Blaze 4460 Android 4.0 keep rebooting
Other Parts Discussed in Thread: 4460, TWL6030, TWL6032, TMP105, UKERNEL
I use Blaze 4460 platform run android 4.0
after I update the pre-build binary, I found I can't boot normally.
Following is the booting log, hope someone can help me.
The pre-build binary is 4AI.1.5 ICS
This link is what I follow http://www.omappedia.com/wiki/4AI.1.5_OMAP4_Icecream_Sandwich_Release_Notes
0621-2012 update booting log
Texas Instruments Inc X-Loader 1.41.0-g835089cd (May 26 2012 - 07:35:44)
OMAP4460: 1.2 GHz capable SOM
Starting OS Bootloader from EMMC ...
U-Boot 1.1.4-gbb9f0949 (Jun  6 2012 - 07:58:50)
Load address: 0x80e80000
DRAM:  1024 MB
Flash:  0 kB
Using default environment
In:    serial
Out:   serial
Err:   serial
efi partition table:
ptbl slot: EMMC:(1).
     256     128K xloader
     512     256K bootloader
    1024     128K misc
    2048      16M efs
   34816      16K crypto
   34848       8M recovery
   51232       8M boot
   67616     512M system
 1116192     256M cache
 1640480    2894M userdata
Net:   KS8851SNL
Hit any key to stop autoboot:  0
kernel   @ 80008000 (4309048)
ramdisk  @ 81000000 (164992)
I2C read: I/O error
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Linux version 3.0.21-00003-OMAP-Android+ (x0159895@achapps-linux) (gcc version 4.4.1 (Sourcery G++ Lite 201
0q1-202) ) #1 SMP PREEMPT Wed Jun 6 08:09:59 CDT 2012
[    0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c5387d
[    0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: OMAP4 blaze board
[    0.000000] android_display: setting default resolution 864*480, bpp=4
[    0.000000] android_display: tiler1d 13271040
[    0.000000] android_display: setting fb0.vram to 3440640
[    0.000000] android_display: setting vram to 3440640
[    0.000000] android_display: ion carveouts: 116916224 tiler2d, 3932160 nonsecure
[    0.000000] omap_ion_init: id=2 [ba300000-bfd00000] size=5a00000
[    0.000000] omap_ion_init: id=1 [ac9c0000-b3a00000] size=7040000
[    0.000000] omap_ion_init: id=3 [ac600000-ac9c0000] size=3c0000
[    0.000000] omap_ion_init: id=0 [ac9c0000-ac9c0000] size=0
[    0.000000] omap_ion_init: id=4 [ac9c0000-ac9c0000] size=0
[    0.000000] Reserving 4194304 bytes SDRAM for VRAM
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] OMAP4460 ES1.1
[    0.000000] SRAM: Mapped pa 0x40300000 to va 0xfe400000 size: 0xd000
[    0.000000] On node 0 totalpages: 180224
[    0.000000] free_area_init_node: node 0, pgdat c084e7c0, node_mem_map c1029000
[    0.000000]   Normal zone: 256 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 32512 pages, LIFO batch:7
[    0.000000]   HighMem zone: 1792 pages used for memmap
[    0.000000]   HighMem zone: 145664 pages, LIFO batch:31
[    0.000000] PERCPU: Embedded 7 pages/cpu @c1834000 s7072 r8192 d13408 u32768
[    0.000000] pcpu-alloc: s7072 r8192 d13408 u32768 alloc=8*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 178176
[    0.000000] Kernel command line: console=ttyO2,115200n8 mem=1G vmalloc=768M androidboot.console=ttyO2 omap_wdt.timer_ma
rgin=30 androidboot.serialno=0A3BDAA716007006 androidboot.bootloader=U-Boot_1.1.4-gbb9f0949
[    0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Memory: 512MB 192MB = 704MB total
[    0.000000] Memory: 702472k/702472k available, 346104k reserved, 589824K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
[    0.000000]     vmalloc : 0xc8800000 - 0xf8000000   ( 760 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xc8000000   ( 128 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .init : 0xc0008000 - 0xc004e000   ( 280 kB)
[    0.000000]       .text : 0xc004e000 - 0xc07d0000   (7688 kB)
[    0.000000]       .data : 0xc07d0000 - 0xc084f320   ( 509 kB)
[    0.000000]        .bss : 0xc084f344 - 0xc09a0450   (1349 kB)
[    0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] NR_IRQS:410
[    0.000000] omap_hwmod: dpll_mpu_m2_ck: missing clockdomain for dpll_mpu_m2_ck.
[    0.000000] OMAP clockevent source: GPTIMER1 at 32768 Hz
[    0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms
[    0.000030] Calibrating delay loop... 1392.74 BogoMIPS (lpj=5439488)
[    0.007904] pid_max: default: 32768 minimum: 301
[    0.070678] Mount-cache hash table entries: 512
[    0.070678] Initializing cgroup subsys debug
[    0.071441] Initializing cgroup subsys cpuacct
[    0.071441] Initializing cgroup subsys freezer
[    0.071441] CPU: Testing write buffer coherency: ok
[    0.071990] L310 cache controller enabled
[    0.071990] l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x5e470000, Cache size: 1048576 B
[    0.150146] CPU1: Booted secondary processor
[    0.220489] Brought up 2 CPUs
[    0.220520] SMP: Total of 2 processors activated (2792.83 BogoMIPS).
[    0.220733] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for emif_fw
[    0.220733] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l3_instr
[    0.223907] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l3_main_1
[    0.223907] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l3_main_2
[    0.223937] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_abe
[    0.223937] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_cfg
[    0.223937] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_per
[    0.223968] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_wkup
[    0.223968] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for mpu_private
[    0.223968] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for sl2if
[    0.224090] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for thermal_sensor
[    0.224121] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for usbhs_ohci
[    0.224121] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for usbhs_ehci
[    0.224365] omap_hwmod: l3_div_ck: missing clockdomain for l3_div_ck.
[    0.225067] omap_hwmod: l4_div_ck: missing clockdomain for l4_div_ck.
[    0.228302] _omap4_module_wait_ready: Timeout waiting for module enable (mcpdm_fck: clkctrl = 0x30002)
[    0.229614] omap_hwmod: mcpdm: cannot be enabled (3)
[    0.234863] print_constraints: dummy:
[    0.234863] NET: Registered protocol family 16
[    0.234863] GPMC revision 6.0
[    0.236114] EMIF0 is enabled with IRQ142
[    0.236114] EMIF1 is enabled with IRQ143
[    0.236968] Last reset was cold reset (PRM_RSTST=0x1)
[    0.236968]
[    0.237426] OMAP GPIO hardware version 0.1
[    0.239196] omap_mux_init: Add partition: #1: core, flags: 2
[    0.240325] omap_mux_init: Add partition: #2: wkup, flags: 2
[    0.241271] omap_mux_get_by_name: Could not find signal uart1_cts.uart1_cts
[    0.241271] omap_hwmod_mux_init: Could not allocate device mux entry
[    0.470428] Modem NOT detected
[    0.470458] Modem state properly updated to state 0
[    0.472839] omap_disp_led_init: Configuring as one display LED
[    0.598083] HSI: skipping omap_device registration
[    0.598083] OMAP DMA hardware revision 0.0
[    0.598388] omap_rproc_get_pool: dsp - no carveout memory is available at all
[    0.598388] omap_rproc_get_pool: ipu - carveout memory is unavailable: 0x0, 0x0
[    0.608245] bio: create slab <bio-0> at 0
[    0.608612] print_constraints: vwl1271: 1800 mV
[    0.608612] i2c-core: driver [twl] using legacy suspend method
[    0.609436] i2c-core: driver [twl] using legacy resume method
[    0.609436] SCSI subsystem initialized
[    0.610717] usbcore: registered new interface driver usbfs
[    0.611053] usbcore: registered new interface driver hub
[    0.611175] usbcore: registered new device driver usb
[    0.611816] omap_i2c omap_i2c.1: bus 1 rev4.0 at 400 kHz
[    0.611877] Skipping twl internal clock init and using bootloader value (unknown osc rate)
[    0.613952] twl6030: PIH (irq 39) chaining IRQs 368..387
[    0.616210] print_constraints: LDOUSB: 3300 mV normal standby
[    0.919891] twl6030_usb twl6030_usb: Initialized TWL6030 USB module
[    0.920471] ------------[ cut here ]------------
[    0.920471] WARNING: at drivers/mfd/twl-core.c:1008 add_children+0x9ec/0x9f4()
[    0.920654] This TWL6032 is an older revision that does not support low power measurements
[    0.920654] Modules linked in:
[    0.920684] Backtrace:
[    0.920684] [<c0059224>] (dump_backtrace+0x0/0x110) from [<c0606554>] (dump_stack+0x18/0x1c)
[    0.920745]  r6:000003f0 r5:c02fdf80 r4:c782bba8 r3:c782a000
[    0.920745] [<c060653c>] (dump_stack+0x0/0x1c) from [<c00a2858>] (warn_slowpath_common+0x5c/0x6c)
[    0.920745] [<c00a27fc>] (warn_slowpath_common+0x0/0x6c) from [<c00a290c>] (warn_slowpath_fmt+0x38/0x40)
[    0.920745]  r8:c08929a8 r7:00000010 r6:c08929a8 r5:00000018 r4:c08027fc
[    0.920837] r3:00000009
[    0.920837] [<c00a28d4>] (warn_slowpath_fmt+0x0/0x40) from [<c02fdf80>] (add_children+0x9ec/0x9f4)
[    0.920837]  r3:00000000 r2:c0765ed8
[    0.920898] [<c02fd594>] (add_children+0x0/0x9f4) from [<c05facec>] (twl_probe+0x33c/0x360)
[    0.920898] [<c05fa9b0>] (twl_probe+0x0/0x360) from [<c03a3d8c>] (i2c_device_probe+0xb8/0xec)
[    0.920959] [<c03a3cd4>] (i2c_device_probe+0x0/0xec) from [<c02e5524>] (driver_probe_device+0xa4/0x1ac)
[    0.920959]  r7:c08266a0 r6:c0830afc r5:c0892690 r4:c78e2020
[    0.920989] [<c02e5480>] (driver_probe_device+0x0/0x1ac) from [<c02e5708>] (__device_attach+0x44/0x48)
[    0.921020]  r8:c089266c r7:c02e56c4 r6:c782bd18 r5:c78e2020 r4:c08266a0
[    0.921051] r3:00000008
[    0.921051] [<c02e56c4>] (__device_attach+0x0/0x48) from [<c02e4948>] (bus_for_each_drv+0x68/0x94)
[    0.921081]  r5:00000000 r4:c78e2020
[    0.921112] [<c02e48e0>] (bus_for_each_drv+0x0/0x94) from [<c02e57d8>] (device_attach+0xa0/0xc0)
[    0.921112]  r7:c78d54a8 r6:00000000 r5:c78e2054 r4:c78e2020
[    0.921112] [<c02e5738>] (device_attach+0x0/0xc0) from [<c02e46e8>] (bus_probe_device+0x2c/0x48)
[    0.921173]  r6:00000000 r5:c78e2028 r4:c78e2020 r3:00000001
[    0.921203] [<c02e46bc>] (bus_probe_device+0x0/0x48) from [<c02e34b8>] (device_add+0x590/0x640)
[    0.921203] [<c02e2f28>] (device_add+0x0/0x640) from [<c02e3584>] (device_register+0x1c/0x20)
[    0.921234] [<c02e3568>] (device_register+0x0/0x20) from [<c03a4928>] (i2c_new_device+0x13c/0x164)
[    0.921264]  r4:c78e2000 r3:c78bcd20
[    0.921264] [<c03a47ec>] (i2c_new_device+0x0/0x164) from [<c03a4d54>] (i2c_register_adapter+0x1b4/0x288)
[    0.921295]  r7:c78d56ec r6:c78d54a8 r5:c788f480 r4:c78d5458
[    0.921295] [<c03a4ba0>] (i2c_register_adapter+0x0/0x288) from [<c03a4ee0>] (i2c_add_numbered_adapter+0xb8/0xd0)
[    0.921295] [<c03a4e28>] (i2c_add_numbered_adapter+0x0/0xd0) from [<c05fee3c>] (omap_i2c_probe+0x38c/0x43c)
[    0.921295]  r6:c786ddd4 r5:c7884200 r4:c78d5400
[    0.921295] [<c05feab0>] (omap_i2c_probe+0x0/0x43c) from [<c02e6b88>] (platform_drv_probe+0x20/0x24)
[    0.921417] [<c02e6b68>] (platform_drv_probe+0x0/0x24) from [<c02e5524>] (driver_probe_device+0xa4/0x1ac)
[    0.921417] [<c02e5480>] (driver_probe_device+0x0/0x1ac) from [<c02e56c0>] (__driver_attach+0x94/0x98)
[    0.921417]  r8:00000000 r7:c02e562c r6:c788423c r5:c0830c74 r4:c7884208
[    0.921478] r3:c02e6dfc
[    0.921478] [<c02e562c>] (__driver_attach+0x0/0x98) from [<c02e4c54>] (bus_for_each_dev+0x68/0x94)
[    0.921508]  r6:c782bee8 r5:00000000 r4:c0830c74 r3:00000000
[    0.921508] [<c02e4bec>] (bus_for_each_dev+0x0/0x94) from [<c02e5370>] (driver_attach+0x24/0x28)
[    0.921508]  r7:00000000 r6:c78da240 r5:c08252f0 r4:c0830c74
[    0.921508] [<c02e534c>] (driver_attach+0x0/0x28) from [<c02e451c>] (bus_add_driver+0x1fc/0x2c8)
[    0.921600] [<c02e4320>] (bus_add_driver+0x0/0x2c8) from [<c02e5d24>] (driver_register+0x80/0x194)
[    0.921630] [<c02e5ca4>] (driver_register+0x0/0x194) from [<c02e709c>] (platform_driver_register+0x58/0x60)
[    0.921630]  r8:00000000 r7:c002ddec r6:00000000 r5:c003ef7c r4:c084f360
[    0.921661] r3:00000000
[    0.921691] [<c02e7044>] (platform_driver_register+0x0/0x60) from [<c002de04>] (omap_i2c_init_driver+0x18/0x1c)
[    0.921722] [<c002ddec>] (omap_i2c_init_driver+0x0/0x1c) from [<c004e628>] (do_one_initcall+0x3c/0x18c)
[    0.921722] [<c004e5ec>] (do_one_initcall+0x0/0x18c) from [<c00083e4>] (kernel_init+0xb0/0x13c)
[    0.921752]  r9:00000000 r8:00000000 r7:00000013 r6:c00a716c r5:c003ef7c
[    0.921783] r4:c003e64c
[    0.921783] [<c0008334>] (kernel_init+0x0/0x13c) from [<c00a716c>] (do_exit+0x0/0x720)
[    0.921813]  r5:c0008334 r4:00000000
[    0.921813] ---[ end trace 1b75b31a2719ed1c ]---
[    0.922698] print_constraints: VANA: 2100 mV normal standby
[    0.923431] print_constraints: CLK32KG:
[    0.924133] print_constraints: CLK32KAUDIO:
[    0.924987] print_constraints: SYSEN:
[    0.925781] print_constraints: REGEN1:
[    0.926177] print_constraints: LDO5: 1200 <--> 3000 mV at 1800 mV normal standby
[    0.927062] print_constraints: LDO1: 1800 <--> 2500 mV at 1900 mV normal standby
[    0.927825] print_constraints: LDO7: 1200 <--> 2900 mV at 1800 mV normal standby
[    0.928558] print_constraints: LDO6: 1800 mV normal standby
[    0.929351] print_constraints: LDOLN: 1800 mV normal standby
[    0.929901] print_constraints: LDO2: 1000 <--> 3000 mV at 2800 mV normal standby
[    0.930358] print_constraints: LDO4: 1200 <--> 2800 mV at 1800 mV normal standby
[    0.931182] print_constraints: LDO3: 1000 <--> 3000 mV at 1200 mV normal standby
[    0.931854] print_constraints: VOUT: 4075 <--> 4950 mV at 3825 mV normal standby
[    0.932464] tps6130x 1-0033: Read from reg 0x7 failed
[    0.932464] tps6130x 1-0033: failed to access device
[    0.933105] tps6130x: probe of 1-0033 failed with error -121
[    0.933349] omap_i2c omap_i2c.2: bus 2 rev4.0 at 400 kHz
[    0.933654] omap_i2c omap_i2c.3: bus 3 rev4.0 at 400 kHz
[    0.934204] omap_i2c omap_i2c.4: bus 4 rev4.0 at 400 kHz
[    0.934600] omap-rproc omap-rproc.0: dsp is available
[    0.934600] omap-rproc omap-rproc.1: ipu is available
[    0.934600] Advanced Linux Sound Architecture Driver Version 1.0.24.
[    0.935333] Bluetooth: Core ver 2.16
[    0.935333] NET: Registered protocol family 31
[    0.935333] Bluetooth: HCI device and connection manager initialized
[    0.936065] Bluetooth: HCI socket layer initialized
[    0.936065] Bluetooth: L2CAP socket layer initialized
[    0.936065] Bluetooth: SCO socket layer initialized
[    0.936126] Switching to clocksource 32k_counter
[    0.938140] musb-hdrc: version 6.0, musb-dma, otg (peripheral+host)
[    0.938446] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[    0.938507] musb-hdrc: MHDRC RTL version 2.0
[    0.938537] musb-hdrc: setup fifo_mode 4
[    0.938537] musb-hdrc: 28/31 max ep, 16384/16384 memory
[    0.938781] musb-hdrc musb-hdrc: USB OTG mode controller at fc0ab000 using DMA, IRQ 124
[    0.939178] Switched to NOHz mode on CPU #0
[    0.939239] Switched to NOHz mode on CPU #1
[    0.939361] NET: Registered protocol family 2
[    0.939361] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.939361] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.940948] TCP bind hash table entries: 16384 (order: 6, 393216 bytes)
[    0.941619] TCP: Hash tables configured (established 16384 bind 16384)
[    0.941619] TCP reno registered
[    0.941650] UDP hash table entries: 64 (order: 0, 4096 bytes)
[    0.941650] UDP-Lite hash table entries: 64 (order: 0, 4096 bytes)
[    0.941650] NET: Registered protocol family 1
[    0.942413] RPC: Registered named UNIX socket transport module.
[    0.942413] RPC: Registered udp transport module.
[    0.942596] RPC: Registered tcp transport module.
[    0.942596] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.942810] Trying to unpack rootfs image as initramfs...
[    0.944183] Freeing initrd memory: 160K
[    1.561553] omap_init_opp_table: no hwmod or odev for hsi, [22] cannot add OPPs.
[    1.561553] omap_init_opp_table: no hwmod or odev for hsi, [23] cannot add OPPs.
[    1.812225] ram_console: got buffer at a0000000, size 200000
[    1.812347] ram_console: no valid data in buffer (sig = 0x00000000)
[    1.837432] console [ram-1] enabled
[    1.838287] omap-iommu omap-iommu.0: ducati registered
[    1.838439] omap-iommu omap-iommu.1: tesla registered
[    1.846252] highmem bounce pool size: 64 pages
[    1.846527] ashmem: initialized
[    1.855316] fuse init (API version 7.16)
[    1.855957] msgmni has been set to 220
[    1.856201] Registering char device tf_driver (122:0)
[    1.856414] SMCAG01.06.0 D
[    1.858428] io scheduler noop registered
[    1.858520] io scheduler deadline registered
[    1.858703] io scheduler cfq registered (default)
[    1.858856] start plist test
[    1.864196] end plist test
[    1.864990] OMAP DSS rev 4.0
[    1.867340] Keyboard driver not present
[    1.882843] dsscomp: initializing.
[    1.882965] misc dsscomp: display0=taal
[    1.883056] misc dsscomp: display1=hdmi_panel
[    1.883209] misc dsscomp: found 2 displays and 4 overlays, WB overlay 1
[    1.883666] could not allocate slot
[    1.884277] omap-rproc omap-rproc.1: powering up ipu
[    1.884674] virtio_rpmsg_bus virtio0: rpmsg backend virtproc probed successfully
[    1.885437] virtio_rpmsg_bus virtio1: rpmsg backend virtproc probed successfully
[    1.886322] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 104) is a OMAP UART0
[    1.886779] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 105) is a OMAP UART1
[    1.887268] omap_uart.2: ttyO2 at MMIO 0x48020000 (irq = 106) is a OMAP UART2
[    3.546874] console [ttyO2] enabled
[    3.546874] omap_uart.3: ttyO3 at MMIO 0x4806e000 (irq = 102) is a OMAP UART3
[    3.559143] in hpd work 1, state=0
[    3.559570] omap_ion_probe: adding heap secure_input of type 2 with ba300000@5a00000
[    3.559814] omap_ion_probe: adding heap tiler of type 4 with ac9c0000@7040000
[    3.559814] omap_ion_probe: adding heap nonsecure_tiler of type 4 with ac600000@3c0000
[    3.559875] omap_ion_probe: adding heap system of type 0 with ac9c0000@0
[    3.559936] omap_ion_probe: adding heap tiler_reservation of type 5 with ac9c0000@0
[    3.565582] brd: module loaded
[    3.570434] loop: module loaded
[    3.570434] (stk) :sysfs entries created
[    3.570434] (stk) : debugfs entries created
[    3.577117] ks8851 spi1.0: message enable is 0
[    3.581054] ks8851 spi1.0: eth0: revision 1, MAC ce:86:1c:47:5e:69, IRQ 194
[    3.581085] PPP generic driver version 2.4.2
[    3.581298] PPP Deflate Compression module registered
[    3.581298] PPP BSD Compression module registered
[    3.582092] PPP MPPE Compression module registered
[    3.582092] NET: Registered protocol family 24
[    3.582092] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.665924] omapdss HDMI: ENTER hdmi_display_enable
[    3.671691] omapdss HDMI: Set c-state constraint for HDMI
[    3.671722]
[    3.679504] HDCP: invalid AKSV
[    3.682922] omapdss HDMI error: *** INVALID AKSV: 0 Do not perform HDCP AUTHENTICATION
[    3.756683] in hpd work 2, state=1
[    4.077026] edid[000] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.077026] edid[010] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.091827] edid[020] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.095672] edid[030] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.106536] edid[040] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.113952] edid[050] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.121337] edid[060] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.128692] edid[070] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.136077] edid[080] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.143402] edid[090] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.150817] edid[0a0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.158142] edid[0b0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.165557] edid[0c0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.172973] edid[0d0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.180297] edid[0e0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.187683] edid[0f0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.195007] edid[100] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.202423] edid[110] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.209808] edid[120] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.217132] edid[130] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.224517] edid[140] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.231842] edid[150] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.239257] edid[160] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.246643] edid[170] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.253997] edid[180] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.261383] edid[190] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.268737] edid[1a0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.276123] edid[1b0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.283447] edid[1c0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.290863] edid[1d0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.298248] edid[1e0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.305603] edid[1f0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.373870] in hpd work 3, state=1
[    4.576995] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[    4.583435] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
[    4.591735] ehci-omap ehci-omap.0: irq 109, io mem 0x4a064c00
[    4.608276] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[    4.614715] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    4.622314] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.630371] usb usb1: Product: OMAP-EHCI Host Controller
[    4.636260] usb usb1: Manufacturer: Linux 3.0.21-00003-OMAP-Android+ ehci_hcd
[    4.644256] usb usb1: SerialNumber: ehci-omap.0
[    4.649841] hub 1-0:1.0: USB hub found
[    4.654022] hub 1-0:1.0: 3 ports detected
[    4.686523] I2C Bus Low?
[    4.686553] usbcore: registered new interface driver cdc_acm
[    4.686553] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    4.686553] Initializing USB Mass Storage driver...
[    4.686676] usbcore: registered new interface driver usb-storage
[    4.686676] USB Mass Storage support registered.
[    4.686828] usbcore: registered new interface driver usbserial
[    4.686859] usbserial: USB Serial Driver core
[    4.733032] edid[000] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.740417] edid[010] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.747802] edid[020] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.755096] edid[030] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.762512] edid[040] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.769866] edid[050] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.777282] edid[060] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.784576] edid[070] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.791992] edid[080] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.799377] edid[090] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.806701] edid[0a0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.814086] edid[0b0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.821411] edid[0c0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.828796] edid[0d0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.836212] edid[0e0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.843536] edid[0f0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.850921] edid[100] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.858245] edid[110] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.865600] edid[120] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.873016] edid[130] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.880310] edid[140] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.887695] edid[150] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.895050] edid[160] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.902404] edid[170] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.909729] edid[180] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.917114] edid[190] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.924499] edid[1a0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.931854] edid[1b0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.939239] edid[1c0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.946563] edid[1d0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.953948] edid[1e0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.961334] edid[1f0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    4.968658] omapdss HDMI: failed to read E-EDID
[    4.988952] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    4.996582] android_usb gadget: Number of LUNs=1
[    5.001770]  lun0: LUN: removable file: (no medium)
[    5.007476] android_usb gadget: android_usb ready
[    5.012695] musb-hdrc musb-hdrc: MUSB HDRC host driver
[    5.018524] musb-hdrc musb-hdrc: new USB bus registered, assigned bus number 2
[    5.026611] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    5.030151] in hpd work 4, state=1
[    5.037963] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.046020] usb usb2: Product: MUSB HDRC host driver
[    5.051513] usb usb2: Manufacturer: Linux 3.0.21-00003-OMAP-Android+ musb-hcd
[    5.059478] usb usb2: SerialNumber: musb-hdrc
[    5.064819] hub 2-0:1.0: USB hub found
[    5.069091] hub 2-0:1.0: 1 port detected
[    5.074005] mousedev: PS/2 mouse device common for all mice
[    5.080902] input: omap4-keypad as /devices/platform/omap/omap4-keypad/input/input0
[    5.095275] tm12xx_ts: Synaptic TM12xx Touchscreen Driver found man id 1 (1)
[    5.108123] tm12xx_ts 2-004b: resetting device (reg 0x62)
[    5.249298] tm12xx_ts 2-004b: no button capabilities found
[    5.255767] tm12xx_ts: Synaptic TM12xx Touchscreen Driver found man id 1 (1)
[    5.264221] tm12xx_ts: product ID: TM1217 family:1 fw:9
[    5.270294] input: syn_tm12xx_ts_1 as /devices/platform/omap/omap_i2c.2/i2c-2/2-004b/input/input1
[    5.281524] tm12xx_ts 2-004b: device status: 0x0, no error
[    5.290863] tm12xx_ts 3-004b: resetting device (reg 0x62)
[    5.342742] I2C Bus Low?
[    5.345611] edid[000] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.353027] edid[010] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.360351] edid[020] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.367736] edid[030] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.375061] edid[040] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.382446] edid[050] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.389770] edid[060] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.397155] edid[070] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.404541] edid[080] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.411865] edid[090] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.419250] edid[0a0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.426574] edid[0b0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.433258] tm12xx_ts 3-004b: no button capabilities found
[    5.434509] tm12xx_ts: product ID: TM1217 family:1 fw:9
[    5.434783] input: syn_tm12xx_ts_2 as /devices/platform/omap/omap_i2c.3/i2c-3/3-004b/input/input2
[    5.435821] tm12xx_ts 3-004b: device status: 0x0, no error
[    5.461730] edid[0c0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.469146] edid[0d0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.472808] CMA3000 Acclerometer : Revision 10
[    5.481475] edid[0e0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.488800] edid[0f0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.496185] edid[100] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.503570] edid[110] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.506927] input: cma3000-acclerometer as /devices/virtual/input/input3
[    5.518341] edid[120] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.525634] edid[130] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.533020] edid[140] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.540344] edid[150] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.546112] bh1780 3-0029: Ambient Light Sensor, Rev : 1
[    5.546295] input: bh1780gli as /devices/virtual/input/input4
[    5.547393] bmp085 4-0077: BMP085 ver. 2.0 found.
[    5.547637] input: bmp085 as /devices/virtual/input/input5
[    5.547790] bmp085 4-0077: Succesfully initialized bmp085!
[    5.548187] twl6030_pwrbutton_probe: Enter
[    5.548645] input: twl6030_pwrbutton as /devices/platform/omap/omap_i2c.1/i2c-1/1-0049/twl6030_pwrbutton/input/input6
[    5.550170] input: hmc5843 as /devices/virtual/input/input7
[    5.550445] sfh7741_probe: Proximity sensor
[    5.550659] input: sfh7741 as /devices/platform/sfh7741.1/input/input8
[    5.551727] twl_rtc twl_rtc: Power up reset detected.
[    5.552764] twl_rtc twl_rtc: Enabling TWL-RTC.
[    5.554748] using rtc device, twl_rtc, for alarms
[    5.554809] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
[    5.634246] edid[160] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.641693] edid[170] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.641815] i2c /dev entries driver
[    5.642486] lirc_dev: IR Remote Control driver registered, major 249
[    5.642486] IR NEC protocol handler initialized
[    5.642517] IR RC5(x) protocol handler initialized
[    5.642517] IR RC6 protocol handler initialized
[    5.642517] IR JVC protocol handler initialized
[    5.642547] IR Sony protocol handler initialized
[    5.642547] IR RC5 (streamzap) protocol handler initialized
[    5.642547] IR LIRC bridge handler initialized
[    5.642547] Linux video capture interface: v2.00
[    5.642730] dmm: probe base: fd300000, irq 145
[    5.706878] edid[180] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.714202] edid[190] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.721588] edid[1a0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.725952] twl6030_bci twl6030_bci: Battery Voltage at Bootup is 3820 mV
[    5.736419] edid[1b0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.736602] lm75 3-0048: hwmon0: sensor 'tmp105'
[    5.741394] OMAP Watchdog Timer Rev 0x01: initial timeout 30 sec
[    5.743011] device-mapper: uevent: version 1.0.3
[    5.743347] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
[    5.743408] Bluetooth: HCI UART driver ver 2.2
[    5.743408] Bluetooth: HCI H4 protocol initialized
[    5.743438] Bluetooth: Bluetooth Driver for TI WiLink - Version 1.0
[    5.787261] edid[1c0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.788635] (stc): st_register(2)
[    5.788635] (stc):  chnl_id list empty :2
[    5.788665] (stk) : st_kim_start
[    5.806243] edid[1d0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.806243] cpuidle: using governor ladder
[    5.806274] cpuidle: using governor menu
[    5.809753] Registered led device: omap4:green:debug0
[    5.809875] Registered led device: omap4:green:debug1
[    5.810089] leds-gpio: probe of leds-gpio failed with error -16
[    5.810546] Registered led device: omap4:green:chrg
[    5.810760] omap4430_sdp_display_probe:Enter
[    5.810852] Registered led device: lcd-backlight
[    5.811279] omap4430_sdp_display_probe:Exit
[    5.811492] omap4430_keypad_led_probe:Enter
[    5.811584] Registered led device: keyboard-backlight
[    5.812042] omap4430_keypad_led_probe:Exit
[    5.814178] usbcore: registered new interface driver usbhid
[    5.814178] usbhid: USB HID core driver
[    5.885864] edid[1e0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.886108] logger: created 256K log 'log_main'
[    5.886230] logger: created 256K log 'log_events'
[    5.886322] logger: created 256K log 'log_radio'
[    5.886444] logger: created 256K log 'log_system'
[    5.888946] thermal_sensor_set_temp: no cooling agents for domain cpu
[    5.888977] omap_report_temp:thermal_sensor_set_temp reports error
[    5.897521] thermal_sensor_set_temp: no cooling agents for domain cpu
[    5.897552] omap_temp_sensor omap_temp_sensor.0: omap_ondie_sensor : 'omap_temp_sensor'
[    5.897796] pcb_temp_sensor pcb_temp_sensor.0: pcb_sensor : 'pcb_temp_sensor'
[    5.897979] OMAPRPC: Registration of OMAPRPC rpmsg service returned 0!
[    5.898742] OMAP HSI: HSI driver version 0.4.3
[    5.899047] OMAP HSI: Platform DRIVER register FAILED: -19
[    5.899444] usbcore: registered new interface driver snd-usb-audio
[    5.902191] SDP4430 SoC init
[    5.910369] (stk) :ldisc_install = 1
[    5.914642] twl6040-codec twl6040-codec: couldn't get VDDHF regulator -19
[    5.991729] edid[1f0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    5.999114] omapdss HDMI: failed to read E-EDID
[    6.021636] asoc: null-codec-dai <-> MultiMedia1 mapping ok
[    6.029205] asoc: null-codec-dai <-> MultiMedia2 mapping ok
[    6.037170] asoc: null-codec-dai <-> Voice mapping ok
[    6.047454] asoc: null-codec-dai <-> Tones mapping ok
[    6.054595] asoc: null-codec-dai <-> Vibra mapping ok
[    6.061370] in hpd work 5, state=1
[    6.062408] asoc: null-codec-dai <-> MODEM mapping ok
[    6.065338] asoc: null-codec-dai <-> MultiMedia1 LP mapping ok
[    6.067260] asoc: FM Digital <-> omap-mcbsp-dai.1 mapping ok
[    6.068695] asoc: twl6040-dl1 <-> mcpdm-dl mapping ok
[    6.070831] asoc: dmic-hifi <-> omap-dmic-dai-0 mapping ok
[    6.072784] twl6040-codec twl6040-codec: ASoC: Failed to create Aux/FM Stereo In debugfs file
[    6.073822] asoc: twl6040-dl1 <-> mcpdm-dl1 mapping ok
[    6.074798] asoc: twl6040-ul <-> mcpdm-ul1 mapping ok
[    6.075744] asoc: twl6040-dl2 <-> mcpdm-dl2 mapping ok
[    6.076690] asoc: twl6040-vib <-> mcpdm-vib mapping ok
[    6.077697] asoc: Bluetooth <-> omap-mcbsp-dai.0 mapping ok
[    6.078674] asoc: Bluetooth <-> omap-mcbsp-dai.0 mapping ok
[    6.079681] asoc: FM Digital <-> omap-mcbsp-dai.1 mapping ok
[    6.080688] asoc: MODEM <-> omap-mcbsp-dai.1 mapping ok
[    6.081634] asoc: dmic-hifi <-> omap-dmic-abe-dai-0 mapping ok
[    6.082611] asoc: dmic-hifi <-> omap-dmic-abe-dai-1 mapping ok
[    6.083587] asoc: dmic-hifi <-> omap-dmic-abe-dai-2 mapping ok
[    6.084564] asoc: null-codec-dai <-> omap-abe-vxrec-dai mapping ok
[    6.087280] input: SDP4430 Headset Jack as /devices/platform/soc-audio/sound/card0/input9
[    6.098785] asoc: hdmi-audio-codec <-> hdmi-audio-dai mapping ok
[    6.099395] ALSA device list:
[    6.099395]   #0: TI OMAP4 Board
[    6.099395]   #1: OMAP4HDMI
[    6.099517] GACT probability NOT on
[    6.099548] Mirror/redirect action on
[    6.099548] u32 classifier
[    6.099548]     Actions configured
[    6.099578] Netfilter messages via NETLINK v0.30.
[    6.099639] nf_conntrack version 0.5.0 (10978 buckets, 43912 max)
[    6.101013] ctnetlink v0.93: registering with nfnetlink.
[    6.101074] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[    6.101104] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[    6.101440] xt_time: kernel timezone is -0000
[    6.104370] ip_tables: (C) 2000-2006 Netfilter Core Team
[    6.104583] arp_tables: (C) 2002 David S. Miller
[    6.104644] TCP cubic registered
[    6.105438] NET: Registered protocol family 10
[    6.108642] mmc0: new high speed DDR MMC card at address 0001
[    6.114868] Mobile IPv6
[    6.114929] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    6.115325] IPv6 over IPv4 tunneling driver
[    6.122863] NET: Registered protocol family 17
[    6.122924] NET: Registered protocol family 15
[    6.123260] Bridge firewalling registered
[    6.123382] Bluetooth: RFCOMM TTY layer initialized
[    6.123413] Bluetooth: RFCOMM socket layer initialized
[    6.123413] Bluetooth: RFCOMM ver 1.11
[    6.123443] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    6.123443] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    6.123596] NET: Registered protocol family 35
[    6.124053] NET: Registered protocol family 37
[    6.124053] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[    6.350128] mmcblk0: mmc0:0001 HYNIX  3.60 GiB
[    6.360504] ThumbEE CPU extension supported.
[    6.360534] mmcblk0boot0: mmc0:0001 HYNIX  partition 1 2.00 MiB
[    6.371917] Registering SWP/SWPB emulation handler
[    6.371948] mmcblk0boot1: mmc0:0001 HYNIX  partition 2 2.00 MiB
[    6.388610] Alternate GPT is invalid, using primary GPT.
[    6.390350] Reprogramming LPDDR2 timings to 400000000 Hz
[    6.400634]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10
[    6.400634] sr_init: No PMIC hook to init smartreflex
[    6.400878] smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver initialized
[    6.401062] smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver initialized
[    6.401245] smartreflex smartreflex.2: omap_sr_probe: SmartReflex driver initialized
[    6.437713] SmartReflex class 1.5 driver: initialized (86400000ms)
[    6.446411] adc_to_temp_conversion:Temp read is invalid 0
[    6.452484] thermal_lookup_temp: getting temp is not supported for domain pcb
[    6.452484]  mmcblk0boot1: unknown partition table
[    6.465759] omap_cpu_thermal_manager:sensor 35200 avg sensor 0 pcb
[    6.472717] 0, delta 2948 hot spot 38148
[    6.477447] omap_cpu_thermal_manager: hot spot temp 38148 - going into safe zone
[    6.477508]  mmcblk0boot0: unknown partition table
[    6.499603] adc_to_temp_conversion:Temp read is invalid 0
[    6.505706] thermal_lookup_temp: getting temp is not supported for domain pcb
[    6.515594] adc_to_temp_conversion:Temp read is invalid 0
[    6.521667] thermal_lookup_temp: getting temp is not supported for domain pcb
[    6.522308] sr_class1p5_calib_work: mpu Stop sampling: Voltage Nominal=1203000 samples=7
[    6.522338] sr_class1p5_calib_work: mpu: Calibration complete: Voltage Nominal=1203000Calib=830000 margin=0
[    6.522369] sr_class1p5_calib_work: iva Stop sampling: Voltage Nominal=950000 samples=7
[    6.522460] sr_class1p5_calib_work: iva: Calibration complete: Voltage Nominal=950000Calib=860920 margin=13000
[    6.522460] sr_class1p5_calib_work: core Stop sampling: Voltage Nominal=1127000 samples=7
[    6.522521] sr_class1p5_calib_work: core Vsafe 1228060 > Vnom 1127000. 25320[13000] margin onvnom 1127000 curr_v=120274
0
[    6.522613] sr_class1p5_calib_work: core: Calibration complete: Voltage Nominal=1127000Calib=1228060 margin=13000
[    6.602966] adc_to_temp_conversion:Temp read is invalid 0
[    6.609100] thermal_lookup_temp: getting temp is not supported for domain pcb
[    6.617034] Power Management for TI OMAP4.
[    6.621856] OMAP4 PM: Static dependency added between MPUSS and DUCATI <-> L4_PER/CFG and L3_1.
[    6.655273] I2C Bus Low?
[    6.658203] edid[000] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.665557] edid[010] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.672973] edid[020] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.680358] edid[030] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.696960] clock: disabling unused clocks to save power
[    6.702880] edid[040] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.710266] edid[050] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.718383] edid[060] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.725524] edid[070] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.732788] edid[080] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.739929] edid[090] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.747131] edid[0a0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.751739] cannot apply mgr(lcd) on inactive device
[    6.751770] omapfb omapfb: failed to apply dispc config
[    6.751800] cannot apply mgr(lcd2) on inactive device
[    6.751800] omapfb omapfb: failed to apply dispc config
[    6.777069] edid[0b0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.784484] edid[0c0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.789947] mmc2: card claims to support voltages below the defined range. These will be ignored.
[    6.801605] edid[0d0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.807769] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[    6.808441] mmc2: new high speed SDIO card at address 0001
[    6.821136] edid[0e0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.828430] edid[0f0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.835815] edid[100] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.843170] edid[110] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.850494] edid[120] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.857849] edid[130] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.865173] edid[140] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.872528] edid[150] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.879913] edid[160] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.887237] edid[170] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.894592] edid[180] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.901916] edid[190] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.909271] edid[1a0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.916595] edid[1b0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.923950] edid[1c0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.931304] edid[1d0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.933807] taal display0: taal panel revision e3.85.7d
[    6.934814] adc_to_temp_conversion:Temp read is invalid 0
[    6.934814] thermal_lookup_temp: getting temp is not supported for domain pcb
[    6.935882] adc_to_temp_conversion:Temp read is invalid 0
[    6.935882] thermal_lookup_temp: getting temp is not supported for domain pcb
[    6.936950] adc_to_temp_conversion:Temp read is invalid 0
[    6.936950] thermal_lookup_temp: getting temp is not supported for domain pcb
[    6.986083] edid[1e0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    6.993469] edid[1f0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.001220] Invalid Device Structure
[    7.005249] omapdss HDMI: failed to read E-EDID
[    7.050537] (stk) :ldisc installation timeout
[    7.055847] (stk) :ldisc_install = 0
[    7.061431] in hpd work 6, state=1
[    7.065734] twl_rtc twl_rtc: setting system clock to 2000-01-01 00:00:01 UTC (946684801)
[    7.075988] Freeing init memory: 280K
[    7.082580] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[    7.213897] keychord: using input dev omap4-keypad for fevent
[    7.269561] EXT4-fs (mmcblk0p8): INFO: recovery required on readonly filesystem
[    7.277954] EXT4-fs (mmcblk0p8): write access will be enabled during recovery
[    7.301879] EXT4-fs (mmcblk0p8): recovery complete
[    7.327056] sr_class1p5_calib_work: core Stop sampling: Voltage Nominal=962000 samples=11
[    7.336547] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: (null)
[    7.336761] sr_class1p5_calib_work: core: Calibration complete: Voltage Nominal=962000Calib=886240 margin=38000
[    7.336822] sr_class1p5_calib_work: mpu Stop sampling: Voltage Nominal=1025000 samples=13
[    7.337097] sr_class1p5_calib_work: mpu: Calibration complete: Voltage Nominal=1025000Calib=840000 margin=10000
[    7.378021] I2C Bus Low?
[    7.380889] edid[000] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.388183] edid[010] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.395446] edid[020] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.402740] edid[030] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.409973] edid[040] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.417297] edid[050] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.424591] edid[060] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.432067] edid[070] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.439331] edid[080] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.446502] edid[090] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.454498] edid[0a0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.461730] edid[0b0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.469360] edid[0c0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.476684] edid[0d0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.483245] sr_class1p5_calib_work: mpu Stop sampling: Voltage Nominal=1380000 samples=0
[    7.483276] sr_class1p5_calib_work: mpu: Calibration complete: Voltage Nominal=1380000Calib=1380000 margin=0
[    7.503417] edid[0e0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.510864] edid[0f0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.518554] edid[100] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.525939] edid[110] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.533111] edid[120] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.540344] edid[130] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.547851] edid[140] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.555480] edid[150] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.562866] EXT4-fs (mmcblk0p10): recovery complete
[    7.563232] edid[160] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.563232] edid[170] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.563262] edid[180] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.563262] edid[190] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.563262] edid[1a0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.563262] edid[1b0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.563293] edid[1c0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.563293] edid[1d0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.563293] edid[1e0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.563323] edid[1f0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    7.563323] omapdss HDMI: failed to read E-EDID
[    7.563323] Failed to read EDID after 5 times. Giving up.
[    7.762878] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit
[    7.940429] adc_to_temp_conversion:Temp read is invalid 0
[    7.948913] thermal_lookup_temp: getting temp is not supported for domain pcb
[    7.960968] adc_to_temp_conversion:Temp read is invalid 0
[    7.967620] thermal_lookup_temp: getting temp is not supported for domain pcb
[    7.977722] adc_to_temp_conversion:Temp read is invalid 0
[    7.983612] thermal_lookup_temp: getting temp is not supported for domain pcb
[    8.005126] omap-rproc omap-rproc.1: Loaded BIOS image ducati-m3.bin, size 6609400
[    8.009063] EXT4-fs (mmcblk0p9): recovery complete
[    8.009063] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: nomblk_io_submit
[    8.038482] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: (null)
[    8.063507] omap_hwmod: ipu: failed to hardreset
[    8.074890] omap-rproc omap-rproc.1: remote processor ipu is now up
[    8.089477] omap_rpmsg_mbox_callback: received echo reply from ipu !
[    8.096740] omap_rpmsg_mbox_callback: received echo reply from ipu !
[    8.104248] omap_rpmsg_mbox_callback: received echo reply from ipu !
[    8.111022] omap_rpmsg_mbox_callback: received echo reply from ipu !
[    8.120269] rpmsg_omx rpmsg-omx0: new OMX connection srv channel: 1024 -> 60!
[    8.210449] (stk) : timed out waiting for ldisc to be un-installed
[    8.238250] rpmsg_omx rpmsg-omx1: new OMX connection srv channel: 1024 -> 60!
[    8.256286] init: cannot find '/system/bin/setup_fs', disabling 'setup_fs'
[    8.264251] HDCP: failed to load keys
[    8.266967] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
[    8.362274] (stk) :ldisc_install = 1
[    8.413177] Compat-wireless backport release: ol_R5.00.18
[    8.419555] Backport based on wl12xx.git ol_R5.00.18
[    8.466186] (stc): st_tty_open
[    8.469604] (stk) :line discipline installed
[    8.474761] (stk) :TIInit_10.6.15.bts
[    8.648254] PVR: PVRCore_Init
[    8.652282] PVR: PVRSRVDriverProbe(pDevice=c78a4800)
[    8.659057] PVR: SGX register base: 0x56000000
[    8.663909] PVR: SGX register size: 65535
[    8.668334] PVR: SGX IRQ: 53
[    8.673828] PVR: EnableSystemClocks: Enabling System Clocks
[    8.681701] PVR: PVRCore_Init: major device 246
[    8.748443] omaplfbOMAPLFBInit: Blitsville gc2d not present, blits disabled
[    8.759552] omaplfb: OMAPLFBInitIonOmap: Device 0: Requesting 2 TILER 2D framebuffers
[    8.834533] cfg80211: Calling CRDA to update world regulatory domain
[    8.855133] cfg80211: World regulatory domain updated:
[    8.861145] cfg80211:     (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[    8.870391] cfg80211:     (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[    8.880981] cfg80211:     (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[    8.895050] cfg80211:     (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[    8.903717] cfg80211:     (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[    8.912078] (stc): add_channel_to_table: id 2
[    8.912078] (stc): st_register(3)
[    8.912078] (stc): add_channel_to_table: id 3
[    8.912109] (stc): st_register(4)
[    8.912109] (stc): add_channel_to_table: id 4
[    8.934906] cfg80211:     (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[    8.943695] PVR: Installing MISR with cookie bf03cf48
[    8.950317] PVR: Installing device LISR SGX ISR on IRQ 53 with cookie c7335000
[    8.958984] PVR: OSUnMapPhysToLin: unmapping 65535 bytes from c8de0000
[    8.966125] PVR: SysFinalise: Version string: SGX revision = 1.2.0
[    8.992645] adc_to_temp_conversion:Temp read is invalid 0
[    8.998535] thermal_lookup_temp: getting temp is not supported for domain pcb
[    9.008087] adc_to_temp_conversion:Temp read is invalid 0
[    9.014129] EXT4-fs (mmcblk0p8): re-mounted. Opts: (null)
[    9.014526] thermal_lookup_temp: getting temp is not supported for domain pcb
[    9.015441] adc_to_temp_conversion:Temp read is invalid 0
[    9.015441] thermal_lookup_temp: getting temp is not supported for domain pcb
[    9.054382] EXT4-fs (mmcblk0p8): re-mounted. Opts: (null)
[    9.657714] wl12xx: driver version: BETA_01202012_01-1547-g4efe999-dirty
[    9.667266] wl12xx: compilation time: Wed Jun  6 08:17:03 2012
[    9.676422] android_usb: already disabled
[    9.682556] mtp_bind_config
[    9.685791] adb_bind_config
shell@android:/ $ [   10.012329] warning: `adbd' uses 32-bit capabilities (legacy support in use)
[   10.021118] adb_open
[   10.024444] adc_to_temp_conversion:Temp read is invalid 0
[   10.031249] thermal_lookup_temp: getting temp is not supported for domain pcb
[   10.040771] adc_to_temp_conversion:Temp read is invalid 0
[   10.046752] thermal_lookup_temp: getting temp is not supported for domain pcb
[   10.054840] sr_class1p5_calib_work: core Stop sampling: Voltage Nominal=1250000 samples=3
[   10.064117] sr_class1p5_calib_work: core: Calibration complete: Voltage Nominal=1250000Calib=1228060 margin=13000
[   10.079528] adc_to_temp_conversion:Temp read is invalid 0
[   10.085937] thermal_lookup_temp: getting temp is not supported for domain pcb
[   10.938018] (stc): remove_channel_from_table: id 2
[   10.943267] (stc): remove_channel_from_table: id 3
[   10.948486] (stc): remove_channel_from_table: id 4
[   10.953765] (stc):  all chnl_ids unregistered
[   10.958526] (stk) :ldisc_install = 0
[   10.962371] (stc): st_tty_close
[   11.093505] adc_to_temp_conversion:Temp read is invalid 0
[   11.099395] thermal_lookup_temp: getting temp is not supported for domain pcb
[   11.108032] adc_to_temp_conversion:Temp read is invalid 0
[   11.113891] thermal_lookup_temp: getting temp is not supported for domain pcb
[   11.122558] adc_to_temp_conversion:Temp read is invalid 0
[   11.128417] thermal_lookup_temp: getting temp is not supported for domain pcb
[   11.768005] PVR_K: HWRecoveryResetSGX: SGX Hardware Recovery triggered
[   11.775268] ACTIVE COMPOSITIONS on lcd
[   11.775268]
[   11.775268]   DISPC pipeline:
[   11.775268]
[   11.775268]     info:        clean (none)
[   11.775268]     cache:       clean (none)
[   11.775268]     shadow:  off clean (none)
[   11.775268]     dispc:             (none)
[   11.775268]
[   11.775268] ACTIVE COMPOSITIONS on tv
[   11.775299]
[   11.775299]   DISPC pipeline:
[   11.775299]
[   11.775299]     info:        clean (none)
[   11.775299]     cache:       clean (none)
[   11.822753]     shadow:  off clean (none)
[   11.822753]     dispc:             (none)
[   11.822753]
[   11.822753] ACTIVE COMPOSITIONS on lcd2
[   11.822753]
[   11.822753]   DISPC pipeline:
[   11.822753]
[   11.822753]     info:        clean (none)
[   11.822753]     cache:       clean (none)
[   11.822784]     dispc:             (none)
[   11.822784]
[   11.822784] ACTIVE GRALLOC FLIPS
[   11.867218]
[   11.867218]
[   11.872070] PVR_K: SGX debug (blaze_android_sgx_ogles1_ogles2_GPL sgxddk 18 1.8@869593)
[   11.884887] PVR_K:(Error): SGX Register Base Address (Linear):   0xC8B20000 [0, ]
[   11.893371] PVR_K:(Error): SGX Register Base Address (Physical): 0x56000000 [0, ]
[   11.901885] PVR_K: (P0) EUR_CR_CORE_ID:          01140000
[   11.908264] PVR_K: (P0) EUR_CR_CORE_REVISION:    00010200
[   11.914215] PVR_K: (P0) EUR_CR_EVENT_STATUS:     20000000
[   11.920288] PVR_K: (P0) EUR_CR_EVENT_STATUS2:    00000008
[   11.926116] PVR_K: (P0) EUR_CR_BIF_CTRL:         00000000
[   11.932067] PVR_K: (P0) EUR_CR_BIF_INT_STAT:     00008000
[   11.937927] PVR_K: (P0) EUR_CR_BIF_FAULT:        00000000
[   11.943756] PVR_K: (P0) EUR_CR_BIF_MEM_REQ_STAT: 00000000
[   11.949584] PVR_K: (P0) EUR_CR_CLKGATECTL:       000AAA6A
[   11.955444] PVR_K: (P0) EUR_CR_PDS_PC_BASE:      00203C50
[   11.961303] PVR_K: Flip Command Complete Data 0 for display device 1:
[   11.968322] PVR_K: Flip Command Complete Data 1 for display device 1:
[   11.975280] PVR_K: SGX Host control:
[   11.979187] PVR_K:   (HC-0) 0x00000001 0x00000000 0x00000000 0x00000001
[   11.986267] PVR_K:   (HC-10) 0x00000000 0x0000000A 0x0005DC00 0x00000003
[   11.993438] PVR_K:   (HC-20) 0x00000001 0x00000001 0x00000000 0x00000001
[   12.000610] PVR_K:   (HC-30) 0x00000017 0xEED1B278 0x00000000 0x00000000
[   12.007965] PVR_K:   (HC-40) 0x00000000 0x087BF500 0x087C6300 0x087C3100
[   12.015563] PVR_K: SGX TA/3D control:
[   12.019592] PVR_K:   (T3C-0) 0x0F003000 0x0F003120 0x0F002000 0x00000000
[   12.027252] PVR_K:   (T3C-10) 0x00000000 0x00000002 0x00000000 0x00000000
[   12.034484] PVR_K:   (T3C-20) 0x00000000 0x00000000 0x00000000 0x00000000
[   12.041748] PVR_K:   (T3C-30) 0x00000000 0x00000000 0x00000000 0x00000000
[   12.049011] PVR_K:   (T3C-40) 0x00000000 0x00000000 0x00000000 0x00000000
[   12.056335] PVR_K:   (T3C-50) 0x00000000 0x00000000 0x00000000 0x00000000
[   12.063568] PVR_K:   (T3C-60) 0x00000000 0x00000000 0x00000000 0x00000000
[   12.070861] PVR_K:   (T3C-70) 0x00000000 0x00000000 0x00000000 0x0F004000
[   12.078124] PVR_K:   (T3C-80) 0x0000000A 0x0001120F 0x00000000 0x0F00DEFC
[   12.085418] PVR_K:   (T3C-90) 0x00000000 0x0F000000 0xAB600000 0x0F037000
[   12.092712] PVR_K:   (T3C-A0) 0x00000000 0x0F010BE0 0x0F00DD00 0x0F00DEFC
[   12.099945] PVR_K:   (T3C-B0) 0x0F010BE0 0x00000000 0x00000000 0x00000000
[   12.107299] PVR_K:   (T3C-C0) 0x00000000 0x00000000 0x00000000 0x00000000
[   12.114532] PVR_K:   (T3C-D0) 0x00000000 0x00000000 0x00000000 0x0F007000
[   12.122283] PVR_K:   (T3C-E0) 0x0F00D420 0x0F00E000 0x0F010720 0x0F010720
[   12.130035] PVR_K:   (T3C-F0) 0x00000000 0x000000B5 0x000000B5 0x00000000
[   12.137390] PVR_K:   (T3C-100) 0x00000001 0x00000000 0x00000000 0x00000000
[   12.144866] PVR_K:   (T3C-110) 0xB50C565C 0x0872E100 0x08787B00 0x08787B00
[   12.152282] PVR_K: Last SGX microkernel status code: AD000A0A
[   12.158630] PVR_K:   (MKT-0) 00000000 00000000 00000000 00000000
[   12.165039] PVR_K:   (MKT-1) 00000000 00000000 00000000 00000000
[   12.171539] PVR_K:   (MKT-2) 00000000 00000000 00000000 00000000
[   12.177978] PVR_K:   (MKT-3) 00000000 00000000 00000000 00000000
[   12.184417] PVR_K:   (MKT-4) 00000000 00000000 00000000 00000000
[   12.190887] PVR_K:   (MKT-5) 00000000 00000000 00000000 00000000
[   12.197326] adc_to_temp_conversion:Temp read is invalid 0
[   12.203247] PVR_K:   (MKT-6) 00000000 00000000 00000000 00000000
[   12.209625] PVR_K:   (MKT-7) 00000000 00000000 00000000 00000000
[   12.216064] thermal_lookup_temp: getting temp is not supported for domain pcb
[   12.223815] PVR_K:   (MKT-8) 00000000 00000000 00000000 00000000
[   12.230346] PVR_K:   (MKT-9) 00000000 00000000 00000000 00000000
[   12.236785] PVR_K:   (MKT-A) 00000000 00000000 00000000 00000000
[   12.243316] PVR_K:   (MKT-B) 00000000 00000000 00000000 00000000
[   12.249725] PVR_K:   (MKT-C) 00000000 00000000 00000000 00000000
[   12.256256] PVR_K:   (MKT-D) 00000000 00000000 00000000 00000000
[   12.262664] PVR_K:   (MKT-E) 00000000 00000000 00000000 00000000
[   12.269195] PVR_K:   (MKT-F) 00000000 00000000 00000000 00000000
[   12.275634] PVR_K:   (MKT-10) 00000000 00000000 00000000 00000000
[   12.282196] adc_to_temp_conversion:Temp read is invalid 0
[   12.288055] PVR_K:   (MKT-11) 00000000 00000000 00000000 00000000
[   12.294616] PVR_K:   (MKT-12) 00000000 00000000 00000000 00000000
[   12.301086] thermal_lookup_temp: getting temp is not supported for domain pcb
[   12.308929] PVR_K:   (MKT-13) 00000000 00000000 00000000 00000000
[   12.315551] PVR_K:   (MKT-14) 00000000 00000000 00000000 00000000
[   12.322143] PVR_K:   (MKT-15) 00000000 00000000 00000000 00000000
[   12.328796] PVR_K:   (MKT-16) 00000000 00000000 00000000 00000000
[   12.335357] PVR_K:   (MKT-17) 00000000 00000000 00000000 00000000
[   12.343627] PVR_K:   (MKT-18) 00000000 00000000 00000000 00000000
[   12.350158] PVR_K:   (MKT-19) 00000000 00000000 00000000 00000000
[   12.356781] PVR_K:   (MKT-1A) 00000000 00000000 00000000 00000000
[   12.363342] PVR_K:   (MKT-1B) 00000000 00000000 00000000 00000000
[   12.369934] adc_to_temp_conversion:Temp read is invalid 0
[   12.375823] PVR_K:   (MKT-1C) 00000000 00000000 00000000 00000000
[   12.382385] thermal_lookup_temp: getting temp is not supported for domain pcb
[   12.390167] PVR_K:   (MKT-1D) 00000000 00000000 00000000 00000000
[   12.396697] PVR_K:   (MKT-1E) 00000000 00000000 00000000 00000000
[   12.403289] PVR_K:   (MKT-1F) 00000000 00000000 00000000 00000000
[   12.409820] PVR_K:   (MKT-20) 00000000 00000000 00000000 00000000
[   12.416412] PVR_K:   (MKT-21) 00000000 00000000 00000000 00000000
[   12.422943] PVR_K:   (MKT-22) 00000000 00000000 00000000 00000000
[   12.429504] PVR_K:   (MKT-23) 00000000 00000000 00000000 00000000
[   12.436035] PVR_K:   (MKT-24) 00000000 00000000 00000000 00000000
[   12.442596] PVR_K:   (MKT-25) 00000000 00000000 00000000 00000000
[   12.449127] PVR_K:   (MKT-26) 00000000 00000000 00000000 00000000
[   12.455688] PVR_K:   (MKT-27) 00000000 00000000 00000000 00000000
[   12.462219] PVR_K:   (MKT-28) 00000000 00000000 00000000 00000000
[   12.468780] PVR_K:   (MKT-29) 00000000 00000000 00000000 00000000
[   12.475311] PVR_K:   (MKT-2A) 00000000 00000000 00000000 00000000
[   12.481872] PVR_K:   (MKT-2B) 00000000 00000000 00000000 00000000
[   12.488433] PVR_K:   (MKT-2C) 00000000 00000000 00000000 00000000
[   12.494964] PVR_K:   (MKT-2D) 00000000 00000000 00000000 00000000
[   12.501556] PVR_K:   (MKT-2E) 00000000 00000000 00000000 00000000
[   12.508087] PVR_K:   (MKT-2F) 00000000 00000000 00000000 00000000
[   12.514678] PVR_K:   (MKT-30) 00000000 00000000 00000000 00000000
[   12.521179] PVR_K:   (MKT-31) 00000000 00000000 00000000 00000000
[   12.527770] PVR_K:   (MKT-32) 00000000 00000000 00000000 00000000
[   12.534301] PVR_K:   (MKT-33) 00000000 00000000 00000000 00000000
[   12.540863] PVR_K:   (MKT-34) 00000000 00000000 00000000 00000000
[   12.547393] PVR_K:   (MKT-35) 00000000 00000000 00000000 00000000
[   12.553955] PVR_K:   (MKT-36) 00000000 00000000 00000000 00000000
[   12.560485] PVR_K:   (MKT-37) 00000000 00000000 00000000 00000000
[   12.567077] PVR_K:   (MKT-38) 00000000 00000000 00000000 00000000
[   12.573608] PVR_K:   (MKT-39) 00000000 00000000 00000000 00000000
[   12.580200] PVR_K:   (MKT-3A) 00000000 00000000 00000000 00000000
[   12.586730] PVR_K:   (MKT-3B) 00000000 00000000 00000000 00000000
[   12.593322] PVR_K:   (MKT-3C) 00000000 00000000 00000000 00000000
[   12.599884] PVR_K:   (MKT-3D) 00000000 00000000 00000000 00000000
[   12.606414] PVR_K:   (MKT-3E) 00000000 00000000 00000000 00000000
[   12.612976] PVR_K:   (MKT-3F) 00000000 00000000 00000000 00000000
[   12.619506] PVR_K:   (MKT-40) 00000000 00000000 00000000 00000000
[   12.626068] PVR_K:   (MKT-41) 00000000 00000000 00000000 00000000
[   12.632598] PVR_K:   (MKT-42) 00000000 00000000 00000000 00000000
[   12.639160] PVR_K:   (MKT-43) 00000000 00000000 00000000 00000000
[   12.645690] PVR_K:   (MKT-44) 00000000 00000000 00000000 00000000
[   12.652252] PVR_K:   (MKT-45) 00000000 00000000 00000000 00000000
[   12.658782] PVR_K:   (MKT-46) 00000000 00000000 00000000 00000000
[   12.665374] PVR_K:   (MKT-47) 00000000 00000000 00000000 00000000
[   12.671905] PVR_K:   (MKT-48) 00000000 00000000 00000000 00000000
[   12.678466] PVR_K:   (MKT-49) 00000000 00000000 00000000 00000000
[   12.684967] PVR_K:   (MKT-4A) 00000000 00000000 00000000 00000000
[   12.691558] PVR_K:   (MKT-4B) 00000000 00000000 00000000 00000000
[   12.698120] PVR_K:   (MKT-4C) 00000000 00000000 00000000 00000000
[   12.704650] PVR_K:   (MKT-4D) 00000000 00000000 00000000 00000000
[   12.711212] PVR_K:   (MKT-4E) 00000000 00000000 00000000 00000000
[   12.717742] PVR_K:   (MKT-4F) 00000000 00000000 00000000 00000000
[   12.724273] PVR_K:   (MKT-50) 00000000 00000000 00000000 00000000
[   12.730804] PVR_K:   (MKT-51) 00000000 00000000 00000000 00000000
[   12.737396] PVR_K:   (MKT-52) 00000000 00000000 00000000 00000000
[   12.743896] PVR_K:   (MKT-53) 00000000 00000000 00000000 00000000
[   12.750488] PVR_K:   (MKT-54) 00000000 00000000 00000000 00000000
[   12.756988] PVR_K:   (MKT-55) 00000000 00000000 00000000 00000000
[   12.763549] PVR_K:   (MKT-56) 00000000 00000000 00000000 00000000
[   12.770080] PVR_K:   (MKT-57) 00000000 00000000 00000000 00000000
[   12.776672] PVR_K:   (MKT-58) 00000000 00000000 00000000 00000000
[   12.783233] PVR_K:   (MKT-59) 00000000 00000000 00000000 00000000
[   12.789794] PVR_K:   (MKT-5A) 00000000 00000000 00000000 00000000
[   12.796325] PVR_K:   (MKT-5B) 00000000 00000000 00000000 00000000
[   12.802886] PVR_K:   (MKT-5C) 00000000 00000000 00000000 00000000
[   12.809448] PVR_K:   (MKT-5D) 00000000 00000000 00000000 00000000
[   12.816009] PVR_K:   (MKT-5E) 00000000 00000000 00000000 00000000
[   12.822570] PVR_K:   (MKT-5F) 00000000 00000000 00000000 00000000
[   12.829132] PVR_K:   (MKT-60) 00000000 00000000 00000000 00000000
[   12.835723] PVR_K:   (MKT-61) 00000000 00000000 00000000 00000000
[   12.842224] PVR_K:   (MKT-62) 00000000 00000000 00000000 00000000
[   12.848785] PVR_K:   (MKT-63) 00000000 00000000 00000000 00000000
[   12.855316] PVR_K:   (MKT-64) 00000000 00000000 00000000 00000000
[   12.861877] PVR_K:   (MKT-65) 00000000 00000000 00000000 00000000
[   12.868408] PVR_K:   (MKT-66) 00000000 00000000 00000000 00000000
[   12.874999] PVR_K:   (MKT-67) 00000000 00000000 00000000 00000000
[   12.881500] PVR_K:   (MKT-68) 00000000 00000000 00000000 00000000
[   12.888092] PVR_K:   (MKT-69) 00000000 00000000 00000000 00000000
[   12.894592] PVR_K:   (MKT-6A) 00000000 00000000 00000000 00000000
[   12.901153] PVR_K:   (MKT-6B) 00000000 00000000 00000000 00000000
[   12.907745] PVR_K:   (MKT-6C) 00000000 00000000 00000000 00000000
[   12.914276] PVR_K:   (MKT-6D) 00000000 00000000 00000000 00000000
[   12.920867] PVR_K:   (MKT-6E) 00000000 00000000 00000000 00000000
[   12.927368] PVR_K:   (MKT-6F) 00000000 00000000 00000000 00000000
[   12.933959] PVR_K:   (MKT-70) 00000000 00000000 00000000 00000000
[   12.940490] PVR_K:   (MKT-71) 00000000 00000000 00000000 00000000
[   12.947052] PVR_K:   (MKT-72) 00000000 00000000 00000000 00000000
[   12.953582] PVR_K:   (MKT-73) 00000000 00000000 00000000 00000000
[   12.960144] PVR_K:   (MKT-74) 00000000 00000000 00000000 00000000
[   12.966674] PVR_K:   (MKT-75) 00000000 00000000 00000000 00000000
[   12.973236] PVR_K:   (MKT-76) 00000000 00000000 00000000 00000000
[   12.979766] PVR_K:   (MKT-77) 00000000 00000000 00000000 00000000
[   12.986328] PVR_K:   (MKT-78) 00000000 00000000 00000000 00000000
[   12.992858] PVR_K:   (MKT-79) 00000000 00000000 00000000 00000000
[   12.999420] PVR_K:   (MKT-7A) 00000000 00000000 00000000 00000000
[   13.005950] PVR_K:   (MKT-7B) 00000000 00000000 00000000 00000000
[   13.012542] PVR_K:   (MKT-7C) 00000000 00000000 00000000 00000000
[   13.019104] PVR_K:   (MKT-7D) 00000000 00000000 00000000 00000000
[   13.025634] PVR_K:   (MKT-7E) 00000000 00000000 00000000 00000000
[   13.032226] PVR_K:   (MKT-7F) 00000000 00000000 00000000 00000000
[   13.038696] PVR_K:   (MKT-80) 00000000 00000000 00000000 00000000
[   13.045257] PVR_K:   (MKT-81) 00000000 00000000 00000000 00000000
[   13.051757] PVR_K:   (MKT-82) 00000000 00000000 00000000 00000000
[   13.058319] PVR_K:   (MKT-83) 00000000 00000000 00000000 00000000
[   13.064819] PVR_K:   (MKT-84) 00000000 00000000 00000000 00000000
[   13.071380] PVR_K:   (MKT-85) 00000000 00000000 00000000 00000000
[   13.077911] PVR_K:   (MKT-86) 00000000 00000000 00000000 00000000
[   13.084655] PVR_K:   (MKT-87) 00000000 00000000 00000000 00000000
[   13.091217] PVR_K:   (MKT-88) 00000000 00000000 00000000 00000000
[   13.098754] PVR_K:   (MKT-89) 00000000 00000000 00000000 00000000
[   13.105255] PVR_K:   (MKT-8A) 00000000 00000000 00000000 00000000
[   13.111846] PVR_K:   (MKT-8B) 00000000 00000000 00000000 00000000
[   13.118408] PVR_K:   (MKT-8C) 00000000 00000000 00000000 00000000
[   13.124908] PVR_K:   (MKT-8D) 00000000 00000000 00000000 00000000
[   13.131591] PVR_K:   (MKT-8E) 00000000 00000000 00000000 00000000
[   13.138122] PVR_K:   (MKT-8F) 00000000 00000000 00000000 00000000
[   13.144805] PVR_K:   (MKT-90) 00000000 00000000 00000000 00000000
[   13.151397] PVR_K:   (MKT-91) 00000000 00000000 00000000 00000000
[   13.157989] PVR_K:   (MKT-92) 00000000 00000000 00000000 00000000
[   13.164520] PVR_K:   (MKT-93) 00000000 00000000 00000000 00000000
[   13.171081] PVR_K:   (MKT-94) 00000000 00000000 00000000 00000000
[   13.177612] PVR_K:   (MKT-95) 00000000 00000000 00000000 00000000
[   13.184234] PVR_K:   (MKT-96) 00000000 00000000 00000000 00000000
[   13.190765] PVR_K:   (MKT-97) 00000000 00000000 00000000 00000000
[   13.197357] PVR_K:   (MKT-98) 00000000 00000000 00000000 00000000
[   13.203918] PVR_K:   (MKT-99) 00000000 00000000 00000000 00000000
[   13.210510] PVR_K:   (MKT-9A) 00000000 00000000 00000000 00000000
[   13.217010] PVR_K:   (MKT-9B) 00000000 00000000 00000000 00000000
[   13.223602] PVR_K:   (MKT-9C) 00000000 00000000 00000000 00000000
[   13.230560] PVR_K:   (MKT-9D) 00000000 00000000 00000000 00000000
[   13.237060] PVR_K:   (MKT-9E) 00000000 00000000 00000000 00000000
[   13.243621] PVR_K:   (MKT-9F) 00000000 00000000 00000000 00000000
[   13.250213] PVR_K:   (MKT-A0) 00000000 00000000 00000000 00000000
[   13.256835] PVR_K:   (MKT-A1) 00000000 00000000 00000000 00000000
[   13.263397] PVR_K:   (MKT-A2) 00000000 00000000 00000000 00000000
[   13.269989] PVR_K:   (MKT-A3) 00000000 00000000 00000000 00000000
[   13.276519] PVR_K:   (MKT-A4) 00000000 00000000 00000000 00000000
[   13.283142] PVR_K:   (MKT-A5) 00000000 00000000 00000000 00000000
[   13.289672] PVR_K:   (MKT-A6) 00000000 00000000 00000000 00000000
[   13.296264] PVR_K:   (MKT-A7) 00000000 00000000 00000000 00000000
[   13.302795] PVR_K:   (MKT-A8) 00000000 00000000 00000000 00000000
[   13.309600] PVR_K:   (MKT-A9) 00000000 00000000 00000000 00000000
[   13.316375] PVR_K:   (MKT-AA) 00000000 00000000 00000000 00000000
[   13.322998] PVR_K:   (MKT-AB) 00000000 00000000 00000000 00000000
[   13.329650] PVR_K:   (MKT-AC) 00000000 00000000 00000000 00000000
[   13.336517] PVR_K:   (MKT-AD) 00000000 00000000 00000000 00000000
[   13.343475] PVR_K:   (MKT-AE) 00000000 00000000 00000000 00000000
[   13.350433] PVR_K:   (MKT-AF) 00000000 00000000 00000000 00000000
[   13.357452] PVR_K:   (MKT-B0) 00000000 00000000 00000000 00000000
[   13.364196] PVR_K:   (MKT-B1) 00000000 00000000 00000000 00000000
[   13.371246] PVR_K:   (MKT-B2) 00000000 00000000 00000000 00000000
[   13.378021] PVR_K:   (MKT-B3) 00000000 00000000 00000000 00000000
[   13.385009] PVR_K:   (MKT-B4) 00000000 00000000 00000000 00000000
[   13.391784] PVR_K:   (MKT-B5) 00000000 00000000 00000000 00000000
[   13.399169] PVR_K:   (MKT-B6) 00000000 00000000 00000000 00000000
[   13.406066] PVR_K:   (MKT-B7) 00000000 00000000 00000000 00000000
[   13.412658] PVR_K:   (MKT-B8) 00000000 00000000 00000000 00000000
[   13.419219] PVR_K:   (MKT-B9) 00000000 00000000 00000000 00000000
[   13.425781] PVR_K:   (MKT-BA) 00000000 00000000 00000000 00000000
[   13.432281] PVR_K:   (MKT-BB) 00000000 00000000 00000000 00000000
[   13.438812] PVR_K:   (MKT-BC) 00000000 00000000 00000000 00000000
[   13.445373] PVR_K:   (MKT-BD) 00000000 00000000 00000000 00000000
[   13.451873] PVR_K:   (MKT-BE) 00000000 00000000 00000000 00000000
[   13.458435] adc_to_temp_conversion:Temp read is invalid 0
[   13.464263] PVR_K:   (MKT-BF) 00000000 00000000 00000000 00000000
[   13.470794] thermal_lookup_temp: getting temp is not supported for domain pcb
[   13.478485] PVR_K:   (MKT-C0) 00000000 00000000 00000000 00000000
[   13.485107] PVR_K:   (MKT-C1) 00000000 00000000 00000000 00000000
[   13.491607] PVR_K:   (MKT-C2) 00000000 00000000 00000000 00000000
[   13.498199] PVR_K:   (MKT-C3) 00000000 00000000 00000000 00000000
[   13.504791] PVR_K:   (MKT-C4) 00000000 00000000 00000000 00000000
[   13.511322] PVR_K:   (MKT-C5) 00000000 00000000 00000000 00000000
[   13.518188] PVR_K:   (MKT-C6) 00000000 00000000 00000000 00000000
[   13.525115] PVR_K:   (MKT-C7) 00000000 00000000 00000000 00000000
[   13.531677] PVR_K:   (MKT-C8) 00000000 00000000 00000000 00000000
[   13.538238] PVR_K:   (MKT-C9) 00000000 00000000 00000000 00000000
[   13.544799] adc_to_temp_conversion:Temp read is invalid 0
[   13.550659] PVR_K:   (MKT-CA) 00000000 00000000 00000000 00000000
[   13.557220] thermal_lookup_temp: getting temp is not supported for domain pcb
[   13.564941] PVR_K:   (MKT-CB) 00000000 00000000 00000000 00000000
[   13.571533] PVR_K:   (MKT-CC) 00000000 00000000 00000000 00000000
[   13.578094] PVR_K:   (MKT-CD) 00000000 00000000 00000000 00000000
[   13.584686] PVR_K:   (MKT-CE) 00000000 00000000 00000000 00000000
[   13.591217] PVR_K:   (MKT-CF) 00000000 00000000 00000000 00000000
[   13.597808] PVR_K:   (MKT-D0) 00000000 00000000 00000000 00000000
[   13.604644] PVR_K:   (MKT-D1) 00000000 00000000 00000000 00000000
[   13.611541] PVR_K:   (MKT-D2) 00000000 00000000 00000000 00000000
[   13.618072] PVR_K:   (MKT-D3) 00000000 00000000 00000000 00000000
[   13.624664] PVR_K:   (MKT-D4) 00000000 00000000 00000000 00000000
[   13.631225] adc_to_temp_conversion:Temp read is invalid 0
[   13.637084] PVR_K:   (MKT-D5) 00000000 00000000 00000000 00000000
[   13.643646] thermal_lookup_temp: getting temp is not supported for domain pcb
[   13.651367] PVR_K:   (MKT-D6) 00000000 00000000 00000000 00000000
[   13.657928] PVR_K:   (MKT-D7) 00000000 00000000 00000000 00000000
[   13.664459] PVR_K:   (MKT-D8) 00000000 00000000 00000000 00000000
[   13.670989] PVR_K:   (MKT-D9) 00000000 00000000 00000000 00000000
[   13.677459] PVR_K:   (MKT-DA) 00000000 00000000 00000000 00000000
[   13.684020] PVR_K:   (MKT-DB) 00000000 00000000 00000000 00000000
[   13.690521] PVR_K:   (MKT-DC) 00000000 00000000 00000000 00000000
[   13.697082] PVR_K:   (MKT-DD) 00000000 00000000 00000000 00000000
[   13.703613] PVR_K:   (MKT-DE) 00000000 00000000 00000000 00000000
[   13.710174] PVR_K:   (MKT-DF) 00000000 00000000 00000000 00000000
[   13.716674] PVR_K:   (MKT-E0) 00000000 00000000 00000000 00000000
[   13.723236] PVR_K:   (MKT-E1) 00000000 00000000 00000000 00000000
[   13.729797] PVR_K:   (MKT-E2) 00000000 00000000 00000000 00000000
[   13.736328] PVR_K:   (MKT-E3) 00000000 00000000 00000000 00000000
[   13.742858] PVR_K:   (MKT-E4) 00000000 00000000 00000000 00000000
[   13.749359] PVR_K:   (MKT-E5) 00000000 00000000 00000000 00000000
[   13.755889] PVR_K:   (MKT-E6) 00000000 00000000 00000000 00000000
[   13.762420] PVR_K:   (MKT-E7) 00000000 00000000 00000000 00000000
[   13.768981] PVR_K:   (MKT-E8) 00000000 00000000 00000000 00000000
[   13.775482] PVR_K:   (MKT-E9) 00000000 00000000 00000000 00000000
[   13.782012] PVR_K:   (MKT-EA) 00000000 00000000 00000000 00000000
[   13.788543] PVR_K:   (MKT-EB) 00000000 00000000 00000000 00000000
[   13.795074] PVR_K:   (MKT-EC) 00000000 00000000 00000000 00000000
[   13.801605] PVR_K:   (MKT-ED) 00000000 00000000 00000000 00000000
[   13.808166] PVR_K:   (MKT-EE) 00000000 00000000 00000000 00000000
[   13.814697] PVR_K:   (MKT-EF) 00000000 00000000 00000000 00000000
[   13.821228] PVR_K:   (MKT-F0) 00000000 00000000 00000000 00000000
[   13.827758] PVR_K:   (MKT-F1) 00000000 00000000 00000000 00000000
[   13.834289] PVR_K:   (MKT-F2) 00000000 00000000 00000000 00000000
[   13.840850] PVR_K:   (MKT-F3) 00000000 00000000 00000000 00000000
[   13.847351] PVR_K:   (MKT-F4) 00000000 00000000 00000000 00000000
[   13.853942] PVR_K:   (MKT-F5) 00000000 00000000 00000000 00000000
[   13.860443] PVR_K:   (MKT-F6) 00000000 00000000 00000000 00000000
[   13.866973] PVR_K:   (MKT-F7) 00000000 00000000 00000000 00000000
[   13.873504] PVR_K:   (MKT-F8) 00000000 00000000 00000000 00000000
[   13.880065] PVR_K:   (MKT-F9) 00000000 00000000 00000000 00000000
[   13.886566] PVR_K:   (MKT-FA) 00000000 00000000 00000000 00000000
[   13.893127] PVR_K:   (MKT-FB) 00000000 00000000 00000000 00000000
[   13.899627] PVR_K:   (MKT-FC) 00000000 00000000 00000000 00000000
[   13.906158] PVR_K:   (MKT-FD) 00000000 00000000 00000000 00000000
[   13.912658] PVR_K:   (MKT-FE) 00000000 00000000 00000000 00000000
[   13.919189] PVR_K:   (MKT-FF) 00000000 00000000 00000000 00000000
[   13.925689] PVR_K:   (MKT-100) 00000000 00000000 00000000 00000000
[   13.932342] PVR_K:   (MKT-101) 00000000 00000000 00000000 00000000
[   13.938964] PVR_K:   (MKT-102) 00000000 00000000 00000000 00000000
[   13.945526] PVR_K:   (MKT-103) 00000000 00000000 00000000 00000000
[   13.952117] PVR_K:   (MKT-104) 00000000 00000000 00000000 00000000
[   13.958709] PVR_K:   (MKT-105) 00000000 00000000 00000000 00000000
[   13.965332] PVR_K:   (MKT-106) 00000000 00000000 00000000 00000000
[   13.971893] PVR_K:   (MKT-107) 00000000 00000000 00000000 00000000
[   13.978576] PVR_K:   (MKT-108) 00000000 00000000 00000000 00000000
[   13.985198] PVR_K:   (MKT-109) 00000000 00000000 00000000 00000000
[   13.993560] PVR_K:   (MKT-10A) 00000000 00000000 00000000 00000000
[   14.000183] PVR_K:   (MKT-10B) 00000000 00000000 00000000 00000000
[   14.006896] PVR_K:   (MKT-10C) 00000000 00000000 00000000 00000000
[   14.013488] PVR_K:   (MKT-10D) 00000000 00000000 00000000 00000000
[   14.020172] PVR_K:   (MKT-10E) 00000000 00000000 00000000 00000000
[   14.026885] PVR_K:   (MKT-10F) 00000000 00000000 00000000 00000000
[   14.033508] PVR_K:   (MKT-110) 00000000 00000000 00000000 00000000
[   14.040161] PVR_K:   (MKT-111) 00000000 00000000 00000000 00000000
[   14.046813] PVR_K:   (MKT-112) 00000000 00000000 00000000 00000000
[   14.053497] PVR_K:   (MKT-113) 00000000 00000000 00000000 00000000
[   14.060485] PVR_K:   (MKT-114) 00000000 00000000 00000000 00000000
[   14.067138] PVR_K:   (MKT-115) 00000000 00000000 00000000 00000000
[   14.073791] PVR_K:   (MKT-116) 00000000 00000000 00000000 00000000
[   14.080444] PVR_K:   (MKT-117) 00000000 00000000 00000000 00000000
[   14.087066] PVR_K:   (MKT-118) 00000000 00000000 00000000 00000000
[   14.093749] PVR_K:   (MKT-119) 00000000 00000000 00000000 00000000
[   14.100372] PVR_K:   (MKT-11A) 00000000 00000000 00000000 00000000
[   14.107086] PVR_K:   (MKT-11B) 00000000 00000000 00000000 00000000
[   14.113739] PVR_K:   (MKT-11C) 00000000 00000000 00000000 00000000
[   14.120361] PVR_K:   (MKT-11D) 00000000 00000000 00000000 00000000
[   14.127014] PVR_K:   (MKT-11E) 00000000 00000000 00000000 00000000
[   14.133666] PVR_K:   (MKT-11F) 00000000 00000000 00000000 00000000
[   14.140350] PVR_K:   (MKT-120) 00000000 00000000 00000000 00000000
[   14.146942] PVR_K:   (MKT-121) 00000000 00000000 00000000 00000000
[   14.153625] PVR_K:   (MKT-122) 00000000 00000000 00000000 00000000
[   14.160247] PVR_K:   (MKT-123) 00000000 00000000 00000000 00000000
[   14.166900] PVR_K:   (MKT-124) 00000000 00000000 00000000 00000000
[   14.173522] PVR_K:   (MKT-125) 00000000 00000000 00000000 00000000
[   14.180206] PVR_K:   (MKT-126) 00000000 00000000 00000000 00000000
[   14.186828] PVR_K:   (MKT-127) 00000000 00000000 00000000 00000000
[   14.193481] PVR_K:   (MKT-128) 00000000 00000000 00000000 00000000
[   14.200164] PVR_K:   (MKT-129) 00000000 00000000 00000000 00000000
[   14.206787] PVR_K:   (MKT-12A) 00000000 00000000 00000000 00000000
[   14.213439] PVR_K:   (MKT-12B) 00000000 00000000 00000000 00000000
[   14.220062] PVR_K:   (MKT-12C) 00000000 00000000 00000000 00000000
[   14.226745] PVR_K:   (MKT-12D) 00000000 00000000 00000000 00000000
[   14.233367] PVR_K:   (MKT-12E) 00000000 00000000 00000000 00000000
[   14.240020] PVR_K:   (MKT-12F) 00000000 00000000 00000000 00000000
[   14.246643] PVR_K:   (MKT-130) 00000000 00000000 00000000 00000000
[   14.253295] PVR_K:   (MKT-131) 00000000 00000000 00000000 00000000
[   14.259918] PVR_K:   (MKT-132) 00000000 00000000 00000000 00000000
[   14.266601] PVR_K:   (MKT-133) 00000000 00000000 00000000 00000000
[   14.273193] PVR_K:   (MKT-134) 00000000 00000000 00000000 00000000
[   14.279846] PVR_K:   (MKT-135) 00000000 00000000 00000000 00000000
[   14.286529] PVR_K:   (MKT-136) 00000000 00000000 00000000 00000000
[   14.293151] PVR_K:   (MKT-137) 00000000 00000000 00000000 00000000
[   14.299835] PVR_K:   (MKT-138) 00000000 00000000 00000000 00000000
[   14.306457] PVR_K:   (MKT-139) 00000000 00000000 00000000 00000000
[   14.313110] PVR_K:   (MKT-13A) 00000000 00000000 00000000 00000000
[   14.319732] PVR_K:   (MKT-13B) 00000000 00000000 00000000 00000000
[   14.326385] PVR_K:   (MKT-13C) 00000000 00000000 00000000 00000000
[   14.333007] PVR_K:   (MKT-13D) 00000000 00000000 00000000 00000000
[   14.339660] PVR_K:   (MKT-13E) 00000000 00000000 00000000 00000000
[   14.346313] PVR_K:   (MKT-13F) 00000000 00000000 00000000 00000000
[   14.352996] PVR_K:   (MKT-140) 00000000 00000000 00000000 00000000
[   14.359649] PVR_K:   (MKT-141) 00000000 00000000 00000000 00000000
[   14.366271] PVR_K:   (MKT-142) 00000000 00000000 00000000 00000000
[   14.372924] PVR_K:   (MKT-143) 00000000 00000000 00000000 00000000
[   14.379577] PVR_K:   (MKT-144) 00000000 00000000 00000000 00000000
[   14.386230] PVR_K:   (MKT-145) 00000000 00000000 00000000 00000000
[   14.392852] PVR_K:   (MKT-146) 00000000 00000000 00000000 00000000
[   14.399536] PVR_K:   (MKT-147) 00000000 00000000 00000000 00000000
[   14.406158] PVR_K:   (MKT-148) 00000000 00000000 00000000 00000000
[   14.412811] PVR_K:   (MKT-149) 00000000 00000000 00000000 00000000
[   14.419433] PVR_K:   (MKT-14A) 00000000 00000000 00000000 00000000
[   14.426116] PVR_K:   (MKT-14B) 00000000 00000000 00000000 00000000
[   14.432739] PVR_K:   (MKT-14C) 00000000 00000000 00000000 00000000
[   14.439392] PVR_K:   (MKT-14D) 00000000 00000000 00000000 00000000
[   14.446075] PVR_K:   (MKT-14E) 00000000 00000000 00000000 00000000
[   14.452697] PVR_K:   (MKT-14F) 00000000 00000000 00000000 00000000
[   14.459350] PVR_K:   (MKT-150) 00000000 00000000 00000000 00000000
[   14.465972] PVR_K:   (MKT-151) 00000000 00000000 00000000 00000000
[   14.472656] PVR_K:   (MKT-152) 00000000 00000000 00000000 00000000
[   14.479278] PVR_K:   (MKT-153) 00000000 00000000 00000000 00000000
[   14.485931] PVR_K:   (MKT-154) 00000000 00000000 00000000 00000000
[   14.492553] PVR_K:   (MKT-155) 00000000 00000000 00000000 00000000
[   14.499206] PVR_K:   (MKT-156) 00000000 00000000 00000000 00000000
[   14.505828] PVR_K:   (MKT-157) 00000000 00000000 00000000 00000000
[   14.512512] PVR_K:   (MKT-158) 00000000 00000000 00000000 00000000
[   14.519134] PVR_K:   (MKT-159) 00000000 00000000 00000000 00000000
[   14.525787] PVR_K:   (MKT-15A) 00000000 00000000 00000000 00000000
[   14.532470] PVR_K:   (MKT-15B) 00000000 00000000 00000000 00000000
[   14.539093] PVR_K:   (MKT-15C) 00000000 00000000 00000000 00000000
[   14.545745] PVR_K:   (MKT-15D) 00000000 00000000 00000000 00000000
[   14.552368] PVR_K:   (MKT-15E) 00000000 00000000 00000000 00000000
[   14.559051] PVR_K:   (MKT-15F) 00000000 00000000 00000000 00000000
[   14.565673] PVR_K:   (MKT-160) 00000000 00000000 00000000 00000000
[   14.572357] PVR_K:   (MKT-161) 00000000 00000000 00000000 00000000
[   14.578979] PVR_K:   (MKT-162) 00000000 00000000 00000000 00000000
[   14.585632] PVR_K:   (MKT-163) 00000000 00000000 00000000 00000000
[   14.592254] PVR_K:   (MKT-164) 00000000 00000000 00000000 00000000
[   14.598907] PVR_K:   (MKT-165) 00000000 00000000 00000000 00000000
[   14.605529] PVR_K:   (MKT-166) 00000000 00000000 00000000 00000000
[   14.612243] PVR_K:   (MKT-167) 00000000 00000000 00000000 00000000
[   14.618927] PVR_K:   (MKT-168) 00000000 00000000 00000000 00000000
[   14.625549] PVR_K:   (MKT-169) 00000000 00000000 00000000 00000000
[   14.632202] PVR_K:   (MKT-16A) 00000000 00000000 00000000 00000000
[   14.638824] PVR_K:   (MKT-16B) 00000000 00000000 00000000 00000000
[   14.645477] PVR_K:   (MKT-16C) 00000000 00000000 00000000 00000000
[   14.652099] PVR_K:   (MKT-16D) 00000000 00000000 00000000 00000000
[   14.658843] PVR_K:   (MKT-16E) 00000000 00000000 00000000 00000000
[   14.665527] PVR_K:   (MKT-16F) 00000000 00000000 00000000 00000000
[   14.672271] PVR_K:   (MKT-170) 00000000 00000000 00000000 00000000
[   14.678924] PVR_K:   (MKT-171) 00000000 00000000 00000000 00000000
[   14.685577] PVR_K:   (MKT-172) 00000000 00000000 00000000 00000000
[   14.692230] PVR_K:   (MKT-173) 00000000 00000000 00000000 00000000
[   14.698883] PVR_K:   (MKT-174) 00000000 00000000 00000000 00000000
[   14.705627] PVR_K:   (MKT-175) 00000000 00000000 00000000 00000000
[   14.712249] PVR_K:   (MKT-176) 00000000 00000000 00000000 00000000
[   14.718933] adc_to_temp_conversion:Temp read is invalid 0
[   14.724975] thermal_lookup_temp: getting temp is not supported for domain pcb
[   14.732788] PVR_K:   (MKT-177) 00000000 00000000 00000000 00000000
[   14.739410] PVR_K:   (MKT-178) 00000000 00000000 00000000 00000000
[   14.746154] PVR_K:   (MKT-179) 00000000 00000000 00000000 00000000
[   14.752868] PVR_K:   (MKT-17A) 00000000 00000000 00000000 00000000
[   14.759613] PVR_K:   (MKT-17B) 00000000 00000000 00000000 00000000
[   14.766265] PVR_K:   (MKT-17C) 00000000 00000000 00000000 00000000
[   14.772949] PVR_K:   (MKT-17D) 00000000 00000000 00000000 00000000
[   14.779632] PVR_K:   (MKT-17E) 00000000 00000000 00000000 00000000
[   14.786315] PVR_K:   (MKT-17F) 00000000 00000000 00000000 00000000
[   14.793060] PVR_K:   (MKT-180) 00000000 00000000 00000000 00000000
[   14.799682] PVR_K:   (MKT-181) 00000000 00000000 00000000 00000000
[   14.806396] adc_to_temp_conversion:Temp read is invalid 0
[   14.812255] PVR_K:   (MKT-182) 00000000 00000000 00000000 00000000
[   14.818939] PVR_K:   (MKT-183) 00000000 00000000 00000000 00000000
[   14.825561] thermal_lookup_temp: getting temp is not supported for domain pcb
[   14.833374] PVR_K:   (MKT-184) 00000000 00000000 00000000 00000000
[   14.840057] PVR_K:   (MKT-185) 00000000 00000000 00000000 00000000
[   14.846771] PVR_K:   (MKT-186) 00000000 00000000 00000000 00000000
[   14.853454] PVR_K:   (MKT-187) 00000000 00000000 00000000 00000000
[   14.860137] PVR_K:   (MKT-188) 00000000 00000000 00000000 00000000
[   14.866912] PVR_K:   (MKT-189) 00000000 00000000 00000000 00000000
[   14.873535] PVR_K:   (MKT-18A) 00000000 00000000 00000000 00000000
[   14.880249] PVR_K:   (MKT-18B) 00000000 00000000 00000000 00000000
[   14.886871] PVR_K:   (MKT-18C) 00000000 00000000 00000000 00000000
[   14.893554] adc_to_temp_conversion:Temp read is invalid 0
[   14.899444] PVR_K:   (MKT-18D) 00000000 00000000 00000000 00000000
[   14.906127] thermal_lookup_temp: getting temp is not supported for domain pcb
[   14.913879] PVR_K:   (MKT-18E) 00000000 00000000 00000000 00000000
[   14.920562] PVR_K:   (MKT-18F) 00000000 00000000 00000000 00000000
[   14.927185] PVR_K:   (MKT-190) 00000000 00000000 00000000 00000000
[   14.933837] PVR_K:   (MKT-191) 00000000 00000000 00000000 00000000
[   14.940460] PVR_K:   (MKT-192) 00000000 00000000 00000000 00000000
[   14.947143] PVR_K:   (MKT-193) 00000000 00000000 00000000 00000000
[   14.953796] PVR_K:   (MKT-194) 00000000 00000000 00000000 00000000
[   14.960418] PVR_K:   (MKT-195) 00000000 00000000 00000000 00000000
[   14.967071] PVR_K:   (MKT-196) 00000000 00000000 00000000 00000000
[   14.973693] PVR_K:   (MKT-197) 00000000 00000000 00000000 00000000
[   14.980346] PVR_K:   (MKT-198) 00000000 00000000 00000000 00000000
[   14.986999] PVR_K:   (MKT-199) 00000000 00000000 00000000 00000000
[   14.993652] PVR_K:   (MKT-19A) 00000000 00000000 00000000 00000000
[   15.000305] PVR_K:   (MKT-19B) 00000000 00000000 00000000 00000000
[   15.006988] PVR_K:   (MKT-19C) 00000000 00000000 00000000 00000000
[   15.013580] PVR_K:   (MKT-19D) 00000000 00000000 00000000 00000000
[   15.020294] PVR_K:   (MKT-19E) 00000000 00000000 00000000 00000000
[   15.026916] PVR_K:   (MKT-19F) 00000000 00000000 00000000 00000000
[   15.033538] PVR_K:   (MKT-1A0) 00000000 00000000 00000000 00000000
[   15.040222] PVR_K:   (MKT-1A1) 00000000 00000000 00000000 00000000
[   15.046844] PVR_K:   (MKT-1A2) 00000000 00000000 00000000 00000000
[   15.053497] PVR_K:   (MKT-1A3) 00000000 00000000 00000000 00000000
[   15.060119] PVR_K:   (MKT-1A4) 00000000 00000000 00000000 00000000
[   15.066802] PVR_K:   (MKT-1A5) 00000000 00000000 00000000 00000000
[   15.073425] PVR_K:   (MKT-1A6) 00000000 00000000 00000000 00000000
[   15.080078] PVR_K:   (MKT-1A7) 00000000 00000000 00000000 00000000
[   15.086700] PVR_K:   (MKT-1A8) 00000000 00000000 00000000 00000000
[   15.093383] PVR_K:   (MKT-1A9) 00000000 00000000 00000000 00000000
[   15.099975] PVR_K:   (MKT-1AA) 00000000 00000000 00000000 00000000
[   15.106658] PVR_K:   (MKT-1AB) 00000000 00000000 00000000 00000000
[   15.113311] PVR_K:   (MKT-1AC) 00000000 00000000 00000000 00000000
[   15.119964] PVR_K:   (MKT-1AD) 00000000 00000000 00000000 00000000
[   15.126617] PVR_K:   (MKT-1AE) 00000000 00000000 00000000 00000000
[   15.133239] PVR_K:   (MKT-1AF) 00000000 00000000 00000000 00000000
[   15.139923] PVR_K:   (MKT-1B0) 00000000 00000000 00000000 00000000
[   15.146514] PVR_K:   (MKT-1B1) 00000000 00000000 00000000 00000000
[   15.153167] PVR_K:   (MKT-1B2) 00000000 00000000 00000000 00000000
[   15.159790] PVR_K:   (MKT-1B3) 00000000 00000000 00000000 00000000
[   15.166473] PVR_K:   (MKT-1B4) 00000000 00000000 00000000 00000000
[   15.173095] PVR_K:   (MKT-1B5) 00000000 00000000 00000000 00000000
[   15.179748] PVR_K:   (MKT-1B6) 00000000 00000000 00000000 00000000
[   15.186370] PVR_K:   (MKT-1B7) 00000000 00000000 00000000 00000000
[   15.193023] PVR_K:   (MKT-1B8) 00000000 00000000 00000000 00000000
[   15.199676] PVR_K:   (MKT-1B9) 00000000 00000000 00000000 00000000
[   15.206329] PVR_K:   (MKT-1BA) 00000000 00000000 00000000 00000000
[   15.212982] PVR_K:   (MKT-1BB) 00000000 00000000 00000000 00000000
[   15.219604] PVR_K:   (MKT-1BC) 00000000 00000000 00000000 00000000
[   15.226287] PVR_K:   (MKT-1BD) 00000000 00000000 00000000 00000000
[   15.232910] PVR_K:   (MKT-1BE) 00000000 00000000 00000000 00000000
[   15.239593] PVR_K:   (MKT-1BF) 00000000 00000000 00000000 00000000
[   15.246185] PVR_K:   (MKT-1C0) 00000000 00000000 00000000 00000000
[   15.252868] PVR_K:   (MKT-1C1) 00000000 00000000 00000000 00000000
[   15.259490] PVR_K:   (MKT-1C2) 00000000 00000000 00000000 00000000
[   15.266143] PVR_K:   (MKT-1C3) 00000000 00000000 00000000 00000000
[   15.272766] PVR_K:   (MKT-1C4) 00000000 00000000 00000000 00000000
[   15.279418] PVR_K:   (MKT-1C5) 00000000 00000000 00000000 00000000
[   15.286071] PVR_K:   (MKT-1C6) 00000000 00000000 00000000 00000000
[   15.292694] PVR_K:   (MKT-1C7) 00000000 00000000 00000000 00000000
[   15.299377] PVR_K:   (MKT-1C8) 00000000 00000000 00000000 00000000
[   15.306030] PVR_K:   (MKT-1C9) 00000000 00000000 00000000 00000000
[   15.312683] PVR_K:   (MKT-1CA) 00000000 00000000 00000000 00000000
[   15.319305] PVR_K:   (MKT-1CB) 00000000 00000000 00000000 00000000
[   15.325958] PVR_K:   (MKT-1CC) 00000000 00000000 00000000 00000000
[   15.332580] PVR_K:   (MKT-1CD) 00000000 00000000 00000000 00000000
[   15.339233] PVR_K:   (MKT-1CE) 00000000 00000000 00000000 00000000
[   15.345886] PVR_K:   (MKT-1CF) 00000000 00000000 00000000 00000000
[   15.352569] PVR_K:   (MKT-1D0) 00000000 00000000 00000000 00000000
[   15.359191] PVR_K:   (MKT-1D1) 00000000 00000000 00000000 00000000
[   15.365844] PVR_K:   (MKT-1D2) 00000000 00000000 00000000 00000000
[   15.372528] PVR_K:   (MKT-1D3) 00000000 00000000 00000000 00000000
[   15.379150] PVR_K:   (MKT-1D4) 00000000 00000000 00000000 00000000
[   15.385803] PVR_K:   (MKT-1D5) 00000000 00000000 00000000 00000000
[   15.392456] PVR_K:   (MKT-1D6) 00000000 00000000 00000000 00000000
[   15.399108] PVR_K:   (MKT-1D7) 00000000 00000000 00000000 00000000
[   15.405731] PVR_K:   (MKT-1D8) 00000000 00000000 00000000 00000000
[   15.412384] PVR_K:   (MKT-1D9) 000005BA 00100808 0100031F AD002300
[   15.419006] PVR_K:   (MKT-1DA) 00000AF1 00100808 0100041F AD00000A
[   15.425659] PVR_K:   (MKT-1DB) 00000B3B 00100808 0100041F AD001100
[   15.432312] PVR_K:   (MKT-1DC) 00000BB5 00100808 0100041F AD002505
[   15.438964] PVR_K:   (MKT-1DD) 00000CCA 00100808 0100041F AD000901
[   15.445617] PVR_K:   (MKT-1DE) 00011EFB 00100808 0100071F AD001A00
[   15.452270] PVR_K:   (MKT-1DF) 000122ED 00100808 0100081F AD00000A
[   15.458953] PVR_K:   (MKT-1E0) 00012357 00100808 0100081F AD000909
[   15.465576] PVR_K:   (MKT-1E1) 000123A1 00100808 0100081F AD001A05
[   15.472259] PVR_K:   (MKT-1E2) 00012459 00100808 0100081F AD001A06
[   15.478881] PVR_K:   (MKT-1E3) 0000049D 00100808 0100031F AD002300
[   15.485565] PVR_K:   (MKT-1E4) 00000A03 00100808 0100041F AD00000A
[   15.492187] PVR_K:   (MKT-1E5) 00000A4E 00100808 0100041F AD001100
[   15.498870] PVR_K:   (MKT-1E6) 00000AC6 00100808 0100041F AD000905
[   15.505523] PVR_K:   (MKT-1E7) 00000C12 00100888 0100041F AD000901
[   15.512176] PVR_K:   (MKT-1E8) 00000C77 00100C08 0100051E AD000281
[   15.518798] PVR_K:   (MKT-1E9) 00000E02 00100808 0100051E AD00080A
[   15.525482] PVR_K:   (MKT-1EA) 00000E1C 00100808 0100051E 0F037000
[   15.532135] PVR_K:   (MKT-1EB) 00000E34 00100808 0100051E 00000073
[   15.538818] PVR_K:   (MKT-1EC) 00000F5C 00100C88 0100051E AD001300
[   15.545501] PVR_K:   (MKT-1ED) 0000109A 00100808 0000051E AD001301
[   15.552093] PVR_K:   (MKT-1EE) 000011D1 00100808 0000051E AD000802
[   15.560424] PVR_K:   (MKT-1EF) 0000133A 00100808 0000051E AD000803
[   15.567016] PVR_K:   (MKT-1F0) 00001388 00184AC8 0000051E AD000282
[   15.573669] PVR_K:   (MKT-1F1) 000034B5 00000808 0100081F AD000200
[   15.580322] PVR_K:   (MKT-1F2) 000035F4 00000808 0100081F AD001703
[   15.586944] PVR_K:   (MKT-1F3) 000037EE 00000808 0000081F AD000202
[   15.593566] PVR_K:   (MKT-1F4) 0000387C 00000808 0100091E AD000183
[   15.600219] PVR_K:   (MKT-1F5) 000039E8 00000808 0100091E AD000302
[   15.606842] PVR_K:   (MKT-1F6) 00003C21 00000808 0100091E AD000404
[   15.613494] PVR_K:   (MKT-1F7) 00003CEA 00000808 0000091E AD000402
[   15.620117] PVR_K:   (MKT-1F8) 00003D26 001008AF 0000091E AD000184
[   15.626800] PVR_K:   (MKT-1F9) 0000596D 00000808 00000B1F AD000101
[   15.633483] PVR_K:   (MKT-1FA) 000059DB 00000808 00000B1F AD000104
[   15.640106] PVR_K:   (MKT-1FB) 00005A04 00000808 01000C1E AD000100
[   15.646759] PVR_K:   (MKT-1FC) 00005B08 00000808 01000C1E AD000501
[   15.653411] PVR_K:   (MKT-1FD) 00005B48 00100829 01000C1E AD000104
[   15.660064] PVR_K:   (MKT-1FE) 00075815 0010182B 0100201F AD000A01
[   15.666717] PVR_K:   (MKT-1FF) 0007585A 0010182B 0100201F AD000A0A
[   15.673400] PVR_K: SGX Kernel CCB WO:0x3 RO:0x3
[   15.679016] misc dsscomp: [c6e64400] ignoring set failure -22
[   15.717681] Invalid Device Structure
[   15.858276] PVR_K:(Error): SGXOSTimer() detected SGX lockup (0x35 tasks) [0, ]
[   15.858276] PVR_K: HWRecoveryResetSGX: SGX Hardware Recovery triggered
[   15.858367] [   15.672]   [c6e89d00] new in dsscomp_gralloc_queue (refs=1)
[   15.858367] [   15.672]                           [c6e64400] dsscomp_new
[   15.858367] [   15.672]   [c6e89d00] ++refs=2 for [c6e64400]
[   15.858367] [   15.672]                           [c6e64400] dsscomp_delayed_apply
[   15.858367] [   15.672]   [c6e89d00] --refs=1 on RELEASED
[   15.858367] [   15.672]                           [c6e64400] dsscomp_apply
[   15.858398] [   15.711]   [c6e89d00] --refs=0 on ECLIPSED
[   15.858398] [   15.711]   [c6e89d00] calling   (null) [  (null)]
[   15.858398] [   15.711]                           [c6e64400] dsscomp_mgr_delayed_cb on ECLIPSED
[   15.858398] ACTIVE COMPOSITIONS on lcd
[   15.858398]
[   15.858398]   DISPC pipeline:
[   15.858398]
[   15.858398]     info:        clean (none)
[   15.858398]     cache:       DIRTY (none)
[   15.858398]     shadow:  off clean (none)
[   15.858428]     dispc:             (none)
[   15.858428]
[   15.858428] ACTIVE COMPOSITIONS on tv
[   15.858428]
[   15.858428]   DISPC pipeline:
[   15.858428]
[   15.858428]     info:        clean (none)
[   15.858428]     cache:       clean (none)
[   15.858428]     shadow:  off clean (none)
[   15.858428]
[   15.858428] ACTIVE COMPOSITIONS on lcd2
[   15.858459]
[   15.858459]   DISPC pipeline:
[   15.858459]
[   15.858459]     info:        clean (none)
[   15.858459]     cache:       clean (none)
[   15.858459]     shadow:  off clean (none)
[   15.858459]     dispc:             (none)
[   15.858459]
[   15.858459] ACTIVE GRALLOC FLIPS
[   15.858459]
[   15.858459]
[   15.858489] PVR_K: SGX debug (blaze_android_sgx_ogles1_ogles2_GPL sgxddk 18 1.8@869593)
[   15.858489] PVR_K:(Error): SGX Register Base Address (Linear):   0xC8B20000 [0, ]
[   15.858520] PVR_K:(Error): SGX Register Base Address (Physical): 0x56000000 [0, ]
[   15.858520] PVR_K: (P0) EUR_CR_CORE_ID:          01140000
[   15.858520] PVR_K: (P0) EUR_CR_CORE_REVISION:    00010200
[   15.858551] PVR_K: (P0) EUR_CR_EVENT_STATUS:     20000000
[   15.858551] PVR_K: (P0) EUR_CR_EVENT_STATUS2:    00000008
[   15.858551] PVR_K: (P0) EUR_CR_BIF_CTRL:         00000000
[   15.858581] PVR_K: (P0) EUR_CR_BIF_INT_STAT:     00008000
[   15.858581] PVR_K: (P0) EUR_CR_BIF_FAULT:        00000000
[   15.858581] PVR_K: (P0) EUR_CR_BIF_MEM_REQ_STAT: 00000000
[   15.858581] PVR_K: (P0) EUR_CR_CLKGATECTL:       000AAA6A
[   15.858612] PVR_K: (P0) EUR_CR_PDS_PC_BASE:      00004008
[   15.858612] PVR_K: Flip Command Complete Data 0 for display device 1:
[   15.858612] PVR_K: Flip Command Complete Data 1 for display device 1:
[   15.858642] PVR_K: SGX Host control:
[   15.858642] PVR_K:   (HC-0) 0x00000001 0x00000000 0x00000000 0x00000001
[   15.858642] PVR_K:   (HC-10) 0x00000001 0x0000000A 0x0005DC00 0x00000003
[   15.858673] PVR_K:   (HC-20) 0x00000000 0x00000001 0x00000000 0x00000001
[   15.858673] PVR_K:   (HC-30) 0x0000001D 0xEF0DA7D4 0x00000000 0x00000000
[   15.858703] PVR_K:   (HC-40) 0x00000000 0x087BF500 0x087C6300 0x087C3100
[   15.858703] PVR_K: SGX TA/3D control:
[   15.858703] PVR_K:   (T3C-0) 0x0F003000 0x0F003120 0x0F002000 0x00000000
[   15.858703] PVR_K:   (T3C-10) 0x00000000 0x00000002 0x00000000 0x00000000
[   15.858734] PVR_K:   (T3C-20) 0x00000000 0x00000000 0x00000000 0x00000000
[   15.858734] PVR_K:   (T3C-30) 0x00000000 0x00000000 0x00000000 0x00000000
[   15.858734] PVR_K:   (T3C-40) 0x00000000 0x00000000 0x00000000 0x00000000
[   15.858764] PVR_K:   (T3C-50) 0x00000000 0x00000000 0x00000000 0x00000000
[   15.858764] PVR_K:   (T3C-60) 0x00000000 0x00000000 0x00000000 0x00000000
[   15.858764] PVR_K:   (T3C-70) 0x00000000 0x00000000 0x00000000 0x0F004000
[   15.858795] PVR_K:   (T3C-80) 0x0000000A 0x0001120F 0x00000000 0x0F00DEB8
[   15.858795] PVR_K:   (T3C-90) 0x00000000 0x0F000000 0xAB600000 0x0F037C00
[   15.858795] PVR_K:   (T3C-A0) 0x00000000 0x0F010BE0 0x0F00DD00 0x0F00DEB8
[   15.858825] PVR_K:   (T3C-B0) 0x0F010BE0 0x00000000 0x00000000 0x00000000
[   15.858825] PVR_K:   (T3C-C0) 0x00000000 0x00000000 0x00000000 0x00000000
[   15.858825] PVR_K:   (T3C-D0) 0x00000000 0x00000001 0x00000001 0x0F007000
[   15.858825] PVR_K:   (T3C-E0) 0x0F00D420 0x0F00E000 0x0F010720 0x0F010720
[   15.858856] PVR_K:   (T3C-F0) 0x00000000 0x000000B5 0x000000B5 0x00000000
[   15.858856] PVR_K:   (T3C-100) 0x00000003 0x00000000 0x00000000 0x00000001
[   15.858856] PVR_K:   (T3C-110) 0xB50C565C 0x0872E100 0x08787B00 0x08787B00
[   15.858886] PVR_K: Last SGX microkernel status code: AD000104
[   15.858886] PVR_K:   (MKT-0) 00000000 00000000 00000000 00000000
[   15.858886] PVR_K:   (MKT-1) 00000000 00000000 00000000 00000000
[   15.858917] PVR_K:   (MKT-2) 00000000 00000000 00000000 00000000
[   15.858917] PVR_K:   (MKT-3) 00000000 00000000 00000000 00000000
[   15.858917] PVR_K:   (MKT-4) 00000000 00000000 00000000 00000000
[   15.858947] PVR_K:   (MKT-5) 00000000 00000000 00000000 00000000
[   15.858947] PVR_K:   (MKT-6) 00000000 00000000 00000000 00000000
[   15.858947] PVR_K:   (MKT-7) 00000000 00000000 00000000 00000000
[   15.858978] PVR_K:   (MKT-8) 00000000 00000000 00000000 00000000
[   15.858978] PVR_K:   (MKT-9) 00000000 00000000 00000000 00000000
[   15.858978] PVR_K:   (MKT-A) 00000000 00000000 00000000 00000000
[   15.858978] PVR_K:   (MKT-B) 00000000 00000000 00000000 00000000
[   15.859008] PVR_K:   (MKT-C) 00000000 00000000 00000000 00000000
[   15.859008] PVR_K:   (MKT-D) 00000000 00000000 00000000 00000000
[   15.859008] PVR_K:   (MKT-E) 00000000 00000000 00000000 00000000
[   15.859039] PVR_K:   (MKT-F) 00000000 00000000 00000000 00000000
[   15.859039] PVR_K:   (MKT-10) 00000000 00000000 00000000 00000000
[   15.859039] PVR_K:   (MKT-11) 00000000 00000000 00000000 00000000
[   15.859069] PVR_K:   (MKT-12) 00000000 00000000 00000000 00000000
[   15.859069] PVR_K:   (MKT-13) 00000000 00000000 00000000 00000000
[   15.859069] PVR_K:   (MKT-14) 00000000 00000000 00000000 00000000
[   15.859100] PVR_K:   (MKT-15) 00000000 00000000 00000000 00000000
[   15.859100] PVR_K:   (MKT-16) 00000000 00000000 00000000 00000000
[   15.859100] PVR_K:   (MKT-17) 00000000 00000000 00000000 00000000
[   15.859130] PVR_K:   (MKT-18) 00000000 00000000 00000000 00000000
[   15.859130] PVR_K:   (MKT-19) 00000000 00000000 00000000 00000000
[   15.859130] PVR_K:   (MKT-1A) 00000000 00000000 00000000 00000000
[   15.859161] PVR_K:   (MKT-1B) 00000000 00000000 00000000 00000000
[   15.859161] PVR_K:   (MKT-1C) 00000000 00000000 00000000 00000000
[   15.859161] PVR_K:   (MKT-1D) 00000000 00000000 00000000 00000000
[   15.859191] PVR_K:   (MKT-1E) 00000000 00000000 00000000 00000000
[   15.859191] PVR_K:   (MKT-1F) 00000000 00000000 00000000 00000000
[   15.859191] PVR_K:   (MKT-20) 00000000 00000000 00000000 00000000
[   15.859222] PVR_K:   (MKT-21) 00000000 00000000 00000000 00000000
[   15.859222] PVR_K:   (MKT-22) 00000000 00000000 00000000 00000000
[   15.859222] PVR_K:   (MKT-23) 00000000 00000000 00000000 00000000
[   15.859252] PVR_K:   (MKT-24) 00000000 00000000 00000000 00000000
[   15.859252] PVR_K:   (MKT-25) 00000000 00000000 00000000 00000000
[   15.859252] PVR_K:   (MKT-26) 00000000 00000000 00000000 00000000
[   15.859283] PVR_K:   (MKT-27) 00000000 00000000 00000000 00000000
[   15.859283] PVR_K:   (MKT-28) 00000000 00000000 00000000 00000000
[   15.859283] PVR_K:   (MKT-29) 00000000 00000000 00000000 00000000
[   15.859283] PVR_K:   (MKT-2A) 00000000 00000000 00000000 00000000
[   15.859313] PVR_K:   (MKT-2B) 00000000 00000000 00000000 00000000
[   15.859313] PVR_K:   (MKT-2C) 00000000 00000000 00000000 00000000
[   15.859313] PVR_K:   (MKT-2D) 00000000 00000000 00000000 00000000
[   15.859344] PVR_K:   (MKT-2E) 00000000 00000000 00000000 00000000
[   15.859344] PVR_K:   (MKT-2F) 00000000 00000000 00000000 00000000
[   15.859344] PVR_K:   (MKT-30) 00000000 00000000 00000000 00000000
[   15.859374] PVR_K:   (MKT-31) 00000000 00000000 00000000 00000000
[   15.859374] PVR_K:   (MKT-32) 00000000 00000000 00000000 00000000
[   15.859374] PVR_K:   (MKT-33) 00000000 00000000 00000000 00000000
[   15.859405] PVR_K:   (MKT-34) 00000000 00000000 00000000 00000000
[   15.859405] PVR_K:   (MKT-35) 00000000 00000000 00000000 00000000
[   15.859405] PVR_K:   (MKT-36) 00000000 00000000 00000000 00000000
[   15.859436] PVR_K:   (MKT-37) 00000000 00000000 00000000 00000000
[   15.859436] PVR_K:   (MKT-38) 00000000 00000000 00000000 00000000
[   15.859436] PVR_K:   (MKT-39) 00000000 00000000 00000000 00000000
[   15.859466] PVR_K:   (MKT-3A) 00000000 00000000 00000000 00000000
[   15.859466] PVR_K:   (MKT-3B) 00000000 00000000 00000000 00000000
[   15.859466] PVR_K:   (MKT-3C) 00000000 00000000 00000000 00000000
[   15.859466] PVR_K:   (MKT-3D) 00000000 00000000 00000000 00000000
[   15.859497] PVR_K:   (MKT-3E) 00000000 00000000 00000000 00000000
[   15.859497] PVR_K:   (MKT-3F) 00000000 00000000 00000000 00000000
[   15.859497] PVR_K:   (MKT-40) 00000000 00000000 00000000 00000000
[   15.859527] PVR_K:   (MKT-41) 00000000 00000000 00000000 00000000
[   15.859527] PVR_K:   (MKT-42) 00000000 00000000 00000000 00000000
[   15.859527] PVR_K:   (MKT-43) 00000000 00000000 00000000 00000000
[   15.859558] PVR_K:   (MKT-44) 00000000 00000000 00000000 00000000
[   15.859558] PVR_K:   (MKT-45) 00000000 00000000 00000000 00000000
[   15.859558] PVR_K:   (MKT-46) 00000000 00000000 00000000 00000000
[   15.859588] PVR_K:   (MKT-47) 00000000 00000000 00000000 00000000
[   15.859588] PVR_K:   (MKT-48) 00000000 00000000 00000000 00000000
[   15.859588] PVR_K:   (MKT-49) 00000000 00000000 00000000 00000000
[   15.859588] PVR_K:   (MKT-4A) 00000000 00000000 00000000 00000000
[   15.859619] PVR_K:   (MKT-4B) 00000000 00000000 00000000 00000000
[   15.859619] PVR_K:   (MKT-4C) 00000000 00000000 00000000 00000000
[   15.859619] PVR_K:   (MKT-4D) 00000000 00000000 00000000 00000000
[   15.859649] PVR_K:   (MKT-4E) 00000000 00000000 00000000 00000000
[   15.859649] PVR_K:   (MKT-4F) 00000000 00000000 00000000 00000000
[   15.859649] PVR_K:   (MKT-50) 00000000 00000000 00000000 00000000
[   15.859680] PVR_K:   (MKT-51) 00000000 00000000 00000000 00000000
[   15.859680] PVR_K:   (MKT-52) 00000000 00000000 00000000 00000000
[   15.859680] PVR_K:   (MKT-53) 00000000 00000000 00000000 00000000
[   15.859710] PVR_K:   (MKT-54) 00000000 00000000 00000000 00000000
[   15.859710] PVR_K:   (MKT-55) 00000000 00000000 00000000 00000000
[   15.859710] PVR_K:   (MKT-56) 00000000 00000000 00000000 00000000
[   15.859741] PVR_K:   (MKT-57) 00000000 00000000 00000000 00000000
[   15.859741] PVR_K:   (MKT-58) 00000000 00000000 00000000 00000000
[   15.859741] PVR_K:   (MKT-59) 00000000 00000000 00000000 00000000
[   15.859771] PVR_K:   (MKT-5A) 00000000 00000000 00000000 00000000
[   15.859771] PVR_K:   (MKT-5B) 00000000 00000000 00000000 00000000
[   15.859771] PVR_K:   (MKT-5C) 00000000 00000000 00000000 00000000
[   15.859802] PVR_K:   (MKT-5D) 00000000 00000000 00000000 00000000
[   15.859802] PVR_K:   (MKT-5E) 00000000 00000000 00000000 00000000
[   15.859802] PVR_K:   (MKT-5F) 00000000 00000000 00000000 00000000
[   15.859832] PVR_K:   (MKT-60) 00000000 00000000 00000000 00000000
[   15.859832] PVR_K:   (MKT-61) 00000000 00000000 00000000 00000000
[   15.859832] PVR_K:   (MKT-62) 00000000 00000000 00000000 00000000
[   15.859832] PVR_K:   (MKT-63) 00000000 00000000 00000000 00000000
[   15.859863] PVR_K:   (MKT-64) 00000000 00000000 00000000 00000000
[   15.859863] PVR_K:   (MKT-65) 00000000 00000000 00000000 00000000
[   15.859863] PVR_K:   (MKT-66) 00000000 00000000 00000000 00000000
[   15.859893] PVR_K:   (MKT-67) 00000000 00000000 00000000 00000000
[   15.859893] PVR_K:   (MKT-68) 00000000 00000000 00000000 00000000
[   15.859893] PVR_K:   (MKT-69) 00000000 00000000 00000000 00000000
[   15.859924] PVR_K:   (MKT-6A) 00000000 00000000 00000000 00000000
[   15.859924] PVR_K:   (MKT-6B) 00000000 00000000 00000000 00000000
[   15.859924] PVR_K:   (MKT-6C) 00000000 00000000 00000000 00000000
[   15.859954] PVR_K:   (MKT-6D) 00000000 00000000 00000000 00000000
[   15.859954] PVR_K:   (MKT-6E) 00000000 00000000 00000000 00000000
[   15.859954] PVR_K:   (MKT-6F) 00000000 00000000 00000000 00000000
[   15.859954] PVR_K:   (MKT-70) 00000000 00000000 00000000 00000000
[   15.859985] PVR_K:   (MKT-71) 00000000 00000000 00000000 00000000
[   15.859985] PVR_K:   (MKT-72) 00000000 00000000 00000000 00000000
[   15.859985] PVR_K:   (MKT-73) 00000000 00000000 00000000 00000000
[   15.860015] PVR_K:   (MKT-74) 00000000 00000000 00000000 00000000
[   15.860015] PVR_K:   (MKT-75) 00000000 00000000 00000000 00000000
[   15.860015] PVR_K:   (MKT-76) 00000000 00000000 00000000 00000000
[   15.860046] PVR_K:   (MKT-77) 00000000 00000000 00000000 00000000
[   15.860046] PVR_K:   (MKT-78) 00000000 00000000 00000000 00000000
[   15.860046] PVR_K:   (MKT-79) 00000000 00000000 00000000 00000000
[   15.860076] PVR_K:   (MKT-7A) 00000000 00000000 00000000 00000000
[   15.860076] PVR_K:   (MKT-7B) 00000000 00000000 00000000 00000000
[   15.860076] PVR_K:   (MKT-7C) 00000000 00000000 00000000 00000000
[   15.860107] PVR_K:   (MKT-7D) 00000000 00000000 00000000 00000000
[   15.860107] PVR_K:   (MKT-7E) 00000000 00000000 00000000 00000000
[   15.860107] PVR_K:   (MKT-7F) 00000000 00000000 00000000 00000000
[   15.860107] PVR_K:   (MKT-80) 00000000 00000000 00000000 00000000
[   15.860137] PVR_K:   (MKT-81) 00000000 00000000 00000000 00000000
[   15.860137] PVR_K:   (MKT-82) 00000000 00000000 00000000 00000000
[   15.860137] PVR_K:   (MKT-83) 00000000 00000000 00000000 00000000
[   15.860168] PVR_K:   (MKT-84) 00000000 00000000 00000000 00000000
[   15.860168] PVR_K:   (MKT-85) 00000000 00000000 00000000 00000000
[   15.860168] PVR_K:   (MKT-86) 00000000 00000000 00000000 00000000
[   15.860198] PVR_K:   (MKT-87) 00000000 00000000 00000000 00000000
[   15.860198] PVR_K:   (MKT-88) 00000000 00000000 00000000 00000000
[   15.860198] PVR_K:   (MKT-89) 00000000 00000000 00000000 00000000
[   15.860229] PVR_K:   (MKT-8A) 00000000 00000000 00000000 00000000
[   15.860229] PVR_K:   (MKT-8B) 00000000 00000000 00000000 00000000
[   15.860229] PVR_K:   (MKT-8C) 00000000 00000000 00000000 00000000
[   15.860260] PVR_K:   (MKT-8D) 00000000 00000000 00000000 00000000
[   15.860260] PVR_K:   (MKT-8E) 00000000 00000000 00000000 00000000
[   15.860260] PVR_K:   (MKT-8F) 00000000 00000000 00000000 00000000
[   15.860290] PVR_K:   (MKT-90) 00000000 00000000 00000000 00000000
[   15.860290] PVR_K:   (MKT-91) 00000000 00000000 00000000 00000000
[   15.860321] PVR_K:   (MKT-92) 00000000 00000000 00000000 00000000
[   15.860321] PVR_K:   (MKT-93) 00000000 00000000 00000000 00000000
[   15.860321] PVR_K:   (MKT-94) 00000000 00000000 00000000 00000000
[   15.860351] PVR_K:   (MKT-95) 00000000 00000000 00000000 00000000
[   15.860351] PVR_K:   (MKT-96) 00000000 00000000 00000000 00000000
[   15.860351] PVR_K:   (MKT-97) 00000000 00000000 00000000 00000000
[   15.860382] PVR_K:   (MKT-98) 00000000 00000000 00000000 00000000
[   15.860382] PVR_K:   (MKT-99) 00000000 00000000 00000000 00000000
[   15.860382] PVR_K:   (MKT-9A) 00000000 00000000 00000000 00000000
[   15.860382] PVR_K:   (MKT-9B) 00000000 00000000 00000000 00000000
[   15.860412] PVR_K:   (MKT-9C) 00000000 00000000 00000000 00000000
[   15.860412] PVR_K:   (MKT-9D) 00000000 00000000 00000000 00000000
[   15.860412] PVR_K:   (MKT-9E) 00000000 00000000 00000000 00000000
[   15.860443] PVR_K:   (MKT-9F) 00000000 00000000 00000000 00000000
[   15.860443] PVR_K:   (MKT-A0) 00000000 00000000 00000000 00000000
[   15.860443] PVR_K:   (MKT-A1) 00000000 00000000 00000000 00000000
[   15.860473] PVR_K:   (MKT-A2) 00000000 00000000 00000000 00000000
[   15.860473] PVR_K:   (MKT-A3) 00000000 00000000 00000000 00000000
[   15.860473] PVR_K:   (MKT-A4) 00000000 00000000 00000000 00000000
[   15.860504] PVR_K:   (MKT-A5) 00000000 00000000 00000000 00000000
[   15.860504] PVR_K:   (MKT-A6) 00000000 00000000 00000000 00000000
[   15.860504] PVR_K:   (MKT-A7) 00000000 00000000 00000000 00000000
[   15.860534] PVR_K:   (MKT-A8) 00000000 00000000 00000000 00000000
[   15.860534] PVR_K:   (MKT-A9) 00000000 00000000 00000000 00000000
[   15.860534] PVR_K:   (MKT-AA) 00000000 00000000 00000000 00000000
[   15.860534] PVR_K:   (MKT-AB) 00000000 00000000 00000000 00000000
[   15.860565] PVR_K:   (MKT-AC) 00000000 00000000 00000000 00000000
[   15.860565] PVR_K:   (MKT-AD) 00000000 00000000 00000000 00000000
[   15.860565] PVR_K:   (MKT-AE) 00000000 00000000 00000000 00000000
[   15.860595] PVR_K:   (MKT-AF) 00000000 00000000 00000000 00000000
[   15.860595] PVR_K:   (MKT-B0) 00000000 00000000 00000000 00000000
[   15.860595] PVR_K:   (MKT-B1) 00000000 00000000 00000000 00000000
[   15.860626] PVR_K:   (MKT-B2) 00000000 00000000 00000000 00000000
[   15.860626] PVR_K:   (MKT-B3) 00000000 00000000 00000000 00000000
[   15.860626] PVR_K:   (MKT-B4) 00000000 00000000 00000000 00000000
[   15.860656] PVR_K:   (MKT-B5) 00000000 00000000 00000000 00000000
[   15.860656] PVR_K:   (MKT-B6) 00000000 00000000 00000000 00000000
[   15.860656] PVR_K:   (MKT-B7) 00000000 00000000 00000000 00000000
[   15.860656] PVR_K:   (MKT-B8) 00000000 00000000 00000000 00000000
[   15.860687] PVR_K:   (MKT-B9) 00000000 00000000 00000000 00000000
[   15.860687] PVR_K:   (MKT-BA) 00000000 00000000 00000000 00000000
[   15.860687] PVR_K:   (MKT-BB) 00000000 00000000 00000000 00000000
[   15.860717] PVR_K:   (MKT-BC) 00000000 00000000 00000000 00000000
[   15.860717] PVR_K:   (MKT-BD) 00000000 00000000 00000000 00000000
[   15.860717] PVR_K:   (MKT-BE) 00000000 00000000 00000000 00000000
[   15.860748] PVR_K:   (MKT-BF) 00000000 00000000 00000000 00000000
[   15.860748] PVR_K:   (MKT-C0) 00000000 00000000 00000000 00000000
[   15.860748] PVR_K:   (MKT-C1) 00000000 00000000 00000000 00000000
[   15.860778] PVR_K:   (MKT-C2) 00000000 00000000 00000000 00000000
[   15.860778] PVR_K:   (MKT-C3) 00000000 00000000 00000000 00000000
[   15.860778] PVR_K:   (MKT-C4) 00000000 00000000 00000000 00000000
[   15.860809] PVR_K:   (MKT-C5) 00000000 00000000 00000000 00000000
[   15.860809] PVR_K:   (MKT-C6) 00000000 00000000 00000000 00000000
[   15.860809] PVR_K:   (MKT-C7) 00000000 00000000 00000000 00000000
[   15.860839] PVR_K:   (MKT-C8) 00000000 00000000 00000000 00000000
[   15.860839] PVR_K:   (MKT-C9) 00000000 00000000 00000000 00000000
[   15.860839] PVR_K:   (MKT-CA) 00000000 00000000 00000000 00000000
[   15.860870] PVR_K:   (MKT-CB) 00000000 00000000 00000000 00000000
[   15.860870] PVR_K:   (MKT-CC) 00000000 00000000 00000000 00000000
[   15.860870] PVR_K:   (MKT-CD) 00000000 00000000 00000000 00000000
[   15.860900] PVR_K:   (MKT-CE) 00000000 00000000 00000000 00000000
[   15.860900] PVR_K:   (MKT-CF) 00000000 00000000 00000000 00000000
[   15.860900] PVR_K:   (MKT-D0) 00000000 00000000 00000000 00000000
[   15.860931] PVR_K:   (MKT-D1) 00000000 00000000 00000000 00000000
[   15.860931] PVR_K:   (MKT-D2) 00000000 00000000 00000000 00000000
[   15.860931] PVR_K:   (MKT-D3) 00000000 00000000 00000000 00000000
[   15.860961] PVR_K:   (MKT-D4) 00000000 00000000 00000000 00000000
[   15.860961] PVR_K:   (MKT-D5) 00000000 00000000 00000000 00000000
[   15.860961] PVR_K:   (MKT-D6) 00000000 00000000 00000000 00000000
[   15.860961] PVR_K:   (MKT-D7) 00000000 00000000 00000000 00000000
[   15.860992] PVR_K:   (MKT-D8) 00000000 00000000 00000000 00000000
[   15.860992] PVR_K:   (MKT-D9) 00000000 00000000 00000000 00000000
[   15.860992] PVR_K:   (MKT-DA) 00000000 00000000 00000000 00000000
[   15.861022] PVR_K:   (MKT-DB) 00000000 00000000 00000000 00000000
[   15.861022] PVR_K:   (MKT-DC) 00000000 00000000 00000000 00000000
[   15.861022] PVR_K:   (MKT-DD) 00000000 00000000 00000000 00000000
[   15.861053] PVR_K:   (MKT-DE) 00000000 00000000 00000000 00000000
[   15.861053] PVR_K:   (MKT-DF) 00000000 00000000 00000000 00000000
[   15.861053] PVR_K:   (MKT-E0) 00000000 00000000 00000000 00000000
[   15.861083] PVR_K:   (MKT-E1) 00000000 00000000 00000000 00000000
[   15.861083] PVR_K:   (MKT-E2) 00000000 00000000 00000000 00000000
[   15.861083] PVR_K:   (MKT-E3) 00000000 00000000 00000000 00000000
[   15.861114] PVR_K:   (MKT-E4) 00000000 00000000 00000000 00000000
[   15.861114] PVR_K:   (MKT-E5) 00000000 00000000 00000000 00000000
[   15.861114] PVR_K:   (MKT-E6) 00000000 00000000 00000000 00000000
[   15.861114] PVR_K:   (MKT-E7) 00000000 00000000 00000000 00000000
[   15.861145] PVR_K:   (MKT-E8) 00000000 00000000 00000000 00000000
[   15.861145] PVR_K:   (MKT-E9) 00000000 00000000 00000000 00000000
[   15.861145] PVR_K:   (MKT-EA) 00000000 00000000 00000000 00000000
[   15.861175] PVR_K:   (MKT-EB) 00000000 00000000 00000000 00000000
[   15.861175] PVR_K:   (MKT-EC) 00000000 00000000 00000000 00000000
[   15.861175] PVR_K:   (MKT-ED) 00000000 00000000 00000000 00000000
[   15.861206] PVR_K:   (MKT-EE) 00000000 00000000 00000000 00000000
[   15.861206] PVR_K:   (MKT-EF) 00000000 00000000 00000000 00000000
[   15.861206] PVR_K:   (MKT-F0) 00000000 00000000 00000000 00000000
[   15.861236] PVR_K:   (MKT-F1) 00000000 00000000 00000000 00000000
[   15.861236] PVR_K:   (MKT-F2) 00000000 00000000 00000000 00000000
[   15.861236] PVR_K:   (MKT-F3) 00000000 00000000 00000000 00000000
[   15.861267] PVR_K:   (MKT-F4) 00000000 00000000 00000000 00000000
[   15.861267] PVR_K:   (MKT-F5) 00000000 00000000 00000000 00000000
[   15.861267] PVR_K:   (MKT-F6) 00000000 00000000 00000000 00000000
[   15.861297] PVR_K:   (MKT-F7) 00000000 00000000 00000000 00000000
[   15.861297] PVR_K:   (MKT-F8) 00000000 00000000 00000000 00000000
[   15.861297] PVR_K:   (MKT-F9) 00000000 00000000 00000000 00000000
[   15.861328] PVR_K:   (MKT-FA) 00000000 00000000 00000000 00000000
[   15.861328] PVR_K:   (MKT-FB) 00000000 00000000 00000000 00000000
[   15.861328] PVR_K:   (MKT-FC) 00000000 00000000 00000000 00000000
[   15.861358] PVR_K:   (MKT-FD) 00000000 00000000 00000000 00000000
[   15.861358] PVR_K:   (MKT-FE) 00000000 00000000 00000000 00000000
[   15.861358] PVR_K:   (MKT-FF) 00000000 00000000 00000000 00000000
[   15.861389] PVR_K:   (MKT-100) 00000000 00000000 00000000 00000000
[   15.861389] PVR_K:   (MKT-101) 00000000 00000000 00000000 00000000
[   15.861389] PVR_K:   (MKT-102) 00000000 00000000 00000000 00000000
[   15.861419] PVR_K:   (MKT-103) 00000000 00000000 00000000 00000000
[   15.861419] PVR_K:   (MKT-104) 00000000 00000000 00000000 00000000
[   15.861419] PVR_K:   (MKT-105) 00000000 00000000 00000000 00000000
[   15.861450] PVR_K:   (MKT-106) 00000000 00000000 00000000 00000000
[   15.861450] PVR_K:   (MKT-107) 00000000 00000000 00000000 00000000
[   15.861450] PVR_K:   (MKT-108) 00000000 00000000 00000000 00000000
[   15.861480] PVR_K:   (MKT-109) 00000000 00000000 00000000 00000000
[   15.861480] PVR_K:   (MKT-10A) 00000000 00000000 00000000 00000000
[   15.861480] PVR_K:   (MKT-10B) 00000000 00000000 00000000 00000000
[   15.861511] PVR_K:   (MKT-10C) 00000000 00000000 00000000 00000000
[   15.861511] PVR_K:   (MKT-10D) 00000000 00000000 00000000 00000000
[   15.861511] PVR_K:   (MKT-10E) 00000000 00000000 00000000 00000000
[   15.861541] PVR_K:   (MKT-10F) 00000000 00000000 00000000 00000000
[   15.861541] PVR_K:   (MKT-110) 00000000 00000000 00000000 00000000
[   15.861572] PVR_K:   (MKT-111) 00000000 00000000 00000000 00000000
[   15.861572] PVR_K:   (MKT-112) 00000000 00000000 00000000 00000000
[   15.861572] PVR_K:   (MKT-113) 00000000 00000000 00000000 00000000
[   15.861572] PVR_K:   (MKT-114) 00000000 00000000 00000000 00000000
[   15.861602] PVR_K:   (MKT-115) 00000000 00000000 00000000 00000000
[   15.861602] PVR_K:   (MKT-116) 00000000 00000000 00000000 00000000
[   15.861602] PVR_K:   (MKT-117) 00000000 00000000 00000000 00000000
[   15.861633] PVR_K:   (MKT-118) 00000000 00000000 00000000 00000000
[   15.861633] PVR_K:   (MKT-119) 00000000 00000000 00000000 00000000
[   15.861663] PVR_K:   (MKT-11A) 00000000 00000000 00000000 00000000
[   15.861663] PVR_K:   (MKT-11B) 00000000 00000000 00000000 00000000
[   15.861663] PVR_K:   (MKT-11C) 00000000 00000000 00000000 00000000
[   15.861694] PVR_K:   (MKT-11D) 00000000 00000000 00000000 00000000
[   15.861694] PVR_K:   (MKT-11E) 00000000 00000000 00000000 00000000
[   15.861694] PVR_K:   (MKT-11F) 00000000 00000000 00000000 00000000
[   15.861724] PVR_K:   (MKT-120) 00000000 00000000 00000000 00000000
[   15.861724] PVR_K:   (MKT-121) 00000000 00000000 00000000 00000000
[   15.861724] PVR_K:   (MKT-122) 00000000 00000000 00000000 00000000
[   15.861755] PVR_K:   (MKT-123) 00000000 00000000 00000000 00000000
[   15.861755] PVR_K:   (MKT-124) 00000000 00000000 00000000 00000000
[   15.861755] PVR_K:   (MKT-125) 00000000 00000000 00000000 00000000
[   15.861785] PVR_K:   (MKT-126) 00000000 00000000 00000000 00000000
[   15.861785] PVR_K:   (MKT-127) 00000000 00000000 00000000 00000000
[   15.861785] PVR_K:   (MKT-128) 00000000 00000000 00000000 00000000
[   15.861785] PVR_K:   (MKT-129) 00000000 00000000 00000000 00000000
[   15.861816] PVR_K:   (MKT-12A) 00000000 00000000 00000000 00000000
[   15.861816] PVR_K:   (MKT-12B) 00000000 00000000 00000000 00000000
[   15.861816] PVR_K:   (MKT-12C) 00000000 00000000 00000000 00000000
[   15.861846] PVR_K:   (MKT-12D) 00000000 00000000 00000000 00000000
[   15.861846] PVR_K:   (MKT-12E) 00000000 00000000 00000000 00000000
[   15.861846] PVR_K:   (MKT-12F) 00000000 00000000 00000000 00000000
[   15.861877] PVR_K:   (MKT-130) 00000000 00000000 00000000 00000000
[   15.861877] PVR_K:   (MKT-131) 00000000 00000000 00000000 00000000
[   15.861877] PVR_K:   (MKT-132) 00000000 00000000 00000000 00000000
[   15.861907] PVR_K:   (MKT-133) 00000000 00000000 00000000 00000000
[   15.861907] PVR_K:   (MKT-134) 00000000 00000000 00000000 00000000
[   15.861907] PVR_K:   (MKT-135) 00000000 00000000 00000000 00000000
[   15.861938] PVR_K:   (MKT-136) 00000000 00000000 00000000 00000000
[   15.861938] PVR_K:   (MKT-137) 00000000 00000000 00000000 00000000
[   15.861938] PVR_K:   (MKT-138) 00000000 00000000 00000000 00000000
[   15.861968] PVR_K:   (MKT-139) 00000000 00000000 00000000 00000000
[   15.861968] PVR_K:   (MKT-13A) 00000000 00000000 00000000 00000000
[   15.861968] PVR_K:   (MKT-13B) 00000000 00000000 00000000 00000000
[   15.861999] PVR_K:   (MKT-13C) 00000000 00000000 00000000 00000000
[   15.861999] PVR_K:   (MKT-13D) 00000000 00000000 00000000 00000000
[   15.861999] PVR_K:   (MKT-13E) 00000000 00000000 00000000 00000000
[   15.862030] PVR_K:   (MKT-13F) 00000000 00000000 00000000 00000000
[   15.862030] PVR_K:   (MKT-140) 00000000 00000000 00000000 00000000
[   15.862030] PVR_K:   (MKT-141) 00000000 00000000 00000000 00000000
[   15.862060] PVR_K:   (MKT-142) 00000000 00000000 00000000 00000000
[   15.862060] PVR_K:   (MKT-143) 00000000 00000000 00000000 00000000
[   15.862060] PVR_K:   (MKT-144) 00000000 00000000 00000000 00000000
[   15.862060] PVR_K:   (MKT-145) 00000000 00000000 00000000 00000000
[   15.862091] PVR_K:   (MKT-146) 00000000 00000000 00000000 00000000
[   15.862091] PVR_K:   (MKT-147) 00000000 00000000 00000000 00000000
[   15.862091] PVR_K:   (MKT-148) 00000000 00000000 00000000 00000000
[   15.862121] PVR_K:   (MKT-149) 00000000 00000000 00000000 00000000
[   15.862121] PVR_K:   (MKT-14A) 00000000 00000000 00000000 00000000
[   15.862121] PVR_K:   (MKT-14B) 00000000 00000000 00000000 00000000
[   15.862152] PVR_K:   (MKT-14C) 00000000 00000000 00000000 00000000
[   15.862152] PVR_K:   (MKT-14D) 00000000 00000000 00000000 00000000
[   15.862152] PVR_K:   (MKT-14E) 00000000 00000000 00000000 00000000
[   15.862182] PVR_K:   (MKT-14F) 00000000 00000000 00000000 00000000
[   15.862182] PVR_K:   (MKT-150) 000005BA 00100808 0100031F AD002300
[   15.862182] PVR_K:   (MKT-151) 00000AF1 00100808 0100041F AD00000A
[   15.862213] PVR_K:   (MKT-152) 00000B3B 00100808 0100041F AD001100
[   15.862213] PVR_K:   (MKT-153) 00000BB5 00100808 0100041F AD002505
[   15.862213] PVR_K:   (MKT-154) 00000CCA 00100808 0100041F AD000901
[   15.862243] PVR_K:   (MKT-155) 00011EFB 00100808 0100071F AD001A00
[   15.862243] PVR_K:   (MKT-156) 000122ED 00100808 0100081F AD00000A
[   15.862243] PVR_K:   (MKT-157) 00012357 00100808 0100081F AD000909
[   15.862274] PVR_K:   (MKT-158) 000123A1 00100808 0100081F AD001A05
[   15.862274] PVR_K:   (MKT-159) 00012459 00100808 0100081F AD001A06
[   15.862274] PVR_K:   (MKT-15A) 0000049D 00100808 0100031F AD002300
[   15.862304] PVR_K:   (MKT-15B) 00000A03 00100808 0100041F AD00000A
[   15.862304] PVR_K:   (MKT-15C) 00000A4E 00100808 0100041F AD001100
[   15.862304] PVR_K:   (MKT-15D) 00000AC6 00100808 0100041F AD000905
[   15.862304] PVR_K:   (MKT-15E) 00000C12 00100888 0100041F AD000901
[   15.862335] PVR_K:   (MKT-15F) 00000C77 00100C08 0100051E AD000281
[   15.862335] PVR_K:   (MKT-160) 00000E02 00100808 0100051E AD00080A
[   15.862335] PVR_K:   (MKT-161) 00000E1C 00100808 0100051E 0F037000
[   15.862365] PVR_K:   (MKT-162) 00000E34 00100808 0100051E 00000073
[   15.862365] PVR_K:   (MKT-163) 00000F5C 00100C88 0100051E AD001300
[   15.862365] PVR_K:   (MKT-164) 0000109A 00100808 0000051E AD001301
[   15.862396] PVR_K:   (MKT-165) 000011D1 00100808 0000051E AD000802
[   15.862396] PVR_K:   (MKT-166) 0000133A 00100808 0000051E AD000803
[   15.862396] PVR_K:   (MKT-167) 00001388 00184AC8 0000051E AD000282
[   15.862426] PVR_K:   (MKT-168) 000034B5 00000808 0100081F AD000200
[   15.862426] PVR_K:   (MKT-169) 000035F4 00000808 0100081F AD001703
[   15.862426] PVR_K:   (MKT-16A) 000037EE 00000808 0000081F AD000202
[   15.862457] PVR_K:   (MKT-16B) 0000387C 00000808 0100091E AD000183
[   15.862457] PVR_K:   (MKT-16C) 000039E8 00000808 0100091E AD000302
[   15.862457] PVR_K:   (MKT-16D) 00003C21 00000808 0100091E AD000404
[   15.862487] PVR_K:   (MKT-16E) 00003CEA 00000808 0000091E AD000402
[   15.862487] PVR_K:   (MKT-16F) 00003D26 001008AF 0000091E AD000184
[   15.862487] PVR_K:   (MKT-170) 0000596D 00000808 00000B1F AD000101
[   15.862518] PVR_K:   (MKT-171) 000059DB 00000808 00000B1F AD000104
[   15.862518] PVR_K:   (MKT-172) 00005A04 00000808 01000C1E AD000100
[   15.862518] PVR_K:   (MKT-173) 00005B08 00000808 01000C1E AD000501
[   15.862548] PVR_K:   (MKT-174) 00005B48 00100829 01000C1E AD000104
[   15.862548] PVR_K:   (MKT-175) 00075815 0010182B 0100201F AD000A01
[   15.862579] PVR_K:   (MKT-176) 0007585A 0010182B 0100201F AD000A0A
[   15.862579] PVR_K:   (MKT-177) 059F68B5 00100808 0100031F AD000B00
[   15.862579] PVR_K:   (MKT-178) 059F68FD 00100808 0100031F AD000B03
[   15.862609] PVR_K:   (MKT-179) 059F693D 00100808 0100031F AD000B05
[   15.862609] PVR_K:   (MKT-17A) 059F69A1 00100808 0100031F AD000B06
[   15.862609] PVR_K:   (MKT-17B) 059F69E5 00100808 0100031F AD000B07
[   15.862640] PVR_K:   (MKT-17C) 059F6A0A 00100808 0100031F AD000B09
[   15.862640] PVR_K:   (MKT-17D) 059F6A5F 00100808 0100031F AD000B01
[   15.862640] PVR_K:   (MKT-17E) 059F6A9B 00100808 0100031F AD002300
[   15.862670] PVR_K:   (MKT-17F) 059F6F18 00100808 0100041F AD00000A
[   15.862670] PVR_K:   (MKT-180) 059F6F88 00100808 0100041F AD000904
[   15.862670] PVR_K:   (MKT-181) 059F7085 00100808 0000041F AD000901
[   15.862701] PVR_K:   (MKT-182) 059F7100 00100808 0100051E AD000183
[   15.862701] PVR_K:   (MKT-183) 059F739B 00100808 0100051E AD000302
[   15.862701] PVR_K:   (MKT-184) 059F73F4 00100808 0100051E AD000303
[   15.862731] PVR_K:   (MKT-185) 059F746B 00100808 0100051E AD000C01
[   15.862731] PVR_K:   (MKT-186) 059F7490 00100808 0100051E 0D800464
[   15.862762] PVR_K:   (MKT-187) 059F74A8 00100808 0100051E 00000001
[   15.862762] PVR_K:   (MKT-188) 059F7925 0010088F 0000051E AD002401
[   15.862762] PVR_K:   (MKT-189) 059F7972 0016EE8F 0000051E AD000184
[   15.862762] PVR_K:   (MKT-18A) 059F8692 00100808 0100071F AD000101
[   15.862792] PVR_K:   (MKT-18B) 059F8775 00100808 0100071F AD001601
[   15.862792] PVR_K:   (MKT-18C) 059F879C 00100808 0100071F 0D8004A4
[   15.862823] PVR_K:   (MKT-18D) 059F87B5 00100808 0100071F 00000001
[   15.862823] PVR_K:   (MKT-18E) 059F8911 00100808 0100071F AD000104
[   15.862823] PVR_K:   (MKT-18F) 059F978C 00100808 0100081F AD00000A
[   15.862854] PVR_K:   (MKT-190) 059F97FD 00100808 0100081F AD000905
[   15.862854] PVR_K:   (MKT-191) 059F993B 00100888 0100081F AD000901
[   15.862854] PVR_K:   (MKT-192) 059F9998 00100C08 0100091E AD000281
[   15.862884] PVR_K:   (MKT-193) 059F9B1C 00100808 0100091E AD00080A
[   15.862884] PVR_K:   (MKT-194) 059F9B34 00100808 0100091E 0F011000
[   15.862884] PVR_K:   (MKT-195) 059F9B4C 00100808 0100091E 00000073
[   15.862915] PVR_K:   (MKT-196) 059F9C71 00100C88 0100091E AD001300
[   15.862915] PVR_K:   (MKT-197) 059F9DAE 00100808 0000091E AD001301
[   15.862915] PVR_K:   (MKT-198) 059F9EDA 00100808 0000091E AD000802
[   15.862945] PVR_K:   (MKT-199) 059FA04B 00100808 0000091E AD000803
