler/c6000_7.3.5/bin/cl6x" -mv6740 -g --rtti --define=_DEBUG --define=BUILD_NUM_MANUAL_INC=1 --define=BUILD_NUMBER=0 --define=DEVELOPER_BASE=6000 --define=Spi_EDMA_ENABLE --define=C6748 --include_path="C:/TI/ccsv5/tools/compiler/c6000_7.3.5/include" --include_path="C:/TI/dsplib_c674x_3_1_0_0/inc" --include_path="C:/TI/mathlib_c674x_3_0_1_1/inc" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Common" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Protocol_Buf_Lite" --include_path="C:/TI/biospsp_03_00_01_00" --include_path="C:/TI/edma3_lld_02_11_04_01" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug" --include_path="C:/TI/bios_6_33_04_39/packages/ti/bios/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Shared" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/libs/boost_1_45_0_ti" --diag_error=225 --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="SignalProcessing/PtScalingBlock.pp" --obj_directory="SignalProcessing" --cmd_file="./configPkg/compiler.opt"  "../SignalProcessing/PtScalingBlock.cpp"
    1 fatal error detected in the compilation of "../SignalProcessing/PtScalingBlock.cpp".
    >> Compilation failure
    gmake: *** [SignalProcessing/PtScalingBlock.obj] Error 1
    'Building file: ../SignalProcessing/PtThresholdBlock.cpp'
    "C:/TI/ccsv5/tools/compiler/c6000_7.3.5/bin/cl6x" -mv6740 -g --rtti --define=_DEBUG --define=BUILD_NUM_MANUAL_INC=1 --define=BUILD_NUMBER=0 --define=DEVELOPER_BASE=6000 --define=Spi_EDMA_ENABLE --define=C6748 --include_path="C:/TI/ccsv5/tools/compiler/c6000_7.3.5/include" --include_path="C:/TI/dsplib_c674x_3_1_0_0/inc" --include_path="C:/TI/mathlib_c674x_3_0_1_1/inc" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Common" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Protocol_Buf_Lite" --include_path="C:/TI/biospsp_03_00_01_00" --include_path="C:/TI/edma3_lld_02_11_04_01" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug" --include_path="C:/TI/bios_6_33_04_39/packages/ti/bios/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Shared" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/libs/boost_1_45_0_ti" --diag_error=225 --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="SignalProcessing/PtThresholdBlock.pp" --obj_directory="SignalProcessing" --cmd_file="./configPkg/compiler.opt"  "../SignalProcessing/PtThresholdBlock.cpp"
    1 fatal error detected in the compilation of "../SignalProcessing/PtThresholdBlock.cpp".
    >> Compilation failure
    gmake: *** [SignalProcessing/PtThresholdBlock.obj] Error 1
    'Building file: ../SignalProcessing/RmsBlock.cpp'
    "C:/TI/ccsv5/tools/compiler/c6000_7.3.5/bin/cl6x" -mv6740 -g --rtti --define=_DEBUG --define=BUILD_NUM_MANUAL_INC=1 --define=BUILD_NUMBER=0 --define=DEVELOPER_BASE=6000 --define=Spi_EDMA_ENABLE --define=C6748 --include_path="C:/TI/ccsv5/tools/compiler/c6000_7.3.5/include" --include_path="C:/TI/dsplib_c674x_3_1_0_0/inc" --include_path="C:/TI/mathlib_c674x_3_0_1_1/inc" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Common" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Protocol_Buf_Lite" --include_path="C:/TI/biospsp_03_00_01_00" --include_path="C:/TI/edma3_lld_02_11_04_01" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug" --include_path="C:/TI/bios_6_33_04_39/packages/ti/bios/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Shared" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/libs/boost_1_45_0_ti" --diag_error=225 --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="SignalProcessing/RmsBlock.pp" --obj_directory="SignalProcessing" --cmd_file="./configPkg/compiler.opt"  "../SignalProcessing/RmsBlock.cpp"
    1 fatal error detected in the compilation of "../SignalProcessing/RmsBlock.cpp".
