Dear Syslink Team,
We integrated the latest syslink release (2_10_05_26) for DM8168 with latest EZSDK (5_04_00_11) & found the attached log messages (
root@dm816x-evm:/ti/syslink-examples/TI816X/messageq# ./run_messageqapp_release.
sh
======== Running app using slaveloader ========
Trace enabledBUG: Your driver calls ioremap() on system memory. This leads
to architecturally unpredictable behaviour on ARMv6+, and ioremap()
will fail in the next kernel release. Please fix your driver.
Trace SetFailu------------[ cut here ]------------
reReason enabledWARNING: at arch/arm/mm/ioremap.c:211 __arm_ioremap_pfn_caller+0x58/0x190()
Attached to slModules linked in:ave procId 0.
L syslinkoading procId 0. ipv6
Backtrace:
[<c0049bb8>] (dump_backtrace+0x0/0x110) from [<c039b7d4>] (dump_stack+0x18/0x1c)
r7:00000000 r6:c004d76c r5:c045bf9b r4:000000d3
[<c039b7bc>] (dump_stack+0x0/0x1c) from [<c006da3c>] (warn_slowpath_common+0x54/0x6c)
[<c006d9e8>] (warn_slowpath_common+0x0/0x6c) from [<c006da78>] (warn_slowpath_null+0x24/0x2c)
r9:00000002 r8:00000000 r7:bf0bf464 r6:0008b000 r5:00029e40
r4:00000000
[<c006da54>] (warn_slowpath_null+0x0/0x2c) from [<c004d76c>] (__arm_ioremap_pfn_caller+0x58/0x190)
[<c004d714>] (__arm_ioremap_pfn_caller+0x0/0x190) from [<c004d928>] (__arm_ioremap_caller+0x64/0x6c)
[<c004d8c4>] (__arm_ioremap_caller+0x0/0x6c) from [<c0060454>] (omap_ioremap+0x60/0x64)
r6:00000000 r5:00029e40 r4:8b000000
[<c00603f4>] (omap_ioremap+0x0/0x64) from [<bf0bf464>] (MemoryOS_map+0x1f0/0x3a8 [syslink])
r7:ca459cc8 r6:00000000 r5:ca459c60 r4:d0091000
[<bf0bf274>] (MemoryOS_map+0x0/0x3a8 [syslink]) from [<bf08d594>] (_ProcMgr_map+0x1cc/0x4ac [syslink])
r8:d0170000 r7:ca459cc8 r6:00000000 r5:06a85000 r4:ca459d48
[<bf08d3c8>] (_ProcMgr_map+0x0/0x4ac [syslink]) from [<bf09b9b8>] (ElfLoaderTrgWrite_copy+0x10c/0x368 [syslink])
[<bf09b8ac>] (ElfLoaderTrgWrite_copy+0x0/0x368 [syslink]) from [<bf09ef84>] (DLIF_copy+0x10/0x1c [syslink])
[<bf09ef74>] (DLIF_copy+0x0/0x1c [syslink]) from [<bf09dd18>] (DLOAD_load+0x734/0xa58 [syslink])
[<bf09d5e4>] (DLOAD_load+0x0/0xa58 [syslink]) from [<bf09aaa4>] (ElfLoader_load+0x268/0x36c [syslink])
[<bf09a83c>] (ElfLoader_load+0x0/0x36c [syslink]) from [<bf08b2d0>] (Loader_load+0xec/0x164 [syslink])
[<bf08b1e4>] (Loader_load+0x0/0x164 [syslink]) from [<bf08fa10>] (ProcMgr_load+0x220/0x2fc [syslink])
[<bf08f7f0>] (ProcMgr_load+0x0/0x2fc [syslink]) from [<bf0919e8>] (ProcMgrDrv_ioctl+0xb98/0x1c38 [syslink])
[<bf090e50>] (ProcMgrDrv_ioctl+0x0/0x1c38 [syslink]) from [<c00d305c>] (vfs_ioctl+0x28/0x44)
r8:becf7b60 r7:00000007 r6:00000007 r5:cb65d580 r4:00000000
[<c00d3034>] (vfs_ioctl+0x0/0x44) from [<c00d376c>] (do_vfs_ioctl+0x500/0x540)
[<c00d326c>] (do_vfs_ioctl+0x0/0x540) from [<c00d3804>] (sys_ioctl+0x58/0x7c)
[<c00d37ac>] (sys_ioctl+0x0/0x7c) from [<c0045e00>] (ret_fast_syscall+0x0/0x30)
r8:c0045fa8 r7:00000036 r6:00000000 r5:00000000 r4:becf7b60
---[ end trace 9228fd6d702c7c83 ]---
Modules linked in: syslink ipv6
Backtrace:
r9:00000002 r8:00000000 r7:bf0bf464 r6:0008b029 r5:00009a30
r4:00000000
r6:00000000 r5:00009a30 r4:8b029e40
---[ end trace 9228fd6d702c7c84 ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf0bf464 r6:0008b033 r5:000040aa
r4:00000000
r6:00000000 r5:000040aa r4:8b033870
---[ end trace 9228fd6d702c7c85 ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf0bf464 r6:0008b037 r5:000014b4
r4:00000000
r6:00000000 r5:000014b4 r4:8b037920
---[ end trace 9228fd6d702c7c86 ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf0bf464 r6:0008b038 r5:00001120
r4:00000000
r6:00000000 r5:00001120 r4:8b038dd8
---[ end trace 9228fd6d702c7c87 ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf0bf464 r6:0008b039 r5:00000010
r4:00000000
r6:00000000 r5:00000010 r4:8b039ef8
---[ end trace 9228fd6d702c7c88 ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf0bf464 r6:0008b03a r5:00000200
r4:00000000
r6:00000000 r5:00000200 r4:8b03a000
---[ end trace 9228fd6d702c7c89 ]---
Backtrace:
r9:00000002 r8:00000000 r7:bf0bf464 r6:0008b03a r5:0000004c
r4:00000000
r6:00000000 r5:0000004c r4:8b03a400
---[ end trace 9228fd6d702c7c8a ]---
Loaded file ./messageq_ti81xx_dsp.xe674 on slave procId 0.
