Adding UBIFS image onto the secondary nand flash
Other Parts Discussed in Thread: DM3730, TSC2007
Hi all:
1st Nand : x-loader, u-boot.bin, uImage
2nd Nand : UBIFS Image
done configuration in kernel and also in u-boot
my logcat is below:
what 's happening, problem help me to solve ?
3583820 bytes read
## Booting kernel from Legacy Image at 80300000 ...
   Image Name:   Linux-2.6.32
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3583756 Bytes = 3.4 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux.....................................................................................................................................................
[    0.000000] Linux version 2.6.32 (ladstech@ladstech-desktop) (gcc version 4.2.0 20070413 (prerelease) (CodeSourcery Sourcery G++ Lite 2007q1-10)) #388 PREEMPT Mon J2
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
[    0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[    0.000000] Machine: OMAP3 Beagle Board
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] OMAP3630/DM3730 ES1.0 (l2cache iva neon isp 192mhz_clk )
[    0.000000] SRAM: Mapped pa 0x40200000 to va 0xfe400000 size: 0x100000
[    0.000000] Reserving 4194304 bytes SDRAM for VRAM
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 65024
[    0.000000] Kernel command line: console=ttyS2,115200n8 ubi.mtd=5 root=ubi0:rootfs rootfstype=ubifs rw rootwait nohz=off init=/sbin/init
[    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Memory: 256MB = 256MB total
[    0.000000] Memory: 247296KB available (6592K code, 1148K data, 344K init, 0K highmem)
[    0.000000] Hierarchical RCU implementation.
[    0.000000] NR_IRQS:402
[    0.000000] Clocking rate (Crystal/Core/MPU): 26.0/332/600 MHz
[    0.000000] Reprogramming SDRC clock to 332000000 Hz
[    0.000000] gpmc_base = fe000000
[    0.000000] GPMC revision 5.0
[    0.000000] cs value = 0
[    0.000000] returned value of the cs = 00000040
[    0.000000] check for chip select
[    0.000000] cs value = 1
[    0.000000] returned value of the cs = (null)
[    0.000000] cs value = 2
[    0.000000] cs value = 3
[    0.000000] cs value = 4
[    0.000000] cs value = 5
[    0.000000] cs value = 6
[    0.000000] cs value = 7
[    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts
[    0.000000] Total of 96 interrupts on 1 active controller
[    0.000000] OMAP GPIO hardware version 2.5
[    0.000000] OMAP clockevent source: GPTIMER12 at 32768 Hz
[    0.000000] Console: colour dummy device 80x30
[    0.000000] Calibrating delay loop... 510.47 BogoMIPS (lpj=1994752)
[    0.000000] Mount-cache hash table entries: 512
[    0.000000] CPU: Testing write buffer coherency: ok
[    0.000000] tmpfs: No value for mount option 'mode'
[    0.000000] devtmpfs: initialized
[    0.000000] regulator: core version 0.5
[    0.000000] NET: Registered protocol family 16
[    0.000000] Testing nand
[    0.000000] Found NAND on CS0
[    0.000000] nand cs = 0
[    0.000000] omap3beagle cs           = 0
[    0.000000] omap3beagle cs_baseaddr = fe000060
[    0.000000] omap3beagle gpmc_base   = fe000000
[    0.000000] Registering NAND on CS0
[    0.000000] Found NAND on CS7
[    0.000000] nand cs = 7
[    0.000000] omap3beagle cs           = 7
[    0.000000] omap3beagle cs_baseaddr = fe0001b0
[    0.000000] Registering NAND on CS7
[    0.000000] Unable to get DVI reset GPIO
[    0.000000] wl12xx_set_platform_data after that
[    0.000000] omap_init_mbox: platform not supported
[  145.067779] OMAP DMA hardware revision 5.0
[  145.074981] bio: create slab <bio-0> at 0
[  145.076202] SCSI subsystem initialized
[  145.077789] usbcore: registered new interface driver usbfs
[  145.077911] usbcore: registered new interface driver hub
[  145.078063] usbcore: registered new device driver usb
[  145.090881] i2c_omap i2c_omap.1: bus 1 rev4.0 at 2600 kHz
[  145.095458] twl4030: PIH (irq 7) chaining IRQs 368..375
[  145.095489] twl4030: power (irq 373) chaining IRQs 376..383
[  145.095764] twl4030: gpio (irq 368) chaining IRQs 384..401
[  145.096191] arch/arm/mach-omap2/devices.c omap2_mmc_mux 600
[  145.098754] regulator: VUSB1V5: 1500 mV normal standby
[  145.098968] regulator: VUSB1V8: 1800 mV normal standby