    >> Compilation failure
    gmake: *** [SignalProcessing/RmsBlock.obj] Error 1
    'Building file: ../SignalProcessing/SignalProcessingService.cpp'
    "C:/TI/ccsv5/tools/compiler/c6000_7.3.5/bin/cl6x" -mv6740 -g --rtti --define=_DEBUG --define=BUILD_NUM_MANUAL_INC=1 --define=BUILD_NUMBER=0 --define=DEVELOPER_BASE=6000 --define=Spi_EDMA_ENABLE --define=C6748 --include_path="C:/TI/ccsv5/tools/compiler/c6000_7.3.5/include" --include_path="C:/TI/dsplib_c674x_3_1_0_0/inc" --include_path="C:/TI/mathlib_c674x_3_0_1_1/inc" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Common" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Protocol_Buf_Lite" --include_path="C:/TI/biospsp_03_00_01_00" --include_path="C:/TI/edma3_lld_02_11_04_01" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug" --include_path="C:/TI/bios_6_33_04_39/packages/ti/bios/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Shared" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/libs/boost_1_45_0_ti" --diag_error=225 --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="SignalProcessing/SignalProcessingService.pp" --obj_directory="SignalProcessing" --cmd_file="./configPkg/compiler.opt"  "../SignalProcessing/SignalProcessingService.cpp"
    1 fatal error detected in the compilation of "../SignalProcessing/SignalProcessingService.cpp".
    >> Compilation failure
    gmake: *** [SignalProcessing/SignalProcessingService.obj] Error 1
    'Building file: ../SignalProcessing/SimulatedDataSource.cpp'
    "C:/TI/ccsv5/tools/compiler/c6000_7.3.5/bin/cl6x" -mv6740 -g --rtti --define=_DEBUG --define=BUILD_NUM_MANUAL_INC=1 --define=BUILD_NUMBER=0 --define=DEVELOPER_BASE=6000 --define=Spi_EDMA_ENABLE --define=C6748 --include_path="C:/TI/ccsv5/tools/compiler/c6000_7.3.5/include" --include_path="C:/TI/dsplib_c674x_3_1_0_0/inc" --include_path="C:/TI/mathlib_c674x_3_0_1_1/inc" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Common" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Protocol_Buf_Lite" --include_path="C:/TI/biospsp_03_00_01_00" --include_path="C:/TI/edma3_lld_02_11_04_01" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug" --include_path="C:/TI/bios_6_33_04_39/packages/ti/bios/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Shared" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/libs/boost_1_45_0_ti" --diag_error=225 --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="SignalProcessing/SimulatedDataSource.pp" --obj_directory="SignalProcessing" --cmd_file="./configPkg/compiler.opt"  "../SignalProcessing/SimulatedDataSource.cpp"
    1 fatal error detected in the compilation of "../SignalProcessing/SimulatedDataSource.cpp".
    >> Compilation failure
    gmake: *** [SignalProcessing/SimulatedDataSource.obj] Error 1
    'Building file: ../SignalProcessing/SineCosineLUT.cpp'
    "C:/TI/ccsv5/tools/compiler/c6000_7.3.5/bin/cl6x" -mv6740 -g --rtti --define=_DEBUG --define=BUILD_NUM_MANUAL_INC=1 --define=BUILD_NUMBER=0 --define=DEVELOPER_BASE=6000 --define=Spi_EDMA_ENABLE --define=C6748 --include_path="C:/TI/ccsv5/tools/compiler/c6000_7.3.5/include" --include_path="C:/TI/dsplib_c674x_3_1_0_0/inc" --include_path="C:/TI/mathlib_c674x_3_0_1_1/inc" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Common" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Protocol_Buf_Lite" --include_path="C:/TI/biospsp_03_00_01_00" --include_path="C:/TI/edma3_lld_02_11_04_01" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug" --include_path="C:/TI/bios_6_33_04_39/packages/ti/bios/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Shared" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/libs/boost_1_45_0_ti" --diag_error=225 --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="SignalProcessing/SineCosineLUT.pp" --obj_directory="SignalProcessing" --cmd_file="./configPkg/compiler.opt"  "../SignalProcessing/SineCosineLUT.cpp"
    1 fatal error detected in the compilation of "../SignalProcessing/SineCosineLUT.cpp".
