Other Parts Discussed in Thread: SYSBIOS, OMAPL138
I am trying to migrate my application from DSP/BIOS to SYS/BIOS with EDMA3 2.11.05.02 and biospsp 3.0.01.00.
I have managed to get it to compile but the linker cannot find the following references.
_ti_sysbios_family_c64p_EventCombiner_disableEvent__E C:\ti\edma3_lld_02_11_05_02\packages\ti\sdo\edma3\drv\sample\lib\c6748-evm\674\release\edma3_lld_drv_sample.a674<sample_c6748_int_reg.o674>
_ti_sysbios_family_c64p_EventCombiner_dispatchPlug__E C:\ti\edma3_lld_02_11_05_02\packages\ti\sdo\edma3\drv\sample\lib\c6748-evm\674\release\edma3_lld_drv_sample.a674<sample_c6748_int_reg.o674>
_ti_sysbios_family_c64p_EventCombiner_enableEvent__E C:\ti\edma3_lld_02_11_05_02\packages\ti\sdo\edma3\drv\sample\lib\c6748-evm\674\release\edma3_lld_drv_sample.a674<sample_c6748_int_reg.o674>
_ti_sysbios_hal_Cache_CacheProxy_wbInv__E C:\ti\bios_6_33_04_39\packages\ti\sysbios\lib\instrumented_674\sysbios\sysbios.lib<BIOS.obj>
_ti_sysbios_hal_Cache_CacheProxy_wb__E C:\ti\bios_6_33_04_39\packages\ti\sysbios\lib\instrumented_674\sysbios\sysbios.lib<BIOS.obj>
_ti_sysbios_io_DEV_Module__state__V C:\ti\bios_6_33_04_39\packages\ti\sysbios\lib\instrumented_674\sysbios\sysbios.lib<BIOS.obj>
_ti_sysbios_io_DEV_Object__create__S C:\ti\bios_6_33_04_39\packages\ti\sysbios\lib\instrumented_674\sysbios\sysbios.lib<BIOS.obj>
_ti_sysbios_io_DEV_Object__delete__S C:\ti\bios_6_33_04_39\packages\ti\sysbios\lib\instrumented_674\sysbios\sysbios.lib<BIOS.obj>
_ti_sysbios_io_DEV_Params__init__S C:\ti\bios_6_33_04_39\packages\ti\sysbios\lib\instrumented_674\sysbios\sysbios.lib<BIOS.obj>
_ti_sysbios_io_DEV_tableSize__C C:\ti\bios_6_33_04_39\packages\ti\sysbios\lib\instrumented_674\sysbios\sysbios.lib<BIOS.obj>
_ti_sysbios_io_GIO_Instance_State_freeList__O C:\ti\bios_6_33_04_39\packages\ti\sysbios\lib\instrumented_674\sysbios\sysbios.lib<BIOS.obj>
_ti_sysbios_io_GIO_Object__create__S ./Dsp_C6748/spiInitC6748.obj
_ti_sysbios_io_GIO_Object__delete__S ./UartInit.obj
_ti_sysbios_io_GIO_Params__init__S ./Dsp_C6748/spiInitC6748.obj
_xdc_runtime_Timestamp_get32__E C:\ti\ipc_1_24_02_27\packages\ti\sdo\ipc\lib\instrumented_674\ipc\ipc.lib<Ipc.obj>
_xdc_runtime_knl_Sync_wait__E C:\ti\ipc_1_24_02_27\packages\ti\sdo\ipc\lib\instrumented_674\ipc\ipc.lib<Ipc.obj>
Can someone explain to me where the libraries are that contain those references. I have looked in the obvious places without success.
Thanks Iain
