So I found the directions to use create-sdcard.sh to create a bootable SD card (working on a beagle-xm). And that works with the provided images. But when I try to install a custom kernel (the one I built), it asks for the directory of the source. What do I use?I suspected I should use the "stuff" in the targetnfs directory but that is a single directory...
For Boot partition
If files are located in Tarball write complete path including the file name.
e.x. $: /home/user/MyCustomTars/boot.tar.gz
If files are located in a directory write the directory path
e.x. $: /ti-sdk/board-support/prebuilt-images/
and the beginning of the files should be labeled with MLO, u-boot, uImage
i.e. test_MLO_image must be labeled as MLO_test_image
NOTE: Not all platforms will have an MLO file and this file can
be ignored for platforms that do not support an MLO
Enter path for Boot Partition :