    >> Compilation failure
    gmake: *** [SignalProcessing/SineCosineLUT.obj] Error 1
    'Building file: ../SignalProcessing/SpeedBlock.cpp'
    "C:/TI/ccsv5/tools/compiler/c6000_7.3.5/bin/cl6x" -mv6740 -g --rtti --define=_DEBUG --define=BUILD_NUM_MANUAL_INC=1 --define=BUILD_NUMBER=0 --define=DEVELOPER_BASE=6000 --define=Spi_EDMA_ENABLE --define=C6748 --include_path="C:/TI/ccsv5/tools/compiler/c6000_7.3.5/include" --include_path="C:/TI/dsplib_c674x_3_1_0_0/inc" --include_path="C:/TI/mathlib_c674x_3_0_1_1/inc" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Common" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Protocol_Buf_Lite" --include_path="C:/TI/biospsp_03_00_01_00" --include_path="C:/TI/edma3_lld_02_11_04_01" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug" --include_path="C:/TI/bios_6_33_04_39/packages/ti/bios/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Shared" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/libs/boost_1_45_0_ti" --diag_error=225 --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="SignalProcessing/SpeedBlock.pp" --obj_directory="SignalProcessing" --cmd_file="./configPkg/compiler.opt"  "../SignalProcessing/SpeedBlock.cpp"
    1 fatal error detected in the compilation of "../SignalProcessing/SpeedBlock.cpp".
    >> Compilation failure
    gmake: *** [SignalProcessing/SpeedBlock.obj] Error 1
    'Building file: ../RTSCpackage/package/package_RTSCpackage.c'
    "C:/TI/ccsv5/tools/compiler/c6000_7.3.5/bin/cl6x" -mv6740 -g --rtti --define=_DEBUG --define=BUILD_NUM_MANUAL_INC=1 --define=BUILD_NUMBER=0 --define=DEVELOPER_BASE=6000 --define=Spi_EDMA_ENABLE --define=C6748 --include_path="C:/TI/ccsv5/tools/compiler/c6000_7.3.5/include" --include_path="C:/TI/dsplib_c674x_3_1_0_0/inc" --include_path="C:/TI/mathlib_c674x_3_0_1_1/inc" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Common" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Protocol_Buf_Lite" --include_path="C:/TI/biospsp_03_00_01_00" --include_path="C:/TI/edma3_lld_02_11_04_01" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug" --include_path="C:/TI/bios_6_33_04_39/packages/ti/bios/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Shared" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/libs/boost_1_45_0_ti" --diag_error=225 --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="RTSCpackage/package/package_RTSCpackage.pp" --obj_directory="RTSCpackage/package" --cmd_file="./configPkg/compiler.opt"  "../RTSCpackage/package/package_RTSCpackage.c"
    'Finished building: ../RTSCpackage/package/package_RTSCpackage.c'
    'Building file: ../BoardSpecific/DeviceManager.cpp'
    "C:/TI/ccsv5/tools/compiler/c6000_7.3.5/bin/cl6x" -mv6740 -g --rtti --define=_DEBUG --define=BUILD_NUM_MANUAL_INC=1 --define=BUILD_NUMBER=0 --define=DEVELOPER_BASE=6000 --define=Spi_EDMA_ENABLE --define=C6748 --include_path="C:/TI/ccsv5/tools/compiler/c6000_7.3.5/include" --include_path="C:/TI/dsplib_c674x_3_1_0_0/inc" --include_path="C:/TI/mathlib_c674x_3_0_1_1/inc" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Common" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Protocol_Buf_Lite" --include_path="C:/TI/biospsp_03_00_01_00" --include_path="C:/TI/edma3_lld_02_11_04_01" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug" --include_path="C:/TI/bios_6_33_04_39/packages/ti/bios/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Shared" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/libs/boost_1_45_0_ti" --diag_error=225 --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="BoardSpecific/DeviceManager.pp" --obj_directory="BoardSpecific" --cmd_file="./configPkg/compiler.opt"  "../BoardSpecific/DeviceManager.cpp"
    1 fatal error detected in the compilation of "../BoardSpecific/DeviceManager.cpp".
