Hi, all
I am developing projects in DM8168 with slicion revision 2.0 on our customer boards.
During developing, i face one strange issue that system halted randomly after rebooting.
So i start to do a simple test, using a script to run init.sh and load.sh to load firmware but do not involve any of our applications.
After finish loading firmware, system reboot immediately by using reboot command. (it will call /sbin/halt.sysvinit).
The testing results are
* Sample 1:
* Using DVRRDK_02.00.00.23 with Hardware A:
- result: system halted after 4 days. (reboot around 5760 times)
* Sample 2:
* Using DVRRDK_02.80.00.10 with Hardware A:
- result: system halted after 3 days (reboot around 4320 times)
* Sample 3:
* Using DVRRDK_02.00.00.23 with Hardware B:
- result: system halted after 8 days. (reboot around 11520 times)
Systems boot from nand flash, and root file systems are cramfs and then mount application file system from UBI partition.
Both of hardware are all DM1868 with silicon revision 2.0 and look like to halt in the sample place.
Any help will be highly appreciated.
======= The partial log as follow =====
RAMDISK: cramfs filesystem found at block 0
RAMDISK: Loading 12828KiB [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/done.
VFS: Mounted root (cramfs filesystem) readonly on device 1:0.
devtmpfs: mounted
Freeing init memory: 196K
INIT: version 2.86 booting
Please wait: booting...
Starting udev
udevd (72): /proc/72/oom_adj is deprecated, please use /proc/72/oom_score_adj instead. <---- halt here
--------------------------------------- useful information --------------------------------------
### U-Boot ENV:
setenv bootcmd 'nand read 0x81000000 0x800000 0x300000;nand read 0x82000000 0x1140000 0xe00000;bootm 0x81000000'
setenv bootargs 'mem=256M console=ttyO2,115200n8 root=/dev/ram0 ro initrd=0x82000000,16M ramdisk_size=16000 ip=192.168.1.146:192.168.1.136:192.168.0.1:255.255.252.0::eth0:off vram=20M notifyk.vpssm3_sva=0xBFD00000'
### Kernel Config
# # Automatically generated make config: don't edit # Linux/arm 2.6.37 Kernel Configuration # Fri Jun 8 22:28:40 2012 # CONFIG_ARM=y CONFIG_SYS_SUPPORTS_APM_EMULATION=y CONFIG_GENERIC_GPIO=y # CONFIG_ARCH_USES_GETTIMEOFFSET is not set CONFIG_GENERIC_CLOCKEVENTS=y CONFIG_HAVE_PROC_CPU=y CONFIG_GENERIC_HARDIRQS=y CONFIG_STACKTRACE_SUPPORT=y CONFIG_HAVE_LATENCYTOP_SUPPORT=y CONFIG_LOCKDEP_SUPPORT=y CONFIG_TRACE_IRQFLAGS_SUPPORT=y CONFIG_HARDIRQS_SW_RESEND=y CONFIG_GENERIC_IRQ_PROBE=y CONFIG_RWSEM_GENERIC_SPINLOCK=y CONFIG_ARCH_HAS_CPUFREQ=y CONFIG_ARCH_HAS_CPU_IDLE_WAIT=y CONFIG_GENERIC_HWEIGHT=y CONFIG_GENERIC_CALIBRATE_DELAY=y CONFIG_NEED_DMA_MAP_STATE=y CONFIG_GENERIC_HARDIRQS_NO__DO_IRQ=y CONFIG_ARM_L1_CACHE_SHIFT_6=y CONFIG_VECTORS_BASE=0xffff0000 CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config" CONFIG_CONSTRUCTORS=y CONFIG_HAVE_IRQ_WORK=y # # General setup # CONFIG_EXPERIMENTAL=y CONFIG_BROKEN_ON_SMP=y CONFIG_INIT_ENV_ARG_LIMIT=32 CONFIG_CROSS_COMPILE="" CONFIG_LOCALVERSION="" # CONFIG_LOCALVERSION_AUTO is not set CONFIG_HAVE_KERNEL_GZIP=y CONFIG_HAVE_KERNEL_LZMA=y CONFIG_HAVE_KERNEL_LZO=y CONFIG_KERNEL_GZIP=y # CONFIG_KERNEL_LZMA is not set # CONFIG_KERNEL_LZO is not set # CONFIG_SWAP is not set CONFIG_SYSVIPC=y CONFIG_SYSVIPC_SYSCTL=y # CONFIG_POSIX_MQUEUE is not set CONFIG_BSD_PROCESS_ACCT=y # CONFIG_BSD_PROCESS_ACCT_V3 is not set # CONFIG_TASKSTATS is not set # CONFIG_AUDIT is not set # CONFIG_HAVE_GENERIC_HARDIRQS is not set # CONFIG_SPARSE_IRQ is not set # # RCU Subsystem # CONFIG_TINY_RCU=y # CONFIG_PREEMPT_RCU is not set # CONFIG_TREE_RCU_TRACE is not set # CONFIG_IKCONFIG is not set CONFIG_LOG_BUF_SHIFT=17 # CONFIG_CGROUPS is not set CONFIG_NAMESPACES=y # CONFIG_UTS_NS is not set # CONFIG_IPC_NS is not set # CONFIG_USER_NS is not set # CONFIG_PID_NS is not set # CONFIG_NET_NS is not set # CONFIG_SYSFS_DEPRECATED is not set # CONFIG_RELAY is not set CONFIG_BLK_DEV_INITRD=y CONFIG_INITRAMFS_SOURCE="" CONFIG_RD_GZIP=y # CONFIG_RD_BZIP2 is not set # CONFIG_RD_LZMA is not set # CONFIG_RD_LZO is not set CONFIG_CC_OPTIMIZE_FOR_SIZE=y CONFIG_SYSCTL=y CONFIG_ANON_INODES=y CONFIG_EMBEDDED=y CONFIG_UID16=y CONFIG_SYSCTL_SYSCALL=y CONFIG_KALLSYMS=y CONFIG_KALLSYMS_ALL=y CONFIG_KALLSYMS_EXTRA_PASS=y CONFIG_HOTPLUG=y CONFIG_PRINTK=y CONFIG_BUG=y CONFIG_ELF_CORE=y CONFIG_BASE_FULL=y CONFIG_FUTEX=y CONFIG_EPOLL=y CONFIG_SIGNALFD=y CONFIG_TIMERFD=y CONFIG_EVENTFD=y CONFIG_SHMEM=y CONFIG_AIO=y CONFIG_HAVE_PERF_EVENTS=y CONFIG_PERF_USE_VMALLOC=y # # Kernel Performance Events And Counters # # CONFIG_PERF_EVENTS is not set # CONFIG_PERF_COUNTERS is not set CONFIG_VM_EVENT_COUNTERS=y CONFIG_PCI_QUIRKS=y CONFIG_SLUB_DEBUG=y CONFIG_COMPAT_BRK=y # CONFIG_SLAB is not set CONFIG_SLUB=y # CONFIG_SLOB is not set # CONFIG_PROFILING is not set CONFIG_HAVE_OPROFILE=y CONFIG_KPROBES=y CONFIG_KRETPROBES=y CONFIG_HAVE_KPROBES=y CONFIG_HAVE_KRETPROBES=y CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y CONFIG_HAVE_CLK=y # # GCOV-based kernel profiling # # CONFIG_GCOV_KERNEL is not set CONFIG_HAVE_GENERIC_DMA_COHERENT=y CONFIG_SLABINFO=y CONFIG_RT_MUTEXES=y CONFIG_BASE_SMALL=0 CONFIG_MODULES=y # CONFIG_MODULE_FORCE_LOAD is not set CONFIG_MODULE_UNLOAD=y # CONFIG_MODULE_FORCE_UNLOAD is not set CONFIG_MODVERSIONS=y # CONFIG_MODULE_SRCVERSION_ALL is not set CONFIG_BLOCK=y # CONFIG_LBDAF is not set # CONFIG_BLK_DEV_BSG is not set # CONFIG_BLK_DEV_INTEGRITY is not set # # IO Schedulers # CONFIG_IOSCHED_NOOP=y CONFIG_IOSCHED_DEADLINE=y CONFIG_IOSCHED_CFQ=y # CONFIG_DEFAULT_DEADLINE is not set CONFIG_DEFAULT_CFQ=y # CONFIG_DEFAULT_NOOP is not set CONFIG_DEFAULT_IOSCHED="cfq" # CONFIG_INLINE_SPIN_TRYLOCK is not set # CONFIG_INLINE_SPIN_TRYLOCK_BH is not set # CONFIG_INLINE_SPIN_LOCK is not set # CONFIG_INLINE_SPIN_LOCK_BH is not set # CONFIG_INLINE_SPIN_LOCK_IRQ is not set # CONFIG_INLINE_SPIN_LOCK_IRQSAVE is not set CONFIG_INLINE_SPIN_UNLOCK=y # CONFIG_INLINE_SPIN_UNLOCK_BH is not set CONFIG_INLINE_SPIN_UNLOCK_IRQ=y # CONFIG_INLINE_SPIN_UNLOCK_IRQRESTORE is not set # CONFIG_INLINE_READ_TRYLOCK is not set # CONFIG_INLINE_READ_LOCK is not set # CONFIG_INLINE_READ_LOCK_BH is not set # CONFIG_INLINE_READ_LOCK_IRQ is not set # CONFIG_INLINE_READ_LOCK_IRQSAVE is not set CONFIG_INLINE_READ_UNLOCK=y # CONFIG_INLINE_READ_UNLOCK_BH is not set CONFIG_INLINE_READ_UNLOCK_IRQ=y # CONFIG_INLINE_READ_UNLOCK_IRQRESTORE is not set # CONFIG_INLINE_WRITE_TRYLOCK is not set # CONFIG_INLINE_WRITE_LOCK is not set # CONFIG_INLINE_WRITE_LOCK_BH is not set # CONFIG_INLINE_WRITE_LOCK_IRQ is not set # CONFIG_INLINE_WRITE_LOCK_IRQSAVE is not set CONFIG_INLINE_WRITE_UNLOCK=y # CONFIG_INLINE_WRITE_UNLOCK_BH is not set CONFIG_INLINE_WRITE_UNLOCK_IRQ=y # CONFIG_INLINE_WRITE_UNLOCK_IRQRESTORE is not set # CONFIG_MUTEX_SPIN_ON_OWNER is not set # CONFIG_FREEZER is not set # # System Type # CONFIG_MMU=y # CONFIG_ARCH_AAEC2000 is not set # CONFIG_ARCH_INTEGRATOR is not set # CONFIG_ARCH_REALVIEW is not set # CONFIG_ARCH_VERSATILE is not set # CONFIG_ARCH_VEXPRESS is not set # CONFIG_ARCH_AT91 is not set # CONFIG_ARCH_BCMRING is not set # CONFIG_ARCH_CLPS711X is not set # CONFIG_ARCH_CNS3XXX is not set # CONFIG_ARCH_GEMINI is not set # CONFIG_ARCH_EBSA110 is not set # CONFIG_ARCH_EP93XX is not set # CONFIG_ARCH_FOOTBRIDGE is not set # CONFIG_ARCH_MXC is not set # CONFIG_ARCH_STMP3XXX is not set # CONFIG_ARCH_NETX is not set # CONFIG_ARCH_H720X is not set # CONFIG_ARCH_IOP13XX is not set # CONFIG_ARCH_IOP32X is not set # CONFIG_ARCH_IOP33X is not set # CONFIG_ARCH_IXP23XX is not set # CONFIG_ARCH_IXP2000 is not set # CONFIG_ARCH_IXP4XX is not set # CONFIG_ARCH_DOVE is not set # CONFIG_ARCH_KIRKWOOD is not set # CONFIG_ARCH_LOKI is not set # CONFIG_ARCH_LPC32XX is not set # CONFIG_ARCH_MV78XX0 is not set # CONFIG_ARCH_ORION5X is not set # CONFIG_ARCH_MMP is not set # CONFIG_ARCH_KS8695 is not set # CONFIG_ARCH_NS9XXX is not set # CONFIG_ARCH_W90X900 is not set # CONFIG_ARCH_NUC93X is not set # CONFIG_ARCH_TEGRA is not set # CONFIG_ARCH_PNX4008 is not set # CONFIG_ARCH_PXA is not set # CONFIG_ARCH_MSM is not set # CONFIG_ARCH_SHMOBILE is not set # CONFIG_ARCH_RPC is not set # CONFIG_ARCH_SA1100 is not set # CONFIG_ARCH_S3C2410 is not set # CONFIG_ARCH_S3C64XX is not set # CONFIG_ARCH_S5P64X0 is not set # CONFIG_ARCH_S5P6442 is not set # CONFIG_ARCH_S5PC100 is not set # CONFIG_ARCH_S5PV210 is not set # CONFIG_ARCH_S5PV310 is not set # CONFIG_ARCH_SHARK is not set # CONFIG_ARCH_TCC_926 is not set # CONFIG_ARCH_LH7A40X is not set # CONFIG_ARCH_U300 is not set # CONFIG_ARCH_U8500 is not set # CONFIG_ARCH_NOMADIK is not set # CONFIG_ARCH_DAVINCI is not set CONFIG_ARCH_OMAP=y # CONFIG_PLAT_SPEAR is not set # # TI OMAP Common Features # # CONFIG_ARCH_OMAP1 is not set CONFIG_ARCH_OMAP2PLUS=y # # OMAP Feature Selections # # CONFIG_OMAP_RESET_CLOCKS is not set CONFIG_OMAP_MUX=y # CONFIG_OMAP_MUX_DEBUG is not set CONFIG_OMAP_MUX_WARNINGS=y # CONFIG_OMAP_MCBSP is not set CONFIG_OMAP_MBOX_FWK=y CONFIG_OMAP_MBOX_KFIFO_SIZE=256 CONFIG_OMAP_IOMMU=y # CONFIG_OMAP_IOMMU_DEBUG is not set CONFIG_OMAP_MPU_TIMER=y # CONFIG_OMAP_32K_TIMER is not set CONFIG_OMAP_DM_TIMER=y # CONFIG_OMAP_PM_NONE is not set CONFIG_OMAP_PM_NOOP=y # # TI OMAP2/3/4 Specific Features # CONFIG_ARCH_OMAP2PLUS_TYPICAL=y # CONFIG_ARCH_OMAP2 is not set # CONFIG_ARCH_OMAP3 is not set # CONFIG_ARCH_OMAP4 is not set CONFIG_ARCH_TI81XX=y CONFIG_ARCH_TI816X=y # CONFIG_ARCH_TI814X is not set # # OMAP Board Type # # # TI81XX Board Type # # CONFIG_MACH_TI8168EVM is not set CONFIG_MACH_TI8168_DVR=y # # Processor Type # CONFIG_CPU_32v6K=y CONFIG_CPU_V7=y CONFIG_CPU_32v7=y CONFIG_CPU_ABRT_EV7=y CONFIG_CPU_PABRT_V7=y CONFIG_CPU_CACHE_V7=y CONFIG_CPU_CACHE_VIPT=y CONFIG_CPU_COPY_V6=y CONFIG_CPU_TLB_V7=y CONFIG_CPU_HAS_ASID=y CONFIG_CPU_CP15=y CONFIG_CPU_CP15_MMU=y # # Processor Features # CONFIG_ARM_THUMB=y # CONFIG_ARM_THUMBEE is not set # CONFIG_CPU_ICACHE_DISABLE is not set # CONFIG_CPU_DCACHE_DISABLE is not set # CONFIG_CPU_BPREDICT_DISABLE is not set CONFIG_ARM_L1_CACHE_SHIFT=6 CONFIG_ARM_DMA_MEM_BUFFERABLE=y CONFIG_CPU_HAS_PMU=y # CONFIG_ARM_ERRATA_430973 is not set # CONFIG_ARM_ERRATA_458693 is not set # CONFIG_ARM_ERRATA_460075 is not set # CONFIG_ARM_ERRATA_743622 is not set CONFIG_COMMON_CLKDEV=y # # Bus support # CONFIG_PCI=y CONFIG_PCI_SYSCALL=y CONFIG_ARCH_SUPPORTS_MSI=y CONFIG_PCI_MSI=y # CONFIG_PCI_DEBUG is not set # CONFIG_PCI_STUB is not set # CONFIG_PCI_IOV is not set # CONFIG_PCCARD is not set # # Kernel Features # CONFIG_TICK_ONESHOT=y CONFIG_NO_HZ=y CONFIG_HIGH_RES_TIMERS=y CONFIG_GENERIC_CLOCKEVENTS_BUILD=y CONFIG_VMSPLIT_3G=y # CONFIG_VMSPLIT_2G is not set # CONFIG_VMSPLIT_1G is not set CONFIG_PAGE_OFFSET=0xC0000000 CONFIG_PREEMPT_NONE=y # CONFIG_PREEMPT_VOLUNTARY is not set # CONFIG_PREEMPT is not set CONFIG_HZ=100 # CONFIG_THUMB2_KERNEL is not set CONFIG_AEABI=y CONFIG_OABI_COMPAT=y CONFIG_ARCH_HAS_HOLES_MEMORYMODEL=y # CONFIG_ARCH_SPARSEMEM_DEFAULT is not set # CONFIG_ARCH_SELECT_MEMORY_MODEL is not set # CONFIG_HIGHMEM is not set CONFIG_SELECT_MEMORY_MODEL=y CONFIG_FLATMEM_MANUAL=y CONFIG_FLATMEM=y CONFIG_FLAT_NODE_MEM_MAP=y CONFIG_HAVE_MEMBLOCK=y CONFIG_PAGEFLAGS_EXTENDED=y CONFIG_SPLIT_PTLOCK_CPUS=4 # CONFIG_PHYS_ADDR_T_64BIT is not set CONFIG_ZONE_DMA_FLAG=0 CONFIG_VIRT_TO_BUS=y # CONFIG_KSM is not set CONFIG_DEFAULT_MMAP_MIN_ADDR=4096 CONFIG_NEED_PER_CPU_KM=y CONFIG_FORCE_MAX_ZONEORDER=11 # CONFIG_LEDS is not set CONFIG_ALIGNMENT_TRAP=y # CONFIG_UACCESS_WITH_MEMCPY is not set # CONFIG_SECCOMP is not set # CONFIG_CC_STACKPROTECTOR is not set # CONFIG_DEPRECATED_PARAM_STRUCT is not set # # Boot options # CONFIG_ZBOOT_ROM_TEXT=0 CONFIG_ZBOOT_ROM_BSS=0 CONFIG_CMDLINE="" # CONFIG_XIP_KERNEL is not set # CONFIG_KEXEC is not set # CONFIG_AUTO_ZRELADDR is not set # # CPU Power Management # # CONFIG_CPU_FREQ is not set # CONFIG_CPU_IDLE is not set # # Floating point emulation # # # At least one emulation must be selected # CONFIG_FPE_NWFPE=y # CONFIG_FPE_NWFPE_XP is not set # CONFIG_FPE_FASTFPE is not set CONFIG_VFP=y CONFIG_VFPv3=y CONFIG_NEON=y # # Userspace binary formats # CONFIG_BINFMT_ELF=y # CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set CONFIG_HAVE_AOUT=y # CONFIG_BINFMT_AOUT is not set CONFIG_BINFMT_MISC=y # # Power management options # CONFIG_PM=y CONFIG_PM_DEBUG=y # CONFIG_PM_ADVANCED_DEBUG is not set CONFIG_PM_VERBOSE=y # CONFIG_SUSPEND is not set # CONFIG_APM_EMULATION is not set CONFIG_PM_RUNTIME=y CONFIG_PM_OPS=y CONFIG_ARCH_SUSPEND_POSSIBLE=y CONFIG_NET=y # # Networking options # CONFIG_PACKET=y CONFIG_UNIX=y CONFIG_XFRM=y # CONFIG_XFRM_USER is not set # CONFIG_XFRM_SUB_POLICY is not set # CONFIG_XFRM_MIGRATE is not set # CONFIG_XFRM_STATISTICS is not set # CONFIG_NET_KEY is not set CONFIG_INET=y # CONFIG_IP_MULTICAST is not set # CONFIG_IP_ADVANCED_ROUTER is not set CONFIG_IP_FIB_HASH=y CONFIG_IP_PNP=y CONFIG_IP_PNP_DHCP=y CONFIG_IP_PNP_BOOTP=y CONFIG_IP_PNP_RARP=y # CONFIG_NET_IPIP is not set # CONFIG_NET_IPGRE_DEMUX is not set # CONFIG_ARPD is not set # CONFIG_SYN_COOKIES is not set # CONFIG_INET_AH is not set # CONFIG_INET_ESP is not set # CONFIG_INET_IPCOMP is not set # CONFIG_INET_XFRM_TUNNEL is not set CONFIG_INET_TUNNEL=y CONFIG_INET_XFRM_MODE_TRANSPORT=y CONFIG_INET_XFRM_MODE_TUNNEL=y CONFIG_INET_XFRM_MODE_BEET=y CONFIG_INET_LRO=y CONFIG_INET_DIAG=y CONFIG_INET_TCP_DIAG=y # CONFIG_TCP_CONG_ADVANCED is not set CONFIG_TCP_CONG_CUBIC=y CONFIG_DEFAULT_TCP_CONG="cubic" # CONFIG_TCP_MD5SIG is not set CONFIG_IPV6=y # CONFIG_IPV6_PRIVACY is not set # CONFIG_IPV6_ROUTER_PREF is not set # CONFIG_IPV6_OPTIMISTIC_DAD is not set # CONFIG_INET6_AH is not set # CONFIG_INET6_ESP is not set # CONFIG_INET6_IPCOMP is not set # CONFIG_IPV6_MIP6 is not set # CONFIG_INET6_XFRM_TUNNEL is not set # CONFIG_INET6_TUNNEL is not set CONFIG_INET6_XFRM_MODE_TRANSPORT=y CONFIG_INET6_XFRM_MODE_TUNNEL=y CONFIG_INET6_XFRM_MODE_BEET=y # CONFIG_INET6_XFRM_MODE_ROUTEOPTIMIZATION is not set CONFIG_IPV6_SIT=y # CONFIG_IPV6_SIT_6RD is not set CONFIG_IPV6_NDISC_NODETYPE=y # CONFIG_IPV6_TUNNEL is not set # CONFIG_IPV6_MULTIPLE_TABLES is not set # CONFIG_IPV6_MROUTE is not set # CONFIG_NETLABEL is not set # CONFIG_NETWORK_SECMARK is not set # CONFIG_NETWORK_PHY_TIMESTAMPING is not set # CONFIG_NETFILTER is not set # CONFIG_IP_DCCP is not set # CONFIG_IP_SCTP is not set # CONFIG_RDS is not set # CONFIG_TIPC is not set # CONFIG_ATM is not set # CONFIG_L2TP is not set # CONFIG_BRIDGE is not set # CONFIG_NET_DSA is not set # CONFIG_VLAN_8021Q is not set # CONFIG_DECNET is not set # CONFIG_LLC2 is not set # CONFIG_IPX is not set # CONFIG_ATALK is not set # CONFIG_X25 is not set # CONFIG_LAPB is not set # CONFIG_ECONET is not set # CONFIG_WAN_ROUTER is not set # CONFIG_PHONET is not set # CONFIG_IEEE802154 is not set # CONFIG_NET_SCHED is not set # CONFIG_DCB is not set # CONFIG_DNS_RESOLVER is not set # # Network testing # # CONFIG_NET_PKTGEN is not set # CONFIG_NET_TCPPROBE is not set # CONFIG_HAMRADIO is not set # CONFIG_CAN is not set # CONFIG_IRDA is not set # CONFIG_BT is not set # CONFIG_AF_RXRPC is not set # CONFIG_WIRELESS is not set # CONFIG_WIMAX is not set # CONFIG_RFKILL is not set # CONFIG_NET_9P is not set # CONFIG_CAIF is not set # CONFIG_CEPH_LIB is not set # # Device Drivers # # # Generic Driver Options # CONFIG_UEVENT_HELPER_PATH="" CONFIG_DEVTMPFS=y CONFIG_DEVTMPFS_MOUNT=y CONFIG_STANDALONE=y CONFIG_PREVENT_FIRMWARE_BUILD=y CONFIG_FW_LOADER=y CONFIG_FIRMWARE_IN_KERNEL=y CONFIG_EXTRA_FIRMWARE="" # CONFIG_DEBUG_DRIVER is not set # CONFIG_DEBUG_DEVRES is not set # CONFIG_SYS_HYPERVISOR is not set # CONFIG_CONNECTOR is not set CONFIG_MTD=y # CONFIG_MTD_DEBUG is not set # CONFIG_MTD_TESTS is not set CONFIG_MTD_CONCAT=y CONFIG_MTD_PARTITIONS=y # CONFIG_MTD_REDBOOT_PARTS is not set CONFIG_MTD_CMDLINE_PARTS=y # CONFIG_MTD_AFS_PARTS is not set # CONFIG_MTD_AR7_PARTS is not set # # User Modules And Translation Layers # CONFIG_MTD_CHAR=y CONFIG_MTD_BLKDEVS=y CONFIG_MTD_BLOCK=y # CONFIG_FTL is not set # CONFIG_NFTL is not set # CONFIG_INFTL is not set # CONFIG_RFD_FTL is not set # CONFIG_SSFDC is not set # CONFIG_SM_FTL is not set # CONFIG_MTD_OOPS is not set # # RAM/ROM/Flash chip drivers # # CONFIG_MTD_CFI is not set # CONFIG_MTD_JEDECPROBE is not set CONFIG_MTD_MAP_BANK_WIDTH_1=y CONFIG_MTD_MAP_BANK_WIDTH_2=y CONFIG_MTD_MAP_BANK_WIDTH_4=y # CONFIG_MTD_MAP_BANK_WIDTH_8 is not set # CONFIG_MTD_MAP_BANK_WIDTH_16 is not set # CONFIG_MTD_MAP_BANK_WIDTH_32 is not set CONFIG_MTD_CFI_I1=y CONFIG_MTD_CFI_I2=y # CONFIG_MTD_CFI_I4 is not set # CONFIG_MTD_CFI_I8 is not set # CONFIG_MTD_RAM is not set # CONFIG_MTD_ROM is not set # CONFIG_MTD_ABSENT is not set # # Mapping drivers for chip access # # CONFIG_MTD_COMPLEX_MAPPINGS is not set # CONFIG_MTD_INTEL_VR_NOR is not set # CONFIG_MTD_PLATRAM is not set # # Self-contained MTD device drivers # # CONFIG_MTD_PMC551 is not set # CONFIG_MTD_SLRAM is not set # CONFIG_MTD_PHRAM is not set # CONFIG_MTD_MTDRAM is not set # CONFIG_MTD_BLOCK2MTD is not set # # Disk-On-Chip Device Drivers # # CONFIG_MTD_DOC2000 is not set # CONFIG_MTD_DOC2001 is not set # CONFIG_MTD_DOC2001PLUS is not set CONFIG_MTD_NAND_ECC=y # CONFIG_MTD_NAND_ECC_SMC is not set CONFIG_MTD_NAND=y CONFIG_MTD_NAND_VERIFY_WRITE=y # CONFIG_MTD_SM_COMMON is not set # CONFIG_MTD_NAND_MUSEUM_IDS is not set # CONFIG_MTD_NAND_DENALI is not set # CONFIG_MTD_NAND_GPIO is not set CONFIG_MTD_NAND_OMAP2=y CONFIG_MTD_NAND_IDS=y # CONFIG_MTD_NAND_RICOH is not set # CONFIG_MTD_NAND_DISKONCHIP is not set # CONFIG_MTD_NAND_CAFE is not set # CONFIG_MTD_NAND_NANDSIM is not set # CONFIG_MTD_NAND_PLATFORM is not set # CONFIG_MTD_ALAUDA is not set # CONFIG_MTD_ONENAND is not set # # LPDDR flash memory drivers # # CONFIG_MTD_LPDDR is not set CONFIG_MTD_UBI=y CONFIG_MTD_UBI_WL_THRESHOLD=4096 CONFIG_MTD_UBI_BEB_RESERVE=1 # CONFIG_MTD_UBI_GLUEBI is not set # # UBI debugging options # CONFIG_MTD_UBI_DEBUG=y CONFIG_MTD_UBI_DEBUG_MSG=y # CONFIG_MTD_UBI_DEBUG_PARANOID is not set # CONFIG_MTD_UBI_DEBUG_DISABLE_BGT is not set # CONFIG_MTD_UBI_DEBUG_EMULATE_BITFLIPS is not set # CONFIG_MTD_UBI_DEBUG_EMULATE_WRITE_FAILURES is not set # CONFIG_MTD_UBI_DEBUG_EMULATE_ERASE_FAILURES is not set # # Additional UBI debugging messages # # CONFIG_MTD_UBI_DEBUG_MSG_BLD is not set # CONFIG_MTD_UBI_DEBUG_MSG_EBA is not set # CONFIG_MTD_UBI_DEBUG_MSG_WL is not set # CONFIG_MTD_UBI_DEBUG_MSG_IO is not set # CONFIG_PARPORT is not set CONFIG_BLK_DEV=y # CONFIG_BLK_CPQ_DA is not set # CONFIG_BLK_CPQ_CISS_DA is not set # CONFIG_BLK_DEV_DAC960 is not set # CONFIG_BLK_DEV_UMEM is not set # CONFIG_BLK_DEV_COW_COMMON is not set CONFIG_BLK_DEV_LOOP=y # CONFIG_BLK_DEV_CRYPTOLOOP is not set # # DRBD disabled because PROC_FS, INET or CONNECTOR not selected # # CONFIG_BLK_DEV_NBD is not set # CONFIG_BLK_DEV_SX8 is not set # CONFIG_BLK_DEV_UB is not set CONFIG_BLK_DEV_RAM=y CONFIG_BLK_DEV_RAM_COUNT=16 CONFIG_BLK_DEV_RAM_SIZE=32768 # CONFIG_BLK_DEV_XIP is not set # CONFIG_CDROM_PKTCDVD is not set # CONFIG_ATA_OVER_ETH is not set # CONFIG_MG_DISK is not set # CONFIG_BLK_DEV_RBD is not set CONFIG_MISC_DEVICES=y # CONFIG_AD525X_DPOT is not set # CONFIG_PHANTOM is not set # CONFIG_SGI_IOC4 is not set # CONFIG_TIFM_CORE is not set # CONFIG_ICS932S401 is not set # CONFIG_ENCLOSURE_SERVICES is not set # CONFIG_HP_ILO is not set # CONFIG_APDS9802ALS is not set # CONFIG_ISL29003 is not set # CONFIG_ISL29020 is not set # CONFIG_SENSORS_TSL2550 is not set # CONFIG_SENSORS_BH1780 is not set # CONFIG_SENSORS_BH1770 is not set # CONFIG_SENSORS_APDS990X is not set # CONFIG_HMC6352 is not set # CONFIG_DS1682 is not set # CONFIG_BMP085 is not set # CONFIG_PCH_PHUB is not set CONFIG_DM8168_DVR_IO=y # CONFIG_C2PORT is not set # # EEPROM support # # CONFIG_EEPROM_AT24 is not set # CONFIG_EEPROM_LEGACY is not set # CONFIG_EEPROM_MAX6875 is not set # CONFIG_EEPROM_93CX6 is not set # CONFIG_EEPROM_3WIRED_AT93C66 is not set # CONFIG_CB710_CORE is not set # CONFIG_IWMC3200TOP is not set # # Texas Instruments shared transport line discipline # CONFIG_HAVE_IDE=y # CONFIG_IDE is not set # # SCSI device support # CONFIG_SCSI_MOD=y # CONFIG_RAID_ATTRS is not set CONFIG_SCSI=y CONFIG_SCSI_DMA=y # CONFIG_SCSI_TGT is not set # CONFIG_SCSI_NETLINK is not set CONFIG_SCSI_PROC_FS=y # # SCSI support type (disk, tape, CD-ROM) # CONFIG_BLK_DEV_SD=y # CONFIG_CHR_DEV_ST is not set # CONFIG_CHR_DEV_OSST is not set CONFIG_BLK_DEV_SR=y CONFIG_BLK_DEV_SR_VENDOR=y CONFIG_CHR_DEV_SG=y # CONFIG_CHR_DEV_SCH is not set # CONFIG_SCSI_MULTI_LUN is not set # CONFIG_SCSI_CONSTANTS is not set # CONFIG_SCSI_LOGGING is not set # CONFIG_SCSI_SCAN_ASYNC is not set CONFIG_SCSI_WAIT_SCAN=m # # SCSI Transports # # CONFIG_SCSI_SPI_ATTRS is not set # CONFIG_SCSI_FC_ATTRS is not set # CONFIG_SCSI_ISCSI_ATTRS is not set # CONFIG_SCSI_SAS_ATTRS is not set # CONFIG_SCSI_SAS_LIBSAS is not set # CONFIG_SCSI_SRP_ATTRS is not set # CONFIG_SCSI_LOWLEVEL is not set # CONFIG_SCSI_DH is not set # CONFIG_SCSI_OSD_INITIATOR is not set CONFIG_ATA=y # CONFIG_ATA_NONSTANDARD is not set CONFIG_ATA_VERBOSE_ERROR=y CONFIG_SATA_PMP=y # # Controllers with non-SFF native interface # # CONFIG_SATA_AHCI is not set CONFIG_SATA_AHCI_PLATFORM=y # CONFIG_SATA_INIC162X is not set CONFIG_SATA_SIL24=y # CONFIG_ATA_SFF is not set # CONFIG_MD is not set # CONFIG_FUSION is not set # # IEEE 1394 (FireWire) support # # CONFIG_FIREWIRE is not set # CONFIG_FIREWIRE_NOSY is not set # CONFIG_I2O is not set CONFIG_NETDEVICES=y # CONFIG_DUMMY is not set # CONFIG_BONDING is not set # CONFIG_MACVLAN is not set # CONFIG_EQUALIZER is not set # CONFIG_TUN is not set # CONFIG_VETH is not set # CONFIG_ARCNET is not set CONFIG_MII=y CONFIG_PHYLIB=y # # MII PHY device drivers # # CONFIG_MARVELL_PHY is not set # CONFIG_DAVICOM_PHY is not set # CONFIG_QSEMI_PHY is not set # CONFIG_LXT_PHY is not set # CONFIG_CICADA_PHY is not set # CONFIG_VITESSE_PHY is not set # CONFIG_SMSC_PHY is not set # CONFIG_BROADCOM_PHY is not set # CONFIG_BCM63XX_PHY is not set # CONFIG_ICPLUS_PHY is not set # CONFIG_REALTEK_PHY is not set # CONFIG_NATIONAL_PHY is not set # CONFIG_STE10XP is not set CONFIG_LSI_ET1011C_PHY=y # CONFIG_MICREL_PHY is not set # CONFIG_FIXED_PHY is not set # CONFIG_MDIO_BITBANG is not set # CONFIG_NET_ETHERNET is not set CONFIG_NETDEV_1000=y # CONFIG_ACENIC is not set # CONFIG_DL2K is not set CONFIG_TI_DAVINCI_EMAC=y CONFIG_TI_DAVINCI_MDIO=y CONFIG_TI_DAVINCI_CPDMA=y # CONFIG_E1000 is not set # CONFIG_E1000E is not set # CONFIG_IP1000 is not set # CONFIG_IGB is not set # CONFIG_IGBVF is not set # CONFIG_NS83820 is not set # CONFIG_HAMACHI is not set # CONFIG_YELLOWFIN is not set # CONFIG_R8169 is not set # CONFIG_SIS190 is not set # CONFIG_SKGE is not set # CONFIG_SKY2 is not set # CONFIG_VIA_VELOCITY is not set # CONFIG_TIGON3 is not set # CONFIG_BNX2 is not set # CONFIG_CNIC is not set # CONFIG_QLA3XXX is not set # CONFIG_ATL1 is not set # CONFIG_ATL1E is not set # CONFIG_ATL1C is not set # CONFIG_JME is not set # CONFIG_STMMAC_ETH is not set # CONFIG_PCH_GBE is not set # CONFIG_NETDEV_10000 is not set # CONFIG_TR is not set # CONFIG_WLAN is not set # # Enable WiMAX (Networking options) to see the WiMAX drivers # # # USB Network Adapters # # CONFIG_USB_CATC is not set # CONFIG_USB_KAWETH is not set # CONFIG_USB_PEGASUS is not set # CONFIG_USB_RTL8150 is not set CONFIG_USB_USBNET=y # CONFIG_USB_NET_AX8817X is not set CONFIG_USB_NET_CDCETHER=y # CONFIG_USB_NET_CDC_EEM is not set CONFIG_USB_NET_DM9601=y # CONFIG_USB_NET_SMSC75XX is not set # CONFIG_USB_NET_SMSC95XX is not set # CONFIG_USB_NET_GL620A is not set # CONFIG_USB_NET_NET1080 is not set # CONFIG_USB_NET_PLUSB is not set # CONFIG_USB_NET_MCS7830 is not set # CONFIG_USB_NET_RNDIS_HOST is not set # CONFIG_USB_NET_CDC_SUBSET is not set # CONFIG_USB_NET_ZAURUS is not set # CONFIG_USB_NET_CX82310_ETH is not set # CONFIG_USB_NET_INT51X1 is not set # CONFIG_USB_IPHETH is not set # CONFIG_USB_SIERRA_NET is not set # CONFIG_WAN is not set # # CAIF transport drivers # # CONFIG_FDDI is not set # CONFIG_HIPPI is not set # CONFIG_PPP is not set # CONFIG_SLIP is not set # CONFIG_NET_FC is not set # CONFIG_NETCONSOLE is not set # CONFIG_NETPOLL is not set # CONFIG_NET_POLL_CONTROLLER is not set # CONFIG_VMXNET3 is not set # CONFIG_ISDN is not set # CONFIG_PHONE is not set # # Input device support # CONFIG_INPUT=y # CONFIG_INPUT_FF_MEMLESS is not set # CONFIG_INPUT_POLLDEV is not set # CONFIG_INPUT_SPARSEKMAP is not set # # Userland interfaces # CONFIG_INPUT_MOUSEDEV=y # CONFIG_INPUT_MOUSEDEV_PSAUX is not set CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024 CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768 # CONFIG_INPUT_JOYDEV is not set CONFIG_INPUT_EVDEV=y # CONFIG_INPUT_EVBUG is not set # # Input Device Drivers # # CONFIG_INPUT_KEYBOARD is not set # CONFIG_INPUT_MOUSE is not set # CONFIG_INPUT_JOYSTICK is not set # CONFIG_INPUT_TABLET is not set # CONFIG_INPUT_TOUCHSCREEN is not set CONFIG_INPUT_MISC=y # CONFIG_INPUT_AD714X is not set # CONFIG_INPUT_ATI_REMOTE is not set # CONFIG_INPUT_ATI_REMOTE2 is not set # CONFIG_INPUT_KEYSPAN_REMOTE is not set # CONFIG_INPUT_POWERMATE is not set # CONFIG_INPUT_YEALINK is not set # CONFIG_INPUT_CM109 is not set CONFIG_INPUT_UINPUT=y # CONFIG_INPUT_PCF8574 is not set # CONFIG_INPUT_GPIO_ROTARY_ENCODER is not set # CONFIG_INPUT_ADXL34X is not set # # Hardware I/O ports # CONFIG_SERIO=y CONFIG_SERIO_SERPORT=y # CONFIG_SERIO_PCIPS2 is not set # CONFIG_SERIO_LIBPS2 is not set # CONFIG_SERIO_RAW is not set # CONFIG_SERIO_ALTERA_PS2 is not set # CONFIG_SERIO_PS2MULT is not set # CONFIG_GAMEPORT is not set # # Character devices # CONFIG_VT=y CONFIG_CONSOLE_TRANSLATIONS=y CONFIG_VT_CONSOLE=y CONFIG_HW_CONSOLE=y # CONFIG_VT_HW_CONSOLE_BINDING is not set CONFIG_DEVKMEM=y CONFIG_SERIAL_NONSTANDARD=y # CONFIG_COMPUTONE is not set # CONFIG_ROCKETPORT is not set # CONFIG_CYCLADES is not set # CONFIG_DIGIEPCA is not set # CONFIG_MOXA_INTELLIO is not set # CONFIG_MOXA_SMARTIO is not set # CONFIG_ISI is not set # CONFIG_SYNCLINKMP is not set # CONFIG_SYNCLINK_GT is not set # CONFIG_N_HDLC is not set # CONFIG_N_GSM is not set # CONFIG_RISCOM8 is not set # CONFIG_SPECIALIX is not set # CONFIG_STALDRV is not set # CONFIG_NOZOMI is not set # # Serial drivers # CONFIG_SERIAL_8250=y CONFIG_SERIAL_8250_CONSOLE=y CONFIG_SERIAL_8250_PCI=y CONFIG_SERIAL_8250_NR_UARTS=64 CONFIG_SERIAL_8250_RUNTIME_UARTS=4 CONFIG_SERIAL_8250_EXTENDED=y # CONFIG_SERIAL_8250_MANY_PORTS is not set CONFIG_SERIAL_8250_SHARE_IRQ=y