[   15.862945] PVR_K:   (MKT-19A) 059FA099 00184AC8 0000091E AD000282
[   15.862945] PVR_K:   (MKT-19B) 059FAA22 00180838 01000C1F AD00000A
[   15.862976] PVR_K:   (MKT-19C) 059FAAB5 00180838 01000C1F AD000906
[   15.862976] PVR_K:   (MKT-19D) 059FAB73 001808B8 01000C1F AD000901
[   15.862976] PVR_K:   (MKT-19E) 059FABD1 00180C38 01000D1E AD000281
[   15.863006] PVR_K:   (MKT-19F) 059FAC22 00180838 01000D1E AD000282
[   15.863006] PVR_K:   (MKT-1A0) 059FD49E 00000C08 01000F1F AD000200
[   15.863037] PVR_K:   (MKT-1A1) 059FD5E5 00000808 01000F1F AD001703
[   15.863037] PVR_K:   (MKT-1A2) 059FD758 00000808 00000F1F AD000202
[   15.863037] PVR_K:   (MKT-1A3) 059FD7E8 00000808 0100101E AD000183
[   15.863067] PVR_K:   (MKT-1A4) 059FD948 00000808 0100101E AD000302
[   15.863067] PVR_K:   (MKT-1A5) 059FDC0B 00000808 0000101E AD000402
[   15.863067] PVR_K:   (MKT-1A6) 059FDC46 001008AF 0000101E AD000184
[   15.863098] PVR_K:   (MKT-1A7) 05A06FD4 00100828 0100131F AD000101
[   15.863098] PVR_K:   (MKT-1A8) 05A0704B 00100828 0100131F AD000104
[   15.863098] PVR_K:   (MKT-1A9) 05A07463 00000808 0100141F AD000100
[   15.863128] PVR_K:   (MKT-1AA) 05A074DB 00000808 0100141F AD000502
[   15.863128] PVR_K:   (MKT-1AB) 05A07525 00000808 0100141F AD000C01
[   15.863159] PVR_K:   (MKT-1AC) 05A07548 00000808 0100141F 0D800044
[   15.863159] PVR_K:   (MKT-1AD) 05A07560 00000808 0100141F 00000001
[   15.863159] PVR_K:   (MKT-1AE) 05A077F8 00000808 0100141F AD000104
[   15.863189] PVR_K:   (MKT-1AF) 05A098ED 00000808 0100161F AD00000A
[   15.863189] PVR_K:   (MKT-1B0) 05A09953 00000808 0100161F AD000905
[   15.863189] PVR_K:   (MKT-1B1) 05A09A85 00000888 0100161F AD000901
[   15.863220] PVR_K:   (MKT-1B2) 05A09AE4 00000C08 0100171E AD000281
[   15.863220] PVR_K:   (MKT-1B3) 05A09C68 00000808 0100171E AD00080A
[   15.863220] PVR_K:   (MKT-1B4) 05A09C81 00000808 0100171E 0F037300
[   15.863250] PVR_K:   (MKT-1B5) 05A09C99 00000808 0100171E 00000071
[   15.863250] PVR_K:   (MKT-1B6) 05A09D22 00000808 0100171E AD001302
[   15.863250] PVR_K:   (MKT-1B7) 05A09D70 00000808 0000171E AD001303
[   15.863281] PVR_K:   (MKT-1B8) 05A09E1B 00000C88 0000171E AD001300
[   15.863281] PVR_K:   (MKT-1B9) 05A0F184 00000808 0000171E AD001301
[   15.863281] PVR_K:   (MKT-1BA) 05A0F2BB 00000808 0000171E AD000802
[   15.863311] PVR_K:   (MKT-1BB) 05A0F427 00000808 0000171E AD000803
[   15.863311] PVR_K:   (MKT-1BC) 05A0F477 00184AC8 0000171E AD000282
[   15.863342] PVR_K:   (MKT-1BD) 05A0F57C 00180838 0000181F AD00000A
[   15.863342] PVR_K:   (MKT-1BE) 05A0F5F3 00180838 0000181F AD000905
[   15.863342] PVR_K:   (MKT-1BF) 05A0F715 001808B8 0000181F AD000901
[   15.863372] PVR_K:   (MKT-1C0) 05A0F792 00180838 00001A1C AD00000A
[   15.863372] PVR_K:   (MKT-1C1) 05A0F7D4 00180838 00001A1C AD001100
[   15.863372] PVR_K:   (MKT-1C2) 05A0F839 00180838 00001A1C AD000904
[   15.863403] PVR_K:   (MKT-1C3) 05A0F926 00180838 00001A1C AD000901
[   15.863403] PVR_K:   (MKT-1C4) 05A0FA33 00180838 00001C1A AD00000A
[   15.863403] PVR_K:   (MKT-1C5) 05A0FA8E 00180838 00001C1A AD000905
[   15.863433] PVR_K:   (MKT-1C6) 05A0FB79 00180838 00001C1A AD000901
[   15.863433] PVR_K:   (MKT-1C7) 05A0FBF3 00180838 00001D19 AD00000A
[   15.863433] PVR_K:   (MKT-1C8) 05A0FC5F 00180838 00001D19 AD000905
[   15.863464] PVR_K:   (MKT-1C9) 05A0FD07 00180838 00001D19 AD000901
[   15.863464] PVR_K:   (MKT-1CA) 05A0FD7F 00180C38 00001F1E AD000281
[   15.863464] PVR_K:   (MKT-1CB) 05A0FDE3 00180838 00001F1E AD000282
[   15.863494] PVR_K:   (MKT-1CC) 05A0FE92 00180838 0100201F AD000183
[   15.863494] PVR_K:   (MKT-1CD) 05A101E9 001808BF 0000201F AD002401
[   15.863494] PVR_K:   (MKT-1CE) 05A1022F 001EEEBF 0000201F AD000184
[   15.863525] PVR_K:   (MKT-1CF) 05A109DA 00180838 0100221F AD000101
[   15.863525] PVR_K:   (MKT-1D0) 05A10ABB 00180838 0100221F AD001601
[   15.863525] PVR_K:   (MKT-1D1) 05A10AE1 00180838 0100221F 0D8004E4
[   15.863555] PVR_K:   (MKT-1D2) 05A10AFA 00180838 0100221F 00000001
[   15.863555] PVR_K:   (MKT-1D3) 05A10C44 00180838 0000221F AD000104
[   15.863555] PVR_K:   (MKT-1D4) 05A10CA1 00180C38 0100231E AD000281
[   15.863586] PVR_K:   (MKT-1D5) 05A10CFA 00180838 0100231E AD000282
[   15.863586] PVR_K:   (MKT-1D6) 05A1195D 00000808 0100241F AD000200
[   15.863616] PVR_K:   (MKT-1D7) 05A11BDD 00000808 0000241F AD000202
[   15.863616] PVR_K:   (MKT-1D8) 05A11C2C 00000808 0100251E AD000281
[   15.863616] PVR_K:   (MKT-1D9) 05A11D73 00000808 0100251E AD00080A
[   15.863647] PVR_K:   (MKT-1DA) 05A11D8C 00000808 0100251E 0F037600
[   15.863647] PVR_K:   (MKT-1DB) 05A11DA4 00000808 0100251E 00000060
[   15.863647] PVR_K:   (MKT-1DC) 05A12054 00000808 0000251E AD000803
[   15.863677] PVR_K:   (MKT-1DD) 05A1209B 001808C8 0000251E AD000282
[   15.863677] PVR_K:   (MKT-1DE) 05A1218F 00000808 0100271F AD000200
[   15.863677] PVR_K:   (MKT-1DF) 05A123B5 00000808 0100271F AD000202
[   15.863708] PVR_K:   (MKT-1E0) 05A1240B 00000808 0100281E AD000281
[   15.863708] PVR_K:   (MKT-1E1) 05A1255C 00000808 0100281E AD00080A
[   15.863708] PVR_K:   (MKT-1E2) 05A12574 00000808 0100281E 0F037900
[   15.863739] PVR_K:   (MKT-1E3) 05A1258D 00000808 0100281E 00000060
[   15.863739] PVR_K:   (MKT-1E4) 05A1283A 00000808 0000281E AD000803
[   15.863769] PVR_K:   (MKT-1E5) 05A12880 00180CC8 0000281E AD000282
[   15.863769] PVR_K:   (MKT-1E6) 05A12968 00000808 01002A1F AD000200
[   15.863769] PVR_K:   (MKT-1E7) 05A12B8F 00000808 01002A1F AD000202
[   15.863800] PVR_K:   (MKT-1E8) 05A12BDD 00000808 01002B1E AD000281
[   15.863800] PVR_K:   (MKT-1E9) 05A12D29 00000808 01002B1E AD00080A
[   15.863800] PVR_K:   (MKT-1EA) 05A12D41 00000808 01002B1E 0F037C00
[   15.863830] PVR_K:   (MKT-1EB) 05A12D5A 00000808 01002B1E 00000062
[   15.863830] PVR_K:   (MKT-1EC) 05A13006 00000808 00002B1E AD000803
[   15.863830] PVR_K:   (MKT-1ED) 05A1304C 00180C88 00002B1E AD000282
[   15.863861] PVR_K:   (MKT-1EE) 05A13B50 00000808 01002D1F AD000200
[   15.863861] PVR_K:   (MKT-1EF) 05A13C6D 00000808 01002D1F AD001703
[   15.863861] PVR_K:   (MKT-1F0) 05A13E5C 00000808 00002D1F AD000202
[   15.863861] PVR_K:   (MKT-1F1) 05A13EDA 00000808 01002E1E AD000183
[   15.863891] PVR_K:   (MKT-1F2) 05A1402D 00000808 00002E1E AD000302
[   15.863891] PVR_K:   (MKT-1F3) 05A14266 00000808 00002E1E AD000404
[   15.863891] PVR_K:   (MKT-1F4) 05A14328 00000808 00002E1E AD000402
[   15.863922] PVR_K:   (MKT-1F5) 05A14363 001008AD 00002E1E AD000184
[   15.863922] PVR_K:   (MKT-1F6) 05A16BA9 00000808 0000311F AD000101
[   15.863922] PVR_K:   (MKT-1F7) 05A16C22 00000808 0000311F AD000104
[   15.863952] PVR_K:   (MKT-1F8) 05A16C5E 00000808 0100321E AD000100
[   15.863952] PVR_K:   (MKT-1F9) 05A16D64 00000808 0100321E AD000501
[   15.863952] PVR_K:   (MKT-1FA) 05A16DA3 0010082B 0100321E AD000104
[   15.863983] PVR_K:   (MKT-1FB) 05A19004 00100828 0100331F AD000101
[   15.863983] PVR_K:   (MKT-1FC) 05A19059 00100828 0100331F AD000104
[   15.863983] PVR_K:   (MKT-1FD) 05A19165 00000808 0100341F AD000100
[   15.864013] PVR_K:   (MKT-1FE) 05A19239 00000808 0100341F AD000501
[   15.864013] PVR_K:   (MKT-1FF) 05A1926F 00100829 0100341F AD000104
[   15.864013] PVR_K: SGX Kernel CCB WO:0xB RO:0xB
[   15.921630] adc_to_temp_conversion:Temp read is invalid 0
[   15.921630] thermal_lookup_temp: getting temp is not supported for domain pcb
[   15.922485] adc_to_temp_conversion:Temp read is invalid 0
[   15.922485] thermal_lookup_temp: getting temp is not supported for domain pcb
[   15.923339] adc_to_temp_conversion:Temp read is invalid 0
[   15.923339] thermal_lookup_temp: getting temp is not supported for domain pcb
[   19.780090] adc_to_temp_conversion:Temp read is invalid 0
[   19.785980] thermal_lookup_temp: getting temp is not supported for domain pcb
[   19.794525] adc_to_temp_conversion:Temp read is invalid 0
[   19.800445] thermal_lookup_temp: getting temp is not supported for domain pcb
[   19.809356] adc_to_temp_conversion:Temp read is invalid 0
[   19.815277] thermal_lookup_temp: getting temp is not supported for domain pcb
[   20.006713] PVR_K:(Error): SGXOSTimer() detected SGX lockup (0x6 tasks) [0, ]
[   20.014312] PVR_K: HWRecoveryResetSGX: SGX Hardware Recovery triggered
[   20.021514] [   15.672]   [c6e89d00] new in dsscomp_gralloc_queue (refs=1)
[   20.021514] [   15.672]                           [c6e64400] dsscomp_new
[   20.021545] [   15.672]   [c6e89d00] ++refs=2 for [c6e64400]
[   20.021545] [   15.672]                           [c6e64400] dsscomp_delayed_apply
[   20.021545] [   15.672]   [c6e89d00] --refs=1 on RELEASED
[   20.052795] [   15.672]                           [c6e64400] dsscomp_apply
[   20.052795] [   15.711]   [c6e89d00] --refs=0 on ECLIPSED
[   20.052795] [   15.711]   [c6e89d00] calling   (null) [  (null)]
[   20.052795] [   15.711]                           [c6e64400] dsscomp_mgr_delayed_cb on ECLIPSED
[   20.082519] [   19.772]    [c6edb7a0] new in dsscomp_gralloc_queue (refs=1)
[   20.082550] [   19.772]                        [c738c400] dsscomp_new
[   20.082550] [   19.772]    [c6edb7a0] ++refs=2 for [c738c400]
[   20.082550] [   19.772]                        [c738c400] dsscomp_delayed_apply
[   20.112274] [   19.772]    [c6edb7a0] --refs=1 on RELEASED
[   20.112274] [   19.772]                        [c738c400] dsscomp_apply
[   20.112274] [   19.773]                        [c738c400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   20.112274] [   19.779]    [c6e89d40] new in dsscomp_gralloc_queue (refs=1)
[   20.142059] [   19.779]                           [c6e64400] dsscomp_new
[   20.142059] [   19.779]    [c6e89d40] ++refs=2 for [c6e64400]
[   20.142089] [   19.779]                           [c6e64400] dsscomp_delayed_apply
[   20.142089] [   19.779]    [c6e89d40] --refs=1 on RELEASED
[   20.142089] [   19.779]                           [c6e64400] dsscomp_apply
[   20.173400] [   19.801]                        [c738c400] dsscomp_mgr_delayed_cb on DISPLAYED
[   20.173400] [   19.801]    [c6edb7a0] --refs=0 on RELEASED
[   20.173400] [   19.801]    [c6edb7a0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   20.173400] [   19.801]                        [c738c400] dsscomp_mgr_delayed_cb on RELEASED
[   20.203155] [   19.801]   [c6edb760] new in dsscomp_gralloc_queue (refs=1)
[   20.203155] [   19.801]                        [c6f10400] dsscomp_new
[   20.203155] [   19.801]   [c6edb760] ++refs=2 for [c6f10400]
[   20.203155] [   19.801]                        [c6f10400] dsscomp_delayed_apply
[   20.232910] [   19.801]   [c6edb760] --refs=1 on RELEASED
[   20.232910] [   19.801]                           [c6e64400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   20.232910] [   19.801]                        [c6f10400] dsscomp_apply
[   20.232910] [   19.816]                           [c6e64400] dsscomp_mgr_delayed_cb on DISPLAYED
[   20.262695] [   19.816]    [c6e89d40] --refs=0 on RELEASED
[   20.262695] [   19.816]    [c6e89d40] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   20.262695] [   19.816]                           [c6e64400] dsscomp_mgr_delayed_cb on RELEASED
[   20.290924] [   19.816]                        [c6f10400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   20.290924] [   19.832]                        [c6f10400] dsscomp_mgr_delayed_cb on DISPLAYED
[   20.290924] ACTIVE COMPOSITIONS on lcd
[   20.290924]
[   20.290924]   [c6f10400]: DISPLAYED
[   20.290924]     sync_id=0, flags=AD-
[   20.323760]     ovl0={ON z0 ARGB32-8888 premult *100% 864*480:0,0+864,480 rot0 => 0,0+864,480 7f9ac000/  (null)|3456}
[   20.323760]     gsync=[c6edb760] dsscomp_gralloc_cb
[   20.323760]
[   20.323760]   DISPC pipeline:
[   20.323760]
[   20.323760]     info:        clean (none)
[   20.323760]     cache:       clean (none)
[   20.323791]     shadow:  ACT clean (none)
[   20.359588]     dispc:   DISPLAYED mask=---R [c6f10400] dsscomp_mgr_callback
[   20.359588]
[   20.359588] ACTIVE COMPOSITIONS on tv
[   20.359619]
[   20.359619]   DISPC pipeline:
[   20.359619]
[   20.359619]     info:        clean (none)
[   20.359619]     cache:       clean (none)
[   20.359619]     shadow:  off clean (none)
[   20.359619]     dispc:   DISPLAYED (none)
[   20.359619]
[   20.359619] ACTIVE COMPOSITIONS on lcd2
[   20.401611]
[   20.401611]   DISPC pipeline:
[   20.401611]
[   20.401611]     info:        clean (none)
[   20.401611]     cache:       clean (none)
[   20.401611]     shadow:  off clean (none)
[   20.401611]     dispc:             (none)
[   20.401611]
[   20.401611] ACTIVE GRALLOC FLIPS
[   20.401611]
[   20.401611]   [c6edb760] (refs=1)
[   20.401611]     slots=[7f9ac000]
[   20.401611]     cmdcb=[c73f6480] dsscomp_proxy_cmdcomplete
[   20.445159]
[   20.445190]   |           lcd
[   20.445190]   | [c6f10400] DISPL'D
[   20.445190]   |     19.801  ACTIVE
[   20.445190]   |     19.801 APPLY'N
[   20.445190]   |     19.801 APPLIED
[   20.445190]   |     19.816 PROGR'D
[   20.445190]   |     19.832 DISPL'D
[   20.445190]
[   20.445190]
[   20.476715] PVR_K: SGX debug (blaze_android_sgx_ogles1_ogles2_GPL sgxddk 18 1.8@869593)
[   20.485290] PVR_K:(Error): SGX Register Base Address (Linear):   0xC8B20000 [0, ]
[   20.493316] PVR_K:(Error): SGX Register Base Address (Physical): 0x56000000 [0, ]
[   20.501281] PVR_K: (P0) EUR_CR_CORE_ID:          01140000
[   20.507110] PVR_K: (P0) EUR_CR_CORE_REVISION:    00010200
[   20.512847] PVR_K: (P0) EUR_CR_EVENT_STATUS:     20000000
[   20.518646] PVR_K: (P0) EUR_CR_EVENT_STATUS2:    00000008
[   20.524414] PVR_K: (P0) EUR_CR_BIF_CTRL:         00000000
[   20.530212] PVR_K: (P0) EUR_CR_BIF_INT_STAT:     00008000
[   20.535980] PVR_K: (P0) EUR_CR_BIF_FAULT:        00000000
[   20.541778] PVR_K: (P0) EUR_CR_BIF_MEM_REQ_STAT: 00000001
[   20.547546] PVR_K: (P0) EUR_CR_CLKGATECTL:       000AAA6A
[   20.553344] PVR_K: (P0) EUR_CR_PDS_PC_BASE:      00004008
[   20.559112] PVR_K: Flip Command Complete Data 0 for display device 1:
[   20.566040] PVR_K:   SRC 0: ROC DevVAddr:0xD800494 ROP:0x2 ROC:0x0, WOC DevVAddr:0xD800484 WOP:0x2 WOC:0x1
[   20.576232] PVR_K: Flip Command Complete Data 1 for display device 1:
[   20.583099] PVR_K:   SRC 0: (Not in use)
[   20.587249] PVR_K: SGX Host control:
[   20.591094] PVR_K:   (HC-0) 0x00000001 0x00000000 0x00000000 0x00000001
[   20.598052] PVR_K:   (HC-10) 0x00000002 0x0000000A 0x0005DC00 0x00000003
[   20.605163] PVR_K:   (HC-20) 0x00000000 0x00000003 0x00000000 0x00000003
[   20.612274] PVR_K:   (HC-30) 0x00000026 0xEF4CF3A0 0x00000000 0x00000000
[   20.631683] PVR_K:   (HC-40) 0x00000000 0x087BF500 0x087C6300 0x087C3100
[   20.638793] PVR_K: SGX TA/3D control:
[   20.655151] PVR_K:   (T3C-0) 0x0F003000 0x0F003120 0x0F002000 0x00000000
[   20.662231] PVR_K:   (T3C-10) 0x00000001 0x00000002 0x00000001 0x0F00DD00
[   20.678588] PVR_K:   (T3C-20) 0x00000000 0x00000000 0x00000000 0x00000000
[   20.685791] PVR_K:   (T3C-30) 0x00000000 0x00000000 0x00000000 0x00000000
[   20.702484] PVR_K:   (T3C-40) 0x00000000 0x00000000 0x00000000 0x00000000
[   20.717620] PVR_K:   (T3C-50) 0x00000000 0x00000000 0x00000000 0x00000000
[   20.724822] PVR_K:   (T3C-60) 0x00000000 0x00000000 0x0F00DD00 0x00000000
[   20.745941] PVR_K:   (T3C-70) 0x00000000 0x0F00DD00 0x00000000 0x0F004000
[   20.764495] PVR_K:   (T3C-80) 0x00000109 0x0001120F 0x00000000 0x0F00DEFC
[   20.771636] PVR_K:   (T3C-90) 0x00000000 0x0F000000 0xAB600000 0x0F038800
[   20.787933] PVR_K:   (T3C-A0) 0x00000000 0x0F010BE0 0x0F00DD00 0x0F00DEFC
[   20.795135] PVR_K:   (T3C-B0) 0x0F010BE0 0x00000000 0x00000000 0x00000000
[   20.819213] PVR_K:   (T3C-C0) 0x00000000 0x00000000 0x00000000 0x00000000
[   20.820098] adc_to_temp_conversion:Temp read is invalid 0
[   20.820098] thermal_lookup_temp: getting temp is not supported for domain pcb
[   20.820953] adc_to_temp_conversion:Temp read is invalid 0
[   20.820953] thermal_lookup_temp: getting temp is not supported for domain pcb
[   20.821777] adc_to_temp_conversion:Temp read is invalid 0
[   20.821777] thermal_lookup_temp: getting temp is not supported for domain pcb
[   20.866516] PVR_K:   (T3C-D0) 0x00000000 0x00000002 0x00000002 0x0F007000
[   20.873687] PVR_K:   (T3C-E0) 0x0F00D420 0x0F00E000 0x0F010720 0x0F010720
[   20.880859] PVR_K:   (T3C-F0) 0x00000000 0x000000B5 0x000000B5 0x00000000
[   20.888061] PVR_K:   (T3C-100) 0x00000003 0x00000000 0x00000000 0x00000000
[   20.895294] PVR_K:   (T3C-110) 0xB50C565C 0x0872E100 0x08787B00 0x08787B00
[   20.902587] PVR_K: Last SGX microkernel status code: AD000184
[   20.908813] PVR_K:   (MKT-0) 00000000 00000000 00000000 00000000
[   20.915130] PVR_K:   (MKT-1) 00000000 00000000 00000000 00000000
[   20.921478] PVR_K:   (MKT-2) 00000000 00000000 00000000 00000000
[   20.927795] PVR_K:   (MKT-3) 00000000 00000000 00000000 00000000
[   20.934173] PVR_K:   (MKT-4) 00000000 00000000 00000000 00000000
[   20.940490] PVR_K:   (MKT-5) 00000000 00000000 00000000 00000000
[   20.946868] PVR_K:   (MKT-6) 00000000 00000000 00000000 00000000
[   20.953186] PVR_K:   (MKT-7) 00000000 00000000 00000000 00000000
[   20.959533] PVR_K:   (MKT-8) 00000000 00000000 00000000 00000000
[   20.965850] PVR_K:   (MKT-9) 00000000 00000000 00000000 00000000
[   20.972229] PVR_K:   (MKT-A) 00000000 00000000 00000000 00000000
[   20.978546] PVR_K:   (MKT-B) 00000000 00000000 00000000 00000000
[   20.984893] PVR_K:   (MKT-C) 00000000 00000000 00000000 00000000
[   20.991210] PVR_K:   (MKT-D) 00000000 00000000 00000000 00000000
[   20.997558] PVR_K:   (MKT-E) 00000000 00000000 00000000 00000000
[   21.003875] PVR_K:   (MKT-F) 00000000 00000000 00000000 00000000
[   21.010284] PVR_K:   (MKT-10) 00000000 00000000 00000000 00000000
[   21.016723] PVR_K:   (MKT-11) 00000000 00000000 00000000 00000000
[   21.023132] PVR_K:   (MKT-12) 00000000 00000000 00000000 00000000
[   21.029571] PVR_K:   (MKT-13) 00000000 00000000 00000000 00000000
[   21.035980] PVR_K:   (MKT-14) 00000000 00000000 00000000 00000000
[   21.042449] PVR_K:   (MKT-15) 00000000 00000000 00000000 00000000
[   21.048828] PVR_K:   (MKT-16) 00000000 00000000 00000000 00000000
[   21.055297] PVR_K:   (MKT-17) 00000000 00000000 00000000 00000000
[   21.061706] PVR_K:   (MKT-18) 00000000 00000000 00000000 00000000
[   21.068145] PVR_K:   (MKT-19) 00000000 00000000 00000000 00000000
[   21.074554] PVR_K:   (MKT-1A) 00000000 00000000 00000000 00000000
[   21.080993] PVR_K:   (MKT-1B) 00000000 00000000 00000000 00000000
[   21.087432] PVR_K:   (MKT-1C) 00000000 00000000 00000000 00000000
[   21.093963] PVR_K:   (MKT-1D) 00000000 00000000 00000000 00000000
[   21.100463] PVR_K:   (MKT-1E) 00000000 00000000 00000000 00000000
[   21.106933] PVR_K:   (MKT-1F) 00000000 00000000 00000000 00000000
[   21.113433] PVR_K:   (MKT-20) 00000000 00000000 00000000 00000000
[   21.119934] PVR_K:   (MKT-21) 00000000 00000000 00000000 00000000
[   21.126403] PVR_K:   (MKT-22) 00000000 00000000 00000000 00000000
[   21.132843] PVR_K:   (MKT-23) 00000000 00000000 00000000 00000000
[   21.139282] PVR_K:   (MKT-24) 00000000 00000000 00000000 00000000
[   21.145721] PVR_K:   (MKT-25) 00000000 00000000 00000000 00000000
[   21.152160] PVR_K:   (MKT-26) 00000000 00000000 00000000 00000000
[   21.158569] PVR_K:   (MKT-27) 00000000 00000000 00000000 00000000
[   21.165039] PVR_K:   (MKT-28) 00000000 00000000 00000000 00000000
[   21.171447] PVR_K:   (MKT-29) 00000000 00000000 00000000 00000000
[   21.177886] PVR_K:   (MKT-2A) 00000000 00000000 00000000 00000000
[   21.184265] PVR_K:   (MKT-2B) 00000000 00000000 00000000 00000000
[   21.190765] PVR_K:   (MKT-2C) 00000000 00000000 00000000 00000000
[   21.197174] PVR_K:   (MKT-2D) 00000000 00000000 00000000 00000000
[   21.203613] PVR_K:   (MKT-2E) 00000000 00000000 00000000 00000000
[   21.210052] PVR_K:   (MKT-2F) 00000000 00000000 00000000 00000000
[   21.216491] PVR_K:   (MKT-30) 00000000 00000000 00000000 00000000
[   21.222961] PVR_K:   (MKT-31) 00000000 00000000 00000000 00000000
[   21.229400] PVR_K:   (MKT-32) 00000000 00000000 00000000 00000000
[   21.235839] PVR_K:   (MKT-33) 00000000 00000000 00000000 00000000
[   21.242279] PVR_K:   (MKT-34) 00000000 00000000 00000000 00000000
[   21.248718] PVR_K:   (MKT-35) 00000000 00000000 00000000 00000000
[   21.255126] PVR_K:   (MKT-36) 00000000 00000000 00000000 00000000
[   21.261627] PVR_K:   (MKT-37) 00000000 00000000 00000000 00000000
[   21.268035] PVR_K:   (MKT-38) 00000000 00000000 00000000 00000000
[   21.274505] PVR_K:   (MKT-39) 00000000 00000000 00000000 00000000
[   21.280914] PVR_K:   (MKT-3A) 00000000 00000000 00000000 00000000
[   21.287353] PVR_K:   (MKT-3B) 00000000 00000000 00000000 00000000
[   21.293762] PVR_K:   (MKT-3C) 00000000 00000000 00000000 00000000
[   21.300231] PVR_K:   (MKT-3D) 00000000 00000000 00000000 00000000
[   21.306671] PVR_K:   (MKT-3E) 00000000 00000000 00000000 00000000
[   21.313171] PVR_K:   (MKT-3F) 00000000 00000000 00000000 00000000
[   21.319580] PVR_K:   (MKT-40) 00000000 00000000 00000000 00000000
[   21.326019] PVR_K:   (MKT-41) 00000000 00000000 00000000 00000000
[   21.332489] PVR_K:   (MKT-42) 00000000 00000000 00000000 00000000
[   21.338897] PVR_K:   (MKT-43) 00000000 00000000 00000000 00000000
[   21.345367] PVR_K:   (MKT-44) 00000000 00000000 00000000 00000000
[   21.351776] PVR_K:   (MKT-45) 00000000 00000000 00000000 00000000
[   21.358245] PVR_K:   (MKT-46) 00000000 00000000 00000000 00000000
[   21.364624] PVR_K:   (MKT-47) 00000000 00000000 00000000 00000000
[   21.371093] PVR_K:   (MKT-48) 00000000 00000000 00000000 00000000
[   21.377502] PVR_K:   (MKT-49) 00000000 00000000 00000000 00000000
[   21.383972] PVR_K:   (MKT-4A) 00000000 00000000 00000000 00000000
[   21.390411] PVR_K:   (MKT-4B) 00000000 00000000 00000000 00000000
[   21.396850] PVR_K:   (MKT-4C) 00000000 00000000 00000000 00000000
[   21.403259] PVR_K:   (MKT-4D) 00000000 00000000 00000000 00000000
[   21.409729] PVR_K:   (MKT-4E) 00000000 00000000 00000000 00000000
[   21.416168] PVR_K:   (MKT-4F) 00000000 00000000 00000000 00000000
[   21.422637] PVR_K:   (MKT-50) 00000000 00000000 00000000 00000000
[   21.429107] PVR_K:   (MKT-51) 00000000 00000000 00000000 00000000
[   21.435516] PVR_K:   (MKT-52) 00000000 00000000 00000000 00000000
[   21.441986] PVR_K:   (MKT-53) 00000000 00000000 00000000 00000000
[   21.448394] PVR_K:   (MKT-54) 00000000 00000000 00000000 00000000
[   21.454833] PVR_K:   (MKT-55) 00000000 00000000 00000000 00000000
[   21.461242] PVR_K:   (MKT-56) 00000000 00000000 00000000 00000000
[   21.467712] PVR_K:   (MKT-57) 00000000 00000000 00000000 00000000
[   21.474090] PVR_K:   (MKT-58) 00000000 00000000 00000000 00000000
[   21.480560] PVR_K:   (MKT-59) 00000000 00000000 00000000 00000000
[   21.486968] PVR_K:   (MKT-5A) 00000000 00000000 00000000 00000000
[   21.493438] PVR_K:   (MKT-5B) 00000000 00000000 00000000 00000000
[   21.499847] PVR_K:   (MKT-5C) 00000000 00000000 00000000 00000000
[   21.506286] PVR_K:   (MKT-5D) 00000000 00000000 00000000 00000000
[   21.512695] PVR_K:   (MKT-5E) 00000000 00000000 00000000 00000000
[   21.519195] PVR_K:   (MKT-5F) 00000000 00000000 00000000 00000000
[   21.525604] PVR_K:   (MKT-60) 00000000 00000000 00000000 00000000
[   21.532073] PVR_K:   (MKT-61) 00000000 00000000 00000000 00000000
[   21.538543] PVR_K:   (MKT-62) 00000000 00000000 00000000 00000000
[   21.544952] PVR_K:   (MKT-63) 00000000 00000000 00000000 00000000
[   21.551422] PVR_K:   (MKT-64) 00000000 00000000 00000000 00000000
[   21.557830] PVR_K:   (MKT-65) 00000000 00000000 00000000 00000000
[   21.564270] PVR_K:   (MKT-66) 00000000 00000000 00000000 00000000
[   21.570709] PVR_K:   (MKT-67) 00000000 00000000 00000000 00000000
[   21.577178] PVR_K:   (MKT-68) 00000000 00000000 00000000 00000000
[   21.583587] PVR_K:   (MKT-69) 00000000 00000000 00000000 00000000
[   21.590057] PVR_K:   (MKT-6A) 00000000 00000000 00000000 00000000
[   21.596435] PVR_K:   (MKT-6B) 00000000 00000000 00000000 00000000
[   21.602905] PVR_K:   (MKT-6C) 00000000 00000000 00000000 00000000
[   21.609313] PVR_K:   (MKT-6D) 00000000 00000000 00000000 00000000
[   21.615722] PVR_K:   (MKT-6E) 00000000 00000000 00000000 00000000
[   21.622222] PVR_K:   (MKT-6F) 00000000 00000000 00000000 00000000
[   21.628692] PVR_K:   (MKT-70) 00000000 00000000 00000000 00000000
[   21.635162] PVR_K:   (MKT-71) 00000000 00000000 00000000 00000000
[   21.641571] PVR_K:   (MKT-72) 00000000 00000000 00000000 00000000
[   21.648010] PVR_K:   (MKT-73) 00000000 00000000 00000000 00000000
[   21.654418] PVR_K:   (MKT-74) 00000000 00000000 00000000 00000000
[   21.660858] PVR_K:   (MKT-75) 00000000 00000000 00000000 00000000
[   21.667266] PVR_K:   (MKT-76) 00000000 00000000 00000000 00000000
[   21.673706] PVR_K:   (MKT-77) 00000000 00000000 00000000 00000000
[   21.680145] PVR_K:   (MKT-78) 00000000 00000000 00000000 00000000
[   21.686584] PVR_K:   (MKT-79) 00000000 00000000 00000000 00000000
[   21.692962] PVR_K:   (MKT-7A) 00000000 00000000 00000000 00000000
[   21.699401] PVR_K:   (MKT-7B) 00000000 00000000 00000000 00000000
[   21.705810] PVR_K:   (MKT-7C) 00000000 00000000 00000000 00000000
[   21.712249] PVR_K:   (MKT-7D) 00000000 00000000 00000000 00000000
[   21.718688] PVR_K:   (MKT-7E) 00000000 00000000 00000000 00000000
[   21.725128] PVR_K:   (MKT-7F) 00000000 00000000 00000000 00000000
[   21.731536] PVR_K:   (MKT-80) 00000000 00000000 00000000 00000000
[   21.738006] PVR_K:   (MKT-81) 00000000 00000000 00000000 00000000
[   21.744476] PVR_K:   (MKT-82) 00000000 00000000 00000000 00000000
[   21.750885] PVR_K:   (MKT-83) 00000000 00000000 00000000 00000000
[   21.757324] PVR_K:   (MKT-84) 00000000 00000000 00000000 00000000
[   21.763732] PVR_K:   (MKT-85) 00000000 00000000 00000000 00000000
[   21.770202] PVR_K:   (MKT-86) 00000000 00000000 00000000 00000000
[   21.776611] PVR_K:   (MKT-87) 00000000 00000000 00000000 00000000
[   21.783050] PVR_K:   (MKT-88) 00000000 00000000 00000000 00000000
[   21.789459] PVR_K:   (MKT-89) 00000000 00000000 00000000 00000000
[   21.795898] PVR_K:   (MKT-8A) 00000000 00000000 00000000 00000000
[   21.802307] PVR_K:   (MKT-8B) 00000000 00000000 00000000 00000000
[   21.808746] PVR_K:   (MKT-8C) 00000000 00000000 00000000 00000000
[   21.815155] PVR_K:   (MKT-8D) 00000000 00000000 00000000 00000000
[   21.821624] PVR_K:   (MKT-8E) 00000000 00000000 00000000 00000000
[   21.827850] adc_to_temp_conversion:Temp read is invalid 0
[   21.827850] thermal_lookup_temp: getting temp is not supported for domain pcb
[   21.828674] adc_to_temp_conversion:Temp read is invalid 0
[   21.828704] thermal_lookup_temp: getting temp is not supported for domain pcb
[   21.829528] adc_to_temp_conversion:Temp read is invalid 0
[   21.829528] thermal_lookup_temp: getting temp is not supported for domain pcb
[   21.868164] PVR_K:   (MKT-8F) 00000000 00000000 00000000 00000000
[   21.874572] PVR_K:   (MKT-90) 00000000 00000000 00000000 00000000
[   21.881011] PVR_K:   (MKT-91) 00000000 00000000 00000000 00000000
[   21.887420] PVR_K:   (MKT-92) 00000000 00000000 00000000 00000000
[   21.893890] PVR_K:   (MKT-93) 00000000 00000000 00000000 00000000
[   21.900299] PVR_K:   (MKT-94) 00000000 00000000 00000000 00000000
[   21.906738] PVR_K:   (MKT-95) 00000000 00000000 00000000 00000000
[   21.913177] PVR_K:   (MKT-96) 00000000 00000000 00000000 00000000
[   21.919555] PVR_K:   (MKT-97) 00000000 00000000 00000000 00000000
[   21.926055] PVR_K:   (MKT-98) 00000000 00000000 00000000 00000000
[   21.932464] PVR_K:   (MKT-99) 00000000 00000000 00000000 00000000
[   21.938934] PVR_K:   (MKT-9A) 00000000 00000000 00000000 00000000
[   21.945343] PVR_K:   (MKT-9B) 00000000 00000000 00000000 00000000
[   21.951782] PVR_K:   (MKT-9C) 00000000 00000000 00000000 00000000
[   21.958190] PVR_K:   (MKT-9D) 00000000 00000000 00000000 00000000
[   21.964660] PVR_K:   (MKT-9E) 00000000 00000000 00000000 00000000
[   21.971069] PVR_K:   (MKT-9F) 00000000 00000000 00000000 00000000
[   21.977539] PVR_K:   (MKT-A0) 00000000 00000000 00000000 00000000
[   21.983947] PVR_K:   (MKT-A1) 00000000 00000000 00000000 00000000
[   21.990386] PVR_K:   (MKT-A2) 00000000 00000000 00000000 00000000
[   21.996826] PVR_K:   (MKT-A3) 00000000 00000000 00000000 00000000
[   22.003265] PVR_K:   (MKT-A4) 00000000 00000000 00000000 00000000
[   22.009704] PVR_K:   (MKT-A5) 00000000 00000000 00000000 00000000
[   22.016143] PVR_K:   (MKT-A6) 00000000 00000000 00000000 00000000
[   22.022644] PVR_K:   (MKT-A7) 00000000 00000000 00000000 00000000
[   22.029022] PVR_K:   (MKT-A8) 00000000 00000000 00000000 00000000
[   22.035491] PVR_K:   (MKT-A9) 00000000 00000000 00000000 00000000
[   22.041931] PVR_K:   (MKT-AA) 00000000 00000000 00000000 00000000
[   22.048370] PVR_K:   (MKT-AB) 00000000 00000000 00000000 00000000
[   22.054809] PVR_K:   (MKT-AC) 00000000 00000000 00000000 00000000
[   22.061248] PVR_K:   (MKT-AD) 00000000 00000000 00000000 00000000
[   22.067687] PVR_K:   (MKT-AE) 00000000 00000000 00000000 00000000
[   22.074127] PVR_K:   (MKT-AF) 00000000 00000000 00000000 00000000
[   22.080535] PVR_K:   (MKT-B0) 00000000 00000000 00000000 00000000
[   22.087005] PVR_K:   (MKT-B1) 00000000 00000000 00000000 00000000
[   22.093414] PVR_K:   (MKT-B2) 00000000 00000000 00000000 00000000
[   22.099853] PVR_K:   (MKT-B3) 00000000 00000000 00000000 00000000
[   22.106262] PVR_K:   (MKT-B4) 00000000 00000000 00000000 00000000
[   22.112731] PVR_K:   (MKT-B5) 00000000 00000000 00000000 00000000
[   22.119140] PVR_K:   (MKT-B6) 00000000 00000000 00000000 00000000
[   22.125610] PVR_K:   (MKT-B7) 00000000 00000000 00000000 00000000
[   22.132080] PVR_K:   (MKT-B8) 00000000 00000000 00000000 00000000
[   22.138458] PVR_K:   (MKT-B9) 00000000 00000000 00000000 00000000
[   22.144927] PVR_K:   (MKT-BA) 00000000 00000000 00000000 00000000
[   22.151336] PVR_K:   (MKT-BB) 00000000 00000000 00000000 00000000
[   22.157806] PVR_K:   (MKT-BC) 00000000 00000000 00000000 00000000
[   22.164215] PVR_K:   (MKT-BD) 00000000 00000000 00000000 00000000
[   22.170684] PVR_K:   (MKT-BE) 00000000 00000000 00000000 00000000
[   22.177093] PVR_K:   (MKT-BF) 00000000 00000000 00000000 00000000
[   22.183563] PVR_K:   (MKT-C0) 00000000 00000000 00000000 00000000
[   22.189971] PVR_K:   (MKT-C1) 00000000 00000000 00000000 00000000
[   22.196441] PVR_K:   (MKT-C2) 00000000 00000000 00000000 00000000
[   22.202850] PVR_K:   (MKT-C3) 00000000 00000000 00000000 00000000
[   22.209289] PVR_K:   (MKT-C4) 00000000 00000000 00000000 00000000
[   22.215728] PVR_K:   (MKT-C5) 00000000 00000000 00000000 00000000
[   22.222167] PVR_K:   (MKT-C6) 00000000 00000000 00000000 00000000
[   22.228668] PVR_K:   (MKT-C7) 00000000 00000000 00000000 00000000
[   22.235076] PVR_K:   (MKT-C8) 00000000 00000000 00000000 00000000
[   22.241546] PVR_K:   (MKT-C9) 00000000 00000000 00000000 00000000
[   22.247924] PVR_K:   (MKT-CA) 00000000 00000000 00000000 00000000
[   22.254394] PVR_K:   (MKT-CB) 00000000 00000000 00000000 00000000
[   22.260833] PVR_K:   (MKT-CC) 00000000 00000000 00000000 00000000
[   22.267272] PVR_K:   (MKT-CD) 00000000 00000000 00000000 00000000
[   22.273712] PVR_K:   (MKT-CE) 00000000 00000000 00000000 00000000
[   22.280151] PVR_K:   (MKT-CF) 00000000 00000000 00000000 00000000
[   22.286560] PVR_K:   (MKT-D0) 00000000 00000000 00000000 00000000
[   22.293029] PVR_K:   (MKT-D1) 00000000 00000000 00000000 00000000
[   22.299438] PVR_K:   (MKT-D2) 00000000 00000000 00000000 00000000
[   22.305877] PVR_K:   (MKT-D3) 00000000 00000000 00000000 00000000
[   22.312316] PVR_K:   (MKT-D4) 00000000 00000000 00000000 00000000
[   22.318756] PVR_K:   (MKT-D5) 00000000 00000000 00000000 00000000
[   22.325164] PVR_K:   (MKT-D6) 00000000 00000000 00000000 00000000
[   22.331604] PVR_K:   (MKT-D7) 00000000 00000000 00000000 00000000
[   22.338073] PVR_K:   (MKT-D8) 00000000 00000000 00000000 00000000
[   22.344482] PVR_K:   (MKT-D9) 00000000 00000000 00000000 00000000
[   22.350952] PVR_K:   (MKT-DA) 00000000 00000000 00000000 00000000
[   22.357330] PVR_K:   (MKT-DB) 00000000 00000000 00000000 00000000
[   22.363800] PVR_K:   (MKT-DC) 00000000 00000000 00000000 00000000
[   22.370208] PVR_K:   (MKT-DD) 00000000 00000000 00000000 00000000
[   22.376647] PVR_K:   (MKT-DE) 00000000 00000000 00000000 00000000
[   22.383087] PVR_K:   (MKT-DF) 00000000 00000000 00000000 00000000
[   22.389526] PVR_K:   (MKT-E0) 00000000 00000000 00000000 00000000
[   22.395935] PVR_K:   (MKT-E1) 00000000 00000000 00000000 00000000
[   22.402374] PVR_K:   (MKT-E2) 00000000 00000000 00000000 00000000
[   22.408782] PVR_K:   (MKT-E3) 00000000 00000000 00000000 00000000
[   22.415252] PVR_K:   (MKT-E4) 00000000 00000000 00000000 00000000
[   22.421661] PVR_K:   (MKT-E5) 00000000 00000000 00000000 00000000
[   22.428100] PVR_K:   (MKT-E6) 00000000 00000000 00000000 00000000
[   22.434600] PVR_K:   (MKT-E7) 00000000 00000000 00000000 00000000
[   22.441009] PVR_K:   (MKT-E8) 00000000 00000000 00000000 00000000
[   22.447479] PVR_K:   (MKT-E9) 00000000 00000000 00000000 00000000
[   22.453887] PVR_K:   (MKT-EA) 000005BA 00100808 0100031F AD002300
[   22.460357] PVR_K:   (MKT-EB) 00000AF1 00100808 0100041F AD00000A
[   22.466735] PVR_K:   (MKT-EC) 00000B3B 00100808 0100041F AD001100
[   22.473205] PVR_K:   (MKT-ED) 00000BB5 00100808 0100041F AD002505
[   22.479614] PVR_K:   (MKT-EE) 00000CCA 00100808 0100041F AD000901
[   22.486083] PVR_K:   (MKT-EF) 00011EFB 00100808 0100071F AD001A00
[   22.492492] PVR_K:   (MKT-F0) 000122ED 00100808 0100081F AD00000A
[   22.498931] PVR_K:   (MKT-F1) 00012357 00100808 0100081F AD000909
[   22.505340] PVR_K:   (MKT-F2) 000123A1 00100808 0100081F AD001A05
[   22.511779] PVR_K:   (MKT-F3) 00012459 00100808 0100081F AD001A06
[   22.518188] PVR_K:   (MKT-F4) 0000049D 00100808 0100031F AD002300
[   22.524627] PVR_K:   (MKT-F5) 00000A03 00100808 0100041F AD00000A
[   22.531097] PVR_K:   (MKT-F6) 00000A4E 00100808 0100041F AD001100
[   22.537475] PVR_K:   (MKT-F7) 00000AC6 00100808 0100041F AD000905
[   22.543945] PVR_K:   (MKT-F8) 00000C12 00100888 0100041F AD000901
[   22.550384] PVR_K:   (MKT-F9) 00000C77 00100C08 0100051E AD000281
[   22.556823] PVR_K:   (MKT-FA) 00000E02 00100808 0100051E AD00080A
[   22.563232] PVR_K:   (MKT-FB) 00000E1C 00100808 0100051E 0F037000
[   22.569702] PVR_K:   (MKT-FC) 00000E34 00100808 0100051E 00000073
[   22.576080] PVR_K:   (MKT-FD) 00000F5C 00100C88 0100051E AD001300
[   22.582550] PVR_K:   (MKT-FE) 0000109A 00100808 0000051E AD001301
[   22.588958] PVR_K:   (MKT-FF) 000011D1 00100808 0000051E AD000802
[   22.595397] PVR_K:   (MKT-100) 0000133A 00100808 0000051E AD000803
[   22.601898] PVR_K:   (MKT-101) 00001388 00184AC8 0000051E AD000282
[   22.608459] PVR_K:   (MKT-102) 000034B5 00000808 0100081F AD000200
[   22.614929] PVR_K:   (MKT-103) 000035F4 00000808 0100081F AD001703
[   22.621490] PVR_K:   (MKT-104) 000037EE 00000808 0000081F AD000202
[   22.628051] PVR_K:   (MKT-105) 0000387C 00000808 0100091E AD000183
[   22.634582] PVR_K:   (MKT-106) 000039E8 00000808 0100091E AD000302
[   22.641143] PVR_K:   (MKT-107) 00003C21 00000808 0100091E AD000404
[   22.647644] PVR_K:   (MKT-108) 00003CEA 00000808 0000091E AD000402
[   22.654174] PVR_K:   (MKT-109) 00003D26 001008AF 0000091E AD000184
[   22.660675] PVR_K:   (MKT-10A) 0000596D 00000808 00000B1F AD000101
[   22.667236] PVR_K:   (MKT-10B) 000059DB 00000808 00000B1F AD000104
[   22.673736] PVR_K:   (MKT-10C) 00005A04 00000808 01000C1E AD000100
[   22.680267] PVR_K:   (MKT-10D) 00005B08 00000808 01000C1E AD000501
[   22.686767] PVR_K:   (MKT-10E) 00005B48 00100829 01000C1E AD000104
[   22.693298] PVR_K:   (MKT-10F) 00075815 0010182B 0100201F AD000A01
[   22.699798] PVR_K:   (MKT-110) 0007585A 0010182B 0100201F AD000A0A
[   22.706359] PVR_K:   (MKT-111) 059F68B5 00100808 0100031F AD000B00
[   22.712890] PVR_K:   (MKT-112) 059F68FD 00100808 0100031F AD000B03
[   22.719390] PVR_K:   (MKT-113) 059F693D 00100808 0100031F AD000B05
[   22.725921] PVR_K:   (MKT-114) 059F69A1 00100808 0100031F AD000B06
[   22.732421] PVR_K:   (MKT-115) 059F69E5 00100808 0100031F AD000B07
[   22.739013] PVR_K:   (MKT-116) 059F6A0A 00100808 0100031F AD000B09
[   22.745513] PVR_K:   (MKT-117) 059F6A5F 00100808 0100031F AD000B01
[   22.752044] PVR_K:   (MKT-118) 059F6A9B 00100808 0100031F AD002300
[   22.758544] PVR_K:   (MKT-119) 059F6F18 00100808 0100041F AD00000A
[   22.765075] PVR_K:   (MKT-11A) 059F6F88 00100808 0100041F AD000904
[   22.771575] PVR_K:   (MKT-11B) 059F7085 00100808 0000041F AD000901
[   22.778137] PVR_K:   (MKT-11C) 059F7100 00100808 0100051E AD000183
[   22.784637] PVR_K:   (MKT-11D) 059F739B 00100808 0100051E AD000302
[   22.791168] PVR_K:   (MKT-11E) 059F73F4 00100808 0100051E AD000303
[   22.797729] PVR_K:   (MKT-11F) 059F746B 00100808 0100051E AD000C01
[   22.804229] PVR_K:   (MKT-120) 059F7490 00100808 0100051E 0D800464
[   22.810760] PVR_K:   (MKT-121) 059F74A8 00100808 0100051E 00000001
[   22.817260] PVR_K:   (MKT-122) 059F7925 0010088F 0000051E AD002401
[   22.823822] PVR_K:   (MKT-123) 059F7972 0016EE8F 0000051E AD000184
[   22.827911] adc_to_temp_conversion:Temp read is invalid 0
[   22.827911] thermal_lookup_temp: getting temp is not supported for domain pcb
[   22.828765] adc_to_temp_conversion:Temp read is invalid 0
[   22.828765] thermal_lookup_temp: getting temp is not supported for domain pcb
[   22.829589] adc_to_temp_conversion:Temp read is invalid 0
[   22.829620] thermal_lookup_temp: getting temp is not supported for domain pcb
[   22.870452] PVR_K:   (MKT-124) 059F8692 00100808 0100071F AD000101
[   22.876953] PVR_K:   (MKT-125) 059F8775 00100808 0100071F AD001601
[   22.883514] PVR_K:   (MKT-126) 059F879C 00100808 0100071F 0D8004A4
[   22.890014] PVR_K:   (MKT-127) 059F87B5 00100808 0100071F 00000001
[   22.896545] PVR_K:   (MKT-128) 059F8911 00100808 0100071F AD000104
[   22.903045] PVR_K:   (MKT-129) 059F978C 00100808 0100081F AD00000A
[   22.909606] PVR_K:   (MKT-12A) 059F97FD 00100808 0100081F AD000905
[   22.916107] PVR_K:   (MKT-12B) 059F993B 00100888 0100081F AD000901
[   22.922637] PVR_K:   (MKT-12C) 059F9998 00100C08 0100091E AD000281
[   22.929138] PVR_K:   (MKT-12D) 059F9B1C 00100808 0100091E AD00080A
[   22.935668] PVR_K:   (MKT-12E) 059F9B34 00100808 0100091E 0F011000
[   22.942199] PVR_K:   (MKT-12F) 059F9B4C 00100808 0100091E 00000073
[   22.948730] PVR_K:   (MKT-130) 059F9C71 00100C88 0100091E AD001300
[   22.955291] PVR_K:   (MKT-131) 059F9DAE 00100808 0000091E AD001301
[   22.961761] PVR_K:   (MKT-132) 059F9EDA 00100808 0000091E AD000802
[   22.968322] PVR_K:   (MKT-133) 059FA04B 00100808 0000091E AD000803
[   22.974822] PVR_K:   (MKT-134) 059FA099 00184AC8 0000091E AD000282
[   22.981384] PVR_K:   (MKT-135) 059FAA22 00180838 01000C1F AD00000A
[   22.987884] PVR_K:   (MKT-136) 059FAAB5 00180838 01000C1F AD000906
[   22.994445] PVR_K:   (MKT-137) 059FAB73 001808B8 01000C1F AD000901
[   23.000946] PVR_K:   (MKT-138) 059FABD1 00180C38 01000D1E AD000281
[   23.007507] PVR_K:   (MKT-139) 059FAC22 00180838 01000D1E AD000282
[   23.013977] PVR_K:   (MKT-13A) 059FD49E 00000C08 01000F1F AD000200
[   23.020538] PVR_K:   (MKT-13B) 059FD5E5 00000808 01000F1F AD001703
[   23.027038] PVR_K:   (MKT-13C) 059FD758 00000808 00000F1F AD000202
[   23.033599] PVR_K:   (MKT-13D) 059FD7E8 00000808 0100101E AD000183
[   23.040161] PVR_K:   (MKT-13E) 059FD948 00000808 0100101E AD000302
[   23.046661] PVR_K:   (MKT-13F) 059FDC0B 00000808 0000101E AD000402
[   23.053192] PVR_K:   (MKT-140) 059FDC46 001008AF 0000101E AD000184
[   23.059722] PVR_K:   (MKT-141) 05A06FD4 00100828 0100131F AD000101
[   23.066253] PVR_K:   (MKT-142) 05A0704B 00100828 0100131F AD000104
[   23.072784] PVR_K:   (MKT-143) 05A07463 00000808 0100141F AD000100
[   23.079345] PVR_K:   (MKT-144) 05A074DB 00000808 0100141F AD000502
[   23.085845] PVR_K:   (MKT-145) 05A07525 00000808 0100141F AD000C01
[   23.092376] PVR_K:   (MKT-146) 05A07548 00000808 0100141F 0D800044
[   23.098876] PVR_K:   (MKT-147) 05A07560 00000808 0100141F 00000001
[   23.105438] PVR_K:   (MKT-148) 05A077F8 00000808 0100141F AD000104
[   23.111938] PVR_K:   (MKT-149) 05A098ED 00000808 0100161F AD00000A
[   23.118499] PVR_K:   (MKT-14A) 05A09953 00000808 0100161F AD000905
[   23.125061] PVR_K:   (MKT-14B) 05A09A85 00000888 0100161F AD000901
[   23.131530] PVR_K:   (MKT-14C) 05A09AE4 00000C08 0100171E AD000281
[   23.138092] PVR_K:   (MKT-14D) 05A09C68 00000808 0100171E AD00080A
[   23.144592] PVR_K:   (MKT-14E) 05A09C81 00000808 0100171E 0F037300
[   23.151153] PVR_K:   (MKT-14F) 05A09C99 00000808 0100171E 00000071
[   23.157653] PVR_K:   (MKT-150) 05A09D22 00000808 0100171E AD001302
[   23.164184] PVR_K:   (MKT-151) 05A09D70 00000808 0000171E AD001303
[   23.170684] PVR_K:   (MKT-152) 05A09E1B 00000C88 0000171E AD001300
[   23.177276] PVR_K:   (MKT-153) 05A0F184 00000808 0000171E AD001301
[   23.183776] PVR_K:   (MKT-154) 05A0F2BB 00000808 0000171E AD000802
[   23.190307] PVR_K:   (MKT-155) 05A0F427 00000808 0000171E AD000803
[   23.196807] PVR_K:   (MKT-156) 05A0F477 00184AC8 0000171E AD000282
[   23.203308] PVR_K:   (MKT-157) 05A0F57C 00180838 0000181F AD00000A
[   23.209869] PVR_K:   (MKT-158) 05A0F5F3 00180838 0000181F AD000905
[   23.216339] PVR_K:   (MKT-159) 05A0F715 001808B8 0000181F AD000901
[   23.222900] PVR_K:   (MKT-15A) 05A0F792 00180838 00001A1C AD00000A
[   23.229400] PVR_K:   (MKT-15B) 05A0F7D4 00180838 00001A1C AD001100
[   23.235931] PVR_K:   (MKT-15C) 05A0F839 00180838 00001A1C AD000904
[   23.242431] PVR_K:   (MKT-15D) 05A0F926 00180838 00001A1C AD000901
[   23.248992] PVR_K:   (MKT-15E) 05A0FA33 00180838 00001C1A AD00000A
[   23.255462] PVR_K:   (MKT-15F) 05A0FA8E 00180838 00001C1A AD000905
[   23.262023] PVR_K:   (MKT-160) 05A0FB79 00180838 00001C1A AD000901
[   23.268524] PVR_K:   (MKT-161) 05A0FBF3 00180838 00001D19 AD00000A
[   23.275115] PVR_K:   (MKT-162) 05A0FC5F 00180838 00001D19 AD000905
[   23.281646] PVR_K:   (MKT-163) 05A0FD07 00180838 00001D19 AD000901
[   23.288146] PVR_K:   (MKT-164) 05A0FD7F 00180C38 00001F1E AD000281
[   23.294677] PVR_K:   (MKT-165) 05A0FDE3 00180838 00001F1E AD000282
[   23.301208] PVR_K:   (MKT-166) 05A0FE92 00180838 0100201F AD000183
[   23.307739] PVR_K:   (MKT-167) 05A101E9 001808BF 0000201F AD002401
[   23.314239] PVR_K:   (MKT-168) 05A1022F 001EEEBF 0000201F AD000184
[   23.320770] PVR_K:   (MKT-169) 05A109DA 00180838 0100221F AD000101
[   23.327301] PVR_K:   (MKT-16A) 05A10ABB 00180838 0100221F AD001601
[   23.333831] PVR_K:   (MKT-16B) 05A10AE1 00180838 0100221F 0D8004E4
[   23.340332] PVR_K:   (MKT-16C) 05A10AFA 00180838 0100221F 00000001
[   23.346862] PVR_K:   (MKT-16D) 05A10C44 00180838 0000221F AD000104
[   23.353363] PVR_K:   (MKT-16E) 05A10CA1 00180C38 0100231E AD000281
[   23.359924] PVR_K:   (MKT-16F) 05A10CFA 00180838 0100231E AD000282
[   23.366485] PVR_K:   (MKT-170) 05A1195D 00000808 0100241F AD000200
[   23.372955] PVR_K:   (MKT-171) 05A11BDD 00000808 0000241F AD000202
[   23.379547] PVR_K:   (MKT-172) 05A11C2C 00000808 0100251E AD000281
[   23.386047] PVR_K:   (MKT-173) 05A11D73 00000808 0100251E AD00080A
[   23.392608] PVR_K:   (MKT-174) 05A11D8C 00000808 0100251E 0F037600
[   23.399108] PVR_K:   (MKT-175) 05A11DA4 00000808 0100251E 00000060
[   23.405670] PVR_K:   (MKT-176) 05A12054 00000808 0000251E AD000803
[   23.412139] PVR_K:   (MKT-177) 05A1209B 001808C8 0000251E AD000282
[   23.418701] PVR_K:   (MKT-178) 05A1218F 00000808 0100271F AD000200
[   23.425201] PVR_K:   (MKT-179) 05A123B5 00000808 0100271F AD000202
[   23.431732] PVR_K:   (MKT-17A) 05A1240B 00000808 0100281E AD000281
[   23.438232] PVR_K:   (MKT-17B) 05A1255C 00000808 0100281E AD00080A
[   23.444793] PVR_K:   (MKT-17C) 05A12574 00000808 0100281E 0F037900
[   23.451324] PVR_K:   (MKT-17D) 05A1258D 00000808 0100281E 00000060
[   23.457824] PVR_K:   (MKT-17E) 05A1283A 00000808 0000281E AD000803
[   23.464385] PVR_K:   (MKT-17F) 05A12880 00180CC8 0000281E AD000282
[   23.470886] PVR_K:   (MKT-180) 05A12968 00000808 01002A1F AD000200
[   23.477447] PVR_K:   (MKT-181) 05A12B8F 00000808 01002A1F AD000202
[   23.483978] PVR_K:   (MKT-182) 05A12BDD 00000808 01002B1E AD000281
[   23.490509] PVR_K:   (MKT-183) 05A12D29 00000808 01002B1E AD00080A
[   23.497009] PVR_K:   (MKT-184) 05A12D41 00000808 01002B1E 0F037C00
[   23.503540] PVR_K:   (MKT-185) 05A12D5A 00000808 01002B1E 00000062
[   23.510070] PVR_K:   (MKT-186) 05A13006 00000808 00002B1E AD000803
[   23.516601] PVR_K:   (MKT-187) 05A1304C 00180C88 00002B1E AD000282
[   23.523132] PVR_K:   (MKT-188) 05A13B50 00000808 01002D1F AD000200
[   23.529663] PVR_K:   (MKT-189) 05A13C6D 00000808 01002D1F AD001703
[   23.536224] PVR_K:   (MKT-18A) 05A13E5C 00000808 00002D1F AD000202
[   23.542724] PVR_K:   (MKT-18B) 05A13EDA 00000808 01002E1E AD000183
[   23.549285] PVR_K:   (MKT-18C) 05A1402D 00000808 00002E1E AD000302
[   23.555816] PVR_K:   (MKT-18D) 05A14266 00000808 00002E1E AD000404
[   23.562347] PVR_K:   (MKT-18E) 05A14328 00000808 00002E1E AD000402
[   23.568847] PVR_K:   (MKT-18F) 05A14363 001008AD 00002E1E AD000184
[   23.575378] PVR_K:   (MKT-190) 05A16BA9 00000808 0000311F AD000101
[   23.581909] PVR_K:   (MKT-191) 05A16C22 00000808 0000311F AD000104
[   23.588470] PVR_K:   (MKT-192) 05A16C5E 00000808 0100321E AD000100
[   23.594970] PVR_K:   (MKT-193) 05A16D64 00000808 0100321E AD000501
[   23.601531] PVR_K:   (MKT-194) 05A16DA3 0010082B 0100321E AD000104
[   23.608032] PVR_K:   (MKT-195) 05A19004 00100828 0100331F AD000101
[   23.614562] PVR_K:   (MKT-196) 05A19059 00100828 0100331F AD000104
[   23.621124] PVR_K:   (MKT-197) 05A19165 00000808 0100341F AD000100
[   23.627624] PVR_K:   (MKT-198) 05A19239 00000808 0100341F AD000501
[   23.634155] PVR_K:   (MKT-199) 05A1926F 00100829 0100341F AD000104
[   23.640655] PVR_K:   (MKT-19A) 05E36A93 00100808 0100031F AD000B00
[   23.647186] PVR_K:   (MKT-19B) 05E36AD9 00100808 0100031F AD000B03
[   23.653686] PVR_K:   (MKT-19C) 05E36B18 00100808 0100031F AD000B05
[   23.660247] PVR_K:   (MKT-19D) 05E36B7B 00100808 0100031F AD000B06
[   23.666748] PVR_K:   (MKT-19E) 05E36BC0 00100808 0100031F AD000B07
[   23.673309] PVR_K:   (MKT-19F) 05E36BE5 00100808 0100031F AD000B09
[   23.679840] PVR_K:   (MKT-1A0) 05E36C3B 00100808 0100031F AD000B01
[   23.686401] PVR_K:   (MKT-1A1) 05E36C77 00100808 0100031F AD002300
[   23.692871] PVR_K:   (MKT-1A2) 05E36FEE 00100808 0100041F AD00000A
[   23.699432] PVR_K:   (MKT-1A3) 05E3706C 00100808 0100041F AD000906
[   23.705963] PVR_K:   (MKT-1A4) 05E3712B 00100808 0000041F AD000901
[   23.712463] PVR_K:   (MKT-1A5) 05E371A5 00100808 0100051E AD000183
[   23.719024] PVR_K:   (MKT-1A6) 05E3730B 00100808 0100051E AD000302
[   23.725524] PVR_K:   (MKT-1A7) 05E3735E 00100808 0100051E AD000303
[   23.732055] PVR_K:   (MKT-1A8) 05E373D6 00100808 0100051E AD000C01
[   23.738555] PVR_K:   (MKT-1A9) 05E373F9 00100808 0100051E 0D800484
[   23.745086] PVR_K:   (MKT-1AA) 05E37412 00100808 0100051E 00000001
[   23.751586] PVR_K:   (MKT-1AB) 05E37622 00100808 0100051E AD000184
[   23.758148] PVR_K:   (MKT-1AC) 05E48621 00100808 0100081F AD001A00
[   23.764648] PVR_K:   (MKT-1AD) 05E48964 00100808 0100091F AD00000A
[   23.771209] PVR_K:   (MKT-1AE) 05E489C5 00100808 0100091F AD000909
[   23.777709] PVR_K:   (MKT-1AF) 05E48A0F 00100808 0100091F AD001A05
[   23.784301] PVR_K:   (MKT-1B0) 05E48AC7 00100808 0100091F AD001A06
[   23.790832] PVR_K:   (MKT-1B1) 00000543 00100808 0100031F AD002300
[   23.797332] PVR_K:   (MKT-1B2) 00001CAD 00100808 0100041F AD00000A
[   23.803894] PVR_K:   (MKT-1B3) 00001D1F 00100808 0100041F AD000905
[   23.810363] PVR_K:   (MKT-1B4) 00001E69 00100888 0100041F AD000901
[   23.816925] PVR_K:   (MKT-1B5) 00001EC8 00100C08 0100051E AD000281
[   23.823425] PVR_K:   (MKT-1B6) 00002056 00100808 0100051E AD00080A
[   23.827880] adc_to_temp_conversion:Temp read is invalid 0
[   23.827911] thermal_lookup_temp: getting temp is not supported for domain pcb
[   23.828735] adc_to_temp_conversion:Temp read is invalid 0
[   23.828765] thermal_lookup_temp: getting temp is not supported for domain pcb
[   23.829589] adc_to_temp_conversion:Temp read is invalid 0
[   23.829620] thermal_lookup_temp: getting temp is not supported for domain pcb
[   23.870056] PVR_K:   (MKT-1B7) 0000206E 00100888 0100051E 0F037F00
[   23.876617] PVR_K:   (MKT-1B8) 00002087 00100808 0000051E 00000061
[   23.883148] PVR_K:   (MKT-1B9) 000021AE 00100C88 0000051E AD001300
[   23.889709] PVR_K:   (MKT-1BA) 000073AE 00100808 0000051E AD001301
[   23.896179] PVR_K:   (MKT-1BB) 000074D8 00100808 0000051E AD000802
[   23.902740] PVR_K:   (MKT-1BC) 00007637 00100808 0000051E AD000803
[   23.909240] PVR_K:   (MKT-1BD) 00007684 00184AC8 0000051E AD000282
[   23.915802] PVR_K:   (MKT-1BE) 00007768 00180CB8 0000061F AD00000A
[   23.922302] PVR_K:   (MKT-1BF) 000077DB 00180838 0000061F AD000905
[   23.928863] PVR_K:   (MKT-1C0) 000078EC 001808B8 0000061F AD000901
[   23.935394] PVR_K:   (MKT-1C1) 0000796A 00180838 0000081C AD00000A
[   23.941894] PVR_K:   (MKT-1C2) 000079CA 00180838 0000081C AD000905
[   23.948425] PVR_K:   (MKT-1C3) 00007A70 00180838 0000081C AD000901
[   23.954925] PVR_K:   (MKT-1C4) 00007AC2 00180838 0000091B AD00000A
[   23.961486] PVR_K:   (MKT-1C5) 00007B25 00180838 0000091B AD000905
[   23.967987] PVR_K:   (MKT-1C6) 00007BCE 00180838 0000091B AD000901
[   23.974517] PVR_K:   (MKT-1C7) 00007CF0 00180C38 01000C1E AD000281
[   23.981018] PVR_K:   (MKT-1C8) 00007D49 00180838 01000C1E AD000282
[   23.987609] PVR_K:   (MKT-1C9) 00009659 00000808 01000D1F AD000200
[   23.994110] PVR_K:   (MKT-1CA) 000098AC 00000808 00000D1F AD000202
[   24.000640] PVR_K:   (MKT-1CB) 000098F9 00000808 01000E1E AD000281
[   24.007141] PVR_K:   (MKT-1CC) 00009A40 00000808 01000E1E AD00080A
[   24.013671] PVR_K:   (MKT-1CD) 00009A59 00000808 01000E1E 0F038200
[   24.020233] PVR_K:   (MKT-1CE) 00009A71 00000808 01000E1E 00000060
[   24.026733] PVR_K:   (MKT-1CF) 00009D1C 00000808 00000E1E AD000803
[   24.033264] PVR_K:   (MKT-1D0) 00009D69 00180CC8 00000E1E AD000282
[   24.039764] PVR_K:   (MKT-1D1) 00009E0B 00000808 0100101F AD000200
[   24.046295] PVR_K:   (MKT-1D2) 0000A02C 00000808 0000101F AD000202
[   24.052795] PVR_K:   (MKT-1D3) 0000A078 00000808 0100111E AD000281
[   24.059326] PVR_K:   (MKT-1D4) 0000A1BE 00000808 0100111E AD00080A
[   24.065856] PVR_K:   (MKT-1D5) 0000A1D7 00000808 0100111E 0F038500
[   24.072387] PVR_K:   (MKT-1D6) 0000A1EF 00000808 0100111E 00000060
[   24.078887] PVR_K:   (MKT-1D7) 0000A4AD 00000808 0000111E AD000803
[   24.085479] PVR_K:   (MKT-1D8) 0000A4F2 00180CC8 0000111E AD000282
[   24.091979] PVR_K:   (MKT-1D9) 0000A5DA 00000808 0100131F AD000200
[   24.098510] PVR_K:   (MKT-1DA) 0000A7FC 00000808 0000131F AD000202
[   24.105072] PVR_K:   (MKT-1DB) 0000A84E 00000808 0100141E AD000281
[   24.111572] PVR_K:   (MKT-1DC) 0000A998 00000808 0100141E AD00080A
[   24.118133] PVR_K:   (MKT-1DD) 0000A9B1 00000808 0100141E 0F038800
[   24.124633] PVR_K:   (MKT-1DE) 0000A9C9 00000808 0100141E 00000062
[   24.131195] PVR_K:   (MKT-1DF) 0000AC76 00000808 0000141E AD000803
[   24.137695] PVR_K:   (MKT-1E0) 0000ACBC 00180C88 0000141E AD000282
[   24.144226] PVR_K:   (MKT-1E1) 0000B7E3 00000808 0100161F AD000200
[   24.150726] PVR_K:   (MKT-1E2) 0000B909 00000808 0100161F AD001703
[   24.157287] PVR_K:   (MKT-1E3) 0000BAFE 00000808 0000161F AD000202
[   24.163787] PVR_K:   (MKT-1E4) 0000BB8F 00000808 0100171E AD000183
[   24.170318] PVR_K:   (MKT-1E5) 0000BC8E 00000808 0100171E AD00030E
[   24.176849] PVR_K:   (MKT-1E6) 0000BCA6 00000808 0100171E 0D800474
[   24.183380] PVR_K:   (MKT-1E7) 0000BCBF 00000808 0100171E 00000000
[   24.189971] PVR_K:   (MKT-1E8) 0000BCE3 00000808 0100171E 00000001
[   24.196472] PVR_K:   (MKT-1E9) 0000BD71 00000808 0100171E AD000184
[   24.203033] PVR_K:   (MKT-1EA) 00017C4E 00000808 01001A1F AD001A00
[   24.209503] PVR_K:   (MKT-1EB) 000290AF 00000808 01001D1F AD00000A
[   24.216064] PVR_K:   (MKT-1EC) 00029110 00000808 01001D1F AD000909
[   24.222564] PVR_K:   (MKT-1ED) 0002915C 00000808 01001D1F AD001A05
[   24.229125] PVR_K:   (MKT-1EE) 0002918D 00000808 01001D1F AD001302
[   24.235626] PVR_K:   (MKT-1EF) 000291CF 00000808 01001D1F AD001303
[   24.242156] PVR_K:   (MKT-1F0) 00029261 00000808 01001D1F AD000D04
[   24.248657] PVR_K:   (MKT-1F1) 00029339 00000808 01001D1F AD000D05
[   24.255218] PVR_K:   (MKT-1F2) 000293AD 00000808 01001D1F AD001A06
[   24.261718] PVR_K:   (MKT-1F3) 00000450 00100808 0100031F AD002300
[   24.268249] PVR_K:   (MKT-1F4) 0000092A 00100808 0100041F AD00000A
[   24.274810] PVR_K:   (MKT-1F5) 000009A6 00100808 0100041F AD000906
[   24.281311] PVR_K:   (MKT-1F6) 00000A7E 00100808 0000041F AD000901
[   24.287841] PVR_K:   (MKT-1F7) 00000AF8 00100808 0100051E AD000183
[   24.294403] PVR_K:   (MKT-1F8) 00000C71 00100808 0100051E AD000302
[   24.300964] PVR_K:   (MKT-1F9) 00000DF7 00100808 0100051E AD000D06
[   24.307464] PVR_K:   (MKT-1FA) 00000EDB 00100808 0100051E AD000D07
[   24.314025] PVR_K:   (MKT-1FB) 00000F25 00100808 0100051E AD001304
[   24.320526] PVR_K:   (MKT-1FC) 00001010 00100808 0100051E AD001305
[   24.327087] PVR_K:   (MKT-1FD) 00001120 00100888 0100051E AD000404
[   24.333557] PVR_K:   (MKT-1FE) 000011E1 00100808 0000051E AD000402
[   24.340118] PVR_K:   (MKT-1FF) 0000122A 0010082B 0000051E AD000184
[   24.346618] PVR_K: SGX Kernel CCB WO:0x1B RO:0x13
[   24.537963] PVR_K:(Error): SGXOSTimer() detected SGX lockup (0x2c tasks) [0, ]
[   24.545715] PVR_K: HWRecoveryResetSGX: SGX Hardware Recovery triggered
[   24.552886] [   15.672]   [c6e89d00] new in dsscomp_gralloc_queue (refs=1)
[   24.552886] [   15.672]                           [c6e64400] dsscomp_new
[   24.552917] [   15.672]   [c6e89d00] ++refs=2 for [c6e64400]
[   24.552917] [   15.672]                           [c6e64400] dsscomp_delayed_apply
[   24.552917] [   15.672]   [c6e89d00] --refs=1 on RELEASED
[   24.584106] [   15.672]                           [c6e64400] dsscomp_apply
[   24.584106] [   15.711]   [c6e89d00] --refs=0 on ECLIPSED
[   24.584106] [   15.711]   [c6e89d00] calling   (null) [  (null)]
[   24.584106] [   15.711]                           [c6e64400] dsscomp_mgr_delayed_cb on ECLIPSED
[   24.613830] [   19.772]    [c6edb7a0] new in dsscomp_gralloc_queue (refs=1)
[   24.613830] [   19.772]                        [c738c400] dsscomp_new
[   24.613830] [   19.772]    [c6edb7a0] ++refs=2 for [c738c400]
[   24.613830] [   19.772]                        [c738c400] dsscomp_delayed_apply
[   24.643585] [   19.772]    [c6edb7a0] --refs=1 on RELEASED
[   24.643615] [   19.772]                        [c738c400] dsscomp_apply
[   24.643615] [   19.773]                        [c738c400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   24.643615] [   19.779]    [c6e89d40] new in dsscomp_gralloc_queue (refs=1)
[   24.673339] [   19.779]                           [c6e64400] dsscomp_new
[   24.673339] [   19.779]    [c6e89d40] ++refs=2 for [c6e64400]
[   24.673339] [   19.779]                           [c6e64400] dsscomp_delayed_apply
[   24.673339] [   19.779]    [c6e89d40] --refs=1 on RELEASED
[   24.673339] [   19.779]                           [c6e64400] dsscomp_apply
[   24.704650] [   19.801]                        [c738c400] dsscomp_mgr_delayed_cb on DISPLAYED
[   24.704650] [   19.801]    [c6edb7a0] --refs=0 on RELEASED
[   24.704650] [   19.801]    [c6edb7a0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   24.704650] [   19.801]                        [c738c400] dsscomp_mgr_delayed_cb on RELEASED
[   24.734405] [   19.801]   [c6edb760] new in dsscomp_gralloc_queue (refs=1)
[   24.734405] [   19.801]                        [c6f10400] dsscomp_new
[   24.734405] [   19.801]   [c6edb760] ++refs=2 for [c6f10400]
[   24.734405] [   19.801]                        [c6f10400] dsscomp_delayed_apply
[   24.764190] [   19.801]   [c6edb760] --refs=1 on RELEASED
[   24.764190] [   19.801]                           [c6e64400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   24.764190] [   19.801]                        [c6f10400] dsscomp_apply
[   24.764190] [   19.816]                           [c6e64400] dsscomp_mgr_delayed_cb on DISPLAYED
[   24.793914] [   19.816]    [c6e89d40] --refs=0 on RELEASED
[   24.793914] [   19.816]    [c6e89d40] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   24.793914] [   19.816]                           [c6e64400] dsscomp_mgr_delayed
[   24.820068] adc_to_temp_conversion:Temp read is invalid 0
[   24.820068] thermal_lookup_temp: getting temp is not supported for domain pcb
[   24.820922] adc_to_temp_conversion:Temp read is invalid 0
[   24.820953] thermal_lookup_temp: getting temp is not supported for domain pcb
[   24.821807] adc_to_temp_conversion:Temp read is invalid 0
[   24.821807] thermal_lookup_temp: getting temp is not supported for domain pcb
[   24.862518] _cb on RELEASED
[   24.862518] [   19.816]                        [c6f10400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   24.862518] [   19.832]                        [c6f10400] dsscomp_mgr_delayed_cb on DISPLAYED
[   24.862518] [   24.345]   [c6edb920] new in dsscomp_gralloc_queue (refs=1)
[   24.862518] [   24.345]                         [c6f11400] dsscomp_new
[   24.893646] [   24.345]   [c6edb920] ++refs=2 for [c6f11400]
[   24.893646] [   24.345]                         [c6f11400] dsscomp_delayed_apply
[   24.893646] [   24.345]   [c6edb920] --refs=1 on RELEASED
[   24.893646] [   24.345]                         [c6f11400] dsscomp_apply
[   24.923431] [   24.345]   [c6edb760] --refs=0 on RELEASED
[   24.923431] [   24.345]   [c6edb760] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   24.923431] [   24.345]                        [c6f10400] dsscomp_mgr_delayed_cb on RELEASED
[   24.923461] [   24.345]                         [c6f11400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   24.953186] [   24.369]                         [c6f11400] dsscomp_mgr_delayed_cb on DISPLAYED
[   24.953186] ACTIVE COMPOSITIONS on lcd
[   24.953186]
[   24.953186]   [c6f11400]: DISPLAYED
[   24.953186]     sync_id=0, flags=AD-
[   24.953186]     ovl0={ON z0 ARGB32-8888 premult *100% 864*480:0,0+864,480 rot0 => 0,0+864,480 7f358000/  (null)|3456}
[   24.986053]     gsync=[c6edb920] dsscomp_gralloc_cb
[   24.986053]
[   24.986053]   DISPC pipeline:
[   24.986053]
[   24.986053]     info:        clean (none)
[   24.986053]     cache:       clean (none)
[   24.986083]     shadow:  ACT clean (none)
[   24.986083]     dispc:   DISPLAYED mask=---R [c6f11400] dsscomp_mgr_callback
[   25.021972]
[   25.021972] ACTIVE COMPOSITIONS on tv
[   25.021972]
[   25.021972]   DISPC pipeline:
[   25.021972]
[   25.021972]     info:        clean (none)
[   25.021972]     cache:       clean (none)
[   25.021972]     shadow:  off clean (none)
[   25.021972]     dispc:   DISPLAYED (none)
[   25.022003]
[   25.022003] ACTIVE COMPOSITIONS on lcd2
[   25.022003]
[   25.022003]   DISPC pipeline:
[   25.022003]
[   25.022003]     info:        clean (none)
[   25.068634]     cache:       clean (none)
[   25.068634]     shadow:  off clean (none)
[   25.068634]     dispc:             (none)
[   25.068634]
[   25.068634] ACTIVE GRALLOC FLIPS
[   25.068634]
[   25.068634]   [c6edb920] (refs=1)
[   25.068634]     slots=[7f358000]
[   25.068634]     cmdcb=[c73f6900] dsscomp_proxy_cmdcomplete
[   25.068634]
[   25.068634]   |           lcd
[   25.068634]   | [c6f11400] DISPL'D
[   25.068664]   |     24.345  ACTIVE
[   25.112030]   |     24.345 APPLY'N
[   25.112030]   |     24.345 APPLIED
[   25.112030]   |     24.345 PROGR'D
[   25.112030]   |     24.369 DISPL'D
[   25.112030]
[   25.112030]
[   25.132263] PVR_K: SGX debug (blaze_android_sgx_ogles1_ogles2_GPL sgxddk 18 1.8@869593)
[   25.140808] PVR_K:(Error): SGX Register Base Address (Linear):   0xC8B20000 [0, ]
[   25.148803] PVR_K:(Error): SGX Register Base Address (Physical): 0x56000000 [0, ]
[   25.156799] PVR_K: (P0) EUR_CR_CORE_ID:          01140000
[   25.162567] PVR_K: (P0) EUR_CR_CORE_REVISION:    00010200
[   25.168365] PVR_K: (P0) EUR_CR_EVENT_STATUS:     20002000
[   25.174133] PVR_K: (P0) EUR_CR_EVENT_STATUS2:    00000008
[   25.179962] PVR_K: (P0) EUR_CR_BIF_CTRL:         00000000
[   25.185699] PVR_K: (P0) EUR_CR_BIF_INT_STAT:     00008000
[   25.191497] PVR_K: (P0) EUR_CR_BIF_FAULT:        00000000
[   25.197265] PVR_K: (P0) EUR_CR_BIF_MEM_REQ_STAT: 00000000
[   25.203094] PVR_K: (P0) EUR_CR_CLKGATECTL:       000AAA6A
[   25.208831] PVR_K: (P0) EUR_CR_PDS_PC_BASE:      00000D70
[   25.214660] PVR_K: Flip Command Complete Data 0 for display device 1:
[   25.221527] PVR_K:   SRC 0: (Not in use)
[   25.225708] PVR_K: Flip Command Complete Data 1 for display device 1:
[   25.232543] PVR_K:   SRC 0: ROC DevVAddr:0xD800474 ROP:0x3 ROC:0x1, WOC DevVAddr:0xD800464 WOP:0x3 WOC:0x2
[   25.242767] PVR_K: SGX Host control:
[   25.246612] PVR_K:   (HC-0) 0x00000001 0x00000000 0x00000000 0x00000001
[   25.253601] PVR_K:   (HC-10) 0x00000003 0x0000000A 0x0005DC00 0x00000003
[   25.260650] PVR_K:   (HC-20) 0x00000000 0x00000001 0x00000000 0x00000003
[   25.267761] PVR_K:   (HC-30) 0x00000028 0xEF9216B0 0x00000000 0x00000000
[   25.274841] PVR_K:   (HC-40) 0x00000000 0x087BF500 0x087C6300 0x087C3100
[   25.281921] PVR_K: SGX TA/3D control:
[   25.285888] PVR_K:   (T3C-0) 0x0F003000 0x0F003120 0x0F002000 0x00000000
[   25.292938] PVR_K:   (T3C-10) 0x00000001 0x00000002 0x00000001 0x0F00DD00
[   25.300109] PVR_K:   (T3C-20) 0x00000000 0x00000000 0x00000000 0x00000000
[   25.307281] PVR_K:   (T3C-30) 0x00000000 0x00000000 0x00000000 0x00000000
[   25.314453] PVR_K:   (T3C-40) 0x00000000 0x00000000 0x00000000 0x00000000
[   25.321624] PVR_K:   (T3C-50) 0x00000000 0x00000000 0x00000000 0x00000000
[   25.328796] PVR_K:   (T3C-60) 0x00000000 0x00000000 0x0F00DD00 0x00000000
[   25.335998] PVR_K:   (T3C-70) 0x00000000 0x0F00DD00 0x00000000 0x0F004000
[   25.343139] PVR_K:   (T3C-80) 0x00000109 0x0001120F 0x00000000 0x0F00DEB8
[   25.350311] PVR_K:   (T3C-90) 0x0F00DEFC 0x0F000000 0xAB600000 0x0F03A000
[   25.357452] PVR_K:   (T3C-A0) 0x0F00DEFC 0x0F010760 0x0F00DD00 0x0F00DEB8
[   25.364654] PVR_K:   (T3C-B0) 0x0F0109A0 0x00000000 0x00000000 0x00000000
[   25.371826] PVR_K:   (T3C-C0) 0x00000000 0x00000000 0x00000000 0x00000000
[   25.378967] PVR_K:   (T3C-D0) 0x00000000 0x00000004 0x00000003 0x0F007000
[   25.386169] PVR_K:   (T3C-E0) 0x0F00D420 0x0F00E000 0x0F010720 0x0F010720
[   25.393310] PVR_K:   (T3C-F0) 0x00000000 0x000000B5 0x000000B5 0x00000000
[   25.400482] PVR_K:   (T3C-100) 0x00000003 0x00000000 0x00000000 0x00000000
[   25.407775] PVR_K:   (T3C-110) 0xB50C565C 0x0872E100 0x08787B00 0x08787B00
[   25.415008] PVR_K: Last SGX microkernel status code: AD000282
[   25.421203] PVR_K:   (MKT-0) 00000000 00000000 00000000 00000000
[   25.427490] PVR_K:   (MKT-1) 00000000 00000000 00000000 00000000
[   25.433868] PVR_K:   (MKT-2) 00000000 00000000 00000000 00000000
[   25.440185] PVR_K:   (MKT-3) 00000000 00000000 00000000 00000000
[   25.446533] PVR_K:   (MKT-4) 00000000 00000000 00000000 00000000
[   25.452850] PVR_K:   (MKT-5) 00000000 00000000 00000000 00000000
[   25.459197] PVR_K:   (MKT-6) 00000000 00000000 00000000 00000000
[   25.465515] PVR_K:   (MKT-7) 00000000 00000000 00000000 00000000
[   25.471893] PVR_K:   (MKT-8) 00000000 00000000 00000000 00000000
[   25.478210] PVR_K:   (MKT-9) 00000000 00000000 00000000 00000000
[   25.484558] PVR_K:   (MKT-A) 00000000 00000000 00000000 00000000
[   25.490875] PVR_K:   (MKT-B) 00000000 00000000 00000000 00000000
[   25.497222] PVR_K:   (MKT-C) 00000000 00000000 00000000 00000000
[   25.503570] PVR_K:   (MKT-D) 00000000 00000000 00000000 00000000
[   25.509887] PVR_K:   (MKT-E) 00000000 00000000 00000000 00000000
[   25.516265] PVR_K:   (MKT-F) 00000000 00000000 00000000 00000000
[   25.522583] PVR_K:   (MKT-10) 00000000 00000000 00000000 00000000
[   25.529022] PVR_K:   (MKT-11) 00000000 00000000 00000000 00000000
[   25.535430] PVR_K:   (MKT-12) 00000000 00000000 00000000 00000000
[   25.541870] PVR_K:   (MKT-13) 00000000 00000000 00000000 00000000
[   25.548278] PVR_K:   (MKT-14) 00000000 00000000 00000000 00000000
[   25.554748] PVR_K:   (MKT-15) 00000000 00000000 00000000 00000000
[   25.561157] PVR_K:   (MKT-16) 00000000 00000000 00000000 00000000
[   25.567596] PVR_K:   (MKT-17) 00000000 00000000 00000000 00000000
[   25.574005] PVR_K:   (MKT-18) 00000000 00000000 00000000 00000000
[   25.580444] PVR_K:   (MKT-19) 00000000 00000000 00000000 00000000
[   25.586853] PVR_K:   (MKT-1A) 00000000 00000000 00000000 00000000
[   25.593322] PVR_K:   (MKT-1B) 00000000 00000000 00000000 00000000
[   25.599731] PVR_K:   (MKT-1C) 00000000 00000000 00000000 00000000
[   25.606170] PVR_K:   (MKT-1D) 00000000 00000000 00000000 00000000
[   25.612640] PVR_K:   (MKT-1E) 00000000 00000000 00000000 00000000
[   25.619049] PVR_K:   (MKT-1F) 00000000 00000000 00000000 00000000
[   25.625488] PVR_K:   (MKT-20) 00000000 00000000 00000000 00000000
[   25.631896] PVR_K:   (MKT-21) 00000000 00000000 00000000 00000000
[   25.638366] PVR_K:   (MKT-22) 00000000 00000000 00000000 00000000
[   25.644775] PVR_K:   (MKT-23) 00000000 00000000 00000000 00000000
[   25.651214] PVR_K:   (MKT-24) 00000000 00000000 00000000 00000000
[   25.657623] PVR_K:   (MKT-25) 00000000 00000000 00000000 00000000
[   25.664093] PVR_K:   (MKT-26) 00000000 00000000 00000000 00000000
[   25.670471] PVR_K:   (MKT-27) 00000000 00000000 00000000 00000000
[   25.676940] PVR_K:   (MKT-28) 00000000 00000000 00000000 00000000
[   25.683349] PVR_K:   (MKT-29) 00000000 00000000 00000000 00000000
[   25.689788] PVR_K:   (MKT-2A) 00000000 00000000 00000000 00000000
[   25.696197] PVR_K:   (MKT-2B) 00000000 00000000 00000000 00000000
[   25.702636] PVR_K:   (MKT-2C) 00000000 00000000 00000000 00000000
[   25.709075] PVR_K:   (MKT-2D) 00000000 00000000 00000000 00000000
[   25.715484] PVR_K:   (MKT-2E) 00000000 00000000 00000000 00000000
[   25.721954] PVR_K:   (MKT-2F) 00000000 00000000 00000000 00000000
[   25.728363] PVR_K:   (MKT-30) 00000000 00000000 00000000 00000000
[   25.734832] PVR_K:   (MKT-31) 00000000 00000000 00000000 00000000
[   25.741241] PVR_K:   (MKT-32) 00000000 00000000 00000000 00000000
[   25.747680] PVR_K:   (MKT-33) 00000000 00000000 00000000 00000000
[   25.754089] PVR_K:   (MKT-34) 00000000 00000000 00000000 00000000
[   25.760528] PVR_K:   (MKT-35) 00000000 00000000 00000000 00000000
[   25.766967] PVR_K:   (MKT-36) 00000000 00000000 00000000 00000000
[   25.773406] PVR_K:   (MKT-37) 00000000 00000000 00000000 00000000
[   25.779785] PVR_K:   (MKT-38) 00000000 00000000 00000000 00000000
[   25.786254] PVR_K:   (MKT-39) 00000000 00000000 00000000 00000000
[   25.792663] PVR_K:   (MKT-3A) 00000000 00000000 00000000 00000000
[   25.799102] PVR_K:   (MKT-3B) 00000000 00000000 00000000 00000000
[   25.805511] PVR_K:   (MKT-3C) 00000000 00000000 00000000 00000000
[   25.811981] PVR_K:   (MKT-3D) 00000000 00000000 00000000 00000000
[   25.818420] PVR_K:   (MKT-3E) 00000000 00000000 00000000 00000000
[   25.819519] bq2415x_charger 1-006a: CHARGER FAULT d4
[   25.825103] adc_to_temp_conversion:Temp read is invalid 0
[   25.825134] thermal_lookup_temp: getting temp is not supported for domain pcb
[   25.825988] adc_to_temp_conversion:Temp read is invalid 0
[   25.825988] thermal_lookup_temp: getting temp is not supported for domain pcb
[   25.826843] adc_to_temp_conversion:Temp read is invalid 0
[   25.826843] thermal_lookup_temp: getting temp is not supported for domain pcb
[   25.870300] PVR_K:   (MKT-3F) 00000000 00000000 00000000 00000000
[   25.876708] PVR_K:   (MKT-40) 00000000 00000000 00000000 00000000
[   25.883178] PVR_K:   (MKT-41) 00000000 00000000 00000000 00000000
[   25.889587] PVR_K:   (MKT-42) 00000000 00000000 00000000 00000000
[   25.896026] PVR_K:   (MKT-43) 00000000 00000000 00000000 00000000
[   25.902435] PVR_K:   (MKT-44) 00000000 00000000 00000000 00000000
[   25.908843] PVR_K:   (MKT-45) 00000000 00000000 00000000 00000000
[   25.915283] PVR_K:   (MKT-46) 00000000 00000000 00000000 00000000
[   25.921691] PVR_K:   (MKT-47) 00000000 00000000 00000000 00000000
[   25.928161] PVR_K:   (MKT-48) 00000000 00000000 00000000 00000000
[   25.934570] PVR_K:   (MKT-49) 00000000 00000000 00000000 00000000
[   25.941009] PVR_K:   (MKT-4A) 00000000 00000000 00000000 00000000
[   25.947418] PVR_K:   (MKT-4B) 00000000 00000000 00000000 00000000
[   25.953887] PVR_K:   (MKT-4C) 00000000 00000000 00000000 00000000
[   25.960296] PVR_K:   (MKT-4D) 00000000 00000000 00000000 00000000
[   25.966735] PVR_K:   (MKT-4E) 00000000 00000000 00000000 00000000
[   25.973144] PVR_K:   (MKT-4F) 00000000 00000000 00000000 00000000
[   25.979614] PVR_K:   (MKT-50) 00000000 00000000 00000000 00000000
[   25.986022] PVR_K:   (MKT-51) 00000000 00000000 00000000 00000000
[   25.992462] PVR_K:   (MKT-52) 00000000 00000000 00000000 00000000
[   25.998870] PVR_K:   (MKT-53) 00000000 00000000 00000000 00000000
[   26.005310] PVR_K:   (MKT-54) 00000000 00000000 00000000 00000000
[   26.011749] PVR_K:   (MKT-55) 00000000 00000000 00000000 00000000
[   26.018157] PVR_K:   (MKT-56) 00000000 00000000 00000000 00000000
[   26.024627] PVR_K:   (MKT-57) 00000000 00000000 00000000 00000000
[   26.031036] PVR_K:   (MKT-58) 00000000 00000000 00000000 00000000
[   26.037475] PVR_K:   (MKT-59) 00000000 00000000 00000000 00000000
[   26.043884] PVR_K:   (MKT-5A) 00000000 00000000 00000000 00000000
[   26.050354] PVR_K:   (MKT-5B) 00000000 00000000 00000000 00000000
[   26.056762] PVR_K:   (MKT-5C) 00000000 00000000 00000000 00000000
[   26.063201] PVR_K:   (MKT-5D) 00000000 00000000 00000000 00000000
[   26.069641] PVR_K:   (MKT-5E) 00000000 00000000 00000000 00000000
[   26.076080] PVR_K:   (MKT-5F) 00000000 00000000 00000000 00000000
[   26.082489] PVR_K:   (MKT-60) 00000000 00000000 00000000 00000000
[   26.088928] PVR_K:   (MKT-61) 00000000 00000000 00000000 00000000
[   26.095336] PVR_K:   (MKT-62) 00000000 00000000 00000000 00000000
[   26.101806] PVR_K:   (MKT-63) 00000000 00000000 00000000 00000000
[   26.108215] PVR_K:   (MKT-64) 00000000 00000000 00000000 00000000
[   26.114624] PVR_K:   (MKT-65) 00000000 00000000 00000000 00000000
[   26.121063] PVR_K:   (MKT-66) 00000000 00000000 00000000 00000000
[   26.127502] PVR_K:   (MKT-67) 00000000 00000000 00000000 00000000
[   26.133941] PVR_K:   (MKT-68) 00000000 00000000 00000000 00000000
[   26.140350] PVR_K:   (MKT-69) 00000000 00000000 00000000 00000000
[   26.146789] PVR_K:   (MKT-6A) 00000000 00000000 00000000 00000000
[   26.153198] PVR_K:   (MKT-6B) 00000000 00000000 00000000 00000000
[   26.159667] PVR_K:   (MKT-6C) 000005BA 00100808 0100031F AD002300
[   26.166076] PVR_K:   (MKT-6D) 00000AF1 00100808 0100041F AD00000A
[   26.172546] PVR_K:   (MKT-6E) 00000B3B 00100808 0100041F AD001100
[   26.178955] PVR_K:   (MKT-6F) 00000BB5 00100808 0100041F AD002505
[   26.185394] PVR_K:   (MKT-70) 00000CCA 00100808 0100041F AD000901
[   26.191802] PVR_K:   (MKT-71) 00011EFB 00100808 0100071F AD001A00
[   26.198272] PVR_K:   (MKT-72) 000122ED 00100808 0100081F AD00000A
[   26.204681] PVR_K:   (MKT-73) 00012357 00100808 0100081F AD000909
[   26.211120] PVR_K:   (MKT-74) 000123A1 00100808 0100081F AD001A05
[   26.217590] PVR_K:   (MKT-75) 00012459 00100808 0100081F AD001A06
[   26.223999] PVR_K:   (MKT-76) 0000049D 00100808 0100031F AD002300
[   26.230438] PVR_K:   (MKT-77) 00000A03 00100808 0100041F AD00000A
[   26.236846] PVR_K:   (MKT-78) 00000A4E 00100808 0100041F AD001100
[   26.243316] PVR_K:   (MKT-79) 00000AC6 00100808 0100041F AD000905
[   26.249725] PVR_K:   (MKT-7A) 00000C12 00100888 0100041F AD000901
[   26.256164] PVR_K:   (MKT-7B) 00000C77 00100C08 0100051E AD000281
[   26.262573] PVR_K:   (MKT-7C) 00000E02 00100808 0100051E AD00080A
[   26.269042] PVR_K:   (MKT-7D) 00000E1C 00100808 0100051E 0F037000
[   26.275451] PVR_K:   (MKT-7E) 00000E34 00100808 0100051E 00000073
[   26.281890] PVR_K:   (MKT-7F) 00000F5C 00100C88 0100051E AD001300
[   26.288299] PVR_K:   (MKT-80) 0000109A 00100808 0000051E AD001301
[   26.294769] PVR_K:   (MKT-81) 000011D1 00100808 0000051E AD000802
[   26.301147] PVR_K:   (MKT-82) 0000133A 00100808 0000051E AD000803
[   26.307617] PVR_K:   (MKT-83) 00001388 00184AC8 0000051E AD000282
[   26.314025] PVR_K:   (MKT-84) 000034B5 00000808 0100081F AD000200
[   26.320434] PVR_K:   (MKT-85) 000035F4 00000808 0100081F AD001703
[   26.326873] PVR_K:   (MKT-86) 000037EE 00000808 0000081F AD000202
[   26.333282] PVR_K:   (MKT-87) 0000387C 00000808 0100091E AD000183
[   26.339721] PVR_K:   (MKT-88) 000039E8 00000808 0100091E AD000302
[   26.346130] PVR_K:   (MKT-89) 00003C21 00000808 0100091E AD000404
[   26.352600] PVR_K:   (MKT-8A) 00003CEA 00000808 0000091E AD000402
[   26.359008] PVR_K:   (MKT-8B) 00003D26 001008AF 0000091E AD000184
[   26.365447] PVR_K:   (MKT-8C) 0000596D 00000808 00000B1F AD000101
[   26.371856] PVR_K:   (MKT-8D) 000059DB 00000808 00000B1F AD000104
[   26.378326] PVR_K:   (MKT-8E) 00005A04 00000808 01000C1E AD000100
[   26.384735] PVR_K:   (MKT-8F) 00005B08 00000808 01000C1E AD000501
[   26.391204] PVR_K:   (MKT-90) 00005B48 00100829 01000C1E AD000104
[   26.397613] PVR_K:   (MKT-91) 00075815 0010182B 0100201F AD000A01
[   26.404052] PVR_K:   (MKT-92) 0007585A 0010182B 0100201F AD000A0A
[   26.410461] PVR_K:   (MKT-93) 059F68B5 00100808 0100031F AD000B00
[   26.416900] PVR_K:   (MKT-94) 059F68FD 00100808 0100031F AD000B03
[   26.423370] PVR_K:   (MKT-95) 059F693D 00100808 0100031F AD000B05
[   26.429779] PVR_K:   (MKT-96) 059F69A1 00100808 0100031F AD000B06
[   26.436218] PVR_K:   (MKT-97) 059F69E5 00100808 0100031F AD000B07
[   26.442626] PVR_K:   (MKT-98) 059F6A0A 00100808 0100031F AD000B09
[   26.449066] PVR_K:   (MKT-99) 059F6A5F 00100808 0100031F AD000B01
[   26.455474] PVR_K:   (MKT-9A) 059F6A9B 00100808 0100031F AD002300
[   26.461944] PVR_K:   (MKT-9B) 059F6F18 00100808 0100041F AD00000A
[   26.468353] PVR_K:   (MKT-9C) 059F6F88 00100808 0100041F AD000904
[   26.474792] PVR_K:   (MKT-9D) 059F7085 00100808 0000041F AD000901
[   26.481201] PVR_K:   (MKT-9E) 059F7100 00100808 0100051E AD000183
[   26.487670] PVR_K:   (MKT-9F) 059F739B 00100808 0100051E AD000302
[   26.494079] PVR_K:   (MKT-A0) 059F73F4 00100808 0100051E AD000303
[   26.500549] PVR_K:   (MKT-A1) 059F746B 00100808 0100051E AD000C01
[   26.506958] PVR_K:   (MKT-A2) 059F7490 00100808 0100051E 0D800464
[   26.513397] PVR_K:   (MKT-A3) 059F74A8 00100808 0100051E 00000001
[   26.519805] PVR_K:   (MKT-A4) 059F7925 0010088F 0000051E AD002401
[   26.526214] PVR_K:   (MKT-A5) 059F7972 0016EE8F 0000051E AD000184
[   26.532684] PVR_K:   (MKT-A6) 059F8692 00100808 0100071F AD000101
[   26.539093] PVR_K:   (MKT-A7) 059F8775 00100808 0100071F AD001601
[   26.545532] PVR_K:   (MKT-A8) 059F879C 00100808 0100071F 0D8004A4
[   26.551940] PVR_K:   (MKT-A9) 059F87B5 00100808 0100071F 00000001
[   26.558380] PVR_K:   (MKT-AA) 059F8911 00100808 0100071F AD000104
[   26.564819] PVR_K:   (MKT-AB) 059F978C 00100808 0100081F AD00000A
[   26.571258] PVR_K:   (MKT-AC) 059F97FD 00100808 0100081F AD000905
[   26.577667] PVR_K:   (MKT-AD) 059F993B 00100888 0100081F AD000901
[   26.584106] PVR_K:   (MKT-AE) 059F9998 00100C08 0100091E AD000281
[   26.590545] PVR_K:   (MKT-AF) 059F9B1C 00100808 0100091E AD00080A
[   26.596984] PVR_K:   (MKT-B0) 059F9B34 00100808 0100091E 0F011000
[   26.603393] PVR_K:   (MKT-B1) 059F9B4C 00100808 0100091E 00000073
[   26.609863] PVR_K:   (MKT-B2) 059F9C71 00100C88 0100091E AD001300
[   26.616271] PVR_K:   (MKT-B3) 059F9DAE 00100808 0000091E AD001301
[   26.622711] PVR_K:   (MKT-B4) 059F9EDA 00100808 0000091E AD000802
[   26.629150] PVR_K:   (MKT-B5) 059FA04B 00100808 0000091E AD000803
[   26.635559] PVR_K:   (MKT-B6) 059FA099 00184AC8 0000091E AD000282
[   26.642028] PVR_K:   (MKT-B7) 059FAA22 00180838 01000C1F AD00000A
[   26.648437] PVR_K:   (MKT-B8) 059FAAB5 00180838 01000C1F AD000906
[   26.654876] PVR_K:   (MKT-B9) 059FAB73 001808B8 01000C1F AD000901
[   26.661285] PVR_K:   (MKT-BA) 059FABD1 00180C38 01000D1E AD000281
[   26.667724] PVR_K:   (MKT-BB) 059FAC22 00180838 01000D1E AD000282
[   26.674133] PVR_K:   (MKT-BC) 059FD49E 00000C08 01000F1F AD000200
[   26.680603] PVR_K:   (MKT-BD) 059FD5E5 00000808 01000F1F AD001703
[   26.687011] PVR_K:   (MKT-BE) 059FD758 00000808 00000F1F AD000202
[   26.693481] PVR_K:   (MKT-BF) 059FD7E8 00000808 0100101E AD000183
[   26.699859] PVR_K:   (MKT-C0) 059FD948 00000808 0100101E AD000302
[   26.706329] PVR_K:   (MKT-C1) 059FDC0B 00000808 0000101E AD000402
[   26.712738] PVR_K:   (MKT-C2) 059FDC46 001008AF 0000101E AD000184
[   26.719207] PVR_K:   (MKT-C3) 05A06FD4 00100828 0100131F AD000101
[   26.725616] PVR_K:   (MKT-C4) 05A0704B 00100828 0100131F AD000104
[   26.732025] PVR_K:   (MKT-C5) 05A07463 00000808 0100141F AD000100
[   26.738464] PVR_K:   (MKT-C6) 05A074DB 00000808 0100141F AD000502
[   26.744873] PVR_K:   (MKT-C7) 05A07525 00000808 0100141F AD000C01
[   26.751312] PVR_K:   (MKT-C8) 05A07548 00000808 0100141F 0D800044
[   26.757720] PVR_K:   (MKT-C9) 05A07560 00000808 0100141F 00000001
[   26.764160] PVR_K:   (MKT-CA) 05A077F8 00000808 0100141F AD000104
[   26.770568] PVR_K:   (MKT-CB) 05A098ED 00000808 0100161F AD00000A
[   26.777038] PVR_K:   (MKT-CC) 05A09953 00000808 0100161F AD000905
[   26.783447] PVR_K:   (MKT-CD) 05A09A85 00000888 0100161F AD000901
[   26.789916] PVR_K:   (MKT-CE) 05A09AE4 00000C08 0100171E AD000281
[   26.796325] PVR_K:   (MKT-CF) 05A09C68 00000808 0100171E AD00080A
[   26.802764] PVR_K:   (MKT-D0) 05A09C81 00000808 0100171E 0F037300
[   26.809173] PVR_K:   (MKT-D1) 05A09C99 00000808 0100171E 00000071
[   26.815643] PVR_K:   (MKT-D2) 05A09D22 00000808 0100171E AD001302
[   26.820037] adc_to_temp_conversion:Temp read is invalid 0
[   26.820068] thermal_lookup_temp: getting temp is not supported for domain pcb
[   26.820892] adc_to_temp_conversion:Temp read is invalid 0
[   26.820922] thermal_lookup_temp: getting temp is not supported for domain pcb
[   26.821777] adc_to_temp_conversion:Temp read is invalid 0
[   26.821777] thermal_lookup_temp: getting temp is not supported for domain pcb
[   26.862182] PVR_K:   (MKT-D3) 05A09D70 00000808 0000171E AD001303
[   26.868591] PVR_K:   (MKT-D4) 05A09E1B 00000C88 0000171E AD001300
[   26.875030] PVR_K:   (MKT-D5) 05A0F184 00000808 0000171E AD001301
[   26.881439] PVR_K:   (MKT-D6) 05A0F2BB 00000808 0000171E AD000802
[   26.887908] PVR_K:   (MKT-D7) 05A0F427 00000808 0000171E AD000803
[   26.894317] PVR_K:   (MKT-D8) 05A0F477 00184AC8 0000171E AD000282
[   26.900787] PVR_K:   (MKT-D9) 05A0F57C 00180838 0000181F AD00000A
[   26.907226] PVR_K:   (MKT-DA) 05A0F5F3 00180838 0000181F AD000905
[   26.913635] PVR_K:   (MKT-DB) 05A0F715 001808B8 0000181F AD000901
[   26.920104] PVR_K:   (MKT-DC) 05A0F792 00180838 00001A1C AD00000A
[   26.926483] PVR_K:   (MKT-DD) 05A0F7D4 00180838 00001A1C AD001100
[   26.932952] PVR_K:   (MKT-DE) 05A0F839 00180838 00001A1C AD000904
[   26.939361] PVR_K:   (MKT-DF) 05A0F926 00180838 00001A1C AD000901
[   26.945800] PVR_K:   (MKT-E0) 05A0FA33 00180838 00001C1A AD00000A
[   26.952209] PVR_K:   (MKT-E1) 05A0FA8E 00180838 00001C1A AD000905
[   26.958648] PVR_K:   (MKT-E2) 05A0FB79 00180838 00001C1A AD000901
[   26.965087] PVR_K:   (MKT-E3) 05A0FBF3 00180838 00001D19 AD00000A
[   26.971527] PVR_K:   (MKT-E4) 05A0FC5F 00180838 00001D19 AD000905
[   26.977935] PVR_K:   (MKT-E5) 05A0FD07 00180838 00001D19 AD000901
[   26.984405] PVR_K:   (MKT-E6) 05A0FD7F 00180C38 00001F1E AD000281
[   26.990814] PVR_K:   (MKT-E7) 05A0FDE3 00180838 00001F1E AD000282
[   26.997253] PVR_K:   (MKT-E8) 05A0FE92 00180838 0100201F AD000183
[   27.003662] PVR_K:   (MKT-E9) 05A101E9 001808BF 0000201F AD002401
[   27.010131] PVR_K:   (MKT-EA) 05A1022F 001EEEBF 0000201F AD000184
[   27.016571] PVR_K:   (MKT-EB) 05A109DA 00180838 0100221F AD000101
[   27.022979] PVR_K:   (MKT-EC) 05A10ABB 00180838 0100221F AD001601
[   27.029418] PVR_K:   (MKT-ED) 05A10AE1 00180838 0100221F 0D8004E4
[   27.035858] PVR_K:   (MKT-EE) 05A10AFA 00180838 0100221F 00000001
[   27.042297] PVR_K:   (MKT-EF) 05A10C44 00180838 0000221F AD000104
[   27.048706] PVR_K:   (MKT-F0) 05A10CA1 00180C38 0100231E AD000281
[   27.055175] PVR_K:   (MKT-F1) 05A10CFA 00180838 0100231E AD000282
[   27.061584] PVR_K:   (MKT-F2) 05A1195D 00000808 0100241F AD000200
[   27.068023] PVR_K:   (MKT-F3) 05A11BDD 00000808 0000241F AD000202
[   27.074432] PVR_K:   (MKT-F4) 05A11C2C 00000808 0100251E AD000281
[   27.080902] PVR_K:   (MKT-F5) 05A11D73 00000808 0100251E AD00080A
[   27.087310] PVR_K:   (MKT-F6) 05A11D8C 00000808 0100251E 0F037600
[   27.093780] PVR_K:   (MKT-F7) 05A11DA4 00000808 0100251E 00000060
[   27.100158] PVR_K:   (MKT-F8) 05A12054 00000808 0000251E AD000803
[   27.106628] PVR_K:   (MKT-F9) 05A1209B 001808C8 0000251E AD000282
[   27.113098] PVR_K:   (MKT-FA) 05A1218F 00000808 0100271F AD000200
[   27.119506] PVR_K:   (MKT-FB) 05A123B5 00000808 0100271F AD000202
[   27.125946] PVR_K:   (MKT-FC) 05A1240B 00000808 0100281E AD000281
[   27.132354] PVR_K:   (MKT-FD) 05A1255C 00000808 0100281E AD00080A
[   27.138793] PVR_K:   (MKT-FE) 05A12574 00000808 0100281E 0F037900
[   27.145202] PVR_K:   (MKT-FF) 05A1258D 00000808 0100281E 00000060
[   27.151672] PVR_K:   (MKT-100) 05A1283A 00000808 0000281E AD000803
[   27.158172] PVR_K:   (MKT-101) 05A12880 00180CC8 0000281E AD000282
[   27.164703] PVR_K:   (MKT-102) 05A12968 00000808 01002A1F AD000200
[   27.171203] PVR_K:   (MKT-103) 05A12B8F 00000808 01002A1F AD000202
[   27.177734] PVR_K:   (MKT-104) 05A12BDD 00000808 01002B1E AD000281
[   27.184234] PVR_K:   (MKT-105) 05A12D29 00000808 01002B1E AD00080A
[   27.190795] PVR_K:   (MKT-106) 05A12D41 00000808 01002B1E 0F037C00
[   27.197296] PVR_K:   (MKT-107) 05A12D5A 00000808 01002B1E 00000062
[   27.203857] PVR_K:   (MKT-108) 05A13006 00000808 00002B1E AD000803
[   27.210388] PVR_K:   (MKT-109) 05A1304C 00180C88 00002B1E AD000282
[   27.216857] PVR_K:   (MKT-10A) 05A13B50 00000808 01002D1F AD000200
[   27.223419] PVR_K:   (MKT-10B) 05A13C6D 00000808 01002D1F AD001703
[   27.229919] PVR_K:   (MKT-10C) 05A13E5C 00000808 00002D1F AD000202
[   27.236450] PVR_K:   (MKT-10D) 05A13EDA 00000808 01002E1E AD000183
[   27.242950] PVR_K:   (MKT-10E) 05A1402D 00000808 00002E1E AD000302
[   27.249511] PVR_K:   (MKT-10F) 05A14266 00000808 00002E1E AD000404
[   27.256011] PVR_K:   (MKT-110) 05A14328 00000808 00002E1E AD000402
[   27.262542] PVR_K:   (MKT-111) 05A14363 001008AD 00002E1E AD000184
[   27.269042] PVR_K:   (MKT-112) 05A16BA9 00000808 0000311F AD000101
[   27.275604] PVR_K:   (MKT-113) 05A16C22 00000808 0000311F AD000104
[   27.282104] PVR_K:   (MKT-114) 05A16C5E 00000808 0100321E AD000100
[   27.288635] PVR_K:   (MKT-115) 05A16D64 00000808 0100321E AD000501
[   27.295196] PVR_K:   (MKT-116) 05A16DA3 0010082B 0100321E AD000104
[   27.301696] PVR_K:   (MKT-117) 05A19004 00100828 0100331F AD000101
[   27.308227] PVR_K:   (MKT-118) 05A19059 00100828 0100331F AD000104
[   27.314727] PVR_K:   (MKT-119) 05A19165 00000808 0100341F AD000100
[   27.321258] PVR_K:   (MKT-11A) 05A19239 00000808 0100341F AD000501
[   27.327789] PVR_K:   (MKT-11B) 05A1926F 00100829 0100341F AD000104
[   27.334320] PVR_K:   (MKT-11C) 05E36A93 00100808 0100031F AD000B00
[   27.340820] PVR_K:   (MKT-11D) 05E36AD9 00100808 0100031F AD000B03
[   27.347351] PVR_K:   (MKT-11E) 05E36B18 00100808 0100031F AD000B05
[   27.353851] PVR_K:   (MKT-11F) 05E36B7B 00100808 0100031F AD000B06
[   27.360382] PVR_K:   (MKT-120) 05E36BC0 00100808 0100031F AD000B07
[   27.366882] PVR_K:   (MKT-121) 05E36BE5 00100808 0100031F AD000B09
[   27.373443] PVR_K:   (MKT-122) 05E36C3B 00100808 0100031F AD000B01
[   27.379974] PVR_K:   (MKT-123) 05E36C77 00100808 0100031F AD002300
[   27.386474] PVR_K:   (MKT-124) 05E36FEE 00100808 0100041F AD00000A
[   27.393035] PVR_K:   (MKT-125) 05E3706C 00100808 0100041F AD000906
[   27.399536] PVR_K:   (MKT-126) 05E3712B 00100808 0000041F AD000901
[   27.406097] PVR_K:   (MKT-127) 05E371A5 00100808 0100051E AD000183
[   27.412597] PVR_K:   (MKT-128) 05E3730B 00100808 0100051E AD000302
[   27.419128] PVR_K:   (MKT-129) 05E3735E 00100808 0100051E AD000303
[   27.425628] PVR_K:   (MKT-12A) 05E373D6 00100808 0100051E AD000C01
[   27.432189] PVR_K:   (MKT-12B) 05E373F9 00100808 0100051E 0D800484
[   27.438690] PVR_K:   (MKT-12C) 05E37412 00100808 0100051E 00000001
[   27.445220] PVR_K:   (MKT-12D) 05E37622 00100808 0100051E AD000184
[   27.451721] PVR_K:   (MKT-12E) 05E48621 00100808 0100081F AD001A00
[   27.458221] PVR_K:   (MKT-12F) 05E48964 00100808 0100091F AD00000A
[   27.464752] PVR_K:   (MKT-130) 05E489C5 00100808 0100091F AD000909
[   27.471252] PVR_K:   (MKT-131) 05E48A0F 00100808 0100091F AD001A05
[   27.477813] PVR_K:   (MKT-132) 05E48AC7 00100808 0100091F AD001A06
[   27.484313] PVR_K:   (MKT-133) 00000543 00100808 0100031F AD002300
[   27.490844] PVR_K:   (MKT-134) 00001CAD 00100808 0100041F AD00000A
[   27.497344] PVR_K:   (MKT-135) 00001D1F 00100808 0100041F AD000905
[   27.503906] PVR_K:   (MKT-136) 00001E69 00100888 0100041F AD000901
[   27.510406] PVR_K:   (MKT-137) 00001EC8 00100C08 0100051E AD000281
[   27.516967] PVR_K:   (MKT-138) 00002056 00100808 0100051E AD00080A
[   27.523437] PVR_K:   (MKT-139) 0000206E 00100888 0100051E 0F037F00
[   27.529998] PVR_K:   (MKT-13A) 00002087 00100808 0000051E 00000061
[   27.536529] PVR_K:   (MKT-13B) 000021AE 00100C88 0000051E AD001300
[   27.543029] PVR_K:   (MKT-13C) 000073AE 00100808 0000051E AD001301
[   27.549591] PVR_K:   (MKT-13D) 000074D8 00100808 0000051E AD000802
[   27.556060] PVR_K:   (MKT-13E) 00007637 00100808 0000051E AD000803
[   27.562622] PVR_K:   (MKT-13F) 00007684 00184AC8 0000051E AD000282
[   27.569091] PVR_K:   (MKT-140) 00007768 00180CB8 0000061F AD00000A
[   27.575653] PVR_K:   (MKT-141) 000077DB 00180838 0000061F AD000905
[   27.582122] PVR_K:   (MKT-142) 000078EC 001808B8 0000061F AD000901
[   27.588684] PVR_K:   (MKT-143) 0000796A 00180838 0000081C AD00000A
[   27.595184] PVR_K:   (MKT-144) 000079CA 00180838 0000081C AD000905
[   27.601745] PVR_K:   (MKT-145) 00007A70 00180838 0000081C AD000901
[   27.608245] PVR_K:   (MKT-146) 00007AC2 00180838 0000091B AD00000A
[   27.614776] PVR_K:   (MKT-147) 00007B25 00180838 0000091B AD000905
[   27.621307] PVR_K:   (MKT-148) 00007BCE 00180838 0000091B AD000901
[   27.627838] PVR_K:   (MKT-149) 00007CF0 00180C38 01000C1E AD000281
[   27.634368] PVR_K:   (MKT-14A) 00007D49 00180838 01000C1E AD000282
[   27.640869] PVR_K:   (MKT-14B) 00009659 00000808 01000D1F AD000200
[   27.647430] PVR_K:   (MKT-14C) 000098AC 00000808 00000D1F AD000202
[   27.653930] PVR_K:   (MKT-14D) 000098F9 00000808 01000E1E AD000281
[   27.660461] PVR_K:   (MKT-14E) 00009A40 00000808 01000E1E AD00080A
[   27.666961] PVR_K:   (MKT-14F) 00009A59 00000808 01000E1E 0F038200
[   27.673492] PVR_K:   (MKT-150) 00009A71 00000808 01000E1E 00000060
[   27.679992] PVR_K:   (MKT-151) 00009D1C 00000808 00000E1E AD000803
[   27.686553] PVR_K:   (MKT-152) 00009D69 00180CC8 00000E1E AD000282
[   27.693054] PVR_K:   (MKT-153) 00009E0B 00000808 0100101F AD000200
[   27.699676] PVR_K:   (MKT-154) 0000A02C 00000808 0000101F AD000202
[   27.706268] PVR_K:   (MKT-155) 0000A078 00000808 0100111E AD000281
[   27.712768] PVR_K:   (MKT-156) 0000A1BE 00000808 0100111E AD00080A
[   27.719329] PVR_K:   (MKT-157) 0000A1D7 00000808 0100111E 0F038500
[   27.725830] PVR_K:   (MKT-158) 0000A1EF 00000808 0100111E 00000060
[   27.732360] PVR_K:   (MKT-159) 0000A4AD 00000808 0000111E AD000803
[   27.738861] PVR_K:   (MKT-15A) 0000A4F2 00180CC8 0000111E AD000282
[   27.745391] PVR_K:   (MKT-15B) 0000A5DA 00000808 0100131F AD000200
[   27.751892] PVR_K:   (MKT-15C) 0000A7FC 00000808 0000131F AD000202
[   27.758422] PVR_K:   (MKT-15D) 0000A84E 00000808 0100141E AD000281
[   27.764953] PVR_K:   (MKT-15E) 0000A998 00000808 0100141E AD00080A
[   27.771484] PVR_K:   (MKT-15F) 0000A9B1 00000808 0100141E 0F038800
[   27.777984] PVR_K:   (MKT-160) 0000A9C9 00000808 0100141E 00000062
[   27.784545] PVR_K:   (MKT-161) 0000AC76 00000808 0000141E AD000803
[   27.791076] PVR_K:   (MKT-162) 0000ACBC 00180C88 0000141E AD000282
[   27.797607] PVR_K:   (MKT-163) 0000B7E3 00000808 0100161F AD000200
[   27.804138] PVR_K:   (MKT-164) 0000B909 00000808 0100161F AD001703
[   27.810638] PVR_K:   (MKT-165) 0000BAFE 00000808 0000161F AD000202
[   27.817169] PVR_K:   (MKT-166) 0000BB8F 00000808 0100171E AD000183
[   27.823669] PVR_K:   (MKT-167) 0000BC8E 00000808 0100171E AD00030E
[   27.827880] adc_to_temp_conversion:Temp read is invalid 0
[   27.827880] thermal_lookup_temp: getting temp is not supported for domain pcb
[   27.828735] adc_to_temp_conversion:Temp read is invalid 0
[   27.828765] thermal_lookup_temp: getting temp is not supported for domain pcb
[   27.829620] adc_to_temp_conversion:Temp read is invalid 0
[   27.829620] thermal_lookup_temp: getting temp is not supported for domain pcb
[   27.870330] PVR_K:   (MKT-168) 0000BCA6 00000808 0100171E 0D800474
[   27.876892] PVR_K:   (MKT-169) 0000BCBF 00000808 0100171E 00000000
[   27.883422] PVR_K:   (MKT-16A) 0000BCE3 00000808 0100171E 00000001
[   27.890075] PVR_K:   (MKT-16B) 0000BD71 00000808 0100171E AD000184
[   27.896575] PVR_K:   (MKT-16C) 00017C4E 00000808 01001A1F AD001A00
[   27.903228] PVR_K:   (MKT-16D) 000290AF 00000808 01001D1F AD00000A
[   27.909759] PVR_K:   (MKT-16E) 00029110 00000808 01001D1F AD000909
[   27.916320] PVR_K:   (MKT-16F) 0002915C 00000808 01001D1F AD001A05
[   27.922821] PVR_K:   (MKT-170) 0002918D 00000808 01001D1F AD001302
[   27.929351] PVR_K:   (MKT-171) 000291CF 00000808 01001D1F AD001303
[   27.935852] PVR_K:   (MKT-172) 00029261 00000808 01001D1F AD000D04
[   27.942382] PVR_K:   (MKT-173) 00029339 00000808 01001D1F AD000D05
[   27.948944] PVR_K:   (MKT-174) 000293AD 00000808 01001D1F AD001A06
[   27.955444] PVR_K:   (MKT-175) 00000450 00100808 0100031F AD002300
[   27.961975] PVR_K:   (MKT-176) 0000092A 00100808 0100041F AD00000A
[   27.968475] PVR_K:   (MKT-177) 000009A6 00100808 0100041F AD000906
[   27.975006] PVR_K:   (MKT-178) 00000A7E 00100808 0000041F AD000901
[   27.981536] PVR_K:   (MKT-179) 00000AF8 00100808 0100051E AD000183
[   27.988067] PVR_K:   (MKT-17A) 00000C71 00100808 0100051E AD000302
[   27.994567] PVR_K:   (MKT-17B) 00000DF7 00100808 0100051E AD000D06
[   28.001129] PVR_K:   (MKT-17C) 00000EDB 00100808 0100051E AD000D07
[   28.007629] PVR_K:   (MKT-17D) 00000F25 00100808 0100051E AD001304
[   28.014160] PVR_K:   (MKT-17E) 00001010 00100808 0100051E AD001305
[   28.020660] PVR_K:   (MKT-17F) 00001120 00100888 0100051E AD000404
[   28.027191] PVR_K:   (MKT-180) 000011E1 00100808 0000051E AD000402
[   28.033752] PVR_K:   (MKT-181) 0000122A 0010082B 0000051E AD000184
[   28.040252] PVR_K:   (MKT-182) 067A6C36 00100808 0100031F AD000B00
[   28.046813] PVR_K:   (MKT-183) 067A6C6E 00100808 0100031F AD000B02
[   28.053283] PVR_K:   (MKT-184) 067A6CEF 00100808 0100031F AD000B02
[   28.059844] PVR_K:   (MKT-185) 067A6D2E 00100808 0100031F AD000B02
[   28.066375] PVR_K:   (MKT-186) 067A6D6C 00100808 0100031F AD000B02
[   28.072937] PVR_K:   (MKT-187) 067A6DAA 00100808 0100031F AD000B02
[   28.079437] PVR_K:   (MKT-188) 067A6DEC 00100808 0100031F AD000B02
[   28.085968] PVR_K:   (MKT-189) 067A6E2C 00100808 0100031F AD000B02
[   28.092468] PVR_K:   (MKT-18A) 067A6E6D 00100808 0100031F AD000B02
[   28.098999] PVR_K:   (MKT-18B) 067A6EAF 00100808 0100031F AD000B03
[   28.105529] PVR_K:   (MKT-18C) 067A6F30 00100808 0100031F AD000B05
[   28.112030] PVR_K:   (MKT-18D) 067A6F87 00100808 0100031F AD000B06
[   28.118591] PVR_K:   (MKT-18E) 067A6FCF 00100808 0100031F AD000B07
[   28.125091] PVR_K:   (MKT-18F) 067A6FF4 00100808 0100031F AD000B09
[   28.131622] PVR_K:   (MKT-190) 067A7048 00100808 0100031F AD000B01
[   28.138122] PVR_K:   (MKT-191) 067A7084 00100808 0100031F AD002300
[   28.144653] PVR_K:   (MKT-192) 067A765B 00100808 0100041F AD00000A
[   28.151153] PVR_K:   (MKT-193) 067A76D3 00100808 0100041F AD000906
[   28.157714] PVR_K:   (MKT-194) 067A778E 00100808 0000041F AD000901
[   28.164215] PVR_K:   (MKT-195) 067A780E 00100808 0000051E AD000183
[   28.170776] PVR_K:   (MKT-196) 067A7976 00100808 0000051E AD000302
[   28.177246] PVR_K:   (MKT-197) 067A79C9 00100808 0000051E AD000303
[   28.183776] PVR_K:   (MKT-198) 067A7A40 00100808 0000051E AD000C01
[   28.190338] PVR_K:   (MKT-199) 067A7A64 00100808 0000051E 0D800464
[   28.196838] PVR_K:   (MKT-19A) 067A7A7D 00100808 0000051E 00000002
[   28.203399] PVR_K:   (MKT-19B) 067A7C8E 00100808 0000051E AD000184
[   28.209869] PVR_K:   (MKT-19C) 067A7D0D 00100C08 0100061D AD000281
[   28.216430] PVR_K:   (MKT-19D) 067A7E91 00100808 0100061D AD00080A
[   28.222930] PVR_K:   (MKT-19E) 067A7EAD 00100808 0100061D 0F038B00
[   28.229492] PVR_K:   (MKT-19F) 067A7EC6 00100808 0100061D 00000061
[   28.235961] PVR_K:   (MKT-1A0) 067A7FE4 00100C88 0100061D AD001300
[   28.242523] PVR_K:   (MKT-1A1) 067AD43A 00100808 0000061D AD001301
[   28.249023] PVR_K:   (MKT-1A2) 067AD571 00100888 0000061D AD000802
[   28.255554] PVR_K:   (MKT-1A3) 067AD6DB 00100888 0000061D AD000803
[   28.262023] PVR_K:   (MKT-1A4) 067AD72D 001808C8 0000061D AD000282
[   28.268585] PVR_K:   (MKT-1A5) 067AD811 00184AF8 0000081E AD00000A
[   28.275115] PVR_K:   (MKT-1A6) 067AD889 001808F8 0000081E AD000905
[   28.281616] PVR_K:   (MKT-1A7) 067AD9B5 001808B8 0000081E AD000901
[   28.288177] PVR_K:   (MKT-1A8) 067ADA27 00180838 0000091C AD00000A
[   28.294647] PVR_K:   (MKT-1A9) 067ADA90 00180838 0000091C AD000905
[   28.301208] PVR_K:   (MKT-1AA) 067ADB3B 00180838 0000091C AD000901
[   28.307708] PVR_K:   (MKT-1AB) 067ADB96 00180838 00000A1B AD00000A
[   28.314270] PVR_K:   (MKT-1AC) 067ADC09 00180838 00000A1B AD000906
[   28.320770] PVR_K:   (MKT-1AD) 067ADC94 00180838 00000A1B AD000901
[   28.327331] PVR_K:   (MKT-1AE) 067ADCF7 00180838 00000B1A AD00000A
[   28.333801] PVR_K:   (MKT-1AF) 067ADD66 00180838 00000B1A AD000905
[   28.340362] PVR_K:   (MKT-1B0) 067ADE11 00180838 00000B1A AD000901
[   28.346862] PVR_K:   (MKT-1B1) 067ADE6B 00180838 00000C19 AD00000A
[   28.353424] PVR_K:   (MKT-1B2) 067ADECC 00180838 00000C19 AD000905
[   28.359954] PVR_K:   (MKT-1B3) 067ADF88 00180838 00000C19 AD000901
[   28.366455] PVR_K:   (MKT-1B4) 067AE0B8 00180C38 01000F1F AD000281
[   28.372985] PVR_K:   (MKT-1B5) 067AE113 00180838 01000F1F AD000282
[   28.379516] PVR_K:   (MKT-1B6) 067AF7F8 00000808 0100101F AD000200
[   28.386047] PVR_K:   (MKT-1B7) 067AFA4E 00000808 0000101F AD000202
[   28.392547] PVR_K:   (MKT-1B8) 067AFA9E 00000808 0100111E AD000281
[   28.399078] PVR_K:   (MKT-1B9) 067AFBF0 00000808 0100111E AD00080A
[   28.405609] PVR_K:   (MKT-1BA) 067AFC09 00000808 0100111E 0F038E00
[   28.412139] PVR_K:   (MKT-1BB) 067AFC21 00000808 0100111E 00000060
[   28.418640] PVR_K:   (MKT-1BC) 067AFEE6 00000808 0000111E AD000803
[   28.425170] PVR_K:   (MKT-1BD) 067AFF2F 00180CC8 0000111E AD000282
[   28.431671] PVR_K:   (MKT-1BE) 067AFFCD 00000808 0100131F AD000200
[   28.438232] PVR_K:   (MKT-1BF) 067B01F4 00000808 0000131F AD000202
[   28.444763] PVR_K:   (MKT-1C0) 067B0242 00000808 0100141E AD000281
[   28.451263] PVR_K:   (MKT-1C1) 067B0390 00000808 0100141E AD00080A
[   28.457794] PVR_K:   (MKT-1C2) 067B03AB 00000808 0100141E 0F039100
[   28.464294] PVR_K:   (MKT-1C3) 067B03C3 00000808 0100141E 00000060
[   28.470825] PVR_K:   (MKT-1C4) 067B0676 00000808 0000141E AD000803
[   28.477355] PVR_K:   (MKT-1C5) 067B06BC 00180CC8 0000141E AD000282
[   28.483886] PVR_K:   (MKT-1C6) 067B07A1 00000808 0100161F AD000200
[   28.490386] PVR_K:   (MKT-1C7) 067B09CF 00000808 0000161F AD000202
[   28.496917] PVR_K:   (MKT-1C8) 067B0A21 00000808 0100171E AD000281
[   28.503417] PVR_K:   (MKT-1C9) 067B0B6D 00000808 0100171E AD00080A
[   28.510009] PVR_K:   (MKT-1CA) 067B0B86 00000808 0100171E 0F039400
[   28.516510] PVR_K:   (MKT-1CB) 067B0B9E 00000808 0100171E 00000062
[   28.523040] PVR_K:   (MKT-1CC) 067B0E55 00000808 0000171E AD000803
[   28.529571] PVR_K:   (MKT-1CD) 067B0E9B 00180C88 0000171E AD000282
[   28.536102] PVR_K:   (MKT-1CE) 067B1984 00000808 0100191F AD000200
[   28.542633] PVR_K:   (MKT-1CF) 067B1AA1 00000808 0100191F AD001703
[   28.549133] PVR_K:   (MKT-1D0) 067B1CA6 00000808 0000191F AD000202
[   28.555664] PVR_K:   (MKT-1D1) 067B1D33 00000808 00001A1E AD000183
[   28.562164] PVR_K:   (MKT-1D2) 067B1E9B 00000808 00001A1E AD000302
[   28.568695] PVR_K:   (MKT-1D3) 067B20D4 00000808 00001A1E AD000404
[   28.575195] PVR_K:   (MKT-1D4) 067B2197 00000808 00001A1E AD000402
[   28.581756] PVR_K:   (MKT-1D5) 067B21D1 001008AD 00001A1E AD000184
[   28.588256] PVR_K:   (MKT-1D6) 067B2266 00119DA9 00001B1D AD000281
[   28.594787] PVR_K:   (MKT-1D7) 067B2496 001199AB 00001B1D AD00080A
[   28.601318] PVR_K:   (MKT-1D8) 067B24B0 001089AB 00001B1D 0F039700
[   28.607849] PVR_K:   (MKT-1D9) 067B24CC 001199AD 00001B1D 00000061
[   28.614410] PVR_K:   (MKT-1DA) 067B267D 001198AF 00001B1D AD000802
[   28.620910] PVR_K:   (MKT-1DB) 067B2827 001089AD 00001B1D AD000803
[   28.627471] PVR_K:   (MKT-1DC) 067B2877 0019DEEF 00001B1D AD000282
[   28.633972] PVR_K:   (MKT-1DD) 067B4FB6 00180838 00001F1F AD000101
[   28.640563] PVR_K:   (MKT-1DE) 067B5034 00180838 00001F1F AD000104
[   28.647033] PVR_K:   (MKT-1DF) 067B5073 00180838 0100201E AD000100
[   28.653594] PVR_K:   (MKT-1E0) 067B517C 00100828 0100201E AD000501
[   28.660095] PVR_K:   (MKT-1E1) 067B51BC 00100829 0100201E AD000104
[   28.666656] PVR_K:   (MKT-1E2) 067B52B9 00100DAF 0100211A AD000200
[   28.673187] PVR_K:   (MKT-1E3) 067B55AA 001199A9 0000211A AD000202
[   28.679718] PVR_K:   (MKT-1E4) 067B5656 001199AB 0000221F AD000183
[   28.686218] PVR_K:   (MKT-1E5) 067B56D5 001199AD 0000221F AD000184
[   28.692749] PVR_K:   (MKT-1E6) 067B5747 00119DA9 01002318 AD000281
[   28.699554] PVR_K:   (MKT-1E7) 067B593A 001089AB 01002318 AD00080A
[   28.706115] PVR_K:   (MKT-1E8) 067B5955 0017FBAB 01002318 0F039A00
[   28.712738] PVR_K:   (MKT-1E9) 067B5972 0017FBAB 01002318 00000060
[   28.719268] PVR_K:   (MKT-1EA) 067B5CE4 001199AD 00002318 AD000803
[   28.725830] PVR_K:   (MKT-1EB) 067B5D3B 001889ED 00002318 AD000282
[   28.732299] PVR_K:   (MKT-1EC) 067B5E8D 001008AF 01002517 AD000200
[   28.738861] PVR_K:   (MKT-1ED) 067B612C 001199AF 00002517 AD000202
[   28.745391] PVR_K:   (MKT-1EE) 067B61E2 001089AB 0000261F AD000183
[   28.751922] PVR_K:   (MKT-1EF) 067B6265 001199AF 0000261F AD000184
[   28.758453] PVR_K:   (MKT-1F0) 067B62CD 00108DAB 00000000 AD000281
[   28.764984] PVR_K:   (MKT-1F1) 067B64B0 001199AF 00000000 AD00080A
[   28.771484] PVR_K:   (MKT-1F2) 067B64CB 001199AD 00000000 0F039D00
[   28.778045] PVR_K:   (MKT-1F3) 067B64E5 001089AB 00000000 00000060
[   28.784576] PVR_K:   (MKT-1F4) 067B6840 001009A9 0000271E AD000803
[   28.791076] PVR_K:   (MKT-1F5) 067B6894 001808ED 0000271E AD000282
[   28.797607] PVR_K:   (MKT-1F6) 067B6A03 001089AF 0100291F AD000200
[   28.804107] PVR_K:   (MKT-1F7) 067B6C7E 001089AF 0000291F AD000202
[   28.810607] PVR_K:   (MKT-1F8) 067B6D1A 001099A9 00002A1E AD000183
[   28.817169] PVR_K:   (MKT-1F9) 067B6D91 001089AB 00002A1E AD000184
[   28.823699] PVR_K:   (MKT-1FA) 067B6DFB 00108DAB 01002B1D AD000281
[   28.830200] PVR_K:   (MKT-1FB) 067B6FED 001009AF 01002B1D AD00080A
[   28.835723] adc_to_temp_conversion:Temp read is invalid 0
[   28.835723] thermal_lookup_temp: getting temp is not supported for domain pcb
[   28.836578] adc_to_temp_conversion:Temp read is invalid 0
[   28.836578] thermal_lookup_temp: getting temp is not supported for domain pcb
[   28.837402] adc_to_temp_conversion:Temp read is invalid 0
[   28.837432] thermal_lookup_temp: getting temp is not supported for domain pcb
[   28.876861] PVR_K:   (MKT-1FC) 067B700A 001199AB 01002B1D 0F03A000
[   28.883422] PVR_K:   (MKT-1FD) 067B7027 001199AF 01002B1D 00000062
[   28.889923] PVR_K:   (MKT-1FE) 067B7362 001008AB 00002B1D AD000803
[   28.896453] PVR_K:   (MKT-1FF) 067B73B5 00180CAF 00002B1D AD000282
[   28.902923] PVR_K: SGX Kernel CCB WO:0x21 RO:0x21
[   29.116088] PVR_K:(Error): SGXOSTimer() detected SGX lockup (0xe tasks) [0, ]
[   29.123687] PVR_K: HWRecoveryResetSGX: SGX Hardware Recovery triggered
[   29.147613] [   15.672]   [c6e89d00] new in dsscomp_gralloc_queue (refs=1)
[   29.147613] [   15.672]                           [c6e64400] dsscomp_new
[   29.147644] [   15.672]   [c6e89d00] ++refs=2 for [c6e64400]
[   29.147644] [   15.672]                           [c6e64400] dsscomp_delayed_apply
[   29.147644] [   15.672]   [c6e89d00] --refs=1 on RELEASED
[   29.209838] [   15.672]                           [c6e64400] dsscomp_apply
[   29.209838] [   15.711]   [c6e89d00] --refs=0 on ECLIPSED
[   29.209838] [   15.711]   [c6e89d00] calling   (null) [  (null)]
[   29.209838] [   15.711]                           [c6e64400] dsscomp_mgr_delayed_cb on ECLIPSED
[   29.264495] [   19.772]    [c6edb7a0] new in dsscomp_gralloc_queue (refs=1)
[   29.264495] [   19.772]                        [c738c400] dsscomp_new
[   29.264495] [   19.772]    [c6edb7a0] ++refs=2 for [c738c400]
[   29.264526] [   19.772]                        [c738c400] dsscomp_delayed_apply
[   29.326995] [   19.772]    [c6edb7a0] --refs=1 on RELEASED
[   29.326995] [   19.772]                        [c738c400] dsscomp_apply
[   29.326995] [   19.773]                        [c738c400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   29.327026] [   19.779]    [c6e89d40] new in dsscomp_gralloc_queue (refs=1)
[   29.389495] [   19.779]                           [c6e64400] dsscomp_new
[   29.389495] [   19.779]    [c6e89d40] ++refs=2 for [c6e64400]
[   29.389495] [   19.779]                           [c6e64400] dsscomp_delayed_apply
[   29.389495] [   19.779]    [c6e89d40] --refs=1 on RELEASED
[   29.389495] [   19.779]                           [c6e64400] dsscomp_apply
[   29.451995] [   19.801]                        [c738c400] dsscomp_mgr_delayed_cb on DISPLAYED
[   29.452026] [   19.801]    [c6edb7a0] --refs=0 on RELEASED
[   29.452026] [   19.801]    [c6edb7a0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   29.452026] [   19.801]                        [c738c400] dsscomp_mgr_delayed_cb on RELEASED
[   29.506683] [   19.801]   [c6edb760] new in dsscomp_gralloc_queue (refs=1)
[   29.506683] [   19.801]                        [c6f10400] dsscomp_new
[   29.506683] [   19.801]   [c6edb760] ++refs=2 for [c6f10400]
[   29.506683] [   19.801]                        [c6f10400] dsscomp_delayed_apply
[   29.569183] [   19.801]   [c6edb760] --refs=1 on RELEASED
[   29.569213] [   19.801]                           [c6e64400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   29.569213] [   19.801]                        [c6f10400] dsscomp_apply
[   29.569213] [   19.816]                           [c6e64400] dsscomp_mgr_delayed_cb on DISPLAYED
[   29.623901] [   19.816]    [c6e89d40] --refs=0 on RELEASED
[   29.623901] [   19.816]    [c6e89d40] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   29.623901] [   19.816]                           [c6e64400] dsscomp_mgr_delayed_cb on RELEASED
[   29.686370] [   19.816]                        [c6f10400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   29.686401] [   19.832]                        [c6f10400] dsscomp_mgr_delayed_cb on DISPLAYED
[   29.686401] [   24.345]   [c6edb920] new in dsscomp_gralloc_queue (refs=1)
[   29.686401] [   24.345]                         [c6f11400] dsscomp_new
[   29.741058] [   24.345]   [c6edb920] ++refs=2 for [c6f11400]
[   29.741058] [   24.345]                         [c6f11400] dsscomp_delayed_apply
[   29.741058] [   24.345]   [c6edb920] --refs=1 on RELEASED
[   29.741058] [   24.345]                         [c6f11400] dsscomp_apply
[   29.803558] [   24.345]   [c6edb760] --refs=0 on RELEASED
[   29.803558] [   24.345]   [c6edb760] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   29.803558] [   24.345]                        [c6f10400] dsscomp_mgr_delayed_cb on RELEASED
[   29.803558] [   24.345]                         [c6f11400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   29.866058] [   24.369]                         [c6f11400] dsscomp_mgr_delayed_cb on DISPLAYED
[   29.866058] [   28.901]    [c6e89d40] new in dsscomp_gralloc_queue (refs=1)
[   29.866088] [   28.901]                           [c6e64400] dsscomp_new
[   29.866088] [   28.901]    [c6e89d40] ++refs=2 for [c6e64400]
[   29.920745] [   28.901]                           [c6e64400] dsscomp_delayed_apply
[   29.920745] [   28.901]    [c6e89d40] --refs=1 on RELEASED
[   29.920745] [   28.901]                           [c6e64400] dsscomp_apply
[   29.920745] [   28.901]   [c6edb920] --refs=0 on RELEASED
[   29.983245] [   28.901]   [c6edb920] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   29.983245] [   28.901]                         [c6f11400] dsscomp_mgr_delayed_cb on RELEASED
[   29.983245] [   28.901]                           [c6e64400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   29.983245] [   28.902] [c6e89d60] new in dsscomp_gralloc_queue (refs=1)
[   30.037933] [   28.902]                      [c6e64800] dsscomp_new
[   30.037933] [   28.902] [c6e89d60] ++refs=2 for [c6e64800]
[   30.037933] [   28.902]                      [c6e64800] dsscomp_delayed_apply
[   30.037933] [   28.902] [c6e89d60] --refs=1 on RELEASED
[   30.079559] [   28.902]                      [c6e64800] dsscomp_apply
[   30.079589] [   28.925]                           [c6e64400] dsscomp_mgr_delayed_cb on DISPLAYED
[   30.079589] [   28.925]    [c6e89d40] --refs=0 on RELEASED
[   30.079589] [   28.925]    [c6e89d40] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   30.110992] [   28.925]                           [c6e64400] dsscomp_mgr_delayed_cb on RELEASED
[   30.111022] [   28.925]                      [c6e64800] dsscomp_mgr_delayed_cb on PROGRAMMED
[   30.111022] [   28.942]                      [c6e64800] dsscomp_mgr_delayed_cb on DISPLAYED
[   30.139251] ACTIVE COMPOSITIONS on lcd
[   30.139251]
[   30.139251]   [c6e64800]: DISPLAYED
[   30.139251]     sync_id=0, flags=AD-
[   30.139251]     ovl0={ON z0 ARGB32-8888 premult *100% 864*480:0,0+864,480 rot0 => 0,0+864,480 7f358000/  (null)|3456}
[   30.139251]     gsync=[c6e89d60] dsscomp_gralloc_cb
[   30.139251]
[   30.139251]   DISPC pipeline:
[   30.139251]
[   30.139251]     info:        clean (none)
[   30.178192]     cache:       clean (none)
[   30.178222]     shadow:  ACT clean (none)
[   30.178222]     dispc:   DISPLAYED mask=---R [c6e64800] dsscomp_mgr_callback
[   30.178222]
[   30.178222] ACTIVE COMPOSITIONS on tv
[   30.178222]
[   30.178222]   DISPC pipeline:
[   30.178222]
[   30.178222]     info:        clean (none)
[   30.178222]     cache:       clean (none)
[   30.217193]     shadow:  off clean (none)
[   30.217193]     dispc:   DISPLAYED (none)
[   30.217193]
[   30.217193] ACTIVE COMPOSITIONS on lcd2
[   30.217224]
[   30.217224]   DISPC pipeline:
[   30.217224]
[   30.217224]     info:        clean (none)
[   30.217224]     cache:       clean (none)
[   30.217224]     shadow:  off clean (none)
[   30.217224]     dispc:             (none)
[   30.217224]
[   30.217224] ACTIVE GRALLOC FLIPS
[   30.217224]
[   30.217224]   [c6e89d60] (refs=1)
[   30.263763]     slots=[7f358000]
[   30.263763]     cmdcb=[c73f6900] dsscomp_proxy_cmdcomplete
[   30.263763]
[   30.263793]   |           lcd
[   30.263793]   | [c6e64800] DISPL'D
[   30.263793]   |     28.902  ACTIVE
[   30.263793]   |     28.902 APPLY'N
[   30.263793]   |     28.902 APPLIED
[   30.263793]   |     28.925 PROGR'D
[   30.263793]   |     28.942 DISPL'D
[   30.302825]
[   30.302825]
[   30.306091] PVR_K: SGX debug (blaze_android_sgx_ogles1_ogles2_GPL sgxddk 18 1.8@869593)
[   30.314636] PVR_K:(Error): SGX Register Base Address (Linear):   0xC8B20000 [0, ]
[   30.322631] PVR_K:(Error): SGX Register Base Address (Physical): 0x56000000 [0, ]
[   30.330627] PVR_K: (P0) EUR_CR_CORE_ID:          01140000
[   30.336395] PVR_K: (P0) EUR_CR_CORE_REVISION:    00010200
[   30.342193] PVR_K: (P0) EUR_CR_EVENT_STATUS:     20000000
[   30.347961] PVR_K: (P0) EUR_CR_EVENT_STATUS2:    00000008
[   30.353759] PVR_K: (P0) EUR_CR_BIF_CTRL:         00000000
[   30.359527] PVR_K: (P0) EUR_CR_BIF_INT_STAT:     00008000
[   30.365295] PVR_K: (P0) EUR_CR_BIF_FAULT:        00000000
[   30.371063] PVR_K: (P0) EUR_CR_BIF_MEM_REQ_STAT: 00000000
[   30.376892] PVR_K: (P0) EUR_CR_CLKGATECTL:       000AAA6A
[   30.382629] PVR_K: (P0) EUR_CR_PDS_PC_BASE:      00000E50
[   30.388427] PVR_K: Flip Command Complete Data 0 for display device 1:
[   30.395294] PVR_K:   SRC 0: (Not in use)
[   30.399475] PVR_K: Flip Command Complete Data 1 for display device 1:
[   30.406341] PVR_K:   SRC 0: ROC DevVAddr:0xD800474 ROP:0x4 ROC:0x2, WOC DevVAddr:0xD800464 WOP:0x4 WOC:0x3
[   30.416564] PVR_K: SGX Host control:
[   30.420379] PVR_K:   (HC-0) 0x00000001 0x00000000 0x00000000 0x00000001
[   30.427398] PVR_K:   (HC-10) 0x00000004 0x0000000A 0x0005DC00 0x00000003
[   30.434478] PVR_K:   (HC-20) 0x00000000 0x00000001 0x00000000 0x00000004
[   30.441528] PVR_K:   (HC-30) 0x0000002E 0xEFD7F0D8 0x00000000 0x00000000
[   30.448638] PVR_K:   (HC-40) 0x00000000 0x087BF500 0x087C6300 0x087C3100
[   30.455688] PVR_K: SGX TA/3D control:
[   30.459655] PVR_K:   (T3C-0) 0x0F003000 0x0F003120 0x0F002000 0x00000000
[   30.466705] PVR_K:   (T3C-10) 0x00000001 0x00000002 0x00000001 0x0F00DD00
[   30.473907] PVR_K:   (T3C-20) 0x00000000 0x00000000 0x00000000 0x00000000
[   30.481048] PVR_K:   (T3C-30) 0x00000000 0x00000000 0x00000000 0x00000000
[   30.488250] PVR_K:   (T3C-40) 0x00000000 0x00000000 0x00000000 0x00000000
[   30.495422] PVR_K:   (T3C-50) 0x0F00DD00 0x00000000 0x00000000 0x0F00DD00
[   30.502563] PVR_K:   (T3C-60) 0x00000000 0x00000000 0x0F00DD00 0x00000000
[   30.509765] PVR_K:   (T3C-70) 0x00000000 0x0F00DD00 0x00000000 0x0F004000
[   30.516906] PVR_K:   (T3C-80) 0x0000004A 0x0001120F 0x00000000 0x0F00DEB8
[   30.524108] PVR_K:   (T3C-90) 0x00000000 0x0F000000 0xAB600000 0x0F03B800
[   30.531280] PVR_K:   (T3C-A0) 0x00000000 0x0F0109A0 0x0F00DD00 0x0F00DEB8
[   30.538421] PVR_K:   (T3C-B0) 0x0F010BE0 0x00000000 0x00000000 0x00000000
[   30.545623] PVR_K:   (T3C-C0) 0x00000000 0x00000000 0x00000000 0x00000000
[   30.554748] PVR_K:   (T3C-D0) 0x00000000 0x00000006 0x00000005 0x0F007000
[   30.561950] PVR_K:   (T3C-E0) 0x0F00D420 0x0F00E000 0x0F010720 0x0F010720
[   30.569122] PVR_K:   (T3C-F0) 0x00000000 0x000000B5 0x000000B5 0x00000000
[   30.576263] PVR_K:   (T3C-100) 0x00000003 0x00000000 0x00000000 0x00000000
[   30.583557] PVR_K:   (T3C-110) 0xB50C565C 0x0872E100 0x08787B00 0x08787B00
[   30.590789] PVR_K: Last SGX microkernel status code: AD000104
[   30.596954] PVR_K:   (MKT-0) 05A0F184 00000808 0000171E AD001301
[   30.605224] PVR_K:   (MKT-1) 05A0F2BB 00000808 0000171E AD000802
[   30.611572] PVR_K:   (MKT-2) 05A0F427 00000808 0000171E AD000803
[   30.617889] PVR_K:   (MKT-3) 05A0F477 00184AC8 0000171E AD000282
[   30.624267] PVR_K:   (MKT-4) 05A0F57C 00180838 0000181F AD00000A
[   30.630554] PVR_K:   (MKT-5) 05A0F5F3 00180838 0000181F AD000905
[   30.636932] PVR_K:   (MKT-6) 05A0F715 001808B8 0000181F AD000901
[   30.643249] PVR_K:   (MKT-7) 05A0F792 00180838 00001A1C AD00000A
[   30.649566] PVR_K:   (MKT-8) 05A0F7D4 00180838 00001A1C AD001100
[   30.656951] PVR_K:   (MKT-9) 05A0F839 00180838 00001A1C AD000904
[   30.663269] PVR_K:   (MKT-A) 05A0F926 00180838 00001A1C AD000901
[   30.669616] PVR_K:   (MKT-B) 05A0FA33 00180838 00001C1A AD00000A
[   30.675933] PVR_K:   (MKT-C) 05A0FA8E 00180838 00001C1A AD000905
[   30.682678] PVR_K:   (MKT-D) 05A0FB79 00180838 00001C1A AD000901
[   30.689025] PVR_K:   (MKT-E) 05A0FBF3 00180838 00001D19 AD00000A
[   30.695373] PVR_K:   (MKT-F) 05A0FC5F 00180838 00001D19 AD000905
[   30.701690] PVR_K:   (MKT-10) 05A0FD07 00180838 00001D19 AD000901
[   30.708129] PVR_K:   (MKT-11) 05A0FD7F 00180C38 00001F1E AD000281
[   30.714538] PVR_K:   (MKT-12) 05A0FDE3 00180838 00001F1E AD000282
[   30.721008] PVR_K:   (MKT-13) 05A0FE92 00180838 0100201F AD000183
[   30.727416] PVR_K:   (MKT-14) 05A101E9 001808BF 0000201F AD002401
[   30.733886] PVR_K:   (MKT-15) 05A1022F 001EEEBF 0000201F AD000184
[   30.740295] PVR_K:   (MKT-16) 05A109DA 00180838 0100221F AD000101
[   30.746734] PVR_K:   (MKT-17) 05A10ABB 00180838 0100221F AD001601
[   30.753143] PVR_K:   (MKT-18) 05A10AE1 00180838 0100221F 0D8004E4
[   30.759582] PVR_K:   (MKT-19) 05A10AFA 00180838 0100221F 00000001
[   30.766052] PVR_K:   (MKT-1A) 05A10C44 00180838 0000221F AD000104
[   30.772460] PVR_K:   (MKT-1B) 05A10CA1 00180C38 0100231E AD000281
[   30.778900] PVR_K:   (MKT-1C) 05A10CFA 00180838 0100231E AD000282
[   30.785308] PVR_K:   (MKT-1D) 05A1195D 00000808 0100241F AD000200
[   30.791778] PVR_K:   (MKT-1E) 05A11BDD 00000808 0000241F AD000202
[   30.798187] PVR_K:   (MKT-1F) 05A11C2C 00000808 0100251E AD000281
[   30.804656] PVR_K:   (MKT-20) 05A11D73 00000808 0100251E AD00080A
[   30.811035] PVR_K:   (MKT-21) 05A11D8C 00000808 0100251E 0F037600
[   30.817504] PVR_K:   (MKT-22) 05A11DA4 00000808 0100251E 00000060
[   30.823913] PVR_K:   (MKT-23) 05A12054 00000808 0000251E AD000803
[   30.830352] PVR_K:   (MKT-24) 05A1209B 001808C8 0000251E AD000282
[   30.836761] PVR_K:   (MKT-25) 05A1218F 00000808 0100271F AD000200
[   30.843200] PVR_K:   (MKT-26) 05A123B5 00000808 0100271F AD000202
[   30.849609] PVR_K:   (MKT-27) 05A1240B 00000808 0100281E AD000281
[   30.856048] PVR_K:   (MKT-28) 05A1255C 00000808 0100281E AD00080A
[   30.862457] PVR_K:   (MKT-29) 05A12574 00000808 0100281E 0F037900
[   30.868927] PVR_K:   (MKT-2A) 05A1258D 00000808 0100281E 00000060
[   30.875366] PVR_K:   (MKT-2B) 05A1283A 00000808 0000281E AD000803
[   30.881774] PVR_K:   (MKT-2C) 05A12880 00180CC8 0000281E AD000282
[   30.888214] PVR_K:   (MKT-2D) 05A12968 00000808 01002A1F AD000200
[   30.894622] PVR_K:   (MKT-2E) 05A12B8F 00000808 01002A1F AD000202
[   30.901092] PVR_K:   (MKT-2F) 05A12BDD 00000808 01002B1E AD000281
[   30.907501] PVR_K:   (MKT-30) 05A12D29 00000808 01002B1E AD00080A
[   30.913940] PVR_K:   (MKT-31) 05A12D41 00000808 01002B1E 0F037C00
[   30.920349] PVR_K:   (MKT-32) 05A12D5A 00000808 01002B1E 00000062
[   30.926818] PVR_K:   (MKT-33) 05A13006 00000808 00002B1E AD000803
[   30.933197] PVR_K:   (MKT-34) 05A1304C 00180C88 00002B1E AD000282
[   30.939666] PVR_K:   (MKT-35) 05A13B50 00000808 01002D1F AD000200
[   30.946075] PVR_K:   (MKT-36) 05A13C6D 00000808 01002D1F AD001703
[   30.952514] PVR_K:   (MKT-37) 05A13E5C 00000808 00002D1F AD000202
[   30.958923] PVR_K:   (MKT-38) 05A13EDA 00000808 01002E1E AD000183
[   30.965393] PVR_K:   (MKT-39) 05A1402D 00000808 00002E1E AD000302
[   30.971832] PVR_K:   (MKT-3A) 05A14266 00000808 00002E1E AD000404
[   30.978271] PVR_K:   (MKT-3B) 05A14328 00000808 00002E1E AD000402
[   30.984710] PVR_K:   (MKT-3C) 05A14363 001008AD 00002E1E AD000184
[   30.991119] PVR_K:   (MKT-3D) 05A16BA9 00000808 0000311F AD000101
[   30.997558] PVR_K:   (MKT-3E) 05A16C22 00000808 0000311F AD000104
[   31.003997] PVR_K:   (MKT-3F) 05A16C5E 00000808 0100321E AD000100
[   31.010437] PVR_K:   (MKT-40) 05A16D64 00000808 0100321E AD000501
[   31.016845] PVR_K:   (MKT-41) 05A16DA3 0010082B 0100321E AD000104
[   31.023345] PVR_K:   (MKT-42) 05A19004 00100828 0100331F AD000101
[   31.029724] PVR_K:   (MKT-43) 05A19059 00100828 0100331F AD000104
[   31.036193] PVR_K:   (MKT-44) 05A19165 00000808 0100341F AD000100
[   31.042602] PVR_K:   (MKT-45) 05A19239 00000808 0100341F AD000501
[   31.049072] PVR_K:   (MKT-46) 05A1926F 00100829 0100341F AD000104
[   31.055480] PVR_K:   (MKT-47) 05E36A93 00100808 0100031F AD000B00
[   31.061920] PVR_K:   (MKT-48) 05E36AD9 00100808 0100031F AD000B03
[   31.068328] PVR_K:   (MKT-49) 05E36B18 00100808 0100031F AD000B05
[   31.074768] PVR_K:   (MKT-4A) 05E36B7B 00100808 0100031F AD000B06
[   31.081207] PVR_K:   (MKT-4B) 05E36BC0 00100808 0100031F AD000B07
[   31.087646] PVR_K:   (MKT-4C) 05E36BE5 00100808 0100031F AD000B09
[   31.094085] PVR_K:   (MKT-4D) 05E36C3B 00100808 0100031F AD000B01
[   31.100494] PVR_K:   (MKT-4E) 05E36C77 00100808 0100031F AD002300
[   31.106933] PVR_K:   (MKT-4F) 05E36FEE 00100808 0100041F AD00000A
[   31.113342] PVR_K:   (MKT-50) 05E3706C 00100808 0100041F AD000906
[   31.119781] PVR_K:   (MKT-51) 05E3712B 00100808 0000041F AD000901
[   31.126190] PVR_K:   (MKT-52) 05E371A5 00100808 0100051E AD000183
[   31.132659] PVR_K:   (MKT-53) 05E3730B 00100808 0100051E AD000302
[   31.139068] PVR_K:   (MKT-54) 05E3735E 00100808 0100051E AD000303
[   31.145507] PVR_K:   (MKT-55) 05E373D6 00100808 0100051E AD000C01
[   31.151916] PVR_K:   (MKT-56) 05E373F9 00100808 0100051E 0D800484
[   31.158386] PVR_K:   (MKT-57) 05E37412 00100808 0100051E 00000001
[   31.164794] PVR_K:   (MKT-58) 05E37622 00100808 0100051E AD000184
[   31.171234] PVR_K:   (MKT-59) 05E48621 00100808 0100081F AD001A00
[   31.177673] PVR_K:   (MKT-5A) 05E48964 00100808 0100091F AD00000A
[   31.184082] PVR_K:   (MKT-5B) 05E489C5 00100808 0100091F AD000909
[   31.190551] PVR_K:   (MKT-5C) 05E48A0F 00100808 0100091F AD001A05
[   31.196960] PVR_K:   (MKT-5D) 05E48AC7 00100808 0100091F AD001A06
[   31.203399] PVR_K:   (MKT-5E) 00000543 00100808 0100031F AD002300
[   31.209808] PVR_K:   (MKT-5F) 00001CAD 00100808 0100041F AD00000A
[   31.216278] PVR_K:   (MKT-60) 00001D1F 00100808 0100041F AD000905
[   31.222656] PVR_K:   (MKT-61) 00001E69 00100888 0100041F AD000901
[   31.229125] PVR_K:   (MKT-62) 00001EC8 00100C08 0100051E AD000281
[   31.235534] PVR_K:   (MKT-63) 00002056 00100808 0100051E AD00080A
[   31.242004] PVR_K:   (MKT-64) 0000206E 00100888 0100051E 0F037F00
[   31.248413] PVR_K:   (MKT-65) 00002087 00100808 0000051E 00000061
[   31.254852] PVR_K:   (MKT-66) 000021AE 00100C88 0000051E AD001300
[   31.261260] PVR_K:   (MKT-67) 000073AE 00100808 0000051E AD001301
[   31.267730] PVR_K:   (MKT-68) 000074D8 00100808 0000051E AD000802
[   31.274108] PVR_K:   (MKT-69) 00007637 00100808 0000051E AD000803
[   31.280578] PVR_K:   (MKT-6A) 00007684 00184AC8 0000051E AD000282
[   31.287017] PVR_K:   (MKT-6B) 00007768 00180CB8 0000061F AD00000A
[   31.293426] PVR_K:   (MKT-6C) 000077DB 00180838 0000061F AD000905
[   31.299865] PVR_K:   (MKT-6D) 000078EC 001808B8 0000061F AD000901
[   31.306274] PVR_K:   (MKT-6E) 0000796A 00180838 0000081C AD00000A
[   31.312744] PVR_K:   (MKT-6F) 000079CA 00180838 0000081C AD000905
[   31.319152] PVR_K:   (MKT-70) 00007A70 00180838 0000081C AD000901
[   31.325592] PVR_K:   (MKT-71) 00007AC2 00180838 0000091B AD00000A
[   31.332000] PVR_K:   (MKT-72) 00007B25 00180838 0000091B AD000905
[   31.338439] PVR_K:   (MKT-73) 00007BCE 00180838 0000091B AD000901
[   31.344848] PVR_K:   (MKT-74) 00007CF0 00180C38 01000C1E AD000281
[   31.351318] PVR_K:   (MKT-75) 00007D49 00180838 01000C1E AD000282
[   31.357696] PVR_K:   (MKT-76) 00009659 00000808 01000D1F AD000200
[   31.364166] PVR_K:   (MKT-77) 000098AC 00000808 00000D1F AD000202
[   31.370697] PVR_K:   (MKT-78) 000098F9 00000808 01000E1E AD000281
[   31.379669] PVR_K:   (MKT-79) 00009A40 00000808 01000E1E AD00080A
[   31.386932] PVR_K:   (MKT-7A) 00009A59 00000808 01000E1E 0F038200
[   31.393341] PVR_K:   (MKT-7B) 00009A71 00000808 01000E1E 00000060
[   31.399810] PVR_K:   (MKT-7C) 00009D1C 00000808 00000E1E AD000803
[   31.406219] PVR_K:   (MKT-7D) 00009D69 00180CC8 00000E1E AD000282
[   31.413024] PVR_K:   (MKT-7E) 00009E0B 00000808 0100101F AD000200
[   31.419525] PVR_K:   (MKT-7F) 0000A02C 00000808 0000101F AD000202
[   31.429046] PVR_K:   (MKT-80) 0000A078 00000808 0100111E AD000281
[   31.436309] PVR_K:   (MKT-81) 0000A1BE 00000808 0100111E AD00080A
[   31.443328] PVR_K:   (MKT-82) 0000A1D7 00000808 0100111E 0F038500
[   31.456176] PVR_K:   (MKT-83) 0000A1EF 00000808 0100111E 00000060
[   31.469177] PVR_K:   (MKT-84) 0000A4AD 00000808 0000111E AD000803
[   31.482574] PVR_K:   (MKT-85) 0000A4F2 00180CC8 0000111E AD000282
[   31.498901] PVR_K:   (MKT-86) 0000A5DA 00000808 0100131F AD000200
[   31.505310] PVR_K:   (MKT-87) 0000A7FC 00000808 0000131F AD000202
[   31.517028] PVR_K:   (MKT-88) 0000A84E 00000808 0100141E AD000281
[   31.523468] PVR_K:   (MKT-89) 0000A998 00000808 0100141E AD00080A
[   31.529968] PVR_K:   (MKT-8A) 0000A9B1 00000808 0100141E 0F038800
[   31.536468] PVR_K:   (MKT-8B) 0000A9C9 00000808 0100141E 00000062
[   31.542907] PVR_K:   (MKT-8C) 0000AC76 00000808 0000141E AD000803
[   31.549346] PVR_K:   (MKT-8D) 0000ACBC 00180C88 0000141E AD000282
[   31.555755] PVR_K:   (MKT-8E) 0000B7E3 00000808 0100161F AD000200
[   31.562225] PVR_K:   (MKT-8F) 0000B909 00000808 0100161F AD001703
[   31.568634] PVR_K:   (MKT-90) 0000BAFE 00000808 0000161F AD000202
[   31.575073] PVR_K:   (MKT-91) 0000BB8F 00000808 0100171E AD000183
[   31.581481] PVR_K:   (MKT-92) 0000BC8E 00000808 0100171E AD00030E
[   31.587982] PVR_K:   (MKT-93) 0000BCA6 00000808 0100171E 0D800474
[   31.594360] PVR_K:   (MKT-94) 0000BCBF 00000808 0100171E 00000000
[   31.600799] PVR_K:   (MKT-95) 0000BCE3 00000808 0100171E 00000001
[   31.607177] PVR_K:   (MKT-96) 0000BD71 00000808 0100171E AD000184
[   31.613616] PVR_K:   (MKT-97) 00017C4E 00000808 01001A1F AD001A00
[   31.619995] PVR_K:   (MKT-98) 000290AF 00000808 01001D1F AD00000A
[   31.626464] PVR_K:   (MKT-99) 00029110 00000808 01001D1F AD000909
[   31.632934] PVR_K:   (MKT-9A) 0002915C 00000808 01001D1F AD001A05
[   31.639312] PVR_K:   (MKT-9B) 0002918D 00000808 01001D1F AD001302
[   31.645782] PVR_K:   (MKT-9C) 000291CF 00000808 01001D1F AD001303
[   31.652191] PVR_K:   (MKT-9D) 00029261 00000808 01001D1F AD000D04
[   31.658660] PVR_K:   (MKT-9E) 00029339 00000808 01001D1F AD000D05
[   31.665069] PVR_K:   (MKT-9F) 000293AD 00000808 01001D1F AD001A06
[   31.671539] PVR_K:   (MKT-A0) 00000450 00100808 0100031F AD002300
[   31.677947] PVR_K:   (MKT-A1) 0000092A 00100808 0100041F AD00000A
[   31.684387] PVR_K:   (MKT-A2) 000009A6 00100808 0100041F AD000906
[   31.690826] PVR_K:   (MKT-A3) 00000A7E 00100808 0000041F AD000901
[   31.697265] PVR_K:   (MKT-A4) 00000AF8 00100808 0100051E AD000183
[   31.703674] PVR_K:   (MKT-A5) 00000C71 00100808 0100051E AD000302
[   31.710144] PVR_K:   (MKT-A6) 00000DF7 00100808 0100051E AD000D06
[   31.716522] PVR_K:   (MKT-A7) 00000EDB 00100808 0100051E AD000D07
[   31.722991] PVR_K:   (MKT-A8) 00000F25 00100808 0100051E AD001304
[   31.729400] PVR_K:   (MKT-A9) 00001010 00100808 0100051E AD001305
[   31.735900] PVR_K:   (MKT-AA) 00001120 00100888 0100051E AD000404
[   31.742340] PVR_K:   (MKT-AB) 000011E1 00100808 0000051E AD000402
[   31.748748] PVR_K:   (MKT-AC) 0000122A 0010082B 0000051E AD000184
[   31.755218] PVR_K:   (MKT-AD) 067A6C36 00100808 0100031F AD000B00
[   31.761627] PVR_K:   (MKT-AE) 067A6C6E 00100808 0100031F AD000B02
[   31.768066] PVR_K:   (MKT-AF) 067A6CEF 00100808 0100031F AD000B02
[   31.774475] PVR_K:   (MKT-B0) 067A6D2E 00100808 0100031F AD000B02
[   31.780914] PVR_K:   (MKT-B1) 067A6D6C 00100808 0100031F AD000B02
[   31.787322] PVR_K:   (MKT-B2) 067A6DAA 00100808 0100031F AD000B02
[   31.793762] PVR_K:   (MKT-B3) 067A6DEC 00100808 0100031F AD000B02
[   31.800201] PVR_K:   (MKT-B4) 067A6E2C 00100808 0100031F AD000B02
[   31.806640] PVR_K:   (MKT-B5) 067A6E6D 00100808 0100031F AD000B02
[   31.813049] PVR_K:   (MKT-B6) 067A6EAF 00100808 0100031F AD000B03
[   31.819519] PVR_K:   (MKT-B7) 067A6F30 00100808 0100031F AD000B05
[   31.825927] PVR_K:   (MKT-B8) 067A6F87 00100808 0100031F AD000B06
[   31.832366] PVR_K:   (MKT-B9) 067A6FCF 00100808 0100031F AD000B07
[   31.838836] PVR_K:   (MKT-BA) 067A6FF4 00100808 0100031F AD000B09
[   31.845245] PVR_K:   (MKT-BB) 067A7048 00100808 0100031F AD000B01
[   31.851715] PVR_K:   (MKT-BC) 067A7084 00100808 0100031F AD002300
[   31.858123] PVR_K:   (MKT-BD) 067A765B 00100808 0100041F AD00000A
[   31.864562] PVR_K:   (MKT-BE) 067A76D3 00100808 0100041F AD000906
[   31.871002] PVR_K:   (MKT-BF) 067A778E 00100808 0000041F AD000901
[   31.877441] PVR_K:   (MKT-C0) 067A780E 00100808 0000051E AD000183
[   31.883850] PVR_K:   (MKT-C1) 067A7976 00100808 0000051E AD000302
[   31.890319] PVR_K:   (MKT-C2) 067A79C9 00100808 0000051E AD000303
[   31.896728] PVR_K:   (MKT-C3) 067A7A40 00100808 0000051E AD000C01
[   31.903167] PVR_K:   (MKT-C4) 067A7A64 00100808 0000051E 0D800464
[   31.909576] PVR_K:   (MKT-C5) 067A7A7D 00100808 0000051E 00000002
[   31.916046] PVR_K:   (MKT-C6) 067A7C8E 00100808 0000051E AD000184
[   31.922454] PVR_K:   (MKT-C7) 067A7D0D 00100C08 0100061D AD000281
[   31.928924] PVR_K:   (MKT-C8) 067A7E91 00100808 0100061D AD00080A
[   31.935302] PVR_K:   (MKT-C9) 067A7EAD 00100808 0100061D 0F038B00
[   31.941802] PVR_K:   (MKT-CA) 067A7EC6 00100808 0100061D 00000061
[   31.949890] PVR_K:   (MKT-CB) 067A7FE4 00100C88 0100061D AD001300
[   31.956329] PVR_K:   (MKT-CC) 067AD43A 00100808 0000061D AD001301
[   31.962768] PVR_K:   (MKT-CD) 067AD571 00100888 0000061D AD000802
[   31.969177] PVR_K:   (MKT-CE) 067AD6DB 00100888 0000061D AD000803
[   31.975646] PVR_K:   (MKT-CF) 067AD72D 001808C8 0000061D AD000282
[   31.982025] PVR_K:   (MKT-D0) 067AD811 00184AF8 0000081E AD00000A
[   31.988525] PVR_K:   (MKT-D1) 067AD889 001808F8 0000081E AD000905
[   31.994934] PVR_K:   (MKT-D2) 067AD9B5 001808B8 0000081E AD000901
[   32.001373] PVR_K:   (MKT-D3) 067ADA27 00180838 0000091C AD00000A
[   32.007781] PVR_K:   (MKT-D4) 067ADA90 00180838 0000091C AD000905