[  145.099151] regulator: VUSB3V1: 3100 mV normal standby
[  145.101043] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[  145.101379] regulator: VMMC1: 1850 <--> 3150 mV normal standby
[  145.101593] regulator: VDAC: 1800 mV normal standby
[  145.101806] regulator: VPLL2: 1800 mV normal standby
[  145.102081] regulator: VSIM: 1800 <--> 3000 mV normal standby
[  145.102447] regulator: VAUX3: 1800 mV normal standby
[  145.102813] regulator: VAUX4: 1800 mV normal standby
[  145.110900] i2c_omap i2c_omap.2: bus 2 rev4.0 at 400 kHz
[  145.112518] cfg80211: Using static regulatory domain info
[  145.112548] cfg80211: Regulatory domain: 00
[  145.112548]     (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[  145.112579]     (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[  145.112579]     (2457000 KHz - 2482000 KHz @ 20000 KHz), (600 mBi, 2000 mBm)
[  145.112609]     (2474000 KHz - 2494000 KHz @ 20000 KHz), (600 mBi, 2000 mBm)
[  145.112640]     (5170000 KHz - 5250000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[  145.112640]     (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[  145.112701] cfg80211: Calling CRDA to update world regulatory domain
[  145.112915] Switching to clocksource 32k_counter
[  145.120727] musb_hdrc: version 6.0, musb-dma, otg (peripheral+host), debug=0
[  145.121063] musb_hdrc: USB OTG mode controller at fa0ab000 using DMA, IRQ 92
[  145.121765] NET: Registered protocol family 2
[  145.121948] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[  145.122406] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[  145.122619] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[  145.122741] TCP: Hash tables configured (established 8192 bind 8192)
[  145.122741] TCP reno registered
[  145.122772] UDP hash table entries: 256 (order: 0, 4096 bytes)
[  145.122802] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[  145.122985] NET: Registered protocol family 1
[  145.123382] RPC: Registered udp transport module.
[  145.123382] RPC: Registered tcp transport module.
[  145.123413] RPC: Registered tcp NFSv4.1 backchannel transport module.
[  145.131347] ashmem: initialized
[  145.131896] VFS: Disk quotas dquot_6.5.2
[  145.131988] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[  145.132965] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[  145.133666] JFFS2 version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[  145.134338] msgmni has been set to 483
[  145.138061] alg: No test for stdrng (krng)
[  145.138336] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[  145.138336] io scheduler noop registered
[  145.138366] io scheduler deadline registered
[  145.138488] io scheduler cfq registered (default)
[  145.199035] OMAP DSS rev 2.0
[  145.199096] OMAP DISPC rev 3.0
[  145.199157] OMAP VENC rev 2
[  145.199432] cmel_oled43_panel: init panel
[  145.199432] cmel_oled43_panel: requesting GPIOs
[  145.733489] cmel_oled43_panel: done
[  145.741943] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[  145.760223] serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654
[  145.777862] serial8250.1: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654
[  145.795440] serial8250.2: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654
[  146.487701] console [ttyS2] enabled
[  146.497680] brd: module loaded
[  146.503875] loop: module loaded
[  146.508850] twl4030_madc twl4030_madc: clk disabled, enabling
[  146.516418] omap2-nand driver initializing
[  146.520690] res = 3481419476
[  146.523590] address of phys_base = 0
[  146.527191] size = 16777216
[  146.529998] returned value of the cs = 00000040
[  146.534576] adjust resource function
[  146.538177] value of adjust resource = 30000000
[  146.542938] NAND device: Manufacturer ID: 0xad, Chip ID: 0xbc (Hynix NAND 512MiB 1,8V 16-bit)
[  146.552001] cmdlinepart partition parsing not available
[  146.557250] Creating 5 MTD partitions on "omap2-nand":
[  146.562500] 0x000000000000-0x000000080000 : "X-Loader"
[  146.568817] 0x000000080000-0x000000260000 : "U-Boot"
[  146.575256] 0x000000260000-0x000000280000 : "U-Boot Env"
[  146.581329] 0x000000280000-0x000000680000 : "Kernel"
[  146.588439] 0x000000680000-0x000020000000 : "File System"