CONFIG_SERIAL_8250_DETECT_IRQ=y CONFIG_SERIAL_8250_RSA=y # # Non-8250 serial port support # # CONFIG_SERIAL_MFD_HSU is not set CONFIG_SERIAL_CORE=y CONFIG_SERIAL_CORE_CONSOLE=y # CONFIG_SERIAL_JSM is not set CONFIG_SERIAL_OMAP=y CONFIG_SERIAL_OMAP_CONSOLE=y # CONFIG_SERIAL_TIMBERDALE is not set # CONFIG_SERIAL_ALTERA_JTAGUART is not set # CONFIG_SERIAL_ALTERA_UART is not set CONFIG_UNIX98_PTYS=y # CONFIG_DEVPTS_MULTIPLE_INSTANCES is not set # CONFIG_LEGACY_PTYS is not set # CONFIG_TTY_PRINTK is not set # CONFIG_IPMI_HANDLER is not set # CONFIG_HW_RANDOM is not set # CONFIG_R3964 is not set # CONFIG_APPLICOM is not set # CONFIG_RAW_DRIVER is not set # CONFIG_TCG_TPM is not set CONFIG_DEVPORT=y # CONFIG_TI81XX_PCIE_BOOTDRV is not set # CONFIG_RAMOOPS is not set CONFIG_I2C=y CONFIG_I2C_BOARDINFO=y CONFIG_I2C_COMPAT=y CONFIG_I2C_CHARDEV=y # CONFIG_I2C_MUX is not set CONFIG_I2C_HELPER_AUTO=y # # I2C Hardware Bus support # # # PC SMBus host controller drivers # # CONFIG_I2C_ALI1535 is not set # CONFIG_I2C_ALI1563 is not set # CONFIG_I2C_ALI15X3 is not set # CONFIG_I2C_AMD756 is not set # CONFIG_I2C_AMD8111 is not set # CONFIG_I2C_I801 is not set # CONFIG_I2C_ISCH is not set # CONFIG_I2C_PIIX4 is not set # CONFIG_I2C_NFORCE2 is not set # CONFIG_I2C_SIS5595 is not set # CONFIG_I2C_SIS630 is not set # CONFIG_I2C_SIS96X is not set # CONFIG_I2C_VIA is not set # CONFIG_I2C_VIAPRO is not set # # I2C system bus drivers (mostly embedded / system-on-chip) # # CONFIG_I2C_DESIGNWARE is not set # CONFIG_I2C_GPIO is not set # CONFIG_I2C_INTEL_MID is not set # CONFIG_I2C_OCORES is not set CONFIG_I2C_OMAP=y # CONFIG_I2C_PCA_PLATFORM is not set # CONFIG_I2C_SIMTEC is not set # CONFIG_I2C_XILINX is not set # # External I2C/SMBus adapter drivers # # CONFIG_I2C_PARPORT_LIGHT is not set # CONFIG_I2C_TAOS_EVM is not set # CONFIG_I2C_TINY_USB is not set # # Other I2C/SMBus bus drivers # # CONFIG_I2C_STUB is not set # CONFIG_I2C_DEBUG_CORE is not set # CONFIG_I2C_DEBUG_ALGO is not set # CONFIG_I2C_DEBUG_BUS is not set # CONFIG_SPI is not set # # PPS support # # CONFIG_PPS is not set # # PTP clock support # # # Enable Device Drivers -> PPS to see the PTP clock options. # CONFIG_ARCH_REQUIRE_GPIOLIB=y CONFIG_GPIOLIB=y # CONFIG_DEBUG_GPIO is not set CONFIG_GPIO_SYSFS=y # # Memory mapped GPIO expanders: # # CONFIG_GPIO_BASIC_MMIO is not set # CONFIG_GPIO_IT8761E is not set # CONFIG_GPIO_SCH is not set # CONFIG_GPIO_VX855 is not set # # I2C GPIO expanders: # # CONFIG_GPIO_MAX7300 is not set # CONFIG_GPIO_MAX732X is not set # CONFIG_GPIO_PCA953X is not set # CONFIG_GPIO_PCF857X is not set # CONFIG_GPIO_SX150X is not set # CONFIG_GPIO_ADP5588 is not set # # PCI GPIO expanders: # # CONFIG_GPIO_CS5535 is not set # CONFIG_GPIO_BT8XX is not set # CONFIG_GPIO_LANGWELL is not set # CONFIG_GPIO_PCH is not set # CONFIG_GPIO_RDC321X is not set # # SPI GPIO expanders: # # # AC97 GPIO expanders: # # # MODULbus GPIO expanders: # # CONFIG_W1 is not set # CONFIG_POWER_SUPPLY is not set # CONFIG_HWMON is not set # CONFIG_THERMAL is not set CONFIG_WATCHDOG=y # CONFIG_WATCHDOG_NOWAYOUT is not set # # Watchdog Device Drivers # # CONFIG_SOFT_WATCHDOG is not set CONFIG_OMAP_WATCHDOG=y # CONFIG_MAX63XX_WATCHDOG is not set # CONFIG_ALIM7101_WDT is not set # # PCI-based Watchdog Cards # # CONFIG_PCIPCWATCHDOG is not set # CONFIG_WDTPCI is not set # # USB-based Watchdog Cards # # CONFIG_USBPCWATCHDOG is not set CONFIG_SSB_POSSIBLE=y # # Sonics Silicon Backplane # CONFIG_SSB=m CONFIG_SSB_SPROM=y CONFIG_SSB_PCIHOST_POSSIBLE=y CONFIG_SSB_PCIHOST=y # CONFIG_SSB_B43_PCI_BRIDGE is not set CONFIG_SSB_SDIOHOST_POSSIBLE=y # CONFIG_SSB_SDIOHOST is not set # CONFIG_SSB_SILENT is not set # CONFIG_SSB_DEBUG is not set CONFIG_SSB_DRIVER_PCICORE_POSSIBLE=y # CONFIG_SSB_DRIVER_PCICORE is not set CONFIG_MFD_SUPPORT=y # CONFIG_MFD_CORE is not set # CONFIG_MFD_88PM860X is not set # CONFIG_MFD_SM501 is not set # CONFIG_MFD_ASIC3 is not set # CONFIG_HTC_EGPIO is not set # CONFIG_HTC_PASIC3 is not set # CONFIG_HTC_I2CPLD is not set # CONFIG_TPS65010 is not set # CONFIG_TPS6507X is not set # CONFIG_MFD_STMPE is not set # CONFIG_MFD_TC35892 is not set # CONFIG_MFD_TMIO is not set # CONFIG_MFD_T7L66XB is not set # CONFIG_MFD_TC6387XB is not set # CONFIG_MFD_TC6393XB is not set # CONFIG_PMIC_DA903X is not set # CONFIG_PMIC_ADP5520 is not set # CONFIG_MFD_MAX8925 is not set # CONFIG_MFD_MAX8998 is not set # CONFIG_MFD_WM8400 is not set # CONFIG_MFD_WM831X_I2C is not set # CONFIG_MFD_WM8350_I2C is not set # CONFIG_MFD_WM8994 is not set # CONFIG_MFD_PCF50633 is not set # CONFIG_ABX500_CORE is not set # CONFIG_MFD_TIMBERDALE is not set # CONFIG_LPC_SCH is not set # CONFIG_MFD_RDC321X is not set # CONFIG_MFD_JANZ_CMODIO is not set # CONFIG_MFD_TPS6586X is not set # CONFIG_MFD_VX855 is not set CONFIG_REGULATOR=y # CONFIG_REGULATOR_DEBUG is not set # CONFIG_REGULATOR_DUMMY is not set # CONFIG_REGULATOR_FIXED_VOLTAGE is not set # CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set # CONFIG_REGULATOR_USERSPACE_CONSUMER is not set # CONFIG_REGULATOR_BQ24022 is not set # CONFIG_REGULATOR_MAX1586 is not set # CONFIG_REGULATOR_MAX8649 is not set # CONFIG_REGULATOR_MAX8660 is not set # CONFIG_REGULATOR_MAX8952 is not set # CONFIG_REGULATOR_LP3971 is not set # CONFIG_REGULATOR_LP3972 is not set # CONFIG_REGULATOR_TPS65023 is not set # CONFIG_REGULATOR_TPS40400 is not set # CONFIG_REGULATOR_GPIO is not set # CONFIG_REGULATOR_TPS6507X is not set # CONFIG_REGULATOR_ISL6271A is not set # CONFIG_REGULATOR_AD5398 is not set CONFIG_MEDIA_SUPPORT=y # # Multimedia core support # # CONFIG_MEDIA_CONTROLLER is not set CONFIG_VIDEO_DEV=y CONFIG_VIDEO_V4L2_COMMON=y CONFIG_VIDEO_ALLOW_V4L1=y CONFIG_VIDEO_V4L1_COMPAT=y # CONFIG_DVB_CORE is not set CONFIG_VIDEO_MEDIA=y # # Multimedia drivers # # CONFIG_IR_CORE is not set # CONFIG_MEDIA_ATTACH is not set CONFIG_MEDIA_TUNER=y # CONFIG_MEDIA_TUNER_CUSTOMISE is not set CONFIG_MEDIA_TUNER_SIMPLE=y CONFIG_MEDIA_TUNER_TDA8290=y CONFIG_MEDIA_TUNER_TDA827X=y CONFIG_MEDIA_TUNER_TDA18271=y CONFIG_MEDIA_TUNER_TDA9887=y CONFIG_MEDIA_TUNER_TEA5761=y CONFIG_MEDIA_TUNER_TEA5767=y CONFIG_MEDIA_TUNER_MT20XX=y CONFIG_MEDIA_TUNER_XC2028=y CONFIG_MEDIA_TUNER_XC5000=y CONFIG_MEDIA_TUNER_MC44S803=y CONFIG_VIDEO_V4L2=y CONFIG_VIDEO_V4L1=y CONFIG_VIDEOBUF_GEN=y CONFIG_VIDEOBUF_DMA_SG=y CONFIG_VIDEOBUF_DMA_CONTIG=y CONFIG_VIDEO_CAPTURE_DRIVERS=y # CONFIG_VIDEO_ADV_DEBUG is not set # CONFIG_VIDEO_FIXED_MINOR_RANGES is not set # CONFIG_VIDEO_HELPER_CHIPS_AUTO is not set # # Encoders/decoders and other helper chips # # # Audio decoders # # CONFIG_VIDEO_TVAUDIO is not set # CONFIG_VIDEO_TDA7432 is not set # CONFIG_VIDEO_TDA9840 is not set # CONFIG_VIDEO_TDA9875 is not set # CONFIG_VIDEO_TEA6415C is not set # CONFIG_VIDEO_TEA6420 is not set # CONFIG_VIDEO_MSP3400 is not set # CONFIG_VIDEO_CS5345 is not set # CONFIG_VIDEO_CS53L32A is not set # CONFIG_VIDEO_M52790 is not set # CONFIG_VIDEO_TLV320AIC23B is not set # CONFIG_VIDEO_WM8775 is not set # CONFIG_VIDEO_WM8739 is not set # CONFIG_VIDEO_VP27SMPX is not set # # RDS decoders # # CONFIG_VIDEO_SAA6588 is not set # # Video decoders # # CONFIG_VIDEO_ADV7180 is not set # CONFIG_VIDEO_BT819 is not set # CONFIG_VIDEO_BT856 is not set # CONFIG_VIDEO_BT866 is not set # CONFIG_VIDEO_KS0127 is not set # CONFIG_VIDEO_OV7670 is not set # CONFIG_VIDEO_MT9T001 is not set # CONFIG_VIDEO_MT9V011 is not set # CONFIG_VIDEO_MT9V113 is not set # CONFIG_VIDEO_MT9T111 is not set # CONFIG_VIDEO_TCM825X is not set # CONFIG_VIDEO_SAA7110 is not set # CONFIG_VIDEO_SAA711X is not set # CONFIG_VIDEO_SAA717X is not set # CONFIG_VIDEO_SAA7191 is not set # CONFIG_VIDEO_TVP514X is not set # CONFIG_VIDEO_TVP5150 is not set CONFIG_VIDEO_TVP7002=m # CONFIG_VIDEO_VPX3220 is not set # # Video and audio decoders # # CONFIG_VIDEO_CX25840 is not set # # MPEG video encoders # # CONFIG_VIDEO_CX2341X is not set # # Video encoders # # CONFIG_VIDEO_SAA7127 is not set # CONFIG_VIDEO_SAA7185 is not set # CONFIG_VIDEO_ADV7170 is not set # CONFIG_VIDEO_ADV7175 is not set # CONFIG_VIDEO_THS7303 is not set # CONFIG_VIDEO_ADV7343 is not set # CONFIG_VIDEO_AK881X is not set # # Video improvement chips # # CONFIG_VIDEO_UPD64031A is not set # CONFIG_VIDEO_UPD64083 is not set CONFIG_VIDEO_TI81XX_VIDOUT=m CONFIG_VIDEO_TI81XX_VIDIN=m # CONFIG_VIDEO_CPIA2 is not set # CONFIG_VIDEO_SAA7134 is not set # CONFIG_VIDEO_MXB is not set # CONFIG_VIDEO_HEXIUM_ORION is not set # CONFIG_VIDEO_HEXIUM_GEMINI is not set # CONFIG_VIDEO_CAFE_CCIC is not set # CONFIG_VIDEO_SR030PC30 is not set # CONFIG_SOC_CAMERA is not set CONFIG_V4L_USB_DRIVERS=y CONFIG_USB_VIDEO_CLASS=y CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y # CONFIG_USB_GSPCA is not set # CONFIG_VIDEO_PVRUSB2 is not set # CONFIG_VIDEO_HDPVR is not set # CONFIG_VIDEO_USBVISION is not set # CONFIG_USB_VICAM is not set # CONFIG_USB_IBMCAM is not set # CONFIG_USB_KONICAWC is not set # CONFIG_USB_ET61X251 is not set # CONFIG_USB_SE401 is not set # CONFIG_USB_SN9C102 is not set # CONFIG_USB_PWC is not set # CONFIG_USB_ZR364XX is not set # CONFIG_USB_STKWEBCAM is not set # CONFIG_USB_S2255 is not set # CONFIG_V4L_MEM2MEM_DRIVERS is not set # CONFIG_RADIO_ADAPTERS is not set # CONFIG_DAB is not set CONFIG_HAVE_TI_TILER=y # CONFIG_TI_TILER is not set # # Graphics support # CONFIG_VGA_ARB=y CONFIG_VGA_ARB_MAX_GPUS=16 # CONFIG_DRM is not set # CONFIG_STUB_POULSBO is not set # CONFIG_VGASTATE is not set # CONFIG_VIDEO_OUTPUT_CONTROL is not set CONFIG_FB=y # CONFIG_FIRMWARE_EDID is not set # CONFIG_FB_DDC is not set # CONFIG_FB_BOOT_VESA_SUPPORT is not set CONFIG_FB_CFB_FILLRECT=y CONFIG_FB_CFB_COPYAREA=y CONFIG_FB_CFB_IMAGEBLIT=y # CONFIG_FB_CFB_REV_PIXELS_IN_BYTE is not set # CONFIG_FB_SYS_FILLRECT is not set # CONFIG_FB_SYS_COPYAREA is not set # CONFIG_FB_SYS_IMAGEBLIT is not set # CONFIG_FB_FOREIGN_ENDIAN is not set # CONFIG_FB_SYS_FOPS is not set # CONFIG_FB_SVGALIB is not set # CONFIG_FB_MACMODES is not set # CONFIG_FB_BACKLIGHT is not set # CONFIG_FB_MODE_HELPERS is not set # CONFIG_FB_TILEBLITTING is not set # # Frame buffer hardware drivers # # CONFIG_FB_CIRRUS is not set # CONFIG_FB_PM2 is not set # CONFIG_FB_CYBER2000 is not set # CONFIG_FB_ASILIANT is not set # CONFIG_FB_IMSTT is not set # CONFIG_FB_S1D13XXX is not set # CONFIG_FB_NVIDIA is not set # CONFIG_FB_RIVA is not set # CONFIG_FB_MATROX is not set # CONFIG_FB_RADEON is not set # CONFIG_FB_ATY128 is not set # CONFIG_FB_ATY is not set # CONFIG_FB_S3 is not set # CONFIG_FB_SAVAGE is not set # CONFIG_FB_SIS is not set # CONFIG_FB_NEOMAGIC is not set # CONFIG_FB_KYRO is not set # CONFIG_FB_3DFX is not set # CONFIG_FB_VOODOO1 is not set # CONFIG_FB_VT8623 is not set # CONFIG_FB_TRIDENT is not set # CONFIG_FB_ARK is not set # CONFIG_FB_PM3 is not set # CONFIG_FB_CARMINE is not set # CONFIG_FB_VIRTUAL is not set # CONFIG_FB_METRONOME is not set # CONFIG_FB_MB862XX is not set # CONFIG_FB_BROADSHEET is not set CONFIG_TI81XX_VPSS=m CONFIG_TI81XX_VPSS_VRAM_SIZE=50 CONFIG_TI81XX_VPSS_DEBUG_SUPPORT=y CONFIG_FB_TI81XX=m CONFIG_FB_TI81XX_DEBUG_SUPPORT=y CONFIG_FB_TI81XX_NUM_FBS=3 CONFIG_TI81XX_HDMI=m # CONFIG_SII9022a is not set # CONFIG_BACKLIGHT_LCD_SUPPORT is not set # # Display device support # # CONFIG_DISPLAY_SUPPORT is not set # # Console display driver support # CONFIG_DUMMY_CONSOLE=y # CONFIG_FRAMEBUFFER_CONSOLE is not set # CONFIG_LOGO is not set CONFIG_SOUND=y # CONFIG_SOUND_OSS_CORE is not set CONFIG_SND=y CONFIG_SND_TIMER=y CONFIG_SND_PCM=y CONFIG_SND_HWDEP=y CONFIG_SND_RAWMIDI=y CONFIG_SND_JACK=y # CONFIG_SND_SEQUENCER is not set # CONFIG_SND_MIXER_OSS is not set # CONFIG_SND_PCM_OSS is not set # CONFIG_SND_HRTIMER is not set # CONFIG_SND_DYNAMIC_MINORS is not set CONFIG_SND_SUPPORT_OLD_API=y CONFIG_SND_VERBOSE_PROCFS=y # CONFIG_SND_VERBOSE_PRINTK is not set # CONFIG_SND_DEBUG is not set # CONFIG_SND_RAWMIDI_SEQ is not set # CONFIG_SND_OPL3_LIB_SEQ is not set # CONFIG_SND_OPL4_LIB_SEQ is not set # CONFIG_SND_SBAWE_SEQ is not set # CONFIG_SND_EMU10K1_SEQ is not set # CONFIG_SND_DRIVERS is not set CONFIG_SND_PCI=y # CONFIG_SND_AD1889 is not set # CONFIG_SND_ALS300 is not set # CONFIG_SND_ALI5451 is not set # CONFIG_SND_ATIIXP is not set # CONFIG_SND_ATIIXP_MODEM is not set # CONFIG_SND_AU8810 is not set # CONFIG_SND_AU8820 is not set # CONFIG_SND_AU8830 is not set # CONFIG_SND_AW2 is not set # CONFIG_SND_AZT3328 is not set # CONFIG_SND_BT87X is not set # CONFIG_SND_CA0106 is not set # CONFIG_SND_CMIPCI is not set # CONFIG_SND_OXYGEN is not set # CONFIG_SND_CS4281 is not set # CONFIG_SND_CS46XX is not set # CONFIG_SND_CS5535AUDIO is not set # CONFIG_SND_CTXFI is not set # CONFIG_SND_DARLA20 is not set # CONFIG_SND_GINA20 is not set # CONFIG_SND_LAYLA20 is not set # CONFIG_SND_DARLA24 is not set # CONFIG_SND_GINA24 is not set # CONFIG_SND_LAYLA24 is not set # CONFIG_SND_MONA is not set # CONFIG_SND_MIA is not set # CONFIG_SND_ECHO3G is not set # CONFIG_SND_INDIGO is not set # CONFIG_SND_INDIGOIO is not set # CONFIG_SND_INDIGODJ is not set # CONFIG_SND_INDIGOIOX is not set # CONFIG_SND_INDIGODJX is not set # CONFIG_SND_EMU10K1 is not set # CONFIG_SND_EMU10K1X is not set # CONFIG_SND_ENS1370 is not set # CONFIG_SND_ENS1371 is not set # CONFIG_SND_ES1938 is not set # CONFIG_SND_ES1968 is not set # CONFIG_SND_FM801 is not set # CONFIG_SND_HDA_INTEL is not set # CONFIG_SND_HDSP is not set # CONFIG_SND_HDSPM is not set # CONFIG_SND_HIFIER is not set # CONFIG_SND_ICE1712 is not set # CONFIG_SND_ICE1724 is not set # CONFIG_SND_INTEL8X0 is not set # CONFIG_SND_INTEL8X0M is not set # CONFIG_SND_KORG1212 is not set # CONFIG_SND_LX6464ES is not set # CONFIG_SND_MAESTRO3 is not set # CONFIG_SND_MIXART is not set # CONFIG_SND_NM256 is not set # CONFIG_SND_PCXHR is not set # CONFIG_SND_RIPTIDE is not set # CONFIG_SND_RME32 is not set # CONFIG_SND_RME96 is not set # CONFIG_SND_RME9652 is not set # CONFIG_SND_SONICVIBES is not set # CONFIG_SND_TRIDENT is not set # CONFIG_SND_VIA82XX is not set # CONFIG_SND_VIA82XX_MODEM is not set # CONFIG_SND_VIRTUOSO is not set # CONFIG_SND_VX222 is not set # CONFIG_SND_YMFPCI is not set # CONFIG_SND_ARM is not set CONFIG_SND_USB=y CONFIG_SND_USB_AUDIO=y # CONFIG_SND_USB_UA101 is not set # CONFIG_SND_USB_CAIAQ is not set CONFIG_SND_SOC=y CONFIG_SND_TI81XX_SOC=y CONFIG_SND_DAVINCI_SOC_MCASP=y CONFIG_SND_SOC_TVP5158AUDIO=y # CONFIG_SND_TI81XX_SOC_EVM is not set CONFIG_SND_SOC_TI81XX_HDMI=y CONFIG_SND_TI81XX_SOC_DVR=y # CONFIG_SND_OMAP_SOC is not set CONFIG_SND_SOC_I2C_AND_SPI=y # CONFIG_SND_SOC_ALL_CODECS is not set CONFIG_SND_SOC_TLV320AIC3X=y CONFIG_SND_SOC_SII9022a=y # CONFIG_SOUND_PRIME is not set CONFIG_HID_SUPPORT=y CONFIG_HID=y # CONFIG_HIDRAW is not set # # USB Input Devices # CONFIG_USB_HID=y # CONFIG_HID_PID is not set # CONFIG_USB_HIDDEV is not set # # Special HID drivers # # CONFIG_HID_3M_PCT is not set # CONFIG_HID_A4TECH is not set # CONFIG_HID_ACRUX_FF is not set # CONFIG_HID_APPLE is not set # CONFIG_HID_BELKIN is not set # CONFIG_HID_CANDO is not set # CONFIG_HID_CHERRY is not set # CONFIG_HID_CHICONY is not set # CONFIG_HID_PRODIKEYS is not set # CONFIG_HID_CYPRESS is not set # CONFIG_HID_DRAGONRISE is not set # CONFIG_HID_EGALAX is not set # CONFIG_HID_EZKEY is not set # CONFIG_HID_KYE is not set # CONFIG_HID_UCLOGIC is not set # CONFIG_HID_WALTOP is not set # CONFIG_HID_GYRATION is not set # CONFIG_HID_TWINHAN is not set # CONFIG_HID_KENSINGTON is not set # CONFIG_HID_LOGITECH is not set # CONFIG_HID_MICROSOFT is not set # CONFIG_HID_MOSART is not set # CONFIG_HID_MONTEREY is not set # CONFIG_HID_NTRIG is not set # CONFIG_HID_ORTEK is not set # CONFIG_HID_PANTHERLORD is not set # CONFIG_HID_PETALYNX is not set # CONFIG_HID_PICOLCD is not set # CONFIG_HID_QUANTA is not set # CONFIG_HID_ROCCAT is not set # CONFIG_HID_ROCCAT_KONE is not set # CONFIG_HID_ROCCAT_PYRA is not set # CONFIG_HID_SAMSUNG is not set # CONFIG_HID_SONY is not set # CONFIG_HID_STANTUM is not set # CONFIG_HID_SUNPLUS is not set # CONFIG_HID_GREENASIA is not set # CONFIG_HID_SMARTJOYPLUS is not set # CONFIG_HID_TOPSEED is not set # CONFIG_HID_THRUSTMASTER is not set # CONFIG_HID_ZEROPLUS is not set # CONFIG_HID_ZYDACRON is not set CONFIG_USB_SUPPORT=y CONFIG_USB_ARCH_HAS_HCD=y CONFIG_USB_ARCH_HAS_OHCI=y CONFIG_USB_ARCH_HAS_EHCI=y CONFIG_USB=y # CONFIG_USB_DEBUG is not set CONFIG_USB_ANNOUNCE_NEW_DEVICES=y # # Miscellaneous USB options # CONFIG_USB_DEVICEFS=y CONFIG_USB_DEVICE_CLASS=y # CONFIG_USB_DYNAMIC_MINORS is not set CONFIG_USB_SUSPEND=y # CONFIG_USB_OTG is not set # CONFIG_USB_OTG_WHITELIST is not set # CONFIG_USB_OTG_BLACKLIST_HUB is not set # CONFIG_USB_MON is not set # CONFIG_USB_WUSB is not set # CONFIG_USB_WUSB_CBAF is not set # # USB Host Controller Drivers # # CONFIG_USB_C67X00_HCD is not set # CONFIG_USB_XHCI_HCD is not set # CONFIG_USB_EHCI_HCD is not set # CONFIG_USB_OXU210HP_HCD is not set # CONFIG_USB_ISP116X_HCD is not set # CONFIG_USB_ISP1760_HCD is not set # CONFIG_USB_ISP1362_HCD is not set # CONFIG_USB_OHCI_HCD is not set # CONFIG_USB_UHCI_HCD is not set # CONFIG_USB_SL811_HCD is not set # CONFIG_USB_R8A66597_HCD is not set # CONFIG_USB_WHCI_HCD is not set # CONFIG_USB_HWA_HCD is not set CONFIG_USB_MUSB_HDRC=y # # Platform Glue Layer # # CONFIG_USB_MUSB_TUSB6010_GLUE is not set # CONFIG_USB_MUSB_OMAP2PLUS_GLUE is not set # CONFIG_USB_MUSB_AM35X_GLUE is not set CONFIG_USB_MUSB_TI81XX_GLUE=y # CONFIG_USB_MUSB_DAVINCI is not set # CONFIG_USB_MUSB_DA8XX is not set # CONFIG_USB_MUSB_TUSB6010 is not set # CONFIG_USB_MUSB_OMAP2PLUS is not set # CONFIG_USB_MUSB_AM35X is not set CONFIG_USB_MUSB_TI81XX=y # CONFIG_USB_MUSB_BLACKFIN is not set # CONFIG_USB_MUSB_UX500 is not set CONFIG_USB_TI816X_USBID_CTRL_SW=y # CONFIG_USB_TI816X_USBID_CTRL_HW is not set CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_HDRC_HCD=y # CONFIG_MUSB_PIO_ONLY is not set # CONFIG_USB_INVENTRA_DMA_HW is not set # CONFIG_USB_TI_CPPI_DMA_HW is not set CONFIG_USB_TI_CPPI41_DMA_HW=y # CONFIG_USB_INVENTRA_DMA is not set # CONFIG_USB_TI_CPPI_DMA is not set CONFIG_USB_TI_CPPI41_DMA=y # CONFIG_USB_TUSB_OMAP_DMA is not set CONFIG_USB_MUSB_DEBUG=y # # USB Device Class drivers # # CONFIG_USB_ACM is not set # CONFIG_USB_PRINTER is not set # CONFIG_USB_WDM is not set # CONFIG_USB_TMC is not set # # NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may # # # also be needed; see USB_STORAGE Help for more info # CONFIG_USB_STORAGE=y # CONFIG_USB_STORAGE_DEBUG is not set # CONFIG_USB_STORAGE_DATAFAB is not set # CONFIG_USB_STORAGE_FREECOM is not set # CONFIG_USB_STORAGE_ISD200 is not set # CONFIG_USB_STORAGE_USBAT is not set # CONFIG_USB_STORAGE_SDDR09 is not set # CONFIG_USB_STORAGE_SDDR55 is not set # CONFIG_USB_STORAGE_JUMPSHOT is not set # CONFIG_USB_STORAGE_ALAUDA is not set # CONFIG_USB_STORAGE_ONETOUCH is not set # CONFIG_USB_STORAGE_KARMA is not set # CONFIG_USB_STORAGE_CYPRESS_ATACB is not set # CONFIG_USB_UAS is not set # CONFIG_USB_LIBUSUAL is not set # # USB Imaging devices # # CONFIG_USB_MDC800 is not set # CONFIG_USB_MICROTEK is not set # # USB port drivers # # CONFIG_USB_SERIAL is not set # # USB Miscellaneous drivers # # CONFIG_USB_EMI62 is not set # CONFIG_USB_EMI26 is not set # CONFIG_USB_ADUTUX is not set # CONFIG_USB_SEVSEG is not set # CONFIG_USB_RIO500 is not set # CONFIG_USB_LEGOTOWER is not set # CONFIG_USB_LCD is not set # CONFIG_USB_LED is not set # CONFIG_USB_CYPRESS_CY7C63 is not set # CONFIG_USB_CYTHERM is not set # CONFIG_USB_IDMOUSE is not set # CONFIG_USB_FTDI_ELAN is not set # CONFIG_USB_APPLEDISPLAY is not set # CONFIG_USB_SISUSBVGA is not set # CONFIG_USB_LD is not set # CONFIG_USB_TRANCEVIBRATOR is not set # CONFIG_USB_IOWARRIOR is not set # CONFIG_USB_TEST is not set # CONFIG_USB_ISIGHTFW is not set # CONFIG_USB_YUREX is not set # CONFIG_USB_GADGET is not set # # OTG and related infrastructure # CONFIG_USB_OTG_UTILS=y # CONFIG_USB_GPIO_VBUS is not set # CONFIG_USB_ULPI is not set CONFIG_NOP_USB_XCEIV=y # CONFIG_UWB is not set CONFIG_MMC=y # CONFIG_MMC_DEBUG is not set # CONFIG_MMC_UNSAFE_RESUME is not set # # MMC/SD/SDIO Card Drivers # CONFIG_MMC_BLOCK=y CONFIG_MMC_BLOCK_MINORS=8 CONFIG_MMC_BLOCK_BOUNCE=y # CONFIG_SDIO_UART is not set # CONFIG_MMC_TEST is not set # # MMC/SD/SDIO Host Controller Drivers # # CONFIG_MMC_SDHCI is not set # CONFIG_MMC_OMAP is not set CONFIG_MMC_OMAP_HS=y # CONFIG_MMC_TIFM_SD is not set # CONFIG_MMC_CB710 is not set # CONFIG_MMC_VIA_SDMMC is not set # CONFIG_MMC_USHC is not set # CONFIG_MEMSTICK is not set # CONFIG_NEW_LEDS is not set # CONFIG_ACCESSIBILITY is not set # CONFIG_INFINIBAND is not set CONFIG_RTC_LIB=y CONFIG_RTC_CLASS=y CONFIG_RTC_HCTOSYS=y CONFIG_RTC_HCTOSYS_DEVICE="rtc1" # CONFIG_RTC_DEBUG is not set # # RTC interfaces # CONFIG_RTC_INTF_SYSFS=y CONFIG_RTC_INTF_PROC=y CONFIG_RTC_INTF_DEV=y # CONFIG_RTC_INTF_DEV_UIE_EMUL is not set # CONFIG_RTC_DRV_TEST is not set # # I2C RTC drivers # # CONFIG_RTC_DRV_DS1307 is not set # CONFIG_RTC_DRV_DS1374 is not set # CONFIG_RTC_DRV_DS1672 is not set # CONFIG_RTC_DRV_DS3232 is not set # CONFIG_RTC_DRV_MAX6900 is not set # CONFIG_RTC_DRV_RS5C372 is not set # CONFIG_RTC_DRV_ISL1208 is not set # CONFIG_RTC_DRV_ISL12022 is not set # CONFIG_RTC_DRV_X1205 is not set # CONFIG_RTC_DRV_PCF8563 is not set # CONFIG_RTC_DRV_PCF8583 is not set # CONFIG_RTC_DRV_M41T80 is not set # CONFIG_RTC_DRV_BQ32K is not set CONFIG_RTC_DRV_S35390A=y # CONFIG_RTC_DRV_FM3130 is not set # CONFIG_RTC_DRV_RX8581 is not set # CONFIG_RTC_DRV_RX8025 is not set # # SPI RTC drivers # # # Platform RTC drivers # # CONFIG_RTC_DRV_CMOS is not set # CONFIG_RTC_DRV_DS1286 is not set # CONFIG_RTC_DRV_DS1511 is not set # CONFIG_RTC_DRV_DS1553 is not set # CONFIG_RTC_DRV_DS1742 is not set # CONFIG_RTC_DRV_STK17TA8 is not set # CONFIG_RTC_DRV_M48T86 is not set # CONFIG_RTC_DRV_M48T35 is not set # CONFIG_RTC_DRV_M48T59 is not set # CONFIG_RTC_DRV_MSM6242 is not set # CONFIG_RTC_DRV_BQ4802 is not set # CONFIG_RTC_DRV_RP5C01 is not set # CONFIG_RTC_DRV_V3020 is not set # # on-CPU RTC drivers # CONFIG_RTC_DRV_OMAP=y # CONFIG_DMADEVICES is not set # CONFIG_AUXDISPLAY is not set # CONFIG_UIO is not set # CONFIG_STAGING is not set CONFIG_Sys_Link=y CONFIG_SYSLINK_MULTIPROC=y CONFIG_SYSLINK_NOTIFY=y # # File systems # CONFIG_EXT2_FS=y CONFIG_EXT2_FS_XATTR=y CONFIG_EXT2_FS_POSIX_ACL=y CONFIG_EXT2_FS_SECURITY=y # CONFIG_EXT2_FS_XIP is not set CONFIG_EXT3_FS=y # CONFIG_EXT3_DEFAULTS_TO_ORDERED is not set CONFIG_EXT3_FS_XATTR=y CONFIG_EXT3_FS_POSIX_ACL=y CONFIG_EXT3_FS_SECURITY=y # CONFIG_EXT4_FS is not set CONFIG_JBD=y # CONFIG_JBD_DEBUG is not set CONFIG_FS_MBCACHE=y # CONFIG_REISERFS_FS is not set # CONFIG_JFS_FS is not set CONFIG_FS_POSIX_ACL=y # CONFIG_XFS_FS is not set # CONFIG_OCFS2_FS is not set # CONFIG_BTRFS_FS is not set # CONFIG_NILFS2_FS is not set CONFIG_FILE_LOCKING=y # CONFIG_FSNOTIFY is not set # CONFIG_DNOTIFY is not set # CONFIG_INOTIFY_USER is not set # CONFIG_FANOTIFY is not set # CONFIG_QUOTA is not set # CONFIG_QUOTACTL is not set # CONFIG_AUTOFS4_FS is not set # CONFIG_FUSE_FS is not set # # Caches # # CONFIG_FSCACHE is not set # # CD-ROM/DVD Filesystems # # CONFIG_ISO9660_FS is not set # CONFIG_UDF_FS is not set # # DOS/FAT/NT Filesystems # CONFIG_FAT_FS=y CONFIG_MSDOS_FS=y CONFIG_VFAT_FS=y CONFIG_FAT_DEFAULT_CODEPAGE=437 CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1" # CONFIG_NTFS_FS is not set # # Pseudo filesystems # CONFIG_PROC_FS=y CONFIG_PROC_SYSCTL=y CONFIG_PROC_PAGE_MONITOR=y CONFIG_SYSFS=y CONFIG_TMPFS=y # CONFIG_TMPFS_POSIX_ACL is not set # CONFIG_HUGETLB_PAGE is not set # CONFIG_CONFIGFS_FS is not set CONFIG_MISC_FILESYSTEMS=y # CONFIG_ADFS_FS is not set # CONFIG_AFFS_FS is not set # CONFIG_ECRYPT_FS is not set # CONFIG_HFS_FS is not set # CONFIG_HFSPLUS_FS is not set # CONFIG_BEFS_FS is not set # CONFIG_BFS_FS is not set # CONFIG_EFS_FS is not set CONFIG_JFFS2_FS=y CONFIG_JFFS2_FS_DEBUG=0 CONFIG_JFFS2_FS_WRITEBUFFER=y CONFIG_JFFS2_FS_WBUF_VERIFY=y # CONFIG_JFFS2_SUMMARY is not set # CONFIG_JFFS2_FS_XATTR is not set # CONFIG_JFFS2_COMPRESSION_OPTIONS is not set CONFIG_JFFS2_ZLIB=y # CONFIG_JFFS2_LZO is not set CONFIG_JFFS2_RTIME=y # CONFIG_JFFS2_RUBIN is not set CONFIG_UBIFS_FS=y # CONFIG_UBIFS_FS_XATTR is not set # CONFIG_UBIFS_FS_ADVANCED_COMPR is not set CONFIG_UBIFS_FS_LZO=y CONFIG_UBIFS_FS_ZLIB=y # CONFIG_UBIFS_FS_DEBUG is not set # CONFIG_LOGFS is not set CONFIG_CRAMFS=y # CONFIG_SQUASHFS is not set # CONFIG_VXFS_FS is not set # CONFIG_MINIX_FS is not set # CONFIG_OMFS_FS is not set # CONFIG_HPFS_FS is not set # CONFIG_QNX4FS_FS is not set # CONFIG_ROMFS_FS is not set # CONFIG_SYSV_FS is not set # CONFIG_UFS_FS is not set CONFIG_NETWORK_FILESYSTEMS=y CONFIG_NFS_FS=y CONFIG_NFS_V3=y # CONFIG_NFS_V3_ACL is not set # CONFIG_NFS_V4 is not set CONFIG_ROOT_NFS=y # CONFIG_NFSD is not set CONFIG_LOCKD=y CONFIG_LOCKD_V4=y CONFIG_NFS_COMMON=y CONFIG_SUNRPC=y # CONFIG_RPCSEC_GSS_KRB5 is not set # CONFIG_CEPH_FS is not set # CONFIG_CIFS is not set # CONFIG_NCP_FS is not set # CONFIG_CODA_FS is not set # CONFIG_AFS_FS is not set # # Partition Types # # CONFIG_PARTITION_ADVANCED is not set CONFIG_MSDOS_PARTITION=y CONFIG_NLS=y CONFIG_NLS_DEFAULT="utf8" CONFIG_NLS_CODEPAGE_437=y # CONFIG_NLS_CODEPAGE_737 is not set # CONFIG_NLS_CODEPAGE_775 is not set # CONFIG_NLS_CODEPAGE_850 is not set # CONFIG_NLS_CODEPAGE_852 is not set # CONFIG_NLS_CODEPAGE_855 is not set # CONFIG_NLS_CODEPAGE_857 is not set # CONFIG_NLS_CODEPAGE_860 is not set # CONFIG_NLS_CODEPAGE_861 is not set # CONFIG_NLS_CODEPAGE_862 is not set # CONFIG_NLS_CODEPAGE_863 is not set # CONFIG_NLS_CODEPAGE_864 is not set # CONFIG_NLS_CODEPAGE_865 is not set # CONFIG_NLS_CODEPAGE_866 is not set # CONFIG_NLS_CODEPAGE_869 is not set # CONFIG_NLS_CODEPAGE_936 is not set # CONFIG_NLS_CODEPAGE_950 is not set # CONFIG_NLS_CODEPAGE_932 is not set # CONFIG_NLS_CODEPAGE_949 is not set # CONFIG_NLS_CODEPAGE_874 is not set # CONFIG_NLS_ISO8859_8 is not set # CONFIG_NLS_CODEPAGE_1250 is not set # CONFIG_NLS_CODEPAGE_1251 is not set CONFIG_NLS_ASCII=y CONFIG_NLS_ISO8859_1=y # CONFIG_NLS_ISO8859_2 is not set # CONFIG_NLS_ISO8859_3 is not set # CONFIG_NLS_ISO8859_4 is not set # CONFIG_NLS_ISO8859_5 is not set # CONFIG_NLS_ISO8859_6 is not set # CONFIG_NLS_ISO8859_7 is not set # CONFIG_NLS_ISO8859_9 is not set # CONFIG_NLS_ISO8859_13 is not set # CONFIG_NLS_ISO8859_14 is not set # CONFIG_NLS_ISO8859_15 is not set # CONFIG_NLS_KOI8_R is not set # CONFIG_NLS_KOI8_U is not set CONFIG_NLS_UTF8=y # CONFIG_DLM is not set # # Kernel hacking # # CONFIG_PRINTK_TIME is not set CONFIG_ENABLE_WARN_DEPRECATED=y CONFIG_ENABLE_MUST_CHECK=y CONFIG_FRAME_WARN=1024 CONFIG_MAGIC_SYSRQ=y # CONFIG_STRIP_ASM_SYMS is not set # CONFIG_UNUSED_SYMBOLS is not set CONFIG_DEBUG_FS=y # CONFIG_HEADERS_CHECK is not set CONFIG_DEBUG_KERNEL=y # CONFIG_DEBUG_SHIRQ is not set # CONFIG_LOCKUP_DETECTOR is not set # CONFIG_HARDLOCKUP_DETECTOR is not set # CONFIG_DETECT_HUNG_TASK is not set # CONFIG_SCHED_DEBUG is not set # CONFIG_SCHEDSTATS is not set # CONFIG_TIMER_STATS is not set # CONFIG_DEBUG_OBJECTS is not set # CONFIG_SLUB_DEBUG_ON is not set # CONFIG_SLUB_STATS is not set # CONFIG_DEBUG_KMEMLEAK is not set # CONFIG_DEBUG_RT_MUTEXES is not set # CONFIG_RT_MUTEX_TESTER is not set # CONFIG_DEBUG_SPINLOCK is not set # CONFIG_DEBUG_MUTEXES is not set CONFIG_BKL=y # CONFIG_DEBUG_LOCK_ALLOC is not set # CONFIG_PROVE_LOCKING is not set # CONFIG_SPARSE_RCU_POINTER is not set # CONFIG_LOCK_STAT is not set # CONFIG_DEBUG_SPINLOCK_SLEEP is not set # CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set # CONFIG_DEBUG_KOBJECT is not set CONFIG_DEBUG_BUGVERBOSE=y # CONFIG_DEBUG_INFO is not set # CONFIG_DEBUG_VM is not set # CONFIG_DEBUG_WRITECOUNT is not set # CONFIG_DEBUG_MEMORY_INIT is not set # CONFIG_DEBUG_LIST is not set # CONFIG_TEST_LIST_SORT is not set # CONFIG_DEBUG_SG is not set # CONFIG_DEBUG_NOTIFIERS is not set # CONFIG_DEBUG_CREDENTIALS is not set CONFIG_FRAME_POINTER=y # CONFIG_BOOT_PRINTK_DELAY is not set # CONFIG_RCU_TORTURE_TEST is not set # CONFIG_KPROBES_SANITY_TEST is not set # CONFIG_BACKTRACE_SELF_TEST is not set # CONFIG_DEBUG_BLOCK_EXT_DEVT is not set # CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set # CONFIG_LKDTM is not set # CONFIG_FAULT_INJECTION is not set # CONFIG_LATENCYTOP is not set # CONFIG_SYSCTL_SYSCALL_CHECK is not set # CONFIG_PAGE_POISONING is not set CONFIG_HAVE_FUNCTION_TRACER=y CONFIG_HAVE_DYNAMIC_FTRACE=y CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y CONFIG_TRACING_SUPPORT=y # CONFIG_FTRACE is not set # CONFIG_DYNAMIC_DEBUG is not set # CONFIG_ATOMIC64_SELFTEST is not set # CONFIG_SAMPLES is not set CONFIG_HAVE_ARCH_KGDB=y # CONFIG_KGDB is not set # CONFIG_STRICT_DEVMEM is not set # CONFIG_ARM_UNWIND is not set # CONFIG_DEBUG_USER is not set # CONFIG_DEBUG_ERRORS is not set # CONFIG_DEBUG_STACK_USAGE is not set CONFIG_DEBUG_LL=y CONFIG_EARLY_PRINTK=y # CONFIG_DEBUG_ICEDCC is not set # CONFIG_OC_ETM is not set # # Security options # CONFIG_KEYS=y CONFIG_KEYS_DEBUG_PROC_KEYS=y # CONFIG_SECURITY_DMESG_RESTRICT is not set CONFIG_SECURITY=y # CONFIG_SECURITYFS is not set CONFIG_SECURITY_NETWORK=y # CONFIG_SECURITY_NETWORK_XFRM is not set # CONFIG_SECURITY_PATH is not set # CONFIG_SECURITY_TOMOYO is not set # CONFIG_SECURITY_APPARMOR is not set # CONFIG_IMA is not set CONFIG_DEFAULT_SECURITY_DAC=y CONFIG_DEFAULT_SECURITY="" CONFIG_CRYPTO=y # # Crypto core or helper # CONFIG_CRYPTO_ALGAPI=y CONFIG_CRYPTO_ALGAPI2=y # CONFIG_CRYPTO_MANAGER is not set # CONFIG_CRYPTO_MANAGER2 is not set # CONFIG_CRYPTO_GF128MUL is not set # CONFIG_CRYPTO_NULL is not set # CONFIG_CRYPTO_CRYPTD is not set # CONFIG_CRYPTO_AUTHENC is not set # CONFIG_CRYPTO_TEST is not set # # Authenticated Encryption with Associated Data # # CONFIG_CRYPTO_CCM is not set # CONFIG_CRYPTO_GCM is not set # CONFIG_CRYPTO_SEQIV is not set # # Block modes # # CONFIG_CRYPTO_CBC is not set # CONFIG_CRYPTO_CTR is not set # CONFIG_CRYPTO_CTS is not set # CONFIG_CRYPTO_ECB is not set # CONFIG_CRYPTO_LRW is not set # CONFIG_CRYPTO_PCBC is not set # CONFIG_CRYPTO_XTS is not set # # Hash modes # # CONFIG_CRYPTO_HMAC is not set # CONFIG_CRYPTO_XCBC is not set # CONFIG_CRYPTO_VMAC is not set # # Digest # # CONFIG_CRYPTO_CRC32C is not set # CONFIG_CRYPTO_GHASH is not set # CONFIG_CRYPTO_MD4 is not set # CONFIG_CRYPTO_MD5 is not set # CONFIG_CRYPTO_MICHAEL_MIC is not set # CONFIG_CRYPTO_RMD128 is not set # CONFIG_CRYPTO_RMD160 is not set # CONFIG_CRYPTO_RMD256 is not set # CONFIG_CRYPTO_RMD320 is not set # CONFIG_CRYPTO_SHA1 is not set # CONFIG_CRYPTO_SHA256 is not set # CONFIG_CRYPTO_SHA512 is not set # CONFIG_CRYPTO_TGR192 is not set # CONFIG_CRYPTO_WP512 is not set # # Ciphers # # CONFIG_CRYPTO_AES is not set # CONFIG_CRYPTO_ANUBIS is not set # CONFIG_CRYPTO_ARC4 is not set # CONFIG_CRYPTO_BLOWFISH is not set # CONFIG_CRYPTO_CAMELLIA is not set # CONFIG_CRYPTO_CAST5 is not set # CONFIG_CRYPTO_CAST6 is not set # CONFIG_CRYPTO_DES is not set # CONFIG_CRYPTO_FCRYPT is not set # CONFIG_CRYPTO_KHAZAD is not set # CONFIG_CRYPTO_SALSA20 is not set # CONFIG_CRYPTO_SEED is not set # CONFIG_CRYPTO_SERPENT is not set # CONFIG_CRYPTO_TEA is not set # CONFIG_CRYPTO_TWOFISH is not set # # Compression # CONFIG_CRYPTO_DEFLATE=y # CONFIG_CRYPTO_ZLIB is not set CONFIG_CRYPTO_LZO=y # # Random Number Generation # # CONFIG_CRYPTO_ANSI_CPRNG is not set # CONFIG_CRYPTO_HW is not set # CONFIG_BINARY_PRINTF is not set # # Library routines # CONFIG_BITREVERSE=y CONFIG_GENERIC_FIND_LAST_BIT=y # CONFIG_CRC_CCITT is not set CONFIG_CRC16=y # CONFIG_CRC_T10DIF is not set # CONFIG_CRC_ITU_T is not set CONFIG_CRC32=y # CONFIG_CRC7 is not set # CONFIG_LIBCRC32C is not set CONFIG_ZLIB_INFLATE=y CONFIG_ZLIB_DEFLATE=y CONFIG_LZO_COMPRESS=y CONFIG_LZO_DECOMPRESS=y CONFIG_DECOMPRESS_GZIP=y CONFIG_HAS_IOMEM=y CONFIG_HAS_IOPORT=y CONFIG_HAS_DMA=y CONFIG_NLATTR=y
# # Automatically generated make config: don't edit # Linux/arm 2.6.37 Kernel Configuration # Mon Jun 11 16:46:48 2012 # CONFIG_ARM=y CONFIG_SYS_SUPPORTS_APM_EMULATION=y CONFIG_GENERIC_GPIO=y # CONFIG_ARCH_USES_GETTIMEOFFSET is not set CONFIG_GENERIC_CLOCKEVENTS=y CONFIG_HAVE_PROC_CPU=y CONFIG_GENERIC_HARDIRQS=y CONFIG_STACKTRACE_SUPPORT=y CONFIG_HAVE_LATENCYTOP_SUPPORT=y CONFIG_LOCKDEP_SUPPORT=y CONFIG_TRACE_IRQFLAGS_SUPPORT=y CONFIG_HARDIRQS_SW_RESEND=y CONFIG_GENERIC_IRQ_PROBE=y CONFIG_RWSEM_GENERIC_SPINLOCK=y CONFIG_ARCH_HAS_CPUFREQ=y CONFIG_ARCH_HAS_CPU_IDLE_WAIT=y CONFIG_GENERIC_HWEIGHT=y CONFIG_GENERIC_CALIBRATE_DELAY=y CONFIG_NEED_DMA_MAP_STATE=y CONFIG_GENERIC_HARDIRQS_NO__DO_IRQ=y CONFIG_ARM_L1_CACHE_SHIFT_6=y CONFIG_VECTORS_BASE=0xffff0000 # CONFIG_ARM_PATCH_PHYS_VIRT is not set CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config" CONFIG_CONSTRUCTORS=y CONFIG_HAVE_IRQ_WORK=y # # General setup # CONFIG_EXPERIMENTAL=y CONFIG_BROKEN_ON_SMP=y CONFIG_INIT_ENV_ARG_LIMIT=32 CONFIG_CROSS_COMPILE="" CONFIG_LOCALVERSION="" # CONFIG_LOCALVERSION_AUTO is not set CONFIG_HAVE_KERNEL_GZIP=y CONFIG_HAVE_KERNEL_LZMA=y CONFIG_HAVE_KERNEL_LZO=y CONFIG_KERNEL_GZIP=y # CONFIG_KERNEL_LZMA is not set # CONFIG_KERNEL_LZO is not set # CONFIG_SWAP is not set CONFIG_SYSVIPC=y CONFIG_SYSVIPC_SYSCTL=y CONFIG_POSIX_MQUEUE=y CONFIG_POSIX_MQUEUE_SYSCTL=y CONFIG_BSD_PROCESS_ACCT=y # CONFIG_BSD_PROCESS_ACCT_V3 is not set # CONFIG_TASKSTATS is not set # CONFIG_AUDIT is not set # CONFIG_HAVE_GENERIC_HARDIRQS is not set # CONFIG_SPARSE_IRQ is not set # # RCU Subsystem # CONFIG_TINY_RCU=y # CONFIG_PREEMPT_RCU is not set # CONFIG_TREE_RCU_TRACE is not set CONFIG_IKCONFIG=y CONFIG_IKCONFIG_PROC=y CONFIG_LOG_BUF_SHIFT=17 # CONFIG_CGROUPS is not set CONFIG_NAMESPACES=y # CONFIG_UTS_NS is not set # CONFIG_IPC_NS is not set # CONFIG_USER_NS is not set # CONFIG_PID_NS is not set # CONFIG_NET_NS is not set # CONFIG_SYSFS_DEPRECATED is not set # CONFIG_RELAY is not set CONFIG_BLK_DEV_INITRD=y CONFIG_INITRAMFS_SOURCE="" CONFIG_RD_GZIP=y CONFIG_RD_BZIP2=y CONFIG_RD_LZMA=y CONFIG_RD_LZO=y CONFIG_CC_OPTIMIZE_FOR_SIZE=y CONFIG_SYSCTL=y CONFIG_ANON_INODES=y # CONFIG_EMBEDDED is not set CONFIG_UID16=y CONFIG_SYSCTL_SYSCALL=y CONFIG_KALLSYMS=y # CONFIG_KALLSYMS_ALL is not set CONFIG_KALLSYMS_EXTRA_PASS=y CONFIG_HOTPLUG=y CONFIG_PRINTK=y CONFIG_BUG=y CONFIG_ELF_CORE=y CONFIG_BASE_FULL=y CONFIG_FUTEX=y CONFIG_EPOLL=y CONFIG_SIGNALFD=y CONFIG_TIMERFD=y CONFIG_EVENTFD=y CONFIG_SHMEM=y CONFIG_AIO=y CONFIG_HAVE_PERF_EVENTS=y CONFIG_PERF_USE_VMALLOC=y # # Kernel Performance Events And Counters # # CONFIG_PERF_EVENTS is not set # CONFIG_PERF_COUNTERS is not set CONFIG_VM_EVENT_COUNTERS=y CONFIG_PCI_QUIRKS=y CONFIG_SLUB_DEBUG=y CONFIG_COMPAT_BRK=y # CONFIG_SLAB is not set CONFIG_SLUB=y # CONFIG_PROFILING is not set CONFIG_HAVE_OPROFILE=y CONFIG_KPROBES=y CONFIG_KRETPROBES=y CONFIG_HAVE_KPROBES=y CONFIG_HAVE_KRETPROBES=y CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y CONFIG_HAVE_CLK=y # # GCOV-based kernel profiling # # CONFIG_GCOV_KERNEL is not set CONFIG_HAVE_GENERIC_DMA_COHERENT=y CONFIG_SLABINFO=y CONFIG_RT_MUTEXES=y CONFIG_BASE_SMALL=0 CONFIG_MODULES=y # CONFIG_MODULE_FORCE_LOAD is not set CONFIG_MODULE_UNLOAD=y # CONFIG_MODULE_FORCE_UNLOAD is not set CONFIG_MODVERSIONS=y # CONFIG_MODULE_SRCVERSION_ALL is not set CONFIG_BLOCK=y # CONFIG_LBDAF is not set # CONFIG_BLK_DEV_BSG is not set # CONFIG_BLK_DEV_INTEGRITY is not set # # IO Schedulers # CONFIG_IOSCHED_NOOP=y CONFIG_IOSCHED_DEADLINE=y CONFIG_IOSCHED_CFQ=y # CONFIG_DEFAULT_DEADLINE is not set CONFIG_DEFAULT_CFQ=y # CONFIG_DEFAULT_NOOP is not set CONFIG_DEFAULT_IOSCHED="cfq" # CONFIG_INLINE_SPIN_TRYLOCK is not set # CONFIG_INLINE_SPIN_TRYLOCK_BH is not set # CONFIG_INLINE_SPIN_LOCK is not set # CONFIG_INLINE_SPIN_LOCK_BH is not set # CONFIG_INLINE_SPIN_LOCK_IRQ is not set # CONFIG_INLINE_SPIN_LOCK_IRQSAVE is not set CONFIG_INLINE_SPIN_UNLOCK=y # CONFIG_INLINE_SPIN_UNLOCK_BH is not set CONFIG_INLINE_SPIN_UNLOCK_IRQ=y # CONFIG_INLINE_SPIN_UNLOCK_IRQRESTORE is not set # CONFIG_INLINE_READ_TRYLOCK is not set # CONFIG_INLINE_READ_LOCK is not set # CONFIG_INLINE_READ_LOCK_BH is not set # CONFIG_INLINE_READ_LOCK_IRQ is not set # CONFIG_INLINE_READ_LOCK_IRQSAVE is not set CONFIG_INLINE_READ_UNLOCK=y # CONFIG_INLINE_READ_UNLOCK_BH is not set CONFIG_INLINE_READ_UNLOCK_IRQ=y # CONFIG_INLINE_READ_UNLOCK_IRQRESTORE is not set # CONFIG_INLINE_WRITE_TRYLOCK is not set # CONFIG_INLINE_WRITE_LOCK is not set # CONFIG_INLINE_WRITE_LOCK_BH is not set # CONFIG_INLINE_WRITE_LOCK_IRQ is not set # CONFIG_INLINE_WRITE_LOCK_IRQSAVE is not set CONFIG_INLINE_WRITE_UNLOCK=y # CONFIG_INLINE_WRITE_UNLOCK_BH is not set CONFIG_INLINE_WRITE_UNLOCK_IRQ=y # CONFIG_INLINE_WRITE_UNLOCK_IRQRESTORE is not set # CONFIG_MUTEX_SPIN_ON_OWNER is not set # CONFIG_FREEZER is not set # # System Type # CONFIG_MMU=y # CONFIG_ARCH_AAEC2000 is not set # CONFIG_ARCH_INTEGRATOR is not set # CONFIG_ARCH_REALVIEW is not set # CONFIG_ARCH_VERSATILE is not set # CONFIG_ARCH_VEXPRESS is not set # CONFIG_ARCH_AT91 is not set # CONFIG_ARCH_BCMRING is not set # CONFIG_ARCH_CLPS711X is not set # CONFIG_ARCH_CNS3XXX is not set # CONFIG_ARCH_GEMINI is not set # CONFIG_ARCH_EBSA110 is not set # CONFIG_ARCH_EP93XX is not set # CONFIG_ARCH_FOOTBRIDGE is not set # CONFIG_ARCH_MXC is not set # CONFIG_ARCH_STMP3XXX is not set # CONFIG_ARCH_NETX is not set # CONFIG_ARCH_H720X is not set # CONFIG_ARCH_IOP13XX is not set # CONFIG_ARCH_IOP32X is not set # CONFIG_ARCH_IOP33X is not set # CONFIG_ARCH_IXP23XX is not set # CONFIG_ARCH_IXP2000 is not set # CONFIG_ARCH_IXP4XX is not set # CONFIG_ARCH_DOVE is not set # CONFIG_ARCH_KIRKWOOD is not set # CONFIG_ARCH_LOKI is not set # CONFIG_ARCH_LPC32XX is not set # CONFIG_ARCH_MV78XX0 is not set # CONFIG_ARCH_ORION5X is not set # CONFIG_ARCH_MMP is not set # CONFIG_ARCH_KS8695 is not set # CONFIG_ARCH_NS9XXX is not set # CONFIG_ARCH_W90X900 is not set # CONFIG_ARCH_NUC93X is not set # CONFIG_ARCH_TEGRA is not set # CONFIG_ARCH_PNX4008 is not set # CONFIG_ARCH_PXA is not set # CONFIG_ARCH_MSM is not set # CONFIG_ARCH_SHMOBILE is not set # CONFIG_ARCH_RPC is not set # CONFIG_ARCH_SA1100 is not set # CONFIG_ARCH_S3C2410 is not set # CONFIG_ARCH_S3C64XX is not set # CONFIG_ARCH_S5P64X0 is not set # CONFIG_ARCH_S5P6442 is not set # CONFIG_ARCH_S5PC100 is not set # CONFIG_ARCH_S5PV210 is not set # CONFIG_ARCH_S5PV310 is not set # CONFIG_ARCH_SHARK is not set # CONFIG_ARCH_TCC_926 is not set # CONFIG_ARCH_LH7A40X is not set # CONFIG_ARCH_U300 is not set # CONFIG_ARCH_U8500 is not set # CONFIG_ARCH_NOMADIK is not set # CONFIG_ARCH_DAVINCI is not set CONFIG_ARCH_OMAP=y # CONFIG_PLAT_SPEAR is not set # # TI OMAP Common Features # # CONFIG_ARCH_OMAP1 is not set CONFIG_ARCH_OMAP2PLUS=y # # OMAP Feature Selections # # CONFIG_OMAP_RESET_CLOCKS is not set CONFIG_TI816X_SMARTREFLEX=y CONFIG_OMAP_MUX=y # CONFIG_OMAP_MUX_DEBUG is not set CONFIG_OMAP_MUX_WARNINGS=y # CONFIG_OMAP_MCBSP is not set CONFIG_OMAP_MBOX_FWK=y CONFIG_OMAP_MBOX_KFIFO_SIZE=256 CONFIG_OMAP_IOMMU=y # CONFIG_OMAP_IOMMU_DEBUG is not set CONFIG_OMAP_MPU_TIMER=y # CONFIG_OMAP_32K_TIMER is not set CONFIG_OMAP_DM_TIMER=y # CONFIG_OMAP_PM_NONE is not set CONFIG_OMAP_PM_NOOP=y # # TI OMAP2/3/4 Specific Features # CONFIG_ARCH_OMAP2PLUS_TYPICAL=y # CONFIG_ARCH_OMAP2 is not set # CONFIG_ARCH_OMAP3 is not set # CONFIG_ARCH_OMAP4 is not set CONFIG_ARCH_TI81XX=y CONFIG_ARCH_TI816X=y # CONFIG_ARCH_TI814X is not set # # OMAP Board Type # # # TI81XX Board Type # # CONFIG_MACH_TI8168EVM is not set CONFIG_MACH_TI8168_DVR=y # # Processor Type # CONFIG_CPU_32v6K=y CONFIG_CPU_V7=y CONFIG_CPU_32v7=y CONFIG_CPU_ABRT_EV7=y CONFIG_CPU_PABRT_V7=y CONFIG_CPU_CACHE_V7=y CONFIG_CPU_CACHE_VIPT=y CONFIG_CPU_COPY_V6=y CONFIG_CPU_TLB_V7=y CONFIG_CPU_HAS_ASID=y CONFIG_CPU_CP15=y CONFIG_CPU_CP15_MMU=y # # Processor Features # CONFIG_ARM_THUMB=y # CONFIG_ARM_THUMBEE is not set # CONFIG_CPU_ICACHE_DISABLE is not set # CONFIG_CPU_DCACHE_DISABLE is not set # CONFIG_CPU_BPREDICT_DISABLE is not set CONFIG_ARM_L1_CACHE_SHIFT=6 CONFIG_ARM_DMA_MEM_BUFFERABLE=y CONFIG_CPU_HAS_PMU=y # CONFIG_ARM_ERRATA_430973 is not set # CONFIG_ARM_ERRATA_458693 is not set # CONFIG_ARM_ERRATA_460075 is not set # CONFIG_ARM_ERRATA_743622 is not set CONFIG_COMMON_CLKDEV=y # # Bus support # CONFIG_PCI=y CONFIG_PCI_SYSCALL=y CONFIG_ARCH_SUPPORTS_MSI=y CONFIG_PCI_MSI=y # CONFIG_PCI_DEBUG is not set # CONFIG_PCI_STUB is not set # CONFIG_PCI_IOV is not set # CONFIG_PCCARD is not set # # Kernel Features # CONFIG_TICK_ONESHOT=y CONFIG_NO_HZ=y CONFIG_HIGH_RES_TIMERS=y CONFIG_GENERIC_CLOCKEVENTS_BUILD=y # CONFIG_VMSPLIT_3G is not set CONFIG_VMSPLIT_2G=y # CONFIG_VMSPLIT_1G is not set CONFIG_PAGE_OFFSET=0x80000000 CONFIG_PREEMPT_NONE=y # CONFIG_PREEMPT_VOLUNTARY is not set # CONFIG_PREEMPT is not set CONFIG_HZ=100 # CONFIG_THUMB2_KERNEL is not set CONFIG_AEABI=y CONFIG_OABI_COMPAT=y CONFIG_ARCH_HAS_HOLES_MEMORYMODEL=y # CONFIG_ARCH_SPARSEMEM_DEFAULT is not set # CONFIG_ARCH_SELECT_MEMORY_MODEL is not set CONFIG_HIGHMEM=y # CONFIG_HIGHPTE is not set CONFIG_SELECT_MEMORY_MODEL=y CONFIG_FLATMEM_MANUAL=y CONFIG_FLATMEM=y CONFIG_FLAT_NODE_MEM_MAP=y CONFIG_HAVE_MEMBLOCK=y CONFIG_PAGEFLAGS_EXTENDED=y CONFIG_SPLIT_PTLOCK_CPUS=4 # CONFIG_PHYS_ADDR_T_64BIT is not set CONFIG_ZONE_DMA_FLAG=0 CONFIG_BOUNCE=y CONFIG_VIRT_TO_BUS=y # CONFIG_KSM is not set CONFIG_DEFAULT_MMAP_MIN_ADDR=4096 CONFIG_NEED_PER_CPU_KM=y CONFIG_FORCE_MAX_ZONEORDER=11 # CONFIG_LEDS is not set CONFIG_ALIGNMENT_TRAP=y # CONFIG_UACCESS_WITH_MEMCPY is not set # CONFIG_SECCOMP is not set # CONFIG_CC_STACKPROTECTOR is not set # CONFIG_DEPRECATED_PARAM_STRUCT is not set # # Boot options # CONFIG_ZBOOT_ROM_TEXT=0 CONFIG_ZBOOT_ROM_BSS=0 CONFIG_CMDLINE="" # CONFIG_XIP_KERNEL is not set # CONFIG_KEXEC is not set # CONFIG_AUTO_ZRELADDR is not set # # CPU Power Management # # CONFIG_CPU_FREQ is not set # CONFIG_CPU_IDLE is not set # # Floating point emulation # # # At least one emulation must be selected # CONFIG_FPE_NWFPE=y # CONFIG_FPE_NWFPE_XP is not set # CONFIG_FPE_FASTFPE is not set CONFIG_VFP=y CONFIG_VFPv3=y CONFIG_NEON=y # # Userspace binary formats # CONFIG_BINFMT_ELF=y # CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set CONFIG_HAVE_AOUT=y # CONFIG_BINFMT_AOUT is not set CONFIG_BINFMT_MISC=y # # Power management options # CONFIG_PM=y CONFIG_PM_DEBUG=y # CONFIG_PM_ADVANCED_DEBUG is not set CONFIG_PM_VERBOSE=y # CONFIG_SUSPEND is not set # CONFIG_APM_EMULATION is not set CONFIG_PM_RUNTIME=y CONFIG_PM_OPS=y # CONFIG_ARCH_HAS_OPP is not set CONFIG_ARCH_SUSPEND_POSSIBLE=y CONFIG_NET=y # # Networking options # CONFIG_PACKET=y CONFIG_UNIX=y CONFIG_XFRM=y # CONFIG_XFRM_USER is not set # CONFIG_XFRM_SUB_POLICY is not set # CONFIG_XFRM_MIGRATE is not set # CONFIG_XFRM_STATISTICS is not set # CONFIG_NET_KEY is not set CONFIG_INET=y # CONFIG_IP_MULTICAST is not set # CONFIG_IP_ADVANCED_ROUTER is not set CONFIG_IP_FIB_HASH=y CONFIG_IP_PNP=y CONFIG_IP_PNP_DHCP=y CONFIG_IP_PNP_BOOTP=y CONFIG_IP_PNP_RARP=y # CONFIG_NET_IPIP is not set # CONFIG_NET_IPGRE_DEMUX is not set # CONFIG_ARPD is not set # CONFIG_SYN_COOKIES is not set # CONFIG_INET_AH is not set # CONFIG_INET_ESP is not set # CONFIG_INET_IPCOMP is not set # CONFIG_INET_XFRM_TUNNEL is not set # CONFIG_INET_TUNNEL is not set CONFIG_INET_XFRM_MODE_TRANSPORT=y CONFIG_INET_XFRM_MODE_TUNNEL=y CONFIG_INET_XFRM_MODE_BEET=y CONFIG_INET_LRO=y CONFIG_INET_DIAG=y CONFIG_INET_TCP_DIAG=y # CONFIG_TCP_CONG_ADVANCED is not set CONFIG_TCP_CONG_CUBIC=y CONFIG_DEFAULT_TCP_CONG="cubic" # CONFIG_TCP_MD5SIG is not set # CONFIG_IPV6 is not set # CONFIG_NETLABEL is not set # CONFIG_NETWORK_SECMARK is not set # CONFIG_NETWORK_PHY_TIMESTAMPING is not set # CONFIG_NETFILTER is not set # CONFIG_IP_DCCP is not set # CONFIG_IP_SCTP is not set # CONFIG_RDS is not set # CONFIG_TIPC is not set # CONFIG_ATM is not set # CONFIG_L2TP is not set # CONFIG_BRIDGE is not set # CONFIG_NET_DSA is not set # CONFIG_VLAN_8021Q is not set # CONFIG_DECNET is not set # CONFIG_LLC2 is not set # CONFIG_IPX is not set # CONFIG_ATALK is not set # CONFIG_X25 is not set # CONFIG_LAPB is not set # CONFIG_ECONET is not set # CONFIG_WAN_ROUTER is not set # CONFIG_PHONET is not set # CONFIG_IEEE802154 is not set # CONFIG_NET_SCHED is not set # CONFIG_DCB is not set # CONFIG_DNS_RESOLVER is not set # # Network testing # # CONFIG_NET_PKTGEN is not set # CONFIG_NET_TCPPROBE is not set # CONFIG_HAMRADIO is not set # CONFIG_CAN is not set # CONFIG_IRDA is not set # CONFIG_BT is not set # CONFIG_AF_RXRPC is not set # CONFIG_WIRELESS is not set # CONFIG_WIMAX is not set # CONFIG_RFKILL is not set # CONFIG_NET_9P is not set # CONFIG_CAIF is not set # CONFIG_CEPH_LIB is not set # # Device Drivers # # # Generic Driver Options # CONFIG_UEVENT_HELPER_PATH="" CONFIG_DEVTMPFS=y CONFIG_DEVTMPFS_MOUNT=y CONFIG_STANDALONE=y CONFIG_PREVENT_FIRMWARE_BUILD=y CONFIG_FW_LOADER=y CONFIG_FIRMWARE_IN_KERNEL=y CONFIG_EXTRA_FIRMWARE="" # CONFIG_DEBUG_DRIVER is not set # CONFIG_DEBUG_DEVRES is not set # CONFIG_SYS_HYPERVISOR is not set # CONFIG_CONNECTOR is not set CONFIG_MTD=y # CONFIG_MTD_DEBUG is not set # CONFIG_MTD_TESTS is not set CONFIG_MTD_CONCAT=y CONFIG_MTD_PARTITIONS=y # CONFIG_MTD_REDBOOT_PARTS is not set CONFIG_MTD_CMDLINE_PARTS=y # CONFIG_MTD_AFS_PARTS is not set # CONFIG_MTD_AR7_PARTS is not set # # User Modules And Translation Layers # CONFIG_MTD_CHAR=y CONFIG_MTD_BLKDEVS=y CONFIG_MTD_BLOCK=y # CONFIG_FTL is not set # CONFIG_NFTL is not set # CONFIG_INFTL is not set # CONFIG_RFD_FTL is not set # CONFIG_SSFDC is not set # CONFIG_SM_FTL is not set # CONFIG_MTD_OOPS is not set # # RAM/ROM/Flash chip drivers # # CONFIG_MTD_CFI is not set # CONFIG_MTD_JEDECPROBE is not set CONFIG_MTD_MAP_BANK_WIDTH_1=y CONFIG_MTD_MAP_BANK_WIDTH_2=y CONFIG_MTD_MAP_BANK_WIDTH_4=y # CONFIG_MTD_MAP_BANK_WIDTH_8 is not set # CONFIG_MTD_MAP_BANK_WIDTH_16 is not set # CONFIG_MTD_MAP_BANK_WIDTH_32 is not set CONFIG_MTD_CFI_I1=y CONFIG_MTD_CFI_I2=y # CONFIG_MTD_CFI_I4 is not set # CONFIG_MTD_CFI_I8 is not set # CONFIG_MTD_RAM is not set # CONFIG_MTD_ROM is not set # CONFIG_MTD_ABSENT is not set # # Mapping drivers for chip access # # CONFIG_MTD_COMPLEX_MAPPINGS is not set # CONFIG_MTD_INTEL_VR_NOR is not set # CONFIG_MTD_PLATRAM is not set # # Self-contained MTD device drivers # # CONFIG_MTD_PMC551 is not set # CONFIG_MTD_DATAFLASH is not set CONFIG_MTD_M25P80=y CONFIG_M25PXX_USE_FAST_READ=y # CONFIG_MTD_SST25L is not set # CONFIG_MTD_SLRAM is not set # CONFIG_MTD_PHRAM is not set # CONFIG_MTD_MTDRAM is not set # CONFIG_MTD_BLOCK2MTD is not set # # Disk-On-Chip Device Drivers # # CONFIG_MTD_DOC2000 is not set # CONFIG_MTD_DOC2001 is not set # CONFIG_MTD_DOC2001PLUS is not set CONFIG_MTD_NAND_ECC=y # CONFIG_MTD_NAND_ECC_SMC is not set CONFIG_MTD_NAND=y # CONFIG_MTD_NAND_VERIFY_WRITE is not set # CONFIG_MTD_SM_COMMON is not set # CONFIG_MTD_NAND_MUSEUM_IDS is not set # CONFIG_MTD_NAND_DENALI is not set # CONFIG_MTD_NAND_GPIO is not set CONFIG_MTD_NAND_OMAP2=y CONFIG_MTD_NAND_IDS=y # CONFIG_MTD_NAND_RICOH is not set # CONFIG_MTD_NAND_DISKONCHIP is not set # CONFIG_MTD_NAND_CAFE is not set # CONFIG_MTD_NAND_NANDSIM is not set # CONFIG_MTD_NAND_PLATFORM is not set # CONFIG_MTD_ALAUDA is not set # CONFIG_MTD_ONENAND is not set # # LPDDR flash memory drivers # # CONFIG_MTD_LPDDR is not set CONFIG_MTD_UBI=y CONFIG_MTD_UBI_WL_THRESHOLD=4096 CONFIG_MTD_UBI_BEB_RESERVE=1 # CONFIG_MTD_UBI_GLUEBI is not set # CONFIG_MTD_UBI_DEBUG is not set # CONFIG_PARPORT is not set CONFIG_BLK_DEV=y # CONFIG_BLK_CPQ_DA is not set # CONFIG_BLK_CPQ_CISS_DA is not set # CONFIG_BLK_DEV_DAC960 is not set # CONFIG_BLK_DEV_UMEM is not set # CONFIG_BLK_DEV_COW_COMMON is not set CONFIG_BLK_DEV_LOOP=y # CONFIG_BLK_DEV_CRYPTOLOOP is not set # # DRBD disabled because PROC_FS, INET or CONNECTOR not selected # # CONFIG_BLK_DEV_NBD is not set # CONFIG_BLK_DEV_SX8 is not set # CONFIG_BLK_DEV_UB is not set CONFIG_BLK_DEV_RAM=y CONFIG_BLK_DEV_RAM_COUNT=16 CONFIG_BLK_DEV_RAM_SIZE=32768 # CONFIG_BLK_DEV_XIP is not set # CONFIG_CDROM_PKTCDVD is not set # CONFIG_ATA_OVER_ETH is not set # CONFIG_MG_DISK is not set # CONFIG_BLK_DEV_RBD is not set CONFIG_MISC_DEVICES=y # CONFIG_AD525X_DPOT is not set # CONFIG_PHANTOM is not set # CONFIG_SGI_IOC4 is not set # CONFIG_TIFM_CORE is not set # CONFIG_ICS932S401 is not set # CONFIG_ENCLOSURE_SERVICES is not set # CONFIG_HP_ILO is not set # CONFIG_APDS9802ALS is not set # CONFIG_ISL29003 is not set # CONFIG_ISL29020 is not set # CONFIG_SENSORS_TSL2550 is not set # CONFIG_SENSORS_BH1780 is not set # CONFIG_SENSORS_BH1770 is not set # CONFIG_SENSORS_APDS990X is not set # CONFIG_HMC6352 is not set # CONFIG_DS1682 is not set # CONFIG_TI_DAC7512 is not set # CONFIG_BMP085 is not set # CONFIG_PCH_PHUB is not set CONFIG_DM8168_DVR_IO=y # CONFIG_C2PORT is not set # # EEPROM support # # CONFIG_EEPROM_AT24 is not set # CONFIG_EEPROM_AT25 is not set # CONFIG_EEPROM_LEGACY is not set # CONFIG_EEPROM_MAX6875 is not set # CONFIG_EEPROM_93CX6 is not set CONFIG_EEPROM_3WIRED_AT93C66=y # CONFIG_CB710_CORE is not set # CONFIG_IWMC3200TOP is not set # # Texas Instruments shared transport line discipline # CONFIG_HAVE_IDE=y # CONFIG_IDE is not set # # SCSI device support # CONFIG_SCSI_MOD=y # CONFIG_RAID_ATTRS is not set CONFIG_SCSI=y CONFIG_SCSI_DMA=y # CONFIG_SCSI_TGT is not set # CONFIG_SCSI_NETLINK is not set CONFIG_SCSI_PROC_FS=y # # SCSI support type (disk, tape, CD-ROM) # CONFIG_BLK_DEV_SD=y # CONFIG_CHR_DEV_ST is not set # CONFIG_CHR_DEV_OSST is not set CONFIG_BLK_DEV_SR=y CONFIG_BLK_DEV_SR_VENDOR=y CONFIG_CHR_DEV_SG=y # CONFIG_CHR_DEV_SCH is not set # CONFIG_SCSI_MULTI_LUN is not set # CONFIG_SCSI_CONSTANTS is not set # CONFIG_SCSI_LOGGING is not set # CONFIG_SCSI_SCAN_ASYNC is not set CONFIG_SCSI_WAIT_SCAN=m # # SCSI Transports # # CONFIG_SCSI_SPI_ATTRS is not set # CONFIG_SCSI_FC_ATTRS is not set # CONFIG_SCSI_ISCSI_ATTRS is not set # CONFIG_SCSI_SAS_ATTRS is not set # CONFIG_SCSI_SAS_LIBSAS is not set # CONFIG_SCSI_SRP_ATTRS is not set # CONFIG_SCSI_LOWLEVEL is not set # CONFIG_SCSI_DH is not set # CONFIG_SCSI_OSD_INITIATOR is not set CONFIG_ATA=y # CONFIG_ATA_NONSTANDARD is not set CONFIG_ATA_VERBOSE_ERROR=y CONFIG_SATA_PMP=y # # Controllers with non-SFF native interface # CONFIG_SATA_AHCI=y CONFIG_SATA_AHCI_PLATFORM=y # CONFIG_SATA_INIC162X is not set # CONFIG_SATA_SIL24 is not set # CONFIG_ATA_SFF is not set # CONFIG_MD is not set # CONFIG_FUSION is not set # # IEEE 1394 (FireWire) support # # CONFIG_FIREWIRE is not set # CONFIG_FIREWIRE_NOSY is not set # CONFIG_I2O is not set CONFIG_NETDEVICES=y # CONFIG_DUMMY is not set # CONFIG_BONDING is not set # CONFIG_MACVLAN is not set # CONFIG_EQUALIZER is not set # CONFIG_TUN is not set # CONFIG_VETH is not set # CONFIG_ARCNET is not set CONFIG_MII=y CONFIG_PHYLIB=y # # MII PHY device drivers # # CONFIG_MARVELL_PHY is not set # CONFIG_DAVICOM_PHY is not set # CONFIG_QSEMI_PHY is not set # CONFIG_LXT_PHY is not set # CONFIG_CICADA_PHY is not set # CONFIG_VITESSE_PHY is not set # CONFIG_SMSC_PHY is not set # CONFIG_BROADCOM_PHY is not set # CONFIG_BCM63XX_PHY is not set # CONFIG_ICPLUS_PHY is not set # CONFIG_REALTEK_PHY is not set # CONFIG_NATIONAL_PHY is not set # CONFIG_STE10XP is not set # CONFIG_LSI_ET1011C_PHY is not set # CONFIG_MICREL_PHY is not set # CONFIG_FIXED_PHY is not set # CONFIG_MDIO_BITBANG is not set # CONFIG_NET_ETHERNET is not set CONFIG_NETDEV_1000=y # CONFIG_ACENIC is not set # CONFIG_DL2K is not set CONFIG_TI_DAVINCI_EMAC=y CONFIG_TI_DAVINCI_MDIO=y CONFIG_TI_DAVINCI_CPDMA=y # CONFIG_E1000 is not set # CONFIG_E1000E is not set # CONFIG_IP1000 is not set # CONFIG_IGB is not set # CONFIG_IGBVF is not set # CONFIG_NS83820 is not set # CONFIG_HAMACHI is not set # CONFIG_YELLOWFIN is not set # CONFIG_R8169 is not set # CONFIG_SIS190 is not set # CONFIG_SKGE is not set # CONFIG_SKY2 is not set # CONFIG_VIA_VELOCITY is not set # CONFIG_TIGON3 is not set # CONFIG_BNX2 is not set # CONFIG_CNIC is not set # CONFIG_QLA3XXX is not set # CONFIG_ATL1 is not set # CONFIG_ATL1E is not set # CONFIG_ATL1C is not set # CONFIG_JME is not set # CONFIG_STMMAC_ETH is not set # CONFIG_PCH_GBE is not set # CONFIG_NETDEV_10000 is not set # CONFIG_TR is not set # CONFIG_WLAN is not set # # Enable WiMAX (Networking options) to see the WiMAX drivers # # # USB Network Adapters # # CONFIG_USB_CATC is not set # CONFIG_USB_KAWETH is not set # CONFIG_USB_PEGASUS is not set # CONFIG_USB_RTL8150 is not set CONFIG_USB_USBNET=y # CONFIG_USB_NET_AX8817X is not set CONFIG_USB_NET_CDCETHER=y # CONFIG_USB_NET_CDC_EEM is not set CONFIG_USB_NET_DM9601=y # CONFIG_USB_NET_SMSC75XX is not set # CONFIG_USB_NET_SMSC95XX is not set # CONFIG_USB_NET_GL620A is not set # CONFIG_USB_NET_NET1080 is not set # CONFIG_USB_NET_PLUSB is not set # CONFIG_USB_NET_MCS7830 is not set # CONFIG_USB_NET_RNDIS_HOST is not set # CONFIG_USB_NET_CDC_SUBSET is not set # CONFIG_USB_NET_ZAURUS is not set # CONFIG_USB_NET_CX82310_ETH is not set # CONFIG_USB_NET_INT51X1 is not set # CONFIG_USB_IPHETH