[   32.016265] PVR_K:   (MKT-D5) 067ADB3B 00180838 0000091C AD000901
[   32.022674] PVR_K:   (MKT-D6) 067ADB96 00180838 00000A1B AD00000A
[   32.029113] PVR_K:   (MKT-D7) 067ADC09 00180838 00000A1B AD000906
[   32.035522] PVR_K:   (MKT-D8) 067ADC94 00180838 00000A1B AD000901
[   32.041961] PVR_K:   (MKT-D9) 067ADCF7 00180838 00000B1A AD00000A
[   32.048400] PVR_K:   (MKT-DA) 067ADD66 00180838 00000B1A AD000905
[   32.054809] PVR_K:   (MKT-DB) 067ADE11 00180838 00000B1A AD000901
[   32.061248] PVR_K:   (MKT-DC) 067ADE6B 00180838 00000C19 AD00000A
[   32.067657] PVR_K:   (MKT-DD) 067ADECC 00180838 00000C19 AD000905
[   32.074127] PVR_K:   (MKT-DE) 067ADF88 00180838 00000C19 AD000901
[   32.080535] PVR_K:   (MKT-DF) 067AE0B8 00180C38 01000F1F AD000281
[   32.086975] PVR_K:   (MKT-E0) 067AE113 00180838 01000F1F AD000282
[   32.093383] PVR_K:   (MKT-E1) 067AF7F8 00000808 0100101F AD000200
[   32.099822] PVR_K:   (MKT-E2) 067AFA4E 00000808 0000101F AD000202
[   32.106201] PVR_K:   (MKT-E3) 067AFA9E 00000808 0100111E AD000281
[   32.112670] PVR_K:   (MKT-E4) 067AFBF0 00000808 0100111E AD00080A
[   32.119079] PVR_K:   (MKT-E5) 067AFC09 00000808 0100111E 0F038E00
[   32.125518] PVR_K:   (MKT-E6) 067AFC21 00000808 0100111E 00000060
[   32.131927] PVR_K:   (MKT-E7) 067AFEE6 00000808 0000111E AD000803
[   32.138366] PVR_K:   (MKT-E8) 067AFF2F 00180CC8 0000111E AD000282
[   32.144775] PVR_K:   (MKT-E9) 067AFFCD 00000808 0100131F AD000200
[   32.151275] PVR_K:   (MKT-EA) 067B01F4 00000808 0000131F AD000202
[   32.157714] PVR_K:   (MKT-EB) 067B0242 00000808 0100141E AD000281
[   32.164123] PVR_K:   (MKT-EC) 067B0390 00000808 0100141E AD00080A
[   32.170562] PVR_K:   (MKT-ED) 067B03AB 00000808 0100141E 0F039100
[   32.176971] PVR_K:   (MKT-EE) 067B03C3 00000808 0100141E 00000060
[   32.183441] PVR_K:   (MKT-EF) 067B0676 00000808 0000141E AD000803
[   32.189819] PVR_K:   (MKT-F0) 067B06BC 00180CC8 0000141E AD000282
[   32.196289] PVR_K:   (MKT-F1) 067B07A1 00000808 0100161F AD000200
[   32.202697] PVR_K:   (MKT-F2) 067B09CF 00000808 0000161F AD000202
[   32.209136] PVR_K:   (MKT-F3) 067B0A21 00000808 0100171E AD000281
[   32.215545] PVR_K:   (MKT-F4) 067B0B6D 00000808 0100171E AD00080A
[   32.221984] PVR_K:   (MKT-F5) 067B0B86 00000808 0100171E 0F039400
[   32.228393] PVR_K:   (MKT-F6) 067B0B9E 00000808 0100171E 00000062
[   32.234832] PVR_K:   (MKT-F7) 067B0E55 00000808 0000171E AD000803
[   32.241271] PVR_K:   (MKT-F8) 067B0E9B 00180C88 0000171E AD000282
[   32.247711] PVR_K:   (MKT-F9) 067B1984 00000808 0100191F AD000200
[   32.254180] PVR_K:   (MKT-FA) 067B1AA1 00000808 0100191F AD001703
[   32.260559] PVR_K:   (MKT-FB) 067B1CA6 00000808 0000191F AD000202
[   32.267028] PVR_K:   (MKT-FC) 067B1D33 00000808 00001A1E AD000183
[   32.273437] PVR_K:   (MKT-FD) 067B1E9B 00000808 00001A1E AD000302
[   32.279876] PVR_K:   (MKT-FE) 067B20D4 00000808 00001A1E AD000404
[   32.286285] PVR_K:   (MKT-FF) 067B2197 00000808 00001A1E AD000402
[   32.292724] PVR_K:   (MKT-100) 067B21D1 001008AD 00001A1E AD000184
[   32.299224] PVR_K:   (MKT-101) 067B2266 00119DA9 00001B1D AD000281
[   32.305755] PVR_K:   (MKT-102) 067B2496 001199AB 00001B1D AD00080A
[   32.312286] PVR_K:   (MKT-103) 067B24B0 001089AB 00001B1D 0F039700
[   32.318786] PVR_K:   (MKT-104) 067B24CC 001199AD 00001B1D 00000061
[   32.325286] PVR_K:   (MKT-105) 067B267D 001198AF 00001B1D AD000802
[   32.331848] PVR_K:   (MKT-106) 067B2827 001089AD 00001B1D AD000803
[   32.338317] PVR_K:   (MKT-107) 067B2877 0019DEEF 00001B1D AD000282
[   32.344879] PVR_K:   (MKT-108) 067B4FB6 00180838 00001F1F AD000101
[   32.351409] PVR_K:   (MKT-109) 067B5034 00180838 00001F1F AD000104
[   32.357879] PVR_K:   (MKT-10A) 067B5073 00180838 0100201E AD000100
[   32.364440] PVR_K:   (MKT-10B) 067B517C 00100828 0100201E AD000501
[   32.370910] PVR_K:   (MKT-10C) 067B51BC 00100829 0100201E AD000104
[   32.377471] PVR_K:   (MKT-10D) 067B52B9 00100DAF 0100211A AD000200
[   32.383972] PVR_K:   (MKT-10E) 067B55AA 001199A9 0000211A AD000202
[   32.390502] PVR_K:   (MKT-10F) 067B5656 001199AB 0000221F AD000183
[   32.397003] PVR_K:   (MKT-110) 067B56D5 001199AD 0000221F AD000184
[   32.403533] PVR_K:   (MKT-111) 067B5747 00119DA9 01002318 AD000281
[   32.410034] PVR_K:   (MKT-112) 067B593A 001089AB 01002318 AD00080A
[   32.416564] PVR_K:   (MKT-113) 067B5955 0017FBAB 01002318 0F039A00
[   32.423065] PVR_K:   (MKT-114) 067B5972 0017FBAB 01002318 00000060
[   32.429595] PVR_K:   (MKT-115) 067B5CE4 001199AD 00002318 AD000803
[   32.436126] PVR_K:   (MKT-116) 067B5D3B 001889ED 00002318 AD000282
[   32.442626] PVR_K:   (MKT-117) 067B5E8D 001008AF 01002517 AD000200
[   32.449157] PVR_K:   (MKT-118) 067B612C 001199AF 00002517 AD000202
[   32.455657] PVR_K:   (MKT-119) 067B61E2 001089AB 0000261F AD000183
[   32.462188] PVR_K:   (MKT-11A) 067B6265 001199AF 0000261F AD000184
[   32.468688] PVR_K:   (MKT-11B) 067B62CD 00108DAB 00000000 AD000281
[   32.475219] PVR_K:   (MKT-11C) 067B64B0 001199AF 00000000 AD00080A
[   32.481719] PVR_K:   (MKT-11D) 067B64CB 001199AD 00000000 0F039D00
[   32.488281] PVR_K:   (MKT-11E) 067B64E5 001089AB 00000000 00000060
[   32.494781] PVR_K:   (MKT-11F) 067B6840 001009A9 0000271E AD000803
[   32.501312] PVR_K:   (MKT-120) 067B6894 001808ED 0000271E AD000282
[   32.507812] PVR_K:   (MKT-121) 067B6A03 001089AF 0100291F AD000200
[   32.514312] PVR_K:   (MKT-122) 067B6C7E 001089AF 0000291F AD000202
[   32.520843] PVR_K:   (MKT-123) 067B6D1A 001099A9 00002A1E AD000183
[   32.527343] PVR_K:   (MKT-124) 067B6D91 001089AB 00002A1E AD000184
[   32.533874] PVR_K:   (MKT-125) 067B6DFB 00108DAB 01002B1D AD000281
[   32.540374] PVR_K:   (MKT-126) 067B6FED 001009AF 01002B1D AD00080A
[   32.546936] PVR_K:   (MKT-127) 067B700A 001199AB 01002B1D 0F03A000
[   32.553405] PVR_K:   (MKT-128) 067B7027 001199AF 01002B1D 00000062
[   32.559967] PVR_K:   (MKT-129) 067B7362 001008AB 00002B1D AD000803
[   32.566436] PVR_K:   (MKT-12A) 067B73B5 00180CAF 00002B1D AD000282
[   32.572998] PVR_K:   (MKT-12B) 0CFF074F 00100808 0100031F AD000B00
[   32.579498] PVR_K:   (MKT-12C) 0CFF0794 00100808 0100031F AD000B03
[   32.586029] PVR_K:   (MKT-12D) 0CFF0827 00100808 0100031F AD000B04
[   32.592559] PVR_K:   (MKT-12E) 0CFF086B 00100808 0100031F AD000B05
[   32.599060] PVR_K:   (MKT-12F) 0CFF08C1 00100808 0100031F AD000B06
[   32.605621] PVR_K:   (MKT-130) 0CFF0905 00100808 0100031F AD000B07
[   32.612091] PVR_K:   (MKT-131) 0CFF092A 00100808 0100031F AD000B09
[   32.618652] PVR_K:   (MKT-132) 0CFF0981 00100808 0100031F AD000B01
[   32.625122] PVR_K:   (MKT-133) 0CFF09BD 00100808 0100031F AD002300
[   32.631683] PVR_K:   (MKT-134) 0CFF0CBB 00100808 0100041F AD00000A
[   32.638183] PVR_K:   (MKT-135) 0CFF0D3A 00100808 0100041F AD000906
[   32.644714] PVR_K:   (MKT-136) 0CFF0DF4 00100808 0000041F AD000901
[   32.651214] PVR_K:   (MKT-137) 0CFF0E72 00100808 0000051E AD000183
[   32.657775] PVR_K:   (MKT-138) 0CFF0FEB 00100808 0000051E AD000302
[   32.664245] PVR_K:   (MKT-139) 0CFF1045 00100808 0000051E AD000303
[   32.670806] PVR_K:   (MKT-13A) 0CFF10BE 00100808 0000051E AD000C01
[   32.677337] PVR_K:   (MKT-13B) 0CFF10E2 00100808 0000051E 0D800484
[   32.683837] PVR_K:   (MKT-13C) 0CFF10FA 00100808 0000051E 00000002
[   32.690399] PVR_K:   (MKT-13D) 0CFF12F8 00100808 0000051E AD000184
[   32.696899] PVR_K:   (MKT-13E) 0CFF137A 00100C08 0100061D AD000281
[   32.703430] PVR_K:   (MKT-13F) 0CFF14BB 00100808 0100061D AD001000
[   32.710113] PVR_K:   (MKT-140) 0CFF1F6E 00100808 0000061D AD000282
[   32.716674] PVR_K:   (MKT-141) 0CFF201D 00100808 0000081E AD000183
[   32.723175] PVR_K:   (MKT-142) 0CFF2125 00100808 0000081E AD00030E
[   32.729705] PVR_K:   (MKT-143) 0CFF213D 00100808 0000081E 0D800474
[   32.736206] PVR_K:   (MKT-144) 0CFF2157 00100808 0000081E 00000001
[   32.743255] PVR_K:   (MKT-145) 0CFF217A 00100808 0000081E 00000002
[   32.749847] PVR_K:   (MKT-146) 0CFF21E5 00100808 0000081E AD000184
[   32.756439] PVR_K:   (MKT-147) 0CFF2255 00100C08 0100091C AD000281
[   32.763549] PVR_K:   (MKT-148) 0CFF23E2 00100808 0100091C AD00080A
[   32.770050] PVR_K:   (MKT-149) 0CFF23FB 00100808 0100091C 0F03A300
[   32.776611] PVR_K:   (MKT-14A) 0CFF2413 00100808 0100091C 00000061
[   32.783294] PVR_K:   (MKT-14B) 0CFF24D4 00100808 0100091C AD001300
[   32.789916] PVR_K:   (MKT-14C) 0CFF78A6 00100808 0000091C AD001301
[   32.796417] PVR_K:   (MKT-14D) 0CFF79A9 00100808 0000091C AD000802
[   32.803009] PVR_K:   (MKT-14E) 0CFF7B05 00100808 0000091C AD000803
[   32.809570] PVR_K:   (MKT-14F) 0CFF7B4B 00184AC8 0000091C AD000282
[   32.816162] PVR_K:   (MKT-150) 0CFF7C32 00180CB8 00000A1F AD00000A
[   32.823242] PVR_K:   (MKT-151) 0CFF7CAD 00180838 00000A1F AD000905
[   32.829803] PVR_K:   (MKT-152) 0CFF7DC7 001808B8 00000A1F AD000901
[   32.836303] PVR_K:   (MKT-153) 0CFF7E3D 00180838 00000B1E AD00000A
[   32.843048] PVR_K:   (MKT-154) 0CFF7EB4 00180838 00000B1E AD000906
[   32.849639] PVR_K:   (MKT-155) 0CFF7F32 00180838 00000B1E AD000901
[   32.856201] PVR_K:   (MKT-156) 0CFF7F88 00180838 00000C1D AD00000A
[   32.862792] PVR_K:   (MKT-157) 0CFF7FEA 00180838 00000C1D AD000905
[   32.869323] PVR_K:   (MKT-158) 0CFF8094 00180838 00000C1D AD000901
[   32.875915] PVR_K:   (MKT-159) 0CFF80EE 00180838 00000D1B AD00000A
[   32.882690] PVR_K:   (MKT-15A) 0CFF814D 00180838 00000D1B AD000905
[   32.889495] PVR_K:   (MKT-15B) 0CFF81F1 00180838 00000D1B AD000901
[   32.896087] PVR_K:   (MKT-15C) 0CFF8246 00180838 00000E1A AD00000A
[   32.902740] PVR_K:   (MKT-15D) 0CFF82A7 00180838 00000E1A AD000905
[   32.909271] PVR_K:   (MKT-15E) 0CFF8350 00180838 00000E1A AD000901
[   32.915954] PVR_K:   (MKT-15F) 0CFF849F 00180838 0000111C AD000183
[   32.922607] PVR_K:   (MKT-160) 0CFF8608 00180838 0000111C AD000302
[   32.929168] PVR_K:   (MKT-161) 0CFF867B 00180838 0000111C AD000303
[   32.935729] PVR_K:   (MKT-162) 0CFF86F9 00180838 0000111C AD000C01
[   32.942260] PVR_K:   (MKT-163) 0CFF8726 00180838 0000111C 0D800464
[   32.948883] PVR_K:   (MKT-164) 0CFF8740 00180838 0000111C 00000003
[   32.955383] PVR_K:   (MKT-165) 0CFF895E 00180838 0000111C AD000184
[   32.961944] PVR_K:   (MKT-166) 0CFF89C9 00180C38 01001217 AD000281
[   32.968444] PVR_K:   (MKT-167) 0CFF8A1F 00180838 01001217 AD000282
[   32.974975] PVR_K:   (MKT-168) 0CFF95EA 00180838 0100131F AD00000A
[   32.981475] PVR_K:   (MKT-169) 0CFF9656 00180838 0100131F AD000905
[   32.988006] PVR_K:   (MKT-16A) 0CFF9761 00180838 0000131F AD000901
[   32.994537] PVR_K:   (MKT-16B) 0CFF97B2 00180C38 0100141E AD000281
[   33.001129] PVR_K:   (MKT-16C) 0CFF9809 00180838 0100141E AD000282
[   33.007629] PVR_K:   (MKT-16D) 0CFF9A15 00180838 0100151F AD00000A
[   33.014160] PVR_K:   (MKT-16E) 0CFF9A80 00180838 0100151F AD000905
[   33.020690] PVR_K:   (MKT-16F) 0CFF9B79 00100828 0000151F AD000901
[   33.027221] PVR_K:   (MKT-170) 0CFF9BCB 00000C08 0000161E AD000281
[   33.033752] PVR_K:   (MKT-171) 0CFF9C20 00000808 0000161E AD000282
[   33.040252] PVR_K:   (MKT-172) 0CFF9C6F 00000808 0100171F AD000200
[   33.046813] PVR_K:   (MKT-173) 0CFF9EB9 00000808 0000171F AD000202
[   33.054290] PVR_K:   (MKT-174) 0CFF9F63 00000808 0000181E AD00000A
[   33.060821] PVR_K:   (MKT-175) 0CFF9FCB 00000808 0000181E AD000905
[   33.067321] PVR_K:   (MKT-176) 0CFFA0B8 00000808 0000181E AD000901
[   33.073883] PVR_K:   (MKT-177) 0CFFA109 00000C08 0000191D AD000281
[   33.080352] PVR_K:   (MKT-178) 0CFFA26B 00000808 0000191D AD00080A
[   33.086914] PVR_K:   (MKT-179) 0CFFA283 00000808 0000191D 0F03A600
[   33.093414] PVR_K:   (MKT-17A) 0CFFA29B 00000808 0000191D 00000060
[   33.099945] PVR_K:   (MKT-17B) 0CFFA55A 00000808 0000191D AD000803
[   33.106475] PVR_K:   (MKT-17C) 0CFFA5A3 00180CC8 0000191D AD000282
[   33.112976] PVR_K:   (MKT-17D) 0CFFA65A 00000808 00001A1F AD00000A
[   33.119537] PVR_K:   (MKT-17E) 0CFFA6C5 00000808 00001A1F AD000905
[   33.126037] PVR_K:   (MKT-17F) 0CFFA7BA 00000888 00001A1F AD000901
[   33.132568] PVR_K:   (MKT-180) 0CFFA803 00000C08 00001C1D AD000200
[   33.139068] PVR_K:   (MKT-181) 0CFFAA31 00000808 00001C1D AD000202
[   33.145599] PVR_K:   (MKT-182) 0CFFAA89 00000808 01001D1C AD000281
[   33.152099] PVR_K:   (MKT-183) 0CFFABD2 00000808 01001D1C AD00080A
[   33.158630] PVR_K:   (MKT-184) 0CFFABEA 00000808 01001D1C 0F03A900
[   33.165130] PVR_K:   (MKT-185) 0CFFAC03 00000808 01001D1C 00000060
[   33.171691] PVR_K:   (MKT-186) 0CFFAEC8 00000808 00001D1C AD000803
[   33.178192] PVR_K:   (MKT-187) 0CFFAF0F 00180CC8 00001D1C AD000282
[   33.184722] PVR_K:   (MKT-188) 0CFFAFF8 00000808 01001F1F AD000200
[   33.191284] PVR_K:   (MKT-189) 0CFFB21D 00000888 01001F1F AD000202
[   33.197784] PVR_K:   (MKT-18A) 0CFFB26E 00000808 0100201E AD000281
[   33.204315] PVR_K:   (MKT-18B) 0CFFB3C0 00000808 0100201E AD00080A
[   33.210815] PVR_K:   (MKT-18C) 0CFFB3D8 00000808 0100201E 0F03AC00
[   33.217346] PVR_K:   (MKT-18D) 0CFFB3F1 00000808 0100201E 00000062
[   33.223846] PVR_K:   (MKT-18E) 0CFFB6B1 00000808 0000201E AD000803
[   33.230407] PVR_K:   (MKT-18F) 0CFFB6F7 00180C88 0000201E AD000282
[   33.236907] PVR_K:   (MKT-190) 0CFFC219 00000808 0100221F AD000200
[   33.243438] PVR_K:   (MKT-191) 0CFFC33C 00000808 0100221F AD001703
[   33.249938] PVR_K:   (MKT-192) 0CFFC53B 00000888 0000221F AD000202
[   33.256500] PVR_K:   (MKT-193) 0CFFC5B9 00000808 0000231E AD000183
[   33.263000] PVR_K:   (MKT-194) 0CFFC6A8 00000808 0000231E AD00030E
[   33.269561] PVR_K:   (MKT-195) 0CFFC6C0 00000808 0000231E 0D800494
[   33.276092] PVR_K:   (MKT-196) 0CFFC6D8 00000808 0000231E 00000001
[   33.282592] PVR_K:   (MKT-197) 0CFFC705 00000808 0000231E 00000002
[   33.289123] PVR_K:   (MKT-198) 0CFFC772 00000808 0000231E AD000184
[   33.295623] PVR_K:   (MKT-199) 0CFFC7D5 00000C08 0000241D AD000281
[   33.302154] PVR_K:   (MKT-19A) 0CFFC94D 00000808 0000241D AD00080A
[   33.308654] PVR_K:   (MKT-19B) 0CFFC966 00000808 0000241D 0F03AF00
[   33.315216] PVR_K:   (MKT-19C) 0CFFC97E 00000808 0000241D 00000061
[   33.321716] PVR_K:   (MKT-19D) 0CFFCAF9 00000808 0000241D AD000802
[   33.328277] PVR_K:   (MKT-19E) 0CFFCC4A 00000808 0000241D AD000803
[   33.334747] PVR_K:   (MKT-19F) 0CFFCC8F 00184EC8 0000241D AD000282
[   33.341308] PVR_K:   (MKT-1A0) 0CFFEC51 00000C08 0100271F AD000200
[   33.347808] PVR_K:   (MKT-1A1) 0CFFEEA8 00000808 0000271F AD000202
[   33.354339] PVR_K:   (MKT-1A2) 0CFFEF30 00000808 0000281E AD000183
[   33.360870] PVR_K:   (MKT-1A3) 0CFFF018 00000808 0000281E AD00030E
[   33.367340] PVR_K:   (MKT-1A4) 0CFFF030 00000808 0000281E 0D800494
[   33.373901] PVR_K:   (MKT-1A5) 0CFFF048 00000808 0000281E 00000001
[   33.380371] PVR_K:   (MKT-1A6) 0CFFF06B 00000808 0000281E 00000002
[   33.386932] PVR_K:   (MKT-1A7) 0CFFF0D8 00000808 0000281E AD000184
[   33.393432] PVR_K:   (MKT-1A8) 0CFFF13E 00000C08 0100291D AD000281
[   33.399963] PVR_K:   (MKT-1A9) 0CFFF2B2 00000808 0100291D AD00080A
[   33.406463] PVR_K:   (MKT-1AA) 0CFFF2CA 00000808 0100291D 0F03B200
[   33.412994] PVR_K:   (MKT-1AB) 0CFFF2E3 00000808 0100291D 00000060
[   33.419494] PVR_K:   (MKT-1AC) 0CFFF5AA 00000808 0000291D AD000803
[   33.426025] PVR_K:   (MKT-1AD) 0CFFF5F6 00188CC8 0000291D AD000282
[   33.432586] PVR_K:   (MKT-1AE) 0CFFF69A 00000808 01002B1F AD000200
[   33.439086] PVR_K:   (MKT-1AF) 0CFFF8B7 00000808 00002B1F AD000202
[   33.445617] PVR_K:   (MKT-1B0) 0CFFF936 00000808 00002C1E AD000183
[   33.452117] PVR_K:   (MKT-1B1) 0CFFFA21 00000808 00002C1E AD00030E
[   33.458648] PVR_K:   (MKT-1B2) 0CFFFA39 00000808 00002C1E 0D800494
[   33.465118] PVR_K:   (MKT-1B3) 0CFFFA52 00000808 00002C1E 00000001
[   33.471679] PVR_K:   (MKT-1B4) 0CFFFA76 00000808 00002C1E 00000002
[   33.478179] PVR_K:   (MKT-1B5) 0CFFFAE1 00000808 00002C1E AD000184
[   33.484710] PVR_K:   (MKT-1B6) 0CFFFB45 00000C08 01002D1D AD000281
[   33.491210] PVR_K:   (MKT-1B7) 0CFFFCB1 00000808 01002D1D AD00080A
[   33.497741] PVR_K:   (MKT-1B8) 0CFFFCCA 00000808 01002D1D 0F03B500
[   33.504241] PVR_K:   (MKT-1B9) 0CFFFCE3 00000808 01002D1D 00000060
[   33.510772] PVR_K:   (MKT-1BA) 0CFFFF95 00000808 00002D1D AD000803
[   33.517333] PVR_K:   (MKT-1BB) 0CFFFFDC 00180CC8 00002D1D AD000282
[   33.523834] PVR_K:   (MKT-1BC) 0D0000C3 00000808 01002F1F AD000200
[   33.530364] PVR_K:   (MKT-1BD) 0D0002DD 00000808 00002F1F AD000202
[   33.536865] PVR_K:   (MKT-1BE) 0D00035B 00000808 0000301E AD000183
[   33.543395] PVR_K:   (MKT-1BF) 0D000448 00000808 0000301E AD00030E
[   33.549896] PVR_K:   (MKT-1C0) 0D000460 00000808 0000301E 0D800494
[   33.556457] PVR_K:   (MKT-1C1) 0D000479 00000808 0000301E 00000001
[   33.562957] PVR_K:   (MKT-1C2) 0D00049D 00000808 0000301E 00000002
[   33.569488] PVR_K:   (MKT-1C3) 0D00050A 00000808 0000301E AD000184
[   33.575958] PVR_K:   (MKT-1C4) 0D00056E 00000C08 0100311D AD000281
[   33.582519] PVR_K:   (MKT-1C5) 0D0006E6 00000808 0100311D AD00080A
[   33.588989] PVR_K:   (MKT-1C6) 0D0006FF 00000808 0100311D 0F03B800
[   33.595550] PVR_K:   (MKT-1C7) 0D000717 00000808 0100311D 00000062
[   33.602081] PVR_K:   (MKT-1C8) 0D0009C6 00000808 0000311D AD000803
[   33.608581] PVR_K:   (MKT-1C9) 0D000A11 00180C88 0000311D AD000282
[   33.615112] PVR_K:   (MKT-1CA) 0D001547 00000808 0100331F AD000200
[   33.621612] PVR_K:   (MKT-1CB) 0D001662 00000808 0100331F AD001703
[   33.628173] PVR_K:   (MKT-1CC) 0D001843 00000808 0000331F AD000202
[   33.634674] PVR_K:   (MKT-1CD) 0D0018C3 00000808 0000341E AD000183
[   33.641235] PVR_K:   (MKT-1CE) 0D0019AC 00000808 0000341E AD00030E
[   33.647735] PVR_K:   (MKT-1CF) 0D0019C4 00000808 0000341E 0D800494
[   33.654266] PVR_K:   (MKT-1D0) 0D0019DD 00000808 0000341E 00000001
[   33.660766] PVR_K:   (MKT-1D1) 0D001A00 00000808 0000341E 00000002
[   33.667297] PVR_K:   (MKT-1D2) 0D001A6A 00000808 0000341E AD000184
[   33.673828] PVR_K:   (MKT-1D3) 0D001AD0 00000C08 0100351D AD000281
[   33.680358] PVR_K:   (MKT-1D4) 0D001BE1 00000808 0100351D AD000E02
[   33.686889] PVR_K:   (MKT-1D5) 0D001C52 00000808 0100351D AD000282
[   33.693389] PVR_K:   (MKT-1D6) 0D00DEAB 00000808 0100381F AD001A00
[   33.699951] PVR_K:   (MKT-1D7) 0D00E1D6 00000808 0100391F AD00000A
[   33.706451] PVR_K:   (MKT-1D8) 0D00E238 00000808 0100391F AD000909
[   33.712982] PVR_K:   (MKT-1D9) 0D00E282 00000808 0100391F AD001A05
[   33.719482] PVR_K:   (MKT-1DA) 0D00E2B4 00000808 0100391F AD001302
[   33.726043] PVR_K:   (MKT-1DB) 0D00E2F4 00000808 0100391F AD001303
[   33.732513] PVR_K:   (MKT-1DC) 0D00E386 00000808 0100391F AD000D04
[   33.739044] PVR_K:   (MKT-1DD) 0D00E44F 00000808 0100391F AD000D05
[   33.745544] PVR_K:   (MKT-1DE) 0D00E4A9 00000808 0100391F AD000D04
[   33.752105] PVR_K:   (MKT-1DF) 0D00E531 00000808 0100391F AD000D05
[   33.758605] PVR_K:   (MKT-1E0) 0D00E590 00000808 0100391F AD001A06
[   33.765167] PVR_K:   (MKT-1E1) 0000047C 00100808 0100031F AD002300
[   33.772033] PVR_K:   (MKT-1E2) 00000965 00100808 0100041F AD00000A
[   33.778656] PVR_K:   (MKT-1E3) 000009E2 00100808 0100041F AD000906
[   33.785217] PVR_K:   (MKT-1E4) 00000AB4 00100808 0000041F AD000901
[   33.791717] PVR_K:   (MKT-1E5) 00000B32 00100808 0000051E AD000183
[   33.798309] PVR_K:   (MKT-1E6) 00000CA7 00100808 0000051E AD000302
[   33.804870] PVR_K:   (MKT-1E7) 00000E29 00100808 0000051E AD000D06
[   33.811431] PVR_K:   (MKT-1E8) 00000F10 00100808 0000051E AD000D07
[   33.818084] PVR_K:   (MKT-1E9) 00000F59 00100808 0000051E AD001304
[   33.824707] PVR_K:   (MKT-1EA) 00001044 00100808 0000051E AD001305
[   33.831298] PVR_K:   (MKT-1EB) 00001154 00100888 0000051E AD000404
[   33.837890] PVR_K:   (MKT-1EC) 00001217 00100808 0000051E AD000402
[   33.844451] PVR_K:   (MKT-1ED) 00001260 0010082B 0000051E AD000184
[   33.851013] PVR_K:   (MKT-1EE) 000012EB 00108DA9 0000061D AD000281
[   33.857971] PVR_K:   (MKT-1EF) 0000146A 001199AD 0000061D AD000E02
[   33.864501] PVR_K:   (MKT-1F0) 000014C9 001199A9 0000061D AD000282
[   33.871032] PVR_K:   (MKT-1F1) 00003AAE 00100808 0000081F AD000101
[   33.877990] PVR_K:   (MKT-1F2) 00003B25 00100808 0000081F AD000104
[   33.884552] PVR_K:   (MKT-1F3) 00003B63 00100808 0100091E AD000100
[   33.891296] PVR_K:   (MKT-1F4) 00003C69 00100808 0100091E AD000501
[   33.898071] PVR_K:   (MKT-1F5) 00003CA9 0010082B 0100091E AD000104
[   33.904968] PVR_K:   (MKT-1F6) 00005F7F 00100828 01000A1F AD000101
[   33.911956] PVR_K:   (MKT-1F7) 00005FC4 00100828 01000A1F AD000104
[   33.918487] PVR_K:   (MKT-1F8) 000060DB 00100808 01000B1F AD000100
[   33.925476] PVR_K:   (MKT-1F9) 000061A0 00100808 01000B1F AD000501
[   33.932403] PVR_K:   (MKT-1FA) 000061CC 00100829 01000B1F AD000104
[   33.939361] PVR_K:   (MKT-1FB) 000086F6 00100828 01000D1F AD000101
[   33.946319] PVR_K:   (MKT-1FC) 0000876D 00100828 01000D1F AD000104
[   33.952880] PVR_K:   (MKT-1FD) 000087AA 00100808 01000E1E AD000100
[   33.959472] PVR_K:   (MKT-1FE) 000088AA 00100808 01000E1E AD000501
[   33.966003] PVR_K:   (MKT-1FF) 000088E9 00100829 01000E1E AD000104
[   33.972625] PVR_K: SGX Kernel CCB WO:0x2D RO:0x2D
[   33.979492] adc_to_temp_conversion:Temp read is invalid 0
[   33.985656] thermal_lookup_temp: getting temp is not supported for domain pcb
[   33.994354] adc_to_temp_conversion:Temp read is invalid 0
[   34.000427] thermal_lookup_temp: getting temp is not supported for domain pcb
[   34.009002] adc_to_temp_conversion:Temp read is invalid 0
[   34.015075] thermal_lookup_temp: getting temp is not supported for domain pcb
[   34.194244] PVR_K:(Error): SGXOSTimer() detected SGX lockup (0x9 tasks) [0, ]
[   34.201873] PVR_K: HWRecoveryResetSGX: SGX Hardware Recovery triggered
[   34.216308] [   15.672]   [c6e89d00] new in dsscomp_gralloc_queue (refs=1)
[   34.216308] [   15.672]                           [c6e64400] dsscomp_new
[   34.216308] [   15.672]   [c6e89d00] ++refs=2 for [c6e64400]
[   34.216308] [   15.672]                           [c6e64400] dsscomp_delayed_apply
[   34.216308] [   15.672]   [c6e89d00] --refs=1 on RELEASED
[   34.255065] [   15.672]                           [c6e64400] dsscomp_apply
[   34.255065] [   15.711]   [c6e89d00] --refs=0 on ECLIPSED
[   34.255065] [   15.711]   [c6e89d00] calling   (null) [  (null)]
[   34.255065] [   15.711]                           [c6e64400] dsscomp_mgr_delayed_cb on ECLIPSED
[   34.285369] [   19.772]    [c6edb7a0] new in dsscomp_gralloc_queue (refs=1)
[   34.285369] [   19.772]                        [c738c400] dsscomp_new
[   34.285369] [   19.772]    [c6edb7a0] ++refs=2 for [c738c400]
[   34.285400] [   19.772]                        [c738c400] dsscomp_delayed_apply
[   34.315216] [   19.772]    [c6edb7a0] --refs=1 on RELEASED
[   34.315246] [   19.772]                        [c738c400] dsscomp_apply
[   34.315246] [   19.773]                        [c738c400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   34.315246] [   19.779]    [c6e89d40] new in dsscomp_gralloc_queue (refs=1)
[   34.345184] [   19.779]                           [c6e64400] dsscomp_new
[   34.345184] [   19.779]    [c6e89d40] ++refs=2 for [c6e64400]
[   34.345184] [   19.779]                           [c6e64400] dsscomp_delayed_apply
[   34.345184] [   19.779]    [c6e89d40] --refs=1 on RELEASED
[   34.345184] [   19.779]                           [c6e64400] dsscomp_apply
[   34.376525] [   19.801]                        [c738c400] dsscomp_mgr_delayed_cb on DISPLAYED
[   34.376556] [   19.801]    [c6edb7a0] --refs=0 on RELEASED
[   34.376556] [   19.801]    [c6edb7a0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   34.376556] [   19.801]                        [c738c400] dsscomp_mgr_delayed_cb on RELEASED
[   34.406433] [   19.801]   [c6edb760] new in dsscomp_gralloc_queue (refs=1)
[   34.406463] [   19.801]                        [c6f10400] dsscomp_new
[   34.406463] [   19.801]   [c6edb760] ++refs=2 for [c6f10400]
[   34.406463] [   19.801]                        [c6f10400] dsscomp_delayed_apply
[   34.436279] [   19.801]   [c6edb760] --refs=1 on RELEASED
[   34.436279] [   19.801]                           [c6e64400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   34.436309] [   19.801]                        [c6f10400] dsscomp_apply
[   34.436309] [   19.816]                           [c6e64400] dsscomp_mgr_delayed_cb on DISPLAYED
[   34.466156] [   19.816]    [c6e89d40] --refs=0 on RELEASED
[   34.466186] [   19.816]    [c6e89d40] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   34.466186] [   19.816]                           [c6e64400] dsscomp_mgr_delayed_cb on RELEASED
[   34.494476] [   19.816]                        [c6f10400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   34.494476] [   19.832]                        [c6f10400] dsscomp_mgr_delayed_cb on DISPLAYED
[   34.494476] [   24.345]   [c6edb920] new in dsscomp_gralloc_queue (refs=1)
[   34.494476] [   24.345]                         [c6f11400] dsscomp_new
[   34.524322] [   24.345]   [c6edb920] ++refs=2 for [c6f11400]
[   34.524322] [   24.345]                         [c6f11400] dsscomp_delayed_apply
[   34.524353] [   24.345]   [c6edb920] --refs=1 on RELEASED
[   34.524353] [   24.345]                         [c6f11400] dsscomp_apply
[   34.554199] [   24.345]   [c6edb760] --refs=0 on RELEASED
[   34.554199] [   24.345]   [c6edb760] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   34.554199] [   24.345]                        [c6f10400] dsscomp_mgr_delayed_cb on RELEASED
[   34.554199] [   24.345]                         [c6f11400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   34.584045] [   24.369]                         [c6f11400] dsscomp_mgr_delayed_cb on DISPLAYED
[   34.584045] [   28.901]    [c6e89d40] new in dsscomp_gralloc_queue (refs=1)
[   34.584075] [   28.901]                           [c6e64400] dsscomp_new
[   34.584075] [   28.901]    [c6e89d40] ++refs=2 for [c6e64400]
[   34.613922] [   28.901]                           [c6e64400] dsscomp_delayed_apply
[   34.613922] [   28.901]    [c6e89d40] --refs=1 on RELEASED
[   34.613952] [   28.901]                           [c6e64400] dsscomp_apply
[   34.613952] [   28.901]   [c6edb920] --refs=0 on RELEASED
[   34.643768] [   28.901]   [c6edb920] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   34.643768] [   28.901]                         [c6f11400] dsscomp_mgr_delayed_cb on RELEASED
[   34.643768] [   28.901]                           [c6e64400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   34.643798] [   28.902] [c6e89d60] new in dsscomp_gralloc_queue (refs=1)
[   34.673645] [   28.902]                      [c6e64800] dsscomp_new
[   34.673645] [   28.902] [c6e89d60] ++refs=2 for [c6e64800]
[   34.673645] [   28.902]                      [c6e64800] dsscomp_delayed_apply
[   34.673645] [   28.902] [c6e89d60] --refs=1 on RELEASED
[   34.703491] [   28.902]                      [c6e64800] dsscomp_apply
[   34.703491] [   28.925]                           [c6e64400] dsscomp_mgr_delayed_cb on DISPLAYED
[   34.703491] [   28.925]    [c6e89d40] --refs=0 on RELEASED
[   34.703491] [   28.925]    [c6e89d40] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   34.733367] [   28.925]                           [c6e64400] dsscomp_mgr_delayed_cb on RELEASED
[   34.733367] [   28.925]                      [c6e64800] dsscomp_mgr_delayed_cb on PROGRAMMED
[   34.733367] [   28.942]                      [c6e64800] dsscomp_mgr_delayed_cb on DISPLAYED
[   34.761657] [   33.971]  [c6e89da0] new in dsscomp_gralloc_queue (refs=1)
[   34.761688] [   33.971]                        [c6e64c00] dsscomp_new
[   34.761688] [   33.971]  [c6e89da0] ++refs=2 for [c6e64c00]
[   34.761688] [   33.971]                        [c6e64c00] dsscomp_delayed_apply
[   34.761688] [   33.971]  [c6e89da0] --refs=1 on RELEASED
[   34.793090] [   33.971]                        [c6e64c00] dsscomp_apply
[   34.793121] [   33.971] [c6e89d60] --refs=0 on RELEASED
[   34.793121] [   33.971] [c6e89d60] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   34.793121] [   33.971]                      [c6e64800] dsscomp_mgr_delayed_cb on RELEASED
[   34.822937] [   33.971]                        [c6e64c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   34.822937] [   33.972]      [c6edb820] new in dsscomp_gralloc_queue (refs=1)
[   34.822937] [   33.972]                      [c6f10000] dsscomp_new
[   34.822937] [   33.972]      [c6edb820] ++refs=2 for [c6f10000]
[   34.852813] [   33.972]                      [c6f10000] dsscomp_delayed_apply
[   34.852813] [   33.972]      [c6edb820] --refs=1 on RELEASED
[   34.852813] [   33.972]                      [c6f10000] dsscomp_apply
[   34.852844] [   33.993]                        [c6e64c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   34.882659] [   33.993]  [c6e89da0] --refs=0 on RELEASED
[   34.882690] [   33.993]  [c6e89da0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   34.882690] [   34.001]                        [c6e64c00] dsscomp_mgr_delayed_cb on RELEASED
[   34.882690] [   34.001]                      [c6f10000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   34.912567] [   34.008]                      [c6f10000] dsscomp_mgr_delayed_cb on DISPLAYED
[   34.912567] ACTIVE COMPOSITIONS on lcd
[   34.912567]
[   34.912567]   [c6f10000]: DISPLAYED
[   34.912567]     sync_id=0, flags=AD-
[   34.912567]     ovl0={ON z0 ARGB32-8888 premult *100% 864*480:0,0+864,480 rot0 => 0,0+864,480 7f358000/  (null)|3456}
[   34.945526]     gsync=[c6edb820] dsscomp_gralloc_cb
[   34.945526]
[   34.945526]   DISPC pipeline:
[   34.945556]
[   34.945556]     info:        clean (none)
[   34.945556]     cache:       clean (none)
[   34.945556]     shadow:  ACT clean (none)
[   34.945556]     dispc:   DISPLAYED mask=---R [c6f10000] dsscomp_mgr_callback
[   34.986968]
[   34.986968] ACTIVE COMPOSITIONS on tv
[   34.986968]
[   34.986968]   DISPC pipeline:
[   34.986968]
[   34.986968]     info:        clean (none)
[   34.986968]     cache:       clean (none)
[   34.986968]     shadow:  off clean (none)
[   34.986968]     dispc:   DISPLAYED (none)
[   34.986999]
[   34.986999] ACTIVE COMPOSITIONS on lcd2
[   34.986999]
[   34.986999]   DISPC pipeline:
[   34.986999]
[   34.986999]     info:        clean (none)
[   35.036987]     cache:       clean (none)
[   35.036987]     shadow:  off clean (none)
[   35.036987]     dispc:             (none)
[   35.036987]
[   35.036987] ACTIVE GRALLOC FLIPS
[   35.036987]
[   35.036987]   [c6edb820] (refs=1)
[   35.036987]     slots=[7f358000]
[   35.037017]     cmdcb=[c73f6900] dsscomp_proxy_cmdcomplete
[   35.037017]
[   35.037017]   |           lcd
[   35.037017]   | [c6f10000] DISPL'D
[   35.037994] adc_to_temp_conversion:Temp read is invalid 0
[   35.037994] thermal_lookup_temp: getting temp is not supported for domain pcb
[   35.038818] adc_to_temp_conversion:Temp read is invalid 0
[   35.038818] thermal_lookup_temp: getting temp is not supported for domain pcb
[   35.039642] adc_to_temp_conversion:Temp read is invalid 0
[   35.039672] thermal_lookup_temp: getting temp is not supported for domain pcb
[   35.119873]   |     33.972  ACTIVE
[   35.119873]   |     33.972 APPLY'N
[   35.119873]   |     33.972 APPLIED
[   35.119873]   |     34.001 PROGR'D
[   35.119873]   |     34.008 DISPL'D
[   35.119873]
[   35.119873]
[   35.142395] PVR_K: SGX debug (blaze_android_sgx_ogles1_ogles2_GPL sgxddk 18 1.8@869593)
[   35.151092] PVR_K:(Error): SGX Register Base Address (Linear):   0xC8B20000 [0, ]
[   35.159484] PVR_K:(Error): SGX Register Base Address (Physical): 0x56000000 [0, ]
[   35.167785] PVR_K: (P0) EUR_CR_CORE_ID:          01140000
[   35.173797] PVR_K: (P0) EUR_CR_CORE_REVISION:    00010200
[   35.179809] PVR_K: (P0) EUR_CR_EVENT_STATUS:     20000000
[   35.185852] PVR_K: (P0) EUR_CR_EVENT_STATUS2:    00000008
[   35.191864] PVR_K: (P0) EUR_CR_BIF_CTRL:         00000000
[   35.197753] PVR_K: (P0) EUR_CR_BIF_INT_STAT:     00008000
[   35.203796] PVR_K: (P0) EUR_CR_BIF_FAULT:        00000000
[   35.209655] PVR_K: (P0) EUR_CR_BIF_MEM_REQ_STAT: 00000000
[   35.215728] PVR_K: (P0) EUR_CR_CLKGATECTL:       000AAA6A
[   35.221618] PVR_K: (P0) EUR_CR_PDS_PC_BASE:      00004008
[   35.227661] PVR_K: Flip Command Complete Data 0 for display device 1:
[   35.234619] PVR_K:   SRC 0: (Not in use)
[   35.239318] PVR_K: Flip Command Complete Data 1 for display device 1:
[   35.246520] PVR_K:   SRC 0: ROC DevVAddr:0xD800474 ROP:0x5 ROC:0x3, WOC DevVAddr:0xD800464 WOP:0x5 WOC:0x4
[   35.256835] PVR_K: SGX Host control:
[   35.260894] PVR_K:   (HC-0) 0x00000001 0x00000000 0x00000000 0x00000001
[   35.267913] PVR_K:   (HC-10) 0x00000005 0x0000000A 0x0005DC00 0x00000003
[   35.275238] PVR_K:   (HC-20) 0x00000000 0x00000001 0x00000000 0x00000005
[   35.282531] PVR_K:   (HC-30) 0x00000035 0xF0256C00 0x00000000 0x00000000
[   35.289825] PVR_K:   (HC-40) 0x00000000 0x087BF500 0x087C6300 0x087C3100
[   35.297119] PVR_K: SGX TA/3D control:
[   35.301208] PVR_K:   (T3C-0) 0x0F003000 0x0F003120 0x0F002000 0x00000000
[   35.308532] PVR_K:   (T3C-10) 0x00000001 0x00000002 0x00000001 0x0F00DD00
[   35.315917] PVR_K:   (T3C-20) 0x00000000 0x00000000 0x00000000 0x00000000
[   35.323333] PVR_K:   (T3C-30) 0x00000000 0x00000000 0x00000000 0x00000000
[   35.330749] PVR_K:   (T3C-40) 0x00000000 0x00000000 0x00000000 0x00000000
[   35.337951] PVR_K:   (T3C-50) 0x0F00DD00 0x00000000 0x00000000 0x0F00DD00
[   35.346160] PVR_K:   (T3C-60) 0x00000000 0x00000000 0x0F00DD00 0x00000000
[   35.361877] PVR_K:   (T3C-70) 0x00000000 0x0F00DD00 0x00000000 0x0F004000
[   35.378326] PVR_K:   (T3C-80) 0x0000011A 0x0001120F 0x00000000 0x0F00DEB8
[   35.386138] PVR_K:   (T3C-90) 0x00000000 0x0F000000 0xAB600000 0x0F03D000
[   35.393402] PVR_K:   (T3C-A0) 0x00000000 0x0F010BE0 0x0F00DD00 0x0F00DEB8
[   35.400634] PVR_K:   (T3C-B0) 0x0F010760 0x00000000 0x00000000 0x00000000
[   35.410217] PVR_K:   (T3C-C0) 0x00000000 0x00000000 0x00000000 0x00000000
[   35.417480] PVR_K:   (T3C-D0) 0x00000000 0x00000008 0x00000007 0x0F007000
[   35.424774] PVR_K:   (T3C-E0) 0x0F00D420 0x0F00E000 0x0F010720 0x0F010720
[   35.444213] PVR_K:   (T3C-F0) 0x00000000 0x000000B5 0x000000B5 0x00000000
[   35.451385] PVR_K:   (T3C-100) 0x00000003 0x00000000 0x00000000 0x00000000
[   35.467315] PVR_K:   (T3C-110) 0xB50C565C 0x0872E100 0x08787B00 0x08787B00
[   35.474670] PVR_K: Last SGX microkernel status code: AD000104
[   35.480987] PVR_K:   (MKT-0) 067A7C8E 00100808 0000051E AD000184
[   35.492401] PVR_K:   (MKT-1) 067A7D0D 00100C08 0100061D AD000281
[   35.506713] PVR_K:   (MKT-2) 067A7E91 00100808 0100061D AD00080A
[   35.513092] PVR_K:   (MKT-3) 067A7EAD 00100808 0100061D 0F038B00
[   35.519470] PVR_K:   (MKT-4) 067A7EC6 00100808 0100061D 00000061
[   35.530822] PVR_K:   (MKT-5) 067A7FE4 00100C88 0100061D AD001300
[   35.540985] PVR_K:   (MKT-6) 067AD43A 00100808 0000061D AD001301
[   35.547912] PVR_K:   (MKT-7) 067AD571 00100888 0000061D AD000802
[   35.557678] PVR_K:   (MKT-8) 067AD6DB 00100888 0000061D AD000803
[   35.569183] PVR_K:   (MKT-9) 067AD72D 001808C8 0000061D AD000282
[   35.575531] PVR_K:   (MKT-A) 067AD811 00184AF8 0000081E AD00000A
[   35.600463] PVR_K:   (MKT-B) 067AD889 001808F8 0000081E AD000905
[   35.606842] PVR_K:   (MKT-C) 067AD9B5 001808B8 0000081E AD000901
[   35.620422] PVR_K:   (MKT-D) 067ADA27 00180838 0000091C AD00000A
[   35.639526] PVR_K:   (MKT-E) 067ADA90 00180838 0000091C AD000905
[   35.645812] PVR_K:   (MKT-F) 067ADB3B 00180838 0000091C AD000901
[   35.662963] PVR_K:   (MKT-10) 067ADB96 00180838 00000A1B AD00000A
[   35.669372] PVR_K:   (MKT-11) 067ADC09 00180838 00000A1B AD000906
[   35.686401] PVR_K:   (MKT-12) 067ADC94 00180838 00000A1B AD000901
[   35.692810] PVR_K:   (MKT-13) 067ADCF7 00180838 00000B1A AD00000A
[   35.700592] PVR_K:   (MKT-14) 067ADD66 00180838 00000B1A AD000905
[   35.712829] PVR_K:   (MKT-15) 067ADE11 00180838 00000B1A AD000901
[   35.725463] PVR_K:   (MKT-16) 067ADE6B 00180838 00000C19 AD00000A
[   35.731872] PVR_K:   (MKT-17) 067ADECC 00180838 00000C19 AD000905
[   35.745086] PVR_K:   (MKT-18) 067ADF88 00180838 00000C19 AD000901
[   35.755676] PVR_K:   (MKT-19) 067AE0B8 00180C38 01000F1F AD000281
[   35.762176] PVR_K:   (MKT-1A) 067AE113 00180838 01000F1F AD000282
[   35.768859] PVR_K:   (MKT-1B) 067AF7F8 00000808 0100101F AD000200
[   35.775329] PVR_K:   (MKT-1C) 067AFA4E 00000808 0000101F AD000202
[   35.781890] PVR_K:   (MKT-1D) 067AFA9E 00000808 0100111E AD000281
[   35.788421] PVR_K:   (MKT-1E) 067AFBF0 00000808 0100111E AD00080A
[   35.795074] PVR_K:   (MKT-1F) 067AFC09 00000808 0100111E 0F038E00
[   35.801513] PVR_K:   (MKT-20) 067AFC21 00000808 0100111E 00000060
[   35.808227] PVR_K:   (MKT-21) 067AFEE6 00000808 0000111E AD000803
[   35.814697] PVR_K:   (MKT-22) 067AFF2F 00180CC8 0000111E AD000282
[   35.821289] PVR_K:   (MKT-23) 067AFFCD 00000808 0100131F AD000200
[   35.827911] PVR_K:   (MKT-24) 067B01F4 00000808 0000131F AD000202
[   35.835937] PVR_K:   (MKT-25) 067B0242 00000808 0100141E AD000281
[   35.843536] PVR_K:   (MKT-26) 067B0390 00000808 0100141E AD00080A
[   35.851776] PVR_K:   (MKT-27) 067B03AB 00000808 0100141E 0F039100
[   35.858306] PVR_K:   (MKT-28) 067B03C3 00000808 0100141E 00000060
[   35.864959] PVR_K:   (MKT-29) 067B0676 00000808 0000141E AD000803
[   35.871917] PVR_K:   (MKT-2A) 067B06BC 00180CC8 0000141E AD000282
[   35.878601] PVR_K:   (MKT-2B) 067B07A1 00000808 0100161F AD000200
[   35.885223] PVR_K:   (MKT-2C) 067B09CF 00000808 0000161F AD000202
[   35.891754] PVR_K:   (MKT-2D) 067B0A21 00000808 0100171E AD000281
[   35.898315] PVR_K:   (MKT-2E) 067B0B6D 00000808 0100171E AD00080A
[   35.904846] PVR_K:   (MKT-2F) 067B0B86 00000808 0100171E 0F039400
[   35.911407] PVR_K:   (MKT-30) 067B0B9E 00000808 0100171E 00000062
[   35.917938] PVR_K:   (MKT-31) 067B0E55 00000808 0000171E AD000803
[   35.924468] PVR_K:   (MKT-32) 067B0E9B 00180C88 0000171E AD000282
[   35.931182] PVR_K:   (MKT-33) 067B1984 00000808 0100191F AD000200
[   35.938385] PVR_K:   (MKT-34) 067B1AA1 00000808 0100191F AD001703
[   35.945129] PVR_K:   (MKT-35) 067B1CA6 00000808 0000191F AD000202
[   35.951812] PVR_K:   (MKT-36) 067B1D33 00000808 00001A1E AD000183
[   35.958496] PVR_K:   (MKT-37) 067B1E9B 00000808 00001A1E AD000302
[   35.965118] PVR_K:   (MKT-38) 067B20D4 00000808 00001A1E AD000404
[   35.971954] PVR_K:   (MKT-39) 067B2197 00000808 00001A1E AD000402
[   35.978363] PVR_K:   (MKT-3A) 067B21D1 001008AD 00001A1E AD000184
[   35.984985] PVR_K:   (MKT-3B) 067B2266 00119DA9 00001B1D AD000281
[   35.991546] PVR_K:   (MKT-3C) 067B2496 001199AB 00001B1D AD00080A
[   35.998138] PVR_K:   (MKT-3D) 067B24B0 001089AB 00001B1D 0F039700
[   36.004669] PVR_K:   (MKT-3E) 067B24CC 001199AD 00001B1D 00000061
[   36.011505] PVR_K:   (MKT-3F) 067B267D 001198AF 00001B1D AD000802
[   36.017913] PVR_K:   (MKT-40) 067B2827 001089AD 00001B1D AD000803
[   36.024505] PVR_K:   (MKT-41) 067B2877 0019DEEF 00001B1D AD000282
[   36.030975] PVR_K:   (MKT-42) 067B4FB6 00180838 00001F1F AD000101
[   36.032012] adc_to_temp_conversion:Temp read is invalid 0
[   36.032012] thermal_lookup_temp: getting temp is not supported for domain pcb
[   36.032897] adc_to_temp_conversion:Temp read is invalid 0
[   36.032897] thermal_lookup_temp: getting temp is not supported for domain pcb
[   36.033752] adc_to_temp_conversion:Temp read is invalid 0
[   36.033752] thermal_lookup_temp: getting temp is not supported for domain pcb
[   36.077697] PVR_K:   (MKT-43) 067B5034 00180838 00001F1F AD000104
[   36.084625] PVR_K:   (MKT-44) 067B5073 00180838 0100201E AD000100
[   36.091094] PVR_K:   (MKT-45) 067B517C 00100828 0100201E AD000501
[   36.097717] PVR_K:   (MKT-46) 067B51BC 00100829 0100201E AD000104
[   36.104187] PVR_K:   (MKT-47) 067B52B9 00100DAF 0100211A AD000200
[   36.110778] PVR_K:   (MKT-48) 067B55AA 001199A9 0000211A AD000202
[   36.118469] PVR_K:   (MKT-49) 067B5656 001199AB 0000221F AD000183
[   36.125030] PVR_K:   (MKT-4A) 067B56D5 001199AD 0000221F AD000184
[   36.131622] PVR_K:   (MKT-4B) 067B5747 00119DA9 01002318 AD000281
[   36.147338] PVR_K:   (MKT-4C) 067B593A 001089AB 01002318 AD00080A
[   36.153778] PVR_K:   (MKT-4D) 067B5955 0017FBAB 01002318 0F039A00
[   36.160552] PVR_K:   (MKT-4E) 067B5972 0017FBAB 01002318 00000060
[   36.169677] PVR_K:   (MKT-4F) 067B5CE4 001199AD 00002318 AD000803
[   36.176208] PVR_K:   (MKT-50) 067B5D3B 001889ED 00002318 AD000282
[   36.193756] PVR_K:   (MKT-51) 067B5E8D 001008AF 01002517 AD000200
[   36.209808] PVR_K:   (MKT-52) 067B612C 001199AF 00002517 AD000202
[   36.216247] PVR_K:   (MKT-53) 067B61E2 001089AB 0000261F AD000183
[   36.233276] PVR_K:   (MKT-54) 067B6265 001199AF 0000261F AD000184
[   36.239715] PVR_K:   (MKT-55) 067B62CD 00108DAB 00000000 AD000281
[   36.256713] PVR_K:   (MKT-56) 067B64B0 001199AF 00000000 AD00080A
[   36.263183] PVR_K:   (MKT-57) 067B64CB 001199AD 00000000 0F039D00
[   36.270080] PVR_K:   (MKT-58) 067B64E5 001089AB 00000000 00000060
[   36.278930] PVR_K:   (MKT-59) 067B6840 001009A9 0000271E AD000803
[   36.285430] PVR_K:   (MKT-5A) 067B6894 001808ED 0000271E AD000282
[   36.303588] PVR_K:   (MKT-5B) 067B6A03 001089AF 0100291F AD000200
[   36.309997] PVR_K:   (MKT-5C) 067B6C7E 001089AF 0000291F AD000202
[   36.323059] PVR_K:   (MKT-5D) 067B6D1A 001099A9 00002A1E AD000183
[   36.334808] PVR_K:   (MKT-5E) 067B6D91 001089AB 00002A1E AD000184
[   36.341217] PVR_K:   (MKT-5F) 067B6DFB 00108DAB 01002B1D AD000281
[   36.359436] PVR_K:   (MKT-60) 067B6FED 001009AF 01002B1D AD00080A
[   36.373901] PVR_K:   (MKT-61) 067B700A 001199AB 01002B1D 0F03A000
[   36.380371] PVR_K:   (MKT-62) 067B7027 001199AF 01002B1D 00000062
[   36.389862] PVR_K:   (MKT-63) 067B7362 001008AB 00002B1D AD000803
[   36.396362] PVR_K:   (MKT-64) 067B73B5 00180CAF 00002B1D AD000282
[   36.403106] PVR_K:   (MKT-65) 0CFF074F 00100808 0100031F AD000B00
[   36.409637] PVR_K:   (MKT-66) 0CFF0794 00100808 0100031F AD000B03
[   36.416168] PVR_K:   (MKT-67) 0CFF0827 00100808 0100031F AD000B04
[   36.422668] PVR_K:   (MKT-68) 0CFF086B 00100808 0100031F AD000B05
[   36.429199] PVR_K:   (MKT-69) 0CFF08C1 00100808 0100031F AD000B06
[   36.437957] PVR_K:   (MKT-6A) 0CFF0905 00100808 0100031F AD000B07
[   36.452026] PVR_K:   (MKT-6B) 0CFF092A 00100808 0100031F AD000B09
[   36.458496] PVR_K:   (MKT-6C) 0CFF0981 00100808 0100031F AD000B01
[   36.466674] PVR_K:   (MKT-6D) 0CFF09BD 00100808 0100031F AD002300
[   36.473266] PVR_K:   (MKT-6E) 0CFF0CBB 00100808 0100041F AD00000A
[   36.480682] PVR_K:   (MKT-6F) 0CFF0D3A 00100808 0100041F AD000906
[   36.487335] PVR_K:   (MKT-70) 0CFF0DF4 00100808 0000041F AD000901
[   36.493774] PVR_K:   (MKT-71) 0CFF0E72 00100808 0000051E AD000183
[   36.500183] PVR_K:   (MKT-72) 0CFF0FEB 00100808 0000051E AD000302
[   36.509460] PVR_K:   (MKT-73) 0CFF1045 00100808 0000051E AD000303
[   36.517059] PVR_K:   (MKT-74) 0CFF10BE 00100808 0000051E AD000C01
[   36.524383] PVR_K:   (MKT-75) 0CFF10E2 00100808 0000051E 0D800484
[   36.530822] PVR_K:   (MKT-76) 0CFF10FA 00100808 0000051E 00000002
[   36.539276] PVR_K:   (MKT-77) 0CFF12F8 00100808 0000051E AD000184
[   36.547119] PVR_K:   (MKT-78) 0CFF137A 00100C08 0100061D AD000281
[   36.561370] PVR_K:   (MKT-79) 0CFF14BB 00100808 0100061D AD001000
[   36.567779] PVR_K:   (MKT-7A) 0CFF1F6E 00100808 0000061D AD000282
[   36.579406] PVR_K:   (MKT-7B) 0CFF201D 00100808 0000081E AD000183
[   36.585968] PVR_K:   (MKT-7C) 0CFF2125 00100808 0000081E AD00030E
[   36.592529] PVR_K:   (MKT-7D) 0CFF213D 00100808 0000081E 0D800474
[   36.599182] PVR_K:   (MKT-7E) 0CFF2157 00100808 0000081E 00000001
[   36.605682] PVR_K:   (MKT-7F) 0CFF217A 00100808 0000081E 00000002
[   36.612457] PVR_K:   (MKT-80) 0CFF21E5 00100808 0000081E AD000184
[   36.618988] PVR_K:   (MKT-81) 0CFF2255 00100C08 0100091C AD000281
[   36.625579] PVR_K:   (MKT-82) 0CFF23E2 00100808 0100091C AD00080A
[   36.632141] PVR_K:   (MKT-83) 0CFF23FB 00100808 0100091C 0F03A300
[   36.638763] PVR_K:   (MKT-84) 0CFF2413 00100808 0100091C 00000061
[   36.645294] PVR_K:   (MKT-85) 0CFF24D4 00100808 0100091C AD001300
[   36.651885] PVR_K:   (MKT-86) 0CFF78A6 00100808 0000091C AD001301
[   36.658416] PVR_K:   (MKT-87) 0CFF79A9 00100808 0000091C AD000802
[   36.665039] PVR_K:   (MKT-88) 0CFF7B05 00100808 0000091C AD000803
[   36.671600] PVR_K:   (MKT-89) 0CFF7B4B 00184AC8 0000091C AD000282
[   36.678131] PVR_K:   (MKT-8A) 0CFF7C32 00180CB8 00000A1F AD00000A
[   36.684814] PVR_K:   (MKT-8B) 0CFF7CAD 00180838 00000A1F AD000905
[   36.691528] PVR_K:   (MKT-8C) 0CFF7DC7 001808B8 00000A1F AD000901
[   36.698059] PVR_K:   (MKT-8D) 0CFF7E3D 00180838 00000B1E AD00000A
[   36.704620] PVR_K:   (MKT-8E) 0CFF7EB4 00180838 00000B1E AD000906
[   36.714721] PVR_K:   (MKT-8F) 0CFF7F32 00180838 00000B1E AD000901
[   36.733245] PVR_K:   (MKT-90) 0CFF7F88 00180838 00000C1D AD00000A
[   36.739715] PVR_K:   (MKT-91) 0CFF7FEA 00180838 00000C1D AD000905
[   36.755706] PVR_K:   (MKT-92) 0CFF8094 00180838 00000C1D AD000901
[   36.772308] PVR_K:   (MKT-93) 0CFF80EE 00180838 00000D1B AD00000A
[   36.778717] PVR_K:   (MKT-94) 0CFF814D 00180838 00000D1B AD000905
[   36.795776] PVR_K:   (MKT-95) 0CFF81F1 00180838 00000D1B AD000901
[   36.802185] PVR_K:   (MKT-96) 0CFF8246 00180838 00000E1A AD00000A
[   36.819183] PVR_K:   (MKT-97) 0CFF82A7 00180838 00000E1A AD000905
[   36.825592] PVR_K:   (MKT-98) 0CFF8350 00180838 00000E1A AD000901
[   36.842651] PVR_K:   (MKT-99) 0CFF849F 00180838 0000111C AD000183
[   36.849060] PVR_K:   (MKT-9A) 0CFF8608 00180838 0000111C AD000302
[   36.859405] PVR_K:   (MKT-9B) 0CFF867B 00180838 0000111C AD000303
[   36.873870] PVR_K:   (MKT-9C) 0CFF86F9 00180838 0000111C AD000C01
[   36.889495] PVR_K:   (MKT-9D) 0CFF8726 00180838 0000111C 0D800464
[   36.895904] PVR_K:   (MKT-9E) 0CFF8740 00180838 0000111C 00000003
[   36.912933] PVR_K:   (MKT-9F) 0CFF895E 00180838 0000111C AD000184
[   36.919403] PVR_K:   (MKT-A0) 0CFF89C9 00180C38 01001217 AD000281
[   36.936401] PVR_K:   (MKT-A1) 0CFF8A1F 00180838 01001217 AD000282
[   36.942840] PVR_K:   (MKT-A2) 0CFF95EA 00180838 0100131F AD00000A
[   36.959503] PVR_K:   (MKT-A3) 0CFF9656 00180838 0100131F AD000905
[   36.975463] PVR_K:   (MKT-A4) 0CFF9761 00180838 0000131F AD000901
[   36.981872] PVR_K:   (MKT-A5) 0CFF97B2 00180C38 0100141E AD000281
[   36.998901] PVR_K:   (MKT-A6) 0CFF9809 00180838 0100141E AD000282
[   37.005310] PVR_K:   (MKT-A7) 0CFF9A15 00180838 0100151F AD00000A
[   37.013305] PVR_K:   (MKT-A8) 0CFF9A80 00180838 0100151F AD000905
[   37.030120] PVR_K:   (MKT-A9) 0CFF9B79 00100828 0000151F AD000901
[   37.031036] adc_to_temp_conversion:Temp read is invalid 0
[   37.031066] thermal_lookup_temp: getting temp is not supported for domain pcb
[   37.031921] adc_to_temp_conversion:Temp read is invalid 0
[   37.031921] thermal_lookup_temp: getting temp is not supported for domain pcb
[   37.032775] adc_to_temp_conversion:Temp read is invalid 0
[   37.032775] thermal_lookup_temp: getting temp is not supported for domain pcb
[   37.087707] PVR_K:   (MKT-AA) 0CFF9BCB 00000C08 0000161E AD000281
[   37.100463] PVR_K:   (MKT-AB) 0CFF9C20 00000808 0000161E AD000282
[   37.106872] PVR_K:   (MKT-AC) 0CFF9C6F 00000808 0100171F AD000200
[   37.122497] PVR_K:   (MKT-AD) 0CFF9EB9 00000808 0000171F AD000202
[   37.139526] PVR_K:   (MKT-AE) 0CFF9F63 00000808 0000181E AD00000A
[   37.145996] PVR_K:   (MKT-AF) 0CFF9FCB 00000808 0000181E AD000905
[   37.158111] PVR_K:   (MKT-B0) 0CFFA0B8 00000808 0000181E AD000901
[   37.170776] PVR_K:   (MKT-B1) 0CFFA109 00000C08 0000191D AD000281
[   37.177185] PVR_K:   (MKT-B2) 0CFFA26B 00000808 0000191D AD00080A
[   37.194702] PVR_K:   (MKT-B3) 0CFFA283 00000808 0000191D 0F03A600
[   37.204498] PVR_K:   (MKT-B4) 0CFFA29B 00000808 0000191D 00000060
[   37.210968] PVR_K:   (MKT-B5) 0CFFA55A 00000808 0000191D AD000803
[   37.217590] PVR_K:   (MKT-B6) 0CFFA5A3 00180CC8 0000191D AD000282
[   37.224548] PVR_K:   (MKT-B7) 0CFFA65A 00000808 00001A1F AD00000A
[   37.241088] PVR_K:   (MKT-B8) 0CFFA6C5 00000808 00001A1F AD000905
[   37.247528] PVR_K:   (MKT-B9) 0CFFA7BA 00000888 00001A1F AD000901
[   37.272338] PVR_K:   (MKT-BA) 0CFFA803 00000C08 00001C1D AD000200
[   37.278747] PVR_K:   (MKT-BB) 0CFFAA31 00000808 00001C1D AD000202
[   37.290405] PVR_K:   (MKT-BC) 0CFFAA89 00000808 01001D1C AD000281
[   37.299438] PVR_K:   (MKT-BD) 0CFFABD2 00000808 01001D1C AD00080A
[   37.305938] PVR_K:   (MKT-BE) 0CFFABEA 00000808 01001D1C 0F03A900
[   37.312469] PVR_K:   (MKT-BF) 0CFFAC03 00000808 01001D1C 00000060
[   37.318969] PVR_K:   (MKT-C0) 0CFFAEC8 00000808 00001D1C AD000803
[   37.325469] PVR_K:   (MKT-C1) 0CFFAF0F 00180CC8 00001D1C AD000282
[   37.332000] PVR_K:   (MKT-C2) 0CFFAFF8 00000808 01001F1F AD000200
[   37.338836] PVR_K:   (MKT-C3) 0CFFB21D 00000888 01001F1F AD000202
[   37.345428] PVR_K:   (MKT-C4) 0CFFB26E 00000808 0100201E AD000281
[   37.351928] PVR_K:   (MKT-C5) 0CFFB3C0 00000808 0100201E AD00080A
[   37.358367] PVR_K:   (MKT-C6) 0CFFB3D8 00000808 0100201E 0F03AC00
[   37.364837] PVR_K:   (MKT-C7) 0CFFB3F1 00000808 0100201E 00000062
[   37.371612] PVR_K:   (MKT-C8) 0CFFB6B1 00000808 0000201E AD000803
[   37.378112] PVR_K:   (MKT-C9) 0CFFB6F7 00180C88 0000201E AD000282
[   37.384582] PVR_K:   (MKT-CA) 0CFFC219 00000808 0100221F AD000200
[   37.391082] PVR_K:   (MKT-CB) 0CFFC33C 00000808 0100221F AD001703
[   37.398010] PVR_K:   (MKT-CC) 0CFFC53B 00000888 0000221F AD000202
[   37.404632] PVR_K:   (MKT-CD) 0CFFC5B9 00000808 0000231E AD000183
[   37.411193] PVR_K:   (MKT-CE) 0CFFC6A8 00000808 0000231E AD00030E
[   37.417694] PVR_K:   (MKT-CF) 0CFFC6C0 00000808 0000231E 0D800494
[   37.424163] PVR_K:   (MKT-D0) 0CFFC6D8 00000808 0000231E 00000001
[   37.430664] PVR_K:   (MKT-D1) 0CFFC705 00000808 0000231E 00000002
[   37.437103] PVR_K:   (MKT-D2) 0CFFC772 00000808 0000231E AD000184
[   37.443572] PVR_K:   (MKT-D3) 0CFFC7D5 00000C08 0000241D AD000281
[   37.450073] PVR_K:   (MKT-D4) 0CFFC94D 00000808 0000241D AD00080A
[   37.460052] PVR_K:   (MKT-D5) 0CFFC966 00000808 0000241D 0F03AF00
[   37.467956] PVR_K:   (MKT-D6) 0CFFC97E 00000808 0000241D 00000061
[   37.474365] PVR_K:   (MKT-D7) 0CFFCAF9 00000808 0000241D AD000802
[   37.480865] PVR_K:   (MKT-D8) 0CFFCC4A 00000808 0000241D AD000803
[   37.487365] PVR_K:   (MKT-D9) 0CFFCC8F 00184EC8 0000241D AD000282
[   37.493835] PVR_K:   (MKT-DA) 0CFFEC51 00000C08 0100271F AD000200
[   37.500274] PVR_K:   (MKT-DB) 0CFFEEA8 00000808 0000271F AD000202
[   37.506774] PVR_K:   (MKT-DC) 0CFFEF30 00000808 0000281E AD000183
[   37.513305] PVR_K:   (MKT-DD) 0CFFF018 00000808 0000281E AD00030E
[   37.519805] PVR_K:   (MKT-DE) 0CFFF030 00000808 0000281E 0D800494
[   37.526275] PVR_K:   (MKT-DF) 0CFFF048 00000808 0000281E 00000001
[   37.532745] PVR_K:   (MKT-E0) 0CFFF06B 00000808 0000281E 00000002
[   37.539276] PVR_K:   (MKT-E1) 0CFFF0D8 00000808 0000281E AD000184
[   37.545776] PVR_K:   (MKT-E2) 0CFFF13E 00000C08 0100291D AD000281
[   37.552215] PVR_K:   (MKT-E3) 0CFFF2B2 00000808 0100291D AD00080A
[   37.558715] PVR_K:   (MKT-E4) 0CFFF2CA 00000808 0100291D 0F03B200
[   37.565277] PVR_K:   (MKT-E5) 0CFFF2E3 00000808 0100291D 00000060
[   37.571868] PVR_K:   (MKT-E6) 0CFFF5AA 00000808 0000291D AD000803
[   37.578369] PVR_K:   (MKT-E7) 0CFFF5F6 00188CC8 0000291D AD000282
[   37.584808] PVR_K:   (MKT-E8) 0CFFF69A 00000808 01002B1F AD000200
[   37.591308] PVR_K:   (MKT-E9) 0CFFF8B7 00000808 00002B1F AD000202
[   37.597930] PVR_K:   (MKT-EA) 0CFFF936 00000808 00002C1E AD000183
[   37.604614] PVR_K:   (MKT-EB) 0CFFFA21 00000808 00002C1E AD00030E
[   37.611114] PVR_K:   (MKT-EC) 0CFFFA39 00000808 00002C1E 0D800494
[   37.617797] PVR_K:   (MKT-ED) 0CFFFA52 00000808 00002C1E 00000001
[   37.625671] PVR_K:   (MKT-EE) 0CFFFA76 00000808 00002C1E 00000002
[   37.632171] PVR_K:   (MKT-EF) 0CFFFAE1 00000808 00002C1E AD000184
[   37.638641] PVR_K:   (MKT-F0) 0CFFFB45 00000C08 01002D1D AD000281
[   37.645324] PVR_K:   (MKT-F1) 0CFFFCB1 00000808 01002D1D AD00080A
[   37.651794] PVR_K:   (MKT-F2) 0CFFFCCA 00000808 01002D1D 0F03B500
[   37.658264] PVR_K:   (MKT-F3) 0CFFFCE3 00000808 01002D1D 00000060
[   37.664764] PVR_K:   (MKT-F4) 0CFFFF95 00000808 00002D1D AD000803
[   37.671386] PVR_K:   (MKT-F5) 0CFFFFDC 00180CC8 00002D1D AD000282
[   37.678131] PVR_K:   (MKT-F6) 0D0000C3 00000808 01002F1F AD000200
[   37.684600] PVR_K:   (MKT-F7) 0D0002DD 00000808 00002F1F AD000202
[   37.691101] PVR_K:   (MKT-F8) 0D00035B 00000808 0000301E AD000183
[   37.697540] PVR_K:   (MKT-F9) 0D000448 00000808 0000301E AD00030E
[   37.704040] PVR_K:   (MKT-FA) 0D000460 00000808 0000301E 0D800494
[   37.710510] PVR_K:   (MKT-FB) 0D000479 00000808 0000301E 00000001
[   37.716979] PVR_K:   (MKT-FC) 0D00049D 00000808 0000301E 00000002
[   37.723449] PVR_K:   (MKT-FD) 0D00050A 00000808 0000301E AD000184
[   37.729980] PVR_K:   (MKT-FE) 0D00056E 00000C08 0100311D AD000281
[   37.737365] PVR_K:   (MKT-FF) 0D0006E6 00000808 0100311D AD00080A
[   37.743896] PVR_K:   (MKT-100) 0D0006FF 00000808 0100311D 0F03B800
[   37.750457] PVR_K:   (MKT-101) 0D000717 00000808 0100311D 00000062
[   37.757507] PVR_K:   (MKT-102) 0D0009C6 00000808 0000311D AD000803
[   37.772308] PVR_K:   (MKT-103) 0D000A11 00180C88 0000311D AD000282
[   37.778808] PVR_K:   (MKT-104) 0D001547 00000808 0100331F AD000200
[   37.786804] PVR_K:   (MKT-105) 0D001662 00000808 0100331F AD001703
[   37.803558] PVR_K:   (MKT-106) 0D001843 00000808 0000331F AD000202
[   37.810089] PVR_K:   (MKT-107) 0D0018C3 00000808 0000341E AD000183
[   37.819763] PVR_K:   (MKT-108) 0D0019AC 00000808 0000341E AD00030E
[   37.829437] PVR_K:   (MKT-109) 0D0019C4 00000808 0000341E 0D800494
[   37.842041] PVR_K:   (MKT-10A) 0D0019DD 00000808 0000341E 00000001
[   37.853607] PVR_K:   (MKT-10B) 0D001A00 00000808 0000341E 00000002
[   37.862915] PVR_K:   (MKT-10C) 0D001A6A 00000808 0000341E AD000184
[   37.869842] PVR_K:   (MKT-10D) 0D001AD0 00000C08 0100351D AD000281
[   37.881652] PVR_K:   (MKT-10E) 0D001BE1 00000808 0100351D AD000E02
[   37.888214] PVR_K:   (MKT-10F) 0D001C52 00000808 0100351D AD000282
[   37.895782] PVR_K:   (MKT-110) 0D00DEAB 00000808 0100381F AD001A00
[   37.906433] PVR_K:   (MKT-111) 0D00E1D6 00000808 0100391F AD00000A
[   37.919494] PVR_K:   (MKT-112) 0D00E238 00000808 0100391F AD000909
[   37.928802] PVR_K:   (MKT-113) 0D00E282 00000808 0100391F AD001A05
[   37.939910] PVR_K:   (MKT-114) 0D00E2B4 00000808 0100391F AD001302
[   37.951995] PVR_K:   (MKT-115) 0D00E2F4 00000808 0100391F AD001303
[   37.958526] PVR_K:   (MKT-116) 0D00E386 00000808 0100391F AD000D04
[   37.969970] PVR_K:   (MKT-117) 0D00E44F 00000808 0100391F AD000D05
[   37.980346] PVR_K:   (MKT-118) 0D00E4A9 00000808 0100391F AD000D04
[   37.988311] PVR_K:   (MKT-119) 0D00E531 00000808 0100391F AD000D05
[   38.000946] PVR_K:   (MKT-11A) 0D00E590 00000808 0100391F AD001A06
[   38.008361] PVR_K:   (MKT-11B) 0000047C 00100808 0100031F AD002300
[   38.022338] PVR_K:   (MKT-11C) 00000965 00100808 0100041F AD00000A
[   38.028869] PVR_K:   (MKT-11D) 000009E2 00100808 0100041F AD000906
[   38.038818] adc_to_temp_conversion:Temp read is invalid 0
[   38.044006] PVR_K:   (MKT-11E) 00000AB4 00100808 0000041F AD000901
[   38.044006] PVR_K:   (MKT-11F) 00000B32 00100808 0000051E AD000183
[   38.044036] PVR_K:   (MKT-120) 00000CA7 00100808 0000051E AD000302
[   38.044036] PVR_K:   (MKT-121) 00000E29 00100808 0000051E AD000D06
[   38.044036] PVR_K:   (MKT-122) 00000F10 00100808 0000051E AD000D07
[   38.044067] PVR_K:   (MKT-123) 00000F59 00100808 0000051E AD001304
[   38.044067] PVR_K:   (MKT-124) 00001044 00100808 0000051E AD001305
[   38.044067] PVR_K:   (MKT-125) 00001154 00100888 0000051E AD000404
[   38.044097] PVR_K:   (MKT-126) 00001217 00100808 0000051E AD000402
[   38.044097] PVR_K:   (MKT-127) 00001260 0010082B 0000051E AD000184
[   38.044097] PVR_K:   (MKT-128) 000012EB 00108DA9 0000061D AD000281
[   38.044128] PVR_K:   (MKT-129) 0000146A 001199AD 0000061D AD000E02
[   38.044128] PVR_K:   (MKT-12A) 000014C9 001199A9 0000061D AD000282
[   38.044128] PVR_K:   (MKT-12B) 00003AAE 00100808 0000081F AD000101
[   38.044128] PVR_K:   (MKT-12C) 00003B25 00100808 0000081F AD000104
[   38.044158] PVR_K:   (MKT-12D) 00003B63 00100808 0100091E AD000100
[   38.044158] PVR_K:   (MKT-12E) 00003C69 00100808 0100091E AD000501
[   38.044158] PVR_K:   (MKT-12F) 00003CA9 0010082B 0100091E AD000104
[   38.044189] PVR_K:   (MKT-130) 00005F7F 00100828 01000A1F AD000101
[   38.044189] PVR_K:   (MKT-131) 00005FC4 00100828 01000A1F AD000104
[   38.044189] PVR_K:   (MKT-132) 000060DB 00100808 01000B1F AD000100
[   38.044219] PVR_K:   (MKT-133) 000061A0 00100808 01000B1F AD000501
[   38.044219] PVR_K:   (MKT-134) 000061CC 00100829 01000B1F AD000104
[   38.044219] PVR_K:   (MKT-135) 000086F6 00100828 01000D1F AD000101
[   38.044250] PVR_K:   (MKT-136) 0000876D 00100828 01000D1F AD000104
[   38.044250] PVR_K:   (MKT-137) 000087AA 00100808 01000E1E AD000100
[   38.044250] PVR_K:   (MKT-138) 000088AA 00100808 01000E1E AD000501
[   38.044281] PVR_K:   (MKT-139) 000088E9 00100829 01000E1E AD000104
[   38.044281] PVR_K:   (MKT-13A) 0737C0BF 00100808 0100031F AD000B00
[   38.044281] PVR_K:   (MKT-13B) 0737C104 00100808 0100031F AD000B03
[   38.044281] PVR_K:   (MKT-13C) 0737C189 00100808 0100031F AD000B05
[   38.044311] PVR_K:   (MKT-13D) 0737C1DD 00100808 0100031F AD000B06
[   38.044311] PVR_K:   (MKT-13E) 0737C20D 00100808 0100031F AD000B06
[   38.044311] PVR_K:   (MKT-13F) 0737C250 00100808 0100031F AD000B07
[   38.044342] PVR_K:   (MKT-140) 0737C275 00100808 0100031F AD000B09
[   38.044342] PVR_K:   (MKT-141) 0737C2CA 00100808 0100031F AD000B01
[   38.044342] PVR_K:   (MKT-142) 0737C306 00100808 0100031F AD002300
[   38.044372] PVR_K:   (MKT-143) 0737C61E 00100808 0100041F AD00000A
[   38.044372] PVR_K:   (MKT-144) 0737C69C 00100808 0100041F AD000906
[   38.044372] PVR_K:   (MKT-145) 0737C759 00100808 0000041F AD000901
[   38.044403] PVR_K:   (MKT-146) 0737C7D5 00100808 0000051E AD000183
[   38.044403] PVR_K:   (MKT-147) 0737C944 00100808 0000051E AD000302
[   38.044403] PVR_K:   (MKT-148) 0737C996 00100808 0000051E AD000303
[   38.044403] PVR_K:   (MKT-149) 0737CA1C 00100808 0000051E AD000C01
[   38.044433] PVR_K:   (MKT-14A) 0737CA41 00100808 0000051E 0D800484
[   38.044433] PVR_K:   (MKT-14B) 0737CA5A 00100808 0000051E 00000003
[   38.044433] PVR_K:   (MKT-14C) 0737CCAF 00100808 0000051E AD00030E
[   38.044464] PVR_K:   (MKT-14D) 0737CCC7 00100808 0000051E 0D800474
[   38.044464] PVR_K:   (MKT-14E) 0737CCE0 00100808 0000051E 00000002
[   38.044464] PVR_K:   (MKT-14F) 0737CD04 00100808 0000051E 00000003
[   38.044494] PVR_K:   (MKT-150) 0737CD7C 00100808 0000051E AD000184
[   38.044494] PVR_K:   (MKT-151) 0737CE01 00100C08 0100061D AD000281
[   38.044494] PVR_K:   (MKT-152) 0737CF97 00100808 0100061D AD00080A
[   38.044525] PVR_K:   (MKT-153) 0737CFAF 00100808 0100061D 0F03BB00
[   38.044525] PVR_K:   (MKT-154) 0737CFC7 00100808 0100061D 00000061
[   38.044525] PVR_K:   (MKT-155) 0737D0DE 00100C88 0100061D AD001300
[   38.044525] PVR_K:   (MKT-156) 073824DB 00100808 0000061D AD001301
[   38.044555] PVR_K:   (MKT-157) 07382602 00100888 0000061D AD000802
[   38.044555] PVR_K:   (MKT-158) 07382766 00100888 0000061D AD000803
[   38.044555] PVR_K:   (MKT-159) 073827B3 001808C8 0000061D AD000282
[   38.044586] PVR_K:   (MKT-15A) 07382895 00184AF8 0000081E AD00000A
[   38.044586] PVR_K:   (MKT-15B) 0738291C 00184AF8 0000081E AD000905
[   38.044586] PVR_K:   (MKT-15C) 07382A3D 001808B8 0000081E AD000901
[   38.044616] PVR_K:   (MKT-15D) 07382AB6 00180838 0000091C AD00000A
[   38.044616] PVR_K:   (MKT-15E) 07382B24 00180838 0000091C AD000905
[   38.044616] PVR_K:   (MKT-15F) 07382BD3 00180838 0000091C AD000901
[   38.044647] PVR_K:   (MKT-160) 07382C2B 00180838 00000A1B AD00000A
[   38.044647] PVR_K:   (MKT-161) 07382C97 00180838 00000A1B AD000906
[   38.044647] PVR_K:   (MKT-162) 07382D0C 00180838 00000A1B AD000901
[   38.044647] PVR_K:   (MKT-163) 07382D60 00180838 00000B1A AD00000A
[   38.044677] PVR_K:   (MKT-164) 07382DC2 00180838 00000B1A AD000905
[   38.044677] PVR_K:   (MKT-165) 07382E71 00180838 00000B1A AD000901
[   38.044677] PVR_K:   (MKT-166) 07382EC8 00180838 00000C19 AD00000A
[   38.044708] PVR_K:   (MKT-167) 07382F33 00180838 00000C19 AD000905
[   38.044708] PVR_K:   (MKT-168) 07382FEB 00180838 00000C19 AD000901
[   38.044708] PVR_K:   (MKT-169) 0738313E 00180838 00000F1F AD000183
[   38.044738] PVR_K:   (MKT-16A) 073832BA 00180838 00000F1F AD000302
[   38.044738] PVR_K:   (MKT-16B) 0738332C 00180838 00000F1F AD000303
[   38.044738] PVR_K:   (MKT-16C) 073833B0 00180838 00000F1F AD000C01
[   38.044769] PVR_K:   (MKT-16D) 073833D4 00180838 00000F1F 0D800464
[   38.044769] PVR_K:   (MKT-16E) 073833ED 00180838 00000F1F 00000004
[   38.044769] PVR_K:   (MKT-16F) 07383608 00180838 00000F1F AD000184
[   38.044769] PVR_K:   (MKT-170) 07383678 00180C38 0100101D AD000281
[   38.044799] PVR_K:   (MKT-171) 073836CE 00180838 0100101D AD000282
[   38.044799] PVR_K:   (MKT-172) 07384226 00180838 0100111F AD00000A
[   38.044799] PVR_K:   (MKT-173) 07384290 00180838 0100111F AD000905
[   38.044830] PVR_K:   (MKT-174) 07384394 00180838 0000111F AD000901
[   38.044830] PVR_K:   (MKT-175) 073843E5 00180C38 0100121E AD000281
[   38.044830] PVR_K:   (MKT-176) 0738443B 00180838 0100121E AD000282
[   38.044860] PVR_K:   (MKT-177) 073844F7 00180838 0100131F AD00000A
[   38.044860] PVR_K:   (MKT-178) 07384561 00180838 0100131F AD000905
[   38.044860] PVR_K:   (MKT-179) 0738465C 00180838 0000131F AD000901
[   38.044891] PVR_K:   (MKT-17A) 073846AF 00180C38 0100141E AD000281
[   38.044891] PVR_K:   (MKT-17B) 07384708 00180838 0100141E AD000282
[   38.044891] PVR_K:   (MKT-17C) 07384823 00100828 0100151F AD00000A
[   38.044891] PVR_K:   (MKT-17D) 07384894 00100828 0100151F AD000905
[   38.044921] PVR_K:   (MKT-17E) 07384990 00000808 0000151F AD000901
[   38.044921] PVR_K:   (MKT-17F) 073849C8 00000C08 0000161E AD000200
[   38.044921] PVR_K:   (MKT-180) 07384C1A 00000808 0000161E AD000202
[   38.044952] PVR_K:   (MKT-181) 07384C73 00000808 0000171D AD000281
[   38.044952] PVR_K:   (MKT-182) 07384DC2 00000808 0000171D AD00080A
[   38.044952] PVR_K:   (MKT-183) 07384DDB 00000808 0000171D 0F03BE00
[   38.044982] PVR_K:   (MKT-184) 07384DF3 00000808 0000171D 00000060
[   38.044982] PVR_K:   (MKT-185) 073850B6 00000808 0000171D AD000803
[   38.044982] PVR_K:   (MKT-186) 07385100 00180CC8 0000171D AD000282
[   38.045013] PVR_K:   (MKT-187) 073851C3 00000808 0000181F AD00000A
[   38.045013] PVR_K:   (MKT-188) 0738522B 00000808 0000181F AD000905
[   38.045013] PVR_K:   (MKT-189) 07385323 00000888 0000181F AD000901
[   38.045013] PVR_K:   (MKT-18A) 0738536D 00000C08 00001A1D AD000200
[   38.045043] PVR_K:   (MKT-18B) 073855AB 00000808 00001A1D AD000202
[   38.045043] PVR_K:   (MKT-18C) 07385602 00000808 01001B1C AD000281
[   38.045043] PVR_K:   (MKT-18D) 0738574E 00000808 01001B1C AD00080A
[   38.045074] PVR_K:   (MKT-18E) 07385767 00000808 01001B1C 0F03C100
[   38.045074] PVR_K:   (MKT-18F) 0738577F 00000808 01001B1C 00000060
[   38.045074] PVR_K:   (MKT-190) 07385A39 00000808 00001B1C AD000803
[   38.045104] PVR_K:   (MKT-191) 07385A7E 00180CC8 00001B1C AD000282
[   38.045104] PVR_K:   (MKT-192) 07385B69 00000808 01001D1F AD000200
[   38.045104] PVR_K:   (MKT-193) 07385D91 00000808 00001D1F AD000202
[   38.045135] PVR_K:   (MKT-194) 07385DE1 00000808 01001E1E AD000281
[   38.045135] PVR_K:   (MKT-195) 07385F31 00000808 01001E1E AD00080A
[   38.045135] PVR_K:   (MKT-196) 07385F49 00000808 01001E1E 0F03C400
[   38.045135] PVR_K:   (MKT-197) 07385F61 00000808 01001E1E 00000062
[   38.045166] PVR_K:   (MKT-198) 0738620C 00000808 00001E1E AD000803
[   38.045166] PVR_K:   (MKT-199) 07386251 00180C88 00001E1E AD000282
[   38.045166] PVR_K:   (MKT-19A) 07386D4B 00000808 0100201F AD000200
[   38.045196] PVR_K:   (MKT-19B) 07386E68 00000808 0100201F AD001703
[   38.045196] PVR_K:   (MKT-19C) 0738706A 00000808 0000201F AD000202
[   38.045196] PVR_K:   (MKT-19D) 073870E7 00000808 0000211E AD000183
[   38.045227] PVR_K:   (MKT-19E) 073871D2 00000808 0000211E AD00030E
[   38.045227] PVR_K:   (MKT-19F) 073871EA 00000808 0000211E 0D800494
[   38.045227] PVR_K:   (MKT-1A0) 07387203 00000808 0000211E 00000002
[   38.045257] PVR_K:   (MKT-1A1) 07387226 00000808 0000211E 00000003
[   38.045257] PVR_K:   (MKT-1A2) 07387293 00000808 0000211E AD000184
[   38.045257] PVR_K:   (MKT-1A3) 073872F7 00000C08 0100221D AD000281
[   38.045257] PVR_K:   (MKT-1A4) 0738746C 00000808 0100221D AD00080A
[   38.045288] PVR_K:   (MKT-1A5) 07387485 00000808 0100221D 0F03C700
[   38.045288] PVR_K:   (MKT-1A6) 0738749D 00000808 0100221D 00000061
[   38.045288] PVR_K:   (MKT-1A7) 07387611 00000808 0000221D AD000802
[   38.045318] PVR_K:   (MKT-1A8) 0738775F 00000808 0000221D AD000803
[   38.045318] PVR_K:   (MKT-1A9) 073877A4 00184EC8 0000221D AD000282
[   38.045318] PVR_K:   (MKT-1AA) 073896ED 00000C08 0100251F AD000200
[   38.045349] PVR_K:   (MKT-1AB) 0738993A 00000808 0000251F AD000202
[   38.045349] PVR_K:   (MKT-1AC) 073899C2 00000808 0000261E AD000183
[   38.045349] PVR_K:   (MKT-1AD) 07389AAC 00000808 0000261E AD00030E
[   38.045349] PVR_K:   (MKT-1AE) 07389AC4 00000808 0000261E 0D800494
[   38.045379] PVR_K:   (MKT-1AF) 07389ADC 00000808 0000261E 00000002
[   38.045379] PVR_K:   (MKT-1B0) 07389B00 00000808 0000261E 00000003
[   38.045379] PVR_K:   (MKT-1B1) 07389B6A 00000808 0000261E AD000184
[   38.045410] PVR_K:   (MKT-1B2) 07389BCF 00000C08 0100271D AD000281
[   38.045410] PVR_K:   (MKT-1B3) 07389D39 00000808 0100271D AD00080A
[   38.045410] PVR_K:   (MKT-1B4) 07389D51 00000808 0100271D 0F03CA00
[   38.045440] PVR_K:   (MKT-1B5) 07389D6A 00000808 0100271D 00000060
[   38.045440] PVR_K:   (MKT-1B6) 0738A01A 00000808 0000271D AD000803
[   38.045440] PVR_K:   (MKT-1B7) 0738A05F 00180CC8 0000271D AD000282
[   38.045471] PVR_K:   (MKT-1B8) 0738A135 00000808 0100291F AD000200
[   38.045471] PVR_K:   (MKT-1B9) 0738A34D 00000808 0000291F AD000202
[   38.045471] PVR_K:   (MKT-1BA) 0738A3CA 00000808 00002A1E AD000183
[   38.045471] PVR_K:   (MKT-1BB) 0738A4B2 00000808 00002A1E AD00030E
[   38.045501] PVR_K:   (MKT-1BC) 0738A4CA 00000808 00002A1E 0D800494
[   38.045501] PVR_K:   (MKT-1BD) 0738A4E3 00000808 00002A1E 00000002
[   38.045501] PVR_K:   (MKT-1BE) 0738A506 00000808 00002A1E 00000003
[   38.045532] PVR_K:   (MKT-1BF) 0738A573 00000808 00002A1E AD000184
[   38.045532] PVR_K:   (MKT-1C0) 0738A5D6 00000C08 01002B1D AD000281
[   38.045532] PVR_K:   (MKT-1C1) 0738A73D 00000808 01002B1D AD00080A
[   38.045562] PVR_K:   (MKT-1C2) 0738A756 00000808 01002B1D 0F03CD00
[   38.045562] PVR_K:   (MKT-1C3) 0738A76E 00000808 01002B1D 00000060
[   38.045562] PVR_K:   (MKT-1C4) 0738AA1E 00000808 00002B1D AD000803
[   38.045593] PVR_K:   (MKT-1C5) 0738AA63 00188CC8 00002B1D AD000282
[   38.045593] PVR_K:   (MKT-1C6) 0738AB53 00000808 01002D1F AD000200
[   38.045593] PVR_K:   (MKT-1C7) 0738AD6E 00000808 00002D1F AD000202
[   38.045593] PVR_K:   (MKT-1C8) 0738ADF1 00000808 00002E1E AD000183
[   38.045623] PVR_K:   (MKT-1C9) 0738AEDA 00000808 00002E1E AD00030E
[   38.045623] PVR_K:   (MKT-1CA) 0738AEF3 00000808 00002E1E 0D800494
[   38.045623] PVR_K:   (MKT-1CB) 0738AF0B 00000808 00002E1E 00000002
[   38.045654] PVR_K:   (MKT-1CC) 0738AF2F 00000808 00002E1E 00000003
[   38.045654] PVR_K:   (MKT-1CD) 0738AF98 00000808 00002E1E AD000184
[   38.045654] PVR_K:   (MKT-1CE) 0738AFFF 00000C08 01002F1D AD000281
[   38.045684] PVR_K:   (MKT-1CF) 0738B17B 00000808 01002F1D AD00080A
[   38.045684] PVR_K:   (MKT-1D0) 0738B194 00000808 01002F1D 0F03D000
[   38.045684] PVR_K:   (MKT-1D1) 0738B1B4 00000808 01002F1D 00000062
[   38.045715] PVR_K:   (MKT-1D2) 0738B46C 00000808 00002F1D AD000803
[   38.045715] PVR_K:   (MKT-1D3) 0738B4B2 00180C88 00002F1D AD000282
[   38.045745] PVR_K:   (MKT-1D4) 0738BFDA 00000808 0100311F AD000200
[   38.045745] PVR_K:   (MKT-1D5) 0738C0F8 00000808 0100311F AD001703
[   38.045745] PVR_K:   (MKT-1D6) 0738C2DB 00000808 0000311F AD000202
[   38.045776] PVR_K:   (MKT-1D7) 0738C359 00000808 0000321E AD000183
[   38.045776] PVR_K:   (MKT-1D8) 0738C446 00000808 0000321E AD00030E
[   38.045776] PVR_K:   (MKT-1D9) 0738C45F 00000808 0000321E 0D800494
[   38.045806] PVR_K:   (MKT-1DA) 0738C478 00000808 0000321E 00000002
[   38.045806] PVR_K:   (MKT-1DB) 0738C49C 00000808 0000321E 00000003
[   38.045806] PVR_K:   (MKT-1DC) 0738C507 00000808 0000321E AD000184
[   38.045806] PVR_K:   (MKT-1DD) 0738C56C 00000C08 0100331D AD000281
[   38.045837] PVR_K:   (MKT-1DE) 0738C67D 00000808 0100331D AD000E02
[   38.045837] PVR_K:   (MKT-1DF) 0738C6F0 00000808 0100331D AD000282
[   38.045837] PVR_K:   (MKT-1E0) 073997F5 00000808 0100361F AD001A00
[   38.045867] PVR_K:   (MKT-1E1) 073A78F4 00000808 0100391F AD00000A
[   38.045867] PVR_K:   (MKT-1E2) 073A7955 00000808 0100391F AD000909
[   38.045867] PVR_K:   (MKT-1E3) 073A799F 00000808 0100391F AD001A05
[   38.045898] PVR_K:   (MKT-1E4) 073A79D3 00000808 0100391F AD001302
[   38.045898] PVR_K:   (MKT-1E5) 073A7A15 00000808 0100391F AD001303
[   38.045898] PVR_K:   (MKT-1E6) 073A7AA5 00000808 0100391F AD000D04
[   38.045928] PVR_K:   (MKT-1E7) 073A7B70 00000808 0100391F AD000D05
[   38.045928] PVR_K:   (MKT-1E8) 073A7BCB 00000808 0100391F AD000D04
[   38.045928] PVR_K:   (MKT-1E9) 073A7C55 00000808 0100391F AD000D05
[   38.045928] PVR_K:   (MKT-1EA) 073A7CB4 00000808 0100391F AD001A06
[   38.045959] PVR_K:   (MKT-1EB) 000005FA 00100808 0100031F AD002300
[   38.045959] PVR_K:   (MKT-1EC) 00000AFB 00100808 0100041F AD00000A
[   38.045959] PVR_K:   (MKT-1ED) 00000B7D 00100808 0100041F AD000906
[   38.045989] PVR_K:   (MKT-1EE) 00000C4D 00100808 0000041F AD000901
[   38.045989] PVR_K:   (MKT-1EF) 00000CC6 00100808 0000051E AD000183
[   38.045989] PVR_K:   (MKT-1F0) 00000E3A 00100808 0000051E AD000302
[   38.046020] PVR_K:   (MKT-1F1) 00000FBD 00100808 0000051E AD000D06
[   38.046020] PVR_K:   (MKT-1F2) 000010A9 00100808 0000051E AD000D07
[   38.046020] PVR_K:   (MKT-1F3) 000010F2 00100808 0000051E AD001304
[   38.046051] PVR_K:   (MKT-1F4) 000011DD 00100808 0000051E AD001305
[   38.046051] PVR_K:   (MKT-1F5) 000012ED 00100888 0000051E AD000404
[   38.046051] PVR_K:   (MKT-1F6) 000013B2 00100808 0000051E AD000402
[   38.046051] PVR_K:   (MKT-1F7) 000013FA 0010082B 0000051E AD000184
[   38.046081] PVR_K:   (MKT-1F8) 0000149B 00108DA9 0000061D AD000281
[   38.046081] PVR_K:   (MKT-1F9) 00001632 001199AD 0000061D AD000E02
[   38.046081] PVR_K:   (MKT-1FA) 00001697 0010892B 0000061D AD000282
[   38.046112] PVR_K:   (MKT-1FB) 00003D11 00100808 0000081F AD000101
[   38.046112] PVR_K:   (MKT-1FC) 00003D8A 00100808 0000081F AD000104
[   38.046112] PVR_K:   (MKT-1FD) 00003DC6 00100808 0100091E AD000100
[   38.046142] PVR_K:   (MKT-1FE) 00003ECD 00100808 0100091E AD000501
[   38.046142] PVR_K:   (MKT-1FF) 00003F0C 00100829 0100091E AD000104
[   38.046142] PVR_K: SGX Kernel CCB WO:0x39 RO:0x39
[   39.519805] thermal_lookup_temp: getting temp is not supported for domain pcb
[   39.528472] adc_to_temp_conversion:Temp read is invalid 0
[   39.534667] thermal_lookup_temp: getting temp is not supported for domain pcb
[   39.543273] adc_to_temp_conversion:Temp read is invalid 0
[   39.549224] thermal_lookup_temp: getting temp is not supported for domain pcb
[   39.717651] PVR_K:(Error): SGXOSTimer() detected SGX lockup (0xe tasks) [0, ]
[   39.725280] PVR_K: HWRecoveryResetSGX: SGX Hardware Recovery triggered
[   39.732788] [   15.672]   [c6e89d00] new in dsscomp_gralloc_queue (refs=1)
[   39.732788] [   15.672]                           [c6e64400] dsscomp_new
[   39.732788] [   15.672]   [c6e89d00] ++refs=2 for [c6e64400]
[   39.732788] [   15.672]                           [c6e64400] dsscomp_delayed_apply
[   39.732788] [   15.672]   [c6e89d00] --refs=1 on RELEASED
[   39.764038] [   15.672]                           [c6e64400] dsscomp_apply
[   39.764068] [   15.711]   [c6e89d00] --refs=0 on ECLIPSED
[   39.764068] [   15.711]   [c6e89d00] calling   (null) [  (null)]
[   39.764068] [   15.711]                           [c6e64400] dsscomp_mgr_delayed_cb on ECLIPSED
[   39.794403] [   19.772]    [c6edb7a0] new in dsscomp_gralloc_queue (refs=1)
[   39.794433] [   19.772]                        [c738c400] dsscomp_new
[   39.794433] [   19.772]    [c6edb7a0] ++refs=2 for [c738c400]
[   39.794433] [   19.772]                        [c738c400] dsscomp_delayed_apply
[   39.824676] [   19.772]    [c6edb7a0] --refs=1 on RELEASED
[   39.824676] [   19.772]                        [c738c400] dsscomp_apply
[   39.824676] [   19.773]                        [c738c400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   39.824707] [   19.779]    [c6e89d40] new in dsscomp_gralloc_queue (refs=1)
[   39.854492] [   19.779]                           [c6e64400] dsscomp_new
[   39.854492] [   19.779]    [c6e89d40] ++refs=2 for [c6e64400]
[   39.854492] [   19.779]                           [c6e64400] dsscomp_delayed_apply
[   39.854522] [   19.779]    [c6e89d40] --refs=1 on RELEASED
[   39.854522] [   19.779]                           [c6e64400] dsscomp_apply
[   39.885833] [   19.801]                        [c738c400] dsscomp_mgr_delayed_cb on DISPLAYED
[   39.885864] [   19.801]    [c6edb7a0] --refs=0 on RELEASED
[   39.885864] [   19.801]    [c6edb7a0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   39.885864] [   19.801]                        [c738c400] dsscomp_mgr_delayed_cb on RELEASED
[   39.915710] [   19.801]   [c6edb760] new in dsscomp_gralloc_queue (refs=1)
[   39.915710] [   19.801]                        [c6f10400] dsscomp_new
[   39.915710] [   19.801]   [c6edb760] ++refs=2 for [c6f10400]
[   39.915740] [   19.801]                        [c6f10400] dsscomp_delayed_apply
[   39.945495] [   19.801]   [c6edb760] --refs=1 on RELEASED
[   39.945526] [   19.801]                           [c6e64400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   39.945526] [   19.801]                        [c6f10400] dsscomp_apply
[   39.945526] [   19.816]                           [c6e64400] dsscomp_mgr_delayed_cb on DISPLAYED
[   39.975372] [   19.816]    [c6e89d40] --refs=0 on RELEASED
[   39.975372] [   19.816]    [c6e89d40] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   39.975372] [   19.816]                           [c6e64400] dsscomp_mgr_delayed_cb on RELEASED
[   40.003662] [   19.816]                        [c6f10400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   40.003662] [   19.832]                        [c6f10400] dsscomp_mgr_delayed_cb on DISPLAYED
[   40.003662] [   24.345]   [c6edb920] new in dsscomp_gralloc_queue (refs=1)
[   40.003662] [   24.345]                         [c6f11400] dsscomp_new
[   40.033508] [   24.345]   [c6edb920] ++refs=2 for [c6f11400]
[   40.033508] [   24.345]                         [c6f11400] dsscomp_delayed_apply
[   40.033508] [   24.345]   [c6edb920] --refs=1 on RELEASED
[   40.033538] [   24.345]                         [c6f11400] dsscomp_apply
[   40.063323] [   24.345]   [c6edb760] --refs=0 on RELEASED
[   40.063323] [   24.345]   [c6edb760] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   40.063354] [   24.345]                        [c6f10400] dsscomp_mgr_delayed_cb on RELEASED
[   40.063354] [   24.345]                         [c6f11400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   40.093170] [   24.369]                         [c6f11400] dsscomp_mgr_delayed_cb on DISPLAYED
[   40.093170] [   28.901]    [c6e89d40] new in dsscomp_gralloc_queue (refs=1)
[   40.093200] [   28.901]                           [c6e64400] dsscomp_new
[   40.093200] [   28.901]    [c6e89d40] ++refs=2 for [c6e64400]
[   40.122985] [   28.901]                           [c6e64400] dsscomp_delayed_apply
[   40.122985] [   28.901]    [c6e89d40] --refs=1 on RELEASED
[   40.122985] [   28.901]                           [c6e64400] dsscomp_apply
[   40.122985] [   28.901]   [c6edb920] --refs=0 on RELEASED
[   40.152801] [   28.901]   [c6edb920] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   40.152801] [   28.901]                         [c6f11400] dsscomp_mgr_delayed_cb on RELEASED
[   40.152801] [   28.901]                           [c6e64400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   40.152801] [   28.902] [c6e89d60] new in dsscomp_gralloc_queue (refs=1)
[   40.182525] [   28.902]                      [c6e64800] dsscomp_new
[   40.182525] [   28.902] [c6e89d60] ++refs=2 for [c6e64800]
[   40.182525] [   28.902]                      [c6e64800] dsscomp_delayed_apply
[   40.182556] [   28.902] [c6e89d60] --refs=1 on RELEASED
[   40.212280] [   28.902]                      [c6e64800] dsscomp_apply
[   40.212280] [   28.925]                           [c6e64400] dsscomp_mgr_delayed_cb on DISPLAYED
[   40.212310] [   28.925]    [c6e89d40] --refs=0 on RELEASED
[   40.212310] [   28.925]    [c6e89d40] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   40.242095] [   28.925]                           [c6e64400] dsscomp_mgr_delayed_cb on RELEASED
[   40.242095] [   28.925]                      [c6e64800] dsscomp_mgr_delayed_cb on PROGRAMMED
[   40.242095] [   28.942]                      [c6e64800] dsscomp_mgr_delayed_cb on DISPLAYED
[   40.270324] [   33.971]  [c6e89da0] new in dsscomp_gralloc_queue (refs=1)
[   40.270324] [   33.971]                        [c6e64c00] dsscomp_new
[   40.270324] [   33.971]  [c6e89da0] ++refs=2 for [c6e64c00]
[   40.270324] [   33.971]                        [c6e64c00] dsscomp_delayed_apply
[   40.270324] [   33.971]  [c6e89da0] --refs=1 on RELEASED
[   40.301849] [   33.971]                        [c6e64c00] dsscomp_apply
[   40.301849] [   33.971] [c6e89d60] --refs=0 on RELEASED
[   40.301849] [   33.971] [c6e89d60] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   40.301849] [   33.971]                      [c6e64800] dsscomp_mgr_delayed_cb on RELEASED
[   40.331665] [   33.971]                        [c6e64c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   40.331665] [   33.972]      [c6edb820] new in dsscomp_gralloc_queue (refs=1)
[   40.331665] [   33.972]                      [c6f10000] dsscomp_new
[   40.331695] [   33.972]      [c6edb820] ++refs=2 for [c6f10000]
[   40.361511] [   33.972]                      [c6f10000] dsscomp_delayed_apply
[   40.361511] [   33.972]      [c6edb820] --refs=1 on RELEASED
[   40.361511] [   33.972]                      [c6f10000] dsscomp_apply
[   40.361511] [   33.993]                        [c6e64c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   40.391296] [   33.993]  [c6e89da0] --refs=0 on RELEASED
[   40.391296] [   33.993]  [c6e89da0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   40.391296] [   34.001]                        [c6e64c00] dsscomp_mgr_delayed_cb on RELEASED
[   40.391296] [   34.001]                      [c6f10000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   40.421356] [   34.008]                      [c6f10000] dsscomp_mgr_delayed_cb on DISPLAYED
[   40.421386] [   39.512]   [c6edba00] new in dsscomp_gralloc_queue (refs=1)
[   40.421386] [   39.512]                        [c6f12000] dsscomp_new
[   40.421386] [   39.512]   [c6edba00] ++refs=2 for [c6f12000]
[   40.451202] [   39.512]                        [c6f12000] dsscomp_delayed_apply
[   40.451202] [   39.512]   [c6edba00] --refs=1 on RELEASED
[   40.451202] [   39.512]                        [c6f12000] dsscomp_apply
[   40.451202] [   39.512]      [c6edb820] --refs=0 on RELEASED
[   40.481018] [   39.512]      [c6edb820] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   40.481048] [   39.512]                      [c6f10000] dsscomp_mgr_delayed_cb on RELEASED
[   40.481048] [   39.512]                        [c6f12000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   40.481048] [   39.513]      [c6edb820] new in dsscomp_gralloc_queue (refs=1)
[   40.510833] [   39.513]                      [c6f10000] dsscomp_new
[   40.510833] [   39.513]      [c6edb820] ++refs=2 for [c6f10000]
[   40.510833] [   39.513]                      [c6f10000] dsscomp_delayed_apply
[   40.510864] [   39.513]      [c6edb820] --refs=1 on RELEASED
[   40.540771] [   39.513]                      [c6f10000] dsscomp_apply
[   40.540771] [   39.527]                        [c6f12000] dsscomp_mgr_delayed_cb on DISPLAYED
[   40.540771] [   39.527]   [c6edba00] --refs=0 on RELEASED
[   40.540771] [   39.527]   [c6edba00] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   40.570617] [   39.527]                        [c6f12000] dsscomp_mgr_delayed_cb on RELEASED
[   40.570617] [   39.527]                      [c6f10000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   40.570617] [   39.550]                      [c6f10000] dsscomp_mgr_delayed_cb on DISPLAYED
[   40.599304] ACTIVE COMPOSITIONS on lcd
[   40.599304]
[   40.599334]   [c6f10000]: DISPLAYED
[   40.599334]     sync_id=0, flags=AD-
[   40.599334]     ovl0={ON z0 ARGB32-8888 premult *100% 864*480:0,0+864,480 rot0 => 0,0+864,480 7f358000/  (null)|3456}
[   40.599334]     gsync=[c6edb820] dsscomp_gralloc_cb
[   40.599334]
[   40.599334]   DISPC pipeline:
[   40.599334]
[   40.599334]     info:        clean (none)
[   40.638641]     cache:       clean (none)
[   40.638671]     shadow:  ACT clean (none)
[   40.638671]     dispc:   DISPLAYED mask=---R [c6f10000] dsscomp_mgr_callback
[   40.638671]
[   40.638671] ACTIVE COMPOSITIONS on tv
[   40.638671]
[   40.638671]   DISPC pipeline:
[   40.638671]
[   40.638671]     info:        clean (none)
[   40.638671]     cache:       clean (none)
[   40.678131]     shadow:  off clean (none)
[   40.678131]     dispc:   DISPLAYED (none)
[   40.678131]
[   40.678131] ACTIVE COMPOSITIONS on lcd2
[   40.678131]
[   40.678131]   DISPC pipeline:
[   40.678131]
[   40.678131]     info:        clean (none)
[   40.678131]     cache:       clean (none)
[   40.678161]     dispc:             (none)
[   40.678161]
[   40.678161] ACTIVE GRALLOC FLIPS
[   40.678161]
[   40.678161]   [c6edb820] (refs=1)
[   40.725189]     slots=[7f358000]
[   40.725189]     cmdcb=[c73f6900] dsscomp_proxy_cmdcomplete
[   40.725189]
[   40.725189]   |           lcd
[   40.725189]   | [c6f10000] DISPL'D
[   40.725189]   |     39.513  ACTIVE
[   40.725189]   |     39.513 APPLY'N
[   40.725219]   |     39.513 APPLIED
[   40.725219]   |     39.527 PROGR'D
[   40.725219]   |     39.550 DISPL'D
[   40.725219]
[   40.766113]
[   40.767761] PVR_K: SGX debug (blaze_android_sgx_ogles1_ogles2_GPL sgxddk 18 1.8@869593)
[   40.776367] PVR_K:(Error): SGX Register Base Address (Linear):   0xC8B20000 [0, ]
[   40.784423] PVR_K:(Error): SGX Register Base Address (Physical): 0x56000000 [0, ]
[   40.792541] PVR_K: (P0) EUR_CR_CORE_ID:          01140000
[   40.798339] PVR_K: (P0) EUR_CR_CORE_REVISION:    00010200
[   40.804168] PVR_K: (P0) EUR_CR_EVENT_STATUS:     20000000
[   40.810028] PVR_K: (P0) EUR_CR_EVENT_STATUS2:    00000008
[   40.815979] PVR_K: (P0) EUR_CR_BIF_CTRL:         00000000
[   40.821868] PVR_K: (P0) EUR_CR_BIF_INT_STAT:     00008000
[   40.827728] PVR_K: (P0) EUR_CR_BIF_FAULT:        00000000
[   40.833557] PVR_K: (P0) EUR_CR_BIF_MEM_REQ_STAT: 00000000
[   40.839447] PVR_K: (P0) EUR_CR_CLKGATECTL:       000AAA6A
[   40.845245] PVR_K: (P0) EUR_CR_PDS_PC_BASE:      00001010
[   40.851226] PVR_K: Flip Command Complete Data 0 for display device 1:
[   40.858154] PVR_K:   SRC 0: (Not in use)
[   40.862396] PVR_K: Flip Command Complete Data 1 for display device 1:
[   40.869354] PVR_K:   SRC 0: ROC DevVAddr:0xD800474 ROP:0x6 ROC:0x4, WOC DevVAddr:0xD800464 WOP:0x6 WOC:0x5
[   40.879730] PVR_K: SGX Host control:
[   40.883666] PVR_K:   (HC-0) 0x00000001 0x00000000 0x00000000 0x00000001
[   40.890777] PVR_K:   (HC-10) 0x00000006 0x0000000A 0x0005DC00 0x00000003
[   40.897918] PVR_K:   (HC-20) 0x00000000 0x00000001 0x00000000 0x00000007
[   40.905029] PVR_K:   (HC-30) 0x000005FD 0xF079B28C 0x00000000 0x00000000
[   40.912200] PVR_K:   (HC-40) 0x00000000 0x087BF500 0x087C6300 0x087C3100
[   40.919281] PVR_K: SGX TA/3D control:
[   40.923431] PVR_K:   (T3C-0) 0x0F003000 0x0F003120 0x0F002000 0x00000000
[   40.930603] PVR_K:   (T3C-10) 0x00000001 0x00000002 0x00000001 0x0F00DD00
[   40.937866] PVR_K:   (T3C-20) 0x00000000 0x00000000 0x00000000 0x00000000
[   40.945190] PVR_K:   (T3C-30) 0x00000000 0x00000000 0x00000000 0x00000000
[   40.952545] PVR_K:   (T3C-40) 0x00000000 0x00000000 0x00000000 0x00000000
[   40.959838] PVR_K:   (T3C-50) 0x0F00DD00 0x00000000 0x00000000 0x0F00DD00
[   40.967041] PVR_K:   (T3C-60) 0x00000000 0x00000000 0x0F00DD00 0x00000000
[   40.974304] PVR_K:   (T3C-70) 0x00000000 0x0F00DD00 0x00000000 0x0F004000
[   40.981628] PVR_K:   (T3C-80) 0x0000000E 0x0001120F 0x00000000 0x0F00DEB8
[   40.988891] PVR_K:   (T3C-90) 0x00000000 0x0F000000 0xAB600000 0x0F03E800
[   40.996154] PVR_K:   (T3C-A0) 0x00000000 0x0F010760 0x0F00DD00 0x0F00DEB8
[   41.003387] PVR_K:   (T3C-B0) 0x0F0109A0 0x00000000 0x00000000 0x00000000
[   41.010742] PVR_K:   (T3C-C0) 0x00000000 0x00000000 0x00000000 0x00000000
[   41.017913] PVR_K:   (T3C-D0) 0x00000000 0x0000000A 0x00000009 0x0F007000
[   41.025115] PVR_K:   (T3C-E0) 0x0F00D420 0x0F00E000 0x0F010720 0x0F010720
[   41.032470] PVR_K:   (T3C-F0) 0x00000000 0x000000B5 0x000000B5 0x00000000
[   41.039733] PVR_K:   (T3C-100) 0x00000003 0x00000001 0x00000000 0x00000000
[   41.047088] PVR_K:   (T3C-110) 0xB50C565C 0x0872E100 0x08787B00 0x08787B00
[   41.054504] PVR_K: Last SGX microkernel status code: AD000104
[   41.060699] PVR_K:   (MKT-0) 0D00056E 00000C08 0100311D AD000281
[   41.067169] PVR_K:   (MKT-1) 0D0006E6 00000808 0100311D AD00080A
[   41.073638] PVR_K:   (MKT-2) 0D0006FF 00000808 0100311D 0F03B800
[   41.079986] PVR_K:   (MKT-3) 0D000717 00000808 0100311D 00000062
[   41.086486] PVR_K:   (MKT-4) 0D0009C6 00000808 0000311D AD000803
[   41.092895] PVR_K:   (MKT-5) 0D000A11 00180C88 0000311D AD000282
[   41.099334] PVR_K:   (MKT-6) 0D001547 00000808 0100331F AD000200
[   41.105957] PVR_K:   (MKT-7) 0D001662 00000808 0100331F AD001703
[   41.112670] PVR_K:   (MKT-8) 0D001843 00000808 0000331F AD000202
[   41.119323] PVR_K:   (MKT-9) 0D0018C3 00000808 0000341E AD000183
[   41.125701] PVR_K:   (MKT-A) 0D0019AC 00000808 0000341E AD00030E
[   41.132141] PVR_K:   (MKT-B) 0D0019C4 00000808 0000341E 0D800494
[   41.138458] PVR_K:   (MKT-C) 0D0019DD 00000808 0000341E 00000001
[   41.144958] PVR_K:   (MKT-D) 0D001A00 00000808 0000341E 00000002
[   41.151367] PVR_K:   (MKT-E) 0D001A6A 00000808 0000341E AD000184
[   41.157836] PVR_K:   (MKT-F) 0D001AD0 00000C08 0100351D AD000281
[   41.164215] PVR_K:   (MKT-10) 0D001BE1 00000808 0100351D AD000E02
[   41.170715] PVR_K:   (MKT-11) 0D001C52 00000808 0100351D AD000282
[   41.177154] PVR_K:   (MKT-12) 0D00DEAB 00000808 0100381F AD001A00
[   41.183685] PVR_K:   (MKT-13) 0D00E1D6 00000808 0100391F AD00000A
[   41.190124] PVR_K:   (MKT-14) 0D00E238 00000808 0100391F AD000909
[   41.196746] PVR_K:   (MKT-15) 0D00E282 00000808 0100391F AD001A05
[   41.203247] PVR_K:   (MKT-16) 0D00E2B4 00000808 0100391F AD001302
[   41.209747] PVR_K:   (MKT-17) 0D00E2F4 00000808 0100391F AD001303
[   41.216247] PVR_K:   (MKT-18) 0D00E386 00000808 0100391F AD000D04
[   41.222747] PVR_K:   (MKT-19) 0D00E44F 00000808 0100391F AD000D05
[   41.229339] PVR_K:   (MKT-1A) 0D00E4A9 00000808 0100391F AD000D04
[   41.235870] PVR_K:   (MKT-1B) 0D00E531 00000808 0100391F AD000D05
[   41.242401] PVR_K:   (MKT-1C) 0D00E590 00000808 0100391F AD001A06
[   41.248992] PVR_K:   (MKT-1D) 0000047C 00100808 0100031F AD002300
[   41.255462] PVR_K:   (MKT-1E) 00000965 00100808 0100041F AD00000A
[   41.262023] PVR_K:   (MKT-1F) 000009E2 00100808 0100041F AD000906
[   41.268554] PVR_K:   (MKT-20) 00000AB4 00100808 0000041F AD000901
[   41.275054] PVR_K:   (MKT-21) 00000B32 00100808 0000051E AD000183
[   41.281585] PVR_K:   (MKT-22) 00000CA7 00100808 0000051E AD000302
[   41.288055] PVR_K:   (MKT-23) 00000E29 00100808 0000051E AD000D06
[   41.294616] PVR_K:   (MKT-24) 00000F10 00100808 0000051E AD000D07
[   41.301116] PVR_K:   (MKT-25) 00000F59 00100808 0000051E AD001304
[   41.307739] PVR_K:   (MKT-26) 00001044 00100808 0000051E AD001305
[   41.314239] PVR_K:   (MKT-27) 00001154 00100888 0000051E AD000404
[   41.320770] PVR_K:   (MKT-28) 00001217 00100808 0000051E AD000402
[   41.327239] PVR_K:   (MKT-29) 00001260 0010082B 0000051E AD000184
[   41.333679] PVR_K:   (MKT-2A) 000012EB 00108DA9 0000061D AD000281
[   41.340270] PVR_K:   (MKT-2B) 0000146A 001199AD 0000061D AD000E02
[   41.346710] PVR_K:   (MKT-2C) 000014C9 001199A9 0000061D AD000282
[   41.353210] PVR_K:   (MKT-2D) 00003AAE 00100808 0000081F AD000101
[   41.359771] PVR_K:   (MKT-2E) 00003B25 00100808 0000081F AD000104
[   41.366333] PVR_K:   (MKT-2F) 00003B63 00100808 0100091E AD000100
[   41.372802] PVR_K:   (MKT-30) 00003C69 00100808 0100091E AD000501
[   41.379425] PVR_K:   (MKT-31) 00003CA9 0010082B 0100091E AD000104
[   41.385864] PVR_K:   (MKT-32) 00005F7F 00100828 01000A1F AD000101
[   41.392486] PVR_K:   (MKT-33) 00005FC4 00100828 01000A1F AD000104
[   41.399047] PVR_K:   (MKT-34) 000060DB 00100808 01000B1F AD000100
[   41.405609] PVR_K:   (MKT-35) 000061A0 00100808 01000B1F AD000501
[   41.412017] PVR_K:   (MKT-36) 000061CC 00100829 01000B1F AD000104
[   41.418548] PVR_K:   (MKT-37) 000086F6 00100828 01000D1F AD000101
[   41.425109] PVR_K:   (MKT-38) 0000876D 00100828 01000D1F AD000104
[   41.431610] PVR_K:   (MKT-39) 000087AA 00100808 01000E1E AD000100
[   41.438079] PVR_K:   (MKT-3A) 000088AA 00100808 01000E1E AD000501
[   41.444641] PVR_K:   (MKT-3B) 000088E9 00100829 01000E1E AD000104
[   41.451171] PVR_K:   (MKT-3C) 0737C0BF 00100808 0100031F AD000B00
[   41.457672] PVR_K:   (MKT-3D) 0737C104 00100808 0100031F AD000B03
[   41.464447] PVR_K:   (MKT-3E) 0737C189 00100808 0100031F AD000B05
[   41.470886] PVR_K:   (MKT-3F) 0737C1DD 00100808 0100031F AD000B06
[   41.477539] PVR_K:   (MKT-40) 0737C20D 00100808 0100031F AD000B06
[   41.484039] PVR_K:   (MKT-41) 0737C250 00100808 0100031F AD000B07
[   41.490539] PVR_K:   (MKT-42) 0737C275 00100808 0100031F AD000B09
[   41.497039] PVR_K:   (MKT-43) 0737C2CA 00100808 0100031F AD000B01
[   41.503540] PVR_K:   (MKT-44) 0737C306 00100808 0100031F AD002300
[   41.510101] PVR_K:   (MKT-45) 0737C61E 00100808 0100041F AD00000A
[   41.516662] PVR_K:   (MKT-46) 0737C69C 00100808 0100041F AD000906
[   41.523132] PVR_K:   (MKT-47) 0737C759 00100808 0000041F AD000901
[   41.529693] PVR_K:   (MKT-48) 0737C7D5 00100808 0000051E AD000183
[   41.536224] PVR_K:   (MKT-49) 0737C944 00100808 0000051E AD000302
[   41.542785] PVR_K:   (MKT-4A) 0737C996 00100808 0000051E AD000303
[   41.549530] PVR_K:   (MKT-4B) 0737CA1C 00100808 0000051E AD000C01
[   41.556091] PVR_K:   (MKT-4C) 0737CA41 00100808 0000051E 0D800484
[   41.562744] PVR_K:   (MKT-4D) 0737CA5A 00100808 0000051E 00000003
[   41.569152] PVR_K:   (MKT-4E) 0737CCAF 00100808 0000051E AD00030E
[   41.575622] PVR_K:   (MKT-4F) 0737CCC7 00100808 0000051E 0D800474
[   41.582122] PVR_K:   (MKT-50) 0737CCE0 00100808 0000051E 00000002
[   41.588836] PVR_K:   (MKT-51) 0737CD04 00100808 0000051E 00000003
[   41.595458] PVR_K:   (MKT-52) 0737CD7C 00100808 0000051E AD000184
[   41.602020] PVR_K:   (MKT-53) 0737CE01 00100C08 0100061D AD000281
[   41.608459] PVR_K:   (MKT-54) 0737CF97 00100808 0100061D AD00080A
[   41.614929] PVR_K:   (MKT-55) 0737CFAF 00100808 0100061D 0F03BB00
[   41.621398] PVR_K:   (MKT-56) 0737CFC7 00100808 0100061D 00000061
[   41.627899] PVR_K:   (MKT-57) 0737D0DE 00100C88 0100061D AD001300
[   41.634338] PVR_K:   (MKT-58) 073824DB 00100808 0000061D AD001301
[   41.640899] PVR_K:   (MKT-59) 07382602 00100888 0000061D AD000802
[   41.647430] PVR_K:   (MKT-5A) 07382766 00100888 0000061D AD000803
[   41.653900] PVR_K:   (MKT-5B) 073827B3 001808C8 0000061D AD000282
[   41.660461] PVR_K:   (MKT-5C) 07382895 00184AF8 0000081E AD00000A
[   41.666961] PVR_K:   (MKT-5D) 0738291C 00184AF8 0000081E AD000905
[   41.673461] PVR_K:   (MKT-5E) 07382A3D 001808B8 0000081E AD000901
[   41.679901] PVR_K:   (MKT-5F) 07382AB6 00180838 0000091C AD00000A
[   41.686523] PVR_K:   (MKT-60) 07382B24 00180838 0000091C AD000905
[   41.693084] PVR_K:   (MKT-61) 07382BD3 00180838 0000091C AD000901
[   41.699737] PVR_K:   (MKT-62) 07382C2B 00180838 00000A1B AD00000A
[   41.706329] PVR_K:   (MKT-63) 07382C97 00180838 00000A1B AD000906
[   41.712829] PVR_K:   (MKT-64) 07382D0C 00180838 00000A1B AD000901
[   41.719268] PVR_K:   (MKT-65) 07382D60 00180838 00000B1A AD00000A
[   41.725860] PVR_K:   (MKT-66) 07382DC2 00180838 00000B1A AD000905
[   41.732360] PVR_K:   (MKT-67) 07382E71 00180838 00000B1A AD000901
[   41.738830] PVR_K:   (MKT-68) 07382EC8 00180838 00000C19 AD00000A
[   41.745391] PVR_K:   (MKT-69) 07382F33 00180838 00000C19 AD000905
[   41.751922] PVR_K:   (MKT-6A) 07382FEB 00180838 00000C19 AD000901
[   41.758422] PVR_K:   (MKT-6B) 0738313E 00180838 00000F1F AD000183
[   41.764984] PVR_K:   (MKT-6C) 073832BA 00180838 00000F1F AD000302
[   41.771423] PVR_K:   (MKT-6D) 0738332C 00180838 00000F1F AD000303
[   41.777862] PVR_K:   (MKT-6E) 073833B0 00180838 00000F1F AD000C01
[   41.784484] PVR_K:   (MKT-6F) 073833D4 00180838 00000F1F 0D800464
[   41.791015] PVR_K:   (MKT-70) 073833ED 00180838 00000F1F 00000004
[   41.797485] PVR_K:   (MKT-71) 07383608 00180838 00000F1F AD000184
[   41.804046] PVR_K:   (MKT-72) 07383678 00180C38 0100101D AD000281
[   41.810638] PVR_K:   (MKT-73) 073836CE 00180838 0100101D AD000282
[   41.817169] PVR_K:   (MKT-74) 07384226 00180838 0100111F AD00000A
[   41.823791] PVR_K:   (MKT-75) 07384290 00180838 0100111F AD000905
[   41.830230] PVR_K:   (MKT-76) 07384394 00180838 0000111F AD000901
[   41.836822] PVR_K:   (MKT-77) 073843E5 00180C38 0100121E AD000281
[   41.843353] PVR_K:   (MKT-78) 0738443B 00180838 0100121E AD000282
[   41.849884] PVR_K:   (MKT-79) 073844F7 00180838 0100131F AD00000A
[   41.856475] PVR_K:   (MKT-7A) 07384561 00180838 0100131F AD000905
[   41.862915] PVR_K:   (MKT-7B) 0738465C 00180838 0000131F AD000901
[   41.869506] PVR_K:   (MKT-7C) 073846AF 00180C38 0100141E AD000281
[   41.876068] PVR_K:   (MKT-7D) 07384708 00180838 0100141E AD000282
[   41.882537] PVR_K:   (MKT-7E) 07384823 00100828 0100151F AD00000A
[   41.889068] PVR_K:   (MKT-7F) 07384894 00100828 0100151F AD000905
[   41.895629] PVR_K:   (MKT-80) 07384990 00000808 0000151F AD000901
[   41.902130] PVR_K:   (MKT-81) 073849C8 00000C08 0000161E AD000200
[   41.908721] PVR_K:   (MKT-82) 07384C1A 00000808 0000161E AD000202
[   41.915191] PVR_K:   (MKT-83) 07384C73 00000808 0000171D AD000281
[   41.921783] PVR_K:   (MKT-84) 07384DC2 00000808 0000171D AD00080A
[   41.928314] PVR_K:   (MKT-85) 07384DDB 00000808 0000171D 0F03BE00
[   41.934783] PVR_K:   (MKT-86) 07384DF3 00000808 0000171D 00000060
[   41.941345] PVR_K:   (MKT-87) 073850B6 00000808 0000171D AD000803
[   41.947967] PVR_K:   (MKT-88) 07385100 00180CC8 0000171D AD000282
[   41.954650] PVR_K:   (MKT-89) 073851C3 00000808 0000181F AD00000A
[   41.961395] PVR_K:   (MKT-8A) 0738522B 00000808 0000181F AD000905
[   41.967956] PVR_K:   (MKT-8B) 07385323 00000888 0000181F AD000901
[   41.974395] PVR_K:   (MKT-8C) 0738536D 00000C08 00001A1D AD000200
[   41.980926] PVR_K:   (MKT-8D) 073855AB 00000808 00001A1D AD000202
[   41.987396] PVR_K:   (MKT-8E) 07385602 00000808 01001B1C AD000281
[   41.993896] PVR_K:   (MKT-8F) 0738574E 00000808 01001B1C AD00080A
[   42.000366] PVR_K:   (MKT-90) 07385767 00000808 01001B1C 0F03C100
[   42.006866] PVR_K:   (MKT-91) 0738577F 00000808 01001B1C 00000060
[   42.013275] PVR_K:   (MKT-92) 07385A39 00000808 00001B1C AD000803
[   42.019775] PVR_K:   (MKT-93) 07385A7E 00180CC8 00001B1C AD000282
[   42.026184] PVR_K:   (MKT-94) 07385B69 00000808 01001D1F AD000200
[   42.032653] PVR_K:   (MKT-95) 07385D91 00000808 00001D1F AD000202
[   42.039093] PVR_K:   (MKT-96) 07385DE1 00000808 01001E1E AD000281
[   42.045532] PVR_K:   (MKT-97) 07385F31 00000808 01001E1E AD00080A
[   42.051940] PVR_K:   (MKT-98) 07385F49 00000808 01001E1E 0F03C400
[   42.058410] PVR_K:   (MKT-99) 07385F61 00000808 01001E1E 00000062
[   42.064971] PVR_K:   (MKT-9A) 0738620C 00000808 00001E1E AD000803
[   42.071472] PVR_K:   (MKT-9B) 07386251 00180C88 00001E1E AD000282
[   42.077972] PVR_K:   (MKT-9C) 07386D4B 00000808 0100201F AD000200
[   42.084411] PVR_K:   (MKT-9D) 07386E68 00000808 0100201F AD001703
[   42.090911] PVR_K:   (MKT-9E) 0738706A 00000808 0000201F AD000202
[   42.097351] PVR_K:   (MKT-9F) 073870E7 00000808 0000211E AD000183
[   42.103942] PVR_K:   (MKT-A0) 073871D2 00000808 0000211E AD00030E
[   42.110473] PVR_K:   (MKT-A1) 073871EA 00000808 0000211E 0D800494
[   42.116973] PVR_K:   (MKT-A2) 07387203 00000808 0000211E 00000002
[   42.123535] PVR_K:   (MKT-A3) 07387226 00000808 0000211E 00000003
[   42.130249] PVR_K:   (MKT-A4) 07387293 00000808 0000211E AD000184
[   42.136840] PVR_K:   (MKT-A5) 073872F7 00000C08 0100221D AD000281
[   42.143341] PVR_K:   (MKT-A6) 0738746C 00000808 0100221D AD00080A
[   42.149749] PVR_K:   (MKT-A7) 07387485 00000808 0100221D 0F03C700
[   42.156249] PVR_K:   (MKT-A8) 0738749D 00000808 0100221D 00000061
[   42.162628] PVR_K:   (MKT-A9) 07387611 00000808 0000221D AD000802
[   42.169067] PVR_K:   (MKT-AA) 0738775F 00000808 0000221D AD000803
[   42.175537] PVR_K:   (MKT-AB) 073877A4 00184EC8 0000221D AD000282
[   42.181945] PVR_K:   (MKT-AC) 073896ED 00000C08 0100251F AD000200
[   42.188659] PVR_K:   (MKT-AD) 0738993A 00000808 0000251F AD000202
[   42.195251] PVR_K:   (MKT-AE) 073899C2 00000808 0000261E AD000183
[   42.201721] PVR_K:   (MKT-AF) 07389AAC 00000808 0000261E AD00030E
[   42.208160] PVR_K:   (MKT-B0) 07389AC4 00000808 0000261E 0D800494
[   42.214660] PVR_K:   (MKT-B1) 07389ADC 00000808 0000261E 00000002
[   42.221069] PVR_K:   (MKT-B2) 07389B00 00000808 0000261E 00000003
[   42.227508] PVR_K:   (MKT-B3) 07389B6A 00000808 0000261E AD000184
[   42.233947] PVR_K:   (MKT-B4) 07389BCF 00000C08 0100271D AD000281
[   42.240692] PVR_K:   (MKT-B5) 07389D39 00000808 0100271D AD00080A
[   42.247375] PVR_K:   (MKT-B6) 07389D51 00000808 0100271D 0F03CA00
[   42.253875] PVR_K:   (MKT-B7) 07389D6A 00000808 0100271D 00000060
[   42.260284] PVR_K:   (MKT-B8) 0738A01A 00000808 0000271D AD000803
[   42.266784] PVR_K:   (MKT-B9) 0738A05F 00180CC8 0000271D AD000282
[   42.273223] PVR_K:   (MKT-BA) 0738A135 00000808 0100291F AD000200
[   42.279632] PVR_K:   (MKT-BB) 0738A34D 00000808 0000291F AD000202
[   42.286132] PVR_K:   (MKT-BC) 0738A3CA 00000808 00002A1E AD000183
[   42.292541] PVR_K:   (MKT-BD) 0738A4B2 00000808 00002A1E AD00030E
[   42.299011] PVR_K:   (MKT-BE) 0738A4CA 00000808 00002A1E 0D800494
[   42.305419] PVR_K:   (MKT-BF) 0738A4E3 00000808 00002A1E 00000002
[   42.311889] PVR_K:   (MKT-C0) 0738A506 00000808 00002A1E 00000003
[   42.318298] PVR_K:   (MKT-C1) 0738A573 00000808 00002A1E AD000184
[   42.324768] PVR_K:   (MKT-C2) 0738A5D6 00000C08 01002B1D AD000281
[   42.331207] PVR_K:   (MKT-C3) 0738A73D 00000808 01002B1D AD00080A
[   42.337677] PVR_K:   (MKT-C4) 0738A756 00000808 01002B1D 0F03CD00
[   42.344085] PVR_K:   (MKT-C5) 0738A76E 00000808 01002B1D 00000060
[   42.350555] PVR_K:   (MKT-C6) 0738AA1E 00000808 00002B1D AD000803
[   42.356964] PVR_K:   (MKT-C7) 0738AA63 00188CC8 00002B1D AD000282
[   42.363433] PVR_K:   (MKT-C8) 0738AB53 00000808 01002D1F AD000200
[   42.369842] PVR_K:   (MKT-C9) 0738AD6E 00000808 00002D1F AD000202
[   42.376281] PVR_K:   (MKT-CA) 0738ADF1 00000808 00002E1E AD000183
[   42.382751] PVR_K:   (MKT-CB) 0738AEDA 00000808 00002E1E AD00030E
[   42.389160] PVR_K:   (MKT-CC) 0738AEF3 00000808 00002E1E 0D800494
[   42.395629] PVR_K:   (MKT-CD) 0738AF0B 00000808 00002E1E 00000002
[   42.402038] PVR_K:   (MKT-CE) 0738AF2F 00000808 00002E1E 00000003
[   42.408508] PVR_K:   (MKT-CF) 0738AF98 00000808 00002E1E AD000184
[   42.414916] PVR_K:   (MKT-D0) 0738AFFF 00000C08 01002F1D AD000281
[   42.421386] PVR_K:   (MKT-D1) 0738B17B 00000808 01002F1D AD00080A
[   42.427764] PVR_K:   (MKT-D2) 0738B194 00000808 01002F1D 0F03D000
[   42.434234] PVR_K:   (MKT-D3) 0738B1B4 00000808 01002F1D 00000062
[   42.440673] PVR_K:   (MKT-D4) 0738B46C 00000808 00002F1D AD000803
[   42.447143] PVR_K:   (MKT-D5) 0738B4B2 00180C88 00002F1D AD000282
[   42.453552] PVR_K:   (MKT-D6) 0738BFDA 00000808 0100311F AD000200
[   42.460021] PVR_K:   (MKT-D7) 0738C0F8 00000808 0100311F AD001703
[   42.466522] PVR_K:   (MKT-D8) 0738C2DB 00000808 0000311F AD000202
[   42.473114] PVR_K:   (MKT-D9) 0738C359 00000808 0000321E AD000183
[   42.479675] PVR_K:   (MKT-DA) 0738C446 00000808 0000321E AD00030E
[   42.486236] PVR_K:   (MKT-DB) 0738C45F 00000808 0000321E 0D800494
[   42.492858] PVR_K:   (MKT-DC) 0738C478 00000808 0000321E 00000002
[   42.499328] PVR_K:   (MKT-DD) 0738C49C 00000808 0000321E 00000003
[   42.505798] PVR_K:   (MKT-DE) 0738C507 00000808 0000321E AD000184
[   42.512268] PVR_K:   (MKT-DF) 0738C56C 00000C08 0100331D AD000281
[   42.518737] PVR_K:   (MKT-E0) 0738C67D 00000808 0100331D AD000E02
[   42.525482] PVR_K:   (MKT-E1) 0738C6F0 00000808 0100331D AD000282
[   42.532318] PVR_K:   (MKT-E2) 073997F5 00000808 0100361F AD001A00
[   42.538787] PVR_K:   (MKT-E3) 073A78F4 00000808 0100391F AD00000A
[   42.545227] PVR_K:   (MKT-E4) 073A7955 00000808 0100391F AD000909
[   42.551635] PVR_K:   (MKT-E5) 073A799F 00000808 0100391F AD001A05
[   42.558135] PVR_K:   (MKT-E6) 073A79D3 00000808 0100391F AD001302
[   42.564544] PVR_K:   (MKT-E7) 073A7A15 00000808 0100391F AD001303
[   42.571014] PVR_K:   (MKT-E8) 073A7AA5 00000808 0100391F AD000D04
[   42.577423] PVR_K:   (MKT-E9) 073A7B70 00000808 0100391F AD000D05
[   42.583831] PVR_K:   (MKT-EA) 073A7BCB 00000808 0100391F AD000D04
[   42.590301] PVR_K:   (MKT-EB) 073A7C55 00000808 0100391F AD000D05
[   42.596832] PVR_K:   (MKT-EC) 073A7CB4 00000808 0100391F AD001A06
[   42.603424] PVR_K:   (MKT-ED) 000005FA 00100808 0100031F AD002300
[   42.609924] PVR_K:   (MKT-EE) 00000AFB 00100808 0100041F AD00000A
[   42.616455] PVR_K:   (MKT-EF) 00000B7D 00100808 0100041F AD000906
[   42.623687] PVR_K:   (MKT-F0) 00000C4D 00100808 0000041F AD000901
[   42.630157] PVR_K:   (MKT-F1) 00000CC6 00100808 0000051E AD000183
[   42.637359] PVR_K:   (MKT-F2) 00000E3A 00100808 0000051E AD000302
[   42.643859] PVR_K:   (MKT-F3) 00000FBD 00100808 0000051E AD000D06
[   42.650299] PVR_K:   (MKT-F4) 000010A9 00100808 0000051E AD000D07
[   42.656890] PVR_K:   (MKT-F5) 000010F2 00100808 0000051E AD001304
[   42.663391] PVR_K:   (MKT-F6) 000011DD 00100808 0000051E AD001305
[   42.669830] PVR_K:   (MKT-F7) 000012ED 00100888 0000051E AD000404
[   42.676269] PVR_K:   (MKT-F8) 000013B2 00100808 0000051E AD000402
[   42.682769] PVR_K:   (MKT-F9) 000013FA 0010082B 0000051E AD000184
[   42.689331] PVR_K:   (MKT-FA) 0000149B 00108DA9 0000061D AD000281
[   42.695861] PVR_K:   (MKT-FB) 00001632 001199AD 0000061D AD000E02
[   42.702392] PVR_K:   (MKT-FC) 00001697 0010892B 0000061D AD000282
[   42.708801] PVR_K:   (MKT-FD) 00003D11 00100808 0000081F AD000101
[   42.715332] PVR_K:   (MKT-FE) 00003D8A 00100808 0000081F AD000104
[   42.721832] PVR_K:   (MKT-FF) 00003DC6 00100808 0100091E AD000100
[   42.728332] PVR_K:   (MKT-100) 00003ECD 00100808 0100091E AD000501
[   42.734863] PVR_K:   (MKT-101) 00003F0C 00100829 0100091E AD000104
[   42.741516] PVR_K:   (MKT-102) 05C6D12A 00100808 0100031F AD000B00
[   42.748107] PVR_K:   (MKT-103) 05C6D16F 00100808 0100031F AD000B03
[   42.754730] PVR_K:   (MKT-104) 05C6D1F7 00100808 0100031F AD000B05
[   42.761291] PVR_K:   (MKT-105) 05C6D24B 00100808 0100031F AD000B06
[   42.767883] PVR_K:   (MKT-106) 05C6D27A 00100808 0100031F AD000B06
[   42.774627] PVR_K:   (MKT-107) 05C6D2C0 00100808 0100031F AD000B07
[   42.781433] PVR_K:   (MKT-108) 05C6D2E5 00100808 0100031F AD000B09
[   42.788146] PVR_K:   (MKT-109) 05C6D339 00100808 0100031F AD000B01
[   42.794738] PVR_K:   (MKT-10A) 05C6D375 00100808 0100031F AD002300
[   42.801361] PVR_K:   (MKT-10B) 05C6D697 00100808 0100041F AD00000A
[   42.807861] PVR_K:   (MKT-10C) 05C6D71B 00100808 0100041F AD000906
[   42.814453] PVR_K:   (MKT-10D) 05C6D7D5 00100808 0000041F AD000901
[   42.820983] PVR_K:   (MKT-10E) 05C6D850 00100808 0000051E AD000183
[   42.827545] PVR_K:   (MKT-10F) 05C6D9B8 00100808 0000051E AD000302
[   42.834045] PVR_K:   (MKT-110) 05C6DA09 00100808 0000051E AD000303
[   42.840606] PVR_K:   (MKT-111) 05C6DA8C 00100808 0000051E AD000C01
[   42.847137] PVR_K:   (MKT-112) 05C6DAB0 00100808 0000051E 0D800484
[   42.853698] PVR_K:   (MKT-113) 05C6DAC8 00100808 0000051E 00000004
[   42.860198] PVR_K:   (MKT-114) 05C6DD14 00100808 0000051E AD00030E
[   42.866699] PVR_K:   (MKT-115) 05C6DD2C 00100808 0000051E 0D800474
[   42.873229] PVR_K:   (MKT-116) 05C6DD45 00100808 0000051E 00000003
[   42.879760] PVR_K:   (MKT-117) 05C6DD68 00100808 0000051E 00000004
[   42.886413] PVR_K:   (MKT-118) 05C6DDDD 00100808 0000051E AD000184
[   42.893005] PVR_K:   (MKT-119) 05C6DE5B 00100C08 0100061D AD000281
[   42.899597] PVR_K:   (MKT-11A) 05C6DFE8 00100808 0100061D AD00080A
[   42.906127] PVR_K:   (MKT-11B) 05C6E001 00100808 0100061D 0F03D300
[   42.912750] PVR_K:   (MKT-11C) 05C6E019 00100808 0100061D 00000061
[   42.919342] PVR_K:   (MKT-11D) 05C6E132 00100C88 0100061D AD001300
[   42.925933] PVR_K:   (MKT-11E) 05C73285 00100808 0000061D AD001301
[   42.932464] PVR_K:   (MKT-11F) 05C733A9 00100808 0000061D AD000802
[   42.938995] PVR_K:   (MKT-120) 05C7350F 00100808 0000061D AD000803
[   42.945587] PVR_K:   (MKT-121) 05C7355C 00184AC8 0000061D AD000282
[   42.952087] PVR_K:   (MKT-122) 05C754DC 00000C08 01000A1F AD000200
[   42.958618] PVR_K:   (MKT-123) 05C75737 00000808 00000A1F AD000202
[   42.965148] PVR_K:   (MKT-124) 05C757CF 00000808 00000B1E AD000183
[   42.971710] PVR_K:   (MKT-125) 05C758CC 00000808 00000B1E AD00030E
[   42.978240] PVR_K:   (MKT-126) 05C758E4 00000808 00000B1E 0D800474
[   42.984802] PVR_K:   (MKT-127) 05C758FD 00000808 00000B1E 00000003
[   42.991333] PVR_K:   (MKT-128) 05C75921 00000808 00000B1E 00000004
[   42.997863] PVR_K:   (MKT-129) 05C7598A 00000808 00000B1E AD000184
[   43.004394] PVR_K:   (MKT-12A) 05C759F7 00000C08 01000C1D AD000281
[   43.010925] PVR_K:   (MKT-12B) 05C75B5F 00000808 01000C1D AD00080A
[   43.017456] PVR_K:   (MKT-12C) 05C75B78 00000808 01000C1D 0F03D600
[   43.024047] PVR_K:   (MKT-12D) 05C75B90 00000808 01000C1D 00000060
[   43.030670] PVR_K:   (MKT-12E) 05C75E3C 00000808 00000C1D AD000803
[   43.037261] PVR_K:   (MKT-12F) 05C75E82 00188CC8 00000C1D AD000282
[   43.043884] PVR_K:   (MKT-130) 05C75F43 00000808 01000E1F AD000200
[   43.050415] PVR_K:   (MKT-131) 05C76160 00000808 00000E1F AD000202
[   43.057006] PVR_K:   (MKT-132) 05C761DD 00000808 00000F1E AD000183
[   43.063537] PVR_K:   (MKT-133) 05C762C7 00000808 00000F1E AD00030E
[   43.070190] PVR_K:   (MKT-134) 05C762DF 00000808 00000F1E 0D800474
[   43.076812] PVR_K:   (MKT-135) 05C762F8 00000808 00000F1E 00000003
[   43.083496] PVR_K:   (MKT-136) 05C7631D 00000808 00000F1E 00000004
[   43.090148] PVR_K:   (MKT-137) 05C76386 00000808 00000F1E AD000184
[   43.096771] PVR_K:   (MKT-138) 05C763EA 00000C08 0100101D AD000281
[   43.103302] PVR_K:   (MKT-139) 05C76555 00000808 0100101D AD00080A
[   43.109893] PVR_K:   (MKT-13A) 05C7656D 00000808 0100101D 0F03D900
[   43.116455] PVR_K:   (MKT-13B) 05C76586 00000808 0100101D 00000060
[   43.122924] PVR_K:   (MKT-13C) 05C76835 00000808 0000101D AD000803
[   43.129608] PVR_K:   (MKT-13D) 05C7687A 00180CC8 0000101D AD000282
[   43.136199] PVR_K:   (MKT-13E) 05C76969 00000808 0100121F AD000200
[   43.142913] PVR_K:   (MKT-13F) 05C76B83 00000808 0000121F AD000202
[   43.149597] PVR_K:   (MKT-140) 05C76C0C 00000808 0000131E AD000183
[   43.156311] PVR_K:   (MKT-141) 05C76CF8 00000808 0000131E AD00030E
[   43.162841] PVR_K:   (MKT-142) 05C76D10 00000808 0000131E 0D800474
[   43.169433] PVR_K:   (MKT-143) 05C76D29 00000808 0000131E 00000003
[   43.176116] PVR_K:   (MKT-144) 05C76D4E 00000808 0000131E 00000004
[   43.182891] PVR_K:   (MKT-145) 05C76DB8 00000808 0000131E AD000184
[   43.189453] PVR_K:   (MKT-146) 05C76E1D 00000C08 0100141D AD000281
[   43.196075] PVR_K:   (MKT-147) 05C76F89 00000808 0100141D AD00080A
[   43.202697] PVR_K:   (MKT-148) 05C76FA1 00000808 0100141D 0F03DC00
[   43.209289] PVR_K:   (MKT-149) 05C76FBA 00000808 0100141D 00000062
[   43.215881] PVR_K:   (MKT-14A) 05C77264 00000808 0000141D AD000803
[   43.222442] PVR_K:   (MKT-14B) 05C772AC 00180C88 0000141D AD000282
[   43.229187] PVR_K:   (MKT-14C) 05C77D8C 00000808 0100161F AD000200
[   43.235931] PVR_K:   (MKT-14D) 05C77EA7 00000808 0100161F AD001703
[   43.242492] PVR_K:   (MKT-14E) 05C78076 00000808 0000161F AD000202
[   43.248992] PVR_K:   (MKT-14F) 05C780F5 00000808 0100171E AD000183
[   43.255554] PVR_K:   (MKT-150) 05C781E3 00000808 0100171E AD00030E
[   43.262084] PVR_K:   (MKT-151) 05C781FB 00000808 0100171E 0D800474
[   43.268737] PVR_K:   (MKT-152) 05C78214 00000808 0100171E 00000003
[   43.275360] PVR_K:   (MKT-153) 05C78238 00000808 0100171E 00000004
[   43.281982] PVR_K:   (MKT-154) 05C782C3 00000808 0100171E AD000184
[   43.288574] PVR_K:   (MKT-155) 05C84AA3 00000808 01001A1F AD001A00
[   43.295288] PVR_K:   (MKT-156) 07E239CF 00000808 0105D71F AD00000A
[   43.302062] PVR_K:   (MKT-157) 07E23A37 00000808 0105D71F AD000909
[   43.308990] PVR_K:   (MKT-158) 07E23A81 00000808 0105D71F AD001A05
[   43.315948] PVR_K:   (MKT-159) 07E23AB3 00000808 0105D71F AD001302
[   43.322509] PVR_K:   (MKT-15A) 07E23AF2 00000808 0105D71F AD001303
[   43.329162] PVR_K:   (MKT-15B) 07E23B8B 00000808 0105D71F AD000D04
[   43.335693] PVR_K:   (MKT-15C) 07E23C55 00000808 0105D71F AD000D05
[   43.342346] PVR_K:   (MKT-15D) 07E23CC4 00000808 0105D71F AD001A06
[   43.348999] PVR_K:   (MKT-15E) 000004A7 00100808 0100031F AD002300
[   43.355590] PVR_K:   (MKT-15F) 000009BF 00100808 0100041F AD00000A
[   43.362121] PVR_K:   (MKT-160) 00000A30 00100808 0100041F AD000905
[   43.368682] PVR_K:   (MKT-161) 00000B6D 00100808 0000041F AD000901
[   43.375213] PVR_K:   (MKT-162) 00000BEB 00100808 0000051E AD000183
[   43.381713] PVR_K:   (MKT-163) 00000D64 00100808 0000051E AD000302
[   43.388275] PVR_K:   (MKT-164) 00000DBA 00100808 0000051E AD000303
[   43.394775] PVR_K:   (MKT-165) 00000E42 00100808 0000051E AD000C01
[   43.401306] PVR_K:   (MKT-166) 00000E67 00100808 0000051E 0D800464
[   43.407836] PVR_K:   (MKT-167) 00000E80 00100808 0000051E 00000005
[   43.414367] PVR_K:   (MKT-168) 000010DB 00100808 0000051E AD00030E
[   43.420867] PVR_K:   (MKT-169) 000010F3 00100808 0000051E 0D800494
[   43.427398] PVR_K:   (MKT-16A) 0000110C 00100888 0000051E 00000003
[   43.433898] PVR_K:   (MKT-16B) 0000112F 00100808 0000051E 00000004
[   43.440429] PVR_K:   (MKT-16C) 000011A5 00100808 0000051E AD000184
[   43.446929] PVR_K:   (MKT-16D) 00001222 00100C08 0000061D AD000281
[   43.453491] PVR_K:   (MKT-16E) 000013B8 00100808 0000061D AD00080A
[   43.460021] PVR_K:   (MKT-16F) 000013D2 00100808 0000061D 0F03DF00
[   43.466522] PVR_K:   (MKT-170) 000013EB 00100808 0000061D 00000061
[   43.473083] PVR_K:   (MKT-171) 0000150A 00100C88 0000061D AD001300
[   43.479583] PVR_K:   (MKT-172) 00001644 00100808 0000061D AD001301
[   43.486145] PVR_K:   (MKT-173) 0000177A 00100808 0000061D AD000802
[   43.492645] PVR_K:   (MKT-174) 000018E8 00100808 0000061D AD000803
[   43.499206] PVR_K:   (MKT-175) 00001937 00184AC8 0000061D AD000282
[   43.505706] PVR_K:   (MKT-176) 00001A25 00180CB8 0000071F AD00000A
[   43.512237] PVR_K:   (MKT-177) 00001A9D 00180838 0000071F AD000905
[   43.518737] PVR_K:   (MKT-178) 00001BBB 00180838 0000071F AD000901
[   43.525299] PVR_K:   (MKT-179) 00001C41 00180838 0000091C AD00000A
[   43.531799] PVR_K:   (MKT-17A) 00001CA3 00180838 0000091C AD000905
[   43.538330] PVR_K:   (MKT-17B) 00001D4B 00180838 0000091C AD000901
[   43.544891] PVR_K:   (MKT-17C) 00001DA8 00180838 00000B1D AD00000A
[   43.551361] PVR_K:   (MKT-17D) 00001E0F 00180838 00000B1D AD000905
[   43.557922] PVR_K:   (MKT-17E) 00001EBC 00180838 00000B1D AD000901
[   43.564422] PVR_K:   (MKT-17F) 00001F42 00180838 00000C1A AD000183
[   43.570983] PVR_K:   (MKT-180) 00002061 00180838 00000C1A AD00030E
[   43.577484] PVR_K:   (MKT-181) 00002079 00180838 00000C1A 0D800494
[   43.584014] PVR_K:   (MKT-182) 00002093 00180838 00000C1A 00000003
[   43.590515] PVR_K:   (MKT-183) 000020B8 00180838 00000C1A 00000004
[   43.597076] PVR_K:   (MKT-184) 00002124 00180838 00000C1A AD000184
[   43.603576] PVR_K:   (MKT-185) 0000219E 00180C38 01000D19 AD000281
[   43.610107] PVR_K:   (MKT-186) 000021F9 00180838 01000D19 AD000282
[   43.616638] PVR_K:   (MKT-187) 00003A2C 00000808 01000E1F AD000200
[   43.623168] PVR_K:   (MKT-188) 00003C79 00000808 00000E1F AD000202
[   43.629699] PVR_K:   (MKT-189) 00003CF9 00000808 00000F1E AD000183
[   43.636199] PVR_K:   (MKT-18A) 00003DE8 00000808 00000F1E AD00030E
[   43.642761] PVR_K:   (MKT-18B) 00003E01 00000808 00000F1E 0D800494
[   43.649261] PVR_K:   (MKT-18C) 00003E1B 00000808 00000F1E 00000003
[   43.655822] PVR_K:   (MKT-18D) 00003E3F 00000808 00000F1E 00000004
[   43.662292] PVR_K:   (MKT-18E) 00003EAA 00000808 00000F1E AD000184
[   43.668853] PVR_K:   (MKT-18F) 00003F10 00000C08 0100101D AD000281
[   43.675354] PVR_K:   (MKT-190) 00004084 00000808 0100101D AD00080A
[   43.681884] PVR_K:   (MKT-191) 0000409D 00000808 0100101D 0F03E200
[   43.688354] PVR_K:   (MKT-192) 000040B5 00000808 0100101D 00000060
[   43.694915] PVR_K:   (MKT-193) 0000437B 00000808 0000101D AD000803
[   43.701416] PVR_K:   (MKT-194) 000043C4 00180CC8 0000101D AD000282
[   43.707916] PVR_K:   (MKT-195) 0000447F 00000808 0100121F AD000200
[   43.714447] PVR_K:   (MKT-196) 000046A0 00000808 0000121F AD000202
[   43.720947] PVR_K:   (MKT-197) 00004722 00000808 0000131E AD000183
[   43.727478] PVR_K:   (MKT-198) 0000480F 00000808 0000131E AD00030E
[   43.733978] PVR_K:   (MKT-199) 00004828 00000808 0000131E 0D800494
[   43.740509] PVR_K:   (MKT-19A) 00004840 00000808 0000131E 00000003
[   43.747009] PVR_K:   (MKT-19B) 00004865 00000808 0000131E 00000004
[   43.753540] PVR_K:   (MKT-19C) 000048D3 00000808 0000131E AD000184
[   43.760070] PVR_K:   (MKT-19D) 0000493A 00000C08 0100141D AD000281
[   43.766601] PVR_K:   (MKT-19E) 00004AA7 00000808 0100141D AD00080A
[   43.773101] PVR_K:   (MKT-19F) 00004AC2 00000808 0100141D 0F03E500
[   43.779632] PVR_K:   (MKT-1A0) 00004ADA 00000808 0100141D 00000060
[   43.786193] PVR_K:   (MKT-1A1) 00004D97 00000808 0000141D AD000803
[   43.792694] PVR_K:   (MKT-1A2) 00004DDE 00188CC8 0000141D AD000282
[   43.799255] PVR_K:   (MKT-1A3) 00004ECB 00000808 0100161F AD000200
[   43.805725] PVR_K:   (MKT-1A4) 000050EA 00000808 0000161F AD000202
[   43.812286] PVR_K:   (MKT-1A5) 0000516D 00000808 0000171E AD000183
[   43.818786] PVR_K:   (MKT-1A6) 00005258 00000808 0000171E AD00030E
[   43.825317] PVR_K:   (MKT-1A7) 00005270 00000808 0000171E 0D800494
[   43.831817] PVR_K:   (MKT-1A8) 00005289 00000808 0000171E 00000003
[   43.838348] PVR_K:   (MKT-1A9) 000052AC 00000808 0000171E 00000004
[   43.844848] PVR_K:   (MKT-1AA) 00005317 00000808 0000171E AD000184
[   43.851409] PVR_K:   (MKT-1AB) 0000537D 00000C08 0100181D AD000281
[   43.857879] PVR_K:   (MKT-1AC) 000054E9 00000808 0100181D AD00080A
[   43.864440] PVR_K:   (MKT-1AD) 00005501 00000808 0100181D 0F03E800
[   43.870971] PVR_K:   (MKT-1AE) 0000551A 00000808 0100181D 00000062
[   43.877471] PVR_K:   (MKT-1AF) 000057D6 00000808 0000181D AD000803
[   43.884033] PVR_K:   (MKT-1B0) 0000581C 00180C88 0000181D AD000282
[   43.890533] PVR_K:   (MKT-1B1) 0000639D 00000C08 01001B1F AD000200
[   43.897064] PVR_K:   (MKT-1B2) 000064C9 00000888 01001B1F AD001703
[   43.903564] PVR_K:   (MKT-1B3) 000066D4 00000808 00001B1F AD000202
[   43.910125] PVR_K:   (MKT-1B4) 00006778 00000808 00001C1E AD00000A
[   43.916656] PVR_K:   (MKT-1B5) 000067E4 00000888 00001C1E AD000905
[   43.923187] PVR_K:   (MKT-1B6) 000068F0 00000808 00001C1E AD000901
[   43.929687] PVR_K:   (MKT-1B7) 00006959 00000808 00001D1D AD000183
[   43.936248] PVR_K:   (MKT-1B8) 00006A46 00000808 00001D1D AD00030E
[   43.942749] PVR_K:   (MKT-1B9) 00006A5E 00000808 00001D1D 0D800494
[   43.949279] PVR_K:   (MKT-1BA) 00006A77 00000808 00001D1D 00000003
[   43.955841] PVR_K:   (MKT-1BB) 00006A9B 00000808 00001D1D 00000004
[   43.962341] PVR_K:   (MKT-1BC) 00006B06 00000808 00001D1D AD000184
[   43.968872] PVR_K:   (MKT-1BD) 00006BAC 00000808 00001E1F AD00000A
[   43.975372] PVR_K:   (MKT-1BE) 00006C14 00000808 00001E1F AD000905
[   43.981933] PVR_K:   (MKT-1BF) 00006D00 00000808 00001E1F AD000901
[   43.988433] PVR_K:   (MKT-1C0) 00006D4F 00000C08 00001F1C AD000281
[   43.994964] PVR_K:   (MKT-1C1) 00006E68 00000808 00001F1C AD000E02
[   44.001464] PVR_K:   (MKT-1C2) 00006EB8 00000808 00001F1C AD000282
[   44.008026] PVR_K:   (MKT-1C3) 00006F6B 00000808 0000201E AD00000A
[   44.014526] PVR_K:   (MKT-1C4) 00006FD5 00000808 0000201E AD000905
[   44.021057] PVR_K:   (MKT-1C5) 000070BF 00000808 0000201E AD000901
[   44.027557] PVR_K:   (MKT-1C6) 0000712B 00000808 0000211D AD000183
[   44.034088] PVR_K:   (MKT-1C7) 00007216 00000808 0000211D AD00030E
[   44.040649] PVR_K:   (MKT-1C8) 0000722E 00000808 0000211D 0D800494
[   44.047149] PVR_K:   (MKT-1C9) 00007247 00000808 0000211D 00000003
[   44.053680] PVR_K:   (MKT-1CA) 0000726B 00000808 0000211D 00000004
[   44.060180] PVR_K:   (MKT-1CB) 000072D8 00000808 0000211D AD000184
[   44.066711] PVR_K:   (MKT-1CC) 0000737B 00000808 0000221F AD00000A
[   44.073211] PVR_K:   (MKT-1CD) 000073E4 00000808 0000221F AD000905
[   44.079864] PVR_K:   (MKT-1CE) 000074CE 00000808 0000221F AD000901
[   44.086425] PVR_K:   (MKT-1CF) 0000751C 00000C08 0000231C AD000281
[   44.093017] PVR_K:   (MKT-1D0) 00007614 00000808 0000231C AD000E02
[   44.099578] PVR_K:   (MKT-1D1) 00007667 00000808 0000231C AD000282
[   44.106140] PVR_K:   (MKT-1D2) 000076F1 00000808 0100241E AD000183
[   44.113067] PVR_K:   (MKT-1D3) 000077E9 00000808 0100241E AD00030E
[   44.119628] PVR_K:   (MKT-1D4) 00007801 00000808 0100241E 0D800494
[   44.126159] PVR_K:   (MKT-1D5) 00007819 00000808 0100241E 00000003
[   44.133087] PVR_K:   (MKT-1D6) 0000783C 00000808 0100241E 00000004
[   44.139648] PVR_K:   (MKT-1D7) 000078C7 00000808 0100241E AD000184
[   44.146270] PVR_K:   (MKT-1D8) 00017BB0 00000808 0100271F AD001A00
[   44.152832] PVR_K:   (MKT-1D9) 0002EAEE 00000808 01002B1F AD00000A
[   44.159332] PVR_K:   (MKT-1DA) 0002EB50 00000808 01002B1F AD000909
[   44.165924] PVR_K:   (MKT-1DB) 0002EB9D 00000808 01002B1F AD001A05
[   44.172485] PVR_K:   (MKT-1DC) 0002EBCE 00000808 01002B1F AD001302
[   44.179077] PVR_K:   (MKT-1DD) 0002EC10 00000808 01002B1F AD001303
[   44.185607] PVR_K:   (MKT-1DE) 0002ECAB 00000808 01002B1F AD000D04
[   44.192199] PVR_K:   (MKT-1DF) 0002ED83 00000808 01002B1F AD000D05
[   44.198760] PVR_K:   (MKT-1E0) 0002EDF2 00000808 01002B1F AD001A06
[   44.205383] PVR_K:   (MKT-1E1) 00000485 00100808 0100031F AD002300
[   44.211975] PVR_K:   (MKT-1E2) 0000096E 00100808 0100041F AD00000A
[   44.218505] PVR_K:   (MKT-1E3) 000009EA 00100808 0100041F AD000906
[   44.225097] PVR_K:   (MKT-1E4) 00000AB9 00100808 0000041F AD000901
[   44.231689] PVR_K:   (MKT-1E5) 00000B31 00100808 0000051E AD000183
[   44.238281] PVR_K:   (MKT-1E6) 00000CA8 00100808 0000051E AD000302
[   44.244842] PVR_K:   (MKT-1E7) 00000E3A 00100808 0000051E AD000D06
[   44.251495] PVR_K:   (MKT-1E8) 00000F25 00100808 0000051E AD000D07
[   44.258178] PVR_K:   (MKT-1E9) 00000F6F 00100808 0000051E AD001304
[   44.264862] PVR_K:   (MKT-1EA) 0000105D 00100808 0000051E AD001305
[   44.271331] PVR_K:   (MKT-1EB) 00001171 00100888 0000051E AD000404
[   44.277984] PVR_K:   (MKT-1EC) 00001238 00100808 0000051E AD000402
[   44.284515] PVR_K:   (MKT-1ED) 00001282 0010082B 0000051E AD000184
[   44.291107] PVR_K:   (MKT-1EE) 00001323 00118DA9 0000061D AD000281
[   44.298065] PVR_K:   (MKT-1EF) 000014B2 001089AF 0000061D AD000E02
[   44.304687] PVR_K:   (MKT-1F0) 0000150E 0010892B 0000061D AD000282
[   44.311218] PVR_K:   (MKT-1F1) 00003B2A 00100808 0000081F AD000101
[   44.317840] PVR_K:   (MKT-1F2) 00003BA0 00100808 0000081F AD000104
[   44.324523] PVR_K:   (MKT-1F3) 00003BDD 00100808 0100091E AD000100
[   44.331115] PVR_K:   (MKT-1F4) 00003CEA 00100808 0100091E AD000501
[   44.337738] PVR_K:   (MKT-1F5) 00003D29 0010082B 0100091E AD000104
[   44.344299] PVR_K:   (MKT-1F6) 00005F85 00100828 01000A1F AD000101
[   44.350891] PVR_K:   (MKT-1F7) 00005FC9 00100828 01000A1F AD000104
[   44.357421] PVR_K:   (MKT-1F8) 000060E2 00100808 01000B1F AD000100
[   44.364013] PVR_K:   (MKT-1F9) 0000619D 00100808 01000B1F AD000501
[   44.370574] PVR_K:   (MKT-1FA) 000061C8 00100829 01000B1F AD000104
[   44.377197] PVR_K:   (MKT-1FB) 00008717 00100828 01000D1F AD000101
[   44.383789] PVR_K:   (MKT-1FC) 00008790 00100828 01000D1F AD000104
[   44.390350] PVR_K:   (MKT-1FD) 000087CD 00100808 01000E1E AD000100
[   44.396911] PVR_K:   (MKT-1FE) 000088C9 00100808 01000E1E AD000501
[   44.403472] PVR_K:   (MKT-1FF) 00008908 00100829 01000E1E AD000104
[   44.410064] PVR_K: SGX Kernel CCB WO:0x45 RO:0x45
[   44.417449] adc_to_temp_conversion:Temp read is invalid 0
[   44.424438] thermal_lookup_temp: getting temp is not supported for domain pcb
[   44.445281] adc_to_temp_conversion:Temp read is invalid 0
[   44.452484] thermal_lookup_temp: getting temp is not supported for domain pcb
[   44.465148] adc_to_temp_conversion:Temp read is invalid 0
[   44.471038] thermal_lookup_temp: getting temp is not supported for domain pcb
[   44.631713] PVR_K:(Error): SGXOSTimer() detected SGX lockup (0x7 tasks) [0, ]
[   44.639373] PVR_K: HWRecoveryResetSGX: SGX Hardware Recovery triggered
[   44.657135] [   19.772]                        [c738c400] dsscomp_new
[   44.657135] [   19.772]    [c6edb7a0] ++refs=2 for [c738c400]
[   44.657135] [   19.772]                        [c738c400] dsscomp_delayed_apply
[   44.657135] [   19.772]    [c6edb7a0] --refs=1 on RELEASED
[   44.657135] [   19.772]                        [c738c400] dsscomp_apply
[   44.688323] [   19.773]                        [c738c400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   44.688323] [   19.779]    [c6e89d40] new in dsscomp_gralloc_queue (refs=1)
[   44.688323] [   19.779]                           [c6e64400] dsscomp_new
[   44.688323] [   19.779]    [c6e89d40] ++refs=2 for [c6e64400]
[   44.718353] [   19.779]                           [c6e64400] dsscomp_delayed_apply
[   44.718353] [   19.779]    [c6e89d40] --refs=1 on RELEASED
[   44.718353] [   19.779]                           [c6e64400] dsscomp_apply
[   44.718353] [   19.801]                        [c738c400] dsscomp_mgr_delayed_cb on DISPLAYED
[   44.748168] [   19.801]    [c6edb7a0] --refs=0 on RELEASED
[   44.748168] [   19.801]    [c6edb7a0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   44.748168] [   19.801]                        [c738c400] dsscomp_mgr_delayed_cb on RELEASED
[   44.748168] [   19.801]   [c6edb760] new in dsscomp_gralloc_queue (refs=1)
[   44.778442] [   19.801]                        [c6f10400] dsscomp_new
[   44.778442] [   19.801]   [c6edb760] ++refs=2 for [c6f10400]
[   44.778442] [   19.801]                        [c6f10400] dsscomp_delayed_apply
[   44.778442] [   19.801]   [c6edb760] --refs=1 on RELEASED
[   44.808258] [   19.801]                           [c6e64400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   44.808288] [   19.801]                        [c6f10400] dsscomp_apply
[   44.808288] [   19.816]                           [c6e64400] dsscomp_mgr_delayed_cb on DISPLAYED
[   44.808288] [   19.816]    [c6e89d40] --refs=0 on RELEASED
[   44.838104] [   19.816]    [c6e89d40] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   44.838104] [   19.816]                           [c6e64400] dsscomp_mgr_delayed_cb on RELEASED
[   44.838134] [   19.816]                        [c6f10400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   44.868377] [   19.832]                        [c6f10400] dsscomp_mgr_delayed_cb on DISPLAYED
[   44.868377] [   24.345]   [c6edb920] new in dsscomp_gralloc_queue (refs=1)
[   44.868377] [   24.345]                         [c6f11400] dsscomp_new
[   44.868377] [   24.345]   [c6edb920] ++refs=2 for [c6f11400]
[   44.898895] [   24.345]                         [c6f11400] dsscomp_delayed_apply
[   44.898895] [   24.345]   [c6edb920] --refs=1 on RELEASED
[   44.898895] [   24.345]                         [c6f11400] dsscomp_apply
[   44.898895] [   24.345]   [c6edb760] --refs=0 on RELEASED
[   44.898895] [   24.345]   [c6edb760] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   44.930358] [   24.345]                        [c6f10400] dsscomp_mgr_delayed_cb on RELEASED
[   44.930358] [   24.345]                         [c6f11400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   44.930389] [   24.369]                         [c6f11400] dsscomp_mgr_delayed_cb on DISPLAYED
[   44.958740] [   28.901]    [c6e89d40] new in dsscomp_gralloc_queue (refs=1)
[   44.958740] [   28.901]                           [c6e64400] dsscomp_new
[   44.958740] [   28.901]    [c6e89d40] ++refs=2 for [c6e64400]
[   44.958740] [   28.901]                           [c6e64400] dsscomp_delayed_apply
[   44.988555] [   28.901]    [c6e89d40] --refs=1 on RELEASED
[   44.988586] [   28.901]                           [c6e64400] dsscomp_apply
[   44.988586] [   28.901]   [c6edb920] --refs=0 on RELEASED
[   44.988586] [   28.901]   [c6edb920] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   44.988586] [   28.901]                         [c6f11400] dsscomp_mgr_delayed_cb on RELEASED
