Building EZSDK for TI814x
I have sources and pre-built binaries of TI814x EZSDK.
When i run the pre-built images all the applications are working fine.
But when i run the binaries after compiling the sources. the EZSDK is not working.
What is the procedure to copy the compiled binaries from INSTALL directory in to the SDK card.?
Pradeep
  • Hello, Pradeep Kumar1
    There is no strict procedure how to make things happen, but you can try something like that:
        $ cd <EZSDK_home>
        $ make clean
        $ make all
        $ make install
        $ cd <install_folder>                            (default is ~/install/dm814x-evm/)
                $ sudo cp -r * /media/ROOTFS                  (where /media/ROOTFS is the socond partition of the already flashed SD card)
                    or
                $ sudo cp -r * /home/users/<user_name>/targetfs                    (default for NFS)
    This should replace the pre-builds with your stuff. Then boot your system. I hope this helps. If you still have problems, please, write some details. "the EZSDK is not working" - What error is printed?
    BR