is not set # CONFIG_USB_SIERRA_NET is not set # CONFIG_WAN is not set # # CAIF transport drivers # # CONFIG_FDDI is not set # CONFIG_HIPPI is not set # CONFIG_PPP is not set # CONFIG_SLIP is not set # CONFIG_NET_FC is not set # CONFIG_NETCONSOLE is not set # CONFIG_NETPOLL is not set # CONFIG_NET_POLL_CONTROLLER is not set # CONFIG_VMXNET3 is not set # CONFIG_ISDN is not set # CONFIG_PHONE is not set # # Input device support # CONFIG_INPUT=y # CONFIG_INPUT_FF_MEMLESS is not set # CONFIG_INPUT_POLLDEV is not set # CONFIG_INPUT_SPARSEKMAP is not set # # Userland interfaces # CONFIG_INPUT_MOUSEDEV=y # CONFIG_INPUT_MOUSEDEV_PSAUX is not set CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024 CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768 # CONFIG_INPUT_JOYDEV is not set CONFIG_INPUT_EVDEV=y # CONFIG_INPUT_EVBUG is not set # # Input Device Drivers # # CONFIG_INPUT_KEYBOARD is not set # CONFIG_INPUT_MOUSE is not set # CONFIG_INPUT_JOYSTICK is not set # CONFIG_INPUT_TABLET is not set # CONFIG_INPUT_TOUCHSCREEN is not set CONFIG_INPUT_MISC=y # CONFIG_INPUT_AD714X is not set # CONFIG_INPUT_ATI_REMOTE is not set # CONFIG_INPUT_ATI_REMOTE2 is not set # CONFIG_INPUT_KEYSPAN_REMOTE is not set # CONFIG_INPUT_POWERMATE is not set # CONFIG_INPUT_YEALINK is not set # CONFIG_INPUT_CM109 is not set CONFIG_INPUT_UINPUT=y # CONFIG_INPUT_PCF8574 is not set # CONFIG_INPUT_GPIO_ROTARY_ENCODER is not set # CONFIG_INPUT_ADXL34X is not set # # Hardware I/O ports # CONFIG_SERIO=y CONFIG_SERIO_SERPORT=y # CONFIG_SERIO_PCIPS2 is not set # CONFIG_SERIO_RAW is not set # CONFIG_SERIO_ALTERA_PS2 is not set # CONFIG_SERIO_PS2MULT is not set # CONFIG_GAMEPORT is not set # # Character devices # CONFIG_VT=y CONFIG_CONSOLE_TRANSLATIONS=y CONFIG_VT_CONSOLE=y CONFIG_HW_CONSOLE=y # CONFIG_VT_HW_CONSOLE_BINDING is not set CONFIG_DEVKMEM=y CONFIG_SERIAL_NONSTANDARD=y # CONFIG_COMPUTONE is not set # CONFIG_ROCKETPORT is not set # CONFIG_CYCLADES is not set # CONFIG_DIGIEPCA is not set # CONFIG_MOXA_INTELLIO is not set # CONFIG_MOXA_SMARTIO is not set # CONFIG_ISI is not set # CONFIG_SYNCLINKMP is not set # CONFIG_SYNCLINK_GT is not set # CONFIG_N_HDLC is not set # CONFIG_N_GSM is not set # CONFIG_RISCOM8 is not set # CONFIG_SPECIALIX is not set # CONFIG_STALDRV is not set # CONFIG_NOZOMI is not set # # Serial drivers # CONFIG_SERIAL_8250=y CONFIG_SERIAL_8250_CONSOLE=y CONFIG_SERIAL_8250_PCI=y CONFIG_SERIAL_8250_NR_UARTS=64 CONFIG_SERIAL_8250_RUNTIME_UARTS=4 CONFIG_SERIAL_8250_EXTENDED=y # CONFIG_SERIAL_8250_MANY_PORTS is not set CONFIG_SERIAL_8250_SHARE_IRQ=y CONFIG_SERIAL_8250_DETECT_IRQ=y CONFIG_SERIAL_8250_RSA=y # # Non-8250 serial port support # # CONFIG_SERIAL_MAX3100 is not set # CONFIG_SERIAL_MAX3107 is not set # CONFIG_SERIAL_MFD_HSU is not set CONFIG_SERIAL_CORE=y CONFIG_SERIAL_CORE_CONSOLE=y # CONFIG_SERIAL_JSM is not set CONFIG_SERIAL_OMAP=y CONFIG_SERIAL_OMAP_CONSOLE=y # CONFIG_SERIAL_TIMBERDALE is not set # CONFIG_SERIAL_ALTERA_JTAGUART is not set # CONFIG_SERIAL_ALTERA_UART is not set CONFIG_UNIX98_PTYS=y # CONFIG_DEVPTS_MULTIPLE_INSTANCES is not set # CONFIG_LEGACY_PTYS is not set # CONFIG_IPMI_HANDLER is not set # CONFIG_HW_RANDOM is not set # CONFIG_R3964 is not set # CONFIG_APPLICOM is not set # CONFIG_RAW_DRIVER is not set # CONFIG_TCG_TPM is not set CONFIG_DEVPORT=y # CONFIG_TI81XX_PCIE_BOOTDRV is not set # CONFIG_RAMOOPS is not set CONFIG_I2C=y CONFIG_I2C_BOARDINFO=y CONFIG_I2C_COMPAT=y CONFIG_I2C_CHARDEV=y # CONFIG_I2C_MUX is not set CONFIG_I2C_HELPER_AUTO=y # # I2C Hardware Bus support # # # PC SMBus host controller drivers # # CONFIG_I2C_ALI1535 is not set # CONFIG_I2C_ALI1563 is not set # CONFIG_I2C_ALI15X3 is not set # CONFIG_I2C_AMD756 is not set # CONFIG_I2C_AMD8111 is not set # CONFIG_I2C_I801 is not set # CONFIG_I2C_ISCH is not set # CONFIG_I2C_PIIX4 is not set # CONFIG_I2C_NFORCE2 is not set # CONFIG_I2C_SIS5595 is not set # CONFIG_I2C_SIS630 is not set # CONFIG_I2C_SIS96X is not set # CONFIG_I2C_VIA is not set # CONFIG_I2C_VIAPRO is not set # # I2C system bus drivers (mostly embedded / system-on-chip) # # CONFIG_I2C_DESIGNWARE is not set # CONFIG_I2C_GPIO is not set # CONFIG_I2C_INTEL_MID is not set # CONFIG_I2C_OCORES is not set CONFIG_I2C_OMAP=y # CONFIG_I2C_PCA_PLATFORM is not set # CONFIG_I2C_SIMTEC is not set # CONFIG_I2C_XILINX is not set # # External I2C/SMBus adapter drivers # # CONFIG_I2C_PARPORT_LIGHT is not set # CONFIG_I2C_TAOS_EVM is not set # CONFIG_I2C_TINY_USB is not set # # Other I2C/SMBus bus drivers # # CONFIG_I2C_STUB is not set # CONFIG_I2C_DEBUG_CORE is not set # CONFIG_I2C_DEBUG_ALGO is not set # CONFIG_I2C_DEBUG_BUS is not set CONFIG_SPI=y # CONFIG_SPI_DEBUG is not set CONFIG_SPI_MASTER=y # # SPI Master Controller Drivers # # CONFIG_SPI_BITBANG is not set # CONFIG_SPI_GPIO is not set CONFIG_SPI_OMAP24XX=y # CONFIG_SPI_TOPCLIFF_PCH is not set # CONFIG_SPI_XILINX is not set # CONFIG_SPI_DESIGNWARE is not set # # SPI Protocol Masters # # CONFIG_SPI_SPIDEV is not set # CONFIG_SPI_TLE62X0 is not set # # PPS support # # CONFIG_PPS is not set # # PTP clock support # # # Enable Device Drivers -> PPS to see the PTP clock options. # CONFIG_ARCH_REQUIRE_GPIOLIB=y CONFIG_GPIOLIB=y # CONFIG_DEBUG_GPIO is not set # CONFIG_GPIO_SYSFS is not set # # Memory mapped GPIO expanders: # # CONFIG_GPIO_BASIC_MMIO is not set # CONFIG_GPIO_IT8761E is not set # CONFIG_GPIO_SCH is not set # CONFIG_GPIO_VX855 is not set # # I2C GPIO expanders: # # CONFIG_GPIO_MAX7300 is not set # CONFIG_GPIO_MAX732X is not set # CONFIG_GPIO_PCA953X is not set # CONFIG_GPIO_PCF857X is not set # CONFIG_GPIO_SX150X is not set # CONFIG_GPIO_ADP5588 is not set # # PCI GPIO expanders: # # CONFIG_GPIO_CS5535 is not set # CONFIG_GPIO_BT8XX is not set # CONFIG_GPIO_LANGWELL is not set # CONFIG_GPIO_PCH is not set # CONFIG_GPIO_RDC321X is not set # # SPI GPIO expanders: # # CONFIG_GPIO_MAX7301 is not set # CONFIG_GPIO_MCP23S08 is not set # CONFIG_GPIO_MC33880 is not set # CONFIG_GPIO_74X164 is not set # # AC97 GPIO expanders: # # # MODULbus GPIO expanders: # # CONFIG_W1 is not set # CONFIG_POWER_SUPPLY is not set # CONFIG_HWMON is not set # CONFIG_THERMAL is not set CONFIG_WATCHDOG=y # CONFIG_WATCHDOG_NOWAYOUT is not set # # Watchdog Device Drivers # # CONFIG_SOFT_WATCHDOG is not set CONFIG_OMAP_WATCHDOG=y # CONFIG_MAX63XX_WATCHDOG is not set # CONFIG_ALIM7101_WDT is not set # # PCI-based Watchdog Cards # # CONFIG_PCIPCWATCHDOG is not set # CONFIG_WDTPCI is not set # # USB-based Watchdog Cards # # CONFIG_USBPCWATCHDOG is not set CONFIG_SSB_POSSIBLE=y # # Sonics Silicon Backplane # CONFIG_SSB=m CONFIG_SSB_SPROM=y CONFIG_SSB_PCIHOST_POSSIBLE=y CONFIG_SSB_PCIHOST=y # CONFIG_SSB_B43_PCI_BRIDGE is not set CONFIG_SSB_SDIOHOST_POSSIBLE=y # CONFIG_SSB_SDIOHOST is not set # CONFIG_SSB_DEBUG is not set CONFIG_SSB_DRIVER_PCICORE_POSSIBLE=y # CONFIG_SSB_DRIVER_PCICORE is not set CONFIG_MFD_SUPPORT=y # CONFIG_MFD_CORE is not set # CONFIG_MFD_88PM860X is not set # CONFIG_MFD_SM501 is not set # CONFIG_MFD_ASIC3 is not set # CONFIG_HTC_EGPIO is not set # CONFIG_HTC_PASIC3 is not set # CONFIG_HTC_I2CPLD is not set # CONFIG_TPS65010 is not set # CONFIG_TPS6507X is not set # CONFIG_MFD_STMPE is not set # CONFIG_MFD_TC35892 is not set # CONFIG_MFD_TMIO is not set # CONFIG_MFD_T7L66XB is not set # CONFIG_MFD_TC6387XB is not set # CONFIG_MFD_TC6393XB is not set # CONFIG_PMIC_DA903X is not set # CONFIG_PMIC_ADP5520 is not set # CONFIG_MFD_MAX8925 is not set # CONFIG_MFD_MAX8998 is not set # CONFIG_MFD_WM8400 is not set # CONFIG_MFD_WM831X_I2C is not set # CONFIG_MFD_WM831X_SPI is not set # CONFIG_MFD_WM8350_I2C is not set # CONFIG_MFD_WM8994 is not set # CONFIG_MFD_PCF50633 is not set # CONFIG_MFD_MC13XXX is not set # CONFIG_ABX500_CORE is not set # CONFIG_EZX_PCAP is not set # CONFIG_MFD_TIMBERDALE is not set # CONFIG_LPC_SCH is not set # CONFIG_MFD_RDC321X is not set # CONFIG_MFD_JANZ_CMODIO is not set # CONFIG_MFD_TPS6586X is not set # CONFIG_MFD_VX855 is not set # CONFIG_MFD_TPS65910 is not set CONFIG_REGULATOR=y # CONFIG_REGULATOR_DEBUG is not set # CONFIG_REGULATOR_DUMMY is not set # CONFIG_REGULATOR_FIXED_VOLTAGE is not set # CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set # CONFIG_REGULATOR_USERSPACE_CONSUMER is not set # CONFIG_REGULATOR_BQ24022 is not set # CONFIG_REGULATOR_MAX1586 is not set # CONFIG_REGULATOR_MAX8649 is not set # CONFIG_REGULATOR_MAX8660 is not set # CONFIG_REGULATOR_MAX8952 is not set # CONFIG_REGULATOR_LP3971 is not set # CONFIG_REGULATOR_LP3972 is not set # CONFIG_REGULATOR_TPS65023 is not set CONFIG_REGULATOR_TPS40400=y # CONFIG_REGULATOR_GPIO is not set # CONFIG_REGULATOR_TPS6507X is not set # CONFIG_REGULATOR_ISL6271A is not set # CONFIG_REGULATOR_AD5398 is not set CONFIG_MEDIA_SUPPORT=y # # Multimedia core support # # CONFIG_MEDIA_CONTROLLER is not set CONFIG_VIDEO_DEV=y CONFIG_VIDEO_V4L2_COMMON=y CONFIG_VIDEO_ALLOW_V4L1=y CONFIG_VIDEO_V4L1_COMPAT=y # CONFIG_DVB_CORE is not set CONFIG_VIDEO_MEDIA=y # # Multimedia drivers # # CONFIG_IR_CORE is not set # CONFIG_MEDIA_ATTACH is not set CONFIG_MEDIA_TUNER=y # CONFIG_MEDIA_TUNER_CUSTOMISE is not set CONFIG_MEDIA_TUNER_SIMPLE=y CONFIG_MEDIA_TUNER_TDA8290=y CONFIG_MEDIA_TUNER_TDA827X=y CONFIG_MEDIA_TUNER_TDA18271=y CONFIG_MEDIA_TUNER_TDA9887=y CONFIG_MEDIA_TUNER_TEA5761=y CONFIG_MEDIA_TUNER_TEA5767=y CONFIG_MEDIA_TUNER_MT20XX=y CONFIG_MEDIA_TUNER_XC2028=y CONFIG_MEDIA_TUNER_XC5000=y CONFIG_MEDIA_TUNER_MC44S803=y CONFIG_VIDEO_V4L2=y CONFIG_VIDEO_V4L1=y CONFIG_VIDEOBUF_GEN=y CONFIG_VIDEOBUF_DMA_SG=y CONFIG_VIDEOBUF_DMA_CONTIG=y CONFIG_VIDEO_CAPTURE_DRIVERS=y # CONFIG_VIDEO_ADV_DEBUG is not set # CONFIG_VIDEO_FIXED_MINOR_RANGES is not set # CONFIG_VIDEO_HELPER_CHIPS_AUTO is not set # # Encoders/decoders and other helper chips # # # Audio decoders # # CONFIG_VIDEO_TVAUDIO is not set # CONFIG_VIDEO_TDA7432 is not set # CONFIG_VIDEO_TDA9840 is not set # CONFIG_VIDEO_TDA9875 is not set # CONFIG_VIDEO_TEA6415C is not set # CONFIG_VIDEO_TEA6420 is not set # CONFIG_VIDEO_MSP3400 is not set # CONFIG_VIDEO_CS5345 is not set # CONFIG_VIDEO_CS53L32A is not set # CONFIG_VIDEO_M52790 is not set # CONFIG_VIDEO_TLV320AIC23B is not set # CONFIG_VIDEO_WM8775 is not set # CONFIG_VIDEO_WM8739 is not set # CONFIG_VIDEO_VP27SMPX is not set # # RDS decoders # # CONFIG_VIDEO_SAA6588 is not set # # Video decoders # # CONFIG_VIDEO_ADV7180 is not set # CONFIG_VIDEO_BT819 is not set # CONFIG_VIDEO_BT856 is not set # CONFIG_VIDEO_BT866 is not set # CONFIG_VIDEO_KS0127 is not set # CONFIG_VIDEO_OV7670 is not set # CONFIG_VIDEO_MT9T001 is not set # CONFIG_VIDEO_MT9V011 is not set # CONFIG_VIDEO_MT9V113 is not set # CONFIG_VIDEO_MT9T111 is not set # CONFIG_VIDEO_TCM825X is not set # CONFIG_VIDEO_SAA7110 is not set # CONFIG_VIDEO_SAA711X is not set # CONFIG_VIDEO_SAA717X is not set # CONFIG_VIDEO_SAA7191 is not set # CONFIG_VIDEO_TVP514X is not set # CONFIG_VIDEO_TVP5150 is not set # CONFIG_VIDEO_TVP7002 is not set # CONFIG_VIDEO_VPX3220 is not set # # Video and audio decoders # # CONFIG_VIDEO_CX25840 is not set # # MPEG video encoders # # CONFIG_VIDEO_CX2341X is not set # # Video encoders # # CONFIG_VIDEO_SAA7127 is not set # CONFIG_VIDEO_SAA7185 is not set # CONFIG_VIDEO_ADV7170 is not set # CONFIG_VIDEO_ADV7175 is not set # CONFIG_VIDEO_THS7303 is not set # CONFIG_VIDEO_ADV7343 is not set # CONFIG_VIDEO_AK881X is not set # # Video improvement chips # # CONFIG_VIDEO_UPD64031A is not set # CONFIG_VIDEO_UPD64083 is not set CONFIG_VIDEO_TI81XX_VIDOUT=m # CONFIG_VIDEO_TI81XX_VIDIN is not set # CONFIG_VIDEO_CPIA2 is not set # CONFIG_VIDEO_SAA7134 is not set # CONFIG_VIDEO_MXB is not set # CONFIG_VIDEO_HEXIUM_ORION is not set # CONFIG_VIDEO_HEXIUM_GEMINI is not set # CONFIG_VIDEO_CAFE_CCIC is not set # CONFIG_VIDEO_SR030PC30 is not set # CONFIG_SOC_CAMERA is not set CONFIG_V4L_USB_DRIVERS=y CONFIG_USB_VIDEO_CLASS=y CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y # CONFIG_USB_GSPCA is not set # CONFIG_VIDEO_PVRUSB2 is not set # CONFIG_VIDEO_HDPVR is not set # CONFIG_VIDEO_USBVISION is not set # CONFIG_USB_VICAM is not set # CONFIG_USB_IBMCAM is not set # CONFIG_USB_KONICAWC is not set # CONFIG_USB_ET61X251 is not set # CONFIG_USB_SE401 is not set # CONFIG_USB_SN9C102 is not set # CONFIG_USB_PWC is not set # CONFIG_USB_ZR364XX is not set # CONFIG_USB_STKWEBCAM is not set # CONFIG_USB_S2255 is not set # CONFIG_V4L_MEM2MEM_DRIVERS is not set # CONFIG_RADIO_ADAPTERS is not set # CONFIG_DAB is not set CONFIG_HAVE_TI_TILER=y # CONFIG_TI_TILER is not set # # Graphics support # CONFIG_VGA_ARB=y CONFIG_VGA_ARB_MAX_GPUS=16 # CONFIG_DRM is not set # CONFIG_STUB_POULSBO is not set # CONFIG_VGASTATE is not set # CONFIG_VIDEO_OUTPUT_CONTROL is not set CONFIG_FB=y # CONFIG_FIRMWARE_EDID is not set # CONFIG_FB_DDC is not set # CONFIG_FB_BOOT_VESA_SUPPORT is not set CONFIG_FB_CFB_FILLRECT=y CONFIG_FB_CFB_COPYAREA=y CONFIG_FB_CFB_IMAGEBLIT=y # CONFIG_FB_CFB_REV_PIXELS_IN_BYTE is not set # CONFIG_FB_SYS_FILLRECT is not set # CONFIG_FB_SYS_COPYAREA is not set # CONFIG_FB_SYS_IMAGEBLIT is not set # CONFIG_FB_FOREIGN_ENDIAN is not set # CONFIG_FB_SYS_FOPS is not set # CONFIG_FB_SVGALIB is not set # CONFIG_FB_MACMODES is not set # CONFIG_FB_BACKLIGHT is not set # CONFIG_FB_MODE_HELPERS is not set # CONFIG_FB_TILEBLITTING is not set # # Frame buffer hardware drivers # # CONFIG_FB_CIRRUS is not set # CONFIG_FB_PM2 is not set # CONFIG_FB_CYBER2000 is not set # CONFIG_FB_ASILIANT is not set # CONFIG_FB_IMSTT is not set # CONFIG_FB_S1D13XXX is not set # CONFIG_FB_NVIDIA is not set # CONFIG_FB_RIVA is not set # CONFIG_FB_MATROX is not set # CONFIG_FB_RADEON is not set # CONFIG_FB_ATY128 is not set # CONFIG_FB_ATY is not set # CONFIG_FB_S3 is not set # CONFIG_FB_SAVAGE is not set # CONFIG_FB_SIS is not set # CONFIG_FB_NEOMAGIC is not set # CONFIG_FB_KYRO is not set # CONFIG_FB_3DFX is not set # CONFIG_FB_VOODOO1 is not set # CONFIG_FB_VT8623 is not set # CONFIG_FB_TRIDENT is not set # CONFIG_FB_ARK is not set # CONFIG_FB_PM3 is not set # CONFIG_FB_CARMINE is not set # CONFIG_FB_VIRTUAL is not set # CONFIG_FB_METRONOME is not set # CONFIG_FB_MB862XX is not set # CONFIG_FB_BROADSHEET is not set CONFIG_TI81XX_VPSS=m CONFIG_TI81XX_VPSS_VRAM_SIZE=50 CONFIG_TI81XX_VPSS_DEBUG_SUPPORT=y CONFIG_FB_TI81XX=m CONFIG_FB_TI81XX_DEBUG_SUPPORT=y CONFIG_FB_TI81XX_NUM_FBS=3 CONFIG_TI81XX_HDMI=m CONFIG_SII9022a=m # CONFIG_BACKLIGHT_LCD_SUPPORT is not set # # Display device support # # CONFIG_DISPLAY_SUPPORT is not set # # Console display driver support # CONFIG_DUMMY_CONSOLE=y # CONFIG_FRAMEBUFFER_CONSOLE is not set # CONFIG_LOGO is not set CONFIG_SOUND=y # CONFIG_SOUND_OSS_CORE is not set CONFIG_SND=y CONFIG_SND_TIMER=y CONFIG_SND_PCM=y CONFIG_SND_HWDEP=y CONFIG_SND_RAWMIDI=y CONFIG_SND_JACK=y # CONFIG_SND_SEQUENCER is not set # CONFIG_SND_MIXER_OSS is not set # CONFIG_SND_PCM_OSS is not set # CONFIG_SND_HRTIMER is not set # CONFIG_SND_DYNAMIC_MINORS is not set CONFIG_SND_SUPPORT_OLD_API=y CONFIG_SND_VERBOSE_PROCFS=y # CONFIG_SND_VERBOSE_PRINTK is not set # CONFIG_SND_DEBUG is not set # CONFIG_SND_RAWMIDI_SEQ is not set # CONFIG_SND_OPL3_LIB_SEQ is not set # CONFIG_SND_OPL4_LIB_SEQ is not set # CONFIG_SND_SBAWE_SEQ is not set # CONFIG_SND_EMU10K1_SEQ is not set # CONFIG_SND_DRIVERS is not set CONFIG_SND_PCI=y # CONFIG_SND_AD1889 is not set # CONFIG_SND_ALS300 is not set # CONFIG_SND_ALI5451 is not set # CONFIG_SND_ATIIXP is not set # CONFIG_SND_ATIIXP_MODEM is not set # CONFIG_SND_AU8810 is not set # CONFIG_SND_AU8820 is not set # CONFIG_SND_AU8830 is not set # CONFIG_SND_AW2 is not set # CONFIG_SND_AZT3328 is not set # CONFIG_SND_BT87X is not set # CONFIG_SND_CA0106 is not set # CONFIG_SND_CMIPCI is not set # CONFIG_SND_OXYGEN is not set # CONFIG_SND_CS4281 is not set # CONFIG_SND_CS46XX is not set # CONFIG_SND_CS5535AUDIO is not set # CONFIG_SND_CTXFI is not set # CONFIG_SND_DARLA20 is not set # CONFIG_SND_GINA20 is not set # CONFIG_SND_LAYLA20 is not set # CONFIG_SND_DARLA24 is not set # CONFIG_SND_GINA24 is not set # CONFIG_SND_LAYLA24 is not set # CONFIG_SND_MONA is not set # CONFIG_SND_MIA is not set # CONFIG_SND_ECHO3G is not set # CONFIG_SND_INDIGO is not set # CONFIG_SND_INDIGOIO is not set # CONFIG_SND_INDIGODJ is not set # CONFIG_SND_INDIGOIOX is not set # CONFIG_SND_INDIGODJX is not set # CONFIG_SND_EMU10K1 is not set # CONFIG_SND_EMU10K1X is not set # CONFIG_SND_ENS1370 is not set # CONFIG_SND_ENS1371 is not set # CONFIG_SND_ES1938 is not set # CONFIG_SND_ES1968 is not set # CONFIG_SND_FM801 is not set # CONFIG_SND_HDA_INTEL is not set # CONFIG_SND_HDSP is not set # CONFIG_SND_HDSPM is not set # CONFIG_SND_HIFIER is not set # CONFIG_SND_ICE1712 is not set # CONFIG_SND_ICE1724 is not set # CONFIG_SND_INTEL8X0 is not set # CONFIG_SND_INTEL8X0M is not set # CONFIG_SND_KORG1212 is not set # CONFIG_SND_LX6464ES is not set # CONFIG_SND_MAESTRO3 is not set # CONFIG_SND_MIXART is not set # CONFIG_SND_NM256 is not set # CONFIG_SND_PCXHR is not set # CONFIG_SND_RIPTIDE is not set # CONFIG_SND_RME32 is not set # CONFIG_SND_RME96 is not set # CONFIG_SND_RME9652 is not set # CONFIG_SND_SONICVIBES is not set # CONFIG_SND_TRIDENT is not set # CONFIG_SND_VIA82XX is not set # CONFIG_SND_VIA82XX_MODEM is not set # CONFIG_SND_VIRTUOSO is not set # CONFIG_SND_VX222 is not set # CONFIG_SND_YMFPCI is not set # CONFIG_SND_ARM is not set # CONFIG_SND_SPI is not set CONFIG_SND_USB=y CONFIG_SND_USB_AUDIO=y # CONFIG_SND_USB_UA101 is not set # CONFIG_SND_USB_CAIAQ is not set CONFIG_SND_SOC=y CONFIG_SND_TI81XX_SOC=y CONFIG_SND_DAVINCI_SOC_MCASP=y CONFIG_SND_SOC_TVP5158_AUDIO=y # CONFIG_SND_TI81XX_SOC_EVM is not set CONFIG_SND_SOC_TI81XX_HDMI=y CONFIG_SND_TI81XX_SOC_DVR=y # CONFIG_SND_OMAP_SOC is not set CONFIG_SND_SOC_I2C_AND_SPI=y # CONFIG_SND_SOC_ALL_CODECS is not set CONFIG_SND_SOC_TLV320AIC3X=y # CONFIG_SOUND_PRIME is not set CONFIG_HID_SUPPORT=y CONFIG_HID=y # CONFIG_HIDRAW is not set # # USB Input Devices # CONFIG_USB_HID=y # CONFIG_HID_PID is not set # CONFIG_USB_HIDDEV is not set # # Special HID drivers # # CONFIG_HID_3M_PCT is not set CONFIG_HID_A4TECH=y # CONFIG_HID_ACRUX_FF is not set CONFIG_HID_APPLE=y CONFIG_HID_BELKIN=y # CONFIG_HID_CANDO is not set CONFIG_HID_CHERRY=y CONFIG_HID_CHICONY=y # CONFIG_HID_PRODIKEYS is not set CONFIG_HID_CYPRESS=y # CONFIG_HID_DRAGONRISE is not set # CONFIG_HID_EGALAX is not set CONFIG_HID_EZKEY=y CONFIG_HID_KYE=y # CONFIG_HID_UCLOGIC is not set # CONFIG_HID_WALTOP is not set # CONFIG_HID_GYRATION is not set # CONFIG_HID_TWINHAN is not set CONFIG_HID_KENSINGTON=y CONFIG_HID_LOGITECH=y # CONFIG_LOGITECH_FF is not set # CONFIG_LOGIRUMBLEPAD2_FF is not set # CONFIG_LOGIG940_FF is not set # CONFIG_LOGIWII_FF is not set CONFIG_HID_MICROSOFT=y # CONFIG_HID_MOSART is not set CONFIG_HID_MONTEREY=y # CONFIG_HID_NTRIG is not set # CONFIG_HID_ORTEK is not set # CONFIG_HID_PANTHERLORD is not set # CONFIG_HID_PETALYNX is not set # CONFIG_HID_PICOLCD is not set # CONFIG_HID_QUANTA is not set # CONFIG_HID_ROCCAT is not set # CONFIG_HID_ROCCAT_KONE is not set # CONFIG_HID_ROCCAT_PYRA is not set # CONFIG_HID_SAMSUNG is not set # CONFIG_HID_SONY is not set # CONFIG_HID_STANTUM is not set # CONFIG_HID_SUNPLUS is not set # CONFIG_HID_GREENASIA is not set # CONFIG_HID_SMARTJOYPLUS is not set # CONFIG_HID_TOPSEED is not set # CONFIG_HID_THRUSTMASTER is not set # CONFIG_HID_ZEROPLUS is not set # CONFIG_HID_ZYDACRON is not set CONFIG_USB_SUPPORT=y CONFIG_USB_ARCH_HAS_HCD=y CONFIG_USB_ARCH_HAS_OHCI=y CONFIG_USB_ARCH_HAS_EHCI=y CONFIG_USB=y # CONFIG_USB_DEBUG is not set CONFIG_USB_ANNOUNCE_NEW_DEVICES=y # # Miscellaneous USB options # CONFIG_USB_DEVICEFS=y CONFIG_USB_DEVICE_CLASS=y # CONFIG_USB_DYNAMIC_MINORS is not set CONFIG_USB_SUSPEND=y # CONFIG_USB_OTG is not set # CONFIG_USB_MON is not set # CONFIG_USB_WUSB is not set # CONFIG_USB_WUSB_CBAF is not set # # USB Host Controller Drivers # # CONFIG_USB_C67X00_HCD is not set # CONFIG_USB_XHCI_HCD is not set # CONFIG_USB_EHCI_HCD is not set # CONFIG_USB_OXU210HP_HCD is not set # CONFIG_USB_ISP116X_HCD is not set # CONFIG_USB_ISP1760_HCD is not set # CONFIG_USB_ISP1362_HCD is not set # CONFIG_USB_OHCI_HCD is not set # CONFIG_USB_UHCI_HCD is not set # CONFIG_USB_SL811_HCD is not set # CONFIG_USB_R8A66597_HCD is not set # CONFIG_USB_WHCI_HCD is not set # CONFIG_USB_HWA_HCD is not set CONFIG_USB_MUSB_HDRC=y # # Platform Glue Layer # # CONFIG_USB_MUSB_TUSB6010_GLUE is not set # CONFIG_USB_MUSB_OMAP2PLUS_GLUE is not set # CONFIG_USB_MUSB_AM35X_GLUE is not set CONFIG_USB_MUSB_TI81XX_GLUE=y # CONFIG_USB_MUSB_DAVINCI is not set # CONFIG_USB_MUSB_DA8XX is not set # CONFIG_USB_MUSB_TUSB6010 is not set # CONFIG_USB_MUSB_OMAP2PLUS is not set # CONFIG_USB_MUSB_AM35X is not set CONFIG_USB_MUSB_TI81XX=y # CONFIG_USB_MUSB_BLACKFIN is not set # CONFIG_USB_MUSB_UX500 is not set CONFIG_USB_TI81XX_USBID_CTRL_SW=y # CONFIG_USB_TI81XX_USBID_CTRL_HW is not set CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_HDRC_HCD=y # CONFIG_MUSB_PIO_ONLY is not set # CONFIG_USB_INVENTRA_DMA_HW is not set # CONFIG_USB_TI_CPPI_DMA_HW is not set CONFIG_USB_TI_CPPI41_DMA_HW=y # CONFIG_USB_INVENTRA_DMA is not set # CONFIG_USB_TI_CPPI_DMA is not set CONFIG_USB_TI_CPPI41_DMA=y # CONFIG_USB_TUSB_OMAP_DMA is not set CONFIG_USB_MUSB_DEBUG=y # # USB Device Class drivers # # CONFIG_USB_ACM is not set # CONFIG_USB_PRINTER is not set # CONFIG_USB_WDM is not set # CONFIG_USB_TMC is not set # # NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may # # # also be needed; see USB_STORAGE Help for more info # CONFIG_USB_STORAGE=y # CONFIG_USB_STORAGE_DEBUG is not set # CONFIG_USB_STORAGE_DATAFAB is not set # CONFIG_USB_STORAGE_FREECOM is not set # CONFIG_USB_STORAGE_ISD200 is not set # CONFIG_USB_STORAGE_USBAT is not set # CONFIG_USB_STORAGE_SDDR09 is not set # CONFIG_USB_STORAGE_SDDR55 is not set # CONFIG_USB_STORAGE_JUMPSHOT is not set # CONFIG_USB_STORAGE_ALAUDA is not set # CONFIG_USB_STORAGE_ONETOUCH is not set # CONFIG_USB_STORAGE_KARMA is not set # CONFIG_USB_STORAGE_CYPRESS_ATACB is not set # CONFIG_USB_UAS is not set # CONFIG_USB_LIBUSUAL is not set # # USB Imaging devices # # CONFIG_USB_MDC800 is not set # CONFIG_USB_MICROTEK is not set # # USB port drivers # # CONFIG_USB_SERIAL is not set # # USB Miscellaneous drivers # # CONFIG_USB_EMI62 is not set # CONFIG_USB_EMI26 is not set # CONFIG_USB_ADUTUX is not set # CONFIG_USB_SEVSEG is not set # CONFIG_USB_RIO500 is not set # CONFIG_USB_LEGOTOWER is not set # CONFIG_USB_LCD is not set # CONFIG_USB_LED is not set # CONFIG_USB_CYPRESS_CY7C63 is not set # CONFIG_USB_CYTHERM is not set # CONFIG_USB_IDMOUSE is not set # CONFIG_USB_FTDI_ELAN is not set # CONFIG_USB_APPLEDISPLAY is not set # CONFIG_USB_SISUSBVGA is not set # CONFIG_USB_LD is not set # CONFIG_USB_TRANCEVIBRATOR is not set # CONFIG_USB_IOWARRIOR is not set # CONFIG_USB_TEST is not set # CONFIG_USB_ISIGHTFW is not set # CONFIG_USB_YUREX is not set # CONFIG_USB_GADGET is not set # # OTG and related infrastructure # CONFIG_USB_OTG_UTILS=y # CONFIG_USB_GPIO_VBUS is not set # CONFIG_USB_ULPI is not set CONFIG_NOP_USB_XCEIV=y # CONFIG_UWB is not set CONFIG_MMC=y # CONFIG_MMC_DEBUG is not set # CONFIG_MMC_UNSAFE_RESUME is not set # # MMC/SD/SDIO Card Drivers # CONFIG_MMC_BLOCK=y CONFIG_MMC_BLOCK_MINORS=8 CONFIG_MMC_BLOCK_BOUNCE=y # CONFIG_SDIO_UART is not set # CONFIG_MMC_TEST is not set # # MMC/SD/SDIO Host Controller Drivers # # CONFIG_MMC_SDHCI is not set # CONFIG_MMC_OMAP is not set CONFIG_MMC_OMAP_HS=y # CONFIG_MMC_TIFM_SD is not set # CONFIG_MMC_CB710 is not set # CONFIG_MMC_VIA_SDMMC is not set # CONFIG_MMC_USHC is not set # CONFIG_MEMSTICK is not set # CONFIG_NEW_LEDS is not set # CONFIG_ACCESSIBILITY is not set # CONFIG_INFINIBAND is not set CONFIG_RTC_LIB=y CONFIG_RTC_CLASS=y CONFIG_RTC_HCTOSYS=y CONFIG_RTC_HCTOSYS_DEVICE="rtc0" # CONFIG_RTC_DEBUG is not set # # RTC interfaces # CONFIG_RTC_INTF_SYSFS=y CONFIG_RTC_INTF_PROC=y CONFIG_RTC_INTF_DEV=y # CONFIG_RTC_INTF_DEV_UIE_EMUL is not set # CONFIG_RTC_DRV_TEST is not set # # I2C RTC drivers # CONFIG_RTC_DRV_DS1307=y # CONFIG_RTC_DRV_DS1374 is not set # CONFIG_RTC_DRV_DS1672 is not set # CONFIG_RTC_DRV_DS3232 is not set # CONFIG_RTC_DRV_MAX6900 is not set # CONFIG_RTC_DRV_RS5C372 is not set # CONFIG_RTC_DRV_ISL1208 is not set # CONFIG_RTC_DRV_ISL12022 is not set # CONFIG_RTC_DRV_X1205 is not set # CONFIG_RTC_DRV_PCF8563 is not set # CONFIG_RTC_DRV_PCF8583 is not set # CONFIG_RTC_DRV_M41T80 is not set # CONFIG_RTC_DRV_BQ32K is not set # CONFIG_RTC_DRV_S35390A is not set # CONFIG_RTC_DRV_FM3130 is not set # CONFIG_RTC_DRV_RX8581 is not set # CONFIG_RTC_DRV_RX8025 is not set # # SPI RTC drivers # # CONFIG_RTC_DRV_M41T94 is not set # CONFIG_RTC_DRV_DS1305 is not set # CONFIG_RTC_DRV_DS1390 is not set # CONFIG_RTC_DRV_MAX6902 is not set # CONFIG_RTC_DRV_R9701 is not set # CONFIG_RTC_DRV_RS5C348 is not set # CONFIG_RTC_DRV_DS3234 is not set # CONFIG_RTC_DRV_PCF2123 is not set # # Platform RTC drivers # # CONFIG_RTC_DRV_CMOS is not set # CONFIG_RTC_DRV_DS1286 is not set # CONFIG_RTC_DRV_DS1511 is not set # CONFIG_RTC_DRV_DS1553 is not set # CONFIG_RTC_DRV_DS1742 is not set # CONFIG_RTC_DRV_STK17TA8 is not set # CONFIG_RTC_DRV_M48T86 is not set # CONFIG_RTC_DRV_M48T35 is not set # CONFIG_RTC_DRV_M48T59 is not set # CONFIG_RTC_DRV_MSM6242 is not set # CONFIG_RTC_DRV_BQ4802 is not set # CONFIG_RTC_DRV_RP5C01 is not set # CONFIG_RTC_DRV_V3020 is not set # # on-CPU RTC drivers # CONFIG_RTC_DRV_OMAP=y # CONFIG_DMADEVICES is not set # CONFIG_AUXDISPLAY is not set # CONFIG_UIO is not set # CONFIG_STAGING is not set CONFIG_Sys_Link=y CONFIG_SYSLINK_MULTIPROC=y CONFIG_SYSLINK_NOTIFY=y # # File systems # CONFIG_EXT2_FS=y CONFIG_EXT2_FS_XATTR=y CONFIG_EXT2_FS_POSIX_ACL=y CONFIG_EXT2_FS_SECURITY=y # CONFIG_EXT2_FS_XIP is not set CONFIG_EXT3_FS=y # CONFIG_EXT3_DEFAULTS_TO_ORDERED is not set CONFIG_EXT3_FS_XATTR=y CONFIG_EXT3_FS_POSIX_ACL=y CONFIG_EXT3_FS_SECURITY=y # CONFIG_EXT4_FS is not set CONFIG_JBD=y # CONFIG_JBD_DEBUG is not set CONFIG_FS_MBCACHE=y # CONFIG_REISERFS_FS is not set # CONFIG_JFS_FS is not set CONFIG_FS_POSIX_ACL=y # CONFIG_XFS_FS is not set # CONFIG_OCFS2_FS is not set # CONFIG_BTRFS_FS is not set # CONFIG_NILFS2_FS is not set CONFIG_FILE_LOCKING=y # CONFIG_FSNOTIFY is not set # CONFIG_DNOTIFY is not set # CONFIG_INOTIFY_USER is not set # CONFIG_FANOTIFY is not set # CONFIG_QUOTA is not set # CONFIG_QUOTACTL is not set # CONFIG_AUTOFS4_FS is not set # CONFIG_FUSE_FS is not set # # Caches # # CONFIG_FSCACHE is not set # # CD-ROM/DVD Filesystems # CONFIG_ISO9660_FS=y # CONFIG_JOLIET is not set # CONFIG_ZISOFS is not set # CONFIG_UDF_FS is not set # # DOS/FAT/NT Filesystems # CONFIG_FAT_FS=y CONFIG_MSDOS_FS=y CONFIG_VFAT_FS=y CONFIG_FAT_DEFAULT_CODEPAGE=437 CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1" # CONFIG_NTFS_FS is not set # # Pseudo filesystems # CONFIG_PROC_FS=y CONFIG_PROC_SYSCTL=y CONFIG_PROC_PAGE_MONITOR=y CONFIG_SYSFS=y CONFIG_TMPFS=y # CONFIG_TMPFS_POSIX_ACL is not set # CONFIG_HUGETLB_PAGE is not set # CONFIG_CONFIGFS_FS is not set CONFIG_MISC_FILESYSTEMS=y # CONFIG_ADFS_FS is not set # CONFIG_AFFS_FS is not set # CONFIG_ECRYPT_FS is not set # CONFIG_HFS_FS is not set # CONFIG_HFSPLUS_FS is not set # CONFIG_BEFS_FS is not set # CONFIG_BFS_FS is not set # CONFIG_EFS_FS is not set CONFIG_JFFS2_FS=y CONFIG_JFFS2_FS_DEBUG=0 CONFIG_JFFS2_FS_WRITEBUFFER=y CONFIG_JFFS2_FS_WBUF_VERIFY=y # CONFIG_JFFS2_SUMMARY is not set # CONFIG_JFFS2_FS_XATTR is not set # CONFIG_JFFS2_COMPRESSION_OPTIONS is not set CONFIG_JFFS2_ZLIB=y # CONFIG_JFFS2_LZO is not set CONFIG_JFFS2_RTIME=y # CONFIG_JFFS2_RUBIN is not set CONFIG_UBIFS_FS=y # CONFIG_UBIFS_FS_XATTR is not set # CONFIG_UBIFS_FS_ADVANCED_COMPR is not set CONFIG_UBIFS_FS_LZO=y CONFIG_UBIFS_FS_ZLIB=y CONFIG_UBIFS_FS_DEBUG=y # CONFIG_LOGFS is not set CONFIG_CRAMFS=y # CONFIG_SQUASHFS is not set # CONFIG_VXFS_FS is not set # CONFIG_MINIX_FS is not set # CONFIG_OMFS_FS is not set # CONFIG_HPFS_FS is not set # CONFIG_QNX4FS_FS is not set # CONFIG_ROMFS_FS is not set # CONFIG_SYSV_FS is not set # CONFIG_UFS_FS is not set CONFIG_NETWORK_FILESYSTEMS=y CONFIG_NFS_FS=y CONFIG_NFS_V3=y # CONFIG_NFS_V3_ACL is not set # CONFIG_NFS_V4 is not set CONFIG_ROOT_NFS=y # CONFIG_NFSD is not set CONFIG_LOCKD=y CONFIG_LOCKD_V4=y CONFIG_NFS_COMMON=y CONFIG_SUNRPC=y # CONFIG_RPCSEC_GSS_KRB5 is not set # CONFIG_CEPH_FS is not set # CONFIG_CIFS is not set # CONFIG_NCP_FS is not set # CONFIG_CODA_FS is not set # CONFIG_AFS_FS is not set # # Partition Types # # CONFIG_PARTITION_ADVANCED is not set CONFIG_MSDOS_PARTITION=y CONFIG_NLS=y CONFIG_NLS_DEFAULT="utf8" CONFIG_NLS_CODEPAGE_437=y # CONFIG_NLS_CODEPAGE_737 is not set # CONFIG_NLS_CODEPAGE_775 is not set # CONFIG_NLS_CODEPAGE_850 is not set # CONFIG_NLS_CODEPAGE_852 is not set # CONFIG_NLS_CODEPAGE_855 is not set # CONFIG_NLS_CODEPAGE_857 is not set # CONFIG_NLS_CODEPAGE_860 is not set # CONFIG_NLS_CODEPAGE_861 is not set # CONFIG_NLS_CODEPAGE_862 is not set # CONFIG_NLS_CODEPAGE_863 is not set # CONFIG_NLS_CODEPAGE_864 is not set # CONFIG_NLS_CODEPAGE_865 is not set # CONFIG_NLS_CODEPAGE_866 is not set # CONFIG_NLS_CODEPAGE_869 is not set # CONFIG_NLS_CODEPAGE_936 is not set # CONFIG_NLS_CODEPAGE_950 is not set # CONFIG_NLS_CODEPAGE_932 is not set # CONFIG_NLS_CODEPAGE_949 is not set # CONFIG_NLS_CODEPAGE_874 is not set # CONFIG_NLS_ISO8859_8 is not set # CONFIG_NLS_CODEPAGE_1250 is not set # CONFIG_NLS_CODEPAGE_1251 is not set CONFIG_NLS_ASCII=y CONFIG_NLS_ISO8859_1=y # CONFIG_NLS_ISO8859_2 is not set # CONFIG_NLS_ISO8859_3 is not set # CONFIG_NLS_ISO8859_4 is not set # CONFIG_NLS_ISO8859_5 is not set # CONFIG_NLS_ISO8859_6 is not set # CONFIG_NLS_ISO8859_7 is not set # CONFIG_NLS_ISO8859_9 is not set # CONFIG_NLS_ISO8859_13 is not set # CONFIG_NLS_ISO8859_14 is not set # CONFIG_NLS_ISO8859_15 is not set # CONFIG_NLS_KOI8_R is not set # CONFIG_NLS_KOI8_U is not set CONFIG_NLS_UTF8=y # CONFIG_DLM is not set # # Kernel hacking # # CONFIG_PRINTK_TIME is not set CONFIG_ENABLE_WARN_DEPRECATED=y CONFIG_ENABLE_MUST_CHECK=y CONFIG_FRAME_WARN=1024 CONFIG_MAGIC_SYSRQ=y # CONFIG_STRIP_ASM_SYMS is not set # CONFIG_UNUSED_SYMBOLS is not set CONFIG_DEBUG_FS=y # CONFIG_HEADERS_CHECK is not set CONFIG_DEBUG_KERNEL=y # CONFIG_DEBUG_SHIRQ is not set # CONFIG_LOCKUP_DETECTOR is not set # CONFIG_HARDLOCKUP_DETECTOR is not set # CONFIG_DETECT_HUNG_TASK is not set # CONFIG_SCHED_DEBUG is not set # CONFIG_SCHEDSTATS is not set # CONFIG_TIMER_STATS is not set # CONFIG_DEBUG_OBJECTS is not set # CONFIG_SLUB_DEBUG_ON is not set # CONFIG_SLUB_STATS is not set # CONFIG_DEBUG_KMEMLEAK is not set # CONFIG_DEBUG_RT_MUTEXES is not set # CONFIG_RT_MUTEX_TESTER is not set # CONFIG_DEBUG_SPINLOCK is not set # CONFIG_DEBUG_MUTEXES is not set CONFIG_BKL=y # CONFIG_DEBUG_LOCK_ALLOC is not set # CONFIG_PROVE_LOCKING is not set # CONFIG_SPARSE_RCU_POINTER is not set # CONFIG_LOCK_STAT is not set # CONFIG_DEBUG_SPINLOCK_SLEEP is not set # CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set # CONFIG_DEBUG_KOBJECT is not set # CONFIG_DEBUG_HIGHMEM is not set CONFIG_DEBUG_BUGVERBOSE=y # CONFIG_DEBUG_INFO is not set # CONFIG_DEBUG_VM is not set # CONFIG_DEBUG_WRITECOUNT is not set CONFIG_DEBUG_MEMORY_INIT=y # CONFIG_DEBUG_LIST is not set # CONFIG_TEST_LIST_SORT is not set # CONFIG_DEBUG_SG is not set # CONFIG_DEBUG_NOTIFIERS is not set # CONFIG_DEBUG_CREDENTIALS is not set CONFIG_FRAME_POINTER=y # CONFIG_BOOT_PRINTK_DELAY is not set # CONFIG_RCU_TORTURE_TEST is not set # CONFIG_KPROBES_SANITY_TEST is not set # CONFIG_BACKTRACE_SELF_TEST is not set # CONFIG_DEBUG_BLOCK_EXT_DEVT is not set # CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set # CONFIG_LKDTM is not set # CONFIG_FAULT_INJECTION is not set # CONFIG_LATENCYTOP is not set # CONFIG_SYSCTL_SYSCALL_CHECK is not set # CONFIG_PAGE_POISONING is not set CONFIG_HAVE_FUNCTION_TRACER=y CONFIG_HAVE_DYNAMIC_FTRACE=y CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y CONFIG_TRACING_SUPPORT=y # CONFIG_FTRACE is not set # CONFIG_DYNAMIC_DEBUG is not set # CONFIG_ATOMIC64_SELFTEST is not set # CONFIG_SAMPLES is not set CONFIG_HAVE_ARCH_KGDB=y # CONFIG_KGDB is not set # CONFIG_STRICT_DEVMEM is not set # CONFIG_ARM_UNWIND is not set # CONFIG_DEBUG_USER is not set # CONFIG_DEBUG_ERRORS is not set # CONFIG_DEBUG_STACK_USAGE is not set CONFIG_DEBUG_LL=y CONFIG_EARLY_PRINTK=y # CONFIG_DEBUG_ICEDCC is not set # CONFIG_OC_ETM is not set # # Security options # CONFIG_KEYS=y CONFIG_KEYS_DEBUG_PROC_KEYS=y # CONFIG_SECURITY_DMESG_RESTRICT is not set CONFIG_SECURITY=y # CONFIG_SECURITYFS is not set CONFIG_SECURITY_NETWORK=y # CONFIG_SECURITY_NETWORK_XFRM is not set # CONFIG_SECURITY_PATH is not set # CONFIG_SECURITY_TOMOYO is not set # CONFIG_SECURITY_APPARMOR is not set # CONFIG_IMA is not set CONFIG_DEFAULT_SECURITY_DAC=y CONFIG_DEFAULT_SECURITY="" CONFIG_CRYPTO=y # # Crypto core or helper # CONFIG_CRYPTO_ALGAPI=y CONFIG_CRYPTO_ALGAPI2=y # CONFIG_CRYPTO_MANAGER is not set # CONFIG_CRYPTO_MANAGER2 is not set # CONFIG_CRYPTO_GF128MUL is not set # CONFIG_CRYPTO_NULL is not set # CONFIG_CRYPTO_CRYPTD is not set # CONFIG_CRYPTO_AUTHENC is not set # CONFIG_CRYPTO_TEST is not set # # Authenticated Encryption with Associated Data # # CONFIG_CRYPTO_CCM is not set # CONFIG_CRYPTO_GCM is not set # CONFIG_CRYPTO_SEQIV is not set # # Block modes # # CONFIG_CRYPTO_CBC is not set # CONFIG_CRYPTO_CTR is not set # CONFIG_CRYPTO_CTS is not set # CONFIG_CRYPTO_ECB is not set # CONFIG_CRYPTO_LRW is not set # CONFIG_CRYPTO_PCBC is not set # CONFIG_CRYPTO_XTS is not set # # Hash modes # # CONFIG_CRYPTO_HMAC is not set # CONFIG_CRYPTO_XCBC is not set # CONFIG_CRYPTO_VMAC is not set # # Digest # # CONFIG_CRYPTO_CRC32C is not set # CONFIG_CRYPTO_GHASH is not set # CONFIG_CRYPTO_MD4 is not set # CONFIG_CRYPTO_MD5 is not set # CONFIG_CRYPTO_MICHAEL_MIC is not set # CONFIG_CRYPTO_RMD128 is not set # CONFIG_CRYPTO_RMD160 is not set # CONFIG_CRYPTO_RMD256 is not set # CONFIG_CRYPTO_RMD320 is not set # CONFIG_CRYPTO_SHA1 is not set # CONFIG_CRYPTO_SHA256 is not set # CONFIG_CRYPTO_SHA512 is not set # CONFIG_CRYPTO_TGR192 is not set # CONFIG_CRYPTO_WP512 is not set # # Ciphers # # CONFIG_CRYPTO_AES is not set # CONFIG_CRYPTO_ANUBIS is not set # CONFIG_CRYPTO_ARC4 is not set # CONFIG_CRYPTO_BLOWFISH is not set # CONFIG_CRYPTO_CAMELLIA is not set # CONFIG_CRYPTO_CAST5 is not set # CONFIG_CRYPTO_CAST6 is not set # CONFIG_CRYPTO_DES is not set # CONFIG_CRYPTO_FCRYPT is not set # CONFIG_CRYPTO_KHAZAD is not set # CONFIG_CRYPTO_SALSA20 is not set # CONFIG_CRYPTO_SEED is not set # CONFIG_CRYPTO_SERPENT is not set # CONFIG_CRYPTO_TEA is not set # CONFIG_CRYPTO_TWOFISH is not set # # Compression # CONFIG_CRYPTO_DEFLATE=y # CONFIG_CRYPTO_ZLIB is not set CONFIG_CRYPTO_LZO=y # # Random Number Generation # # CONFIG_CRYPTO_ANSI_CPRNG is not set # CONFIG_CRYPTO_HW is not set # CONFIG_BINARY_PRINTF is not set # # Library routines # CONFIG_BITREVERSE=y CONFIG_GENERIC_FIND_LAST_BIT=y # CONFIG_CRC_CCITT is not set CONFIG_CRC16=y # CONFIG_CRC_T10DIF is not set # CONFIG_CRC_ITU_T is not set CONFIG_CRC32=y # CONFIG_CRC7 is not set # CONFIG_LIBCRC32C is not set CONFIG_ZLIB_INFLATE=y CONFIG_ZLIB_DEFLATE=y CONFIG_LZO_COMPRESS=y CONFIG_LZO_DECOMPRESS=y CONFIG_DECOMPRESS_GZIP=y CONFIG_DECOMPRESS_BZIP2=y CONFIG_DECOMPRESS_LZMA=y CONFIG_DECOMPRESS_LZO=y CONFIG_HAS_IOMEM=y CONFIG_HAS_IOPORT=y CONFIG_HAS_DMA=y CONFIG_NLATTR=y
### log files:
U-Boot 2010.06 (Sep 30 2011 - 00:58:16) TI8168-GP rev 1.2 ARM clk: 987MHz DDR clk: 796MHz I2C: ready DRAM: 2 GiB NAND: 128 MiB Net: Ethernet PHY: GENERIC @ 0x01 DaVinci EMAC Hit any key to stop autoboot: 0 NAND read: device 0 offset 0x800000, size 0x300000 3145728 bytes read: OK NAND read: device 0 offset 0x1140000, size 0xe00000 14680064 bytes read: OK ## Booting kernel from Legacy Image at 81000000 ... Image Name: Linux-2.6.37 Created: 2012-06-08 14:39:46 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2661808 Bytes = 2.5 MiB Load Address: 80008000 Entry Point: 80008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ... Linux version 2.6.37 (cglin@cglin-desktop) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #3 Fri Jun 8 22:39:35 CST 2012 CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache Machine: ti8168_dvr vram size = 20971520 at 0x0 reserved size = 20971520 at 0x0 FB: Reserving 20971520 bytes SDRAM for VRAM Memory policy: ECC disabled, Data cache writeback OMAP chip is TI8168 2.0 Built 1 zonelists in Zone order, mobility grouping on. Total pages: 59904 Kernel command line: mem=256M console=ttyO2,115200n8 root=/dev/ram0 ro initrd=0x82000000,16M ramdisk_size=16000 ip=192.168.1.138:192.168.1.136:192.168.0.1:255.255.252.0::eth0:off vram=20M notifyk.vpssm3_sva=0xBFD00000 PID hash table entries: 1024 (order: 0, 4096 bytes) Dentry cache hash table entries: 32768 (order: 5, 131072 bytes) Inode-cache hash table entries: 16384 (order: 4, 65536 bytes) Memory: 236MB = 236MB total Memory: 217280k/217280k available, 44864k reserved, 0K highmem Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) DMA : 0xffc00000 - 0xffe00000 ( 2 MB) vmalloc : 0xd0800000 - 0xf8000000 ( 632 MB) lowmem : 0xc0000000 - 0xd0000000 ( 256 MB) modules : 0xbf000000 - 0xc0000000 ( 16 MB) .init : 0xc0008000 - 0xc0039000 ( 196 kB) .text : 0xc0039000 - 0xc050b000 (4936 kB) .data : 0xc050c000 - 0xc0554800 ( 290 kB) SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 NR_IRQS:407 IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts Total of 128 interrupts on 1 active controller GPMC revision 6.0 Trying to install interrupt handler for IRQ400 Trying to install interrupt handler for IRQ401 Trying to install interrupt handler for IRQ402 Trying to install interrupt handler for IRQ403 Trying to install interrupt handler for IRQ404 Trying to install interrupt handler for IRQ405 Trying to install interrupt handler for IRQ406 Trying to install type control for IRQ407 Trying to set irq flags for IRQ407 OMAP clockevent source: GPTIMER1 at 27000000 Hz Console: colour dummy device 80x30 Calibrating delay loop... 986.31 BogoMIPS (lpj=4931584) pid_max: default: 32768 minimum: 301 Security Framework initialized Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok devtmpfs: initialized omap_voltage_early_init: voltage driver support not added regulator: core version 0.5 regulator: dummy: NET: Registered protocol family 16 OMAP GPIO hardware version 0.1 OMAP GPIO hardware version 0.1 omap_mux_init: Add partition: #1: core, flags: 0 3-wired eeprom init done. (H/W ver:00) _omap_mux_get_by_name: Could not find signal i2c2_scl.i2c2_scl _omap_mux_get_by_name: Could not find signal i2c2_sda.i2c2_sda registered ti816x_vpss device registered TI816x on-chip HDMI device registered ti81xx_vidout device pm_dbg_init: only OMAP3 supported ti81xx_pcie: Invoking PCI BIOS... ti81xx_pcie: Setting up Host Controller... ti81xx_pcie: Register base mapped @0xd0820000 ti81xx_pcie: Starting PCI scan... PCI: bus0: Fast back to back transfers disabled PCI: bus1: Fast back to back transfers disabled pci 0000:00:00.0: BAR 8: assigned [mem 0x20000000-0x200fffff] pci 0000:00:00.0: BAR 9: assigned [mem 0x20100000-0x201fffff pref] pci 0000:00:00.0: BAR 7: can't assign io (size 0x1000) pci 0000:01:00.0: BAR 6: assigned [mem 0x20100000-0x2017ffff pref] pci 0000:01:00.0: BAR 2: assigned [mem 0x20000000-0x20003fff 64bit] pci 0000:01:00.0: BAR 2: set to [mem 0x20000000-0x20003fff 64bit] (PCI address [0x20000000-0x20003fff]) pci 0000:01:00.0: BAR 0: assigned [mem 0x20004000-0x2000407f 64bit] pci 0000:01:00.0: BAR 0: set to [mem 0x20004000-0x2000407f 64bit] (PCI address [0x20004000-0x2000407f]) pci 0000:01:00.0: BAR 4: can't assign io (size 0x80) pci 0000:00:00.0: PCI bridge to [bus 01-01] pci 0000:00:00.0: bridge window [io disabled] pci 0000:00:00.0: bridge window [mem 0x20000000-0x200fffff] pci 0000:00:00.0: bridge window [mem 0x20100000-0x201fffff pref] PCI: enabling device 0000:00:00.0 (0140 -> 0143) bio: create slab <bio-0> at 0 vgaarb: loaded SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb registerd cppi-dma Intr @ IRQ 17 Cppi41 Init Done omap_i2c omap_i2c.1: bus 1 rev4.0 at 400 kHz omap_i2c omap_i2c.2: bus 2 rev4.0 at 400 kHz Advanced Linux Sound Architecture Driver Version 1.0.23. Switching to clocksource gp timer musb-hdrc: version 6.0, host, debug=0 musb-hdrc musb-hdrc.0: dma type: dma-cppi41 musb-hdrc musb-hdrc.0: MUSB HDRC host driver musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1 usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb1: Product: MUSB HDRC host driver usb usb1: Manufacturer: Linux 2.6.37 musb-hcd usb usb1: SerialNumber: musb-hdrc.0 hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected musb-hdrc musb-hdrc.0: USB Host mode controller at d081e000 using DMA, IRQ 18 musb-hdrc musb-hdrc.1: dma type: dma-cppi41 musb-hdrc musb-hdrc.1: MUSB HDRC host driver musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2 usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb2: Product: MUSB HDRC host driver usb usb2: Manufacturer: Linux 2.6.37 musb-hcd usb usb2: SerialNumber: musb-hdrc.1 hub 2-0:1.0: USB hub found hub 2-0:1.0: 1 port detected musb-hdrc musb-hdrc.1: USB Host mode controller at d0826800 using DMA, IRQ 19 NET: Registered protocol family 2 IP route cache hash table entries: 2048 (order: 1, 8192 bytes) TCP established hash table entries: 8192 (order: 4, 65536 bytes) TCP bind hash table entries: 8192 (order: 3, 32768 bytes) TCP: Hash tables configured (established 8192 bind 8192) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. Trying to unpack rootfs image as initramfs... rootfs image is not initramfs (junk in compressed archive); looks like an initrd Freeing initrd memory: 16384K NetWinder Floating Point Emulator V0.97 (double precision) PMU: registered new PMU device of type 0 omap-iommu omap-iommu.0: ducati registered omap-iommu omap-iommu.1: sys registered JFFS2 version 2.2. (NAND) ?? 2001-2006 Red Hat, Inc. msgmni has been set to 456 io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0 omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1 omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2 console [ttyO2] enabled brd: module loaded loop: module loaded ahci ahci.0: forcing PORTS_IMPL to 0x3 ahci ahci.0: AHCI 0001.0100 32 slots 2 ports 3 Gbps 0x3 impl platform mode ahci ahci.0: flags: ncq sntf pm led clo only pmp pio slum part ccc scsi0 : ahci_platform scsi1 : ahci_platform ata1: SATA max UDMA/133 irq_stat 0x00400040, connection status changed irq 16 ata2: SATA max UDMA/133 irq_stat 0x00000040, connection status changed irq 16 PCI: enabling device 0000:01:00.0 (0140 -> 0142) scsi2 : sata_sil24 scsi3 : sata_sil24 ata3: SATA max UDMA/100 host m128@0x20004000 port 0x20000000 irq 48 ata4: SATA max UDMA/100 host m128@0x20004000 port 0x20002000 irq 48 omap2-nand driver initializing NAND device: Maf ID: 0xec, Chip ID: 0xf1 (Samsung, ) erasesize: 0x20000, writesize: 2048, oobsize: 64 Creating 8 MTD partitions on "omap2-nand.0": 0x000000000000-0x000000240000 : "U-Boot" 0x000000240000-0x000000280000 : "U-Boot Env and MAC" 0x000000280000-0x000000580000 : "U-Boot Logo" 0x000000580000-0x000000800000 : "Unused" 0x000000800000-0x000000c40000 : "Kernel" 0x000000c40000-0x000001140000 : "Setting" 0x000001140000-0x000002140000 : "Application File System1" 0x000002140000-0x000008000000 : "Application File System" davinci_mdio davinci_mdio.0: davinci mdio revision 1.6 davinci_mdio davinci_mdio.0: detected phy mask fffffff9 davinci_mdio.0: probed davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver ET1011C davinci_mdio davinci_mdio.0: phy[2]: device 0:02, driver ET1011C usbcore: registered new interface driver cdc_ether usbcore: registered new interface driver dm9601 Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. mice: PS/2 mouse device common for all mice omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0 rtc-s35390a 1-0030: error resetting chip rtc-s35390a: probe of 1-0030 failed with error -5 i2c /dev entries driver Linux video capture interface: v2.00 usbcore: registered new interface driver uvcvideo USB Video Class driver (v1.0.0) OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec usbcore: registered new interface driver usbhid usbhid: USB HID core driver notify_init : notify drivercreated for remote proc id 2 at physical Address 0xbfd00000 usbcore: registered new interface driver snd-usb-audio asoc: tvp5158-hifi <-> davinci-mcasp.0 mapping ok asoc: tlv320aic3x-hifi <-> davinci-mcasp.2 mapping ok asoc: SII9022a-hdmi-codec <-> davinci-mcasp.1 mapping ok asoc: HDMI-DAI-CODEC <-> hdmi-dai mapping ok ALSA device list: #0: TI81XX DVR #1: TI81XX DVR (HDMI) TCP cubic registered NET: Registered protocol family 10 IPv6 over IPv4 tunneling driver NET: Registered protocol family 17 VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3 omap_voltage_late_init: Voltage driver support not added Power Management for TI81XX. davinci_emac_probe: using random MAC addr: e2:f6:b8:2a:52:a2 davinci_emac_probe: using random MAC addr: 26:ed:ad:a9:53:97 drivers/rtc/hctosys.c: unable to open rtc device (rtc1) usb 1-1: new high speed USB device using musb-hdrc and address 2 usb 1-1: New USB device found, idVendor=0409, idProduct=005a usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 hub 1-1:1.0: USB hub found hub 1-1:1.0: 3 ports detected davinci_mdio davinci_mdio.0: resetting idled controller net eth0: attached PHY driver [ET1011C] (mii_bus:phy_addr=0:01, id=282f014) ADDRCONF(NETDEV_UP): eth0: link is not ready IP-Config: Complete: device=eth0, addr=192.168.1.138, mask=255.255.252.0, gw=192.168.0.1, host=192.168.1.138, domain=, nis-domain=(none), bootserver=192.168.1.136, rootserver=192.168.1.136, rootpath= ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 0) ata3.00: ATA-8: WDC WD20EURS-63S48Y0, 51.0AB51, max UDMA/133 ata3.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32) ata3.00: configured for UDMA/100 PHY: 0:01 - Link is Up - 100/Full ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready ata1: link is slow to respond, please be patient (ready=0) ata2: softreset failed (device not ready) ata1: softreset failed (device not ready) ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300) ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300) ata1.00: ATA-8: Hitachi HDS721010CLA330, JP4OA3MA, max UDMA/133 ata1.00: 1953525168 sectors, multi 0: LBA48 NCQ (depth 31/32) ata1.00: configured for UDMA/133 scsi 0:0:0:0: Direct-Access ATA Hitachi HDS72101 JP4O PQ: 0 ANSI: 5 sd 0:0:0:0: Attached scsi generic sg0 type 0 ata2.00: ATA-8: WDC WD1002FAEX-00Z3A0, 05.01D05, max UDMA/133 ata2.00: 1953525168 sectors, multi 0: LBA48 NCQ (depth 31/32) sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB) sd 0:0:0:0: [sda] Write Protect is off sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA ata2.00: configured for UDMA/133 scsi 1:0:0:0: Direct-Access ATA WDC WD1002FAEX-0 05.0 PQ: 0 ANSI: 5 sd 1:0:0:0: Attached scsi generic sg1 type 0 scsi 2:0:0:0: Direct-Access ATA WDC WD20EURS-63S 51.0 PQ: 0 ANSI: 5 sd 2:0:0:0: Attached scsi generic sg2 type 0 sda: unknown partition table sd 1:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB) sd 1:0:0:0: [sdb] Write Protect is off sd 2:0:0:0: [sdc] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB) sd 2:0:0:0: [sdc] 4096-byte physical blocks sd 0:0:0:0: [sda] Attached SCSI disk sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA sd 2:0:0:0: [sdc] Write Protect is off sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA sdb: unknown partition table sd 1:0:0:0: [sdb] Attached SCSI disk sdc: sdc1 < sdc5 sdc6 sdc7 sdc8 sdc9 sdc10 sdc11 > sd 2:0:0:0: [sdc] Attached SCSI disk ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 0) ata4.00: ATA-8: WDC WD20EURS-63S48Y0, 51.0AB51, max UDMA/133 ata4.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32) ata4.00: configured for UDMA/100 scsi 3:0:0:0: Direct-Access ATA WDC WD20EURS-63S 51.0 PQ: 0 ANSI: 5 sd 3:0:0:0: Attached scsi generic sg3 type 0 sd 3:0:0:0: [sdd] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB) sd 3:0:0:0: [sdd] 4096-byte physical blocks sd 3:0:0:0: [sdd] Write Protect is off sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA sdd: sdd1 < sdd5 sdd6 sdd7 sdd8 sdd9 sdd10 sdd11 > sd 3:0:0:0: [sdd] Attached SCSI disk RAMDISK: cramfs filesystem found at block 0 RAMDISK: Loading 12488KiB [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|done. VFS: Mounted root (cramfs filesystem) readonly on device 1:0. devtmpfs: mounted Freeing init memory: 196K INIT: version 2.86 booting Please wait: booting... Starting udev udevd (76): /proc/76/oom_adj is deprecated, please use /proc/76/oom_score_adj instead. Remounting root file system... mount: warning: / seems to be mounted read-only. Caching udev devnodes ALSA: Restoring mixer settings... Configuring network interfaces... No state is present for card DVR Found hardware: "" "" "" "" "" Hardware is initialized using a generic method No state is present for card DVR No state is present for card HDMI Found hardware: "" "" "" "" "" Hardware is initialized using a generic method No state is present for card HDMI done. Setting up IP spoofing protection: rp_filter. INIT: Entering runlevel: 5 Starting system message bus: dbus. Starting telnet daemon. Starting syslogd/klogd: done ################################################## # # Mount Application File System # # ################################################## UBI: attaching mtd7 to ubi0 UBI: physical eraseblock size: 131072 bytes (128 KiB) UBI: logical eraseblock size: 126976 bytes UBI: smallest flash I/O unit: 2048 UBI: sub-page size: 512 UBI: VID header offset: 2048 (aligned 2048) UBI: data offset: 4096 UBI: max. sequence number: 2 UBI: attached mtd7 to ubi0 UBI: MTD device name: "Application File System" UBI: MTD device size: 94 MiB UBI: number of good PEBs: 554 UBI: number of bad PEBs: 204 UBI: number of corrupted PEBs: 0 UBI: max. allowed volumes: 128 UBI: wear-leveling threshold: 4096 UBI: number of internal volumes: 1 UBI: number of user volumes: 1 UBI: available PEBs: 0 UBI: total number of reserved PEBs: 554 UBI: number of PEBs reserved for bad PEB handling: 5 UBI: max/mean erase counter: 3/2 UBI: image sequence number: 1377120172 UBI: background thread "ubi_bgt0d" started, PID 1947 UBI device number 0, total 554 LEBs (70344704 bytes, 67.1 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB) UBIFS: mounted UBI device 0, volume 0, name "appfs" UBIFS: mounted read-only UBIFS: file system size: 66408448 bytes (64852 KiB, 63 MiB, 523 LEBs) UBIFS: journal size: 8888320 bytes (8680 KiB, 8 MiB, 70 LEBs) UBIFS: media format: w4/r0 (latest is w4/r0) UBIFS: default compressor: lzo UBIFS: reserved for root: 0 bytes (0 KiB) ln: /home/root/.ash_history: File exists chmod: env.sh: Read-only file system chmod: init.sh: Read-only file system chmod: load.sh: Read-only file system chmod: run.sh: Read-only file system chmod: run_gui.sh: Read-only file system chmod: run_link_api.sh: Read-only file system chmod: unload.sh: Read-only file system chmod: validate.sh: Read-only file system chmod: ./bin/dvr_rdk_demo_link_api.out: Read-only file system chmod: ./bin/dvr_rdk_demo_mcfw_api.out: Read-only file system chmod: ./bin/fw_load.out: Read-only file system chmod: ./bin/i2c_rdwr.out: Read-only file system chmod: ./bin/mem_rdwr.out: Read-only file system chmod: ./bin/mem_stats.out: Read-only file system chmod: ./bin/remote_debug_client.out: Read-only file system chmod: ./bin/sys_pri.out: Read-only file system chmod: ./bin/vpdma_dump.out: Read-only file system chmod: ./scripts/load_c6xdsp.sh: Read-only file system chmod: ./scripts/load_video.sh: Read-only file system chmod: ./scripts/load_vpss.sh: Read-only file system chmod: ./scripts/osa_kermod_load.sh: Read-only file system chmod: ./scripts/osa_kermod_unload.sh: Read-only file system chmod: ./scripts/send_cmd.sh: Read-only file system chmod: ./scripts/send_str.sh: Read-only file system chmod: ./scripts/tvp5158_probe.sh: Read-only file system chmod: ./scripts/wait_cmd.sh: Read-only file system *** Bootargs Validated for mem param *** *** Bootargs Validated for notifyk.vpssm3 params *** Kernel bootargs validated numid=1,iface=MIXER,name='PCM Playback Volume' ; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0 : values=127,127 | dBscale-min=-63.50dB,step=0.50dB,mute=0 [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000 [m3video] Remote Debug Shared Memory @ 0xbff05020 [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040 SysLink version : 2.00.04.83 SysLink module created on Date:May 15 2012 Time:23:27:29 Trace enabled Trace SetFailureReason enabled Setting DMM priority for [DUCATI ] to [0] ( 0x4e000624 = 0x08000000 ) Setting DMM priority for [HDVICP0 ] to [2] ( 0x4e000634 = 0x0000000a ) Setting DMM priority for [HDVICP1 ] to [2] ( 0x4e000634 = 0x000a0000 ) Setting DMM priority for [HDVICP2 ] to [2] ( 0x4e000634 = 0x00a00000 ) Attached to slave procId 2. Loaded file ../firmware/dvr_rdk_fw_m3vpss.xem3 on slave procId 2. Started slave procId 2. [m3vpss ] ***** SYSTEM : Frequency <ORG> - 250000000, <NEW> - 280000000 [m3vpss ] notify_attach rtnVal 0 [m3vpss ] initProxyServer rtnVal 0 After Ipc_loadcallback status [0x00000000] [m3vpss ] [m3vpss ] *** UTILS: CPU KHz = 560000 Khz *** [m3vpss ] [m3vpss ] 43: SYSTEM : System Common Init in progress !!! [m3vpss ] 43: SYSTEM: IPC init in progress !!! [m3vpss ] 43: SYSTEM: Attaching to [HOST] ... [m3vpss ] 1042: SYSTEM: Attaching to [HOST] ... [m3vpss ] 1044: SYSTEM: Attaching to [HOST] ... SUCCESS !!! [m3vpss ] 1044: SYSTEM: Attaching to [DSP] ... After Ipc_startcallback status [0x097d2000] Attached to slave procId 1. Loaded file ../firmware/dvr_rdk_fw_m3video.xem3 on slave procId 1. Started slave procId 1. After Ipc_loadcallback status [0x00000000] [m3video] ***** SYSTEM : Frequency <ORG> - 250000000, <NEW> - 280000000 [m3vpss ] 2044: SYSTEM: Attaching to [DSP] ... [m3video] [m3video] *** UTILS: CPU KHz = 560000 Khz *** [m3video] [m3video] 1379: SYSTEM : System Common Init in progress !!! [m3video] 1379: SYSTEM: IPC init in progress !!! [m3video] 1379: SYSTEM: Attaching to [HOST] ... [m3video] 2378: SYSTEM: Attaching to [HOST] ... [m3video] 2380: SYSTEM: Attaching to [HOST] ... SUCCESS !!! [m3video] 2380: SYSTEM: Attaching to [DSP] ... After Ipc_startcallback status [0x00000000] Attached to slave procId 0. Loaded file ../firmware/dvr_rdk_fw_c6xdsp.xe674 on slave procId 0. Started slave procId 0. After Ipc_loadcallback status [0x00000000] After Ipc_startcallback status [0x00000000] ./load.sh: line 8: ./osa_kermod_load.sh: Permission denied [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000 [m3video] Remote Debug Shared Memory @ 0xbff05020 [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040 [c6xdsp ] ***** SYSTEM : Frequency <ORG> - 800000000, <NEW> - 800000000 [m3video] 3380: SYSTEM: Attaching to [DSP] ... [m3vpss ] 3044: SYSTEM: Attaching to [DSP] ... [c6xdsp ] [c6xdsp ] *** UTILS: CPU KHz = 800000 Khz *** [c6xdsp ] [c6xdsp ] 5: SYSTEM : System Common Init in progress !!! [c6xdsp ] 5: SYSTEM: IPC init in progress !!! [c6xdsp ] 5: SYSTEM: Attaching to [HOST] ... [c6xdsp ] 1029: SYSTEM: Attaching to [HOST] ... [c6xdsp ] 1031: SYSTEM: Attaching to [HOST] ... SUCCESS !!! [c6xdsp ] 1031: SYSTEM: Attaching to [VIDEO-M3] ... [m3vpss ] 4044: SYSTEM: Attaching to [DSP] ... [m3video] 4380: SYSTEM: Attaching to [DSP] ... [c6xdsp ] 2055: SYSTEM: Attaching to [VIDEO-M3] ... [m3vpss ] 5044: SYSTEM: Attaching to [DSP] ... [c6xdsp ] 3195: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!! [m3video] 5380: SYSTEM: Attaching to [DSP] ... [c6xdsp ] 3195: SYSTEM: Attaching to [VPSS-M3] ... [m3video] 5380: SYSTEM: Attaching to [DSP] ... SUCCESS !!! [m3video] 5380: SYSTEM: Attaching to [VPSS-M3] ... [m3vpss ] 6044: SYSTEM: Attaching to [DSP] ... [c6xdsp ] 4219: SYSTEM: Attaching to [VPSS-M3] ... [m3video] 6380: SYSTEM: Attaching to [VPSS-M3] ... [c6xdsp ] 5114: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!! [m3vpss ] 7044: SYSTEM: Attaching to [DSP] ... [c6xdsp ] 5114: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ... [m3vpss ] 7045: SYSTEM: Attaching to [DSP] ... SUCCESS !!! [m3vpss ] 7045: SYSTEM: Attaching to [VIDEO-M3] ... [m3video] 7380: SYSTEM: Attaching to [VPSS-M3] ... [c6xdsp ] 6138: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ... [m3video] 8045: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!! [m3vpss ] 8044: SYSTEM: Attaching to [VIDEO-M3] ... [m3video] 8045: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ... [m3vpss ] 8045: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!! [m3video] 8045: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ... [m3vpss ] 8045: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ... [m3video] 8046: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ... [m3vpss ] 8045: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ... [m3video] 8047: SYSTEM: Notify register to [HOST] line 0, event 12 ... [m3vpss ] 8045: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ... [m3video] 8047: SYSTEM: Notify register to [DSP] line 0, event 12 ... [m3vpss ] 8047: SYSTEM: Notify register to [HOST] line 0, event 12 ... [m3video] 8047: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ... [m3vpss ] 8047: SYSTEM: Notify register to [DSP] line 0, event 12 ... [m3video] 8047: SYSTEM: IPC init DONE !!! [m3vpss ] 8047: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ... [m3vpss ] 8047: SYSTEM: IPC init DONE !!! [m3video] 8054: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e900000 (233 MB) [m3vpss ] 8054: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e900000 (233 MB) [m3video] 8054: MEM: Shared Region 1: Base = 0x90000000, Length = 0x05180000 (81 MB) [m3vpss ] 8055: MEM: Shared Region 1: Base = 0x90000000, Length = 0x05180000 (81 MB) [m3video] 8056: SYSTEM : System Common Init Done !!! [m3vpss ] 8056: SYSTEM : System Common Init Done !!! [m3video] 8056: SYSTEM : System Video Init in progress !!! [m3vpss ] 8056: SYSTEM : System VPSS Init in progress !!! [m3video] 8056: SYSTEM : System Video Init Done !!! [m3vpss ] === HDVPSS Clocks are enabled === [m3video] 8056: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ... [m3vpss ] === HDVPSS is fully functional === [m3video] 8057: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ... [m3vpss ] === HDVPSS module is not in standby === [m3video] 8057: SYSTEM: ListElem Shared Addr = 0xbe98b280 [m3video] 8059: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ... [m3video] 8059: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ... [m3video] 8059: SYSTEM: ListElem Shared Addr = 0xbe98e380 [m3video] 8067: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_28] in region 0 ... [m3vpss ] === I2C1 Clk is active === [m3video] 8067: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_28] in region 0 ... [m3vpss ] 8062: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ... [m3video] 8068: SYSTEM: ListElem Shared Addr = 0xbe997680 [m3vpss ] 8062: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ... [m3video] 8069: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ... [m3vpss ] 8062: SYSTEM: ListElem Shared Addr = 0xbe991480 [m3video] 8070: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ... [m3vpss ] 8064: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ... [m3video] 8070: SYSTEM: ListElem Shared Addr = 0xbe9aff80 [m3vpss ] 8064: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ... [m3vpss ] 8064: SYSTEM: ListElem Shared Addr = 0xbe994580 [m3video] 8071: HDVICP: Doing PRCM for IVAHD[0] ... [m3vpss ] 8075: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_23] in region 0 ... [m3video] 8077: HDVICP: WARNING: RM_IVAHD_RSTST Timed OUT [0x7] [m3vpss ] 8075: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_23] in region 0 ... [m3video] 8077: HDVICP: PRCM for IVAHD[0] ... DONE. [m3vpss ] 8075: SYSTEM: ListElem Shared Addr = 0xbe9c8880 [m3video] 8077: HDVICP: Doing PRCM for IVAHD[1] ... [m3vpss ] 8077: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ... [m3vpss ] 8077: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ... [m3vpss ] 8078: SYSTEM: ListElem Shared Addr = 0xbe9e7e80 [m3video] 8083: HDVICP: WARNING: RM_IVAHD_RSTST Timed OUT [0x7] [m3vpss ] 8079: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ... [m3video] 8083: HDVICP: PRCM for IVAHD[1] ... DONE. [m3vpss ] 8080: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ... [m3video] 8083: HDVICP: Doing PRCM for IVAHD[2] ... [m3vpss ] 8080: SYSTEM: ListElem Shared Addr = 0xbea07480 [m3vpss ] 8081: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_36 [m3vpss ] 8082: SYSTEM : FVID2 Init in progress !!! [m3video] 8089: HDVICP: WARNING: RM_IVAHD_RSTST Timed OUT [0x7] [m3video] 8089: HDVICP: PRCM for IVAHD[2] ... DONE. [m3video] 8090: SYSTEM : Initializing Links !!! [m3video] 8091: SYSTEM : FREE SPACE : System Heap = 6282288 B, Mbx = 10240 msgs) [m3video] 8091: SYSTEM : FREE SPACE : SR0 Heap = 15570816 B (14 MB) [m3video] 8091: SYSTEM : FREE SPACE : Frame Buffer = 244318080 B (232 MB) [m3video] 8091: SYSTEM : FREE SPACE : Bitstream Buffer = 85458816 B (81 MB) [m3video] 8091: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ... [m3vpss ] 8134: SYSTEM : FVID2 Init in progress DONE !!! [m3video] 8092: SYSTEM : FREE SPACE : Tiler Buffer = 256 B (0 MB) - TILER OFF [m3vpss ] 8134: SYSTEM : Device Init in progress !!! [m3video] 8102: SYSTEM : Initializing Links ... DONE !!! [m3vpss ] initPrms.isI2cInitReq = 0 [m3vpss ] initPrms.isI2cInitReq = 0 [m3vpss ] 8136: SYSTEM : Device Init in progress DONE !!! [m3vpss ] 8255: SYSTEM : System VPSS Init Done !!! [m3vpss ] 8255: SYSTEM : Initializing Links !!! [m3vpss ] 8256: SYSTEM : FREE SPACE : System Heap = 26080 B, Mbx = 10240 msgs) [m3vpss ] 8256: SYSTEM : FREE SPACE : SR0 Heap = 15570816 B (14 MB) [m3vpss ] 8256: SYSTEM : FREE SPACE : Frame Buffer = 240008064 B (228 MB) [m3vpss ] 8256: SYSTEM : FREE SPACE : Bitstream Buffer = 85458816 B (81 MB) [m3vpss ] 8256: SYSTEM : FREE SPACE : Tiler Buffer = 256 B (0 MB) - TILER OFF [m3vpss ] Received character 's' [m3vpss ] 8334: SYSTEM : Initializing Links ... DONE !!! [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000 [m3video] Remote Debug Shared Memory @ 0xbff05020 [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040 [m3video] Received character 's' [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000 [m3video] Remote Debug Shared Memory @ 0xbff05020 [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040 [c6xdsp ] 7162: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ... [c6xdsp ] 7162: SYSTEM: Creating MsgQ [DSP_MSGQ] ... [c6xdsp ] 7162: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ... [c6xdsp ] 7162: SYSTEM: Notify register to [HOST] line 0, event 12 ... [c6xdsp ] 7162: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ... [c6xdsp ] 7162: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ... [c6xdsp ] 7162: SYSTEM: IPC init DONE !!! [c6xdsp ] 7164: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e900000 (233 MB) [c6xdsp ] 7165: MEM: Shared Region 1: Base = 0x90000000, Length = 0x05180000 (81 MB) [c6xdsp ] 716VPSS_FVID2: M3 firmware version 0x1000136 is newer,driver may not work properly. 5: SYSTEM : System Common Init Done !!! [c6xdsp ] 6994: SYSTEM : System DSP Init in progress !!! [c6xdsp ] 7167: SYSTEM: Creating ListMP [DSP_IPC_OUT_23] in region 0 ... [c6xdsp ] 7168: SYSTEM: Creating ListMP [DSP_IPC_IN_23] in region 0 ... [c6xdsp ] 7168: SYSTEM: ListElem Shared Addr = 0xbea26a80 [c6xdsp ] 7168: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ... [c6xdsp ] 7168: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ... [c6xdsp ] 7168: SYSTEM: ListElem Shared Addr = 0xbea46080 [c6xdsp ] 7169: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ... [c6xdsp ] 7169: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ... [c6xdsp ] 7169: SYSTEM: ListElem Shared Addr = 0xbea65680 [c6xdsp ] 7170: SYSTEM: Creating ListMP [DSP_IPC_OUT_28] in region 0 ... [c6xdsp ] 7170: SYSTEM: Creating ListMP [DSP_IPC_IN_28] in region 0 ... [c6xdsp ] 7170: SYSTEM: ListElem Shared Addr = 0xbea84c80 [c6xdsp ] 7171: SYSTEM: Creating ListMP [DSP_IPC_OUT_29] in region 0 ... [c6xdsp ] 7171: SYSTEM: Creating ListMP [DSP_IPC_IN_29] in region 0 ... [c6xdsp ] 7171: SYSTEM: ListElem Shared Addr = 0xbea9d580 [c6xdsp ] !!WARNING.Resource already registered:2 [c6xdsp ] 7000:[module] vpss probe done. SYSTEM : Initializing Links !!! [c6xdsp ] Received character 's' /opt/ti81xx-geo/ti816x [c6xdsp ] 7171: SYSTEM : FREE SPACE : System Heap = 104849008 B, Mbx = 10240 msgs) [c6xdsp ] 7012: SYSTEM : Initializing Links ... DONE !!! [c6xdsp ] 7013: SYSTEM : System DSP Init Done !!! [module] ti81xxfb probe done. HDMI W1 rev 2.0 [module] ti81xx_hdmi probe done. ORG 0x46c00524: 0 NEW 0x46c00524: 2 ==================>Test data=00:00:35-01/01/70 INIT: INIT: SendiStopping telnet daemon. Stopping system message bus: stopped process in pidfile '/var/run/dbus/pid' (pid 1920) dbus. ALSA: Storing mixer settings... /usr/sbin/alsactl: save_state:1547: Cannot open /etc/asound.state for writing: Read-only file system Deconfiguring network interfaces... done. Stopping syslogd/klogd: stopped syslogd (pid 1930) stopped klogd (pid 1932) done Sending all processes the TERM signal... Sending all processes the KILL signal... hwclock: RTC_SET_TIME: Invalid argument /etc/init.d/rc: /etc/rc6.d/S25save-rtc.sh: line 5: can't create /etc/timestamp: Read-only file system Unmounting remote filesystems... Deactivating swap... Unmounting local filesystems... Rebooting... sd 3:0:0:0: [sdd] Synchronizing SCSI cache sd 2:0:0:0: [sdc] Synchronizing SCSI cache sd 1:0:0:0: [sdb] Synchronizing SCSI cache sd 0:0:0:0: [sda] Synchronizing SCSI cache musb-hdrc musb-hdrc.1: remove, state 1 usb usb2: USB disconnect, address 1 musb-hdrc musb-hdrc.1: USB bus 2 deregistered musb-hdrc musb-hdrc.0: remove, state 1 usb usb1: USB disconnect, address 1 usb 1-1: USB disconnect, address 2 musb-hdrc musb-hdrc.0: USB bus 1 deregistered Restarting system. U-Boot 2010.06 (Sep 30 2011 - 00:58:16) TI8168-GP rev 1.2 ARM clk: 987MHz DDR clk: 796MHz I2C: ready DRAM: 2 GiB NAND: 128 MiB Net: Ethernet PHY: GENERIC @ 0x01 DaVinci EMAC Hit any key to stop autoboot: 0 NAND read: device 0 offset 0x800000, size 0x300000 3145728 bytes read: OK NAND read: device 0 offset 0x1140000, size 0xe00000 14680064 bytes read: OK ## Booting kernel from Legacy Image at 81000000 ... Image Name: Linux-2.6.37 Created: 2012-06-08 14:39:46 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2661808 Bytes = 2.5 MiB Load Address: 80008000 Entry Point: 80008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ... Linux version 2.6.37 (cglin@cglin-desktop) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #3 Fri Jun 8 22:39:35 CST 2012 CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache Machine: ti8168_dvr vram size = 20971520 at 0x0 reserved size = 20971520 at 0x0 FB: Reserving 20971520 bytes SDRAM for VRAM Memory policy: ECC disabled, Data cache writeback OMAP chip is TI8168 2.0 Built 1 zonelists in Zone order, mobility grouping on. Total pages: 59904 Kernel command line: mem=256M console=ttyO2,115200n8 root=/dev/ram0 ro initrd=0x82000000,16M ramdisk_size=16000 ip=192.168.1.138:192.168.1.136:192.168.0.1:255.255.252.0::eth0:off vram=20M notifyk.vpssm3_sva=0xBFD00000 PID hash table entries: 1024 (order: 0, 4096 bytes) Dentry cache hash table entries: 32768 (order: 5, 131072 bytes) Inode-cache hash table entries: 16384 (order: 4, 65536 bytes) Memory: 236MB = 236MB total Memory: 217280k/217280k available, 44864k reserved, 0K highmem Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) DMA : 0xffc00000 - 0xffe00000 ( 2 MB) vmalloc : 0xd0800000 - 0xf8000000 ( 632 MB) lowmem : 0xc0000000 - 0xd0000000 ( 256 MB) modules : 0xbf000000 - 0xc0000000 ( 16 MB) .init : 0xc0008000 - 0xc0039000 ( 196 kB) .text : 0xc0039000 - 0xc050b000 (4936 kB) .data : 0xc050c000 - 0xc0554800 ( 290 kB) SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 NR_IRQS:407 IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts Total of 128 interrupts on 1 active controller GPMC revision 6.0 Trying to install interrupt handler for IRQ400 Trying to install interrupt handler for IRQ401 Trying to install interrupt handler for IRQ402 Trying to install interrupt handler for IRQ403 Trying to install interrupt handler for IRQ404 Trying to install interrupt handler for IRQ405 Trying to install interrupt handler for IRQ406 Trying to install type control for IRQ407 Trying to set irq flags for IRQ407 OMAP clockevent source: GPTIMER1 at 27000000 Hz Console: colour dummy device 80x30 Calibrating delay loop... 986.31 BogoMIPS (lpj=4931584) pid_max: default: 32768 minimum: 301 Security Framework initialized Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok devtmpfs: initialized omap_voltage_early_init: voltage driver support not added regulator: core version 0.5 regulator: dummy: NET: Registered protocol family 16 OMAP GPIO hardware version 0.1 OMAP GPIO hardware version 0.1 omap_mux_init: Add partition: #1: core, flags: 0 3-wired eeprom init done. (H/W ver:00) _omap_mux_get_by_name: Could not find signal i2c2_scl.i2c2_scl _omap_mux_get_by_name: Could not find signal i2c2_sda.i2c2_sda registered ti816x_vpss device registered TI816x on-chip HDMI device registered ti81xx_vidout device pm_dbg_init: only OMAP3 supported ti81xx_pcie: Invoking PCI BIOS... ti81xx_pcie: Setting up Host Controller... ti81xx_pcie: Register base mapped @0xd0820000 ti81xx_pcie: Starting PCI scan... PCI: bus0: Fast back to back transfers disabled PCI: bus1: Fast back to back transfers disabled pci 0000:00:00.0: BAR 8: assigned [mem 0x20000000-0x200fffff] pci 0000:00:00.0: BAR 9: assigned [mem 0x20100000-0x201fffff pref] pci 0000:00:00.0: BAR 7: can't assign io (size 0x1000) pci 0000:01:00.0: BAR 6: assigned [mem 0x20100000-0x2017ffff pref] pci 0000:01:00.0: BAR 2: assigned [mem 0x20000000-0x20003fff 64bit] pci 0000:01:00.0: BAR 2: set to [mem 0x20000000-0x20003fff 64bit] (PCI address [0x20000000-0x20003fff]) pci 0000:01:00.0: BAR 0: assigned [mem 0x20004000-0x2000407f 64bit] pci 0000:01:00.0: BAR 0: set to [mem 0x20004000-0x2000407f 64bit] (PCI address [0x20004000-0x2000407f]) pci 0000:01:00.0: BAR 4: can't assign io (size 0x80) pci 0000:00:00.0: PCI bridge to [bus 01-01] pci 0000:00:00.0: bridge window [io disabled] pci 0000:00:00.0: bridge window [mem 0x20000000-0x200fffff] pci 0000:00:00.0: bridge window [mem 0x20100000-0x201fffff pref] PCI: enabling device 0000:00:00.0 (0140 -> 0143) bio: create slab <bio-0> at 0 vgaarb: loaded SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb registerd cppi-dma Intr @ IRQ 17 Cppi41 Init Done omap_i2c omap_i2c.1: bus 1 rev4.0 at 400 kHz omap_i2c omap_i2c.2: bus 2 rev4.0 at 400 kHz Advanced Linux Sound Architecture Driver Version 1.0.23. Switching to clocksource gp timer musb-hdrc: version 6.0, host, debug=0 musb-hdrc musb-hdrc.0: dma type: dma-cppi41 musb-hdrc musb-hdrc.0: MUSB HDRC host driver musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1 usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb1: Product: MUSB HDRC host driver usb usb1: Manufacturer: Linux 2.6.37 musb-hcd usb usb1: SerialNumber: musb-hdrc.0 hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected musb-hdrc musb-hdrc.0: USB Host mode controller at d081e000 using DMA, IRQ 18 musb-hdrc musb-hdrc.1: dma type: dma-cppi41 musb-hdrc musb-hdrc.1: MUSB HDRC host driver musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2 usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb2: Product: MUSB HDRC host driver usb usb2: Manufacturer: Linux 2.6.37 musb-hcd usb usb2: SerialNumber: musb-hdrc.1 hub 2-0:1.0: USB hub found hub 2-0:1.0: 1 port detected musb-hdrc musb-hdrc.1: USB Host mode controller at d0826800 using DMA, IRQ 19 NET: Registered protocol family 2 IP route cache hash table entries: 2048 (order: 1, 8192 bytes) TCP established hash table entries: 8192 (order: 4, 65536 bytes) TCP bind hash table entries: 8192 (order: 3, 32768 bytes) TCP: Hash tables configured (established 8192 bind 8192) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. Trying to unpack rootfs image as initramfs... rootfs image is not initramfs (junk in compressed archive); looks like an initrd Freeing initrd memory: 16384K NetWinder Floating Point Emulator V0.97 (double precision) PMU: registered new PMU device of type 0 omap-iommu omap-iommu.0: ducati registered omap-iommu omap-iommu.1: sys registered JFFS2 version 2.2. (NAND) ?? 2001-2006 Red Hat, Inc. msgmni has been set to 456 io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0 omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1 omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2 console [ttyO2] enabled brd: module loaded loop: module loaded ahci ahci.0: forcing PORTS_IMPL to 0x3 ahci ahci.0: AHCI 0001.0100 32 slots 2 ports 3 Gbps 0x3 impl platform mode ahci ahci.0: flags: ncq sntf pm led clo only pmp pio slum part ccc scsi0 : ahci_platform scsi1 : ahci_platform ata1: SATA max UDMA/133 irq_stat 0x00400040, connection status changed irq 16 ata2: SATA max UDMA/133 irq_stat 0x00000040, connection status changed irq 16 PCI: enabling device 0000:01:00.0 (0140 -> 0142) scsi2 : sata_sil24 scsi3 : sata_sil24 ata3: SATA max UDMA/100 host m128@0x20004000 port 0x20000000 irq 48 ata4: SATA max UDMA/100 host m128@0x20004000 port 0x20002000 irq 48 omap2-nand driver initializing NAND device: Maf ID: 0xec, Chip ID: 0xf1 (Samsung, ) erasesize: 0x20000, writesize: 2048, oobsize: 64 Creating 8 MTD partitions on "omap2-nand.0": 0x000000000000-0x000000240000 : "U-Boot" 0x000000240000-0x000000280000 : "U-Boot Env and MAC" 0x000000280000-0x000000580000 : "U-Boot Logo" 0x000000580000-0x000000800000 : "Unused" 0x000000800000-0x000000c40000 : "Kernel" 0x000000c40000-0x000001140000 : "Setting" 0x000001140000-0x000002140000 : "Application File System1" 0x000002140000-0x000008000000 : "Application File System" davinci_mdio davinci_mdio.0: davinci mdio revision 1.6 davinci_mdio davinci_mdio.0: detected phy mask fffffff9 davinci_mdio.0: probed davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver ET1011C davinci_mdio davinci_mdio.0: phy[2]: device 0:02, driver ET1011C usbcore: registered new interface driver cdc_ether usbcore: registered new interface driver dm9601 Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. mice: PS/2 mouse device common for all mice omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0 rtc-s35390a 1-0030: error resetting chip rtc-s35390a: probe of 1-0030 failed with error -5 i2c /dev entries driver Linux video capture interface: v2.00 usbcore: registered new interface driver uvcvideo USB Video Class driver (v1.0.0) OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec usbcore: registered new interface driver usbhid usbhid: USB HID core driver notify_init : notify drivercreated for remote proc id 2 at physical Address 0xbfd00000 usbcore: registered new interface driver snd-usb-audio asoc: tvp5158-hifi <-> davinci-mcasp.0 mapping ok asoc: tlv320aic3x-hifi <-> davinci-mcasp.2 mapping ok asoc: SII9022a-hdmi-codec <-> davinci-mcasp.1 mapping ok asoc: HDMI-DAI-CODEC <-> hdmi-dai mapping ok ALSA device list: #0: TI81XX DVR #1: TI81XX DVR (HDMI) TCP cubic registered NET: Registered protocol family 10 IPv6 over IPv4 tunneling driver NET: Registered protocol family 17 VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3 omap_voltage_late_init: Voltage driver support not added Power Management for TI81XX. davinci_emac_probe: using random MAC addr: 66:d7:21:f8:47:2c davinci_emac_probe: using random MAC addr: 5e:eb:13:bb:22:c3 drivers/rtc/hctosys.c: unable to open rtc device (rtc1) usb 1-1: new high speed USB device using musb-hdrc and address 2 usb 1-1: New USB device found, idVendor=0409, idProduct=005a usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 hub 1-1:1.0: USB hub found hub 1-1:1.0: 3 ports detected davinci_mdio davinci_mdio.0: resetting idled controller net eth0: attached PHY driver [ET1011C] (mii_bus:phy_addr=0:01, id=282f014) ADDRCONF(NETDEV_UP): eth0: link is not ready IP-Config: Complete: device=eth0, addr=192.168.1.138, mask=255.255.252.0, gw=192.168.0.1, host=192.168.1.138, domain=, nis-domain=(none), bootserver=192.168.1.136, rootserver=192.168.1.136, rootpath= ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 0) ata3.00: ATA-8: WDC WD20EURS-63S48Y0, 51.0AB51, max UDMA/133 ata3.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32) ata3.00: configured for UDMA/100 PHY: 0:01 - Link is Up - 100/Full ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready ata1: link is slow to respond, please be patient (ready=0) ata2: softreset failed (device not ready) ata1: softreset failed (device not ready) ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300) ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300) ata1.00: ATA-8: Hitachi HDS721010CLA330, JP4OA3MA, max UDMA/133 ata1.00: 1953525168 sectors, multi 0: LBA48 NCQ (depth 31/32) ata1.00: configured for UDMA/133 scsi 0:0:0:0: Direct-Access ATA Hitachi HDS72101 JP4O PQ: 0 ANSI: 5 sd 0:0:0:0: Attached scsi generic sg0 type 0 ata2.00: ATA-8: WDC WD1002FAEX-00Z3A0, 05.01D05, max UDMA/133 ata2.00: 1953525168 sectors, multi 0: LBA48 NCQ (depth 31/32) sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB) sd 0:0:0:0: [sda] Write Protect is off sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA ata2.00: configured for UDMA/133 scsi 1:0:0:0: Direct-Access ATA WDC WD1002FAEX-0 05.0 PQ: 0 ANSI: 5 sd 1:0:0:0: Attached scsi generic sg1 type 0 scsi 2:0:0:0: Direct-Access ATA WDC WD20EURS-63S 51.0 PQ: 0 ANSI: 5 sd 2:0:0:0: Attached scsi generic sg2 type 0 sda: unknown partition table sd 1:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB) sd 1:0:0:0: [sdb] Write Protect is off sd 2:0:0:0: [sdc] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB) sd 2:0:0:0: [sdc] 4096-byte physical blocks sd 0:0:0:0: [sda] Attached SCSI disk sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA sd 2:0:0:0: [sdc] Write Protect is off sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA sdb: unknown partition table sd 1:0:0:0: [sdb] Attached SCSI disk sdc: sdc1 < sdc5 sdc6 sdc7 sdc8 sdc9 sdc10 sdc11 > sd 2:0:0:0: [sdc] Attached SCSI disk ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 0) ata4.00: ATA-8: WDC WD20EURS-63S48Y0, 51.0AB51, max UDMA/133 ata4.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32) ata4.00: configured for UDMA/100 scsi 3:0:0:0: Direct-Access ATA WDC WD20EURS-63S 51.0 PQ: 0 ANSI: 5 sd 3:0:0:0: Attached scsi generic sg3 type 0 sd 3:0:0:0: [sdd] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB) sd 3:0:0:0: [sdd] 4096-byte physical blocks sd 3:0:0:0: [sdd] Write Protect is off sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA sdd: sdd1 < sdd5 sdd6 sdd7 sdd8 sdd9 sdd10 sdd11 > sd 3:0:0:0: [sdd] Attached SCSI disk RAMDISK: cramfs filesystem found at block 0 RAMDISK: Loading 12488KiB [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|done. VFS: Mounted root (cramfs filesystem) readonly on device 1:0. devtmpfs: mounted Freeing init memory: 196K INIT: version 2.86 booting Please wait: booting... Starting udev udevd (76): /proc/76/oom_adj is deprecated, please use /proc/76/oom_score_adj instead.