[  146.774932] res = 3481419476
[  146.777862] address of phys_base = 0
[  146.781463] size = 16777216
[  146.784271] returned value of the cs = 00000040
[  146.788848] adjust resource function
[  146.792449] value of adjust resource = 38000000
[  146.797210] NAND device: Manufacturer ID: 0x2c, Chip ID: 0x48 (Micron NAND 1.8v 8-bit)
[  146.805603] cmdlinepart partition parsing not available
[  146.810913] Creating 1 MTD partitions on "omap2-nand.1":
[  146.816345] 0x000000000000-0x000080000000 : "Root file system"
[  146.914642] UBI: attaching mtd5 to ubi0
[  146.918609] UBI: physical eraseblock size:   1048576 bytes (1024 KiB)
[  146.925079] UBI: logical eraseblock size:    1044480 bytes
[  146.930633] UBI: smallest flash I/O unit:    4096
[  146.935394] UBI: sub-page size:              1024
[  146.940124] UBI: VID header offset:          1024 (aligned 1024)
[  146.946197] UBI: data offset:                4096
[  146.951873] UBI error: validate_ec_hdr: bad VID header offset 512, expected 1024
[  146.959350] UBI error: validate_ec_hdr: bad EC header
[  146.964447] UBI error: ubi_io_read_ec_hdr: validation failed for PEB 2
[  146.971405] UBI error: ubi_init: cannot attach mtd5
[  146.976531] UBI error: ubi_init: UBI error: cannot initialize UBI, error -22
[  146.985900] Fixed MDIO Bus: probed
[  146.989562] PPP generic driver version 2.4.2
[  146.994079] PPP Deflate Compression module registered
[  146.999206] PPP BSD Compression module registered
[  147.005187] PPP MPPE Compression module registered
[  147.010009] NET: Registered protocol family 24
[  147.014587] PPPoL2TP kernel driver, V1.0
[  147.018524] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[  147.028289] CSLIP: code copyright 1989 Regents of the University of California.
[  147.035644] SLIP linefill/keepalive option.
[  147.039855] dm9000 Ethernet Driver, V1.31
[  147.044189] usbcore: registered new interface driver catc
[  147.049621] catc: v2.8:CATC EL1210A NetMate USB Ethernet driver
[  147.055694] usbcore: registered new interface driver kaweth
[  147.061309] pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB Ethernet driver
[  147.068939] usbcore: registered new interface driver pegasus
[  147.074645] rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet driver
[  147.081665] usbcore: registered new interface driver rtl8150
[  147.087463] usbcore: registered new interface driver asix
[  147.092956] usbcore: registered new interface driver cdc_ether
[  147.098907] usbcore: registered new interface driver cdc_eem
[  147.104675] usbcore: registered new interface driver dm9601
[  147.110382] usbcore: registered new interface driver smsc95xx
[  147.116271] usbcore: registered new interface driver gl620a
[  147.121948] usbcore: registered new interface driver net1080
[  147.127716] usbcore: registered new interface driver plusb
[  147.133331] usbcore: registered new interface driver rndis_host
[  147.139373] usbcore: registered new interface driver cdc_subset
[  147.145416] usbcore: registered new interface driver zaurus
[  147.151062] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[  147.158630] console [netcon0] enabled
[  147.162353] netconsole: network logging started
[  147.167266] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[  147.174133] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[  147.180175] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
[  147.187774] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[  147.206848] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[  147.212707] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[  147.219604] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[  147.226867] usb usb1: Product: OMAP-EHCI Host Controller
[  147.232238] usb usb1: Manufacturer: Linux 2.6.32 ehci_hcd
[  147.237670] usb usb1: SerialNumber: ehci-omap.0
[  147.242858] hub 1-0:1.0: USB hub found
[  147.246704] hub 1-0:1.0: 3 ports detected
[  147.277191] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[  147.283599] usbcore: registered new interface driver cdc_acm
[  147.289337] cdc_acm: v0.26:USB Abstract Control Model driver for USB modems and ISDN adapters
[  147.297943] Initializing USB Mass Storage driver...