    >> Compilation failure
    gmake: *** [BoardSpecific/DeviceManager.obj] Error 1
    'Building file: ../BoardSpecific/GpioPinDefinitions.cpp'
    "C:/TI/ccsv5/tools/compiler/c6000_7.3.5/bin/cl6x" -mv6740 -g --rtti --define=_DEBUG --define=BUILD_NUM_MANUAL_INC=1 --define=BUILD_NUMBER=0 --define=DEVELOPER_BASE=6000 --define=Spi_EDMA_ENABLE --define=C6748 --include_path="C:/TI/ccsv5/tools/compiler/c6000_7.3.5/include" --include_path="C:/TI/dsplib_c674x_3_1_0_0/inc" --include_path="C:/TI/mathlib_c674x_3_0_1_1/inc" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Common" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Protocol_Buf_Lite" --include_path="C:/TI/biospsp_03_00_01_00" --include_path="C:/TI/edma3_lld_02_11_04_01" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug" --include_path="C:/TI/bios_6_33_04_39/packages/ti/bios/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Shared" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/libs/boost_1_45_0_ti" --diag_error=225 --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="BoardSpecific/GpioPinDefinitions.pp" --obj_directory="BoardSpecific" --cmd_file="./configPkg/compiler.opt"  "../BoardSpecific/GpioPinDefinitions.cpp"
    1 fatal error detected in the compilation of "../BoardSpecific/GpioPinDefinitions.cpp".
    >> Compilation failure
    gmake: *** [BoardSpecific/GpioPinDefinitions.obj] Error 1
    'Building file: ../BoardSpecific/McbspConfig.cpp'
    "C:/TI/ccsv5/tools/compiler/c6000_7.3.5/bin/cl6x" -mv6740 -g --rtti --define=_DEBUG --define=BUILD_NUM_MANUAL_INC=1 --define=BUILD_NUMBER=0 --define=DEVELOPER_BASE=6000 --define=Spi_EDMA_ENABLE --define=C6748 --include_path="C:/TI/ccsv5/tools/compiler/c6000_7.3.5/include" --include_path="C:/TI/dsplib_c674x_3_1_0_0/inc" --include_path="C:/TI/mathlib_c674x_3_0_1_1/inc" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Common" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Protocol_Buf_Lite" --include_path="C:/TI/biospsp_03_00_01_00" --include_path="C:/TI/edma3_lld_02_11_04_01" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug" --include_path="C:/TI/bios_6_33_04_39/packages/ti/bios/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Shared" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/libs/boost_1_45_0_ti" --diag_error=225 --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="BoardSpecific/McbspConfig.pp" --obj_directory="BoardSpecific" --cmd_file="./configPkg/compiler.opt"  "../BoardSpecific/McbspConfig.cpp"
    'Finished building: ../BoardSpecific/McbspConfig.cpp'
    'Building file: ../BoardSpecific/NodeVoltage.cpp'
    "C:/TI/ccsv5/tools/compiler/c6000_7.3.5/bin/cl6x" -mv6740 -g --rtti --define=_DEBUG --define=BUILD_NUM_MANUAL_INC=1 --define=BUILD_NUMBER=0 --define=DEVELOPER_BASE=6000 --define=Spi_EDMA_ENABLE --define=C6748 --include_path="C:/TI/ccsv5/tools/compiler/c6000_7.3.5/include" --include_path="C:/TI/dsplib_c674x_3_1_0_0/inc" --include_path="C:/TI/mathlib_c674x_3_0_1_1/inc" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Common" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Protocol_Buf_Lite" --include_path="C:/TI/biospsp_03_00_01_00" --include_path="C:/TI/edma3_lld_02_11_04_01" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug" --include_path="C:/TI/bios_6_33_04_39/packages/ti/bios/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Shared" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/libs/boost_1_45_0_ti" --diag_error=225 --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="BoardSpecific/NodeVoltage.pp" --obj_directory="BoardSpecific" --cmd_file="./configPkg/compiler.opt"  "../BoardSpecific/NodeVoltage.cpp"
    1 fatal error detected in the compilation of "../BoardSpecific/NodeVoltage.cpp".
    >> Compilation failure
    gmake: *** [BoardSpecific/NodeVoltage.obj] Error 1
    'Building file: ../BoardSpecific/PtDriver.cpp'
    "C:/TI/ccsv5/tools/compiler/c6000_7.3.5/bin/cl6x" -mv6740 -g --rtti --define=_DEBUG --define=BUILD_NUM_MANUAL_INC=1 --define=BUILD_NUMBER=0 --define=DEVELOPER_BASE=6000 --define=Spi_EDMA_ENABLE --define=C6748 --include_path="C:/TI/ccsv5/tools/compiler/c6000_7.3.5/include" --include_path="C:/TI/dsplib_c674x_3_1_0_0/inc" --include_path="C:/TI/mathlib_c674x_3_0_1_1/inc" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Common" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Protocol_Buf_Lite" --include_path="C:/TI/biospsp_03_00_01_00" --include_path="C:/TI/edma3_lld_02_11_04_01" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug" --include_path="C:/TI/bios_6_33_04_39/packages/ti/bios/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Shared" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/libs/boost_1_45_0_ti" --diag_error=225 --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="BoardSpecific/PtDriver.pp" --obj_directory="BoardSpecific" --cmd_file="./configPkg/compiler.opt"  "../BoardSpecific/PtDriver.cpp"
    1 fatal error detected in the compilation of "../BoardSpecific/PtDriver.cpp".