U-Boot 2010.06 (Sep 30 2011 - 00:58:16) TI8168-GP rev 1.2 ARM clk: 987MHz DDR clk: 796MHz I2C: ready DRAM: 2 GiB NAND: 128 MiB Net: Ethernet PHY: GENERIC @ 0x01 DaVinci EMAC Hit any key to stop autoboot: 0 NAND read: device 0 offset 0x800000, size 0x300000 3145728 bytes read: OK NAND read: device 0 offset 0x1140000, size 0xe00000 14680064 bytes read: OK ## Booting kernel from Legacy Image at 81000000 ... Image Name: Linux-2.6.37 Created: 2012-06-11 8:47:24 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2602888 Bytes = 2.5 MiB Load Address: 80008000 Entry Point: 80008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ... Linux version 2.6.37 (cglin@cglin-desktop) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #3 Mon Jun 11 16:47:18 CST 2012 CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache Machine: ti8168_dvr vram size = 20971520 at 0x0 reserved size = 20971520 at 0x0 FB: Reserving 20971520 bytes SDRAM for VRAM Memory policy: ECC disabled, Data cache writeback OMAP chip is TI8168 2.0 Built 1 zonelists in Zone order, mobility grouping on. Total pages: 59904 Kernel command line: mem=256M console=ttyO2,115200n8 root=/dev/ram0 ro initrd=0x82000000,16M ramdisk_size=16000 ip=192.168.1.138:192.168.1.136:192.168.0.1:255.255.252.0::eth0:off vram=20M notifyk.vpssm3_sva=0xBFD00000 PID hash table entries: 1024 (order: 0, 4096 bytes) Dentry cache hash table entries: 32768 (order: 5, 131072 bytes) Inode-cache hash table entries: 16384 (order: 4, 65536 bytes) Memory: 236MB = 236MB total Memory: 217380k/217380k available, 44764k reserved, 0K highmem Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) DMA : 0xffc00000 - 0xffe00000 ( 2 MB) vmalloc : 0x90800000 - 0xf8000000 (1656 MB) lowmem : 0x80000000 - 0x90000000 ( 256 MB) pkmap : 0x7fe00000 - 0x80000000 ( 2 MB) modules : 0x7f000000 - 0x7fe00000 ( 14 MB) .init : 0x80008000 - 0x8003b000 ( 204 kB) .text : 0x8003b000 - 0x804ef000 (4816 kB) .data : 0x804f0000 - 0x80538cc0 ( 292 kB) SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 NR_IRQS:407 IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts Total of 128 interrupts on 1 active controller GPMC revision 6.0 Trying to install interrupt handler for IRQ400 Trying to install interrupt handler for IRQ401 Trying to install interrupt handler for IRQ402 Trying to install interrupt handler for IRQ403 Trying to install interrupt handler for IRQ404 Trying to install interrupt handler for IRQ405 Trying to install interrupt handler for IRQ406 Trying to install type control for IRQ407 Trying to set irq flags for IRQ407 OMAP clockevent source: GPTIMER1 at 27000000 Hz Console: colour dummy device 80x30 Calibrating delay loop... 986.31 BogoMIPS (lpj=4931584) pid_max: default: 32768 minimum: 301 Security Framework initialized Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok devtmpfs: initialized omap_voltage_early_init: voltage driver support not added regulator: core version 0.5 regulator: dummy: NET: Registered protocol family 16 omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting! omap_voltage_add_dev: VDD specified does not exist! OMAP GPIO hardware version 0.1 OMAP GPIO hardware version 0.1 omap_mux_init: Add partition: #1: core, flags: 0 3-wired eeprom init done. (H/W ver:00) _omap_mux_get_by_name: Could not find signal i2c2_scl.i2c2_scl _omap_mux_get_by_name: Could not find signal i2c2_sda.i2c2_sda registered ti816x_sr device pm_dbg_init: only OMAP3 supported registered ti81xx_vpss device registered ti81xx_vidout device registered ti81xx on-chip HDMI device registered ti81xx_fb device bio: create slab <bio-0> at 0 vgaarb: loaded SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb USBSS revision 4ea20809 registerd cppi-dma Intr @ IRQ 17 Cppi41 Init Done omap_i2c omap_i2c.1: bus 1 rev4.0 at 400 kHz omap_i2c omap_i2c.2: bus 2 rev4.0 at 400 kHz Advanced Linux Sound Architecture Driver Version 1.0.23. Switching to clocksource gp timer musb-hdrc: version 6.0, host, debug=0 musb-hdrc musb-hdrc.0: dma type: dma-cppi41 MUSB controller-0 revision 4ea20800 musb-hdrc musb-hdrc.0: MUSB HDRC host driver musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1 usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb1: Product: MUSB HDRC host driver usb usb1: Manufacturer: Linux 2.6.37 musb-hcd usb usb1: SerialNumber: musb-hdrc.0 hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected musb-hdrc musb-hdrc.0: USB Host mode controller at 9081e000 using DMA, IRQ 18 musb-hdrc musb-hdrc.1: dma type: dma-cppi41 MUSB controller-1 revision 4ea20800 musb-hdrc musb-hdrc.1: MUSB HDRC host driver musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2 usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb2: Product: MUSB HDRC host driver usb usb2: Manufacturer: Linux 2.6.37 musb-hcd usb usb2: SerialNumber: musb-hdrc.1 hub 2-0:1.0: USB hub found hub 2-0:1.0: 1 port detected musb-hdrc musb-hdrc.1: USB Host mode controller at 90828800 using DMA, IRQ 19 NET: Registered protocol family 2 IP route cache hash table entries: 2048 (order: 1, 8192 bytes) TCP established hash table entries: 8192 (order: 4, 65536 bytes) TCP bind hash table entries: 8192 (order: 3, 32768 bytes) TCP: Hash tables configured (established 8192 bind 8192) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. Trying to unpack rootfs image as initramfs... rootfs image is not initramfs (junk in compressed archive); looks like an initrd Freeing initrd memory: 16384K NetWinder Floating Point Emulator V0.97 (double precision) PMU: registered new PMU device of type 0 omap-iommu omap-iommu.0: ducati registered omap-iommu omap-iommu.1: sys registered JFFS2 version 2.2. (NAND) ?? 2001-2006 Red Hat, Inc. msgmni has been set to 456 io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0 omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1 omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2 console [ttyO2] enabled brd: module loaded loop: module loaded ahci ahci.0: forcing PORTS_IMPL to 0x3 ahci ahci.0: AHCI 0001.0100 32 slots 2 ports 3 Gbps 0x3 impl platform mode ahci ahci.0: flags: ncq sntf pm led clo only pmp pio slum part ccc scsi0 : ahci_platform scsi1 : ahci_platform ata1: SATA max UDMA/133 irq_stat 0x00400040, connection status changed irq 16 ata2: SATA max UDMA/133 irq_stat 0x00400040, connection status changed irq 16 omap2-nand driver initializing NAND device: Maf ID: 0xec, Chip ID: 0xf1 (Samsung, ) erasesize: 0x20000, writesize: 2048, oobsize: 64 Creating 8 MTD partitions on "omap2-nand.0": 0x000000000000-0x000000240000 : "U-Boot" 0x000000240000-0x000000280000 : "U-Boot Env and MAC" 0x000000280000-0x000000580000 : "U-Boot Logo" 0x000000580000-0x000000800000 : "Unused" 0x000000800000-0x000000c40000 : "Kernel" 0x000000c40000-0x000001140000 : "Setting" 0x000001140000-0x000002140000 : "Application File System1" 0x000002140000-0x000008000000 : "Application File System" davinci_mdio davinci_mdio.0: davinci mdio revision 1.6 davinci_mdio davinci_mdio.0: detected phy mask fffffff9 davinci_mdio.0: probed davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver unknown davinci_mdio davinci_mdio.0: phy[2]: device 0:02, driver unknown usbcore: registered new interface driver cdc_ether usbcore: registered new interface driver dm9601 Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. mice: PS/2 mouse device common for all mice rtc-ds1307: probe of 1-0068 failed with error -5 omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0 i2c /dev entries driver Linux video capture interface: v2.00 usbcore: registered new interface driver uvcvideo USB Video Class driver (v1.0.0) OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec usbcore: registered new interface driver usbhid usbhid: USB HID core driver notify_init : notify drivercreated for remote proc id 2 at physical Address 0xbfd00000 usbcore: registered new interface driver snd-usb-audio Registered tvp5158 audio codec asoc: tvp5158-hifi <-> davinci-mcasp.0 mapping ok asoc: tlv320aic3x-hifi <-> davinci-mcasp.2 mapping ok asoc: HDMI-DAI-CODEC <-> hdmi-dai mapping ok ALSA device list: #0: TI81XX DVR TCP cubic registered NET: Registered protocol family 17 VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3 omap_voltage_late_init: Voltage driver support not added Power Management for TI81XX. smartreflex-ti816x: ti816x_sr_probe done! omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:01 UTC (946684801) usb 1-1: new high speed USB device using musb-hdrc and address 2 usb 1-1: New USB device found, idVendor=0409, idProduct=005a usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 hub 1-1:1.0: USB hub found hub 1-1:1.0: 3 ports detected davinci_mdio davinci_mdio.0: resetting idled controller net eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:01, id=282f014) IP-Config: Complete: device=eth0, addr=192.168.1.138, mask=255.255.252.0, gw=192.168.0.1, host=192.168.1.138, domain=, nis-domain=(none), bootserver=192.168.1.136, rootserver=192.168.1.136, rootpath= Link established after 1 retries ata1: link is slow to respond, please be patient (ready=0) ata1: softreset failed (device not ready) ata2: softreset failed (device not ready) ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300) ata1.00: ATA-8: Hitachi HDS721010CLA330, JP4OA3MA, max UDMA/133 ata1.00: 1953525168 sectors, multi 0: LBA48 NCQ (depth 31/32) ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300) ata1.00: configured for UDMA/133 scsi 0:0:0:0: Direct-Access ATA Hitachi HDS72101 JP4O PQ: 0 ANSI: 5 sd 0:0:0:0: Attached scsi generic sg0 type 0 sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB) ata2.00: ATA-8: WDC WD1002FAEX-00Z3A0, 05.01D05, max UDMA/133 ata2.00: 1953525168 sectors, multi 0: LBA48 NCQ (depth 31/32) sd 0:0:0:0: [sda] Write Protect is off sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA ata2.00: configured for UDMA/133 scsi 1:0:0:0: Direct-Access ATA WDC WD1002FAEX-0 05.0 PQ: 0 ANSI: 5 sd 1:0:0:0: Attached scsi generic sg1 type 0 sd 1:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB) sd 1:0:0:0: [sdb] Write Protect is off sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA sda: unknown partition table sd 0:0:0:0: [sda] Attached SCSI disk sdb: unknown partition table sd 1:0:0:0: [sdb] Attached SCSI disk RAMDISK: cramfs filesystem found at block 0 RAMDISK: Loading 13544KiB [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-done. VFS: Mounted root (cramfs filesystem) readonly on device 1:0. devtmpfs: mounted Freeing init memory: 204K INIT: version 2.86 booting Please wait: booting... Starting udev udevd (73): /proc/73/oom_adj is deprecated, please use /proc/73/oom_score_adj instead. Remounting root file system... mount: warning: / seems to be mounted read-only. Caching udev devnodes ALSA: Restoring mixer settings... No state is present for card DVR Found hardware: "" "" "" "" "" Hardware is initialized using a generic method No state is present for card DVR Configuring network interfaces... done. Setting up IP spoofing protection: rp_filter. INIT: Entering runlevel: 5 Starting system message bus: dbus. Starting telnet daemon. Starting syslogd/klogd: done ################################################## # # Mount Application File System # # ################################################## UBI: attaching mtd7 to ubi0 UBI: physical eraseblock size: 131072 bytes (128 KiB) UBI: logical eraseblock size: 126976 bytes UBI: smallest flash I/O unit: 2048 UBI: sub-page size: 512 UBI: VID header offset: 2048 (aligned 2048) UBI: data offset: 4096 UBI: max. sequence number: 2 UBI: attached mtd7 to ubi0 UBI: MTD device name: "Application File System" UBI: MTD device size: 94 MiB UBI: number of good PEBs: 554 UBI: number of bad PEBs: 204 UBI: number of corrupted PEBs: 0 UBI: max. allowed volumes: 128 UBI: wear-leveling threshold: 4096 UBI: number of internal volumes: 1 UBI: number of user volumes: 1 UBI: available PEBs: 0 UBI: total number of reserved PEBs: 554 UBI: number of PEBs reserved for bad PEB handling: 5 UBI: max/mean erase counter: 11/3 UBI: image sequence number: 325778705 UBI: background thread "ubi_bgt0d" started, PID 1186 UBI device number 0, total 554 LEBs (70344704 bytes, 67.1 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB) UBIFS: mounted UBI device 0, volume 0, name "appfs" UBIFS: mounted read-only UBIFS: file system size: 66408448 bytes (64852 KiB, 63 MiB, 523 LEBs) UBIFS: journal size: 8888320 bytes (8680 KiB, 8 MiB, 70 LEBs) UBIFS: media format: w4/r0 (latest is w4/r0) UBIFS: default compressor: lzo UBIFS: reserved for root: 0 bytes (0 KiB) ln: /home/root/.ash_history: Read-only file system chmod: env.sh: Read-only file system chmod: init.sh: Read-only file system chmod: load.sh: Read-only file system chmod: run.sh: Read-only file system chmod: run_gui.sh: Read-only file system chmod: run_link_api.sh: Read-only file system chmod: unload.sh: Read-only file system chmod: validate.sh: Read-only file system chmod: ./bin/dvr_rdk_demo_link_api.out: Read-only file system chmod: ./bin/dvr_rdk_demo_mcfw_api.out: Read-only file system chmod: ./bin/fw_load.out: Read-only file system chmod: ./bin/i2c_rdwr.out: Read-only file system chmod: ./bin/mem_rdwr.out: Read-only file system chmod: ./bin/mem_stats.out: Read-only file system chmod: ./bin/remote_debug_client.out: Read-only file system chmod: ./bin/sys_pri.out: Read-only file system chmod: ./bin/vpdma_dump.out: Read-only file system chmod: ./scripts/load_c6xdsp.sh: Read-only file system chmod: ./scripts/load_video.sh: Read-only file system chmod: ./scripts/load_vpss.sh: Read-only file system chmod: ./scripts/osa_kermod_load.sh: Read-only file system chmod: ./scripts/osa_kermod_unload.sh: Read-only file system chmod: ./scripts/send_cmd.sh: Read-only file system chmod: ./scripts/send_str.sh: Read-only file system chmod: ./scripts/tvp5158_probe.sh: Read-only file system chmod: ./scripts/wait_cmd.sh: Read-only file system *** Bootargs Validated for mem param *** *** Bootargs Validated for notifyk.vpssm3 params *** Kernel bootargs validated numid=1,iface=MIXER,name='PCM Playback Volume' ; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0 : values=127,127 | dBscale-min=-63.50dB,step=0.50dB,mute=0 [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000 [m3video] Remote Debug Shared Memory @ 0xbff05020 [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040 SysLink version : 2.10.02.17 SysLink module created on Date:May 25 2012 Time:15:24:45 Trace enabled Trace SetFailureReason enabled Setting DMM priority for [DUCATI ] to [0] ( 0x4e000624 = 0x08000000 ) Setting DMM priority for [HDVICP0 ] to [2] ( 0x4e000634 = 0x0000000a ) Setting DMM priority for [HDVICP1 ] to [2] ( 0x4e000634 = 0x000a0000 ) Setting DMM priority for [HDVICP2 ] to [2] ( 0x4e000634 = 0x00a00000 ) *** TVP5158 probe : START *** TI VS EVM : TVP5158 device address : 0x58, 0x5a, 0x5c, 0x5e TI DVR : TVP5158 device address : 0x5c, 0x5d, 0x5e, 0x5f Device found : I2C (0xXX): 0x08 = 0x51 I2C (0xXX): 0x09 = 0x58 Device NOT found : I2C (0xXX): Read ERROR !!! (reg[0x08], count = 2) I2C (0x58): Read ERROR !!! (reg[0x08], count = 2) I2C (0x5a): Read ERROR !!! (reg[0x08], count = 2) I2C (0x5c): Read ERROR !!! (reg[0x08], count = 2) I2C (0x5d): Read ERROR !!! (reg[0x08], count = 2) I2C (0x5e): Read ERROR !!! (reg[0x08], count = 2) I2C (0x5f): Read ERROR !!! (reg[0x08], count = 2) *** TVP5158 probe : END *** /opt/ti81xx-geo/ti816x Attached to slave procId 2. Loaded file ../firmware/dvr_rdk_fw_m3vpss.xem3 on slave procId 2. Started slave procId 2. After Ipc_loadcallback status [0x00000000] [m3vpss ] ***** SYSTEM : Frequency <ORG> - 250000000, <NEW> - 280000000 [m3vpss ] notify_attach rtnVal 0 [m3vpss ] initProxyServer rtnVal 0 [m3vpss ] [m3vpss ] *** UTILS: CPU KHz = 560000 Khz *** [m3vpss ] [m3vpss ] 42: SYSTEM : System Common Init in progress !!! [m3vpss ] 42: SYSTEM: IPC init in progress !!! [m3vpss ] 42: SYSTEM: Attaching to [HOST] ... [m3vpss ] 1042: SYSTEM: Attaching to [HOST] ... [m3vpss ] 1044: SYSTEM: Attaching to [HOST] ... SUCCESS !!! [m3vpss ] 1044: SYSTEM: Attaching to [DSP] ... After Ipc_startcallback status [0x097d2000] Attached to slave procId 1. Loaded file ../firmware/dvr_rdk_fw_m3video.xem3 on slave procId 1. Started slave procId 1. After Ipc_loadcallback status [0x00000000] [m3video] ***** SYSTEM : Frequency <ORG> - 250000000, <NEW> - 280000000 [m3vpss ] 2043: SYSTEM: Attaching to [DSP] ... [m3video] [m3video] *** UTILS: CPU KHz = 560000 Khz *** [m3video] [m3video] 1407: SYSTEM : System Common Init in progress !!! [m3video] 1408: SYSTEM: IPC init in progress !!! [m3video] 1408: SYSTEM: Attaching to [HOST] ... [m3video] 2407: SYSTEM: Attaching to [HOST] ... [m3video] 2409: SYSTEM: Attaching to [HOST] ... SUCCESS !!! [m3video] 2409: SYSTEM: Attaching to [DSP] ... After Ipc_startcallback status [0x00000000] Attached to slave procId 0. Loaded file ../firmware/dvr_rdk_fw_c6xdsp.xe674 on slave procId 0. Started slave procId 0. After Ipc_loadcallback status [0x00000000] [c6xdsp ] ***** SYSTEM : Frequency <ORG> - 800000000, <NEW> - 800000000 [m3video] 3409: SYSTEM: Attaching to [DSP] ... [m3vpss ] 3043: SYSTEM: Attaching to [DSP] ... [c6xdsp ] [c6xdsp ] *** UTILS: CPU KHz = 800000 Khz *** [c6xdsp ] [c6xdsp ] 5: SYSTEM : System Common Init in progress !!! [c6xdsp ] 5: SYSTEM: IPC init in progress !!! [c6xdsp ] 5: SYSTEM: Attaching to [HOST] ... [c6xdsp ] 1029: SYSTEM: Attaching to [HOST] ... [c6xdsp ] 1031: SYSTEM: Attaching to [HOST] ... SUCCESS !!! [c6xdsp ] 1031: SYSTEM: Attaching to [VIDEO-M3] ... After Ipc_startcallback status [0x00000000] ./load.sh: line 8: ./osa_kermod_load.sh: Permission denied [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000 [m3video] Remote Debug Shared Memory @ 0xbff05020 [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040 [m3vpss ] 4043: SYSTEM: Attaching to [DSP] ... [c6xdsp ] 2055: SYSTEM: Attaching to [VIDEO-M3] ... [m3video] 4409: SYSTEM: Attaching to [DSP] ... [m3vpss ] 5043: SYSTEM: Attaching to [DSP] ... [c6xdsp ] 3078: SYSTEM: Attaching to [VIDEO-M3] ... [c6xdsp ] 3300: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!! [m3video] 5409: SYSTEM: Attaching to [DSP] ... [c6xdsp ] 3300: SYSTEM: Attaching to [VPSS-M3] ... [m3video] 5409: SYSTEM: Attaching to [DSP] ... SUCCESS !!! [m3video] 5409: SYSTEM: Attaching to [VPSS-M3] ... [m3vpss ] 6043: SYSTEM: Attaching to [DSP] ... [c6xdsp ] 4323: SYSTEM: Attaching to [VPSS-M3] ... [m3video] 6409: SYSTEM: Attaching to [VPSS-M3] ... [c6xdsp ] 5184: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!! [m3vpss ] 7043: SYSTEM: Attaching to [DSP] ... [c6xdsp ] 5185: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ... [m3vpss ] 7043: SYSTEM: Attaching to [DSP] ... SUCCESS !!! [m3vpss ] 7043: SYSTEM: Attaching to [VIDEO-M3] ... [m3video] 7409: SYSTEM: Attaching to [VPSS-M3] ... [c6xdsp ] 6208: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ... [m3video] 8043: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!! [m3vpss ] 8043: SYSTEM: Attaching to [VIDEO-M3] ... [m3video] 8044: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ... [m3vpss ] 8043: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!! [m3video] 8044: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ... [m3vpss ] 8044: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ... [m3video] 8044: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ... [m3vpss ] 8044: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ... [m3video] 8046: SYSTEM: Notify register to [HOST] line 0, event 15 ... [m3vpss ] 8044: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ... [m3video] 8046: SYSTEM: Notify register to [DSP] line 0, event 15 ... [m3vpss ] 8045: SYSTEM: Notify register to [HOST] line 0, event 15 ... [m3video] 8046: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ... [m3vpss ] 8046: SYSTEM: Notify register to [DSP] line 0, event 15 ... [m3video] 8046: SYSTEM: IPC init DONE !!! [m3vpss ] 8046: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ... [m3vpss ] 8046: SYSTEM: IPC init DONE !!! [m3video] 8052: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e900000 (233 MB) [m3vpss ] 8051: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e900000 (233 MB) [m3video] 8052: MEM: Shared Region 1: Base = 0x90000000, Length = 0x0d180000 (209 MB) [m3vpss ] 8052: MEM: Shared Region 1: Base = 0x90000000, Length = 0x0d180000 (209 MB) [m3video] 8053: SYSTEM : System Common Init Done !!! [m3vpss ] 8053: SYSTEM : System Common Init Done !!! [m3video] 8054: SYSTEM : System Video Init in progress !!! [m3vpss ] 8053: SYSTEM : System VPSS Init in progress !!! [m3video] 8054: SYSTEM : System Video Init Done !!! [m3vpss ] === HDVPSS Clocks are enabled === [m3video] 8054: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ... [m3vpss ] === HDVPSS is fully functional === [m3video] 8054: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ... [m3vpss ] === HDVPSS module is not in standby === [m3video] 8054: SYSTEM: ListElem Shared Addr = 0xbe98b680 [m3video] 8056: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ... [m3video] 8057: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ... [m3video] 8057: SYSTEM: ListElem Shared Addr = 0xbe98eb80 [m3video] 8062: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_23] in region 0 ... [m3vpss ] === I2C1 Clk is active === [m3video] 8063: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_23] in region 0 ... [m3vpss ] 8059: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ... [m3video] 8063: SYSTEM: ListElem Shared Addr = 0xbe998a80 [m3vpss ] 8059: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ... [m3video] 8065: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_24] in region 0 ... [m3vpss ] 8059: SYSTEM: ListElem Shared Addr = 0xbe992080 [m3video] 8065: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_24] in region 0 ... [m3vpss ] 8061: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ... [m3video] 8065: SYSTEM: ListElem Shared Addr = 0xbe9b8480 [m3vpss ] 8061: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ... [m3vpss ] 8061: SYSTEM: ListElem Shared Addr = 0xbe995580 [m3video] 8068: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_25] in region 0 ... [m3vpss ] 8074: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_23] in region 0 ... [m3video] 8068: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_25] in region 0 ... [m3vpss ] 8075: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_23] in region 0 ... [m3video] 8068: SYSTEM: ListElem Shared Addr = 0xbe9d7e80 [m3vpss ] 8075: SYSTEM: ListElem Shared Addr = 0xbe9f7880 [m3video] 8081: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_28] in region 0 ... [m3vpss ] 8077: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ... [m3video] 8081: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_28] in region 0 ... [m3vpss ] 8077: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ... [m3video] 8081: SYSTEM: ListElem Shared Addr = 0xbea56680 [m3vpss ] 8078: SYSTEM: ListElem Shared Addr = 0xbea17280 [m3video] 8083: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ... [m3vpss ] 8080: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ... [m3video] 8083: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ... [m3vpss ] 8080: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ... [m3video] 8083: SYSTEM: ListElem Shared Addr = 0xbea73200 [m3vpss ] 8080: SYSTEM: ListElem Shared Addr = 0xbea36c80 [m3video] 8085: HDVICP: Doing PRCM for IVAHD[0] ... [m3vpss ] 8082: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37 [m3video] 8090: HDVICP: WARNING: RM_IVAHD_RSTST Timed OUT [0x7] [m3vpss ] 8082: SYSTEM : FVID2 Init in progress !!! [m3video] 8091: HDVICP: PRCM for IVAHD[0] ... DONE. [m3vpss ] 8151: SYSTEM : FVID2 Init in progress DONE !!! [m3video] 8091: HDVICP: Doing PRCM for IVAHD[1] ... [m3vpss ] 8151: SYSTEM : Device Init in progress !!! [m3video] 8096: HDVICP: WARNING: RM_IVAHD_RSTST Timed OUT [0x7] [m3video] 8096: HDVICP: PRCM for IVAHD[1] ... DONE. [m3vpss ] initPrms.isI2cInitReq = 0 [m3video] 8096: HDVICP: Doing PRCM for IVAHD[2] ... [m3video] 8102: HDVICP: WARNING: RM_IVAHD_RSTST Timed OUT [0x7] [m3vpss ] initPrms.isI2cInitReq = 0 [m3video] 8102: HDVICP: PRCM for IVAHD[2] ... DONE. [m3vpss ] 8154: SYSTEM : Device Init in progress DONE !!! [m3video] 8103: SYSTEM : Initializing Links !!! [m3vpss ] 8270: SYSTEM : System VPSS Init Done !!! [m3vpss ] 8271: UTILS: DMA: HWI Create for INT62 !!! [m3video] 8103: SYSTEM : FREE SPACE : System Heap = 6280232 B, Mbx = 10240 msgs) [m3vpss ] 8271: SYSTEM : Initializing Links !!! [m3vpss ] Received character 's' [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000 [m3video] Remote Debug Shared Memory @ 0xbff05020 [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040 [m3video] Received character 's' [m3video] 8103: SYSTEM : FREE SPACE : SR0 Heap = 15140992 B (14 MB) [m3vpss ] 8271: SYSTEM : FREE SPACE : System Heap = 13024 B, Mbx = 10240 msgs) [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000 [m3video] Remote Debug Shared Memory @ 0xbff05020 [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040 [m3video] 8103: SYSTEM : FREE SPACE : Frame Buffer = 244318080 B (232 MB) [m3vpss ] 8271: SYSTEM : FREE SPACE : SR0 Heap = 15140992 B (14 MB) [m3video] 8103: SYSTEM : FREE SPACE : Bitstream Buffer = 219676544 B (209 MB) [m3vpss ] 8271: SYSTEM : FREE SPACE : Frame Buffer = 240008064 B (228 MB) [m3video] 8103: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ... [m3vpss ] 8272: SYSTEM : FREE SPACE : Bitstream Buffer = 219676544 B (209 MB) [m3video] 8104: SYSTEM : FREE SPACE : Tiler 8-bit = 134217728 B (128 MB) - TILER ON [m3vpss ] 8272: SYSTEM : FREE SPACE : Tiler 8-bit = 134217728 B (128 MB) - TILER ON [m3video] 8104: SYSTEM : FREE SPACE : Tiler 16-bit = 134217728 B (128 MB) - TILER ON [m3vpss ] 8272: SYSTEM : FREE SPACE : Tiler 16-bit = 134217728 B (128 MB) - TILER ON [m3video] 8135: SYSTEM : Initializing Links ... DONE !!! [m3vpss ] 8374: SYSTEM : Initializing Links ... DONE !!! [c6xdsp ] 7231: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ... [c6xdsp ] 7231: SYSTEM: Creating MsgQ [DSP_MSGQ] ... [c6xdsp ] 7232: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ... [c6xdsp ] 7232: SYSTEM: Notify register to [HOST] line 0, event 15 ... [c6xdsp ] 7232: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ... [c6xdsp ] 7232: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ... [c6xdsp ] 7232: SYSTEM: IPC init DONE !!! [c6xdsp ] 7234: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e900000 (233 MB) [c6xdsp ] 7234: MEM: Shared Region 1: Base = 0x90000000, Length = 0x0d180000 (209 MB) [module] vpss probe done. [c6xdsp ] 7235: SYSTEM : System Common Init Done !!! [c6xdsp ] 7062: SYSTEM : System DSP Init in progress !!! [c6xdsp ] 7062: SYSTEM : RpeServer_init() done... Ret Val 0!!! [c6xdsp ] 7237: SYSTEM: Creating ListMP [DSP_IPC_OUT_23] in region 0 ... [c6xdsp ] 7237: SYSTEM: Creating ListMP [DSP_IPC_IN_23] in region 0 ... [c6xdsp ] 72[module] ti81xxfb probe done. 37: SYSTEM: ListElem Shared Addr = 0xbea8fd80 [c6xdsp ] 7238: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ... [c6xdsp ] 7238: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ... [c6xdsp ] 7238: SYSTEM: ListElem Shared Addr = 0xbeaaf780 [c6xdsp ] 7HDMI W1 rev 2.0 239: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in[module] ti81xx_hdmi probe done. region 0 ... [c6xdsp ] 7239: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ... [c6xdsp ] 7239: SYSTEM: ListElem Shared Addr = 0xbeacf180 [c6xdsp ] 7240: SYSTEM: Creating ListMP [DSP_IPC_OUT_28] in region 0 ... [c6xdsp ] 7240: SYSTEM: Creating ListMP [DSP_IPC_IN_28] in region 0 ... [c6xdsp ] 7240: SYSTEM: ListElem Shared Addr = 0xbeaeeb80 [c6xdsp ] 7240: SYSTEM: Creating ListMP [DSP_IPC_OUT_29] in region 0 ... [c6xdsp ] 7240: SYSTEM: Creating ListMP [DSP_IPC_IN_29] in region 0 ... [c6xdsp ] 7241: SYSTEM: ListElem Shared Addr = 0xbeb0b700 [c6xdsp ] !!WARNING.Resource already registered:2 [c6xdsp ] 7068: SYSTEM : Initializing Links !!! [c6xdsp ] Received character 's' /opt/ti81xx-geo/ti816x [c6xdsp ] 7241: SYSTEM : FREE SPACE : System Heap = 10268448 B, Mbx = 10240 msgs) [c6xdsp ] 7076: SYSTEM : Initializing Links ... DONE !!! [c6xdsp ] 7076: SYSTEM : System DSP Init Done !!! I2C No Ack ORG 0x46c00524: 0 NEW 0x46c00524: 2 =================>Test data=00:00:31-01/01/00 INIT: INIT: SenStopping telnet daemon. Stopping system message bus: stopped process in pidfile '/var/run/dbus/pid' (pid 1157) dbus. ALSA: Storing mixer settings... /usr/sbin/alsactl: save_state:1547: Cannot open /etc/asound.state for writing: Read-only file system Deconfiguring network interfaces... done. Stopping syslogd/klogd: stopped syslogd (pid 1169) stopped klogd (pid 1171) done Sending all processes the TERM signal... Sending all processes the KILL signal... /etc/init.d/rc: /etc/rc6.d/S25save-rtc.sh: line 5: can't create /etc/timestamp: Read-only file system Unmounting remote filesystems... Deactivating swap... Unmounting local filesystems... Rebooting... sd 1:0:0:0: [sdb] Synchronizing SCSI cache sd 0:0:0:0: [sda] Synchronizing SCSI cache musb-hdrc musb-hdrc.1: remove, state 1 usb usb2: USB disconnect, address 1 musb-hdrc musb-hdrc.1: USB bus 2 deregistered musb-hdrc musb-hdrc.0: remove, state 1 usb usb1: USB disconnect, address 1 usb 1-1: USB disconnect, address 2 musb-hdrc musb-hdrc.0: USB bus 1 deregistered Restarting system. U-Boot 2010.06 (Sep 30 2011 - 00:58:16) TI8168-GP rev 1.2 ARM clk: 987MHz DDR clk: 796MHz I2C: ready DRAM: 2 GiB NAND: 128 MiB Net: Ethernet PHY: GENERIC @ 0x01 DaVinci EMAC Hit any key to stop autoboot: 0 NAND read: device 0 offset 0x800000, size 0x300000 3145728 bytes read: OK NAND read: device 0 offset 0x1140000, size 0xe00000 14680064 bytes read: OK ## Booting kernel from Legacy Image at 81000000 ... Image Name: Linux-2.6.37 Created: 2012-06-11 8:47:24 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2602888 Bytes = 2.5 MiB Load Address: 80008000 Entry Point: 80008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ... Linux version 2.6.37 (cglin@cglin-desktop) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #3 Mon Jun 11 16:47:18 CST 2012 CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache Machine: ti8168_dvr vram size = 20971520 at 0x0 reserved size = 20971520 at 0x0 FB: Reserving 20971520 bytes SDRAM for VRAM Memory policy: ECC disabled, Data cache writeback OMAP chip is TI8168 2.0 Built 1 zonelists in Zone order, mobility grouping on. Total pages: 59904 Kernel command line: mem=256M console=ttyO2,115200n8 root=/dev/ram0 ro initrd=0x82000000,16M ramdisk_size=16000 ip=192.168.1.138:192.168.1.136:192.168.0.1:255.255.252.0::eth0:off vram=20M notifyk.vpssm3_sva=0xBFD00000 PID hash table entries: 1024 (order: 0, 4096 bytes) Dentry cache hash table entries: 32768 (order: 5, 131072 bytes) Inode-cache hash table entries: 16384 (order: 4, 65536 bytes) Memory: 236MB = 236MB total Memory: 217380k/217380k available, 44764k reserved, 0K highmem Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) DMA : 0xffc00000 - 0xffe00000 ( 2 MB) vmalloc : 0x90800000 - 0xf8000000 (1656 MB) lowmem : 0x80000000 - 0x90000000 ( 256 MB) pkmap : 0x7fe00000 - 0x80000000 ( 2 MB) modules : 0x7f000000 - 0x7fe00000 ( 14 MB) .init : 0x80008000 - 0x8003b000 ( 204 kB) .text : 0x8003b000 - 0x804ef000 (4816 kB) .data : 0x804f0000 - 0x80538cc0 ( 292 kB) SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 NR_IRQS:407 IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts Total of 128 interrupts on 1 active controller GPMC revision 6.0 Trying to install interrupt handler for IRQ400 Trying to install interrupt handler for IRQ401 Trying to install interrupt handler for IRQ402 Trying to install interrupt handler for IRQ403 Trying to install interrupt handler for IRQ404 Trying to install interrupt handler for IRQ405 Trying to install interrupt handler for IRQ406 Trying to install type control for IRQ407 Trying to set irq flags for IRQ407 OMAP clockevent source: GPTIMER1 at 27000000 Hz Console: colour dummy device 80x30 Calibrating delay loop... 986.31 BogoMIPS (lpj=4931584) pid_max: default: 32768 minimum: 301 Security Framework initialized Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok devtmpfs: initialized omap_voltage_early_init: voltage driver support not added regulator: core version 0.5 regulator: dummy: NET: Registered protocol family 16 omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting! omap_voltage_add_dev: VDD specified does not exist! OMAP GPIO hardware version 0.1 OMAP GPIO hardware version 0.1 omap_mux_init: Add partition: #1: core, flags: 0 3-wired eeprom init done. (H/W ver:00) _omap_mux_get_by_name: Could not find signal i2c2_scl.i2c2_scl _omap_mux_get_by_name: Could not find signal i2c2_sda.i2c2_sda registered ti816x_sr device pm_dbg_init: only OMAP3 supported registered ti81xx_vpss device registered ti81xx_vidout device registered ti81xx on-chip HDMI device registered ti81xx_fb device bio: create slab <bio-0> at 0 vgaarb: loaded SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb USBSS revision 4ea20809 registerd cppi-dma Intr @ IRQ 17 Cppi41 Init Done omap_i2c omap_i2c.1: bus 1 rev4.0 at 400 kHz omap_i2c omap_i2c.2: bus 2 rev4.0 at 400 kHz Advanced Linux Sound Architecture Driver Version 1.0.23. Switching to clocksource gp timer musb-hdrc: version 6.0, host, debug=0 musb-hdrc musb-hdrc.0: dma type: dma-cppi41 MUSB controller-0 revision 4ea20800 musb-hdrc musb-hdrc.0: MUSB HDRC host driver musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1 usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb1: Product: MUSB HDRC host driver usb usb1: Manufacturer: Linux 2.6.37 musb-hcd usb usb1: SerialNumber: musb-hdrc.0 hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected musb-hdrc musb-hdrc.0: USB Host mode controller at 9081e000 using DMA, IRQ 18 musb-hdrc musb-hdrc.1: dma type: dma-cppi41 MUSB controller-1 revision 4ea20800 musb-hdrc musb-hdrc.1: MUSB HDRC host driver musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2 usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb2: Product: MUSB HDRC host driver usb usb2: Manufacturer: Linux 2.6.37 musb-hcd usb usb2: SerialNumber: musb-hdrc.1 hub 2-0:1.0: USB hub found hub 2-0:1.0: 1 port detected musb-hdrc musb-hdrc.1: USB Host mode controller at 90828800 using DMA, IRQ 19 NET: Registered protocol family 2 IP route cache hash table entries: 2048 (order: 1, 8192 bytes) TCP established hash table entries: 8192 (order: 4, 65536 bytes) TCP bind hash table entries: 8192 (order: 3, 32768 bytes) TCP: Hash tables configured (established 8192 bind 8192) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. Trying to unpack rootfs image as initramfs... rootfs image is not initramfs (junk in compressed archive); looks like an initrd Freeing initrd memory: 16384K NetWinder Floating Point Emulator V0.97 (double precision) PMU: registered new PMU device of type 0 omap-iommu omap-iommu.0: ducati registered omap-iommu omap-iommu.1: sys registered JFFS2 version 2.2. (NAND) ?? 2001-2006 Red Hat, Inc. msgmni has been set to 456 io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0 omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1 omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2 console [ttyO2] enabled brd: module loaded loop: module loaded ahci ahci.0: forcing PORTS_IMPL to 0x3 ahci ahci.0: AHCI 0001.0100 32 slots 2 ports 3 Gbps 0x3 impl platform mode ahci ahci.0: flags: ncq sntf pm led clo only pmp pio slum part ccc scsi0 : ahci_platform scsi1 : ahci_platform ata1: SATA max UDMA/133 irq_stat 0x00400040, connection status changed irq 16 ata2: SATA max UDMA/133 irq_stat 0x00000040, connection status changed irq 16 omap2-nand driver initializing NAND device: Maf ID: 0xec, Chip ID: 0xf1 (Samsung, ) erasesize: 0x20000, writesize: 2048, oobsize: 64 Creating 8 MTD partitions on "omap2-nand.0": 0x000000000000-0x000000240000 : "U-Boot" 0x000000240000-0x000000280000 : "U-Boot Env and MAC" 0x000000280000-0x000000580000 : "U-Boot Logo" 0x000000580000-0x000000800000 : "Unused" 0x000000800000-0x000000c40000 : "Kernel" 0x000000c40000-0x000001140000 : "Setting" 0x000001140000-0x000002140000 : "Application File System1" 0x000002140000-0x000008000000 : "Application File System" davinci_mdio davinci_mdio.0: davinci mdio revision 1.6 davinci_mdio davinci_mdio.0: detected phy mask fffffff9 davinci_mdio.0: probed davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver unknown davinci_mdio davinci_mdio.0: phy[2]: device 0:02, driver unknown usbcore: registered new interface driver cdc_ether usbcore: registered new interface driver dm9601 Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. mice: PS/2 mouse device common for all mice rtc-ds1307: probe of 1-0068 failed with error -5 omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0 i2c /dev entries driver Linux video capture interface: v2.00 usbcore: registered new interface driver uvcvideo USB Video Class driver (v1.0.0) OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec usbcore: registered new interface driver usbhid usbhid: USB HID core driver notify_init : notify drivercreated for remote proc id 2 at physical Address 0xbfd00000 usbcore: registered new interface driver snd-usb-audio Registered tvp5158 audio codec asoc: tvp5158-hifi <-> davinci-mcasp.0 mapping ok asoc: tlv320aic3x-hifi <-> davinci-mcasp.2 mapping ok asoc: HDMI-DAI-CODEC <-> hdmi-dai mapping ok ALSA device list: #0: TI81XX DVR TCP cubic registered NET: Registered protocol family 17 VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3 omap_voltage_late_init: Voltage driver support not added Power Management for TI81XX. smartreflex-ti816x: ti816x_sr_probe done! omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800) usb 1-1: new high speed USB device using musb-hdrc and address 2 usb 1-1: New USB device found, idVendor=0409, idProduct=005a usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 hub 1-1:1.0: USB hub found hub 1-1:1.0: 3 ports detected davinci_mdio davinci_mdio.0: resetting idled controller net eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:01, id=282f014) IP-Config: Complete: device=eth0, addr=192.168.1.138, mask=255.255.252.0, gw=192.168.0.1, host=192.168.1.138, domain=, nis-domain=(none), bootserver=192.168.1.136, rootserver=192.168.1.136, rootpath= ata1: link is slow to respond, please be patient (ready=0) ata1: softreset failed (device not ready) ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300) ata1.00: ATA-8: Hitachi HDS721010CLA330, JP4OA3MA, max UDMA/133 ata1.00: 1953525168 sectors, multi 0: LBA48 NCQ (depth 31/32) ata1.00: configured for UDMA/133 scsi 0:0:0:0: Direct-Access ATA Hitachi HDS72101 JP4O PQ: 0 ANSI: 5 sd 0:0:0:0: Attached scsi generic sg0 type 0 sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB) sd 0:0:0:0: [sda] Write Protect is off sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA sda: unknown partition table sd 0:0:0:0: [sda] Attached SCSI disk Link established after 5 retries ata2: softreset failed (device not ready) ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300) ata2.00: ATA-8: WDC WD1002FAEX-00Z3A0, 05.01D05, max UDMA/133 ata2.00: 1953525168 sectors, multi 0: LBA48 NCQ (depth 31/32) ata2.00: configured for UDMA/133 scsi 1:0:0:0: Direct-Access ATA WDC WD1002FAEX-0 05.0 PQ: 0 ANSI: 5 sd 1:0:0:0: Attached scsi generic sg1 type 0 sd 1:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB) sd 1:0:0:0: [sdb] Write Protect is off sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA sdb: unknown partition table sd 1:0:0:0: [sdb] Attached SCSI disk RAMDISK: cramfs filesystem found at block 0 RAMDISK: Loading 13544KiB [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-done. VFS: Mounted root (cramfs filesystem) readonly on device 1:0. devtmpfs: mounted Freeing init memory: 204K INIT: version 2.86 booting Please wait: booting... Starting udev udevd (73): /proc/73/oom_adj is deprecated, please use /proc/73/oom_score_adj instead.