[  147.303009] usbcore: registered new interface driver usb-storage
[  147.309082] USB Mass Storage support registered.
[  147.313934] usbcore: registered new interface driver usbserial
[  147.319885] USB Serial support registered for generic
[  147.325073] usbcore: registered new interface driver usbserial_generic
[  147.331695] usbserial: USB Serial Driver core
[  147.336120] USB Serial support registered for GSM modem (1-port)
[  147.342285] usbcore: registered new interface driver option
[  147.347930] option: v0.7.2:USB Driver for GSM modems
[  147.352935] android init
[  147.355560] android_probe pdata: c070a314
[  147.359649] android_bind
[  147.362243] android_usb gadget: android_usb ready
[  147.367004] musb_hdrc musb_hdrc: MUSB HDRC host driver
[  147.372467] musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 2
[  147.379882] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[  147.386749] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[  147.394012] usb usb2: Product: MUSB HDRC host driver
[  147.399017] usb usb2: Manufacturer: Linux 2.6.32 musb-hcd
[  147.404479] usb usb2: SerialNumber: musb_hdrc
[  147.409454] hub 2-0:1.0: USB hub found
[  147.413269] hub 2-0:1.0: 1 port detected
[  147.417724] f_acm init
[  147.420104] android_register_function acm
[  147.424133] function adb not found in bind_functions
[  147.429138] f_adb init
[  147.431518] android_register_function adb
[  147.435577] f_mass_storage init
[  147.438720] android_register_function usb_mass_storage
[  147.443939] f_rndis init
[  147.446563] android_register_function rndis
[  147.451171] mice: PS/2 mouse device common for all mice
[  147.456817] input: TWL4030 Keypad as /devices/platform/i2c_omap.1/i2c-1/1-004a/twl4030_keypad/input/input0
[  147.468353] tsc2007_init rest_pin=0
[  148.328094] tsc2007_init rest_pin=1
[  148.332641] using rtc device, twl_rtc, for alarms
[  148.337219] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
[  148.343994] twl_rtc twl_rtc: Power up reset detected.
[  148.349639] twl_rtc twl_rtc: Enabling TWL-RTC.
[  148.354675] i2c /dev entries driver
[  148.358795] Linux video capture interface: v2.00
[  148.363555] gspca: main v2.8.0 registered
[  148.368041] usbcore: registered new interface driver uvcvideo
[  148.373840] USB Video Class driver (v0.1.0)
[  148.378051] vpfe_init
[  148.380615] Driver for 1-wire Dallas network protocol.
[  148.385955] 1-Wire driver for the DS2760 battery monitor  chip  - (c) 2004-2005, Szabolcs Gyurko
[  148.395050] ltc4155-battery 2-0009: support ver. 1.0.0 enabled
[  148.401580] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[  148.409362]
[  148.409362]
[  148.409362] drivers/mmc/host/omap_hsmmc.c omap_hsmmc_probe 1658
[  148.418365]
[  148.418365]
[  148.418365] irq in platform driver 83
[  148.418365]
[  148.427795] val->intval of conversion madc = 760
[  148.464599] usb 1-2: new high speed USB device using ehci-omap and address 2
[  148.542999] Registered led device: beagleboard::usr0
[  148.548095] Registered led device: beagleboard::usr1
[  148.554931] Registered led device: beagleboard::pmu_stat
[  148.561492] usbcore: registered new interface driver usbhid
[  148.567138] usbhid: USB HID core driver
[  148.571624] logger: created 64K log 'log_main'
[  148.576293] logger: created 256K log 'log_events'
[  148.581176] logger: created 64K log 'log_radio'
[  148.585906] logger: created 64K log 'log_system'
[  148.590911] Advanced Linux Sound Architecture Driver Version 1.0.21.