    gmake: *** [BoardSpecific/PtDriver.obj] Error 1
    >> Compilation failure
    'Building file: ../BoardSpecific/SpiConfig.cpp'
    "C:/TI/ccsv5/tools/compiler/c6000_7.3.5/bin/cl6x" -mv6740 -g --rtti --define=_DEBUG --define=BUILD_NUM_MANUAL_INC=1 --define=BUILD_NUMBER=0 --define=DEVELOPER_BASE=6000 --define=Spi_EDMA_ENABLE --define=C6748 --include_path="C:/TI/ccsv5/tools/compiler/c6000_7.3.5/include" --include_path="C:/TI/dsplib_c674x_3_1_0_0/inc" --include_path="C:/TI/mathlib_c674x_3_0_1_1/inc" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Common" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Protocol_Buf_Lite" --include_path="C:/TI/biospsp_03_00_01_00" --include_path="C:/TI/edma3_lld_02_11_04_01" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug" --include_path="C:/TI/bios_6_33_04_39/packages/ti/bios/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Shared" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/libs/boost_1_45_0_ti" --diag_error=225 --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="BoardSpecific/SpiConfig.pp" --obj_directory="BoardSpecific" --cmd_file="./configPkg/compiler.opt"  "../BoardSpecific/SpiConfig.cpp"
    1 fatal error detected in the compilation of "../BoardSpecific/SpiConfig.cpp".
    >> Compilation failure
    gmake: *** [BoardSpecific/SpiConfig.obj] Error 1
    'Building file: ../BoardSpecific/UartConfig.cpp'
    "C:/TI/ccsv5/tools/compiler/c6000_7.3.5/bin/cl6x" -mv6740 -g --rtti --define=_DEBUG --define=BUILD_NUM_MANUAL_INC=1 --define=BUILD_NUMBER=0 --define=DEVELOPER_BASE=6000 --define=Spi_EDMA_ENABLE --define=C6748 --include_path="C:/TI/ccsv5/tools/compiler/c6000_7.3.5/include" --include_path="C:/TI/dsplib_c674x_3_1_0_0/inc" --include_path="C:/TI/mathlib_c674x_3_0_1_1/inc" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Common" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Monitor Card/Protocol_Buf_Lite" --include_path="C:/TI/biospsp_03_00_01_00" --include_path="C:/TI/edma3_lld_02_11_04_01" --include_path="C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug" --include_path="C:/TI/bios_6_33_04_39/packages/ti/bios/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/include" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/Shared" --include_path="C:/Users/mask01/Documents/Tortise Files/Firmware/libs/boost_1_45_0_ti" --diag_error=225 --display_error_number --diag_warning=225 --abi=coffabi --preproc_with_compile --preproc_dependency="BoardSpecific/UartConfig.pp" --obj_directory="BoardSpecific" --cmd_file="./configPkg/compiler.opt"  "../BoardSpecific/UartConfig.cpp"
    'Finished building: ../BoardSpecific/UartConfig.cpp'
    Remeber, I've done this:
    - replace '.p' with '.x' in file package.xs.xdt. Find the line 31:
    Thanks for looking.
  • Correct me if I am wrong, but I think you ran the conversion tool to convert your TCF script to a CFG script. If that's the case, then you don't need your TCF script anymore and you don't need the option --tcf. You can turn it off in Project->Properties->CCS Build->XDCtools->Advanced Options. Uncheck the option "Read infile.tcf in addition to infile.cfg".
    If you do have to use the option --tcf, then you also have to have DSP/BIOS 5 on your package path. You can do that in Project->Properties->CCS General->RTSC->Products and Repositories. CLick on Add ..., find a DSP/BIOS installation and add it to the list of repositories.
  • You're correct, Sasha, I used the conversion tool to convert my TCF script to a CFG script. I've unchecked the option to "Read infile.tcf in addition to infile.cfg" but still got the same 27 problems in the Problems window. In addition, I also reverted to the original package.bld.xdt and package.xs.xdt files but I still get the same 27 errors.
