EVM3730 GPTimer10 and PWM
platform: EVM 3730
os:wince 6.0
BSP:BSP BSP_WINCE_ARM_A8 1.01.00.03
Now I want to generate a PWM Signal with the GPTimer10 and output it over the GPIO-PAD GPMC_nCS5 in muxmode 3.
but no pwm signal was generated, who can give  an  advice to me ?
My code listings as follows.
BOOL  EnableDeviceClocks(UINT devId, BOOL bEnable)
    OMAP_CM_REGS* pCmRegs;
    switch (devId)
  case OMAP_DEVICE_GPTIMER10:
   pCmRegs = OALPAtoUA(OMAP_PRCM_WKUP_CM_REGS_PA);
   if (bEnable)
    SETREG32(&pCmRegs->CM_FCLKEN_xxx, CM_CLKEN_GPT10);
    SETREG32(&pCmRegs->CM_ICLKEN_xxx, CM_CLKEN_GPT10);
    while (INREG32(&pCmRegs->CM_IDLEST1_xxx) & CM_IDLEST_ST_GPT10);
   else
    CLRREG32(&pCmRegs->CM_FCLKEN1_xxx, CM_CLKEN_GPT10);
    CLRREG32(&pCmRegs->CM_ICLKEN1_xxx, CM_CLKEN_GPT10);
   break;
    return TRUE;
void Test_PWM10()
 DWORD tclr = 0;
 OMAP_GPTIMER_REGS *pTimerRegs_10 = OALPAtoUA(OMAP_GPTIMER1_REGS_PA);
 //enable GPTMER10 clock
 EnableDeviceClocks(OMAP_DEVICE_GPTIMER10,TRUE);
 // Soft reset GPTIMER and wait until finished
 SETREG32(&pTimerRegs_10->TIOCP, SYSCONFIG_SOFTRESET);
 while ((INREG32(&pTimerRegs_10->TISTAT) & GPTIMER_TISTAT_RESETDONE) == 0);
 OUTREG32(&g_pPerfTimer->TIOCP,
 0x200 | SYSCONFIG_SMARTIDLE|SYSCONFIG_ENAWAKEUP|
 SYSCONFIG_AUTOIDLE);
 // Select posted mode
 SETREG32(&pTimerRegs_10->TSICR, GPTIMER_TSICR_POSTED);
 // clear interrupts
 OUTREG32(&pTimerRegs_10->TISR, 0x00000000);
 // Trigger a counter reload by writing
 OUTREG32(&pTimerRegs_10->TTGR, 0xFFFFFFFF);
 // clear match register
 OUTREG32(&pTimerRegs_10->TMAR, 0xFFFFFFFF);
 // enable wakeups
 //OUTREG32(&pTimerRegs_10->TWER, GPTIMER_TWER_MATCH);
 // Set the load register value.
 OUTREG32(&pTimerRegs_10->TLDR, 0xFFFF0000);
 tclr |= GPTIMER_TCLR_AR | GPTIMER_TCLR_PT | GPTIMER_TCLR_TRG_OVERFLOW;
 OUTREG32(&pTimerRegs_10->TCLR,  tclr);
 //start
 SETREG32(&pTimerRegs_10->TCLR, GPTIMER_TCLR_ST);
  • Hi,all
      I use the TI BSP_WINCE_ARM_A8_01_00_03  for Windows embedded compact 6 running on an Evaluation Board EVM3530 with the TI Processor DM3730.
       who can give me an example to use GPTimer10 as an PWM output? Thank you very much!
  • platform: DM 3730
    os:wince 6.0
        switch (devId)
       if (bEnable)
       else
       break;
        return TRUE;
    void Test_PWM10()
     DWORD tclr = 0;
     OUTREG32(&g_pPerfTimer->TIOCP, 0x200  |  SYSCONFIG_SMARTIDLE | SYSCONFIG_ENAWAKEUP | SYSCONFIG_AUTOIDLE);
     // clear interrupts
     // enable wakeups
     //start
  • for one thing you are mapping OMAP_GPTIMER1_REG_PA instead of timer 10.
    DV
         Thank you very much! could you tell me how to  carry out PulsPulse-Width Modulation e-Width Modulation Pulse-Width Modulation , i.e. which register  can  I modify, TLDR, TMAR  or  TTGR.