[   45.019866] [   28.901]                           [c6e64400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   45.019866] [   28.902] [c6e89d60] new in dsscomp_gralloc_queue (refs=1)
[   45.019897] [   28.902]                      [c6e64800] dsscomp_new
[   45.048217] [   28.902] [c6e89d60] ++refs=2 for [c6e64800]
[   45.048217] [   28.902]                      [c6e64800] dsscomp_delayed_apply
[   45.048217] [   28.902] [c6e89d60] --refs=1 on RELEASED
[   45.048217] [   28.902]                      [c6e64800] dsscomp_apply
[   45.048217] [   28.925]                           [c6e64400] dsscomp_mgr_delayed_cb on DISPLAYED
[   45.079528] [   28.925]    [c6e89d40] --refs=0 on RELEASED
[   45.079528] [   28.925]    [c6e89d40] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   45.079528] [   28.925]                           [c6e64400] dsscomp_mgr_delayed_cb on RELEASED
[   45.107818] [   28.925]                      [c6e64800] dsscomp_mgr_delayed_cb on PROGRAMMED
[   45.107818] [   28.942]                      [c6e64800] dsscomp_mgr_delayed_cb on DISPLAYED
[   45.107818] [   33.971]  [c6e89da0] new in dsscomp_gralloc_queue (refs=1)
[   45.107818] [   33.971]                        [c6e64c00] dsscomp_new
[   45.137939] [   33.971]  [c6e89da0] ++refs=2 for [c6e64c00]
[   45.137939] [   33.971]                        [c6e64c00] dsscomp_delayed_apply
[   45.137939] [   33.971]  [c6e89da0] --refs=1 on RELEASED
[   45.137969] [   33.971]                        [c6e64c00] dsscomp_apply
[   45.168029] [   33.971] [c6e89d60] --refs=0 on RELEASED
[   45.168029] [   33.971] [c6e89d60] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   45.168060] [   33.971]                      [c6e64800] dsscomp_mgr_delayed_cb on RELEASED
[   45.168060] [   33.971]                        [c6e64c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   45.197906] [   33.972]      [c6edb820] new in dsscomp_gralloc_queue (refs=1)
[   45.197906] [   33.972]                      [c6f10000] dsscomp_new
[   45.197906] [   33.972]      [c6edb820] ++refs=2 for [c6f10000]
[   45.197906] [   33.972]                      [c6f10000] dsscomp_delayed_apply
[   45.227752] [   33.972]      [c6edb820] --refs=1 on RELEASED
[   45.227752] [   33.972]                      [c6f10000] dsscomp_apply
[   45.227752] [   33.993]                        [c6e64c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   45.227752] [   33.993]  [c6e89da0] --refs=0 on RELEASED
[   45.227752] [   33.993]  [c6e89da0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   45.259033] [   34.001]                        [c6e64c00] dsscomp_mgr_delayed_cb on RELEASED
[   45.259063] [   34.001]                      [c6f10000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   45.259063] [   34.008]                      [c6f10000] dsscomp_mgr_delayed_cb on DISPLAYED
[   45.287322] [   39.512]   [c6edba00] new in dsscomp_gralloc_queue (refs=1)
[   45.287322] [   39.512]                        [c6f12000] dsscomp_new
[   45.287322] [   39.512]   [c6edba00] ++refs=2 for [c6f12000]
[   45.287322] [   39.512]                        [c6f12000] dsscomp_delayed_apply
[   45.317108] [   39.512]   [c6edba00] --refs=1 on RELEASED
[   45.317138] [   39.512]                        [c6f12000] dsscomp_apply
[   45.317138] [   39.512]      [c6edb820] --refs=0 on RELEASED
[   45.317138] [   39.512]      [c6edb820] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   45.317138] [   39.512]                      [c6f10000] dsscomp_mgr_delayed_cb on RELEASED
[   45.348449] [   39.512]                        [c6f12000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   45.348449] [   39.513]      [c6edb820] new in dsscomp_gralloc_queue (refs=1)
[   45.348449] [   39.513]                      [c6f10000] dsscomp_new
[   45.376678] [   39.513]      [c6edb820] ++refs=2 for [c6f10000]
[   45.376678] [   39.513]                      [c6f10000] dsscomp_delayed_apply
[   45.376678] [   39.513]      [c6edb820] --refs=1 on RELEASED
[   45.376678] [   39.513]                      [c6f10000] dsscomp_apply
[   45.376678] [   39.527]                        [c6f12000] dsscomp_mgr_delayed_cb on DISPLAYED
[   45.408081] [   39.527]   [c6edba00] --refs=0 on RELEASED
[   45.408081] [   39.527]   [c6edba00] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   45.408081] [   39.527]                        [c6f12000] dsscomp_mgr_delayed_cb on RELEASED
[   45.436340] [   39.527]                      [c6f10000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   45.436370] [   39.550]                      [c6f10000] dsscomp_mgr_delayed_cb on DISPLAYED
[   45.436370] [   44.408]    [c6edb7a0] new in dsscomp_gralloc_queue (refs=1)
[   45.436370] [   44.408]                        [c6f12000] dsscomp_new
[   45.466156] [   44.408]    [c6edb7a0] ++refs=2 for [c6f12000]
[   45.466156] [   44.408]                        [c6f12000] dsscomp_delayed_apply
[   45.466156] [   44.408]    [c6edb7a0] --refs=1 on RELEASED
[   45.466156] [   44.408]                        [c6f12000] dsscomp_apply
[   45.496032] [   44.408]      [c6edb820] --refs=0 on RELEASED
[   45.496032] [   44.408]      [c6edb820] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   45.496032] [   44.408]                      [c6f10000] dsscomp_mgr_delayed_cb on RELEASED
[   45.496032] [   44.409]                        [c6f12000]
[   45.496948] adc_to_temp_conversion:Temp read is invalid 0
[   45.496978] thermal_lookup_temp: getting temp is not supported for domain pcb
[   45.497833] adc_to_temp_conversion:Temp read is invalid 0
[   45.497833] thermal_lookup_temp: getting temp is not supported for domain pcb
[   45.498687] adc_to_temp_conversion:Temp read is invalid 0
[   45.498687] thermal_lookup_temp: getting temp is not supported for domain pcb
[   45.566192]  dsscomp_mgr_delayed_cb on PROGRAMMED
[   45.566192] [   44.409]      [c6edb820] new in dsscomp_gralloc_queue (refs=1)
[   45.566192] [   44.409]                      [c6f10000] dsscomp_new
[   45.566192] [   44.409]      [c6edb820] ++refs=2 for [c6f10000]
[   45.566192] [   44.409]                      [c6f10000] dsscomp_delayed_apply
[   45.597320] [   44.409]      [c6edb820] --refs=1 on RELEASED
[   45.597320] [   44.409]                      [c6f10000] dsscomp_apply
[   45.597320] [   44.425]                        [c6f12000] dsscomp_mgr_delayed_cb on DISPLAYED
[   45.597320] [   44.430]    [c6edb7a0] --refs=0 on RELEASED
[   45.627197] [   44.430]    [c6edb7a0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   45.627197] [   44.430]                        [c6f12000] dsscomp_mgr_delayed_cb on RELEASED
[   45.627197] [   44.430]                      [c6f10000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   45.627197] [   44.464]                      [c6f10000] dsscomp_mgr_delayed_cb on DISPLAYED
[   45.657043] ACTIVE COMPOSITIONS on lcd
[   45.657043]
[   45.657043]   [c6f10000]: DISPLAYED
[   45.657043]     sync_id=0, flags=AD-
[   45.657043]     ovl0={ON z0 ARGB32-8888 premult *100% 864*480:0,0+864,480 rot0 => 0,0+864,480 7f358000/  (null)|3456}
[   45.657043]     gsync=[c6edb820] dsscomp_gralloc_cb
[   45.689941]
[   45.689941]   DISPC pipeline:
[   45.689941]
[   45.689941]     info:        clean (none)
[   45.689941]     cache:       clean (none)
[   45.689941]     shadow:  ACT clean (none)
[   45.689941]     dispc:   DISPLAYED mask=---R [c6f10000] dsscomp_mgr_callback
[   45.689971]
[   45.689971] ACTIVE COMPOSITIONS on tv
[   45.689971]
[   45.689971]   DISPC pipeline:
[   45.689971]
[   45.689971]     info:        clean (none)
[   45.733459]     cache:       clean (none)
[   45.733459]     shadow:  off clean (none)
[   45.733459]     dispc:   DISPLAYED (none)
[   45.733459]
[   45.733459] ACTIVE COMPOSITIONS on lcd2
[   45.733489]
[   45.733489]   DISPC pipeline:
[   45.733489]
[   45.733489]     info:        clean (none)
[   45.733489]     cache:       clean (none)
[   45.733489]     shadow:  off clean (none)
[   45.733489]     dispc:             (none)
[   45.775543]
[   45.775543] ACTIVE GRALLOC FLIPS
[   45.775573]
[   45.775573]   [c6edb820] (refs=1)
[   45.775573]     slots=[7f358000]
[   45.775573]     cmdcb=[c73f6900] dsscomp_proxy_cmdcomplete
[   45.775573]
[   45.775573]   |           lcd
[   45.775573]   | [c6f10000] DISPL'D
[   45.775573]   |     44.409  ACTIVE
[   45.775573]   |     44.409 APPLY'N
[   45.775573]   |     44.409 APPLIED
[   45.817565]   |     44.430 PROGR'D
[   45.817596]   |     44.464 DISPL'D
[   45.817596]
[   45.817596]
[   45.828765] PVR_K: SGX debug (blaze_android_sgx_ogles1_ogles2_GPL sgxddk 18 1.8@869593)
[   45.837371] PVR_K:(Error): SGX Register Base Address (Linear):   0xC8B20000 [0, ]
[   45.845397] PVR_K:(Error): SGX Register Base Address (Physical): 0x56000000 [0, ]
[   45.853454] PVR_K: (P0) EUR_CR_CORE_ID:          01140000
[   45.859252] PVR_K: (P0) EUR_CR_CORE_REVISION:    00010200
[   45.865112] PVR_K: (P0) EUR_CR_EVENT_STATUS:     20000000
[   45.870941] PVR_K: (P0) EUR_CR_EVENT_STATUS2:    00000008
[   45.876708] PVR_K: (P0) EUR_CR_BIF_CTRL:         00000000
[   45.882446] PVR_K: (P0) EUR_CR_BIF_INT_STAT:     00008000
[   45.888305] PVR_K: (P0) EUR_CR_BIF_FAULT:        00000000
[   45.894073] PVR_K: (P0) EUR_CR_BIF_MEM_REQ_STAT: 00000000
[   45.899963] PVR_K: (P0) EUR_CR_CLKGATECTL:       000AAA6A
[   45.905761] PVR_K: (P0) EUR_CR_PDS_PC_BASE:      00004008
[   45.911590] PVR_K: Flip Command Complete Data 0 for display device 1:
[   45.918487] PVR_K:   SRC 0: (Not in use)
[   45.922698] PVR_K: Flip Command Complete Data 1 for display device 1:
[   45.929656] PVR_K:   SRC 0: ROC DevVAddr:0xD800474 ROP:0x7 ROC:0x5, WOC DevVAddr:0xD800464 WOP:0x7 WOC:0x6
[   45.939910] PVR_K: SGX Host control:
[   45.943725] PVR_K:   (HC-0) 0x00000001 0x00000000 0x00000000 0x00000001
[   45.950744] PVR_K:   (HC-10) 0x00000007 0x0000000A 0x0005DC00 0x00000003
[   45.957885] PVR_K:   (HC-20) 0x00000000 0x00000001 0x00000000 0x00000008
[   45.964935] PVR_K:   (HC-30) 0x00000605 0xF0C48E5C 0x00000000 0x00000000
[   45.972015] PVR_K:   (HC-40) 0x00000000 0x087BF500 0x087C6300 0x087C3100
[   45.979064] PVR_K: SGX TA/3D control:
[   45.983032] PVR_K:   (T3C-0) 0x0F003000 0x0F003120 0x0F002000 0x00000000
[   45.990081] PVR_K:   (T3C-10) 0x00000001 0x00000002 0x00000001 0x0F00DD00
[   45.997314] PVR_K:   (T3C-20) 0x00000000 0x00000000 0x00000000 0x00000000
[   46.004486] PVR_K:   (T3C-30) 0x00000000 0x00000000 0x00000000 0x00000000
[   46.011657] PVR_K:   (T3C-40) 0x00000000 0x00000000 0x00000000 0x00000000
[   46.018829] PVR_K:   (T3C-50) 0x0F00DD00 0x00000000 0x00000000 0x0F00DD00
[   46.026123] PVR_K:   (T3C-60) 0x00000000 0x00000000 0x0F00DD00 0x00000000
[   46.033325] PVR_K:   (T3C-70) 0x00000000 0x0F00DD00 0x00000000 0x0F004000
[   46.040496] PVR_K:   (T3C-80) 0x000000E2 0x0001120F 0x00000000 0x0F00DEB8
[   46.047729] PVR_K:   (T3C-90) 0x00000000 0x0F000000 0xAB600000 0x0F040000
[   46.054901] PVR_K:   (T3C-A0) 0x00000000 0x0F0109A0 0x0F00DD00 0x0F00DEB8
[   46.062133] PVR_K:   (T3C-B0) 0x0F010BE0 0x00000000 0x00000000 0x00000000
[   46.069366] PVR_K:   (T3C-C0) 0x00000000 0x00000000 0x00000000 0x00000000
[   46.076507] PVR_K:   (T3C-D0) 0x00000000 0x0000000C 0x0000000B 0x0F007000
[   46.083770] PVR_K:   (T3C-E0) 0x0F00D420 0x0F00E000 0x0F010720 0x0F010720
[   46.091003] PVR_K:   (T3C-F0) 0x00000000 0x000000B5 0x000000B5 0x00000000
[   46.098205] PVR_K:   (T3C-100) 0x00000003 0x00000000 0x00000000 0x00000000
[   46.105499] PVR_K:   (T3C-110) 0xB50C565C 0x0872E100 0x08787B00 0x08787B00
[   46.112762] PVR_K: Last SGX microkernel status code: AD000282
[   46.118957] PVR_K:   (MKT-0) 0738A76E 00000808 01002B1D 00000060
[   46.125274] PVR_K:   (MKT-1) 0738AA1E 00000808 00002B1D AD000803
[   46.131622] PVR_K:   (MKT-2) 0738AA63 00188CC8 00002B1D AD000282
[   46.137969] PVR_K:   (MKT-3) 0738AB53 00000808 01002D1F AD000200
[   46.144409] PVR_K:   (MKT-4) 0738AD6E 00000808 00002D1F AD000202
[   46.150787] PVR_K:   (MKT-5) 0738ADF1 00000808 00002E1E AD000183
[   46.157104] PVR_K:   (MKT-6) 0738AEDA 00000808 00002E1E AD00030E
[   46.163452] PVR_K:   (MKT-7) 0738AEF3 00000808 00002E1E 0D800494
[   46.169799] PVR_K:   (MKT-8) 0738AF0B 00000808 00002E1E 00000002
[   46.176208] PVR_K:   (MKT-9) 0738AF2F 00000808 00002E1E 00000003
[   46.182525] PVR_K:   (MKT-A) 0738AF98 00000808 00002E1E AD000184
[   46.188934] PVR_K:   (MKT-B) 0738AFFF 00000C08 01002F1D AD000281
[   46.195312] PVR_K:   (MKT-C) 0738B17B 00000808 01002F1D AD00080A
[   46.201690] PVR_K:   (MKT-D) 0738B194 00000808 01002F1D 0F03D000
[   46.208038] PVR_K:   (MKT-E) 0738B1B4 00000808 01002F1D 00000062
[   46.214447] PVR_K:   (MKT-F) 0738B46C 00000808 00002F1D AD000803
[   46.220794] PVR_K:   (MKT-10) 0738B4B2 00180C88 00002F1D AD000282
[   46.227264] PVR_K:   (MKT-11) 0738BFDA 00000808 0100311F AD000200
[   46.233703] PVR_K:   (MKT-12) 0738C0F8 00000808 0100311F AD001703
[   46.240234] PVR_K:   (MKT-13) 0738C2DB 00000808 0000311F AD000202
[   46.246643] PVR_K:   (MKT-14) 0738C359 00000808 0000321E AD000183
[   46.253112] PVR_K:   (MKT-15) 0738C446 00000808 0000321E AD00030E
[   46.259521] PVR_K:   (MKT-16) 0738C45F 00000808 0000321E 0D800494
[   46.265960] PVR_K:   (MKT-17) 0738C478 00000808 0000321E 00000002
[   46.272460] PVR_K:   (MKT-18) 0738C49C 00000808 0000321E 00000003
[   46.278930] PVR_K:   (MKT-19) 0738C507 00000808 0000321E AD000184
[   46.285430] PVR_K:   (MKT-1A) 0738C56C 00000C08 0100331D AD000281
[   46.291870] PVR_K:   (MKT-1B) 0738C67D 00000808 0100331D AD000E02
[   46.298339] PVR_K:   (MKT-1C) 0738C6F0 00000808 0100331D AD000282
[   46.304809] PVR_K:   (MKT-1D) 073997F5 00000808 0100361F AD001A00
[   46.311309] PVR_K:   (MKT-1E) 073A78F4 00000808 0100391F AD00000A
[   46.317749] PVR_K:   (MKT-1F) 073A7955 00000808 0100391F AD000909
[   46.324310] PVR_K:   (MKT-20) 073A799F 00000808 0100391F AD001A05
[   46.330718] PVR_K:   (MKT-21) 073A79D3 00000808 0100391F AD001302
[   46.337188] PVR_K:   (MKT-22) 073A7A15 00000808 0100391F AD001303
[   46.343627] PVR_K:   (MKT-23) 073A7AA5 00000808 0100391F AD000D04
[   46.350097] PVR_K:   (MKT-24) 073A7B70 00000808 0100391F AD000D05
[   46.356506] PVR_K:   (MKT-25) 073A7BCB 00000808 0100391F AD000D04
[   46.363037] PVR_K:   (MKT-26) 073A7C55 00000808 0100391F AD000D05
[   46.369537] PVR_K:   (MKT-27) 073A7CB4 00000808 0100391F AD001A06
[   46.375946] PVR_K:   (MKT-28) 000005FA 00100808 0100031F AD002300
[   46.382446] PVR_K:   (MKT-29) 00000AFB 00100808 0100041F AD00000A
[   46.388885] PVR_K:   (MKT-2A) 00000B7D 00100808 0100041F AD000906
[   46.395385] PVR_K:   (MKT-2B) 00000C4D 00100808 0000041F AD000901
[   46.401824] PVR_K:   (MKT-2C) 00000CC6 00100808 0000051E AD000183
[   46.408294] PVR_K:   (MKT-2D) 00000E3A 00100808 0000051E AD000302
[   46.414794] PVR_K:   (MKT-2E) 00000FBD 00100808 0000051E AD000D06
[   46.421264] PVR_K:   (MKT-2F) 000010A9 00100808 0000051E AD000D07
[   46.427673] PVR_K:   (MKT-30) 000010F2 00100808 0000051E AD001304
[   46.434173] PVR_K:   (MKT-31) 000011DD 00100808 0000051E AD001305
[   46.440612] PVR_K:   (MKT-32) 000012ED 00100888 0000051E AD000404
[   46.447082] PVR_K:   (MKT-33) 000013B2 00100808 0000051E AD000402
[   46.453552] PVR_K:   (MKT-34) 000013FA 0010082B 0000051E AD000184
[   46.460052] PVR_K:   (MKT-35) 0000149B 00108DA9 0000061D AD000281
[   46.466461] PVR_K:   (MKT-36) 00001632 001199AD 0000061D AD000E02
[   46.472900] PVR_K:   (MKT-37) 00001697 0010892B 0000061D AD000282
[   46.479370] PVR_K:   (MKT-38) 00003D11 00100808 0000081F AD000101
[   46.485839] PVR_K:   (MKT-39) 00003D8A 00100808 0000081F AD000104
[   46.492340] PVR_K:   (MKT-3A) 00003DC6 00100808 0100091E AD000100
[   46.498748] PVR_K:   (MKT-3B) 00003ECD 00100808 0100091E AD000501
[   46.499725] adc_to_temp_conversion:Temp read is invalid 0
[   46.499755] thermal_lookup_temp: getting temp is not supported for domain pcb
[   46.500579] adc_to_temp_conversion:Temp read is invalid 0
[   46.500579] thermal_lookup_temp: getting temp is not supported for domain pcb
[   46.501403] adc_to_temp_conversion:Temp read is invalid 0
[   46.501403] thermal_lookup_temp: getting temp is not supported for domain pcb
[   46.545440] PVR_K:   (MKT-3C) 00003F0C 00100829 0100091E AD000104
[   46.551910] PVR_K:   (MKT-3D) 05C6D12A 00100808 0100031F AD000B00
[   46.558380] PVR_K:   (MKT-3E) 05C6D16F 00100808 0100031F AD000B03
[   46.564880] PVR_K:   (MKT-3F) 05C6D1F7 00100808 0100031F AD000B05
[   46.571319] PVR_K:   (MKT-40) 05C6D24B 00100808 0100031F AD000B06
[   46.577819] PVR_K:   (MKT-41) 05C6D27A 00100808 0100031F AD000B06
[   46.584259] PVR_K:   (MKT-42) 05C6D2C0 00100808 0100031F AD000B07
[   46.590728] PVR_K:   (MKT-43) 05C6D2E5 00100808 0100031F AD000B09
[   46.597167] PVR_K:   (MKT-44) 05C6D339 00100808 0100031F AD000B01
[   46.603698] PVR_K:   (MKT-45) 05C6D375 00100808 0100031F AD002300
[   46.610137] PVR_K:   (MKT-46) 05C6D697 00100808 0100041F AD00000A
[   46.616699] PVR_K:   (MKT-47) 05C6D71B 00100808 0100041F AD000906
[   46.623107] PVR_K:   (MKT-48) 05C6D7D5 00100808 0000041F AD000901
[   46.629577] PVR_K:   (MKT-49) 05C6D850 00100808 0000051E AD000183
[   46.635986] PVR_K:   (MKT-4A) 05C6D9B8 00100808 0000051E AD000302
[   46.642486] PVR_K:   (MKT-4B) 05C6DA09 00100808 0000051E AD000303
[   46.648956] PVR_K:   (MKT-4C) 05C6DA8C 00100808 0000051E AD000C01
[   46.655364] PVR_K:   (MKT-4D) 05C6DAB0 00100808 0000051E 0D800484
[   46.661865] PVR_K:   (MKT-4E) 05C6DAC8 00100808 0000051E 00000004
[   46.668304] PVR_K:   (MKT-4F) 05C6DD14 00100808 0000051E AD00030E
[   46.674804] PVR_K:   (MKT-50) 05C6DD2C 00100808 0000051E 0D800474
[   46.681243] PVR_K:   (MKT-51) 05C6DD45 00100808 0000051E 00000003
[   46.687713] PVR_K:   (MKT-52) 05C6DD68 00100808 0000051E 00000004
[   46.694152] PVR_K:   (MKT-53) 05C6DDDD 00100808 0000051E AD000184
[   46.700653] PVR_K:   (MKT-54) 05C6DE5B 00100C08 0100061D AD000281
[   46.707122] PVR_K:   (MKT-55) 05C6DFE8 00100808 0100061D AD00080A
[   46.713562] PVR_K:   (MKT-56) 05C6E001 00100808 0100061D 0F03D300
[   46.719970] PVR_K:   (MKT-57) 05C6E019 00100808 0100061D 00000061
[   46.726440] PVR_K:   (MKT-58) 05C6E132 00100C88 0100061D AD001300
[   46.732818] PVR_K:   (MKT-59) 05C73285 00100808 0000061D AD001301
[   46.739288] PVR_K:   (MKT-5A) 05C733A9 00100808 0000061D AD000802
[   46.745697] PVR_K:   (MKT-5B) 05C7350F 00100808 0000061D AD000803
[   46.752166] PVR_K:   (MKT-5C) 05C7355C 00184AC8 0000061D AD000282
[   46.758605] PVR_K:   (MKT-5D) 05C754DC 00000C08 01000A1F AD000200
[   46.765014] PVR_K:   (MKT-5E) 05C75737 00000808 00000A1F AD000202
[   46.771453] PVR_K:   (MKT-5F) 05C757CF 00000808 00000B1E AD000183
[   46.777862] PVR_K:   (MKT-60) 05C758CC 00000808 00000B1E AD00030E
[   46.784332] PVR_K:   (MKT-61) 05C758E4 00000808 00000B1E 0D800474
[   46.790740] PVR_K:   (MKT-62) 05C758FD 00000808 00000B1E 00000003
[   46.797210] PVR_K:   (MKT-63) 05C75921 00000808 00000B1E 00000004
[   46.803649] PVR_K:   (MKT-64) 05C7598A 00000808 00000B1E AD000184
[   46.810089] PVR_K:   (MKT-65) 05C759F7 00000C08 01000C1D AD000281
[   46.816497] PVR_K:   (MKT-66) 05C75B5F 00000808 01000C1D AD00080A
[   46.822937] PVR_K:   (MKT-67) 05C75B78 00000808 01000C1D 0F03D600
[   46.829345] PVR_K:   (MKT-68) 05C75B90 00000808 01000C1D 00000060
[   46.835815] PVR_K:   (MKT-69) 05C75E3C 00000808 00000C1D AD000803
[   46.842193] PVR_K:   (MKT-6A) 05C75E82 00188CC8 00000C1D AD000282
[   46.848663] PVR_K:   (MKT-6B) 05C75F43 00000808 01000E1F AD000200
[   46.855102] PVR_K:   (MKT-6C) 05C76160 00000808 00000E1F AD000202
[   46.861511] PVR_K:   (MKT-6D) 05C761DD 00000808 00000F1E AD000183
[   46.867980] PVR_K:   (MKT-6E) 05C762C7 00000808 00000F1E AD00030E
[   46.874389] PVR_K:   (MKT-6F) 05C762DF 00000808 00000F1E 0D800474
[   46.880950] PVR_K:   (MKT-70) 05C762F8 00000808 00000F1E 00000003
[   46.887359] PVR_K:   (MKT-71) 05C7631D 00000808 00000F1E 00000004
[   46.893798] PVR_K:   (MKT-72) 05C76386 00000808 00000F1E AD000184
[   46.900207] PVR_K:   (MKT-73) 05C763EA 00000C08 0100101D AD000281
[   46.906738] PVR_K:   (MKT-74) 05C76555 00000808 0100101D AD00080A
[   46.913177] PVR_K:   (MKT-75) 05C7656D 00000808 0100101D 0F03D900
[   46.919616] PVR_K:   (MKT-76) 05C76586 00000808 0100101D 00000060
[   46.926116] PVR_K:   (MKT-77) 05C76835 00000808 0000101D AD000803
[   46.932586] PVR_K:   (MKT-78) 05C7687A 00180CC8 0000101D AD000282
[   46.939025] PVR_K:   (MKT-79) 05C76969 00000808 0100121F AD000200
[   46.945526] PVR_K:   (MKT-7A) 05C76B83 00000808 0000121F AD000202
[   46.951934] PVR_K:   (MKT-7B) 05C76C0C 00000808 0000131E AD000183
[   46.958465] PVR_K:   (MKT-7C) 05C76CF8 00000808 0000131E AD00030E
[   46.964965] PVR_K:   (MKT-7D) 05C76D10 00000808 0000131E 0D800474
[   46.971405] PVR_K:   (MKT-7E) 05C76D29 00000808 0000131E 00000003
[   46.977844] PVR_K:   (MKT-7F) 05C76D4E 00000808 0000131E 00000004
[   46.984283] PVR_K:   (MKT-80) 05C76DB8 00000808 0000131E AD000184
[   46.990722] PVR_K:   (MKT-81) 05C76E1D 00000C08 0100141D AD000281
[   46.997131] PVR_K:   (MKT-82) 05C76F89 00000808 0100141D AD00080A
[   47.003692] PVR_K:   (MKT-83) 05C76FA1 00000808 0100141D 0F03DC00
[   47.010101] PVR_K:   (MKT-84) 05C76FBA 00000808 0100141D 00000062
[   47.016540] PVR_K:   (MKT-85) 05C77264 00000808 0000141D AD000803
[   47.022949] PVR_K:   (MKT-86) 05C772AC 00180C88 0000141D AD000282
[   47.029449] PVR_K:   (MKT-87) 05C77D8C 00000808 0100161F AD000200
[   47.035858] PVR_K:   (MKT-88) 05C77EA7 00000808 0100161F AD001703
[   47.042327] PVR_K:   (MKT-89) 05C78076 00000808 0000161F AD000202
[   47.048828] PVR_K:   (MKT-8A) 05C780F5 00000808 0100171E AD000183
[   47.055328] PVR_K:   (MKT-8B) 05C781E3 00000808 0100171E AD00030E
[   47.061798] PVR_K:   (MKT-8C) 05C781FB 00000808 0100171E 0D800474
[   47.068206] PVR_K:   (MKT-8D) 05C78214 00000808 0100171E 00000003
[   47.074707] PVR_K:   (MKT-8E) 05C78238 00000808 0100171E 00000004
[   47.081176] PVR_K:   (MKT-8F) 05C782C3 00000808 0100171E AD000184
[   47.087646] PVR_K:   (MKT-90) 05C84AA3 00000808 01001A1F AD001A00
[   47.094055] PVR_K:   (MKT-91) 07E239CF 00000808 0105D71F AD00000A
[   47.100524] PVR_K:   (MKT-92) 07E23A37 00000808 0105D71F AD000909
[   47.106933] PVR_K:   (MKT-93) 07E23A81 00000808 0105D71F AD001A05
[   47.113372] PVR_K:   (MKT-94) 07E23AB3 00000808 0105D71F AD001302
[   47.119873] PVR_K:   (MKT-95) 07E23AF2 00000808 0105D71F AD001303
[   47.126342] PVR_K:   (MKT-96) 07E23B8B 00000808 0105D71F AD000D04
[   47.132751] PVR_K:   (MKT-97) 07E23C55 00000808 0105D71F AD000D05
[   47.139190] PVR_K:   (MKT-98) 07E23CC4 00000808 0105D71F AD001A06
[   47.145599] PVR_K:   (MKT-99) 000004A7 00100808 0100031F AD002300
[   47.152099] PVR_K:   (MKT-9A) 000009BF 00100808 0100041F AD00000A
[   47.158538] PVR_K:   (MKT-9B) 00000A30 00100808 0100041F AD000905
[   47.165069] PVR_K:   (MKT-9C) 00000B6D 00100808 0000041F AD000901
[   47.171569] PVR_K:   (MKT-9D) 00000BEB 00100808 0000051E AD000183
[   47.177978] PVR_K:   (MKT-9E) 00000D64 00100808 0000051E AD000302
[   47.184448] PVR_K:   (MKT-9F) 00000DBA 00100808 0000051E AD000303
[   47.190887] PVR_K:   (MKT-A0) 00000E42 00100808 0000051E AD000C01
[   47.197418] PVR_K:   (MKT-A1) 00000E67 00100808 0000051E 0D800464
[   47.203857] PVR_K:   (MKT-A2) 00000E80 00100808 0000051E 00000005
[   47.210296] PVR_K:   (MKT-A3) 000010DB 00100808 0000051E AD00030E
[   47.216827] PVR_K:   (MKT-A4) 000010F3 00100808 0000051E 0D800494
[   47.223266] PVR_K:   (MKT-A5) 0000110C 00100888 0000051E 00000003
[   47.229675] PVR_K:   (MKT-A6) 0000112F 00100808 0000051E 00000004
[   47.236175] PVR_K:   (MKT-A7) 000011A5 00100808 0000051E AD000184
[   47.242614] PVR_K:   (MKT-A8) 00001222 00100C08 0000061D AD000281
[   47.249084] PVR_K:   (MKT-A9) 000013B8 00100808 0000061D AD00080A
[   47.255554] PVR_K:   (MKT-AA) 000013D2 00100808 0000061D 0F03DF00
[   47.262023] PVR_K:   (MKT-AB) 000013EB 00100808 0000061D 00000061
[   47.268493] PVR_K:   (MKT-AC) 0000150A 00100C88 0000061D AD001300
[   47.274932] PVR_K:   (MKT-AD) 00001644 00100808 0000061D AD001301
[   47.281402] PVR_K:   (MKT-AE) 0000177A 00100808 0000061D AD000802
[   47.287811] PVR_K:   (MKT-AF) 000018E8 00100808 0000061D AD000803
[   47.294281] PVR_K:   (MKT-B0) 00001937 00184AC8 0000061D AD000282
[   47.300720] PVR_K:   (MKT-B1) 00001A25 00180CB8 0000071F AD00000A
[   47.307189] PVR_K:   (MKT-B2) 00001A9D 00180838 0000071F AD000905
[   47.313598] PVR_K:   (MKT-B3) 00001BBB 00180838 0000071F AD000901
[   47.320037] PVR_K:   (MKT-B4) 00001C41 00180838 0000091C AD00000A
[   47.326446] PVR_K:   (MKT-B5) 00001CA3 00180838 0000091C AD000905
[   47.332916] PVR_K:   (MKT-B6) 00001D4B 00180838 0000091C AD000901
[   47.339324] PVR_K:   (MKT-B7) 00001DA8 00180838 00000B1D AD00000A
[   47.345794] PVR_K:   (MKT-B8) 00001E0F 00180838 00000B1D AD000905
[   47.352203] PVR_K:   (MKT-B9) 00001EBC 00180838 00000B1D AD000901
[   47.358642] PVR_K:   (MKT-BA) 00001F42 00180838 00000C1A AD000183
[   47.365051] PVR_K:   (MKT-BB) 00002061 00180838 00000C1A AD00030E
[   47.371520] PVR_K:   (MKT-BC) 00002079 00180838 00000C1A 0D800494
[   47.377990] PVR_K:   (MKT-BD) 00002093 00180838 00000C1A 00000003
[   47.384399] PVR_K:   (MKT-BE) 000020B8 00180838 00000C1A 00000004
[   47.390838] PVR_K:   (MKT-BF) 00002124 00180838 00000C1A AD000184
[   47.405212] PVR_K:   (MKT-C0) 0000219E 00180C38 01000D19 AD000281
[   47.411651] PVR_K:   (MKT-C1) 000021F9 00180838 01000D19 AD000282
[   47.423370] PVR_K:   (MKT-C2) 00003A2C 00000808 01000E1F AD000200
[   47.434051] PVR_K:   (MKT-C3) 00003C79 00000808 00000E1F AD000202
[   47.440490] PVR_K:   (MKT-C4) 00003CF9 00000808 00000F1E AD000183
[   47.446929] PVR_K:   (MKT-C5) 00003DE8 00000808 00000F1E AD00030E
[   47.453369] PVR_K:   (MKT-C6) 00003E01 00000808 00000F1E 0D800494
[   47.459838] PVR_K:   (MKT-C7) 00003E1B 00000808 00000F1E 00000003
[   47.475463] PVR_K:   (MKT-C8) 00003E3F 00000808 00000F1E 00000004
[   47.481933] PVR_K:   (MKT-C9) 00003EAA 00000808 00000F1E AD000184
[   47.492034] adc_to_temp_conversion:Temp read is invalid 0
[   47.493408] PVR_K:   (MKT-CA) 00003F10 00000C08 0100101D AD000281
[   47.493438] PVR_K:   (MKT-CB) 00004084 00000808 0100101D AD00080A
[   47.493438] PVR_K:   (MKT-CC) 0000409D 00000808 0100101D 0F03E200
[   47.493438] PVR_K:   (MKT-CD) 000040B5 00000808 0100101D 00000060
[   47.493469] PVR_K:   (MKT-CE) 0000437B 00000808 0000101D AD000803
[   47.493469] PVR_K:   (MKT-CF) 000043C4 00180CC8 0000101D AD000282
[   47.493469] PVR_K:   (MKT-D0) 0000447F 00000808 0100121F AD000200
[   47.493499] PVR_K:   (MKT-D1) 000046A0 00000808 0000121F AD000202
[   47.493499] PVR_K:   (MKT-D2) 00004722 00000808 0000131E AD000183
[   47.493499] PVR_K:   (MKT-D3) 0000480F 00000808 0000131E AD00030E
[   47.493530] PVR_K:   (MKT-D4) 00004828 00000808 0000131E 0D800494
[   47.493530] PVR_K:   (MKT-D5) 00004840 00000808 0000131E 00000003
[   47.493530] PVR_K:   (MKT-D6) 00004865 00000808 0000131E 00000004
[   47.493560] PVR_K:   (MKT-D7) 000048D3 00000808 0000131E AD000184
[   47.493560] PVR_K:   (MKT-D8) 0000493A 00000C08 0100141D AD000281
[   47.493560] PVR_K:   (MKT-D9) 00004AA7 00000808 0100141D AD00080A
[   47.493560] PVR_K:   (MKT-DA) 00004AC2 00000808 0100141D 0F03E500
[   47.493591] PVR_K:   (MKT-DB) 00004ADA 00000808 0100141D 00000060
[   47.493591] PVR_K:   (MKT-DC) 00004D97 00000808 0000141D AD000803
[   47.493591] PVR_K:   (MKT-DD) 00004DDE 00188CC8 0000141D AD000282
[   47.493621] PVR_K:   (MKT-DE) 00004ECB 00000808 0100161F AD000200
[   47.493621] PVR_K:   (MKT-DF) 000050EA 00000808 0000161F AD000202
[   47.493621] PVR_K:   (MKT-E0) 0000516D 00000808 0000171E AD000183
[   47.493652] PVR_K:   (MKT-E1) 00005258 00000808 0000171E AD00030E
[   47.493652] PVR_K:   (MKT-E2) 00005270 00000808 0000171E 0D800494
[   47.493652] PVR_K:   (MKT-E3) 00005289 00000808 0000171E 00000003
[   47.493682] PVR_K:   (MKT-E4) 000052AC 00000808 0000171E 00000004
[   47.493682] PVR_K:   (MKT-E5) 00005317 00000808 0000171E AD000184
[   47.493682] PVR_K:   (MKT-E6) 0000537D 00000C08 0100181D AD000281
[   47.493682] PVR_K:   (MKT-E7) 000054E9 00000808 0100181D AD00080A
[   47.493713] PVR_K:   (MKT-E8) 00005501 00000808 0100181D 0F03E800
[   47.493713] PVR_K:   (MKT-E9) 0000551A 00000808 0100181D 00000062
[   47.493713] PVR_K:   (MKT-EA) 000057D6 00000808 0000181D AD000803
[   47.493743] PVR_K:   (MKT-EB) 0000581C 00180C88 0000181D AD000282
[   47.493743] PVR_K:   (MKT-EC) 0000639D 00000C08 01001B1F AD000200
[   47.493743] PVR_K:   (MKT-ED) 000064C9 00000888 01001B1F AD001703
[   47.493774] PVR_K:   (MKT-EE) 000066D4 00000808 00001B1F AD000202
[   47.493774] PVR_K:   (MKT-EF) 00006778 00000808 00001C1E AD00000A
[   47.493774] PVR_K:   (MKT-F0) 000067E4 00000888 00001C1E AD000905
[   47.493804] PVR_K:   (MKT-F1) 000068F0 00000808 00001C1E AD000901
[   47.493804] PVR_K:   (MKT-F2) 00006959 00000808 00001D1D AD000183
[   47.493804] PVR_K:   (MKT-F3) 00006A46 00000808 00001D1D AD00030E
[   47.493804] PVR_K:   (MKT-F4) 00006A5E 00000808 00001D1D 0D800494
[   47.493835] PVR_K:   (MKT-F5) 00006A77 00000808 00001D1D 00000003
[   47.493835] PVR_K:   (MKT-F6) 00006A9B 00000808 00001D1D 00000004
[   47.493835] PVR_K:   (MKT-F7) 00006B06 00000808 00001D1D AD000184
[   47.493865] PVR_K:   (MKT-F8) 00006BAC 00000808 00001E1F AD00000A
[   47.493865] PVR_K:   (MKT-F9) 00006C14 00000808 00001E1F AD000905
[   47.493865] PVR_K:   (MKT-FA) 00006D00 00000808 00001E1F AD000901
[   47.493896] PVR_K:   (MKT-FB) 00006D4F 00000C08 00001F1C AD000281
[   47.493896] PVR_K:   (MKT-FC) 00006E68 00000808 00001F1C AD000E02
[   47.493896] PVR_K:   (MKT-FD) 00006EB8 00000808 00001F1C AD000282
[   47.493927] PVR_K:   (MKT-FE) 00006F6B 00000808 0000201E AD00000A
[   47.493927] PVR_K:   (MKT-FF) 00006FD5 00000808 0000201E AD000905
[   47.493927] PVR_K:   (MKT-100) 000070BF 00000808 0000201E AD000901
[   47.493927] PVR_K:   (MKT-101) 0000712B 00000808 0000211D AD000183
[   47.493957] PVR_K:   (MKT-102) 00007216 00000808 0000211D AD00030E
[   47.493957] PVR_K:   (MKT-103) 0000722E 00000808 0000211D 0D800494
[   47.493957] PVR_K:   (MKT-104) 00007247 00000808 0000211D 00000003
[   47.493988] PVR_K:   (MKT-105) 0000726B 00000808 0000211D 00000004
[   47.493988] PVR_K:   (MKT-106) 000072D8 00000808 0000211D AD000184
[   47.493988] PVR_K:   (MKT-107) 0000737B 00000808 0000221F AD00000A
[   47.494018] PVR_K:   (MKT-108) 000073E4 00000808 0000221F AD000905
[   47.494018] PVR_K:   (MKT-109) 000074CE 00000808 0000221F AD000901
[   47.494018] PVR_K:   (MKT-10A) 0000751C 00000C08 0000231C AD000281
[   47.494049] PVR_K:   (MKT-10B) 00007614 00000808 0000231C AD000E02
[   47.494049] PVR_K:   (MKT-10C) 00007667 00000808 0000231C AD000282
[   47.494049] PVR_K:   (MKT-10D) 000076F1 00000808 0100241E AD000183
[   47.494049] PVR_K:   (MKT-10E) 000077E9 00000808 0100241E AD00030E
[   47.494079] PVR_K:   (MKT-10F) 00007801 00000808 0100241E 0D800494
[   47.494079] PVR_K:   (MKT-110) 00007819 00000808 0100241E 00000003
[   47.494079] PVR_K:   (MKT-111) 0000783C 00000808 0100241E 00000004
[   47.494110] PVR_K:   (MKT-112) 000078C7 00000808 0100241E AD000184
[   47.494110] PVR_K:   (MKT-113) 00017BB0 00000808 0100271F AD001A00
[   47.494110] PVR_K:   (MKT-114) 0002EAEE 00000808 01002B1F AD00000A
[   47.494140] PVR_K:   (MKT-115) 0002EB50 00000808 01002B1F AD000909
[   47.494140] PVR_K:   (MKT-116) 0002EB9D 00000808 01002B1F AD001A05
[   47.494140] PVR_K:   (MKT-117) 0002EBCE 00000808 01002B1F AD001302
[   47.494171] PVR_K:   (MKT-118) 0002EC10 00000808 01002B1F AD001303
[   47.494171] PVR_K:   (MKT-119) 0002ECAB 00000808 01002B1F AD000D04
[   47.494171] PVR_K:   (MKT-11A) 0002ED83 00000808 01002B1F AD000D05
[   47.494171] PVR_K:   (MKT-11B) 0002EDF2 00000808 01002B1F AD001A06
[   47.494201] PVR_K:   (MKT-11C) 00000485 00100808 0100031F AD002300
[   47.494201] PVR_K:   (MKT-11D) 0000096E 00100808 0100041F AD00000A
[   47.494201] PVR_K:   (MKT-11E) 000009EA 00100808 0100041F AD000906
[   47.494232] PVR_K:   (MKT-11F) 00000AB9 00100808 0000041F AD000901
[   47.494232] PVR_K:   (MKT-120) 00000B31 00100808 0000051E AD000183
[   47.494232] PVR_K:   (MKT-121) 00000CA8 00100808 0000051E AD000302
[   47.494262] PVR_K:   (MKT-122) 00000E3A 00100808 0000051E AD000D06
[   47.494262] PVR_K:   (MKT-123) 00000F25 00100808 0000051E AD000D07
[   47.494262] PVR_K:   (MKT-124) 00000F6F 00100808 0000051E AD001304
[   47.494293] PVR_K:   (MKT-125) 0000105D 00100808 0000051E AD001305
[   47.494293] PVR_K:   (MKT-126) 00001171 00100888 0000051E AD000404
[   47.494293] PVR_K:   (MKT-127) 00001238 00100808 0000051E AD000402
[   47.494293] PVR_K:   (MKT-128) 00001282 0010082B 0000051E AD000184
[   47.494323] PVR_K:   (MKT-129) 00001323 00118DA9 0000061D AD000281
[   47.494323] PVR_K:   (MKT-12A) 000014B2 001089AF 0000061D AD000E02
[   47.494323] PVR_K:   (MKT-12B) 0000150E 0010892B 0000061D AD000282
[   47.494354] PVR_K:   (MKT-12C) 00003B2A 00100808 0000081F AD000101
[   47.494354] PVR_K:   (MKT-12D) 00003BA0 00100808 0000081F AD000104
[   47.494354] PVR_K:   (MKT-12E) 00003BDD 00100808 0100091E AD000100
[   47.494384] PVR_K:   (MKT-12F) 00003CEA 00100808 0100091E AD000501
[   47.494384] PVR_K:   (MKT-130) 00003D29 0010082B 0100091E AD000104
[   47.494384] PVR_K:   (MKT-131) 00005F85 00100828 01000A1F AD000101
[   47.494415] PVR_K:   (MKT-132) 00005FC9 00100828 01000A1F AD000104
[   47.494415] PVR_K:   (MKT-133) 000060E2 00100808 01000B1F AD000100
[   47.494415] PVR_K:   (MKT-134) 0000619D 00100808 01000B1F AD000501
[   47.494415] PVR_K:   (MKT-135) 000061C8 00100829 01000B1F AD000104
[   47.494445] PVR_K:   (MKT-136) 00008717 00100828 01000D1F AD000101
[   47.494445] PVR_K:   (MKT-137) 00008790 00100828 01000D1F AD000104
[   47.494445] PVR_K:   (MKT-138) 000087CD 00100808 01000E1E AD000100
[   47.494476] PVR_K:   (MKT-139) 000088C9 00100808 01000E1E AD000501
[   47.494476] PVR_K:   (MKT-13A) 00008908 00100829 01000E1E AD000104
[   47.494476] PVR_K:   (MKT-13B) 06FB67D5 00100808 0100031F AD000B00
[   47.494506] PVR_K:   (MKT-13C) 06FB681A 00100808 0100031F AD000B03
[   47.494506] PVR_K:   (MKT-13D) 06FB68A1 00100808 0100031F AD000B05
[   47.494506] PVR_K:   (MKT-13E) 06FB68F8 00100808 0100031F AD000B06
[   47.494537] PVR_K:   (MKT-13F) 06FB6928 00100808 0100031F AD000B06
[   47.494537] PVR_K:   (MKT-140) 06FB696B 00100808 0100031F AD000B07
[   47.494537] PVR_K:   (MKT-141) 06FB6990 00100808 0100031F AD000B09
[   47.494567] PVR_K:   (MKT-142) 06FB69E6 00100808 0100031F AD000B01
[   47.494567] PVR_K:   (MKT-143) 06FB6A22 00100808 0100031F AD002300
[   47.494567] PVR_K:   (MKT-144) 06FB6D3E 00100808 0100041F AD00000A
[   47.494567] PVR_K:   (MKT-145) 06FB6DBC 00100808 0100041F AD000906
[   47.494598] PVR_K:   (MKT-146) 06FB6E7D 00100808 0000041F AD000901
[   47.494598] PVR_K:   (MKT-147) 06FB6EF7 00100808 0000051E AD000183
[   47.494598] PVR_K:   (MKT-148) 06FB706C 00100808 0000051E AD000302
[   47.494628] PVR_K:   (MKT-149) 06FB70C2 00100808 0000051E AD000303
[   47.494628] PVR_K:   (MKT-14A) 06FB714C 00100808 0000051E AD000C01
[   47.494628] PVR_K:   (MKT-14B) 06FB7172 00100808 0000051E 0D800484
[   47.494659] PVR_K:   (MKT-14C) 06FB718A 00100808 0000051E 00000005
[   47.494659] PVR_K:   (MKT-14D) 06FB73DD 00100808 0000051E AD00030E
[   47.494659] PVR_K:   (MKT-14E) 06FB73F5 00100808 0000051E 0D800474
[   47.494689] PVR_K:   (MKT-14F) 06FB740E 00100808 0000051E 00000004
[   47.494689] PVR_K:   (MKT-150) 06FB7432 00100808 0000051E 00000005
[   47.494689] PVR_K:   (MKT-151) 06FB74A8 00100808 0000051E AD000184
[   47.494689] PVR_K:   (MKT-152) 06FB752B 00100C08 0100061D AD000281
[   47.494720] PVR_K:   (MKT-153) 06FB76BF 00100808 0100061D AD00080A
[   47.494720] PVR_K:   (MKT-154) 06FB76D8 00100808 0100061D 0F03EB00
[   47.494720] PVR_K:   (MKT-155) 06FB76F0 00100808 0100061D 00000061
[   47.494750] PVR_K:   (MKT-156) 06FB7807 00100C88 0100061D AD001300
[   47.494750] PVR_K:   (MKT-157) 06FBCBF1 00100808 0000061D AD001301
[   47.494750] PVR_K:   (MKT-158) 06FBCD23 00100888 0000061D AD000802
[   47.494781] PVR_K:   (MKT-159) 06FBCE96 00100888 0000061D AD000803
[   47.494781] PVR_K:   (MKT-15A) 06FBCEE5 001808C8 0000061D AD000282
[   47.494781] PVR_K:   (MKT-15B) 06FBCFCA 00184EF8 0000081E AD00000A
[   47.494812] PVR_K:   (MKT-15C) 06FBD04E 001CCAF8 0000081E AD000905
[   47.494812] PVR_K:   (MKT-15D) 06FBD175 001808B8 0000081E AD000901
[   47.494812] PVR_K:   (MKT-15E) 06FBD1E7 00180838 0000091C AD00000A
[   47.494812] PVR_K:   (MKT-15F) 06FBD253 00180838 0000091C AD000905
[   47.494842] PVR_K:   (MKT-160) 06FBD301 00180838 0000091C AD000901
[   47.494842] PVR_K:   (MKT-161) 06FBD357 00180838 00000A1B AD00000A
[   47.494842] PVR_K:   (MKT-162) 06FBD3B8 00180838 00000A1B AD000905
[   47.494873] PVR_K:   (MKT-163) 06FBD464 00180838 00000A1B AD000901
[   47.494873] PVR_K:   (MKT-164) 06FBD4B8 00180838 00000B1A AD00000A
[   47.494873] PVR_K:   (MKT-165) 06FBD52C 00180838 00000B1A AD000906
[   47.494903] PVR_K:   (MKT-166) 06FBD5A9 00180838 00000B1A AD000901
[   47.494903] PVR_K:   (MKT-167) 06FBD600 00180838 00000C19 AD00000A
[   47.494903] PVR_K:   (MKT-168) 06FBD66C 00180838 00000C19 AD000905
[   47.494934] PVR_K:   (MKT-169) 06FBD721 00180838 00000C19 AD000901
[   47.494934] PVR_K:   (MKT-16A) 06FBD887 00180838 00000F1F AD000183
[   47.494934] PVR_K:   (MKT-16B) 06FBDA0A 00180838 00000F1F AD000302
[   47.494964] PVR_K:   (MKT-16C) 06FBDA7E 00180838 00000F1F AD000303
[   47.494964] PVR_K:   (MKT-16D) 06FBDAFF 00180838 00000F1F AD000C01
[   47.494964] PVR_K:   (MKT-16E) 06FBDB32 00180838 00000F1F 0D800464
[   47.494964] PVR_K:   (MKT-16F) 06FBDB4F 00180838 00000F1F 00000006
[   47.494995] PVR_K:   (MKT-170) 06FBDD78 00180838 00000F1F AD000184
[   47.494995] PVR_K:   (MKT-171) 06FBDDEA 00180C38 0100101D AD000281
[   47.494995] PVR_K:   (MKT-172) 06FBDE41 00180838 0100101D AD000282
[   47.495025] PVR_K:   (MKT-173) 06FBE355 00180838 0100111F AD00000A
[   47.495025] PVR_K:   (MKT-174) 06FBE3BD 00180838 0100111F AD000905
[   47.495025] PVR_K:   (MKT-175) 06FBE4C7 00180838 0000111F AD000901
[   47.495056] PVR_K:   (MKT-176) 06FBE518 00180C38 0100121E AD000281
[   47.495056] PVR_K:   (MKT-177) 06FBE56F 00180838 0100121E AD000282
[   47.495056] PVR_K:   (MKT-178) 06FBE62F 00180838 0100131F AD00000A
[   47.495086] PVR_K:   (MKT-179) 06FBE699 00180838 0100131F AD000905
[   47.495086] PVR_K:   (MKT-17A) 06FBE79A 00180838 0000131F AD000901
[   47.495086] PVR_K:   (MKT-17B) 06FBE7ED 00180C38 0100141E AD000281
[   47.495086] PVR_K:   (MKT-17C) 06FBE845 00180838 0100141E AD000282
[   47.495117] PVR_K:   (MKT-17D) 06FBE97B 00180838 0100151F AD00000A
[   47.495117] PVR_K:   (MKT-17E) 06FBE9E8 00180838 0100151F AD000905
[   47.495117] PVR_K:   (MKT-17F) 06FBEAE3 00180838 0000151F AD000901
[   47.495147] PVR_K:   (MKT-180) 06FBEB33 00180C38 0100161E AD000281
[   47.495147] PVR_K:   (MKT-181) 06FBEB8E 00180838 0000161E AD000282
[   47.495147] PVR_K:   (MKT-182) 06FBEC51 00180838 0100171F AD00000A
[   47.495178] PVR_K:   (MKT-183) 06FBECC1 00180838 0100171F AD000905
[   47.495178] PVR_K:   (MKT-184) 06FBEDBD 00180838 0000171F AD000901
[   47.495178] PVR_K:   (MKT-185) 06FBEE0F 00180C38 0100181E AD000281
[   47.495208] PVR_K:   (MKT-186) 06FBEE6A 00180838 0100181E AD000282
[   47.495208] PVR_K:   (MKT-187) 06FBF184 00000808 0100191F AD000200
[   47.495208] PVR_K:   (MKT-188) 06FBF3CD 00000808 0000191F AD000202
[   47.495239] PVR_K:   (MKT-189) 06FBF41A 00000808 01001A1E AD000281
[   47.495239] PVR_K:   (MKT-18A) 06FBF567 00000808 01001A1E AD00080A
[   47.495239] PVR_K:   (MKT-18B) 06FBF580 00000808 01001A1E 0F03EE00
[   47.495239] PVR_K:   (MKT-18C) 06FBF598 00000808 01001A1E 00000060
[   47.495269] PVR_K:   (MKT-18D) 06FBF86A 00000808 00001A1E AD000803
[   47.495269] PVR_K:   (MKT-18E) 06FBF8B2 00180CC8 00001A1E AD000282
[   47.495269] PVR_K:   (MKT-18F) 06FBF955 00000808 01001C1F AD000200
[   47.495300] PVR_K:   (MKT-190) 06FBFB81 00000808 00001C1F AD000202
[   47.495300] PVR_K:   (MKT-191) 06FBFBCD 00000808 01001D1E AD000281
[   47.495300] PVR_K:   (MKT-192) 06FBFD1F 00000808 01001D1E AD00080A
[   47.495330] PVR_K:   (MKT-193) 06FBFD39 00000808 01001D1E 0F03F100
[   47.495330] PVR_K:   (MKT-194) 06FBFD51 00000808 01001D1E 00000060
[   47.495330] PVR_K:   (MKT-195) 06FC001C 00000808 00001D1E AD000803
[   47.495361] PVR_K:   (MKT-196) 06FC0068 00188CC8 00001D1E AD000282
[   47.495361] PVR_K:   (MKT-197) 06FC0158 00000808 01001F1F AD000200
[   47.495361] PVR_K:   (MKT-198) 06FC038B 00000888 01001F1F AD000202
[   47.495361] PVR_K:   (MKT-199) 06FC03DC 00000808 0100201E AD000281
[   47.495391] PVR_K:   (MKT-19A) 06FC052E 00000808 0100201E AD00080A
[   47.495391] PVR_K:   (MKT-19B) 06FC0547 00000808 0100201E 0F03F400
[   47.495391] PVR_K:   (MKT-19C) 06FC0560 00000808 0100201E 00000062
[   47.495422] PVR_K:   (MKT-19D) 06FC081C 00000808 0000201E AD000803
[   47.495422] PVR_K:   (MKT-19E) 06FC0862 00180C88 0000201E AD000282
[   47.495422] PVR_K:   (MKT-19F) 06FC13CB 00000808 0100221F AD000200
[   47.495452] PVR_K:   (MKT-1A0) 06FC14E9 00000808 0100221F AD001703
[   47.495452] PVR_K:   (MKT-1A1) 06FC16EF 00000808 0000221F AD000202
[   47.495452] PVR_K:   (MKT-1A2) 06FC176F 00000808 0000231E AD000183
[   47.495483] PVR_K:   (MKT-1A3) 06FC185F 00000808 0000231E AD00030E
[   47.495483] PVR_K:   (MKT-1A4) 06FC1877 00000808 0000231E 0D800494
[   47.495483] PVR_K:   (MKT-1A5) 06FC1890 00000808 0000231E 00000004
[   47.495483] PVR_K:   (MKT-1A6) 06FC18B5 00000808 0000231E 00000005
[   47.495513] PVR_K:   (MKT-1A7) 06FC1920 00000808 0000231E AD000184
[   47.495513] PVR_K:   (MKT-1A8) 06FC198A 00000C08 0100241D AD000281
[   47.495513] PVR_K:   (MKT-1A9) 06FC1B03 00000808 0100241D AD00080A
[   47.495544] PVR_K:   (MKT-1AA) 06FC1B1C 00000808 0100241D 0F03F700
[   47.495544] PVR_K:   (MKT-1AB) 06FC1B35 00000808 0100241D 00000061
[   47.495544] PVR_K:   (MKT-1AC) 06FC1CB4 00000808 0000241D AD000802
[   47.495574] PVR_K:   (MKT-1AD) 06FC1E11 00000808 0000241D AD000803
[   47.495574] PVR_K:   (MKT-1AE) 06FC1E59 00184EC8 0000241D AD000282
[   47.495574] PVR_K:   (MKT-1AF) 06FC3E47 00000C08 0100271F AD000200
[   47.495605] PVR_K:   (MKT-1B0) 06FC4096 00000808 0000271F AD000202
[   47.495605] PVR_K:   (MKT-1B1) 06FC411E 00000808 0000281E AD000183
[   47.495605] PVR_K:   (MKT-1B2) 06FC4208 00000808 0000281E AD00030E
[   47.495605] PVR_K:   (MKT-1B3) 06FC4220 00000808 0000281E 0D800494
[   47.495635] PVR_K:   (MKT-1B4) 06FC4238 00000808 0000281E 00000004
[   47.495635] PVR_K:   (MKT-1B5) 06FC425C 00000808 0000281E 00000005
[   47.495635] PVR_K:   (MKT-1B6) 06FC42C8 00000808 0000281E AD000184
[   47.495666] PVR_K:   (MKT-1B7) 06FC432D 00000C08 0100291D AD000281
[   47.495666] PVR_K:   (MKT-1B8) 06FC4498 00000808 0100291D AD00080A
[   47.495666] PVR_K:   (MKT-1B9) 06FC44B0 00000808 0100291D 0F03FA00
[   47.495697] PVR_K:   (MKT-1BA) 06FC44C9 00000808 0100291D 00000060
[   47.495697] PVR_K:   (MKT-1BB) 06FC477F 00000808 0000291D AD000803
[   47.495697] PVR_K:   (MKT-1BC) 06FC47C6 00180CC8 0000291D AD000282
[   47.495727] PVR_K:   (MKT-1BD) 06FC486B 00000808 01002B1F AD000200
[   47.495727] PVR_K:   (MKT-1BE) 06FC4A81 00000808 00002B1F AD000202
[   47.495727] PVR_K:   (MKT-1BF) 06FC4B02 00000808 00002C1E AD000183
[   47.495727] PVR_K:   (MKT-1C0) 06FC4BEC 00000808 00002C1E AD00030E
[   47.495758] PVR_K:   (MKT-1C1) 06FC4C04 00000808 00002C1E 0D800494
[   47.495758] PVR_K:   (MKT-1C2) 06FC4C1D 00000808 00002C1E 00000004
[   47.495758] PVR_K:   (MKT-1C3) 06FC4C41 00000808 00002C1E 00000005
[   47.495788] PVR_K:   (MKT-1C4) 06FC4CAB 00000808 00002C1E AD000184
[   47.495788] PVR_K:   (MKT-1C5) 06FC4D0F 00000C08 01002D1D AD000281
[   47.495788] PVR_K:   (MKT-1C6) 06FC4E78 00000808 01002D1D AD00080A
[   47.495819] PVR_K:   (MKT-1C7) 06FC4E93 00000808 01002D1D 0F03FD00
[   47.495819] PVR_K:   (MKT-1C8) 06FC4EAB 00000808 01002D1D 00000060
[   47.495819] PVR_K:   (MKT-1C9) 06FC5160 00000808 00002D1D AD000803
[   47.495849] PVR_K:   (MKT-1CA) 06FC51A7 00180CC8 00002D1D AD000282
[   47.495849] PVR_K:   (MKT-1CB) 06FC528F 00000808 01002F1F AD000200
[   47.495849] PVR_K:   (MKT-1CC) 06FC54A8 00000808 00002F1F AD000202
[   47.495849] PVR_K:   (MKT-1CD) 06FC5528 00000808 0000301E AD000183
[   47.495880] PVR_K:   (MKT-1CE) 06FC5610 00000808 0000301E AD00030E
[   47.495880] PVR_K:   (MKT-1CF) 06FC5628 00000808 0000301E 0D800494
[   47.495880] PVR_K:   (MKT-1D0) 06FC5641 00000808 0000301E 00000004
[   47.495910] PVR_K:   (MKT-1D1) 06FC5664 00000808 0000301E 00000005
[   47.495910] PVR_K:   (MKT-1D2) 06FC56CF 00000808 0000301E AD000184
[   47.495910] PVR_K:   (MKT-1D3) 06FC5733 00000C08 0100311D AD000281
[   47.495941] PVR_K:   (MKT-1D4) 06FC58A4 00000808 0100311D AD00080A
[   47.495941] PVR_K:   (MKT-1D5) 06FC58BD 00000808 0100311D 0F040000
[   47.495941] PVR_K:   (MKT-1D6) 06FC58D5 00000808 0100311D 00000062
[   47.495971] PVR_K:   (MKT-1D7) 06FC5B87 00000808 0000311D AD000803
[   47.495971] PVR_K:   (MKT-1D8) 06FC5BD0 00180C88 0000311D AD000282
[   47.495971] PVR_K:   (MKT-1D9) 06FC66EC 00000808 0100331F AD000200
[   47.496002] PVR_K:   (MKT-1DA) 06FC6809 00000808 0100331F AD001703
[   47.496002] PVR_K:   (MKT-1DB) 06FC69EE 00000808 0000331F AD000202
[   47.496002] PVR_K:   (MKT-1DC) 06FC6A6C 00000808 0000341E AD000183
[   47.496002] PVR_K:   (MKT-1DD) 06FC6B56 00000808 0000341E AD00030E
[   47.496032] PVR_K:   (MKT-1DE) 06FC6B6E 00000808 0000341E 0D800494
[   47.496032] PVR_K:   (MKT-1DF) 06FC6B86 00000808 0000341E 00000004
[   47.496032] PVR_K:   (MKT-1E0) 06FC6BAA 00000808 0000341E 00000005
[   47.496063] PVR_K:   (MKT-1E1) 06FC6C14 00000808 0000341E AD000184
[   47.496063] PVR_K:   (MKT-1E2) 06FC6C7A 00000C08 0100351D AD000281
[   47.496063] PVR_K:   (MKT-1E3) 06FC6D8A 00000808 0100351D AD000E02
[   47.496093] PVR_K:   (MKT-1E4) 06FC6DFE 00000808 0100351D AD000282
[   47.496093] PVR_K:   (MKT-1E5) 06FD3F10 00000808 0100381F AD001A00
[   47.496093] PVR_K:   (MKT-1E6) 06FE6264 00000808 01003C1F AD00000A
[   47.496124] PVR_K:   (MKT-1E7) 06FE62C8 00000808 01003C1F AD000909
[   47.496124] PVR_K:   (MKT-1E8) 06FE6312 00000808 01003C1F AD001A05
[   47.496124] PVR_K:   (MKT-1E9) 06FE6341 00000808 01003C1F AD001302
[   47.496124] PVR_K:   (MKT-1EA) 06FE6381 00000808 01003C1F AD001303
[   47.496154] PVR_K:   (MKT-1EB) 06FE6411 00000808 01003C1F AD000D04
[   47.496154] PVR_K:   (MKT-1EC) 06FE64DE 00000808 01003C1F AD000D05
[   47.496154] PVR_K:   (MKT-1ED) 06FE6536 00000808 01003C1F AD000D04
[   47.496185] PVR_K:   (MKT-1EE) 06FE65BA 00000808 01003C1F AD000D05
[   47.496185] PVR_K:   (MKT-1EF) 06FE6616 00000808 01003C1F AD001A06
[   47.496185] PVR_K:   (MKT-1F0) 0000051B 00100808 0100031F AD002300
[   47.496215] PVR_K:   (MKT-1F1) 00000A39 00100808 0100041F AD00000A
[   47.496215] PVR_K:   (MKT-1F2) 00000AB8 00100808 0100041F AD000906
[   47.496215] PVR_K:   (MKT-1F3) 00000B8D 00100808 0000041F AD000901
[   47.496246] PVR_K:   (MKT-1F4) 00000C0B 00100808 0000051E AD000183
[   47.496246] PVR_K:   (MKT-1F5) 00000D83 00100808 0000051E AD000302
[   47.496246] PVR_K:   (MKT-1F6) 00000F11 00100808 0000051E AD000D06
[   47.496246] PVR_K:   (MKT-1F7) 00001000 00100808 0000051E AD000D07
[   47.496276] PVR_K:   (MKT-1F8) 0000104B 00100808 0000051E AD001304
[   47.496276] PVR_K:   (MKT-1F9) 00001136 00100808 0000051E AD001305
[   47.496276] PVR_K:   (MKT-1FA) 00001247 00100888 0000051E AD000404
[   47.496307] PVR_K:   (MKT-1FB) 0000130E 00100808 0000051E AD000402
[   47.496307] PVR_K:   (MKT-1FC) 00001356 0010082B 0000051E AD000184
[   47.496307] PVR_K:   (MKT-1FD) 000013F5 00119DA9 0000061D AD000281
[   47.496337] PVR_K:   (MKT-1FE) 0000158A 001199AB 0000061D AD000E02
[   47.496337] PVR_K:   (MKT-1FF) 000015EE 0010892B 0000061D AD000282
[   47.496337] PVR_K: SGX Kernel CCB WO:0x51 RO:0x51
[   49.521087] thermal_lookup_temp: getting temp is not supported for domain pcb
[   49.530548] adc_to_temp_conversion:Temp read is invalid 0
[   49.536804] thermal_lookup_temp: getting temp is not supported for domain pcb
[   49.558349] adc_to_temp_conversion:Temp read is invalid 0
[   49.571197] thermal_lookup_temp: getting temp is not supported for domain pcb
[   49.733306] PVR_K:(Error): SGXOSTimer() detected SGX lockup (0xe tasks) [0, ]
[   49.740966] PVR_K: HWRecoveryResetSGX: SGX Hardware Recovery triggered
[   49.749938] [   19.801]                        [c6f10400] dsscomp_apply
[   49.749969] [   19.816]                           [c6e64400] dsscomp_mgr_delayed_cb on DISPLAYED
[   49.749969] [   19.816]    [c6e89d40] --refs=0 on RELEASED
[   49.749969] [   19.816]    [c6e89d40] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   49.787933] [   19.816]                           [c6e64400] dsscomp_mgr_delayed_cb on RELEASED
[   49.787963] [   19.816]                        [c6f10400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   49.787963] [   19.832]                        [c6f10400] dsscomp_mgr_delayed_cb on DISPLAYED
[   49.854431] [   24.345]   [c6edb920] new in dsscomp_gralloc_queue (refs=1)
[   49.854461] [   24.345]                         [c6f11400] dsscomp_new
[   49.854461] [   24.345]   [c6edb920] ++refs=2 for [c6f11400]
[   49.854461] [   24.345]                         [c6f11400] dsscomp_delayed_apply
[   49.854461] [   24.345]   [c6edb920] --refs=1 on RELEASED
[   49.897308] [   24.345]                         [c6f11400] dsscomp_apply
[   49.897338] [   24.345]   [c6edb760] --refs=0 on RELEASED
[   49.897338] [   24.345]   [c6edb760] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   49.897338] [   24.345]                        [c6f10400] dsscomp_mgr_delayed_cb on RELEASED
[   49.963226] [   24.345]                         [c6f11400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   49.963226] [   24.369]                         [c6f11400] dsscomp_mgr_delayed_cb on DISPLAYED
[   49.963226] [   28.901]    [c6e89d40] new in dsscomp_gralloc_queue (refs=1)
[   49.991516] [   28.901]                           [c6e64400] dsscomp_new
[   49.991516] [   28.901]    [c6e89d40] ++refs=2 for [c6e64400]
[   49.991516] [   28.901]                           [c6e64400] dsscomp_delayed_apply
[   49.991546] [   28.901]    [c6e89d40] --refs=1 on RELEASED
[   49.991546] [   28.901]                           [c6e64400] dsscomp_apply
[   50.037963] [   28.901]   [c6edb920] --refs=0 on RELEASED
[   50.037963] [   28.901]   [c6edb920] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   50.037963] [   28.901]                         [c6f11400] dsscomp_mgr_delayed_cb on RELEASED
[   50.037963] [   28.901]                           [c6e64400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   50.104034] [   28.902] [c6e89d60] new in dsscomp_gralloc_queue (refs=1)
[   50.104034] [   28.902]                      [c6e64800] dsscomp_new
[   50.104034] [   28.902] [c6e89d60] ++refs=2 for [c6e64800]
[   50.104034] [   28.902]                      [c6e64800] dsscomp_delayed_apply
[   50.133941] [   28.902] [c6e89d60] --refs=1 on RELEASED
[   50.133941] [   28.902]                      [c6e64800] dsscomp_apply
[   50.133941] [   28.925]                           [c6e64400] dsscomp_mgr_delayed_cb on DISPLAYED
[   50.133941] [   28.925]    [c6e89d40] --refs=0 on RELEASED
[   50.178588] [   28.925]    [c6e89d40] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   50.178588] [   28.925]                           [c6e64400] dsscomp_mgr_delayed_cb on RELEASED
[   50.178619] [   28.925]                      [c6e64800] dsscomp_mgr_delayed_cb on PROGRAMMED
[   50.236022] [   28.942]                      [c6e64800] dsscomp_mgr_delayed_cb on DISPLAYED
[   50.236022] [   33.971]  [c6e89da0] new in dsscomp_gralloc_queue (refs=1)
[   50.236022] [   33.971]                        [c6e64c00] dsscomp_new
[   50.236022] [   33.971]  [c6e89da0] ++refs=2 for [c6e64c00]
[   50.236022] [   33.971]                        [c6e64c00] dsscomp_delayed_apply
[   50.267425] [   33.971]  [c6e89da0] --refs=1 on RELEASED
[   50.267425] [   33.971]                        [c6e64c00] dsscomp_apply
[   50.267456] [   33.971] [c6e89d60] --refs=0 on RELEASED
[   50.267456] [   33.971] [c6e89d60] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   50.311370] [   33.971]                      [c6e64800] dsscomp_mgr_delayed_cb on RELEASED
[   50.311370] [   33.971]                        [c6e64c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   50.311370] [   33.972]      [c6edb820] new in dsscomp_gralloc_queue (refs=1)
[   50.311370] [   33.972]                      [c6f10000] dsscomp_new
[   50.381683] [   33.972]      [c6edb820] ++refs=2 for [c6f10000]
[   50.381683] [   33.972]                      [c6f10000] dsscomp_delayed_apply
[   50.381683] [   33.972]      [c6edb820] --refs=1 on RELEASED
[   50.381683] [   33.972]                      [c6f10000] dsscomp_apply
[   50.422943] [   33.993]                        [c6e64c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   50.422973] [   33.993]  [c6e89da0] --refs=0 on RELEASED
[   50.422973] [   33.993]  [c6e89da0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   50.422973] [   34.001]                        [c6e64c00] dsscomp_mgr_delayed_cb on RELEASED
[   50.452758] [   34.001]                      [c6f10000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   50.452789] [   34.008]                      [c6f10000] dsscomp_mgr_delayed_cb on DISPLAYED
[   50.452789] [   39.512]   [c6edba00] new in dsscomp_gralloc_queue (refs=1)
[   50.491058] [   39.512]                        [c6f12000] dsscomp_new
[   50.491058] [   39.512]   [c6edba00] ++refs=2 for [c6f12000]
[   50.491058] [   39.512]                        [c6f12000] dsscomp_delayed_apply
[   50.491058] [   39.512]   [c6edba00] --refs=1 on RELEASED
[   50.491088] [   39.512]                        [c6f12000] dsscomp_apply
[   50.569183] [   39.512]      [c6edb820] --refs=0 on RELEASED
[   50.569213] [   39.512]      [c6edb820] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   50.569213] [   39.512]                      [c6f10000] dsscomp_mgr_delayed_cb on RELEASED
[   50.569213] [   39.512]                        [c6f12000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   50.628204] [   39.513]      [c6edb820] new in dsscomp_gralloc_queue (refs=1)
[   50.628204] [   39.513]                      [c6f10000] dsscomp_new
[   50.628234] [   39.513]      [c6edb820] ++refs=2 for [c6f10000]
[   50.628234] [   39.513]                      [c6f10000] dsscomp_delayed_apply
[   50.658050] [   39.513]      [c6edb820] --refs=1 on RELEASED
[   50.658081] [   39.513]                      [c6f10000] dsscomp_apply
[   50.658081] [   39.527]                        [c6f12000] dsscomp_mgr_delayed_cb on DISPLAYED
[   50.658081] [   39.527]   [c6edba00] --refs=0 on RELEASED
[   50.691436] [   39.527]   [c6edba00] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   50.691436] [   39.527]                        [c6f12000] dsscomp_mgr_delayed_cb on RELEASED
[   50.691436] [   39.527]                      [c6f10000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   50.720642] [   39.550]                      [c6f10000] dsscomp_mgr_delayed_cb on DISPLAYED
[   50.720672] [   44.408]    [c6edb7a0] new in dsscomp_gralloc_queue (refs=1)
[   50.720672] [   44.408]                        [c6f12000] dsscomp_new
[   50.720672] [   44.408]    [c6edb7a0] ++refs=2 for [c6f12000]
[   50.720672] [   44.408]                        [c6f12000] dsscomp_delayed_apply
[   50.762481] [   44.408]    [c6edb7a0] --refs=1 on RELEASED
[   50.762481] [   44.408]                        [c6f12000] dsscomp_apply
[   50.762481] [   44.408]      [c6edb820] --refs=0 on RELEASED
[   50.762481] [   44.408]      [c6edb820] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   50.792663] [   44.408]                      [c6f10000] dsscomp_mgr_delayed_cb on RELEASED
[   50.792694] [   44.409]                        [c6f12000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   50.792694] [   44.409]      [c6edb820] new in dsscomp_gralloc_queue (refs=1)
[   50.821075] [   44.409]                      [c6f10000] dsscomp_new
[   50.821105] [   44.409]      [c6edb820] ++refs=2 for [c6f10000]
[   50.821105] [   44.409]                      [c6f10000] dsscomp_delayed_apply
[   50.821105] [   44.409]      [c6edb820] --refs=1 on RELEASED
[   50.821105] [   44.409]                      [c6f10000] dsscomp_apply
[   50.854064] [   44.425]                        [c6f12000] dsscomp_mgr_delayed_cb on DISPLAYED
[   50.854095] [   44.430]    [c6edb7a0] --refs=0 on RELEASED
[   50.854095] [   44.430]    [c6edb7a0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   50.854095] [   44.430]                        [c6f12000] dsscomp_mgr_delayed_cb on RELEASED
[   50.884246] [   44.430]                      [c6f10000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   50.884246] [   44.464]                      [c6f10000] dsscomp_mgr_delayed_cb on DISPLAYED
[   50.884246] [   49.508]   [c6edba00] new in dsscomp_gralloc_queue (refs=1)
[   50.912750] [   49.508]                     [c6f10c00] dsscomp_new
[   50.912750] [   49.508]   [c6edba00] ++refs=2 for [c6f10c00]
[   50.912750] [   49.508]                     [c6f10c00] dsscomp_delayed_apply
[   50.912750] [   49.508]   [c6edba00] --refs=1 on RELEASED
[   50.912750] [   49.508]                     [c6f10c00] dsscomp_apply
[   50.952026] [   49.514]      [c6edb820] --refs=0 on RELEASED
[   50.952026] [   49.514]      [c6edb820] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   50.952056] [   49.514]                      [c6f10000] dsscomp_mgr_delayed_cb on RELEASED
[   50.952056] [   49.514]                     [c6f10c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   50.985198] [   49.522]    [c6edb880] new in dsscomp_gralloc_queue (refs=1)
[   50.985198] [   49.522]                      [c6f10000] dsscomp_new
[   50.985198] [   49.522]    [c6edb880] ++refs=2 for [c6f10000]
[   50.985198] [   49.522]                      [c6f10000] dsscomp_delayed_apply
[   51.015380] [   49.522]    [c6edb880] --refs=1 on RELEASED
[   51.015380] [   49.522]                      [c6f10000] dsscomp_apply
[   51.015411] [   49.543]                     [c6f10c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   51.015411] [   49.543]   [c6edba00] --refs=0 on RELEASED
[   51.045593] [   49.543]   [c6edba00] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   51.045593] [   49.543]                     [c6f10c00] dsscomp_mgr_delayed_cb on RELEASED
[   51.045593] [   49.543]                      [c6f10000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   51.045593] [   49.557]                      [c6f10000] dsscomp_mgr_delayed_cb on DISPLAYED
[   51.084686] ACTIVE COMPOSITIONS on lcd
[   51.084686]
[   51.084686]   [c6f10000]: DISPLAYED
[   51.084686]     sync_id=0, flags=AD-
[   51.084716]     ovl0={ON z0 ARGB32-8888 premult *100% 864*480:0,0+864,480 rot0 => 0,0+864,480 7f358000/  (null)|3456}
[   51.117523]     gsync=[c6edb880] dsscomp_gralloc_cb
[   51.117523]
[   51.117523]   DISPC pipeline:
[   51.117523]
[   51.117523]     info:        clean (none)
[   51.117553]     cache:       clean (none)
[   51.117553]     shadow:  ACT clean (none)
[   51.117553]     dispc:   DISPLAYED mask=---R [c6f10000] dsscomp_mgr_callback
[   51.117553]
[   51.117553] ACTIVE COMPOSITIONS on tv
[   51.117553]
[   51.117553]   DISPC pipeline:
[   51.159698]
[   51.159698]     info:        clean (none)
[   51.159698]     cache:       clean (none)
[   51.159698]     shadow:  off clean (none)
[   51.159698]     dispc:   DISPLAYED (none)
[   51.159698]
[   51.159698] ACTIVE COMPOSITIONS on lcd2
[   51.159698]
[   51.159698]   DISPC pipeline:
[   51.159698]
[   51.159729]     shadow:  off clean (none)
[   51.203613]     dispc:             (none)
[   51.203613]
[   51.203613] ACTIVE GRALLOC FLIPS
[   51.203613]
[   51.203613]   [c6edb880] (refs=1)
[   51.203613]     slots=[7f358000]
[   51.203613]     cmdcb=[c73f6900] dsscomp_proxy_cmdcomplete
[   51.203613]
[   51.203643]   |           lcd
[   51.203643]   | [c6f10000] DISPL'D
[   51.203643]   |     49.522  ACTIVE
[   51.203643]   |     49.522 APPLY'N
[   51.203643]   |     49.522 APPLIED
[   51.247741]   |     49.543 PROGR'D
[   51.247741]   |     49.557 DISPL'D
[   51.247741]
[   51.247741]
[   51.261138] PVR_K: SGX debug (blaze_android_sgx_ogles1_ogles2_GPL sgxddk 18 1.8@869593)
[   51.270751] PVR_K:(Error): SGX Register Base Address (Linear):   0xC8B20000 [0, ]
[   51.293243] PVR_K:(Error): SGX Register Base Address (Physical): 0x56000000 [0, ]
[   51.303466] PVR_K: (P0) EUR_CR_CORE_ID:          01140000
[   51.309631] PVR_K: (P0) EUR_CR_CORE_REVISION:    00010200
[   51.318145] PVR_K: (P0) EUR_CR_EVENT_STATUS:     20000000
[   51.328918] PVR_K: (P0) EUR_CR_EVENT_STATUS2:    00000008
[   51.334747] PVR_K: (P0) EUR_CR_BIF_CTRL:         00000000
[   51.340637] PVR_K: (P0) EUR_CR_BIF_INT_STAT:     00008000
[   51.347991] PVR_K: (P0) EUR_CR_BIF_FAULT:        00000000
[   51.356201] PVR_K: (P0) EUR_CR_BIF_MEM_REQ_STAT: 00000000
[   51.362243] PVR_K: (P0) EUR_CR_CLKGATECTL:       000AAA6A
[   51.368194] PVR_K: (P0) EUR_CR_PDS_PC_BASE:      00004038
[   51.384063] PVR_K: Flip Command Complete Data 0 for display device 1:
[   51.392425] PVR_K:   SRC 0: (Not in use)
[   51.396667] PVR_K: Flip Command Complete Data 1 for display device 1:
[   51.403930] PVR_K:   SRC 0: ROC DevVAddr:0xD800474 ROP:0x8 ROC:0x6, WOC DevVAddr:0xD800464 WOP:0x8 WOC:0x7
[   51.414855] PVR_K: SGX Host control:
[   51.419372] PVR_K:   (HC-0) 0x00000001 0x00000000 0x00000000 0x00000001
[   51.427734] PVR_K:   (HC-10) 0x00000008 0x0000000A 0x0005DC00 0x00000003
[   51.434844] PVR_K:   (HC-20) 0x00000000 0x00000001 0x00000000 0x0000000C
[   51.443054] PVR_K:   (HC-30) 0x00000DF9 0xF1128394 0x00000000 0x00000000
[   51.450958] PVR_K:   (HC-40) 0x00000000 0x087BF500 0x087C6300 0x087C3100
[   51.459014] PVR_K: SGX TA/3D control:
[   51.463317] PVR_K:   (T3C-0) 0x0F003000 0x0F003120 0x0F002000 0x00000000
[   51.473175] PVR_K:   (T3C-10) 0x00000001 0x00000002 0x00000001 0x0F00DD00
[   51.481933] PVR_K:   (T3C-20) 0x00000000 0x00000000 0x00000000 0x00000000
[   51.498596] PVR_K:   (T3C-30) 0x00000000 0x00000000 0x00000000 0x00000000
[   51.507263] PVR_K:   (T3C-40) 0x00000000 0x00000000 0x00000000 0x00000000
[   51.516326] PVR_K:   (T3C-50) 0x0F00DD00 0x00000000 0x00000000 0x0F00DD00
[   51.527587] PVR_K:   (T3C-60) 0x00000000 0x00000000 0x0F00DD00 0x00000000
[   51.545745] PVR_K:   (T3C-70) 0x00000000 0x0F00DD00 0x00000000 0x0F004000
[   51.552947] PVR_K:   (T3C-80) 0x00000005 0x0001120F 0x00000000 0x0F00DEB8
[   51.577270] PVR_K:   (T3C-90) 0x00000000 0x0F000000 0xAB600000 0x0F041800
[   51.588989] PVR_K:   (T3C-A0) 0x00000000 0x0F010BE0 0x0F00DD00 0x0F00DEB8
[   51.597259] PVR_K:   (T3C-B0) 0x0F010760 0x00000000 0x00000000 0x00000000
[   51.613128] PVR_K:   (T3C-C0) 0x00000000 0x00000000 0x00000000 0x00000000
[   51.622833] PVR_K:   (T3C-D0) 0x00000000 0x0000000E 0x0000000D 0x0F007000
[   51.630371] PVR_K:   (T3C-E0) 0x0F00D420 0x0F00E000 0x0F010720 0x0F010720
[   51.647338] PVR_K:   (T3C-F0) 0x00000000 0x000000B5 0x000000B5 0x00000000
[   51.654479] PVR_K:   (T3C-100) 0x00000003 0x00000000 0x00000000 0x00000000
[   51.668884] PVR_K:   (T3C-110) 0xB50C565C 0x0872E100 0x08787B00 0x08787B00
[   51.676239] PVR_K: Last SGX microkernel status code: AD000104
[   51.682434] PVR_K:   (MKT-0) 00005FC9 00100828 01000A1F AD000104
[   51.688842] PVR_K:   (MKT-1) 000060E2 00100808 01000B1F AD000100
[   51.695220] PVR_K:   (MKT-2) 0000619D 00100808 01000B1F AD000501
[   51.701812] PVR_K:   (MKT-3) 000061C8 00100829 01000B1F AD000104
[   51.708343] PVR_K:   (MKT-4) 00008717 00100828 01000D1F AD000101
[   51.715057] PVR_K:   (MKT-5) 00008790 00100828 01000D1F AD000104
[   51.721435] PVR_K:   (MKT-6) 000087CD 00100808 01000E1E AD000100
[   51.727874] PVR_K:   (MKT-7) 000088C9 00100808 01000E1E AD000501
[   51.734313] PVR_K:   (MKT-8) 00008908 00100829 01000E1E AD000104
[   51.741088] PVR_K:   (MKT-9) 06FB67D5 00100808 0100031F AD000B00
[   51.747802] PVR_K:   (MKT-A) 06FB681A 00100808 0100031F AD000B03
[   51.754730] PVR_K:   (MKT-B) 06FB68A1 00100808 0100031F AD000B05
[   51.761444] PVR_K:   (MKT-C) 06FB68F8 00100808 0100031F AD000B06
[   51.768066] PVR_K:   (MKT-D) 06FB6928 00100808 0100031F AD000B06
[   51.774566] PVR_K:   (MKT-E) 06FB696B 00100808 0100031F AD000B07
[   51.781341] PVR_K:   (MKT-F) 06FB6990 00100808 0100031F AD000B09
[   51.788024] PVR_K:   (MKT-10) 06FB69E6 00100808 0100031F AD000B01
[   51.794799] PVR_K:   (MKT-11) 06FB6A22 00100808 0100031F AD002300
[   51.801818] PVR_K:   (MKT-12) 06FB6D3E 00100808 0100041F AD00000A
[   51.808441] PVR_K:   (MKT-13) 06FB6DBC 00100808 0100041F AD000906
[   51.815032] PVR_K:   (MKT-14) 06FB6E7D 00100808 0000041F AD000901
[   51.821655] PVR_K:   (MKT-15) 06FB6EF7 00100808 0000051E AD000183
[   51.828308] PVR_K:   (MKT-16) 06FB706C 00100808 0000051E AD000302
[   51.834777] PVR_K:   (MKT-17) 06FB70C2 00100808 0000051E AD000303
[   51.841522] PVR_K:   (MKT-18) 06FB714C 00100808 0000051E AD000C01
[   51.848205] PVR_K:   (MKT-19) 06FB7172 00100808 0000051E 0D800484
[   51.856262] PVR_K:   (MKT-1A) 06FB718A 00100808 0000051E 00000005
[   51.862792] PVR_K:   (MKT-1B) 06FB73DD 00100808 0000051E AD00030E
[   51.869354] PVR_K:   (MKT-1C) 06FB73F5 00100808 0000051E 0D800474
[   51.880920] PVR_K:   (MKT-1D) 06FB740E 00100808 0000051E 00000004
[   51.892303] PVR_K:   (MKT-1E) 06FB7432 00100808 0000051E 00000005
[   51.902618] PVR_K:   (MKT-1F) 06FB74A8 00100808 0000051E AD000184
[   51.920776] PVR_K:   (MKT-20) 06FB752B 00100C08 0100061D AD000281
[   51.927185] PVR_K:   (MKT-21) 06FB76BF 00100808 0100061D AD00080A
[   51.942779] PVR_K:   (MKT-22) 06FB76D8 00100808 0100061D 0F03EB00
[   51.949279] PVR_K:   (MKT-23) 06FB76F0 00100808 0100061D 00000061
[   51.964721] PVR_K:   (MKT-24) 06FB7807 00100C88 0100061D AD001300
[   51.974151] PVR_K:   (MKT-25) 06FBCBF1 00100808 0000061D AD001301
[   51.987396] PVR_K:   (MKT-26) 06FBCD23 00100888 0000061D AD000802
[   51.993927] PVR_K:   (MKT-27) 06FBCE96 00100888 0000061D AD000803
[   52.000396] PVR_K:   (MKT-28) 06FBCEE5 001808C8 0000061D AD000282
[   52.007080] PVR_K:   (MKT-29) 06FBCFCA 00184EF8 0000081E AD00000A
[   52.013671] PVR_K:   (MKT-2A) 06FBD04E 001CCAF8 0000081E AD000905
[   52.030151] PVR_K:   (MKT-2B) 06FBD175 001808B8 0000081E AD000901
[   52.036560] PVR_K:   (MKT-2C) 06FBD1E7 00180838 0000091C AD00000A
[   52.046142] PVR_K:   (MKT-2D) 06FBD253 00180838 0000091C AD000905
[   52.052581] PVR_K:   (MKT-2E) 06FBD301 00180838 0000091C AD000901
[   52.059112] PVR_K:   (MKT-2F) 06FBD357 00180838 00000A1B AD00000A
[   52.065582] PVR_K:   (MKT-30) 06FBD3B8 00180838 00000A1B AD000905
[   52.072113] PVR_K:   (MKT-31) 06FBD464 00180838 00000A1B AD000901
[   52.078735] PVR_K:   (MKT-32) 06FBD4B8 00180838 00000B1A AD00000A
[   52.085388] PVR_K:   (MKT-33) 06FBD52C 00180838 00000B1A AD000906
[   52.092224] PVR_K:   (MKT-34) 06FBD5A9 00180838 00000B1A AD000901
[   52.098724] PVR_K:   (MKT-35) 06FBD600 00180838 00000C19 AD00000A
[   52.105224] PVR_K:   (MKT-36) 06FBD66C 00180838 00000C19 AD000905
[   52.111755] PVR_K:   (MKT-37) 06FBD721 00180838 00000C19 AD000901
[   52.118621] PVR_K:   (MKT-38) 06FBD887 00180838 00000F1F AD000183
[   52.125427] PVR_K:   (MKT-39) 06FBDA0A 00180838 00000F1F AD000302
[   52.132141] PVR_K:   (MKT-3A) 06FBDA7E 00180838 00000F1F AD000303
[   52.138671] PVR_K:   (MKT-3B) 06FBDAFF 00180838 00000F1F AD000C01
[   52.145263] PVR_K:   (MKT-3C) 06FBDB32 00180838 00000F1F 0D800464
[   52.151733] PVR_K:   (MKT-3D) 06FBDB4F 00180838 00000F1F 00000006
[   52.158233] PVR_K:   (MKT-3E) 06FBDD78 00180838 00000F1F AD000184
[   52.165405] PVR_K:   (MKT-3F) 06FBDDEA 00180C38 0100101D AD000281
[   52.171966] PVR_K:   (MKT-40) 06FBDE41 00180838 0100101D AD000282
[   52.178588] PVR_K:   (MKT-41) 06FBE355 00180838 0100111F AD00000A
[   52.185241] PVR_K:   (MKT-42) 06FBE3BD 00180838 0100111F AD000905
[   52.201995] PVR_K:   (MKT-43) 06FBE4C7 00180838 0000111F AD000901
[   52.208404] PVR_K:   (MKT-44) 06FBE518 00180C38 0100121E AD000281
[   52.216827] PVR_K:   (MKT-45) 06FBE56F 00180838 0100121E AD000282
[   52.225250] PVR_K:   (MKT-46) 06FBE62F 00180838 0100131F AD00000A
[   52.231781] PVR_K:   (MKT-47) 06FBE699 00180838 0100131F AD000905
[   52.238220] PVR_K:   (MKT-48) 06FBE79A 00180838 0000131F AD000901
[   52.256713] PVR_K:   (MKT-49) 06FBE7ED 00180C38 0100141E AD000281
[   52.263122] PVR_K:   (MKT-4A) 06FBE845 00180838 0100141E AD000282
[   52.285675] PVR_K:   (MKT-4B) 06FBE97B 00180838 0100151F AD00000A
[   52.292114] PVR_K:   (MKT-4C) 06FBE9E8 00180838 0100151F AD000905
[   52.308319] PVR_K:   (MKT-4D) 06FBEAE3 00180838 0000151F AD000901
[   52.317504] PVR_K:   (MKT-4E) 06FBEB33 00180C38 0100161E AD000281
[   52.334838] PVR_K:   (MKT-4F) 06FBEB8E 00180838 0000161E AD000282
[   52.341247] PVR_K:   (MKT-50) 06FBEC51 00180838 0100171F AD00000A
[   52.357727] PVR_K:   (MKT-51) 06FBECC1 00180838 0100171F AD000905
[   52.364501] PVR_K:   (MKT-52) 06FBEDBD 00180838 0000171F AD000901
[   52.370941] PVR_K:   (MKT-53) 06FBEE0F 00180C38 0100181E AD000281
[   52.377410] PVR_K:   (MKT-54) 06FBEE6A 00180838 0100181E AD000282
[   52.383819] PVR_K:   (MKT-55) 06FBF184 00000808 0100191F AD000200
[   52.390289] PVR_K:   (MKT-56) 06FBF3CD 00000808 0000191F AD000202
[   52.396697] PVR_K:   (MKT-57) 06FBF41A 00000808 01001A1E AD000281
[   52.404693] PVR_K:   (MKT-58) 06FBF567 00000808 01001A1E AD00080A
[   52.411132] PVR_K:   (MKT-59) 06FBF580 00000808 01001A1E 0F03EE00
[   52.417602] PVR_K:   (MKT-5A) 06FBF598 00000808 01001A1E 00000060
[   52.424041] PVR_K:   (MKT-5B) 06FBF86A 00000808 00001A1E AD000803
[   52.430511] PVR_K:   (MKT-5C) 06FBF8B2 00180CC8 00001A1E AD000282
[   52.436981] PVR_K:   (MKT-5D) 06FBF955 00000808 01001C1F AD000200
[   52.443481] PVR_K:   (MKT-5E) 06FBFB81 00000808 00001C1F AD000202
[   52.449951] PVR_K:   (MKT-5F) 06FBFBCD 00000808 01001D1E AD000281
[   52.456634] PVR_K:   (MKT-60) 06FBFD1F 00000808 01001D1E AD00080A
[   52.463256] PVR_K:   (MKT-61) 06FBFD39 00000808 01001D1E 0F03F100
[   52.470123] PVR_K:   (MKT-62) 06FBFD51 00000808 01001D1E 00000060
[   52.476654] PVR_K:   (MKT-63) 06FC001C 00000808 00001D1E AD000803
[   52.483093] PVR_K:   (MKT-64) 06FC0068 00188CC8 00001D1E AD000282
[   52.489715] PVR_K:   (MKT-65) 06FC0158 00000808 01001F1F AD000200
[   52.496520] PVR_K:   (MKT-66) 06FC038B 00000888 01001F1F AD000202
[   52.503356] PVR_K:   (MKT-67) 06FC03DC 00000808 0100201E AD000281
[   52.510253] PVR_K:   (MKT-68) 06FC052E 00000808 0100201E AD00080A
[   52.517089] PVR_K:   (MKT-69) 06FC0547 00000808 0100201E 0F03F400
[   52.523681] PVR_K:   (MKT-6A) 06FC0560 00000808 0100201E 00000062
[   52.530181] PVR_K:   (MKT-6B) 06FC081C 00000808 0000201E AD000803
[   52.536651] PVR_K:   (MKT-6C) 06FC0862 00180C88 0000201E AD000282
[   52.543914] PVR_K:   (MKT-6D) 06FC13CB 00000808 0100221F AD000200
[   52.550415] PVR_K:   (MKT-6E) 06FC14E9 00000808 0100221F AD001703
[   52.556976] PVR_K:   (MKT-6F) 06FC16EF 00000808 0000221F AD000202
[   52.563446] PVR_K:   (MKT-70) 06FC176F 00000808 0000231E AD000183
[   52.570129] PVR_K:   (MKT-71) 06FC185F 00000808 0000231E AD00030E
[   52.576751] PVR_K:   (MKT-72) 06FC1877 00000808 0000231E 0D800494
[   52.592620] PVR_K:   (MKT-73) 06FC1890 00000808 0000231E 00000004
[   52.599060] PVR_K:   (MKT-74) 06FC18B5 00000808 0000231E 00000005
[   52.608673] PVR_K:   (MKT-75) 06FC1920 00000808 0000231E AD000184
[   52.617248] PVR_K:   (MKT-76) 06FC198A 00000C08 0100241D AD000281
[   52.623687] PVR_K:   (MKT-77) 06FC1B03 00000808 0100241D AD00080A
[   52.630310] PVR_K:   (MKT-78) 06FC1B1C 00000808 0100241D 0F03F700
[   52.647338] PVR_K:   (MKT-79) 06FC1B35 00000808 0100241D 00000061
[   52.653778] PVR_K:   (MKT-7A) 06FC1CB4 00000808 0000241D AD000802
[   52.678588] PVR_K:   (MKT-7B) 06FC1E11 00000808 0000241D AD000803
[   52.685028] PVR_K:   (MKT-7C) 06FC1E59 00184EC8 0000241D AD000282
[   52.691894] PVR_K:   (MKT-7D) 06FC3E47 00000C08 0100271F AD000200
[   52.704498] PVR_K:   (MKT-7E) 06FC4096 00000808 0000271F AD000202
[   52.713745] PVR_K:   (MKT-7F) 06FC411E 00000808 0000281E AD000183
[   52.733245] PVR_K:   (MKT-80) 06FC4208 00000808 0000281E AD00030E
[   52.739654] PVR_K:   (MKT-81) 06FC4220 00000808 0000281E 0D800494
[   52.757751] PVR_K:   (MKT-82) 06FC4238 00000808 0000281E 00000004
[   52.764251] PVR_K:   (MKT-83) 06FC425C 00000808 0000281E 00000005
[   52.770751] PVR_K:   (MKT-84) 06FC42C8 00000808 0000281E AD000184
[   52.777252] PVR_K:   (MKT-85) 06FC432D 00000C08 0100291D AD000281
[   52.783905] PVR_K:   (MKT-86) 06FC4498 00000808 0100291D AD00080A
[   52.790557] PVR_K:   (MKT-87) 06FC44B0 00000808 0100291D 0F03FA00
[   52.797271] PVR_K:   (MKT-88) 06FC44C9 00000808 0100291D 00000060
[   52.803771] PVR_K:   (MKT-89) 06FC477F 00000808 0000291D AD000803
[   52.810241] PVR_K:   (MKT-8A) 06FC47C6 00180CC8 0000291D AD000282
[   52.826599] PVR_K:   (MKT-8B) 06FC486B 00000808 01002B1F AD000200
[   52.834594] PVR_K:   (MKT-8C) 06FC4A81 00000808 00002B1F AD000202
[   52.841094] PVR_K:   (MKT-8D) 06FC4B02 00000808 00002C1E AD000183
[   52.847595] PVR_K:   (MKT-8E) 06FC4BEC 00000808 00002C1E AD00030E
[   52.854095] PVR_K:   (MKT-8F) 06FC4C04 00000808 00002C1E 0D800494
[   52.860565] PVR_K:   (MKT-90) 06FC4C1D 00000808 00002C1E 00000004
[   52.867248] PVR_K:   (MKT-91) 06FC4C41 00000808 00002C1E 00000005
[   52.873870] PVR_K:   (MKT-92) 06FC4CAB 00000808 00002C1E AD000184
[   52.880767] PVR_K:   (MKT-93) 06FC4D0F 00000C08 01002D1D AD000281
[   52.887298] PVR_K:   (MKT-94) 06FC4E78 00000808 01002D1D AD00080A
[   52.893768] PVR_K:   (MKT-95) 06FC4E93 00000808 01002D1D 0F03FD00
[   52.900451] PVR_K:   (MKT-96) 06FC4EAB 00000808 01002D1D 00000060
[   52.907257] PVR_K:   (MKT-97) 06FC5160 00000808 00002D1D AD000803
[   52.914123] PVR_K:   (MKT-98) 06FC51A7 00180CC8 00002D1D AD000282
[   52.920593] PVR_K:   (MKT-99) 06FC528F 00000808 01002F1F AD000200
[   52.927337] PVR_K:   (MKT-9A) 06FC54A8 00000808 00002F1F AD000202
[   52.934020] PVR_K:   (MKT-9B) 06FC5528 00000808 0000301E AD000183
[   52.941040] PVR_K:   (MKT-9C) 06FC5610 00000808 0000301E AD00030E
[   52.947814] PVR_K:   (MKT-9D) 06FC5628 00000808 0000301E 0D800494
[   52.954803] PVR_K:   (MKT-9E) 06FC5641 00000808 0000301E 00000004
[   52.961578] PVR_K:   (MKT-9F) 06FC5664 00000808 0000301E 00000005
[   52.968475] PVR_K:   (MKT-A0) 06FC56CF 00000808 0000301E AD000184
[   52.975280] PVR_K:   (MKT-A1) 06FC5733 00000C08 0100311D AD000281
[   52.981811] PVR_K:   (MKT-A2) 06FC58A4 00000808 0100311D AD00080A
[   52.988433] PVR_K:   (MKT-A3) 06FC58BD 00000808 0100311D 0F040000
[   52.995025] PVR_K:   (MKT-A4) 06FC58D5 00000808 0100311D 00000062
[   53.001647] PVR_K:   (MKT-A5) 06FC5B87 00000808 0000311D AD000803
[   53.008117] PVR_K:   (MKT-A6) 06FC5BD0 00180C88 0000311D AD000282
[   53.014648] PVR_K:   (MKT-A7) 06FC66EC 00000808 0100331F AD000200
[   53.022613] PVR_K:   (MKT-A8) 06FC6809 00000808 0100331F AD001703
[   53.029144] PVR_K:   (MKT-A9) 06FC69EE 00000808 0000331F AD000202
[   53.035949] PVR_K:   (MKT-AA) 06FC6A6C 00000808 0000341E AD000183
[   53.042816] PVR_K:   (MKT-AB) 06FC6B56 00000808 0000341E AD00030E
[   53.050811] PVR_K:   (MKT-AC) 06FC6B6E 00000808 0000341E 0D800494
[   53.057373] PVR_K:   (MKT-AD) 06FC6B86 00000808 0000341E 00000004
[   53.064025] PVR_K:   (MKT-AE) 06FC6BAA 00000808 0000341E 00000005
[   53.070617] PVR_K:   (MKT-AF) 06FC6C14 00000808 0000341E AD000184
[   53.077392] PVR_K:   (MKT-B0) 06FC6C7A 00000C08 0100351D AD000281
[   53.084197] PVR_K:   (MKT-B1) 06FC6D8A 00000808 0100351D AD000E02
[   53.091094] PVR_K:   (MKT-B2) 06FC6DFE 00000808 0100351D AD000282
[   53.097564] PVR_K:   (MKT-B3) 06FD3F10 00000808 0100381F AD001A00
[   53.106201] PVR_K:   (MKT-B4) 06FE6264 00000808 01003C1F AD00000A
[   53.112945] PVR_K:   (MKT-B5) 06FE62C8 00000808 01003C1F AD000909
[   53.119812] PVR_K:   (MKT-B6) 06FE6312 00000808 01003C1F AD001A05
[   53.126312] PVR_K:   (MKT-B7) 06FE6341 00000808 01003C1F AD001302
[   53.133178] PVR_K:   (MKT-B8) 06FE6381 00000808 01003C1F AD001303
[   53.139984] PVR_K:   (MKT-B9) 06FE6411 00000808 01003C1F AD000D04
[   53.146820] PVR_K:   (MKT-BA) 06FE64DE 00000808 01003C1F AD000D05
[   53.154388] PVR_K:   (MKT-BB) 06FE6536 00000808 01003C1F AD000D04
[   53.161254] PVR_K:   (MKT-BC) 06FE65BA 00000808 01003C1F AD000D05
[   53.168060] PVR_K:   (MKT-BD) 06FE6616 00000808 01003C1F AD001A06
[   53.186370] PVR_K:   (MKT-BE) 0000051B 00100808 0100031F AD002300
[   53.192779] PVR_K:   (MKT-BF) 00000A39 00100808 0100041F AD00000A
[   53.205993] PVR_K:   (MKT-C0) 00000AB8 00100808 0100041F AD000906
[   53.212646] PVR_K:   (MKT-C1) 00000B8D 00100808 0000041F AD000901
[   53.219329] PVR_K:   (MKT-C2) 00000C0B 00100808 0000051E AD000183
[   53.225799] PVR_K:   (MKT-C3) 00000D83 00100808 0000051E AD000302
[   53.232238] PVR_K:   (MKT-C4) 00000F11 00100808 0000051E AD000D06
[   53.240661] PVR_K:   (MKT-C5) 00001000 00100808 0000051E AD000D07
[   53.249053] PVR_K:   (MKT-C6) 0000104B 00100808 0000051E AD001304
[   53.255523] PVR_K:   (MKT-C7) 00001136 00100808 0000051E AD001305
[   53.261962] PVR_K:   (MKT-C8) 00001247 00100888 0000051E AD000404
[   53.280151] PVR_K:   (MKT-C9) 0000130E 00100808 0000051E AD000402
[   53.286560] PVR_K:   (MKT-CA) 00001356 0010082B 0000051E AD000184
[   53.297668] PVR_K:   (MKT-CB) 000013F5 00119DA9 0000061D AD000281
[   53.309997] PVR_K:   (MKT-CC) 0000158A 001199AB 0000061D AD000E02
[   53.317932] PVR_K:   (MKT-CD) 000015EE 0010892B 0000061D AD000282
[   53.334808] PVR_K:   (MKT-CE) 046061D8 00100808 0100031F AD000B00
[   53.341278] PVR_K:   (MKT-CF) 04606220 00100808 0100031F AD000B03
[   53.366058] PVR_K:   (MKT-D0) 046062A6 00100808 0100031F AD000B05
[   53.372528] PVR_K:   (MKT-D1) 046062FB 00100808 0100031F AD000B06
[   53.384765] PVR_K:   (MKT-D2) 0460632B 00100808 0100031F AD000B06
[   53.398620] PVR_K:   (MKT-D3) 0460636E 00100808 0100031F AD000B07
[   53.406677] PVR_K:   (MKT-D4) 04606393 00100808 0100031F AD000B09
[   53.428558] PVR_K:   (MKT-D5) 046063E8 00100808 0100031F AD000B01
[   53.435028] PVR_K:   (MKT-D6) 04606424 00100808 0100031F AD002300
[   53.447448] PVR_K:   (MKT-D7) 04606742 00100808 0100041F AD00000A
[   53.453979] PVR_K:   (MKT-D8) 046067C3 00100808 0100041F AD000906
[   53.460479] PVR_K:   (MKT-D9) 04606881 00100808 0000041F AD000901
[   53.467132] PVR_K:   (MKT-DA) 046068FB 00100808 0000051E AD000183
[   53.473754] PVR_K:   (MKT-DB) 04606A69 00100808 0000051E AD000302
[   53.490753] PVR_K:   (MKT-DC) 04606AC6 00100808 0000051E AD000303
[   53.498809] PVR_K:   (MKT-DD) 04606B4E 00100808 0000051E AD000C01
[   53.505310] PVR_K:   (MKT-DE) 04606B72 00100808 0000051E 0D800484
[   53.511779] PVR_K:   (MKT-DF) 04606B8A 00100808 0000051E 00000006
[   53.518280] PVR_K:   (MKT-E0) 04606DD4 00100808 0000051E AD00030E
[   53.527770] PVR_K:   (MKT-E1) 04606DEC 00100808 0000051E 0D800474
[   53.539794] PVR_K:   (MKT-E2) 04606E05 00100808 0000051E 00000005
[   53.546325] PVR_K:   (MKT-E3) 04606E28 00100808 0000051E 00000006
[   53.552764] PVR_K:   (MKT-E4) 04606EA0 00100808 0000051E AD000184
[   53.561096] PVR_K:   (MKT-E5) 04606F1A 00100C08 0100061D AD000281
[   53.567565] PVR_K:   (MKT-E6) 046070A9 00100808 0100061D AD00080A
[   53.574066] PVR_K:   (MKT-E7) 046070C2 00100808 0100061D 0F040300
[   53.580566] PVR_K:   (MKT-E8) 046070DA 00100808 0100061D 00000061
[   53.587097] PVR_K:   (MKT-E9) 046071EE 00100C88 0100061D AD001300
[   53.593719] PVR_K:   (MKT-EA) 0460C371 00100808 0000061D AD001301
[   53.600372] PVR_K:   (MKT-EB) 0460C49A 00100808 0000061D AD000802
[   53.607147] PVR_K:   (MKT-EC) 0460C5FC 00100808 0000061D AD000803
[   53.613647] PVR_K:   (MKT-ED) 0460C649 00184AC8 0000061D AD000282
[   53.620117] PVR_K:   (MKT-EE) 0460E5D0 00000C08 01000A1F AD000200
[   53.626708] PVR_K:   (MKT-EF) 0460E830 00000808 00000A1F AD000202
[   53.633453] PVR_K:   (MKT-F0) 0460E8C9 00000808 00000B1E AD000183
[   53.640258] PVR_K:   (MKT-F1) 0460E9C9 00000808 00000B1E AD00030E
[   53.647674] PVR_K:   (MKT-F2) 0460E9E1 00000808 00000B1E 0D800474
[   53.654235] PVR_K:   (MKT-F3) 0460E9FA 00000808 00000B1E 00000005
[   53.660858] PVR_K:   (MKT-F4) 0460EA1D 00000808 00000B1E 00000006
[   53.667419] PVR_K:   (MKT-F5) 0460EA88 00000808 00000B1E AD000184
[   53.673950] PVR_K:   (MKT-F6) 0460EAF5 00000C08 01000C1D AD000281
[   53.680450] PVR_K:   (MKT-F7) 0460EC5D 00000808 01000C1D AD00080A
[   53.702026] PVR_K:   (MKT-F8) 0460EC76 00000808 01000C1D 0F040600
[   53.708435] PVR_K:   (MKT-F9) 0460EC8E 00000808 01000C1D 00000060
[   53.725311] PVR_K:   (MKT-FA) 0460EF42 00000808 00000C1D AD000803
[   53.731719] PVR_K:   (MKT-FB) 0460EF88 00180CC8 00000C1D AD000282
[   53.746215] PVR_K:   (MKT-FC) 0460F047 00000808 01000E1F AD000200
[   53.752868] PVR_K:   (MKT-FD) 0460F25C 00000808 00000E1F AD000202
[   53.759429] PVR_K:   (MKT-FE) 0460F2DD 00000808 00000F1E AD000183
[   53.765930] PVR_K:   (MKT-FF) 0460F3C5 00000808 00000F1E AD00030E
[   53.772552] PVR_K:   (MKT-100) 0460F3DE 00000808 00000F1E 0D800474
[   53.779052] PVR_K:   (MKT-101) 0460F3F6 00000808 00000F1E 00000005
[   53.785827] PVR_K:   (MKT-102) 0460F41A 00000808 00000F1E 00000006
[   53.792602] PVR_K:   (MKT-103) 0460F483 00000808 00000F1E AD000184
[   53.799407] PVR_K:   (MKT-104) 0460F4E8 00000C08 0100101D AD000281
[   53.806030] PVR_K:   (MKT-105) 0460F657 00000808 0100101D AD00080A
[   53.813446] PVR_K:   (MKT-106) 0460F66F 00000808 0100101D 0F040900
[   53.820098] PVR_K:   (MKT-107) 0460F688 00000808 0100101D 00000060
[   53.826873] PVR_K:   (MKT-108) 0460F940 00000808 0000101D AD000803
[   53.833557] PVR_K:   (MKT-109) 0460F986 00180CC8 0000101D AD000282
[   53.849914] PVR_K:   (MKT-10A) 0460FA6C 00000808 0100121F AD000200
[   53.858337] PVR_K:   (MKT-10B) 0460FC83 00000808 0000121F AD000202
[   53.864898] PVR_K:   (MKT-10C) 0460FD01 00000808 0000131E AD000183
[   53.871520] PVR_K:   (MKT-10D) 0460FDEE 00000808 0000131E AD00030E
[   53.878082] PVR_K:   (MKT-10E) 0460FE06 00000808 0000131E 0D800474
[   53.884826] PVR_K:   (MKT-10F) 0460FE1F 00000808 0000131E 00000005
[   53.891601] PVR_K:   (MKT-110) 0460FE43 00000808 0000131E 00000006
[   53.898376] PVR_K:   (MKT-111) 0460FEAF 00000808 0000131E AD000184
[   53.904968] PVR_K:   (MKT-112) 0460FF13 00000C08 0100141D AD000281
[   53.911529] PVR_K:   (MKT-113) 04610081 00000808 0100141D AD00080A
[   53.928588] PVR_K:   (MKT-114) 0461009A 00000808 0100141D 0F040C00
[   53.935089] PVR_K:   (MKT-115) 046100B2 00000808 0100141D 00000062
[   53.944519] PVR_K:   (MKT-116) 04610366 00000808 0000141D AD000803
[   53.951049] PVR_K:   (MKT-117) 046103AC 00180C88 0000141D AD000282
[   53.957672] PVR_K:   (MKT-118) 04610E9F 00000808 0100161F AD000200
[   53.964233] PVR_K:   (MKT-119) 04610FBC 00000808 0100161F AD001703
[   53.970916] PVR_K:   (MKT-11A) 04611190 00000808 0000161F AD000202
[   53.977478] PVR_K:   (MKT-11B) 0461120C 00000808 0100171E AD000183
[   53.989440] PVR_K:   (MKT-11C) 046112F6 00000808 0100171E AD00030E
[   54.001800] PVR_K:   (MKT-11D) 0461130F 00000808 0100171E 0D800474
[   54.008361] PVR_K:   (MKT-11E) 04611327 00000808 0100171E 00000005
[   54.015075] PVR_K:   (MKT-11F) 0461134A 00000808 0100171E 00000006
[   54.021636] PVR_K:   (MKT-120) 046113D7 00000808 0100171E AD000184
[   54.028320] PVR_K:   (MKT-121) 0461DB54 00000808 01001A1F AD001A00
[   54.035034] PVR_K:   (MKT-122) 07437565 00000808 0107F91F AD00000A
[   54.041809] PVR_K:   (MKT-123) 074375CF 00000808 0107F91F AD000909
[   54.048736] PVR_K:   (MKT-124) 07437619 00000808 0107F91F AD001A05
[   54.055358] PVR_K:   (MKT-125) 07437649 00000808 0107F91F AD001302
[   54.061920] PVR_K:   (MKT-126) 07437689 00000808 0107F91F AD001303
[   54.068695] PVR_K:   (MKT-127) 07437720 00000808 0107F91F AD000D04
[   54.075592] PVR_K:   (MKT-128) 074377EB 00000808 0107F91F AD000D05
[   54.082519] PVR_K:   (MKT-129) 0743785A 00000808 0107F91F AD001A06
[   54.089141] PVR_K:   (MKT-12A) 00000487 00100808 0100031F AD002300
[   54.095825] PVR_K:   (MKT-12B) 0000097D 00100808 0100041F AD00000A
[   54.102569] PVR_K:   (MKT-12C) 000009F1 00100808 0100041F AD000905
[   54.109222] PVR_K:   (MKT-12D) 00000B2F 00100808 0000041F AD000901
[   54.115997] PVR_K:   (MKT-12E) 00000BAC 00100808 0000051E AD000183
[   54.122711] PVR_K:   (MKT-12F) 00000CB9 00100808 0000051E AD00030E
[   54.129730] PVR_K:   (MKT-130) 00000CD2 00100808 0000051E 0D800474
[   54.136627] PVR_K:   (MKT-131) 00000CEB 00100808 0000051E 00000005
[   54.143249] PVR_K:   (MKT-132) 00000D0F 00100808 0000051E 00000006
[   54.149963] PVR_K:   (MKT-133) 00000D7A 00100808 0000051E AD000184
[   54.156738] PVR_K:   (MKT-134) 00000DFA 00100C08 0100061D AD000281
[   54.163299] PVR_K:   (MKT-135) 00000F24 00100808 0100061D AD000E02
[   54.170043] PVR_K:   (MKT-136) 00000F9A 00100808 0100061D AD000282
[   54.176818] PVR_K:   (MKT-137) 000010ED 00100808 0100071F AD00000A
[   54.183807] PVR_K:   (MKT-138) 00001155 00100808 0100071F AD000905
[   54.190734] PVR_K:   (MKT-139) 00001265 00100808 0000071F AD000901
[   54.197418] PVR_K:   (MKT-13A) 000012CF 00100808 0000081E AD000183
[   54.204101] PVR_K:   (MKT-13B) 000013BD 00100808 0000081E AD00030E
[   54.210754] PVR_K:   (MKT-13C) 000013D6 00100808 0000081E 0D800474
[   54.217346] PVR_K:   (MKT-13D) 000013EF 00100808 0000081E 00000005
[   54.223907] PVR_K:   (MKT-13E) 00001412 00100808 0000081E 00000006
[   54.231719] PVR_K:   (MKT-13F) 0000147D 00100808 0000081E AD000184
[   54.238311] PVR_K:   (MKT-140) 000014E4 00100C08 0100091D AD000281
[   54.245513] PVR_K:   (MKT-141) 000015E7 00100808 0000091D AD000E02
[   54.252014] PVR_K:   (MKT-142) 00001659 00100808 0000091D AD000282
[   54.259155] PVR_K:   (MKT-143) 00001716 00100808 01000A1F AD00000A
[   54.266418] PVR_K:   (MKT-144) 00001782 00100808 01000A1F AD000905
[   54.273315] PVR_K:   (MKT-145) 0000188E 00100808 00000A1F AD000901
[   54.295745] PVR_K:   (MKT-146) 000018FB 00100808 00000B1E AD000183
[   54.302642] PVR_K:   (MKT-147) 000019E9 00100808 00000B1E AD00030E
[   54.310729] PVR_K:   (MKT-148) 00001A01 00100808 00000B1E 0D800474
[   54.323120] PVR_K:   (MKT-149) 00001A1A 00100808 00000B1E 00000005
[   54.332397] PVR_K:   (MKT-14A) 00001A3E 00100808 00000B1E 00000006
[   54.350463] PVR_K:   (MKT-14B) 00001AA9 00100808 00000B1E AD000184
[   54.356994] PVR_K:   (MKT-14C) 00001B12 00100C08 00000C1D AD000281
[   54.381683] PVR_K:   (MKT-14D) 00001C12 00100808 00000C1D AD000E02
[   54.388244] PVR_K:   (MKT-14E) 00001C86 00100808 00000C1D AD000282
[   54.400787] PVR_K:   (MKT-14F) 00001D3F 00100808 01000D1F AD00000A
[   54.414550] PVR_K:   (MKT-150) 00001DAA 00100808 01000D1F AD000905
[   54.422821] PVR_K:   (MKT-151) 00001EBE 00100808 00000D1F AD000901
[   54.430633] PVR_K:   (MKT-152) 00001F30 00100808 00000E1E AD000183
[   54.437255] PVR_K:   (MKT-153) 0000201D 00100808 00000E1E AD00030E
[   54.443817] PVR_K:   (MKT-154) 00002036 00100808 00000E1E 0D800474
[   54.450439] PVR_K:   (MKT-155) 0000204E 00100808 00000E1E 00000005
[   54.457153] PVR_K:   (MKT-156) 00002071 00100808 00000E1E 00000006
[   54.463897] PVR_K:   (MKT-157) 000020DE 00100808 00000E1E AD000184
[   54.470733] PVR_K:   (MKT-158) 00002145 00100C08 01000F1D AD000281
[   54.477325] PVR_K:   (MKT-159) 00002246 00100808 01000F1D AD000E02
[   54.483886] PVR_K:   (MKT-15A) 000022BB 00100808 01000F1D AD000282
[   54.492004] PVR_K:   (MKT-15B) 00011DD1 00100808 0100121F AD001A00
[   54.498962] PVR_K:   (MKT-15C) 0001227C 00100808 0100131F AD00000A
[   54.505615] PVR_K:   (MKT-15D) 000122DD 00100808 0100131F AD000909
[   54.512298] PVR_K:   (MKT-15E) 00012328 00100808 0100131F AD001A05
[   54.530151] PVR_K:   (MKT-15F) 000123DC 00100808 0100131F AD001A06
[   54.536712] PVR_K:   (MKT-160) 0000046D 00100808 0100031F AD002300
[   54.545135] PVR_K:   (MKT-161) 00000957 00100808 0100041F AD00000A
[   54.551727] PVR_K:   (MKT-162) 000009D7 00100808 0100041F AD000906
[   54.558288] PVR_K:   (MKT-163) 00000AA8 00100808 0000041F AD000901
[   54.564910] PVR_K:   (MKT-164) 00000B22 00100808 0000051E AD000183
[   54.571502] PVR_K:   (MKT-165) 00000CA0 00100808 0000051E AD000302
[   54.578277] PVR_K:   (MKT-166) 00000CFB 00100808 0000051E AD000303
[   54.584991] PVR_K:   (MKT-167) 00000D82 00100808 0000051E AD000C01
[   54.600433] PVR_K:   (MKT-168) 00000DA7 00100808 0000051E 0D800464
[   54.606994] PVR_K:   (MKT-169) 00000DBF 00100808 0000051E 00000007
[   54.619262] PVR_K:   (MKT-16A) 00001010 00100808 0000051E AD00030E
[   54.631195] PVR_K:   (MKT-16B) 00001028 00100808 0000051E 0D800494
[   54.637847] PVR_K:   (MKT-16C) 00001041 00100808 0000051E 00000005
[   54.644592] PVR_K:   (MKT-16D) 00001065 00100808 0000051E 00000006
[   54.651306] PVR_K:   (MKT-16E) 000010DB 00100808 0000051E AD000184
[   54.658081] PVR_K:   (MKT-16F) 00001156 00100C08 0100061D AD000281
[   54.674896] PVR_K:   (MKT-170) 000012E1 00100808 0100061D AD00080A
[   54.683105] PVR_K:   (MKT-171) 000012FA 00100808 0100061D 0F040F00
[   54.689636] PVR_K:   (MKT-172) 00001312 00100808 0100061D 00000061
[   54.696258] PVR_K:   (MKT-173) 00001429 00100C08 0100061D AD001300
[   54.702819] PVR_K:   (MKT-174) 0000155A 00100808 0000061D AD001301
[   54.709442] PVR_K:   (MKT-175) 00001688 00100808 0000061D AD000802
[   54.716217] PVR_K:   (MKT-176) 000017EC 00100808 0000061D AD000803
[   54.722930] PVR_K:   (MKT-177) 00001839 00184AC8 0000061D AD000282
[   54.741058] PVR_K:   (MKT-178) 000037ED 00000808 0100091F AD000200
[   54.747558] PVR_K:   (MKT-179) 00003A28 00000808 0000091F AD000202
[   54.757171] PVR_K:   (MKT-17A) 00003AC0 00000808 00000A1E AD000183
[   54.763702] PVR_K:   (MKT-17B) 00003BC2 00000808 00000A1E AD00030E
[   54.770324] PVR_K:   (MKT-17C) 00003BDA 00000808 00000A1E 0D800494
[   54.776885] PVR_K:   (MKT-17D) 00003BF3 00000808 00000A1E 00000005
[   54.783477] PVR_K:   (MKT-17E) 00003C17 00000808 00000A1E 00000006
[   54.790222] PVR_K:   (MKT-17F) 00003C81 00000808 00000A1E AD000184
[   54.796966] PVR_K:   (MKT-180) 00003CED 00000C08 01000B1D AD000281
[   54.803833] PVR_K:   (MKT-181) 00003E5F 00000808 01000B1D AD00080A
[   54.810424] PVR_K:   (MKT-182) 00003E78 00000808 01000B1D 0F041200
[   54.817047] PVR_K:   (MKT-183) 00003E90 00000808 01000B1D 00000060
[   54.823699] PVR_K:   (MKT-184) 00004144 00000808 00000B1D AD000803
[   54.830657] PVR_K:   (MKT-185) 0000418A 00180CC8 00000B1D AD000282
[   54.837554] PVR_K:   (MKT-186) 0000424E 00000808 01000D1F AD000200
[   54.844543] PVR_K:   (MKT-187) 00004468 00000808 00000D1F AD000202
[   54.851318] PVR_K:   (MKT-188) 000044E8 00000808 00000E1E AD000183
[   54.858337] PVR_K:   (MKT-189) 000045D4 00000808 00000E1E AD00030E
[   54.865203] PVR_K:   (MKT-18A) 000045EC 00000808 00000E1E 0D800494
[   54.872070] PVR_K:   (MKT-18B) 00004605 00000808 00000E1E 00000005
[   54.879364] PVR_K:   (MKT-18C) 00004629 00000808 00000E1E 00000006
[   54.886291] PVR_K:   (MKT-18D) 00004698 00000808 00000E1E AD000184
[   54.893157] PVR_K:   (MKT-18E) 000046FC 00000C08 01000F1D AD000281
[   54.906799] PVR_K:   (MKT-18F) 0000486F 00000808 01000F1D AD00080A
[   54.913360] PVR_K:   (MKT-190) 00004888 00000808 01000F1D 0F041500
[   54.924957] PVR_K:   (MKT-191) 000048A0 00000808 01000F1D 00000060
[   54.931854] PVR_K:   (MKT-192) 00004B54 00000808 00000F1D AD000803
[   54.940551] PVR_K:   (MKT-193) 00004B99 00180CC8 00000F1D AD000282
[   54.959838] PVR_K:   (MKT-194) 00004C8A 00000808 0100111F AD000200
[   54.966339] PVR_K:   (MKT-195) 00004EA4 00000808 0000111F AD000202
[   54.982849] PVR_K:   (MKT-196) 00004F22 00000808 0000121E AD000183
[   54.996215] PVR_K:   (MKT-197) 0000500C 00000808 0000121E AD00030E
[   55.005218] PVR_K:   (MKT-198) 00005024 00000808 0000121E 0D800494
[   55.021148] PVR_K:   (MKT-199) 0000503D 00000808 0000121E 00000005
[   55.027770] PVR_K:   (MKT-19A) 00005062 00000808 0000121E 00000006
[   55.043212] PVR_K:   (MKT-19B) 000050D1 00000808 0000121E AD000184
[   55.051055] PVR_K:   (MKT-19C) 00005134 00000C08 0100131D AD000281
[   55.057647] PVR_K:   (MKT-19D) 000052A8 00000808 0100131D AD00080A
[   55.064208] PVR_K:   (MKT-19E) 000052C0 00000808 0100131D 0F041800
[   55.070831] PVR_K:   (MKT-19F) 000052D9 00000808 0100131D 00000062
[   55.077423] PVR_K:   (MKT-1A0) 00005590 00000808 0000131D AD000803
[   55.083953] PVR_K:   (MKT-1A1) 000055D6 00180C88 0000131D AD000282
[   55.100128] PVR_K:   (MKT-1A2) 000060E2 00000808 0100151F AD000200
[   55.108001] PVR_K:   (MKT-1A3) 000061FB 00000808 0000151F AD001703
[   55.114562] PVR_K:   (MKT-1A4) 000063D2 00000808 0000151F AD000202
[   55.121154] PVR_K:   (MKT-1A5) 00006547 00000808 0100171D AD000183
[   55.127746] PVR_K:   (MKT-1A6) 00006632 00000808 0100171D AD00030E
[   55.134338] PVR_K:   (MKT-1A7) 0000664A 00000808 0100171D 0D800494
[   55.141082] PVR_K:   (MKT-1A8) 00006663 00000808 0100171D 00000005
[   55.147857] PVR_K:   (MKT-1A9) 00006687 00000808 0100171D 00000006
[   55.154846] PVR_K:   (MKT-1AA) 00006715 00000808 0100171D AD000184
[   55.161437] PVR_K:   (MKT-1AB) 00017B76 00000808 01001A1F AD001A00
[   55.168029] PVR_K:   (MKT-1AC) 0002E415 00000808 01001E1F AD00000A
[   55.174682] PVR_K:   (MKT-1AD) 0002E47D 00000808 01001E1F AD000909
[   55.181610] PVR_K:   (MKT-1AE) 0002E4C8 00000808 01001E1F AD001A05
[   55.188507] PVR_K:   (MKT-1AF) 0002E4F9 00000808 01001E1F AD001302
[   55.195159] PVR_K:   (MKT-1B0) 0002E539 00000808 01001E1F AD001303
[   55.201873] PVR_K:   (MKT-1B1) 0002E5D0 00000808 01001E1F AD000D04
[   55.208618] PVR_K:   (MKT-1B2) 0002E698 00000808 01001E1F AD000D05
[   55.215545] PVR_K:   (MKT-1B3) 0002E70B 00000808 01001E1F AD001A06
[   55.222381] PVR_K:   (MKT-1B4) 000004E9 00100808 0100031F AD002300
[   55.229064] PVR_K:   (MKT-1B5) 000009EC 00100808 0100041F AD00000A
[   55.235656] PVR_K:   (MKT-1B6) 00000A5F 00100808 0100041F AD000905
[   55.242248] PVR_K:   (MKT-1B7) 00000B98 00100808 0000041F AD000901
[   55.249450] PVR_K:   (MKT-1B8) 00000C14 00100808 0000051E AD000183
[   55.256103] PVR_K:   (MKT-1B9) 00000D23 00100808 0000051E AD00030E
[   55.263000] PVR_K:   (MKT-1BA) 00000D3C 00100808 0000051E 0D800494
[   55.269958] PVR_K:   (MKT-1BB) 00000D56 00100808 0000051E 00000005
[   55.278686] PVR_K:   (MKT-1BC) 00000D7B 00100808 0000051E 00000006
[   55.291351] PVR_K:   (MKT-1BD) 00000DE8 00100808 0000051E AD000184
[   55.301818] PVR_K:   (MKT-1BE) 00000E67 00100C08 0100061D AD000281
[   55.314971] PVR_K:   (MKT-1BF) 00000F96 00100808 0000061D AD000E02
[   55.321716] PVR_K:   (MKT-1C0) 00001008 00100808 0000061D AD000282
[   55.328491] PVR_K:   (MKT-1C1) 000010C1 00100808 0100071F AD00000A
[   55.335021] PVR_K:   (MKT-1C2) 0000112C 00100808 0100071F AD000905
[   55.341552] PVR_K:   (MKT-1C3) 00001237 00100808 0000071F AD000901
[   55.351593] PVR_K:   (MKT-1C4) 000012A0 00100808 0000081E AD000183
[   55.360198] PVR_K:   (MKT-1C5) 00001391 00100808 0000081E AD00030E
[   55.366790] PVR_K:   (MKT-1C6) 000013AD 00100808 0000081E 0D800494
[   55.373809] PVR_K:   (MKT-1C7) 000013C6 00100808 0000081E 00000005
[   55.389495] PVR_K:   (MKT-1C8) 000013E9 00100808 0000081E 00000006
[   55.395996] PVR_K:   (MKT-1C9) 00001457 00100808 0000081E AD000184
[   55.424682] PVR_K:   (MKT-1CA) 000014C2 00100C08 0000091D AD000281
[   55.438690] PVR_K:   (MKT-1CB) 000015C5 00100808 0000091D AD000E02
[   55.446777] PVR_K:   (MKT-1CC) 00001638 00100808 0000091D AD000282
[   55.467620] PVR_K:   (MKT-1CD) 000016EA 00100808 01000A1F AD00000A
[   55.474182] PVR_K:   (MKT-1CE) 00001754 00100808 00000A1F AD000905
[   55.498870] PVR_K:   (MKT-1CF) 00001866 00100808 00000A1F AD000901
[   55.505371] PVR_K:   (MKT-1D0) 000018C9 00100808 00000B1E AD00000A
[   55.515106] PVR_K:   (MKT-1D1) 00001929 00100808 00000B1E AD000905
[   55.530181] PVR_K:   (MKT-1D2) 000019CF 00100808 00000B1E AD000901
[   55.536743] PVR_K:   (MKT-1D3) 00001A3A 00100808 00000C1D AD000183
[   55.543273] PVR_K:   (MKT-1D4) 00001B2A 00100808 00000C1D AD00030E
[   55.549804] PVR_K:   (MKT-1D5) 00001B44 00100808 00000C1D 0D800494
[   55.556304] PVR_K:   (MKT-1D6) 00001B5D 00100808 00000C1D 00000005
[   55.562927] PVR_K:   (MKT-1D7) 00001B80 00100808 00000C1D 00000006
[   55.569458] PVR_K:   (MKT-1D8) 00001BEB 00100808 00000C1D AD000184
[   55.582061] PVR_K:   (MKT-1D9) 00001C54 00100C08 01000D1C AD000281
[   55.588653] PVR_K:   (MKT-1DA) 00001D52 00100808 01000D1C AD000E02
[   55.595245] PVR_K:   (MKT-1DB) 00001DCB 00100808 01000D1C AD000282
[   55.602020] PVR_K:   (MKT-1DC) 00011E31 00100808 0100101F AD001A00
[   55.608734] PVR_K:   (MKT-1DD) 0002AB97 00100808 0100151F AD00000A
[   55.615631] PVR_K:   (MKT-1DE) 0002ABF8 00100808 0100151F AD000909
[   55.622192] PVR_K:   (MKT-1DF) 0002AC42 00100808 0100151F AD001A05
[   55.628814] PVR_K:   (MKT-1E0) 0002ACF6 00100808 0100151F AD001A06
[   55.635467] PVR_K:   (MKT-1E1) 000004C9 00100808 0100031F AD002300
[   55.642425] PVR_K:   (MKT-1E2) 000009C1 00100808 0100041F AD00000A
[   55.649322] PVR_K:   (MKT-1E3) 00000A3D 00100808 0100041F AD000906
[   55.656188] PVR_K:   (MKT-1E4) 00000B0D 00100808 0000041F AD000901
[   55.662841] PVR_K:   (MKT-1E5) 00000B85 00100808 0000051E AD000183
[   55.670043] PVR_K:   (MKT-1E6) 00000CFD 00100808 0000051E AD000302
[   55.676757] PVR_K:   (MKT-1E7) 00000E84 00100808 0000051E AD000D06
[   55.683502] PVR_K:   (MKT-1E8) 00000F6D 00100808 0000051E AD000D07
[   55.699157] PVR_K:   (MKT-1E9) 00000FB6 00100808 0000051E AD001304
[   55.705780] PVR_K:   (MKT-1EA) 000010A9 00100808 0000051E AD001305
[   55.716217] PVR_K:   (MKT-1EB) 000011BD 00100888 0000051E AD000404
[   55.729278] PVR_K:   (MKT-1EC) 00001284 00100808 0000051E AD000402
[   55.740631] PVR_K:   (MKT-1ED) 000012CD 0010082B 0000051E AD000184
[   55.756713] PVR_K:   (MKT-1EE) 00001353 00108DA9 0000061D AD000281
[   55.763244] PVR_K:   (MKT-1EF) 000014E5 001089AB 0000061D AD000E02
[   55.789764] PVR_K:   (MKT-1F0) 00001543 0010892B 0000061D AD000282
[   55.798217] PVR_K:   (MKT-1F1) 00003AE1 00100808 0000081F AD000101
[   55.804779] PVR_K:   (MKT-1F2) 00003B56 00100808 0000081F AD000104
[   55.811401] PVR_K:   (MKT-1F3) 00003B94 00100808 0100091E AD000100
[   55.817962] PVR_K:   (MKT-1F4) 00003C99 00100808 0100091E AD000501
[   55.824707] PVR_K:   (MKT-1F5) 00003CD8 0010082B 0100091E AD000104
[   55.831481] PVR_K:   (MKT-1F6) 00005F33 00100828 01000A1F AD000101
[   55.838531] PVR_K:   (MKT-1F7) 00005F89 00100828 01000A1F AD000104
[   55.845153] PVR_K:   (MKT-1F8) 00006096 00100808 01000B1F AD000100
[   55.853027] PVR_K:   (MKT-1F9) 00006150 00100808 01000B1F AD000501
[   55.859954] PVR_K:   (MKT-1FA) 0000617C 00100829 01000B1F AD000104
[   55.866607] PVR_K:   (MKT-1FB) 00008710 00100828 01000D1F AD000101
[   55.873291] PVR_K:   (MKT-1FC) 00008789 00100828 01000D1F AD000104
[   55.879821] PVR_K:   (MKT-1FD) 000087C6 00100808 01000E1E AD000100
[   55.886383] PVR_K:   (MKT-1FE) 000088C1 00100808 01000E1E AD000501
[   55.895019] PVR_K:   (MKT-1FF) 000088FF 00100829 01000E1E AD000104
[   55.908050] PVR_K: SGX Kernel CCB WO:0x60 RO:0x60
[   55.917022] adc_to_temp_conversion:Temp read is invalid 0
[   55.923095] thermal_lookup_temp: getting temp is not supported for domain pcb
[   55.943176] adc_to_temp_conversion:Temp read is invalid 0
[   55.949066] thermal_lookup_temp: getting temp is not supported for domain pcb
[   55.957611] adc_to_temp_conversion:Temp read is invalid 0
[   55.963378] thermal_lookup_temp: getting temp is not supported for domain pcb
[   56.116149] PVR_K:(Error): SGXOSTimer() detected SGX lockup (0xe tasks) [0, ]
[   56.123931] PVR_K: HWRecoveryResetSGX: SGX Hardware Recovery triggered
[   56.132751] [   28.901]    [c6e89d40] --refs=1 on RELEASED
[   56.132751] [   28.901]                           [c6e64400] dsscomp_apply
[   56.132781] [   28.901]   [c6edb920] --refs=0 on RELEASED
[   56.132781] [   28.901]   [c6edb920] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   56.132781] [   28.901]                         [c6f11400] dsscomp_mgr_delayed_cb on RELEASED
[   56.165344] [   28.901]                           [c6e64400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   56.165344] [   28.902] [c6e89d60] new in dsscomp_gralloc_queue (refs=1)
[   56.165374] [   28.902]                      [c6e64800] dsscomp_new
[   56.165374] [   28.902] [c6e89d60] ++refs=2 for [c6e64800]
[   56.195800] [   28.902]                      [c6e64800] dsscomp_delayed_apply
[   56.195800] [   28.902] [c6e89d60] --refs=1 on RELEASED
[   56.195800] [   28.902]                      [c6e64800] dsscomp_apply
[   56.195800] [   28.925]                           [c6e64400] dsscomp_mgr_delayed_cb on DISPLAYED
[   56.225524] [   28.925]    [c6e89d40] --refs=0 on RELEASED
[   56.225524] [   28.925]    [c6e89d40] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   56.225524] [   28.925]                           [c6e64400] dsscomp_mgr_delayed_cb on RELEASED
[   56.225555] [   28.925]                      [c6e64800] dsscomp_mgr_delayed_cb on PROGRAMMED
[   56.255310] [   28.942]                      [c6e64800] dsscomp_mgr_delayed_cb on DISPLAYED
[   56.255310] [   33.971]  [c6e89da0] new in dsscomp_gralloc_queue (refs=1)
[   56.255310] [   33.971]                        [c6e64c00] dsscomp_new
[   56.283508] [   33.971]  [c6e89da0] ++refs=2 for [c6e64c00]
[   56.283538] [   33.971]                        [c6e64c00] dsscomp_delayed_apply
[   56.283538] [   33.971]  [c6e89da0] --refs=1 on RELEASED
[   56.283538] [   33.971]                        [c6e64c00] dsscomp_apply
[   56.283538] [   33.971] [c6e89d60] --refs=0 on RELEASED
[   56.314819] [   33.971] [c6e89d60] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   56.314819] [   33.971]                      [c6e64800] dsscomp_mgr_delayed_cb on RELEASED
[   56.314819] [   33.971]                        [c6e64c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   56.314849] [   33.972]      [c6edb820] new in dsscomp_gralloc_queue (refs=1)
[   56.344543] [   33.972]                      [c6f10000] dsscomp_new
[   56.344543] [   33.972]      [c6edb820] ++refs=2 for [c6f10000]
[   56.344543] [   33.972]                      [c6f10000] dsscomp_delayed_apply
[   56.344543] [   33.972]      [c6edb820] --refs=1 on RELEASED
[   56.374298] [   33.972]                      [c6f10000] dsscomp_apply
[   56.374298] [   33.993]                        [c6e64c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   56.374328] [   33.993]  [c6e89da0] --refs=0 on RELEASED
[   56.374328] [   33.993]  [c6e89da0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   56.404022] [   34.001]                        [c6e64c00] dsscomp_mgr_delayed_cb on RELEASED
[   56.404052] [   34.001]                      [c6f10000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   56.404052] [   34.008]                      [c6f10000] dsscomp_mgr_delayed_cb on DISPLAYED
[   56.432312] [   39.512]   [c6edba00] new in dsscomp_gralloc_queue (refs=1)
[   56.432312] [   39.512]                        [c6f12000] dsscomp_new
[   56.432312] [   39.512]   [c6edba00] ++refs=2 for [c6f12000]
[   56.432312] [   39.512]                        [c6f12000] dsscomp_delayed_apply
[   56.432312] [   39.512]   [c6edba00] --refs=1 on RELEASED
[   56.463531] [   39.512]                        [c6f12000] dsscomp_apply
[   56.463531] [   39.512]      [c6edb820] --refs=0 on RELEASED
[   56.463562] [   39.512]      [c6edb820] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   56.463562] [   39.512]                      [c6f10000] dsscomp_mgr_delayed_cb on RELEASED
[   56.493286] [   39.512]                        [c6f12000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   56.493316] [   39.513]      [c6edb820] new in dsscomp_gralloc_queue (refs=1)
[   56.493316] [   39.513]                      [c6f10000] dsscomp_new
[   56.493316] [   39.513]      [c6edb820] ++refs=2 for [c6f10000]
[   56.523040] [   39.513]                      [c6f10000] dsscomp_delayed_apply
[   56.523040] [   39.513]      [c6edb820] --refs=1 on RELEASED
[   56.523040] [   39.513]                      [c6f10000] dsscomp_apply
[   56.523040] [   39.527]                        [c6f12000] dsscomp_mgr_delayed_cb on DISPLAYED
[   56.552825] [   39.527]   [c6edba00] --refs=0 on RELEASED
[   56.552825] [   39.527]   [c6edba00] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   56.552825] [   39.527]                        [c6f12000] dsscomp_mgr_delayed_cb on RELEASED
[   56.552856] [   39.527]                      [c6f10000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   56.582550] [   39.550]                      [c6f10000] dsscomp_mgr_delayed_cb on DISPLAYED
[   56.582580] [   44.408]    [c6edb7a0] new in dsscomp_gralloc_queue (refs=1)
[   56.582580] [   44.408]                        [c6f12000] dsscomp_new
[   56.610778] [   44.408]    [c6edb7a0] ++refs=2 for [c6f12000]
[   56.610778] [   44.408]                        [c6f12000] dsscomp_delayed_apply
[   56.610778] [   44.408]    [c6edb7a0] --refs=1 on RELEASED
[   56.610778] [   44.408]                        [c6f12000] dsscomp_apply
[   56.610809] [   44.408]      [c6edb820] --refs=0 on RELEASED
[   56.642120] [   44.408]      [c6edb820] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   56.642120] [   44.408]                      [c6f10000] dsscomp_mgr_delayed_cb on RELEASED
[   56.642120] [   44.409]                        [c6f12000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   56.670471] [   44.409]      [c6edb820] new in dsscomp_gralloc_queue (refs=1)
[   56.670501] [   44.409]                      [c6f10000] dsscomp_new
[   56.670501] [   44.409]      [c6edb820] ++refs=2 for [c6f10000]
[   56.670501] [   44.409]                      [c6f10000] dsscomp_delayed_apply
[   56.670501] [   44.409]      [c6edb820] --refs=1 on RELEASED
[   56.701965] [   44.409]                      [c6f10000] dsscomp_apply
[   56.701965] [   44.425]                        [c6f12000] dsscomp_mgr_delayed_cb on DISPLAYED
[   56.701995] [   44.430]    [c6edb7a0] --refs=0 on RELEASED
[   56.701995] [   44.430]    [c6edb7a0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   56.741088] [   44.430]                        [c6f12000] dsscomp_mgr_delayed_cb on RELEASED
[   56.741088] [   44.430]                      [c6f10000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   56.741088] [   44.464]                      [c6f10000] dsscomp_mgr_delayed_cb on DISPLAYED
[   56.776428] [   49.508]   [c6edba00] new in dsscomp_gralloc_queue (refs=1)
[   56.776428] [   49.508]                     [c6f10c00] dsscomp_new
[   56.776458] [   49.508]   [c6edba00] ++refs=2 for [c6f10c00]
[   56.776458] [   49.508]                     [c6f10c00] dsscomp_delayed_apply
[   56.807403] [   49.508]   [c6edba00] --refs=1 on RELEASED
[   56.807434] [   49.508]                     [c6f10c00] dsscomp_apply
[   56.807434] [   49.514]      [c6edb820] --refs=0 on RELEASED
[   56.807434] [   49.514]      [c6edb820] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   56.807434] [   49.514]                      [c6f10000] dsscomp_mgr_delayed_cb on RELEASED
[   56.844482] [   49.514]                     [c6f10c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   56.844512] [   49.522]    [c6edb880] new in dsscomp_gralloc_queue (refs=1)
[   56.844512] [   49.522]                      [c6f10000] dsscomp_new
[   56.881713] [   49.522]    [c6edb880] ++refs=2 for [c6f10000]
[   56.881713] [   49.522]                      [c6f10000] dsscomp_delayed_apply
[   56.881713] [   49.522]    [c6edb880] --refs=1 on RELEASED
[   56.881713] [   49.522]                      [c6f10000] dsscomp_apply
[   56.881713] [   49.543]                     [c6f10c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   56.922821] [   49.543]   [c6edba00] --refs=0 on RELEASED
[   56.922821] [   49.543]   [c6edba00] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   56.922821] [   49.543]                     [c6f10c00] dsscomp_mgr_delayed_cb on RELEASED
[   56.922821] [   49.543]                      [c6f10000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   56.952728] [   49.557]                      [c6f10000] dsscomp_mgr_delayed_cb on DISPLAYED
[   56.952728] [   55.906]  [c6fa40a0] new in dsscomp_gralloc_queue (refs=1)
[   56.952728] [   55.906]                          [c6e66c00] ds
[   56.982177] adc_to_temp_conversion:Temp read is invalid 0
[   56.991088] scomp_new
[   56.991088] [   55.906]  [c6fa40a0] ++refs=2 for [c6e66c00]
[   56.991088] [   55.906]                          [c6e66c00] dsscomp_delayed_apply
[   56.991088] [   55.906]  [c6fa40a0] --refs=1 on RELEASED
[   56.991088] [   55.906]                          [c6e66c00] dsscomp_apply
[   56.991088] [   55.907]    [c6edb
[   56.998870] thermal_lookup_temp: getting temp is not supported for domain pcb
[   56.999755] adc_to_temp_conversion:Temp read is invalid 0
[   56.999755] thermal_lookup_temp: getting temp is not supported for domain pcb
[   57.000579] adc_to_temp_conversion:Temp read is invalid 0
[   57.000610] thermal_lookup_temp: getting temp is not supported for domain pcb
[   57.067840] 880] --refs=0 on RELEASED
[   57.067840] [   55.907]    [c6edb880] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   57.067871] [   55.907]                      [c6f10000] dsscomp_mgr_delayed_cb on RELEASED
[   57.067871] [   55.907]                          [c6e66c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   57.103302] [   55.908]     [c6fa4160] new in dsscomp_gralloc_queue (refs=1)
[   57.103302] [   55.908]                         [c6e67800] dsscomp_new
[   57.103302] [   55.908]     [c6fa4160] ++refs=2 for [c6e67800]
[   57.103302] [   55.908]                         [c6e67800] dsscomp_delayed_apply
[   57.103302] [   55.908]     [c6fa4160] --refs=1 on RELEASED
[   57.134704] [   55.908]                         [c6e67800] dsscomp_apply
[   57.134704] [   55.924]                          [c6e66c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   57.134704] [   55.924]  [c6fa40a0] --refs=0 on RELEASED
[   57.134704] [   55.924]  [c6fa40a0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   57.170776] [   55.924]                          [c6e66c00] dsscomp_mgr_delayed_cb on RELEASED
[   57.170776] [   55.924]                         [c6e67800] dsscomp_mgr_delayed_cb on PROGRAMMED
[   57.170776] [   55.942]                         [c6e67800] dsscomp_mgr_delayed_cb on DISPLAYED
[   57.212371] ACTIVE COMPOSITIONS on lcd
[   57.212371]
[   57.212371]   [c6e67800]: DISPLAYED
[   57.212371]     sync_id=0, flags=AD-
[   57.212402]     ovl0={ON z0 ARGB32-8888 premult *100% 864*480:0,0+864,480 rot0 => 0,0+864,480 7f358000/  (null)|3456}
[   57.212402]     gsync=[c6fa4160] dsscomp_gralloc_cb
[   57.251098]
[   57.251098]   DISPC pipeline:
[   57.251098]
[   57.251098]     info:        clean (none)
[   57.251098]     cache:       clean (none)
[   57.251098]     shadow:  ACT clean (none)
[   57.251129]     dispc:   DISPLAYED mask=---R [c6e67800] dsscomp_mgr_callback
[   57.251129]
[   57.251129] ACTIVE COMPOSITIONS on tv
[   57.251129]
[   57.251129]   DISPC pipeline:
[   57.251129]
[   57.251129]     info:        clean (none)
[   57.294799]     cache:       clean (none)
[   57.294830]     shadow:  off clean (none)
[   57.294830]     dispc:   DISPLAYED (none)
[   57.294830]
[   57.294830] ACTIVE COMPOSITIONS on lcd2
[   57.294830]
[   57.294830]   DISPC pipeline:
[   57.294830]
[   57.294830]     info:        clean (none)
[   57.294830]     cache:       clean (none)
[   57.294830]     dispc:             (none)
[   57.336883]
[   57.336883] ACTIVE GRALLOC FLIPS
[   57.336883]
[   57.336883]   [c6fa4160] (refs=1)
[   57.336883]     slots=[7f358000]
[   57.336883]     cmdcb=[c73f6900] dsscomp_proxy_cmdcomplete
[   57.336883]
[   57.336883]   |           lcd
[   57.336883]   | [c6e67800] DISPL'D
[   57.336914]   |     55.908  ACTIVE
[   57.336914]   |     55.908 APPLY'N
[   57.336914]   |     55.908 APPLIED
[   57.336914]   |     55.924 PROGR'D
[   57.389526]   |     55.942 DISPL'D
[   57.389526]
[   57.389526]
[   57.397186] PVR_K: SGX debug (blaze_android_sgx_ogles1_ogles2_GPL sgxddk 18 1.8@869593)
[   57.415557] PVR_K:(Error): SGX Register Base Address (Linear):   0xC8B20000 [0, ]
[   57.429138] PVR_K:(Error): SGX Register Base Address (Physical): 0x56000000 [0, ]
[   57.437133] PVR_K: (P0) EUR_CR_CORE_ID:          01140000
[   57.442932] PVR_K: (P0) EUR_CR_CORE_REVISION:    00010200
[   57.448730] PVR_K: (P0) EUR_CR_EVENT_STATUS:     20000000
[   57.454589] PVR_K: (P0) EUR_CR_EVENT_STATUS2:    00000008
[   57.467651] PVR_K: (P0) EUR_CR_BIF_CTRL:         00000000
[   57.473480] PVR_K: (P0) EUR_CR_BIF_INT_STAT:     00008000
[   57.490722] PVR_K: (P0) EUR_CR_BIF_FAULT:        00000000
[   57.501953] PVR_K: (P0) EUR_CR_BIF_MEM_REQ_STAT: 00000000
[   57.507812] PVR_K: (P0) EUR_CR_CLKGATECTL:       000AAA6A
[   57.513610] PVR_K: (P0) EUR_CR_PDS_PC_BASE:      000012B0
[   57.519378] PVR_K: Flip Command Complete Data 0 for display device 1:
[   57.526306] PVR_K:   SRC 0: (Not in use)
[   57.530456] PVR_K: Flip Command Complete Data 1 for display device 1:
[   57.537322] PVR_K:   SRC 0: ROC DevVAddr:0xD800474 ROP:0x9 ROC:0x7, WOC DevVAddr:0xD800464 WOP:0x9 WOC:0x8
[   57.547576] PVR_K: SGX Host control:
[   57.551422] PVR_K:   (HC-0) 0x00000001 0x00000000 0x00000000 0x00000001
[   57.558410] PVR_K:   (HC-10) 0x00000009 0x0000000A 0x0005DC00 0x00000003
[   57.565521] PVR_K:   (HC-20) 0x00000000 0x00000001 0x00000000 0x0000000D
[   57.572570] PVR_K:   (HC-30) 0x00000E03 0xF173E6D8 0x00000000 0x00000000
[   57.579681] PVR_K:   (HC-40) 0x00000000 0x087BF500 0x087C6300 0x087C3100
[   57.586761] PVR_K: SGX TA/3D control:
[   57.590698] PVR_K:   (T3C-0) 0x0F003000 0x0F003120 0x0F002000 0x00000000
[   57.597747] PVR_K:   (T3C-10) 0x00000001 0x00000002 0x00000001 0x0F00DD00
[   57.604919] PVR_K:   (T3C-20) 0x00000000 0x00000000 0x00000000 0x00000000
[   57.612091] PVR_K:   (T3C-30) 0x00000000 0x00000000 0x00000000 0x00000000
[   57.619262] PVR_K:   (T3C-40) 0x00000000 0x00000000 0x00000000 0x00000000
[   57.626434] PVR_K:   (T3C-50) 0x0F00DD00 0x00000000 0x00000000 0x0F00DD00
[   57.633575] PVR_K:   (T3C-60) 0x00000000 0x00000000 0x0F00DD00 0x00000000
[   57.640747] PVR_K:   (T3C-70) 0x00000000 0x0F00DD00 0x00000000 0x0F004000
[   57.647949] PVR_K:   (T3C-80) 0x000000D3 0x0001120F 0x00000000 0x0F00DEB8
[   57.655090] PVR_K:   (T3C-90) 0x00000000 0x0F000000 0xAB600000 0x0F043000
[   57.662292] PVR_K:   (T3C-A0) 0x00000000 0x0F010760 0x0F00DD00 0x0F00DEB8
[   57.669433] PVR_K:   (T3C-B0) 0x0F0109A0 0x00000000 0x00000000 0x00000000
[   57.676635] PVR_K:   (T3C-C0) 0x00000000 0x00000000 0x00000000 0x00000000
[   57.683807] PVR_K:   (T3C-D0) 0x00000000 0x00000010 0x0000000F 0x0F007000
[   57.690979] PVR_K:   (T3C-E0) 0x0F00D420 0x0F00E000 0x0F010720 0x0F010720
[   57.698150] PVR_K:   (T3C-F0) 0x00000000 0x000000B5 0x000000B5 0x00000000
[   57.705352] PVR_K:   (T3C-100) 0x00000003 0x00000000 0x00000000 0x00000000
[   57.712615] PVR_K:   (T3C-110) 0xB50C565C 0x0872E100 0x08787B00 0x08787B00
[   57.719909] PVR_K: Last SGX microkernel status code: AD000104
[   57.726043] PVR_K:   (MKT-0) 046061D8 00100808 0100031F AD000B00
[   57.732391] PVR_K:   (MKT-1) 04606220 00100808 0100031F AD000B03
[   57.738739] PVR_K:   (MKT-2) 046062A6 00100808 0100031F AD000B05
[   57.745086] PVR_K:   (MKT-3) 046062FB 00100808 0100031F AD000B06
[   57.751464] PVR_K:   (MKT-4) 0460632B 00100808 0100031F AD000B06
[   57.757843] PVR_K:   (MKT-5) 0460636E 00100808 0100031F AD000B07
[   57.772338] PVR_K:   (MKT-6) 04606393 00100808 0100031F AD000B09
[   57.778717] PVR_K:   (MKT-7) 046063E8 00100808 0100031F AD000B01
[   57.794769] PVR_K:   (MKT-8) 04606424 00100808 0100031F AD002300
[   57.802551] PVR_K:   (MKT-9) 04606742 00100808 0100041F AD00000A
[   57.814483] PVR_K:   (MKT-A) 046067C3 00100808 0100041F AD000906
[   57.820892] PVR_K:   (MKT-B) 04606881 00100808 0000041F AD000901
[   57.827209] PVR_K:   (MKT-C) 046068FB 00100808 0000051E AD000183
[   57.833618] PVR_K:   (MKT-D) 04606A69 00100808 0000051E AD000302
[   57.839996] PVR_K:   (MKT-E) 04606AC6 00100808 0000051E AD000303
[   57.846405] PVR_K:   (MKT-F) 04606B4E 00100808 0000051E AD000C01
[   57.858306] PVR_K:   (MKT-10) 04606B72 00100808 0000051E 0D800484
[   57.864776] PVR_K:   (MKT-11) 04606B8A 00100808 0000051E 00000006
[   57.886718] PVR_K:   (MKT-12) 04606DD4 00100808 0000051E AD00030E
[   57.893737] PVR_K:   (MKT-13) 04606DEC 00100808 0000051E 0D800474
[   57.905822] PVR_K:   (MKT-14) 04606E05 00100808 0000051E 00000005
[   57.912231] PVR_K:   (MKT-15) 04606E28 00100808 0000051E 00000006
[   57.918701] PVR_K:   (MKT-16) 04606EA0 00100808 0000051E AD000184
[   57.925109] PVR_K:   (MKT-17) 04606F1A 00100C08 0100061D AD000281
[   57.931610] PVR_K:   (MKT-18) 046070A9 00100808 0100061D AD00080A
[   57.944213] PVR_K:   (MKT-19) 046070C2 00100808 0100061D 0F040300
[   57.950683] PVR_K:   (MKT-1A) 046070DA 00100808 0100061D 00000061
[   57.972198] PVR_K:   (MKT-1B) 046071EE 00100C88 0100061D AD001300
[   57.980377] PVR_K:   (MKT-1C) 0460C371 00100808 0000061D AD001301
[   57.986846] PVR_K:   (MKT-1D) 0460C49A 00100808 0000061D AD000802
[   57.997772] PVR_K:   (MKT-1E) 0460C5FC 00100808 0000061D AD000803
[   57.999786] adc_to_temp_conversion:Temp read is invalid 0
[   57.999786] thermal_lookup_temp: getting temp is not supported for domain pcb
[   58.000640] adc_to_temp_conversion:Temp read is invalid 0
[   58.000640] thermal_lookup_temp: getting temp is not supported for domain pcb
[   58.001495] adc_to_temp_conversion:Temp read is invalid 0
[   58.001495] thermal_lookup_temp: getting temp is not supported for domain pcb
[   58.053588] PVR_K:   (MKT-1F) 0460C649 00184AC8 0000061D AD000282
[   58.059997] PVR_K:   (MKT-20) 0460E5D0 00000C08 01000A1F AD000200
[   58.066497] PVR_K:   (MKT-21) 0460E830 00000808 00000A1F AD000202
[   58.072937] PVR_K:   (MKT-22) 0460E8C9 00000808 00000B1E AD000183
[   58.079376] PVR_K:   (MKT-23) 0460E9C9 00000808 00000B1E AD00030E
[   58.085784] PVR_K:   (MKT-24) 0460E9E1 00000808 00000B1E 0D800474
[   58.092254] PVR_K:   (MKT-25) 0460E9FA 00000808 00000B1E 00000005
[   58.098693] PVR_K:   (MKT-26) 0460EA1D 00000808 00000B1E 00000006
[   58.105163] PVR_K:   (MKT-27) 0460EA88 00000808 00000B1E AD000184
[   58.111633] PVR_K:   (MKT-28) 0460EAF5 00000C08 01000C1D AD000281
[   58.118041] PVR_K:   (MKT-29) 0460EC5D 00000808 01000C1D AD00080A
[   58.124511] PVR_K:   (MKT-2A) 0460EC76 00000808 01000C1D 0F040600
[   58.130920] PVR_K:   (MKT-2B) 0460EC8E 00000808 01000C1D 00000060
[   58.137390] PVR_K:   (MKT-2C) 0460EF42 00000808 00000C1D AD000803
[   58.143829] PVR_K:   (MKT-2D) 0460EF88 00180CC8 00000C1D AD000282
[   58.150299] PVR_K:   (MKT-2E) 0460F047 00000808 01000E1F AD000200
[   58.156707] PVR_K:   (MKT-2F) 0460F25C 00000808 00000E1F AD000202
[   58.163208] PVR_K:   (MKT-30) 0460F2DD 00000808 00000F1E AD000183
[   58.169616] PVR_K:   (MKT-31) 0460F3C5 00000808 00000F1E AD00030E
[   58.176086] PVR_K:   (MKT-32) 0460F3DE 00000808 00000F1E 0D800474
[   58.182495] PVR_K:   (MKT-33) 0460F3F6 00000808 00000F1E 00000005
[   58.188934] PVR_K:   (MKT-34) 0460F41A 00000808 00000F1E 00000006
[   58.195373] PVR_K:   (MKT-35) 0460F483 00000808 00000F1E AD000184
[   58.201812] PVR_K:   (MKT-36) 0460F4E8 00000C08 0100101D AD000281
[   58.208343] PVR_K:   (MKT-37) 0460F657 00000808 0100101D AD00080A
[   58.214782] PVR_K:   (MKT-38) 0460F66F 00000808 0100101D 0F040900
[   58.221252] PVR_K:   (MKT-39) 0460F688 00000808 0100101D 00000060
[   58.227691] PVR_K:   (MKT-3A) 0460F940 00000808 0000101D AD000803
[   58.234191] PVR_K:   (MKT-3B) 0460F986 00180CC8 0000101D AD000282
[   58.240600] PVR_K:   (MKT-3C) 0460FA6C 00000808 0100121F AD000200
[   58.247070] PVR_K:   (MKT-3D) 0460FC83 00000808 0000121F AD000202
[   58.253479] PVR_K:   (MKT-3E) 0460FD01 00000808 0000131E AD000183
[   58.259948] PVR_K:   (MKT-3F) 0460FDEE 00000808 0000131E AD00030E
[   58.266387] PVR_K:   (MKT-40) 0460FE06 00000808 0000131E 0D800474
[   58.272857] PVR_K:   (MKT-41) 0460FE1F 00000808 0000131E 00000005
[   58.279235] PVR_K:   (MKT-42) 0460FE43 00000808 0000131E 00000006
[   58.285705] PVR_K:   (MKT-43) 0460FEAF 00000808 0000131E AD000184
[   58.292144] PVR_K:   (MKT-44) 0460FF13 00000C08 0100141D AD000281
[   58.298614] PVR_K:   (MKT-45) 04610081 00000808 0100141D AD00080A
[   58.305053] PVR_K:   (MKT-46) 0461009A 00000808 0100141D 0F040C00
[   58.311523] PVR_K:   (MKT-47) 046100B2 00000808 0100141D 00000062
[   58.317993] PVR_K:   (MKT-48) 04610366 00000808 0000141D AD000803
[   58.324432] PVR_K:   (MKT-49) 046103AC 00180C88 0000141D AD000282
[   58.330963] PVR_K:   (MKT-4A) 04610E9F 00000808 0100161F AD000200
[   58.337371] PVR_K:   (MKT-4B) 04610FBC 00000808 0100161F AD001703
[   58.343841] PVR_K:   (MKT-4C) 04611190 00000808 0000161F AD000202
[   58.350250] PVR_K:   (MKT-4D) 0461120C 00000808 0100171E AD000183
[   58.356689] PVR_K:   (MKT-4E) 046112F6 00000808 0100171E AD00030E
[   58.363128] PVR_K:   (MKT-4F) 0461130F 00000808 0100171E 0D800474
[   58.369598] PVR_K:   (MKT-50) 04611327 00000808 0100171E 00000005
[   58.376007] PVR_K:   (MKT-51) 0461134A 00000808 0100171E 00000006
[   58.382476] PVR_K:   (MKT-52) 046113D7 00000808 0100171E AD000184
[   58.388885] PVR_K:   (MKT-53) 0461DB54 00000808 01001A1F AD001A00
[   58.395355] PVR_K:   (MKT-54) 07437565 00000808 0107F91F AD00000A
[   58.401794] PVR_K:   (MKT-55) 074375CF 00000808 0107F91F AD000909
[   58.408264] PVR_K:   (MKT-56) 07437619 00000808 0107F91F AD001A05
[   58.414703] PVR_K:   (MKT-57) 07437649 00000808 0107F91F AD001302
[   58.421112] PVR_K:   (MKT-58) 07437689 00000808 0107F91F AD001303
[   58.427581] PVR_K:   (MKT-59) 07437720 00000808 0107F91F AD000D04
[   58.434020] PVR_K:   (MKT-5A) 074377EB 00000808 0107F91F AD000D05
[   58.440551] PVR_K:   (MKT-5B) 0743785A 00000808 0107F91F AD001A06
[   58.446960] PVR_K:   (MKT-5C) 00000487 00100808 0100031F AD002300
[   58.453460] PVR_K:   (MKT-5D) 0000097D 00100808 0100041F AD00000A
[   58.459869] PVR_K:   (MKT-5E) 000009F1 00100808 0100041F AD000905
[   58.466339] PVR_K:   (MKT-5F) 00000B2F 00100808 0000041F AD000901
[   58.472747] PVR_K:   (MKT-60) 00000BAC 00100808 0000051E AD000183
[   58.479217] PVR_K:   (MKT-61) 00000CB9 00100808 0000051E AD00030E
[   58.485626] PVR_K:   (MKT-62) 00000CD2 00100808 0000051E 0D800474
[   58.492095] PVR_K:   (MKT-63) 00000CEB 00100808 0000051E 00000005
[   58.498504] PVR_K:   (MKT-64) 00000D0F 00100808 0000051E 00000006
[   58.505004] PVR_K:   (MKT-65) 00000D7A 00100808 0000051E AD000184
[   58.511474] PVR_K:   (MKT-66) 00000DFA 00100C08 0100061D AD000281
[   58.517944] PVR_K:   (MKT-67) 00000F24 00100808 0100061D AD000E02
[   58.524414] PVR_K:   (MKT-68) 00000F9A 00100808 0100061D AD000282
[   58.530853] PVR_K:   (MKT-69) 000010ED 00100808 0100071F AD00000A
[   58.537292] PVR_K:   (MKT-6A) 00001155 00100808 0100071F AD000905
[   58.543701] PVR_K:   (MKT-6B) 00001265 00100808 0000071F AD000901
[   58.550170] PVR_K:   (MKT-6C) 000012CF 00100808 0000081E AD000183
[   58.556640] PVR_K:   (MKT-6D) 000013BD 00100808 0000081E AD00030E
[   58.563079] PVR_K:   (MKT-6E) 000013D6 00100808 0000081E 0D800474
[   58.569519] PVR_K:   (MKT-6F) 000013EF 00100808 0000081E 00000005
[   58.575958] PVR_K:   (MKT-70) 00001412 00100808 0000081E 00000006
[   58.582397] PVR_K:   (MKT-71) 0000147D 00100808 0000081E AD000184
[   58.588867] PVR_K:   (MKT-72) 000014E4 00100C08 0100091D AD000281
[   58.595275] PVR_K:   (MKT-73) 000015E7 00100808 0000091D AD000E02
[   58.601745] PVR_K:   (MKT-74) 00001659 00100808 0000091D AD000282
[   58.608154] PVR_K:   (MKT-75) 00001716 00100808 01000A1F AD00000A
[   58.614624] PVR_K:   (MKT-76) 00001782 00100808 01000A1F AD000905
[   58.621093] PVR_K:   (MKT-77) 0000188E 00100808 00000A1F AD000901
[   58.627532] PVR_K:   (MKT-78) 000018FB 00100808 00000B1E AD000183
[   58.633972] PVR_K:   (MKT-79) 000019E9 00100808 00000B1E AD00030E
[   58.640411] PVR_K:   (MKT-7A) 00001A01 00100808 00000B1E 0D800474
[   58.646850] PVR_K:   (MKT-7B) 00001A1A 00100808 00000B1E 00000005
[   58.653289] PVR_K:   (MKT-7C) 00001A3E 00100808 00000B1E 00000006
[   58.659759] PVR_K:   (MKT-7D) 00001AA9 00100808 00000B1E AD000184
[   58.666168] PVR_K:   (MKT-7E) 00001B12 00100C08 00000C1D AD000281
[   58.672698] PVR_K:   (MKT-7F) 00001C12 00100808 00000C1D AD000E02
[   58.679107] PVR_K:   (MKT-80) 00001C86 00100808 00000C1D AD000282
[   58.685546] PVR_K:   (MKT-81) 00001D3F 00100808 01000D1F AD00000A
[   58.691955] PVR_K:   (MKT-82) 00001DAA 00100808 01000D1F AD000905
[   58.698425] PVR_K:   (MKT-83) 00001EBE 00100808 00000D1F AD000901
[   58.704833] PVR_K:   (MKT-84) 00001F30 00100808 00000E1E AD000183
[   58.711303] PVR_K:   (MKT-85) 0000201D 00100808 00000E1E AD00030E
[   58.717712] PVR_K:   (MKT-86) 00002036 00100808 00000E1E 0D800474
[   58.724151] PVR_K:   (MKT-87) 0000204E 00100808 00000E1E 00000005
[   58.730621] PVR_K:   (MKT-88) 00002071 00100808 00000E1E 00000006
[   58.737030] PVR_K:   (MKT-89) 000020DE 00100808 00000E1E AD000184
[   58.743499] PVR_K:   (MKT-8A) 00002145 00100C08 01000F1D AD000281
[   58.749908] PVR_K:   (MKT-8B) 00002246 00100808 01000F1D AD000E02
[   58.756378] PVR_K:   (MKT-8C) 000022BB 00100808 01000F1D AD000282
[   58.762847] PVR_K:   (MKT-8D) 00011DD1 00100808 0100121F AD001A00
[   58.769378] PVR_K:   (MKT-8E) 0001227C 00100808 0100131F AD00000A
[   58.775848] PVR_K:   (MKT-8F) 000122DD 00100808 0100131F AD000909