Started slave procId 0.
MessageQApp sample application
Trace enabled
Trace SetFailureReason enabled
Run for all supported proc IDs
Entered MessageQApp_startup
Warning! Unsupported procID specified for running the sample application! proc ID: [1]
Warning! Unsupported procID specified for running the sample application! proc ID: [2]
After Ipc_loadcallback:
status [0x0]
After Ipc_startcallback:
status [0x97d2000]
Leaving MessageQApp_startup 97d2000
Entered MessageQApp_execute
MessageQApp_threadHandler entered
Registering heapId 0 with MessageQ for procId: 0
MessageQ_create name MSGQ_30 status [0x0] : procId [0]
Sending synchronizaion notification to ProcId: 0
Sent synchronizaion notification to ProcId: 0
MessageQ_open Status [0x0] : procId [0]
MessageQApp_queueId [0x0] : procId [0]
Sending a message #100 to 0
Sending a message #200 to 0
Sending a message #300 to 0
Sending a message #400 to 0
Sending a message #500 to 0
Sending a message #600 to 0
Sending a message #700 to 0
Sending a message #800 to 0
Sending a message #900 to 0
Sending a message #1000 to 0
Leaving MessageQApp_threadHandler 0
Leaving MessageQApp_execute
Entered MessageQApp_shutdown()
After Ipc_stopCallback status: [0x97d2000]
Leaving MessageQApp_shutdown() (0x97d2000)
Trace enabled
Stopped slave procId 0.
Unloaded slave pBUG: Your driver calls ioremap() on system memory. This leads
rocId 0.
Detach------------[ cut here ]------------
ed from slave prWARNING: at arch/arm/mm/ioremap.c:211 __arm_ioremap_pfn_caller+0x58/0x190()
ocId 0.
=======Modules linked in:= Running app us syslinking arguments == ipv6======
MessageQ
App sample appliBacktrace: cation
Trace en
abled
Trace Set[<c0049bb8>] (dump_backtrace+0x0/0x110) from [<c039b7d4>] (dump_stack+0x18/0x1c)
FailureReason en r7:00000000abled
Entered M r6:c004d76cessageQApp_start r5:c045bf9bup
Loading and r4:000000d3starting procId
[0] with [./mess[<c039b7bc>] (dump_stack+0x0/0x1c) from [<c006da3c>] (warn_slowpath_common+0x54/0x6c)
ageq_ti81xx_dsp.[<c006d9e8>] (warn_slowpath_common+0x0/0x6c) from [<c006da78>] (warn_slowpath_null+0x24/0x2c)
xe674]
Attached r9:00000002 to slave procId r8:00000000 0.
Loading pro r7:bf0bf464cId 0.
r4:00000000
r7:cb771cc8 r6:00000000 r5:cb771c60 r4:d0091000
r8:d0236000 r7:cb771cc8 r6:00000000 r5:06a85000 r4:cb771d48
r8:bebfdb30 r7:00000007 r6:00000007 r5:cb7e6380 r4:00000000
r8:c0045fa8 r7:00000036 r6:00000000 r5:00000000 r4:bebfdb30
---[ end trace 9228fd6d702c7c8b ]---
Backtrace:
r4:00000000
---[ end trace 9228fd6d702c7c8c ]---
Backtrace:
r4:00000000
---[ end trace 9228fd6d702c7c8d ]---
Backtrace:
r4:00000000
---[ end trace 9228fd6d702c7c8e ]---
Backtrace:
r4:00000000
---[ end trace 9228fd6d702c7c8f ]---
Backtrace:
r4:00000000
---[ end trace 9228fd6d702c7c90 ]---
Backtrace:
r4:00000000
---[ end trace 9228fd6d702c7c91 ]---
Backtrace:
r4:00000000
---[ end trace 9228fd6d702c7c92 ]---
SlaveLoader_startup status [111693824]
status [0x0]
status [0x97d2000]
Shutting down procId [0]
Unloaded slave procId 0.
Detached from slave procId 0.
SlaveLoader_shutdown status [0]
Leaving MessageQApp_shutdown() (0x0)
Amit