    Output is pasted below:
    "C:/TI/xdctools_3_23_02_47/packages/xdc/cfg/global.h", line 39: fatal error #5: could not open source file "C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug/configPkg/package/cfg/VibrationMonitor_p674.h"
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    Thanks for looking. I appreciate any help you can offer.
  • You have to clean the project first. Then, rebuild it and post the configuration part of the console output that starts with
    until the line that says
    'Finished building: ../VibrationMonitor.cfg'
    or something similar. If that parts goes through without errors, check the content of the directory where the missing header file should be. If everything goes well, you should have more than two files there, including the missing header file.
  • I've been cleaning the project first then rebuilding all along as you have been instructing but I'll gladly do it again.
    Immediately after I perform a clean, I'm seeing this problem in the Problems window:
    Description    Resource    Path    Location    Type
    Cannot set property "ENABLE" of undefined to "1" (C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/VibrationMonitor.cfg#162)    VibrationMonitor.cfg    /VibrationMonitorRTSC2    162    C/C++ Problem
    And this is what's in the Console window (I did not perform a build - this is simply what's in the console window upon performing a clean):
    "C:/TI/xdctools_3_23_02_47/xs" --xdcpath="C:/TI/biospsp_03_00_01_00/drivers;C:/TI/dsplib_c674x_3_1_0_0/packages;C:/TI/edma3_lld_02_11_04_01/packages;C:/TI/ipc_1_23_05_40/packages;C:/TI/mathlib_c674x_3_0_1_1/packages;C:/TI/bios_6_33_04_39/packages;C:/TI/uia_1_00_03_25/packages;C:/TI/xdais_7_21_01_07/packages;C:/TI/xdais_7_21_01_07/examples;" xdc.tools.configuro -o configPkg -t ti.targets.C674 -p ti.platforms.evm6748 -r release -b "C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/RTSCpackage/config.bld" -c "C:/TI/ccsv5/tools/compiler/c6000_7.3.5" "../VibrationMonitor.cfg"
    configuring VibrationMonitor.x674 from package/cfg/VibrationMonitor_p674.cfg ...
    bios.enableRealTimeAnalysis is not supported
    bios.enableRtdx is not supported
    js: "C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/VibrationMonitor.cfg", line 162: TypeError: Cannot set property "ENABLE" of undefined to "1" (C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/VibrationMonitor.cfg#162)
        "./package/cfg/VibrationMonitor_p674.cfg", line 193
        "./package/cfg/VibrationMonitor_p674.cfg", line 272
        "./package/cfg/VibrationMonitor_p674.cfg", line 180
    gmake.exe: *** [package/cfg/VibrationMonitor_p674.xdl] Error 1
    Then, when I perform a build, I get this (repeated 27 times) in the Problems window:
     fatal error #5: could not open source file "C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/Debug/configPkg/package/cfg/VibrationMonitor_p674.h"    .xdchelp    /VibrationMonitorRTSC2    39    C/C++ Problem
    And this is what's in the Console window (27 times)
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    >> Compilation failure
    As you can see, nothing is going through without errors. I don't have more than two files in C:\Users\mask01\Documents\CCSWorkspace1\VibrationMonitorRTSC2\Debug\configPkg\package\cfg. The only two files that exist are VibrationMonitor_p674.cfg and VibrationMonitor_p674.mak.
    Anything you can do to help me solve this problem I sincerely appreciate. Thank you.
  • js: "C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/VibrationMonitor.cfg", line 162: TypeError: Cannot set property "ENABLE" of undefined to "1" (C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/VibrationMonitor.cfg#162)
    So, what's on the line 162 in your CFG script VibrationMonitor.cfg?
    BTW, you don't have to post these compilation errors for your C files. They are all a result of the errors in the config step. Until you get the config step to build correctly, there is no point in building the C files. Yous should clean and then build each time the config step fails.
  • I copied and pasted the file in Visual Studio and this is what line 162 is:
    bios.PWRM.ENABLE = 1;
    I tried this:
    bios.Power.ENABLE = 1;
    Same error:
    Cannot set property "ENABLE" of undefined to "1" (C:/Users/mask01/Documents/CCSWorkspace1/VibrationMonitorRTSC2/VibrationMonitor.cfg#163)    VibrationMonitor.cfg    /VibrationMonitorRTSC2    163    C/C++ Problem