[   58.782348] PVR_K:   (MKT-90) 00012328 00100808 0100131F AD001A05
[   58.788787] PVR_K:   (MKT-91) 000123DC 00100808 0100131F AD001A06
[   58.795288] PVR_K:   (MKT-92) 0000046D 00100808 0100031F AD002300
[   58.801727] PVR_K:   (MKT-93) 00000957 00100808 0100041F AD00000A
[   58.808227] PVR_K:   (MKT-94) 000009D7 00100808 0100041F AD000906
[   58.814666] PVR_K:   (MKT-95) 00000AA8 00100808 0000041F AD000901
[   58.821136] PVR_K:   (MKT-96) 00000B22 00100808 0000051E AD000183
[   58.827575] PVR_K:   (MKT-97) 00000CA0 00100808 0000051E AD000302
[   58.834014] PVR_K:   (MKT-98) 00000CFB 00100808 0000051E AD000303
[   58.840484] PVR_K:   (MKT-99) 00000D82 00100808 0000051E AD000C01
[   58.846893] PVR_K:   (MKT-9A) 00000DA7 00100808 0000051E 0D800464
[   58.853363] PVR_K:   (MKT-9B) 00000DBF 00100808 0000051E 00000007
[   58.859771] PVR_K:   (MKT-9C) 00001010 00100808 0000051E AD00030E
[   58.866210] PVR_K:   (MKT-9D) 00001028 00100808 0000051E 0D800494
[   58.872619] PVR_K:   (MKT-9E) 00001041 00100808 0000051E 00000005
[   58.879058] PVR_K:   (MKT-9F) 00001065 00100808 0000051E 00000006
[   58.885498] PVR_K:   (MKT-A0) 000010DB 00100808 0000051E AD000184
[   58.891937] PVR_K:   (MKT-A1) 00001156 00100C08 0100061D AD000281
[   58.898345] PVR_K:   (MKT-A2) 000012E1 00100808 0100061D AD00080A
[   58.904815] PVR_K:   (MKT-A3) 000012FA 00100808 0100061D 0F040F00
[   58.911224] PVR_K:   (MKT-A4) 00001312 00100808 0100061D 00000061
[   58.917663] PVR_K:   (MKT-A5) 00001429 00100C08 0100061D AD001300
[   58.924102] PVR_K:   (MKT-A6) 0000155A 00100808 0000061D AD001301
[   58.930541] PVR_K:   (MKT-A7) 00001688 00100808 0000061D AD000802
[   58.937011] PVR_K:   (MKT-A8) 000017EC 00100808 0000061D AD000803
[   58.943420] PVR_K:   (MKT-A9) 00001839 00184AC8 0000061D AD000282
[   58.949890] PVR_K:   (MKT-AA) 000037ED 00000808 0100091F AD000200
[   58.956268] PVR_K:   (MKT-AB) 00003A28 00000808 0000091F AD000202
[   58.962768] PVR_K:   (MKT-AC) 00003AC0 00000808 00000A1E AD000183
[   58.969177] PVR_K:   (MKT-AD) 00003BC2 00000808 00000A1E AD00030E
[   58.975616] PVR_K:   (MKT-AE) 00003BDA 00000808 00000A1E 0D800494
[   58.982025] PVR_K:   (MKT-AF) 00003BF3 00000808 00000A1E 00000005
[   58.988494] PVR_K:   (MKT-B0) 00003C17 00000808 00000A1E 00000006
[   58.994964] PVR_K:   (MKT-B1) 00003C81 00000808 00000A1E AD000184
[   58.999725] adc_to_temp_conversion:Temp read is invalid 0
[   58.999725] thermal_lookup_temp: getting temp is not supported for domain pcb
[   59.000549] adc_to_temp_conversion:Temp read is invalid 0
[   59.000549] thermal_lookup_temp: getting temp is not supported for domain pcb
[   59.001373] adc_to_temp_conversion:Temp read is invalid 0
[   59.001373] thermal_lookup_temp: getting temp is not supported for domain pcb
[   59.041503] PVR_K:   (MKT-B2) 00003CED 00000C08 01000B1D AD000281
[   59.047973] PVR_K:   (MKT-B3) 00003E5F 00000808 01000B1D AD00080A
[   59.054382] PVR_K:   (MKT-B4) 00003E78 00000808 01000B1D 0F041200
[   59.060852] PVR_K:   (MKT-B5) 00003E90 00000808 01000B1D 00000060
[   59.067291] PVR_K:   (MKT-B6) 00004144 00000808 00000B1D AD000803
[   59.073791] PVR_K:   (MKT-B7) 0000418A 00180CC8 00000B1D AD000282
[   59.080261] PVR_K:   (MKT-B8) 0000424E 00000808 01000D1F AD000200
[   59.086853] PVR_K:   (MKT-B9) 00004468 00000808 00000D1F AD000202
[   59.096771] PVR_K:   (MKT-BA) 000044E8 00000808 00000E1E AD000183
[   59.116088] PVR_K:   (MKT-BB) 000045D4 00000808 00000E1E AD00030E
[   59.122558] PVR_K:   (MKT-BC) 000045EC 00000808 00000E1E 0D800494
[   59.147338] PVR_K:   (MKT-BD) 00004605 00000808 00000E1E 00000005
[   59.153808] PVR_K:   (MKT-BE) 00004629 00000808 00000E1E 00000006
[   59.178588] PVR_K:   (MKT-BF) 00004698 00000808 00000E1E AD000184
[   59.185058] PVR_K:   (MKT-C0) 000046FC 00000C08 01000F1D AD000281
[   59.191650] PVR_K:   (MKT-C1) 0000486F 00000808 01000F1D AD00080A
[   59.198120] PVR_K:   (MKT-C2) 00004888 00000808 01000F1D 0F041500
[   59.204528] PVR_K:   (MKT-C3) 000048A0 00000808 01000F1D 00000060
[   59.210998] PVR_K:   (MKT-C4) 00004B54 00000808 00000F1D AD000803
[   59.217437] PVR_K:   (MKT-C5) 00004B99 00180CC8 00000F1D AD000282
[   59.223876] PVR_K:   (MKT-C6) 00004C8A 00000808 0100111F AD000200
[   59.230316] PVR_K:   (MKT-C7) 00004EA4 00000808 0000111F AD000202
[   59.236755] PVR_K:   (MKT-C8) 00004F22 00000808 0000121E AD000183
[   59.243164] PVR_K:   (MKT-C9) 0000500C 00000808 0000121E AD00030E
[   59.249603] PVR_K:   (MKT-CA) 00005024 00000808 0000121E 0D800494
[   59.256011] PVR_K:   (MKT-CB) 0000503D 00000808 0000121E 00000005
[   59.262451] PVR_K:   (MKT-CC) 00005062 00000808 0000121E 00000006
[   59.268920] PVR_K:   (MKT-CD) 000050D1 00000808 0000121E AD000184
[   59.275329] PVR_K:   (MKT-CE) 00005134 00000C08 0100131D AD000281
[   59.281829] PVR_K:   (MKT-CF) 000052A8 00000808 0100131D AD00080A
[   59.288238] PVR_K:   (MKT-D0) 000052C0 00000808 0100131D 0F041800
[   59.294677] PVR_K:   (MKT-D1) 000052D9 00000808 0100131D 00000062
[   59.301086] PVR_K:   (MKT-D2) 00005590 00000808 0000131D AD000803
[   59.307556] PVR_K:   (MKT-D3) 000055D6 00180C88 0000131D AD000282
[   59.313964] PVR_K:   (MKT-D4) 000060E2 00000808 0100151F AD000200
[   59.320404] PVR_K:   (MKT-D5) 000061FB 00000808 0000151F AD001703
[   59.326812] PVR_K:   (MKT-D6) 000063D2 00000808 0000151F AD000202
[   59.333251] PVR_K:   (MKT-D7) 00006547 00000808 0100171D AD000183
[   59.339660] PVR_K:   (MKT-D8) 00006632 00000808 0100171D AD00030E
[   59.346099] PVR_K:   (MKT-D9) 0000664A 00000808 0100171D 0D800494
[   59.352508] PVR_K:   (MKT-DA) 00006663 00000808 0100171D 00000005
[   59.358978] PVR_K:   (MKT-DB) 00006687 00000808 0100171D 00000006
[   59.365417] PVR_K:   (MKT-DC) 00006715 00000808 0100171D AD000184
[   59.371795] PVR_K:   (MKT-DD) 00017B76 00000808 01001A1F AD001A00
[   59.378234] PVR_K:   (MKT-DE) 0002E415 00000808 01001E1F AD00000A
[   59.384643] PVR_K:   (MKT-DF) 0002E47D 00000808 01001E1F AD000909
[   59.391113] PVR_K:   (MKT-E0) 0002E4C8 00000808 01001E1F AD001A05
[   59.397521] PVR_K:   (MKT-E1) 0002E4F9 00000808 01001E1F AD001302
[   59.403961] PVR_K:   (MKT-E2) 0002E539 00000808 01001E1F AD001303
[   59.410369] PVR_K:   (MKT-E3) 0002E5D0 00000808 01001E1F AD000D04
[   59.416809] PVR_K:   (MKT-E4) 0002E698 00000808 01001E1F AD000D05
[   59.423217] PVR_K:   (MKT-E5) 0002E70B 00000808 01001E1F AD001A06
[   59.429656] PVR_K:   (MKT-E6) 000004E9 00100808 0100031F AD002300
[   59.436065] PVR_K:   (MKT-E7) 000009EC 00100808 0100041F AD00000A
[   59.442535] PVR_K:   (MKT-E8) 00000A5F 00100808 0100041F AD000905
[   59.448944] PVR_K:   (MKT-E9) 00000B98 00100808 0000041F AD000901
[   59.455383] PVR_K:   (MKT-EA) 00000C14 00100808 0000051E AD000183
[   59.461791] PVR_K:   (MKT-EB) 00000D23 00100808 0000051E AD00030E
[   59.468261] PVR_K:   (MKT-EC) 00000D3C 00100808 0000051E 0D800494
[   59.474731] PVR_K:   (MKT-ED) 00000D56 00100808 0000051E 00000005
[   59.481109] PVR_K:   (MKT-EE) 00000D7B 00100808 0000051E 00000006
[   59.487579] PVR_K:   (MKT-EF) 00000DE8 00100808 0000051E AD000184
[   59.493988] PVR_K:   (MKT-F0) 00000E67 00100C08 0100061D AD000281
[   59.500427] PVR_K:   (MKT-F1) 00000F96 00100808 0000061D AD000E02
[   59.506866] PVR_K:   (MKT-F2) 00001008 00100808 0000061D AD000282
[   59.513305] PVR_K:   (MKT-F3) 000010C1 00100808 0100071F AD00000A
[   59.519714] PVR_K:   (MKT-F4) 0000112C 00100808 0100071F AD000905
[   59.526153] PVR_K:   (MKT-F5) 00001237 00100808 0000071F AD000901
[   59.532562] PVR_K:   (MKT-F6) 000012A0 00100808 0000081E AD000183
[   59.539001] PVR_K:   (MKT-F7) 00001391 00100808 0000081E AD00030E
[   59.545410] PVR_K:   (MKT-F8) 000013AD 00100808 0000081E 0D800494
[   59.551879] PVR_K:   (MKT-F9) 000013C6 00100808 0000081E 00000005
[   59.558288] PVR_K:   (MKT-FA) 000013E9 00100808 0000081E 00000006
[   59.564727] PVR_K:   (MKT-FB) 00001457 00100808 0000081E AD000184
[   59.571197] PVR_K:   (MKT-FC) 000014C2 00100C08 0000091D AD000281
[   59.577575] PVR_K:   (MKT-FD) 000015C5 00100808 0000091D AD000E02
[   59.584014] PVR_K:   (MKT-FE) 00001638 00100808 0000091D AD000282
[   59.590423] PVR_K:   (MKT-FF) 000016EA 00100808 01000A1F AD00000A
[   59.596893] PVR_K:   (MKT-100) 00001754 00100808 00000A1F AD000905
[   59.603393] PVR_K:   (MKT-101) 00001866 00100808 00000A1F AD000901
[   59.609924] PVR_K:   (MKT-102) 000018C9 00100808 00000B1E AD00000A
[   59.616455] PVR_K:   (MKT-103) 00001929 00100808 00000B1E AD000905
[   59.622985] PVR_K:   (MKT-104) 000019CF 00100808 00000B1E AD000901
[   59.629486] PVR_K:   (MKT-105) 00001A3A 00100808 00000C1D AD000183
[   59.636016] PVR_K:   (MKT-106) 00001B2A 00100808 00000C1D AD00030E
[   59.642517] PVR_K:   (MKT-107) 00001B44 00100808 00000C1D 0D800494
[   59.649047] PVR_K:   (MKT-108) 00001B5D 00100808 00000C1D 00000005
[   59.655548] PVR_K:   (MKT-109) 00001B80 00100808 00000C1D 00000006
[   59.662078] PVR_K:   (MKT-10A) 00001BEB 00100808 00000C1D AD000184
[   59.668640] PVR_K:   (MKT-10B) 00001C54 00100C08 01000D1C AD000281
[   59.675140] PVR_K:   (MKT-10C) 00001D52 00100808 01000D1C AD000E02
[   59.681671] PVR_K:   (MKT-10D) 00001DCB 00100808 01000D1C AD000282
[   59.688171] PVR_K:   (MKT-10E) 00011E31 00100808 0100101F AD001A00
[   59.694732] PVR_K:   (MKT-10F) 0002AB97 00100808 0100151F AD00000A
[   59.701202] PVR_K:   (MKT-110) 0002ABF8 00100808 0100151F AD000909
[   59.707763] PVR_K:   (MKT-111) 0002AC42 00100808 0100151F AD001A05
[   59.714263] PVR_K:   (MKT-112) 0002ACF6 00100808 0100151F AD001A06
[   59.720825] PVR_K:   (MKT-113) 000004C9 00100808 0100031F AD002300
[   59.727325] PVR_K:   (MKT-114) 000009C1 00100808 0100041F AD00000A
[   59.733856] PVR_K:   (MKT-115) 00000A3D 00100808 0100041F AD000906
[   59.740356] PVR_K:   (MKT-116) 00000B0D 00100808 0000041F AD000901
[   59.746917] PVR_K:   (MKT-117) 00000B85 00100808 0000051E AD000183
[   59.753448] PVR_K:   (MKT-118) 00000CFD 00100808 0000051E AD000302
[   59.759948] PVR_K:   (MKT-119) 00000E84 00100808 0000051E AD000D06
[   59.766510] PVR_K:   (MKT-11A) 00000F6D 00100808 0000051E AD000D07
[   59.772979] PVR_K:   (MKT-11B) 00000FB6 00100808 0000051E AD001304
[   59.779541] PVR_K:   (MKT-11C) 000010A9 00100808 0000051E AD001305
[   59.786041] PVR_K:   (MKT-11D) 000011BD 00100888 0000051E AD000404
[   59.792572] PVR_K:   (MKT-11E) 00001284 00100808 0000051E AD000402
[   59.799072] PVR_K:   (MKT-11F) 000012CD 0010082B 0000051E AD000184
[   59.805603] PVR_K:   (MKT-120) 00001353 00108DA9 0000061D AD000281
[   59.812103] PVR_K:   (MKT-121) 000014E5 001089AB 0000061D AD000E02
[   59.818664] PVR_K:   (MKT-122) 00001543 0010892B 0000061D AD000282
[   59.825164] PVR_K:   (MKT-123) 00003AE1 00100808 0000081F AD000101
[   59.831634] PVR_K:   (MKT-124) 00003B56 00100808 0000081F AD000104
[   59.838195] PVR_K:   (MKT-125) 00003B94 00100808 0100091E AD000100
[   59.844665] PVR_K:   (MKT-126) 00003C99 00100808 0100091E AD000501
[   59.851226] PVR_K:   (MKT-127) 00003CD8 0010082B 0100091E AD000104
[   59.857727] PVR_K:   (MKT-128) 00005F33 00100828 01000A1F AD000101
[   59.864257] PVR_K:   (MKT-129) 00005F89 00100828 01000A1F AD000104
[   59.870758] PVR_K:   (MKT-12A) 00006096 00100808 01000B1F AD000100
[   59.877319] PVR_K:   (MKT-12B) 00006150 00100808 01000B1F AD000501
[   59.883850] PVR_K:   (MKT-12C) 0000617C 00100829 01000B1F AD000104
[   59.890380] PVR_K:   (MKT-12D) 00008710 00100828 01000D1F AD000101
[   59.897186] PVR_K:   (MKT-12E) 00008789 00100828 01000D1F AD000104
[   59.903778] PVR_K:   (MKT-12F) 000087C6 00100808 01000E1E AD000100
[   59.911773] PVR_K:   (MKT-130) 000088C1 00100808 01000E1E AD000501
[   59.918304] PVR_K:   (MKT-131) 000088FF 00100829 01000E1E AD000104
[   59.924865] PVR_K:   (MKT-132) 091A3338 00100808 0100031F AD000B00
[   59.931365] PVR_K:   (MKT-133) 091A337F 00100808 0100031F AD000B03
[   59.937957] PVR_K:   (MKT-134) 091A3407 00100808 0100031F AD000B05
[   59.944458] PVR_K:   (MKT-135) 091A345D 00100808 0100031F AD000B06
[   59.950988] PVR_K:   (MKT-136) 091A348C 00100808 0100031F AD000B06
[   59.957489] PVR_K:   (MKT-137) 091A34D0 00100808 0100031F AD000B07
[   59.964050] PVR_K:   (MKT-138) 091A34F5 00100808 0100031F AD000B09
[   59.970550] PVR_K:   (MKT-139) 091A354D 00100808 0100031F AD000B01
[   59.977111] PVR_K:   (MKT-13A) 091A3589 00100808 0100031F AD002300
[   59.983612] PVR_K:   (MKT-13B) 091A3B59 00100808 0100041F AD00000A
[   59.990142] PVR_K:   (MKT-13C) 091A3BD5 00100808 0100041F AD000906
[   59.996704] PVR_K:   (MKT-13D) 091A3C96 00100808 0000041F AD000901
[   59.999786] adc_to_temp_conversion:Temp read is invalid 0
[   59.999816] thermal_lookup_temp: getting temp is not supported for domain pcb
[   60.000640] adc_to_temp_conversion:Temp read is invalid 0
[   60.000640] thermal_lookup_temp: getting temp is not supported for domain pcb
[   60.001464] adc_to_temp_conversion:Temp read is invalid 0
[   60.001464] thermal_lookup_temp: getting temp is not supported for domain pcb
[   60.043243] PVR_K:   (MKT-13E) 091A3D11 00100808 0000051E AD000183
[   60.049774] PVR_K:   (MKT-13F) 091A3E88 00100808 0000051E AD000302
[   60.056274] PVR_K:   (MKT-140) 091A3EDB 00100808 0000051E AD000303
[   60.062835] PVR_K:   (MKT-141) 091A3F60 00100808 0000051E AD000C01
[   60.069396] PVR_K:   (MKT-142) 091A3F87 00100808 0000051E 0D800484
[   60.075897] PVR_K:   (MKT-143) 091A3F9F 00100808 0000051E 00000007
[   60.082427] PVR_K:   (MKT-144) 091A41F7 00100808 0000051E AD00030E
[   60.088989] PVR_K:   (MKT-145) 091A420F 00100808 0000051E 0D800474
[   60.095550] PVR_K:   (MKT-146) 091A4227 00100808 0000051E 00000006
[   60.102050] PVR_K:   (MKT-147) 091A424B 00100808 0000051E 00000007
[   60.108612] PVR_K:   (MKT-148) 091A42C4 00100808 0000051E AD000184
[   60.115112] PVR_K:   (MKT-149) 091A4346 00100C08 0100061D AD000281
[   60.121643] PVR_K:   (MKT-14A) 091A44DD 00100808 0100061D AD00080A
[   60.128143] PVR_K:   (MKT-14B) 091A44F6 00100808 0100061D 0F041B00
[   60.134704] PVR_K:   (MKT-14C) 091A4511 00100808 0100061D 00000061
[   60.141204] PVR_K:   (MKT-14D) 091A4630 00100C88 0100061D AD001300
[   60.147796] PVR_K:   (MKT-14E) 091A9AAE 00100808 0000061D AD001301
[   60.154327] PVR_K:   (MKT-14F) 091A9BDE 00100888 0000061D AD000802
[   60.160827] PVR_K:   (MKT-150) 091A9D50 00100888 0000061D AD000803
[   60.167388] PVR_K:   (MKT-151) 091A9DA4 001808C8 0000061D AD000282
[   60.173889] PVR_K:   (MKT-152) 091A9E87 00184AF8 0000081E AD00000A
[   60.180450] PVR_K:   (MKT-153) 091A9F11 00184AF8 0000081E AD000905
[   60.186950] PVR_K:   (MKT-154) 091AA02E 001808B8 0000081E AD000901
[   60.193481] PVR_K:   (MKT-155) 091AA0A3 00180838 0000091C AD00000A
[   60.200012] PVR_K:   (MKT-156) 091AA11C 00180838 0000091C AD000906
[   60.206542] PVR_K:   (MKT-157) 091AA18D 00180838 0000091C AD000901
[   60.213073] PVR_K:   (MKT-158) 091AA1E3 00180838 00000A1B AD00000A
[   60.219635] PVR_K:   (MKT-159) 091AA248 00180838 00000A1B AD000905
[   60.226196] PVR_K:   (MKT-15A) 091AA2F6 00180838 00000A1B AD000901
[   60.232757] PVR_K:   (MKT-15B) 091AA34A 00180838 00000B1A AD00000A
[   60.239349] PVR_K:   (MKT-15C) 091AA3AB 00180838 00000B1A AD000905
[   60.245849] PVR_K:   (MKT-15D) 091AA462 00180838 00000B1A AD000901
[   60.252410] PVR_K:   (MKT-15E) 091AA4B9 00180838 00000C19 AD00000A
[   60.258911] PVR_K:   (MKT-15F) 091AA521 00180838 00000C19 AD000905
[   60.265533] PVR_K:   (MKT-160) 091AA5C9 00180838 00000C19 AD000901
[   60.274353] PVR_K:   (MKT-161) 091AA71F 00180838 00000F1F AD000183
[   60.286651] PVR_K:   (MKT-162) 091AA8A9 00180838 00000F1F AD000302
[   60.286834] request_suspend_state: wakeup (3->0) at 60280151369 (2000-01-01 00:00:54.714599611 UTC)
[   60.302856] PVR_K:   (MKT-163) 091AA91C 00180838 00000F1F AD000303
[   60.309570] PVR_K:   (MKT-164) 091AA99E 00180838 00000F1F AD000C01
[   60.316131] PVR_K:   (MKT-165) 091AA9C3 00180838 00000F1F 0D800464
[   60.322692] PVR_K:   (MKT-166) 091AA9DC 00180838 00000F1F 00000008
[   60.329193] PVR_K:   (MKT-167) 091AABF9 00180838 00000F1F AD000184
[   60.335754] PVR_K:   (MKT-168) 091AAC65 00180C38 0100101D AD000281
[   60.342224] PVR_K:   (MKT-169) 091AACC0 00180838 0100101D AD000282
[   60.348785] PVR_K:   (MKT-16A) 091ABB59 00180838 0100111F AD00000A
[   60.355316] PVR_K:   (MKT-16B) 091ABBC3 00180838 0100111F AD000905
[   60.361877] PVR_K:   (MKT-16C) 091ABCC6 00180838 0000111F AD000901
[   60.368408] PVR_K:   (MKT-16D) 091ABD17 00180C38 0100121E AD000281
[   60.374938] PVR_K:   (MKT-16E) 091ABD70 00180838 0100121E AD000282
[   60.381469] PVR_K:   (MKT-16F) 091ABE2A 00180838 0100131F AD00000A
[   60.388031] PVR_K:   (MKT-170) 091ABE93 00100828 0100131F AD000905
[   60.394592] PVR_K:   (MKT-171) 091ABF8E 00000808 0000131F AD000901
[   60.401123] PVR_K:   (MKT-172) 091ABFC4 00000C08 0000141E AD000200
[   60.407745] PVR_K:   (MKT-173) 091AC20D 00000808 0000141E AD000202
[   60.414337] PVR_K:   (MKT-174) 091AC269 00000808 0000151D AD000281
[   60.420959] PVR_K:   (MKT-175) 091AC3BC 00000808 0000151D AD00080A
[   60.427459] PVR_K:   (MKT-176) 091AC3D6 00000808 0000151D 0F041E00
[   60.434020] PVR_K:   (MKT-177) 091AC3EE 00000808 0000151D 00000060
[   60.440521] PVR_K:   (MKT-178) 091AC6BB 00000808 0000151D AD000803
[   60.447082] PVR_K:   (MKT-179) 091AC703 00180CC8 0000151D AD000282
[   60.453613] PVR_K:   (MKT-17A) 091AC7BC 00000808 0000161F AD00000A
[   60.460113] PVR_K:   (MKT-17B) 091AC825 00000808 0000161F AD000905
[   60.466644] PVR_K:   (MKT-17C) 091AC91E 00000888 0000161F AD000901
[   60.473693] PVR_K:   (MKT-17D) 091AC984 00000808 0000171E AD00000A
[   60.480255] PVR_K:   (MKT-17E) 091AC9E3 00000808 0000171E AD000905
[   60.486816] PVR_K:   (MKT-17F) 091ACA89 00000808 0000171E AD000901
[   60.493408] PVR_K:   (MKT-180) 091ACAD1 00000C08 0000191D AD000200
[   60.499908] PVR_K:   (MKT-181) 091ACD00 00000808 0000191D AD000202
[   60.506439] PVR_K:   (MKT-182) 091ACD57 00000808 01001A1B AD000281
[   60.512939] PVR_K:   (MKT-183) 091ACEA3 00000808 01001A1B AD00080A
[   60.519500] PVR_K:   (MKT-184) 091ACEBC 00000808 01001A1B 0F042100
[   60.526031] PVR_K:   (MKT-185) 091ACED4 00000808 01001A1B 00000060
[   60.532562] PVR_K:   (MKT-186) 091AD190 00000808 00001A1B AD000803
[   60.539184] PVR_K:   (MKT-187) 091AD1D6 00180CC8 00001A1B AD000282
[   60.545684] PVR_K:   (MKT-188) 091AD2C0 00000808 01001C1F AD000200
[   60.552246] PVR_K:   (MKT-189) 091AD4F3 00000808 01001C1F AD000202
[   60.558746] PVR_K:   (MKT-18A) 091AD543 00000808 01001D1E AD000281
[   60.565307] PVR_K:   (MKT-18B) 091AD691 00000808 01001D1E AD00080A
[   60.571807] PVR_K:   (MKT-18C) 091AD6AC 00000808 01001D1E 0F042400
[   60.578338] PVR_K:   (MKT-18D) 091AD6C5 00000808 01001D1E 00000062
[   60.584869] PVR_K:   (MKT-18E) 091AD980 00000808 00001D1E AD000803
[   60.591400] PVR_K:   (MKT-18F) 091AD9C7 00180C88 00001D1E AD000282
[   60.597930] PVR_K:   (MKT-190) 091AE4FB 00000808 01001F1F AD000200
[   60.604461] PVR_K:   (MKT-191) 091AE61E 00000808 01001F1F AD001703
[   60.611022] PVR_K:   (MKT-192) 091AE82B 00000808 00001F1F AD000202
[   60.617584] PVR_K:   (MKT-193) 091AE8AA 00000808 0000201E AD000183
[   60.624145] PVR_K:   (MKT-194) 091AE99A 00000808 0000201E AD00030E
[   60.630645] PVR_K:   (MKT-195) 091AE9B2 00000808 0000201E 0D800494
[   60.637176] PVR_K:   (MKT-196) 091AE9CB 00000808 0000201E 00000006
[   60.643676] PVR_K:   (MKT-197) 091AE9EF 00000808 0000201E 00000007
[   60.650238] PVR_K:   (MKT-198) 091AEA5B 00000808 0000201E AD000184
[   60.656738] PVR_K:   (MKT-199) 091AEAC2 00000C08 0100211D AD000281
[   60.663299] PVR_K:   (MKT-19A) 091AEC43 00000808 0100211D AD00080A
[   60.669769] PVR_K:   (MKT-19B) 091AEC5C 00000808 0100211D 0F042700
[   60.676330] PVR_K:   (MKT-19C) 091AEC75 00000808 0100211D 00000061
[   60.682891] PVR_K:   (MKT-19D) 091AEDEE 00000808 0000211D AD000802
[   60.689422] PVR_K:   (MKT-19E) 091AEF43 00000808 0000211D AD000803
[   60.695922] PVR_K:   (MKT-19F) 091AEF8E 00184EC8 0000211D AD000282
[   60.702484] PVR_K:   (MKT-1A0) 091B1078 00000C08 0100241F AD000200
[   60.709014] PVR_K:   (MKT-1A1) 091B12D8 00000808 0000241F AD000202
[   60.715515] PVR_K:   (MKT-1A2) 091B136A 00000808 0000251E AD000183
[   60.722076] PVR_K:   (MKT-1A3) 091B1456 00000808 0000251E AD00030E
[   60.728637] PVR_K:   (MKT-1A4) 091B146E 00000808 0000251E 0D800494
[   60.735321] PVR_K:   (MKT-1A5) 091B1488 00000808 0000251E 00000006
[   60.741973] PVR_K:   (MKT-1A6) 091B14AF 00000808 0000251E 00000007
[   60.748657] PVR_K:   (MKT-1A7) 091B151D 00000808 0000251E AD000184
[   60.755493] PVR_K:   (MKT-1A8) 091B1584 00000C08 0100261D AD000281
[   60.762420] PVR_K:   (MKT-1A9) 091B16F7 00000808 0100261D AD00080A
[   60.768981] PVR_K:   (MKT-1AA) 091B1710 00000808 0100261D 0F042A00
[   60.775543] PVR_K:   (MKT-1AB) 091B1728 00000808 0100261D 00000060
[   60.782104] PVR_K:   (MKT-1AC) 091B19E9 00000808 0000261D AD000803
[   60.788665] PVR_K:   (MKT-1AD) 091B1A31 00180CC8 0000261D AD000282
[   60.795166] PVR_K:   (MKT-1AE) 091B1AD4 00000808 0100281F AD000200
[   60.801696] PVR_K:   (MKT-1AF) 091B1CFE 00000808 0000281F AD000202
[   60.808258] PVR_K:   (MKT-1B0) 091B1D84 00000808 0000291E AD000183
[   60.814758] PVR_K:   (MKT-1B1) 091B1E6D 00000808 0000291E AD00030E
[   60.821380] PVR_K:   (MKT-1B2) 091B1E85 00000808 0000291E 0D800494
[   60.827911] PVR_K:   (MKT-1B3) 091B1E9E 00000808 0000291E 00000006
[   60.834442] PVR_K:   (MKT-1B4) 091B1EC3 00000808 0000291E 00000007
[   60.840942] PVR_K:   (MKT-1B5) 091B1F2E 00000808 0000291E AD000184
[   60.847473] PVR_K:   (MKT-1B6) 091B1F95 00000C08 01002A1D AD000281
[   60.854003] PVR_K:   (MKT-1B7) 091B2106 00000808 01002A1D AD00080A
[   60.860687] PVR_K:   (MKT-1B8) 091B211E 00000808 01002A1D 0F042D00
[   60.867248] PVR_K:   (MKT-1B9) 091B2137 00000808 01002A1D 00000060
[   60.873809] PVR_K:   (MKT-1BA) 091B23FC 00000808 00002A1D AD000803
[   60.880432] PVR_K:   (MKT-1BB) 091B2443 00180CC8 00002A1D AD000282
[   60.886962] PVR_K:   (MKT-1BC) 091B252F 00000808 01002C1F AD000200
[   60.893554] PVR_K:   (MKT-1BD) 091B2750 00000808 00002C1F AD000202
[   60.900054] PVR_K:   (MKT-1BE) 091B27D0 00000808 00002D1E AD000183
[   60.906616] PVR_K:   (MKT-1BF) 091B28BD 00000808 00002D1E AD00030E
[   60.913116] PVR_K:   (MKT-1C0) 091B28D7 00000808 00002D1E 0D800494
[   60.919647] PVR_K:   (MKT-1C1) 091B28F1 00000808 00002D1E 00000006
[   60.926147] PVR_K:   (MKT-1C2) 091B2916 00000808 00002D1E 00000007
[   60.932708] PVR_K:   (MKT-1C3) 091B2980 00000808 00002D1E AD000184
[   60.939208] PVR_K:   (MKT-1C4) 091B29EB 00000C08 01002E1D AD000281
[   60.945770] PVR_K:   (MKT-1C5) 091B2B64 00000808 01002E1D AD00080A
[   60.952239] PVR_K:   (MKT-1C6) 091B2B7D 00000808 01002E1D 0F043000
[   60.958740] PVR_K:   (MKT-1C7) 091B2B96 00000808 01002E1D 00000062
[   60.965301] PVR_K:   (MKT-1C8) 091B2E54 00000808 00002E1D AD000803
[   60.971801] PVR_K:   (MKT-1C9) 091B2E9C 00180C88 00002E1D AD000282
[   60.978332] PVR_K:   (MKT-1CA) 091B3A62 00000808 0100301F AD000200
[   60.984863] PVR_K:   (MKT-1CB) 091B3B7F 00000808 0100301F AD001703
[   60.991455] PVR_K:   (MKT-1CC) 091B3D68 00000808 0000301F AD000202
[   60.998016] PVR_K:   (MKT-1CD) 091B3DE7 00000808 0000311E AD000183
[   60.999755] adc_to_temp_conversion:Temp read is invalid 0
[   60.999755] thermal_lookup_temp: getting temp is not supported for domain pcb
[   61.000640] adc_to_temp_conversion:Temp read is invalid 0
[   61.000640] thermal_lookup_temp: getting temp is not supported for domain pcb
[   61.001525] adc_to_temp_conversion:Temp read is invalid 0
[   61.001525] thermal_lookup_temp: getting temp is not supported for domain pcb
[   61.044647] PVR_K:   (MKT-1CE) 091B3ED4 00000808 0000311E AD00030E
[   61.051300] PVR_K:   (MKT-1CF) 091B3EF4 00000808 0000311E 0D800494
[   61.057830] PVR_K:   (MKT-1D0) 091B3F0D 00000808 0000311E 00000006
[   61.064361] PVR_K:   (MKT-1D1) 091B3F35 00000808 0000311E 00000007
[   61.070861] PVR_K:   (MKT-1D2) 091B3F9F 00000808 0000311E AD000184
[   61.077453] PVR_K:   (MKT-1D3) 091B4003 00000C08 0100321D AD000281
[   61.083953] PVR_K:   (MKT-1D4) 091B4118 00000808 0100321D AD000E02
[   61.090576] PVR_K:   (MKT-1D5) 091B418D 00000808 0100321D AD000282
[   61.097137] PVR_K:   (MKT-1D6) 091C0A78 00000808 0100351F AD001A00
[   61.103698] PVR_K:   (MKT-1D7) 091DB904 00000808 01003A1F AD00000A
[   61.110290] PVR_K:   (MKT-1D8) 091DB967 00000808 01003A1F AD000909
[   61.116790] PVR_K:   (MKT-1D9) 091DB9B2 00000808 01003A1F AD001A05
[   61.123413] PVR_K:   (MKT-1DA) 091DB9E3 00000808 01003A1F AD001302
[   61.129943] PVR_K:   (MKT-1DB) 091DBA24 00000808 01003A1F AD001303
[   61.136474] PVR_K:   (MKT-1DC) 091DBABD 00000808 01003A1F AD000D04
[   61.142974] PVR_K:   (MKT-1DD) 091DBB96 00000808 01003A1F AD000D05
[   61.149536] PVR_K:   (MKT-1DE) 091DBBEF 00000808 01003A1F AD000D04
[   61.156036] PVR_K:   (MKT-1DF) 091DBC79 00000808 01003A1F AD000D05
[   61.162567] PVR_K:   (MKT-1E0) 091DBCD8 00000808 01003A1F AD001A06
[   61.169067] PVR_K:   (MKT-1E1) 000004D5 00100808 0100031F AD002300
[   61.175628] PVR_K:   (MKT-1E2) 000009DA 00100808 0100041F AD00000A
[   61.182128] PVR_K:   (MKT-1E3) 00000A58 00100808 0100041F AD000906
[   61.188659] PVR_K:   (MKT-1E4) 00000B2A 00100808 0000041F AD000901
[   61.195281] PVR_K:   (MKT-1E5) 00000BA4 00100808 0000051E AD000183
[   61.201782] PVR_K:   (MKT-1E6) 00000D22 00100808 0000051E AD000302
[   61.208343] PVR_K:   (MKT-1E7) 00000EAF 00100808 0000051E AD000D06
[   61.214843] PVR_K:   (MKT-1E8) 00000F9D 00100808 0000051E AD000D07
[   61.221374] PVR_K:   (MKT-1E9) 00000FE7 00100808 0000051E AD001304
[   61.227874] PVR_K:   (MKT-1EA) 000010DC 00100808 0000051E AD001305
[   61.234436] PVR_K:   (MKT-1EB) 000011F3 00100888 0000051E AD000404
[   61.240905] PVR_K:   (MKT-1EC) 000012B8 00100808 0000051E AD000402
[   61.247467] PVR_K:   (MKT-1ED) 00001300 0010082B 0000051E AD000184
[   61.253997] PVR_K:   (MKT-1EE) 0000139E 00119DA9 0000061D AD000281
[   61.260620] PVR_K:   (MKT-1EF) 00001530 001089AF 0000061D AD000E02
[   61.267120] PVR_K:   (MKT-1F0) 00001589 0010892B 0000061D AD000282
[   61.273651] PVR_K:   (MKT-1F1) 00003B65 00100808 0000081F AD000101
[   61.280212] PVR_K:   (MKT-1F2) 00003BDD 00100808 0000081F AD000104
[   61.286712] PVR_K:   (MKT-1F3) 00003C1C 00100808 0100091E AD000100
[   61.293243] PVR_K:   (MKT-1F4) 00003D29 00100808 0100091E AD000501
[   61.299743] PVR_K:   (MKT-1F5) 00003D69 00100829 0100091E AD000104
[   61.306274] PVR_K:   (MKT-1F6) 00005FFE 00100828 01000A1F AD000101
[   61.312774] PVR_K:   (MKT-1F7) 00006058 00100828 01000A1F AD000104
[   61.319305] PVR_K:   (MKT-1F8) 00006170 00100808 01000B1F AD000100
[   61.325805] PVR_K:   (MKT-1F9) 00006240 00100808 01000B1F AD000501
[   61.332366] PVR_K:   (MKT-1FA) 00006276 00100829 00000B1F AD000104
[   61.338897] PVR_K:   (MKT-1FB) 000087D6 00100828 01000D1F AD000101
[   61.345428] PVR_K:   (MKT-1FC) 0000884B 00100828 01000D1F AD000104
[   61.351928] PVR_K:   (MKT-1FD) 00008889 00100808 01000E1E AD000100
[   61.358489] PVR_K:   (MKT-1FE) 00008987 00100808 01000E1E AD000501
[   61.365020] PVR_K:   (MKT-1FF) 000089C6 00100829 01000E1E AD000104
[   61.371520] PVR_K: SGX Kernel CCB WO:0x6C RO:0x6C
[   61.577087] PVR_K:(Error): SGXOSTimer() detected SGX lockup (0xc tasks) [0, ]
[   61.584869] PVR_K: HWRecoveryResetSGX: SGX Hardware Recovery triggered
[   61.593688] [   33.971]  [c6e89da0] --refs=1 on RELEASED
[   61.593688] [   33.971]                        [c6e64c00] dsscomp_apply
[   61.593719] [   33.971] [c6e89d60] --refs=0 on RELEASED
[   61.593719] [   33.971] [c6e89d60] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   61.593719] [   33.971]                      [c6e64800] dsscomp_mgr_delayed_cb on RELEASED
[   61.625640] [   33.971]                        [c6e64c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   61.625640] [   33.972]      [c6edb820] new in dsscomp_gralloc_queue (refs=1)
[   61.625671] [   33.972]                      [c6f10000] dsscomp_new
[   61.625671] [   33.972]      [c6edb820] ++refs=2 for [c6f10000]
[   61.657073] [   33.972]                      [c6f10000] dsscomp_delayed_apply
[   61.657104] [   33.972]      [c6edb820] --refs=1 on RELEASED
[   61.657104] [   33.972]                      [c6f10000] dsscomp_apply
[   61.657104] [   33.993]                        [c6e64c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   61.687072] [   33.993]  [c6e89da0] --refs=0 on RELEASED
[   61.687072] [   33.993]  [c6e89da0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   61.687072] [   34.001]                        [c6e64c00] dsscomp_mgr_delayed_cb on RELEASED
[   61.687103] [   34.001]                      [c6f10000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   61.716918] [   34.008]                      [c6f10000] dsscomp_mgr_delayed_cb on DISPLAYED
[   61.716918] [   39.512]   [c6edba00] new in dsscomp_gralloc_queue (refs=1)
[   61.716918] [   39.512]                        [c6f12000] dsscomp_new
[   61.745147] [   39.512]   [c6edba00] ++refs=2 for [c6f12000]
[   61.745147] [   39.512]                        [c6f12000] dsscomp_delayed_apply
[   61.745147] [   39.512]   [c6edba00] --refs=1 on RELEASED
[   61.745147] [   39.512]                        [c6f12000] dsscomp_apply
[   61.745147] [   39.512]      [c6edb820] --refs=0 on RELEASED
[   61.776489] [   39.512]      [c6edb820] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   61.776489] [   39.512]                      [c6f10000] dsscomp_mgr_delayed_cb on RELEASED
[   61.776489] [   39.512]                        [c6f12000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   61.804779] [   39.513]      [c6edb820] new in dsscomp_gralloc_queue (refs=1)
[   61.804779] [   39.513]                      [c6f10000] dsscomp_new
[   61.804779] [   39.513]      [c6edb820] ++refs=2 for [c6f10000]
[   61.804779] [   39.513]                      [c6f10000] dsscomp_delayed_apply
[   61.804809] [   39.513]      [c6edb820] --refs=1 on RELEASED
[   61.835968] [   39.513]                      [c6f10000] dsscomp_apply
[   61.835968] [   39.527]                        [c6f12000] dsscomp_mgr_delayed_cb on DISPLAYED
[   61.835968] [   39.527]   [c6edba00] --refs=0 on RELEASED
[   61.835998] [   39.527]   [c6edba00] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   61.865753] [   39.527]                        [c6f12000] dsscomp_mgr_delayed_cb on RELEASED
[   61.865753] [   39.527]                      [c6f10000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   61.865753] [   39.550]                      [c6f10000] dsscomp_mgr_delayed_cb on DISPLAYED
[   61.893981] [   44.408]    [c6edb7a0] new in dsscomp_gralloc_queue (refs=1)
[   61.893981] [   44.408]                        [c6f12000] dsscomp_new
[   61.893981] [   44.408]    [c6edb7a0] ++refs=2 for [c6f12000]
[   61.893981] [   44.408]                        [c6f12000] dsscomp_delayed_apply
[   61.924285] [   44.408]    [c6edb7a0] --refs=1 on RELEASED
[   61.924285] [   44.408]                        [c6f12000] dsscomp_apply
[   61.924285] [   44.408]      [c6edb820] --refs=0 on RELEASED
[   61.924285] [   44.408]      [c6edb820] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   61.924285] [   44.408]                      [c6f10000] dsscomp_mgr_delayed_cb on RELEASED
[   61.955718] [   44.409]                        [c6f12000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   61.955718] [   44.409]      [c6edb820] new in dsscomp_gralloc_queue (refs=1)
[   61.955718] [   44.409]                      [c6f10000] dsscomp_new
[   61.984649] [   44.409]      [c6edb820] ++refs=2 for [c6f10000]
[   61.984649] [   44.409]                      [c6f10000] dsscomp_delayed_apply
[   61.984649] [   44.409]      [c6edb820] --refs=1 on RELEASED
[   61.984649] [   44.409]                      [c6f10000] dsscomp_apply
[   61.984649] [   44.425]                        [c6f12000] dsscomp_mgr_delayed_cb on DISPLAYED
[   62.016082] [   44.430]    [c6edb7a0] --refs=0 on RELEASED
[   62.016113] [   44.430]    [c6edb7a0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   62.016113] [   44.430]                        [c6f12000] dsscomp_mgr_delayed_cb on RELEASED
[   62.016113] [   44.430]                      [c6f10000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   62.046051] [   44.464]                      [c6f10000] dsscomp_mgr_delayed_cb on DISPLAYED
[   62.046051] [   49.508]   [c6edba00] new in dsscomp_gralloc_queue (refs=1)
[   62.046051] [   49.508]                     [c6f10c00] dsscomp_new
[   62.077148] [   49.508]   [c6edba00] ++refs=2 for [c6f10c00]
[   62.077148] [   49.508]                     [c6f10c00] dsscomp_delayed_apply
[   62.077148] [   49.508]   [c6edba00] --refs=1 on RELEASED
[   62.077148] [   49.508]                     [c6f10c00] dsscomp_apply
[   62.077148] [   49.514]      [c6edb820] --refs=0 on RELEASED
[   62.108612] [   49.514]      [c6edb820] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   62.108612] [   49.514]                      [c6f10000] dsscomp_mgr_delayed_cb on RELEASED
[   62.108642] [   49.514]                     [c6f10c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   62.136993] [   49.522]    [c6edb880] new in dsscomp_gralloc_queue (refs=1)
[   62.136993] [   49.522]                      [c6f10000] dsscomp_new
[   62.136993] [   49.522]    [c6edb880] ++refs=2 for [c6f10000]
[   62.136993] [   49.522]                      [c6f10000] dsscomp_delayed_apply
[   62.137023] [   49.522]    [c6edb880] --refs=1 on RELEASED
[   62.168457] [   49.522]                      [c6f10000] dsscomp_apply
[   62.168457] [   49.543]                     [c6f10c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   62.168457] [   49.543]   [c6edba00] --refs=0 on RELEASED
[   62.168457] [   49.543]   [c6edba00] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   62.198364] [   49.543]                     [c6f10c00] dsscomp_mgr_delayed_cb on RELEASED
[   62.198364] [   49.543]                      [c6f10000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   62.198364] [   49.557]                      [c6f10000] dsscomp_mgr_delayed_cb on DISPLAYED
[   62.226684] [   55.906]  [c6fa40a0] new in dsscomp_gralloc_queue (refs=1)
[   62.226684] [   55.906]                          [c6e66c00] dsscomp_new
[   62.226684] [   55.906]  [c6fa40a0] ++refs=2 for [c6e66c00]
[   62.226715] [   55.906]                          [c6e66c00] dsscomp_delayed_apply
[   62.226715] [   55.906]  [c6fa40a0] --refs=1 on RELEASED
[   62.258026] [   55.906]                          [c6e66c00] dsscomp_apply
[   62.258026] [   55.907]    [c6edb880] --refs=0 on RELEASED
[   62.258026] [   55.907]    [c6edb880] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   62.258056] [   55.907]                      [c6f10000] dsscomp_mgr_delayed_cb on RELEASED
[   62.287902] [   55.907]                          [c6e66c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   62.287902] [   55.908]     [c6fa4160] new in dsscomp_gralloc_queue (refs=1)
[   62.287902] [   55.908]                         [c6e67800] dsscomp_new
[   62.287902] [   55.908]     [c6fa4160] ++refs=2 for [c6e67800]
[   62.317687] [   55.908]                         [c6e67800] dsscomp_delayed_apply
[   62.317718] [   55.908]     [c6fa4160] --refs=1 on RELEASED
[   62.317718] [   55.908]                         [c6e67800] dsscomp_apply
[   62.317718] [   55.924]                          [c6e66c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   62.347564] [   55.924]  [c6fa40a0] --refs=0 on RELEASED
[   62.347564] [   55.924]  [c6fa40a0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   62.347595] [   55.924]                          [c6e66c00] dsscomp_mgr_delayed_cb on RELEASED
[   62.347595] [   55.924]                         [c6e67800] dsscomp_mgr_delayed_cb on PROGRAMMED
[   62.377380] [   55.942]                         [c6e67800] dsscomp_mgr_delayed_cb on DISPLAYED
[   62.377410] [   61.370]   [c6edbbc0] new in dsscomp_gralloc_queue (refs=1)
[   62.377410] [   61.370]                          [c6f10800] dsscomp_new
[   62.405700] [   61.370]   [c6edbbc0] ++refs=2 for [c6f10800]
[   62.405700] [   61.370]                          [c6f10800] dsscomp_delayed_apply
[   62.405700] [   61.370]   [c6edbbc0] --refs=1 on RELEASED
[   62.405700] [   61.370]                          [c6f10800] dsscomp_apply
[   62.435577] [   61.370]     [c6fa4160] --refs=0 on RELEASED
[   62.435577] [   61.370]     [c6fa4160] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   62.435577] [   61.370]                         [c6e67800] dsscomp_mgr_delayed_cb on RELEASED
[   62.435577] [   61.370]                          [c6f10800] dsscomp_mgr_delayed_cb on PROGRAMMED
[   62.465362] [   61.371]    [c6edbc00] new in dsscomp_gralloc_queue (refs=1)
[   62.465362] [   61.371]                         [c6f11400] dsscomp_new
[   62.465362] [   61.371]    [c6edbc00] ++refs=2 for [c6f11400]
[   62.465362] [   61.371]                         [c6f11400] dsscomp_delayed_apply
[   62.495849] [   61.371]    [c6edbc00] --refs=1 on RELEASED
[   62.495849] [   61.371]                         [c6f11400] dsscomp_apply
[   62.495849] [   61.383]                          [c6f10800] dsscomp_mgr_delayed_cb on DISPLAYED
[   62.495849] [   61.383]   [c6edbbc0] --refs=0 on RELEASED
[   62.525726] [   61.383]   [c6edbbc0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   62.525726] [   61.383]                          [c6f10800] dsscomp_mgr_delayed_cb on RELEASED
[   62.525726] [   61.383]                         [c6f11400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   62.525726] [   61.400]                         [c6f11400] dsscomp_mgr_delayed_cb on DISPLAYED
[   62.555694] ACTIVE COMPOSITIONS on lcd
[   62.555694]
[   62.555694]   [c6f11400]: DISPLAYED
[   62.555694]     sync_id=0, flags=AD-
[   62.555694]     ovl0={ON z0 ARGB32-8888 premult *100% 864*480:0,0+864,480 rot0 => 0,0+864,480 7f358000/  (null)|3456}
[   62.555694]     gsync=[c6edbc00] dsscomp_gralloc_cb
[   62.588623]
[   62.588623]   DISPC pipeline:
[   62.588623]
[   62.588623]     info:        clean (none)
[   62.588623]     cache:       clean (none)
[   62.588623]     shadow:  ACT clean (none)
[   62.588623]     dispc:   DISPLAYED mask=---R [c6f11400] dsscomp_mgr_callback
[   62.588623]
[   62.588623] ACTIVE COMPOSITIONS on tv
[   62.588623]
[   62.588623]
[   62.588653]     info:        clean (none)
[   62.632263]     cache:       clean (none)
[   62.632263]     shadow:  off clean (none)
[   62.632263]     dispc:   DISPLAYED (none)
[   62.632263]
[   62.632263] ACTIVE COMPOSITIONS on lcd2
[   62.632263]
[   62.632263]   DISPC pipeline:
[   62.632263]
[   62.632263]     info:        clean (none)
[   62.632293]     cache:       clean (none)
[   62.632293]     shadow:  off clean (none)
[   62.672821]     dispc:             (none)
[   62.672821]
[   62.672851] ACTIVE GRALLOC FLIPS
[   62.672851]
[   62.672851]   [c6edbc00] (refs=1)
[   62.672851]     slots=[7f358000]
[   62.672851]     cmdcb=[c73f6900] dsscomp_proxy_cmdcomplete
[   62.672851]
[   62.672851]   |           lcd
[   62.672851]   | [c6f11400] DISPL'D
[   62.672851]   |     61.371  ACTIVE
[   62.672851]   |     61.371 APPLY'N
[   62.672851]   |     61.371 APPLIED
[   62.716400]   |     61.383 PROGR'D
[   62.716400]   |     61.400 DISPL'D
[   62.716400]
[   62.716400]
[   62.728118] PVR_K: SGX debug (blaze_android_sgx_ogles1_ogles2_GPL sgxddk 18 1.8@869593)
[   62.736694] PVR_K:(Error): SGX Register Base Address (Linear):   0xC8B20000 [0, ]
[   62.744720] PVR_K:(Error): SGX Register Base Address (Physical): 0x56000000 [0, ]
[   62.752716] PVR_K: (P0) EUR_CR_CORE_ID:          01140000
[   62.758514] PVR_K: (P0) EUR_CR_CORE_REVISION:    00010200
[   62.764343] PVR_K: (P0) EUR_CR_EVENT_STATUS:     20000000
[   62.770111] PVR_K: (P0) EUR_CR_EVENT_STATUS2:    00000008
[   62.775939] PVR_K: (P0) EUR_CR_BIF_CTRL:         00000000
[   62.781707] PVR_K: (P0) EUR_CR_BIF_INT_STAT:     00008000
[   62.787536] PVR_K: (P0) EUR_CR_BIF_FAULT:        00000000
[   62.793365] PVR_K: (P0) EUR_CR_BIF_MEM_REQ_STAT: 00000000
[   62.799163] PVR_K: (P0) EUR_CR_CLKGATECTL:       000AAA6A
[   62.804931] PVR_K: (P0) EUR_CR_PDS_PC_BASE:      00004038
[   62.810699] PVR_K: Flip Command Complete Data 0 for display device 1:
[   62.817626] PVR_K:   SRC 0: (Not in use)
[   62.821746] PVR_K: Flip Command Complete Data 1 for display device 1:
[   62.829467] PVR_K:   SRC 0: ROC DevVAddr:0xD800474 ROP:0xa ROC:0x8, WOC DevVAddr:0xD800464 WOP:0xa WOC:0x9
[   62.839782] PVR_K: SGX Host control:
[   62.843658] PVR_K:   (HC-0) 0x00000001 0x00000000 0x00000000 0x00000001
[   62.850891] PVR_K:   (HC-10) 0x0000000A 0x0000000A 0x0005DC00 0x00000003
[   62.858367] PVR_K:   (HC-20) 0x00000000 0x00000001 0x00000000 0x0000000E
[   62.865783] PVR_K:   (HC-30) 0x00000E09 0xF1C73944 0x00000000 0x00000000
[   62.873107] PVR_K:   (HC-40) 0x00000000 0x087BF500 0x087C6300 0x087C3100
[   62.880187] PVR_K: SGX TA/3D control:
[   62.884155] PVR_K:   (T3C-0) 0x0F003000 0x0F003120 0x0F002000 0x00000000
[   62.891265] PVR_K:   (T3C-10) 0x00000001 0x00000002 0x00000001 0x0F00DD00
[   62.898437] PVR_K:   (T3C-20) 0x00000000 0x00000000 0x00000000 0x00000000
[   62.905578] PVR_K:   (T3C-30) 0x00000000 0x00000000 0x00000000 0x00000000
[   62.912750] PVR_K:   (T3C-40) 0x00000000 0x00000000 0x00000000 0x00000000
[   62.919891] PVR_K:   (T3C-50) 0x0F00DD00 0x00000000 0x00000000 0x0F00DD00
[   62.927093] PVR_K:   (T3C-60) 0x00000000 0x00000000 0x0F00DD00 0x00000000
[   62.934295] PVR_K:   (T3C-70) 0x00000000 0x0F00DD00 0x00000000 0x0F004000
[   62.941467] PVR_K:   (T3C-80) 0x000001A3 0x0001120F 0x00000000 0x0F00DEB8
[   62.948669] PVR_K:   (T3C-90) 0x00000000 0x0F000000 0xAB600000 0x0F044800
[   62.955810] PVR_K:   (T3C-A0) 0x00000000 0x0F0109A0 0x0F00DD00 0x0F00DEB8
[   62.962982] PVR_K:   (T3C-B0) 0x0F010BE0 0x00000000 0x00000000 0x00000000
[   62.970153] PVR_K:   (T3C-C0) 0x00000000 0x00000000 0x00000000 0x00000000
[   62.977325] PVR_K:   (T3C-D0) 0x00000000 0x00000012 0x00000011 0x0F007000
[   62.984497] PVR_K:   (T3C-E0) 0x0F00D420 0x0F00E000 0x0F010720 0x0F010720
[   62.991638] PVR_K:   (T3C-F0) 0x00000000 0x000000B5 0x000000B5 0x00000000
[   62.998809] PVR_K:   (T3C-100) 0x00000003 0x00000000 0x00000000 0x00000001
[   63.006042] PVR_K:   (T3C-110) 0xB50C565C 0x0872E100 0x08787B00 0x08787B00
[   63.013336] PVR_K: Last SGX microkernel status code: AD000104
[   63.019500] PVR_K:   (MKT-0) 0000503D 00000808 0000121E 00000005
[   63.025817] PVR_K:   (MKT-1) 00005062 00000808 0000121E 00000006
[   63.032196] PVR_K:   (MKT-2) 000050D1 00000808 0000121E AD000184
[   63.038543] PVR_K:   (MKT-3) 00005134 00000C08 0100131D AD000281
[   63.044891] PVR_K:   (MKT-4) 000052A8 00000808 0100131D AD00080A
[   63.051208] PVR_K:   (MKT-5) 000052C0 00000808 0100131D 0F041800
[   63.057586] PVR_K:   (MKT-6) 000052D9 00000808 0100131D 00000062
[   63.063903] PVR_K:   (MKT-7) 00005590 00000808 0000131D AD000803
[   63.070281] PVR_K:   (MKT-8) 000055D6 00180C88 0000131D AD000282
[   63.076599] PVR_K:   (MKT-9) 000060E2 00000808 0100151F AD000200
[   63.082977] PVR_K:   (MKT-A) 000061FB 00000808 0000151F AD001703
[   63.089294] PVR_K:   (MKT-B) 000063D2 00000808 0000151F AD000202
[   63.095672] PVR_K:   (MKT-C) 00006547 00000808 0100171D AD000183
[   63.101989] PVR_K:   (MKT-D) 00006632 00000808 0100171D AD00030E
[   63.108367] PVR_K:   (MKT-E) 0000664A 00000808 0100171D 0D800494
[   63.114654] PVR_K:   (MKT-F) 00006663 00000808 0100171D 00000005
[   63.121032] PVR_K:   (MKT-10) 00006687 00000808 0100171D 00000006
[   63.127441] PVR_K:   (MKT-11) 00006715 00000808 0100171D AD000184
[   63.133911] PVR_K:   (MKT-12) 00017B76 00000808 01001A1F AD001A00
[   63.140380] PVR_K:   (MKT-13) 0002E415 00000808 01001E1F AD00000A
[   63.146789] PVR_K:   (MKT-14) 0002E47D 00000808 01001E1F AD000909
[   63.153259] PVR_K:   (MKT-15) 0002E4C8 00000808 01001E1F AD001A05
[   63.159667] PVR_K:   (MKT-16) 0002E4F9 00000808 01001E1F AD001302
[   63.166137] PVR_K:   (MKT-17) 0002E539 00000808 01001E1F AD001303
[   63.172546] PVR_K:   (MKT-18) 0002E5D0 00000808 01001E1F AD000D04
[   63.179016] PVR_K:   (MKT-19) 0002E698 00000808 01001E1F AD000D05
[   63.185424] PVR_K:   (MKT-1A) 0002E70B 00000808 01001E1F AD001A06
[   63.191864] PVR_K:   (MKT-1B) 000004E9 00100808 0100031F AD002300
[   63.198303] PVR_K:   (MKT-1C) 000009EC 00100808 0100041F AD00000A
[   63.204742] PVR_K:   (MKT-1D) 00000A5F 00100808 0100041F AD000905
[   63.211181] PVR_K:   (MKT-1E) 00000B98 00100808 0000041F AD000901
[   63.217651] PVR_K:   (MKT-1F) 00000C14 00100808 0000051E AD000183
[   63.224060] PVR_K:   (MKT-20) 00000D23 00100808 0000051E AD00030E
[   63.232086] PVR_K:   (MKT-21) 00000D3C 00100808 0000051E 0D800494
[   63.238555] PVR_K:   (MKT-22) 00000D56 00100808 0000051E 00000005
[   63.244995] PVR_K:   (MKT-23) 00000D7B 00100808 0000051E 00000006
[   63.251434] PVR_K:   (MKT-24) 00000DE8 00100808 0000051E AD000184
[   63.257873] PVR_K:   (MKT-25) 00000E67 00100C08 0100061D AD000281
[   63.264312] PVR_K:   (MKT-26) 00000F96 00100808 0000061D AD000E02
[   63.270721] PVR_K:   (MKT-27) 00001008 00100808 0000061D AD000282
[   63.277191] PVR_K:   (MKT-28) 000010C1 00100808 0100071F AD00000A
[   63.283599] PVR_K:   (MKT-29) 0000112C 00100808 0100071F AD000905
[   63.290039] PVR_K:   (MKT-2A) 00001237 00100808 0000071F AD000901
[   63.296447] PVR_K:   (MKT-2B) 000012A0 00100808 0000081E AD000183
[   63.302886] PVR_K:   (MKT-2C) 00001391 00100808 0000081E AD00030E
[   63.309295] PVR_K:   (MKT-2D) 000013AD 00100808 0000081E 0D800494
[   63.315765] PVR_K:   (MKT-2E) 000013C6 00100808 0000081E 00000005
[   63.322174] PVR_K:   (MKT-2F) 000013E9 00100808 0000081E 00000006
[   63.328613] PVR_K:   (MKT-30) 00001457 00100808 0000081E AD000184
[   63.335021] PVR_K:   (MKT-31) 000014C2 00100C08 0000091D AD000281
[   63.341461] PVR_K:   (MKT-32) 000015C5 00100808 0000091D AD000E02
[   63.347930] PVR_K:   (MKT-33) 00001638 00100808 0000091D AD000282
[   63.354370] PVR_K:   (MKT-34) 000016EA 00100808 01000A1F AD00000A
[   63.360809] PVR_K:   (MKT-35) 00001754 00100808 00000A1F AD000905
[   63.367218] PVR_K:   (MKT-36) 00001866 00100808 00000A1F AD000901
[   63.373870] PVR_K:   (MKT-37) 000018C9 00100808 00000B1E AD00000A
[   63.380737] PVR_K:   (MKT-38) 00001929 00100808 00000B1E AD000905
[   63.387176] PVR_K:   (MKT-39) 000019CF 00100808 00000B1E AD000901
[   63.393585] PVR_K:   (MKT-3A) 00001A3A 00100808 00000C1D AD000183
[   63.400115] PVR_K:   (MKT-3B) 00001B2A 00100808 00000C1D AD00030E
[   63.406524] PVR_K:   (MKT-3C) 00001B44 00100808 00000C1D 0D800494
[   63.413055] PVR_K:   (MKT-3D) 00001B5D 00100808 00000C1D 00000005
[   63.419464] PVR_K:   (MKT-3E) 00001B80 00100808 00000C1D 00000006
[   63.425933] PVR_K:   (MKT-3F) 00001BEB 00100808 00000C1D AD000184
[   63.432373] PVR_K:   (MKT-40) 00001C54 00100C08 01000D1C AD000281
[   63.438842] PVR_K:   (MKT-41) 00001D52 00100808 01000D1C AD000E02
[   63.445312] PVR_K:   (MKT-42) 00001DCB 00100808 01000D1C AD000282
[   63.451751] PVR_K:   (MKT-43) 00011E31 00100808 0100101F AD001A00
[   63.458221] PVR_K:   (MKT-44) 0002AB97 00100808 0100151F AD00000A
[   63.464660] PVR_K:   (MKT-45) 0002ABF8 00100808 0100151F AD000909
[   63.471405] PVR_K:   (MKT-46) 0002AC42 00100808 0100151F AD001A05
[   63.477844] PVR_K:   (MKT-47) 0002ACF6 00100808 0100151F AD001A06
[   63.484313] PVR_K:   (MKT-48) 000004C9 00100808 0100031F AD002300
[   63.490722] PVR_K:   (MKT-49) 000009C1 00100808 0100041F AD00000A
[   63.497253] PVR_K:   (MKT-4A) 00000A3D 00100808 0100041F AD000906
[   63.503662] PVR_K:   (MKT-4B) 00000B0D 00100808 0000041F AD000901
[   63.510101] PVR_K:   (MKT-4C) 00000B85 00100808 0000051E AD000183
[   63.516540] PVR_K:   (MKT-4D) 00000CFD 00100808 0000051E AD000302
[   63.523010] PVR_K:   (MKT-4E) 00000E84 00100808 0000051E AD000D06
[   63.529418] PVR_K:   (MKT-4F) 00000F6D 00100808 0000051E AD000D07
[   63.536651] PVR_K:   (MKT-50) 00000FB6 00100808 0000051E AD001304
[   63.543121] PVR_K:   (MKT-51) 000010A9 00100808 0000051E AD001305
[   63.549682] PVR_K:   (MKT-52) 000011BD 00100888 0000051E AD000404
[   63.556304] PVR_K:   (MKT-53) 00001284 00100808 0000051E AD000402
[   63.562805] PVR_K:   (MKT-54) 000012CD 0010082B 0000051E AD000184
[   63.569305] PVR_K:   (MKT-55) 00001353 00108DA9 0000061D AD000281
[   63.575714] PVR_K:   (MKT-56) 000014E5 001089AB 0000061D AD000E02
[   63.582183] PVR_K:   (MKT-57) 00001543 0010892B 0000061D AD000282
[   63.588592] PVR_K:   (MKT-58) 00003AE1 00100808 0000081F AD000101
[   63.595031] PVR_K:   (MKT-59) 00003B56 00100808 0000081F AD000104
[   63.601470] PVR_K:   (MKT-5A) 00003B94 00100808 0100091E AD000100
[   63.607910] PVR_K:   (MKT-5B) 00003C99 00100808 0100091E AD000501
[   63.614318] PVR_K:   (MKT-5C) 00003CD8 0010082B 0100091E AD000104
[   63.620758] PVR_K:   (MKT-5D) 00005F33 00100828 01000A1F AD000101
[   63.627197] PVR_K:   (MKT-5E) 00005F89 00100828 01000A1F AD000104
[   63.633636] PVR_K:   (MKT-5F) 00006096 00100808 01000B1F AD000100
[   63.640106] PVR_K:   (MKT-60) 00006150 00100808 01000B1F AD000501
[   63.646545] PVR_K:   (MKT-61) 0000617C 00100829 01000B1F AD000104
[   63.653045] PVR_K:   (MKT-62) 00008710 00100828 01000D1F AD000101
[   63.659820] PVR_K:   (MKT-63) 00008789 00100828 01000D1F AD000104
[   63.666290] PVR_K:   (MKT-64) 000087C6 00100808 01000E1E AD000100
[   63.672729] PVR_K:   (MKT-65) 000088C1 00100808 01000E1E AD000501
[   63.679199] PVR_K:   (MKT-66) 000088FF 00100829 01000E1E AD000104
[   63.685607] PVR_K:   (MKT-67) 091A3338 00100808 0100031F AD000B00
[   63.692077] PVR_K:   (MKT-68) 091A337F 00100808 0100031F AD000B03
[   63.698577] PVR_K:   (MKT-69) 091A3407 00100808 0100031F AD000B05
[   63.705047] PVR_K:   (MKT-6A) 091A345D 00100808 0100031F AD000B06
[   63.711456] PVR_K:   (MKT-6B) 091A348C 00100808 0100031F AD000B06
[   63.717895] PVR_K:   (MKT-6C) 091A34D0 00100808 0100031F AD000B07
[   63.724304] PVR_K:   (MKT-6D) 091A34F5 00100808 0100031F AD000B09
[   63.730773] PVR_K:   (MKT-6E) 091A354D 00100808 0100031F AD000B01
[   63.737182] PVR_K:   (MKT-6F) 091A3589 00100808 0100031F AD002300
[   63.743652] PVR_K:   (MKT-70) 091A3B59 00100808 0100041F AD00000A
[   63.750122] PVR_K:   (MKT-71) 091A3BD5 00100808 0100041F AD000906
[   63.756561] PVR_K:   (MKT-72) 091A3C96 00100808 0000041F AD000901
[   63.763031] PVR_K:   (MKT-73) 091A3D11 00100808 0000051E AD000183
[   63.769500] PVR_K:   (MKT-74) 091A3E88 00100808 0000051E AD000302
[   63.775970] PVR_K:   (MKT-75) 091A3EDB 00100808 0000051E AD000303
[   63.782379] PVR_K:   (MKT-76) 091A3F60 00100808 0000051E AD000C01
[   63.788848] PVR_K:   (MKT-77) 091A3F87 00100808 0000051E 0D800484
[   63.795257] PVR_K:   (MKT-78) 091A3F9F 00100808 0000051E 00000007
[   63.801727] PVR_K:   (MKT-79) 091A41F7 00100808 0000051E AD00030E
[   63.808197] PVR_K:   (MKT-7A) 091A420F 00100808 0000051E 0D800474
[   63.814666] PVR_K:   (MKT-7B) 091A4227 00100808 0000051E 00000006
[   63.821075] PVR_K:   (MKT-7C) 091A424B 00100808 0000051E 00000007
[   63.827575] PVR_K:   (MKT-7D) 091A42C4 00100808 0000051E AD000184
[   63.833953] PVR_K:   (MKT-7E) 091A4346 00100C08 0100061D AD000281
[   63.840423] PVR_K:   (MKT-7F) 091A44DD 00100808 0100061D AD00080A
[   63.847656] PVR_K:   (MKT-80) 091A44F6 00100808 0100061D 0F041B00
[   63.854217] PVR_K:   (MKT-81) 091A4511 00100808 0100061D 00000061
[   63.860717] PVR_K:   (MKT-82) 091A4630 00100C88 0100061D AD001300
[   63.867401] PVR_K:   (MKT-83) 091A9AAE 00100808 0000061D AD001301
[   63.874267] PVR_K:   (MKT-84) 091A9BDE 00100888 0000061D AD000802
[   63.880676] PVR_K:   (MKT-85) 091A9D50 00100888 0000061D AD000803
[   63.887145] PVR_K:   (MKT-86) 091A9DA4 001808C8 0000061D AD000282
[   63.893585] PVR_K:   (MKT-87) 091A9E87 00184AF8 0000081E AD00000A
[   63.900024] PVR_K:   (MKT-88) 091A9F11 00184AF8 0000081E AD000905
[   63.906433] PVR_K:   (MKT-89) 091AA02E 001808B8 0000081E AD000901
[   63.912872] PVR_K:   (MKT-8A) 091AA0A3 00180838 0000091C AD00000A
[   63.919311] PVR_K:   (MKT-8B) 091AA11C 00180838 0000091C AD000906
[   63.925750] PVR_K:   (MKT-8C) 091AA18D 00180838 0000091C AD000901
[   63.932189] PVR_K:   (MKT-8D) 091AA1E3 00180838 00000A1B AD00000A
[   63.938629] PVR_K:   (MKT-8E) 091AA248 00180838 00000A1B AD000905
[   63.945037] PVR_K:   (MKT-8F) 091AA2F6 00180838 00000A1B AD000901
[   63.951477] PVR_K:   (MKT-90) 091AA34A 00180838 00000B1A AD00000A
[   63.957916] PVR_K:   (MKT-91) 091AA3AB 00180838 00000B1A AD000905
[   63.964385] PVR_K:   (MKT-92) 091AA462 00180838 00000B1A AD000901
[   63.970855] PVR_K:   (MKT-93) 091AA4B9 00180838 00000C19 AD00000A
[   63.977264] PVR_K:   (MKT-94) 091AA521 00180838 00000C19 AD000905
[   63.983703] PVR_K:   (MKT-95) 091AA5C9 00180838 00000C19 AD000901
[   63.990112] PVR_K:   (MKT-96) 091AA71F 00180838 00000F1F AD000183
[   63.996551] PVR_K:   (MKT-97) 091AA8A9 00180838 00000F1F AD000302
[   64.002990] PVR_K:   (MKT-98) 091AA91C 00180838 00000F1F AD000303
[   64.009460] PVR_K:   (MKT-99) 091AA99E 00180838 00000F1F AD000C01
[   64.015869] PVR_K:   (MKT-9A) 091AA9C3 00180838 00000F1F 0D800464
[   64.022338] PVR_K:   (MKT-9B) 091AA9DC 00180838 00000F1F 00000008
[   64.028747] PVR_K:   (MKT-9C) 091AABF9 00180838 00000F1F AD000184
[   64.035217] PVR_K:   (MKT-9D) 091AAC65 00180C38 0100101D AD000281
[   64.041625] PVR_K:   (MKT-9E) 091AACC0 00180838 0100101D AD000282
[   64.048095] PVR_K:   (MKT-9F) 091ABB59 00180838 0100111F AD00000A
[   64.054534] PVR_K:   (MKT-A0) 091ABBC3 00180838 0100111F AD000905
[   64.061004] PVR_K:   (MKT-A1) 091ABCC6 00180838 0000111F AD000901
[   64.067443] PVR_K:   (MKT-A2) 091ABD17 00180C38 0100121E AD000281
[   64.073883] PVR_K:   (MKT-A3) 091ABD70 00180838 0100121E AD000282
[   64.080322] PVR_K:   (MKT-A4) 091ABE2A 00180838 0100131F AD00000A
[   64.086730] PVR_K:   (MKT-A5) 091ABE93 00100828 0100131F AD000905
[   64.093200] PVR_K:   (MKT-A6) 091ABF8E 00000808 0000131F AD000901
[   64.099609] PVR_K:   (MKT-A7) 091ABFC4 00000C08 0000141E AD000200
[   64.106079] PVR_K:   (MKT-A8) 091AC20D 00000808 0000141E AD000202
[   64.112487] PVR_K:   (MKT-A9) 091AC269 00000808 0000151D AD000281
[   64.118957] PVR_K:   (MKT-AA) 091AC3BC 00000808 0000151D AD00080A
[   64.125366] PVR_K:   (MKT-AB) 091AC3D6 00000808 0000151D 0F041E00
[   64.131805] PVR_K:   (MKT-AC) 091AC3EE 00000808 0000151D 00000060
[   64.138214] PVR_K:   (MKT-AD) 091AC6BB 00000808 0000151D AD000803
[   64.144653] PVR_K:   (MKT-AE) 091AC703 00180CC8 0000151D AD000282
[   64.151092] PVR_K:   (MKT-AF) 091AC7BC 00000808 0000161F AD00000A
[   64.157562] PVR_K:   (MKT-B0) 091AC825 00000808 0000161F AD000905
[   64.164031] PVR_K:   (MKT-B1) 091AC91E 00000888 0000161F AD000901
[   64.170501] PVR_K:   (MKT-B2) 091AC984 00000808 0000171E AD00000A
[   64.176971] PVR_K:   (MKT-B3) 091AC9E3 00000808 0000171E AD000905
[   64.184936] PVR_K:   (MKT-B4) 091ACA89 00000808 0000171E AD000901
[   64.191406] PVR_K:   (MKT-B5) 091ACAD1 00000C08 0000191D AD000200
[   64.197814] PVR_K:   (MKT-B6) 091ACD00 00000808 0000191D AD000202
[   64.204284] PVR_K:   (MKT-B7) 091ACD57 00000808 01001A1B AD000281
[   64.210693] PVR_K:   (MKT-B8) 091ACEA3 00000808 01001A1B AD00080A
[   64.217132] PVR_K:   (MKT-B9) 091ACEBC 00000808 01001A1B 0F042100
[   64.223541] PVR_K:   (MKT-BA) 091ACED4 00000808 01001A1B 00000060
[   64.230010] PVR_K:   (MKT-BB) 091AD190 00000808 00001A1B AD000803
[   64.236419] PVR_K:   (MKT-BC) 091AD1D6 00180CC8 00001A1B AD000282
[   64.242858] PVR_K:   (MKT-BD) 091AD2C0 00000808 01001C1F AD000200
[   64.249298] PVR_K:   (MKT-BE) 091AD4F3 00000808 01001C1F AD000202
[   64.255737] PVR_K:   (MKT-BF) 091AD543 00000808 01001D1E AD000281
[   64.262176] PVR_K:   (MKT-C0) 091AD691 00000808 01001D1E AD00080A
[   64.268615] PVR_K:   (MKT-C1) 091AD6AC 00000808 01001D1E 0F042400
[   64.275085] PVR_K:   (MKT-C2) 091AD6C5 00000808 01001D1E 00000062
[   64.281494] PVR_K:   (MKT-C3) 091AD980 00000808 00001D1E AD000803
[   64.288116] PVR_K:   (MKT-C4) 091AD9C7 00180C88 00001D1E AD000282
[   64.294525] PVR_K:   (MKT-C5) 091AE4FB 00000808 01001F1F AD000200
[   64.301177] PVR_K:   (MKT-C6) 091AE61E 00000808 01001F1F AD001703
[   64.307617] PVR_K:   (MKT-C7) 091AE82B 00000808 00001F1F AD000202
[   64.314086] PVR_K:   (MKT-C8) 091AE8AA 00000808 0000201E AD000183
[   64.320495] PVR_K:   (MKT-C9) 091AE99A 00000808 0000201E AD00030E
[   64.327056] PVR_K:   (MKT-CA) 091AE9B2 00000808 0000201E 0D800494
[   64.333435] PVR_K:   (MKT-CB) 091AE9CB 00000808 0000201E 00000006
[   64.339904] PVR_K:   (MKT-CC) 091AE9EF 00000808 0000201E 00000007
[   64.346343] PVR_K:   (MKT-CD) 091AEA5B 00000808 0000201E AD000184
[   64.352813] PVR_K:   (MKT-CE) 091AEAC2 00000C08 0100211D AD000281
[   64.359252] PVR_K:   (MKT-CF) 091AEC43 00000808 0100211D AD00080A
[   64.365722] PVR_K:   (MKT-D0) 091AEC5C 00000808 0100211D 0F042700
[   64.372161] PVR_K:   (MKT-D1) 091AEC75 00000808 0100211D 00000061
[   64.378631] PVR_K:   (MKT-D2) 091AEDEE 00000808 0000211D AD000802
[   64.385284] PVR_K:   (MKT-D3) 091AEF43 00000808 0000211D AD000803
[   64.391723] PVR_K:   (MKT-D4) 091AEF8E 00184EC8 0000211D AD000282
[   64.398193] PVR_K:   (MKT-D5) 091B1078 00000C08 0100241F AD000200
[   64.404632] PVR_K:   (MKT-D6) 091B12D8 00000808 0000241F AD000202
[   64.411132] PVR_K:   (MKT-D7) 091B136A 00000808 0000251E AD000183
[   64.417541] PVR_K:   (MKT-D8) 091B1456 00000808 0000251E AD00030E
[   64.424011] PVR_K:   (MKT-D9) 091B146E 00000808 0000251E 0D800494
[   64.430419] PVR_K:   (MKT-DA) 091B1488 00000808 0000251E 00000006
[   64.436889] PVR_K:   (MKT-DB) 091B14AF 00000808 0000251E 00000007
[   64.443298] PVR_K:   (MKT-DC) 091B151D 00000808 0000251E AD000184
[   64.450500] PVR_K:   (MKT-DD) 091B1584 00000C08 0100261D AD000281
[   64.456970] PVR_K:   (MKT-DE) 091B16F7 00000808 0100261D AD00080A
[   64.463562] PVR_K:   (MKT-DF) 091B1710 00000808 0100261D 0F042A00
[   64.470123] PVR_K:   (MKT-E0) 091B1728 00000808 0100261D 00000060
[   64.476715] PVR_K:   (MKT-E1) 091B19E9 00000808 0000261D AD000803
[   64.483215] PVR_K:   (MKT-E2) 091B1A31 00180CC8 0000261D AD000282
[   64.489654] PVR_K:   (MKT-E3) 091B1AD4 00000808 0100281F AD000200
[   64.496124] PVR_K:   (MKT-E4) 091B1CFE 00000808 0000281F AD000202
[   64.502532] PVR_K:   (MKT-E5) 091B1D84 00000808 0000291E AD000183
[   64.509002] PVR_K:   (MKT-E6) 091B1E6D 00000808 0000291E AD00030E
[   64.515411] PVR_K:   (MKT-E7) 091B1E85 00000808 0000291E 0D800494
[   64.521850] PVR_K:   (MKT-E8) 091B1E9E 00000808 0000291E 00000006
[   64.528259] PVR_K:   (MKT-E9) 091B1EC3 00000808 0000291E 00000007
[   64.534698] PVR_K:   (MKT-EA) 091B1F2E 00000808 0000291E AD000184
[   64.541137] PVR_K:   (MKT-EB) 091B1F95 00000C08 01002A1D AD000281
[   64.547576] PVR_K:   (MKT-EC) 091B2106 00000808 01002A1D AD00080A
[   64.553985] PVR_K:   (MKT-ED) 091B211E 00000808 01002A1D 0F042D00
[   64.560424] PVR_K:   (MKT-EE) 091B2137 00000808 01002A1D 00000060
[   64.566864] PVR_K:   (MKT-EF) 091B23FC 00000808 00002A1D AD000803
[   64.573333] PVR_K:   (MKT-F0) 091B2443 00180CC8 00002A1D AD000282
[   64.579742] PVR_K:   (MKT-F1) 091B252F 00000808 01002C1F AD000200
[   64.586212] PVR_K:   (MKT-F2) 091B2750 00000808 00002C1F AD000202
[   64.592681] PVR_K:   (MKT-F3) 091B27D0 00000808 00002D1E AD000183
[   64.599060] PVR_K:   (MKT-F4) 091B28BD 00000808 00002D1E AD00030E
[   64.605560] PVR_K:   (MKT-F5) 091B28D7 00000808 00002D1E 0D800494
[   64.611968] PVR_K:   (MKT-F6) 091B28F1 00000808 00002D1E 00000006
[   64.618438] PVR_K:   (MKT-F7) 091B2916 00000808 00002D1E 00000007
[   64.625579] PVR_K:   (MKT-F8) 091B2980 00000808 00002D1E AD000184
[   64.632049] PVR_K:   (MKT-F9) 091B29EB 00000C08 01002E1D AD000281
[   64.638458] PVR_K:   (MKT-FA) 091B2B64 00000808 01002E1D AD00080A
[   64.644897] PVR_K:   (MKT-FB) 091B2B7D 00000808 01002E1D 0F043000
[   64.651306] PVR_K:   (MKT-FC) 091B2B96 00000808 01002E1D 00000062
[   64.657775] PVR_K:   (MKT-FD) 091B2E54 00000808 00002E1D AD000803
[   64.664215] PVR_K:   (MKT-FE) 091B2E9C 00180C88 00002E1D AD000282
[   64.670654] PVR_K:   (MKT-FF) 091B3A62 00000808 0100301F AD000200
[   64.677154] PVR_K:   (MKT-100) 091B3B7F 00000808 0100301F AD001703
[   64.683715] PVR_K:   (MKT-101) 091B3D68 00000808 0000301F AD000202
[   64.690246] PVR_K:   (MKT-102) 091B3DE7 00000808 0000311E AD000183
[   64.696838] PVR_K:   (MKT-103) 091B3ED4 00000808 0000311E AD00030E
[   64.703399] PVR_K:   (MKT-104) 091B3EF4 00000808 0000311E 0D800494
[   64.709899] PVR_K:   (MKT-105) 091B3F0D 00000808 0000311E 00000006
[   64.716430] PVR_K:   (MKT-106) 091B3F35 00000808 0000311E 00000007
[   64.722961] PVR_K:   (MKT-107) 091B3F9F 00000808 0000311E AD000184
[   64.729522] PVR_K:   (MKT-108) 091B4003 00000C08 0100321D AD000281
[   64.736022] PVR_K:   (MKT-109) 091B4118 00000808 0100321D AD000E02
[   64.742584] PVR_K:   (MKT-10A) 091B418D 00000808 0100321D AD000282
[   64.749084] PVR_K:   (MKT-10B) 091C0A78 00000808 0100351F AD001A00
[   64.755645] PVR_K:   (MKT-10C) 091DB904 00000808 01003A1F AD00000A
[   64.762237] PVR_K:   (MKT-10D) 091DB967 00000808 01003A1F AD000909
[   64.768798] PVR_K:   (MKT-10E) 091DB9B2 00000808 01003A1F AD001A05
[   64.775360] PVR_K:   (MKT-10F) 091DB9E3 00000808 01003A1F AD001302
[   64.781860] PVR_K:   (MKT-110) 091DBA24 00000808 01003A1F AD001303
[   64.788421] PVR_K:   (MKT-111) 091DBABD 00000808 01003A1F AD000D04
[   64.794921] PVR_K:   (MKT-112) 091DBB96 00000808 01003A1F AD000D05
[   64.801483] PVR_K:   (MKT-113) 091DBBEF 00000808 01003A1F AD000D04
[   64.807983] PVR_K:   (MKT-114) 091DBC79 00000808 01003A1F AD000D05
[   64.814514] PVR_K:   (MKT-115) 091DBCD8 00000808 01003A1F AD001A06
[   64.821014] PVR_K:   (MKT-116) 000004D5 00100808 0100031F AD002300
[   64.827575] PVR_K:   (MKT-117) 000009DA 00100808 0100041F AD00000A
[   64.834045] PVR_K:   (MKT-118) 00000A58 00100808 0100041F AD000906
[   64.840606] PVR_K:   (MKT-119) 00000B2A 00100808 0000041F AD000901
[   64.847106] PVR_K:   (MKT-11A) 00000BA4 00100808 0000051E AD000183
[   64.853637] PVR_K:   (MKT-11B) 00000D22 00100808 0000051E AD000302
[   64.860198] PVR_K:   (MKT-11C) 00000EAF 00100808 0000051E AD000D06
[   64.866729] PVR_K:   (MKT-11D) 00000F9D 00100808 0000051E AD000D07
[   64.873260] PVR_K:   (MKT-11E) 00000FE7 00100808 0000051E AD001304
[   64.879791] PVR_K:   (MKT-11F) 000010DC 00100808 0000051E AD001305
[   64.886322] PVR_K:   (MKT-120) 000011F3 00100888 0000051E AD000404
[   64.892822] PVR_K:   (MKT-121) 000012B8 00100808 0000051E AD000402
[   64.899383] PVR_K:   (MKT-122) 00001300 0010082B 0000051E AD000184
[   64.905853] PVR_K:   (MKT-123) 0000139E 00119DA9 0000061D AD000281
[   64.912384] PVR_K:   (MKT-124) 00001530 001089AF 0000061D AD000E02
[   64.918914] PVR_K:   (MKT-125) 00001589 0010892B 0000061D AD000282
[   64.925445] PVR_K:   (MKT-126) 00003B65 00100808 0000081F AD000101
[   64.931945] PVR_K:   (MKT-127) 00003BDD 00100808 0000081F AD000104
[   64.938507] PVR_K:   (MKT-128) 00003C1C 00100808 0100091E AD000100
[   64.945037] PVR_K:   (MKT-129) 00003D29 00100808 0100091E AD000501
[   64.951538] PVR_K:   (MKT-12A) 00003D69 00100829 0100091E AD000104
[   64.958068] PVR_K:   (MKT-12B) 00005FFE 00100828 01000A1F AD000101
[   64.964569] PVR_K:   (MKT-12C) 00006058 00100828 01000A1F AD000104
[   64.971160] PVR_K:   (MKT-12D) 00006170 00100808 01000B1F AD000100
[   64.977661] PVR_K:   (MKT-12E) 00006240 00100808 01000B1F AD000501
[   64.984222] PVR_K:   (MKT-12F) 00006276 00100829 00000B1F AD000104
[   64.990692] PVR_K:   (MKT-130) 000087D6 00100828 01000D1F AD000101
[   64.997253] PVR_K:   (MKT-131) 0000884B 00100828 01000D1F AD000104
[   65.003753] PVR_K:   (MKT-132) 00008889 00100808 01000E1E AD000100
[   65.010314] PVR_K:   (MKT-133) 00008987 00100808 01000E1E AD000501
[   65.016815] PVR_K:   (MKT-134) 000089C6 00100829 01000E1E AD000104
[   65.023345] PVR_K:   (MKT-135) 07CA4DA4 00100808 0100031F AD000B00
[   65.029876] PVR_K:   (MKT-136) 07CA4DEA 00100808 0100031F AD000B03
[   65.036376] PVR_K:   (MKT-137) 07CA4E70 00100808 0100031F AD000B05
[   65.042938] PVR_K:   (MKT-138) 07CA4EC5 00100808 0100031F AD000B06
[   65.049438] PVR_K:   (MKT-139) 07CA4EF4 00100808 0100031F AD000B06
[   65.055999] PVR_K:   (MKT-13A) 07CA4F37 00100808 0100031F AD000B07
[   65.062469] PVR_K:   (MKT-13B) 07CA4F5C 00100808 0100031F AD000B09
[   65.069030] PVR_K:   (MKT-13C) 07CA4FB1 00100808 0100031F AD000B01
[   65.075531] PVR_K:   (MKT-13D) 07CA4FED 00100808 0100031F AD002300
[   65.082092] PVR_K:   (MKT-13E) 07CA52FD 00100808 0100041F AD00000A
[   65.088592] PVR_K:   (MKT-13F) 07CA537E 00100808 0100041F AD000906
[   65.095123] PVR_K:   (MKT-140) 07CA5438 00100808 0000041F AD000901
[   65.101623] PVR_K:   (MKT-141) 07CA54B2 00100808 0000051E AD000183
[   65.108154] PVR_K:   (MKT-142) 07CA561D 00100808 0000051E AD000302
[   65.114715] PVR_K:   (MKT-143) 07CA5678 00100808 0000051E AD000303
[   65.121215] PVR_K:   (MKT-144) 07CA56FC 00100808 0000051E AD000C01
[   65.127746] PVR_K:   (MKT-145) 07CA5720 00100808 0000051E 0D800484
[   65.134246] PVR_K:   (MKT-146) 07CA5739 00100808 0000051E 00000008
[   65.140808] PVR_K:   (MKT-147) 07CA5986 00100808 0000051E AD00030E
[   65.147308] PVR_K:   (MKT-148) 07CA599E 00100808 0000051E 0D800474
[   65.153839] PVR_K:   (MKT-149) 07CA59B6 00100808 0000051E 00000007
[   65.160339] PVR_K:   (MKT-14A) 07CA59DB 00100808 0000051E 00000008
[   65.166870] PVR_K:   (MKT-14B) 07CA5A52 00100808 0000051E AD000184
[   65.173400] PVR_K:   (MKT-14C) 07CA5ACF 00100C08 0100061D AD000281
[   65.179962] PVR_K:   (MKT-14D) 07CA5C6A 00100808 0100061D AD00080A
[   65.186462] PVR_K:   (MKT-14E) 07CA5C82 00100808 0100061D 0F043300
[   65.192962] PVR_K:   (MKT-14F) 07CA5C9B 00100808 0100061D 00000061
[   65.199523] PVR_K:   (MKT-150) 07CA5DB1 00100C08 0000061D AD001300
[   65.206024] PVR_K:   (MKT-151) 07CAB15F 00100808 0000061D AD001301
[   65.212554] PVR_K:   (MKT-152) 07CAB288 00100888 0000061D AD000802
[   65.219055] PVR_K:   (MKT-153) 07CAB3EA 00100888 0000061D AD000803
[   65.225585] PVR_K:   (MKT-154) 07CAB43A 001808C8 0000061D AD000282
[   65.232086] PVR_K:   (MKT-155) 07CAB520 00184AF8 0000081E AD00000A
[   65.238616] PVR_K:   (MKT-156) 07CAB5A2 00184AF8 0000081E AD000905
[   65.245117] PVR_K:   (MKT-157) 07CAB6B9 001808B8 0000081E AD000901
[   65.251647] PVR_K:   (MKT-158) 07CAB72A 00180838 0000091C AD00000A
[   65.258148] PVR_K:   (MKT-159) 07CAB797 00180838 0000091C AD000905
[   65.264709] PVR_K:   (MKT-15A) 07CAB843 00180838 0000091C AD000901
[   65.271240] PVR_K:   (MKT-15B) 07CAB89D 00180838 00000A1B AD00000A
[   65.277740] PVR_K:   (MKT-15C) 07CAB912 00180838 00000A1B AD000906
[   65.284301] PVR_K:   (MKT-15D) 07CAB98E 00180838 00000A1B AD000901
[   65.290802] PVR_K:   (MKT-15E) 07CAB9EA 00180838 00000B1A AD00000A
[   65.297332] PVR_K:   (MKT-15F) 07CABA5B 00180838 00000B1A AD000905
[   65.303863] PVR_K:   (MKT-160) 07CABB05 00180838 00000B1A AD000901
[   65.310394] PVR_K:   (MKT-161) 07CABB5E 00180838 00000C19 AD00000A
[   65.316894] PVR_K:   (MKT-162) 07CABBC8 00180838 00000C19 AD000905
[   65.323425] PVR_K:   (MKT-163) 07CABC7F 00180838 00000C19 AD000901
[   65.329925] PVR_K:   (MKT-164) 07CABDCE 00180838 00000F1F AD000183
[   65.336486] PVR_K:   (MKT-165) 07CABF4F 00180838 00000F1F AD000302
[   65.342987] PVR_K:   (MKT-166) 07CABFC4 00180838 00000F1F AD000303
[   65.349517] PVR_K:   (MKT-167) 07CAC04B 00180838 00000F1F AD000C01
[   65.356048] PVR_K:   (MKT-168) 07CAC072 00180838 00000F1F 0D800464
[   65.362579] PVR_K:   (MKT-169) 07CAC08A 00180838 00000F1F 00000009
[   65.369110] PVR_K:   (MKT-16A) 07CAC2A2 00180838 00000F1F AD000184
[   65.375640] PVR_K:   (MKT-16B) 07CAC314 00180C38 0100101D AD000281
[   65.382171] PVR_K:   (MKT-16C) 07CAC36A 00180838 0100101D AD000282
[   65.388671] PVR_K:   (MKT-16D) 07CAD075 00180838 0100111F AD00000A
[   65.395202] PVR_K:   (MKT-16E) 07CAD0DF 00180838 0100111F AD000905
[   65.401702] PVR_K:   (MKT-16F) 07CAD1DF 00180838 0000111F AD000901
[   65.408264] PVR_K:   (MKT-170) 07CAD22F 00180C38 0100121E AD000281
[   65.414733] PVR_K:   (MKT-171) 07CAD289 00180838 0100121E AD000282
[   65.421295] PVR_K:   (MKT-172) 07CAD3DE 00180838 0100131F AD00000A
[   65.427795] PVR_K:   (MKT-173) 07CAD447 00180838 0100131F AD000905
[   65.434326] PVR_K:   (MKT-174) 07CAD540 00100828 0000131F AD000901
[   65.440887] PVR_K:   (MKT-175) 07CAD592 00000C08 0000141E AD000281
[   65.447387] PVR_K:   (MKT-176) 07CAD5E8 00000808 0000141E AD000282
[   65.453918] PVR_K:   (MKT-177) 07CAD633 00000808 0100151F AD000200
[   65.460418] PVR_K:   (MKT-178) 07CAD885 00000808 0000151F AD000202
[   65.467041] PVR_K:   (MKT-179) 07CAD930 00000808 0000161E AD00000A
[   65.473541] PVR_K:   (MKT-17A) 07CAD999 00000808 0000161E AD000905
[   65.480102] PVR_K:   (MKT-17B) 07CADA88 00000808 0000161E AD000901
[   65.486633] PVR_K:   (MKT-17C) 07CADAD8 00000C08 0000171D AD000281
[   65.493194] PVR_K:   (MKT-17D) 07CADC3D 00000808 0000171D AD00080A
[   65.499694] PVR_K:   (MKT-17E) 07CADC56 00000808 0000171D 0F043600
[   65.507141] PVR_K:   (MKT-17F) 07CADC6E 00000808 0000171D 00000060
[   65.513641] PVR_K:   (MKT-180) 07CADF22 00000808 0000171D AD000803
[   65.520263] PVR_K:   (MKT-181) 07CADF68 00180CC8 0000171D AD000282
[   65.527038] PVR_K:   (MKT-182) 07CAE01C 00000808 0000181F AD00000A
[   65.533813] PVR_K:   (MKT-183) 07CAE086 00000808 0000181F AD000905
[   65.540344] PVR_K:   (MKT-184) 07CAE17B 00000888 0000181F AD000901
[   65.546874] PVR_K:   (MKT-185) 07CAE1C4 00000C08 00001A1D AD000200
[   65.553405] PVR_K:   (MKT-186) 07CAE3F1 00000808 00001A1D AD000202
[   65.559906] PVR_K:   (MKT-187) 07CAE448 00000808 01001B1C AD000281
[   65.566467] PVR_K:   (MKT-188) 07CAE593 00000808 01001B1C AD00080A
[   65.573913] PVR_K:   (MKT-189) 07CAE5AC 00000808 01001B1C 0F043900
[   65.580505] PVR_K:   (MKT-18A) 07CAE5C4 00000808 01001B1C 00000060
[   65.587005] PVR_K:   (MKT-18B) 07CAE87F 00000808 00001B1C AD000803
[   65.593536] PVR_K:   (MKT-18C) 07CAE8C5 00180CC8 00001B1C AD000282
[   65.600036] PVR_K:   (MKT-18D) 07CAE9A9 00000808 01001D1F AD000200
[   65.606597] PVR_K:   (MKT-18E) 07CAEBD2 00000808 01001D1F AD000202
[   65.613159] PVR_K:   (MKT-18F) 07CAEC22 00000808 01001E1E AD000281
[   65.619659] PVR_K:   (MKT-190) 07CAED6D 00000808 01001E1E AD00080A
[   65.626190] PVR_K:   (MKT-191) 07CAED85 00000808 01001E1E 0F043C00
[   65.632720] PVR_K:   (MKT-192) 07CAED9E 00000808 01001E1E 00000062
[   65.639251] PVR_K:   (MKT-193) 07CAF056 00000808 00001E1E AD000803
[   65.645751] PVR_K:   (MKT-194) 07CAF09E 00180C88 00001E1E AD000282
[   65.652282] PVR_K:   (MKT-195) 07CAFBD3 00000808 0100201F AD000200
[   65.658813] PVR_K:   (MKT-196) 07CAFCF1 00000808 0100201F AD001703
[   65.665344] PVR_K:   (MKT-197) 07CAFEF0 00000808 0000201F AD000202
[   65.671844] PVR_K:   (MKT-198) 07CAFF6D 00000808 0000211E AD000183
[   65.678375] PVR_K:   (MKT-199) 07CB005B 00000808 0000211E AD00030E
[   65.684906] PVR_K:   (MKT-19A) 07CB0073 00000808 0000211E 0D800494
[   65.691497] PVR_K:   (MKT-19B) 07CB008D 00000808 0000211E 00000007
[   65.698059] PVR_K:   (MKT-19C) 07CB00B1 00000808 0000211E 00000008
[   65.704589] PVR_K:   (MKT-19D) 07CB011B 00000808 0000211E AD000184
[   65.711944] PVR_K:   (MKT-19E) 07CB017F 00000C08 0100221D AD000281
[   65.718444] PVR_K:   (MKT-19F) 07CB02F5 00000808 0100221D AD00080A
[   65.725006] PVR_K:   (MKT-1A0) 07CB030E 00000808 0100221D 0F043F00
[   65.731506] PVR_K:   (MKT-1A1) 07CB0326 00000808 0100221D 00000061
[   65.738159] PVR_K:   (MKT-1A2) 07CB04A6 00000808 0000221D AD000802
[   65.744659] PVR_K:   (MKT-1A3) 07CB05F5 00000808 0000221D AD000803
[   65.751220] PVR_K:   (MKT-1A4) 07CB063A 00184EC8 0000221D AD000282
[   65.757965] PVR_K:   (MKT-1A5) 07CB25FC 00000C08 0100251F AD000200
[   65.764526] PVR_K:   (MKT-1A6) 07CB284C 00000808 0000251F AD000202
[   65.771026] PVR_K:   (MKT-1A7) 07CB28D3 00000808 0000261E AD000183
[   65.777587] PVR_K:   (MKT-1A8) 07CB29BB 00000808 0000261E AD00030E
[   65.784149] PVR_K:   (MKT-1A9) 07CB29D3 00000808 0000261E 0D800494
[   65.790679] PVR_K:   (MKT-1AA) 07CB29EC 00000808 0000261E 00000007
[   65.797210] PVR_K:   (MKT-1AB) 07CB2A0F 00000808 0000261E 00000008
[   65.803771] PVR_K:   (MKT-1AC) 07CB2A79 00000808 0000261E AD000184
[   65.810302] PVR_K:   (MKT-1AD) 07CB2ADF 00000C08 0100271D AD000281
[   65.816833] PVR_K:   (MKT-1AE) 07CB2C4B 00000808 0100271D AD00080A
[   65.823486] PVR_K:   (MKT-1AF) 07CB2C64 00000808 0100271D 0F044200
[   65.830017] PVR_K:   (MKT-1B0) 07CB2C7C 00000808 0100271D 00000060
[   65.836639] PVR_K:   (MKT-1B1) 07CB2F2E 00000808 0000271D AD000803
[   65.843231] PVR_K:   (MKT-1B2) 07CB2F74 00180CC8 0000271D AD000282
[   65.849792] PVR_K:   (MKT-1B3) 07CB3016 00000808 0100291F AD000200
[   65.856292] PVR_K:   (MKT-1B4) 07CB3231 00000808 0000291F AD000202
[   65.863006] PVR_K:   (MKT-1B5) 07CB32AF 00000808 00002A1E AD000183
[   65.869567] PVR_K:   (MKT-1B6) 07CB339C 00000808 00002A1E AD00030E
[   65.876098] PVR_K:   (MKT-1B7) 07CB33B4 00000808 00002A1E 0D800494
[   65.883605] PVR_K:   (MKT-1B8) 07CB33CD 00000808 00002A1E 00000007
[   65.890167] PVR_K:   (MKT-1B9) 07CB33F0 00000808 00002A1E 00000008
[   65.896728] PVR_K:   (MKT-1BA) 07CB345A 00000808 00002A1E AD000184
[   65.903289] PVR_K:   (MKT-1BB) 07CB34BE 00000C08 01002B1D AD000281
[   65.909851] PVR_K:   (MKT-1BC) 07CB3625 00000808 01002B1D AD00080A
[   65.917144] PVR_K:   (MKT-1BD) 07CB363E 00000808 01002B1D 0F044500
[   65.923706] PVR_K:   (MKT-1BE) 07CB3656 00000808 01002B1D 00000060
[   65.930999] PVR_K:   (MKT-1BF) 07CB390C 00000808 00002B1D AD000803
[   65.937591] PVR_K:   (MKT-1C0) 07CB3952 00180CC8 00002B1D AD000282
[   65.944091] PVR_K:   (MKT-1C1) 07CB3A3C 00000808 01002D1F AD000200
[   65.950653] PVR_K:   (MKT-1C2) 07CB3C53 00000808 00002D1F AD000202
[   65.957244] PVR_K:   (MKT-1C3) 07CB3CD5 00000808 00002E1E AD000183
[   65.964233] PVR_K:   (MKT-1C4) 07CB3DC0 00000808 00002E1E AD00030E
[   65.970825] PVR_K:   (MKT-1C5) 07CB3DD8 00000808 00002E1E 0D800494
[   65.977325] PVR_K:   (MKT-1C6) 07CB3DF1 00000808 00002E1E 00000007
[   65.983917] PVR_K:   (MKT-1C7) 07CB3E14 00000808 00002E1E 00000008
[   65.990417] PVR_K:   (MKT-1C8) 07CB3E82 00000808 00002E1E AD000184
[   65.996948] PVR_K:   (MKT-1C9) 07CB3EE7 00000C08 01002F1D AD000281
[   66.003509] PVR_K:   (MKT-1CA) 07CB4056 00000808 01002F1D AD00080A
[   66.010070] PVR_K:   (MKT-1CB) 07CB406E 00000808 01002F1D 0F044800
[   66.016571] PVR_K:   (MKT-1CC) 07CB4086 00000808 01002F1D 00000062
[   66.023132] PVR_K:   (MKT-1CD) 07CB4336 00000808 00002F1D AD000803
[   66.029663] PVR_K:   (MKT-1CE) 07CB437D 00180C88 00002F1D AD000282
[   66.036163] PVR_K:   (MKT-1CF) 07CB4EC6 00000808 0100311F AD000200
[   66.042724] PVR_K:   (MKT-1D0) 07CB4FE1 00000808 0100311F AD001703
[   66.049255] PVR_K:   (MKT-1D1) 07CB51C1 00000808 0000311F AD000202
[   66.055816] PVR_K:   (MKT-1D2) 07CB523E 00000808 0000321E AD000183
[   66.062316] PVR_K:   (MKT-1D3) 07CB5329 00000808 0000321E AD00030E
[   66.068878] PVR_K:   (MKT-1D4) 07CB5341 00000808 0000321E 0D800494
[   66.075378] PVR_K:   (MKT-1D5) 07CB5359 00000808 0000321E 00000007
[   66.081970] PVR_K:   (MKT-1D6) 07CB5380 00000808 0000321E 00000008
[   66.088470] PVR_K:   (MKT-1D7) 07CB53EA 00000808 0000321E AD000184
[   66.095031] PVR_K:   (MKT-1D8) 07CB544F 00000C08 0100331D AD000281
[   66.101562] PVR_K:   (MKT-1D9) 07CB5560 00000808 0100331D AD000E02
[   66.108123] PVR_K:   (MKT-1DA) 07CB55D4 00000808 0100331D AD000282
[   66.114685] PVR_K:   (MKT-1DB) 07CC24DB 00000808 0100361F AD001A00
[   66.121215] PVR_K:   (MKT-1DC) 07CC27F3 00000808 0100371F AD00000A
[   66.127777] PVR_K:   (MKT-1DD) 07CC2854 00000808 0100371F AD000909
[   66.134307] PVR_K:   (MKT-1DE) 07CC289E 00000808 0100371F AD001A05
[   66.141021] PVR_K:   (MKT-1DF) 07CC28CF 00000808 0100371F AD001302
[   66.147521] PVR_K:   (MKT-1E0) 07CC290E 00000808 0100371F AD001303
[   66.154083] PVR_K:   (MKT-1E1) 07CC29A0 00000808 0100371F AD000D04
[   66.160583] PVR_K:   (MKT-1E2) 07CC2A6E 00000808 0100371F AD000D05
[   66.167144] PVR_K:   (MKT-1E3) 07CC2AC8 00000808 0100371F AD000D04
[   66.173645] PVR_K:   (MKT-1E4) 07CC2B4E 00000808 0100371F AD000D05
[   66.180175] PVR_K:   (MKT-1E5) 07CC2BAB 00000808 0100371F AD001A06
[   66.186676] PVR_K:   (MKT-1E6) 00000460 00100808 0100031F AD002300
[   66.193237] PVR_K:   (MKT-1E7) 0000093A 00100808 0100041F AD00000A
[   66.199768] PVR_K:   (MKT-1E8) 000009B7 00100808 0100041F AD000906
[   66.206268] PVR_K:   (MKT-1E9) 00000A84 00100808 0000041F AD000901
[   66.212799] PVR_K:   (MKT-1EA) 00000AFE 00100808 0000051E AD000183
[   66.219299] PVR_K:   (MKT-1EB) 00000C74 00100808 0000051E AD000302
[   66.225860] PVR_K:   (MKT-1EC) 00000DFD 00100808 0000051E AD000D06
[   66.232360] PVR_K:   (MKT-1ED) 00000EE1 00100808 0000051E AD000D07
[   66.238922] PVR_K:   (MKT-1EE) 00000F2D 00100808 0000051E AD001304
[   66.246276] PVR_K:   (MKT-1EF) 00001019 00100808 0000051E AD001305
[   66.252838] PVR_K:   (MKT-1F0) 00001128 00100888 0000051E AD000404
[   66.259338] PVR_K:   (MKT-1F1) 000011EB 00100808 0000051E AD000402
[   66.265899] PVR_K:   (MKT-1F2) 00001233 0010082B 0000051E AD000184
[   66.272399] PVR_K:   (MKT-1F3) 000012D3 00108DA9 0000061D AD000281
[   66.279022] PVR_K:   (MKT-1F4) 0000145F 001089AB 0000061D AD000E02
[   66.285583] PVR_K:   (MKT-1F5) 000014BD 001089AF 0000061D AD000282
[   66.292236] PVR_K:   (MKT-1F6) 00003A90 00100808 0000081F AD000101
[   66.298797] PVR_K:   (MKT-1F7) 00003B06 00100808 0000081F AD000104
[   66.305267] PVR_K:   (MKT-1F8) 00003B42 00100808 0100091E AD000100
[   66.311828] PVR_K:   (MKT-1F9) 00003C45 00100808 0100091E AD000501
[   66.318328] PVR_K:   (MKT-1FA) 00003C85 0010082B 0100091E AD000104
[   66.324890] PVR_K:   (MKT-1FB) 00005EE5 00100828 01000A1F AD000101
[   66.331390] PVR_K:   (MKT-1FC) 00005F3C 00100828 01000A1F AD000104
[   66.337951] PVR_K:   (MKT-1FD) 0000604F 00100808 01000B1F AD000100
[   66.344482] PVR_K:   (MKT-1FE) 0000611C 00100808 01000B1F AD000501
[   66.351043] PVR_K:   (MKT-1FF) 00006152 00100829 01000B1F AD000104
[   66.357574] PVR_K: SGX Kernel CCB WO:0x78 RO:0x78
[   66.365081] adc_to_temp_conversion:Temp read is invalid 0
[   66.371063] thermal_lookup_temp: getting temp is not supported for domain pcb
[   66.383972] adc_to_temp_conversion:Temp read is invalid 0
[   66.389892] thermal_lookup_temp: getting temp is not supported for domain pcb
[   66.406219] adc_to_temp_conversion:Temp read is invalid 0
[   66.412139] thermal_lookup_temp: getting temp is not supported for domain pcb
[   66.577056] PVR_K:(Error): SGXOSTimer() detected SGX lockup (0xc tasks) [0, ]
[   66.584777] PVR_K: HWRecoveryResetSGX: SGX Hardware Recovery triggered
[   66.604553] [   39.512]   [c6edba00] --refs=1 on RELEASED
[   66.604553] [   39.512]                        [c6f12000] dsscomp_apply
[   66.604553] [   39.512]      [c6edb820] --refs=0 on RELEASED
[   66.604553] [   39.512]      [c6edb820] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   66.604553] [   39.512]                      [c6f10000] dsscomp_mgr_delayed_cb on RELEASED
[   66.668914] [   39.512]                        [c6f12000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   66.668945] [   39.513]      [c6edb820] new in dsscomp_gralloc_queue (refs=1)
[   66.668945] [   39.513]                      [c6f10000] dsscomp_new
[   66.725433] [   39.513]      [c6edb820] ++refs=2 for [c6f10000]
[   66.725463] [   39.513]                      [c6f10000] dsscomp_delayed_apply
[   66.725463] [   39.513]      [c6edb820] --refs=1 on RELEASED
[   66.725463] [   39.513]                      [c6f10000] dsscomp_apply
[   66.725463] [   39.527]                        [c6f12000] dsscomp_mgr_delayed_cb on DISPLAYED
[   66.787933] [   39.527]   [c6edba00] --refs=0 on RELEASED
[   66.787933] [   39.527]   [c6edba00] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   66.787963] [   39.527]                        [c6f12000] dsscomp_mgr_delayed_cb on RELEASED
[   66.787963] [   39.527]                      [c6f10000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   66.850433] [   39.550]                      [c6f10000] dsscomp_mgr_delayed_cb on DISPLAYED
[   66.850433] [   44.408]    [c6edb7a0] new in dsscomp_gralloc_queue (refs=1)
[   66.850433] [   44.408]                        [c6f12000] dsscomp_new
[   66.905151] [   44.408]    [c6edb7a0] ++refs=2 for [c6f12000]
[   66.905151] [   44.408]                        [c6f12000] dsscomp_delayed_apply
[   66.905151] [   44.408]    [c6edb7a0] --refs=1 on RELEASED
[   66.905151] [   44.408]                        [c6f12000] dsscomp_apply
[   66.905151] [   44.408]      [c6edb820] --refs=0 on RELEASED
[   66.967620] [   44.408]      [c6edb820] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   66.967651] [   44.408]                      [c6f10000] dsscomp_mgr_delayed_cb on RELEASED
[   66.967651] [   44.409]                        [c6f12000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   67.022338] [   44.409]      [c6edb820] new in dsscomp_gralloc_queue (refs=1)
[   67.022369] [   44.409]                      [c6f10000] dsscomp_new
[   67.022369] [   44.409]      [c6edb820] ++refs=2 for [c6f10000]
[   67.022369] [   44.409]                      [c6f10000] dsscomp_delayed_apply
[   67.084808] [   44.409]      [c6edb820] --refs=1 on RELEASED
[   67.084808] [   44.409]                      [c6f10000] dsscomp_apply
[   67.084808] [   44.425]                        [c6f12000] dsscomp_mgr_delayed_cb on DISPLAYED
[   67.084838] [   44.430]    [c6edb7a0] --refs=0 on RELEASED
[   67.084838] [   44.430]    [c6edb7a0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   67.147338] [   44.430]                        [c6f12000] dsscomp_mgr_delayed_cb on RELEASED
[   67.147338] [   44.430]                      [c6f10000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   67.147338] [   44.464]                      [c6f10000] dsscomp_mgr_delayed_cb on DISPLAYED
[   67.202026] [   49.508]   [c6edba00] new in dsscomp_gralloc_queue (refs=1)
[   67.202026] [   49.508]                     [c6f10c00] dsscomp_new
[   67.202026] [   49.508]   [c6edba00] ++refs=2 for [c6f10c00]
[   67.202026] [   49.508]                     [c6f10c00] dsscomp_delayed_apply
[   67.264495] [   49.508]   [c6edba00] --refs=1 on RELEASED
[   67.264495] [   49.508]                     [c6f10c00] dsscomp_apply
[   67.264495] [   49.514]      [c6edb820] --refs=0 on RELEASED
[   67.264495] [   49.514]      [c6edb820] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   67.264495] [   49.514]                      [c6f10000] dsscomp_mgr_delayed_cb on RELEASED
[   67.326995] [   49.514]                     [c6f10c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   67.326995] [   49.522]    [c6edb880] new in dsscomp_gralloc_queue (refs=1)
[   67.326995] [   49.522]                      [c6f10000] dsscomp_new
[   67.381683] [   49.522]    [c6edb880] ++refs=2 for [c6f10000]
[   67.381713] [   49.522]                      [c6f10000] dsscomp_delayed_apply
[   67.381713] [   49.522]    [c6edb880] --refs=1 on RELEASED
[   67.381713] [   49.522]                      [c6f10000] dsscomp_apply
[   67.381713] [   49.543]                     [c6f10c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   67.444213] [   49.543]   [c6edba00] --refs=0 on RELEASED
[   67.444213] [   49.543]   [c6edba00] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   67.444213] [   49.543]                     [c6f10c00] dsscomp_mgr_delayed_cb on RELEASED
[   67.444213] [   49.543]                      [c6f10000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   67.506683] [   49.557]                      [c6f10000] dsscomp_mgr_delayed_cb on DISPLAYED
[   67.506683] [   55.906]  [c6fa40a0] new in dsscomp_gralloc_queue (refs=1)
[   67.506683] [   55.906]                          [c6e66c00] dsscomp_new
[   67.561370] [   55.906]  [c6fa40a0] ++refs=2 for [c6e66c00]
[   67.561401] [   55.906]                          [c6e66c00] dsscomp_delayed_apply
[   67.561401] [   55.906]  [c6fa40a0] --refs=1 on RELEASED
[   67.561401] [   55.906]                          [c6e66c00] dsscomp_apply
[   67.561401] [   55.907]    [c6edb880] --refs=0 on RELEASED
[   67.623870] [   55.907]    [c6edb880] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   67.623870] [   55.907]                      [c6f10000] dsscomp_mgr_delayed_cb on RELEASED
[   67.623901] [   55.907]                          [c6e66c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   67.678558] [   55.908]     [c6fa4160] new in dsscomp_gralloc_queue (refs=1)
[   67.678558] [   55.908]                         [c6e67800] dsscomp_new
[   67.678588] [   55.908]     [c6fa4160] ++refs=2 for [c6e67800]
[   67.678588] [   55.908]                         [c6e67800] dsscomp_delayed_apply
[   67.678588] [   55.908]     [c6fa4160] --refs=1 on RELEASED
[   67.741088] [   55.908]                         [c6e67800] dsscomp_apply
[   67.741088] [   55.924]                          [c6e66c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   67.741088] [   55.924]  [c6fa40a0] --refs=0 on RELEASED
[   67.741088] [   55.924]  [c6fa40a0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   67.803588] [   55.924]                          [c6e66c00] dsscomp_mgr_delayed_cb on RELEASED
[   67.803588] [   55.924]                         [c6e67800] dsscomp_mgr_delayed_cb on PROGRAMMED
[   67.803588] [   55.942]                         [c6e67800] dsscomp_mgr_delayed_cb on DISPLAYED
[   67.858245] [   61.370]   [c6edbbc0] new in dsscomp_gralloc_queue (refs=1)
[   67.858245] [   61.370]                          [c6f10800] dsscomp_new
[   67.858276] [   61.370]   [c6edbbc0] ++refs=2 for [c6f10800]
[   67.858276] [   61.370]                          [c6f10800] dsscomp_delayed_apply
[   67.920745] [   61.370]   [c6edbbc0] --refs=1 on RELEASED
[   67.920776] [   61.370]                          [c6f10800] dsscomp_apply
[   67.920776] [   61.370]     [c6fa4160] --refs=0 on RELEASED
[   67.920776] [   61.370]     [c6fa4160] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   67.975433] [   61.370]                         [c6e67800] dsscomp_mgr_delayed_cb on RELEASED
[   67.975433] [   61.370]                          [c6f10800] dsscomp_mgr_delayed_cb on PROGRAMMED
[   67.975433] [   61.371]    [c6edbc00] new in dsscomp_gralloc_queue (refs=1)
[   67.975433] [   61.371]                         [c6f11400] dsscomp_new
[   68.037933] [   61.371]    [c6edbc00] ++refs=2 for [c6f11400]
[   68.037933] [   61.371]                         [c6f11400] dsscomp_delayed_apply
[   68.037933] [   61.371]    [c6edbc00] --refs=1 on RELEASED
[   68.037933] [   61.371]                         [c6f11400] dsscomp_apply
[   68.100433] [   61.383]                          [c6f10800] dsscomp_mgr_delayed_cb on DISPLAYED
[   68.100433] [   61.383]   [c6edbbc0] --refs=0 on RELEASED
[   68.100433] [   61.383]   [c6edbbc0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   68.100433] [   61.383]                          [c6f10800] dsscomp_mgr_delayed_cb on RELEASED
[   68.153778] [   61.383]                         [c6f11400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   68.153778] [   61.400]                         [c6f11400] dsscomp_mgr_delayed_cb on DISPLAYED
[   68.153778] [   66.356]     [c6fa4320] new in dsscomp_gralloc_queue (refs=1)
[   68.184967] [   66.356]                          [c6e66c00] dsscomp_new
[   68.184997] [   66.356]     [c6fa4320] ++refs=2 for [c6e66c00]
[   68.184997] [   66.356]                          [c6e66c00] dsscomp_delayed_apply
[   68.184997] [   66.356]     [c6fa4320] --refs=1 on RELEASED
[   68.184997] [   66.356]                          [c6e66c00] dsscomp_apply
[   68.217987] [   66.356]    [c6edbc00] --refs=0 on RELEASED
[   68.217987] [   66.356]    [c6edbc00] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   68.217987] [   66.356]                         [c6f11400] dsscomp_mgr_delayed_cb on RELEASED
[   68.217987] [   66.356]                          [c6e66c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   68.247711] [   66.357]  [c6edbb80] new in dsscomp_gralloc_queue (refs=1)
[   68.247741] [   66.357]                          [c6f10800] dsscomp_new
[   68.247741] [   66.357]  [c6edbb80] ++refs=2 for [c6f10800]
[   68.247741] [   66.357]                          [c6f10800] dsscomp_delayed_apply
[   68.277496] [   66.357]  [c6edbb80] --refs=1 on RELEASED
[   68.277496] [   66.357]                          [c6f10800] dsscomp_apply
[   68.277496] [   66.375]                          [c6e66c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   68.277496] [   66.375]     [c6fa4320] --refs=0 on RELEASED
[   68.309265] [   66.375]     [c6fa4320] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   68.309265] [   66.376]                          [c6e66c00] dsscomp_mgr_delayed_cb on RELEASED
[   68.309265] [   66.376]                          [c6f10800] dsscomp_mgr_delayed_cb on PROGRAMMED
[   68.337524] [   66.393]                          [c6f10800] dsscomp_mgr_delayed_cb on DISPLAYED
[   68.337524] ACTIVE COMPOSITIONS on lcd
[   68.337524]
[   68.337524]   [c6f10800]: DISPLAYED
[   68.337524]     sync_id=0, flags=AD-
[   68.337524]     ovl0={ON z0 ARGB32-8888 premult *100% 864*480:0,0+864,480 rot0 => 0,0+864,480 7f358000/  (null)|3456}
[   68.372314]     gsync=[c6edbb80] dsscomp_gralloc_cb
[   68.372314]
[   68.372314]   DISPC pipeline:
[   68.372314]
[   68.372344]     info:        clean (none)
[   68.372344]     cache:       clean (none)
[   68.372344]     shadow:  ACT clean (none)
[   68.372344]     dispc:   DISPLAYED mask=---R [c6f10800] dsscomp_mgr_callback
[   68.372344]
[   68.372344] ACTIVE COMPOSITIONS on tv
[   68.411254]
[   68.411254]   DISPC pipeline:
[   68.411254]
[   68.411285]     info:        clean (none)
[   68.411285]     cache:       clean (none)
[   68.411285]     shadow:  off clean (none)
[   68.411285]     dispc:   DISPLAYED (none)
[   68.411285]
[   68.411285] ACTIVE COMPOSITIONS on lcd2
[   68.411285]
[   68.411285]   DISPC pipeline:
[   68.411285]
[   68.457550]     shadow:  off clean (none)
[   68.457580]     dispc:             (none)
[   68.457580]
[   68.457580] ACTIVE GRALLOC FLIPS
[   68.457580]
[   68.457580]   [c6edbb80] (refs=1)
[   68.457580]     slots=[7f358000]
[   68.457580]     cmdcb=[c73f6900] dsscomp_proxy_cmdcomplete
[   68.457580]
[   68.457580]   |           lcd
[   68.457580]   | [c6f10800] DISPL'D
[   68.457580]   |     66.357  ACTIVE
[   68.499816]   |     66.357 APPLY'N
[   68.499847]   |     66.357 APPLIED
[   68.499847]   |     66.376 PROGR'D
[   68.499847]   |     66.393 DISPL'D
[   68.499847]
[   68.499847]
[   68.518646] PVR_K: SGX debug (blaze_android_sgx_ogles1_ogles2_GPL sgxddk 18 1.8@869593)
[   68.527160] PVR_K:(Error): SGX Register Base Address (Linear):   0xC8B20000 [0, ]
[   68.535247] PVR_K:(Error): SGX Register Base Address (Physical): 0x56000000 [0, ]
[   68.543304] PVR_K: (P0) EUR_CR_CORE_ID:          01140000
[   68.549102] PVR_K: (P0) EUR_CR_CORE_REVISION:    00010200
[   68.557708] PVR_K: (P0) EUR_CR_EVENT_STATUS:     20000000
[   68.564361] PVR_K: (P0) EUR_CR_EVENT_STATUS2:    00000008
[   68.570159] PVR_K: (P0) EUR_CR_BIF_CTRL:         00000000
[   68.575927] PVR_K: (P0) EUR_CR_BIF_INT_STAT:     00008000
[   68.581726] PVR_K: (P0) EUR_CR_BIF_FAULT:        00000000
[   68.587707] PVR_K: (P0) EUR_CR_BIF_MEM_REQ_STAT: 00000000
[   68.593627] PVR_K: (P0) EUR_CR_CLKGATECTL:       000AAA6A
[   68.599426] PVR_K: (P0) EUR_CR_PDS_PC_BASE:      00004008
[   68.605285] PVR_K: Flip Command Complete Data 0 for display device 1:
[   68.612213] PVR_K:   SRC 0: (Not in use)
[   68.620056] PVR_K: Flip Command Complete Data 1 for display device 1:
[   68.627044] PVR_K:   SRC 0: ROC DevVAddr:0xD800474 ROP:0xb ROC:0x9, WOC DevVAddr:0xD800464 WOP:0xb WOC:0xa
[   68.638153] PVR_K: SGX Host control:
[   68.641998] PVR_K:   (HC-0) 0x00000001 0x00000000 0x00000000 0x00000001
[   68.649871] PVR_K:   (HC-10) 0x0000000B 0x0000000A 0x0005DC00 0x00000003
[   68.656982] PVR_K:   (HC-20) 0x00000000 0x00000001 0x00000000 0x0000000F
[   68.664337] PVR_K:   (HC-30) 0x00000E12 0xF21364C0 0x00000000 0x00000000
[   68.671783] PVR_K:   (HC-40) 0x00000000 0x087BF500 0x087C6300 0x087C3100
[   68.678955] PVR_K: SGX TA/3D control:
[   68.682922] PVR_K:   (T3C-0) 0x0F003000 0x0F003120 0x0F002000 0x00000000
[   68.690032] PVR_K:   (T3C-10) 0x00000001 0x00000002 0x00000001 0x0F00DD00
[   68.697235] PVR_K:   (T3C-20) 0x00000000 0x00000000 0x00000000 0x00000000
[   68.704376] PVR_K:   (T3C-30) 0x00000000 0x00000000 0x00000000 0x00000000
[   68.711578] PVR_K:   (T3C-40) 0x00000000 0x00000000 0x00000000 0x00000000
[   68.718719] PVR_K:   (T3C-50) 0x0F00DD00 0x00000000 0x00000000 0x0F00DD00
[   68.725921] PVR_K:   (T3C-60) 0x00000000 0x00000000 0x0F00DD00 0x00000000
[   68.733093] PVR_K:   (T3C-70) 0x00000000 0x0F00DD00 0x00000000 0x0F004000
[   68.740264] PVR_K:   (T3C-80) 0x0000006E 0x0001120F 0x00000000 0x0F00DEB8
[   68.747436] PVR_K:   (T3C-90) 0x00000000 0x0F000000 0xAB600000 0x0F046000
[   68.754577] PVR_K:   (T3C-A0) 0x00000000 0x0F010BE0 0x0F00DD00 0x0F00DEB8
[   68.761749] PVR_K:   (T3C-B0) 0x0F010760 0x00000000 0x00000000 0x00000000
[   68.768920] PVR_K:   (T3C-C0) 0x00000000 0x00000000 0x00000000 0x00000000
[   68.776031] PVR_K:   (T3C-D0) 0x00000000 0x00000014 0x00000013 0x0F007000
[   68.783233] PVR_K:   (T3C-E0) 0x0F00D420 0x0F00E000 0x0F010720 0x0F010720
[   68.790374] PVR_K:   (T3C-F0) 0x00000000 0x000000B5 0x000000B5 0x00000000
[   68.797546] PVR_K:   (T3C-100) 0x00000003 0x00000000 0x00000000 0x00000001
[   68.804809] PVR_K:   (T3C-110) 0xB50C565C 0x0872E100 0x08787B00 0x08787B00
[   68.812072] PVR_K: Last SGX microkernel status code: AD000104
[   68.818267] PVR_K:   (MKT-0) 091AE9CB 00000808 0000201E 00000006
[   68.824584] PVR_K:   (MKT-1) 091AE9EF 00000808 0000201E 00000007
[   68.830932] PVR_K:   (MKT-2) 091AEA5B 00000808 0000201E AD000184
[   68.837249] PVR_K:   (MKT-3) 091AEAC2 00000C08 0100211D AD000281
[   68.843627] PVR_K:   (MKT-4) 091AEC43 00000808 0100211D AD00080A
[   68.849945] PVR_K:   (MKT-5) 091AEC5C 00000808 0100211D 0F042700
[   68.856292] PVR_K:   (MKT-6) 091AEC75 00000808 0100211D 00000061
[   68.862640] PVR_K:   (MKT-7) 091AEDEE 00000808 0000211D AD000802
[   68.868988] PVR_K:   (MKT-8) 091AEF43 00000808 0000211D AD000803
[   68.875335] PVR_K:   (MKT-9) 091AEF8E 00184EC8 0000211D AD000282
[   68.881683] PVR_K:   (MKT-A) 091B1078 00000C08 0100241F AD000200
[   68.888000] PVR_K:   (MKT-B) 091B12D8 00000808 0000241F AD000202
[   68.894348] PVR_K:   (MKT-C) 091B136A 00000808 0000251E AD000183
[   68.900665] PVR_K:   (MKT-D) 091B1456 00000808 0000251E AD00030E
[   68.907043] PVR_K:   (MKT-E) 091B146E 00000808 0000251E 0D800494
[   68.913360] PVR_K:   (MKT-F) 091B1488 00000808 0000251E 00000006
[   68.919708] PVR_K:   (MKT-10) 091B14AF 00000808 0000251E 00000007
[   68.926147] PVR_K:   (MKT-11) 091B151D 00000808 0000251E AD000184
[   68.932556] PVR_K:   (MKT-12) 091B1584 00000C08 0100261D AD000281
[   68.938995] PVR_K:   (MKT-13) 091B16F7 00000808 0100261D AD00080A
[   68.945434] PVR_K:   (MKT-14) 091B1710 00000808 0100261D 0F042A00
[   68.951873] PVR_K:   (MKT-15) 091B1728 00000808 0100261D 00000060
[   68.958282] PVR_K:   (MKT-16) 091B19E9 00000808 0000261D AD000803
[   68.964721] PVR_K:   (MKT-17) 091B1A31 00180CC8 0000261D AD000282
[   68.971130] PVR_K:   (MKT-18) 091B1AD4 00000808 0100281F AD000200
[   68.977600] PVR_K:   (MKT-19) 091B1CFE 00000808 0000281F AD000202
[   68.983978] PVR_K:   (MKT-1A) 091B1D84 00000808 0000291E AD000183
[   68.990447] PVR_K:   (MKT-1B) 091B1E6D 00000808 0000291E AD00030E
[   68.996856] PVR_K:   (MKT-1C) 091B1E85 00000808 0000291E 0D800494
[   69.003295] PVR_K:   (MKT-1D) 091B1E9E 00000808 0000291E 00000006
[   69.009704] PVR_K:   (MKT-1E) 091B1EC3 00000808 0000291E 00000007
[   69.016174] PVR_K:   (MKT-1F) 091B1F2E 00000808 0000291E AD000184
[   69.022552] PVR_K:   (MKT-20) 091B1F95 00000C08 01002A1D AD000281
[   69.028991] PVR_K:   (MKT-21) 091B2106 00000808 01002A1D AD00080A
[   69.035430] PVR_K:   (MKT-22) 091B211E 00000808 01002A1D 0F042D00
[   69.041839] PVR_K:   (MKT-23) 091B2137 00000808 01002A1D 00000060
[   69.048278] PVR_K:   (MKT-24) 091B23FC 00000808 00002A1D AD000803
[   69.054687] PVR_K:   (MKT-25) 091B2443 00180CC8 00002A1D AD000282
[   69.061157] PVR_K:   (MKT-26) 091B252F 00000808 01002C1F AD000200
[   69.068603] PVR_K:   (MKT-27) 091B2750 00000808 00002C1F AD000202
[   69.075073] PVR_K:   (MKT-28) 091B27D0 00000808 00002D1E AD000183
[   69.081451] PVR_K:   (MKT-29) 091B28BD 00000808 00002D1E AD00030E
[   69.087921] PVR_K:   (MKT-2A) 091B28D7 00000808 00002D1E 0D800494
[   69.094329] PVR_K:   (MKT-2B) 091B28F1 00000808 00002D1E 00000006
[   69.100769] PVR_K:   (MKT-2C) 091B2916 00000808 00002D1E 00000007
[   69.107177] PVR_K:   (MKT-2D) 091B2980 00000808 00002D1E AD000184
[   69.113616] PVR_K:   (MKT-2E) 091B29EB 00000C08 01002E1D AD000281
[   69.122070] PVR_K:   (MKT-2F) 091B2B64 00000808 01002E1D AD00080A
[   69.128540] PVR_K:   (MKT-30) 091B2B7D 00000808 01002E1D 0F043000
[   69.134948] PVR_K:   (MKT-31) 091B2B96 00000808 01002E1D 00000062
[   69.141357] PVR_K:   (MKT-32) 091B2E54 00000808 00002E1D AD000803
[   69.147827] PVR_K:   (MKT-33) 091B2E9C 00180C88 00002E1D AD000282
[   69.154205] PVR_K:   (MKT-34) 091B3A62 00000808 0100301F AD000200
[   69.160644] PVR_K:   (MKT-35) 091B3B7F 00000808 0100301F AD001703
[   69.167053] PVR_K:   (MKT-36) 091B3D68 00000808 0000301F AD000202
[   69.173492] PVR_K:   (MKT-37) 091B3DE7 00000808 0000311E AD000183
[   69.179901] PVR_K:   (MKT-38) 091B3ED4 00000808 0000311E AD00030E
[   69.187072] PVR_K:   (MKT-39) 091B3EF4 00000808 0000311E 0D800494
[   69.193450] PVR_K:   (MKT-3A) 091B3F0D 00000808 0000311E 00000006
[   69.200042] PVR_K:   (MKT-3B) 091B3F35 00000808 0000311E 00000007
[   69.206573] PVR_K:   (MKT-3C) 091B3F9F 00000808 0000311E AD000184
[   69.213012] PVR_K:   (MKT-3D) 091B4003 00000C08 0100321D AD000281
[   69.219451] PVR_K:   (MKT-3E) 091B4118 00000808 0100321D AD000E02
[   69.225982] PVR_K:   (MKT-3F) 091B418D 00000808 0100321D AD000282
[   69.232421] PVR_K:   (MKT-40) 091C0A78 00000808 0100351F AD001A00
[   69.239471] PVR_K:   (MKT-41) 091DB904 00000808 01003A1F AD00000A
[   69.245910] PVR_K:   (MKT-42) 091DB967 00000808 01003A1F AD000909
[   69.252319] PVR_K:   (MKT-43) 091DB9B2 00000808 01003A1F AD001A05
[   69.258972] PVR_K:   (MKT-44) 091DB9E3 00000808 01003A1F AD001302
[   69.265441] PVR_K:   (MKT-45) 091DBA24 00000808 01003A1F AD001303
[   69.271942] PVR_K:   (MKT-46) 091DBABD 00000808 01003A1F AD000D04
[   69.278411] PVR_K:   (MKT-47) 091DBB96 00000808 01003A1F AD000D05
[   69.284912] PVR_K:   (MKT-48) 091DBBEF 00000808 01003A1F AD000D04
[   69.291870] PVR_K:   (MKT-49) 091DBC79 00000808 01003A1F AD000D05
[   69.298400] PVR_K:   (MKT-4A) 091DBCD8 00000808 01003A1F AD001A06
[   69.304840] PVR_K:   (MKT-4B) 000004D5 00100808 0100031F AD002300
[   69.311309] PVR_K:   (MKT-4C) 000009DA 00100808 0100041F AD00000A
[   69.317749] PVR_K:   (MKT-4D) 00000A58 00100808 0100041F AD000906
[   69.324340] PVR_K:   (MKT-4E) 00000B2A 00100808 0000041F AD000901
[   69.330871] PVR_K:   (MKT-4F) 00000BA4 00100808 0000051E AD000183
[   69.337341] PVR_K:   (MKT-50) 00000D22 00100808 0000051E AD000302
[   69.343902] PVR_K:   (MKT-51) 00000EAF 00100808 0000051E AD000D06
[   69.350280] PVR_K:   (MKT-52) 00000F9D 00100808 0000051E AD000D07
[   69.356781] PVR_K:   (MKT-53) 00000FE7 00100808 0000051E AD001304
[   69.363250] PVR_K:   (MKT-54) 000010DC 00100808 0000051E AD001305
[   69.369750] PVR_K:   (MKT-55) 000011F3 00100888 0000051E AD000404
[   69.376190] PVR_K:   (MKT-56) 000012B8 00100808 0000051E AD000402
[   69.382690] PVR_K:   (MKT-57) 00001300 0010082B 0000051E AD000184
[   69.389129] PVR_K:   (MKT-58) 0000139E 00119DA9 0000061D AD000281
[   69.395660] PVR_K:   (MKT-59) 00001530 001089AF 0000061D AD000E02
[   69.402099] PVR_K:   (MKT-5A) 00001589 0010892B 0000061D AD000282
[   69.408599] PVR_K:   (MKT-5B) 00003B65 00100808 0000081F AD000101
[   69.415802] PVR_K:   (MKT-5C) 00003BDD 00100808 0000081F AD000104
[   69.422302] PVR_K:   (MKT-5D) 00003C1C 00100808 0100091E AD000100
[   69.428741] PVR_K:   (MKT-5E) 00003D29 00100808 0100091E AD000501
[   69.435485] PVR_K:   (MKT-5F) 00003D69 00100829 0100091E AD000104
[   69.442138] PVR_K:   (MKT-60) 00005FFE 00100828 01000A1F AD000101
[   69.448608] PVR_K:   (MKT-61) 00006058 00100828 01000A1F AD000104
[   69.455078] PVR_K:   (MKT-62) 00006170 00100808 01000B1F AD000100
[   69.461486] PVR_K:   (MKT-63) 00006240 00100808 01000B1F AD000501
[   69.467956] PVR_K:   (MKT-64) 00006276 00100829 00000B1F AD000104
[   69.474334] PVR_K:   (MKT-65) 000087D6 00100828 01000D1F AD000101
[   69.480773] PVR_K:   (MKT-66) 0000884B 00100828 01000D1F AD000104
[   69.487182] PVR_K:   (MKT-67) 00008889 00100808 01000E1E AD000100
[   69.493652] PVR_K:   (MKT-68) 00008987 00100808 01000E1E AD000501
[   69.500061] PVR_K:   (MKT-69) 000089C6 00100829 01000E1E AD000104
[   69.506530] PVR_K:   (MKT-6A) 07CA4DA4 00100808 0100031F AD000B00
[   69.513275] PVR_K:   (MKT-6B) 07CA4DEA 00100808 0100031F AD000B03
[   69.519714] PVR_K:   (MKT-6C) 07CA4E70 00100808 0100031F AD000B05
[   69.526275] PVR_K:   (MKT-6D) 07CA4EC5 00100808 0100031F AD000B06
[   69.532867] PVR_K:   (MKT-6E) 07CA4EF4 00100808 0100031F AD000B06
[   69.539276] PVR_K:   (MKT-6F) 07CA4F37 00100808 0100031F AD000B07
[   69.545776] PVR_K:   (MKT-70) 07CA4F5C 00100808 0100031F AD000B09
[   69.552215] PVR_K:   (MKT-71) 07CA4FB1 00100808 0100031F AD000B01
[   69.558654] PVR_K:   (MKT-72) 07CA4FED 00100808 0100031F AD002300
[   69.565185] PVR_K:   (MKT-73) 07CA52FD 00100808 0100041F AD00000A
[   69.571655] PVR_K:   (MKT-74) 07CA537E 00100808 0100041F AD000906
[   69.578186] PVR_K:   (MKT-75) 07CA5438 00100808 0000041F AD000901
[   69.584655] PVR_K:   (MKT-76) 07CA54B2 00100808 0000051E AD000183
[   69.591156] PVR_K:   (MKT-77) 07CA561D 00100808 0000051E AD000302
[   69.597595] PVR_K:   (MKT-78) 07CA5678 00100808 0000051E AD000303
[   69.604827] PVR_K:   (MKT-79) 07CA56FC 00100808 0000051E AD000C01
[   69.611267] PVR_K:   (MKT-7A) 07CA5720 00100808 0000051E 0D800484
[   69.617797] PVR_K:   (MKT-7B) 07CA5739 00100808 0000051E 00000008
[   69.624298] PVR_K:   (MKT-7C) 07CA5986 00100808 0000051E AD00030E
[   69.630828] PVR_K:   (MKT-7D) 07CA599E 00100808 0000051E 0D800474
[   69.637329] PVR_K:   (MKT-7E) 07CA59B6 00100808 0000051E 00000007
[   69.643798] PVR_K:   (MKT-7F) 07CA59DB 00100808 0000051E 00000008
[   69.650207] PVR_K:   (MKT-80) 07CA5A52 00100808 0000051E AD000184
[   69.656646] PVR_K:   (MKT-81) 07CA5ACF 00100C08 0100061D AD000281
[   69.663116] PVR_K:   (MKT-82) 07CA5C6A 00100808 0100061D AD00080A
[   69.669494] PVR_K:   (MKT-83) 07CA5C82 00100808 0100061D 0F043300
[   69.675964] PVR_K:   (MKT-84) 07CA5C9B 00100808 0100061D 00000061
[   69.682373] PVR_K:   (MKT-85) 07CA5DB1 00100C08 0000061D AD001300
[   69.688812] PVR_K:   (MKT-86) 07CAB15F 00100808 0000061D AD001301
[   69.695220] PVR_K:   (MKT-87) 07CAB288 00100888 0000061D AD000802
[   69.701690] PVR_K:   (MKT-88) 07CAB3EA 00100888 0000061D AD000803
[   69.708679] PVR_K:   (MKT-89) 07CAB43A 001808C8 0000061D AD000282
[   69.715118] PVR_K:   (MKT-8A) 07CAB520 00184AF8 0000081E AD00000A
[   69.721527] PVR_K:   (MKT-8B) 07CAB5A2 00184AF8 0000081E AD000905
[   69.727996] PVR_K:   (MKT-8C) 07CAB6B9 001808B8 0000081E AD000901
[   69.734374] PVR_K:   (MKT-8D) 07CAB72A 00180838 0000091C AD00000A
[   69.740814] PVR_K:   (MKT-8E) 07CAB797 00180838 0000091C AD000905
[   69.747222] PVR_K:   (MKT-8F) 07CAB843 00180838 0000091C AD000901
[   69.753692] PVR_K:   (MKT-90) 07CAB89D 00180838 00000A1B AD00000A
[   69.760101] PVR_K:   (MKT-91) 07CAB912 00180838 00000A1B AD000906
[   69.766479] PVR_K:   (MKT-92) 07CAB98E 00180838 00000A1B AD000901
[   69.772949] PVR_K:   (MKT-93) 07CAB9EA 00180838 00000B1A AD00000A
[   69.779327] PVR_K:   (MKT-94) 07CABA5B 00180838 00000B1A AD000905
[   69.785766] PVR_K:   (MKT-95) 07CABB05 00180838 00000B1A AD000901
[   69.792175] PVR_K:   (MKT-96) 07CABB5E 00180838 00000C19 AD00000A
[   69.798645] PVR_K:   (MKT-97) 07CABBC8 00180838 00000C19 AD000905
[   69.805023] PVR_K:   (MKT-98) 07CABC7F 00180838 00000C19 AD000901
[   69.811492] PVR_K:   (MKT-99) 07CABDCE 00180838 00000F1F AD000183
[   69.817871] PVR_K:   (MKT-9A) 07CABF4F 00180838 00000F1F AD000302
[   69.824340] PVR_K:   (MKT-9B) 07CABFC4 00180838 00000F1F AD000303
[   69.830749] PVR_K:   (MKT-9C) 07CAC04B 00180838 00000F1F AD000C01
[   69.837219] PVR_K:   (MKT-9D) 07CAC072 00180838 00000F1F 0D800464
[   69.843597] PVR_K:   (MKT-9E) 07CAC08A 00180838 00000F1F 00000009
[   69.850067] PVR_K:   (MKT-9F) 07CAC2A2 00180838 00000F1F AD000184
[   69.856445] PVR_K:   (MKT-A0) 07CAC314 00180C38 0100101D AD000281
[   69.862915] PVR_K:   (MKT-A1) 07CAC36A 00180838 0100101D AD000282
[   69.869354] PVR_K:   (MKT-A2) 07CAD075 00180838 0100111F AD00000A
[   69.875762] PVR_K:   (MKT-A3) 07CAD0DF 00180838 0100111F AD000905
[   69.882202] PVR_K:   (MKT-A4) 07CAD1DF 00180838 0000111F AD000901
[   69.888610] PVR_K:   (MKT-A5) 07CAD22F 00180C38 0100121E AD000281
[   69.895080] PVR_K:   (MKT-A6) 07CAD289 00180838 0100121E AD000282
[   69.901489] PVR_K:   (MKT-A7) 07CAD3DE 00180838 0100131F AD00000A
[   69.907928] PVR_K:   (MKT-A8) 07CAD447 00180838 0100131F AD000905
[   69.914337] PVR_K:   (MKT-A9) 07CAD540 00100828 0000131F AD000901
[   69.920806] PVR_K:   (MKT-AA) 07CAD592 00000C08 0000141E AD000281
[   69.927215] PVR_K:   (MKT-AB) 07CAD5E8 00000808 0000141E AD000282
[   69.933654] PVR_K:   (MKT-AC) 07CAD633 00000808 0100151F AD000200
[   69.940063] PVR_K:   (MKT-AD) 07CAD885 00000808 0000151F AD000202
[   69.946533] PVR_K:   (MKT-AE) 07CAD930 00000808 0000161E AD00000A
[   69.952941] PVR_K:   (MKT-AF) 07CAD999 00000808 0000161E AD000905
[   69.959381] PVR_K:   (MKT-B0) 07CADA88 00000808 0000161E AD000901
[   69.965789] PVR_K:   (MKT-B1) 07CADAD8 00000C08 0000171D AD000281
[   69.972198] PVR_K:   (MKT-B2) 07CADC3D 00000808 0000171D AD00080A
[   69.978637] PVR_K:   (MKT-B3) 07CADC56 00000808 0000171D 0F043600
[   69.985046] PVR_K:   (MKT-B4) 07CADC6E 00000808 0000171D 00000060
[   69.991485] PVR_K:   (MKT-B5) 07CADF22 00000808 0000171D AD000803
[   69.997894] PVR_K:   (MKT-B6) 07CADF68 00180CC8 0000171D AD000282
[   70.004364] PVR_K:   (MKT-B7) 07CAE01C 00000808 0000181F AD00000A
[   70.010742] PVR_K:   (MKT-B8) 07CAE086 00000808 0000181F AD000905
[   70.017211] PVR_K:   (MKT-B9) 07CAE17B 00000888 0000181F AD000901
[   70.023590] PVR_K:   (MKT-BA) 07CAE1C4 00000C08 00001A1D AD000200
[   70.030059] PVR_K:   (MKT-BB) 07CAE3F1 00000808 00001A1D AD000202
[   70.036468] PVR_K:   (MKT-BC) 07CAE448 00000808 01001B1C AD000281
[   70.042907] PVR_K:   (MKT-BD) 07CAE593 00000808 01001B1C AD00080A
[   70.049316] PVR_K:   (MKT-BE) 07CAE5AC 00000808 01001B1C 0F043900
[   70.055755] PVR_K:   (MKT-BF) 07CAE5C4 00000808 01001B1C 00000060
[   70.062164] PVR_K:   (MKT-C0) 07CAE87F 00000808 00001B1C AD000803
[   70.068634] PVR_K:   (MKT-C1) 07CAE8C5 00180CC8 00001B1C AD000282
[   70.075073] PVR_K:   (MKT-C2) 07CAE9A9 00000808 01001D1F AD000200
[   70.081481] PVR_K:   (MKT-C3) 07CAEBD2 00000808 01001D1F AD000202
[   70.087951] PVR_K:   (MKT-C4) 07CAEC22 00000808 01001E1E AD000281
[   70.094360] PVR_K:   (MKT-C5) 07CAED6D 00000808 01001E1E AD00080A
[   70.100799] PVR_K:   (MKT-C6) 07CAED85 00000808 01001E1E 0F043C00
[   70.107208] PVR_K:   (MKT-C7) 07CAED9E 00000808 01001E1E 00000062
[   70.113647] PVR_K:   (MKT-C8) 07CAF056 00000808 00001E1E AD000803
[   70.120056] PVR_K:   (MKT-C9) 07CAF09E 00180C88 00001E1E AD000282
[   70.126525] PVR_K:   (MKT-CA) 07CAFBD3 00000808 0100201F AD000200
[   70.132934] PVR_K:   (MKT-CB) 07CAFCF1 00000808 0100201F AD001703
[   70.139373] PVR_K:   (MKT-CC) 07CAFEF0 00000808 0000201F AD000202
[   70.145782] PVR_K:   (MKT-CD) 07CAFF6D 00000808 0000211E AD000183
[   70.152221] PVR_K:   (MKT-CE) 07CB005B 00000808 0000211E AD00030E
[   70.158630] PVR_K:   (MKT-CF) 07CB0073 00000808 0000211E 0D800494
[   70.165069] PVR_K:   (MKT-D0) 07CB008D 00000808 0000211E 00000007
[   70.171478] PVR_K:   (MKT-D1) 07CB00B1 00000808 0000211E 00000008
[   70.177856] PVR_K:   (MKT-D2) 07CB011B 00000808 0000211E AD000184
[   70.184326] PVR_K:   (MKT-D3) 07CB017F 00000C08 0100221D AD000281
[   70.190734] PVR_K:   (MKT-D4) 07CB02F5 00000808 0100221D AD00080A
[   70.197174] PVR_K:   (MKT-D5) 07CB030E 00000808 0100221D 0F043F00
[   70.203582] PVR_K:   (MKT-D6) 07CB0326 00000808 0100221D 00000061
[   70.210052] PVR_K:   (MKT-D7) 07CB04A6 00000808 0000221D AD000802
[   70.216430] PVR_K:   (MKT-D8) 07CB05F5 00000808 0000221D AD000803
[   70.222900] PVR_K:   (MKT-D9) 07CB063A 00184EC8 0000221D AD000282
[   70.229309] PVR_K:   (MKT-DA) 07CB25FC 00000C08 0100251F AD000200
[   70.235748] PVR_K:   (MKT-DB) 07CB284C 00000808 0000251F AD000202
[   70.242156] PVR_K:   (MKT-DC) 07CB28D3 00000808 0000261E AD000183
[   70.248596] PVR_K:   (MKT-DD) 07CB29BB 00000808 0000261E AD00030E
[   70.255004] PVR_K:   (MKT-DE) 07CB29D3 00000808 0000261E 0D800494
[   70.261474] PVR_K:   (MKT-DF) 07CB29EC 00000808 0000261E 00000007
[   70.267883] PVR_K:   (MKT-E0) 07CB2A0F 00000808 0000261E 00000008
[   70.274353] PVR_K:   (MKT-E1) 07CB2A79 00000808 0000261E AD000184
[   70.280792] PVR_K:   (MKT-E2) 07CB2ADF 00000C08 0100271D AD000281
[   70.287200] PVR_K:   (MKT-E3) 07CB2C4B 00000808 0100271D AD00080A
[   70.293670] PVR_K:   (MKT-E4) 07CB2C64 00000808 0100271D 0F044200
[   70.300079] PVR_K:   (MKT-E5) 07CB2C7C 00000808 0100271D 00000060
[   70.306518] PVR_K:   (MKT-E6) 07CB2F2E 00000808 0000271D AD000803
[   70.312927] PVR_K:   (MKT-E7) 07CB2F74 00180CC8 0000271D AD000282
[   70.319396] PVR_K:   (MKT-E8) 07CB3016 00000808 0100291F AD000200
[   70.325775] PVR_K:   (MKT-E9) 07CB3231 00000808 0000291F AD000202
[   70.332214] PVR_K:   (MKT-EA) 07CB32AF 00000808 00002A1E AD000183
[   70.338653] PVR_K:   (MKT-EB) 07CB339C 00000808 00002A1E AD00030E
[   70.345092] PVR_K:   (MKT-EC) 07CB33B4 00000808 00002A1E 0D800494
[   70.351501] PVR_K:   (MKT-ED) 07CB33CD 00000808 00002A1E 00000007
[   70.357940] PVR_K:   (MKT-EE) 07CB33F0 00000808 00002A1E 00000008
[   70.364349] PVR_K:   (MKT-EF) 07CB345A 00000808 00002A1E AD000184
[   70.370788] PVR_K:   (MKT-F0) 07CB34BE 00000C08 01002B1D AD000281
[   70.377197] PVR_K:   (MKT-F1) 07CB3625 00000808 01002B1D AD00080A
[   70.383605] PVR_K:   (MKT-F2) 07CB363E 00000808 01002B1D 0F044500
[   70.390075] PVR_K:   (MKT-F3) 07CB3656 00000808 01002B1D 00000060
[   70.396484] PVR_K:   (MKT-F4) 07CB390C 00000808 00002B1D AD000803
[   70.403137] PVR_K:   (MKT-F5) 07CB3952 00180CC8 00002B1D AD000282
[   70.409667] PVR_K:   (MKT-F6) 07CB3A3C 00000808 01002D1F AD000200
[   70.416137] PVR_K:   (MKT-F7) 07CB3C53 00000808 00002D1F AD000202
[   70.422546] PVR_K:   (MKT-F8) 07CB3CD5 00000808 00002E1E AD000183
[   70.429046] PVR_K:   (MKT-F9) 07CB3DC0 00000808 00002E1E AD00030E
[   70.435485] PVR_K:   (MKT-FA) 07CB3DD8 00000808 00002E1E 0D800494
[   70.441986] PVR_K:   (MKT-FB) 07CB3DF1 00000808 00002E1E 00000007
[   70.448486] PVR_K:   (MKT-FC) 07CB3E14 00000808 00002E1E 00000008
[   70.455017] PVR_K:   (MKT-FD) 07CB3E82 00000808 00002E1E AD000184
[   70.461517] PVR_K:   (MKT-FE) 07CB3EE7 00000C08 01002F1D AD000281
[   70.468017] PVR_K:   (MKT-FF) 07CB4056 00000808 01002F1D AD00080A
[   70.474456] PVR_K:   (MKT-100) 07CB406E 00000808 01002F1D 0F044800
[   70.481048] PVR_K:   (MKT-101) 07CB4086 00000808 01002F1D 00000062
[   70.488372] PVR_K:   (MKT-102) 07CB4336 00000808 00002F1D AD000803
[   70.494903] PVR_K:   (MKT-103) 07CB437D 00180C88 00002F1D AD000282
[   70.501525] PVR_K:   (MKT-104) 07CB4EC6 00000808 0100311F AD000200
[   70.508178] PVR_K:   (MKT-105) 07CB4FE1 00000808 0100311F AD001703
[   70.514862] PVR_K:   (MKT-106) 07CB51C1 00000808 0000311F AD000202
[   70.521423] PVR_K:   (MKT-107) 07CB523E 00000808 0000321E AD000183
[   70.528015] PVR_K:   (MKT-108) 07CB5329 00000808 0000321E AD00030E
[   70.534515] PVR_K:   (MKT-109) 07CB5341 00000808 0000321E 0D800494
[   70.541046] PVR_K:   (MKT-10A) 07CB5359 00000808 0000321E 00000007
[   70.547546] PVR_K:   (MKT-10B) 07CB5380 00000808 0000321E 00000008
[   70.554107] PVR_K:   (MKT-10C) 07CB53EA 00000808 0000321E AD000184
[   70.560791] PVR_K:   (MKT-10D) 07CB544F 00000C08 0100331D AD000281
[   70.567352] PVR_K:   (MKT-10E) 07CB5560 00000808 0100331D AD000E02
[   70.573883] PVR_K:   (MKT-10F) 07CB55D4 00000808 0100331D AD000282
[   70.580505] PVR_K:   (MKT-110) 07CC24DB 00000808 0100361F AD001A00
[   70.587127] PVR_K:   (MKT-111) 07CC27F3 00000808 0100371F AD00000A
[   70.593780] PVR_K:   (MKT-112) 07CC2854 00000808 0100371F AD000909
[   70.600311] PVR_K:   (MKT-113) 07CC289E 00000808 0100371F AD001A05
[   70.606842] PVR_K:   (MKT-114) 07CC28CF 00000808 0100371F AD001302
[   70.613464] PVR_K:   (MKT-115) 07CC290E 00000808 0100371F AD001303
[   70.620025] PVR_K:   (MKT-116) 07CC29A0 00000808 0100371F AD000D04
[   70.626586] PVR_K:   (MKT-117) 07CC2A6E 00000808 0100371F AD000D05
[   70.633178] PVR_K:   (MKT-118) 07CC2AC8 00000808 0100371F AD000D04
[   70.639801] PVR_K:   (MKT-119) 07CC2B4E 00000808 0100371F AD000D05
[   70.646362] PVR_K:   (MKT-11A) 07CC2BAB 00000808 0100371F AD001A06
[   70.652954] PVR_K:   (MKT-11B) 00000460 00100808 0100031F AD002300
[   70.659576] PVR_K:   (MKT-11C) 0000093A 00100808 0100041F AD00000A
[   70.666107] PVR_K:   (MKT-11D) 000009B7 00100808 0100041F AD000906
[   70.673156] PVR_K:   (MKT-11E) 00000A84 00100808 0000041F AD000901
[   70.679718] PVR_K:   (MKT-11F) 00000AFE 00100808 0000051E AD000183
[   70.686279] PVR_K:   (MKT-120) 00000C74 00100808 0000051E AD000302
[   70.692810] PVR_K:   (MKT-121) 00000DFD 00100808 0000051E AD000D06
[   70.699371] PVR_K:   (MKT-122) 00000EE1 00100808 0000051E AD000D07
[   70.706024] PVR_K:   (MKT-123) 00000F2D 00100808 0000051E AD001304
[   70.712677] PVR_K:   (MKT-124) 00001019 00100808 0000051E AD001305
[   70.719207] PVR_K:   (MKT-125) 00001128 00100888 0000051E AD000404
[   70.725860] PVR_K:   (MKT-126) 000011EB 00100808 0000051E AD000402
[   70.732360] PVR_K:   (MKT-127) 00001233 0010082B 0000051E AD000184
[   70.738952] PVR_K:   (MKT-128) 000012D3 00108DA9 0000061D AD000281
[   70.745544] PVR_K:   (MKT-129) 0000145F 001089AB 0000061D AD000E02
[   70.752075] PVR_K:   (MKT-12A) 000014BD 001089AF 0000061D AD000282
[   70.758666] PVR_K:   (MKT-12B) 00003A90 00100808 0000081F AD000101
[   70.765258] PVR_K:   (MKT-12C) 00003B06 00100808 0000081F AD000104
[   70.771850] PVR_K:   (MKT-12D) 00003B42 00100808 0100091E AD000100
[   70.778411] PVR_K:   (MKT-12E) 00003C45 00100808 0100091E AD000501
[   70.785003] PVR_K:   (MKT-12F) 00003C85 0010082B 0100091E AD000104
[   70.791534] PVR_K:   (MKT-130) 00005EE5 00100828 01000A1F AD000101
[   70.798919] PVR_K:   (MKT-131) 00005F3C 00100828 01000A1F AD000104
[   70.805480] PVR_K:   (MKT-132) 0000604F 00100808 01000B1F AD000100
[   70.812103] PVR_K:   (MKT-133) 0000611C 00100808 01000B1F AD000501
[   70.818908] PVR_K:   (MKT-134) 00006152 00100829 01000B1F AD000104
[   70.826110] PVR_K:   (MKT-135) 071CF768 00100808 0100031F AD000B00
[   70.833435] PVR_K:   (MKT-136) 071CF7AC 00100808 0100031F AD000B03
[   70.840240] PVR_K:   (MKT-137) 071CF835 00100808 0100031F AD000B05
[   70.846832] PVR_K:   (MKT-138) 071CF889 00100808 0100031F AD000B06
[   70.853790] PVR_K:   (MKT-139) 071CF8B8 00100808 0100031F AD000B06
[   70.861083] PVR_K:   (MKT-13A) 071CF8FB 00100808 0100031F AD000B07
[   70.867919] PVR_K:   (MKT-13B) 071CF920 00100808 0100031F AD000B09
[   70.874603] PVR_K:   (MKT-13C) 071CF975 00100808 0100031F AD000B01
[   70.881439] PVR_K:   (MKT-13D) 071CF9B1 00100808 0100031F AD002300
[   70.888244] PVR_K:   (MKT-13E) 071CFCC4 00100808 0100041F AD00000A
[   70.894775] PVR_K:   (MKT-13F) 071CFD43 00100808 0100041F AD000906
[   70.901336] PVR_K:   (MKT-140) 071CFE00 00100808 0000041F AD000901
[   70.907867] PVR_K:   (MKT-141) 071CFE81 00100808 0000051E AD000183
[   70.914398] PVR_K:   (MKT-142) 071CFFED 00100808 0000051E AD000302
[   70.920928] PVR_K:   (MKT-143) 071D0041 00100808 0000051E AD000303
[   70.927429] PVR_K:   (MKT-144) 071D00C7 00100808 0000051E AD000C01
[   70.933959] PVR_K:   (MKT-145) 071D00EC 00100808 0000051E 0D800484
[   70.940460] PVR_K:   (MKT-146) 071D0104 00100808 0000051E 00000009
[   70.947021] PVR_K:   (MKT-147) 071D035E 00100808 0000051E AD00030E
[   70.953521] PVR_K:   (MKT-148) 071D0377 00100808 0000051E 0D800474
[   70.960479] PVR_K:   (MKT-149) 071D0390 00100808 0000051E 00000008
[   70.967102] PVR_K:   (MKT-14A) 071D03B4 00100808 0000051E 00000009
[   70.973754] PVR_K:   (MKT-14B) 071D042A 00100808 0000051E AD000184
[   70.980346] PVR_K:   (MKT-14C) 071D04AB 00100C08 0100061D AD000281
[   70.986968] PVR_K:   (MKT-14D) 071D0649 00100808 0100061D AD00080A
[   70.993591] PVR_K:   (MKT-14E) 071D0662 00100808 0100061D 0F044B00
[   71.000183] PVR_K:   (MKT-14F) 071D067A 00100808 0100061D 00000061
[   71.006835] PVR_K:   (MKT-150) 071D0794 00100C88 0100061D AD001300
[   71.013397] PVR_K:   (MKT-151) 071D5BC6 00100808 0000061D AD001301
[   71.020080] PVR_K:   (MKT-152) 071D5CF2 00100888 0000061D AD000802
[   71.026641] PVR_K:   (MKT-153) 071D5E60 00100888 0000061D AD000803
[   71.033264] PVR_K:   (MKT-154) 071D5EAF 001808C8 0000061D AD000282
[   71.039855] PVR_K:   (MKT-155) 071D5F93 00184EF8 0000081E AD00000A
[   71.046478] PVR_K:   (MKT-156) 071D600D 001808F8 0000081E AD000905
[   71.052947] PVR_K:   (MKT-157) 071D6131 001808B8 0000081E AD000901
[   71.059509] PVR_K:   (MKT-158) 071D61A7 00180838 0000091C AD00000A
[   71.066009] PVR_K:   (MKT-159) 071D621C 00180838 0000091C AD000906
[   71.072570] PVR_K:   (MKT-15A) 071D6290 00180838 0000091C AD000901
[   71.079132] PVR_K:   (MKT-15B) 071D62E7 00180838 00000A1B AD00000A
[   71.085601] PVR_K:   (MKT-15C) 071D6355 00180838 00000A1B AD000905
[   71.092132] PVR_K:   (MKT-15D) 071D6410 00180838 00000A1B AD000901
[   71.098632] PVR_K:   (MKT-15E) 071D6466 00180838 00000B1A AD00000A
[   71.105194] PVR_K:   (MKT-15F) 071D64C7 00180838 00000B1A AD000905
[   71.111694] PVR_K:   (MKT-160) 071D6572 00180838 00000B1A AD000901
[   71.118255] PVR_K:   (MKT-161) 071D65C6 00180838 00000C19 AD00000A
[   71.124755] PVR_K:   (MKT-162) 071D662C 00180838 00000C19 AD000905
[   71.131286] PVR_K:   (MKT-163) 071D66D5 00180838 00000C19 AD000901
[   71.137786] PVR_K:   (MKT-164) 071D6825 00180838 00000F1F AD000183
[   71.144317] PVR_K:   (MKT-165) 071D69A3 00180838 00000F1F AD000302
[   71.150848] PVR_K:   (MKT-166) 071D6A13 00180838 00000F1F AD000303
[   71.157379] PVR_K:   (MKT-167) 071D6A94 00180838 00000F1F AD000C01
[   71.163940] PVR_K:   (MKT-168) 071D6ABA 00180838 00000F1F 0D800464
[   71.170410] PVR_K:   (MKT-169) 071D6AD2 00180838 00000F1F 0000000A
[   71.176971] PVR_K:   (MKT-16A) 071D6D08 00180838 00000F1F AD000184
[   71.183471] PVR_K:   (MKT-16B) 071D6D7D 00180C38 0100101D AD000281
[   71.190032] PVR_K:   (MKT-16C) 071D6DD3 00180838 0100101D AD000282
[   71.196533] PVR_K:   (MKT-16D) 071D7A34 00180838 0100111F AD00000A
[   71.203094] PVR_K:   (MKT-16E) 071D7A9E 00180838 0100111F AD000905
[   71.209564] PVR_K:   (MKT-16F) 071D7BA3 00180838 0000111F AD000901
[   71.216125] PVR_K:   (MKT-170) 071D7BF4 00180C38 0100121E AD000281
[   71.222625] PVR_K:   (MKT-171) 071D7C4B 00180838 0100121E AD000282
[   71.229187] PVR_K:   (MKT-172) 071D7D3F 00180838 0100131F AD00000A
[   71.235687] PVR_K:   (MKT-173) 071D7DAB 00180838 0100131F AD000905
[   71.242218] PVR_K:   (MKT-174) 071D7EA5 00180838 0000131F AD000901
[   71.248748] PVR_K:   (MKT-175) 071D7EF9 00180C38 0100141E AD000281
[   71.255279] PVR_K:   (MKT-176) 071D7F52 00100828 0100141E AD000282
[   71.261840] PVR_K:   (MKT-177) 071D8011 00000808 0100151F AD000200
[   71.268341] PVR_K:   (MKT-178) 071D8262 00000808 0000151F AD000202
[   71.274871] PVR_K:   (MKT-179) 071D830B 00000808 0000161E AD00000A
[   71.281372] PVR_K:   (MKT-17A) 071D837C 00000808 0000161E AD000905
[   71.287933] PVR_K:   (MKT-17B) 071D846A 00000808 0000161E AD000901
[   71.294403] PVR_K:   (MKT-17C) 071D84BA 00000C08 0000171D AD000281
[   71.300964] PVR_K:   (MKT-17D) 071D861A 00000808 0000171D AD00080A
[   71.307464] PVR_K:   (MKT-17E) 071D8633 00000808 0000171D 0F044E00
[   71.313995] PVR_K:   (MKT-17F) 071D864B 00000808 0000171D 00000060
[   71.320495] PVR_K:   (MKT-180) 071D890E 00000808 0000171D AD000803
[   71.327056] PVR_K:   (MKT-181) 071D8954 00180CC8 0000171D AD000282
[   71.333587] PVR_K:   (MKT-182) 071D8A0B 00000808 0000181F AD00000A
[   71.340087] PVR_K:   (MKT-183) 071D8A74 00000808 0000181F AD000905
[   71.346618] PVR_K:   (MKT-184) 071D8B69 00000888 0000181F AD000901
[   71.353118] PVR_K:   (MKT-185) 071D8BB4 00000C08 00001A1D AD000200
[   71.359680] PVR_K:   (MKT-186) 071D8DE8 00000808 00001A1D AD000202
[   71.366180] PVR_K:   (MKT-187) 071D8E3F 00000808 01001B1C AD000281
[   71.372711] PVR_K:   (MKT-188) 071D8F8C 00000808 01001B1C AD00080A
[   71.379211] PVR_K:   (MKT-189) 071D8FA5 00000808 01001B1C 0F045100
[   71.385742] PVR_K:   (MKT-18A) 071D8FBD 00000808 01001B1C 00000060
[   71.392242] PVR_K:   (MKT-18B) 071D9284 00000808 00001B1C AD000803
[   71.398803] PVR_K:   (MKT-18C) 071D92CF 00180CC8 00001B1C AD000282
[   71.405303] PVR_K:   (MKT-18D) 071D93B8 00000808 01001D1F AD000200
[   71.411834] PVR_K:   (MKT-18E) 071D95E6 00000808 01001D1F AD000202
[   71.418365] PVR_K:   (MKT-18F) 071D9635 00000808 01001E1E AD000281
[   71.424865] PVR_K:   (MKT-190) 071D9786 00000808 01001E1E AD00080A
[   71.431396] PVR_K:   (MKT-191) 071D97A2 00000808 01001E1E 0F045400
[   71.437896] PVR_K:   (MKT-192) 071D97BB 00000808 01001E1E 00000062
[   71.444458] PVR_K:   (MKT-193) 071D9A82 00000808 00001E1E AD000803
[   71.450927] PVR_K:   (MKT-194) 071D9ACB 00180C88 00001E1E AD000282
[   71.457489] PVR_K:   (MKT-195) 071DA649 00000808 0100201F AD000200
[   71.463989] PVR_K:   (MKT-196) 071DA767 00000808 0100201F AD001703
[   71.470520] PVR_K:   (MKT-197) 071DA96D 00000808 0000201F AD000202
[   71.477020] PVR_K:   (MKT-198) 071DA9F0 00000808 0000211E AD000183
[   71.483581] PVR_K:   (MKT-199) 071DAADE 00000808 0000211E AD00030E
[   71.490051] PVR_K:   (MKT-19A) 071DAAF6 00000808 0000211E 0D800494
[   71.496612] PVR_K:   (MKT-19B) 071DAB12 00000808 0000211E 00000008
[   71.503143] PVR_K:   (MKT-19C) 071DAB35 00000808 0000211E 00000009
[   71.509643] PVR_K:   (MKT-19D) 071DABA2 00000808 0000211E AD000184
[   71.516174] PVR_K:   (MKT-19E) 071DAC08 00000C08 0100221D AD000281
[   71.522674] PVR_K:   (MKT-19F) 071DAD84 00000808 0100221D AD00080A
[   71.529205] PVR_K:   (MKT-1A0) 071DAD9D 00000808 0100221D 0F045700
[   71.535736] PVR_K:   (MKT-1A1) 071DADB5 00000808 0100221D 00000061
[   71.543243] PVR_K:   (MKT-1A2) 071DAF36 00000808 0000221D AD000802
[   71.549743] PVR_K:   (MKT-1A3) 071DB08C 00000808 0000221D AD000803
[   71.556274] PVR_K:   (MKT-1A4) 071DB0D3 00184EC8 0000221D AD000282
[   71.562774] PVR_K:   (MKT-1A5) 071DD046 00000C08 0100251F AD000200
[   71.569305] PVR_K:   (MKT-1A6) 071DD2A3 00000808 0000251F AD000202
[   71.575805] PVR_K:   (MKT-1A7) 071DD32D 00000808 0000261E AD000183
[   71.582336] PVR_K:   (MKT-1A8) 071DD418 00000808 0000261E AD00030E
[   71.588897] PVR_K:   (MKT-1A9) 071DD430 00000808 0000261E 0D800494
[   71.595367] PVR_K:   (MKT-1AA) 071DD449 00000808 0000261E 00000008
[   71.601898] PVR_K:   (MKT-1AB) 071DD46D 00000808 0000261E 00000009
[   71.608398] PVR_K:   (MKT-1AC) 071DD4DA 00000808 0000261E AD000184
[   71.614929] PVR_K:   (MKT-1AD) 071DD53E 00000C08 0100271D AD000281
[   71.621429] PVR_K:   (MKT-1AE) 071DD6A9 00000808 0100271D AD00080A
[   71.627960] PVR_K:   (MKT-1AF) 071DD6C2 00000808 0100271D 0F045A00
[   71.634429] PVR_K:   (MKT-1B0) 071DD6DA 00000808 0100271D 00000060
[   71.640991] PVR_K:   (MKT-1B1) 071DD98D 00000808 0000271D AD000803
[   71.647460] PVR_K:   (MKT-1B2) 071DD9D3 00180CC8 0000271D AD000282
[   71.653991] PVR_K:   (MKT-1B3) 071DDA93 00000808 0100291F AD000200
[   71.660491] PVR_K:   (MKT-1B4) 071DDCB0 00000808 0000291F AD000202
[   71.666961] PVR_K:   (MKT-1B5) 071DDD2E 00000808 00002A1E AD000183
[   71.673522] PVR_K:   (MKT-1B6) 071DDE1B 00000808 00002A1E AD00030E
[   71.679992] PVR_K:   (MKT-1B7) 071DDE33 00000808 00002A1E 0D800494
[   71.686523] PVR_K:   (MKT-1B8) 071DDE4C 00000808 00002A1E 00000008
[   71.693023] PVR_K:   (MKT-1B9) 071DDE6F 00000808 00002A1E 00000009
[   71.699554] PVR_K:   (MKT-1BA) 071DDED9 00000808 00002A1E AD000184
[   71.706054] PVR_K:   (MKT-1BB) 071DDF40 00000C08 01002B1D AD000281
[   71.712585] PVR_K:   (MKT-1BC) 071DE0AE 00000808 01002B1D AD00080A
[   71.719085] PVR_K:   (MKT-1BD) 071DE0C6 00000808 01002B1D 0F045D00
[   71.725616] PVR_K:   (MKT-1BE) 071DE0DE 00000808 01002B1D 00000060
[   71.732086] PVR_K:   (MKT-1BF) 071DE386 00000808 00002B1D AD000803
[   71.738616] PVR_K:   (MKT-1C0) 071DE3CC 00188CC8 00002B1D AD000282
[   71.745178] PVR_K:   (MKT-1C1) 071DE4B5 00000808 01002D1F AD000200
[   71.751647] PVR_K:   (MKT-1C2) 071DE6CF 00000808 00002D1F AD000202
[   71.758209] PVR_K:   (MKT-1C3) 071DE74F 00000808 00002E1E AD000183
[   71.764709] PVR_K:   (MKT-1C4) 071DE83A 00000808 00002E1E AD00030E
[   71.771240] PVR_K:   (MKT-1C5) 071DE853 00000808 00002E1E 0D800494
[   71.777740] PVR_K:   (MKT-1C6) 071DE86B 00000808 00002E1E 00000008
[   71.784271] PVR_K:   (MKT-1C7) 071DE88F 00000808 00002E1E 00000009
[   71.790771] PVR_K:   (MKT-1C8) 071DE8F9 00000808 00002E1E AD000184
[   71.797302] PVR_K:   (MKT-1C9) 071DE95F 00000C08 01002F1D AD000281
[   71.803802] PVR_K:   (MKT-1CA) 071DEAD3 00000808 01002F1D AD00080A