[  148.598968]
[  148.598968] twl4030_modinit 2270
[  148.631713] usb 1-2: New USB device found, idVendor=0424, idProduct=2514
[  148.640289] usb 1-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[  148.652160] hub 1-2:1.0: USB hub found
[  148.657867] hub 1-2:1.0: 4 ports detected
[  148.678894] No device for DAI omap-mcbsp-dai-0
[  148.683441] No device for DAI omap-mcbsp-dai-1
[  148.687896] No device for DAI omap-mcbsp-dai-2
[  148.692382] No device for DAI omap-mcbsp-dai-3
[  148.696899] No device for DAI omap-mcbsp-dai-4
[  148.701385] OMAP3 Beagle SoC init
[  148.704956]
[  148.704956] twl4030_soc_probe2120
[  148.710449] asoc: twl4030 <-> omap-mcbsp-dai-0 mapping ok
[  148.716033]
[  148.716033] twl4030_add_widgets1498
[  148.721801]
[  148.721801] twl4030_soc_probe2154
[  148.731445] ALSA device list:
[  148.734436]   #0: omap3beagle (twl4030)
[  148.738494] oprofile: using arm/armv7
[  148.742431] TCP cubic registered
[  148.746093] NET: Registered protocol family 10
[  148.751434] NET: Registered protocol family 17
[  148.755981] NET: Registered protocol family 15
[  148.761108] NET: Registered protocol family 33
[  148.765655] lib80211: common routines for IEEE802.11 drivers
[  148.771392] ThumbEE CPU extension supported.
[  148.775695] Power Management for TI OMAP3.
[  148.781677] SmartReflex driver initialized
[  148.786010] omap3beaglelmb: Driver registration complete
[  148.798553] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[  148.806854] registered taskstats version 1
[  148.823730] Console: switching to colour frame buffer device 40x30
[  148.831298] omapdss DPI: Could not find exact pixel clock. Requested 11360 kHz, got 11220 kHz
[  148.841613] cmel_oled43_panel: panel_enable begin
[  149.318511] cmel_oled43_panel: panel_enable end
[  149.323791] regulator_init_complete: incomplete constraints, leaving VAUX3 on
[  149.331390] regulator_init_complete: incomplete constraints, leaving VDVI on
[  149.338653] regulator_init_complete: incomplete constraints, leaving VDAC on
[  149.346923] twl_rtc twl_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[  149.355194] omapdss DPI error: display already enabled
[  149.360382] omap_vout omap_vout: 'lcd' Display already enabled
[  149.366271] omapdss DPI error: display already enabled
[  149.371459] omap_vout omap_vout: 'lcd' Display already enabled
[  149.377349] omap_vout omap_vout: Buffer Size = 3686400
[  149.383392] omap_vout omap_vout: : registered and initialized video device 0
[  149.390655] omap_vout omap_vout: Buffer Size = 3686400
[  149.396636] omap_vout omap_vout: : registered and initialized video device 1
[  149.404235] UBIFS error (pid 1): ubifs_get_sb: cannot open "ubi0:rootfs", error -19
[  149.411987] VFS: Cannot open root device "ubi0:rootfs" or unknown-block(0,0)
[  149.419128] Please append a correct "root=" boot option; here are the available partitions:
[  149.427581] 1f00             512 mtdblock0 (driver?)
[  149.432586] 1f01            1920 mtdblock1 (driver?)
[  149.437591] 1f02             128 mtdblock2 (driver?)
[  149.442596] 1f03            4096 mtdblock3 (driver?)
[  149.447601] 1f04          517632 mtdblock4 (driver?)
[  149.452606] 1f05         2097152 mtdblock5 (driver?)
[  149.457641] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
santosh vastrad