U-Boot 2010.06-svn (May 31 2012 - 14:37:42) TI8168-GP rev 2.0 ARM clk: 987MHz DDR clk: 796MHz HDVICP clk: 600MHz L3 Fast clk: 560MHz HDVPSS clk: 280MHz Ducati M3 clk: 280MHz I2C: ready DRAM: 2 GiB NAND: 128 MiB MMC: OMAP SD/MMC: 0 Net: Ethernet PHY: GENERIC @ 0x01 DaVinci EMAC Hit any key to stop autoboot: 1 0 NAND read: device 0 offset 0x800000, size 0x300000 3145728 bytes read: OK NAND read: device 0 offset 0x1140000, size 0xe00000 Skipping bad block 0x01b60000 14680064 bytes read: OK ## Booting kernel from Legacy Image at 81000000 ... Image Name: Linux-2.6.37 Created: 2012-06-08 14:39:46 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2661808 Bytes = 2.5 MiB Load Address: 80008000 Entry Point: 80008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ... Linux version 2.6.37 (cglin@cglin-desktop) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #3 Fri Jun 8 22:39:35 CST 2012 CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache Machine: ti8168_dvr vram size = 20971520 at 0x0 reserved size = 20971520 at 0x0 FB: Reserving 20971520 bytes SDRAM for VRAM Memory policy: ECC disabled, Data cache writeback OMAP chip is TI8168 2.0 Built 1 zonelists in Zone order, mobility grouping on. Total pages: 59904 Kernel command line: mem=256M console=ttyO2,115200n8 root=/dev/ram0 ro initrd=0x82000000,16M ramdisk_size=16000 ip=192.168.1.146:192.168.1.136:192.168.0.1:255.255.252.0::eth0:off vram=20M notifyk.vpssm3_sva=0xBFD00000 PID hash table entries: 1024 (order: 0, 4096 bytes) Dentry cache hash table entries: 32768 (order: 5, 131072 bytes) Inode-cache hash table entries: 16384 (order: 4, 65536 bytes) Memory: 236MB = 236MB total Memory: 217280k/217280k available, 44864k reserved, 0K highmem Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) DMA : 0xffc00000 - 0xffe00000 ( 2 MB) vmalloc : 0xd0800000 - 0xf8000000 ( 632 MB) lowmem : 0xc0000000 - 0xd0000000 ( 256 MB) modules : 0xbf000000 - 0xc0000000 ( 16 MB) .init : 0xc0008000 - 0xc0039000 ( 196 kB) .text : 0xc0039000 - 0xc050b000 (4936 kB) .data : 0xc050c000 - 0xc0554800 ( 290 kB) SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 NR_IRQS:407 IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts Total of 128 interrupts on 1 active controller GPMC revision 6.0 Trying to install interrupt handler for IRQ400 Trying to install interrupt handler for IRQ401 Trying to install interrupt handler for IRQ402 Trying to install interrupt handler for IRQ403 Trying to install interrupt handler for IRQ404 Trying to install interrupt handler for IRQ405 Trying to install interrupt handler for IRQ406 Trying to install type control for IRQ407 Trying to set irq flags for IRQ407 OMAP clockevent source: GPTIMER1 at 27000000 Hz Console: colour dummy device 80x30 Calibrating delay loop... 986.31 BogoMIPS (lpj=4931584) pid_max: default: 32768 minimum: 301 Security Framework initialized Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok devtmpfs: initialized omap_voltage_early_init: voltage driver support not added regulator: core version 0.5 regulator: dummy: NET: Registered protocol family 16 OMAP GPIO hardware version 0.1 OMAP GPIO hardware version 0.1 omap_mux_init: Add partition: #1: core, flags: 0 3-wired eeprom init done. (H/W ver:00) _omap_mux_get_by_name: Could not find signal i2c2_scl.i2c2_scl _omap_mux_get_by_name: Could not find signal i2c2_sda.i2c2_sda registered ti816x_vpss device registered TI816x on-chip HDMI device registered ti81xx_vidout device pm_dbg_init: only OMAP3 supported ti81xx_pcie: Invoking PCI BIOS... ti81xx_pcie: Setting up Host Controller... ti81xx_pcie: Register base mapped @0xd0820000 ti81xx_pcie: Starting PCI scan... PCI: bus0: Fast back to back transfers enabled bio: create slab <bio-0> at 0 vgaarb: loaded SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb registerd cppi-dma Intr @ IRQ 17 Cppi41 Init Done omap_i2c omap_i2c.1: bus 1 rev4.0 at 400 kHz omap_i2c omap_i2c.2: bus 2 rev4.0 at 400 kHz Advanced Linux Sound Architecture Driver Version 1.0.23. Switching to clocksource gp timer musb-hdrc: version 6.0, host, debug=0 musb-hdrc musb-hdrc.0: dma type: dma-cppi41 musb-hdrc musb-hdrc.0: MUSB HDRC host driver musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1 usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb1: Product: MUSB HDRC host driver usb usb1: Manufacturer: Linux 2.6.37 musb-hcd usb usb1: SerialNumber: musb-hdrc.0 hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected musb-hdrc musb-hdrc.0: USB Host mode controller at d081e000 using DMA, IRQ 18 musb-hdrc musb-hdrc.1: dma type: dma-cppi41 musb-hdrc musb-hdrc.1: MUSB HDRC host driver musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2 usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb2: Product: MUSB HDRC host driver usb usb2: Manufacturer: Linux 2.6.37 musb-hcd usb usb2: SerialNumber: musb-hdrc.1 hub 2-0:1.0: USB hub found hub 2-0:1.0: 1 port detected musb-hdrc musb-hdrc.1: USB Host mode controller at d0826800 using DMA, IRQ 19 NET: Registered protocol family 2 IP route cache hash table entries: 2048 (order: 1, 8192 bytes) TCP established hash table entries: 8192 (order: 4, 65536 bytes) TCP bind hash table entries: 8192 (order: 3, 32768 bytes) TCP: Hash tables configured (established 8192 bind 8192) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. Trying to unpack rootfs image as initramfs... rootfs image is not initramfs (junk in compressed archive); looks like an initrd Freeing initrd memory: 16384K NetWinder Floating Point Emulator V0.97 (double precision) PMU: registered new PMU device of type 0 omap-iommu omap-iommu.0: ducati registered omap-iommu omap-iommu.1: sys registered JFFS2 version 2.2. (NAND) ?? 2001-2006 Red Hat, Inc. msgmni has been set to 456 io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0 omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1 omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2 console [ttyO2] enabled brd: module loaded loop: module loaded ahci ahci.0: forcing PORTS_IMPL to 0x3 ahci ahci.0: AHCI 0001.0100 32 slots 2 ports 3 Gbps 0x3 impl platform mode ahci ahci.0: flags: ncq sntf pm led clo only pmp pio slum part ccc scsi0 : ahci_platform scsi1 : ahci_platform ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a150fff] port 0x100 irq 16 ata2: SATA max UDMA/133 irq_stat 0x00400040, connection status changed irq 16 omap2-nand driver initializing NAND device: Maf ID: 0xec, Chip ID: 0xf1 (Samsung, ) erasesize: 0x20000, writesize: 2048, oobsize: 64 Creating 8 MTD partitions on "omap2-nand.0": 0x000000000000-0x000000240000 : "U-Boot" 0x000000240000-0x000000280000 : "U-Boot Env and MAC" 0x000000280000-0x000000580000 : "U-Boot Logo" 0x000000580000-0x000000800000 : "Unused" 0x000000800000-0x000000c40000 : "Kernel" 0x000000c40000-0x000001140000 : "Setting" 0x000001140000-0x000002140000 : "Application File System1" 0x000002140000-0x000008000000 : "Application File System" davinci_mdio davinci_mdio.0: davinci mdio revision 1.6 davinci_mdio davinci_mdio.0: detected phy mask fffffff9 davinci_mdio.0: probed davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver ET1011C davinci_mdio davinci_mdio.0: phy[2]: device 0:02, driver ET1011C usbcore: registered new interface driver cdc_ether usbcore: registered new interface driver dm9601 Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. mice: PS/2 mouse device common for all mice omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0 rtc-s35390a 1-0030: rtc core: registered rtc-s35390a as rtc1 i2c /dev entries driver Linux video capture interface: v2.00 usbcore: registered new interface driver uvcvideo USB Video Class driver (v1.0.0) OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec usbcore: registered new interface driver usbhid usbhid: USB HID core driver notify_init : notify drivercreated for remote proc id 2 at physical Address 0xbfd00000 usbcore: registered new interface driver snd-usb-audio asoc: tvp5158-hifi <-> davinci-mcasp.0 mapping ok asoc: tlv320aic3x-hifi <-> davinci-mcasp.2 mapping ok asoc: SII9022a-hdmi-codec <-> davinci-mcasp.1 mapping ok asoc: HDMI-DAI-CODEC <-> hdmi-dai mapping ok ALSA device list: #0: TI81XX DVR #1: TI81XX DVR (HDMI) TCP cubic registered NET: Registered protocol family 10 IPv6 over IPv4 tunneling driver NET: Registered protocol family 17 VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3 omap_voltage_late_init: Voltage driver support not added Power Management for TI81XX. davinci_emac_probe: using random MAC addr: de:e8:9f:cc:5a:3f davinci_emac_probe: using random MAC addr: a2:d7:c5:4d:a0:5f rtc-s35390a 1-0030: setting system clock to 2012-06-17 07:00:23 UTC (1339916423) davinci_mdio davinci_mdio.0: resetting idled controller net eth0: attached PHY driver [ET1011C] (mii_bus:phy_addr=0:01, id=282f014) ADDRCONF(NETDEV_UP): eth0: link is not ready IP-Config: Complete: device=eth0, addr=192.168.1.146, mask=255.255.252.0, gw=192.168.0.1, host=192.168.1.146, domain=, nis-domain=(none), bootserver=192.168.1.136, rootserver=192.168.1.136, rootpath= PHY: 0:01 - Link is Up - 100/Full ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready ata1: SATA link down (SStatus 0 SControl 300) ata2: link is slow to respond, please be patient (ready=0) ata2: softreset failed (device not ready) ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300) ata2.00: ATA-8: WDC WD20EURS-63S48Y0, 51.0AB51, max UDMA/133 ata2.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32) ata2.00: configured for UDMA/133 scsi 1:0:0:0: Direct-Access ATA WDC WD20EURS-63S 51.0 PQ: 0 ANSI: 5 sd 1:0:0:0: Attached scsi generic sg0 type 0 sd 1:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB) sd 1:0:0:0: [sda] 4096-byte physical blocks sd 1:0:0:0: [sda] Write Protect is off sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA sda: unknown partition table sd 1:0:0:0: [sda] Attached SCSI disk RAMDISK: cramfs filesystem found at block 0 RAMDISK: Loading 12828KiB [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/done. VFS: Mounted root (cramfs filesystem) readonly on device 1:0. devtmpfs: mounted Freeing init memory: 196K INIT: version 2.86 booting Please wait: booting... Starting udev udevd (72): /proc/72/oom_adj is deprecated, please use /proc/72/oom_score_adj instead. Remounting root file system... mount: warning: / seems to be mounted read-only. Caching udev devnodes ALSA: Restoring mixer settings... Configuring network interfaces... No state is present for card DVR Found hardware: "" "" "" "" "" Hardware is initialized using a generic method No state is present for card DVR No state is present for card HDMI Found hardware: "" "" "" "" "" Hardware is initialized using a generic method No state is present for card HDMI done. Setting up IP spoofing protection: rp_filter. INIT: Entering runlevel: 5 Starting system message bus: dbus. Starting telnet daemon. Starting syslogd/klogd: done UBI: attaching mtd7 to ubi0 UBI: physical eraseblock size: 131072 bytes (128 KiB) UBI: logical eraseblock size: 126976 bytes UBI: smallest flash I/O unit: 2048 UBI: sub-page size: 512 UBI: VID header offset: 2048 (aligned 2048) UBI: data offset: 4096 UBI: max. sequence number: 2 UBI: attached mtd7 to ubi0 UBI: MTD device name: "Application File System" UBI: MTD device size: 94 MiB UBI: number of good PEBs: 755 UBI: number of bad PEBs: 3 UBI: number of corrupted PEBs: 0 UBI: max. allowed volumes: 128 UBI: wear-leveling threshold: 4096 UBI: number of internal volumes: 1 UBI: number of user volumes: 1 UBI: available PEBs: 0 UBI: total number of reserved PEBs: 755 UBI: number of PEBs reserved for bad PEB handling: 7 UBI: max/mean erase counter: 5/3 UBI: image sequence number: 206721370 UBI: background thread "ubi_bgt0d" started, PID 1164 UBI device number 0, total 755 LEBs (95866880 bytes, 91.4 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB) route: SIOCDELRT: No such process UBIFS: mounted UBI device 0, volume 0, name "appfs" UBIFS: mounted read-only UBIFS: file system size: 89772032 bytes (87668 KiB, 85 MiB, 707 LEBs) UBIFS: journal size: 9023488 bytes (8812 KiB, 8 MiB, 72 LEBs) UBIFS: media format: w4/r0 (latest is w4/r0) UBIFS: default compressor: lzo UBIFS: reserved for root: 0 bytes (0 KiB) ==============================================>XX :: Sun Jun 17 07:00:38 UTC 2012 chmod: env.sh: Read-only file system chmod: init.sh: Read-only file system chmod: load.sh: Read-only file system chmod: run.sh: Read-only file system chmod: run_gui.sh: Read-only file system chmod: run_link_api.sh: Read-only file system chmod: unload.sh: Read-only file system chmod: validate.sh: Read-only file system chmod: ./bin/dvr_rdk_demo_link_api.out: Read-only file system chmod: ./bin/dvr_rdk_demo_mcfw_api.out: Read-only file system chmod: ./bin/fw_load.out: Read-only file system chmod: ./bin/i2c_rdwr.out: Read-only file system chmod: ./bin/mem_rdwr.out: Read-only file system chmod: ./bin/remote_debug_client.out: Read-only file system chmod: ./bin/sys_pri.out: Read-only file system chmod: ./scripts/load_c6xdsp.sh: Read-only file system chmod: ./scripts/load_video.sh: Read-only file system chmod: ./scripts/load_vpss.sh: Read-only file system chmod: ./scripts/osa_kermod_load.sh: Read-only file system chmod: ./scripts/osa_kermod_unload.sh: Read-only file system chmod: ./scripts/send_cmd.sh: Read-only file system chmod: ./scripts/send_str.sh: Read-only file system chmod: ./scripts/tvp5158_probe.sh: Read-only file system chmod: ./scripts/wait_cmd.sh: Read-only file system *** Bootargs Validated for mem param *** *** Bootargs Validated for notifyk.vpssm3 params *** Kernel bootargs validated numid=1,iface=MIXER,name='PCM Playback Volume' ; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0 : values=127,127 | dBscale-min=-63.50dB,step=0.50dB,mute=0 [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000 [m3video] Remote Debug Shared Memory @ 0xbff05020 [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040 SysLink version : 2.00.04.83 SysLink module created on Date:May 17 2012 Time:09:28:15 Trace enabled Trace SetFailureReason enabled Setting DMM priority for [DUCATI ] to [0] ( 0x4e000624 = 0x08000000 ) Setting DMM priority for [HDVICP0 ] to [2] ( 0x4e000634 = 0x0000000a ) Setting DMM priority for [HDVICP1 ] to [2] ( 0x4e000634 = 0x000a0000 ) Setting DMM priority for [HDVICP2 ] to [2] ( 0x4e000634 = 0x00a00000 ) Attached to slave procId 2. Loaded file ../firmware/dvr_rdk_fw_m3vpss.xem3 on slave procId 2. Started slave procId 2. [m3vpss ] ***** SYSTEM : Frequency <ORG> - 250000000, <NEW> - 280000000 [m3vpss ] notify_attach rtnVal 0 [m3vpss ] initProxyServer rtnVal 0 [m3vpss ] [m3vpss ] *** UTILS: CPU KHz = 560000 Khz *** [m3vpss ] [m3vpss ] 48: SYSTEM : System Common Init in progress !!! [m3vpss ] 48: SYSTEM: IPC init in progress !!! [m3vpss ] 48: SYSTEM: Attaching to [HOST] ... After Ipc_loadcallback status [0x00000000] [m3vpss ] 1047: SYSTEM: Attaching to [HOST] ... [m3vpss ] 1049: SYSTEM: Attaching to [HOST] ... SUCCESS !!! [m3vpss ] 1050: SYSTEM: Attaching to [DSP] ... After Ipc_startcallback status [0x097d2000] Attached to slave procId 1. Loaded file ../firmware/dvr_rdk_fw_m3video.xem3 on slave procId 1. Started slave procId 1. After Ipc_loadcallback status [0x00000000] [m3video] ***** SYSTEM : Frequency <ORG> - 250000000, <NEW> - 280000000 [m3vpss ] 2049: SYSTEM: Attaching to [DSP] ... [m3video] [m3video] *** UTILS: CPU KHz = 560000 Khz *** [m3video] [m3video] 1416: SYSTEM : System Common Init in progress !!! [m3video] 1416: SYSTEM: IPC init in progress !!! [m3video] 1416: SYSTEM: Attaching to [HOST] ... [m3video] 2415: SYSTEM: Attaching to [HOST] ... [m3video] 2417: SYSTEM: Attaching to [HOST] ... SUCCESS !!! [m3video] 2417: SYSTEM: Attaching to [DSP] ... After Ipc_startcallback status [0x00000000] Attached to slave procId 0. Loaded file ../firmware/dvr_rdk_fw_c6xdsp.xe674 on slave procId 0. Started slave procId 0. After Ipc_loadcallback status [0x00000000] After Ipc_startcallback status [0x00000000] DMA: Module install successful, device major num = 250 DRV: Module install successful DRV: Module built on May 17 2012 09:36:54 [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000 [m3video] Remote Debug Shared Memory @ 0xbff05020 [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040 [c6xdsp ] ***** SYSTEM : Frequency <ORG> - 800000000, <NEW> - 800000000 [m3video] 3417: SYSTEM: Attaching to [DSP] ... [m3vpss ] 3049: SYSTEM: Attaching to [DSP] ... [c6xdsp ] [c6xdsp ] *** UTILS: CPU KHz = 800000 Khz *** [c6xdsp ] [c6xdsp ] 5: SYSTEM : System Common Init in progress !!! [c6xdsp ] 5: SYSTEM: IPC init in progress !!! [c6xdsp ] 5: SYSTEM: Attaching to [HOST] ... [c6xdsp ] 1029: SYSTEM: Attaching to [HOST] ... [c6xdsp ] 1031: SYSTEM: Attaching to [HOST] ... SUCCESS !!! [c6xdsp ] 1031: SYSTEM: Attaching to [VIDEO-M3] ... [m3vpss ] 4049: SYSTEM: Attaching to [DSP] ... [m3video] 4417: SYSTEM: Attaching to [DSP] ... [c6xdsp ] 2055: SYSTEM: Attaching to [VIDEO-M3] ... [m3vpss ] 5049: SYSTEM: Attaching to [DSP] ... [c6xdsp ] 2790: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!! [m3video] 5417: SYSTEM: Attaching to [DSP] ... [c6xdsp ] 2790: SYSTEM: Attaching to [VPSS-M3] ... [m3video] 5417: SYSTEM: Attaching to [DSP] ... SUCCESS !!! [m3video] 5418: SYSTEM: Attaching to [VPSS-M3] ... [m3vpss ] 6049: SYSTEM: Attaching to [DSP] ... [m3video] 6417: SYSTEM: Attaching to [VPSS-M3] ... [c6xdsp ] 3813: SYSTEM: Attaching to [VPSS-M3] ... [c6xdsp ] 4449: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!! [m3vpss ] 7049: SYSTEM: Attaching to [DSP] ... [c6xdsp ] 4449: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ... [m3vpss ] 7050: SYSTEM: Attaching to [DSP] ... SUCCESS !!! [m3vpss ] 7050: SYSTEM: Attaching to [VIDEO-M3] ... [m3video] 7417: SYSTEM: Attaching to [VPSS-M3] ... [m3video] 8050: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!! [m3vpss ] 8049: SYSTEM: Attaching to [VIDEO-M3] ... [m3video] 8050: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ... [m3vpss ] 8050: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!! [m3video] 8050: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ... [m3vpss ] 8050: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ... [m3video] 8051: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ... [m3vpss ] 8050: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ... [m3vpss ] 8050: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ... [c6xdsp ] 5473: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ... [m3video] 8052: SYSTEM: Notify register to [HOST] line 0, event 12 ... [m3vpss ] 8052: SYSTEM: Notify register to [HOST] line 0, event 12 ... [c6xdsp ] 5473: SYSTEM: Creating MsgQ [DSP_MSGQ] ... [m3video] 8052: SYSTEM: Notify register to [DSP] line 0, event 12 ... [m3vpss ] 8052: SYSTEM: Notify register to [DSP] line 0, event 12 ... [c6xdsp ] 5473: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ... [m3video] 8052: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ... [m3vpss ] 8052: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ... [c6xdsp ] 5473: SYSTEM: Notify register to [HOST] line 0, event 12 ... [m3video] 8053: SYSTEM: IPC init DONE !!! [m3vpss ] 8053: SYSTEM: IPC init DONE !!! [c6xdsp ] 5473: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ... [m3video] 8059: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e900000 (233 MB) [m3vpss ] 8060: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e900000 (233 MB) [c6xdsp ] 5473: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ... [m3video] 8059: MEM: Shared Region 1: Base = 0x90000000, Length = 0x05180000 (81 MB) [m3vpss ] 8060: MEM: Shared Region 1: Base = 0x90000000, Length = 0x05180000 (81 MB) [c6xdsp ] 5473: SYSTEM: IPC init DONE !!! [m3video] 8061: SYSTEM : System Common Init Done !!! [m3vpss ] 8062: SYSTEM : System Common Init Done !!! [c6xdsp ] 5475: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e900000 (233 MB) [m3video] 8061: SYSTEM : System Video Init in progress !!! [m3vpss ] 8062: SYSTEM : System VPSS Init in progress !!! [c6xdsp ] 5476: MEM: Shared Region 1: Base = 0x90000000, Length = 0x05180000 (81 MB) [m3video] 8061: SYSTEM : System Video Init Done !!! [c6xdsp ] 5476: SYSTEM : System Common Init Done !!! [m3video] 8062: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ... [c6xdsp ] 5344: SYSTEM : System DSP Init in progress !!! [m3video] 8062: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ... [m3video] 8062: SYSTEM: ListElem Shared Addr = 0xbe98b280 [c6xdsp ] 5479: SYSTEM: Creating ListMP [DSP_IPC_OUT_23] in region 0 ... [m3video] 8064: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ... [m3vpss ] === HDVPSS Clocks are enabled === [c6xdsp ] 5479: SYSTEM: Creating ListMP [DSP_IPC_IN_23] in region 0 ... [m3video] 8064: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ... [m3vpss ] === HDVPSS is fully functional === [c6xdsp ] 5479: SYSTEM: ListElem Shared Addr = 0xbe98e380 [m3video] 8064: SYSTEM: ListElem Shared Addr = 0xbe9ccf80 [m3vpss ] === HDVPSS module is not in standby === [c6xdsp ] 5480: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ... [m3vpss ] === I2C1 Clk is active === [c6xdsp ] 5480: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ... [m3video] 8073: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_28] in region 0 ... [m3vpss ] 8067: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ... [c6xdsp ] 5480: SYSTEM: ListElem Shared Addr = 0xbe9ada00 [m3vpss ] 8067: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ... [c6xdsp ] 5481: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ... [m3vpss ] 8067: SYSTEM: ListElem Shared Addr = 0xbea20880 [c6xdsp ] 5481: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ... [m3vpss ] 8069: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ... [c6xdsp ] 5481: SYSTEM: ListElem Shared Addr = 0xbe9d0080 [m3vpss ] 8069: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ... [c6xdsp ] 5482: SYSTEM: Creating ListMP [DSP_IPC_OUT_28] in region 0 ... [m3video] 8073: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_28] in region 0 ... [m3vpss ] 8070: SYSTEM: ListElem Shared Addr = 0xbea23980 [c6xdsp ] 5482: SYSTEM: Creating ListMP [DSP_IPC_IN_28] in region 0 ... [m3video] 8073: SYSTEM: ListElem Shared Addr = 0xbea26a80 [m3vpss ] 8081: SYSTEM: Creating ListMP [VPSS-M3_IVPSS_FVID2: M3 firmware version 0x1000136 is newer,driver may not work properly. PC_OUT_23] in region 0 ... [c6xdsp ] 5482: SYSTEM: ListElem Shared Addr = 0xbe9ef680 [m3video] 8075: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ... [m3vpss ] 8081: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_23] in region 0 ... [c6xdsp ] 5483: SYSTEM: Creating ListMP [DSP_IPC_OUT_29] in region 0 ... [m3video] 8075: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ... [m3vpss ] 8081: SYSTEM: ListElem Shared Addr = 0xbea57c80 [c6xdsp ] 5483: SYSTEM: Creating ListMP [DSP_IPC_IN_29] in region 0 ... [m3video] 8075: SYSTEM: ListElem Shared Addr = 0xbea3f380 [m3vpss ] 8083: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ... [c6xdsp ] 5483: SYSTEM: ListElem Shared Addr = 0xbea07f80 [m3video] 8077: HDVICP: Doing PRCM for IVAHD[0] ... [m3vpss ] 8083: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ... [c6xdsp ] !!WARNING.Resource already registered:2 [c6xdsp ] 5351: SYSTEM : Initializing Links !!! [m3video] 8077: HDVICP: PRCM for IVAHD[0] ... DONE. [m3vpss ] 8084: SYSTEM: ListElem Shared Addr = 0xbea77280 [m3video] 8077: HDVICP: Doing PRCM for IVAHD[1] ... [m3vpss ] 8086: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ..[module] vpss probe done. . [c6xdsp ] 5484: SYSTEM : FREE SPACE : System Heap = 104849008 B, Mbx = 10240 msgs) [m3video] 8078: HDVICP: PRCM for IVAHD[1] ... DONE. [m3vpss ] 8086: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ... [m3video] 8078: HDVICP: Doing PRCM for IVAHD[2] ... [m3vpss ] 8086: SYSTEM: ListElem Shared Addr = 0xbea96880 [c6xdsp ] 5367: SYSTEM : Initializing Links ... DONE !!! [m3video] 8078: HDVICP: PRCM for IVAH[module] ti81xxfb probe done. D[2] ... DONE. [m3vpss ] 8088: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_36 [m3video] 8079: SYSTEM : Initializing Links !!! [m3vpss ] 8088: SYSTEM : FVID2 Init in progress !!! [c6xdsp ] HDMI W1 rev 2.0 5367: SYSTEM : [module] ti81xx_hdmi probe done. System DSP Init Done !!! [m3vpss ] 8140: SYSTEM : FVID2 Init in progress DONE !!! [m3video] 8079: SYSTEM : FREE SPACE : System Heap = 6282288 B, Mbx = 10240 msgs) [m3vpss ] 8140: SYSTEM : Device Init in progress !!! [m3vpss ] Received character 's' [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000 [m3video] Remote Debug Shared Memory @ 0xbff05020 [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040 [m3video] Received character 's' [m3video] 8079: SYSTEM : FREE SPACE : SR0 Heap = 15369600 B (14 MB) [m3vpss ] initPrms.isI2cInitReq = 0 [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000 [m3video] Remote Debug Shared Memory @ 0xbff05020 [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040 [c6xdsp ] Received character 's' /opt/ti81xx-geo/ti816x [m3video] 8079: SYSTEM : FREE SPACE : Frame Buffer = 244318080 B (232 MB) [m3vpss ] initPrms.isI2cInitReq = 0 [m3vpss ] 8142: SYSTEM : Device Init in progress DONE !!! [m3video] 8079: SYSTEM : FREE SPACE : Bitstream Buffer = 85458816 B (81 MB) [m3vpss ] 8263: SYSTEM : System VPSS Init Done !!! [m3vpss ] 8263: SYSTEM : Initializing Links !!! [m3video] 8079: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ... [m3video] 8088: SYSTEM : FREE SPACE : Tiler Buffer = 256 B (0 MB) - TILER OFF [m3vpss ] 8263: SYSTEM : FREE SPACE : System Heap = 26080 B, Mbx = 10240 msgs) [m3video] 8098: SYSTEM : Initializing Links ... DONE !!! [m3vpss ] 8263: SYSTEM : FREE SPACE : SR0 Heap = 14984064 B (14 MB) [m3vpss ] 8264: SYSTEM : FREE SPACE : Frame Buffer = 240008064 B (228 MB) [m3vpss ] 8264: SYSTEM : FREE SPACE : Bitstream Buffer = 85458816 B (81 MB) [m3vpss ] 8264: SYSTEM : FREE SPACE : Tiler Buffer = 256 B (0 MB) - TILER OFF [m3vpss ] 8342: SYSTEM : Initializing Links ... DONE !!! ORG 0x46c00524: 0 NEW 0x46c00524: 2 INIT: INIT: Sending processes the TERM signal Stopping telnet daemon. Stopping system message bus: stopped process in pidfile '/var/run/dbus/pid' (pid 1137) dbus. ALSA: Storing mixer settings... /usr/sbin/alsactl: save_state:1547: Cannot open /etc/asound.state for writing: Read-only file system Deconfiguring network interfaces... done. Stopping syslogd/klogd: stopped syslogd (pid 1147) stopped klogd (pid 1149) done Sending all processes the TERM signal... Sending all processes the KILL signal... /etc/init.d/rc: /etc/rc6.d/S25save-rtc.sh: line 5: can't create /etc/timestamp: Read-only file system Unmounting remote filesystems... Deactivating swap... Unmounting local filesystems... Rebooting... sd 1:0:0:0: [sda] Synchronizing SCSI cache musb-hdrc musb-hdrc.1: remove, state 1 usb usb2: USB disconnect, address 1 musb-hdrc musb-hdrc.1: USB bus 2 deregistered musb-hdrc musb-hdrc.0: remove, state 1 usb usb1: USB disconnect, address 1 musb-hdrc musb-hdrc.0: USB bus 1 deregistered Restarting system. U-Boot 2010.06-svn (May 31 2012 - 14:37:42) TI8168-GP rev 2.0 ARM clk: 987MHz DDR clk: 796MHz HDVICP clk: 600MHz L3 Fast clk: 560MHz HDVPSS clk: 280MHz Ducati M3 clk: 280MHz I2C: ready DRAM: 2 GiB NAND: 128 MiB MMC: OMAP SD/MMC: 0 Net: Ethernet PHY: GENERIC @ 0x01 DaVinci EMAC Hit any key to stop autoboot: 1 0 NAND read: device 0 offset 0x800000, size 0x300000 3145728 bytes read: OK NAND read: device 0 offset 0x1140000, size 0xe00000 Skipping bad block 0x01b60000 14680064 bytes read: OK ## Booting kernel from Legacy Image at 81000000 ... Image Name: Linux-2.6.37 Created: 2012-06-08 14:39:46 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2661808 Bytes = 2.5 MiB Load Address: 80008000 Entry Point: 80008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ... Linux version 2.6.37 (cglin@cglin-desktop) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #3 Fri Jun 8 22:39:35 CST 2012 CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache Machine: ti8168_dvr vram size = 20971520 at 0x0 reserved size = 20971520 at 0x0 FB: Reserving 20971520 bytes SDRAM for VRAM Memory policy: ECC disabled, Data cache writeback OMAP chip is TI8168 2.0 Built 1 zonelists in Zone order, mobility grouping on. Total pages: 59904 Kernel command line: mem=256M console=ttyO2,115200n8 root=/dev/ram0 ro initrd=0x82000000,16M ramdisk_size=16000 ip=192.168.1.146:192.168.1.136:192.168.0.1:255.255.252.0::eth0:off vram=20M notifyk.vpssm3_sva=0xBFD00000 PID hash table entries: 1024 (order: 0, 4096 bytes) Dentry cache hash table entries: 32768 (order: 5, 131072 bytes) Inode-cache hash table entries: 16384 (order: 4, 65536 bytes) Memory: 236MB = 236MB total Memory: 217280k/217280k available, 44864k reserved, 0K highmem Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) DMA : 0xffc00000 - 0xffe00000 ( 2 MB) vmalloc : 0xd0800000 - 0xf8000000 ( 632 MB) lowmem : 0xc0000000 - 0xd0000000 ( 256 MB) modules : 0xbf000000 - 0xc0000000 ( 16 MB) .init : 0xc0008000 - 0xc0039000 ( 196 kB) .text : 0xc0039000 - 0xc050b000 (4936 kB) .data : 0xc050c000 - 0xc0554800 ( 290 kB) SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 NR_IRQS:407 IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts Total of 128 interrupts on 1 active controller GPMC revision 6.0 Trying to install interrupt handler for IRQ400 Trying to install interrupt handler for IRQ401 Trying to install interrupt handler for IRQ402 Trying to install interrupt handler for IRQ403 Trying to install interrupt handler for IRQ404 Trying to install interrupt handler for IRQ405 Trying to install interrupt handler for IRQ406 Trying to install type control for IRQ407 Trying to set irq flags for IRQ407 OMAP clockevent source: GPTIMER1 at 27000000 Hz Console: colour dummy device 80x30 Calibrating delay loop... 986.31 BogoMIPS (lpj=4931584) pid_max: default: 32768 minimum: 301 Security Framework initialized Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok devtmpfs: initialized omap_voltage_early_init: voltage driver support not added regulator: core version 0.5 regulator: dummy: NET: Registered protocol family 16 OMAP GPIO hardware version 0.1 OMAP GPIO hardware version 0.1 omap_mux_init: Add partition: #1: core, flags: 0 3-wired eeprom init done. (H/W ver:00) _omap_mux_get_by_name: Could not find signal i2c2_scl.i2c2_scl _omap_mux_get_by_name: Could not find signal i2c2_sda.i2c2_sda registered ti816x_vpss device registered TI816x on-chip HDMI device registered ti81xx_vidout device pm_dbg_init: only OMAP3 supported ti81xx_pcie: Invoking PCI BIOS... ti81xx_pcie: Setting up Host Controller... ti81xx_pcie: Register base mapped @0xd0820000 ti81xx_pcie: Starting PCI scan... PCI: bus0: Fast back to back transfers enabled bio: create slab <bio-0> at 0 vgaarb: loaded SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb registerd cppi-dma Intr @ IRQ 17 Cppi41 Init Done omap_i2c omap_i2c.1: bus 1 rev4.0 at 400 kHz omap_i2c omap_i2c.2: bus 2 rev4.0 at 400 kHz Advanced Linux Sound Architecture Driver Version 1.0.23. Switching to clocksource gp timer musb-hdrc: version 6.0, host, debug=0 musb-hdrc musb-hdrc.0: dma type: dma-cppi41 musb-hdrc musb-hdrc.0: MUSB HDRC host driver musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1 usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb1: Product: MUSB HDRC host driver usb usb1: Manufacturer: Linux 2.6.37 musb-hcd usb usb1: SerialNumber: musb-hdrc.0 hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected musb-hdrc musb-hdrc.0: USB Host mode controller at d081e000 using DMA, IRQ 18 musb-hdrc musb-hdrc.1: dma type: dma-cppi41 musb-hdrc musb-hdrc.1: MUSB HDRC host driver musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2 usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb2: Product: MUSB HDRC host driver usb usb2: Manufacturer: Linux 2.6.37 musb-hcd usb usb2: SerialNumber: musb-hdrc.1 hub 2-0:1.0: USB hub found hub 2-0:1.0: 1 port detected musb-hdrc musb-hdrc.1: USB Host mode controller at d0826800 using DMA, IRQ 19 NET: Registered protocol family 2 IP route cache hash table entries: 2048 (order: 1, 8192 bytes) TCP established hash table entries: 8192 (order: 4, 65536 bytes) TCP bind hash table entries: 8192 (order: 3, 32768 bytes) TCP: Hash tables configured (established 8192 bind 8192) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. Trying to unpack rootfs image as initramfs... rootfs image is not initramfs (junk in compressed archive); looks like an initrd Freeing initrd memory: 16384K NetWinder Floating Point Emulator V0.97 (double precision) PMU: registered new PMU device of type 0 omap-iommu omap-iommu.0: ducati registered omap-iommu omap-iommu.1: sys registered JFFS2 version 2.2. (NAND) ?? 2001-2006 Red Hat, Inc. msgmni has been set to 456 io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0 omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1 omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2 console [ttyO2] enabled brd: module loaded loop: module loaded ahci ahci.0: forcing PORTS_IMPL to 0x3 ahci ahci.0: AHCI 0001.0100 32 slots 2 ports 3 Gbps 0x3 impl platform mode ahci ahci.0: flags: ncq sntf pm led clo only pmp pio slum part ccc scsi0 : ahci_platform scsi1 : ahci_platform ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a150fff] port 0x100 irq 16 ata2: SATA max UDMA/133 irq_stat 0x00400040, connection status changed irq 16 omap2-nand driver initializing NAND device: Maf ID: 0xec, Chip ID: 0xf1 (Samsung, ) erasesize: 0x20000, writesize: 2048, oobsize: 64 Creating 8 MTD partitions on "omap2-nand.0": 0x000000000000-0x000000240000 : "U-Boot" 0x000000240000-0x000000280000 : "U-Boot Env and MAC" 0x000000280000-0x000000580000 : "U-Boot Logo" 0x000000580000-0x000000800000 : "Unused" 0x000000800000-0x000000c40000 : "Kernel" 0x000000c40000-0x000001140000 : "Setting" 0x000001140000-0x000002140000 : "Application File System1" 0x000002140000-0x000008000000 : "Application File System" davinci_mdio davinci_mdio.0: davinci mdio revision 1.6 davinci_mdio davinci_mdio.0: detected phy mask fffffff9 davinci_mdio.0: probed davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver ET1011C davinci_mdio davinci_mdio.0: phy[2]: device 0:02, driver ET1011C usbcore: registered new interface driver cdc_ether usbcore: registered new interface driver dm9601 Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. mice: PS/2 mouse device common for all mice omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0 rtc-s35390a 1-0030: rtc core: registered rtc-s35390a as rtc1 i2c /dev entries driver Linux video capture interface: v2.00 usbcore: registered new interface driver uvcvideo USB Video Class driver (v1.0.0) OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec usbcore: registered new interface driver usbhid usbhid: USB HID core driver notify_init : notify drivercreated for remote proc id 2 at physical Address 0xbfd00000 usbcore: registered new interface driver snd-usb-audio asoc: tvp5158-hifi <-> davinci-mcasp.0 mapping ok asoc: tlv320aic3x-hifi <-> davinci-mcasp.2 mapping ok asoc: SII9022a-hdmi-codec <-> davinci-mcasp.1 mapping ok asoc: HDMI-DAI-CODEC <-> hdmi-dai mapping ok ALSA device list: #0: TI81XX DVR #1: TI81XX DVR (HDMI) TCP cubic registered NET: Registered protocol family 10 IPv6 over IPv4 tunneling driver NET: Registered protocol family 17 VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3 omap_voltage_late_init: Voltage driver support not added Power Management for TI81XX. davinci_emac_probe: using random MAC addr: 66:20:a5:72:c1:19 davinci_emac_probe: using random MAC addr: 0a:e3:ed:16:23:46 rtc-s35390a 1-0030: setting system clock to 2012-06-17 07:01:28 UTC (1339916488) davinci_mdio davinci_mdio.0: resetting idled controller net eth0: attached PHY driver [ET1011C] (mii_bus:phy_addr=0:01, id=282f014) ADDRCONF(NETDEV_UP): eth0: link is not ready IP-Config: Complete: device=eth0, addr=192.168.1.146, mask=255.255.252.0, gw=192.168.0.1, host=192.168.1.146, domain=, nis-domain=(none), bootserver=192.168.1.136, rootserver=192.168.1.136, rootpath= PHY: 0:01 - Link is Up - 100/Full ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready ata1: SATA link down (SStatus 0 SControl 300) ata2: link is slow to respond, please be patient (ready=0) ata2: softreset failed (device not ready) ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300) ata2.00: ATA-8: WDC WD20EURS-63S48Y0, 51.0AB51, max UDMA/133 ata2.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32) ata2.00: configured for UDMA/133 scsi 1:0:0:0: Direct-Access ATA WDC WD20EURS-63S 51.0 PQ: 0 ANSI: 5 sd 1:0:0:0: Attached scsi generic sg0 type 0 sd 1:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB) sd 1:0:0:0: [sda] 4096-byte physical blocks sd 1:0:0:0: [sda] Write Protect is off sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA sda: unknown partition table sd 1:0:0:0: [sda] Attached SCSI disk RAMDISK: cramfs filesystem found at block 0 RAMDISK: Loading 12828KiB [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/done. VFS: Mounted root (cramfs filesystem) readonly on device 1:0. devtmpfs: mounted Freeing init memory: 196K INIT: version 2.86 booting Please wait: booting... Starting udev udevd (72): /proc/72/oom_adj is deprecated, please use /proc/72/oom_score_adj instead.