[   71.810333] PVR_K:   (MKT-1CB) 071DEAEC 00000808 01002F1D 0F046000
[   71.816833] PVR_K:   (MKT-1CC) 071DEB04 00000808 01002F1D 00000062
[   71.823364] PVR_K:   (MKT-1CD) 071DEDB1 00000808 00002F1D AD000803
[   71.829925] PVR_K:   (MKT-1CE) 071DEDF6 00180C88 00002F1D AD000282
[   71.836395] PVR_K:   (MKT-1CF) 071DF903 00000808 0100311F AD000200
[   71.842956] PVR_K:   (MKT-1D0) 071DFA21 00000808 0100311F AD001703
[   71.849456] PVR_K:   (MKT-1D1) 071DFC05 00000808 0000311F AD000202
[   71.855987] PVR_K:   (MKT-1D2) 071DFC81 00000808 0000321E AD000183
[   71.862487] PVR_K:   (MKT-1D3) 071DFD6B 00000808 0000321E AD00030E
[   71.869018] PVR_K:   (MKT-1D4) 071DFD83 00000808 0000321E 0D800494
[   71.875518] PVR_K:   (MKT-1D5) 071DFD9C 00000808 0000321E 00000008
[   71.882049] PVR_K:   (MKT-1D6) 071DFDC1 00000808 0000321E 00000009
[   71.888549] PVR_K:   (MKT-1D7) 071DFE2E 00000808 0000321E AD000184
[   71.895080] PVR_K:   (MKT-1D8) 071DFE92 00000C08 0100331D AD000281
[   71.901580] PVR_K:   (MKT-1D9) 071DFFA5 00000808 0100331D AD000E02
[   71.908111] PVR_K:   (MKT-1DA) 071E001A 00000808 0100331D AD000282
[   71.914672] PVR_K:   (MKT-1DB) 071ECEA0 00000808 0100361F AD001A00
[   71.921142] PVR_K:   (MKT-1DC) 071FECC6 00000808 01003A1F AD00000A
[   71.927673] PVR_K:   (MKT-1DD) 071FED28 00000808 01003A1F AD000909
[   71.934173] PVR_K:   (MKT-1DE) 071FED72 00000808 01003A1F AD001A05
[   71.940704] PVR_K:   (MKT-1DF) 071FEDA2 00000808 01003A1F AD001302
[   71.947204] PVR_K:   (MKT-1E0) 071FEDE1 00000808 01003A1F AD001303
[   71.953735] PVR_K:   (MKT-1E1) 071FEE70 00000808 01003A1F AD000D04
[   71.960235] PVR_K:   (MKT-1E2) 071FEF3F 00000808 01003A1F AD000D05
[   71.966766] PVR_K:   (MKT-1E3) 071FEF97 00000808 01003A1F AD000D04
[   71.973266] PVR_K:   (MKT-1E4) 071FF01C 00000808 01003A1F AD000D05
[   71.979797] PVR_K:   (MKT-1E5) 071FF07C 00000808 01003A1F AD001A06
[   71.986297] PVR_K:   (MKT-1E6) 000004C0 00100808 0100031F AD002300
[   71.992828] PVR_K:   (MKT-1E7) 000009A6 00100808 0100041F AD00000A
[   71.999359] PVR_K:   (MKT-1E8) 00000A24 00100808 0100041F AD000906
[   72.005859] PVR_K:   (MKT-1E9) 00000AF2 00100808 0000041F AD000901
[   72.012390] PVR_K:   (MKT-1EA) 00000B6C 00100808 0000051E AD000183
[   72.018890] PVR_K:   (MKT-1EB) 00000CE5 00100808 0000051E AD000302
[   72.025421] PVR_K:   (MKT-1EC) 00000E65 00100808 0000051E AD000D06
[   72.031921] PVR_K:   (MKT-1ED) 00000F49 00100808 0000051E AD000D07
[   72.038452] PVR_K:   (MKT-1EE) 00000F93 00100808 0000051E AD001304
[   72.044921] PVR_K:   (MKT-1EF) 0000107E 00100808 0000051E AD001305
[   72.051483] PVR_K:   (MKT-1F0) 00001190 00100888 0000051E AD000404
[   72.057983] PVR_K:   (MKT-1F1) 00001252 00100808 0000051E AD000402
[   72.064514] PVR_K:   (MKT-1F2) 0000129A 0010082B 0000051E AD000184
[   72.071014] PVR_K:   (MKT-1F3) 00001321 00108DAF 0000061D AD000281
[   72.077545] PVR_K:   (MKT-1F4) 000014A8 001199AD 0000061D AD000E02
[   72.084075] PVR_K:   (MKT-1F5) 00001504 001199A9 0000061D AD000282
[   72.090576] PVR_K:   (MKT-1F6) 00003B05 00100808 0000081F AD000101
[   72.097137] PVR_K:   (MKT-1F7) 00003B7A 00100808 0000081F AD000104
[   72.103637] PVR_K:   (MKT-1F8) 00003BB6 00100808 0100091E AD000100
[   72.110168] PVR_K:   (MKT-1F9) 00003CB9 00100808 0100091E AD000501
[   72.116668] PVR_K:   (MKT-1FA) 00003CF8 0010082B 0100091E AD000104
[   72.123199] PVR_K:   (MKT-1FB) 00005F46 00100828 01000A1F AD000101
[   72.129699] PVR_K:   (MKT-1FC) 00005F8A 00100828 01000A1F AD000104
[   72.136230] PVR_K:   (MKT-1FD) 0000608D 00100808 01000B1F AD000100
[   72.142730] PVR_K:   (MKT-1FE) 00006146 00100808 01000B1F AD000501
[   72.149261] PVR_K:   (MKT-1FF) 00006172 00100829 01000B1F AD000104
[   72.155761] PVR_K: SGX Kernel CCB WO:0x84 RO:0x84
[   72.162353] adc_to_temp_conversion:Temp read is invalid 0
[   72.168395] thermal_lookup_temp: getting temp is not supported for domain pcb
[   72.177001] adc_to_temp_conversion:Temp read is invalid 0
[   72.183135] thermal_lookup_temp: getting temp is not supported for domain pcb
[   72.191833] adc_to_temp_conversion:Temp read is invalid 0
[   72.197692] thermal_lookup_temp: getting temp is not supported for domain pcb
[   72.366149] PVR_K:(Error): SGXOSTimer() detected SGX lockup (0xc tasks) [0, ]
[   72.374053] PVR_K: HWRecoveryResetSGX: SGX Hardware Recovery triggered
[   72.382751] [   44.408]    [c6edb7a0] --refs=1 on RELEASED
[   72.382751] [   44.408]                        [c6f12000] dsscomp_apply
[   72.382781] [   44.408]      [c6edb820] --refs=0 on RELEASED
[   72.382781] [   44.408]      [c6edb820] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   72.382781] [   44.408]                      [c6f10000] dsscomp_mgr_delayed_cb on RELEASED
[   72.416809] [   44.409]                        [c6f12000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   72.416839] [   44.409]      [c6edb820] new in dsscomp_gralloc_queue (refs=1)
[   72.416839] [   44.409]                      [c6f10000] dsscomp_new
[   72.445526] [   44.409]      [c6edb820] ++refs=2 for [c6f10000]
[   72.445526] [   44.409]                      [c6f10000] dsscomp_delayed_apply
[   72.445526] [   44.409]      [c6edb820] --refs=1 on RELEASED
[   72.445556] [   44.409]                      [c6f10000] dsscomp_apply
[   72.445556] [   44.425]                        [c6f12000] dsscomp_mgr_delayed_cb on DISPLAYED
[   72.476959] [   44.430]    [c6edb7a0] --refs=0 on RELEASED
[   72.476959] [   44.430]    [c6edb7a0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   72.476989] [   44.430]                        [c6f12000] dsscomp_mgr_delayed_cb on RELEASED
[   72.476989] [   44.430]                      [c6f10000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   72.506866] [   44.464]                      [c6f10000] dsscomp_mgr_delayed_cb on DISPLAYED
[   72.506866] [   49.508]   [c6edba00] new in dsscomp_gralloc_queue (refs=1)
[   72.506866] [   49.508]                     [c6f10c00] dsscomp_new
[   72.535186] [   49.508]   [c6edba00] ++refs=2 for [c6f10c00]
[   72.535217] [   49.508]                     [c6f10c00] dsscomp_delayed_apply
[   72.535217] [   49.508]   [c6edba00] --refs=1 on RELEASED
[   72.535217] [   49.508]                     [c6f10c00] dsscomp_apply
[   72.535217] [   49.514]      [c6edb820] --refs=0 on RELEASED
[   72.566528] [   49.514]      [c6edb820] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   72.566558] [   49.514]                      [c6f10000] dsscomp_mgr_delayed_cb on RELEASED
[   72.566558] [   49.514]                     [c6f10c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   72.594909] [   49.522]    [c6edb880] new in dsscomp_gralloc_queue (refs=1)
[   72.594909] [   49.522]                      [c6f10000] dsscomp_new
[   72.594909] [   49.522]    [c6edb880] ++refs=2 for [c6f10000]
[   72.594909] [   49.522]                      [c6f10000] dsscomp_delayed_apply
[   72.594909] [   49.522]    [c6edb880] --refs=1 on RELEASED
[   72.627014] [   49.522]                      [c6f10000] dsscomp_apply
[   72.627014] [   49.543]                     [c6f10c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   72.627044] [   49.543]   [c6edba00] --refs=0 on RELEASED
[   72.627044] [   49.543]   [c6edba00] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   72.657073] [   49.543]                     [c6f10c00] dsscomp_mgr_delayed_cb on RELEASED
[   72.657073] [   49.543]                      [c6f10000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   72.657104] [   49.557]                      [c6f10000] dsscomp_mgr_delayed_cb on DISPLAYED
[   72.685394] [   55.906]  [c6fa40a0] new in dsscomp_gralloc_queue (refs=1)
[   72.685424] [   55.906]                          [c6e66c00] dsscomp_new
[   72.685424] [   55.906]  [c6fa40a0] ++refs=2 for [c6e66c00]
[   72.685424] [   55.906]                          [c6e66c00] dsscomp_delayed_apply
[   72.685424] [   55.906]  [c6fa40a0] --refs=1 on RELEASED
[   72.716796] [   55.906]                          [c6e66c00] dsscomp_apply
[   72.716796] [   55.907]    [c6edb880] --refs=0 on RELEASED
[   72.716827] [   55.907]    [c6edb880] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   72.716827] [   55.907]                      [c6f10000] dsscomp_mgr_delayed_cb on RELEASED
[   72.746612] [   55.907]                          [c6e66c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   72.746612] [   55.908]     [c6fa4160] new in dsscomp_gralloc_queue (refs=1)
[   72.746612] [   55.908]                         [c6e67800] dsscomp_new
[   72.746643] [   55.908]     [c6fa4160] ++refs=2 for [c6e67800]
[   72.776397] [   55.908]                         [c6e67800] dsscomp_delayed_apply
[   72.776428] [   55.908]     [c6fa4160] --refs=1 on RELEASED
[   72.776428] [   55.908]                         [c6e67800] dsscomp_apply
[   72.776428] [   55.924]                          [c6e66c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   72.806945] [   55.924]  [c6fa40a0] --refs=0 on RELEASED
[   72.806945] [   55.924]  [c6fa40a0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   72.806945] [   55.924]                          [c6e66c00] dsscomp_mgr_delayed_cb on RELEASED
[   72.806976] [   55.924]                         [c6e67800] dsscomp_mgr_delayed_cb on PROGRAMMED
[   72.837249] [   55.942]                         [c6e67800] dsscomp_mgr_delayed_cb on DISPLAYED
[   72.837280] [   61.370]   [c6edbbc0] new in dsscomp_gralloc_queue (refs=1)
[   72.837280] [   61.370]                          [c6f10800] dsscomp_new
[   72.865905] [   61.370]   [c6edbbc0] ++refs=2 for [c6f10800]
[   72.865905] [   61.370]                          [c6f10800] dsscomp_delayed_apply
[   72.865936] [   61.370]   [c6edbbc0] --refs=1 on RELEASED
[   72.865936] [   61.370]                          [c6f10800] dsscomp_apply
[   72.865936] [   61.370]     [c6fa4160] --refs=0 on RELEASED
[   72.897674] [   61.370]     [c6fa4160] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   72.897674] [   61.370]                         [c6e67800] dsscomp_mgr_delayed_cb on RELEASED
[   72.897674] [   61.370]                          [c6f10800] dsscomp_mgr_delayed_cb on PROGRAMMED
[   72.926300] [   61.371]    [c6edbc00] new in dsscomp_gralloc_queue (refs=1)
[   72.926330] [   61.371]                         [c6f11400] dsscomp_new
[   72.926330] [   61.371]    [c6edbc00] ++refs=2 for [c6f11400]
[   72.926330] [   61.371]                         [c6f11400] dsscomp_delayed_apply
[   72.956451] [   61.371]    [c6edbc00] --refs=1 on RELEASED
[   72.956451] [   61.371]                         [c6f11400] dsscomp_apply
[   72.956451] [   61.383]                          [c6f10800] dsscomp_mgr_delayed_cb on DISPLAYED
[   72.956451] [   61.383]   [c6edbbc0] --refs=0 on RELEASED
[   72.956451] [   61.383]   [c6edbbc0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   72.988098] [   61.383]                          [c6f10800] dsscomp_mgr_delayed_cb on RELEASED
[   72.988098] [   61.383]                         [c6f11400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   72.988098] [   61.400]                         [c6f11400] dsscomp_mgr_delayed_cb on DISPLAYED
[   73.016357] [   66.356]     [c6fa4320] new in dsscomp_gralloc_queue (refs=1)
[   73.016387] [   66.356]                          [c6e66c00] dsscomp_new
[   73.016387] [   66.356]     [c6fa4320] ++refs=2 for [c6e66c00]
[   73.016387] [   66.356]                          [c6e66c00] dsscomp_delayed_apply
[   73.046203] [   66.356]     [c6fa4320] --refs=1 on RELEASED
[   73.046203] [   66.356]                          [c6e66c00] dsscomp_apply
[   73.046203] [   66.356]    [c6edbc00] --refs=0 on RELEASED
[   73.046203] [   66.356]    [c6edbc00] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   73.075927] [   66.356]                         [c6f11400] dsscomp_mgr_delayed_cb on RELEASED
[   73.075927] [   66.356]                          [c6e66c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   73.075927] [   66.357]  [c6edbb80] new in dsscomp_gralloc_queue (refs=1)
[   73.075958] [   66.357]                          [c6f10800] dsscomp_new
[   73.105651] [   66.357]  [c6edbb80] ++refs=2 for [c6f10800]
[   73.105651] [   66.357]                          [c6f10800] dsscomp_delayed_apply
[   73.105651] [   66.357]  [c6edbb80] --refs=1 on RELEASED
[   73.105682] [   66.357]                          [c6f10800] dsscomp_apply
[   73.135406] [   66.375]                          [c6e66c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   73.135406] [   66.375]     [c6fa4320] --refs=0 on RELEASED
[   73.135406] [   66.375]     [c6fa4320] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   73.135406] [   66.376]                          [c6e66c00] dsscomp_mgr_delayed_cb on RELEASED
[   73.165191] [   66.376]                          [c6f10800] dsscomp_mgr_delayed_cb on PROGRAMMED
[   73.165191] [   66.393]                          [c6f10800] dsscomp_mgr_delayed_cb on DISPLAYED
[   73.165191] [   72.154]  [c6fa4420] new in dsscomp_gralloc_queue (refs=1)
[   73.193389] [   72.154]                           [c6e66000] dsscomp_new
[   73.193389] [   72.154]  [c6fa4420] ++refs=2 for [c6e66000]
[   73.193420] [   72.154]                           [c6e66000] dsscomp_delayed_apply
[   73.193420] [   72.154]  [c6fa4420] --refs=1 on RELEASED
[   73.223144] [   72.154]                           [c6e66000] dsscomp_apply
[   73.223144] [   72.154]  [c6edbb80] --refs=0 on RELEASED
[   73.223144] [   72.154]  [c6edbb80] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   73.223144] [   72.154]                          [c6f10800] dsscomp_mgr_delayed_cb on RELEASED
[   73.252899] [   72.154]                           [c6e66000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   73.252899] [   72.155]       [c6edbcc0] new in dsscomp_gralloc_queue (refs=1)
[   73.252929] [   72.155]                       [c6f12c00] dsscomp_new
[   73.252929] [   72.155]       [c6edbcc0] ++refs=2 for [c6f12c00]
[   73.282623] [   72.155]                       [c6f12c00] dsscomp_delayed_apply
[   73.282623] [   72.155]       [c6edbcc0] --refs=1 on RELEASED
[   73.282623] [   72.155]                       [c6f12c00] dsscomp_apply
[   73.282623] [   72.176]                           [c6e66000] dsscomp_mgr_delayed_cb on DISPLAYED
[   73.312438] [   72.176]  [c6fa4420] --refs=0 on RELEASED
[   73.312438] [   72.176]  [c6fa4420] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   73.312438] [   72.176]                           [c6e66000] dsscomp_mgr_delayed_cb on RELEASED
[   73.312438] [   72.176]                       [c6f12c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   73.342163] [   72.191]                       [c6f12c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   73.342193] ACTIVE COMPOSITIONS on lcd
[   73.342193]
[   73.342193]   [c6f12c00]: DISPLAYED
[   73.342193]     sync_id=0, flags=AD-
[   73.342193]     ovl0={ON z0 ARGB32-8888 premult *100% 864*480:0,0+864,480 rot0 => 0,0+864,480 7f358000/  (null)|3456}
[   73.375030]     gsync=[c6edbcc0] dsscomp_gralloc_cb
[   73.375030]
[   73.375030]   DISPC pipeline:
[   73.375030]
[   73.375030]     info:        clean (none)
[   73.375030]     cache:       clean (none)
[   73.375030]     shadow:  ACT clean (none)
[   73.375030]     dispc:   DISPLAYED mask=---R [c6f12c00] dsscomp_mgr_callback
[   73.410888]
[   73.410888] ACTIVE COMPOSITIONS on tv
[   73.410888]
[   73.410888]   DISPC pipeline:
[   73.410888]
[   73.410919]     info:        clean (none)
[   73.410919]     cache:       clean (none)
[   73.410919]     shadow:  off clean (none)
[   73.410919]     dispc:   DISPLAYED (none)
[   73.410919]
[   73.410919] ACTIVE COMPOSITIONS on lcd2
[   73.410919]
[   73.410919]   DISPC pipeline:
[   73.410919]
[   73.459014]     shadow:  off clean (none)
[   73.459045]     dispc:             (none)
[   73.459045]
[   73.459045] ACTIVE GRALLOC FLIPS
[   73.459045]
[   73.459045]   [c6edbcc0] (refs=1)
[   73.459045]     slots=[7f358000]
[   73.459045]     cmdcb=[c73f6900] dsscomp_proxy_cmdcomplete
[   73.459045]
[   73.459045]   |           lcd
[   73.459045]   | [c6f12c00] DISPL'D
[   73.459045]   |     72.155  ACTIVE
[   73.501037]   |     72.155 APPLY'N
[   73.501037]   |     72.155 APPLIED
[   73.501068]   |     72.176 PROGR'D
[   73.501068]   |     72.191 DISPL'D
[   73.501068]
[   73.501068]
[   73.521087] PVR_K: SGX debug (blaze_android_sgx_ogles1_ogles2_GPL sgxddk 18 1.8@869593)
[   73.529693] PVR_K:(Error): SGX Register Base Address (Linear):   0xC8B20000 [0, ]
[   73.539215] PVR_K:(Error): SGX Register Base Address (Physical): 0x56000000 [0, ]
[   73.547241] PVR_K: (P0) EUR_CR_CORE_ID:          01140000
[   73.553009] PVR_K: (P0) EUR_CR_CORE_REVISION:    00010200
[   73.558807] PVR_K: (P0) EUR_CR_EVENT_STATUS:     20000000
[   73.564575] PVR_K: (P0) EUR_CR_EVENT_STATUS2:    00000008
[   73.570373] PVR_K: (P0) EUR_CR_BIF_CTRL:         00000000
[   73.576110] PVR_K: (P0) EUR_CR_BIF_INT_STAT:     00008000
[   73.581939] PVR_K: (P0) EUR_CR_BIF_FAULT:        00000000
[   73.587677] PVR_K: (P0) EUR_CR_BIF_MEM_REQ_STAT: 00000000
[   73.593505] PVR_K: (P0) EUR_CR_CLKGATECTL:       000AAA6A
[   73.599243] PVR_K: (P0) EUR_CR_PDS_PC_BASE:      00004038
[   73.605041] PVR_K: Flip Command Complete Data 0 for display device 1:
[   73.611907] PVR_K:   SRC 0: (Not in use)
[   73.616241] PVR_K: Flip Command Complete Data 1 for display device 1:
[   73.623107] PVR_K:   SRC 0: ROC DevVAddr:0xD800474 ROP:0xc ROC:0xa, WOC DevVAddr:0xD800464 WOP:0xc WOC:0xb
[   73.634857] PVR_K: SGX Host control:
[   73.638702] PVR_K:   (HC-0) 0x00000001 0x00000000 0x00000000 0x00000001
[   73.645690] PVR_K:   (HC-10) 0x0000000C 0x0000000A 0x0005DC00 0x00000003
[   73.652740] PVR_K:   (HC-20) 0x00000000 0x00000001 0x00000000 0x00000010
[   73.659851] PVR_K:   (HC-30) 0x00000E1A 0xF26BD758 0x00000000 0x00000000
[   73.666931] PVR_K:   (HC-40) 0x00000000 0x087BF500 0x087C6300 0x087C3100
[   73.673950] PVR_K: SGX TA/3D control:
[   73.677917] PVR_K:   (T3C-0) 0x0F003000 0x0F003120 0x0F002000 0x00000000
[   73.684967] PVR_K:   (T3C-10) 0x00000001 0x00000002 0x00000001 0x0F00DD00
[   73.692138] PVR_K:   (T3C-20) 0x00000000 0x00000000 0x00000000 0x00000000
[   73.699279] PVR_K:   (T3C-30) 0x00000000 0x00000000 0x00000000 0x00000000
[   73.706481] PVR_K:   (T3C-40) 0x00000000 0x00000000 0x00000000 0x00000000
[   73.713623] PVR_K:   (T3C-50) 0x0F00DD00 0x00000000 0x00000000 0x0F00DD00
[   73.720794] PVR_K:   (T3C-60) 0x00000000 0x00000000 0x0F00DD00 0x00000000
[   73.727996] PVR_K:   (T3C-70) 0x00000000 0x0F00DD00 0x00000000 0x0F004000
[   73.735137] PVR_K:   (T3C-80) 0x00000139 0x0001120F 0x00000000 0x0F00DEB8
[   73.742309] PVR_K:   (T3C-90) 0x00000000 0x0F000000 0xAB600000 0x0F037800
[   73.749450] PVR_K:   (T3C-A0) 0x00000000 0x0F010760 0x0F00DD00 0x0F00DEB8
[   73.756622] PVR_K:   (T3C-B0) 0x0F0109A0 0x00000000 0x00000000 0x00000000
[   73.763793] PVR_K:   (T3C-C0) 0x00000000 0x00000000 0x00000000 0x00000000
[   73.770935] PVR_K:   (T3C-D0) 0x00000000 0x00000016 0x00000015 0x0F007000
[   73.778137] PVR_K:   (T3C-E0) 0x0F00D420 0x0F00E000 0x0F010720 0x0F010720
[   73.785278] PVR_K:   (T3C-F0) 0x00000000 0x000000B5 0x000000B5 0x00000000
[   73.792449] PVR_K:   (T3C-100) 0x00000003 0x00000000 0x00000000 0x00000001
[   73.799743] PVR_K:   (T3C-110) 0xB50C565C 0x0872E100 0x08787B00 0x08787B00
[   73.806945] PVR_K: Last SGX microkernel status code: AD000104
[   73.813140] PVR_K:   (MKT-0) 07CAFCF1 00000808 0100201F AD001703
[   73.819458] PVR_K:   (MKT-1) 07CAFEF0 00000808 0000201F AD000202
[   73.825805] PVR_K:   (MKT-2) 07CAFF6D 00000808 0000211E AD000183
[   73.832092] PVR_K:   (MKT-3) 07CB005B 00000808 0000211E AD00030E
[   73.838470] PVR_K:   (MKT-4) 07CB0073 00000808 0000211E 0D800494
[   73.844757] PVR_K:   (MKT-5) 07CB008D 00000808 0000211E 00000007
[   73.851135] PVR_K:   (MKT-6) 07CB00B1 00000808 0000211E 00000008
[   73.857421] PVR_K:   (MKT-7) 07CB011B 00000808 0000211E AD000184
[   73.863800] PVR_K:   (MKT-8) 07CB017F 00000C08 0100221D AD000281
[   73.870117] PVR_K:   (MKT-9) 07CB02F5 00000808 0100221D AD00080A
[   73.876464] PVR_K:   (MKT-A) 07CB030E 00000808 0100221D 0F043F00
[   73.882781] PVR_K:   (MKT-B) 07CB0326 00000808 0100221D 00000061
[   73.889129] PVR_K:   (MKT-C) 07CB04A6 00000808 0000221D AD000802
[   73.895507] PVR_K:   (MKT-D) 07CB05F5 00000808 0000221D AD000803
[   73.901824] PVR_K:   (MKT-E) 07CB063A 00184EC8 0000221D AD000282
[   73.908172] PVR_K:   (MKT-F) 07CB25FC 00000C08 0100251F AD000200
[   73.914489] PVR_K:   (MKT-10) 07CB284C 00000808 0000251F AD000202
[   73.920959] PVR_K:   (MKT-11) 07CB28D3 00000808 0000261E AD000183
[   73.927337] PVR_K:   (MKT-12) 07CB29BB 00000808 0000261E AD00030E
[   73.933807] PVR_K:   (MKT-13) 07CB29D3 00000808 0000261E 0D800494
[   73.940216] PVR_K:   (MKT-14) 07CB29EC 00000808 0000261E 00000007
[   73.946655] PVR_K:   (MKT-15) 07CB2A0F 00000808 0000261E 00000008
[   73.953063] PVR_K:   (MKT-16) 07CB2A79 00000808 0000261E AD000184
[   73.959503] PVR_K:   (MKT-17) 07CB2ADF 00000C08 0100271D AD000281
[   73.965911] PVR_K:   (MKT-18) 07CB2C4B 00000808 0100271D AD00080A
[   73.972381] PVR_K:   (MKT-19) 07CB2C64 00000808 0100271D 0F044200
[   73.978759] PVR_K:   (MKT-1A) 07CB2C7C 00000808 0100271D 00000060
[   73.985229] PVR_K:   (MKT-1B) 07CB2F2E 00000808 0000271D AD000803
[   73.991638] PVR_K:   (MKT-1C) 07CB2F74 00180CC8 0000271D AD000282
[   73.998077] PVR_K:   (MKT-1D) 07CB3016 00000808 0100291F AD000200
[   74.004547] PVR_K:   (MKT-1E) 07CB3231 00000808 0000291F AD000202
[   74.010955] PVR_K:   (MKT-1F) 07CB32AF 00000808 00002A1E AD000183
[   74.017395] PVR_K:   (MKT-20) 07CB339C 00000808 00002A1E AD00030E
[   74.023803] PVR_K:   (MKT-21) 07CB33B4 00000808 00002A1E 0D800494
[   74.030242] PVR_K:   (MKT-22) 07CB33CD 00000808 00002A1E 00000007
[   74.036651] PVR_K:   (MKT-23) 07CB33F0 00000808 00002A1E 00000008
[   74.043090] PVR_K:   (MKT-24) 07CB345A 00000808 00002A1E AD000184
[   74.049499] PVR_K:   (MKT-25) 07CB34BE 00000C08 01002B1D AD000281
[   74.055969] PVR_K:   (MKT-26) 07CB3625 00000808 01002B1D AD00080A
[   74.062347] PVR_K:   (MKT-27) 07CB363E 00000808 01002B1D 0F044500
[   74.068817] PVR_K:   (MKT-28) 07CB3656 00000808 01002B1D 00000060
[   74.075195] PVR_K:   (MKT-29) 07CB390C 00000808 00002B1D AD000803
[   74.081665] PVR_K:   (MKT-2A) 07CB3952 00180CC8 00002B1D AD000282
[   74.088073] PVR_K:   (MKT-2B) 07CB3A3C 00000808 01002D1F AD000200
[   74.094512] PVR_K:   (MKT-2C) 07CB3C53 00000808 00002D1F AD000202
[   74.100982] PVR_K:   (MKT-2D) 07CB3CD5 00000808 00002E1E AD000183
[   74.107360] PVR_K:   (MKT-2E) 07CB3DC0 00000808 00002E1E AD00030E
[   74.113830] PVR_K:   (MKT-2F) 07CB3DD8 00000808 00002E1E 0D800494
[   74.120239] PVR_K:   (MKT-30) 07CB3DF1 00000808 00002E1E 00000007
[   74.126678] PVR_K:   (MKT-31) 07CB3E14 00000808 00002E1E 00000008
[   74.133087] PVR_K:   (MKT-32) 07CB3E82 00000808 00002E1E AD000184
[   74.139556] PVR_K:   (MKT-33) 07CB3EE7 00000C08 01002F1D AD000281
[   74.145935] PVR_K:   (MKT-34) 07CB4056 00000808 01002F1D AD00080A
[   74.152404] PVR_K:   (MKT-35) 07CB406E 00000808 01002F1D 0F044800
[   74.158813] PVR_K:   (MKT-36) 07CB4086 00000808 01002F1D 00000062
[   74.165252] PVR_K:   (MKT-37) 07CB4336 00000808 00002F1D AD000803
[   74.171661] PVR_K:   (MKT-38) 07CB437D 00180C88 00002F1D AD000282
[   74.178100] PVR_K:   (MKT-39) 07CB4EC6 00000808 0100311F AD000200
[   74.184478] PVR_K:   (MKT-3A) 07CB4FE1 00000808 0100311F AD001703
[   74.190948] PVR_K:   (MKT-3B) 07CB51C1 00000808 0000311F AD000202
[   74.197357] PVR_K:   (MKT-3C) 07CB523E 00000808 0000321E AD000183
[   74.203796] PVR_K:   (MKT-3D) 07CB5329 00000808 0000321E AD00030E
[   74.210266] PVR_K:   (MKT-3E) 07CB5341 00000808 0000321E 0D800494
[   74.216644] PVR_K:   (MKT-3F) 07CB5359 00000808 0000321E 00000007
[   74.223083] PVR_K:   (MKT-40) 07CB5380 00000808 0000321E 00000008
[   74.229492] PVR_K:   (MKT-41) 07CB53EA 00000808 0000321E AD000184
[   74.235961] PVR_K:   (MKT-42) 07CB544F 00000C08 0100331D AD000281
[   74.242370] PVR_K:   (MKT-43) 07CB5560 00000808 0100331D AD000E02
[   74.248809] PVR_K:   (MKT-44) 07CB55D4 00000808 0100331D AD000282
[   74.255218] PVR_K:   (MKT-45) 07CC24DB 00000808 0100361F AD001A00
[   74.261688] PVR_K:   (MKT-46) 07CC27F3 00000808 0100371F AD00000A
[   74.268096] PVR_K:   (MKT-47) 07CC2854 00000808 0100371F AD000909
[   74.274536] PVR_K:   (MKT-48) 07CC289E 00000808 0100371F AD001A05
[   74.280944] PVR_K:   (MKT-49) 07CC28CF 00000808 0100371F AD001302
[   74.287384] PVR_K:   (MKT-4A) 07CC290E 00000808 0100371F AD001303
[   74.293792] PVR_K:   (MKT-4B) 07CC29A0 00000808 0100371F AD000D04
[   74.300262] PVR_K:   (MKT-4C) 07CC2A6E 00000808 0100371F AD000D05
[   74.306701] PVR_K:   (MKT-4D) 07CC2AC8 00000808 0100371F AD000D04
[   74.313110] PVR_K:   (MKT-4E) 07CC2B4E 00000808 0100371F AD000D05
[   74.319549] PVR_K:   (MKT-4F) 07CC2BAB 00000808 0100371F AD001A06
[   74.325958] PVR_K:   (MKT-50) 00000460 00100808 0100031F AD002300
[   74.332397] PVR_K:   (MKT-51) 0000093A 00100808 0100041F AD00000A
[   74.338836] PVR_K:   (MKT-52) 000009B7 00100808 0100041F AD000906
[   74.345275] PVR_K:   (MKT-53) 00000A84 00100808 0000041F AD000901
[   74.351684] PVR_K:   (MKT-54) 00000AFE 00100808 0000051E AD000183
[   74.358123] PVR_K:   (MKT-55) 00000C74 00100808 0000051E AD000302
[   74.364532] PVR_K:   (MKT-56) 00000DFD 00100808 0000051E AD000D06
[   74.371154] PVR_K:   (MKT-57) 00000EE1 00100808 0000051E AD000D07
[   74.377563] PVR_K:   (MKT-58) 00000F2D 00100808 0000051E AD001304
[   74.384521] PVR_K:   (MKT-59) 00001019 00100808 0000051E AD001305
[   74.390960] PVR_K:   (MKT-5A) 00001128 00100888 0000051E AD000404
[   74.397399] PVR_K:   (MKT-5B) 000011EB 00100808 0000051E AD000402
[   74.403869] PVR_K:   (MKT-5C) 00001233 0010082B 0000051E AD000184
[   74.410308] PVR_K:   (MKT-5D) 000012D3 00108DA9 0000061D AD000281
[   74.416870] PVR_K:   (MKT-5E) 0000145F 001089AB 0000061D AD000E02
[   74.423278] PVR_K:   (MKT-5F) 000014BD 001089AF 0000061D AD000282
[   74.429748] PVR_K:   (MKT-60) 00003A90 00100808 0000081F AD000101
[   74.436157] PVR_K:   (MKT-61) 00003B06 00100808 0000081F AD000104
[   74.442626] PVR_K:   (MKT-62) 00003B42 00100808 0100091E AD000100
[   74.449035] PVR_K:   (MKT-63) 00003C45 00100808 0100091E AD000501
[   74.455505] PVR_K:   (MKT-64) 00003C85 0010082B 0100091E AD000104
[   74.461944] PVR_K:   (MKT-65) 00005EE5 00100828 01000A1F AD000101
[   74.468414] PVR_K:   (MKT-66) 00005F3C 00100828 01000A1F AD000104
[   74.474822] PVR_K:   (MKT-67) 0000604F 00100808 01000B1F AD000100
[   74.481842] PVR_K:   (MKT-68) 0000611C 00100808 01000B1F AD000501
[   74.488250] PVR_K:   (MKT-69) 00006152 00100829 01000B1F AD000104
[   74.494689] PVR_K:   (MKT-6A) 071CF768 00100808 0100031F AD000B00
[   74.501159] PVR_K:   (MKT-6B) 071CF7AC 00100808 0100031F AD000B03
[   74.507629] PVR_K:   (MKT-6C) 071CF835 00100808 0100031F AD000B05
[   74.514129] PVR_K:   (MKT-6D) 071CF889 00100808 0100031F AD000B06
[   74.520538] PVR_K:   (MKT-6E) 071CF8B8 00100808 0100031F AD000B06
[   74.527008] PVR_K:   (MKT-6F) 071CF8FB 00100808 0100031F AD000B07
[   74.533416] PVR_K:   (MKT-70) 071CF920 00100808 0100031F AD000B09
[   74.539886] PVR_K:   (MKT-71) 071CF975 00100808 0100031F AD000B01
[   74.546325] PVR_K:   (MKT-72) 071CF9B1 00100808 0100031F AD002300
[   74.553527] PVR_K:   (MKT-73) 071CFCC4 00100808 0100041F AD00000A
[   74.559997] PVR_K:   (MKT-74) 071CFD43 00100808 0100041F AD000906
[   74.566497] PVR_K:   (MKT-75) 071CFE00 00100808 0000041F AD000901
[   74.573242] PVR_K:   (MKT-76) 071CFE81 00100808 0000051E AD000183
[   74.579895] PVR_K:   (MKT-77) 071CFFED 00100808 0000051E AD000302
[   74.586303] PVR_K:   (MKT-78) 071D0041 00100808 0000051E AD000303
[   74.592773] PVR_K:   (MKT-79) 071D00C7 00100808 0000051E AD000C01
[   74.599151] PVR_K:   (MKT-7A) 071D00EC 00100808 0000051E 0D800484
[   74.605621] PVR_K:   (MKT-7B) 071D0104 00100808 0000051E 00000009
[   74.612060] PVR_K:   (MKT-7C) 071D035E 00100808 0000051E AD00030E
[   74.618499] PVR_K:   (MKT-7D) 071D0377 00100808 0000051E 0D800474
[   74.624969] PVR_K:   (MKT-7E) 071D0390 00100808 0000051E 00000008
[   74.631378] PVR_K:   (MKT-7F) 071D03B4 00100808 0000051E 00000009
[   74.637847] PVR_K:   (MKT-80) 071D042A 00100808 0000051E AD000184
[   74.644256] PVR_K:   (MKT-81) 071D04AB 00100C08 0100061D AD000281
[   74.650909] PVR_K:   (MKT-82) 071D0649 00100808 0100061D AD00080A
[   74.657318] PVR_K:   (MKT-83) 071D0662 00100808 0100061D 0F044B00
[   74.663787] PVR_K:   (MKT-84) 071D067A 00100808 0100061D 00000061
[   74.670196] PVR_K:   (MKT-85) 071D0794 00100C88 0100061D AD001300
[   74.676635] PVR_K:   (MKT-86) 071D5BC6 00100808 0000061D AD001301
[   74.683044] PVR_K:   (MKT-87) 071D5CF2 00100888 0000061D AD000802
[   74.689514] PVR_K:   (MKT-88) 071D5E60 00100888 0000061D AD000803
[   74.695922] PVR_K:   (MKT-89) 071D5EAF 001808C8 0000061D AD000282
[   74.702362] PVR_K:   (MKT-8A) 071D5F93 00184EF8 0000081E AD00000A
[   74.708770] PVR_K:   (MKT-8B) 071D600D 001808F8 0000081E AD000905
[   74.715209] PVR_K:   (MKT-8C) 071D6131 001808B8 0000081E AD000901
[   74.721649] PVR_K:   (MKT-8D) 071D61A7 00180838 0000091C AD00000A
[   74.728088] PVR_K:   (MKT-8E) 071D621C 00180838 0000091C AD000906
[   74.734527] PVR_K:   (MKT-8F) 071D6290 00180838 0000091C AD000901
[   74.740936] PVR_K:   (MKT-90) 071D62E7 00180838 00000A1B AD00000A
[   74.747375] PVR_K:   (MKT-91) 071D6355 00180838 00000A1B AD000905
[   74.753784] PVR_K:   (MKT-92) 071D6410 00180838 00000A1B AD000901
[   74.760253] PVR_K:   (MKT-93) 071D6466 00180838 00000B1A AD00000A
[   74.766662] PVR_K:   (MKT-94) 071D64C7 00180838 00000B1A AD000905
[   74.773101] PVR_K:   (MKT-95) 071D6572 00180838 00000B1A AD000901
[   74.779510] PVR_K:   (MKT-96) 071D65C6 00180838 00000C19 AD00000A
[   74.785949] PVR_K:   (MKT-97) 071D662C 00180838 00000C19 AD000905
[   74.792358] PVR_K:   (MKT-98) 071D66D5 00180838 00000C19 AD000901
[   74.798828] PVR_K:   (MKT-99) 071D6825 00180838 00000F1F AD000183
[   74.805236] PVR_K:   (MKT-9A) 071D69A3 00180838 00000F1F AD000302
[   74.811676] PVR_K:   (MKT-9B) 071D6A13 00180838 00000F1F AD000303
[   74.818084] PVR_K:   (MKT-9C) 071D6A94 00180838 00000F1F AD000C01
[   74.824523] PVR_K:   (MKT-9D) 071D6ABA 00180838 00000F1F 0D800464
[   74.830963] PVR_K:   (MKT-9E) 071D6AD2 00180838 00000F1F 0000000A
[   74.837371] PVR_K:   (MKT-9F) 071D6D08 00180838 00000F1F AD000184
[   74.843841] PVR_K:   (MKT-A0) 071D6D7D 00180C38 0100101D AD000281
[   74.850219] PVR_K:   (MKT-A1) 071D6DD3 00180838 0100101D AD000282
[   74.856689] PVR_K:   (MKT-A2) 071D7A34 00180838 0100111F AD00000A
[   74.863098] PVR_K:   (MKT-A3) 071D7A9E 00180838 0100111F AD000905
[   74.869537] PVR_K:   (MKT-A4) 071D7BA3 00180838 0000111F AD000901
[   74.875946] PVR_K:   (MKT-A5) 071D7BF4 00180C38 0100121E AD000281
[   74.882385] PVR_K:   (MKT-A6) 071D7C4B 00180838 0100121E AD000282
[   74.888793] PVR_K:   (MKT-A7) 071D7D3F 00180838 0100131F AD00000A
[   74.895263] PVR_K:   (MKT-A8) 071D7DAB 00180838 0100131F AD000905
[   74.901672] PVR_K:   (MKT-A9) 071D7EA5 00180838 0000131F AD000901
[   74.908111] PVR_K:   (MKT-AA) 071D7EF9 00180C38 0100141E AD000281
[   74.914520] PVR_K:   (MKT-AB) 071D7F52 00100828 0100141E AD000282
[   74.920989] PVR_K:   (MKT-AC) 071D8011 00000808 0100151F AD000200
[   74.927429] PVR_K:   (MKT-AD) 071D8262 00000808 0000151F AD000202
[   74.933837] PVR_K:   (MKT-AE) 071D830B 00000808 0000161E AD00000A
[   74.940277] PVR_K:   (MKT-AF) 071D837C 00000808 0000161E AD000905
[   74.946685] PVR_K:   (MKT-B0) 071D846A 00000808 0000161E AD000901
[   74.953155] PVR_K:   (MKT-B1) 071D84BA 00000C08 0000171D AD000281
[   74.959564] PVR_K:   (MKT-B2) 071D861A 00000808 0000171D AD00080A
[   74.966033] PVR_K:   (MKT-B3) 071D8633 00000808 0000171D 0F044E00
[   74.972412] PVR_K:   (MKT-B4) 071D864B 00000808 0000171D 00000060
[   74.978881] PVR_K:   (MKT-B5) 071D890E 00000808 0000171D AD000803
[   74.985290] PVR_K:   (MKT-B6) 071D8954 00180CC8 0000171D AD000282
[   74.991729] PVR_K:   (MKT-B7) 071D8A0B 00000808 0000181F AD00000A
[   74.998138] PVR_K:   (MKT-B8) 071D8A74 00000808 0000181F AD000905
[   75.004608] PVR_K:   (MKT-B9) 071D8B69 00000888 0000181F AD000901
[   75.010986] PVR_K:   (MKT-BA) 071D8BB4 00000C08 00001A1D AD000200
[   75.017456] PVR_K:   (MKT-BB) 071D8DE8 00000808 00001A1D AD000202
[   75.023864] PVR_K:   (MKT-BC) 071D8E3F 00000808 01001B1C AD000281
[   75.030303] PVR_K:   (MKT-BD) 071D8F8C 00000808 01001B1C AD00080A
[   75.036743] PVR_K:   (MKT-BE) 071D8FA5 00000808 01001B1C 0F045100
[   75.043151] PVR_K:   (MKT-BF) 071D8FBD 00000808 01001B1C 00000060
[   75.049621] PVR_K:   (MKT-C0) 071D9284 00000808 00001B1C AD000803
[   75.056030] PVR_K:   (MKT-C1) 071D92CF 00180CC8 00001B1C AD000282
[   75.062469] PVR_K:   (MKT-C2) 071D93B8 00000808 01001D1F AD000200
[   75.068878] PVR_K:   (MKT-C3) 071D95E6 00000808 01001D1F AD000202
[   75.075317] PVR_K:   (MKT-C4) 071D9635 00000808 01001E1E AD000281
[   75.081726] PVR_K:   (MKT-C5) 071D9786 00000808 01001E1E AD00080A
[   75.088195] PVR_K:   (MKT-C6) 071D97A2 00000808 01001E1E 0F045400
[   75.094604] PVR_K:   (MKT-C7) 071D97BB 00000808 01001E1E 00000062
[   75.101043] PVR_K:   (MKT-C8) 071D9A82 00000808 00001E1E AD000803
[   75.107452] PVR_K:   (MKT-C9) 071D9ACB 00180C88 00001E1E AD000282
[   75.113891] PVR_K:   (MKT-CA) 071DA649 00000808 0100201F AD000200
[   75.120300] PVR_K:   (MKT-CB) 071DA767 00000808 0100201F AD001703
[   75.126770] PVR_K:   (MKT-CC) 071DA96D 00000808 0000201F AD000202
[   75.133209] PVR_K:   (MKT-CD) 071DA9F0 00000808 0000211E AD000183
[   75.139617] PVR_K:   (MKT-CE) 071DAADE 00000808 0000211E AD00030E
[   75.146057] PVR_K:   (MKT-CF) 071DAAF6 00000808 0000211E 0D800494
[   75.152465] PVR_K:   (MKT-D0) 071DAB12 00000808 0000211E 00000008
[   75.158935] PVR_K:   (MKT-D1) 071DAB35 00000808 0000211E 00000009
[   75.165344] PVR_K:   (MKT-D2) 071DABA2 00000808 0000211E AD000184
[   75.171783] PVR_K:   (MKT-D3) 071DAC08 00000C08 0100221D AD000281
[   75.178192] PVR_K:   (MKT-D4) 071DAD84 00000808 0100221D AD00080A
[   75.184661] PVR_K:   (MKT-D5) 071DAD9D 00000808 0100221D 0F045700
[   75.191040] PVR_K:   (MKT-D6) 071DADB5 00000808 0100221D 00000061
[   75.197509] PVR_K:   (MKT-D7) 071DAF36 00000808 0000221D AD000802
[   75.203918] PVR_K:   (MKT-D8) 071DB08C 00000808 0000221D AD000803
[   75.210388] PVR_K:   (MKT-D9) 071DB0D3 00184EC8 0000221D AD000282
[   75.216766] PVR_K:   (MKT-DA) 071DD046 00000C08 0100251F AD000200
[   75.223236] PVR_K:   (MKT-DB) 071DD2A3 00000808 0000251F AD000202
[   75.229614] PVR_K:   (MKT-DC) 071DD32D 00000808 0000261E AD000183
[   75.236083] PVR_K:   (MKT-DD) 071DD418 00000808 0000261E AD00030E
[   75.242523] PVR_K:   (MKT-DE) 071DD430 00000808 0000261E 0D800494
[   75.248931] PVR_K:   (MKT-DF) 071DD449 00000808 0000261E 00000008
[   75.255401] PVR_K:   (MKT-E0) 071DD46D 00000808 0000261E 00000009
[   75.261810] PVR_K:   (MKT-E1) 071DD4DA 00000808 0000261E AD000184
[   75.268249] PVR_K:   (MKT-E2) 071DD53E 00000C08 0100271D AD000281
[   75.274658] PVR_K:   (MKT-E3) 071DD6A9 00000808 0100271D AD00080A
[   75.281127] PVR_K:   (MKT-E4) 071DD6C2 00000808 0100271D 0F045A00
[   75.287536] PVR_K:   (MKT-E5) 071DD6DA 00000808 0100271D 00000060
[   75.293975] PVR_K:   (MKT-E6) 071DD98D 00000808 0000271D AD000803
[   75.300384] PVR_K:   (MKT-E7) 071DD9D3 00180CC8 0000271D AD000282
[   75.306823] PVR_K:   (MKT-E8) 071DDA93 00000808 0100291F AD000200
[   75.313232] PVR_K:   (MKT-E9) 071DDCB0 00000808 0000291F AD000202
[   75.319702] PVR_K:   (MKT-EA) 071DDD2E 00000808 00002A1E AD000183
[   75.326080] PVR_K:   (MKT-EB) 071DDE1B 00000808 00002A1E AD00030E
[   75.332550] PVR_K:   (MKT-EC) 071DDE33 00000808 00002A1E 0D800494
[   75.339019] PVR_K:   (MKT-ED) 071DDE4C 00000808 00002A1E 00000008
[   75.345428] PVR_K:   (MKT-EE) 071DDE6F 00000808 00002A1E 00000009
[   75.351898] PVR_K:   (MKT-EF) 071DDED9 00000808 00002A1E AD000184
[   75.358398] PVR_K:   (MKT-F0) 071DDF40 00000C08 01002B1D AD000281
[   75.364868] PVR_K:   (MKT-F1) 071DE0AE 00000808 01002B1D AD00080A
[   75.371276] PVR_K:   (MKT-F2) 071DE0C6 00000808 01002B1D 0F045D00
[   75.377746] PVR_K:   (MKT-F3) 071DE0DE 00000808 01002B1D 00000060
[   75.384155] PVR_K:   (MKT-F4) 071DE386 00000808 00002B1D AD000803
[   75.390624] PVR_K:   (MKT-F5) 071DE3CC 00188CC8 00002B1D AD000282
[   75.397033] PVR_K:   (MKT-F6) 071DE4B5 00000808 01002D1F AD000200
[   75.403472] PVR_K:   (MKT-F7) 071DE6CF 00000808 00002D1F AD000202
[   75.409912] PVR_K:   (MKT-F8) 071DE74F 00000808 00002E1E AD000183
[   75.416381] PVR_K:   (MKT-F9) 071DE83A 00000808 00002E1E AD00030E
[   75.422821] PVR_K:   (MKT-FA) 071DE853 00000808 00002E1E 0D800494
[   75.429290] PVR_K:   (MKT-FB) 071DE86B 00000808 00002E1E 00000008
[   75.435699] PVR_K:   (MKT-FC) 071DE88F 00000808 00002E1E 00000009
[   75.442169] PVR_K:   (MKT-FD) 071DE8F9 00000808 00002E1E AD000184
[   75.448638] PVR_K:   (MKT-FE) 071DE95F 00000C08 01002F1D AD000281
[   75.455047] PVR_K:   (MKT-FF) 071DEAD3 00000808 01002F1D AD00080A
[   75.461517] PVR_K:   (MKT-100) 071DEAEC 00000808 01002F1D 0F046000
[   75.468780] PVR_K:   (MKT-101) 071DEB04 00000808 01002F1D 00000062
[   75.475341] PVR_K:   (MKT-102) 071DEDB1 00000808 00002F1D AD000803
[   75.481933] PVR_K:   (MKT-103) 071DEDF6 00180C88 00002F1D AD000282
[   75.488525] PVR_K:   (MKT-104) 071DF903 00000808 0100311F AD000200
[   75.495056] PVR_K:   (MKT-105) 071DFA21 00000808 0100311F AD001703
[   75.501617] PVR_K:   (MKT-106) 071DFC05 00000808 0000311F AD000202
[   75.508148] PVR_K:   (MKT-107) 071DFC81 00000808 0000321E AD000183
[   75.514709] PVR_K:   (MKT-108) 071DFD6B 00000808 0000321E AD00030E
[   75.521575] PVR_K:   (MKT-109) 071DFD83 00000808 0000321E 0D800494
[   75.528137] PVR_K:   (MKT-10A) 071DFD9C 00000808 0000321E 00000008
[   75.534667] PVR_K:   (MKT-10B) 071DFDC1 00000808 0000321E 00000009
[   75.541168] PVR_K:   (MKT-10C) 071DFE2E 00000808 0000321E AD000184
[   75.547729] PVR_K:   (MKT-10D) 071DFE92 00000C08 0100331D AD000281
[   75.554229] PVR_K:   (MKT-10E) 071DFFA5 00000808 0100331D AD000E02
[   75.560760] PVR_K:   (MKT-10F) 071E001A 00000808 0100331D AD000282
[   75.567260] PVR_K:   (MKT-110) 071ECEA0 00000808 0100361F AD001A00
[   75.573791] PVR_K:   (MKT-111) 071FECC6 00000808 01003A1F AD00000A
[   75.580291] PVR_K:   (MKT-112) 071FED28 00000808 01003A1F AD000909
[   75.586822] PVR_K:   (MKT-113) 071FED72 00000808 01003A1F AD001A05
[   75.593322] PVR_K:   (MKT-114) 071FEDA2 00000808 01003A1F AD001302
[   75.599884] PVR_K:   (MKT-115) 071FEDE1 00000808 01003A1F AD001303
[   75.606384] PVR_K:   (MKT-116) 071FEE70 00000808 01003A1F AD000D04
[   75.612915] PVR_K:   (MKT-117) 071FEF3F 00000808 01003A1F AD000D05
[   75.619476] PVR_K:   (MKT-118) 071FEF97 00000808 01003A1F AD000D04
[   75.625976] PVR_K:   (MKT-119) 071FF01C 00000808 01003A1F AD000D05
[   75.632507] PVR_K:   (MKT-11A) 071FF07C 00000808 01003A1F AD001A06
[   75.639007] PVR_K:   (MKT-11B) 000004C0 00100808 0100031F AD002300
[   75.645568] PVR_K:   (MKT-11C) 000009A6 00100808 0100041F AD00000A
[   75.652069] PVR_K:   (MKT-11D) 00000A24 00100808 0100041F AD000906
[   75.658599] PVR_K:   (MKT-11E) 00000AF2 00100808 0000041F AD000901
[   75.665100] PVR_K:   (MKT-11F) 00000B6C 00100808 0000051E AD000183
[   75.671661] PVR_K:   (MKT-120) 00000CE5 00100808 0000051E AD000302
[   75.678161] PVR_K:   (MKT-121) 00000E65 00100808 0000051E AD000D06
[   75.684692] PVR_K:   (MKT-122) 00000F49 00100808 0000051E AD000D07
[   75.691192] PVR_K:   (MKT-123) 00000F93 00100808 0000051E AD001304
[   75.697723] PVR_K:   (MKT-124) 0000107E 00100808 0000051E AD001305
[   75.704284] PVR_K:   (MKT-125) 00001190 00100888 0000051E AD000404
[   75.710784] PVR_K:   (MKT-126) 00001252 00100808 0000051E AD000402
[   75.717315] PVR_K:   (MKT-127) 0000129A 0010082B 0000051E AD000184
[   75.723815] PVR_K:   (MKT-128) 00001321 00108DAF 0000061D AD000281
[   75.730377] PVR_K:   (MKT-129) 000014A8 001199AD 0000061D AD000E02
[   75.736846] PVR_K:   (MKT-12A) 00001504 001199A9 0000061D AD000282
[   75.743408] PVR_K:   (MKT-12B) 00003B05 00100808 0000081F AD000101
[   75.749877] PVR_K:   (MKT-12C) 00003B7A 00100808 0000081F AD000104
[   75.756439] PVR_K:   (MKT-12D) 00003BB6 00100808 0100091E AD000100
[   75.762939] PVR_K:   (MKT-12E) 00003CB9 00100808 0100091E AD000501
[   75.769470] PVR_K:   (MKT-12F) 00003CF8 0010082B 0100091E AD000104
[   75.775970] PVR_K:   (MKT-130) 00005F46 00100828 01000A1F AD000101
[   75.782531] PVR_K:   (MKT-131) 00005F8A 00100828 01000A1F AD000104
[   75.789062] PVR_K:   (MKT-132) 0000608D 00100808 01000B1F AD000100
[   75.795562] PVR_K:   (MKT-133) 00006146 00100808 01000B1F AD000501
[   75.802093] PVR_K:   (MKT-134) 00006172 00100829 01000B1F AD000104
[   75.808593] PVR_K:   (MKT-135) 08441FB0 00100808 0100031F AD000B00
[   75.815155] PVR_K:   (MKT-136) 08441FF5 00100808 0100031F AD000B03
[   75.821655] PVR_K:   (MKT-137) 0844207C 00100808 0100031F AD000B05
[   75.828186] PVR_K:   (MKT-138) 084420D3 00100808 0100031F AD000B06
[   75.834686] PVR_K:   (MKT-139) 08442102 00100808 0100031F AD000B06
[   75.841217] PVR_K:   (MKT-13A) 08442146 00100808 0100031F AD000B07
[   75.847717] PVR_K:   (MKT-13B) 0844216B 00100808 0100031F AD000B09
[   75.854248] PVR_K:   (MKT-13C) 084421C0 00100808 0100031F AD000B01
[   75.860778] PVR_K:   (MKT-13D) 084421FC 00100808 0100031F AD002300
[   75.867309] PVR_K:   (MKT-13E) 0844250C 00100808 0100041F AD00000A
[   75.873870] PVR_K:   (MKT-13F) 08442589 00100808 0100041F AD000906
[   75.880340] PVR_K:   (MKT-140) 08442643 00100808 0000041F AD000901
[   75.886901] PVR_K:   (MKT-141) 084426BE 00100808 0000051E AD000183
[   75.893371] PVR_K:   (MKT-142) 08442829 00100808 0000051E AD000302
[   75.899932] PVR_K:   (MKT-143) 0844287E 00100808 0000051E AD000303
[   75.906433] PVR_K:   (MKT-144) 08442904 00100808 0000051E AD000C01
[   75.912994] PVR_K:   (MKT-145) 08442929 00100808 0000051E 0D800484
[   75.919464] PVR_K:   (MKT-146) 08442942 00100808 0000051E 0000000A
[   75.926025] PVR_K:   (MKT-147) 08442BA3 00100808 0000051E AD00030E
[   75.932495] PVR_K:   (MKT-148) 08442BBB 00100808 0000051E 0D800474
[   75.939056] PVR_K:   (MKT-149) 08442BD3 00100808 0000051E 00000009
[   75.945556] PVR_K:   (MKT-14A) 08442BF9 00100808 0000051E 0000000A
[   75.952117] PVR_K:   (MKT-14B) 08442C73 00100808 0000051E AD000184
[   75.958648] PVR_K:   (MKT-14C) 08442CF2 00100C08 0100061D AD000281
[   75.965423] PVR_K:   (MKT-14D) 08442E89 00100808 0100061D AD00080A
[   75.971954] PVR_K:   (MKT-14E) 08442EA3 00100808 0100061D 0F046300
[   75.978454] PVR_K:   (MKT-14F) 08442EBB 00100808 0100061D 00000061
[   75.985015] PVR_K:   (MKT-150) 08442FD2 00100C88 0100061D AD001300
[   75.991516] PVR_K:   (MKT-151) 084483B7 00100808 0000061D AD001301
[   75.998046] PVR_K:   (MKT-152) 084484E4 00100888 0000061D AD000802
[   76.004547] PVR_K:   (MKT-153) 0844864D 00100888 0000061D AD000803
[   76.011108] PVR_K:   (MKT-154) 0844869D 001808C8 0000061D AD000282
[   76.017608] PVR_K:   (MKT-155) 0844878A 00184AF8 0000081E AD00000A
[   76.024139] PVR_K:   (MKT-156) 0844880A 001808F8 0000081E AD000905
[   76.030639] PVR_K:   (MKT-157) 08448930 001808B8 0000081E AD000901
[   76.037139] PVR_K:   (MKT-158) 084489A9 00180838 0000091C AD00000A
[   76.043670] PVR_K:   (MKT-159) 08448A1E 00180838 0000091C AD000906
[   76.050170] PVR_K:   (MKT-15A) 08448A94 00180838 0000091C AD000901
[   76.056732] PVR_K:   (MKT-15B) 08448AEE 00180838 00000A1B AD00000A
[   76.063232] PVR_K:   (MKT-15C) 08448B53 00180838 00000A1B AD000905
[   76.069793] PVR_K:   (MKT-15D) 08448C03 00180838 00000A1B AD000901
[   76.076263] PVR_K:   (MKT-15E) 08448C5B 00180838 00000B1A AD00000A
[   76.082824] PVR_K:   (MKT-15F) 08448CC0 00180838 00000B1A AD000905
[   76.089324] PVR_K:   (MKT-160) 08448D6D 00180838 00000B1A AD000901
[   76.095855] PVR_K:   (MKT-161) 08448DC6 00180838 00000C19 AD00000A
[   76.102355] PVR_K:   (MKT-162) 08448E33 00180838 00000C19 AD000905
[   76.108917] PVR_K:   (MKT-163) 08448EE0 00180838 00000C19 AD000901
[   76.115447] PVR_K:   (MKT-164) 0844903A 00180838 00000F1F AD000183
[   76.121948] PVR_K:   (MKT-165) 084491BC 00180838 00000F1F AD000302
[   76.128479] PVR_K:   (MKT-166) 0844922E 00180838 00000F1F AD000303
[   76.134979] PVR_K:   (MKT-167) 084492B0 00180838 00000F1F AD000C01
[   76.141540] PVR_K:   (MKT-168) 084492D7 00180838 00000F1F 0D800464
[   76.148040] PVR_K:   (MKT-169) 084492EF 00180838 00000F1F 0000000B
[   76.154571] PVR_K:   (MKT-16A) 08449506 00180838 00000F1F AD000184
[   76.161071] PVR_K:   (MKT-16B) 08449573 00180C38 0100101D AD000281
[   76.167633] PVR_K:   (MKT-16C) 084495CB 00180838 0100101D AD000282
[   76.174102] PVR_K:   (MKT-16D) 0844A1E7 00180838 0100111F AD00000A
[   76.180664] PVR_K:   (MKT-16E) 0844A254 00180838 0100111F AD000905
[   76.187164] PVR_K:   (MKT-16F) 0844A35C 00180838 0000111F AD000901
[   76.193695] PVR_K:   (MKT-170) 0844A3AD 00180C38 0100121E AD000281
[   76.200256] PVR_K:   (MKT-171) 0844A407 00180838 0100121E AD000282
[   76.206756] PVR_K:   (MKT-172) 0844A4E8 00180838 0100131F AD00000A
[   76.213287] PVR_K:   (MKT-173) 0844A553 00180838 0100131F AD000905
[   76.219787] PVR_K:   (MKT-174) 0844A650 00180838 0000131F AD000901
[   76.226379] PVR_K:   (MKT-175) 0844A6A5 00180C38 0100141E AD000281
[   76.232879] PVR_K:   (MKT-176) 0844A6FD 00100828 0100141E AD000282
[   76.239471] PVR_K:   (MKT-177) 0844A81E 00000808 0000151F AD00000A
[   76.245971] PVR_K:   (MKT-178) 0844A888 00000808 0000151F AD000905
[   76.252532] PVR_K:   (MKT-179) 0844A982 00000808 0000151F AD000901
[   76.259124] PVR_K:   (MKT-17A) 0844A9B9 00000C08 0000161E AD000200
[   76.265655] PVR_K:   (MKT-17B) 0844AC09 00000808 0000161E AD000202
[   76.272155] PVR_K:   (MKT-17C) 0844AC61 00000808 0000171D AD000281
[   76.278717] PVR_K:   (MKT-17D) 0844ADAC 00000808 0000171D AD00080A
[   76.285247] PVR_K:   (MKT-17E) 0844ADC5 00000808 0000171D 0F046600
[   76.291778] PVR_K:   (MKT-17F) 0844ADDE 00000808 0000171D 00000060
[   76.298339] PVR_K:   (MKT-180) 0844B096 00000808 0000171D AD000803
[   76.304840] PVR_K:   (MKT-181) 0844B0DB 00180CC8 0000171D AD000282
[   76.311401] PVR_K:   (MKT-182) 0844B18D 00000808 0000181F AD00000A
[   76.317901] PVR_K:   (MKT-183) 0844B1F7 00000808 0000181F AD000905
[   76.324432] PVR_K:   (MKT-184) 0844B2EA 00000888 0000181F AD000901
[   76.330963] PVR_K:   (MKT-185) 0844B333 00000C08 00001A1D AD000200
[   76.337524] PVR_K:   (MKT-186) 0844B562 00000808 00001A1D AD000202
[   76.344055] PVR_K:   (MKT-187) 0844B5BC 00000808 01001B1C AD000281
[   76.350646] PVR_K:   (MKT-188) 0844B706 00000808 01001B1C AD00080A
[   76.357147] PVR_K:   (MKT-189) 0844B71E 00000808 01001B1C 0F046900
[   76.363677] PVR_K:   (MKT-18A) 0844B737 00000808 01001B1C 00000060
[   76.370239] PVR_K:   (MKT-18B) 0844B9E6 00000808 00001B1C AD000803
[   76.376739] PVR_K:   (MKT-18C) 0844BA2D 00180CC8 00001B1C AD000282
[   76.383300] PVR_K:   (MKT-18D) 0844BB20 00000808 01001D1F AD000200
[   76.390594] PVR_K:   (MKT-18E) 0844BD4B 00000808 00001D1F AD000202
[   76.397155] PVR_K:   (MKT-18F) 0844BD98 00000808 01001E1E AD000281
[   76.403747] PVR_K:   (MKT-190) 0844BEE2 00000808 01001E1E AD00080A
[   76.410339] PVR_K:   (MKT-191) 0844BEFA 00000808 01001E1E 0F046C00
[   76.416900] PVR_K:   (MKT-192) 0844BF12 00000808 01001E1E 00000062
[   76.423461] PVR_K:   (MKT-193) 0844C1B9 00000808 00001E1E AD000803
[   76.430084] PVR_K:   (MKT-194) 0844C1FE 00180C88 00001E1E AD000282
[   76.436798] PVR_K:   (MKT-195) 0844CCEC 00000808 0100201F AD000200
[   76.443267] PVR_K:   (MKT-196) 0844CE06 00000808 0100201F AD001703
[   76.449829] PVR_K:   (MKT-197) 0844D002 00000808 0000201F AD000202
[   76.456420] PVR_K:   (MKT-198) 0844D080 00000808 0000211E AD000183
[   76.462921] PVR_K:   (MKT-199) 0844D16C 00000808 0000211E AD00030E
[   76.469482] PVR_K:   (MKT-19A) 0844D184 00000808 0000211E 0D800494
[   76.476013] PVR_K:   (MKT-19B) 0844D19D 00000808 0000211E 00000009
[   76.482543] PVR_K:   (MKT-19C) 0844D1C0 00000808 0000211E 0000000A
[   76.489044] PVR_K:   (MKT-19D) 0844D22D 00000808 0000211E AD000184
[   76.495605] PVR_K:   (MKT-19E) 0844D290 00000C08 0100221D AD000281
[   76.502105] PVR_K:   (MKT-19F) 0844D406 00000808 0100221D AD00080A
[   76.508666] PVR_K:   (MKT-1A0) 0844D41F 00000808 0100221D 0F046F00
[   76.515197] PVR_K:   (MKT-1A1) 0844D437 00000808 0100221D 00000061
[   76.521728] PVR_K:   (MKT-1A2) 0844D5B4 00000808 0000221D AD000802
[   76.528259] PVR_K:   (MKT-1A3) 0844D704 00000808 0000221D AD000803
[   76.534942] PVR_K:   (MKT-1A4) 0844D74C 00184EC8 0000221D AD000282
[   76.541503] PVR_K:   (MKT-1A5) 0844F6AB 00000C08 0100251F AD000200
[   76.548004] PVR_K:   (MKT-1A6) 0844F8FA 00000808 0000251F AD000202
[   76.554565] PVR_K:   (MKT-1A7) 0844F982 00000808 0000261E AD000183
[   76.561157] PVR_K:   (MKT-1A8) 0844FA6E 00000808 0000261E AD00030E
[   76.567687] PVR_K:   (MKT-1A9) 0844FA86 00000808 0000261E 0D800494
[   76.574218] PVR_K:   (MKT-1AA) 0844FA9F 00000808 0000261E 00000009
[   76.580749] PVR_K:   (MKT-1AB) 0844FAC2 00000808 0000261E 0000000A
[   76.587249] PVR_K:   (MKT-1AC) 0844FB2C 00000808 0000261E AD000184
[   76.593811] PVR_K:   (MKT-1AD) 0844FB98 00000C08 0100271D AD000281
[   76.600311] PVR_K:   (MKT-1AE) 0844FD07 00000808 0100271D AD00080A
[   76.606872] PVR_K:   (MKT-1AF) 0844FD20 00000808 0100271D 0F037200
[   76.613372] PVR_K:   (MKT-1B0) 0844FD38 00000808 0100271D 00000060
[   76.619934] PVR_K:   (MKT-1B1) 0844FFE4 00000808 0000271D AD000803
[   76.626495] PVR_K:   (MKT-1B2) 0845002F 00188CC8 0000271D AD000282
[   76.632995] PVR_K:   (MKT-1B3) 084500D0 00000808 0100291F AD000200
[   76.639587] PVR_K:   (MKT-1B4) 084502ED 00000808 0000291F AD000202
[   76.646087] PVR_K:   (MKT-1B5) 0845036C 00000808 00002A1E AD000183
[   76.652618] PVR_K:   (MKT-1B6) 08450455 00000808 00002A1E AD00030E
[   76.659149] PVR_K:   (MKT-1B7) 0845046D 00000808 00002A1E 0D800494
[   76.665710] PVR_K:   (MKT-1B8) 08450486 00000808 00002A1E 00000009
[   76.672210] PVR_K:   (MKT-1B9) 084504A9 00000808 00002A1E 0000000A
[   76.678771] PVR_K:   (MKT-1BA) 08450514 00000808 00002A1E AD000184
[   76.685272] PVR_K:   (MKT-1BB) 08450578 00000C08 01002B1D AD000281
[   76.691833] PVR_K:   (MKT-1BC) 084506E3 00000808 01002B1D AD00080A
[   76.699127] PVR_K:   (MKT-1BD) 084506FB 00000808 01002B1D 0F037500
[   76.705749] PVR_K:   (MKT-1BE) 08450714 00000808 01002B1D 00000060
[   76.712371] PVR_K:   (MKT-1BF) 084509BC 00000808 00002B1D AD000803
[   76.719085] PVR_K:   (MKT-1C0) 08450A01 00180CC8 00002B1D AD000282
[   76.726043] PVR_K:   (MKT-1C1) 08450AE7 00000808 01002D1F AD000200
[   76.732788] PVR_K:   (MKT-1C2) 08450D01 00000808 00002D1F AD000202
[   76.739593] PVR_K:   (MKT-1C3) 08450D7F 00000808 00002E1E AD000183
[   76.746093] PVR_K:   (MKT-1C4) 08450E6C 00000808 00002E1E AD00030E
[   76.752655] PVR_K:   (MKT-1C5) 08450E85 00000808 00002E1E 0D800494
[   76.759155] PVR_K:   (MKT-1C6) 08450E9E 00000808 00002E1E 00000009
[   76.765716] PVR_K:   (MKT-1C7) 08450EC2 00000808 00002E1E 0000000A
[   76.772186] PVR_K:   (MKT-1C8) 08450F2C 00000808 00002E1E AD000184
[   76.778747] PVR_K:   (MKT-1C9) 08450F90 00000C08 01002F1D AD000281
[   76.785247] PVR_K:   (MKT-1CA) 084510FC 00000808 01002F1D AD00080A
[   76.791778] PVR_K:   (MKT-1CB) 08451115 00000808 01002F1D 0F037800
[   76.798339] PVR_K:   (MKT-1CC) 0845112D 00000808 01002F1D 00000062
[   76.804809] PVR_K:   (MKT-1CD) 084513E3 00000808 00002F1D AD000803
[   76.811340] PVR_K:   (MKT-1CE) 08451429 00180C88 00002F1D AD000282
[   76.817840] PVR_K:   (MKT-1CF) 08451F40 00000808 0100311F AD000200
[   76.824401] PVR_K:   (MKT-1D0) 0845205B 00000808 0100311F AD001703
[   76.830902] PVR_K:   (MKT-1D1) 0845223C 00000808 0000311F AD000202
[   76.837432] PVR_K:   (MKT-1D2) 084522B9 00000808 0000321E AD000183
[   76.843933] PVR_K:   (MKT-1D3) 084523A4 00000808 0000321E AD00030E
[   76.850494] PVR_K:   (MKT-1D4) 084523BD 00000808 0000321E 0D800494
[   76.856994] PVR_K:   (MKT-1D5) 084523D6 00000808 0000321E 00000009
[   76.863525] PVR_K:   (MKT-1D6) 084523FA 00000808 0000321E 0000000A
[   76.870056] PVR_K:   (MKT-1D7) 08452464 00000808 0000321E AD000184
[   76.876556] PVR_K:   (MKT-1D8) 084524C8 00000C08 0100331D AD000281
[   76.883087] PVR_K:   (MKT-1D9) 084525D8 00000808 0100331D AD000E02
[   76.889587] PVR_K:   (MKT-1DA) 08452649 00000808 0100331D AD000282
[   76.896118] PVR_K:   (MKT-1DB) 0845F6EA 00000808 0100361F AD001A00
[   76.902648] PVR_K:   (MKT-1DC) 0846D45F 00000808 0100391F AD00000A
[   76.909179] PVR_K:   (MKT-1DD) 0846D4C3 00000808 0100391F AD000909
[   76.915679] PVR_K:   (MKT-1DE) 0846D511 00000808 0100391F AD001A05
[   76.922241] PVR_K:   (MKT-1DF) 0846D543 00000808 0100391F AD001302
[   76.928741] PVR_K:   (MKT-1E0) 0846D583 00000808 0100391F AD001303
[   76.935272] PVR_K:   (MKT-1E1) 0846D616 00000808 0100391F AD000D04
[   76.941772] PVR_K:   (MKT-1E2) 0846D6E4 00000808 0100391F AD000D05
[   76.948303] PVR_K:   (MKT-1E3) 0846D73C 00000808 0100391F AD000D04
[   76.954864] PVR_K:   (MKT-1E4) 0846D7C1 00000808 0100391F AD000D05
[   76.961364] PVR_K:   (MKT-1E5) 0846D81D 00000808 0100391F AD001A06
[   76.967895] PVR_K:   (MKT-1E6) 00000468 00100808 0100031F AD002300
[   76.974395] PVR_K:   (MKT-1E7) 00000949 00100808 0100041F AD00000A
[   76.980926] PVR_K:   (MKT-1E8) 000009C7 00100808 0100041F AD000906
[   76.987457] PVR_K:   (MKT-1E9) 00000A95 00100808 0000041F AD000901
[   76.993988] PVR_K:   (MKT-1EA) 00000B0F 00100808 0000051E AD000183
[   77.000518] PVR_K:   (MKT-1EB) 00000C85 00100808 0000051E AD000302
[   77.007049] PVR_K:   (MKT-1EC) 00000E10 00100808 0000051E AD000D06
[   77.013549] PVR_K:   (MKT-1ED) 00000EF8 00100808 0000051E AD000D07
[   77.020111] PVR_K:   (MKT-1EE) 00000F41 00100808 0000051E AD001304
[   77.026641] PVR_K:   (MKT-1EF) 00001030 00100808 0000051E AD001305
[   77.033233] PVR_K:   (MKT-1F0) 00001147 00100888 0000051E AD000404
[   77.039764] PVR_K:   (MKT-1F1) 0000120A 00100808 0000051E AD000402
[   77.047821] PVR_K:   (MKT-1F2) 00001253 0010082B 0000051E AD000184
[   77.054382] PVR_K:   (MKT-1F3) 000012DD 00119DAD 0000061D AD000281
[   77.060882] PVR_K:   (MKT-1F4) 00001477 001199AB 0000061D AD000E02
[   77.067413] PVR_K:   (MKT-1F5) 000014D4 001088AD 0000061D AD000282
[   77.073913] PVR_K:   (MKT-1F6) 00003AB9 00100808 0000081F AD000101
[   77.080474] PVR_K:   (MKT-1F7) 00003B2F 00100808 0000081F AD000104
[   77.086975] PVR_K:   (MKT-1F8) 00003B6C 00100808 0100091E AD000100
[   77.093536] PVR_K:   (MKT-1F9) 00003C74 00100808 0100091E AD000501
[   77.100006] PVR_K:   (MKT-1FA) 00003CB3 0010082B 0100091E AD000104
[   77.106567] PVR_K:   (MKT-1FB) 00005F30 00100828 01000A1F AD000101
[   77.113037] PVR_K:   (MKT-1FC) 00005F74 00100828 01000A1F AD000104
[   77.119598] PVR_K:   (MKT-1FD) 00006084 00100808 01000B1F AD000100
[   77.126129] PVR_K:   (MKT-1FE) 0000613E 00100808 01000B1F AD000501
[   77.132629] PVR_K:   (MKT-1FF) 0000616A 00100829 01000B1F AD000104
[   77.139160] PVR_K: SGX Kernel CCB WO:0x90 RO:0x90
[   77.145660] adc_to_temp_conversion:Temp read is invalid 0
[   77.151611] thermal_lookup_temp: getting temp is not supported for domain pcb
[   77.164581] adc_to_temp_conversion:Temp read is invalid 0
[   77.170410] thermal_lookup_temp: getting temp is not supported for domain pcb
[   77.179321] adc_to_temp_conversion:Temp read is invalid 0
[   77.185150] thermal_lookup_temp: getting temp is not supported for domain pcb
[   77.374053] PVR_K:(Error): SGXOSTimer() detected SGX lockup (0x6 tasks) [0, ]
[   77.389495] PVR_K: HWRecoveryResetSGX: SGX Hardware Recovery triggered
[   77.397003] [   49.522]                      [c6f10000] dsscomp_apply
[   77.397003] [   49.543]                     [c6f10c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   77.397003] [   49.543]   [c6edba00] --refs=0 on RELEASED
[   77.397003] [   49.543]   [c6edba00] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   77.397003] [   49.543]                     [c6f10c00] dsscomp_mgr_delayed_cb on RELEASED
[   77.432922] [   49.543]                      [c6f10000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   77.432922] [   49.557]                      [c6f10000] dsscomp_mgr_delayed_cb on DISPLAYED
[   77.432922] [   55.906]  [c6fa40a0] new in dsscomp_gralloc_queue (refs=1)
[   77.461273] [   55.906]                          [c6e66c00] dsscomp_new
[   77.461273] [   55.906]  [c6fa40a0] ++refs=2 for [c6e66c00]
[   77.461303] [   55.906]                          [c6e66c00] dsscomp_delayed_apply
[   77.461303] [   55.906]  [c6fa40a0] --refs=1 on RELEASED
[   77.491180] [   55.906]                          [c6e66c00] dsscomp_apply
[   77.491180] [   55.907]    [c6edb880] --refs=0 on RELEASED
[   77.491180] [   55.907]    [c6edb880] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   77.491180] [   55.907]                      [c6f10000] dsscomp_mgr_delayed_cb on RELEASED
[   77.521087] [   55.907]                          [c6e66c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   77.521087] [   55.908]     [c6fa4160] new in dsscomp_gralloc_queue (refs=1)
[   77.521087] [   55.908]                         [c6e67800] dsscomp_new
[   77.521087] [   55.908]     [c6fa4160] ++refs=2 for [c6e67800]
[   77.550933] [   55.908]                         [c6e67800] dsscomp_delayed_apply
[   77.550933] [   55.908]     [c6fa4160] --refs=1 on RELEASED
[   77.550964] [   55.908]                         [c6e67800] dsscomp_apply
[   77.550964] [   55.924]                          [c6e66c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   77.580780] [   55.924]  [c6fa40a0] --refs=0 on RELEASED
[   77.580780] [   55.924]  [c6fa40a0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   77.580780] [   55.924]                          [c6e66c00] dsscomp_mgr_delayed_cb on RELEASED
[   77.580780] [   55.924]                         [c6e67800] dsscomp_mgr_delayed_cb on PROGRAMMED
[   77.610595] [   55.942]                         [c6e67800] dsscomp_mgr_delayed_cb on DISPLAYED
[   77.610595] [   61.370]   [c6edbbc0] new in dsscomp_gralloc_queue (refs=1)
[   77.610626] [   61.370]                          [c6f10800] dsscomp_new
[   77.610626] [   61.370]   [c6edbbc0] ++refs=2 for [c6f10800]
[   77.640411] [   61.370]                          [c6f10800] dsscomp_delayed_apply
[   77.640411] [   61.370]   [c6edbbc0] --refs=1 on RELEASED
[   77.640411] [   61.370]                          [c6f10800] dsscomp_apply
[   77.640411] [   61.370]     [c6fa4160] --refs=0 on RELEASED
[   77.670532] [   61.370]     [c6fa4160] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   77.670532] [   61.370]                         [c6e67800] dsscomp_mgr_delayed_cb on RELEASED
[   77.670532] [   61.370]                          [c6f10800] dsscomp_mgr_delayed_cb on PROGRAMMED
[   77.670532] [   61.371]    [c6edbc00] new in dsscomp_gralloc_queue (refs=1)
[   77.700347] [   61.371]                         [c6f11400] dsscomp_new
[   77.700347] [   61.371]    [c6edbc00] ++refs=2 for [c6f11400]
[   77.700347] [   61.371]                         [c6f11400] dsscomp_delayed_apply
[   77.700378] [   61.371]    [c6edbc00] --refs=1 on RELEASED
[   77.730224] [   61.371]                         [c6f11400] dsscomp_apply
[   77.730224] [   61.383]                          [c6f10800] dsscomp_mgr_delayed_cb on DISPLAYED
[   77.730224] [   61.383]   [c6edbbc0] --refs=0 on RELEASED
[   77.730255] [   61.383]   [c6edbbc0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   77.760009] [   61.383]                          [c6f10800] dsscomp_mgr_delayed_cb on RELEASED
[   77.760009] [   61.383]                         [c6f11400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   77.760040] [   61.400]                         [c6f11400] dsscomp_mgr_delayed_cb on DISPLAYED
[   77.788330] [   66.356]     [c6fa4320] new in dsscomp_gralloc_queue (refs=1)
[   77.788330] [   66.356]                          [c6e66c00] dsscomp_new
[   77.788360] [   66.356]     [c6fa4320] ++refs=2 for [c6e66c00]
[   77.788360] [   66.356]                          [c6e66c00] dsscomp_delayed_apply
[   77.818145] [   66.356]     [c6fa4320] --refs=1 on RELEASED
[   77.818145] [   66.356]                          [c6e66c00] dsscomp_apply
[   77.818145] [   66.356]    [c6edbc00] --refs=0 on RELEASED
[   77.818145] [   66.356]    [c6edbc00] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   77.818145] [   66.356]                         [c6f11400] dsscomp_mgr_delayed_cb on RELEASED
[   77.849487] [   66.356]                          [c6e66c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   77.849487] [   66.357]  [c6edbb80] new in dsscomp_gralloc_queue (refs=1)
[   77.849487] [   66.357]                          [c6f10800] dsscomp_new
[   77.877716] [   66.357]  [c6edbb80] ++refs=2 for [c6f10800]
[   77.877716] [   66.357]                          [c6f10800] dsscomp_delayed_apply
[   77.877716] [   66.357]  [c6edbb80] --refs=1 on RELEASED
[   77.877716] [   66.357]                          [c6f10800] dsscomp_apply
[   77.877746] [   66.375]                          [c6e66c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   77.909057] [   66.375]     [c6fa4320] --refs=0 on RELEASED
[   77.909057] [   66.375]     [c6fa4320] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   77.909057] [   66.376]                          [c6e66c00] dsscomp_mgr_delayed_cb on RELEASED
[   77.937316] [   66.376]                          [c6f10800] dsscomp_mgr_delayed_cb on PROGRAMMED
[   77.937316] [   66.393]                          [c6f10800] dsscomp_mgr_delayed_cb on DISPLAYED
[   77.937316] [   72.154]  [c6fa4420] new in dsscomp_gralloc_queue (refs=1)
[   77.965545] [   72.154]                           [c6e66000] dsscomp_new
[   77.965545] [   72.154]  [c6fa4420] ++refs=2 for [c6e66000]
[   77.965545] [   72.154]                           [c6e66000] dsscomp_delayed_apply
[   77.965545] [   72.154]  [c6fa4420] --refs=1 on RELEASED
[   77.965545] [   72.154]                           [c6e66000] dsscomp_apply
[   77.996887] [   72.154]  [c6edbb80] --refs=0 on RELEASED
[   77.996887] [   72.154]  [c6edbb80] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   77.996887] [   72.154]                          [c6f10800] dsscomp_mgr_delayed_cb on RELEASED
[   77.996887] [   72.154]                           [c6e66000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   78.026672] [   72.155]       [c6edbcc0] new in dsscomp_gralloc_queue (refs=1)
[   78.026672] [   72.155]                       [c6f12c00] dsscomp_new
[   78.026672] [   72.155]       [c6edbcc0] ++refs=2 for [c6f12c00]
[   78.026672] [   72.155]                       [c6f12c00] dsscomp_delayed_apply
[   78.056457] [   72.155]       [c6edbcc0] --refs=1 on RELEASED
[   78.056488] [   72.155]                       [c6f12c00] dsscomp_apply
[   78.056488] [   72.176]                           [c6e66000] dsscomp_mgr_delayed_cb on DISPLAYED
[   78.056488] [   72.176]  [c6fa4420] --refs=0 on RELEASED
[   78.086212] [   72.176]  [c6fa4420] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   78.086242] [   72.176]                           [c6e66000] dsscomp_mgr_delayed_cb on RELEASED
[   78.086242] [   72.176]                       [c6f12c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   78.114501] [   72.191]                       [c6f12c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   78.114501] [   77.137]    [c6fa43c0] new in dsscomp_gralloc_queue (refs=1)
[   78.114501] [   77.137]                           [c6e67c00] dsscomp_new
[   78.114532] [   77.137]    [c6fa43c0] ++refs=2 for [c6e67c00]
[   78.144256] [   77.137]                           [c6e67c00] dsscomp_delayed_apply
[   78.144256] [   77.137]    [c6fa43c0] --refs=1 on RELEASED
[   78.144287] [   77.137]                           [c6e67c00] dsscomp_apply
[   78.144287] [   77.138]       [c6edbcc0] --refs=0 on RELEASED
[   78.144287] [   77.138]       [c6edbcc0] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   78.175598] [   77.138]                       [c6f12c00] dsscomp_mgr_delayed_cb on RELEASED
[   78.175598] [   77.138]                           [c6e67c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   78.175598] [   77.138]    [c6edbc00] new in dsscomp_gralloc_queue (refs=1)
[   78.203857] [   77.138]                         [c6f11400] dsscomp_new
[   78.203857] [   77.138]    [c6edbc00] ++refs=2 for [c6f11400]
[   78.203857] [   77.138]                         [c6f11400] dsscomp_delayed_apply
[   78.203857] [   77.138]    [c6edbc00] --refs=1 on RELEASED
[   78.233612] [   77.138]                         [c6f11400] dsscomp_apply
[   78.233612] [   77.152]                           [c6e67c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   78.233612] [   77.152]    [c6fa43c0] --refs=0 on RELEASED
[   78.233612] [   77.152]    [c6fa43c0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   78.263397] [   77.152]                           [c6e67c00] dsscomp_mgr_delayed_cb on RELEASED
[   78.263397] [   77.152]                         [c6f11400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   78.263427] [   77.154]    [c6fa44a0] new in dsscomp_gralloc_queue (refs=1)
[   78.263427] [   77.154]                           [c6e67c00] dsscomp_new
[   78.293212] [   77.154]    [c6fa44a0] ++refs=2 for [c6e67c00]
[   78.293212] [   77.154]                           [c6e67c00] dsscomp_delayed_apply
[   78.293212] [   77.154]    [c6fa44a0] --refs=1 on RELEASED
[   78.293212] [   77.154]                           [c6e67c00] dsscomp_apply
[   78.323028] [   77.171]                         [c6f11400] dsscomp_mgr_delayed_cb on DISPLAYED
[   78.323028] [   77.171]    [c6edbc00] --refs=0 on RELEASED
[   78.323028] [   77.171]    [c6edbc00] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   78.323028] [   77.171]                         [c6f11400] dsscomp_mgr_delayed_cb on RELEASED
[   78.352813] [   77.171]                           [c6e67c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   78.352813] [   77.186]                           [c6e67c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   78.352813] ACTIVE COMPOSITIONS on lcd
[   78.352813]
[   78.352813]   [c6e67c00]: DISPLAYED
[   78.384124]     sync_id=0, flags=AD-
[   78.384124]     ovl0={ON z0 ARGB32-8888 premult *100% 864*480:0,0+864,480 rot0 => 0,0+864,480 7f9ac000/  (null)|3456}
[   78.384155]     gsync=[c6fa44a0] dsscomp_gralloc_cb
[   78.384155]
[   78.384155]   DISPC pipeline:
[   78.384155]
[   78.384155]     info:        clean (none)
[   78.384155]     cache:       clean (none)
[   78.420043]     shadow:  ACT clean (none)
[   78.420074]     dispc:   DISPLAYED mask=---R [c6e67c00] dsscomp_mgr_callback
[   78.420074]
[   78.420074] ACTIVE COMPOSITIONS on tv
[   78.420074]
[   78.420074]   DISPC pipeline:
[   78.420074]
[   78.420074]     info:        clean (none)
[   78.420074]     cache:       clean (none)
[   78.420074]     shadow:  off clean (none)
[   78.420074]     dispc:   DISPLAYED (none)
[   78.460510]
[   78.460540] ACTIVE COMPOSITIONS on lcd2
[   78.460540]
[   78.460540]   DISPC pipeline:
[   78.460540]
[   78.460540]     info:        clean (none)
[   78.460540]     cache:       clean (none)
[   78.460540]     shadow:  off clean (none)
[   78.460540]     dispc:             (none)
[   78.460540]
[   78.460540] ACTIVE GRALLOC FLIPS
[   78.460540]
[   78.460540]   [c6fa44a0] (refs=1)
[   78.460540]     slots=[7f9ac000]
[   78.460571]     cmdcb=[c73f6480] dsscomp_proxy_cmdcomplete
[   78.507202]
[   78.507202]   |           lcd
[   78.507202]   | [c6e67c00] DISPL'D
[   78.507202]   |     77.154  ACTIVE
[   78.507202]   |     77.154 APPLY'N
[   78.507202]   |     77.154 APPLIED
[   78.507202]   |     77.171 PROGR'D
[   78.507202]   |     77.186 DISPL'D
[   78.507232]
[   78.507232]
[   78.545013] PVR_K: SGX debug (blaze_android_sgx_ogles1_ogles2_GPL sgxddk 18 1.8@869593)
[   78.553588] PVR_K:(Error): SGX Register Base Address (Linear):   0xC8B20000 [0, ]
[   78.561676] PVR_K:(Error): SGX Register Base Address (Physical): 0x56000000 [0, ]
[   78.569671] PVR_K: (P0) EUR_CR_CORE_ID:          01140000
[   78.575439] PVR_K: (P0) EUR_CR_CORE_REVISION:    00010200
[   78.581298] PVR_K: (P0) EUR_CR_EVENT_STATUS:     20000000
[   78.587097] PVR_K: (P0) EUR_CR_EVENT_STATUS2:    00000008
[   78.592895] PVR_K: (P0) EUR_CR_BIF_CTRL:         00000000
[   78.598632] PVR_K: (P0) EUR_CR_BIF_INT_STAT:     00008000
[   78.604492] PVR_K: (P0) EUR_CR_BIF_FAULT:        00000000
[   78.610443] PVR_K: (P0) EUR_CR_BIF_MEM_REQ_STAT: 00000001
[   78.616271] PVR_K: (P0) EUR_CR_CLKGATECTL:       000AAA6A
[   78.622009] PVR_K: (P0) EUR_CR_PDS_PC_BASE:      00004008
[   78.627838] PVR_K: Flip Command Complete Data 0 for display device 1:
[   78.634704] PVR_K:   SRC 0: ROC DevVAddr:0xD800494 ROP:0xd ROC:0xb, WOC DevVAddr:0xD800484 WOP:0xd WOC:0xc
[   78.644927] PVR_K: Flip Command Complete Data 1 for display device 1:
[   78.651824] PVR_K:   SRC 0: (Not in use)
[   78.655944] PVR_K: SGX Host control:
[   78.659790] PVR_K:   (HC-0) 0x00000001 0x00000000 0x00000000 0x00000001
[   78.666778] PVR_K:   (HC-10) 0x0000000D 0x0000000A 0x0005DC00 0x00000003
[   78.673828] PVR_K:   (HC-20) 0x00000000 0x00000003 0x00000000 0x00000012
[   78.680938] PVR_K:   (HC-30) 0x00000E33 0xF2B802D4 0x00000000 0x00000000
[   78.688018] PVR_K:   (HC-40) 0x00000000 0x087BF500 0x087C6300 0x087C3100
[   78.695068] PVR_K: SGX TA/3D control:
[   78.699005] PVR_K:   (T3C-0) 0x0F003000 0x0F003120 0x0F002000 0x00000000
[   78.706085] PVR_K:   (T3C-10) 0x00000001 0x00000002 0x00000001 0x0F00DD00
[   78.713287] PVR_K:   (T3C-20) 0x00000000 0x00000000 0x00000000 0x00000000
[   78.720428] PVR_K:   (T3C-30) 0x00000000 0x00000000 0x00000000 0x00000000
[   78.727630] PVR_K:   (T3C-40) 0x00000000 0x00000000 0x00000000 0x00000000
[   78.734771] PVR_K:   (T3C-50) 0x00000000 0x00000000 0x00000000 0x00000000
[   78.741943] PVR_K:   (T3C-60) 0x00000000 0x00000000 0x0F00DD00 0x00000000
[   78.749145] PVR_K:   (T3C-70) 0x00000000 0x0F00DD00 0x00000000 0x0F004000
[   78.756256] PVR_K:   (T3C-80) 0x00000072 0x0001120F 0x00000000 0x0F00DEFC
[   78.763458] PVR_K:   (T3C-90) 0x00000000 0x0F000000 0xAB600000 0x0F039C00
[   78.770629] PVR_K:   (T3C-A0) 0x00000000 0x0F010760 0x0F00DD00 0x0F00DEFC
[   78.777801] PVR_K:   (T3C-B0) 0x0F0109A0 0x00000000 0x00000000 0x00000000
[   78.785003] PVR_K:   (T3C-C0) 0x00000000 0x00000000 0x00000000 0x00000000
[   78.792144] PVR_K:   (T3C-D0) 0x00000000 0x00000019 0x00000018 0x0F007000
[   78.799377] PVR_K:   (T3C-E0) 0x0F00D420 0x0F00E000 0x0F010720 0x0F010720
[   78.806518] PVR_K:   (T3C-F0) 0x00000000 0x000000B5 0x000000B5 0x00000000
[   78.813720] PVR_K:   (T3C-100) 0x00000003 0x00000000 0x00000000 0x00000000
[   78.820983] PVR_K:   (T3C-110) 0xB50C565C 0x0872E100 0x08787B00 0x08787B00
[   78.828216] PVR_K: Last SGX microkernel status code: AD000184
[   78.834381] PVR_K:   (MKT-0) 00003B7A 00100808 0000081F AD000104
[   78.840698] PVR_K:   (MKT-1) 00003BB6 00100808 0100091E AD000100
[   78.847076] PVR_K:   (MKT-2) 00003CB9 00100808 0100091E AD000501
[   78.853393] PVR_K:   (MKT-3) 00003CF8 0010082B 0100091E AD000104
[   78.859741] PVR_K:   (MKT-4) 00005F46 00100828 01000A1F AD000101
[   78.866088] PVR_K:   (MKT-5) 00005F8A 00100828 01000A1F AD000104
[   78.872436] PVR_K:   (MKT-6) 0000608D 00100808 01000B1F AD000100
[   78.878753] PVR_K:   (MKT-7) 00006146 00100808 01000B1F AD000501
[   78.885131] PVR_K:   (MKT-8) 00006172 00100829 01000B1F AD000104
[   78.891448] PVR_K:   (MKT-9) 08441FB0 00100808 0100031F AD000B00
[   78.897796] PVR_K:   (MKT-A) 08441FF5 00100808 0100031F AD000B03
[   78.904113] PVR_K:   (MKT-B) 0844207C 00100808 0100031F AD000B05
[   78.910461] PVR_K:   (MKT-C) 084420D3 00100808 0100031F AD000B06
[   78.916778] PVR_K:   (MKT-D) 08442102 00100808 0100031F AD000B06
[   78.923156] PVR_K:   (MKT-E) 08442146 00100808 0100031F AD000B07
[   78.929473] PVR_K:   (MKT-F) 0844216B 00100808 0100031F AD000B09
[   78.935821] PVR_K:   (MKT-10) 084421C0 00100808 0100031F AD000B01
[   78.942291] PVR_K:   (MKT-11) 084421FC 00100808 0100031F AD002300
[   78.948699] PVR_K:   (MKT-12) 0844250C 00100808 0100041F AD00000A
[   78.955139] PVR_K:   (MKT-13) 08442589 00100808 0100041F AD000906
[   78.961547] PVR_K:   (MKT-14) 08442643 00100808 0000041F AD000901
[   78.968017] PVR_K:   (MKT-15) 084426BE 00100808 0000051E AD000183
[   78.974395] PVR_K:   (MKT-16) 08442829 00100808 0000051E AD000302
[   78.980865] PVR_K:   (MKT-17) 0844287E 00100808 0000051E AD000303
[   78.987274] PVR_K:   (MKT-18) 08442904 00100808 0000051E AD000C01
[   78.993743] PVR_K:   (MKT-19) 08442929 00100808 0000051E 0D800484
[   79.000152] PVR_K:   (MKT-1A) 08442942 00100808 0000051E 0000000A
[   79.006591] PVR_K:   (MKT-1B) 08442BA3 00100808 0000051E AD00030E
[   79.013000] PVR_K:   (MKT-1C) 08442BBB 00100808 0000051E 0D800474
[   79.019439] PVR_K:   (MKT-1D) 08442BD3 00100808 0000051E 00000009
[   79.025878] PVR_K:   (MKT-1E) 08442BF9 00100808 0000051E 0000000A
[   79.032318] PVR_K:   (MKT-1F) 08442C73 00100808 0000051E AD000184
[   79.038726] PVR_K:   (MKT-20) 08442CF2 00100C08 0100061D AD000281
[   79.045166] PVR_K:   (MKT-21) 08442E89 00100808 0100061D AD00080A
[   79.051635] PVR_K:   (MKT-22) 08442EA3 00100808 0100061D 0F046300
[   79.058044] PVR_K:   (MKT-23) 08442EBB 00100808 0100061D 00000061
[   79.064514] PVR_K:   (MKT-24) 08442FD2 00100C88 0100061D AD001300
[   79.070922] PVR_K:   (MKT-25) 084483B7 00100808 0000061D AD001301
[   79.077362] PVR_K:   (MKT-26) 084484E4 00100888 0000061D AD000802
[   79.083770] PVR_K:   (MKT-27) 0844864D 00100888 0000061D AD000803
[   79.090240] PVR_K:   (MKT-28) 0844869D 001808C8 0000061D AD000282
[   79.096649] PVR_K:   (MKT-29) 0844878A 00184AF8 0000081E AD00000A
[   79.103088] PVR_K:   (MKT-2A) 0844880A 001808F8 0000081E AD000905
[   79.109497] PVR_K:   (MKT-2B) 08448930 001808B8 0000081E AD000901
[   79.115936] PVR_K:   (MKT-2C) 084489A9 00180838 0000091C AD00000A
[   79.122344] PVR_K:   (MKT-2D) 08448A1E 00180838 0000091C AD000906
[   79.128784] PVR_K:   (MKT-2E) 08448A94 00180838 0000091C AD000901
[   79.135192] PVR_K:   (MKT-2F) 08448AEE 00180838 00000A1B AD00000A
[   79.141662] PVR_K:   (MKT-30) 08448B53 00180838 00000A1B AD000905
[   79.148101] PVR_K:   (MKT-31) 08448C03 00180838 00000A1B AD000901
[   79.154510] PVR_K:   (MKT-32) 08448C5B 00180838 00000B1A AD00000A
[   79.160949] PVR_K:   (MKT-33) 08448CC0 00180838 00000B1A AD000905
[   79.167388] PVR_K:   (MKT-34) 08448D6D 00180838 00000B1A AD000901
[   79.173828] PVR_K:   (MKT-35) 08448DC6 00180838 00000C19 AD00000A
[   79.180236] PVR_K:   (MKT-36) 08448E33 00180838 00000C19 AD000905
[   79.186706] PVR_K:   (MKT-37) 08448EE0 00180838 00000C19 AD000901
[   79.193115] PVR_K:   (MKT-38) 0844903A 00180838 00000F1F AD000183
[   79.199554] PVR_K:   (MKT-39) 084491BC 00180838 00000F1F AD000302
[   79.205963] PVR_K:   (MKT-3A) 0844922E 00180838 00000F1F AD000303
[   79.212432] PVR_K:   (MKT-3B) 084492B0 00180838 00000F1F AD000C01
[   79.218811] PVR_K:   (MKT-3C) 084492D7 00180838 00000F1F 0D800464
[   79.225250] PVR_K:   (MKT-3D) 084492EF 00180838 00000F1F 0000000B
[   79.231689] PVR_K:   (MKT-3E) 08449506 00180838 00000F1F AD000184
[   79.238128] PVR_K:   (MKT-3F) 08449573 00180C38 0100101D AD000281
[   79.244537] PVR_K:   (MKT-40) 084495CB 00180838 0100101D AD000282
[   79.250946] PVR_K:   (MKT-41) 0844A1E7 00180838 0100111F AD00000A
[   79.257385] PVR_K:   (MKT-42) 0844A254 00180838 0100111F AD000905
[   79.263793] PVR_K:   (MKT-43) 0844A35C 00180838 0000111F AD000901
[   79.270263] PVR_K:   (MKT-44) 0844A3AD 00180C38 0100121E AD000281
[   79.276641] PVR_K:   (MKT-45) 0844A407 00180838 0100121E AD000282
[   79.283111] PVR_K:   (MKT-46) 0844A4E8 00180838 0100131F AD00000A
[   79.289520] PVR_K:   (MKT-47) 0844A553 00180838 0100131F AD000905
[   79.295989] PVR_K:   (MKT-48) 0844A650 00180838 0000131F AD000901
[   79.302490] PVR_K:   (MKT-49) 0844A6A5 00180C38 0100141E AD000281
[   79.309082] PVR_K:   (MKT-4A) 0844A6FD 00100828 0100141E AD000282
[   79.315521] PVR_K:   (MKT-4B) 0844A81E 00000808 0000151F AD00000A
[   79.322021] PVR_K:   (MKT-4C) 0844A888 00000808 0000151F AD000905
[   79.328491] PVR_K:   (MKT-4D) 0844A982 00000808 0000151F AD000901
[   79.334991] PVR_K:   (MKT-4E) 0844A9B9 00000C08 0000161E AD000200
[   79.341430] PVR_K:   (MKT-4F) 0844AC09 00000808 0000161E AD000202
[   79.347930] PVR_K:   (MKT-50) 0844AC61 00000808 0000171D AD000281
[   79.354431] PVR_K:   (MKT-51) 0844ADAC 00000808 0000171D AD00080A
[   79.360870] PVR_K:   (MKT-52) 0844ADC5 00000808 0000171D 0F046600
[   79.367401] PVR_K:   (MKT-53) 0844ADDE 00000808 0000171D 00000060
[   79.373840] PVR_K:   (MKT-54) 0844B096 00000808 0000171D AD000803
[   79.381225] PVR_K:   (MKT-55) 0844B0DB 00180CC8 0000171D AD000282
[   79.387695] PVR_K:   (MKT-56) 0844B18D 00000808 0000181F AD00000A
[   79.394226] PVR_K:   (MKT-57) 0844B1F7 00000808 0000181F AD000905
[   79.401031] PVR_K:   (MKT-58) 0844B2EA 00000888 0000181F AD000901
[   79.407958] PVR_K:   (MKT-59) 0844B333 00000C08 00001A1D AD000200
[   79.414428] PVR_K:   (MKT-5A) 0844B562 00000808 00001A1D AD000202
[   79.420867] PVR_K:   (MKT-5B) 0844B5BC 00000808 01001B1C AD000281
[   79.427276] PVR_K:   (MKT-5C) 0844B706 00000808 01001B1C AD00080A
[   79.433746] PVR_K:   (MKT-5D) 0844B71E 00000808 01001B1C 0F046900
[   79.440155] PVR_K:   (MKT-5E) 0844B737 00000808 01001B1C 00000060
[   79.446594] PVR_K:   (MKT-5F) 0844B9E6 00000808 00001B1C AD000803
[   79.453033] PVR_K:   (MKT-60) 0844BA2D 00180CC8 00001B1C AD000282
[   79.459411] PVR_K:   (MKT-61) 0844BB20 00000808 01001D1F AD000200
[   79.465881] PVR_K:   (MKT-62) 0844BD4B 00000808 00001D1F AD000202
[   79.472290] PVR_K:   (MKT-63) 0844BD98 00000808 01001E1E AD000281
[   79.478729] PVR_K:   (MKT-64) 0844BEE2 00000808 01001E1E AD00080A
[   79.485168] PVR_K:   (MKT-65) 0844BEFA 00000808 01001E1E 0F046C00
[   79.491607] PVR_K:   (MKT-66) 0844BF12 00000808 01001E1E 00000062
[   79.498016] PVR_K:   (MKT-67) 0844C1B9 00000808 00001E1E AD000803
[   79.504486] PVR_K:   (MKT-68) 0844C1FE 00180C88 00001E1E AD000282
[   79.510894] PVR_K:   (MKT-69) 0844CCEC 00000808 0100201F AD000200
[   79.517333] PVR_K:   (MKT-6A) 0844CE06 00000808 0100201F AD001703
[   79.523742] PVR_K:   (MKT-6B) 0844D002 00000808 0000201F AD000202
[   79.530212] PVR_K:   (MKT-6C) 0844D080 00000808 0000211E AD000183
[   79.536621] PVR_K:   (MKT-6D) 0844D16C 00000808 0000211E AD00030E
[   79.543090] PVR_K:   (MKT-6E) 0844D184 00000808 0000211E 0D800494
[   79.549499] PVR_K:   (MKT-6F) 0844D19D 00000808 0000211E 00000009
[   79.555999] PVR_K:   (MKT-70) 0844D1C0 00000808 0000211E 0000000A
[   79.562469] PVR_K:   (MKT-71) 0844D22D 00000808 0000211E AD000184
[   79.568878] PVR_K:   (MKT-72) 0844D290 00000C08 0100221D AD000281
[   79.576538] PVR_K:   (MKT-73) 0844D406 00000808 0100221D AD00080A
[   79.582977] PVR_K:   (MKT-74) 0844D41F 00000808 0100221D 0F046F00
[   79.589416] PVR_K:   (MKT-75) 0844D437 00000808 0100221D 00000061
[   79.595825] PVR_K:   (MKT-76) 0844D5B4 00000808 0000221D AD000802
[   79.602294] PVR_K:   (MKT-77) 0844D704 00000808 0000221D AD000803
[   79.609069] PVR_K:   (MKT-78) 0844D74C 00184EC8 0000221D AD000282
[   79.615539] PVR_K:   (MKT-79) 0844F6AB 00000C08 0100251F AD000200
[   79.621978] PVR_K:   (MKT-7A) 0844F8FA 00000808 0000251F AD000202
[   79.628540] PVR_K:   (MKT-7B) 0844F982 00000808 0000261E AD000183
[   79.634948] PVR_K:   (MKT-7C) 0844FA6E 00000808 0000261E AD00030E
[   79.641448] PVR_K:   (MKT-7D) 0844FA86 00000808 0000261E 0D800494
[   79.647918] PVR_K:   (MKT-7E) 0844FA9F 00000808 0000261E 00000009
[   79.654418] PVR_K:   (MKT-7F) 0844FAC2 00000808 0000261E 0000000A
[   79.661010] PVR_K:   (MKT-80) 0844FB2C 00000808 0000261E AD000184
[   79.667510] PVR_K:   (MKT-81) 0844FB98 00000C08 0100271D AD000281
[   79.674041] PVR_K:   (MKT-82) 0844FD07 00000808 0100271D AD00080A
[   79.680511] PVR_K:   (MKT-83) 0844FD20 00000808 0100271D 0F037200
[   79.687042] PVR_K:   (MKT-84) 0844FD38 00000808 0100271D 00000060
[   79.693481] PVR_K:   (MKT-85) 0844FFE4 00000808 0000271D AD000803
[   79.700744] PVR_K:   (MKT-86) 0845002F 00188CC8 0000271D AD000282
[   79.707244] PVR_K:   (MKT-87) 084500D0 00000808 0100291F AD000200
[   79.713745] PVR_K:   (MKT-88) 084502ED 00000808 0000291F AD000202
[   79.721038] PVR_K:   (MKT-89) 0845036C 00000808 00002A1E AD000183
[   79.727508] PVR_K:   (MKT-8A) 08450455 00000808 00002A1E AD00030E
[   79.734802] PVR_K:   (MKT-8B) 0845046D 00000808 00002A1E 0D800494
[   79.741302] PVR_K:   (MKT-8C) 08450486 00000808 00002A1E 00000009
[   79.747741] PVR_K:   (MKT-8D) 084504A9 00000808 00002A1E 0000000A
[   79.754211] PVR_K:   (MKT-8E) 08450514 00000808 00002A1E AD000184
[   79.760620] PVR_K:   (MKT-8F) 08450578 00000C08 01002B1D AD000281
[   79.767089] PVR_K:   (MKT-90) 084506E3 00000808 01002B1D AD00080A
[   79.773559] PVR_K:   (MKT-91) 084506FB 00000808 01002B1D 0F037500
[   79.779968] PVR_K:   (MKT-92) 08450714 00000808 01002B1D 00000060
[   79.786407] PVR_K:   (MKT-93) 084509BC 00000808 00002B1D AD000803
[   79.792816] PVR_K:   (MKT-94) 08450A01 00180CC8 00002B1D AD000282
[   79.799285] PVR_K:   (MKT-95) 08450AE7 00000808 01002D1F AD000200
[   79.805694] PVR_K:   (MKT-96) 08450D01 00000808 00002D1F AD000202
[   79.812194] PVR_K:   (MKT-97) 08450D7F 00000808 00002E1E AD000183
[   79.818572] PVR_K:   (MKT-98) 08450E6C 00000808 00002E1E AD00030E
[   79.825042] PVR_K:   (MKT-99) 08450E85 00000808 00002E1E 0D800494
[   79.831451] PVR_K:   (MKT-9A) 08450E9E 00000808 00002E1E 00000009
[   79.837921] PVR_K:   (MKT-9B) 08450EC2 00000808 00002E1E 0000000A
[   79.844329] PVR_K:   (MKT-9C) 08450F2C 00000808 00002E1E AD000184
[   79.850769] PVR_K:   (MKT-9D) 08450F90 00000C08 01002F1D AD000281
[   79.857177] PVR_K:   (MKT-9E) 084510FC 00000808 01002F1D AD00080A
[   79.863616] PVR_K:   (MKT-9F) 08451115 00000808 01002F1D 0F037800
[   79.870056] PVR_K:   (MKT-A0) 0845112D 00000808 01002F1D 00000062
[   79.876464] PVR_K:   (MKT-A1) 084513E3 00000808 00002F1D AD000803
[   79.882934] PVR_K:   (MKT-A2) 08451429 00180C88 00002F1D AD000282
[   79.889343] PVR_K:   (MKT-A3) 08451F40 00000808 0100311F AD000200
[   79.895782] PVR_K:   (MKT-A4) 0845205B 00000808 0100311F AD001703
[   79.902191] PVR_K:   (MKT-A5) 0845223C 00000808 0000311F AD000202
[   79.908660] PVR_K:   (MKT-A6) 084522B9 00000808 0000321E AD000183
[   79.915069] PVR_K:   (MKT-A7) 084523A4 00000808 0000321E AD00030E
[   79.921539] PVR_K:   (MKT-A8) 084523BD 00000808 0000321E 0D800494
[   79.927917] PVR_K:   (MKT-A9) 084523D6 00000808 0000321E 00000009
[   79.934387] PVR_K:   (MKT-AA) 084523FA 00000808 0000321E 0000000A
[   79.940795] PVR_K:   (MKT-AB) 08452464 00000808 0000321E AD000184
[   79.947265] PVR_K:   (MKT-AC) 084524C8 00000C08 0100331D AD000281
[   79.953674] PVR_K:   (MKT-AD) 084525D8 00000808 0100331D AD000E02
[   79.960144] PVR_K:   (MKT-AE) 08452649 00000808 0100331D AD000282
[   79.966522] PVR_K:   (MKT-AF) 0845F6EA 00000808 0100361F AD001A00
[   79.972991] PVR_K:   (MKT-B0) 0846D45F 00000808 0100391F AD00000A
[   79.979461] PVR_K:   (MKT-B1) 0846D4C3 00000808 0100391F AD000909
[   79.985870] PVR_K:   (MKT-B2) 0846D511 00000808 0100391F AD001A05
[   79.993682] PVR_K:   (MKT-B3) 0846D543 00000808 0100391F AD001302
[   80.000122] PVR_K:   (MKT-B4) 0846D583 00000808 0100391F AD001303
[   80.006561] PVR_K:   (MKT-B5) 0846D616 00000808 0100391F AD000D04
[   80.012969] PVR_K:   (MKT-B6) 0846D6E4 00000808 0100391F AD000D05
[   80.019409] PVR_K:   (MKT-B7) 0846D73C 00000808 0100391F AD000D04
[   80.025817] PVR_K:   (MKT-B8) 0846D7C1 00000808 0100391F AD000D05
[   80.032684] PVR_K:   (MKT-B9) 0846D81D 00000808 0100391F AD001A06
[   80.039215] PVR_K:   (MKT-BA) 00000468 00100808 0100031F AD002300
[   80.045654] PVR_K:   (MKT-BB) 00000949 00100808 0100041F AD00000A
[   80.052093] PVR_K:   (MKT-BC) 000009C7 00100808 0100041F AD000906
[   80.058624] PVR_K:   (MKT-BD) 00000A95 00100808 0000041F AD000901
[   80.065093] PVR_K:   (MKT-BE) 00000B0F 00100808 0000051E AD000183
[   80.071746] PVR_K:   (MKT-BF) 00000C85 00100808 0000051E AD000302
[   80.078277] PVR_K:   (MKT-C0) 00000E10 00100808 0000051E AD000D06
[   80.084747] PVR_K:   (MKT-C1) 00000EF8 00100808 0000051E AD000D07
[   80.091247] PVR_K:   (MKT-C2) 00000F41 00100808 0000051E AD001304
[   80.097686] PVR_K:   (MKT-C3) 00001030 00100808 0000051E AD001305
[   80.104187] PVR_K:   (MKT-C4) 00001147 00100888 0000051E AD000404
[   80.111389] PVR_K:   (MKT-C5) 0000120A 00100808 0000051E AD000402
[   80.117889] PVR_K:   (MKT-C6) 00001253 0010082B 0000051E AD000184
[   80.124359] PVR_K:   (MKT-C7) 000012DD 00119DAD 0000061D AD000281
[   80.131256] PVR_K:   (MKT-C8) 00001477 001199AB 0000061D AD000E02
[   80.138031] PVR_K:   (MKT-C9) 000014D4 001088AD 0000061D AD000282
[   80.144500] PVR_K:   (MKT-CA) 00003AB9 00100808 0000081F AD000101
[   80.150909] PVR_K:   (MKT-CB) 00003B2F 00100808 0000081F AD000104
[   80.157379] PVR_K:   (MKT-CC) 00003B6C 00100808 0100091E AD000100
[   80.163787] PVR_K:   (MKT-CD) 00003C74 00100808 0100091E AD000501
[   80.170562] PVR_K:   (MKT-CE) 00003CB3 0010082B 0100091E AD000104
[   80.176971] PVR_K:   (MKT-CF) 00005F30 00100828 01000A1F AD000101
[   80.183410] PVR_K:   (MKT-D0) 00005F74 00100828 01000A1F AD000104
[   80.189880] PVR_K:   (MKT-D1) 00006084 00100808 01000B1F AD000100
[   80.196289] PVR_K:   (MKT-D2) 0000613E 00100808 01000B1F AD000501
[   80.202728] PVR_K:   (MKT-D3) 0000616A 00100829 01000B1F AD000104
[   80.209106] PVR_K:   (MKT-D4) 0718E8AF 00100808 0100031F AD000B00
[   80.215576] PVR_K:   (MKT-D5) 0718E8F3 00100808 0100031F AD000B03
[   80.221984] PVR_K:   (MKT-D6) 0718E97B 00100808 0100031F AD000B05
[   80.228424] PVR_K:   (MKT-D7) 0718E9CF 00100808 0100031F AD000B06
[   80.234832] PVR_K:   (MKT-D8) 0718E9FE 00100808 0100031F AD000B06
[   80.241271] PVR_K:   (MKT-D9) 0718EA41 00100808 0100031F AD000B07
[   80.247680] PVR_K:   (MKT-DA) 0718EA66 00100808 0100031F AD000B09
[   80.254119] PVR_K:   (MKT-DB) 0718EABA 00100808 0100031F AD000B01
[   80.260528] PVR_K:   (MKT-DC) 0718EAF6 00100808 0100031F AD002300
[   80.266998] PVR_K:   (MKT-DD) 0718EE0E 00100808 0100041F AD00000A
[   80.273406] PVR_K:   (MKT-DE) 0718EE8C 00100808 0100041F AD000906
[   80.279815] PVR_K:   (MKT-DF) 0718EF4D 00100808 0000041F AD000901
[   80.286224] PVR_K:   (MKT-E0) 0718EFC7 00100808 0000051E AD000183
[   80.292633] PVR_K:   (MKT-E1) 0718F137 00100808 0000051E AD000302
[   80.299102] PVR_K:   (MKT-E2) 0718F18A 00100808 0000051E AD000303
[   80.305511] PVR_K:   (MKT-E3) 0718F214 00100808 0000051E AD000C01
[   80.311950] PVR_K:   (MKT-E4) 0718F239 00100808 0000051E 0D800484
[   80.318389] PVR_K:   (MKT-E5) 0718F251 00100808 0000051E 0000000B
[   80.324859] PVR_K:   (MKT-E6) 0718F4A0 00100808 0000051E AD00030E
[   80.331268] PVR_K:   (MKT-E7) 0718F4B9 00100808 0000051E 0D800474
[   80.337707] PVR_K:   (MKT-E8) 0718F4D1 00100808 0000051E 0000000A
[   80.344116] PVR_K:   (MKT-E9) 0718F4F6 00100808 0000051E 0000000B
[   80.350555] PVR_K:   (MKT-EA) 0718F56F 00100808 0000051E AD000184
[   80.356933] PVR_K:   (MKT-EB) 0718F5EE 00100C08 0100061D AD000281
[   80.363403] PVR_K:   (MKT-EC) 0718F789 00100808 0100061D AD00080A
[   80.369781] PVR_K:   (MKT-ED) 0718F7A2 00100808 0100061D 0F037B00
[   80.376251] PVR_K:   (MKT-EE) 0718F7BA 00100808 0100061D 00000061
[   80.382659] PVR_K:   (MKT-EF) 0718F8D6 00100C88 0100061D AD001300
[   80.389099] PVR_K:   (MKT-F0) 07194CBE 00100808 0000061D AD001301
[   80.395538] PVR_K:   (MKT-F1) 07194DEC 00100888 0000061D AD000802
[   80.401947] PVR_K:   (MKT-F2) 07194F5C 00100888 0000061D AD000803
[   80.408416] PVR_K:   (MKT-F3) 07194FA9 001808C8 0000061D AD000282
[   80.414794] PVR_K:   (MKT-F4) 07195094 00184EF8 0000081E AD00000A
[   80.421264] PVR_K:   (MKT-F5) 0719511B 00184AF8 0000081E AD000905
[   80.427642] PVR_K:   (MKT-F6) 0719522C 001808B8 0000081E AD000901
[   80.434112] PVR_K:   (MKT-F7) 0719529F 00180838 0000091C AD00000A
[   80.440490] PVR_K:   (MKT-F8) 07195313 00180838 0000091C AD000906
[   80.446960] PVR_K:   (MKT-F9) 0719538A 00180838 0000091C AD000901
[   80.453369] PVR_K:   (MKT-FA) 071953DF 00180838 00000A1B AD00000A
[   80.459808] PVR_K:   (MKT-FB) 07195442 00180838 00000A1B AD000905
[   80.466217] PVR_K:   (MKT-FC) 071954F3 00180838 00000A1B AD000901
[   80.472656] PVR_K:   (MKT-FD) 0719554A 00180838 00000B1A AD00000A
[   80.479064] PVR_K:   (MKT-FE) 071955AC 00180838 00000B1A AD000905
[   80.485534] PVR_K:   (MKT-FF) 0719565B 00180838 00000B1A AD000901
[   80.491912] PVR_K:   (MKT-100) 071956AE 00180838 00000C19 AD00000A
[   80.498413] PVR_K:   (MKT-101) 0719571E 00180838 00000C19 AD000905
[   80.504974] PVR_K:   (MKT-102) 071957CA 00180838 00000C19 AD000901
[   80.511474] PVR_K:   (MKT-103) 07195919 00180838 00000F1F AD000183
[   80.518005] PVR_K:   (MKT-104) 07195A9A 00180838 00000F1F AD000302
[   80.524505] PVR_K:   (MKT-105) 07195B0E 00180838 00000F1F AD000303
[   80.531036] PVR_K:   (MKT-106) 07195B90 00180838 00000F1F AD000C01
[   80.537536] PVR_K:   (MKT-107) 07195BBA 00180838 00000F1F 0D800464
[   80.544097] PVR_K:   (MKT-108) 07195BD3 00180838 00000F1F 0000000C
[   80.550598] PVR_K:   (MKT-109) 07195DF1 00180838 00000F1F AD000184
[   80.557128] PVR_K:   (MKT-10A) 07195E60 00180C38 0100101D AD000281
[   80.563629] PVR_K:   (MKT-10B) 07195EB7 00180838 0100101D AD000282
[   80.570190] PVR_K:   (MKT-10C) 07196B71 00180838 0100111F AD00000A
[   80.576721] PVR_K:   (MKT-10D) 07196BDA 00180838 0100111F AD000905
[   80.583221] PVR_K:   (MKT-10E) 07196CE0 00180838 0000111F AD000901
[   80.589752] PVR_K:   (MKT-10F) 07196D33 00180C38 0100121E AD000281
[   80.596252] PVR_K:   (MKT-110) 07196D8E 00180838 0100121E AD000282
[   80.602813] PVR_K:   (MKT-111) 07196E9E 00180838 0100131F AD00000A
[   80.609313] PVR_K:   (MKT-112) 07196F09 00180838 0100131F AD000905
[   80.615844] PVR_K:   (MKT-113) 0719700A 00180838 0000131F AD000901
[   80.622314] PVR_K:   (MKT-114) 0719705C 00100C28 0100141E AD000281
[   80.628875] PVR_K:   (MKT-115) 071970B4 00100828 0100141E AD000282
[   80.635345] PVR_K:   (MKT-116) 07197117 00000808 0100151F AD000200
[   80.641906] PVR_K:   (MKT-117) 0719736D 00000808 0000151F AD000202
[   80.648406] PVR_K:   (MKT-118) 0719741A 00000808 0000161E AD00000A
[   80.654937] PVR_K:   (MKT-119) 07197485 00000808 0000161E AD000905
[   80.661468] PVR_K:   (MKT-11A) 07197573 00000808 0000161E AD000901
[   80.667968] PVR_K:   (MKT-11B) 071975C2 00000C08 0000171D AD000281
[   80.674530] PVR_K:   (MKT-11C) 07197720 00000808 0000171D AD00080A
[   80.681030] PVR_K:   (MKT-11D) 07197739 00000808 0000171D 0F037E00
[   80.687561] PVR_K:   (MKT-11E) 07197751 00000808 0000171D 00000060
[   80.694061] PVR_K:   (MKT-11F) 07197A1B 00000808 0000171D AD000803
[   80.700592] PVR_K:   (MKT-120) 07197A61 00180CC8 0000171D AD000282
[   80.707092] PVR_K:   (MKT-121) 07197B14 00000808 0000181F AD00000A
[   80.713653] PVR_K:   (MKT-122) 07197B7D 00000808 0000181F AD000905
[   80.720153] PVR_K:   (MKT-123) 07197C70 00000888 0000181F AD000901
[   80.726684] PVR_K:   (MKT-124) 07197CBA 00000C08 00001A1D AD000200
[   80.733184] PVR_K:   (MKT-125) 07197EE8 00000808 00001A1D AD000202
[   80.739746] PVR_K:   (MKT-126) 07197F3F 00000808 01001B1C AD000281
[   80.746276] PVR_K:   (MKT-127) 0719808D 00000808 01001B1C AD00080A
[   80.752777] PVR_K:   (MKT-128) 071980A6 00000808 01001B1C 0F038100
[   80.759490] PVR_K:   (MKT-129) 071980BE 00000808 01001B1C 00000060
[   80.765991] PVR_K:   (MKT-12A) 0719836A 00000808 00001B1C AD000803
[   80.772552] PVR_K:   (MKT-12B) 071983AF 00188CC8 00001B1C AD000282
[   80.779052] PVR_K:   (MKT-12C) 071984A2 00000808 01001D1F AD000200
[   80.785583] PVR_K:   (MKT-12D) 071986C7 00000808 01001D1F AD000202
[   80.792114] PVR_K:   (MKT-12E) 07198718 00000808 01001E1E AD000281
[   80.798645] PVR_K:   (MKT-12F) 07198860 00000808 01001E1E AD00080A
[   80.805145] PVR_K:   (MKT-130) 07198878 00000808 01001E1E 0F038400
[   80.811706] PVR_K:   (MKT-131) 07198891 00000808 01001E1E 00000062
[   80.818176] PVR_K:   (MKT-132) 07198B47 00000808 00001E1E AD000803
[   80.824768] PVR_K:   (MKT-133) 07198B8D 00180C88 00001E1E AD000282
[   80.831298] PVR_K:   (MKT-134) 0719969B 00000808 0100201F AD000200
[   80.837799] PVR_K:   (MKT-135) 071997B9 00000808 0100201F AD001703
[   80.844360] PVR_K:   (MKT-136) 071999B6 00000808 0000201F AD000202
[   80.850860] PVR_K:   (MKT-137) 07199A31 00000808 0000211E AD000183
[   80.857543] PVR_K:   (MKT-138) 07199B1B 00000808 0000211E AD00030E
[   80.864166] PVR_K:   (MKT-139) 07199B34 00000808 0000211E 0D800494
[   80.870727] PVR_K:   (MKT-13A) 07199B4C 00000808 0000211E 0000000A
[   80.877227] PVR_K:   (MKT-13B) 07199B6F 00000808 0000211E 0000000B
[   80.883819] PVR_K:   (MKT-13C) 07199BD9 00000808 0000211E AD000184
[   80.890380] PVR_K:   (MKT-13D) 07199C3C 00000C08 0100221D AD000281
[   80.896942] PVR_K:   (MKT-13E) 07199DB6 00000808 0100221D AD00080A
[   80.903533] PVR_K:   (MKT-13F) 07199DCF 00000808 0100221D 0F038700
[   80.910156] PVR_K:   (MKT-140) 07199DE7 00000808 0100221D 00000061
[   80.916778] PVR_K:   (MKT-141) 07199F61 00000808 0000221D AD000802
[   80.923339] PVR_K:   (MKT-142) 0719A0AE 00000808 0000221D AD000803
[   80.929931] PVR_K:   (MKT-143) 0719A0F4 00184EC8 0000221D AD000282
[   80.936492] PVR_K:   (MKT-144) 0719C064 00000C08 0100251F AD000200
[   80.943786] PVR_K:   (MKT-145) 0719C2B0 00000808 0000251F AD000202
[   80.950347] PVR_K:   (MKT-146) 0719C33A 00000808 0000261E AD000183
[   80.957000] PVR_K:   (MKT-147) 0719C426 00000808 0000261E AD00030E
[   80.963897] PVR_K:   (MKT-148) 0719C43E 00000808 0000261E 0D800494
[   80.970581] PVR_K:   (MKT-149) 0719C458 00000808 0000261E 0000000A
[   80.977203] PVR_K:   (MKT-14A) 0719C47C 00000808 0000261E 0000000B
[   80.983856] PVR_K:   (MKT-14B) 0719C4E6 00000808 0000261E AD000184
[   80.990417] PVR_K:   (MKT-14C) 0719C54A 00000C08 0100271D AD000281
[   80.997070] PVR_K:   (MKT-14D) 0719C6B3 00000808 0100271D AD00080A
[   81.003692] PVR_K:   (MKT-14E) 0719C6CC 00000808 0100271D 0F038A00
[   81.010345] PVR_K:   (MKT-14F) 0719C6E4 00000808 0100271D 00000060
[   81.016967] PVR_K:   (MKT-150) 0719C993 00000808 0000271D AD000803
[   81.023590] PVR_K:   (MKT-151) 0719C9D9 00180CC8 0000271D AD000282
[   81.030151] PVR_K:   (MKT-152) 0719CA99 00000808 0100291F AD000200
[   81.036682] PVR_K:   (MKT-153) 0719CCB8 00000808 0000291F AD000202
[   81.043304] PVR_K:   (MKT-154) 0719CD36 00000808 00002A1E AD000183
[   81.049865] PVR_K:   (MKT-155) 0719CE24 00000808 00002A1E AD00030E
[   81.056488] PVR_K:   (MKT-156) 0719CE3C 00000808 00002A1E 0D800494
[   81.063049] PVR_K:   (MKT-157) 0719CE55 00000808 00002A1E 0000000A
[   81.069641] PVR_K:   (MKT-158) 0719CE79 00000808 00002A1E 0000000B
[   81.076202] PVR_K:   (MKT-159) 0719CEE3 00000808 00002A1E AD000184
[   81.082824] PVR_K:   (MKT-15A) 0719CF48 00000C08 01002B1D AD000281
[   81.089416] PVR_K:   (MKT-15B) 0719D0B8 00000808 01002B1D AD00080A
[   81.096740] PVR_K:   (MKT-15C) 0719D0D0 00000808 01002B1D 0F038D00
[   81.103332] PVR_K:   (MKT-15D) 0719D0E9 00000808 01002B1D 00000060
[   81.109924] PVR_K:   (MKT-15E) 0719D396 00000808 00002B1D AD000803
[   81.116485] PVR_K:   (MKT-15F) 0719D3DB 00180CC8 00002B1D AD000282
[   81.122955] PVR_K:   (MKT-160) 0719D4CD 00000808 01002D1F AD000200
[   81.129516] PVR_K:   (MKT-161) 0719D6EC 00000808 00002D1F AD000202
[   81.136077] PVR_K:   (MKT-162) 0719D769 00000808 00002E1E AD000183
[   81.142639] PVR_K:   (MKT-163) 0719D851 00000808 00002E1E AD00030E
[   81.149169] PVR_K:   (MKT-164) 0719D869 00000808 00002E1E 0D800494
[   81.155822] PVR_K:   (MKT-165) 0719D887 00000808 00002E1E 0000000A
[   81.162292] PVR_K:   (MKT-166) 0719D8AF 00000808 00002E1E 0000000B
[   81.168853] PVR_K:   (MKT-167) 0719D91A 00000808 00002E1E AD000184
[   81.175415] PVR_K:   (MKT-168) 0719D97F 00000C08 01002F1D AD000281
[   81.182006] PVR_K:   (MKT-169) 0719DAF3 00000808 01002F1D AD00080A
[   81.188568] PVR_K:   (MKT-16A) 0719DB0C 00000808 01002F1D 0F039000
[   81.195068] PVR_K:   (MKT-16B) 0719DB24 00000808 01002F1D 00000062
[   81.201599] PVR_K:   (MKT-16C) 0719DDDF 00000808 00002F1D AD000803
[   81.208129] PVR_K:   (MKT-16D) 0719DE24 00180C88 00002F1D AD000282
[   81.214660] PVR_K:   (MKT-16E) 0719E962 00000808 0100311F AD000200
[   81.221191] PVR_K:   (MKT-16F) 0719EA7F 00000808 0100311F AD001703
[   81.227752] PVR_K:   (MKT-170) 0719EC62 00000808 0000311F AD000202
[   81.234252] PVR_K:   (MKT-171) 0719ECE1 00000808 0000321E AD000183
[   81.240814] PVR_K:   (MKT-172) 0719EDCC 00000808 0000321E AD00030E
[   81.247344] PVR_K:   (MKT-173) 0719EDE4 00000808 0000321E 0D800494
[   81.253906] PVR_K:   (MKT-174) 0719EDFC 00000808 0000321E 0000000A
[   81.260467] PVR_K:   (MKT-175) 0719EE20 00000808 0000321E 0000000B
[   81.266998] PVR_K:   (MKT-176) 0719EE8A 00000808 0000321E AD000184
[   81.273559] PVR_K:   (MKT-177) 0719EEEE 00000C08 0100331D AD000281
[   81.280059] PVR_K:   (MKT-178) 0719EFFF 00000808 0100331D AD000E02
[   81.286621] PVR_K:   (MKT-179) 0719F074 00000808 0100331D AD000282
[   81.293151] PVR_K:   (MKT-17A) 071ABFE4 00000808 0100361F AD001A00
[   81.299682] PVR_K:   (MKT-17B) 071B9A81 00000808 0100391F AD00000A
[   81.306945] PVR_K:   (MKT-17C) 071B9AE1 00000808 0100391F AD000909
[   81.313568] PVR_K:   (MKT-17D) 071B9B2D 00000808 0100391F AD001A05
[   81.320129] PVR_K:   (MKT-17E) 071B9B5E 00000808 0100391F AD001302
[   81.326751] PVR_K:   (MKT-17F) 071B9B9E 00000808 0100391F AD001303
[   81.333282] PVR_K:   (MKT-180) 071B9C30 00000808 0100391F AD000D04
[   81.339782] PVR_K:   (MKT-181) 071B9D04 00000808 0100391F AD000D05
[   81.346343] PVR_K:   (MKT-182) 071B9D5D 00000808 0100391F AD000D04
[   81.352844] PVR_K:   (MKT-183) 071B9DE1 00000808 0100391F AD000D05
[   81.359374] PVR_K:   (MKT-184) 071B9E3D 00000808 0100391F AD001A06
[   81.365875] PVR_K:   (MKT-185) 00000458 00100808 0100031F AD002300
[   81.372406] PVR_K:   (MKT-186) 00000935 00100808 0100041F AD00000A
[   81.378967] PVR_K:   (MKT-187) 000009B2 00100808 0100041F AD000906
[   81.385528] PVR_K:   (MKT-188) 00000A81 00100808 0000041F AD000901
[   81.392028] PVR_K:   (MKT-189) 00000AFB 00100808 0000051E AD000183
[   81.398925] PVR_K:   (MKT-18A) 00000C6D 00100808 0000051E AD000302
[   81.405456] PVR_K:   (MKT-18B) 00000DEF 00100808 0000051E AD000D06
[   81.411987] PVR_K:   (MKT-18C) 00000ED4 00100808 0000051E AD000D07
[   81.418518] PVR_K:   (MKT-18D) 00000F1F 00100808 0000051E AD001304
[   81.425018] PVR_K:   (MKT-18E) 0000100C 00100808 0000051E AD001305
[   81.431579] PVR_K:   (MKT-18F) 0000111F 00100888 0000051E AD000404
[   81.438079] PVR_K:   (MKT-190) 000011E4 00100808 0000051E AD000402
[   81.444610] PVR_K:   (MKT-191) 0000122E 0010082B 0000051E AD000184
[   81.451110] PVR_K:   (MKT-192) 000012CD 00108DA9 0000061D AD000281
[   81.457641] PVR_K:   (MKT-193) 00001452 001089AF 0000061D AD000E02
[   81.464141] PVR_K:   (MKT-194) 000014AF 0010892B 0000061D AD000282
[   81.470703] PVR_K:   (MKT-195) 00003B2E 00100808 0000081F AD000101
[   81.477203] PVR_K:   (MKT-196) 00003BA2 00100808 0000081F AD000104
[   81.483734] PVR_K:   (MKT-197) 00003BDE 00100808 0100091E AD000100
[   81.490234] PVR_K:   (MKT-198) 00003CE3 00100808 0100091E AD000501
[   81.496795] PVR_K:   (MKT-199) 00003D21 0010082B 0100091E AD000104
[   81.503356] PVR_K:   (MKT-19A) 00005F9D 00100828 01000A1F AD000101
[   81.509857] PVR_K:   (MKT-19B) 00005FE1 00100828 01000A1F AD000104
[   81.516387] PVR_K:   (MKT-19C) 000060F5 00100808 01000B1F AD000100
[   81.522918] PVR_K:   (MKT-19D) 000061AF 00100808 01000B1F AD000501
[   81.529449] PVR_K:   (MKT-19E) 000061DB 00100829 01000B1F AD000104
[   81.535949] PVR_K:   (MKT-19F) 00008715 00100828 01000D1F AD000101
[   81.542510] PVR_K:   (MKT-1A0) 0000878A 00100828 01000D1F AD000104
[   81.548980] PVR_K:   (MKT-1A1) 000087C6 00100808 01000E1E AD000100
[   81.555541] PVR_K:   (MKT-1A2) 000088C4 00100808 01000E1E AD000501
[   81.562042] PVR_K:   (MKT-1A3) 00008903 0010082B 01000E1E AD000104
[   81.568572] PVR_K:   (MKT-1A4) 0000A93B 00100828 01000F1F AD000101
[   81.575073] PVR_K:   (MKT-1A5) 0000A97F 00100828 01000F1F AD000104
[   81.581665] PVR_K:   (MKT-1A6) 0000AB75 00100808 0100101F AD000100
[   81.588195] PVR_K:   (MKT-1A7) 0000ABEC 00100808 0100101F AD000502
[   81.594696] PVR_K:   (MKT-1A8) 0000AC3F 00100808 0100101F AD000C01
[   81.601257] PVR_K:   (MKT-1A9) 0000AC62 00100808 0100101F 0D800484
[   81.607757] PVR_K:   (MKT-1AA) 0000AC7A 00100808 0100101F 0000000C
[   81.614318] PVR_K:   (MKT-1AB) 0000AF39 00100808 0000101F AD00030E
[   81.620819] PVR_K:   (MKT-1AC) 0000AF51 00100808 0000101F 0D800474
[   81.627349] PVR_K:   (MKT-1AD) 0000AF6A 00100808 0000101F 0000000B
[   81.633850] PVR_K:   (MKT-1AE) 0000AF8C 00100808 0000101F 0000000C
[   81.640411] PVR_K:   (MKT-1AF) 0000B024 00100808 0000101F AD000104
[   81.646911] PVR_K:   (MKT-1B0) 0000B09A 00100C08 0100111E AD000281
[   81.653442] PVR_K:   (MKT-1B1) 0000B212 00100808 0100111E AD00080A
[   81.659942] PVR_K:   (MKT-1B2) 0000B22C 00100808 0100111E 0F039300
[   81.666473] PVR_K:   (MKT-1B3) 0000B244 00100808 0100111E 00000061
[   81.673034] PVR_K:   (MKT-1B4) 0000B3C4 00100808 0000111E AD000802
[   81.679534] PVR_K:   (MKT-1B5) 0000B51C 00100808 0000111E AD000803
[   81.686065] PVR_K:   (MKT-1B6) 0000B562 00184AC8 0000111E AD000282
[   81.692565] PVR_K:   (MKT-1B7) 0000D54A 00000C08 0100141F AD000200
[   81.699096] PVR_K:   (MKT-1B8) 0000D79C 00000808 0000141F AD000202
[   81.705627] PVR_K:   (MKT-1B9) 0000D826 00000808 0000151E AD000183
[   81.712158] PVR_K:   (MKT-1BA) 0000D90F 00000808 0000151E AD00030E
[   81.718658] PVR_K:   (MKT-1BB) 0000D927 00000808 0000151E 0D800474
[   81.725189] PVR_K:   (MKT-1BC) 0000D940 00000808 0000151E 0000000B
[   81.731689] PVR_K:   (MKT-1BD) 0000D964 00000808 0000151E 0000000C
[   81.738250] PVR_K:   (MKT-1BE) 0000D9D0 00000808 0000151E AD000184
[   81.744750] PVR_K:   (MKT-1BF) 0000DA35 00000C08 0100161D AD000281
[   81.751281] PVR_K:   (MKT-1C0) 0000DBA4 00000808 0100161D AD00080A
[   81.757812] PVR_K:   (MKT-1C1) 0000DBBC 00000808 0100161D 0F039600
[   81.764312] PVR_K:   (MKT-1C2) 0000DBD5 00000808 0100161D 00000060
[   81.770843] PVR_K:   (MKT-1C3) 0000DE8C 00000808 0000161D AD000803
[   81.777343] PVR_K:   (MKT-1C4) 0000DED1 00180CC8 0000161D AD000282
[   81.783874] PVR_K:   (MKT-1C5) 0000DF73 00000808 0100181F AD000200
[   81.790374] PVR_K:   (MKT-1C6) 0000E18B 00000808 0000181F AD000202
[   81.796905] PVR_K:   (MKT-1C7) 0000E208 00000808 0000191E AD000183
[   81.803405] PVR_K:   (MKT-1C8) 0000E2F4 00000808 0000191E AD00030E
[   81.809967] PVR_K:   (MKT-1C9) 0000E30C 00000808 0000191E 0D800474
[   81.816467] PVR_K:   (MKT-1CA) 0000E325 00000808 0000191E 0000000B
[   81.822998] PVR_K:   (MKT-1CB) 0000E348 00000808 0000191E 0000000C
[   81.829498] PVR_K:   (MKT-1CC) 0000E3B2 00000808 0000191E AD000184
[   81.836059] PVR_K:   (MKT-1CD) 0000E41A 00000C08 01001A1D AD000281
[   81.842590] PVR_K:   (MKT-1CE) 0000E587 00000808 01001A1D AD00080A
[   81.849090] PVR_K:   (MKT-1CF) 0000E5A0 00000808 01001A1D 0F039900
[   81.855651] PVR_K:   (MKT-1D0) 0000E5B8 00000808 01001A1D 00000060
[   81.862152] PVR_K:   (MKT-1D1) 0000E86D 00000808 00001A1D AD000803
[   81.868682] PVR_K:   (MKT-1D2) 0000E8B3 00180CC8 00001A1D AD000282
[   81.875183] PVR_K:   (MKT-1D3) 0000E99D 00000808 01001C1F AD000200
[   81.881744] PVR_K:   (MKT-1D4) 0000EBB8 00000808 00001C1F AD000202
[   81.888214] PVR_K:   (MKT-1D5) 0000EC38 00000808 00001D1E AD000183
[   81.894775] PVR_K:   (MKT-1D6) 0000ED23 00000808 00001D1E AD00030E
[   81.901275] PVR_K:   (MKT-1D7) 0000ED3B 00000808 00001D1E 0D800474
[   81.907806] PVR_K:   (MKT-1D8) 0000ED54 00000808 00001D1E 0000000B
[   81.914306] PVR_K:   (MKT-1D9) 0000ED78 00000808 00001D1E 0000000C
[   81.920837] PVR_K:   (MKT-1DA) 0000EDE2 00000808 00001D1E AD000184
[   81.927398] PVR_K:   (MKT-1DB) 0000EE46 00000C08 01001E1D AD000281
[   81.933898] PVR_K:   (MKT-1DC) 0000EFAD 00000808 01001E1D AD00080A
[   81.940429] PVR_K:   (MKT-1DD) 0000EFC6 00000808 01001E1D 0F039C00
[   81.946960] PVR_K:   (MKT-1DE) 0000EFDE 00000808 01001E1D 00000062
[   81.953491] PVR_K:   (MKT-1DF) 0000F293 00000808 00001E1D AD000803
[   81.959991] PVR_K:   (MKT-1E0) 0000F2D9 00180C88 00001E1D AD000282
[   81.966552] PVR_K:   (MKT-1E1) 0000FDB6 00000808 0100201F AD000200
[   81.973022] PVR_K:   (MKT-1E2) 0000FED3 001FFFFF 0100201F AD001703
[   81.979583] PVR_K:   (MKT-1E3) 000100A6 00000808 0000201F AD000202
[   81.986083] PVR_K:   (MKT-1E4) 00010123 00000808 0100211E AD000183
[   81.992614] PVR_K:   (MKT-1E5) 0001020C 00000808 0100211E AD00030E
[   81.999114] PVR_K:   (MKT-1E6) 00010224 00000808 0100211E 0D800474
[   82.005676] PVR_K:   (MKT-1E7) 0001023D 00000808 0100211E 0000000B
[   82.012207] PVR_K:   (MKT-1E8) 00010260 00000808 0100211E 0000000C
[   82.018707] PVR_K:   (MKT-1E9) 000102EC 00000808 0100211E AD000184
[   82.025268] PVR_K:   (MKT-1EA) 0001D923 00000808 0100241F AD001A00
[   82.031768] PVR_K:   (MKT-1EB) 0006D023 00000808 0100321F AD00000A
[   82.038299] PVR_K:   (MKT-1EC) 0006D08C 00000808 0100321F AD000909
[   82.044799] PVR_K:   (MKT-1ED) 0006D0D5 00000808 0100321F AD001A05
[   82.051361] PVR_K:   (MKT-1EE) 0006D104 00000808 0100321F AD001302
[   82.057861] PVR_K:   (MKT-1EF) 0006D144 00000808 0100321F AD001303
[   82.064392] PVR_K:   (MKT-1F0) 0006D1DB 00000808 0100321F AD000D04
[   82.070892] PVR_K:   (MKT-1F1) 0006D2A3 00000808 0100321F AD000D05
[   82.077453] PVR_K:   (MKT-1F2) 0006D311 00000808 0100321F AD001A06
[   82.083923] PVR_K:   (MKT-1F3) 000004A3 00100808 0100031F AD002300
[   82.090515] PVR_K:   (MKT-1F4) 00000977 00100808 0100041F AD00000A
[   82.097045] PVR_K:   (MKT-1F5) 000009F2 00100808 0100041F AD000906
[   82.103576] PVR_K:   (MKT-1F6) 00000AC5 00100808 0000041F AD000901
[   82.110137] PVR_K:   (MKT-1F7) 00000B3F 00100808 0100051E AD000183
[   82.116638] PVR_K:   (MKT-1F8) 00000CB3 00100808 0100051E AD000302
[   82.123168] PVR_K:   (MKT-1F9) 00000E32 00100808 0100051E AD000D06
[   82.129760] PVR_K:   (MKT-1FA) 00000F15 00100808 0100051E AD000D07
[   82.136291] PVR_K:   (MKT-1FB) 00000F5F 00100808 0100051E AD001304
[   82.142822] PVR_K:   (MKT-1FC) 0000104A 00100808 0100051E AD001305
[   82.149353] PVR_K:   (MKT-1FD) 00001159 00100888 0100051E AD000404
[   82.155883] PVR_K:   (MKT-1FE) 0000121A 00100808 0000051E AD000402
[   82.162414] PVR_K:   (MKT-1FF) 00001262 0010082B 0000051E AD000184
[   82.168945] PVR_K: SGX Kernel CCB WO:0xA2 RO:0x9E
[   82.175445] adc_to_temp_conversion:Temp read is invalid 0
[   82.181427] thermal_lookup_temp: getting temp is not supported for domain pcb
[   82.190490] adc_to_temp_conversion:Temp read is invalid 0
[   82.196350] thermal_lookup_temp: getting temp is not supported for domain pcb
[   82.204956] adc_to_temp_conversion:Temp read is invalid 0
[   82.210845] thermal_lookup_temp: getting temp is not supported for domain pcb
[   82.373901] PVR_K:(Error): SGXOSTimer() detected SGX lockup (0xc tasks) [0, ]
[   82.381561] PVR_K: HWRecoveryResetSGX: SGX Hardware Recovery triggered
[   82.389739] [   55.908]                         [c6e67800] dsscomp_apply
[   82.389739] [   55.924]                          [c6e66c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   82.389739] [   55.924]  [c6fa40a0] --refs=0 on RELEASED
[   82.389739] [   55.924]  [c6fa40a0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   82.419433] [   55.924]                          [c6e66c00] dsscomp_mgr_delayed_cb on RELEASED
[   82.419433] [   55.924]                         [c6e67800] dsscomp_mgr_delayed_cb on PROGRAMMED
[   82.419433] [   55.942]                         [c6e67800] dsscomp_mgr_delayed_cb on DISPLAYED
[   82.419433] [   61.370]   [c6edbbc0] new in dsscomp_gralloc_queue (refs=1)
[   82.449218] [   61.370]                          [c6f10800] dsscomp_new
[   82.449218] [   61.370]   [c6edbbc0] ++refs=2 for [c6f10800]
[   82.449218] [   61.370]                          [c6f10800] dsscomp_delayed_apply
[   82.449218] [   61.370]   [c6edbbc0] --refs=1 on RELEASED
[   82.479034] [   61.370]                          [c6f10800] dsscomp_apply
[   82.479034] [   61.370]     [c6fa4160] --refs=0 on RELEASED
[   82.479034] [   61.370]     [c6fa4160] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   82.479034] [   61.370]                         [c6e67800] dsscomp_mgr_delayed_cb on RELEASED
[   82.508819] [   61.370]                          [c6f10800] dsscomp_mgr_delayed_cb on PROGRAMMED
[   82.508819] [   61.371]    [c6edbc00] new in dsscomp_gralloc_queue (refs=1)
[   82.508819] [   61.371]                         [c6f11400] dsscomp_new
[   82.508819] [   61.371]    [c6edbc00] ++refs=2 for [c6f11400]
[   82.538604] [   61.371]                         [c6f11400] dsscomp_delayed_apply
[   82.538604] [   61.371]    [c6edbc00] --refs=1 on RELEASED
[   82.538604] [   61.371]                         [c6f11400] dsscomp_apply
[   82.538635] [   61.383]                          [c6f10800] dsscomp_mgr_delayed_cb on DISPLAYED
[   82.568359] [   61.383]   [c6edbbc0] --refs=0 on RELEASED
[   82.568389] [   61.383]   [c6edbbc0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   82.568389] [   61.383]                          [c6f10800] dsscomp_mgr_delayed_cb on RELEASED
[   82.568389] [   61.383]                         [c6f11400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   82.598175] [   61.400]                         [c6f11400] dsscomp_mgr_delayed_cb on DISPLAYED
[   82.598175] [   66.356]     [c6fa4320] new in dsscomp_gralloc_queue (refs=1)
[   82.598175] [   66.356]                          [c6e66c00] dsscomp_new
[   82.626403] [   66.356]     [c6fa4320] ++refs=2 for [c6e66c00]
[   82.626403] [   66.356]                          [c6e66c00] dsscomp_delayed_apply
[   82.626403] [   66.356]     [c6fa4320] --refs=1 on RELEASED
[   82.626403] [   66.356]                          [c6e66c00] dsscomp_apply
[   82.626403] [   66.356]    [c6edbc00] --refs=0 on RELEASED
[   82.657714] [   66.356]    [c6edbc00] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   82.657714] [   66.356]                         [c6f11400] dsscomp_mgr_delayed_cb on RELEASED
[   82.657714] [   66.356]                          [c6e66c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   82.685943] [   66.357]  [c6edbb80] new in dsscomp_gralloc_queue (refs=1)
[   82.685943] [   66.357]                          [c6f10800] dsscomp_new
[   82.685943] [   66.357]  [c6edbb80] ++refs=2 for [c6f10800]
[   82.685943] [   66.357]                          [c6f10800] dsscomp_delayed_apply
[   82.715728] [   66.357]  [c6edbb80] --refs=1 on RELEASED
[   82.715728] [   66.357]                          [c6f10800] dsscomp_apply
[   82.715728] [   66.375]                          [c6e66c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   82.715728] [   66.375]     [c6fa4320] --refs=0 on RELEASED
[   82.715728] [   66.375]     [c6fa4320] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   82.747039] [   66.376]                          [c6e66c00] dsscomp_mgr_delayed_cb on RELEASED
[   82.747039] [   66.376]                          [c6f10800] dsscomp_mgr_delayed_cb on PROGRAMMED
[   82.747039] [   66.393]                          [c6f10800] dsscomp_mgr_delayed_cb on DISPLAYED
[   82.775268] [   72.154]  [c6fa4420] new in dsscomp_gralloc_queue (refs=1)
[   82.775268] [   72.154]                           [c6e66000] dsscomp_new
[   82.775268] [   72.154]  [c6fa4420] ++refs=2 for [c6e66000]
[   82.775268] [   72.154]                           [c6e66000] dsscomp_delayed_apply
[   82.805053] [   72.154]  [c6fa4420] --refs=1 on RELEASED
[   82.805053] [   72.154]                           [c6e66000] dsscomp_apply
[   82.805053] [   72.154]  [c6edbb80] --refs=0 on RELEASED
[   82.805053] [   72.154]  [c6edbb80] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   82.834808] [   72.154]                          [c6f10800] dsscomp_mgr_delayed_cb on RELEASED
[   82.834808] [   72.154]                           [c6e66000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   82.834808] [   72.155]       [c6edbcc0] new in dsscomp_gralloc_queue (refs=1)
[   82.834808] [   72.155]                       [c6f12c00] dsscomp_new
[   82.864562] [   72.155]       [c6edbcc0] ++refs=2 for [c6f12c00]
[   82.864562] [   72.155]                       [c6f12c00] dsscomp_delayed_apply
[   82.864562] [   72.155]       [c6edbcc0] --refs=1 on RELEASED
[   82.864593] [   72.155]                       [c6f12c00] dsscomp_apply
[   82.894317] [   72.176]                           [c6e66000] dsscomp_mgr_delayed_cb on DISPLAYED
[   82.894317] [   72.176]  [c6fa4420] --refs=0 on RELEASED
[   82.894348] [   72.176]  [c6fa4420] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   82.894348] [   72.176]                           [c6e66000] dsscomp_mgr_delayed_cb on RELEASED
[   82.924133] [   72.176]                       [c6f12c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   82.924163] [   72.191]                       [c6f12c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   82.924163] [   77.137]    [c6fa43c0] new in dsscomp_gralloc_queue (refs=1)
[   82.952392] [   77.137]                           [c6e67c00] dsscomp_new
[   82.952392] [   77.137]    [c6fa43c0] ++refs=2 for [c6e67c00]
[   82.952392] [   77.137]                           [c6e67c00] dsscomp_delayed_apply
[   82.952392] [   77.137]    [c6fa43c0] --refs=1 on RELEASED
[   82.952392] [   77.137]                           [c6e67c00] dsscomp_apply
[   82.983734] [   77.138]       [c6edbcc0] --refs=0 on RELEASED
[   82.983734] [   77.138]       [c6edbcc0] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   82.983734] [   77.138]                       [c6f12c00] dsscomp_mgr_delayed_cb on RELEASED
[   83.011962] [   77.138]                           [c6e67c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   83.011962] [   77.138]    [c6edbc00] new in dsscomp_gralloc_queue (refs=1)
[   83.011962] [   77.138]                         [c6f11400] dsscomp_new
[   83.011962] [   77.138]    [c6edbc00] ++refs=2 for [c6f11400]
[   83.041748] [   77.138]                         [c6f11400] dsscomp_delayed_apply
[   83.041748] [   77.138]    [c6edbc00] --refs=1 on RELEASED
[   83.041748] [   77.138]                         [c6f11400] dsscomp_apply
[   83.041778] [   77.152]                           [c6e67c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   83.071502] [   77.152]    [c6fa43c0] --refs=0 on RELEASED
[   83.071533] [   77.152]    [c6fa43c0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   83.071533] [   77.152]                           [c6e67c00] dsscomp_mgr_delayed_cb on RELEASED
[   83.071533] [   77.152]                         [c6f11400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   83.101531] [   77.154]    [c6fa44a0] new in dsscomp_gralloc_queue (refs=1)
[   83.101531] [   77.154]                           [c6e67c00] dsscomp_new
[   83.101531] [   77.154]    [c6fa44a0] ++refs=2 for [c6e67c00]
[   83.101531] [   77.154]                           [c6e67c00] dsscomp_delayed_apply
[   83.131469] [   77.154]    [c6fa44a0] --refs=1 on RELEASED
[   83.131469] [   77.154]                           [c6e67c00] dsscomp_apply
[   83.131500] [   77.171]                         [c6f11400] dsscomp_mgr_delayed_cb on DISPLAYED
[   83.131500] [   77.171]    [c6edbc00] --refs=0 on RELEASED
[   83.161285] [   77.171]    [c6edbc00] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   83.161285] [   77.171]                         [c6f11400] dsscomp_mgr_delayed_cb on RELEASED
[   83.161315] [   77.171]                           [c6e67c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   83.189636] [   77.186]                           [c6e67c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   83.189666] [   82.167]   [c6fa4460] new in dsscomp_gralloc_queue (refs=1)
[   83.189666] [   82.167]                           [c6e66000] dsscomp_new
[   83.189666] [   82.167]   [c6fa4460] ++refs=2 for [c6e66000]
[   83.219451] [   82.167]                           [c6e66000] dsscomp_delayed_apply
[   83.219451] [   82.167]   [c6fa4460] --refs=1 on RELEASED
[   83.219451] [   82.167]                           [c6e66000] dsscomp_apply
[   83.219451] [   82.167]    [c6fa44a0] --refs=0 on RELEASED
[   83.219482] [   82.167]    [c6fa44a0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   83.250915] [   82.167]                           [c6e67c00] dsscomp_mgr_delayed_cb on RELEASED
[   83.250915] [   82.167]                           [c6e66000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   83.250915] [   82.168]   [c6edbca0] new in dsscomp_gralloc_queue (refs=1)
[   83.279205] [   82.168]                          [c6f10800] dsscomp_new
[   83.279205] [   82.168]   [c6edbca0] ++refs=2 for [c6f10800]
[   83.279235] [   82.168]                          [c6f10800] dsscomp_delayed_apply
[   83.279235] [   82.168]   [c6edbca0] --refs=1 on RELEASED
[   83.279235] [   82.168]                          [c6f10800] dsscomp_apply
[   83.310638] [   82.183]                           [c6e66000] dsscomp_mgr_delayed_cb on DISPLAYED
[   83.310638] [   82.183]   [c6fa4460] --refs=0 on RELEASED
[   83.310638] [   82.183]   [c6fa4460] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   83.310668] [   82.183]                           [c6e66000] dsscomp_mgr_delayed_cb on RELEASED
[   83.340454] [   82.183]                          [c6f10800] dsscomp_mgr_delayed_cb on PROGRAMMED
[   83.340454] [   82.204]                          [c6f10800] dsscomp_mgr_delayed_cb on DISPLAYED
[   83.340454] ACTIVE COMPOSITIONS on lcd
[   83.368774]
[   83.368774]   [c6f10800]: DISPLAYED
[   83.368774]     sync_id=0, flags=AD-
[   83.368774]     ovl0={ON z0 ARGB32-8888 premult *100% 864*480:0,0+864,480 rot0 => 0,0+864,480 7f9ac000/  (null)|3456}
[   83.368774]     gsync=[c6edbca0] dsscomp_gralloc_cb
[   83.368774]
[   83.368774]   DISPC pipeline:
[   83.368804]
[   83.368804]     info:        clean (none)
[   83.406219]     cache:       clean (none)
[   83.406219]     shadow:  ACT clean (none)
[   83.406219]     dispc:   DISPLAYED mask=---R [c6f10800] dsscomp_mgr_callback
[   83.406219]
[   83.406219] ACTIVE COMPOSITIONS on tv
[   83.406219]
[   83.406219]   DISPC pipeline:
[   83.406219]
[   83.406219]     info:        clean (none)
[   83.406249]     cache:       clean (none)
[   83.406249]     shadow:  off clean (none)
[   83.446807]     dispc:   DISPLAYED (none)
[   83.446807]
[   83.446807] ACTIVE COMPOSITIONS on lcd2
[   83.446807]
[   83.446807]   DISPC pipeline:
[   83.446807]
[   83.446807]     info:        clean (none)
[   83.446807]     cache:       clean (none)
[   83.446807]     shadow:  off clean (none)
[   83.446807]     dispc:             (none)
[   83.446838]
[   83.446838] ACTIVE GRALLOC FLIPS
[   83.446838]
[   83.446838]   [c6edbca0] (refs=1)
[   83.491882]     slots=[7f9ac000]
[   83.491882]     cmdcb=[c73f6480] dsscomp_proxy_cmdcomplete
[   83.491882]
[   83.491882]   |           lcd
[   83.491882]   | [c6f10800] DISPL'D
[   83.491882]   |     82.168  ACTIVE
[   83.491882]   |     82.168 APPLY'N
[   83.491882]   |     82.168 APPLIED
[   83.491912]   |     82.183 PROGR'D
[   83.491912]   |     82.204 DISPL'D
[   83.491912]
[   83.491912]
[   83.533355] PVR_K: SGX debug (blaze_android_sgx_ogles1_ogles2_GPL sgxddk 18 1.8@869593)
[   83.541931] PVR_K:(Error): SGX Register Base Address (Linear):   0xC8B20000 [0, ]
[   83.549896] PVR_K:(Error): SGX Register Base Address (Physical): 0x56000000 [0, ]
[   83.557891] PVR_K: (P0) EUR_CR_CORE_ID:          01140000
[   83.563659] PVR_K: (P0) EUR_CR_CORE_REVISION:    00010200
[   83.569458] PVR_K: (P0) EUR_CR_EVENT_STATUS:     20000000
[   83.575195] PVR_K: (P0) EUR_CR_EVENT_STATUS2:    00000008
[   83.581024] PVR_K: (P0) EUR_CR_BIF_CTRL:         00000000
[   83.586791] PVR_K: (P0) EUR_CR_BIF_INT_STAT:     00008000
[   83.592590] PVR_K: (P0) EUR_CR_BIF_FAULT:        00000000
[   83.598327] PVR_K: (P0) EUR_CR_BIF_MEM_REQ_STAT: 00000000
[   83.604156] PVR_K: (P0) EUR_CR_CLKGATECTL:       000AAA6A
[   83.609893] PVR_K: (P0) EUR_CR_PDS_PC_BASE:      00004038
[   83.615722] PVR_K: Flip Command Complete Data 0 for display device 1:
[   83.622558] PVR_K:   SRC 0: ROC DevVAddr:0xD800494 ROP:0xe ROC:0xc, WOC DevVAddr:0xD800484 WOP:0xe WOC:0xd
[   83.632781] PVR_K: Flip Command Complete Data 1 for display device 1:
[   83.639709] PVR_K:   SRC 0: (Not in use)
[   83.643798] PVR_K: SGX Host control:
[   83.647644] PVR_K:   (HC-0) 0x00000001 0x00000000 0x00000000 0x00000001
[   83.654632] PVR_K:   (HC-10) 0x0000000E 0x0000000A 0x0005DC00 0x00000003
[   83.661834] PVR_K:   (HC-20) 0x00000000 0x00000001 0x00000000 0x00000013
[   83.669036] PVR_K:   (HC-30) 0x00000E3B 0xF30489DC 0x00000000 0x00000000
[   83.676147] PVR_K:   (HC-40) 0x00000000 0x087BF500 0x087C6300 0x087C3100
[   83.683258] PVR_K: SGX TA/3D control:
[   83.687286] PVR_K:   (T3C-0) 0x0F003000 0x0F003120 0x0F002000 0x00000000
[   83.694366] PVR_K:   (T3C-10) 0x00000001 0x00000002 0x00000001 0x0F00DD00
[   83.701599] PVR_K:   (T3C-20) 0x00000000 0x00000000 0x00000000 0x00000000
[   83.708801] PVR_K:   (T3C-30) 0x00000000 0x00000000 0x00000000 0x00000000
[   83.716064] PVR_K:   (T3C-40) 0x00000000 0x00000000 0x00000000 0x00000000
[   83.723297] PVR_K:   (T3C-50) 0x0F00DD00 0x00000000 0x00000000 0x0F00DD00
[   83.730499] PVR_K:   (T3C-60) 0x00000000 0x00000000 0x0F00DD00 0x00000000
[   83.737731] PVR_K:   (T3C-70) 0x00000000 0x0F00DD00 0x00000000 0x0F004000
[   83.744964] PVR_K:   (T3C-80) 0x00000134 0x0001120F 0x00000000 0x0F00DEFC
[   83.752197] PVR_K:   (T3C-90) 0x00000000 0x0F000000 0xAB600000 0x0F03B400
[   83.760162] PVR_K:   (T3C-A0) 0x00000000 0x0F0109A0 0x0F00DD00 0x0F00DEFC
[   83.767303] PVR_K:   (T3C-B0) 0x0F010BE0 0x00000000 0x00000000 0x00000000
[   83.775268] PVR_K:   (T3C-C0) 0x00000000 0x00000000 0x00000000 0x00000000
[   83.782531] PVR_K:   (T3C-D0) 0x00000000 0x0000001B 0x0000001A 0x0F007000
[   83.789764] PVR_K:   (T3C-E0) 0x0F00D420 0x0F00E000 0x0F010720 0x0F010720
[   83.796905] PVR_K:   (T3C-F0) 0x00000000 0x000000B5 0x000000B5 0x00000000
[   83.804077] PVR_K:   (T3C-100) 0x00000003 0x00000000 0x00000000 0x00000001
[   83.811340] PVR_K:   (T3C-110) 0xB50C565C 0x0872E100 0x08787B00 0x08787B00
[   83.818572] PVR_K: Last SGX microkernel status code: AD000104
[   83.824768] PVR_K:   (MKT-0) 00005F30 00100828 01000A1F AD000101
[   83.831085] PVR_K:   (MKT-1) 00005F74 00100828 01000A1F AD000104
[   83.837463] PVR_K:   (MKT-2) 00006084 00100808 01000B1F AD000100
[   83.843780] PVR_K:   (MKT-3) 0000613E 00100808 01000B1F AD000501
[   83.850128] PVR_K:   (MKT-4) 0000616A 00100829 01000B1F AD000104
[   83.856933] PVR_K:   (MKT-5) 0718E8AF 00100808 0100031F AD000B00
[   83.863281] PVR_K:   (MKT-6) 0718E8F3 00100808 0100031F AD000B03
[   83.869598] PVR_K:   (MKT-7) 0718E97B 00100808 0100031F AD000B05
[   83.875976] PVR_K:   (MKT-8) 0718E9CF 00100808 0100031F AD000B06
[   83.882293] PVR_K:   (MKT-9) 0718E9FE 00100808 0100031F AD000B06
[   83.888641] PVR_K:   (MKT-A) 0718EA41 00100808 0100031F AD000B07
[   83.894989] PVR_K:   (MKT-B) 0718EA66 00100808 0100031F AD000B09
[   83.901306] PVR_K:   (MKT-C) 0718EABA 00100808 0100031F AD000B01
[   83.907684] PVR_K:   (MKT-D) 0718EAF6 00100808 0100031F AD002300
[   83.914001] PVR_K:   (MKT-E) 0718EE0E 00100808 0100041F AD00000A
[   83.920349] PVR_K:   (MKT-F) 0718EE8C 00100808 0100041F AD000906
[   83.926666] PVR_K:   (MKT-10) 0718EF4D 00100808 0000041F AD000901
[   83.933105] PVR_K:   (MKT-11) 0718EFC7 00100808 0000051E AD000183
[   83.939544] PVR_K:   (MKT-12) 0718F137 00100808 0000051E AD000302
[   83.945983] PVR_K:   (MKT-13) 0718F18A 00100808 0000051E AD000303
[   83.952392] PVR_K:   (MKT-14) 0718F214 00100808 0000051E AD000C01
[   83.958831] PVR_K:   (MKT-15) 0718F239 00100808 0000051E 0D800484
[   83.965240] PVR_K:   (MKT-16) 0718F251 00100808 0000051E 0000000B
[   83.971710] PVR_K:   (MKT-17) 0718F4A0 00100808 0000051E AD00030E
[   83.978088] PVR_K:   (MKT-18) 0718F4B9 00100808 0000051E 0D800474
[   83.984558] PVR_K:   (MKT-19) 0718F4D1 00100808 0000051E 0000000A
[   83.990966] PVR_K:   (MKT-1A) 0718F4F6 00100808 0000051E 0000000B
[   83.997406] PVR_K:   (MKT-1B) 0718F56F 00100808 0000051E AD000184
[   84.003875] PVR_K:   (MKT-1C) 0718F5EE 00100C08 0100061D AD000281
[   84.010253] PVR_K:   (MKT-1D) 0718F789 00100808 0100061D AD00080A
[   84.016723] PVR_K:   (MKT-1E) 0718F7A2 00100808 0100061D 0F037B00
[   84.023132] PVR_K:   (MKT-1F) 0718F7BA 00100808 0100061D 00000061
[   84.029571] PVR_K:   (MKT-20) 0718F8D6 00100C88 0100061D AD001300
[   84.035980] PVR_K:   (MKT-21) 07194CBE 00100808 0000061D AD001301
[   84.042449] PVR_K:   (MKT-22) 07194DEC 00100888 0000061D AD000802
[   84.048858] PVR_K:   (MKT-23) 07194F5C 00100888 0000061D AD000803
[   84.055328] PVR_K:   (MKT-24) 07194FA9 001808C8 0000061D AD000282
[   84.061737] PVR_K:   (MKT-25) 07195094 00184EF8 0000081E AD00000A
[   84.068176] PVR_K:   (MKT-26) 0719511B 00184AF8 0000081E AD000905
[   84.074584] PVR_K:   (MKT-27) 0719522C 001808B8 0000081E AD000901
[   84.081024] PVR_K:   (MKT-28) 0719529F 00180838 0000091C AD00000A
[   84.087432] PVR_K:   (MKT-29) 07195313 00180838 0000091C AD000906
[   84.093872] PVR_K:   (MKT-2A) 0719538A 00180838 0000091C AD000901
[   84.100280] PVR_K:   (MKT-2B) 071953DF 00180838 00000A1B AD00000A
[   84.106750] PVR_K:   (MKT-2C) 07195442 00180838 00000A1B AD000905
[   84.113189] PVR_K:   (MKT-2D) 071954F3 00180838 00000A1B AD000901
[   84.119598] PVR_K:   (MKT-2E) 0719554A 00180838 00000B1A AD00000A
[   84.126068] PVR_K:   (MKT-2F) 071955AC 00180838 00000B1A AD000905
[   84.132476] PVR_K:   (MKT-30) 0719565B 00180838 00000B1A AD000901
[   84.138946] PVR_K:   (MKT-31) 071956AE 00180838 00000C19 AD00000A
[   84.145324] PVR_K:   (MKT-32) 0719571E 00180838 00000C19 AD000905
[   84.151794] PVR_K:   (MKT-33) 071957CA 00180838 00000C19 AD000901
[   84.158203] PVR_K:   (MKT-34) 07195919 00180838 00000F1F AD000183
[   84.164642] PVR_K:   (MKT-35) 07195A9A 00180838 00000F1F AD000302
[   84.171051] PVR_K:   (MKT-36) 07195B0E 00180838 00000F1F AD000303
[   84.177520] PVR_K:   (MKT-37) 07195B90 00180838 00000F1F AD000C01
[   84.183929] PVR_K:   (MKT-38) 07195BBA 00180838 00000F1F 0D800464
[   84.190368] PVR_K:   (MKT-39) 07195BD3 00180838 00000F1F 0000000C
[   84.196777] PVR_K:   (MKT-3A) 07195DF1 00180838 00000F1F AD000184
[   84.203216] PVR_K:   (MKT-3B) 07195E60 00180C38 0100101D AD000281
[   84.209655] PVR_K:   (MKT-3C) 07195EB7 00180838 0100101D AD000282
[   84.216064] PVR_K:   (MKT-3D) 07196B71 00180838 0100111F AD00000A
[   84.222534] PVR_K:   (MKT-3E) 07196BDA 00180838 0100111F AD000905
[   84.228942] PVR_K:   (MKT-3F) 07196CE0 00180838 0000111F AD000901
[   84.235382] PVR_K:   (MKT-40) 07196D33 00180C38 0100121E AD000281
[   84.241790] PVR_K:   (MKT-41) 07196D8E 00180838 0100121E AD000282
[   84.248229] PVR_K:   (MKT-42) 07196E9E 00180838 0100131F AD00000A
[   84.254638] PVR_K:   (MKT-43) 07196F09 00180838 0100131F AD000905
[   84.261108] PVR_K:   (MKT-44) 0719700A 00180838 0000131F AD000901
[   84.267700] PVR_K:   (MKT-45) 0719705C 00100C28 0100141E AD000281
[   84.274261] PVR_K:   (MKT-46) 071970B4 00100828 0100141E AD000282
[   84.280700] PVR_K:   (MKT-47) 07197117 00000808 0100151F AD000200
[   84.287139] PVR_K:   (MKT-48) 0719736D 00000808 0000151F AD000202
[   84.293609] PVR_K:   (MKT-49) 0719741A 00000808 0000161E AD00000A
[   84.300109] PVR_K:   (MKT-4A) 07197485 00000808 0000161E AD000905
[   84.306549] PVR_K:   (MKT-4B) 07197573 00000808 0000161E AD000901
[   84.313079] PVR_K:   (MKT-4C) 071975C2 00000C08 0000171D AD000281
[   84.319641] PVR_K:   (MKT-4D) 07197720 00000808 0000171D AD00080A
[   84.326080] PVR_K:   (MKT-4E) 07197739 00000808 0000171D 0F037E00
[   84.332611] PVR_K:   (MKT-4F) 07197751 00000808 0000171D 00000060
[   84.339080] PVR_K:   (MKT-50) 07197A1B 00000808 0000171D AD000803
[   84.345581] PVR_K:   (MKT-51) 07197A61 00180CC8 0000171D AD000282
[   84.352050] PVR_K:   (MKT-52) 07197B14 00000808 0000181F AD00000A
[   84.358612] PVR_K:   (MKT-53) 07197B7D 00000808 0000181F AD000905
[   84.365020] PVR_K:   (MKT-54) 07197C70 00000888 0000181F AD000901
[   84.371490] PVR_K:   (MKT-55) 07197CBA 00000C08 00001A1D AD000200
[   84.377960] PVR_K:   (MKT-56) 07197EE8 00000808 00001A1D AD000202
[   84.384429] PVR_K:   (MKT-57) 07197F3F 00000808 01001B1C AD000281
[   84.390838] PVR_K:   (MKT-58) 0719808D 00000808 01001B1C AD00080A
[   84.397277] PVR_K:   (MKT-59) 071980A6 00000808 01001B1C 0F038100
[   84.403686] PVR_K:   (MKT-5A) 071980BE 00000808 01001B1C 00000060
[   84.410156] PVR_K:   (MKT-5B) 0719836A 00000808 00001B1C AD000803
[   84.416595] PVR_K:   (MKT-5C) 071983AF 00188CC8 00001B1C AD000282
[   84.423004] PVR_K:   (MKT-5D) 071984A2 00000808 01001D1F AD000200
[   84.429473] PVR_K:   (MKT-5E) 071986C7 00000808 01001D1F AD000202
[   84.435882] PVR_K:   (MKT-5F) 07198718 00000808 01001E1E AD000281
[   84.442321] PVR_K:   (MKT-60) 07198860 00000808 01001E1E AD00080A
[   84.448760] PVR_K:   (MKT-61) 07198878 00000808 01001E1E 0F038400
[   84.455200] PVR_K:   (MKT-62) 07198891 00000808 01001E1E 00000062
[   84.461608] PVR_K:   (MKT-63) 07198B47 00000808 00001E1E AD000803
[   84.468078] PVR_K:   (MKT-64) 07198B8D 00180C88 00001E1E AD000282
[   84.474487] PVR_K:   (MKT-65) 0719969B 00000808 0100201F AD000200
[   84.480926] PVR_K:   (MKT-66) 071997B9 00000808 0100201F AD001703
[   84.488037] PVR_K:   (MKT-67) 071999B6 00000808 0000201F AD000202
[   84.494506] PVR_K:   (MKT-68) 07199A31 00000808 0000211E AD000183
[   84.500915] PVR_K:   (MKT-69) 07199B1B 00000808 0000211E AD00030E
[   84.507354] PVR_K:   (MKT-6A) 07199B34 00000808 0000211E 0D800494
[   84.513977] PVR_K:   (MKT-6B) 07199B4C 00000808 0000211E 0000000A
[   84.520568] PVR_K:   (MKT-6C) 07199B6F 00000808 0000211E 0000000B
[   84.527038] PVR_K:   (MKT-6D) 07199BD9 00000808 0000211E AD000184
[   84.533447] PVR_K:   (MKT-6E) 07199C3C 00000C08 0100221D AD000281
[   84.539947] PVR_K:   (MKT-6F) 07199DB6 00000808 0100221D AD00080A
[   84.546417] PVR_K:   (MKT-70) 07199DCF 00000808 0100221D 0F038700
[   84.552917] PVR_K:   (MKT-71) 07199DE7 00000808 0100221D 00000061
[   84.559448] PVR_K:   (MKT-72) 07199F61 00000808 0000221D AD000802
[   84.565979] PVR_K:   (MKT-73) 0719A0AE 00000808 0000221D AD000803
[   84.572479] PVR_K:   (MKT-74) 0719A0F4 00184EC8 0000221D AD000282
[   84.578979] PVR_K:   (MKT-75) 0719C064 00000C08 0100251F AD000200
[   84.585449] PVR_K:   (MKT-76) 0719C2B0 00000808 0000251F AD000202
[   84.591918] PVR_K:   (MKT-77) 0719C33A 00000808 0000261E AD000183
[   84.598449] PVR_K:   (MKT-78) 0719C426 00000808 0000261E AD00030E
[   84.604949] PVR_K:   (MKT-79) 0719C43E 00000808 0000261E 0D800494
[   84.611389] PVR_K:   (MKT-7A) 0719C458 00000808 0000261E 0000000A
[   84.617858] PVR_K:   (MKT-7B) 0719C47C 00000808 0000261E 0000000B
[   84.624328] PVR_K:   (MKT-7C) 0719C4E6 00000808 0000261E AD000184
[   84.630737] PVR_K:   (MKT-7D) 0719C54A 00000C08 0100271D AD000281
[   84.637176] PVR_K:   (MKT-7E) 0719C6B3 00000808 0100271D AD00080A
[   84.643585] PVR_K:   (MKT-7F) 0719C6CC 00000808 0100271D 0F038A00
[   84.650207] PVR_K:   (MKT-80) 0719C6E4 00000808 0100271D 00000060
[   84.656616] PVR_K:   (MKT-81) 0719C993 00000808 0000271D AD000803
[   84.663177] PVR_K:   (MKT-82) 0719C9D9 00180CC8 0000271D AD000282
[   84.669586] PVR_K:   (MKT-83) 0719CA99 00000808 0100291F AD000200
[   84.676208] PVR_K:   (MKT-84) 0719CCB8 00000808 0000291F AD000202
[   84.682617] PVR_K:   (MKT-85) 0719CD36 00000808 00002A1E AD000183
[   84.689117] PVR_K:   (MKT-86) 0719CE24 00000808 00002A1E AD00030E
[   84.695617] PVR_K:   (MKT-87) 0719CE3C 00000808 00002A1E 0D800494
[   84.702087] PVR_K:   (MKT-88) 0719CE55 00000808 00002A1E 0000000A
[   84.708557] PVR_K:   (MKT-89) 0719CE79 00000808 00002A1E 0000000B
[   84.715057] PVR_K:   (MKT-8A) 0719CEE3 00000808 00002A1E AD000184
[   84.721557] PVR_K:   (MKT-8B) 0719CF48 00000C08 01002B1D AD000281
[   84.728057] PVR_K:   (MKT-8C) 0719D0B8 00000808 01002B1D AD00080A
[   84.734558] PVR_K:   (MKT-8D) 0719D0D0 00000808 01002B1D 0F038D00
[   84.740997] PVR_K:   (MKT-8E) 0719D0E9 00000808 01002B1D 00000060
[   84.747558] PVR_K:   (MKT-8F) 0719D396 00000808 00002B1D AD000803
[   84.753997] PVR_K:   (MKT-90) 0719D3DB 00180CC8 00002B1D AD000282
[   84.760467] PVR_K:   (MKT-91) 0719D4CD 00000808 01002D1F AD000200
[   84.767211] PVR_K:   (MKT-92) 0719D6EC 00000808 00002D1F AD000202
[   84.774169] PVR_K:   (MKT-93) 0719D769 00000808 00002E1E AD000183
[   84.780639] PVR_K:   (MKT-94) 0719D851 00000808 00002E1E AD00030E
[   84.787078] PVR_K:   (MKT-95) 0719D869 00000808 00002E1E 0D800494
[   84.793487] PVR_K:   (MKT-96) 0719D887 00000808 00002E1E 0000000A
[   84.799987] PVR_K:   (MKT-97) 0719D8AF 00000808 00002E1E 0000000B
[   84.806396] PVR_K:   (MKT-98) 0719D91A 00000808 00002E1E AD000184
[   84.812866] PVR_K:   (MKT-99) 0719D97F 00000C08 01002F1D AD000281
[   84.819244] PVR_K:   (MKT-9A) 0719DAF3 00000808 01002F1D AD00080A
[   84.825683] PVR_K:   (MKT-9B) 0719DB0C 00000808 01002F1D 0F039000
[   84.832153] PVR_K:   (MKT-9C) 0719DB24 00000808 01002F1D 00000062
[   84.838562] PVR_K:   (MKT-9D) 0719DDDF 00000808 00002F1D AD000803
[   84.845001] PVR_K:   (MKT-9E) 0719DE24 00180C88 00002F1D AD000282
[   84.851409] PVR_K:   (MKT-9F) 0719E962 00000808 0100311F AD000200
[   84.857849] PVR_K:   (MKT-A0) 0719EA7F 00000808 0100311F AD001703
[   84.864257] PVR_K:   (MKT-A1) 0719EC62 00000808 0000311F AD000202
[   84.870727] PVR_K:   (MKT-A2) 0719ECE1 00000808 0000321E AD000183
[   84.877197] PVR_K:   (MKT-A3) 0719EDCC 00000808 0000321E AD00030E
[   84.883666] PVR_K:   (MKT-A4) 0719EDE4 00000808 0000321E 0D800494
[   84.890045] PVR_K:   (MKT-A5) 0719EDFC 00000808 0000321E 0000000A
[   84.896514] PVR_K:   (MKT-A6) 0719EE20 00000808 0000321E 0000000B
[   84.902923] PVR_K:   (MKT-A7) 0719EE8A 00000808 0000321E AD000184
[   84.909393] PVR_K:   (MKT-A8) 0719EEEE 00000C08 0100331D AD000281
[   84.915802] PVR_K:   (MKT-A9) 0719EFFF 00000808 0100331D AD000E02
[   84.922271] PVR_K:   (MKT-AA) 0719F074 00000808 0100331D AD000282
[   84.928680] PVR_K:   (MKT-AB) 071ABFE4 00000808 0100361F AD001A00
[   84.935119] PVR_K:   (MKT-AC) 071B9A81 00000808 0100391F AD00000A
[   84.941589] PVR_K:   (MKT-AD) 071B9AE1 00000808 0100391F AD000909
[   84.947998] PVR_K:   (MKT-AE) 071B9B2D 00000808 0100391F AD001A05
[   84.954437] PVR_K:   (MKT-AF) 071B9B5E 00000808 0100391F AD001302
[   84.960845] PVR_K:   (MKT-B0) 071B9B9E 00000808 0100391F AD001303
[   84.967285] PVR_K:   (MKT-B1) 071B9C30 00000808 0100391F AD000D04
[   84.973693] PVR_K:   (MKT-B2) 071B9D04 00000808 0100391F AD000D05
[   84.980163] PVR_K:   (MKT-B3) 071B9D5D 00000808 0100391F AD000D04
[   84.986572] PVR_K:   (MKT-B4) 071B9DE1 00000808 0100391F AD000D05
[   84.993011] PVR_K:   (MKT-B5) 071B9E3D 00000808 0100391F AD001A06
[   84.999420] PVR_K:   (MKT-B6) 00000458 00100808 0100031F AD002300
[   85.005859] PVR_K:   (MKT-B7) 00000935 00100808 0100041F AD00000A
[   85.012268] PVR_K:   (MKT-B8) 000009B2 00100808 0100041F AD000906
[   85.018737] PVR_K:   (MKT-B9) 00000A81 00100808 0000041F AD000901
[   85.025146] PVR_K:   (MKT-BA) 00000AFB 00100808 0000051E AD000183
[   85.031616] PVR_K:   (MKT-BB) 00000C6D 00100808 0000051E AD000302
[   85.038085] PVR_K:   (MKT-BC) 00000DEF 00100808 0000051E AD000D06
[   85.046173] PVR_K:   (MKT-BD) 00000ED4 00100808 0000051E AD000D07
[   85.052642] PVR_K:   (MKT-BE) 00000F1F 00100808 0000051E AD001304
[   85.059051] PVR_K:   (MKT-BF) 0000100C 00100808 0000051E AD001305
[   85.065490] PVR_K:   (MKT-C0) 0000111F 00100888 0000051E AD000404
[   85.071899] PVR_K:   (MKT-C1) 000011E4 00100808 0000051E AD000402
[   85.078338] PVR_K:   (MKT-C2) 0000122E 0010082B 0000051E AD000184
[   85.084716] PVR_K:   (MKT-C3) 000012CD 00108DA9 0000061D AD000281
[   85.091156] PVR_K:   (MKT-C4) 00001452 001089AF 0000061D AD000E02
[   85.097564] PVR_K:   (MKT-C5) 000014AF 0010892B 0000061D AD000282
[   85.104583] PVR_K:   (MKT-C6) 00003B2E 00100808 0000081F AD000101
[   85.111083] PVR_K:   (MKT-C7) 00003BA2 00100808 0000081F AD000104
[   85.117645] PVR_K:   (MKT-C8) 00003BDE 00100808 0100091E AD000100
[   85.124053] PVR_K:   (MKT-C9) 00003CE3 00100808 0100091E AD000501
[   85.130554] PVR_K:   (MKT-CA) 00003D21 0010082B 0100091E AD000104
[   85.136993] PVR_K:   (MKT-CB) 00005F9D 00100828 01000A1F AD000101
[   85.143493] PVR_K:   (MKT-CC) 00005FE1 00100828 01000A1F AD000104
[   85.150207] PVR_K:   (MKT-CD) 000060F5 00100808 01000B1F AD000100
[   85.156616] PVR_K:   (MKT-CE) 000061AF 00100808 01000B1F AD000501
[   85.163177] PVR_K:   (MKT-CF) 000061DB 00100829 01000B1F AD000104
[   85.169647] PVR_K:   (MKT-D0) 00008715 00100828 01000D1F AD000101
[   85.176147] PVR_K:   (MKT-D1) 0000878A 00100828 01000D1F AD000104
[   85.182617] PVR_K:   (MKT-D2) 000087C6 00100808 01000E1E AD000100
[   85.189117] PVR_K:   (MKT-D3) 000088C4 00100808 01000E1E AD000501
[   85.195617] PVR_K:   (MKT-D4) 00008903 0010082B 01000E1E AD000104
[   85.202087] PVR_K:   (MKT-D5) 0000A93B 00100828 01000F1F AD000101
[   85.208526] PVR_K:   (MKT-D6) 0000A97F 00100828 01000F1F AD000104
[   85.214996] PVR_K:   (MKT-D7) 0000AB75 00100808 0100101F AD000100
[   85.221405] PVR_K:   (MKT-D8) 0000ABEC 00100808 0100101F AD000502
[   85.227996] PVR_K:   (MKT-D9) 0000AC3F 00100808 0100101F AD000C01
[   85.234497] PVR_K:   (MKT-DA) 0000AC62 00100808 0100101F 0D800484
[   85.240966] PVR_K:   (MKT-DB) 0000AC7A 00100808 0100101F 0000000C
[   85.247558] PVR_K:   (MKT-DC) 0000AF39 00100808 0000101F AD00030E
[   85.253967] PVR_K:   (MKT-DD) 0000AF51 00100808 0000101F 0D800474
[   85.260467] PVR_K:   (MKT-DE) 0000AF6A 00100808 0000101F 0000000B
[   85.266937] PVR_K:   (MKT-DF) 0000AF8C 00100808 0000101F 0000000C
[   85.273437] PVR_K:   (MKT-E0) 0000B024 00100808 0000101F AD000104
[   85.279876] PVR_K:   (MKT-E1) 0000B09A 00100C08 0100111E AD000281
[   85.286376] PVR_K:   (MKT-E2) 0000B212 00100808 0100111E AD00080A
[   85.292877] PVR_K:   (MKT-E3) 0000B22C 00100808 0100111E 0F039300
[   85.299346] PVR_K:   (MKT-E4) 0000B244 00100808 0100111E 00000061
[   85.305847] PVR_K:   (MKT-E5) 0000B3C4 00100808 0000111E AD000802
[   85.312347] PVR_K:   (MKT-E6) 0000B51C 00100808 0000111E AD000803
[   85.318756] PVR_K:   (MKT-E7) 0000B562 00184AC8 0000111E AD000282
[   85.325317] PVR_K:   (MKT-E8) 0000D54A 00000C08 0100141F AD000200
[   85.332580] PVR_K:   (MKT-E9) 0000D79C 00000808 0000141F AD000202
[   85.339050] PVR_K:   (MKT-EA) 0000D826 00000808 0000151E AD000183
[   85.346282] PVR_K:   (MKT-EB) 0000D90F 00000808 0000151E AD00030E
[   85.352844] PVR_K:   (MKT-EC) 0000D927 00000808 0000151E 0D800474
[   85.359344] PVR_K:   (MKT-ED) 0000D940 00000808 0000151E 0000000B
[   85.365722] PVR_K:   (MKT-EE) 0000D964 00000808 0000151E 0000000C
[   85.372161] PVR_K:   (MKT-EF) 0000D9D0 00000808 0000151E AD000184
[   85.378570] PVR_K:   (MKT-F0) 0000DA35 00000C08 0100161D AD000281
[   85.385040] PVR_K:   (MKT-F1) 0000DBA4 00000808 0100161D AD00080A
[   85.391448] PVR_K:   (MKT-F2) 0000DBBC 00000808 0100161D 0F039600
[   85.397918] PVR_K:   (MKT-F3) 0000DBD5 00000808 0100161D 00000060
[   85.404296] PVR_K:   (MKT-F4) 0000DE8C 00000808 0000161D AD000803
[   85.410766] PVR_K:   (MKT-F5) 0000DED1 00180CC8 0000161D AD000282
[   85.417175] PVR_K:   (MKT-F6) 0000DF73 00000808 0100181F AD000200
[   85.423645] PVR_K:   (MKT-F7) 0000E18B 00000808 0000181F AD000202
[   85.430541] PVR_K:   (MKT-F8) 0000E208 00000808 0000191E AD000183
[   85.437011] PVR_K:   (MKT-F9) 0000E2F4 00000808 0000191E AD00030E
[   85.443420] PVR_K:   (MKT-FA) 0000E30C 00000808 0000191E 0D800474
[   85.449859] PVR_K:   (MKT-FB) 0000E325 00000808 0000191E 0000000B
[   85.456298] PVR_K:   (MKT-FC) 0000E348 00000808 0000191E 0000000C
[   85.462707] PVR_K:   (MKT-FD) 0000E3B2 00000808 0000191E AD000184
[   85.469146] PVR_K:   (MKT-FE) 0000E41A 00000C08 01001A1D AD000281
[   85.475738] PVR_K:   (MKT-FF) 0000E587 00000808 01001A1D AD00080A
[   85.482208] PVR_K:   (MKT-100) 0000E5A0 00000808 01001A1D 0F039900
[   85.488861] PVR_K:   (MKT-101) 0000E5B8 00000808 01001A1D 00000060
[   85.495391] PVR_K:   (MKT-102) 0000E86D 00000808 00001A1D AD000803
[   85.501892] PVR_K:   (MKT-103) 0000E8B3 00180CC8 00001A1D AD000282
[   85.508483] PVR_K:   (MKT-104) 0000E99D 00000808 01001C1F AD000200
[   85.515045] PVR_K:   (MKT-105) 0000EBB8 00000808 00001C1F AD000202
[   85.521606] PVR_K:   (MKT-106) 0000EC38 00000808 00001D1E AD000183
[   85.528198] PVR_K:   (MKT-107) 0000ED23 00000808 00001D1E AD00030E
[   85.534790] PVR_K:   (MKT-108) 0000ED3B 00000808 00001D1E 0D800474
[   85.541381] PVR_K:   (MKT-109) 0000ED54 00000808 00001D1E 0000000B
[   85.547912] PVR_K:   (MKT-10A) 0000ED78 00000808 00001D1E 0000000C
[   85.554504] PVR_K:   (MKT-10B) 0000EDE2 00000808 00001D1E AD000184
[   85.561065] PVR_K:   (MKT-10C) 0000EE46 00000C08 01001E1D AD000281
[   85.567718] PVR_K:   (MKT-10D) 0000EFAD 00000808 01001E1D AD00080A
[   85.574249] PVR_K:   (MKT-10E) 0000EFC6 00000808 01001E1D 0F039C00
[   85.580871] PVR_K:   (MKT-10F) 0000EFDE 00000808 01001E1D 00000062
[   85.587402] PVR_K:   (MKT-110) 0000F293 00000808 00001E1D AD000803
[   85.594024] PVR_K:   (MKT-111) 0000F2D9 00180C88 00001E1D AD000282
[   85.600585] PVR_K:   (MKT-112) 0000FDB6 00000808 0100201F AD000200
[   85.607147] PVR_K:   (MKT-113) 0000FED3 001FFFFF 0100201F AD001703
[   85.613800] PVR_K:   (MKT-114) 000100A6 00000808 0000201F AD000202
[   85.620330] PVR_K:   (MKT-115) 00010123 00000808 0100211E AD000183
[   85.626892] PVR_K:   (MKT-116) 0001020C 00000808 0100211E AD00030E
[   85.633422] PVR_K:   (MKT-117) 00010224 00000808 0100211E 0D800474
[   85.640045] PVR_K:   (MKT-118) 0001023D 00000808 0100211E 0000000B
[   85.646545] PVR_K:   (MKT-119) 00010260 00000808 0100211E 0000000C
[   85.653167] PVR_K:   (MKT-11A) 000102EC 00000808 0100211E AD000184
[   85.659698] PVR_K:   (MKT-11B) 0001D923 00000808 0100241F AD001A00
[   85.666320] PVR_K:   (MKT-11C) 0006D023 00000808 0100321F AD00000A
[   85.672851] PVR_K:   (MKT-11D) 0006D08C 00000808 0100321F AD000909
[   85.679473] PVR_K:   (MKT-11E) 0006D0D5 00000808 0100321F AD001A05
[   85.685974] PVR_K:   (MKT-11F) 0006D104 00000808 0100321F AD001302
[   85.692626] PVR_K:   (MKT-120) 0006D144 00000808 0100321F AD001303
[   85.699157] PVR_K:   (MKT-121) 0006D1DB 00000808 0100321F AD000D04
[   85.706024] PVR_K:   (MKT-122) 0006D2A3 00000808 0100321F AD000D05
[   85.713134] PVR_K:   (MKT-123) 0006D311 00000808 0100321F AD001A06
[   85.719848] PVR_K:   (MKT-124) 000004A3 00100808 0100031F AD002300
[   85.726470] PVR_K:   (MKT-125) 00000977 00100808 0100041F AD00000A
[   85.732971] PVR_K:   (MKT-126) 000009F2 00100808 0100041F AD000906
[   85.739501] PVR_K:   (MKT-127) 00000AC5 00100808 0000041F AD000901
[   85.746032] PVR_K:   (MKT-128) 00000B3F 00100808 0100051E AD000183
[   85.752563] PVR_K:   (MKT-129) 00000CB3 00100808 0100051E AD000302
[   85.759063] PVR_K:   (MKT-12A) 00000E32 00100808 0100051E AD000D06
[   85.765594] PVR_K:   (MKT-12B) 00000F15 00100808 0100051E AD000D07
[   85.772094] PVR_K:   (MKT-12C) 00000F5F 00100808 0100051E AD001304
[   85.778656] PVR_K:   (MKT-12D) 0000104A 00100808 0100051E AD001305
[   85.785156] PVR_K:   (MKT-12E) 00001159 00100888 0100051E AD000404
[   85.791717] PVR_K:   (MKT-12F) 0000121A 00100808 0000051E AD000402
[   85.798248] PVR_K:   (MKT-130) 00001262 0010082B 0000051E AD000184
[   85.804748] PVR_K:   (MKT-131) 072587F9 00100808 0100031F AD000B00
[   85.811279] PVR_K:   (MKT-132) 07258833 00100808 0100031F AD000B02
[   85.817810] PVR_K:   (MKT-133) 072588B7 00100808 0100031F AD000B02
[   85.824371] PVR_K:   (MKT-134) 072588F6 00100808 0100031F AD000B02
[   85.830871] PVR_K:   (MKT-135) 07258935 00100808 0100031F AD000B02
[   85.837432] PVR_K:   (MKT-136) 07258974 00100808 0100031F AD000B03
[   85.843902] PVR_K:   (MKT-137) 072589F3 00100808 0100031F AD000B05
[   85.850463] PVR_K:   (MKT-138) 07258A47 00100808 0100031F AD000B06
[   85.856964] PVR_K:   (MKT-139) 07258A76 00100808 0100031F AD000B06
[   85.863494] PVR_K:   (MKT-13A) 07258ABD 00100808 0100031F AD000B07
[   85.869995] PVR_K:   (MKT-13B) 07258AE2 00100808 0100031F AD000B09
[   85.876556] PVR_K:   (MKT-13C) 07258B38 00100808 0100031F AD000B01
[   85.884277] PVR_K:   (MKT-13D) 07258B74 00100808 0100031F AD002300
[   85.890777] PVR_K:   (MKT-13E) 07258D5C 00100808 0100041F AD00000A
[   85.897338] PVR_K:   (MKT-13F) 07258DD0 00100808 0100041F AD000906
[   85.903808] PVR_K:   (MKT-140) 07258E8F 00100808 0000041F AD000901
[   85.910339] PVR_K:   (MKT-141) 07258F0B 00100808 0000051E AD000183
[   85.916839] PVR_K:   (MKT-142) 07259077 00100808 0000051E AD000302
[   85.923400] PVR_K:   (MKT-143) 072590CA 00100808 0000051E AD000303
[   85.929870] PVR_K:   (MKT-144) 07259157 00100808 0000051E AD000C01
[   85.936401] PVR_K:   (MKT-145) 0725917C 00100808 0000051E 0D800464
[   85.943267] PVR_K:   (MKT-146) 07259194 00100808 0000051E 0000000D
[   85.949951] PVR_K:   (MKT-147) 072593EA 00100808 0000051E AD00030E
[   85.956420] PVR_K:   (MKT-148) 07259402 00100808 0000051E 0D800494
[   85.963317] PVR_K:   (MKT-149) 0725941B 00100808 0000051E 0000000B
[   85.969940] PVR_K:   (MKT-14A) 07259440 00100808 0000051E 0000000C
[   85.976501] PVR_K:   (MKT-14B) 072594B9 00100808 0000051E AD000184
[   85.983276] PVR_K:   (MKT-14C) 07259538 00100C08 0100061D AD000281
[   85.989746] PVR_K:   (MKT-14D) 072596D8 00100808 0100061D AD00080A
[   85.996398] PVR_K:   (MKT-14E) 072596F0 00100808 0100061D 0F039F00
[   86.002960] PVR_K:   (MKT-14F) 07259708 00100808 0100061D 00000061
[   86.009552] PVR_K:   (MKT-150) 07259825 00100C88 0100061D AD001300
[   86.016113] PVR_K:   (MKT-151) 0725EC2E 00100808 0000061D AD001301
[   86.022705] PVR_K:   (MKT-152) 0725ED61 00100888 0000061D AD000802
[   86.029357] PVR_K:   (MKT-153) 0725EED1 00100888 0000061D AD000803
[   86.036041] PVR_K:   (MKT-154) 0725EF20 001808C8 0000061D AD000282
[   86.042877] PVR_K:   (MKT-155) 0725F002 00184EF8 0000081E AD00000A
[   86.049560] PVR_K:   (MKT-156) 0725F089 00184AF8 0000081E AD000905
[   86.056243] PVR_K:   (MKT-157) 0725F1A5 001808B8 0000081E AD000901
[   86.062835] PVR_K:   (MKT-158) 0725F21A 00180838 0000091C AD00000A
[   86.069519] PVR_K:   (MKT-159) 0725F28E 00180838 0000091C AD000906
[   86.076080] PVR_K:   (MKT-15A) 0725F303 00180838 0000091C AD000901
[   86.082672] PVR_K:   (MKT-15B) 0725F35D 00180838 00000A1B AD00000A
[   86.089263] PVR_K:   (MKT-15C) 0725F3C0 00180838 00000A1B AD000905
[   86.095916] PVR_K:   (MKT-15D) 0725F468 00180838 00000A1B AD000901
[   86.102478] PVR_K:   (MKT-15E) 0725F4C6 00180838 00000B1A AD00000A
[   86.109130] PVR_K:   (MKT-15F) 0725F52C 00180838 00000B1A AD000905
[   86.115631] PVR_K:   (MKT-160) 0725F5D4 00180838 00000B1A AD000901
[   86.122222] PVR_K:   (MKT-161) 0725F626 00180838 00000C19 AD00000A
[   86.128784] PVR_K:   (MKT-162) 0725F68E 00180838 00000C19 AD000905
[   86.135375] PVR_K:   (MKT-163) 0725F736 00180838 00000C19 AD000901
[   86.141998] PVR_K:   (MKT-164) 0725F886 00180838 00000F1F AD000183
[   86.148529] PVR_K:   (MKT-165) 0725F9FE 00180838 00000F1F AD000302
[   86.155120] PVR_K:   (MKT-166) 0725FA71 00180838 00000F1F AD000303
[   86.161651] PVR_K:   (MKT-167) 0725FAF6 00180838 00000F1F AD000C01
[   86.168243] PVR_K:   (MKT-168) 0725FB1A 00180838 00000F1F 0D800484
[   86.174774] PVR_K:   (MKT-169) 0725FB34 00180838 00000F1F 0000000D
[   86.181427] PVR_K:   (MKT-16A) 0725FD4C 00180838 00000F1F AD000184
[   86.187957] PVR_K:   (MKT-16B) 0725FDBE 00180C38 0100101D AD000281
[   86.194824] PVR_K:   (MKT-16C) 0725FE1B 00180838 0100101D AD000282
[   86.202087] PVR_K:   (MKT-16D) 07260AAF 00180838 0100111F AD00000A
[   86.208923] PVR_K:   (MKT-16E) 07260B1C 00180838 0100111F AD000905
[   86.215698] PVR_K:   (MKT-16F) 07260C25 00180838 0000111F AD000901
[   86.222686] PVR_K:   (MKT-170) 07260C78 00180C38 0100121E AD000281
[   86.229309] PVR_K:   (MKT-171) 07260CD2 00180838 0100121E AD000282
[   86.235809] PVR_K:   (MKT-172) 07260DD9 00180838 0100131F AD00000A
[   86.242340] PVR_K:   (MKT-173) 07260E45 00180838 0100131F AD000905
[   86.248840] PVR_K:   (MKT-174) 07260F42 00180838 0000131F AD000901
[   86.255371] PVR_K:   (MKT-175) 07260F92 00100C28 0100141E AD000281
[   86.261871] PVR_K:   (MKT-176) 07260FEC 00100828 0100141E AD000282
[   86.268432] PVR_K:   (MKT-177) 072610BD 00000808 0100151F AD000200
[   86.274932] PVR_K:   (MKT-178) 07261313 00000808 0000151F AD000202
[   86.281463] PVR_K:   (MKT-179) 072613BB 00000808 0000161E AD00000A
[   86.287963] PVR_K:   (MKT-17A) 07261423 00000808 0000161E AD000905
[   86.294494] PVR_K:   (MKT-17B) 07261515 00000808 0000161E AD000901
[   86.300994] PVR_K:   (MKT-17C) 07261567 00000C08 0000171D AD000281
[   86.307525] PVR_K:   (MKT-17D) 072616CF 00000808 0000171D AD00080A
[   86.314056] PVR_K:   (MKT-17E) 072616E7 00000808 0000171D 0F03A200
[   86.320587] PVR_K:   (MKT-17F) 07261700 00000808 0000171D 00000060
[   86.327148] PVR_K:   (MKT-180) 072619B9 00000808 0000171D AD000803
[   86.333618] PVR_K:   (MKT-181) 072619FF 00180CC8 0000171D AD000282
[   86.340179] PVR_K:   (MKT-182) 07261AAE 00000808 0000181F AD00000A
[   86.346679] PVR_K:   (MKT-183) 07261B19 00000808 0000181F AD000905
[   86.353210] PVR_K:   (MKT-184) 07261C0B 00000888 0000181F AD000901
[   86.359710] PVR_K:   (MKT-185) 07261C53 00000C08 00001A1D AD000200
[   86.366271] PVR_K:   (MKT-186) 07261E89 00000808 00001A1D AD000202
[   86.372741] PVR_K:   (MKT-187) 07261EE0 00000808 01001B1C AD000281
[   86.379302] PVR_K:   (MKT-188) 07262026 00000808 01001B1C AD00080A
[   86.385803] PVR_K:   (MKT-189) 0726203F 00000808 01001B1C 0F03A500
[   86.392303] PVR_K:   (MKT-18A) 07262057 00000808 01001B1C 00000060
[   86.398834] PVR_K:   (MKT-18B) 0726230D 00000808 00001B1C AD000803
[   86.405334] PVR_K:   (MKT-18C) 07262353 00180CC8 00001B1C AD000282
[   86.411865] PVR_K:   (MKT-18D) 07262437 00000808 01001D1F AD000200
[   86.418365] PVR_K:   (MKT-18E) 0726265D 00000808 01001D1F AD000202
[   86.424896] PVR_K:   (MKT-18F) 072626AA 00000808 01001E1E AD000281
[   86.431427] PVR_K:   (MKT-190) 072627F5 00000808 01001E1E AD00080A
[   86.437957] PVR_K:   (MKT-191) 0726280E 00000808 01001E1E 0F03A800
[   86.444458] PVR_K:   (MKT-192) 07262826 00000808 01001E1E 00000062
[   86.450988] PVR_K:   (MKT-193) 07262AD8 00000808 00001E1E AD000803
[   86.457519] PVR_K:   (MKT-194) 07262B1E 00180C88 00001E1E AD000282
[   86.464050] PVR_K:   (MKT-195) 0726363A 00000808 0100201F AD000200
[   86.470611] PVR_K:   (MKT-196) 07263754 00000808 0100201F AD001703
[   86.477111] PVR_K:   (MKT-197) 07263957 00000808 0000201F AD000202
[   86.483642] PVR_K:   (MKT-198) 072639D3 00000808 0000211E AD000183
[   86.490142] PVR_K:   (MKT-199) 07263ABA 00000808 0000211E AD00030E
[   86.496704] PVR_K:   (MKT-19A) 07263AD3 00000808 0000211E 0D800474
[   86.503204] PVR_K:   (MKT-19B) 07263AEC 00000808 0000211E 0000000C
[   86.509735] PVR_K:   (MKT-19C) 07263B14 00000808 0000211E 0000000D
[   86.516235] PVR_K:   (MKT-19D) 07263B7E 00000808 0000211E AD000184
[   86.522796] PVR_K:   (MKT-19E) 07263BE2 00000C08 0100221D AD000281
[   86.529266] PVR_K:   (MKT-19F) 07263D56 00000808 0100221D AD00080A
[   86.535827] PVR_K:   (MKT-1A0) 07263D6F 00000808 0100221D 0F03AB00
[   86.542327] PVR_K:   (MKT-1A1) 07263D87 00000808 0100221D 00000061
[   86.548889] PVR_K:   (MKT-1A2) 07263EFA 00000808 0000221D AD000802
[   86.555419] PVR_K:   (MKT-1A3) 0726404A 00000808 0000221D AD000803
[   86.561920] PVR_K:   (MKT-1A4) 0726408F 00184EC8 0000221D AD000282
[   86.568450] PVR_K:   (MKT-1A5) 07265FE9 00000C08 0100251F AD000200
[   86.574981] PVR_K:   (MKT-1A6) 07266232 00000808 0000251F AD000202
[   86.581542] PVR_K:   (MKT-1A7) 072662BA 00000808 0000261E AD000183
[   86.588043] PVR_K:   (MKT-1A8) 072663A3 00000808 0000261E AD00030E
[   86.594573] PVR_K:   (MKT-1A9) 072663BC 00000808 0000261E 0D800474
[   86.601074] PVR_K:   (MKT-1AA) 072663D4 00000808 0000261E 0000000C
[   86.607604] PVR_K:   (MKT-1AB) 072663F8 00000808 0000261E 0000000D
[   86.614105] PVR_K:   (MKT-1AC) 07266461 00000808 0000261E AD000184
[   86.620666] PVR_K:   (MKT-1AD) 072664C6 00000C08 0100271D AD000281
[   86.627166] PVR_K:   (MKT-1AE) 0726662D 00000808 0100271D AD00080A
[   86.633697] PVR_K:   (MKT-1AF) 07266646 00000808 0100271D 0F03AE00
[   86.640258] PVR_K:   (MKT-1B0) 0726665E 00000808 0100271D 00000060
[   86.646759] PVR_K:   (MKT-1B1) 07266918 00000808 0000271D AD000803
[   86.653320] PVR_K:   (MKT-1B2) 07266966 00180CC8 0000271D AD000282
[   86.659820] PVR_K:   (MKT-1B3) 07266A05 00000808 0100291F AD000200
[   86.666381] PVR_K:   (MKT-1B4) 07266C20 00000808 0000291F AD000202
[   86.672912] PVR_K:   (MKT-1B5) 07266CA1 00000808 00002A1E AD000183
[   86.681121] PVR_K:   (MKT-1B6) 07266D8E 00000808 00002A1E AD00030E
[   86.687622] PVR_K:   (MKT-1B7) 07266DA6 00000808 00002A1E 0D800474
[   86.694183] PVR_K:   (MKT-1B8) 07266DBF 00000808 00002A1E 0000000C
[   86.700653] PVR_K:   (MKT-1B9) 07266DE5 00000808 00002A1E 0000000D
[   86.707214] PVR_K:   (MKT-1BA) 07266E50 00000808 00002A1E AD000184
[   86.713684] PVR_K:   (MKT-1BB) 07266EB7 00000C08 01002B1D AD000281
[   86.720245] PVR_K:   (MKT-1BC) 0726701F 00000808 01002B1D AD00080A
[   86.726776] PVR_K:   (MKT-1BD) 07267038 00000808 01002B1D 0F03B100
[   86.733276] PVR_K:   (MKT-1BE) 07267050 00000808 01002B1D 00000060
[   86.739807] PVR_K:   (MKT-1BF) 07267303 00000808 00002B1D AD000803
[   86.746307] PVR_K:   (MKT-1C0) 0726734D 00188CC8 00002B1D AD000282
[   86.752838] PVR_K:   (MKT-1C1) 07267436 00000808 01002D1F AD000200
[   86.759338] PVR_K:   (MKT-1C2) 0726764F 00000808 00002D1F AD000202
[   86.765869] PVR_K:   (MKT-1C3) 072676CF 00000808 00002E1E AD000183
[   86.772369] PVR_K:   (MKT-1C4) 072677B8 00000808 00002E1E AD00030E
[   86.778869] PVR_K:   (MKT-1C5) 072677D0 00000808 00002E1E 0D800474
[   86.785369] PVR_K:   (MKT-1C6) 072677E8 00000808 00002E1E 0000000C
[   86.791931] PVR_K:   (MKT-1C7) 0726780B 00000808 00002E1E 0000000D
[   86.798431] PVR_K:   (MKT-1C8) 07267876 00000808 00002E1E AD000184
[   86.804962] PVR_K:   (MKT-1C9) 072678DA 00000C08 01002F1D AD000281
[   86.811523] PVR_K:   (MKT-1CA) 07267A44 00000808 01002F1D AD00080A
[   86.817993] PVR_K:   (MKT-1CB) 07267A5D 00000808 01002F1D 0F03B400
[   86.824554] PVR_K:   (MKT-1CC) 07267A75 00000808 01002F1D 00000062
[   86.831054] PVR_K:   (MKT-1CD) 07267D25 00000808 00002F1D AD000803
[   86.837615] PVR_K:   (MKT-1CE) 07267D6C 00180C88 00002F1D AD000282
[   86.844085] PVR_K:   (MKT-1CF) 0726885F 00000808 0100311F AD000200
[   86.850646] PVR_K:   (MKT-1D0) 0726897B 00000808 0100311F AD001703
[   86.857116] PVR_K:   (MKT-1D1) 07268B65 00000808 0000311F AD000202
[   86.863647] PVR_K:   (MKT-1D2) 07268BE2 00000808 0000321E AD000183
[   86.870147] PVR_K:   (MKT-1D3) 07268CCC 00000808 0000321E AD00030E
[   86.876678] PVR_K:   (MKT-1D4) 07268CE4 00000808 0000321E 0D800474
[   86.883178] PVR_K:   (MKT-1D5) 07268CFD 00000808 0000321E 0000000C
[   86.889739] PVR_K:   (MKT-1D6) 07268D20 00000808 0000321E 0000000D
[   86.896270] PVR_K:   (MKT-1D7) 07268D8C 00000808 0000321E AD000184
[   86.902770] PVR_K:   (MKT-1D8) 07268DF0 00000C08 0100331D AD000281
[   86.909301] PVR_K:   (MKT-1D9) 07268F00 00000808 0100331D AD000E02
[   86.915771] PVR_K:   (MKT-1DA) 07268F75 00000808 0100331D AD000282
[   86.922332] PVR_K:   (MKT-1DB) 07276062 00000808 0100361F AD001A00
[   86.928833] PVR_K:   (MKT-1DC) 0728391E 00000808 0100391F AD00000A
[   86.935333] PVR_K:   (MKT-1DD) 07283980 00000808 0100391F AD000909
[   86.941833] PVR_K:   (MKT-1DE) 072839CE 00000808 0100391F AD001A05
[   86.948364] PVR_K:   (MKT-1DF) 07283A02 00000808 0100391F AD001302
[   86.954864] PVR_K:   (MKT-1E0) 07283A45 00000808 0100391F AD001303
[   86.961395] PVR_K:   (MKT-1E1) 07283AD6 00000808 0100391F AD000D04
[   86.967895] PVR_K:   (MKT-1E2) 07283BA9 00000808 0100391F AD000D05
[   86.974426] PVR_K:   (MKT-1E3) 07283C04 00000808 0100391F AD000D04
[   86.980957] PVR_K:   (MKT-1E4) 07283C8C 00000808 0100391F AD000D05
[   86.987426] PVR_K:   (MKT-1E5) 07283CE9 00000808 0100391F AD001A06
[   86.993988] PVR_K:   (MKT-1E6) 0000047B 00100808 0100031F AD002300
[   87.000488] PVR_K:   (MKT-1E7) 00000952 00100808 0100041F AD00000A
[   87.007019] PVR_K:   (MKT-1E8) 000009CF 00100808 0100041F AD000906
[   87.013488] PVR_K:   (MKT-1E9) 00000AA2 00100808 0000041F AD000901
[   87.020019] PVR_K:   (MKT-1EA) 00000B1D 00100808 0000051E AD000183
[   87.026519] PVR_K:   (MKT-1EB) 00000C92 00100808 0000051E AD000302
[   87.033050] PVR_K:   (MKT-1EC) 00000E14 00100808 0000051E AD000D06
[   87.039550] PVR_K:   (MKT-1ED) 00000EF9 00100808 0000051E AD000D07
[   87.046081] PVR_K:   (MKT-1EE) 00000F43 00100808 0000051E AD001304
[   87.052581] PVR_K:   (MKT-1EF) 00001032 00100808 0000051E AD001305
[   87.059112] PVR_K:   (MKT-1F0) 00001146 00100888 0000051E AD000404
[   87.065643] PVR_K:   (MKT-1F1) 0000120B 00100808 0000051E AD000402
[   87.072143] PVR_K:   (MKT-1F2) 00001254 0010082B 0000051E AD000184
[   87.078674] PVR_K:   (MKT-1F3) 000012F6 00108DA9 0000061D AD000281
[   87.085174] PVR_K:   (MKT-1F4) 00001484 001009AF 0000061D AD000E02
[   87.091705] PVR_K:   (MKT-1F5) 000014E5 001008AF 0000061D AD000282
[   87.098205] PVR_K:   (MKT-1F6) 00003A86 00100808 0000081F AD000101
[   87.104736] PVR_K:   (MKT-1F7) 00003AFD 00100808 0000081F AD000104
[   87.111236] PVR_K:   (MKT-1F8) 00003B39 00100808 0100091E AD000100
[   87.117767] PVR_K:   (MKT-1F9) 00003C2D 00100808 0100091E AD000501
[   87.124267] PVR_K:   (MKT-1FA) 00003C6F 0010082B 0100091E AD000104
[   87.130828] PVR_K:   (MKT-1FB) 00005EE6 00100828 01000A1F AD000101
[   87.137298] PVR_K:   (MKT-1FC) 00005F2B 00100828 01000A1F AD000104
[   87.143859] PVR_K:   (MKT-1FD) 00006045 00100808 01000B1F AD000100
[   87.150390] PVR_K:   (MKT-1FE) 00006101 00100808 01000B1F AD000501
[   87.156860] PVR_K:   (MKT-1FF) 0000612D 00100829 01000B1F AD000104
[   87.163391] PVR_K: SGX Kernel CCB WO:0xAE RO:0xAE
[   87.170501] adc_to_temp_conversion:Temp read is invalid 0
[   87.176483] thermal_lookup_temp: getting temp is not supported for domain pcb
[   87.185211] adc_to_temp_conversion:Temp read is invalid 0
[   87.191101] thermal_lookup_temp: getting temp is not supported for domain pcb
[   87.200378] adc_to_temp_conversion:Temp read is invalid 0
[   87.206298] thermal_lookup_temp: getting temp is not supported for domain pcb
[   87.366149] PVR_K:(Error): SGXOSTimer() detected SGX lockup (0xe tasks) [0, ]
[   87.374053] PVR_K: HWRecoveryResetSGX: SGX Hardware Recovery triggered
[   87.382873] [   61.371]                         [c6f11400] dsscomp_apply
[   87.382904] [   61.383]                          [c6f10800] dsscomp_mgr_delayed_cb on DISPLAYED
[   87.382904] [   61.383]   [c6edbbc0] --refs=0 on RELEASED
[   87.382904] [   61.383]   [c6edbbc0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   87.415924] [   61.383]                          [c6f10800] dsscomp_mgr_delayed_cb on RELEASED
[   87.415954] [   61.383]                         [c6f11400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   87.415954] [   61.400]                         [c6f11400] dsscomp_mgr_delayed_cb on DISPLAYED
[   87.415954] [   66.356]     [c6fa4320] new in dsscomp_gralloc_queue (refs=1)
[   87.446014] [   66.356]                          [c6e66c00] dsscomp_new
[   87.446044] [   66.356]     [c6fa4320] ++refs=2 for [c6e66c00]
[   87.446044] [   66.356]                          [c6e66c00] dsscomp_delayed_apply
[   87.446044] [   66.356]     [c6fa4320] --refs=1 on RELEASED
[   87.476226] [   66.356]                          [c6e66c00] dsscomp_apply
[   87.476226] [   66.356]    [c6edbc00] --refs=0 on RELEASED
[   87.476226] [   66.356]    [c6edbc00] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   87.476226] [   66.356]                         [c6f11400] dsscomp_mgr_delayed_cb on RELEASED
[   87.506103] [   66.356]                          [c6e66c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   87.506103] [   66.357]  [c6edbb80] new in dsscomp_gralloc_queue (refs=1)
[   87.506103] [   66.357]                          [c6f10800] dsscomp_new
[   87.506103] [   66.357]  [c6edbb80] ++refs=2 for [c6f10800]
[   87.535949] [   66.357]                          [c6f10800] dsscomp_delayed_apply
[   87.535949] [   66.357]  [c6edbb80] --refs=1 on RELEASED
[   87.535949] [   66.357]                          [c6f10800] dsscomp_apply
[   87.535949] [   66.375]                          [c6e66c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   87.565734] [   66.375]     [c6fa4320] --refs=0 on RELEASED
[   87.565734] [   66.375]     [c6fa4320] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   87.565734] [   66.376]                          [c6e66c00] dsscomp_mgr_delayed_cb on RELEASED
[   87.565765] [   66.376]                          [c6f10800] dsscomp_mgr_delayed_cb on PROGRAMMED
[   87.595611] [   66.393]                          [c6f10800] dsscomp_mgr_delayed_cb on DISPLAYED
[   87.595611] [   72.154]  [c6fa4420] new in dsscomp_gralloc_queue (refs=1)
[   87.595642] [   72.154]                           [c6e66000] dsscomp_new
[   87.623870] [   72.154]  [c6fa4420] ++refs=2 for [c6e66000]
[   87.623870] [   72.154]                           [c6e66000] dsscomp_delayed_apply
[   87.623870] [   72.154]  [c6fa4420] --refs=1 on RELEASED
[   87.623870] [   72.154]                           [c6e66000] dsscomp_apply
[   87.654113] [   72.154]  [c6edbb80] --refs=0 on RELEASED
[   87.654113] [   72.154]  [c6edbb80] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   87.654113] [   72.154]                          [c6f10800] dsscomp_mgr_delayed_cb on RELEASED
[   87.654144] [   72.154]                           [c6e66000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   87.684020] [   72.155]       [c6edbcc0] new in dsscomp_gralloc_queue (refs=1)
[   87.684020] [   72.155]                       [c6f12c00] dsscomp_new
[   87.684020] [   72.155]       [c6edbcc0] ++refs=2 for [c6f12c00]
[   87.684051] [   72.155]                       [c6f12c00] dsscomp_delayed_apply
[   87.713928] [   72.155]       [c6edbcc0] --refs=1 on RELEASED
[   87.713928] [   72.155]                       [c6f12c00] dsscomp_apply
[   87.713928] [   72.176]                           [c6e66000] dsscomp_mgr_delayed_cb on DISPLAYED
[   87.713928] [   72.176]  [c6fa4420] --refs=0 on RELEASED
[   87.713928] [   72.176]  [c6fa4420] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   87.745239] [   72.176]                           [c6e66000] dsscomp_mgr_delayed_cb on RELEASED
[   87.745269] [   72.176]                       [c6f12c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   87.745269] [   72.191]                       [c6f12c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   87.773559] [   77.137]    [c6fa43c0] new in dsscomp_gralloc_queue (refs=1)
[   87.773559] [   77.137]                           [c6e67c00] dsscomp_new
[   87.773590] [   77.137]    [c6fa43c0] ++refs=2 for [c6e67c00]
[   87.773590] [   77.137]                           [c6e67c00] dsscomp_delayed_apply
[   87.803375] [   77.137]    [c6fa43c0] --refs=1 on RELEASED
[   87.803375] [   77.137]                           [c6e67c00] dsscomp_apply
[   87.803375] [   77.138]       [c6edbcc0] --refs=0 on RELEASED
[   87.803375] [   77.138]       [c6edbcc0] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   87.833312] [   77.138]                       [c6f12c00] dsscomp_mgr_delayed_cb on RELEASED
[   87.833343] [   77.138]                           [c6e67c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   87.833343] [   77.138]    [c6edbc00] new in dsscomp_gralloc_queue (refs=1)
[   87.861663] [   77.138]                         [c6f11400] dsscomp_new
[   87.861663] [   77.138]    [c6edbc00] ++refs=2 for [c6f11400]
[   87.861663] [   77.138]                         [c6f11400] dsscomp_delayed_apply
[   87.861663] [   77.138]    [c6edbc00] --refs=1 on RELEASED
[   87.861663] [   77.138]                         [c6f11400] dsscomp_apply
[   87.893066] [   77.152]                           [c6e67c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   87.893066] [   77.152]    [c6fa43c0] --refs=0 on RELEASED
[   87.893066] [   77.152]    [c6fa43c0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   87.893066] [   77.152]                           [c6e67c00] dsscomp_mgr_delayed_cb on RELEASED
[   87.922912] [   77.152]                         [c6f11400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   87.922943] [   77.154]    [c6fa44a0] new in dsscomp_gralloc_queue (refs=1)
[   87.922943] [   77.154]                           [c6e67c00] dsscomp_new
[   87.951202] [   77.154]    [c6fa44a0] ++refs=2 for [c6e67c00]
[   87.951232] [   77.154]                           [c6e67c00] dsscomp_delayed_apply
[   87.951232] [   77.154]    [c6fa44a0] --refs=1 on RELEASED
[   87.951232] [   77.154]                           [c6e67c00] dsscomp_apply
[   87.951232] [   77.171]                         [c6f11400] dsscomp_mgr_delayed_cb on DISPLAYED
[   87.982574] [   77.171]    [c6edbc00] --refs=0 on RELEASED
[   87.982574] [   77.171]    [c6edbc00] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   87.982604] [   77.171]                         [c6f11400] dsscomp_mgr_delayed_cb on RELEASED
[   88.010833] [   77.171]                           [c6e67c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   88.010833] [   77.186]                           [c6e67c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   88.010833] [   82.167]   [c6fa4460] new in dsscomp_gralloc_queue (refs=1)
[   88.010833] [   82.167]                           [c6e66000] dsscomp_new
[   88.040710] [   82.167]   [c6fa4460] ++refs=2 for [c6e66000]
[   88.040710] [   82.167]                           [c6e66000] dsscomp_delayed_apply
[   88.040710] [   82.167]   [c6fa4460] --refs=1 on RELEASED
[   88.040710] [   82.167]                           [c6e66000] dsscomp_apply
[   88.070526] [   82.167]    [c6fa44a0] --refs=0 on RELEASED
[   88.070526] [   82.167]    [c6fa44a0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   88.070526] [   82.167]                           [c6e67c00] dsscomp_mgr_delayed_cb on RELEASED
[   88.070526] [   82.167]                           [c6e66000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   88.100402] [   82.168]   [c6edbca0] new in dsscomp_gralloc_queue (refs=1)
[   88.100402] [   82.168]                          [c6f10800] dsscomp_new
[   88.100402] [   82.168]   [c6edbca0] ++refs=2 for [c6f10800]
[   88.100402] [   82.168]                          [c6f10800] dsscomp_delayed_apply
[   88.130218] [   82.168]   [c6edbca0] --refs=1 on RELEASED
[   88.130218] [   82.168]                          [c6f10800] dsscomp_apply
[   88.130218] [   82.183]                           [c6e66000] dsscomp_mgr_delayed_cb on DISPLAYED
[   88.130249] [   82.183]   [c6fa4460] --refs=0 on RELEASED
[   88.160064] [   82.183]   [c6fa4460] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   88.160064] [   82.183]                           [c6e66000] dsscomp_mgr_delayed_cb on RELEASED
[   88.160095] [   82.183]                          [c6f10800] dsscomp_mgr_delayed_cb on PROGRAMMED
[   88.188323] [   82.204]                          [c6f10800] dsscomp_mgr_delayed_cb on DISPLAYED
[   88.188323] [   87.162]    [c6edbdc0] new in dsscomp_gralloc_queue (refs=1)
[   88.188323] [   87.162]                       [c6f12c00] dsscomp_new
[   88.188323] [   87.162]    [c6edbdc0] ++refs=2 for [c6f12c00]
[   88.218078] [   87.162]                       [c6f12c00] dsscomp_delayed_apply
[   88.218078] [   87.162]    [c6edbdc0] --refs=1 on RELEASED
[   88.218078] [   87.162]                       [c6f12c00] dsscomp_apply
[   88.218078] [   87.162]   [c6edbca0] --refs=0 on RELEASED
[   88.218078] [   87.162]   [c6edbca0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   88.249572] [   87.162]                          [c6f10800] dsscomp_mgr_delayed_cb on RELEASED
[   88.249572] [   87.162]                       [c6f12c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   88.249572] [   87.163]    [c6edbce0] new in dsscomp_gralloc_queue (refs=1)
[   88.277984] [   87.163]                           [c6f13400] dsscomp_new
[   88.277984] [   87.163]    [c6edbce0] ++refs=2 for [c6f13400]
[   88.277984] [   87.163]                           [c6f13400] dsscomp_delayed_apply
[   88.278015] [   87.163]    [c6edbce0] --refs=1 on RELEASED
[   88.278015] [   87.163]                           [c6f13400] dsscomp_apply
[   88.309387] [   87.177]                       [c6f12c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   88.309417] [   87.177]    [c6edbdc0] --refs=0 on RELEASED
[   88.309417] [   87.177]    [c6edbdc0] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   88.309417] [   87.178]                       [c6f12c00] dsscomp_mgr_delayed_cb on RELEASED
[   88.339233] [   87.178]                           [c6f13400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   88.339263] [   87.199]                           [c6f13400] dsscomp_mgr_delayed_cb on DISPLAYED
[   88.339263] ACTIVE COMPOSITIONS on lcd
[   88.367553]
[   88.367553]   [c6f13400]: DISPLAYED
[   88.367553]     sync_id=0, flags=AD-
[   88.367553]     ovl0={ON z0 ARGB32-8888 premult *100% 864*480:0,0+864,480 rot0 => 0,0+864,480 7f9ac000/  (null)|3456}
[   88.367553]     gsync=[c6edbce0] dsscomp_gralloc_cb
[   88.367584]
[   88.367584]   DISPC pipeline:
[   88.367584]
[   88.367584]     info:        clean (none)
[   88.405029]     cache:       clean (none)
[   88.405029]     shadow:  ACT clean (none)
[   88.405029]     dispc:   DISPLAYED mask=---R [c6f13400] dsscomp_mgr_callback
[   88.405029]
[   88.405029] ACTIVE COMPOSITIONS on tv
[   88.405029]
[   88.405029]   DISPC pipeline:
[   88.405029]
[   88.405029]     info:        clean (none)
[   88.405029]     shadow:  off clean (none)
[   88.445526]     dispc:   DISPLAYED (none)
[   88.445526]
[   88.445526] ACTIVE COMPOSITIONS on lcd2
[   88.445526]
[   88.445526]   DISPC pipeline:
[   88.445526]
[   88.445526]     info:        clean (none)
[   88.445526]     cache:       clean (none)
[   88.445526]     shadow:  off clean (none)
[   88.445526]     dispc:             (none)
[   88.445526]
[   88.445556] ACTIVE GRALLOC FLIPS
[   88.445556]
[   88.445556]   [c6edbce0] (refs=1)
[   88.490631]     slots=[7f9ac000]
[   88.490631]     cmdcb=[c73f6480] dsscomp_proxy_cmdcomplete
[   88.490631]
[   88.490631]   |           lcd
[   88.490631]   | [c6f13400] DISPL'D
[   88.490631]   |     87.163  ACTIVE
[   88.490631]   |     87.163 APPLY'N
[   88.490631]   |     87.163 APPLIED
[   88.490631]   |     87.178 PROGR'D
[   88.490631]   |     87.199 DISPL'D
[   88.490661]
[   88.490661]
[   88.531463] PVR_K: SGX debug (blaze_android_sgx_ogles1_ogles2_GPL sgxddk 18 1.8@869593)
[   88.540100] PVR_K:(Error): SGX Register Base Address (Linear):   0xC8B20000 [0, ]
[   88.548126] PVR_K:(Error): SGX Register Base Address (Physical): 0x56000000 [0, ]
[   88.556182] PVR_K: (P0) EUR_CR_CORE_ID:          01140000
[   88.562042] PVR_K: (P0) EUR_CR_CORE_REVISION:    00010200
[   88.567810] PVR_K: (P0) EUR_CR_EVENT_STATUS:     20000000
[   88.573699] PVR_K: (P0) EUR_CR_EVENT_STATUS2:    00000008
[   88.579528] PVR_K: (P0) EUR_CR_BIF_CTRL:         00000000
[   88.586181] PVR_K: (P0) EUR_CR_BIF_INT_STAT:     00008000
[   88.591979] PVR_K: (P0) EUR_CR_BIF_FAULT:        00000000
[   88.598602] PVR_K: (P0) EUR_CR_BIF_MEM_REQ_STAT: 00000000
[   88.604553] PVR_K: (P0) EUR_CR_CLKGATECTL:       000AAA6A
[   88.610351] PVR_K: (P0) EUR_CR_PDS_PC_BASE:      00001860
[   88.616149] PVR_K: Flip Command Complete Data 0 for display device 1:
[   88.623016] PVR_K:   SRC 0: ROC DevVAddr:0xD800494 ROP:0xf ROC:0xd, WOC DevVAddr:0xD800484 WOP:0xf WOC:0xe
[   88.633239] PVR_K: Flip Command Complete Data 1 for display device 1:
[   88.640136] PVR_K:   SRC 0: (Not in use)
[   88.644226] PVR_K: SGX Host control:
[   88.648071] PVR_K:   (HC-0) 0x00000001 0x00000000 0x00000000 0x00000001
[   88.655059] PVR_K:   (HC-10) 0x0000000F 0x0000000A 0x0005DC00 0x00000003
[   88.662139] PVR_K:   (HC-20) 0x00000000 0x00000001 0x00000000 0x00000014
[   88.669189] PVR_K:   (HC-30) 0x00000E43 0xF350B558 0x00000000 0x00000000
[   88.676300] PVR_K:   (HC-40) 0x00000000 0x087BF500 0x087C6300 0x087C3100
[   88.683349] PVR_K: SGX TA/3D control:
[   88.687316] PVR_K:   (T3C-0) 0x0F003000 0x0F003120 0x0F002000 0x00000000
[   88.694366] PVR_K:   (T3C-10) 0x00000001 0x00000002 0x00000001 0x0F00DD00
[   88.701538] PVR_K:   (T3C-20) 0x00000000 0x00000000 0x00000000 0x00000000
[   88.708679] PVR_K:   (T3C-30) 0x00000000 0x00000000 0x00000000 0x00000000
[   88.715881] PVR_K:   (T3C-40) 0x00000000 0x00000000 0x00000000 0x00000000
[   88.723083] PVR_K:   (T3C-50) 0x0F00DD00 0x00000000 0x00000000 0x0F00DD00
[   88.730224] PVR_K:   (T3C-60) 0x00000000 0x00000000 0x0F00DD00 0x00000000
[   88.737426] PVR_K:   (T3C-70) 0x00000000 0x0F00DD00 0x00000000 0x0F004000
[   88.744567] PVR_K:   (T3C-80) 0x000001FF 0x0001120F 0x00000000 0x0F00DEFC
[   88.751770] PVR_K:   (T3C-90) 0x00000000 0x0F000000 0xAB600000 0x0F03CC00
[   88.758941] PVR_K:   (T3C-A0) 0x00000000 0x0F010BE0 0x0F00DD00 0x0F00DEFC
[   88.766082] PVR_K:   (T3C-B0) 0x0F010760 0x00000000 0x00000000 0x00000000
[   88.773254] PVR_K:   (T3C-C0) 0x00000000 0x00000000 0x00000000 0x00000000
[   88.780395] PVR_K:   (T3C-D0) 0x00000000 0x0000001D 0x0000001C 0x0F007000
[   88.788635] PVR_K:   (T3C-E0) 0x0F00D420 0x0F00E000 0x0F010720 0x0F010720
[   88.795837] PVR_K:   (T3C-F0) 0x00000000 0x000000B5 0x000000B5 0x00000000
[   88.802978] PVR_K:   (T3C-100) 0x00000003 0x00000000 0x00000000 0x00000000
[   88.810272] PVR_K:   (T3C-110) 0xB50C565C 0x0872E100 0x08787B00 0x08787B00
[   88.817474] PVR_K: Last SGX microkernel status code: AD000104
[   88.823669] PVR_K:   (MKT-0) 00008715 00100828 01000D1F AD000101
[   88.829956] PVR_K:   (MKT-1) 0000878A 00100828 01000D1F AD000104
[   88.836334] PVR_K:   (MKT-2) 000087C6 00100808 01000E1E AD000100
[   88.842987] PVR_K:   (MKT-3) 000088C4 00100808 01000E1E AD000501
[   88.849334] PVR_K:   (MKT-4) 00008903 0010082B 01000E1E AD000104
[   88.855865] PVR_K:   (MKT-5) 0000A93B 00100828 01000F1F AD000101
[   88.862182] PVR_K:   (MKT-6) 0000A97F 00100828 01000F1F AD000104
[   88.868591] PVR_K:   (MKT-7) 0000AB75 00100808 0100101F AD000100
[   88.874969] PVR_K:   (MKT-8) 0000ABEC 00100808 0100101F AD000502
[   88.881347] PVR_K:   (MKT-9) 0000AC3F 00100808 0100101F AD000C01
[   88.887817] PVR_K:   (MKT-A) 0000AC62 00100808 0100101F 0D800484
[   88.894256] PVR_K:   (MKT-B) 0000AC7A 00100808 0100101F 0000000C
[   88.900665] PVR_K:   (MKT-C) 0000AF39 00100808 0000101F AD00030E
[   88.907073] PVR_K:   (MKT-D) 0000AF51 00100808 0000101F 0D800474
[   88.913421] PVR_K:   (MKT-E) 0000AF6A 00100808 0000101F 0000000B
[   88.919830] PVR_K:   (MKT-F) 0000AF8C 00100808 0000101F 0000000C
[   88.926208] PVR_K:   (MKT-10) 0000B024 00100808 0000101F AD000104
[   88.932708] PVR_K:   (MKT-11) 0000B09A 00100C08 0100111E AD000281
[   88.939361] PVR_K:   (MKT-12) 0000B212 00100808 0100111E AD00080A
[   88.946044] PVR_K:   (MKT-13) 0000B22C 00100808 0100111E 0F039300
[   88.952514] PVR_K:   (MKT-14) 0000B244 00100808 0100111E 00000061
[   88.958953] PVR_K:   (MKT-15) 0000B3C4 00100808 0000111E AD000802
[   88.965393] PVR_K:   (MKT-16) 0000B51C 00100808 0000111E AD000803
[   88.971862] PVR_K:   (MKT-17) 0000B562 00184AC8 0000111E AD000282
[   88.978302] PVR_K:   (MKT-18) 0000D54A 00000C08 0100141F AD000200
[   88.984710] PVR_K:   (MKT-19) 0000D79C 00000808 0000141F AD000202
[   88.991180] PVR_K:   (MKT-1A) 0000D826 00000808 0000151E AD000183
[   88.997558] PVR_K:   (MKT-1B) 0000D90F 00000808 0000151E AD00030E
[   89.004028] PVR_K:   (MKT-1C) 0000D927 00000808 0000151E 0D800474
[   89.010437] PVR_K:   (MKT-1D) 0000D940 00000808 0000151E 0000000B
[   89.016876] PVR_K:   (MKT-1E) 0000D964 00000808 0000151E 0000000C
[   89.023284] PVR_K:   (MKT-1F) 0000D9D0 00000808 0000151E AD000184
[   89.029724] PVR_K:   (MKT-20) 0000DA35 00000C08 0100161D AD000281
[   89.036102] PVR_K:   (MKT-21) 0000DBA4 00000808 0100161D AD00080A
[   89.043304] PVR_K:   (MKT-22) 0000DBBC 00000808 0100161D 0F039600
[   89.049713] PVR_K:   (MKT-23) 0000DBD5 00000808 0100161D 00000060
[   89.056182] PVR_K:   (MKT-24) 0000DE8C 00000808 0000161D AD000803
[   89.062591] PVR_K:   (MKT-25) 0000DED1 00180CC8 0000161D AD000282
[   89.069030] PVR_K:   (MKT-26) 0000DF73 00000808 0100181F AD000200
[   89.075408] PVR_K:   (MKT-27) 0000E18B 00000808 0000181F AD000202
[   89.081878] PVR_K:   (MKT-28) 0000E208 00000808 0000191E AD000183
[   89.088317] PVR_K:   (MKT-29) 0000E2F4 00000808 0000191E AD00030E
[   89.094696] PVR_K:   (MKT-2A) 0000E30C 00000808 0000191E 0D800474
[   89.101409] PVR_K:   (MKT-2B) 0000E325 00000808 0000191E 0000000B
[   89.107818] PVR_K:   (MKT-2C) 0000E348 00000808 0000191E 0000000C
[   89.114440] PVR_K:   (MKT-2D) 0000E3B2 00000808 0000191E AD000184
[   89.120819] PVR_K:   (MKT-2E) 0000E41A 00000C08 01001A1D AD000281
[   89.127288] PVR_K:   (MKT-2F) 0000E587 00000808 01001A1D AD00080A
[   89.133758] PVR_K:   (MKT-30) 0000E5A0 00000808 01001A1D 0F039900
[   89.140258] PVR_K:   (MKT-31) 0000E5B8 00000808 01001A1D 00000060
[   89.146697] PVR_K:   (MKT-32) 0000E86D 00000808 00001A1D AD000803
[   89.153289] PVR_K:   (MKT-33) 0000E8B3 00180CC8 00001A1D AD000282
[   89.159790] PVR_K:   (MKT-34) 0000E99D 00000808 01001C1F AD000200
[   89.166320] PVR_K:   (MKT-35) 0000EBB8 00000808 00001C1F AD000202
[   89.172760] PVR_K:   (MKT-36) 0000EC38 00000808 00001D1E AD000183
[   89.179260] PVR_K:   (MKT-37) 0000ED23 00000808 00001D1E AD00030E
[   89.185729] PVR_K:   (MKT-38) 0000ED3B 00000808 00001D1E 0D800474
[   89.192230] PVR_K:   (MKT-39) 0000ED54 00000808 00001D1E 0000000B
[   89.198730] PVR_K:   (MKT-3A) 0000ED78 00000808 00001D1E 0000000C
[   89.205200] PVR_K:   (MKT-3B) 0000EDE2 00000808 00001D1E AD000184
[   89.211669] PVR_K:   (MKT-3C) 0000EE46 00000C08 01001E1D AD000281
[   89.218048] PVR_K:   (MKT-3D) 0000EFAD 00000808 01001E1D AD00080A
[   89.224487] PVR_K:   (MKT-3E) 0000EFC6 00000808 01001E1D 0F039C00
[   89.230895] PVR_K:   (MKT-3F) 0000EFDE 00000808 01001E1D 00000062
[   89.237365] PVR_K:   (MKT-40) 0000F293 00000808 00001E1D AD000803
[   89.243804] PVR_K:   (MKT-41) 0000F2D9 00180C88 00001E1D AD000282
[   89.250610] PVR_K:   (MKT-42) 0000FDB6 00000808 0100201F AD000200
[   89.257019] PVR_K:   (MKT-43) 0000FED3 001FFFFF 0100201F AD001703
[   89.263610] PVR_K:   (MKT-44) 000100A6 00000808 0000201F AD000202
[   89.270141] PVR_K:   (MKT-45) 00010123 00000808 0100211E AD000183
[   89.276611] PVR_K:   (MKT-46) 0001020C 00000808 0100211E AD00030E
[   89.283050] PVR_K:   (MKT-47) 00010224 00000808 0100211E 0D800474
[   89.289581] PVR_K:   (MKT-48) 0001023D 00000808 0100211E 0000000B
[   89.296081] PVR_K:   (MKT-49) 00010260 00000808 0100211E 0000000C
[   89.302551] PVR_K:   (MKT-4A) 000102EC 00000808 0100211E AD000184
[   89.309082] PVR_K:   (MKT-4B) 0001D923 00000808 0100241F AD001A00
[   89.315551] PVR_K:   (MKT-4C) 0006D023 00000808 0100321F AD00000A
[   89.322082] PVR_K:   (MKT-4D) 0006D08C 00000808 0100321F AD000909
[   89.328552] PVR_K:   (MKT-4E) 0006D0D5 00000808 0100321F AD001A05
[   89.335021] PVR_K:   (MKT-4F) 0006D104 00000808 0100321F AD001302
[   89.341461] PVR_K:   (MKT-50) 0006D144 00000808 0100321F AD001303
[   89.347991] PVR_K:   (MKT-51) 0006D1DB 00000808 0100321F AD000D04
[   89.354461] PVR_K:   (MKT-52) 0006D2A3 00000808 0100321F AD000D05
[   89.360931] PVR_K:   (MKT-53) 0006D311 00000808 0100321F AD001A06
[   89.367492] PVR_K:   (MKT-54) 000004A3 00100808 0100031F AD002300
[   89.374023] PVR_K:   (MKT-55) 00000977 00100808 0100041F AD00000A
[   89.380432] PVR_K:   (MKT-56) 000009F2 00100808 0100041F AD000906
[   89.387054] PVR_K:   (MKT-57) 00000AC5 00100808 0000041F AD000901
[   89.393493] PVR_K:   (MKT-58) 00000B3F 00100808 0100051E AD000183
[   89.399902] PVR_K:   (MKT-59) 00000CB3 00100808 0100051E AD000302
[   89.406402] PVR_K:   (MKT-5A) 00000E32 00100808 0100051E AD000D06
[   89.412841] PVR_K:   (MKT-5B) 00000F15 00100808 0100051E AD000D07
[   89.419342] PVR_K:   (MKT-5C) 00000F5F 00100808 0100051E AD001304
[   89.425781] PVR_K:   (MKT-5D) 0000104A 00100808 0100051E AD001305
[   89.432312] PVR_K:   (MKT-5E) 00001159 00100888 0100051E AD000404
[   89.438751] PVR_K:   (MKT-5F) 0000121A 00100808 0000051E AD000402
[   89.445251] PVR_K:   (MKT-60) 00001262 0010082B 0000051E AD000184
[   89.451690] PVR_K:   (MKT-61) 072587F9 00100808 0100031F AD000B00
[   89.458190] PVR_K:   (MKT-62) 07258833 00100808 0100031F AD000B02
[   89.464691] PVR_K:   (MKT-63) 072588B7 00100808 0100031F AD000B02
[   89.471191] PVR_K:   (MKT-64) 072588F6 00100808 0100031F AD000B02
[   89.477966] PVR_K:   (MKT-65) 07258935 00100808 0100031F AD000B02
[   89.485107] PVR_K:   (MKT-66) 07258974 00100808 0100031F AD000B03
[   89.491943] PVR_K:   (MKT-67) 072589F3 00100808 0100031F AD000B05
[   89.498382] PVR_K:   (MKT-68) 07258A47 00100808 0100031F AD000B06
[   89.504913] PVR_K:   (MKT-69) 07258A76 00100808 0100031F AD000B06
[   89.511322] PVR_K:   (MKT-6A) 07258ABD 00100808 0100031F AD000B07
[   89.517791] PVR_K:   (MKT-6B) 07258AE2 00100808 0100031F AD000B09
[   89.524200] PVR_K:   (MKT-6C) 07258B38 00100808 0100031F AD000B01
[   89.530639] PVR_K:   (MKT-6D) 07258B74 00100808 0100031F AD002300
[   89.537048] PVR_K:   (MKT-6E) 07258D5C 00100808 0100041F AD00000A
[   89.543518] PVR_K:   (MKT-6F) 07258DD0 00100808 0100041F AD000906
[   89.549957] PVR_K:   (MKT-70) 07258E8F 00100808 0000041F AD000901
[   89.556427] PVR_K:   (MKT-71) 07258F0B 00100808 0000051E AD000183
[   89.562835] PVR_K:   (MKT-72) 07259077 00100808 0000051E AD000302
[   89.569305] PVR_K:   (MKT-73) 072590CA 00100808 0000051E AD000303
[   89.575683] PVR_K:   (MKT-74) 07259157 00100808 0000051E AD000C01
[   89.582122] PVR_K:   (MKT-75) 0725917C 00100808 0000051E 0D800464
[   89.588562] PVR_K:   (MKT-76) 07259194 00100808 0000051E 0000000D
[   89.595001] PVR_K:   (MKT-77) 072593EA 00100808 0000051E AD00030E
[   89.601440] PVR_K:   (MKT-78) 07259402 00100808 0000051E 0D800494
[   89.607818] PVR_K:   (MKT-79) 0725941B 00100808 0000051E 0000000B
[   89.614288] PVR_K:   (MKT-7A) 07259440 00100808 0000051E 0000000C
[   89.620666] PVR_K:   (MKT-7B) 072594B9 00100808 0000051E AD000184
[   89.627136] PVR_K:   (MKT-7C) 07259538 00100C08 0100061D AD000281
[   89.633544] PVR_K:   (MKT-7D) 072596D8 00100808 0100061D AD00080A
[   89.639984] PVR_K:   (MKT-7E) 072596F0 00100808 0100061D 0F039F00
[   89.646392] PVR_K:   (MKT-7F) 07259708 00100808 0100061D 00000061
[   89.652832] PVR_K:   (MKT-80) 07259825 00100C88 0100061D AD001300
[   89.659271] PVR_K:   (MKT-81) 0725EC2E 00100808 0000061D AD001301
[   89.665710] PVR_K:   (MKT-82) 0725ED61 00100888 0000061D AD000802
[   89.672119] PVR_K:   (MKT-83) 0725EED1 00100888 0000061D AD000803
[   89.678588] PVR_K:   (MKT-84) 0725EF20 001808C8 0000061D AD000282
[   89.686065] PVR_K:   (MKT-85) 0725F002 00184EF8 0000081E AD00000A
[   89.692535] PVR_K:   (MKT-86) 0725F089 00184AF8 0000081E AD000905
[   89.698944] PVR_K:   (MKT-87) 0725F1A5 001808B8 0000081E AD000901
[   89.705413] PVR_K:   (MKT-88) 0725F21A 00180838 0000091C AD00000A
[   89.711853] PVR_K:   (MKT-89) 0725F28E 00180838 0000091C AD000906
[   89.718261] PVR_K:   (MKT-8A) 0725F303 00180838 0000091C AD000901
[   89.725036] PVR_K:   (MKT-8B) 0725F35D 00180838 00000A1B AD00000A
[   89.731567] PVR_K:   (MKT-8C) 0725F3C0 00180838 00000A1B AD000905
[   89.738006] PVR_K:   (MKT-8D) 0725F468 00180838 00000A1B AD000901
[   89.744476] PVR_K:   (MKT-8E) 0725F4C6 00180838 00000B1A AD00000A
[   89.750976] PVR_K:   (MKT-8F) 0725F52C 00180838 00000B1A AD000905
[   89.757415] PVR_K:   (MKT-90) 0725F5D4 00180838 00000B1A AD000901
[   89.764038] PVR_K:   (MKT-91) 0725F626 00180838 00000C19 AD00000A
[   89.770446] PVR_K:   (MKT-92) 0725F68E 00180838 00000C19 AD000905
[   89.776977] PVR_K:   (MKT-93) 0725F736 00180838 00000C19 AD000901
[   89.783477] PVR_K:   (MKT-94) 0725F886 00180838 00000F1F AD000183
[   89.789978] PVR_K:   (MKT-95) 0725F9FE 00180838 00000F1F AD000302
[   89.796417] PVR_K:   (MKT-96) 0725FA71 00180838 00000F1F AD000303
[   89.802917] PVR_K:   (MKT-97) 0725FAF6 00180838 00000F1F AD000C01
[   89.809478] PVR_K:   (MKT-98) 0725FB1A 00180838 00000F1F 0D800484
[   89.815948] PVR_K:   (MKT-99) 0725FB34 00180838 00000F1F 0000000D
[   89.822692] PVR_K:   (MKT-9A) 0725FD4C 00180838 00000F1F AD000184
[   89.829315] PVR_K:   (MKT-9B) 0725FDBE 00180C38 0100101D AD000281
[   89.835815] PVR_K:   (MKT-9C) 0725FE1B 00180838 0100101D AD000282
[   89.842407] PVR_K:   (MKT-9D) 07260AAF 00180838 0100111F AD00000A
[   89.848876] PVR_K:   (MKT-9E) 07260B1C 00180838 0100111F AD000905
[   89.855285] PVR_K:   (MKT-9F) 07260C25 00180838 0000111F AD000901
[   89.861816] PVR_K:   (MKT-A0) 07260C78 00180C38 0100121E AD000281
[   89.868347] PVR_K:   (MKT-A1) 07260CD2 00180838 0100121E AD000282
[   89.874816] PVR_K:   (MKT-A2) 07260DD9 00180838 0100131F AD00000A
[   89.881256] PVR_K:   (MKT-A3) 07260E45 00180838 0100131F AD000905
[   89.887786] PVR_K:   (MKT-A4) 07260F42 00180838 0000131F AD000901
[   89.894226] PVR_K:   (MKT-A5) 07260F92 00100C28 0100141E AD000281
[   89.900726] PVR_K:   (MKT-A6) 07260FEC 00100828 0100141E AD000282
[   89.907196] PVR_K:   (MKT-A7) 072610BD 00000808 0100151F AD000200
[   89.913726] PVR_K:   (MKT-A8) 07261313 00000808 0000151F AD000202
[   89.920227] PVR_K:   (MKT-A9) 072613BB 00000808 0000161E AD00000A
[   89.926696] PVR_K:   (MKT-AA) 07261423 00000808 0000161E AD000905
[   89.933166] PVR_K:   (MKT-AB) 07261515 00000808 0000161E AD000901
[   89.939666] PVR_K:   (MKT-AC) 07261567 00000C08 0000171D AD000281
[   89.946166] PVR_K:   (MKT-AD) 072616CF 00000808 0000171D AD00080A
[   89.952606] PVR_K:   (MKT-AE) 072616E7 00000808 0000171D 0F03A200
[   89.959045] PVR_K:   (MKT-AF) 07261700 00000808 0000171D 00000060
[   89.965484] PVR_K:   (MKT-B0) 072619B9 00000808 0000171D AD000803
[   89.971954] PVR_K:   (MKT-B1) 072619FF 00180CC8 0000171D AD000282
[   89.978363] PVR_K:   (MKT-B2) 07261AAE 00000808 0000181F AD00000A
[   89.984893] PVR_K:   (MKT-B3) 07261B19 00000808 0000181F AD000905
[   89.991394] PVR_K:   (MKT-B4) 07261C0B 00000888 0000181F AD000901
[   89.997863] PVR_K:   (MKT-B5) 07261C53 00000C08 00001A1D AD000200
[   90.004425] PVR_K:   (MKT-B6) 07261E89 00000808 00001A1D AD000202
[   90.010864] PVR_K:   (MKT-B7) 07261EE0 00000808 01001B1C AD000281
[   90.017333] PVR_K:   (MKT-B8) 07262026 00000808 01001B1C AD00080A
[   90.023773] PVR_K:   (MKT-B9) 0726203F 00000808 01001B1C 0F03A500
[   90.030273] PVR_K:   (MKT-BA) 07262057 00000808 01001B1C 00000060
[   90.036712] PVR_K:   (MKT-BB) 0726230D 00000808 00001B1C AD000803
[   90.043212] PVR_K:   (MKT-BC) 07262353 00180CC8 00001B1C AD000282
[   90.049682] PVR_K:   (MKT-BD) 07262437 00000808 01001D1F AD000200
[   90.056243] PVR_K:   (MKT-BE) 0726265D 00000808 01001D1F AD000202
[   90.062713] PVR_K:   (MKT-BF) 072626AA 00000808 01001E1E AD000281
[   90.069213] PVR_K:   (MKT-C0) 072627F5 00000808 01001E1E AD00080A
[   90.075622] PVR_K:   (MKT-C1) 0726280E 00000808 01001E1E 0F03A800
[   90.082153] PVR_K:   (MKT-C2) 07262826 00000808 01001E1E 00000062
[   90.088592] PVR_K:   (MKT-C3) 07262AD8 00000808 00001E1E AD000803
[   90.095153] PVR_K:   (MKT-C4) 07262B1E 00180C88 00001E1E AD000282
[   90.101562] PVR_K:   (MKT-C5) 0726363A 00000808 0100201F AD000200
[   90.108123] PVR_K:   (MKT-C6) 07263754 00000808 0100201F AD001703
[   90.114624] PVR_K:   (MKT-C7) 07263957 00000808 0000201F AD000202
[   90.121215] PVR_K:   (MKT-C8) 072639D3 00000808 0000211E AD000183
[   90.127685] PVR_K:   (MKT-C9) 07263ABA 00000808 0000211E AD00030E
[   90.134124] PVR_K:   (MKT-CA) 07263AD3 00000808 0000211E 0D800474
[   90.140624] PVR_K:   (MKT-CB) 07263AEC 00000808 0000211E 0000000C
[   90.147064] PVR_K:   (MKT-CC) 07263B14 00000808 0000211E 0000000D
[   90.153564] PVR_K:   (MKT-CD) 07263B7E 00000808 0000211E AD000184
[   90.160003] PVR_K:   (MKT-CE) 07263BE2 00000C08 0100221D AD000281
[   90.166534] PVR_K:   (MKT-CF) 07263D56 00000808 0100221D AD00080A
[   90.172973] PVR_K:   (MKT-D0) 07263D6F 00000808 0100221D 0F03AB00
[   90.179504] PVR_K:   (MKT-D1) 07263D87 00000808 0100221D 00000061
[   90.185913] PVR_K:   (MKT-D2) 07263EFA 00000808 0000221D AD000802
[   90.192474] PVR_K:   (MKT-D3) 0726404A 00000808 0000221D AD000803
[   90.198913] PVR_K:   (MKT-D4) 0726408F 00184EC8 0000221D AD000282
[   90.205413] PVR_K:   (MKT-D5) 07265FE9 00000C08 0100251F AD000200
[   90.211853] PVR_K:   (MKT-D6) 07266232 00000808 0000251F AD000202
[   90.218292] PVR_K:   (MKT-D7) 072662BA 00000808 0000261E AD000183
[   90.224731] PVR_K:   (MKT-D8) 072663A3 00000808 0000261E AD00030E
[   90.231170] PVR_K:   (MKT-D9) 072663BC 00000808 0000261E 0D800474
[   90.237792] PVR_K:   (MKT-DA) 072663D4 00000808 0000261E 0000000C
[   90.244201] PVR_K:   (MKT-DB) 072663F8 00000808 0000261E 0000000D
[   90.250671] PVR_K:   (MKT-DC) 07266461 00000808 0000261E AD000184
[   90.257171] PVR_K:   (MKT-DD) 072664C6 00000C08 0100271D AD000281
[   90.263610] PVR_K:   (MKT-DE) 0726662D 00000808 0100271D AD00080A
[   90.270202] PVR_K:   (MKT-DF) 07266646 00000808 0100271D 0F03AE00
[   90.276672] PVR_K:   (MKT-E0) 0726665E 00000808 0100271D 00000060
[   90.283111] PVR_K:   (MKT-E1) 07266918 00000808 0000271D AD000803
[   90.289642] PVR_K:   (MKT-E2) 07266966 00180CC8 0000271D AD000282
[   90.296081] PVR_K:   (MKT-E3) 07266A05 00000808 0100291F AD000200
[   90.302581] PVR_K:   (MKT-E4) 07266C20 00000808 0000291F AD000202
[   90.309082] PVR_K:   (MKT-E5) 07266CA1 00000808 00002A1E AD000183
[   90.315612] PVR_K:   (MKT-E6) 07266D8E 00000808 00002A1E AD00030E
[   90.322082] PVR_K:   (MKT-E7) 07266DA6 00000808 00002A1E 0D800474
[   90.328582] PVR_K:   (MKT-E8) 07266DBF 00000808 00002A1E 0000000C
[   90.335052] PVR_K:   (MKT-E9) 07266DE5 00000808 00002A1E 0000000D
[   90.341491] PVR_K:   (MKT-EA) 07266E50 00000808 00002A1E AD000184
[   90.348022] PVR_K:   (MKT-EB) 07266EB7 00000C08 01002B1D AD000281
[   90.354461] PVR_K:   (MKT-EC) 0726701F 00000808 01002B1D AD00080A
[   90.360931] PVR_K:   (MKT-ED) 07267038 00000808 01002B1D 0F03B100
[   90.367370] PVR_K:   (MKT-EE) 07267050 00000808 01002B1D 00000060
[   90.373809] PVR_K:   (MKT-EF) 07267303 00000808 00002B1D AD000803
[   90.380218] PVR_K:   (MKT-F0) 0726734D 00188CC8 00002B1D AD000282
[   90.386688] PVR_K:   (MKT-F1) 07267436 00000808 01002D1F AD000200
[   90.393096] PVR_K:   (MKT-F2) 0726764F 00000808 00002D1F AD000202
[   90.399566] PVR_K:   (MKT-F3) 072676CF 00000808 00002E1E AD000183
[   90.405944] PVR_K:   (MKT-F4) 072677B8 00000808 00002E1E AD00030E
[   90.412414] PVR_K:   (MKT-F5) 072677D0 00000808 00002E1E 0D800474
[   90.418823] PVR_K:   (MKT-F6) 072677E8 00000808 00002E1E 0000000C
[   90.425231] PVR_K:   (MKT-F7) 0726780B 00000808 00002E1E 0000000D
[   90.431671] PVR_K:   (MKT-F8) 07267876 00000808 00002E1E AD000184
[   90.438110] PVR_K:   (MKT-F9) 072678DA 00000C08 01002F1D AD000281
[   90.444549] PVR_K:   (MKT-FA) 07267A44 00000808 01002F1D AD00080A
[   90.450958] PVR_K:   (MKT-FB) 07267A5D 00000808 01002F1D 0F03B400
[   90.457397] PVR_K:   (MKT-FC) 07267A75 00000808 01002F1D 00000062
[   90.463806] PVR_K:   (MKT-FD) 07267D25 00000808 00002F1D AD000803
[   90.470275] PVR_K:   (MKT-FE) 07267D6C 00180C88 00002F1D AD000282
[   90.476684] PVR_K:   (MKT-FF) 0726885F 00000808 0100311F AD000200
[   90.483093] PVR_K:   (MKT-100) 0726897B 00000808 0100311F AD001703
[   90.489593] PVR_K:   (MKT-101) 07268B65 00000808 0000311F AD000202
[   90.496154] PVR_K:   (MKT-102) 07268BE2 00000808 0000321E AD000183
[   90.502655] PVR_K:   (MKT-103) 07268CCC 00000808 0000321E AD00030E
[   90.509185] PVR_K:   (MKT-104) 07268CE4 00000808 0000321E 0D800474
[   90.515686] PVR_K:   (MKT-105) 07268CFD 00000808 0000321E 0000000C
[   90.522216] PVR_K:   (MKT-106) 07268D20 00000808 0000321E 0000000D
[   90.528778] PVR_K:   (MKT-107) 07268D8C 00000808 0000321E AD000184
[   90.535247] PVR_K:   (MKT-108) 07268DF0 00000C08 0100331D AD000281
[   90.541809] PVR_K:   (MKT-109) 07268F00 00000808 0100331D AD000E02
[   90.548309] PVR_K:   (MKT-10A) 07268F75 00000808 0100331D AD000282
[   90.554870] PVR_K:   (MKT-10B) 07276062 00000808 0100361F AD001A00
[   90.561401] PVR_K:   (MKT-10C) 0728391E 00000808 0100391F AD00000A
[   90.567962] PVR_K:   (MKT-10D) 07283980 00000808 0100391F AD000909
[   90.574462] PVR_K:   (MKT-10E) 072839CE 00000808 0100391F AD001A05
[   90.580993] PVR_K:   (MKT-10F) 07283A02 00000808 0100391F AD001302
[   90.587524] PVR_K:   (MKT-110) 07283A45 00000808 0100391F AD001303
[   90.594085] PVR_K:   (MKT-111) 07283AD6 00000808 0100391F AD000D04
[   90.602264] PVR_K:   (MKT-112) 07283BA9 00000808 0100391F AD000D05
[   90.608825] PVR_K:   (MKT-113) 07283C04 00000808 0100391F AD000D04
[   90.615356] PVR_K:   (MKT-114) 07283C8C 00000808 0100391F AD000D05
[   90.621856] PVR_K:   (MKT-115) 07283CE9 00000808 0100391F AD001A06
[   90.628387] PVR_K:   (MKT-116) 0000047B 00100808 0100031F AD002300
[   90.634887] PVR_K:   (MKT-117) 00000952 00100808 0100041F AD00000A
[   90.641448] PVR_K:   (MKT-118) 000009CF 00100808 0100041F AD000906
[   90.647949] PVR_K:   (MKT-119) 00000AA2 00100808 0000041F AD000901
[   90.654479] PVR_K:   (MKT-11A) 00000B1D 00100808 0000051E AD000183
[   90.660980] PVR_K:   (MKT-11B) 00000C92 00100808 0000051E AD000302
[   90.667510] PVR_K:   (MKT-11C) 00000E14 00100808 0000051E AD000D06
[   90.675048] PVR_K:   (MKT-11D) 00000EF9 00100808 0000051E AD000D07
[   90.681610] PVR_K:   (MKT-11E) 00000F43 00100808 0000051E AD001304
[   90.688110] PVR_K:   (MKT-11F) 00001032 00100808 0000051E AD001305
[   90.694854] PVR_K:   (MKT-120) 00001146 00100888 0000051E AD000404
[   90.701416] PVR_K:   (MKT-121) 0000120B 00100808 0000051E AD000402
[   90.708068] PVR_K:   (MKT-122) 00001254 0010082B 0000051E AD000184
[   90.714630] PVR_K:   (MKT-123) 000012F6 00108DA9 0000061D AD000281
[   90.721160] PVR_K:   (MKT-124) 00001484 001009AF 0000061D AD000E02
[   90.727752] PVR_K:   (MKT-125) 000014E5 001008AF 0000061D AD000282
[   90.734283] PVR_K:   (MKT-126) 00003A86 00100808 0000081F AD000101
[   90.741180] PVR_K:   (MKT-127) 00003AFD 00100808 0000081F AD000104
[   90.747680] PVR_K:   (MKT-128) 00003B39 00100808 0100091E AD000100
[   90.754364] PVR_K:   (MKT-129) 00003C2D 00100808 0100091E AD000501
[   90.760925] PVR_K:   (MKT-12A) 00003C6F 0010082B 0100091E AD000104
[   90.767517] PVR_K:   (MKT-12B) 00005EE6 00100828 01000A1F AD000101
[   90.774078] PVR_K:   (MKT-12C) 00005F2B 00100828 01000A1F AD000104
[   90.780639] PVR_K:   (MKT-12D) 00006045 00100808 01000B1F AD000100
[   90.787261] PVR_K:   (MKT-12E) 00006101 00100808 01000B1F AD000501
[   90.793853] PVR_K:   (MKT-12F) 0000612D 00100829 01000B1F AD000104
[   90.800445] PVR_K:   (MKT-130) 071F3382 00100808 0100031F AD000B00
[   90.807006] PVR_K:   (MKT-131) 071F33C6 00100808 0100031F AD000B03
[   90.813690] PVR_K:   (MKT-132) 071F344F 00100808 0100031F AD000B05
[   90.820281] PVR_K:   (MKT-133) 071F34A3 00100808 0100031F AD000B06
[   90.826873] PVR_K:   (MKT-134) 071F34D4 00100808 0100031F AD000B06
[   90.833435] PVR_K:   (MKT-135) 071F3518 00100808 0100031F AD000B07
[   90.840026] PVR_K:   (MKT-136) 071F353E 00100808 0100031F AD000B09
[   90.846557] PVR_K:   (MKT-137) 071F3592 00100808 0100031F AD000B01
[   90.853149] PVR_K:   (MKT-138) 071F35CE 00100808 0100031F AD002300
[   90.859771] PVR_K:   (MKT-139) 071F38E2 00100808 0100041F AD00000A
[   90.866394] PVR_K:   (MKT-13A) 071F3962 00100808 0100041F AD000906
[   90.872955] PVR_K:   (MKT-13B) 071F3A1E 00100808 0000041F AD000901
[   90.879516] PVR_K:   (MKT-13C) 071F3A99 00100808 0000051E AD000183
[   90.886108] PVR_K:   (MKT-13D) 071F3C09 00100808 0000051E AD000302
[   90.892669] PVR_K:   (MKT-13E) 071F3C5F 00100808 0000051E AD000303
[   90.899261] PVR_K:   (MKT-13F) 071F3CE5 00100808 0000051E AD000C01
[   90.905822] PVR_K:   (MKT-140) 071F3D0A 00100808 0000051E 0D800464
[   90.912567] PVR_K:   (MKT-141) 071F3D22 00100808 0000051E 0000000E
[   90.919128] PVR_K:   (MKT-142) 071F3F78 00100808 0000051E AD00030E
[   90.925750] PVR_K:   (MKT-143) 071F3F90 00100808 0000051E 0D800494
[   90.932312] PVR_K:   (MKT-144) 071F3FA9 00100808 0000051E 0000000C
[   90.938903] PVR_K:   (MKT-145) 071F3FCD 00100808 0000051E 0000000D
[   90.945434] PVR_K:   (MKT-146) 071F4046 00100808 0000051E AD000184
[   90.951934] PVR_K:   (MKT-147) 071F40C4 00100C08 0100061D AD000281
[   90.958587] PVR_K:   (MKT-148) 071F425D 00100808 0100061D AD00080A
[   90.965576] PVR_K:   (MKT-149) 071F4276 00100808 0100061D 0F03B700
[   90.972167] PVR_K:   (MKT-14A) 071F428E 00100808 0100061D 00000061
[   90.978729] PVR_K:   (MKT-14B) 071F43AA 00100C88 0100061D AD001300
[   90.985321] PVR_K:   (MKT-14C) 071F9799 00100808 0000061D AD001301
[   90.991882] PVR_K:   (MKT-14D) 071F98C1 00100888 0000061D AD000802
[   90.998504] PVR_K:   (MKT-14E) 071F9A24 00100888 0000061D AD000803
[   91.005126] PVR_K:   (MKT-14F) 071F9A72 001808C8 0000061D AD000282
[   91.011901] PVR_K:   (MKT-150) 071F9B53 00184EF8 0000081E AD00000A
[   91.018524] PVR_K:   (MKT-151) 071F9BD2 001808F8 0000081E AD000905
[   91.025238] PVR_K:   (MKT-152) 071F9CF6 001808B8 0000081E AD000901
[   91.031921] PVR_K:   (MKT-153) 071F9D6A 00180838 0000091C AD00000A
[   91.038574] PVR_K:   (MKT-154) 071F9DCB 00180838 0000091C AD000905
[   91.045227] PVR_K:   (MKT-155) 071F9E73 00180838 0000091C AD000901
[   91.051879] PVR_K:   (MKT-156) 071F9EC7 00180838 00000A1B AD00000A
[   91.058593] PVR_K:   (MKT-157) 071F9F28 00180838 00000A1B AD000905
[   91.065277] PVR_K:   (MKT-158) 071F9FD7 00180838 00000A1B AD000901
[   91.071929] PVR_K:   (MKT-159) 071FA032 00180838 00000B1A AD00000A
[   91.078552] PVR_K:   (MKT-15A) 071FA0A0 00180838 00000B1A AD000905
[   91.085205] PVR_K:   (MKT-15B) 071FA148 00180838 00000B1A AD000901
[   91.091796] PVR_K:   (MKT-15C) 071FA19A 00180838 00000C19 AD00000A
[   91.098449] PVR_K:   (MKT-15D) 071FA210 00180838 00000C19 AD000906
[   91.105072] PVR_K:   (MKT-15E) 071FA28E 00180838 00000C19 AD000901
[   91.111694] PVR_K:   (MKT-15F) 071FA3DF 00180838 00000F1F AD000183
[   91.118347] PVR_K:   (MKT-160) 071FA558 00180838 00000F1F AD000302
[   91.124938] PVR_K:   (MKT-161) 071FA5D0 00180838 00000F1F AD000303
[   91.131500] PVR_K:   (MKT-162) 071FA64C 00180838 00000F1F AD000C01
[   91.138092] PVR_K:   (MKT-163) 071FA678 00180838 00000F1F 0D800484
[   91.144653] PVR_K:   (MKT-164) 071FA690 00180838 00000F1F 0000000E
[   91.151184] PVR_K:   (MKT-165) 071FA8B1 00180838 00000F1F AD000184
[   91.157775] PVR_K:   (MKT-166) 071FA922 00180C38 0100101D AD000281
[   91.164398] PVR_K:   (MKT-167) 071FA978 00180838 0100101D AD000282
[   91.171020] PVR_K:   (MKT-168) 071FB5E7 00180838 0100111F AD00000A
[   91.177734] PVR_K:   (MKT-169) 071FB651 00180838 0100111F AD000905
[   91.184478] PVR_K:   (MKT-16A) 071FB753 00180838 0000111F AD000901
[   91.191070] PVR_K:   (MKT-16B) 071FB7A6 00180C38 0100121E AD000281
[   91.197662] PVR_K:   (MKT-16C) 071FB801 00180838 0100121E AD000282
[   91.204284] PVR_K:   (MKT-16D) 071FB8DF 00180838 0100131F AD00000A
[   91.210845] PVR_K:   (MKT-16E) 071FB949 00180838 0100131F AD000905
[   91.217437] PVR_K:   (MKT-16F) 071FBA47 00180838 0000131F AD000901
[   91.223999] PVR_K:   (MKT-170) 071FBA99 00180C38 0100141E AD000281
[   91.230682] PVR_K:   (MKT-171) 071FBAF5 00100828 0100141E AD000282
[   91.237304] PVR_K:   (MKT-172) 071FBBEE 00000888 0100151F AD00000A
[   91.243927] PVR_K:   (MKT-173) 071FBC59 00000808 0000151F AD000905
[   91.250640] PVR_K:   (MKT-174) 071FBD54 00000808 0000151F AD000901
[   91.257354] PVR_K:   (MKT-175) 071FBD8A 00000C08 0000161E AD000200
[   91.264038] PVR_K:   (MKT-176) 071FBFDB 00000808 0000161E AD000202
[   91.270690] PVR_K:   (MKT-177) 071FC032 00000808 0000171D AD000281
[   91.277252] PVR_K:   (MKT-178) 071FC17D 00000808 0000171D AD00080A
[   91.283905] PVR_K:   (MKT-179) 071FC196 00000808 0000171D 0F03BA00
[   91.295867] PVR_K:   (MKT-17A) 071FC1AF 00000808 0000171D 00000060
[   91.310089] PVR_K:   (MKT-17B) 071FC469 00000808 0000171D AD000803
[   91.329559] PVR_K:   (MKT-17C) 071FC4B0 00180CC8 0000171D AD000282
[   91.336212] PVR_K:   (MKT-17D) 071FC562 00000808 0000181F AD00000A
[   91.344879] acc_open
[   91.347259] acc_release
[   91.349945] PVR_K:   (MKT-17E) 071FC5CA 00000808 0000181F AD000905
[   91.358276] PVR_K:   (MKT-17F) 071FC6C1 00000888 0000181F AD000901
[   91.365753] PVR_K:   (MKT-180) 071FC70B 00000C08 00001A1D AD000200
[   91.372406] PVR_K:   (MKT-181) 071FC93D 00000808 00001A1D AD000202
[   91.379241] PVR_K:   (MKT-182) 071FC998 00000808 01001B1C AD000281
[   91.385833] PVR_K:   (MKT-183) 071FCAE8 00000808 01001B1C AD00080A
[   91.392333] PVR_K:   (MKT-184) 071FCB00 00000808 01001B1C 0F03BD00
[   91.398986] PVR_K:   (MKT-185) 071FCB18 00000808 01001B1C 00000060
[   91.405517] PVR_K:   (MKT-186) 071FCDCD 00000808 00001B1C AD000803
[   91.412078] PVR_K:   (MKT-187) 071FCE13 00180CC8 00001B1C AD000282
[   91.428558] PVR_K:   (MKT-188) 071FCF02 00000808 01001D1F AD000200
[   91.435119] PVR_K:   (MKT-189) 071FD139 00000808 00001D1F AD000202
[   91.456207] PVR_K:   (MKT-18A) 071FD18A 00000808 01001E1E AD000281
[   91.462951] PVR_K:   (MKT-18B) 071FD2E3 00000808 01001E1E AD00080A
[   91.469512] PVR_K:   (MKT-18C) 071FD2FC 00000808 01001E1E 0F03C000
[   91.476013] PVR_K:   (MKT-18D) 071FD314 00000808 01001E1E 00000062
[   91.482543] PVR_K:   (MKT-18E) 071FD5D1 00000808 00001E1E AD000803
[   91.489044] PVR_K:   (MKT-18F) 071FD618 00180C88 00001E1E AD000282
[   91.495574] PVR_K:   (MKT-190) 071FE180 00000808 0100201F AD000200
[   91.502075] PVR_K:   (MKT-191) 071FE29A 00000808 0100201F AD001703
[   91.508636] PVR_K:   (MKT-192) 071FE49B 00000808 0000201F AD000202
[   91.515136] PVR_K:   (MKT-193) 071FE517 00000808 0000211E AD000183
[   91.521667] PVR_K:   (MKT-194) 071FE604 00000808 0000211E AD00030E
[   91.528411] PVR_K:   (MKT-195) 071FE61C 00000808 0000211E 0D800474
[   91.535003] PVR_K:   (MKT-196) 071FE635 00000808 0000211E 0000000D
[   91.541564] PVR_K:   (MKT-197) 071FE658 00000808 0000211E 0000000E
[   91.548065] PVR_K:   (MKT-198) 071FE6C2 00000808 0000211E AD000184
[   91.554595] PVR_K:   (MKT-199) 071FE728 00000C08 0100221D AD000281
[   91.561157] PVR_K:   (MKT-19A) 071FE8A2 00000808 0100221D AD00080A
[   91.567749] PVR_K:   (MKT-19B) 071FE8BB 00000808 0100221D 0F03C300
[   91.574249] PVR_K:   (MKT-19C) 071FE8D3 00000808 0100221D 00000061
[   91.580810] PVR_K:   (MKT-19D) 071FEA4E 00000808 0000221D AD000802
[   91.587310] PVR_K:   (MKT-19E) 071FEB9E 00000808 0000221D AD000803
[   91.594085] PVR_K:   (MKT-19F) 071FEBE9 00184EC8 0000221D AD000282
[   91.600708] PVR_K:   (MKT-1A0) 07200B3A 00000C08 0100251F AD000200
[   91.607269] PVR_K:   (MKT-1A1) 07200D84 00000808 0000251F AD000202
[   91.613769] PVR_K:   (MKT-1A2) 07200E0D 00000808 0000261E AD000183
[   91.620330] PVR_K:   (MKT-1A3) 07200EFA 00000808 0000261E AD00030E
[   91.626892] PVR_K:   (MKT-1A4) 07200F12 00000808 0000261E 0D800474
[   91.633392] PVR_K:   (MKT-1A5) 07200F2A 00000808 0000261E 0000000D
[   91.639953] PVR_K:   (MKT-1A6) 07200F4F 00000808 0000261E 0000000E
[   91.646453] PVR_K:   (MKT-1A7) 07200FB9 00000808 0000261E AD000184
[   91.653015] PVR_K:   (MKT-1A8) 0720101F 00000C08 0100271D AD000281
[   91.659729] PVR_K:   (MKT-1A9) 07201189 00000808 0100271D AD00080A
[   91.666412] PVR_K:   (MKT-1AA) 072011A2 00000808 0100271D 0F03C600
[   91.672943] PVR_K:   (MKT-1AB) 072011BA 00000808 0100271D 00000060
[   91.679473] PVR_K:   (MKT-1AC) 0720146B 00000808 0000271D AD000803
[   91.685974] PVR_K:   (MKT-1AD) 072014B1 00180CC8 0000271D AD000282
[   91.692535] PVR_K:   (MKT-1AE) 07201551 00000808 0100291F AD000200
[   91.699066] PVR_K:   (MKT-1AF) 07201769 00000808 0000291F AD000202
[   91.705566] PVR_K:   (MKT-1B0) 072017E8 00000808 00002A1E AD000183
[   91.712127] PVR_K:   (MKT-1B1) 072018D0 00000808 00002A1E AD00030E
[   91.718627] PVR_K:   (MKT-1B2) 072018E9 00000808 00002A1E 0D800474
[   91.725158] PVR_K:   (MKT-1B3) 07201902 00000808 00002A1E 0000000D
[   91.731689] PVR_K:   (MKT-1B4) 07201926 00000808 00002A1E 0000000E
[   91.738403] PVR_K:   (MKT-1B5) 07201990 00000808 00002A1E AD000184
[   91.745056] PVR_K:   (MKT-1B6) 072019F4 00000C08 01002B1D AD000281
[   91.751617] PVR_K:   (MKT-1B7) 07201B5D 00000808 01002B1D AD00080A
[   91.758117] PVR_K:   (MKT-1B8) 07201B76 00000808 01002B1D 0F03C900
[   91.764648] PVR_K:   (MKT-1B9) 07201B8E 00000808 01002B1D 00000060
[   91.771148] PVR_K:   (MKT-1BA) 07201E44 00000808 00002B1D AD000803
[   91.777740] PVR_K:   (MKT-1BB) 07201E8A 00180CC8 00002B1D AD000282
[   91.784301] PVR_K:   (MKT-1BC) 07201F73 00000808 01002D1F AD000200
[   91.790802] PVR_K:   (MKT-1BD) 0720218C 00000808 00002D1F AD000202
[   91.797332] PVR_K:   (MKT-1BE) 0720220C 00000808 00002E1E AD000183
[   91.803863] PVR_K:   (MKT-1BF) 072022F8 00000808 00002E1E AD00030E
[   91.810394] PVR_K:   (MKT-1C0) 07202310 00000808 00002E1E 0D800474
[   91.817108] PVR_K:   (MKT-1C1) 07202329 00000808 00002E1E 0000000D
[   91.823791] PVR_K:   (MKT-1C2) 0720234E 00000808 00002E1E 0000000E
[   91.830291] PVR_K:   (MKT-1C3) 072023BA 00000808 00002E1E AD000184
[   91.836853] PVR_K:   (MKT-1C4) 0720241E 00000C08 01002F1D AD000281
[   91.843353] PVR_K:   (MKT-1C5) 07202589 00000808 01002F1D AD00080A
[   91.849914] PVR_K:   (MKT-1C6) 072025A1 00000808 01002F1D 0F03CC00
[   91.856414] PVR_K:   (MKT-1C7) 072025B9 00000808 01002F1D 00000062
[   91.862976] PVR_K:   (MKT-1C8) 0720286C 00000808 00002F1D AD000803
[   91.869506] PVR_K:   (MKT-1C9) 072028B2 00180C88 00002F1D AD000282
[   91.876007] PVR_K:   (MKT-1CA) 072033AB 00000808 0100311F AD000200
[   91.882568] PVR_K:   (MKT-1CB) 072034C7 00000808 0100311F AD001703
[   91.889251] PVR_K:   (MKT-1CC) 072036A5 00000808 0000311F AD000202
[   91.895935] PVR_K:   (MKT-1CD) 07203723 00000808 0000321E AD000183
[   91.902465] PVR_K:   (MKT-1CE) 0720380B 00000808 0000321E AD00030E
[   91.909027] PVR_K:   (MKT-1CF) 07203824 00000808 0000321E 0D800474
[   91.915527] PVR_K:   (MKT-1D0) 0720383C 00000808 0000321E 0000000D
[   91.922088] PVR_K:   (MKT-1D1) 07203861 00000808 0000321E 0000000E
[   91.928619] PVR_K:   (MKT-1D2) 072038CB 00000808 0000321E AD000184
[   91.935150] PVR_K:   (MKT-1D3) 07203931 00000C08 0100331D AD000281
[   91.941650] PVR_K:   (MKT-1D4) 07203A49 00000808 0100331D AD000E02
[   91.948211] PVR_K:   (MKT-1D5) 07203AB9 00000808 0100331D AD000282
[   91.954772] PVR_K:   (MKT-1D6) 07210ABD 00000808 0100361F AD001A00
[   91.961273] PVR_K:   (MKT-1D7) 072216AD 00000808 0100391F AD00000A
[   91.968017] PVR_K:   (MKT-1D8) 0722170E 00000808 0100391F AD000909
[   91.974639] PVR_K:   (MKT-1D9) 07221758 00000808 0100391F AD001A05
[   91.981201] PVR_K:   (MKT-1DA) 07221789 00000808 0100391F AD001302
[   91.987701] PVR_K:   (MKT-1DB) 072217C9 00000808 0100391F AD001303
[   91.994262] PVR_K:   (MKT-1DC) 0722185D 00000808 0100391F AD000D04
[   92.000762] PVR_K:   (MKT-1DD) 0722192C 00000808 0100391F AD000D05
[   92.007354] PVR_K:   (MKT-1DE) 07221985 00000808 0100391F AD000D04
[   92.013824] PVR_K:   (MKT-1DF) 07221A09 00000808 0100391F AD000D05
[   92.020385] PVR_K:   (MKT-1E0) 07221A66 00000808 0100391F AD001A06
[   92.026916] PVR_K:   (MKT-1E1) 00000466 00100808 0100031F AD002300
[   92.033447] PVR_K:   (MKT-1E2) 00000938 00100808 0100041F AD00000A
[   92.040008] PVR_K:   (MKT-1E3) 000009B4 00100808 0100041F AD000906
[   92.046722] PVR_K:   (MKT-1E4) 00000A85 00100808 0000041F AD000901
[   92.053405] PVR_K:   (MKT-1E5) 00000AFE 00100808 0000051E AD000183
[   92.059906] PVR_K:   (MKT-1E6) 00000C73 00100808 0000051E AD000302
[   92.066467] PVR_K:   (MKT-1E7) 00000E00 00100808 0000051E AD000D06
[   92.072967] PVR_K:   (MKT-1E8) 00000EE6 00100808 0000051E AD000D07
[   92.079528] PVR_K:   (MKT-1E9) 00000F2F 00100808 0000051E AD001304
[   92.086059] PVR_K:   (MKT-1EA) 0000101F 00100808 0000051E AD001305
[   92.092620] PVR_K:   (MKT-1EB) 00001133 00100888 0000051E AD000404
[   92.099090] PVR_K:   (MKT-1EC) 000011F7 00100808 0000051E AD000402
[   92.105651] PVR_K:   (MKT-1ED) 0000123F 0010082B 0000051E AD000184
[   92.112152] PVR_K:   (MKT-1EE) 000012CA 00119DAD 0000061D AD000281
[   92.118713] PVR_K:   (MKT-1EF) 00001464 001009AF 0000061D AD000E02
[   92.127929] PVR_K:   (MKT-1F0) 000014C1 0010892B 0000061D AD000282
[   92.134582] PVR_K:   (MKT-1F1) 00003A68 00100808 0000081F AD000101
[   92.141113] PVR_K:   (MKT-1F2) 00003ADF 00100808 0000081F AD000104
[   92.147644] PVR_K:   (MKT-1F3) 00003B1C 00100808 0100091E AD000100
[   92.154174] PVR_K:   (MKT-1F4) 00003C18 00100808 0100091E AD000501
[   92.162200] PVR_K:   (MKT-1F5) 00003C57 0010082B 0100091E AD000104
[   92.169586] PVR_K:   (MKT-1F6) 00005EDB 00100828 01000A1F AD000101
[   92.179840] PVR_K:   (MKT-1F7) 00005F30 00100828 01000A1F AD000104
[   92.186523] PVR_K:   (MKT-1F8) 0000603E 00100808 01000B1F AD000100
[   92.193084] PVR_K:   (MKT-1F9) 000060FE 00100808 01000B1F AD000501
[   92.199798] PVR_K:   (MKT-1FA) 0000612A 00100829 01000B1F AD000104
[   92.206542] PVR_K:   (MKT-1FB) 00008656 00100828 01000D1F AD000101
[   92.213775] PVR_K:   (MKT-1FC) 000086CC 00100828 01000D1F AD000104
[   92.220397] PVR_K:   (MKT-1FD) 00008709 00100808 01000E1E AD000100
[   92.228637] PVR_K:   (MKT-1FE) 000087F6 00100808 01000E1E AD000501
[   92.235260] PVR_K:   (MKT-1FF) 00008837 0010082B 01000E1E AD000104
[   92.241943] PVR_K: SGX Kernel CCB WO:0xBA RO:0xBA
[   92.249176] adc_to_temp_conversion:Temp read is invalid 0
[   92.255157] thermal_lookup_temp: getting temp is not supported for domain pcb
[   92.264373] adc_to_temp_conversion:Temp read is invalid 0
[   92.270141] thermal_lookup_temp: getting temp is not supported for domain pcb
[   92.278625] adc_to_temp_conversion:Temp read is invalid 0
[   92.284637] thermal_lookup_temp: getting temp is not supported for domain pcb
[   92.451385] PVR_K:(Error): SGXOSTimer() detected SGX lockup (0xc tasks) [0, ]
[   92.459228] PVR_K: HWRecoveryResetSGX: SGX Hardware Recovery triggered
[   92.467102] [   66.357]                          [c6f10800] dsscomp_apply
[   92.467102] [   66.375]                          [c6e66c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   92.467102] [   66.375]     [c6fa4320] --refs=0 on RELEASED
[   92.467102] [   66.375]     [c6fa4320] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   92.497009] [   66.376]                          [c6e66c00] dsscomp_mgr_delayed_cb on RELEASED
[   92.497009] [   66.376]                          [c6f10800] dsscomp_mgr_delayed_cb on PROGRAMMED
[   92.497039] [   66.393]                          [c6f10800] dsscomp_mgr_delayed_cb on DISPLAYED
[   92.525329] [   72.154]  [c6fa4420] new in dsscomp_gralloc_queue (refs=1)
[   92.525329] [   72.154]                           [c6e66000] dsscomp_new
[   92.525329] [   72.154]  [c6fa4420] ++refs=2 for [c6e66000]
[   92.525329] [   72.154]                           [c6e66000] dsscomp_delayed_apply
[   92.525329] [   72.154]  [c6fa4420] --refs=1 on RELEASED
[   92.556671] [   72.154]                           [c6e66000] dsscomp_apply
[   92.556671] [   72.154]  [c6edbb80] --refs=0 on RELEASED
[   92.556671] [   72.154]  [c6edbb80] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   92.556671] [   72.154]                          [c6f10800] dsscomp_mgr_delayed_cb on RELEASED
[   92.586456] [   72.154]                           [c6e66000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   92.586486] [   72.155]       [c6edbcc0] new in dsscomp_gralloc_queue (refs=1)
[   92.586486] [   72.155]                       [c6f12c00] dsscomp_new
[   92.586486] [   72.155]       [c6edbcc0] ++refs=2 for [c6f12c00]
[   92.616241] [   72.155]                       [c6f12c00] dsscomp_delayed_apply
[   92.616241] [   72.155]       [c6edbcc0] --refs=1 on RELEASED
[   92.616241] [   72.155]                       [c6f12c00] dsscomp_apply
[   92.616241] [   72.176]                           [c6e66000] dsscomp_mgr_delayed_cb on DISPLAYED
[   92.646087] [   72.176]  [c6fa4420] --refs=0 on RELEASED
[   92.646087] [   72.176]  [c6fa4420] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   92.646087] [   72.176]                           [c6e66000] dsscomp_mgr_delayed_cb on RELEASED
[   92.646087] [   72.176]                       [c6f12c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   92.675933] [   72.191]                       [c6f12c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   92.675933] [   77.137]    [c6fa43c0] new in dsscomp_gralloc_queue (refs=1)
[   92.675933] [   77.137]                           [c6e67c00] dsscomp_new
[   92.704284] [   77.137]    [c6fa43c0] ++refs=2 for [c6e67c00]
[   92.704284] [   77.137]                           [c6e67c00] dsscomp_delayed_apply
[   92.704284] [   77.137]    [c6fa43c0] --refs=1 on RELEASED
[   92.704284] [   77.137]                           [c6e67c00] dsscomp_apply
[   92.734039] [   77.138]       [c6edbcc0] --refs=0 on RELEASED
[   92.734039] [   77.138]       [c6edbcc0] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   92.734069] [   77.138]                       [c6f12c00] dsscomp_mgr_delayed_cb on RELEASED
[   92.734069] [   77.138]                           [c6e67c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   92.763824] [   77.138]    [c6edbc00] new in dsscomp_gralloc_queue (refs=1)
[   92.763854] [   77.138]                         [c6f11400] dsscomp_new
[   92.763854] [   77.138]    [c6edbc00] ++refs=2 for [c6f11400]
[   92.763854] [   77.138]                         [c6f11400] dsscomp_delayed_apply
[   92.793609] [   77.138]    [c6edbc00] --refs=1 on RELEASED
[   92.793609] [   77.138]                         [c6f11400] dsscomp_apply
[   92.793609] [   77.152]                           [c6e67c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   92.793609] [   77.152]    [c6fa43c0] --refs=0 on RELEASED
[   92.823425] [   77.152]    [c6fa43c0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   92.823425] [   77.152]                           [c6e67c00] dsscomp_mgr_delayed_cb on RELEASED
[   92.823425] [   77.152]                         [c6f11400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   92.823455] [   77.154]    [c6fa44a0] new in dsscomp_gralloc_queue (refs=1)
[   92.853179] [   77.154]                           [c6e67c00] dsscomp_new
[   92.853179] [   77.154]    [c6fa44a0] ++refs=2 for [c6e67c00]
[   92.853179] [   77.154]                           [c6e67c00] dsscomp_delayed_apply
[   92.853210] [   77.154]    [c6fa44a0] --refs=1 on RELEASED
[   92.882995] [   77.154]                           [c6e67c00] dsscomp_apply
[   92.882995] [   77.171]                         [c6f11400] dsscomp_mgr_delayed_cb on DISPLAYED
[   92.882995] [   77.171]    [c6edbc00] --refs=0 on RELEASED
[   92.882995] [   77.171]    [c6edbc00] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   92.912811] [   77.171]                         [c6f11400] dsscomp_mgr_delayed_cb on RELEASED
[   92.912811] [   77.171]                           [c6e67c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   92.912811] [   77.186]                           [c6e67c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   92.941040] [   82.167]   [c6fa4460] new in dsscomp_gralloc_queue (refs=1)
[   92.941040] [   82.167]                           [c6e66000] dsscomp_new
[   92.941040] [   82.167]   [c6fa4460] ++refs=2 for [c6e66000]
[   92.941040] [   82.167]                           [c6e66000] dsscomp_delayed_apply
[   92.970825] [   82.167]   [c6fa4460] --refs=1 on RELEASED
[   92.970825] [   82.167]                           [c6e66000] dsscomp_apply
[   92.970825] [   82.167]    [c6fa44a0] --refs=0 on RELEASED
[   92.970825] [   82.167]    [c6fa44a0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   92.970855] [   82.167]                           [c6e67c00] dsscomp_mgr_delayed_cb on RELEASED
[   93.002105] [   82.167]                           [c6e66000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   93.002105] [   82.168]   [c6edbca0] new in dsscomp_gralloc_queue (refs=1)
[   93.002105] [   82.168]                          [c6f10800] dsscomp_new
[   93.030364] [   82.168]   [c6edbca0] ++refs=2 for [c6f10800]
[   93.030395] [   82.168]                          [c6f10800] dsscomp_delayed_apply
[   93.030395] [   82.168]   [c6edbca0] --refs=1 on RELEASED
[   93.030395] [   82.168]                          [c6f10800] dsscomp_apply
[   93.030395] [   82.183]                           [c6e66000] dsscomp_mgr_delayed_cb on DISPLAYED
[   93.061614] [   82.183]   [c6fa4460] --refs=0 on RELEASED
[   93.061614] [   82.183]   [c6fa4460] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   93.061614] [   82.183]                           [c6e66000] dsscomp_mgr_delayed_cb on RELEASED
[   93.089843] [   82.183]                          [c6f10800] dsscomp_mgr_delayed_cb on PROGRAMMED
[   93.089843] [   82.204]                          [c6f10800] dsscomp_mgr_delayed_cb on DISPLAYED
[   93.089843] [   87.162]    [c6edbdc0] new in dsscomp_gralloc_queue (refs=1)
[   93.118072] [   87.162]                       [c6f12c00] dsscomp_new
[   93.118072] [   87.162]    [c6edbdc0] ++refs=2 for [c6f12c00]
[   93.118072] [   87.162]                       [c6f12c00] dsscomp_delayed_apply
[   93.118072] [   87.162]    [c6edbdc0] --refs=1 on RELEASED
[   93.118072] [   87.162]                       [c6f12c00] dsscomp_apply
[   93.149383] [   87.162]   [c6edbca0] --refs=0 on RELEASED
[   93.149383] [   87.162]   [c6edbca0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   93.149383] [   87.162]                          [c6f10800] dsscomp_mgr_delayed_cb on RELEASED
[   93.149383] [   87.162]                       [c6f12c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   93.179199] [   87.163]    [c6edbce0] new in dsscomp_gralloc_queue (refs=1)
[   93.179199] [   87.163]                           [c6f13400] dsscomp_new
[   93.179229] [   87.163]    [c6edbce0] ++refs=2 for [c6f13400]
[   93.179229] [   87.163]                           [c6f13400] dsscomp_delayed_apply
[   93.208984] [   87.163]    [c6edbce0] --refs=1 on RELEASED
[   93.208984] [   87.163]                           [c6f13400] dsscomp_apply
[   93.208984] [   87.177]                       [c6f12c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   93.209014] [   87.177]    [c6edbdc0] --refs=0 on RELEASED
[   93.238739] [   87.177]    [c6edbdc0] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   93.238739] [   87.178]                       [c6f12c00] dsscomp_mgr_delayed_cb on RELEASED
[   93.238739] [   87.178]                           [c6f13400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   93.266998] [   87.199]                           [c6f13400] dsscomp_mgr_delayed_cb on DISPLAYED
[   93.266998] [   92.240]       [c6fa4720] new in dsscomp_gralloc_queue (refs=1)
[   93.266998] [   92.240]                       [c6e67400] dsscomp_new
[   93.266998] [   92.240]       [c6fa4720] ++refs=2 for [c6e67400]
[   93.296783] [   92.240]                       [c6e67400] dsscomp_delayed_apply
[   93.296813] [   92.240]       [c6fa4720] --refs=1 on RELEASED
[   93.296813] [   92.240]                       [c6e67400] dsscomp_apply
[   93.296813] [   92.240]    [c6edbce0] --refs=0 on RELEASED
[   93.296813] [   92.240]    [c6edbce0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   93.328094] [   92.240]                           [c6f13400] dsscomp_mgr_delayed_cb on RELEASED
[   93.328094] [   92.240]                       [c6e67400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   93.328094] [   92.241]      [c6edbc80] new in dsscomp_gralloc_queue (refs=1)
[   93.356384] [   92.241]                         [c6f13000] dsscomp_new
[   93.356384] [   92.241]      [c6edbc80] ++refs=2 for [c6f13000]
[   93.356384] [   92.241]                         [c6f13000] dsscomp_delayed_apply
[   93.356384] [   92.241]      [c6edbc80] --refs=1 on RELEASED
[   93.356414] [   92.241]                         [c6f13000] dsscomp_apply
[   93.387664] [   92.256]                       [c6e67400] dsscomp_mgr_delayed_cb on DISPLAYED
[   93.387664] [   92.256]       [c6fa4720] --refs=0 on RELEASED
[   93.387664] [   92.256]       [c6fa4720] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   93.415954] [   92.256]                       [c6e67400] dsscomp_mgr_delayed_cb on RELEASED
[   93.415954] [   92.256]                         [c6f13000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   93.415954] [   92.277]                         [c6f13000] dsscomp_mgr_delayed_cb on DISPLAYED
[   93.444274] ACTIVE COMPOSITIONS on lcd
[   93.444305]
[   93.444305]   [c6f13000]: DISPLAYED
[   93.444305]     sync_id=0, flags=AD-
[   93.444305]     ovl0={ON z0 ARGB32-8888 premult *100% 864*480:0,0+864,480 rot0 => 0,0+864,480 7f9ac000/  (null)|3456}
[   93.444305]     gsync=[c6edbc80] dsscomp_gralloc_cb
[   93.444305]
[   93.444305]   DISPC pipeline:
[   93.444305]
[   93.444305]     info:        clean (none)
[   93.483093]     cache:       clean (none)
[   93.483093]     shadow:  ACT clean (none)
[   93.483093]     dispc:   DISPLAYED mask=---R [c6f13000] dsscomp_mgr_callback
[   93.483093]
[   93.483123] ACTIVE COMPOSITIONS on tv
[   93.483123]
[   93.483123]   DISPC pipeline:
[   93.483123]
[   93.483123]     info:        clean (none)
[   93.483123]     cache:       clean (none)
[   93.483123]     shadow:  off clean (none)
[   93.523590]     dispc:   DISPLAYED (none)
[   93.523590]
[   93.523590] ACTIVE COMPOSITIONS on lcd2
[   93.523620]
[   93.523620]   DISPC pipeline:
[   93.523620]
[   93.523620]     info:        clean (none)
[   93.523620]     cache:       clean (none)
[   93.523620]     shadow:  off clean (none)
[   93.523620]     dispc:             (none)
[   93.523620]
[   93.523620] ACTIVE GRALLOC FLIPS
[   93.523620]
[   93.523620]   [c6edbc80] (refs=1)
[   93.568664]     slots=[7f9ac000]
[   93.568664]     cmdcb=[c73f6480] dsscomp_proxy_cmdcomplete
[   93.568664]
[   93.568664]   |           lcd
[   93.568664]   | [c6f13000] DISPL'D
[   93.568664]   |     92.241  ACTIVE
[   93.568664]   |     92.241 APPLY'N
[   93.568664]   |     92.241 APPLIED
[   93.568664]   |     92.256 PROGR'D
[   93.568695]   |     92.277 DISPL'D
[   93.568695]
[   93.568695]
[   93.610229] PVR_K: SGX debug (blaze_android_sgx_ogles1_ogles2_GPL sgxddk 18 1.8@869593)
[   93.618774] PVR_K:(Error): SGX Register Base Address (Linear):   0xC8B20000 [0, ]
[   93.626770] PVR_K:(Error): SGX Register Base Address (Physical): 0x56000000 [0, ]
[   93.634796] PVR_K: (P0) EUR_CR_CORE_ID:          01140000
[   93.640594] PVR_K: (P0) EUR_CR_CORE_REVISION:    00010200
[   93.646392] PVR_K: (P0) EUR_CR_EVENT_STATUS:     20000000
[   93.652160] PVR_K: (P0) EUR_CR_EVENT_STATUS2:    00000008
[   93.657989] PVR_K: (P0) EUR_CR_BIF_CTRL:         00000000
[   93.663787] PVR_K: (P0) EUR_CR_BIF_INT_STAT:     00008000
[   93.669525] PVR_K: (P0) EUR_CR_BIF_FAULT:        00000000
[   93.675354] PVR_K: (P0) EUR_CR_BIF_MEM_REQ_STAT: 00000000
[   93.681121] PVR_K: (P0) EUR_CR_CLKGATECTL:       000AAA6A
[   93.686950] PVR_K: (P0) EUR_CR_PDS_PC_BASE:      00004038
[   93.692687] PVR_K: Flip Command Complete Data 0 for display device 1:
[   93.699615] PVR_K:   SRC 0: ROC DevVAddr:0xD800494 ROP:0x10 ROC:0xe, WOC DevVAddr:0xD800484 WOP:0x10 WOC:0xf
[   93.710083] PVR_K: Flip Command Complete Data 1 for display device 1:
[   93.716949] PVR_K:   SRC 0: (Not in use)
[   93.721130] PVR_K: SGX Host control:
[   93.725250] PVR_K:   (HC-0) 0x00000001 0x00000000 0x00000000 0x00000001
[   93.732299] PVR_K:   (HC-10) 0x00000010 0x0000000A 0x0005DC00 0x00000003
[   93.739349] PVR_K:   (HC-20) 0x00000000 0x00000001 0x00000000 0x00000015
[   93.746459] PVR_K:   (HC-30) 0x00000E4B 0xF39E3080 0x00000000 0x00000000
[   93.753540] PVR_K:   (HC-40) 0x00000000 0x087BF500 0x087C6300 0x087C3100
[   93.760650] PVR_K: SGX TA/3D control:
[   93.764587] PVR_K:   (T3C-0) 0x0F003000 0x0F003120 0x0F002000 0x00000000
[   93.771667] PVR_K:   (T3C-10) 0x00000001 0x00000002 0x00000001 0x0F00DD00
[   93.778808] PVR_K:   (T3C-20) 0x00000000 0x00000000 0x00000000 0x00000000
[   93.786041] PVR_K:   (T3C-30) 0x00000000 0x00000000 0x00000000 0x00000000
[   93.793212] PVR_K:   (T3C-40) 0x00000000 0x00000000 0x00000000 0x00000000
[   93.800384] PVR_K:   (T3C-50) 0x0F00DD00 0x00000000 0x00000000 0x0F00DD00
[   93.807586] PVR_K:   (T3C-60) 0x00000000 0x00000000 0x0F00DD00 0x00000000
[   93.814758] PVR_K:   (T3C-70) 0x00000000 0x0F00DD00 0x00000000 0x0F004000
[   93.821960] PVR_K:   (T3C-80) 0x000000CD 0x0001120F 0x00000000 0x0F00DEFC
[   93.829162] PVR_K:   (T3C-90) 0x00000000 0x0F000000 0xAB600000 0x0F03E400
[   93.836334] PVR_K:   (T3C-A0) 0x00000000 0x0F010760 0x0F00DD00 0x0F00DEFC
[   93.843536] PVR_K:   (T3C-B0) 0x0F0109A0 0x00000000 0x00000000 0x00000000
[   93.850677] PVR_K:   (T3C-C0) 0x00000000 0x00000000 0x00000000 0x00000000
[   93.857879] PVR_K:   (T3C-D0) 0x00000000 0x0000001F 0x0000001E 0x0F007000
[   93.865112] PVR_K:   (T3C-E0) 0x0F00D420 0x0F00E000 0x0F010720 0x0F010720
[   93.872283] PVR_K:   (T3C-F0) 0x00000000 0x000000B5 0x000000B5 0x00000000
[   93.879486] PVR_K:   (T3C-100) 0x00000003 0x00000000 0x00000000 0x00000001
[   93.886718] PVR_K:   (T3C-110) 0xB50C565C 0x0872E100 0x08787B00 0x08787B00
[   93.894042] PVR_K: Last SGX microkernel status code: AD000104
[   93.900177] PVR_K:   (MKT-0) 07263ABA 00000808 0000211E AD00030E
[   93.906524] PVR_K:   (MKT-1) 07263AD3 00000808 0000211E 0D800474
[   93.912902] PVR_K:   (MKT-2) 07263AEC 00000808 0000211E 0000000C
[   93.919219] PVR_K:   (MKT-3) 07263B14 00000808 0000211E 0000000D
[   93.925628] PVR_K:   (MKT-4) 07263B7E 00000808 0000211E AD000184
[   93.931976] PVR_K:   (MKT-5) 07263BE2 00000C08 0100221D AD000281
[   93.938659] PVR_K:   (MKT-6) 07263D56 00000808 0100221D AD00080A
[   93.944976] PVR_K:   (MKT-7) 07263D6F 00000808 0100221D 0F03AB00
[   93.951354] PVR_K:   (MKT-8) 07263D87 00000808 0100221D 00000061
[   93.957702] PVR_K:   (MKT-9) 07263EFA 00000808 0000221D AD000802
[   93.964080] PVR_K:   (MKT-A) 0726404A 00000808 0000221D AD000803
[   93.970397] PVR_K:   (MKT-B) 0726408F 00184EC8 0000221D AD000282
[   93.976745] PVR_K:   (MKT-C) 07265FE9 00000C08 0100251F AD000200
[   93.983062] PVR_K:   (MKT-D) 07266232 00000808 0000251F AD000202
[   93.989440] PVR_K:   (MKT-E) 072662BA 00000808 0000261E AD000183
[   93.995758] PVR_K:   (MKT-F) 072663A3 00000808 0000261E AD00030E
[   94.002136] PVR_K:   (MKT-10) 072663BC 00000808 0000261E 0D800474
[   94.008544] PVR_K:   (MKT-11) 072663D4 00000808 0000261E 0000000C
[   94.015014] PVR_K:   (MKT-12) 072663F8 00000808 0000261E 0000000D
[   94.021423] PVR_K:   (MKT-13) 07266461 00000808 0000261E AD000184
[   94.027893] PVR_K:   (MKT-14) 072664C6 00000C08 0100271D AD000281
[   94.034454] PVR_K:   (MKT-15) 0726662D 00000808 0100271D AD00080A
[   94.040863] PVR_K:   (MKT-16) 07266646 00000808 0100271D 0F03AE00
[   94.047302] PVR_K:   (MKT-17) 0726665E 00000808 0100271D 00000060
[   94.053710] PVR_K:   (MKT-18) 07266918 00000808 0000271D AD000803
[   94.060150] PVR_K:   (MKT-19) 07266966 00180CC8 0000271D AD000282
[   94.066589] PVR_K:   (MKT-1A) 07266A05 00000808 0100291F AD000200
[   94.073028] PVR_K:   (MKT-1B) 07266C20 00000808 0000291F AD000202
[   94.079437] PVR_K:   (MKT-1C) 07266CA1 00000808 00002A1E AD000183
[   94.085906] PVR_K:   (MKT-1D) 07266D8E 00000808 00002A1E AD00030E
[   94.092315] PVR_K:   (MKT-1E) 07266DA6 00000808 00002A1E 0D800474
[   94.098754] PVR_K:   (MKT-1F) 07266DBF 00000808 00002A1E 0000000C
[   94.105194] PVR_K:   (MKT-20) 07266DE5 00000808 00002A1E 0000000D
[   94.111663] PVR_K:   (MKT-21) 07266E50 00000808 00002A1E AD000184
[   94.118103] PVR_K:   (MKT-22) 07266EB7 00000C08 01002B1D AD000281
[   94.124572] PVR_K:   (MKT-23) 0726701F 00000808 01002B1D AD00080A
[   94.130981] PVR_K:   (MKT-24) 07267038 00000808 01002B1D 0F03B100
[   94.137420] PVR_K:   (MKT-25) 07267050 00000808 01002B1D 00000060
[   94.143920] PVR_K:   (MKT-26) 07267303 00000808 00002B1D AD000803
[   94.150329] PVR_K:   (MKT-27) 0726734D 00188CC8 00002B1D AD000282
[   94.156768] PVR_K:   (MKT-28) 07267436 00000808 01002D1F AD000200
[   94.163208] PVR_K:   (MKT-29) 0726764F 00000808 00002D1F AD000202
[   94.169677] PVR_K:   (MKT-2A) 072676CF 00000808 00002E1E AD000183
[   94.176086] PVR_K:   (MKT-2B) 072677B8 00000808 00002E1E AD00030E
[   94.182983] PVR_K:   (MKT-2C) 072677D0 00000808 00002E1E 0D800474
[   94.189392] PVR_K:   (MKT-2D) 072677E8 00000808 00002E1E 0000000C
[   94.195831] PVR_K:   (MKT-2E) 0726780B 00000808 00002E1E 0000000D
[   94.202270] PVR_K:   (MKT-2F) 07267876 00000808 00002E1E AD000184
[   94.208709] PVR_K:   (MKT-30) 072678DA 00000C08 01002F1D AD000281
[   94.215148] PVR_K:   (MKT-31) 07267A44 00000808 01002F1D AD00080A
[   94.221618] PVR_K:   (MKT-32) 07267A5D 00000808 01002F1D 0F03B400
[   94.228057] PVR_K:   (MKT-33) 07267A75 00000808 01002F1D 00000062
[   94.234527] PVR_K:   (MKT-34) 07267D25 00000808 00002F1D AD000803
[   94.240966] PVR_K:   (MKT-35) 07267D6C 00180C88 00002F1D AD000282
[   94.247375] PVR_K:   (MKT-36) 0726885F 00000808 0100311F AD000200
[   94.253845] PVR_K:   (MKT-37) 0726897B 00000808 0100311F AD001703
[   94.260253] PVR_K:   (MKT-38) 07268B65 00000808 0000311F AD000202
[   94.266723] PVR_K:   (MKT-39) 07268BE2 00000808 0000321E AD000183
[   94.273132] PVR_K:   (MKT-3A) 07268CCC 00000808 0000321E AD00030E
[   94.279602] PVR_K:   (MKT-3B) 07268CE4 00000808 0000321E 0D800474
[   94.286010] PVR_K:   (MKT-3C) 07268CFD 00000808 0000321E 0000000C
[   94.292480] PVR_K:   (MKT-3D) 07268D20 00000808 0000321E 0000000D
[   94.298889] PVR_K:   (MKT-3E) 07268D8C 00000808 0000321E AD000184
[   94.305358] PVR_K:   (MKT-3F) 07268DF0 00000C08 0100331D AD000281
[   94.311767] PVR_K:   (MKT-40) 07268F00 00000808 0100331D AD000E02
[   94.318267] PVR_K:   (MKT-41) 07268F75 00000808 0100331D AD000282
[   94.324676] PVR_K:   (MKT-42) 07276062 00000808 0100361F AD001A00
[   94.331115] PVR_K:   (MKT-43) 0728391E 00000808 0100391F AD00000A
[   94.337707] PVR_K:   (MKT-44) 07283980 00000808 0100391F AD000909
[   94.344238] PVR_K:   (MKT-45) 072839CE 00000808 0100391F AD001A05
[   94.350860] PVR_K:   (MKT-46) 07283A02 00000808 0100391F AD001302
[   94.357299] PVR_K:   (MKT-47) 07283A45 00000808 0100391F AD001303
[   94.363800] PVR_K:   (MKT-48) 07283AD6 00000808 0100391F AD000D04
[   94.370269] PVR_K:   (MKT-49) 07283BA9 00000808 0100391F AD000D05
[   94.376800] PVR_K:   (MKT-4A) 07283C04 00000808 0100391F AD000D04
[   94.383239] PVR_K:   (MKT-4B) 07283C8C 00000808 0100391F AD000D05
[   94.389770] PVR_K:   (MKT-4C) 07283CE9 00000808 0100391F AD001A06
[   94.396209] PVR_K:   (MKT-4D) 0000047B 00100808 0100031F AD002300
[   94.402679] PVR_K:   (MKT-4E) 00000952 00100808 0100041F AD00000A
[   94.409210] PVR_K:   (MKT-4F) 000009CF 00100808 0100041F AD000906
[   94.415740] PVR_K:   (MKT-50) 00000AA2 00100808 0000041F AD000901
[   94.422210] PVR_K:   (MKT-51) 00000B1D 00100808 0000051E AD000183
[   94.428710] PVR_K:   (MKT-52) 00000C92 00100808 0000051E AD000302
[   94.435150] PVR_K:   (MKT-53) 00000E14 00100808 0000051E AD000D06
[   94.441650] PVR_K:   (MKT-54) 00000EF9 00100808 0000051E AD000D07
[   94.448150] PVR_K:   (MKT-55) 00000F43 00100808 0000051E AD001304
[   94.454589] PVR_K:   (MKT-56) 00001032 00100808 0000051E AD001305
[   94.461120] PVR_K:   (MKT-57) 00001146 00100888 0000051E AD000404
[   94.467559] PVR_K:   (MKT-58) 0000120B 00100808 0000051E AD000402
[   94.474121] PVR_K:   (MKT-59) 00001254 0010082B 0000051E AD000184
[   94.480529] PVR_K:   (MKT-5A) 000012F6 00108DA9 0000061D AD000281
[   94.487030] PVR_K:   (MKT-5B) 00001484 001009AF 0000061D AD000E02
[   94.493499] PVR_K:   (MKT-5C) 000014E5 001008AF 0000061D AD000282
[   94.499969] PVR_K:   (MKT-5D) 00003A86 00100808 0000081F AD000101
[   94.506439] PVR_K:   (MKT-5E) 00003AFD 00100808 0000081F AD000104
[   94.512908] PVR_K:   (MKT-5F) 00003B39 00100808 0100091E AD000100
[   94.519378] PVR_K:   (MKT-60) 00003C2D 00100808 0100091E AD000501
[   94.525878] PVR_K:   (MKT-61) 00003C6F 0010082B 0100091E AD000104
[   94.532318] PVR_K:   (MKT-62) 00005EE6 00100828 01000A1F AD000101
[   94.538818] PVR_K:   (MKT-63) 00005F2B 00100828 01000A1F AD000104
[   94.545288] PVR_K:   (MKT-64) 00006045 00100808 01000B1F AD000100
[   94.551757] PVR_K:   (MKT-65) 00006101 00100808 01000B1F AD000501
[   94.558258] PVR_K:   (MKT-66) 0000612D 00100829 01000B1F AD000104
[   94.564727] PVR_K:   (MKT-67) 071F3382 00100808 0100031F AD000B00
[   94.571258] PVR_K:   (MKT-68) 071F33C6 00100808 0100031F AD000B03
[   94.577728] PVR_K:   (MKT-69) 071F344F 00100808 0100031F AD000B05
[   94.584197] PVR_K:   (MKT-6A) 071F34A3 00100808 0100031F AD000B06
[   94.590667] PVR_K:   (MKT-6B) 071F34D4 00100808 0100031F AD000B06
[   94.597167] PVR_K:   (MKT-6C) 071F3518 00100808 0100031F AD000B07
[   94.603607] PVR_K:   (MKT-6D) 071F353E 00100808 0100031F AD000B09
[   94.610076] PVR_K:   (MKT-6E) 071F3592 00100808 0100031F AD000B01
[   94.616577] PVR_K:   (MKT-6F) 071F35CE 00100808 0100031F AD002300
[   94.623107] PVR_K:   (MKT-70) 071F38E2 00100808 0100041F AD00000A
[   94.629577] PVR_K:   (MKT-71) 071F3962 00100808 0100041F AD000906
[   94.636047] PVR_K:   (MKT-72) 071F3A1E 00100808 0000041F AD000901
[   94.642486] PVR_K:   (MKT-73) 071F3A99 00100808 0000051E AD000183
[   94.648986] PVR_K:   (MKT-74) 071F3C09 00100808 0000051E AD000302
[   94.655487] PVR_K:   (MKT-75) 071F3C5F 00100808 0000051E AD000303
[   94.661926] PVR_K:   (MKT-76) 071F3CE5 00100808 0000051E AD000C01
[   94.668426] PVR_K:   (MKT-77) 071F3D0A 00100808 0000051E 0D800464
[   94.674865] PVR_K:   (MKT-78) 071F3D22 00100808 0000051E 0000000E
[   94.681365] PVR_K:   (MKT-79) 071F3F78 00100808 0000051E AD00030E
[   94.687805] PVR_K:   (MKT-7A) 071F3F90 00100808 0000051E 0D800494
[   94.694335] PVR_K:   (MKT-7B) 071F3FA9 00100808 0000051E 0000000C
[   94.700775] PVR_K:   (MKT-7C) 071F3FCD 00100808 0000051E 0000000D
[   94.707275] PVR_K:   (MKT-7D) 071F4046 00100808 0000051E AD000184
[   94.713714] PVR_K:   (MKT-7E) 071F40C4 00100C08 0100061D AD000281
[   94.720245] PVR_K:   (MKT-7F) 071F425D 00100808 0100061D AD00080A
[   94.726715] PVR_K:   (MKT-80) 071F4276 00100808 0100061D 0F03B700
[   94.733245] PVR_K:   (MKT-81) 071F428E 00100808 0100061D 00000061
[   94.739715] PVR_K:   (MKT-82) 071F43AA 00100C88 0100061D AD001300
[   94.746215] PVR_K:   (MKT-83) 071F9799 00100808 0000061D AD001301
[   94.752685] PVR_K:   (MKT-84) 071F98C1 00100888 0000061D AD000802
[   94.759185] PVR_K:   (MKT-85) 071F9A24 00100888 0000061D AD000803
[   94.765716] PVR_K:   (MKT-86) 071F9A72 001808C8 0000061D AD000282
[   94.772155] PVR_K:   (MKT-87) 071F9B53 00184EF8 0000081E AD00000A
[   94.778717] PVR_K:   (MKT-88) 071F9BD2 001808F8 0000081E AD000905
[   94.785125] PVR_K:   (MKT-89) 071F9CF6 001808B8 0000081E AD000901
[   94.791625] PVR_K:   (MKT-8A) 071F9D6A 00180838 0000091C AD00000A
[   94.798095] PVR_K:   (MKT-8B) 071F9DCB 00180838 0000091C AD000905
[   94.804595] PVR_K:   (MKT-8C) 071F9E73 00180838 0000091C AD000901
[   94.811035] PVR_K:   (MKT-8D) 071F9EC7 00180838 00000A1B AD00000A
[   94.817535] PVR_K:   (MKT-8E) 071F9F28 00180838 00000A1B AD000905
[   94.823974] PVR_K:   (MKT-8F) 071F9FD7 00180838 00000A1B AD000901
[   94.830505] PVR_K:   (MKT-90) 071FA032 00180838 00000B1A AD00000A
[   94.836975] PVR_K:   (MKT-91) 071FA0A0 00180838 00000B1A AD000905
[   94.843444] PVR_K:   (MKT-92) 071FA148 00180838 00000B1A AD000901
[   94.849884] PVR_K:   (MKT-93) 071FA19A 00180838 00000C19 AD00000A
[   94.856384] PVR_K:   (MKT-94) 071FA210 00180838 00000C19 AD000906
[   94.862884] PVR_K:   (MKT-95) 071FA28E 00180838 00000C19 AD000901
[   94.869384] PVR_K:   (MKT-96) 071FA3DF 00180838 00000F1F AD000183
[   94.875915] PVR_K:   (MKT-97) 071FA558 00180838 00000F1F AD000302
[   94.882385] PVR_K:   (MKT-98) 071FA5D0 00180838 00000F1F AD000303
[   94.888854] PVR_K:   (MKT-99) 071FA64C 00180838 00000F1F AD000C01
[   94.895324] PVR_K:   (MKT-9A) 071FA678 00180838 00000F1F 0D800484
[   94.901855] PVR_K:   (MKT-9B) 071FA690 00180838 00000F1F 0000000E
[   94.908294] PVR_K:   (MKT-9C) 071FA8B1 00180838 00000F1F AD000184
[   94.914825] PVR_K:   (MKT-9D) 071FA922 00180C38 0100101D AD000281
[   94.921264] PVR_K:   (MKT-9E) 071FA978 00180838 0100101D AD000282
[   94.927795] PVR_K:   (MKT-9F) 071FB5E7 00180838 0100111F AD00000A
[   94.934234] PVR_K:   (MKT-A0) 071FB651 00180838 0100111F AD000905
[   94.940673] PVR_K:   (MKT-A1) 071FB753 00180838 0000111F AD000901
[   94.947113] PVR_K:   (MKT-A2) 071FB7A6 00180C38 0100121E AD000281
[   94.953613] PVR_K:   (MKT-A3) 071FB801 00180838 0100121E AD000282
[   94.960083] PVR_K:   (MKT-A4) 071FB8DF 00180838 0100131F AD00000A
[   94.966552] PVR_K:   (MKT-A5) 071FB949 00180838 0100131F AD000905
[   94.973052] PVR_K:   (MKT-A6) 071FBA47 00180838 0000131F AD000901
[   94.979522] PVR_K:   (MKT-A7) 071FBA99 00180C38 0100141E AD000281
[   94.986022] PVR_K:   (MKT-A8) 071FBAF5 00100828 0100141E AD000282
[   94.992492] PVR_K:   (MKT-A9) 071FBBEE 00000888 0100151F AD00000A
[   94.998992] PVR_K:   (MKT-AA) 071FBC59 00000808 0000151F AD000905
[   95.005432] PVR_K:   (MKT-AB) 071FBD54 00000808 0000151F AD000901
[   95.011932] PVR_K:   (MKT-AC) 071FBD8A 00000C08 0000161E AD000200
[   95.018402] PVR_K:   (MKT-AD) 071FBFDB 00000808 0000161E AD000202
[   95.024932] PVR_K:   (MKT-AE) 071FC032 00000808 0000171D AD000281
[   95.031402] PVR_K:   (MKT-AF) 071FC17D 00000808 0000171D AD00080A
[   95.037872] PVR_K:   (MKT-B0) 071FC196 00000808 0000171D 0F03BA00
[   95.044342] PVR_K:   (MKT-B1) 071FC1AF 00000808 0000171D 00000060
[   95.050811] PVR_K:   (MKT-B2) 071FC469 00000808 0000171D AD000803
[   95.057220] PVR_K:   (MKT-B3) 071FC4B0 00180CC8 0000171D AD000282
[   95.063659] PVR_K:   (MKT-B4) 071FC562 00000808 0000181F AD00000A
[   95.070098] PVR_K:   (MKT-B5) 071FC5CA 00000808 0000181F AD000905
[   95.076507] PVR_K:   (MKT-B6) 071FC6C1 00000888 0000181F AD000901
[   95.083007] PVR_K:   (MKT-B7) 071FC70B 00000C08 00001A1D AD000200
[   95.089477] PVR_K:   (MKT-B8) 071FC93D 00000808 00001A1D AD000202
[   95.095947] PVR_K:   (MKT-B9) 071FC998 00000808 01001B1C AD000281
[   95.102416] PVR_K:   (MKT-BA) 071FCAE8 00000808 01001B1C AD00080A
[   95.109100] PVR_K:   (MKT-BB) 071FCB00 00000808 01001B1C 0F03BD00
[   95.115631] PVR_K:   (MKT-BC) 071FCB18 00000808 01001B1C 00000060
[   95.122070] PVR_K:   (MKT-BD) 071FCDCD 00000808 00001B1C AD000803
[   95.128509] PVR_K:   (MKT-BE) 071FCE13 00180CC8 00001B1C AD000282
[   95.135009] PVR_K:   (MKT-BF) 071FCF02 00000808 01001D1F AD000200
[   95.141479] PVR_K:   (MKT-C0) 071FD139 00000808 00001D1F AD000202
[   95.147979] PVR_K:   (MKT-C1) 071FD18A 00000808 01001E1E AD000281
[   95.154418] PVR_K:   (MKT-C2) 071FD2E3 00000808 01001E1E AD00080A
[   95.160919] PVR_K:   (MKT-C3) 071FD2FC 00000808 01001E1E 0F03C000
[   95.167358] PVR_K:   (MKT-C4) 071FD314 00000808 01001E1E 00000062
[   95.173858] PVR_K:   (MKT-C5) 071FD5D1 00000808 00001E1E AD000803
[   95.180389] PVR_K:   (MKT-C6) 071FD618 00180C88 00001E1E AD000282
[   95.186828] PVR_K:   (MKT-C7) 071FE180 00000808 0100201F AD000200
[   95.193328] PVR_K:   (MKT-C8) 071FE29A 00000808 0100201F AD001703
[   95.199798] PVR_K:   (MKT-C9) 071FE49B 00000808 0000201F AD000202
[   95.206298] PVR_K:   (MKT-CA) 071FE517 00000808 0000211E AD000183
[   95.212799] PVR_K:   (MKT-CB) 071FE604 00000808 0000211E AD00030E
[   95.219299] PVR_K:   (MKT-CC) 071FE61C 00000808 0000211E 0D800474
[   95.225769] PVR_K:   (MKT-CD) 071FE635 00000808 0000211E 0000000D
[   95.232269] PVR_K:   (MKT-CE) 071FE658 00000808 0000211E 0000000E
[   95.238739] PVR_K:   (MKT-CF) 071FE6C2 00000808 0000211E AD000184
[   95.245239] PVR_K:   (MKT-D0) 071FE728 00000C08 0100221D AD000281
[   95.251708] PVR_K:   (MKT-D1) 071FE8A2 00000808 0100221D AD00080A
[   95.258209] PVR_K:   (MKT-D2) 071FE8BB 00000808 0100221D 0F03C300
[   95.264678] PVR_K:   (MKT-D3) 071FE8D3 00000808 0100221D 00000061
[   95.271209] PVR_K:   (MKT-D4) 071FEA4E 00000808 0000221D AD000802
[   95.277679] PVR_K:   (MKT-D5) 071FEB9E 00000808 0000221D AD000803
[   95.284149] PVR_K:   (MKT-D6) 071FEBE9 00184EC8 0000221D AD000282
[   95.290649] PVR_K:   (MKT-D7) 07200B3A 00000C08 0100251F AD000200
[   95.297088] PVR_K:   (MKT-D8) 07200D84 00000808 0000251F AD000202
[   95.303558] PVR_K:   (MKT-D9) 07200E0D 00000808 0000261E AD000183
[   95.309967] PVR_K:   (MKT-DA) 07200EFA 00000808 0000261E AD00030E
[   95.316436] PVR_K:   (MKT-DB) 07200F12 00000808 0000261E 0D800474
[   95.322845] PVR_K:   (MKT-DC) 07200F2A 00000808 0000261E 0000000D
[   95.329345] PVR_K:   (MKT-DD) 07200F4F 00000808 0000261E 0000000E
[   95.335754] PVR_K:   (MKT-DE) 07200FB9 00000808 0000261E AD000184
[   95.342193] PVR_K:   (MKT-DF) 0720101F 00000C08 0100271D AD000281
[   95.348632] PVR_K:   (MKT-E0) 07201189 00000808 0100271D AD00080A
[   95.355102] PVR_K:   (MKT-E1) 072011A2 00000808 0100271D 0F03C600
[   95.361511] PVR_K:   (MKT-E2) 072011BA 00000808 0100271D 00000060
[   95.367980] PVR_K:   (MKT-E3) 0720146B 00000808 0000271D AD000803
[   95.374389] PVR_K:   (MKT-E4) 072014B1 00180CC8 0000271D AD000282
[   95.380859] PVR_K:   (MKT-E5) 07201551 00000808 0100291F AD000200
[   95.387359] PVR_K:   (MKT-E6) 07201769 00000808 0000291F AD000202
[   95.393768] PVR_K:   (MKT-E7) 072017E8 00000808 00002A1E AD000183
[   95.400238] PVR_K:   (MKT-E8) 072018D0 00000808 00002A1E AD00030E
[   95.406677] PVR_K:   (MKT-E9) 072018E9 00000808 00002A1E 0D800474
[   95.413146] PVR_K:   (MKT-EA) 07201902 00000808 00002A1E 0000000D
[   95.419555] PVR_K:   (MKT-EB) 07201926 00000808 00002A1E 0000000E
[   95.426025] PVR_K:   (MKT-EC) 07201990 00000808 00002A1E AD000184
[   95.432434] PVR_K:   (MKT-ED) 072019F4 00000C08 01002B1D AD000281
[   95.438903] PVR_K:   (MKT-EE) 07201B5D 00000808 01002B1D AD00080A
[   95.445343] PVR_K:   (MKT-EF) 07201B76 00000808 01002B1D 0F03C900
[   95.451812] PVR_K:   (MKT-F0) 07201B8E 00000808 01002B1D 00000060
[   95.458221] PVR_K:   (MKT-F1) 07201E44 00000808 00002B1D AD000803
[   95.464691] PVR_K:   (MKT-F2) 07201E8A 00180CC8 00002B1D AD000282
[   95.471099] PVR_K:   (MKT-F3) 07201F73 00000808 01002D1F AD000200
[   95.477569] PVR_K:   (MKT-F4) 0720218C 00000808 00002D1F AD000202
[   95.484039] PVR_K:   (MKT-F5) 0720220C 00000808 00002E1E AD000183
[   95.490447] PVR_K:   (MKT-F6) 072022F8 00000808 00002E1E AD00030E
[   95.496917] PVR_K:   (MKT-F7) 07202310 00000808 00002E1E 0D800474
[   95.503326] PVR_K:   (MKT-F8) 07202329 00000808 00002E1E 0000000D
[   95.509796] PVR_K:   (MKT-F9) 0720234E 00000808 00002E1E 0000000E
[   95.516204] PVR_K:   (MKT-FA) 072023BA 00000808 00002E1E AD000184
[   95.522705] PVR_K:   (MKT-FB) 0720241E 00000C08 01002F1D AD000281
[   95.529113] PVR_K:   (MKT-FC) 07202589 00000808 01002F1D AD00080A
[   95.535583] PVR_K:   (MKT-FD) 072025A1 00000808 01002F1D 0F03CC00
[   95.541992] PVR_K:   (MKT-FE) 072025B9 00000808 01002F1D 00000062
[   95.548461] PVR_K:   (MKT-FF) 0720286C 00000808 00002F1D AD000803
[   95.554870] PVR_K:   (MKT-100) 072028B2 00180C88 00002F1D AD000282
[   95.561431] PVR_K:   (MKT-101) 072033AB 00000808 0100311F AD000200
[   95.567901] PVR_K:   (MKT-102) 072034C7 00000808 0100311F AD001703
[   95.574462] PVR_K:   (MKT-103) 072036A5 00000808 0000311F AD000202
[   95.581024] PVR_K:   (MKT-104) 07203723 00000808 0000321E AD000183
[   95.587524] PVR_K:   (MKT-105) 0720380B 00000808 0000321E AD00030E
[   95.594085] PVR_K:   (MKT-106) 07203824 00000808 0000321E 0D800474
[   95.600616] PVR_K:   (MKT-107) 0720383C 00000808 0000321E 0000000D
[   95.607147] PVR_K:   (MKT-108) 07203861 00000808 0000321E 0000000E
[   95.613677] PVR_K:   (MKT-109) 072038CB 00000808 0000321E AD000184
[   95.620208] PVR_K:   (MKT-10A) 07203931 00000C08 0100331D AD000281
[   95.626708] PVR_K:   (MKT-10B) 07203A49 00000808 0100331D AD000E02
[   95.633300] PVR_K:   (MKT-10C) 07203AB9 00000808 0100331D AD000282
[   95.639801] PVR_K:   (MKT-10D) 07210ABD 00000808 0100361F AD001A00
[   95.646362] PVR_K:   (MKT-10E) 072216AD 00000808 0100391F AD00000A
[   95.652862] PVR_K:   (MKT-10F) 0722170E 00000808 0100391F AD000909
[   95.659423] PVR_K:   (MKT-110) 07221758 00000808 0100391F AD001A05
[   95.665954] PVR_K:   (MKT-111) 07221789 00000808 0100391F AD001302
[   95.672485] PVR_K:   (MKT-112) 072217C9 00000808 0100391F AD001303
[   95.679016] PVR_K:   (MKT-113) 0722185D 00000808 0100391F AD000D04
[   95.685516] PVR_K:   (MKT-114) 0722192C 00000808 0100391F AD000D05
[   95.692077] PVR_K:   (MKT-115) 07221985 00000808 0100391F AD000D04
[   95.698577] PVR_K:   (MKT-116) 07221A09 00000808 0100391F AD000D05
[   95.705139] PVR_K:   (MKT-117) 07221A66 00000808 0100391F AD001A06
[   95.711669] PVR_K:   (MKT-118) 00000466 00100808 0100031F AD002300
[   95.718200] PVR_K:   (MKT-119) 00000938 00100808 0100041F AD00000A
[   95.724700] PVR_K:   (MKT-11A) 000009B4 00100808 0100041F AD000906
[   95.731262] PVR_K:   (MKT-11B) 00000A85 00100808 0000041F AD000901
[   95.737762] PVR_K:   (MKT-11C) 00000AFE 00100808 0000051E AD000183
[   95.744323] PVR_K:   (MKT-11D) 00000C73 00100808 0000051E AD000302
[   95.750885] PVR_K:   (MKT-11E) 00000E00 00100808 0000051E AD000D06
[   95.757446] PVR_K:   (MKT-11F) 00000EE6 00100808 0000051E AD000D07
[   95.764160] PVR_K:   (MKT-120) 00000F2F 00100808 0000051E AD001304
[   95.770660] PVR_K:   (MKT-121) 0000101F 00100808 0000051E AD001305
[   95.777221] PVR_K:   (MKT-122) 00001133 00100888 0000051E AD000404
[   95.783721] PVR_K:   (MKT-123) 000011F7 00100808 0000051E AD000402
[   95.790313] PVR_K:   (MKT-124) 0000123F 0010082B 0000051E AD000184
[   95.796844] PVR_K:   (MKT-125) 000012CA 00119DAD 0000061D AD000281
[   95.804321] PVR_K:   (MKT-126) 00001464 001009AF 0000061D AD000E02
[   95.819244] PVR_K:   (MKT-127) 000014C1 0010892B 0000061D AD000282
[   95.825866] PVR_K:   (MKT-128) 00003A68 00100808 0000081F AD000101
[   95.833129] PVR_K:   (MKT-129) 00003ADF 00100808 0000081F AD000104
[   95.839721] PVR_K:   (MKT-12A) 00003B1C 00100808 0100091E AD000100
[   95.847015] PVR_K:   (MKT-12B) 00003C18 00100808 0100091E AD000501
[   95.853546] PVR_K:   (MKT-12C) 00003C57 0010082B 0100091E AD000104
[   95.860137] PVR_K:   (MKT-12D) 00005EDB 00100828 01000A1F AD000101
[   95.866668] PVR_K:   (MKT-12E) 00005F30 00100828 01000A1F AD000104
[   95.873199] PVR_K:   (MKT-12F) 0000603E 00100808 01000B1F AD000100
[   95.879699] PVR_K:   (MKT-130) 000060FE 00100808 01000B1F AD000501
[   95.886413] PVR_K:   (MKT-131) 0000612A 00100829 01000B1F AD000104
[   95.892913] PVR_K:   (MKT-132) 00008656 00100828 01000D1F AD000101
[   95.899444] PVR_K:   (MKT-133) 000086CC 00100828 01000D1F AD000104
[   95.905944] PVR_K:   (MKT-134) 00008709 00100808 01000E1E AD000100
[   95.912475] PVR_K:   (MKT-135) 000087F6 00100808 01000E1E AD000501
[   95.919006] PVR_K:   (MKT-136) 00008837 0010082B 01000E1E AD000104
[   95.925537] PVR_K:   (MKT-137) 073DFDD3 00100808 0100031F AD000B00
[   95.932098] PVR_K:   (MKT-138) 073DFE1A 00100808 0100031F AD000B03
[   95.938659] PVR_K:   (MKT-139) 073DFEA1 00100808 0100031F AD000B05
[   95.952056] PVR_K:   (MKT-13A) 073DFEF5 00100808 0100031F AD000B06
[   95.958557] PVR_K:   (MKT-13B) 073DFF24 00100808 0100031F AD000B06
[   95.981323] PVR_K:   (MKT-13C) 073DFF6A 00100808 0100031F AD000B07
[   95.995666] PVR_K:   (MKT-13D) 073DFF90 00100808 0100031F AD000B09
[   96.002593] PVR_K:   (MKT-13E) 073DFFE6 00100808 0100031F AD000B01
[   96.014556] PVR_K:   (MKT-13F) 073E0022 00100808 0100031F AD002300
[   96.021118] PVR_K:   (MKT-140) 073E0360 00100808 0100041F AD00000A
[   96.028686] PVR_K:   (MKT-141) 073E03E1 00100808 0100041F AD000906
[   96.035278] PVR_K:   (MKT-142) 073E049C 00100808 0000041F AD000901
[   96.041839] PVR_K:   (MKT-143) 073E0517 00100808 0000051E AD000183
[   96.048400] PVR_K:   (MKT-144) 073E0688 00100808 0000051E AD000302
[   96.054962] PVR_K:   (MKT-145) 073E06DB 00100808 0000051E AD000303
[   96.061462] PVR_K:   (MKT-146) 073E0762 00100808 0000051E AD000C01
[   96.067993] PVR_K:   (MKT-147) 073E0786 00100808 0000051E 0D800464
[   96.074493] PVR_K:   (MKT-148) 073E079E 00100808 0000051E 0000000F
[   96.081054] PVR_K:   (MKT-149) 073E09F2 00100808 0000051E AD00030E
[   96.087554] PVR_K:   (MKT-14A) 073E0A0B 00100808 0000051E 0D800494
[   96.094085] PVR_K:   (MKT-14B) 073E0A24 00100808 0000051E 0000000D
[   96.100585] PVR_K:   (MKT-14C) 073E0A47 00100808 0000051E 0000000E
[   96.107116] PVR_K:   (MKT-14D) 073E0AC4 00100808 0000051E AD000184
[   96.113616] PVR_K:   (MKT-14E) 073E0B46 00100C08 0100061D AD000281
[   96.120147] PVR_K:   (MKT-14F) 073E0CDF 00100808 0100061D AD00080A
[   96.126647] PVR_K:   (MKT-150) 073E0CF8 00100808 0100061D 0F03CF00
[   96.133178] PVR_K:   (MKT-151) 073E0D10 00100808 0100061D 00000061
[   96.139770] PVR_K:   (MKT-152) 073E0E2D 00100C88 0100061D AD001300
[   96.146270] PVR_K:   (MKT-153) 073E6271 00100808 0000061D AD001301
[   96.152801] PVR_K:   (MKT-154) 073E63AA 00100888 0000061D AD000802
[   96.159301] PVR_K:   (MKT-155) 073E6513 00100888 0000061D AD000803
[   96.165832] PVR_K:   (MKT-156) 073E6561 001808C8 0000061D AD000282
[   96.172332] PVR_K:   (MKT-157) 073E6641 00184AF8 0000081E AD00000A
[   96.178894] PVR_K:   (MKT-158) 073E66C9 00184AF8 0000081E AD000905
[   96.185363] PVR_K:   (MKT-159) 073E67E8 001808B8 0000081E AD000901
[   96.191925] PVR_K:   (MKT-15A) 073E685D 00180838 0000091C AD00000A
[   96.198394] PVR_K:   (MKT-15B) 073E68D4 00180838 0000091C AD000906
[   96.204956] PVR_K:   (MKT-15C) 073E6945 00180838 0000091C AD000901
[   96.211456] PVR_K:   (MKT-15D) 073E699D 00180838 00000A1B AD00000A
[   96.217987] PVR_K:   (MKT-15E) 073E6A05 00180838 00000A1B AD000905
[   96.224517] PVR_K:   (MKT-15F) 073E6AAC 00180838 00000A1B AD000901
[   96.231018] PVR_K:   (MKT-160) 073E6B04 00180838 00000B1A AD00000A
[   96.237548] PVR_K:   (MKT-161) 073E6B69 00180838 00000B1A AD000905
[   96.244049] PVR_K:   (MKT-162) 073E6C1C 00180838 00000B1A AD000901
[   96.250610] PVR_K:   (MKT-163) 073E6C71 00180838 00000C19 AD00000A
[   96.257080] PVR_K:   (MKT-164) 073E6CD6 00180838 00000C19 AD000905
[   96.263610] PVR_K:   (MKT-165) 073E6D7F 00180838 00000C19 AD000901
[   96.270111] PVR_K:   (MKT-166) 073E6EDE 00180838 00000F1F AD000183
[   96.276641] PVR_K:   (MKT-167) 073E705B 00180838 00000F1F AD000302
[   96.283142] PVR_K:   (MKT-168) 073E70DD 00180838 00000F1F AD000303
[   96.289703] PVR_K:   (MKT-169) 073E715B 00180838 00000F1F AD000C01
[   96.296173] PVR_K:   (MKT-16A) 073E7180 00180838 00000F1F 0D800484
[   96.302673] PVR_K:   (MKT-16B) 073E7199 00180838 00000F1F 0000000F
[   96.309204] PVR_K:   (MKT-16C) 073E73C9 00180838 00000F1F AD000184
[   96.315704] PVR_K:   (MKT-16D) 073E7439 00180C38 0100101D AD000281
[   96.322235] PVR_K:   (MKT-16E) 073E7491 00180838 0100101D AD000282
[   96.328735] PVR_K:   (MKT-16F) 073E828F 00180838 0100111F AD00000A
[   96.335296] PVR_K:   (MKT-170) 073E82FB 00180838 0100111F AD000905
[   96.341766] PVR_K:   (MKT-171) 073E8407 00180838 0000111F AD000901
[   96.348327] PVR_K:   (MKT-172) 073E8459 00180C38 0100121E AD000281
[   96.354827] PVR_K:   (MKT-173) 073E84B2 00180838 0100121E AD000282
[   96.361358] PVR_K:   (MKT-174) 073E8600 00180838 0100131F AD00000A
[   96.367858] PVR_K:   (MKT-175) 073E866B 00100828 0100131F AD000905
[   96.374389] PVR_K:   (MKT-176) 073E8765 00000808 0000131F AD000901
[   96.380950] PVR_K:   (MKT-177) 073E879B 00000C08 0000141E AD000200
[   96.387451] PVR_K:   (MKT-178) 073E89EA 00000808 0000141E AD000202
[   96.394012] PVR_K:   (MKT-179) 073E8A42 00000808 0000151D AD000281
[   96.400512] PVR_K:   (MKT-17A) 073E8B8B 00000808 0000151D AD00080A
[   96.407043] PVR_K:   (MKT-17B) 073E8BA3 00000808 0000151D 0F03D200
[   96.413543] PVR_K:   (MKT-17C) 073E8BBB 00000808 0000151D 00000060
[   96.420074] PVR_K:   (MKT-17D) 073E8E7D 00000808 0000151D AD000803
[   96.426574] PVR_K:   (MKT-17E) 073E8EC3 00180CC8 0000151D AD000282
[   96.433105] PVR_K:   (MKT-17F) 073E8F75 00000808 0000161F AD00000A
[   96.439605] PVR_K:   (MKT-180) 073E8FDE 00000808 0000161F AD000905
[   96.446166] PVR_K:   (MKT-181) 073E90D6 00000888 0000161F AD000901
[   96.452667] PVR_K:   (MKT-182) 073E9140 00000808 0000171E AD00000A
[   96.459197] PVR_K:   (MKT-183) 073E919F 00000808 0000171E AD000905
[   96.465728] PVR_K:   (MKT-184) 073E9244 00000808 0000171E AD000901
[   96.472229] PVR_K:   (MKT-185) 073E928E 00000C08 0000191D AD000200
[   96.478790] PVR_K:   (MKT-186) 073E94BA 00000808 0000191D AD000202
[   96.485290] PVR_K:   (MKT-187) 073E9516 00000808 01001A1B AD000281
[   96.491821] PVR_K:   (MKT-188) 073E9662 00000808 01001A1B AD00080A
[   96.498321] PVR_K:   (MKT-189) 073E967B 00000808 01001A1B 0F03D500
[   96.504852] PVR_K:   (MKT-18A) 073E9693 00000808 01001A1B 00000060
[   96.511352] PVR_K:   (MKT-18B) 073E994F 00000808 00001A1B AD000803
[   96.517913] PVR_K:   (MKT-18C) 073E9998 00180CC8 00001A1B AD000282
[   96.524414] PVR_K:   (MKT-18D) 073E9A80 00000808 01001C1F AD000200
[   96.530944] PVR_K:   (MKT-18E) 073E9CAD 00000808 00001C1F AD000202
[   96.537445] PVR_K:   (MKT-18F) 073E9CFA 00000808 01001D1E AD000281
[   96.544006] PVR_K:   (MKT-190) 073E9E49 00000808 01001D1E AD00080A
[   96.550537] PVR_K:   (MKT-191) 073E9E62 00000808 01001D1E 0F03D800
[   96.557037] PVR_K:   (MKT-192) 073E9E7B 00000808 01001D1E 00000062
[   96.563598] PVR_K:   (MKT-193) 073EA135 00000808 00001D1E AD000803
[   96.570098] PVR_K:   (MKT-194) 073EA180 00180C88 00001D1E AD000282
[   96.576629] PVR_K:   (MKT-195) 073EACE2 00000808 01001F1F AD000200
[   96.583129] PVR_K:   (MKT-196) 073EAE03 00000808 01001F1F AD001703
[   96.589660] PVR_K:   (MKT-197) 073EB003 00000808 00001F1F AD000202
[   96.596160] PVR_K:   (MKT-198) 073EB081 00000808 0000201E AD000183
[   96.602722] PVR_K:   (MKT-199) 073EB16D 00000808 0000201E AD00030E
[   96.609222] PVR_K:   (MKT-19A) 073EB185 00000808 0000201E 0D800474
[   96.615753] PVR_K:   (MKT-19B) 073EB19F 00000808 0000201E 0000000E
[   96.622253] PVR_K:   (MKT-19C) 073EB1C2 00000808 0000201E 0000000F
[   96.628814] PVR_K:   (MKT-19D) 073EB22D 00000808 0000201E AD000184
[   96.635345] PVR_K:   (MKT-19E) 073EB295 00000C08 0100211D AD000281
[   96.642028] PVR_K:   (MKT-19F) 073EB41A 00000808 0100211D AD00080A
[   96.648620] PVR_K:   (MKT-1A0) 073EB433 00000808 0100211D 0F03DB00
[   96.655120] PVR_K:   (MKT-1A1) 073EB44B 00000808 0100211D 00000061
[   96.661651] PVR_K:   (MKT-1A2) 073EB5CB 00000808 0000211D AD000802
[   96.668151] PVR_K:   (MKT-1A3) 073EB722 00000808 0000211D AD000803
[   96.674713] PVR_K:   (MKT-1A4) 073EB76B 00184EC8 0000211D AD000282
[   96.681396] PVR_K:   (MKT-1A5) 073ED72C 00000C08 0100241F AD000200
[   96.688049] PVR_K:   (MKT-1A6) 073ED986 00000808 0000241F AD000202
[   96.694793] PVR_K:   (MKT-1A7) 073EDA10 00000808 0000251E AD000183
[   96.701568] PVR_K:   (MKT-1A8) 073EDAFF 00000808 0000251E AD00030E
[   96.708404] PVR_K:   (MKT-1A9) 073EDB17 00000808 0000251E 0D800474
[   96.715301] PVR_K:   (MKT-1AA) 073EDB30 00000808 0000251E 0000000E
[   96.721984] PVR_K:   (MKT-1AB) 073EDB58 00000808 0000251E 0000000F
[   96.728668] PVR_K:   (MKT-1AC) 073EDBC3 00000808 0000251E AD000184
[   96.735351] PVR_K:   (MKT-1AD) 073EDC29 00000C08 0100261D AD000281
[   96.742004] PVR_K:   (MKT-1AE) 073EDD9D 00000808 0100261D AD00080A
[   96.748626] PVR_K:   (MKT-1AF) 073EDDB5 00000808 0100261D 0F03DE00
[   96.755310] PVR_K:   (MKT-1B0) 073EDDCE 00000808 0100261D 00000060
[   96.761993] PVR_K:   (MKT-1B1) 073EE08D 00000808 0000261D AD000803
[   96.771240] PVR_K:   (MKT-1B2) 073EE0D3 00180CC8 0000261D AD000282
[   96.780548] PVR_K:   (MKT-1B3) 073EE193 00000808 0100281F AD000200
[   96.789489] PVR_K:   (MKT-1B4) 073EE3B1 00000808 0000281F AD000202
[   96.796325] PVR_K:   (MKT-1B5) 073EE437 00000808 0000291E AD000183
[   96.805328] PVR_K:   (MKT-1B6) 073EE52D 00000808 0000291E AD00030E
[   96.812103] PVR_K:   (MKT-1B7) 073EE545 00000808 0000291E 0D800474
[   96.818969] PVR_K:   (MKT-1B8) 073EE55E 00000808 0000291E 0000000E
[   96.825805] PVR_K:   (MKT-1B9) 073EE581 00000808 0000291E 0000000F
[   96.832519] PVR_K:   (MKT-1BA) 073EE5EC 00000808 0000291E AD000184
[   96.839141] PVR_K:   (MKT-1BB) 073EE653 00000C08 01002A1D AD000281
[   96.845886] PVR_K:   (MKT-1BC) 073EE7C4 00000808 01002A1D AD00080A
[   96.852569] PVR_K:   (MKT-1BD) 073EE7DD 00000808 01002A1D 0F03E100
[   96.859130] PVR_K:   (MKT-1BE) 073EE7F6 00000808 01002A1D 00000060
[   96.865753] PVR_K:   (MKT-1BF) 073EEAB9 00000808 00002A1D AD000803
[   96.872741] PVR_K:   (MKT-1C0) 073EEAFF 00180CC8 00002A1D AD000282
[   96.879669] PVR_K:   (MKT-1C1) 073EEBF0 00000808 01002C1F AD000200
[   96.886444] PVR_K:   (MKT-1C2) 073EEE17 00000808 00002C1F AD000202
[   96.893035] PVR_K:   (MKT-1C3) 073EEE9A 00000808 00002D1E AD000183
[   96.899780] PVR_K:   (MKT-1C4) 073EEF85 00000808 00002D1E AD00030E
[   96.906463] PVR_K:   (MKT-1C5) 073EEF9D 00000808 00002D1E 0D800474
[   96.913055] PVR_K:   (MKT-1C6) 073EEFB6 00000808 00002D1E 0000000E
[   96.919708] PVR_K:   (MKT-1C7) 073EEFD9 00000808 00002D1E 0000000F
[   96.926208] PVR_K:   (MKT-1C8) 073EF044 00000808 00002D1E AD000184
[   96.932830] PVR_K:   (MKT-1C9) 073EF0AC 00000C08 01002E1D AD000281
[   96.939422] PVR_K:   (MKT-1CA) 073EF221 00000808 01002E1D AD00080A
[   96.946228] PVR_K:   (MKT-1CB) 073EF23A 00000808 01002E1D 0F03E400
[   96.953002] PVR_K:   (MKT-1CC) 073EF253 00000808 01002E1D 00000062
[   96.959747] PVR_K:   (MKT-1CD) 073EF50B 00000808 00002E1D AD000803
[   96.966400] PVR_K:   (MKT-1CE) 073EF551 00180C88 00002E1D AD000282
[   96.973114] PVR_K:   (MKT-1CF) 073F0072 00000808 0100301F AD000200
[   96.979980] PVR_K:   (MKT-1D0) 073F0192 00000808 0100301F AD001703
[   96.986602] PVR_K:   (MKT-1D1) 073F0382 00000808 0000301F AD000202
[   96.993225] PVR_K:   (MKT-1D2) 073F0400 00000808 0000311E AD000183
[   96.999816] PVR_K:   (MKT-1D3) 073F04EC 00000808 0000311E AD00030E
[   97.007110] PVR_K:   (MKT-1D4) 073F0504 00000808 0000311E 0D800474
[   97.013610] PVR_K:   (MKT-1D5) 073F051E 00000808 0000311E 0000000E
[   97.020263] PVR_K:   (MKT-1D6) 073F0542 00000808 0000311E 0000000F
[   97.027252] PVR_K:   (MKT-1D7) 073F05AD 00000808 0000311E AD000184
[   97.033905] PVR_K:   (MKT-1D8) 073F0611 00000C08 0100321D AD000281
[   97.040527] PVR_K:   (MKT-1D9) 073F0729 00000808 0100321D AD000E02
[   97.047180] PVR_K:   (MKT-1DA) 073F079C 00000808 0100321D AD000282
[   97.053771] PVR_K:   (MKT-1DB) 073FD511 00000808 0100351F AD001A00
[   97.060607] PVR_K:   (MKT-1DC) 0740E26B 00000808 0100381F AD00000A
[   97.068267] PVR_K:   (MKT-1DD) 0740E2CB 00000808 0100381F AD000909
[   97.074829] PVR_K:   (MKT-1DE) 0740E318 00000808 0100381F AD001A05
[   97.081695] PVR_K:   (MKT-1DF) 0740E348 00000808 0100381F AD001302
[   97.088592] PVR_K:   (MKT-1E0) 0740E388 00000808 0100381F AD001303
[   97.095336] PVR_K:   (MKT-1E1) 0740E417 00000808 0100381F AD000D04
[   97.102081] PVR_K:   (MKT-1E2) 0740E4DD 00000808 0100381F AD000D05
[   97.118103] PVR_K:   (MKT-1E3) 0740E534 00000808 0100381F AD000D04
[   97.124755] PVR_K:   (MKT-1E4) 0740E5BB 00000808 0100381F AD000D05
[   97.131652] PVR_K:   (MKT-1E5) 0740E618 00000808 0100381F AD001A06
[   97.138183] PVR_K:   (MKT-1E6) 00000797 00100808 0100031F AD002300
[   97.145416] PVR_K:   (MKT-1E7) 00000C82 00100808 0100041F AD00000A
[   97.153625] PVR_K:   (MKT-1E8) 00000CFF 00100808 0100041F AD000906
[   97.160186] PVR_K:   (MKT-1E9) 00000DD4 00100808 0000041F AD000901
[   97.166748] PVR_K:   (MKT-1EA) 00000E52 00100808 0000051E AD000183
[   97.175079] PVR_K:   (MKT-1EB) 00000FC8 00100808 0000051E AD000302
[   97.191131] PVR_K:   (MKT-1EC) 0000114C 00100808 0000051E AD000D06
[   97.197662] PVR_K:   (MKT-1ED) 00001236 00100808 0000051E AD000D07
[   97.225036] PVR_K:   (MKT-1EE) 00001280 00100808 0000051E AD001304
[   97.231811] PVR_K:   (MKT-1EF) 00001371 00100808 0000051E AD001305
[   97.243499] PVR_K:   (MKT-1F0) 00001485 00100888 0000051E AD000404
[   97.250488] PVR_K:   (MKT-1F1) 00001550 00100808 0000051E AD000402
[   97.257232] PVR_K:   (MKT-1F2) 00001599 0010082B 0000051E AD000184
[   97.264221] PVR_K:   (MKT-1F3) 00001660 00119CAD 0000061D AD000281
[   97.270812] PVR_K:   (MKT-1F4) 000017C6 001089AF 0000061D AD000E02
[   97.280426] PVR_K:   (MKT-1F5) 00001824 0010092B 0000061D AD000282
[   97.297790] PVR_K:   (MKT-1F6) 00003DD3 00100808 0000081F AD000101
[   97.304351] PVR_K:   (MKT-1F7) 00003E48 00100808 0000081F AD000104
[   97.311096] PVR_K:   (MKT-1F8) 00003E84 00100808 0100091E AD000100
[   97.318023] PVR_K:   (MKT-1F9) 00003F7C 00100808 0100091E AD000501
[   97.324615] PVR_K:   (MKT-1FA) 00003FBA 0010082B 0100091E AD000104
[   97.334686] PVR_K:   (MKT-1FB) 0000626E 00100828 01000A1F AD000101
[   97.341735] PVR_K:   (MKT-1FC) 000062C5 00100828 01000A1F AD000104
[   97.348419] PVR_K:   (MKT-1FD) 000063CE 00100808 01000B1F AD000100
[   97.355072] PVR_K:   (MKT-1FE) 0000649C 00100808 01000B1F AD000501
[   97.373474] PVR_K:   (MKT-1FF) 000064D2 00100829 01000B1F AD000104
[   97.381042] PVR_K: SGX Kernel CCB WO:0xC6 RO:0xC6
[   97.388275] adc_to_temp_conversion:Temp read is invalid 0
[   97.407348] thermal_lookup_temp: getting temp is not supported for domain pcb
[   97.428985] adc_to_temp_conversion:Temp read is invalid 0
[   97.444213] thermal_lookup_temp: getting temp is not supported for domain pcb
[   97.472717] adc_to_temp_conversion:Temp read is invalid 0
[   97.483245] thermal_lookup_temp: getting temp is not supported for domain pcb
[   97.647338] PVR_K:(Error): SGXOSTimer() detected SGX lockup (0xb tasks) [0, ]
[   97.654998] PVR_K: HWRecoveryResetSGX: SGX Hardware Recovery triggered
[   97.662658] [   77.138]                         [c6f11400] dsscomp_apply
[   97.662658] [   77.152]                           [c6e67c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   97.662658] [   77.152]    [c6fa43c0] --refs=0 on RELEASED
[   97.662658] [   77.152]    [c6fa43c0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   97.692443] [   77.152]                           [c6e67c00] dsscomp_mgr_delayed_cb on RELEASED
[   97.692443] [   77.152]                         [c6f11400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   97.692474] [   77.154]    [c6fa44a0] new in dsscomp_gralloc_queue (refs=1)
[   97.692474] [   77.154]                           [c6e67c00] dsscomp_new
[   97.722259] [   77.154]    [c6fa44a0] ++refs=2 for [c6e67c00]
[   97.722259] [   77.154]                           [c6e67c00] dsscomp_delayed_apply
[   97.722259] [   77.154]    [c6fa44a0] --refs=1 on RELEASED
[   97.722290] [   77.154]                           [c6e67c00] dsscomp_apply
[   97.752075] [   77.171]                         [c6f11400] dsscomp_mgr_delayed_cb on DISPLAYED
[   97.752075] [   77.171]    [c6edbc00] --refs=0 on RELEASED
[   97.752075] [   77.171]    [c6edbc00] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   97.752105] [   77.171]                         [c6f11400] dsscomp_mgr_delayed_cb on RELEASED
[   97.782104] [   77.171]                           [c6e67c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   97.782104] [   77.186]                           [c6e67c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   97.782104] [   82.167]   [c6fa4460] new in dsscomp_gralloc_queue (refs=1)
[   97.810516] [   82.167]                           [c6e66000] dsscomp_new
[   97.810516] [   82.167]   [c6fa4460] ++refs=2 for [c6e66000]
[   97.810516] [   82.167]                           [c6e66000] dsscomp_delayed_apply
[   97.810516] [   82.167]   [c6fa4460] --refs=1 on RELEASED
[   97.810516] [   82.167]                           [c6e66000] dsscomp_apply
[   97.841888] [   82.167]    [c6fa44a0] --refs=0 on RELEASED
[   97.841888] [   82.167]    [c6fa44a0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   97.841888] [   82.167]                           [c6e67c00] dsscomp_mgr_delayed_cb on RELEASED
[   97.870483] [   82.167]                           [c6e66000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   97.870513] [   82.168]   [c6edbca0] new in dsscomp_gralloc_queue (refs=1)
[   97.870513] [   82.168]                          [c6f10800] dsscomp_new
[   97.870513] [   82.168]   [c6edbca0] ++refs=2 for [c6f10800]
[   97.900604] [   82.168]                          [c6f10800] dsscomp_delayed_apply
[   97.900604] [   82.168]   [c6edbca0] --refs=1 on RELEASED
[   97.900634] [   82.168]                          [c6f10800] dsscomp_apply
[   97.900634] [   82.183]                           [c6e66000] dsscomp_mgr_delayed_cb on DISPLAYED
[   97.930419] [   82.183]   [c6fa4460] --refs=0 on RELEASED
[   97.930419] [   82.183]   [c6fa4460] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   97.930419] [   82.183]                           [c6e66000] dsscomp_mgr_delayed_cb on RELEASED
[   97.930419] [   82.183]                          [c6f10800] dsscomp_mgr_delayed_cb on PROGRAMMED
[   97.960327] [   82.204]                          [c6f10800] dsscomp_mgr_delayed_cb on DISPLAYED
[   97.960327] [   87.162]    [c6edbdc0] new in dsscomp_gralloc_queue (refs=1)
[   97.960327] [   87.162]                       [c6f12c00] dsscomp_new
[   97.960327] [   87.162]    [c6edbdc0] ++refs=2 for [c6f12c00]
[   97.990173] [   87.162]                       [c6f12c00] dsscomp_delayed_apply
[   97.990173] [   87.162]    [c6edbdc0] --refs=1 on RELEASED
[   97.990173] [   87.162]                       [c6f12c00] dsscomp_apply
[   97.990203] [   87.162]   [c6edbca0] --refs=0 on RELEASED
[   98.023010] [   87.162]   [c6edbca0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   98.023040] [   87.162]                          [c6f10800] dsscomp_mgr_delayed_cb on RELEASED
[   98.023040] [   87.162]                       [c6f12c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[   98.023040] [   87.163]    [c6edbce0] new in dsscomp_gralloc_queue (refs=1)
[   98.052886] [   87.163]                           [c6f13400] dsscomp_new
[   98.052917] [   87.163]    [c6edbce0] ++refs=2 for [c6f13400]
[   98.052917] [   87.163]                           [c6f13400] dsscomp_delayed_apply
[   98.052917] [   87.163]    [c6edbce0] --refs=1 on RELEASED
[   98.082824] [   87.163]                           [c6f13400] dsscomp_apply
[   98.082824] [   87.177]                       [c6f12c00] dsscomp_mgr_delayed_cb on DISPLAYED
[   98.082824] [   87.177]    [c6edbdc0] --refs=0 on RELEASED
[   98.082824] [   87.177]    [c6edbdc0] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   98.112731] [   87.178]                       [c6f12c00] dsscomp_mgr_delayed_cb on RELEASED
[   98.112731] [   87.178]                           [c6f13400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   98.112731] [   87.199]                           [c6f13400] dsscomp_mgr_delayed_cb on DISPLAYED
[   98.141143] [   92.240]       [c6fa4720] new in dsscomp_gralloc_queue (refs=1)
[   98.141143] [   92.240]                       [c6e67400] dsscomp_new
[   98.141143] [   92.240]       [c6fa4720] ++refs=2 for [c6e67400]
[   98.141143] [   92.240]                       [c6e67400] dsscomp_delayed_apply
[   98.170959] [   92.240]       [c6fa4720] --refs=1 on RELEASED
[   98.170989] [   92.240]                       [c6e67400] dsscomp_apply
[   98.170989] [   92.240]    [c6edbce0] --refs=0 on RELEASED
[   98.170989] [   92.240]    [c6edbce0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   98.170989] [   92.240]                           [c6f13400] dsscomp_mgr_delayed_cb on RELEASED
[   98.202545] [   92.240]                       [c6e67400] dsscomp_mgr_delayed_cb on PROGRAMMED
[   98.202545] [   92.241]      [c6edbc80] new in dsscomp_gralloc_queue (refs=1)
[   98.202545] [   92.241]                         [c6f13000] dsscomp_new
[   98.230865] [   92.241]      [c6edbc80] ++refs=2 for [c6f13000]
[   98.230895] [   92.241]                         [c6f13000] dsscomp_delayed_apply
[   98.230895] [   92.241]      [c6edbc80] --refs=1 on RELEASED
[   98.230895] [   92.241]                         [c6f13000] dsscomp_apply
[   98.230895] [   92.256]                       [c6e67400] dsscomp_mgr_delayed_cb on DISPLAYED
[   98.262329] [   92.256]       [c6fa4720] --refs=0 on RELEASED
[   98.262329] [   92.256]       [c6fa4720] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   98.262329] [   92.256]                       [c6e67400] dsscomp_mgr_delayed_cb on RELEASED
[   98.290740] [   92.256]                         [c6f13000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   98.290740] [   92.277]                         [c6f13000] dsscomp_mgr_delayed_cb on DISPLAYED
[   98.290740] [   97.379]       [c6edbb00] new in dsscomp_gralloc_queue (refs=1)
[   98.290771] [   97.379]                      [c6f10000] dsscomp_new
[   98.320587] [   97.379]       [c6edbb00] ++refs=2 for [c6f10000]
[   98.320587] [   97.379]                      [c6f10000] dsscomp_delayed_apply
[   98.320587] [   97.379]       [c6edbb00] --refs=1 on RELEASED
[   98.320587] [   97.379]                      [c6f10000] dsscomp_apply
[   98.350463] [   97.380]      [c6edbc80] --refs=0 on RELEASED
[   98.350463] [   97.380]      [c6edbc80] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   98.350463] [   97.380]                         [c6f13000] dsscomp_mgr_delayed_cb on RELEASED
[   98.350494] [   97.380]                      [c6f10000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   98.381652] [   97.380]   [c6edbca0] new in dsscomp_gralloc_queue (refs=1)
[   98.381652] [   97.380]                          [c6f10800] dsscomp_new
[   98.381652] [   97.380]   [c6edbca0] ++refs=2 for [c6f10800]
[   98.381652] [   97.380]                          [c6f10800] dsscomp_delayed_apply
[   98.412811] [   97.380]   [c6edbca0] --refs=1 on RELEASED
[   98.412811] [   97.380]                          [c6f10800] dsscomp_apply
[   98.412811] [   97.408]                      [c6f10000] dsscomp_mgr_delayed_cb on DISPLAYED
[   98.412811] [   97.408]       [c6edbb00] --refs=0 on RELEASED
[   98.442932] [   97.408]       [c6edbb00] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   98.442932] [   97.408]                      [c6f10000] dsscomp_mgr_delayed_cb on RELEASED
[   98.442932] [   97.408]                          [c6f10800] dsscomp_mgr_delayed_cb on PROGRAMMED
[   98.471466] [   97.410] [c6fa4760] new in dsscomp_gralloc_queue (refs=1)
[   98.471466] [   97.410]                      [c6f10000] dsscomp_new
[   98.471466] [   97.410] [c6fa4760] ++refs=2 for [c6f10000]
[   98.471466] [   97.410]                      [c6f10000] dsscomp_delayed_apply
[   98.471496] [   97.410] [c6fa4760] --refs=1 on RELEASED
[   98.502838] [   97.410]                      [c6f10000] dsscomp_apply
[   98.502868] [   97.421]                          [c6f10800] dsscomp_mgr_delayed_cb on DISPLAYED
[   98.502868] [   97.421]   [c6edbca0] --refs=0 on RELEASED
[   98.502868] [   97.421]   [c6edbca0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[   98.532745] [   97.421]                          [c6f10800] dsscomp_mgr_delayed_cb on RELEASED
[   98.532745] [   97.421]    [c6edb880] new in dsscomp_gralloc_queue (refs=1)
[   98.532745] [   97.421]                          [c6f10800] dsscomp_new
[   98.532745] [   97.421]    [c6edb880] ++refs=2 for [c6f10800]
[   98.562683] [   97.421]                          [c6f10800] dsscomp_delayed_apply
[   98.562683] [   97.421]    [c6edb880] --refs=1 on RELEASED
[   98.562683] [   97.421]                      [c6f10000] dsscomp_mgr_delayed_cb on PROGRAMMED
[   98.562683] [   97.421]                          [c6f10800] dsscomp_apply
[   98.592529] [   97.445]                      [c6f10000] dsscomp_mgr_delayed_cb on DISPLAYED
[   98.592529] [   97.445] [c6fa4760] --refs=0 on RELEASED
[   98.592529] [   97.445] [c6fa4760] calling dsscomp_proxy_cmdcomplete [c73f6900]
[   98.592529] [   97.445]                      [c6f10000] dsscomp_mgr_delayed_cb on RELEASED
[   98.622344] [   97.445]                          [c6f10800] dsscomp_mgr_delayed_cb on PROGRAMMED
[   98.622344] [   97.473]                          [c6f10800] dsscomp_mgr_delayed_cb on DISPLAYED
[   98.622344] ACTIVE COMPOSITIONS on lcd
[   98.622344]
[   98.622344]   [c6f10800]: DISPLAYED
[   98.653747]     sync_id=0, flags=AD-
[   98.653778]     ovl0={ON z0 ARGB32-8888 premult *100% 864*480:0,0+864,480 rot0 => 0,0+864,480 7f9ac000/  (null)|3456}
[   98.653778]     gsync=[c6edb880] dsscomp_gralloc_cb
[   98.653778]
[   98.653778]   DISPC pipeline:
[   98.653778]
[   98.653778]     info:        clean (none)
[   98.653778]     cache:       clean (none)
[   98.692993]     shadow:  ACT clean (none)
[   98.692993]     dispc:   DISPLAYED mask=---R [c6f10800] dsscomp_mgr_callback
[   98.692993]
[   98.692993] ACTIVE COMPOSITIONS on tv
[   98.692993]
[   98.692993]   DISPC pipeline:
[   98.693023]
[   98.693023]     info:        clean (none)
[   98.693023]     cache:       clean (none)
[   98.693023]     shadow:  off clean (none)
[   98.693023]     dispc:   DISPLAYED (none)
[   98.734802]
[   98.734832] ACTIVE COMPOSITIONS on lcd2
[   98.734832]
[   98.734832]   DISPC pipeline:
[   98.734832]
[   98.734832]     info:        clean (none)
[   98.734832]     cache:       clean (none)
[   98.734832]     shadow:  off clean (none)
[   98.734832]     dispc:             (none)
[   98.734832]
[   98.734832] ACTIVE GRALLOC FLIPS
[   98.734832]
[   98.734832]   [c6edb880] (refs=1)
[   98.734863]     slots=[7f9ac000]
[   98.734863]     cmdcb=[c73f6480] dsscomp_proxy_cmdcomplete
[   98.781799]
[   98.781799]   |           lcd
[   98.781799]   | [c6f10800] DISPL'D
[   98.781799]   |     97.421  ACTIVE
[   98.781799]   |     97.421 APPLY'N
[   98.781799]   |     97.421 APPLIED
[   98.781799]   |     97.445 PROGR'D
[   98.781829]   |     97.473 DISPL'D
[   98.781829]
[   98.781829]
[   98.816345] PVR_K: SGX debug (blaze_android_sgx_ogles1_ogles2_GPL sgxddk 18 1.8@869593)
[   98.825042] PVR_K:(Error): SGX Register Base Address (Linear):   0xC8B20000 [0, ]
[   98.833068] PVR_K:(Error): SGX Register Base Address (Physical): 0x56000000 [0, ]
[   98.841033] PVR_K: (P0) EUR_CR_CORE_ID:          01140000
[   98.846862] PVR_K: (P0) EUR_CR_CORE_REVISION:    00010200
[   98.852630] PVR_K: (P0) EUR_CR_EVENT_STATUS:     20000000
[   98.858459] PVR_K: (P0) EUR_CR_EVENT_STATUS2:    00000008
[   98.864196] PVR_K: (P0) EUR_CR_BIF_CTRL:         00000000
[   98.870330] PVR_K: (P0) EUR_CR_BIF_INT_STAT:     0000E000
[   98.879486] PVR_K: (P0) EUR_CR_BIF_FAULT:        0DC7C000
[   98.894378] PVR_K: (P0) EUR_CR_BIF_MEM_REQ_STAT: 00000000
[   98.900848] PVR_K: (P0) EUR_CR_CLKGATECTL:       000AAA6A
[   98.907257] PVR_K: (P0) EUR_CR_PDS_PC_BASE:      0001F040
[   98.914001] PVR_K: Found MMU context for page fault 0x0dc7c000
[   98.921142] PVR_K: PDE valid: PTE = 0x00000000 (PhysAddr = 0x00000000, Invalid)
[   98.930603] PVR_K: Flip Command Complete Data 0 for display device 1:
[   98.943237] PVR_K:   SRC 0: ROC DevVAddr:0xD800474 ROP:0x13 ROC:0x11, WOC DevVAddr:0xD800464 WOP:0x12 WOC:0x11
[   98.956726] PVR_K: Flip Command Complete Data 1 for display device 1:
[   98.966094] PVR_K:   SRC 0: (Not in use)
[   98.994812] PVR_K: SGX Host control:
[   98.998687] PVR_K:   (HC-0) 0x00000001 0x00000000 0x00000000 0x00000001
[   99.014587] PVR_K:   (HC-10) 0x00000011 0x0000000A 0x0005DC00 0x00000003
[   99.021667] PVR_K:   (HC-20) 0x00000000 0x00000003 0x00000000 0x00000017
[   99.059631] PVR_K:   (HC-30) 0x00000E5B 0xF3ECFB54 0x00000000 0x00000000
[   99.077056] PVR_K:   (HC-40) 0x00000000 0x087BF500 0x087C6300 0x087C3100
[   99.085144] PVR_K: SGX TA/3D control:
[   99.089111] PVR_K:   (T3C-0) 0x0F003000 0x0F003120 0x0F002000 0x00000000
[   99.098571] PVR_K:   (T3C-10) 0x00000001 0x00000002 0x00000001 0x0F00DD00
[   99.109313] PVR_K:   (T3C-20) 0x00000000 0x00000000 0x00000000 0x00000000
[   99.131317] PVR_K:   (T3C-30) 0x00000000 0x00000000 0x00000000 0x00000000
[   99.143829] PVR_K:   (T3C-40) 0x00000000 0x00000000 0x00000000 0x00000000
[   99.151062] PVR_K:   (T3C-50) 0x00000000 0x00000000 0x00000000 0x00000000
[   99.158264] PVR_K:   (T3C-60) 0x00000000 0x00000000 0x0F00DD00 0x00000000
[   99.165618] PVR_K:   (T3C-70) 0x00000000 0x0F00DD00 0x00000000 0x0F004000
[   99.172882] PVR_K:   (T3C-80) 0x00000009 0x0001120F 0x00000000 0x0F00DEB8
[   99.185516] PVR_K:   (T3C-90) 0x00000000 0x0F000000 0xAB600000 0x0F040800
[   99.193359] PVR_K:   (T3C-A0) 0x00000000 0x0F010760 0x0F00DD00 0x0F00DEB8
[   99.201293] PVR_K:   (T3C-B0) 0x0F0109A0 0x00000000 0x00000000 0x00000000
[   99.209869] PVR_K:   (T3C-C0) 0x00000000 0x00000000 0x00000000 0x00000000
[   99.217346] PVR_K:   (T3C-D0) 0x00000000 0x00000022 0x00000021 0x0F007000
[   99.224975] PVR_K:   (T3C-E0) 0x0F00D420 0x0F00E000 0x0F010720 0x0F010720
[   99.232452] PVR_K:   (T3C-F0) 0x00000000 0x000000B5 0x000000B5 0x00000000
[   99.239807] PVR_K:   (T3C-100) 0x00000003 0x00000000 0x00000000 0x00000001
[   99.247192] PVR_K:   (T3C-110) 0xB50C565C 0x0872E100 0x08787B00 0x08787B00
[   99.254547] PVR_K: Last SGX microkernel status code: AD000104
[   99.261627] PVR_K:   (MKT-0) 073DFEA1 00100808 0100031F AD000B05
[   99.268096] PVR_K:   (MKT-1) 073DFEF5 00100808 0100031F AD000B06
[   99.274566] PVR_K:   (MKT-2) 073DFF24 00100808 0100031F AD000B06
[   99.280944] PVR_K:   (MKT-3) 073DFF6A 00100808 0100031F AD000B07
[   99.287658] PVR_K:   (MKT-4) 073DFF90 00100808 0100031F AD000B09
[   99.294036] PVR_K:   (MKT-5) 073DFFE6 00100808 0100031F AD000B01
[   99.300415] PVR_K:   (MKT-6) 073E0022 00100808 0100031F AD002300
[   99.306915] PVR_K:   (MKT-7) 073E0360 00100808 0100041F AD00000A
[   99.313446] PVR_K:   (MKT-8) 073E03E1 00100808 0100041F AD000906
[   99.320068] PVR_K:   (MKT-9) 073E049C 00100808 0000041F AD000901
[   99.326812] PVR_K:   (MKT-A) 073E0517 00100808 0000051E AD000183
[   99.333770] PVR_K:   (MKT-B) 073E0688 00100808 0000051E AD000302
[   99.340179] PVR_K:   (MKT-C) 073E06DB 00100808 0000051E AD000303
[   99.346557] PVR_K:   (MKT-D) 073E0762 00100808 0000051E AD000C01
[   99.352935] PVR_K:   (MKT-E) 073E0786 00100808 0000051E 0D800464
[   99.359313] PVR_K:   (MKT-F) 073E079E 00100808 0000051E 0000000F
[   99.365692] PVR_K:   (MKT-10) 073E09F2 00100808 0000051E AD00030E
[   99.372100] PVR_K:   (MKT-11) 073E0A0B 00100808 0000051E 0D800494
[   99.378631] PVR_K:   (MKT-12) 073E0A24 00100808 0000051E 0000000D
[   99.385223] PVR_K:   (MKT-13) 073E0A47 00100808 0000051E 0000000E
[   99.392913] PVR_K:   (MKT-14) 073E0AC4 00100808 0000051E AD000184
[   99.399719] PVR_K:   (MKT-15) 073E0B46 00100C08 0100061D AD000281
[   99.406372] PVR_K:   (MKT-16) 073E0CDF 00100808 0100061D AD00080A
[   99.412841] PVR_K:   (MKT-17) 073E0CF8 00100808 0100061D 0F03CF00
[   99.419372] PVR_K:   (MKT-18) 073E0D10 00100808 0100061D 00000061
[   99.426483] PVR_K:   (MKT-19) 073E0E2D 00100C88 0100061D AD001300
[   99.432922] PVR_K:   (MKT-1A) 073E6271 00100808 0000061D AD001301
[   99.439514] PVR_K:   (MKT-1B) 073E63AA 00100888 0000061D AD000802
[   99.446411] PVR_K:   (MKT-1C) 073E6513 00100888 0000061D AD000803
[   99.453247] PVR_K:   (MKT-1D) 073E6561 001808C8 0000061D AD000282
[   99.466400] PVR_K:   (MKT-1E) 073E6641 00184AF8 0000081E AD00000A
[   99.472991] PVR_K:   (MKT-1F) 073E66C9 00184AF8 0000081E AD000905
[   99.479736] PVR_K:   (MKT-20) 073E67E8 001808B8 0000081E AD000901
[   99.486328] PVR_K:   (MKT-21) 073E685D 00180838 0000091C AD00000A
[   99.492950] PVR_K:   (MKT-22) 073E68D4 00180838 0000091C AD000906
[   99.499725] PVR_K:   (MKT-23) 073E6945 00180838 0000091C AD000901
[   99.507537] PVR_K:   (MKT-24) 073E699D 00180838 00000A1B AD00000A
[   99.514770] PVR_K:   (MKT-25) 073E6A05 00180838 00000A1B AD000905
[   99.521240] PVR_K:   (MKT-26) 073E6AAC 00180838 00000A1B AD000901
[   99.528411] PVR_K:   (MKT-27) 073E6B04 00180838 00000B1A AD00000A
[   99.535247] PVR_K:   (MKT-28) 073E6B69 00180838 00000B1A AD000905
[   99.541931] PVR_K:   (MKT-29) 073E6C1C 00180838 00000B1A AD000901
[   99.548614] PVR_K:   (MKT-2A) 073E6C71 00180838 00000C19 AD00000A
[   99.555023] PVR_K:   (MKT-2B) 073E6CD6 00180838 00000C19 AD000905
[   99.561553] PVR_K:   (MKT-2C) 073E6D7F 00180838 00000C19 AD000901
[   99.568023] PVR_K:   (MKT-2D) 073E6EDE 00180838 00000F1F AD000183
[   99.574584] PVR_K:   (MKT-2E) 073E705B 00180838 00000F1F AD000302
[   99.581176] PVR_K:   (MKT-2F) 073E70DD 00180838 00000F1F AD000303
[   99.587890] PVR_K:   (MKT-30) 073E715B 00180838 00000F1F AD000C01
[   99.594360] PVR_K:   (MKT-31) 073E7180 00180838 00000F1F 0D800484
[   99.600799] PVR_K:   (MKT-32) 073E7199 00180838 00000F1F 0000000F
[   99.607238] PVR_K:   (MKT-33) 073E73C9 00180838 00000F1F AD000184
[   99.623901] PVR_K:   (MKT-34) 073E7439 00180C38 0100101D AD000281
[   99.630340] PVR_K:   (MKT-35) 073E7491 00180838 0100101D AD000282
[   99.640136] PVR_K:   (MKT-36) 073E828F 00180838 0100111F AD00000A
[   99.649353] PVR_K:   (MKT-37) 073E82FB 00180838 0100111F AD000905
[   99.658966] PVR_K:   (MKT-38) 073E8407 00180838 0000111F AD000901
[   99.667724] PVR_K:   (MKT-39) 073E8459 00180C38 0100121E AD000281
[   99.674133] PVR_K:   (MKT-3A) 073E84B2 00180838 0100121E AD000282
[   99.680603] PVR_K:   (MKT-3B) 073E8600 00180838 0100131F AD00000A
[   99.687011] PVR_K:   (MKT-3C) 073E866B 00100828 0100131F AD000905
[   99.702026] PVR_K:   (MKT-3D) 073E8765 00000808 0000131F AD000901
[   99.708435] PVR_K:   (MKT-3E) 073E879B 00000C08 0000141E AD000200
[   99.725463] PVR_K:   (MKT-3F) 073E89EA 00000808 0000141E AD000202
[   99.731903] PVR_K:   (MKT-40) 073E8A42 00000808 0000151D AD000281
[   99.755584] PVR_K:   (MKT-41) 073E8B8B 00000808 0000151D AD00080A
[   99.762573] PVR_K:   (MKT-42) 073E8BA3 00000808 0000151D 0F03D200
[   99.769104] PVR_K:   (MKT-43) 073E8BBB 00000808 0000151D 00000060
[   99.775634] PVR_K:   (MKT-44) 073E8E7D 00000808 0000151D AD000803
[   99.782073] PVR_K:   (MKT-45) 073E8EC3 00180CC8 0000151D AD000282
[   99.788543] PVR_K:   (MKT-46) 073E8F75 00000808 0000161F AD00000A
[   99.794952] PVR_K:   (MKT-47) 073E8FDE 00000808 0000161F AD000905
[   99.801452] PVR_K:   (MKT-48) 073E90D6 00000888 0000161F AD000901
[   99.807861] PVR_K:   (MKT-49) 073E9140 00000808 0000171E AD00000A
[   99.814331] PVR_K:   (MKT-4A) 073E919F 00000808 0000171E AD000905
[   99.820770] PVR_K:   (MKT-4B) 073E9244 00000808 0000171E AD000901
[   99.827270] PVR_K:   (MKT-4C) 073E928E 00000C08 0000191D AD000200
[   99.833679] PVR_K:   (MKT-4D) 073E94BA 00000808 0000191D AD000202
[   99.840209] PVR_K:   (MKT-4E) 073E9516 00000808 01001A1B AD000281
[   99.858306] PVR_K:   (MKT-4F) 073E9662 00000808 01001A1B AD00080A
[   99.864807] PVR_K:   (MKT-50) 073E967B 00000808 01001A1B 0F03D500
[   99.881744] PVR_K:   (MKT-51) 073E9693 00000808 01001A1B 00000060
[   99.888214] PVR_K:   (MKT-52) 073E994F 00000808 00001A1B AD000803
[   99.920684] PVR_K:   (MKT-53) 073E9998 00180CC8 00001A1B AD000282
[   99.929382] PVR_K:   (MKT-54) 073E9A80 00000808 01001C1F AD000200
[   99.936492] PVR_K:   (MKT-55) 073E9CAD 00000808 00001C1F AD000202
[   99.951568] PVR_K:   (MKT-56) 073E9CFA 00000808 01001D1E AD000281
[   99.958526] PVR_K:   (MKT-57) 073E9E49 00000808 01001D1E AD00080A
[   99.974548] PVR_K:   (MKT-58) 073E9E62 00000808 01001D1E 0F03D800
[   99.984283] PVR_K:   (MKT-59) 073E9E7B 00000808 01001D1E 00000062
[   99.992584] PVR_K:   (MKT-5A) 073EA135 00000808 00001D1E AD000803
[   99.999420] PVR_K:   (MKT-5B) 073EA180 00180C88 00001D1E AD000282
[  100.006469] PVR_K:   (MKT-5C) 073EACE2 00000808 01001F1F AD000200
[  100.014984] PVR_K:   (MKT-5D) 073EAE03 00000808 01001F1F AD001703
[  100.021392] PVR_K:   (MKT-5E) 073EB003 00000808 00001F1F AD000202
[  100.028839] PVR_K:   (MKT-5F) 073EB081 00000808 0000201E AD000183
[  100.035797] PVR_K:   (MKT-60) 073EB16D 00000808 0000201E AD00030E
[  100.042694] PVR_K:   (MKT-61) 073EB185 00000808 0000201E 0D800474
[  100.060272] PVR_K:   (MKT-62) 073EB19F 00000808 0000201E 0000000E
[  100.066833] PVR_K:   (MKT-63) 073EB1C2 00000808 0000201E 0000000F
[  100.075683] PVR_K:   (MKT-64) 073EB22D 00000808 0000201E AD000184
[  100.082214] PVR_K:   (MKT-65) 073EB295 00000C08 0100211D AD000281
[  100.089447] PVR_K:   (MKT-66) 073EB41A 00000808 0100211D AD00080A
[  100.096130] PVR_K:   (MKT-67) 073EB433 00000808 0100211D 0F03DB00
[  100.108276] PVR_K:   (MKT-68) 073EB44B 00000808 0100211D 00000061
[  100.114715] PVR_K:   (MKT-69) 073EB5CB 00000808 0000211D AD000802
[  100.127929] PVR_K:   (MKT-6A) 073EB722 00000808 0000211D AD000803
[  100.137908] PVR_K:   (MKT-6B) 073EB76B 00184EC8 0000211D AD000282
[  100.144439] PVR_K:   (MKT-6C) 073ED72C 00000C08 0100241F AD000200
[  100.150848] PVR_K:   (MKT-6D) 073ED986 00000808 0000241F AD000202
[  100.157348] PVR_K:   (MKT-6E) 073EDA10 00000808 0000251E AD000183
[  100.163757] PVR_K:   (MKT-6F) 073EDAFF 00000808 0000251E AD00030E
[  100.170227] PVR_K:   (MKT-70) 073EDB17 00000808 0000251E 0D800474
[  100.176788] PVR_K:   (MKT-71) 073EDB30 00000808 0000251E 0000000E
[  100.183227] PVR_K:   (MKT-72) 073EDB58 00000808 0000251E 0000000F
[  100.189636] PVR_K:   (MKT-73) 073EDBC3 00000808 0000251E AD000184
[  100.196105] PVR_K:   (MKT-74) 073EDC29 00000C08 0100261D AD000281
[  100.202575] PVR_K:   (MKT-75) 073EDD9D 00000808 0100261D AD00080A
[  100.208984] PVR_K:   (MKT-76) 073EDDB5 00000808 0100261D 0F03DE00
[  100.215454] PVR_K:   (MKT-77) 073EDDCE 00000808 0100261D 00000060
[  100.221984] PVR_K:   (MKT-78) 073EE08D 00000808 0000261D AD000803
[  100.228454] PVR_K:   (MKT-79) 073EE0D3 00180CC8 0000261D AD000282
[  100.234863] PVR_K:   (MKT-7A) 073EE193 00000808 0100281F AD000200
[  100.241302] PVR_K:   (MKT-7B) 073EE3B1 00000808 0000281F AD000202
[  100.247711] PVR_K:   (MKT-7C) 073EE437 00000808 0000291E AD000183
[  100.254150] PVR_K:   (MKT-7D) 073EE52D 00000808 0000291E AD00030E
[  100.260589] PVR_K:   (MKT-7E) 073EE545 00000808 0000291E 0D800474
[  100.267059] PVR_K:   (MKT-7F) 073EE55E 00000808 0000291E 0000000E
[  100.273468] PVR_K:   (MKT-80) 073EE581 00000808 0000291E 0000000F
[  100.279937] PVR_K:   (MKT-81) 073EE5EC 00000808 0000291E AD000184
[  100.286346] PVR_K:   (MKT-82) 073EE653 00000C08 01002A1D AD000281
[  100.292785] PVR_K:   (MKT-83) 073EE7C4 00000808 01002A1D AD00080A
[  100.299285] PVR_K:   (MKT-84) 073EE7DD 00000808 01002A1D 0F03E100
[  100.305725] PVR_K:   (MKT-85) 073EE7F6 00000808 01002A1D 00000060
[  100.312194] PVR_K:   (MKT-86) 073EEAB9 00000808 00002A1D AD000803
[  100.318664] PVR_K:   (MKT-87) 073EEAFF 00180CC8 00002A1D AD000282
[  100.325134] PVR_K:   (MKT-88) 073EEBF0 00000808 01002C1F AD000200
[  100.331542] PVR_K:   (MKT-89) 073EEE17 00000808 00002C1F AD000202
[  100.338043] PVR_K:   (MKT-8A) 073EEE9A 00000808 00002D1E AD000183
[  100.344848] PVR_K:   (MKT-8B) 073EEF85 00000808 00002D1E AD00030E
[  100.351318] PVR_K:   (MKT-8C) 073EEF9D 00000808 00002D1E 0D800474
[  100.357727] PVR_K:   (MKT-8D) 073EEFB6 00000808 00002D1E 0000000E
[  100.364196] PVR_K:   (MKT-8E) 073EEFD9 00000808 00002D1E 0000000F
[  100.370605] PVR_K:   (MKT-8F) 073EF044 00000808 00002D1E AD000184
[  100.377075] PVR_K:   (MKT-90) 073EF0AC 00000C08 01002E1D AD000281
[  100.383514] PVR_K:   (MKT-91) 073EF221 00000808 01002E1D AD00080A
[  100.389953] PVR_K:   (MKT-92) 073EF23A 00000808 01002E1D 0F03E400
[  100.396362] PVR_K:   (MKT-93) 073EF253 00000808 01002E1D 00000062
[  100.402862] PVR_K:   (MKT-94) 073EF50B 00000808 00002E1D AD000803
[  100.409301] PVR_K:   (MKT-95) 073EF551 00180C88 00002E1D AD000282
[  100.415710] PVR_K:   (MKT-96) 073F0072 00000808 0100301F AD000200
[  100.422180] PVR_K:   (MKT-97) 073F0192 00000808 0100301F AD001703
[  100.428588] PVR_K:   (MKT-98) 073F0382 00000808 0000301F AD000202
[  100.435058] PVR_K:   (MKT-99) 073F0400 00000808 0000311E AD000183
[  100.441497] PVR_K:   (MKT-9A) 073F04EC 00000808 0000311E AD00030E
[  100.447967] PVR_K:   (MKT-9B) 073F0504 00000808 0000311E 0D800474
[  100.454376] PVR_K:   (MKT-9C) 073F051E 00000808 0000311E 0000000E
[  100.460845] PVR_K:   (MKT-9D) 073F0542 00000808 0000311E 0000000F
[  100.467254] PVR_K:   (MKT-9E) 073F05AD 00000808 0000311E AD000184
[  100.473693] PVR_K:   (MKT-9F) 073F0611 00000C08 0100321D AD000281
[  100.480560] PVR_K:   (MKT-A0) 073F0729 00000808 0100321D AD000E02
[  100.486999] PVR_K:   (MKT-A1) 073F079C 00000808 0100321D AD000282
[  100.493408] PVR_K:   (MKT-A2) 073FD511 00000808 0100351F AD001A00
[  100.499938] PVR_K:   (MKT-A3) 0740E26B 00000808 0100381F AD00000A
[  100.506378] PVR_K:   (MKT-A4) 0740E2CB 00000808 0100381F AD000909
[  100.512786] PVR_K:   (MKT-A5) 0740E318 00000808 0100381F AD001A05
[  100.519256] PVR_K:   (MKT-A6) 0740E348 00000808 0100381F AD001302
[  100.525665] PVR_K:   (MKT-A7) 0740E388 00000808 0100381F AD001303
[  100.532196] PVR_K:   (MKT-A8) 0740E417 00000808 0100381F AD000D04
[  100.538604] PVR_K:   (MKT-A9) 0740E4DD 00000808 0100381F AD000D05
[  100.545043] PVR_K:   (MKT-AA) 0740E534 00000808 0100381F AD000D04
[  100.551452] PVR_K:   (MKT-AB) 0740E5BB 00000808 0100381F AD000D05
[  100.557891] PVR_K:   (MKT-AC) 0740E618 00000808 0100381F AD001A06
[  100.567138] PVR_K:   (MKT-AD) 00000797 00100808 0100031F AD002300
[  100.573760] PVR_K:   (MKT-AE) 00000C82 00100808 0100041F AD00000A
[  100.580230] PVR_K:   (MKT-AF) 00000CFF 00100808 0100041F AD000906
[  100.586822] PVR_K:   (MKT-B0) 00000DD4 00100808 0000041F AD000901
[  100.593261] PVR_K:   (MKT-B1) 00000E52 00100808 0000051E AD000183
[  100.599731] PVR_K:   (MKT-B2) 00000FC8 00100808 0000051E AD000302
[  100.606109] PVR_K:   (MKT-B3) 0000114C 00100808 0000051E AD000D06
[  100.612609] PVR_K:   (MKT-B4) 00001236 00100808 0000051E AD000D07
[  100.619079] PVR_K:   (MKT-B5) 00001280 00100808 0000051E AD001304
[  100.625488] PVR_K:   (MKT-B6) 00001371 00100808 0000051E AD001305
[  100.632019] PVR_K:   (MKT-B7) 00001485 00100888 0000051E AD000404
[  100.639099] PVR_K:   (MKT-B8) 00001550 00100808 0000051E AD000402
[  100.645812] PVR_K:   (MKT-B9) 00001599 0010082B 0000051E AD000184
[  100.652313] PVR_K:   (MKT-BA) 00001660 00119CAD 0000061D AD000281
[  100.658874] PVR_K:   (MKT-BB) 000017C6 001089AF 0000061D AD000E02
[  100.665405] PVR_K:   (MKT-BC) 00001824 0010092B 0000061D AD000282
[  100.671874] PVR_K:   (MKT-BD) 00003DD3 00100808 0000081F AD000101
[  100.678314] PVR_K:   (MKT-BE) 00003E48 00100808 0000081F AD000104
[  100.684844] PVR_K:   (MKT-BF) 00003E84 00100808 0100091E AD000100
[  100.691284] PVR_K:   (MKT-C0) 00003F7C 00100808 0100091E AD000501
[  100.697937] PVR_K:   (MKT-C1) 00003FBA 0010082B 0100091E AD000104
[  100.704437] PVR_K:   (MKT-C2) 0000626E 00100828 01000A1F AD000101
[  100.710906] PVR_K:   (MKT-C3) 000062C5 00100828 01000A1F AD000104
[  100.717376] PVR_K:   (MKT-C4) 000063CE 00100808 01000B1F AD000100
[  100.723785] PVR_K:   (MKT-C5) 0000649C 00100808 01000B1F AD000501
[  100.730316] PVR_K:   (MKT-C6) 000064D2 00100829 01000B1F AD000104
[  100.736755] PVR_K:   (MKT-C7) 075413CC 00100808 0100031F AD000B00
[  100.743194] PVR_K:   (MKT-C8) 07541413 00100808 0100031F AD000B03
[  100.749603] PVR_K:   (MKT-C9) 07541498 00100808 0100031F AD000B05
[  100.756103] PVR_K:   (MKT-CA) 075414EC 00100808 0100031F AD000B06
[  100.762512] PVR_K:   (MKT-CB) 0754151B 00100808 0100031F AD000B06
[  100.768981] PVR_K:   (MKT-CC) 0754155F 00100808 0100031F AD000B07
[  100.775451] PVR_K:   (MKT-CD) 07541584 00100808 0100031F AD000B09
[  100.781921] PVR_K:   (MKT-CE) 075415D9 00100808 0100031F AD000B01
[  100.788330] PVR_K:   (MKT-CF) 07541615 00100808 0100031F AD002300
[  100.794799] PVR_K:   (MKT-D0) 07541940 00100808 0100041F AD00000A
[  100.801208] PVR_K:   (MKT-D1) 0754198E 00100808 0100041F AD001100
[  100.807678] PVR_K:   (MKT-D2) 07541A19 00100808 0100041F AD000906
[  100.814178] PVR_K:   (MKT-D3) 07541ACF 00100808 0000041F AD000901
[  100.820648] PVR_K:   (MKT-D4) 07541B4A 00100808 0000051E AD000183
[  100.827087] PVR_K:   (MKT-D5) 07541CC9 00100808 0000051E AD000302
[  100.833496] PVR_K:   (MKT-D6) 07541D1D 00100808 0000051E AD000303
[  100.839935] PVR_K:   (MKT-D7) 07541DA6 00100808 0000051E AD000C01
[  100.846405] PVR_K:   (MKT-D8) 07541DCA 00100808 0000051E 0D800464
[  100.852874] PVR_K:   (MKT-D9) 07541DE3 00100808 0000051E 00000010
[  100.859283] PVR_K:   (MKT-DA) 07542047 00100808 0000051E AD00030E
[  100.865753] PVR_K:   (MKT-DB) 0754205F 00100808 0000051E 0D800494
[  100.872161] PVR_K:   (MKT-DC) 07542078 00100808 0000051E 0000000E
[  100.878631] PVR_K:   (MKT-DD) 0754209C 00100808 0000051E 0000000F
[  100.885040] PVR_K:   (MKT-DE) 07542114 00100808 0000051E AD000184
[  100.891723] PVR_K:   (MKT-DF) 07542192 00100C08 0100061D AD000281
[  100.898468] PVR_K:   (MKT-E0) 07542330 00100808 0100061D AD00080A
[  100.905334] PVR_K:   (MKT-E1) 07542349 00100808 0100061D 0F03E700
[  100.913757] PVR_K:   (MKT-E2) 07542361 00100808 0100061D 00000061
[  100.920379] PVR_K:   (MKT-E3) 0754247A 00100C88 0100061D AD001300
[  100.926818] PVR_K:   (MKT-E4) 075478A2 00100808 0000061D AD001301
[  100.933258] PVR_K:   (MKT-E5) 075479D9 00100888 0000061D AD000802
[  100.939727] PVR_K:   (MKT-E6) 07547B45 00100888 0000061D AD000803
[  100.946166] PVR_K:   (MKT-E7) 07547B93 001808C8 0000061D AD000282
[  100.952697] PVR_K:   (MKT-E8) 07547C75 00184AF8 0000081E AD00000A
[  100.959197] PVR_K:   (MKT-E9) 07547CED 001808F8 0000081E AD000905
[  100.965667] PVR_K:   (MKT-EA) 07547E10 001808B8 0000081E AD000901
[  100.972229] PVR_K:   (MKT-EB) 07547E88 00180838 0000091C AD00000A
[  100.978851] PVR_K:   (MKT-EC) 07547EEF 00180838 0000091C AD000905
[  100.986022] PVR_K:   (MKT-ED) 07547F9B 00180838 0000091C AD000901
[  100.992553] PVR_K:   (MKT-EE) 07547FF9 00180838 00000A1B AD00000A
[  100.999328] PVR_K:   (MKT-EF) 0754805D 00180838 00000A1B AD000905
[  101.005950] PVR_K:   (MKT-F0) 07548114 00180838 00000A1B AD000901
[  101.022338] PVR_K:   (MKT-F1) 07548168 00180838 00000B1A AD00000A
[  101.028808] PVR_K:   (MKT-F2) 075481D4 00180838 00000B1A AD000906
[  101.035858] PVR_K:   (MKT-F3) 07548249 00180838 00000B1A AD000901
[  101.046356] PVR_K:   (MKT-F4) 0754829E 00180838 00000C19 AD00000A
[  101.052825] PVR_K:   (MKT-F5) 0754830C 00180838 00000C19 AD000905
[  101.059234] PVR_K:   (MKT-F6) 075483B7 00180838 00000C19 AD000901
[  101.065734] PVR_K:   (MKT-F7) 07548535 00180838 00000F1F AD000183
[  101.072143] PVR_K:   (MKT-F8) 075486B0 00180838 00000F1F AD000302
[  101.078582] PVR_K:   (MKT-F9) 07548731 00180838 00000F1F AD000303
[  101.085021] PVR_K:   (MKT-FA) 075487B1 00180838 00000F1F AD000C01
[  101.091461] PVR_K:   (MKT-FB) 075487D5 00180838 00000F1F 0D800484
[  101.097930] PVR_K:   (MKT-FC) 075487EF 00180838 00000F1F 00000010
[  101.104370] PVR_K:   (MKT-FD) 07548A21 00180838 00000F1F AD000184
[  101.110778] PVR_K:   (MKT-FE) 07548A92 00180C38 0100101D AD000281
[  101.117248] PVR_K:   (MKT-FF) 07548AED 00180838 0100101D AD000282
[  101.123657] PVR_K:   (MKT-100) 075493D5 00180838 0100111F AD00000A
[  101.130187] PVR_K:   (MKT-101) 0754943E 00180838 0100111F AD000905
[  101.136718] PVR_K:   (MKT-102) 07549540 00180838 0000111F AD000901
[  101.143249] PVR_K:   (MKT-103) 07549590 00180C38 0100121E AD000281
[  101.149810] PVR_K:   (MKT-104) 075495E8 00180838 0100121E AD000282
[  101.156402] PVR_K:   (MKT-105) 075496D0 00180838 0100131F AD00000A
[  101.162963] PVR_K:   (MKT-106) 0754973A 00180838 0100131F AD000905
[  101.169464] PVR_K:   (MKT-107) 0754983A 00180838 0000131F AD000901
[  101.176025] PVR_K:   (MKT-108) 0754988C 00180C38 0100141E AD000281
[  101.182525] PVR_K:   (MKT-109) 075498E3 00180838 0100141E AD000282
[  101.189086] PVR_K:   (MKT-10A) 07549A22 00180838 0100151F AD00000A
[  101.195587] PVR_K:   (MKT-10B) 07549A8D 00180838 0100151F AD000905
[  101.202117] PVR_K:   (MKT-10C) 07549B90 00180838 0000151F AD000901
[  101.208618] PVR_K:   (MKT-10D) 07549BE2 00180C38 0100161E AD000281
[  101.215179] PVR_K:   (MKT-10E) 07549C40 00180838 0000161E AD000282
[  101.221679] PVR_K:   (MKT-10F) 07549CF5 00180838 0100171F AD00000A
[  101.228210] PVR_K:   (MKT-110) 07549D61 00100828 0100171F AD000905
[  101.234771] PVR_K:   (MKT-111) 07549E60 00000808 0000171F AD000901
[  101.241271] PVR_K:   (MKT-112) 07549E96 00000C08 0000181E AD000200
[  101.247802] PVR_K:   (MKT-113) 0754A0E5 00000808 0000181E AD000202
[  101.254333] PVR_K:   (MKT-114) 0754A13F 00000808 0100191D AD000281
[  101.260864] PVR_K:   (MKT-115) 0754A28F 00000808 0100191D AD00080A
[  101.267364] PVR_K:   (MKT-116) 0754A2A8 00000808 0100191D 0F03EA00
[  101.273956] PVR_K:   (MKT-117) 0754A2C0 00000808 0100191D 00000060
[  101.280456] PVR_K:   (MKT-118) 0754A579 00000808 0000191D AD000803
[  101.286987] PVR_K:   (MKT-119) 0754A5C0 00180CC8 0000191D AD000282
[  101.293518] PVR_K:   (MKT-11A) 0754A66A 00000808 01001B1F AD000200
[  101.300079] PVR_K:   (MKT-11B) 0754A892 00000808 00001B1F AD000202
[  101.306579] PVR_K:   (MKT-11C) 0754A8E3 00000808 01001C1E AD000281
[  101.313140] PVR_K:   (MKT-11D) 0754AA34 00000808 01001C1E AD00080A
[  101.319702] PVR_K:   (MKT-11E) 0754AA4D 00000808 01001C1E 0F03ED00
[  101.326354] PVR_K:   (MKT-11F) 0754AA66 00000808 01001C1E 00000060
[  101.333007] PVR_K:   (MKT-120) 0754AD29 00000808 00001C1E AD000803
[  101.339599] PVR_K:   (MKT-121) 0754AD71 00180CC8 00001C1E AD000282
[  101.346221] PVR_K:   (MKT-122) 0754AE5B 00000808 01001E1F AD000200
[  101.352752] PVR_K:   (MKT-123) 0754B084 00000808 00001E1F AD000202
[  101.359313] PVR_K:   (MKT-124) 0754B0D2 00000808 01001F1E AD000281
[  101.365783] PVR_K:   (MKT-125) 0754B22D 00000808 01001F1E AD00080A
[  101.372406] PVR_K:   (MKT-126) 0754B246 00000808 01001F1E 0F03F000
[  101.378906] PVR_K:   (MKT-127) 0754B25E 00000808 01001F1E 00000062
[  101.385437] PVR_K:   (MKT-128) 0754B519 00000808 00001F1E AD000803
[  101.392089] PVR_K:   (MKT-129) 0754B561 00180C88 00001F1E AD000282
[  101.398559] PVR_K:   (MKT-12A) 0754C0CC 00000808 0100211F AD000200
[  101.405120] PVR_K:   (MKT-12B) 0754C1E9 001FFFFF 0100211F AD001703
[  101.411621] PVR_K:   (MKT-12C) 0754C3EE 00000808 0000211F AD000202
[  101.420471] PVR_K:   (MKT-12D) 0754C472 00000808 0000221E AD000183
[  101.428192] PVR_K:   (MKT-12E) 0754C55F 00000808 0000221E AD00030E
[  101.435058] PVR_K:   (MKT-12F) 0754C577 00000808 0000221E 0D800474
[  101.441589] PVR_K:   (MKT-130) 0754C591 00000808 0000221E 0000000F
[  101.448150] PVR_K:   (MKT-131) 0754C5B4 00000808 0000221E 00000010
[  101.454681] PVR_K:   (MKT-132) 0754C620 00000808 0000221E AD000184
[  101.461212] PVR_K:   (MKT-133) 0754C687 00000C08 0100231D AD000281
[  101.467712] PVR_K:   (MKT-134) 0754C809 00000808 0100231D AD00080A
[  101.474273] PVR_K:   (MKT-135) 0754C822 00000808 0100231D 0F03F300
[  101.480834] PVR_K:   (MKT-136) 0754C83C 00000808 0100231D 00000061
[  101.487518] PVR_K:   (MKT-137) 0754C9C8 00000808 0000231D AD000802
[  101.494079] PVR_K:   (MKT-138) 0754CB20 00000808 0000231D AD000803
[  101.500579] PVR_K:   (MKT-139) 0754CB68 00184EC8 0000231D AD000282
[  101.507110] PVR_K:   (MKT-13A) 0754EBC6 00000C08 0100261F AD000200
[  101.516601] PVR_K:   (MKT-13B) 0754EE1D 00000808 0000261F AD000202
[  101.523162] PVR_K:   (MKT-13C) 0754EEA6 00000808 0000271E AD000183
[  101.529663] PVR_K:   (MKT-13D) 0754EF97 00000808 0000271E AD00030E
[  101.536224] PVR_K:   (MKT-13E) 0754EFAF 00000808 0000271E 0D800474
[  101.542755] PVR_K:   (MKT-13F) 0754EFC7 00000808 0000271E 0000000F
[  101.549285] PVR_K:   (MKT-140) 0754EFEB 00000808 0000271E 00000010
[  101.557922] PVR_K:   (MKT-141) 0754F057 00000808 0000271E AD000184
[  101.564483] PVR_K:   (MKT-142) 0754F0BD 00000C08 0100281D AD000281
[  101.571044] PVR_K:   (MKT-143) 0754F22D 00000808 0100281D AD00080A
[  101.577575] PVR_K:   (MKT-144) 0754F246 00000808 0100281D 0F03F600
[  101.584106] PVR_K:   (MKT-145) 0754F25E 00000808 0100281D 00000060
[  101.590606] PVR_K:   (MKT-146) 0754F528 00000808 0000281D AD000803
[  101.597198] PVR_K:   (MKT-147) 0754F571 00180CC8 0000281D AD000282
[  101.603759] PVR_K:   (MKT-148) 0754F613 00000808 01002A1F AD000200
[  101.610351] PVR_K:   (MKT-149) 0754F83A 00000808 00002A1F AD000202
[  101.616851] PVR_K:   (MKT-14A) 0754F8BD 00000808 00002B1E AD000183
[  101.623382] PVR_K:   (MKT-14B) 0754F9AE 00000808 00002B1E AD00030E
[  101.630035] PVR_K:   (MKT-14C) 0754F9C6 00000808 00002B1E 0D800474
[  101.636596] PVR_K:   (MKT-14D) 0754F9E0 00000808 00002B1E 0000000F
[  101.643066] PVR_K:   (MKT-14E) 0754FA05 00000808 00002B1E 00000010
[  101.649627] PVR_K:   (MKT-14F) 0754FA71 00000808 00002B1E AD000184
[  101.649749] eth0: no IPv6 routers present
[  101.660552] PVR_K:   (MKT-150) 0754FAD8 00000C08 01002C1D AD000281
[  101.667083] PVR_K:   (MKT-151) 0754FC4A 00000808 01002C1D AD00080A
[  101.673614] PVR_K:   (MKT-152) 0754FC63 00000808 01002C1D 0F03F900
[  101.680786] PVR_K:   (MKT-153) 0754FC7B 00000808 01002C1D 00000060
[  101.687377] PVR_K:   (MKT-154) 0754FF3D 00000808 00002C1D AD000803
[  101.693969] PVR_K:   (MKT-155) 0754FF83 00188CC8 00002C1D AD000282
[  101.700500] PVR_K:   (MKT-156) 0755006D 00000808 01002E1F AD000200
[  101.707031] PVR_K:   (MKT-157) 07550291 00000808 00002E1F AD000202
[  101.713745] PVR_K:   (MKT-158) 07550311 00000808 00002F1E AD000183
[  101.720306] PVR_K:   (MKT-159) 075503FA 00000808 00002F1E AD00030E
[  101.726776] PVR_K:   (MKT-15A) 07550412 00000808 00002F1E 0D800474
[  101.733337] PVR_K:   (MKT-15B) 0755042B 00000808 00002F1E 0000000F
[  101.739837] PVR_K:   (MKT-15C) 0755044E 00000808 00002F1E 00000010
[  101.748443] PVR_K:   (MKT-15D) 075504BB 00000808 00002F1E AD000184
[  101.757049] PVR_K:   (MKT-15E) 07550521 00000C08 0100301D AD000281
[  101.763610] PVR_K:   (MKT-15F) 07550697 00000808 0100301D AD00080A
[  101.770172] PVR_K:   (MKT-160) 075506B0 00000808 0100301D 0F03FC00
[  101.777191] PVR_K:   (MKT-161) 075506C9 00000808 0100301D 00000062
[  101.783843] PVR_K:   (MKT-162) 0755098D 00000808 0000301D AD000803
[  101.790374] PVR_K:   (MKT-163) 075509D3 00180C88 0000301D AD000282
[  101.796936] PVR_K:   (MKT-164) 07551510 00000808 0100321F AD000200
[  101.803436] PVR_K:   (MKT-165) 0755162C 00000808 0100321F AD001703
[  101.809997] PVR_K:   (MKT-166) 07551819 00000808 0000321F AD000202
[  101.816528] PVR_K:   (MKT-167) 07551899 00000808 0000331E AD000183
[  101.823089] PVR_K:   (MKT-168) 0755198A 00000808 0000331E AD00030E
[  101.829589] PVR_K:   (MKT-169) 075519A2 00000808 0000331E 0D800474
[  101.836151] PVR_K:   (MKT-16A) 075519BB 00000808 0000331E 0000000F
[  101.842681] PVR_K:   (MKT-16B) 075519E2 00000808 0000331E 00000010
[  101.849212] PVR_K:   (MKT-16C) 07551A4D 00000808 0000331E AD000184
[  101.855865] PVR_K:   (MKT-16D) 07551AB6 00000C08 0100341D AD000281
[  101.862365] PVR_K:   (MKT-16E) 07551BCB 00000808 0100341D AD000E02
[  101.868896] PVR_K:   (MKT-16F) 07551C40 00000808 0100341D AD000282
[  101.875396] PVR_K:   (MKT-170) 0755EB04 00000808 0100371F AD001A00
[  101.881958] PVR_K:   (MKT-171) 0757CD04 00000808 01003D1F AD00000A
[  101.888458] PVR_K:   (MKT-172) 0757CD67 00000808 01003D1F AD000909
[  101.895019] PVR_K:   (MKT-173) 0757CDB3 00000808 01003D1F AD001A05
[  101.901550] PVR_K:   (MKT-174) 0757CDE6 00000808 01003D1F AD001302
[  101.908111] PVR_K:   (MKT-175) 0757CE2B 00000808 01003D1F AD001303
[  101.915008] PVR_K:   (MKT-176) 0757CEC1 00000808 01003D1F AD000D04
[  101.921569] PVR_K:   (MKT-177) 0757CF8E 00000808 01003D1F AD000D05
[  101.928100] PVR_K:   (MKT-178) 0757CFEC 00000808 01003D1F AD000D04
[  101.935424] PVR_K:   (MKT-179) 0757D076 00000808 01003D1F AD000D05
[  101.942291] PVR_K:   (MKT-17A) 0757D0D5 00000808 01003D1F AD001A06
[  101.948852] PVR_K:   (MKT-17B) 00000495 00100808 0100031F AD002300
[  101.955627] PVR_K:   (MKT-17C) 0000098D 00100808 0100041F AD00000A
[  101.962158] PVR_K:   (MKT-17D) 00000A0B 00100808 0100041F AD000906
[  101.968719] PVR_K:   (MKT-17E) 00000ADC 00100808 0000041F AD000901
[  101.975219] PVR_K:   (MKT-17F) 00000B55 00100808 0000051E AD000183
[  101.981781] PVR_K:   (MKT-180) 00000CCA 00100808 0000051E AD000302
[  101.988281] PVR_K:   (MKT-181) 00000E59 00100808 0000051E AD000D06
[  101.994995] PVR_K:   (MKT-182) 00000F44 00100808 0000051E AD000D07
[  102.001495] PVR_K:   (MKT-183) 00000F8F 00100808 0000051E AD001304
[  102.008056] PVR_K:   (MKT-184) 00001081 00100808 0000051E AD001305
[  102.014556] PVR_K:   (MKT-185) 00001197 00100888 0000051E AD000404
[  102.021148] PVR_K:   (MKT-186) 00001260 00100808 0000051E AD000402
[  102.027709] PVR_K:   (MKT-187) 000012AA 0010082B 0000051E AD000184
[  102.034210] PVR_K:   (MKT-188) 00001357 00108DA9 0000061D AD000281
[  102.040771] PVR_K:   (MKT-189) 000014E9 001089AF 0000061D AD000E02
[  102.047271] PVR_K:   (MKT-18A) 00001547 0010892B 0000061D AD000282
[  102.056121] PVR_K:   (MKT-18B) 00003C81 00100808 0000081F AD000101
[  102.062683] PVR_K:   (MKT-18C) 00003CFD 00100808 0000081F AD000104
[  102.069213] PVR_K:   (MKT-18D) 00003D3A 00100808 0100091E AD000100
[  102.075744] PVR_K:   (MKT-18E) 00003E3F 00100808 0100091E AD000501
[  102.082305] PVR_K:   (MKT-18F) 00003E7F 00100829 0100091E AD000104
[  102.088897] PVR_K:   (MKT-190) 000063E3 00100828 01000B1E AD000101
[  102.095458] PVR_K:   (MKT-191) 0000645F 00100828 01000B1E AD000104
[  102.101959] PVR_K:   (MKT-192) 000064A7 00100808 01000C1F AD000100
[  102.108551] PVR_K:   (MKT-193) 00006597 00100808 01000C1F AD000501
[  102.115081] PVR_K:   (MKT-194) 000065D6 00100829 01000C1F AD000104
[  102.121612] PVR_K:   (MKT-195) 00008C46 00100828 01000D1F AD000101
[  102.128173] PVR_K:   (MKT-196) 00008C9E 00100828 01000D1F AD000104
[  102.134674] PVR_K:   (MKT-197) 00008D33 00100808 01000E1F AD000100
[  102.141204] PVR_K:   (MKT-198) 00008E10 00100808 01000E1F AD000501
[  102.147735] PVR_K:   (MKT-199) 00008E47 00100829 01000E1F AD000104
[  102.154266] PVR_K:   (MKT-19A) 0000AFC8 00100828 01000F1F AD000101
[  102.160858] PVR_K:   (MKT-19B) 0000B01D 00100828 01000F1F AD000104
[  102.167510] PVR_K:   (MKT-19C) 0000B1F4 00100808 0100101F AD000100
[  102.174072] PVR_K:   (MKT-19D) 0000B282 00100808 0100101F AD000502
[  102.180664] PVR_K:   (MKT-19E) 0000B2CC 00100808 0100101F AD000C01
[  102.187225] PVR_K:   (MKT-19F) 0000B2F0 00100808 0100101F 0D800464
[  102.193817] PVR_K:   (MKT-1A0) 0000B308 00100808 0100101F 00000011
[  102.200744] PVR_K:   (MKT-1A1) 0000B5CC 00100808 0000101F AD00030E
[  102.207336] PVR_K:   (MKT-1A2) 0000B5E4 00100808 0000101F 0D800494
[  102.213989] PVR_K:   (MKT-1A3) 0000B600 00100808 0000101F 0000000F
[  102.220672] PVR_K:   (MKT-1A4) 0000B623 00100808 0000101F 00000010
[  102.227203] PVR_K:   (MKT-1A5) 0000B6BD 00100808 0000101F AD000104
[  102.233703] PVR_K:   (MKT-1A6) 0000B73A 00100C08 0100111E AD000281
[  102.240295] PVR_K:   (MKT-1A7) 0000B8BE 00100808 0100111E AD00080A
[  102.246795] PVR_K:   (MKT-1A8) 0000B8D7 00100808 0100111E 0F03FF00
[  102.253326] PVR_K:   (MKT-1A9) 0000B8EF 00100808 0100111E 00000061
[  102.259826] PVR_K:   (MKT-1AA) 0000BA7C 00100808 0000111E AD000802
[  102.266387] PVR_K:   (MKT-1AB) 0000BBDB 00100808 0000111E AD000803
[  102.273193] PVR_K:   (MKT-1AC) 0000BC25 00184AC8 0000111E AD000282
[  102.279724] PVR_K:   (MKT-1AD) 0000DCCF 00000C08 0100141F AD000200
[  102.286285] PVR_K:   (MKT-1AE) 0000DF25 00000808 0000141F AD000202
[  102.292785] PVR_K:   (MKT-1AF) 0000DFB0 00000808 0000151E AD000183
[  102.299316] PVR_K:   (MKT-1B0) 0000E0A1 00000808 0000151E AD00030E
[  102.305816] PVR_K:   (MKT-1B1) 0000E0C1 00000808 0000151E 0D800494
[  102.312377] PVR_K:   (MKT-1B2) 0000E0DA 00000808 0000151E 0000000F
[  102.318847] PVR_K:   (MKT-1B3) 0000E0FE 00000808 0000151E 00000010
[  102.325408] PVR_K:   (MKT-1B4) 0000E168 00000808 0000151E AD000184
[  102.331878] PVR_K:   (MKT-1B5) 0000E1D1 00000C08 0100161D AD000281
[  102.338439] PVR_K:   (MKT-1B6) 0000E33E 00000808 0100161D AD00080A
[  102.344940] PVR_K:   (MKT-1B7) 0000E356 00000808 0100161D 0F040200
[  102.351470] PVR_K:   (MKT-1B8) 0000E371 00000808 0100161D 00000060
[  102.357940] PVR_K:   (MKT-1B9) 0000E635 00000808 0000161D AD000803
[  102.364532] PVR_K:   (MKT-1BA) 0000E67C 00180CC8 0000161D AD000282
[  102.371063] PVR_K:   (MKT-1BB) 0000E71D 00000808 0100181F AD000200
[  102.377563] PVR_K:   (MKT-1BC) 0000E93B 00000808 0000181F AD000202
[  102.384094] PVR_K:   (MKT-1BD) 0000E9BB 00000808 0000191E AD000183
[  102.390563] PVR_K:   (MKT-1BE) 0000EAA6 00000808 0000191E AD00030E
[  102.397094] PVR_K:   (MKT-1BF) 0000EAC6 00000808 0000191E 0D800494
[  102.403594] PVR_K:   (MKT-1C0) 0000EAE0 00000808 0000191E 0000000F
[  102.410156] PVR_K:   (MKT-1C1) 0000EB05 00000808 0000191E 00000010
[  102.416625] PVR_K:   (MKT-1C2) 0000EB6F 00000808 0000191E AD000184
[  102.423187] PVR_K:   (MKT-1C3) 0000EBD6 00000C08 01001A1D AD000281
[  102.429687] PVR_K:   (MKT-1C4) 0000ED44 00000808 01001A1D AD00080A
[  102.436218] PVR_K:   (MKT-1C5) 0000ED5D 00000808 01001A1D 0F040500
[  102.442718] PVR_K:   (MKT-1C6) 0000ED75 00000808 01001A1D 00000060
[  102.449340] PVR_K:   (MKT-1C7) 0000F027 00000808 00001A1D AD000803
[  102.455871] PVR_K:   (MKT-1C8) 0000F070 00180CC8 00001A1D AD000282
[  102.462371] PVR_K:   (MKT-1C9) 0000F13B 00000808 01001C1F AD000200
[  102.468933] PVR_K:   (MKT-1CA) 0000F359 00000808 00001C1F AD000202
[  102.475402] PVR_K:   (MKT-1CB) 0000F3DA 00000808 00001D1E AD000183
[  102.481964] PVR_K:   (MKT-1CC) 0000F4C7 00000808 00001D1E AD00030E
[  102.488464] PVR_K:   (MKT-1CD) 0000F4DF 00000808 00001D1E 0D800494
[  102.494995] PVR_K:   (MKT-1CE) 0000F4F8 00000808 00001D1E 0000000F
[  102.501495] PVR_K:   (MKT-1CF) 0000F51B 00000808 00001D1E 00000010
[  102.508026] PVR_K:   (MKT-1D0) 0000F586 00000808 00001D1E AD000184
[  102.514556] PVR_K:   (MKT-1D1) 0000F5EB 00000C08 01001E1D AD000281
[  102.521087] PVR_K:   (MKT-1D2) 0000F75C 00000808 01001E1D AD00080A
[  102.527587] PVR_K:   (MKT-1D3) 0000F774 00000808 01001E1D 0F040800
[  102.534149] PVR_K:   (MKT-1D4) 0000F78D 00000808 01001E1D 00000062
[  102.540679] PVR_K:   (MKT-1D5) 0000FA3F 00000808 00001E1D AD000803
[  102.547180] PVR_K:   (MKT-1D6) 0000FA84 00180C88 00001E1D AD000282
[  102.555786] PVR_K:   (MKT-1D7) 000105C7 00000808 0100201F AD000200
[  102.562286] PVR_K:   (MKT-1D8) 000106E6 00000808 0100201F AD001703
[  102.568817] PVR_K:   (MKT-1D9) 000108B9 00000808 0000201F AD000202
[  102.575317] PVR_K:   (MKT-1DA) 00010936 00000808 0100211E AD000183
[  102.581878] PVR_K:   (MKT-1DB) 00010A21 00000808 0100211E AD00030E
[  102.588378] PVR_K:   (MKT-1DC) 00010A39 00000808 0100211E 0D800494
[  102.594909] PVR_K:   (MKT-1DD) 00010A52 00000808 0100211E 0000000F
[  102.601409] PVR_K:   (MKT-1DE) 00010A75 00000808 0100211E 00000010
[  102.607940] PVR_K:   (MKT-1DF) 00010B02 00000808 0100211E AD000184
[  102.614471] PVR_K:   (MKT-1E0) 0001D960 00000808 0100241F AD001A00
[  102.621002] PVR_K:   (MKT-1E1) 0001DEB6 00000808 0100251F AD00000A
[  102.627532] PVR_K:   (MKT-1E2) 0001DF24 00000808 0100251F AD000909
[  102.634033] PVR_K:   (MKT-1E3) 0001DF6F 00000808 0100251F AD001A05
[  102.640594] PVR_K:   (MKT-1E4) 0001DF9F 00000808 0100251F AD001302
[  102.647064] PVR_K:   (MKT-1E5) 0001DFE0 00000808 0100251F AD001303
[  102.653625] PVR_K:   (MKT-1E6) 0001E078 00000808 0100251F AD000D04
[  102.660095] PVR_K:   (MKT-1E7) 0001E140 00000808 0100251F AD000D05
[  102.666656] PVR_K:   (MKT-1E8) 0001E1B3 00000808 0100251F AD001A06
[  102.673156] PVR_K:   (MKT-1E9) 00000527 00100808 0100031F AD002300
[  102.679687] PVR_K:   (MKT-1EA) 00000A4B 00100808 0100041F AD00000A
[  102.686187] PVR_K:   (MKT-1EB) 00000AC9 00100808 0100041F AD000906
[  102.692718] PVR_K:   (MKT-1EC) 00000BA1 00100808 0000041F AD000901
[  102.699279] PVR_K:   (MKT-1ED) 00000C1D 00100808 0100051E AD000183
[  102.705780] PVR_K:   (MKT-1EE) 00000D99 00100808 0100051E AD000302
[  102.712310] PVR_K:   (MKT-1EF) 00000F2D 00100808 0100051E AD000D06
[  102.718811] PVR_K:   (MKT-1F0) 0000101B 00100808 0100051E AD000D07
[  102.725341] PVR_K:   (MKT-1F1) 00001067 00100808 0100051E AD001304
[  102.731842] PVR_K:   (MKT-1F2) 00001159 00100808 0100051E AD001305
[  102.738403] PVR_K:   (MKT-1F3) 00001270 00100888 0100051E AD000404
[  102.744903] PVR_K:   (MKT-1F4) 0000133F 00100808 0000051E AD000402
[  102.751434] PVR_K:   (MKT-1F5) 00001388 0010082B 0000051E AD000184
[  102.757934] PVR_K:   (MKT-1F6) 00003C73 00100808 0000071F AD000101
[  102.764495] PVR_K:   (MKT-1F7) 00003CE2 00100808 0000071F AD000104
[  102.770965] PVR_K:   (MKT-1F8) 00003D0E 00100808 0100081E AD000100
[  102.777526] PVR_K:   (MKT-1F9) 00003E1A 00100808 0100081E AD000501
[  102.784088] PVR_K:   (MKT-1FA) 00003E5C 0010082B 0100081E AD000104
[  102.790588] PVR_K:   (MKT-1FB) 00006114 00100828 0100091F AD000101
[  102.797149] PVR_K:   (MKT-1FC) 0000616E 00100828 0100091F AD000104
[  102.803649] PVR_K:   (MKT-1FD) 00006285 00100808 01000A1F AD000100
[  102.810150] PVR_K:   (MKT-1FE) 0000635D 00100808 00000A1F AD000501
[  102.816650] PVR_K:   (MKT-1FF) 00006394 00100829 00000A1F AD000104
[  102.823211] PVR_K: SGX Kernel CCB WO:0xD9 RO:0xD4
[  102.830291] adc_to_temp_conversion:Temp read is invalid 0
[  102.836334] thermal_lookup_temp: getting temp is not supported for domain pcb
[  102.848602] adc_to_temp_conversion:Temp read is invalid 0
[  102.854492] thermal_lookup_temp: getting temp is not supported for domain pcb
[  102.863983] adc_to_temp_conversion:Temp read is invalid 0
[  102.870422] thermal_lookup_temp: getting temp is not supported for domain pcb
[  103.037994] PVR_K:(Error): SGXOSTimer() detected SGX lockup (0x23 tasks) [0, ]
[  103.046722] PVR_K: HWRecoveryResetSGX: SGX Hardware Recovery triggered
[  103.054504] [   82.167]   [c6fa4460] --refs=1 on RELEASED
[  103.054504] [   82.167]                           [c6e66000] dsscomp_apply
[  103.054504] [   82.167]    [c6fa44a0] --refs=0 on RELEASED
[  103.054534] [   82.167]    [c6fa44a0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[  103.054534] [   82.167]                           [c6e67c00] dsscomp_mgr_delayed_cb on RELEASED
[  103.086517] [   82.167]                           [c6e66000] dsscomp_mgr_delayed_cb on PROGRAMMED
[  103.086517] [   82.168]   [c6edbca0] new in dsscomp_gralloc_queue (refs=1)
[  103.086517] [   82.168]                          [c6f10800] dsscomp_new
[  103.115417] [   82.168]   [c6edbca0] ++refs=2 for [c6f10800]
[  103.115417] [   82.168]                          [c6f10800] dsscomp_delayed_apply
[  103.115447] [   82.168]   [c6edbca0] --refs=1 on RELEASED
[  103.115447] [   82.168]                          [c6f10800] dsscomp_apply
[  103.115447] [   82.183]                           [c6e66000] dsscomp_mgr_delayed_cb on DISPLAYED
[  103.151550] [   82.183]   [c6fa4460] --refs=0 on RELEASED
[  103.151580] [   82.183]   [c6fa4460] calling dsscomp_proxy_cmdcomplete [c73f6900]
[  103.151580] [   82.183]                           [c6e66000] dsscomp_mgr_delayed_cb on RELEASED
[  103.180358] [   82.183]                          [c6f10800] dsscomp_mgr_delayed_cb on PROGRAMMED
[  103.180358] [   82.204]                          [c6f10800] dsscomp_mgr_delayed_cb on DISPLAYED
[  103.180358] [   87.162]    [c6edbdc0] new in dsscomp_gralloc_queue (refs=1)
[  103.180358] [   87.162]                       [c6f12c00] dsscomp_new
[  103.210449] [   87.162]    [c6edbdc0] ++refs=2 for [c6f12c00]
[  103.210449] [   87.162]                       [c6f12c00] dsscomp_delayed_apply
[  103.210479] [   87.162]    [c6edbdc0] --refs=1 on RELEASED
[  103.210479] [   87.162]                       [c6f12c00] dsscomp_apply
[  103.240417] [   87.162]   [c6edbca0] --refs=0 on RELEASED
[  103.240417] [   87.162]   [c6edbca0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[  103.240417] [   87.162]                          [c6f10800] dsscomp_mgr_delayed_cb on RELEASED
[  103.240417] [   87.162]                       [c6f12c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[  103.271179] [   87.163]    [c6edbce0] new in dsscomp_gralloc_queue (refs=1)
[  103.271179] [   87.163]                           [c6f13400] dsscomp_new
[  103.271209] [   87.163]    [c6edbce0] ++refs=2 for [c6f13400]
[  103.271209] [   87.163]                           [c6f13400] dsscomp_delayed_apply
[  103.301818] [   87.163]    [c6edbce0] --refs=1 on RELEASED
[  103.301849] [   87.163]                           [c6f13400] dsscomp_apply
[  103.301849] [   87.177]                       [c6f12c00] dsscomp_mgr_delayed_cb on DISPLAYED
[  103.301849] [   87.177]    [c6edbdc0] --refs=0 on RELEASED
[  103.331939] [   87.177]    [c6edbdc0] calling dsscomp_proxy_cmdcomplete [c73f6900]
[  103.331970] [   87.178]                       [c6f12c00] dsscomp_mgr_delayed_cb on RELEASED
[  103.331970] [   87.178]                           [c6f13400] dsscomp_mgr_delayed_cb on PROGRAMMED
[  103.331970] [   87.199]                           [c6f13400] dsscomp_mgr_delayed_cb on DISPLAYED
[  103.362182] [   92.240]       [c6fa4720] new in dsscomp_gralloc_queue (refs=1)
[  103.362182] [   92.240]                       [c6e67400] dsscomp_new
[  103.362182] [   92.240]       [c6fa4720] ++refs=2 for [c6e67400]
[  103.362182] [   92.240]                       [c6e67400] dsscomp_delayed_apply
[  103.394470] [   92.240]       [c6fa4720] --refs=1 on RELEASED
[  103.394470] [   92.240]                       [c6e67400] dsscomp_apply
[  103.394470] [   92.240]    [c6edbce0] --refs=0 on RELEASED
[  103.394470] [   92.240]    [c6edbce0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[  103.425415] [   92.240]                           [c6f13400] dsscomp_mgr_delayed_cb on RELEASED
[  103.425415] [   92.240]                       [c6e67400] dsscomp_mgr_delayed_cb on PROGRAMMED
[  103.425415] [   92.241]      [c6edbc80] new in dsscomp_gralloc_queue (refs=1)
[  103.454315] [   92.241]                         [c6f13000] dsscomp_new
[  103.454315] [   92.241]      [c6edbc80] ++refs=2 for [c6f13000]
[  103.454315] [   92.241]                         [c6f13000] dsscomp_delayed_apply
[  103.454345] [   92.241]      [c6edbc80] --refs=1 on RELEASED
[  103.454345] [   92.241]                         [c6f13000] dsscomp_apply
[  103.487182] [   92.256]                       [c6e67400] dsscomp_mgr_delayed_cb on DISPLAYED
[  103.487182] [   92.256]       [c6fa4720] --refs=0 on RELEASED
[  103.487182] [   92.256]       [c6fa4720] calling dsscomp_proxy_cmdcomplete [c73f6900]
[  103.487182] [   92.256]                       [c6e67400] dsscomp_mgr_delayed_cb on RELEASED
[  103.520141] [   92.256]                         [c6f13000] dsscomp_mgr_delayed_cb on PROGRAMMED
[  103.520141] [   92.277]                         [c6f13000] dsscomp_mgr_delayed_cb on DISPLAYED
[  103.520141] [   97.379]       [c6edbb00] new in dsscomp_gralloc_queue (refs=1)
[  103.548706] [   97.379]                      [c6f10000] dsscomp_new
[  103.548706] [   97.379]       [c6edbb00] ++refs=2 for [c6f10000]
[  103.548736] [   97.379]                      [c6f10000] dsscomp_delayed_apply
[  103.548736] [   97.379]       [c6edbb00] --refs=1 on RELEASED
[  103.578887] [   97.379]                      [c6f10000] dsscomp_apply
[  103.578887] [   97.380]      [c6edbc80] --refs=0 on RELEASED
[  103.578887] [   97.380]      [c6edbc80] calling dsscomp_proxy_cmdcomplete [c73f6480]
[  103.578918] [   97.380]                         [c6f13000] dsscomp_mgr_delayed_cb on RELEASED
[  103.609069] [   97.380]                      [c6f10000] dsscomp_mgr_delayed_cb on PROGRAMMED
[  103.609069] [   97.380]   [c6edbca0] new in dsscomp_gralloc_queue (refs=1)
[  103.609069] [   97.380]                          [c6f10800] dsscomp_new
[  103.609069] [   97.380]   [c6edbca0] ++refs=2 for [c6f10800]
[  103.642059] [   97.380]                          [c6f10800] dsscomp_delayed_apply
[  103.642059] [   97.380]   [c6edbca0] --refs=1 on RELEASED
[  103.642059] [   97.380]                          [c6f10800] dsscomp_apply
[  103.642059] [   97.408]                      [c6f10000] dsscomp_mgr_delayed_cb on DISPLAYED
[  103.671844] [   97.408]       [c6edbb00] --refs=0 on RELEASED
[  103.671874] [   97.408]       [c6edbb00] calling dsscomp_proxy_cmdcomplete [c73f6900]
[  103.671874] [   97.408]                      [c6f10000] dsscomp_mgr_delayed_cb on RELEASED
[  103.671874] [   97.408]                          [c6f10800] dsscomp_mgr_delayed_cb on PROGRAMMED
[  103.701934] [   97.410] [c6fa4760] new in dsscomp_gralloc_queue (refs=1)
[  103.701965] [   97.410]                      [c6f10000] dsscomp_new
[  103.701965] [   97.410] [c6fa4760] ++refs=2 for [c6f10000]
[  103.701965] [   97.410]                      [c6f10000] dsscomp_delayed_apply
[  103.731811] [   97.410] [c6fa4760] --refs=1 on RELEASED
[  103.731811] [   97.410]                      [c6f10000] dsscomp_apply
[  103.731811] [   97.421]                          [c6f10800] dsscomp_mgr_delayed_cb on DISPLAYED
[  103.731811] [   97.421]   [c6edbca0] --refs=0 on RELEASED
[  103.761566] [   97.421]   [c6edbca0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[  103.761566] [   97.421]                          [c6f10800] dsscomp_mgr_delayed_cb on RELEASED
[  103.761596] [   97.421]    [c6edb880] new in dsscomp_gralloc_queue (refs=1)
[  103.761596] [   97.421]                          [c6f10800] dsscomp_new
[  103.791473] [   97.421]    [c6edb880] ++refs=2 for [c6f10800]
[  103.791473] [   97.421]                          [c6f10800] dsscomp_delayed_apply
[  103.791473] [   97.421]    [c6edb880] --refs=1 on RELEASED
[  103.791473] [   97.421]                      [c6f10000] dsscomp_mgr_delayed_cb on PROGRAMMED
[  103.821655] [   97.421]                          [c6f10800] dsscomp_apply
[  103.821655] [   97.445]                      [c6f10000] dsscomp_mgr_delayed_cb on DISPLAYED
[  103.821655] [   97.445] [c6fa4760] --refs=0 on RELEASED
[  103.821655] [   97.445] [c6fa4760] calling dsscomp_proxy_cmdcomplete [c73f6900]
[  103.851531] [   97.445]                      [c6f10000] dsscomp_mgr_delayed_cb on RELEASED
[  103.851531] [   97.445]                          [c6f10800] dsscomp_mgr_delayed_cb on PROGRAMMED
[  103.851531] [   97.473]                          [c6f10800] dsscomp_mgr_delayed_cb on DISPLAYED
[  103.880767] [  102.822]  [c602d0c0] new in dsscomp_gralloc_queue (refs=1)
[  103.880767] [  102.822]                        [c6f10400] dsscomp_new
[  103.880767] [  102.822]  [c602d0c0] ++refs=2 for [c6f10400]
[  103.880767] [  102.822]                        [c6f10400] dsscomp_delayed_apply
[  103.880798] [  102.822]
[  103.882568] adc_to_temp_conversion:Temp read is invalid 0
[  103.882598] thermal_lookup_temp: getting temp is not supported for domain pcb
[  103.883422] adc_to_temp_conversion:Temp read is invalid 0
[  103.883422] thermal_lookup_temp: getting temp is not supported for domain pcb
[  103.884246] adc_to_temp_conversion:Temp read is invalid 0
[  103.884246] thermal_lookup_temp: getting temp is not supported for domain pcb
[  103.952423] [c602d0c0] --refs=1 on RELEASED
[  103.952423] [  102.822]                        [c6f10400] dsscomp_apply
[  103.952423] [  102.823]    [c6edb880] --refs=0 on RELEASED
[  103.952423] [  102.823]    [c6edb880] calling dsscomp_proxy_cmdcomplete [c73f6480]
[  103.952423] [  102.823]                          [c6f10800] dsscomp_mgr_delayed_cb on RELEASED
[  103.983734] [  102.823]                        [c6f10400] dsscomp_mgr_delayed_cb on PROGRAMMED
[  103.983734] [  102.823]     [c602d420] new in dsscomp_gralloc_queue (refs=1)
[  103.983734] [  102.823]                          [c6f10800] dsscomp_new
[  103.983764] [  102.823]     [c602d420] ++refs=2 for [c6f10800]
[  104.013793] [  102.823]                          [c6f10800] dsscomp_delayed_apply
[  104.013793] [  102.823]     [c602d420] --refs=1 on RELEASED
[  104.013793] [  102.823]                          [c6f10800] dsscomp_apply
[  104.013793] [  102.839]                        [c6f10400] dsscomp_mgr_delayed_cb on DISPLAYED
[  104.043579] [  102.839]  [c602d0c0] --refs=0 on RELEASED
[  104.043579] [  102.839]  [c602d0c0] calling dsscomp_proxy_cmdcomplete [c73f6900]
[  104.043579] [  102.839]                        [c6f10400] dsscomp_mgr_delayed_cb on RELEASED
[  104.043579] [  102.839]                          [c6f10800] dsscomp_mgr_delayed_cb on PROGRAMMED
[  104.073394] [  102.856]                          [c6f10800] dsscomp_mgr_delayed_cb on DISPLAYED
[  104.073394] ACTIVE COMPOSITIONS on lcd
[  104.073394]
[  104.073394]   [c6f10800]: DISPLAYED
[  104.073394]     sync_id=0, flags=AD-
[  104.073425]     ovl0={ON z0 ARGB32-88
[  104.077087] PVR_K:(Error): PVRSRVSwapToDCBuffer2KM: Failed to get space in queue [0, ]
[  104.114868] 88 premult *100% 864*480:0,0+864,480 rot0 => 0,0+864,480 7f9ac000/  (null)|3456}
[  104.114868]     gsync=[c602d420] dsscomp_gralloc_cb
[  104.114868]
[  104.114868]   DISPC pipeline:
[  104.114868]
[  104.114868]     info:        clean (none)
[  104.114868]     cache:       clean (none)
[  104.114898]     shadow:  ACT clean (none)
[  104.114898]     dispc:   DISPLAYED mask=---R [c6f10800] dsscomp_mgr_callback
[  104.152160]
[  104.152160] ACTIVE COMPOSITIONS on tv
[  104.152160]
[  104.152160]   DISPC pipeline:
[  104.152160]
[  104.152160]     info:        clean (none)
[  104.152191]     cache:       clean (none)
[  104.152191]     shadow:  off clean (none)
[  104.152191]     dispc:   DISPLAYED (none)
[  104.152191]
[  104.152191] ACTIVE COMPOSITIONS on lcd2
[  104.152191]
[  104.152191]   DISPC pipeline:
[  104.152191]
[  104.197296]     info:        clean (none)
[  104.197296]     cache:       clean (none)
[  104.197296]     shadow:  off clean (none)
[  104.197326]     dispc:             (none)
[  104.197326]
[  104.197326] ACTIVE GRALLOC FLIPS
[  104.197326]
[  104.197326]   [c602d420] (refs=1)
[  104.197326]     slots=[7f9ac000]
[  104.197326]     cmdcb=[c73f6480] dsscomp_proxy_cmdcomplete
[  104.197326]
[  104.197326]   |           lcd
[  104.239227]   | [c6f10800] DISPL'D
[  104.239257]   |    102.823  ACTIVE
[  104.239257]   |    102.823 APPLY'N
[  104.239257]   |    102.823 APPLIED
[  104.239257]   |    102.839 PROGR'D
[  104.239257]   |    102.856 DISPL'D
[  104.239257]
[  104.239257]
[  104.265289] PVR_K: SGX debug (blaze_android_sgx_ogles1_ogles2_GPL sgxddk 18 1.8@869593)
[  104.273864] PVR_K:(Error): SGX Register Base Address (Linear):   0xC8B20000 [0, ]
[  104.281890] PVR_K:(Error): SGX Register Base Address (Physical): 0x56000000 [0, ]
[  104.289886] PVR_K: (P0) EUR_CR_CORE_ID:          01140000
[  104.295654] PVR_K: (P0) EUR_CR_CORE_REVISION:    00010200
[  104.301483] PVR_K: (P0) EUR_CR_EVENT_STATUS:     20000000
[  104.307250] PVR_K: (P0) EUR_CR_EVENT_STATUS2:    00000008
[  104.313049] PVR_K: (P0) EUR_CR_BIF_CTRL:         00000000
[  104.318786] PVR_K: (P0) EUR_CR_BIF_INT_STAT:     00008000
[  104.324615] PVR_K: (P0) EUR_CR_BIF_FAULT:        00000000
[  104.330352] PVR_K: (P0) EUR_CR_BIF_MEM_REQ_STAT: 00000000
[  104.336181] PVR_K: (P0) EUR_CR_CLKGATECTL:       000AAA6A
[  104.341918] PVR_K: (P0) EUR_CR_PDS_PC_BASE:      00001B70
[  104.347686] PVR_K: Flip Command Complete Data 0 for display device 1:
[  104.354614] PVR_K:   SRC 0: ROC DevVAddr:0xD800474 ROP:0x14 ROC:0x12, WOC DevVAddr:0xD800464 WOP:0x13 WOC:0x12
[  104.365173] PVR_K: Flip Command Complete Data 1 for display device 1:
[  104.372039] PVR_K:   SRC 0: (Not in use)
[  104.376220] PVR_K: SGX Host control:
[  104.380035] PVR_K:   (HC-0) 0x00000001 0x00000000 0x00000000 0x00000001
[  104.387023] PVR_K:   (HC-10) 0x00000012 0x0000000A 0x0005DC00 0x00000003
[  104.394073] PVR_K:   (HC-20) 0x00000000 0x00000003 0x00000000 0x00000018
[  104.401184] PVR_K:   (HC-30) 0x00000E66 0xF43FB52C 0x00000000 0x00000000
[  104.408233] PVR_K:   (HC-40) 0x00000000 0x087BF500 0x087C6300 0x087C3100
[  104.415344] PVR_K: SGX TA/3D control:
[  104.419250] PVR_K:   (T3C-0) 0x0F003000 0x0F003120 0x0F002000 0x0F06E540
[  104.426330] PVR_K:   (T3C-10) 0x00000001 0x00000002 0x00000001 0x0F05CC20
[  104.433532] PVR_K:   (T3C-20) 0x00000000 0x00000000 0x00000000 0x00000000
[  104.440673] PVR_K:   (T3C-30) 0x00000000 0x00000000 0x00000000 0x00000000
[  104.447845] PVR_K:   (T3C-40) 0x00000000 0x00000000 0x00000000 0x00000000
[  104.454986] PVR_K:   (T3C-50) 0x0F00DD00 0x00000000 0x00000000 0x0F00DD00
[  104.462188] PVR_K:   (T3C-60) 0x00000000 0x00000000 0x0F00DD00 0x00000000
[  104.469390] PVR_K:   (T3C-70) 0x00000000 0x0F00DD00 0x00000000 0x0F004000
[  104.476531] PVR_K:   (T3C-80) 0x00000106 0x0001120F 0x00000000 0x0F00DEB8
[  104.483703] PVR_K:   (T3C-90) 0x00000000 0x0F000000 0xAB600000 0x0F05D000
[  104.490844] PVR_K:   (T3C-A0) 0x00000000 0x0F07F400 0x0F00DFA0 0x0F00DEB8
[  104.498016] PVR_K:   (T3C-B0) 0x0F010BE0 0x00000000 0x00000000 0x00000000
[  104.505157] PVR_K:   (T3C-C0) 0x00000000 0x00000000 0x00000000 0x00000000
[  104.512329] PVR_K:   (T3C-D0) 0x00000000 0x00000000 0x00000023 0x0F007000
[  104.519531] PVR_K:   (T3C-E0) 0x0F00D420 0x0F00E000 0x0F010720 0x0F010720
[  104.526672] PVR_K:   (T3C-F0) 0x00000000 0x00000191 0x000000B5 0x00000000
[  104.533874] PVR_K:   (T3C-100) 0x00000003 0x00000000 0x00000000 0x00000000
[  104.541137] PVR_K:   (T3C-110) 0xB50C565C 0x0872E100 0x08787B00 0x08787B00
[  104.548400] PVR_K: Last SGX microkernel status code: AD000104
[  104.554595] PVR_K:   (MKT-0) 0754FC63 00000808 01002C1D 0F03F900
[  104.560913] PVR_K:   (MKT-1) 0754FC7B 00000808 01002C1D 00000060
[  104.567291] PVR_K:   (MKT-2) 0754FF3D 00000808 00002C1D AD000803
[  104.576263] PVR_K:   (MKT-3) 0754FF83 00188CC8 00002C1D AD000282
[  104.582916] PVR_K:   (MKT-4) 0755006D 00000808 01002E1F AD000200
[  104.589569] PVR_K:   (MKT-5) 07550291 00000808 00002E1F AD000202
[  104.595977] PVR_K:   (MKT-6) 07550311 00000808 00002F1E AD000183
[  104.602325] PVR_K:   (MKT-7) 075503FA 00000808 00002F1E AD00030E
[  104.608703] PVR_K:   (MKT-8) 07550412 00000808 00002F1E 0D800474
[  104.615020] PVR_K:   (MKT-9) 0755042B 00000808 00002F1E 0000000F
[  104.630249] PVR_K:   (MKT-A) 0755044E 00000808 00002F1E 00000010
[  104.637237] PVR_K:   (MKT-B) 075504BB 00000808 00002F1E AD000184
[  104.644104] PVR_K:   (MKT-C) 07550521 00000C08 0100301D AD000281
[  104.650756] PVR_K:   (MKT-D) 07550697 00000808 0100301D AD00080A
[  104.657775] PVR_K:   (MKT-E) 075506B0 00000808 0100301D 0F03FC00
[  104.664459] PVR_K:   (MKT-F) 075506C9 00000808 0100301D 00000062
[  104.671417] PVR_K:   (MKT-10) 0755098D 00000808 0000301D AD000803
[  104.679779] PVR_K:   (MKT-11) 075509D3 00180C88 0000301D AD000282
[  104.688354] PVR_K:   (MKT-12) 07551510 00000808 0100321F AD000200
[  104.695037] PVR_K:   (MKT-13) 0755162C 00000808 0100321F AD001703
[  104.701538] PVR_K:   (MKT-14) 07551819 00000808 0000321F AD000202
[  104.708099] PVR_K:   (MKT-15) 07551899 00000808 0000331E AD000183
[  104.721130] PVR_K:   (MKT-16) 0755198A 00000808 0000331E AD00030E
[  104.735778] PVR_K:   (MKT-17) 075519A2 00000808 0000331E 0D800474
[  104.742218] PVR_K:   (MKT-18) 075519BB 00000808 0000331E 0000000F
[  104.753845] PVR_K:   (MKT-19) 075519E2 00000808 0000331E 00000010
[  104.765380] PVR_K:   (MKT-1A) 07551A4D 00000808 0000331E AD000184
[  104.771942] PVR_K:   (MKT-1B) 07551AB6 00000C08 0100341D AD000281
[  104.787994] PVR_K:   (MKT-1C) 07551BCB 00000808 0100341D AD000E02
[  104.794433] PVR_K:   (MKT-1D) 07551C40 00000808 0100341D AD000282
[  104.811401] PVR_K:   (MKT-1E) 0755EB04 00000808 0100371F AD001A00
[  104.817840] PVR_K:   (MKT-1F) 0757CD04 00000808 01003D1F AD00000A
[  104.830261] PVR_K:   (MKT-20) 0757CD67 00000808 01003D1F AD000909
[  104.842712] PVR_K:   (MKT-21) 0757CDB3 00000808 01003D1F AD001A05
[  104.850524] PVR_K:   (MKT-22) 0757CDE6 00000808 01003D1F AD001302
[  104.856933] PVR_K:   (MKT-23) 0757CE2B 00000808 01003D1F AD001303
[  104.863403] PVR_K:   (MKT-24) 0757CEC1 00000808 01003D1F AD000D04
[  104.869812] PVR_K:   (MKT-25) 0757CF8E 00000808 01003D1F AD000D05
[  104.876251] PVR_K:   (MKT-26) 0757CFEC 00000808 01003D1F AD000D04
[  104.882537] adc_to_temp_conversion:Temp read is invalid 0
[  104.882537] thermal_lookup_temp: getting temp is not supported for domain pcb
[  104.883514] adc_to_temp_conversion:Temp read is invalid 0
[  104.883514] thermal_lookup_temp: getting temp is not supported for domain pcb
[  104.884399] adc_to_temp_conversion:Temp read is invalid 0
[  104.884399] thermal_lookup_temp: getting temp is not supported for domain pcb
[  104.922821] PVR_K:   (MKT-27) 0757D076 00000808 01003D1F AD000D05
[  104.929260] PVR_K:   (MKT-28) 0757D0D5 00000808 01003D1F AD001A06
[  104.935791] PVR_K:   (MKT-29) 00000495 00100808 0100031F AD002300
[  104.942230] PVR_K:   (MKT-2A) 0000098D 00100808 0100041F AD00000A
[  104.949340] PVR_K:   (MKT-2B) 00000A0B 00100808 0100041F AD000906
[  104.964599] PVR_K:   (MKT-2C) 00000ADC 00100808 0000041F AD000901
[  104.983276] PVR_K:   (MKT-2D) 00000B55 00100808 0000051E AD000183
[  104.989685] PVR_K:   (MKT-2E) 00000CCA 00100808 0000051E AD000302
[  105.003967] PVR_K:   (MKT-2F) 00000E59 00100808 0000051E AD000D06
[  105.013793] PVR_K:   (MKT-30) 00000F44 00100808 0000051E AD000D07
[  105.022857] PVR_K:   (MKT-31) 00000F8F 00100808 0000051E AD001304
[  105.034057] PVR_K:   (MKT-32) 00001081 00100808 0000051E AD001305
[  105.041778] PVR_K:   (MKT-33) 00001197 00100888 0000051E AD000404
[  105.048339] PVR_K:   (MKT-34) 00001260 00100808 0000051E AD000402
[  105.054870] PVR_K:   (MKT-35) 000012AA 0010082B 0000051E AD000184
[  105.061309] PVR_K:   (MKT-36) 00001357 00108DA9 0000061D AD000281
[  105.067779] PVR_K:   (MKT-37) 000014E9 001089AF 0000061D AD000E02
[  105.074768] PVR_K:   (MKT-38) 00001547 0010892B 0000061D AD000282
[  105.081298] PVR_K:   (MKT-39) 00003C81 00100808 0000081F AD000101
[  105.087768] PVR_K:   (MKT-3A) 00003CFD 00100808 0000081F AD000104
[  105.094238] PVR_K:   (MKT-3B) 00003D3A 00100808 0100091E AD000100
[  105.100708] PVR_K:   (MKT-3C) 00003E3F 00100808 0100091E AD000501
[  105.107147] PVR_K:   (MKT-3D) 00003E7F 00100829 0100091E AD000104
[  105.113616] PVR_K:   (MKT-3E) 000063E3 00100828 01000B1E AD000101
[  105.120056] PVR_K:   (MKT-3F) 0000645F 00100828 01000B1E AD000104
[  105.126495] PVR_K:   (MKT-40) 000064A7 00100808 01000C1F AD000100
[  105.132904] PVR_K:   (MKT-41) 00006597 00100808 01000C1F AD000501
[  105.139373] PVR_K:   (MKT-42) 000065D6 00100829 01000C1F AD000104
[  105.145782] PVR_K:   (MKT-43) 00008C46 00100828 01000D1F AD000101
[  105.152313] PVR_K:   (MKT-44) 00008C9E 00100828 01000D1F AD000104
[  105.158721] PVR_K:   (MKT-45) 00008D33 00100808 01000E1F AD000100
[  105.165191] PVR_K:   (MKT-46) 00008E10 00100808 01000E1F AD000501
[  105.171600] PVR_K:   (MKT-47) 00008E47 00100829 01000E1F AD000104
[  105.177978] PVR_K:   (MKT-48) 0000AFC8 00100828 01000F1F AD000101
[  105.184448] PVR_K:   (MKT-49) 0000B01D 00100828 01000F1F AD000104
[  105.190826] PVR_K:   (MKT-4A) 0000B1F4 00100808 0100101F AD000100
[  105.197326] PVR_K:   (MKT-4B) 0000B282 00100808 0100101F AD000502
[  105.204315] PVR_K:   (MKT-4C) 0000B2CC 00100808 0100101F AD000C01
[  105.211456] PVR_K:   (MKT-4D) 0000B2F0 00100808 0100101F 0D800464
[  105.218597] PVR_K:   (MKT-4E) 0000B308 00100808 0100101F 00000011
[  105.225067] PVR_K:   (MKT-4F) 0000B5CC 00100808 0000101F AD00030E
[  105.231842] PVR_K:   (MKT-50) 0000B5E4 00100808 0000101F 0D800494
[  105.238311] PVR_K:   (MKT-51) 0000B600 00100808 0000101F 0000000F
[  105.244750] PVR_K:   (MKT-52) 0000B623 00100808 0000101F 00000010
[  105.251190] PVR_K:   (MKT-53) 0000B6BD 00100808 0000101F AD000104
[  105.257629] PVR_K:   (MKT-54) 0000B73A 00100C08 0100111E AD000281
[  105.264068] PVR_K:   (MKT-55) 0000B8BE 00100808 0100111E AD00080A
[  105.270477] PVR_K:   (MKT-56) 0000B8D7 00100808 0100111E 0F03FF00
[  105.276947] PVR_K:   (MKT-57) 0000B8EF 00100808 0100111E 00000061
[  105.283386] PVR_K:   (MKT-58) 0000BA7C 00100808 0000111E AD000802
[  105.289794] PVR_K:   (MKT-59) 0000BBDB 00100808 0000111E AD000803
[  105.296264] PVR_K:   (MKT-5A) 0000BC25 00184AC8 0000111E AD000282
[  105.302673] PVR_K:   (MKT-5B) 0000DCCF 00000C08 0100141F AD000200
[  105.309173] PVR_K:   (MKT-5C) 0000DF25 00000808 0000141F AD000202
[  105.315612] PVR_K:   (MKT-5D) 0000DFB0 00000808 0000151E AD000183
[  105.322052] PVR_K:   (MKT-5E) 0000E0A1 00000808 0000151E AD00030E
[  105.328491] PVR_K:   (MKT-5F) 0000E0C1 00000808 0000151E 0D800494
[  105.334991] PVR_K:   (MKT-60) 0000E0DA 00000808 0000151E 0000000F
[  105.341430] PVR_K:   (MKT-61) 0000E0FE 00000808 0000151E 00000010
[  105.347900] PVR_K:   (MKT-62) 0000E168 00000808 0000151E AD000184
[  105.354309] PVR_K:   (MKT-63) 0000E1D1 00000C08 0100161D AD000281
[  105.360778] PVR_K:   (MKT-64) 0000E33E 00000808 0100161D AD00080A
[  105.367187] PVR_K:   (MKT-65) 0000E356 00000808 0100161D 0F040200
[  105.373657] PVR_K:   (MKT-66) 0000E371 00000808 0100161D 00000060
[  105.380065] PVR_K:   (MKT-67) 0000E635 00000808 0000161D AD000803
[  105.386474] PVR_K:   (MKT-68) 0000E67C 00180CC8 0000161D AD000282
[  105.392944] PVR_K:   (MKT-69) 0000E71D 00000808 0100181F AD000200
[  105.399353] PVR_K:   (MKT-6A) 0000E93B 00000808 0000181F AD000202
[  105.405822] PVR_K:   (MKT-6B) 0000E9BB 00000808 0000191E AD000183
[  105.412231] PVR_K:   (MKT-6C) 0000EAA6 00000808 0000191E AD00030E
[  105.418670] PVR_K:   (MKT-6D) 0000EAC6 00000808 0000191E 0D800494
[  105.425079] PVR_K:   (MKT-6E) 0000EAE0 00000808 0000191E 0000000F
[  105.431549] PVR_K:   (MKT-6F) 0000EB05 00000808 0000191E 00000010
[  105.437957] PVR_K:   (MKT-70) 0000EB6F 00000808 0000191E AD000184
[  105.444396] PVR_K:   (MKT-71) 0000EBD6 00000C08 01001A1D AD000281
[  105.450805] PVR_K:   (MKT-72) 0000ED44 00000808 01001A1D AD00080A
[  105.457244] PVR_K:   (MKT-73) 0000ED5D 00000808 01001A1D 0F040500
[  105.463684] PVR_K:   (MKT-74) 0000ED75 00000808 01001A1D 00000060
[  105.470153] PVR_K:   (MKT-75) 0000F027 00000808 00001A1D AD000803
[  105.476562] PVR_K:   (MKT-76) 0000F070 00180CC8 00001A1D AD000282
[  105.483001] PVR_K:   (MKT-77) 0000F13B 00000808 01001C1F AD000200
[  105.489471] PVR_K:   (MKT-78) 0000F359 00000808 00001C1F AD000202
[  105.495880] PVR_K:   (MKT-79) 0000F3DA 00000808 00001D1E AD000183
[  105.502349] PVR_K:   (MKT-7A) 0000F4C7 00000808 00001D1E AD00030E
[  105.508758] PVR_K:   (MKT-7B) 0000F4DF 00000808 00001D1E 0D800494
[  105.515228] PVR_K:   (MKT-7C) 0000F4F8 00000808 00001D1E 0000000F
[  105.521636] PVR_K:   (MKT-7D) 0000F51B 00000808 00001D1E 00000010
[  105.528076] PVR_K:   (MKT-7E) 0000F586 00000808 00001D1E AD000184
[  105.534515] PVR_K:   (MKT-7F) 0000F5EB 00000C08 01001E1D AD000281
[  105.540954] PVR_K:   (MKT-80) 0000F75C 00000808 01001E1D AD00080A
[  105.547363] PVR_K:   (MKT-81) 0000F774 00000808 01001E1D 0F040800
[  105.553802] PVR_K:   (MKT-82) 0000F78D 00000808 01001E1D 00000062
[  105.560211] PVR_K:   (MKT-83) 0000FA3F 00000808 00001E1D AD000803
[  105.566711] PVR_K:   (MKT-84) 0000FA84 00180C88 00001E1D AD000282
[  105.573120] PVR_K:   (MKT-85) 000105C7 00000808 0100201F AD000200
[  105.579589] PVR_K:   (MKT-86) 000106E6 00000808 0100201F AD001703
[  105.585998] PVR_K:   (MKT-87) 000108B9 00000808 0000201F AD000202
[  105.592376] PVR_K:   (MKT-88) 00010936 00000808 0100211E AD000183
[  105.598846] PVR_K:   (MKT-89) 00010A21 00000808 0100211E AD00030E
[  105.605255] PVR_K:   (MKT-8A) 00010A39 00000808 0100211E 0D800494
[  105.611724] PVR_K:   (MKT-8B) 00010A52 00000808 0100211E 0000000F
[  105.618133] PVR_K:   (MKT-8C) 00010A75 00000808 0100211E 00000010
[  105.624603] PVR_K:   (MKT-8D) 00010B02 00000808 0100211E AD000184
[  105.630981] PVR_K:   (MKT-8E) 0001D960 00000808 0100241F AD001A00
[  105.637451] PVR_K:   (MKT-8F) 0001DEB6 00000808 0100251F AD00000A
[  105.643859] PVR_K:   (MKT-90) 0001DF24 00000808 0100251F AD000909
[  105.650390] PVR_K:   (MKT-91) 0001DF6F 00000808 0100251F AD001A05
[  105.656799] PVR_K:   (MKT-92) 0001DF9F 00000808 0100251F AD001302
[  105.663269] PVR_K:   (MKT-93) 0001DFE0 00000808 0100251F AD001303
[  105.669647] PVR_K:   (MKT-94) 0001E078 00000808 0100251F AD000D04
[  105.676116] PVR_K:   (MKT-95) 0001E140 00000808 0100251F AD000D05
[  105.682525] PVR_K:   (MKT-96) 0001E1B3 00000808 0100251F AD001A06
[  105.688964] PVR_K:   (MKT-97) 00000527 00100808 0100031F AD002300
[  105.695404] PVR_K:   (MKT-98) 00000A4B 00100808 0100041F AD00000A
[  105.701812] PVR_K:   (MKT-99) 00000AC9 00100808 0100041F AD000906
[  105.708251] PVR_K:   (MKT-9A) 00000BA1 00100808 0000041F AD000901
[  105.714691] PVR_K:   (MKT-9B) 00000C1D 00100808 0100051E AD000183
[  105.721160] PVR_K:   (MKT-9C) 00000D99 00100808 0100051E AD000302
[  105.727600] PVR_K:   (MKT-9D) 00000F2D 00100808 0100051E AD000D06
[  105.734069] PVR_K:   (MKT-9E) 0000101B 00100808 0100051E AD000D07
[  105.740447] PVR_K:   (MKT-9F) 00001067 00100808 0100051E AD001304
[  105.746917] PVR_K:   (MKT-A0) 00001159 00100808 0100051E AD001305
[  105.753326] PVR_K:   (MKT-A1) 00001270 00100888 0100051E AD000404
[  105.759765] PVR_K:   (MKT-A2) 0000133F 00100808 0000051E AD000402
[  105.766174] PVR_K:   (MKT-A3) 00001388 0010082B 0000051E AD000184
[  105.772644] PVR_K:   (MKT-A4) 00003C73 00100808 0000071F AD000101
[  105.779052] PVR_K:   (MKT-A5) 00003CE2 00100808 0000071F AD000104
[  105.785675] PVR_K:   (MKT-A6) 00003D0E 00100808 0100081E AD000100
[  105.792602] PVR_K:   (MKT-A7) 00003E1A 00100808 0100081E AD000501
[  105.799499] PVR_K:   (MKT-A8) 00003E5C 0010082B 0100081E AD000104
[  105.806060] PVR_K:   (MKT-A9) 00006114 00100828 0100091F AD000101
[  105.812561] PVR_K:   (MKT-AA) 0000616E 00100828 0100091F AD000104
[  105.819030] PVR_K:   (MKT-AB) 00006285 00100808 01000A1F AD000100
[  105.825469] PVR_K:   (MKT-AC) 0000635D 00100808 00000A1F AD000501
[  105.831939] PVR_K:   (MKT-AD) 00006394 00100829 00000A1F AD000104
[  105.838378] PVR_K:   (MKT-AE) 07B99D1C 00100808 0100031F AD000B00
[  105.844818] PVR_K:   (MKT-AF) 07B99D54 00100808 0100031F AD000B02
[  105.851257] PVR_K:   (MKT-B0) 07B99D9C 00100808 0100031F AD000B02
[  105.857696] PVR_K:   (MKT-B1) 07B99E00 00100808 0100031F AD000B02
[  105.864196] PVR_K:   (MKT-B2) 07B99E41 00100808 0100031F AD000B02
[  105.870635] PVR_K:   (MKT-B3) 07B99E7F 00100808 0100031F AD000B02
[  105.877044] PVR_K:   (MKT-B4) 07B99EBF 00100808 0100031F AD000B03
[  105.882537] adc_to_temp_conversion:Temp read is invalid 0
[  105.882537] thermal_lookup_temp: getting temp is not supported for domain pcb
[  105.883422] adc_to_temp_conversion:Temp read is invalid 0
[  105.883422] thermal_lookup_temp: getting temp is not supported for domain pcb
[  105.884246] adc_to_temp_conversion:Temp read is invalid 0
[  105.884246] thermal_lookup_temp: getting temp is not supported for domain pcb
[  105.923583] PVR_K:   (MKT-B5) 07B99F3F 00100808 0100031F AD000B05
[  105.930053] PVR_K:   (MKT-B6) 07B99F95 00100808 0100031F AD000B06
[  105.936462] PVR_K:   (MKT-B7) 07B99FC4 00100808 0100031F AD000B06
[  105.942901] PVR_K:   (MKT-B8) 07B9A007 00100808 0100031F AD000B07
[  105.949310] PVR_K:   (MKT-B9) 07B9A02C 00100808 0100031F AD000B09
[  105.955780] PVR_K:   (MKT-BA) 07B9A080 00100808 0100031F AD000B01
[  105.962158] PVR_K:   (MKT-BB) 07B9A0BF 00100808 0100031F AD002300
[  105.968627] PVR_K:   (MKT-BC) 07B9A2E4 00100808 0100041F AD00000A
[  105.975067] PVR_K:   (MKT-BD) 07B9A35B 00100808 0100041F AD000906
[  105.981475] PVR_K:   (MKT-BE) 07B9A419 00100808 0000041F AD000901
[  105.987976] PVR_K:   (MKT-BF) 07B9A46C 00100808 0000051E AD00000A
[  105.994384] PVR_K:   (MKT-C0) 07B9A4D1 00100808 0000051E AD000904
[  106.000946] PVR_K:   (MKT-C1) 07B9A58D 00100808 0000051E AD000901
[  106.007354] PVR_K:   (MKT-C2) 07B9A60B 00100808 0000061D AD000183
[  106.013854] PVR_K:   (MKT-C3) 07B9A958 0010088F 0000061D AD002401
[  106.020294] PVR_K:   (MKT-C4) 07B9A99F 0016EE8F 0000061D AD000184
[  106.026763] PVR_K:   (MKT-C5) 07B9AA27 0017FF8F 0000071C AD000281
[  106.033142] PVR_K:   (MKT-C6) 07B9ABA9 0017FB8F 0000071C AD000E02
[  106.039611] PVR_K:   (MKT-C7) 07B9AC02 0017FB8F 0000071C AD000282
[  106.046020] PVR_K:   (MKT-C8) 07B9C556 00100808 0100091F AD000101
[  106.052459] PVR_K:   (MKT-C9) 07B9C816 00100808 0000091F AD000302
[  106.058898] PVR_K:   (MKT-CA) 07B9C86A 00100808 0000091F AD000303
[  106.065338] PVR_K:   (MKT-CB) 07B9C8EE 00100808 0000091F AD000C01
[  106.071807] PVR_K:   (MKT-CC) 07B9C912 00100808 0000091F 0D800484
[  106.078247] PVR_K:   (MKT-CD) 07B9C92A 00100808 0000091F 00000011
[  106.084716] PVR_K:   (MKT-CE) 07B9CB6D 00100808 0000091F AD00030E
[  106.091125] PVR_K:   (MKT-CF) 07B9CB85 00100808 0000091F 0D800474
[  106.097564] PVR_K:   (MKT-D0) 07B9CB9E 00100808 0000091F 00000011
[  106.103973] PVR_K:   (MKT-D1) 07B9CBC1 00100808 0000091F 00000012
[  106.110412] PVR_K:   (MKT-D2) 07B9CC56 00100808 0000091F AD000104
[  106.116821] PVR_K:   (MKT-D3) 07B9CCBA 00100C08 01000A1E AD000281
[  106.123260] PVR_K:   (MKT-D4) 07B9CE27 00100808 01000A1E AD00080A
[  106.129669] PVR_K:   (MKT-D5) 07B9CE3F 00100808 01000A1E 0F040B00
[  106.136138] PVR_K:   (MKT-D6) 07B9CE58 00100808 01000A1E 00000061
[  106.142547] PVR_K:   (MKT-D7) 07B9CF70 00100C88 01000A1E AD001300
[  106.149017] PVR_K:   (MKT-D8) 07BA23C8 00100888 00000A1E AD001301
[  106.155426] PVR_K:   (MKT-D9) 07BA2503 00100888 00000A1E AD000802
[  106.161895] PVR_K:   (MKT-DA) 07BA2674 00100888 00000A1E AD000803
[  106.168273] PVR_K:   (MKT-DB) 07BA26C4 001808C8 00000A1E AD000282
[  106.174743] PVR_K:   (MKT-DC) 07BA27A5 00184AF8 00000C1D AD00000A
[  106.181182] PVR_K:   (MKT-DD) 07BA2823 001888F8 00000C1D AD000904
[  106.187591] PVR_K:   (MKT-DE) 07BA2946 001808B8 00000C1D AD000901
[  106.194061] PVR_K:   (MKT-DF) 07BA29AF 00180838 00000D1C AD00000A
[  106.200469] PVR_K:   (MKT-E0) 07BA2A11 00180838 00000D1C AD000905
[  106.206909] PVR_K:   (MKT-E1) 07BA2AD9 00180838 00000D1C AD000901
[  106.213317] PVR_K:   (MKT-E2) 07BA2B2E 00180838 00000E1B AD00000A
[  106.219787] PVR_K:   (MKT-E3) 07BA2B8A 001808B8 00000E1B AD000904
[  106.226196] PVR_K:   (MKT-E4) 07BA2C29 00180838 00000E1B AD000901
[  106.232635] PVR_K:   (MKT-E5) 07BA2C81 00180838 00000F1A AD00000A
[  106.239044] PVR_K:   (MKT-E6) 07BA2CDB 00180838 00000F1A AD000904
[  106.245483] PVR_K:   (MKT-E7) 07BA2D7B 00180838 00000F1A AD000901
[  106.251892] PVR_K:   (MKT-E8) 07BA2DD3 00180838 00001019 AD00000A
[  106.258361] PVR_K:   (MKT-E9) 07BA2E3F 00180838 00001019 AD000905
[  106.264770] PVR_K:   (MKT-EA) 07BA2EE6 00180838 00001019 AD000901
[  106.271209] PVR_K:   (MKT-EB) 07BA2F3A 00180838 00001118 AD00000A
[  106.277587] PVR_K:   (MKT-EC) 07BA2F9F 00180838 00001118 AD000905
[  106.284057] PVR_K:   (MKT-ED) 07BA304E 00180838 00001118 AD000901
[  106.290557] PVR_K:   (MKT-EE) 07BA3135 00180838 00001217 AD00000A
[  106.296966] PVR_K:   (MKT-EF) 07BA3195 00180838 00001217 AD000905
[  106.303405] PVR_K:   (MKT-F0) 07BA3279 00180838 00001217 AD000901
[  106.309814] PVR_K:   (MKT-F1) 07BA32F9 00180838 0000131F AD000183
[  106.316253] PVR_K:   (MKT-F2) 07BA347A 00180838 0000131F AD000F04
[  106.322662] PVR_K:   (MKT-F3) 07BA358D 00180838 0000131F AD000302
[  106.329101] PVR_K:   (MKT-F4) 07BA3600 00180838 0000131F AD000303
[  106.335510] PVR_K:   (MKT-F5) 07BA367C 00180838 0000131F AD000C01
[  106.341949] PVR_K:   (MKT-F6) 07BA36A0 00180838 0000131F 0D800464
[  106.348358] PVR_K:   (MKT-F7) 07BA36B9 00180838 0000131F 00000012
[  106.354797] PVR_K:   (MKT-F8) 07BA397B 00180838 0000131F AD000F04
[  106.361267] PVR_K:   (MKT-F9) 07BA39D9 00180838 0000131F AD000184
[  106.367706] PVR_K:   (MKT-FA) 07BA3A4D 00180C38 0000141E AD000281
[  106.374114] PVR_K:   (MKT-FB) 07BA3AA3 00180838 0000141E AD000282
[  106.380554] PVR_K:   (MKT-FC) 07BA3B58 00180838 0100151D AD00000A
[  106.386993] PVR_K:   (MKT-FD) 07BA3BD0 00180838 0100151D AD000906
[  106.393402] PVR_K:   (MKT-FE) 07BA3C84 00180838 0000151D AD000901
[  106.399871] PVR_K:   (MKT-FF) 07BA3CF4 00180838 0000161F AD000183
[  106.406280] PVR_K:   (MKT-100) 07BA3E36 00180838 0000161F AD000F04
[  106.412811] PVR_K:   (MKT-101) 07BA3E89 00180838 0000161F AD000184
[  106.419281] PVR_K:   (MKT-102) 07BA3EEF 00180C38 0100171E AD000281
[  106.425842] PVR_K:   (MKT-103) 07BA3F45 00180838 0100171E AD000282
[  106.432373] PVR_K:   (MKT-104) 07BA455B 00180838 0100181F AD00000A
[  106.438934] PVR_K:   (MKT-105) 07BA45C9 00180838 0100181F AD000905
[  106.445434] PVR_K:   (MKT-106) 07BA46C8 00180838 0000181F AD000901
[  106.451965] PVR_K:   (MKT-107) 07BA4736 00180838 0000191E AD000183
[  106.458465] PVR_K:   (MKT-108) 07BA4878 00000808 0000191E AD000F04
[  106.464996] PVR_K:   (MKT-109) 07BA48CA 00000808 0000191E AD000184
[  106.471496] PVR_K:   (MKT-10A) 07BA4934 00000C08 00001A1D AD000281
[  106.477996] PVR_K:   (MKT-10B) 07BA498B 00000808 00001A1D AD000282
[  106.484558] PVR_K:   (MKT-10C) 07BA4A3D 00000808 00001B1F AD00000A
[  106.491058] PVR_K:   (MKT-10D) 07BA4AA8 00000808 00001B1F AD000905
[  106.497589] PVR_K:   (MKT-10E) 07BA4BA2 00000808 00001B1F AD000901
[  106.504089] PVR_K:   (MKT-10F) 07BA4BD8 00000C08 00001C1C AD000200
[  106.510620] PVR_K:   (MKT-110) 07BA4E1C 00000808 00001C1C AD000202
[  106.517120] PVR_K:   (MKT-111) 07BA4ED1 00000808 00001D1E AD00000A
[  106.523651] PVR_K:   (MKT-112) 07BA4F3C 00000808 00001D1E AD000905
[  106.530181] PVR_K:   (MKT-113) 07BA5020 00000808 00001D1E AD000901
[  106.536712] PVR_K:   (MKT-114) 07BA5089 00000808 00001E1D AD000183
[  106.543212] PVR_K:   (MKT-115) 07BA5385 0000088F 00001E1D AD002401
[  106.549743] PVR_K:   (MKT-116) 07BA53CF 0006EC8F 00001E1D AD000184
[  106.556274] PVR_K:   (MKT-117) 07BA545B 0007FF8F 00001F1B AD000281
[  106.562774] PVR_K:   (MKT-118) 07BA55CD 0007FB8F 00001F1B AD000E03
[  106.569305] PVR_K:   (MKT-119) 07BA55FB 0007F98F 00001F1B AD000282
[  106.575805] PVR_K:   (MKT-11A) 07BA56F5 0007FB8E 0000201F AD00000A
[  106.582366] PVR_K:   (MKT-11B) 07BA5778 00000908 0000201F AD000905
[  106.588836] PVR_K:   (MKT-11C) 07BA5882 00000808 0000201F AD000901
[  106.595397] PVR_K:   (MKT-11D) 07BA58E3 00000808 0000221D AD000101
[  106.601898] PVR_K:   (MKT-11E) 07BA5CF0 0000088F 0000221D AD002401
[  106.608428] PVR_K:   (MKT-11F) 07BA5D59 0007FB8F 0000221D AD000104
[  106.614929] PVR_K:   (MKT-120) 07BA5DC9 0007FB8F 0000231C AD000183
[  106.621459] PVR_K:   (MKT-121) 07BA5E1B 0007FB8F 0000231C AD000184
[  106.627990] PVR_K:   (MKT-122) 07BA5E82 0007FF8F 0000241B AD000281
[  106.634521] PVR_K:   (MKT-123) 07BA5FB8 0007FB8F 0000241B AD000E03
[  106.641113] PVR_K:   (MKT-124) 07BA5FE6 0007FB8F 0000241B AD000282
[  106.647613] PVR_K:   (MKT-125) 07BA6B22 00000808 0100271F AD000101
[  106.654144] PVR_K:   (MKT-126) 07BA6F0C 0000088F 0000271F AD002401
[  106.660614] PVR_K:   (MKT-127) 07BA6F73 0007F98F 0000271F AD000104
[  106.667175] PVR_K:   (MKT-128) 07BA6FE7 0007FF8F 0000281E AD000281
[  106.673675] PVR_K:   (MKT-129) 07BA7132 0007FB8F 0000281E AD000E03
[  106.680206] PVR_K:   (MKT-12A) 07BA7163 0007F98F 0000281E AD000282
[  106.686706] PVR_K:   (MKT-12B) 07BA7676 00000808 01002A1F AD000101
[  106.693237] PVR_K:   (MKT-12C) 07BA783F 00000808 00002A1F AD000104
[  106.699737] PVR_K:   (MKT-12D) 07BA78A4 00000C08 01002B1E AD000281
[  106.706298] PVR_K:   (MKT-12E) 07BA79F2 00000808 01002B1E AD00080A
[  106.712829] PVR_K:   (MKT-12F) 07BA7A0B 00000808 01002B1E 0F040E00
[  106.719360] PVR_K:   (MKT-130) 07BA7A23 00000808 01002B1E 00000060
[  106.725921] PVR_K:   (MKT-131) 07BA7D6F 00000808 00002B1E AD000803
[  106.732391] PVR_K:   (MKT-132) 07BA7DBB 00188CC8 00002B1E AD000282
[  106.738952] PVR_K:   (MKT-133) 07BA7F25 00000808 01002E1F AD000200
[  106.745452] PVR_K:   (MKT-134) 07BA814F 00000808 01002E1F AD000202
[  106.751983] PVR_K:   (MKT-135) 07BA81A6 00000808 01002F1E AD000281
[  106.758453] PVR_K:   (MKT-136) 07BA82F6 00000808 01002F1E AD00080A
[  106.765014] PVR_K:   (MKT-137) 07BA830F 00000808 01002F1E 0F041100
[  106.771484] PVR_K:   (MKT-138) 07BA8327 00000808 01002F1E 00000060
[  106.778045] PVR_K:   (MKT-139) 07BA85D9 00000808 00002F1E AD000803
[  106.784576] PVR_K:   (MKT-13A) 07BA861F 00188CC8 00002F1E AD000282
[  106.791137] PVR_K:   (MKT-13B) 07BA870C 00000808 0100311F AD000200
[  106.797607] PVR_K:   (MKT-13C) 07BA892E 00000808 0000311F AD000202
[  106.804168] PVR_K:   (MKT-13D) 07BA897A 00000808 0100321E AD000281
[  106.810699] PVR_K:   (MKT-13E) 07BA8ACA 00000808 0100321E AD00080A
[  106.817199] PVR_K:   (MKT-13F) 07BA8AE2 00000808 0100321E 0F041400
[  106.823730] PVR_K:   (MKT-140) 07BA8AFA 00000808 0100321E 00000062
[  106.830261] PVR_K:   (MKT-141) 07BA8DAF 00000808 0000321E AD000803
[  106.836791] PVR_K:   (MKT-142) 07BA8DF4 00180C88 0000321E AD000282
[  106.843292] PVR_K:   (MKT-143) 07BA99A1 00000808 0100341F AD000200
[  106.849853] PVR_K:   (MKT-144) 07BA9ABE 00000808 0100341F AD001703
[  106.856384] PVR_K:   (MKT-145) 07BA9CBA 00000808 0000341F AD000202
[  106.862915] PVR_K:   (MKT-146) 07BA9D4A 00000808 0000351E AD000183
[  106.869415] PVR_K:   (MKT-147) 07BA9E4B 00000808 0000351E AD00030E
[  106.875976] PVR_K:   (MKT-148) 07BA9E64 00000808 0000351E 0D800494
[  106.876861] adc_to_temp_conversion:Temp read is invalid 0
[  106.876861] thermal_lookup_temp: getting temp is not supported for domain pcb
[  106.877716] adc_to_temp_conversion:Temp read is invalid 0
[  106.877716] thermal_lookup_temp: getting temp is not supported for domain pcb
[  106.878601] adc_to_temp_conversion:Temp read is invalid 0
[  106.878601] thermal_lookup_temp: getting temp is not supported for domain pcb
[  106.922851] PVR_K:   (MKT-149) 07BA9E7C 00000808 0000351E 00000010
[  106.929351] PVR_K:   (MKT-14A) 07BA9E9F 00000808 0000351E 00000011
[  106.935882] PVR_K:   (MKT-14B) 07BA9F0D 00000808 0000351E AD000184
[  106.942382] PVR_K:   (MKT-14C) 07BA9F7C 00000C08 0100361D AD000281
[  106.948944] PVR_K:   (MKT-14D) 07BAA0F4 00000808 0100361D AD00080A
[  106.955444] PVR_K:   (MKT-14E) 07BAA10D 00000808 0100361D 0F041700
[  106.961975] PVR_K:   (MKT-14F) 07BAA125 00000808 0100361D 00000061
[  106.968536] PVR_K:   (MKT-150) 07BAA2A2 00000808 0000361D AD000802
[  106.975036] PVR_K:   (MKT-151) 07BAA3F8 00000808 0000361D AD000803
[  106.981567] PVR_K:   (MKT-152) 07BAA43D 00184EC8 0000361D AD000282
[  106.988067] PVR_K:   (MKT-153) 07BAC39C 00000C08 0100391F AD000200
[  106.994689] PVR_K:   (MKT-154) 07BAC5E7 00000808 0000391F AD000202
[  107.001220] PVR_K:   (MKT-155) 07BAC670 00000808 00003A1E AD000183
[  107.007751] PVR_K:   (MKT-156) 07BAC759 00000808 00003A1E AD00030E
[  107.014221] PVR_K:   (MKT-157) 07BAC772 00000808 00003A1E 0D800494
[  107.020782] PVR_K:   (MKT-158) 07BAC78A 00000808 00003A1E 00000010
[  107.027282] PVR_K:   (MKT-159) 07BAC7AE 00000808 00003A1E 00000011
[  107.033843] PVR_K:   (MKT-15A) 07BAC818 00000808 00003A1E AD000184
[  107.040313] PVR_K:   (MKT-15B) 07BAC87F 00000C08 01003B1D AD000281
[  107.046874] PVR_K:   (MKT-15C) 07BAC9F0 00000808 01003B1D AD00080A
[  107.053405] PVR_K:   (MKT-15D) 07BACA09 00000808 01003B1D 0F041A00
[  107.059906] PVR_K:   (MKT-15E) 07BACA21 00000808 01003B1D 00000060
[  107.066528] PVR_K:   (MKT-15F) 07BACCD8 00000808 00003B1D AD000803
[  107.073028] PVR_K:   (MKT-160) 07BACD1D 00180CC8 00003B1D AD000282
[  107.079589] PVR_K:   (MKT-161) 07BACDE4 00000808 01003D1F AD000200
[  107.086090] PVR_K:   (MKT-162) 07BAD001 00000808 00003D1F AD000202
[  107.092620] PVR_K:   (MKT-163) 07BAD07F 00000808 00003E1E AD000183
[  107.099121] PVR_K:   (MKT-164) 07BAD169 00000808 00003E1E AD00030E
[  107.105651] PVR_K:   (MKT-165) 07BAD182 00000808 00003E1E 0D800494
[  107.112152] PVR_K:   (MKT-166) 07BAD19A 00000808 00003E1E 00000010
[  107.118682] PVR_K:   (MKT-167) 07BAD1BE 00000808 00003E1E 00000011
[  107.125213] PVR_K:   (MKT-168) 07BAD22A 00000808 00003E1E AD000184
[  107.131744] PVR_K:   (MKT-169) 07BAD28D 00000C08 01003F1D AD000281
[  107.138275] PVR_K:   (MKT-16A) 07BAD3FB 00000808 01003F1D AD00080A
[  107.144775] PVR_K:   (MKT-16B) 07BAD414 00000808 01003F1D 0F041D00
[  107.151336] PVR_K:   (MKT-16C) 07BAD42C 00000808 01003F1D 00000060
[  107.157836] PVR_K:   (MKT-16D) 07BAD6E1 00000808 00003F1D AD000803
[  107.164367] PVR_K:   (MKT-16E) 07BAD728 00180CC8 00003F1D AD000282
[  107.170867] PVR_K:   (MKT-16F) 07BAD80E 00000808 0100411F AD000200
[  107.177429] PVR_K:   (MKT-170) 07BADA26 00000808 0000411F AD000202
[  107.183898] PVR_K:   (MKT-171) 07BADAA8 00000808 0000421E AD000183
[  107.190460] PVR_K:   (MKT-172) 07BADB90 00000808 0000421E AD00030E
[  107.196960] PVR_K:   (MKT-173) 07BADBA8 00000808 0000421E 0D800494
[  107.203552] PVR_K:   (MKT-174) 07BADBC1 00000808 0000421E 00000010
[  107.210083] PVR_K:   (MKT-175) 07BADBE4 00000808 0000421E 00000011
[  107.216583] PVR_K:   (MKT-176) 07BADC52 00000808 0000421E AD000184
[  107.223144] PVR_K:   (MKT-177) 07BADCB5 00000C08 0100431D AD000281
[  107.229644] PVR_K:   (MKT-178) 07BADE25 00000808 0100431D AD00080A
[  107.236206] PVR_K:   (MKT-179) 07BADE3E 00000808 0100431D 0F042000
[  107.242706] PVR_K:   (MKT-17A) 07BADE56 00000808 0100431D 00000062
[  107.249267] PVR_K:   (MKT-17B) 07BAE107 00000808 0000431D AD000803
[  107.255737] PVR_K:   (MKT-17C) 07BAE150 00180C88 0000431D AD000282
[  107.262298] PVR_K:   (MKT-17D) 07BAEC60 00000808 0100451F AD000200
[  107.268798] PVR_K:   (MKT-17E) 07BAED7E 00000808 0100451F AD001703
[  107.275360] PVR_K:   (MKT-17F) 07BAEF5E 00000808 0000451F AD000202
[  107.281890] PVR_K:   (MKT-180) 07BAEFDD 00000808 0000461E AD000183
[  107.288421] PVR_K:   (MKT-181) 07BAF0C5 00000808 0000461E AD00030E
[  107.294952] PVR_K:   (MKT-182) 07BAF0DD 00000808 0000461E 0D800494
[  107.301452] PVR_K:   (MKT-183) 07BAF0F6 00000808 0000461E 00000010
[  107.308013] PVR_K:   (MKT-184) 07BAF119 00000808 0000461E 00000011
[  107.314514] PVR_K:   (MKT-185) 07BAF183 00000808 0000461E AD000184
[  107.321075] PVR_K:   (MKT-186) 07BAF1E8 00000C08 0100471D AD000281
[  107.327575] PVR_K:   (MKT-187) 07BAF2FB 00000808 0100471D AD000E02
[  107.334106] PVR_K:   (MKT-188) 07BAF36B 00000808 0100471D AD000282
[  107.340576] PVR_K:   (MKT-189) 07BBD36A 00000808 01004A1F AD001A00
[  107.347137] PVR_K:   (MKT-18A) 07BC9978 00000808 01004D1F AD00000A
[  107.353637] PVR_K:   (MKT-18B) 07BC99E1 00000808 01004D1F AD000909
[  107.360168] PVR_K:   (MKT-18C) 07BC9A2D 00000808 01004D1F AD001A05
[  107.366729] PVR_K:   (MKT-18D) 07BC9A5C 00000808 01004D1F AD001302
[  107.373260] PVR_K:   (MKT-18E) 07BC9AA4 00000808 01004D1F AD001303
[  107.379791] PVR_K:   (MKT-18F) 07BC9B3F 00000808 01004D1F AD000D04
[  107.386291] PVR_K:   (MKT-190) 07BC9C0C 00000808 01004D1F AD000D05
[  107.392852] PVR_K:   (MKT-191) 07BC9C63 00000808 01004D1F AD000D04
[  107.399353] PVR_K:   (MKT-192) 07BC9CE8 00000808 01004D1F AD000D05
[  107.405914] PVR_K:   (MKT-193) 07BC9D44 00000808 01004D1F AD001A06
[  107.412445] PVR_K:   (MKT-194) 00000493 00100808 0100031F AD002300
[  107.419006] PVR_K:   (MKT-195) 00000978 00100808 0100041F AD00000A
[  107.425476] PVR_K:   (MKT-196) 000009E9 00100808 0100041F AD000904
[  107.432037] PVR_K:   (MKT-197) 00000B02 00100808 0000041F AD000901
[  107.438537] PVR_K:   (MKT-198) 00000B7E 00100808 0000051E AD000183
[  107.445098] PVR_K:   (MKT-199) 00000EE4 0010088F 0000051E AD002401
[  107.451568] PVR_K:   (MKT-19A) 00000F2E 0016EC8F 0000051E AD000184
[  107.458129] PVR_K:   (MKT-19B) 00000FC8 0017FF8F 0000061D AD000281
[  107.464660] PVR_K:   (MKT-19C) 00001146 0017FB8F 0000061D AD000E02
[  107.471191] PVR_K:   (MKT-19D) 000011B7 0017F98F 0000061D AD000282
[  107.477722] PVR_K:   (MKT-19E) 00001342 00100808 0100081F AD000101
[  107.484191] PVR_K:   (MKT-19F) 0000143E 00100808 0100081F AD001601
[  107.490753] PVR_K:   (MKT-1A0) 00001468 00100808 0100081F 0D800784
[  107.497253] PVR_K:   (MKT-1A1) 00001481 00100808 0100081F 00000001
[  107.503784] PVR_K:   (MKT-1A2) 0000161D 00100808 0000081F AD00030E
[  107.510345] PVR_K:   (MKT-1A3) 00001635 00100808 0000081F 0D800494
[  107.516876] PVR_K:   (MKT-1A4) 0000164E 00100808 0000081F 00000010
[  107.523376] PVR_K:   (MKT-1A5) 00001673 00100808 0000081F 00000011
[  107.529937] PVR_K:   (MKT-1A6) 000016FF 00100808 0000081F AD000104
[  107.536437] PVR_K:   (MKT-1A7) 00001765 00100C08 0100091E AD000281
[  107.542968] PVR_K:   (MKT-1A8) 00001861 00100808 0100091E AD000E02
[  107.549530] PVR_K:   (MKT-1A9) 000018D4 00100808 0100091E AD000282
[  107.556030] PVR_K:   (MKT-1AA) 0000413A 00100808 01000A1F AD00000A
[  107.562591] PVR_K:   (MKT-1AB) 000041AC 00100808 01000A1F AD000905
[  107.569061] PVR_K:   (MKT-1AC) 000042F5 00100808 00000A1F AD000901
[  107.575622] PVR_K:   (MKT-1AD) 00004365 00100808 00000B1E AD000183
[  107.582122] PVR_K:   (MKT-1AE) 00004454 00100808 00000B1E AD00030E
[  107.588684] PVR_K:   (MKT-1AF) 0000446C 00100808 00000B1E 0D800494
[  107.595184] PVR_K:   (MKT-1B0) 00004485 00100808 00000B1E 00000010
[  107.601745] PVR_K:   (MKT-1B1) 000044A9 00100808 00000B1E 00000011
[  107.608245] PVR_K:   (MKT-1B2) 00004514 00100808 00000B1E AD000184
[  107.614807] PVR_K:   (MKT-1B3) 0000457A 00100C08 01000C1D AD000281
[  107.621276] PVR_K:   (MKT-1B4) 00004656 00100808 01000C1D AD000E02
[  107.627899] PVR_K:   (MKT-1B5) 000047F3 00100808 01000C1D AD00080A
[  107.634429] PVR_K:   (MKT-1B6) 0000480E 00100808 01000C1D 0F05D000
[  107.640960] PVR_K:   (MKT-1B7) 00004828 00100808 01000C1D 00000073
[  107.649047] PVR_K:   (MKT-1B8) 000048EB 00100808 01000C1D AD001300
[  107.655609] PVR_K:   (MKT-1B9) 00004A0A 00100808 01000C1D AD001301
[  107.670440] PVR_K:   (MKT-1BA) 00004B21 00100C08 00000C1D AD000802
[  107.677368] PVR_K:   (MKT-1BB) 00004C9A 00100808 00000C1D AD000803
[  107.684173] PVR_K:   (MKT-1BC) 00004CE2 00184AC8 00000C1D AD000282
[  107.690704] PVR_K:   (MKT-1BD) 00005423 00000808 01000E1F AD000200
[  107.697326] PVR_K:   (MKT-1BE) 00005562 00000808 01000E1F AD001703
[  107.703857] PVR_K:   (MKT-1BF) 00005757 00000808 00000E1F AD000202
[  107.710388] PVR_K:   (MKT-1C0) 000057D7 00000808 00000F1E AD000183
[  107.716888] PVR_K:   (MKT-1C1) 000058D0 00000808 00000F1E AD00030E
[  107.723419] PVR_K:   (MKT-1C2) 000058E8 00000808 00000F1E 0D800494
[  107.729980] PVR_K:   (MKT-1C3) 00005903 00000808 00000F1E 00000010
[  107.736511] PVR_K:   (MKT-1C4) 00005926 00000808 00000F1E 00000011
[  107.743072] PVR_K:   (MKT-1C5) 00005A2B 00000808 00000F1E AD000302
[  107.749572] PVR_K:   (MKT-1C6) 00005C73 00000808 00000F1E AD000404
[  107.756072] PVR_K:   (MKT-1C7) 00005D40 00000808 00000F1E AD000402
[  107.762573] PVR_K:   (MKT-1C8) 00005D7D 001008AD 00000F1E AD000184
[  107.769195] PVR_K:   (MKT-1C9) 00005E12 00108DA9 0000101D AD000281
[  107.775695] PVR_K:   (MKT-1CA) 00005F66 001089AB 0000101D AD000E02
[  107.782257] PVR_K:   (MKT-1CB) 00005FC3 001089AD 0000101D AD000282
[  107.788787] PVR_K:   (MKT-1CC) 000065A4 00100828 0100131F AD000101
[  107.795318] PVR_K:   (MKT-1CD) 0000661B 001008A8 0100131F AD000104
[  107.801818] PVR_K:   (MKT-1CE) 00006650 00000808 0100141E AD000100
[  107.808380] PVR_K:   (MKT-1CF) 0000673A 00000808 0100141E AD000501
[  107.814941] PVR_K:   (MKT-1D0) 0000677A 0010082B 0100141E AD000104
[  107.821441] PVR_K:   (MKT-1D1) 00006EE4 00100828 0100151F AD000101
[  107.827972] PVR_K:   (MKT-1D2) 00006F33 00100828 0100151F AD000104
[  107.834533] PVR_K:   (MKT-1D3) 00006FAC 00000808 0100161F AD000100
[  107.841094] PVR_K:   (MKT-1D4) 00007034 00000808 0100161F AD000502
[  107.847625] PVR_K:   (MKT-1D5) 0000707D 00000808 0100161F AD000C01
[  107.854156] PVR_K:   (MKT-1D6) 000070A5 00000808 0100161F 0D8006E4
[  107.860656] PVR_K:   (MKT-1D7) 000070BD 00000808 0100161F 00000001
[  107.867218] PVR_K:   (MKT-1D8) 0000735C 00000808 0000161F AD00030E
[  107.873718] PVR_K:   (MKT-1D9) 00007374 00000808 0000161F 0D800494
[  107.880249] PVR_K:   (MKT-1DA) 0000738C 00000808 0000161F 00000010
[  107.881164] adc_to_temp_conversion:Temp read is invalid 0
[  107.881164] thermal_lookup_temp: getting temp is not supported for domain pcb
[  107.882019] adc_to_temp_conversion:Temp read is invalid 0
[  107.882019] thermal_lookup_temp: getting temp is not supported for domain pcb
[  107.882873] adc_to_temp_conversion:Temp read is invalid 0
[  107.882904] thermal_lookup_temp: getting temp is not supported for domain pcb
[  107.926971] PVR_K:   (MKT-1DB) 000073B0 00000808 0000161F 00000011
[  107.933471] PVR_K:   (MKT-1DC) 00007447 00000808 0000161F AD000104
[  107.940032] PVR_K:   (MKT-1DD) 000074AE 00000C08 0100171E AD000281
[  107.946533] PVR_K:   (MKT-1DE) 000075AF 00000808 0100171E AD000E02
[  107.953063] PVR_K:   (MKT-1DF) 0000761F 00000808 0100171E AD000282
[  107.959625] PVR_K:   (MKT-1E0) 0000D151 00000808 0100191F AD00000A
[  107.966094] PVR_K:   (MKT-1E1) 0000D1BB 00000808 0100191F AD000906
[  107.972656] PVR_K:   (MKT-1E2) 0000D27A 00000808 0000191F AD000901
[  107.979156] PVR_K:   (MKT-1E3) 0000D2E4 00000808 00001A1E AD000183
[  107.985687] PVR_K:   (MKT-1E4) 0000D43A 00000808 00001A1E AD000302
[  107.992187] PVR_K:   (MKT-1E5) 0000D5C3 00000808 00001A1E AD000D06
[  107.998748] PVR_K:   (MKT-1E6) 0000D6AC 00000808 00001A1E AD000D07
[  108.005249] PVR_K:   (MKT-1E7) 0000D6E9 00000808 00001A1E AD001306
[  108.011810] PVR_K:   (MKT-1E8) 0000D72D 00000808 00001A1E AD001307
[  108.018310] PVR_K:   (MKT-1E9) 0000D752 00000808 00001A1E AD001304
[  108.024841] PVR_K:   (MKT-1EA) 0000D82F 00000808 00001A1E AD001305
[  108.031341] PVR_K:   (MKT-1EB) 0000D93E 00000888 00001A1E AD000404
[  108.037902] PVR_K:   (MKT-1EC) 0000DA02 00000808 00001A1E AD000402
[  108.044464] PVR_K:   (MKT-1ED) 0000DA4C 0010082B 00001A1E AD000184
[  108.050964] PVR_K:   (MKT-1EE) 0000DAF2 00119DA9 00001B1D AD000281
[  108.057495] PVR_K:   (MKT-1EF) 0000DC7C 001199AD 00001B1D AD000E02
[  108.064025] PVR_K:   (MKT-1F0) 0000DCDD 001009AF 00001B1D AD000282
[  108.070587] PVR_K:   (MKT-1F1) 00010317 00000808 00001D1F AD000101
[  108.077087] PVR_K:   (MKT-1F2) 0001038D 00000808 00001D1F AD000104
[  108.083618] PVR_K:   (MKT-1F3) 000103C9 00000808 01001E1E AD000100
[  108.090148] PVR_K:   (MKT-1F4) 000104CE 00000808 01001E1E AD000501
[  108.096679] PVR_K:   (MKT-1F5) 0001050D 0010082B 01001E1E AD000104
[  108.103179] PVR_K:   (MKT-1F6) 00012823 00100828 0100201F AD000101
[  108.109741] PVR_K:   (MKT-1F7) 0001289D 00100828 0100201F AD000104
[  108.116241] PVR_K:   (MKT-1F8) 00012952 00000808 0100211F AD000100
[  108.122772] PVR_K:   (MKT-1F9) 00012A44 00000808 0100211F AD000501
[  108.129333] PVR_K:   (MKT-1FA) 00012A83 00100829 0100211F AD000104
[  108.135833] PVR_K:   (MKT-1FB) 00014FD0 00100828 0100221F AD000101
[  108.142395] PVR_K:   (MKT-1FC) 00015016 00100828 0100221F AD000104
[  108.148895] PVR_K:   (MKT-1FD) 000150A9 00000808 0100231F AD000100
[  108.155426] PVR_K:   (MKT-1FE) 00015172 00000808 0100231F AD000501
[  108.161926] PVR_K:   (MKT-1FF) 0001519E 00100829 0100231F AD000104
[  108.168487] PVR_K: SGX Kernel CCB WO:0xF5 RO:0xEB
[  108.173522] PVR_K:(Error): PVRSRVSwapToDCBuffer2KM: Failed to get space in queue [0, ]
[  108.389556] PVR_K:(Error): SGXOSTimer() detected SGX lockup (0x9 tasks) [0, ]
[  108.397491] PVR_K: HWRecoveryResetSGX: SGX Hardware Recovery triggered
[  108.406249] [   87.162]    [c6edbdc0] --refs=1 on RELEASED
[  108.406249] [   87.162]                       [c6f12c00] dsscomp_apply
[  108.406280] [   87.162]   [c6edbca0] --refs=0 on RELEASED
[  108.406280] [   87.162]   [c6edbca0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[  108.406280] [   87.162]                          [c6f10800] dsscomp_mgr_delayed_cb on RELEASED
[  108.438385] [   87.162]                       [c6f12c00] dsscomp_mgr_delayed_cb on PROGRAMMED
[  108.438415] [   87.163]    [c6edbce0] new in dsscomp_gralloc_queue (refs=1)
[  108.438415] [   87.163]                           [c6f13400] dsscomp_new
[  108.468383] [   87.163]    [c6edbce0] ++refs=2 for [c6f13400]
[  108.468383] [   87.163]                           [c6f13400] dsscomp_delayed_apply
[  108.468414] [   87.163]    [c6edbce0] --refs=1 on RELEASED
[  108.468414] [   87.163]                           [c6f13400] dsscomp_apply
[  108.468414] [   87.177]                       [c6f12c00] dsscomp_mgr_delayed_cb on DISPLAYED
[  108.499877] [   87.177]    [c6edbdc0] --refs=0 on RELEASED
[  108.499908] [   87.177]    [c6edbdc0] calling dsscomp_proxy_cmdcomplete [c73f6900]
[  108.499908] [   87.178]                       [c6f12c00] dsscomp_mgr_delayed_cb on RELEASED
[  108.499908] [   87.178]                           [c6f13400] dsscomp_mgr_delayed_cb on PROGRAMMED
[  108.529693] [   87.199]                           [c6f13400] dsscomp_mgr_delayed_cb on DISPLAYED
[  108.529693] [   92.240]       [c6fa4720] new in dsscomp_gralloc_queue (refs=1)
[  108.529693] [   92.240]                       [c6e67400] dsscomp_new
[  108.557952] [   92.240]       [c6fa4720] ++refs=2 for [c6e67400]
[  108.557952] [   92.240]                       [c6e67400] dsscomp_delayed_apply
[  108.557952] [   92.240]       [c6fa4720] --refs=1 on RELEASED
[  108.557952] [   92.240]                       [c6e67400] dsscomp_apply
[  108.587738] [   92.240]    [c6edbce0] --refs=0 on RELEASED
[  108.587738] [   92.240]    [c6edbce0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[  108.587738] [   92.240]                           [c6f13400] dsscomp_mgr_delayed_cb on RELEASED
[  108.587768] [   92.240]                       [c6e67400] dsscomp_mgr_delayed_cb on PROGRAMMED
[  108.617523] [   92.241]      [c6edbc80] new in dsscomp_gralloc_queue (refs=1)
[  108.617523] [   92.241]                         [c6f13000] dsscomp_new
[  108.617523] [   92.241]      [c6edbc80] ++refs=2 for [c6f13000]
[  108.617523] [   92.241]                         [c6f13000] dsscomp_delayed_apply
[  108.647338] [   92.241]      [c6edbc80] --refs=1 on RELEASED
[  108.647338] [   92.241]                         [c6f13000] dsscomp_apply
[  108.647338] [   92.256]                       [c6e67400] dsscomp_mgr_delayed_cb on DISPLAYED
[  108.647338] [   92.256]       [c6fa4720] --refs=0 on RELEASED
[  108.677093] [   92.256]       [c6fa4720] calling dsscomp_proxy_cmdcomplete [c73f6900]
[  108.677093] [   92.256]                       [c6e67400] dsscomp_mgr_delayed_cb on RELEASED
[  108.677124] [   92.256]                         [c6f13000] dsscomp_mgr_delayed_cb on PROGRAMMED
[  108.677124] [   92.277]                         [c6f13000] dsscomp_mgr_delayed_cb on DISPLAYED
[  108.706939] [   97.379]       [c6edbb00] new in dsscomp_gralloc_queue (refs=1)
[  108.706939] [   97.379]                      [c6f10000] dsscomp_new
[  108.706939] [   97.379]       [c6edbb00] ++refs=2 for [c6f10000]
[  108.706939] [   97.379]                      [c6f10000] dsscomp_delayed_apply
[  108.736694] [   97.379]       [c6edbb00] --refs=1 on RELEASED
[  108.736694] [   97.379]                      [c6f10000] dsscomp_apply
[  108.736694] [   97.380]      [c6edbc80] --refs=0 on RELEASED
[  108.736694] [   97.380]      [c6edbc80] calling dsscomp_proxy_cmdcomplete [c73f6480]
[  108.766510] [   97.380]                         [c6f13000] dsscomp_mgr_delayed_cb on RELEASED
[  108.766510] [   97.380]                      [c6f10000] dsscomp_mgr_delayed_cb on PROGRAMMED
[  108.766510] [   97.380]   [c6edbca0] new in dsscomp_gralloc_queue (refs=1)
[  108.795196] [   97.380]                          [c6f10800] dsscomp_new
[  108.795227] [   97.380]   [c6edbca0] ++refs=2 for [c6f10800]
[  108.795227] [   97.380]                          [c6f10800] dsscomp_delayed_apply
[  108.795227] [   97.380]   [c6edbca0] --refs=1 on RELEASED
[  108.795227] [   97.380]                          [c6f10800] dsscomp_apply
[  108.826568] [   97.408]                      [c6f10000] dsscomp_mgr_delayed_cb on DISPLAYED
[  108.826568] [   97.408]       [c6edbb00] --refs=0 on RELEASED
[  108.826568] [   97.408]       [c6edbb00] calling dsscomp_proxy_cmdcomplete [c73f6900]
[  108.826568] [   97.408]                      [c6f10000] dsscomp_mgr_delayed_cb on RELEASED
[  108.856353] [   97.408]                          [c6f10800] dsscomp_mgr_delayed_cb on PROGRAMMED
[  108.856353] [   97.410] [c6fa4760] new in dsscomp_gralloc_queue (refs=1)
[  108.856353] [   97.410]                      [c6f10000] dsscomp_new
[  108.884613] [   97.410] [c6fa4760] ++refs=2 for [c6f10000]
[  108.884613] [   97.410]                      [c6f10000] dsscomp_delayed_apply
[  108.884613] [   97.410] [c6fa4760] --refs=1 on RELEASED
[  108.884613] [   97.410]                      [c6f10000] dsscomp_apply
[  108.884643] [   97.421]                          [c6f10800] dsscomp_mgr_delayed_cb on DISPLAYED
[  108.915954] [   97.421]   [c6edbca0] --refs=0 on RELEASED
[  108.915954] [   97.421]   [c6edbca0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[  108.915954] [   97.421]                          [c6f10800] dsscomp_mgr_delayed_cb on RELEASED
[  108.915954] [   97.421]    [c6edb880] new in dsscomp_gralloc_queue (refs=1)
[  108.945739] [   97.421]                          [c6f10800] dsscomp_new
[  108.945770] [   97.421]    [c6edb880] ++refs=2 for [c6f10800]
[  108.945770] [   97.421]                          [c6f10800] dsscomp_delayed_apply
[  108.945770] [   97.421]    [c6edb880] --refs=1 on RELEASED
[  108.975555] [   97.421]                      [c6f10000] dsscomp_mgr_delayed_cb on PROGRAMMED
[  108.975555] [   97.421]                          [c6f10800] dsscomp_apply
[  108.975555] [   97.445]                      [c6f10000] dsscomp_mgr_delayed_cb on DISPLAYED
[  109.003906] [   97.445] [c6fa4760] --refs=0 on RELEASED
[  109.003906] [   97.445] [c6fa4760] calling dsscomp_proxy_cmdcomplete [c73f6900]
[  109.003906] [   97.445]                      [c6f10000] dsscomp_mgr_delayed_cb on RELEASED
[  109.003936] [   97.445]                          [c6f10800] dsscomp_mgr_delayed_cb on PROGRAMMED
[  109.033569] [   97.473]                          [c6f10800] dsscomp_mgr_delayed_cb on DISPLAYED
[  109.033569] [  102.822]  [c602d0c0] new in dsscomp_gralloc_queue (refs=1)
[  109.033569] [  102.822]                        [c6f10400] dsscomp_new
[  109.033569] [  102.822]  [c602d0c0] ++refs=2 for [c6f10400]
[  109.063323] [  102.822]                        [c6f10400] dsscomp_delayed_apply
[  109.063354] [  102.822]  [c602d0c0] --refs=1 on RELEASED
[  109.063354] [  102.822]                        [c6f10400] dsscomp_apply
[  109.063354] [  102.823]    [c6edb880] --refs=0 on RELEASED
[  109.063354] [  102.823]    [c6edb880] calling dsscomp_proxy_cmdcomplete [c73f6480]
[  109.094665] [  102.823]                          [c6f10800] dsscomp_mgr_delayed_cb on RELEASED
[  109.094665] [  102.823]                        [c6f10400] dsscomp_mgr_delayed_cb on PROGRAMMED
[  109.094665] [  102.823]     [c602d420] new in dsscomp_gralloc_queue (refs=1)
[  109.122985] [  102.823]                          [c6f10800] dsscomp_new
[  109.122985] [  102.823]     [c602d420] ++refs=2 for [c6f10800]
[  109.123016] [  102.823]                          [c6f10800] dsscomp_delayed_apply
[  109.123016] [  102.823]     [c602d420] --refs=1 on RELEASED
[  109.123016] [  102.823]                          [c6f10800] dsscomp_apply
[  109.154357] [  102.839]                        [c6f10400] dsscomp_mgr_delayed_cb on DISPLAYED
[  109.154357] [  102.839]  [c602d0c0] --refs=0 on RELEASED
[  109.154357] [  102.839]  [c602d0c0] calling dsscomp_proxy_cmdcomplete [c73f6900]
[  109.182586] [  102.839]                        [c6f10400] dsscomp_mgr_delayed_cb on RELEASED
[  109.182617] [  102.839]                          [c6f10800] dsscomp_mgr_delayed_cb on PROGRAMMED
[  109.182617] [  102.856]                          [c6f10800] dsscomp_mgr_delayed_cb on DISPLAYED
[  109.182617] [  108.175]  [c6296080] new in dsscomp_gralloc_queue (refs=1)
[  109.212402] [  108.175]                           [c61c4000] dsscomp_new
[  109.212402] [  108.175]  [c6296080] ++refs=2 for [c61c4000]
[  109.212402] [  108.175]                           [c61c4000] dsscomp_delayed_apply
[  109.212402] [  108.175]  [c6296080] --refs=1 on RELEASED
[  109.242187] [  108.175]                           [c61c4000] dsscomp_apply
[  109.242187] [  108.176]     [c602d420] --refs=0 on RELEASED
[  109.242187] [  108.176]     [c602d420] calling dsscomp_proxy_cmdcomplete [c73f6480]
[  109.242187] [  108.176]                          [c6f10800] dsscomp_mgr_delayed_cb on RELEASED
[  109.272003] [  108.176]                           [c61c4000] dsscomp_mgr_delayed_cb on PROGRAMMED
[  109.272003] [  108.176]    [c61b2660] new in dsscomp_gralloc_queue (refs=1)
[  109.272033] [  108.176]                     [c71efc00] dsscomp_new
[  109.272033] [  108.176]    [c61b2660] ++refs=2 for [c71efc00]
[  109.301788] [  108.176]                     [c71efc00] dsscomp_delayed_apply
[  109.301788] [  108.176]    [c61b2660] --refs=1 on RELEASED
[  109.301788] [  108.176]                     [c71efc00] dsscomp_apply
[  109.301788] [  108.197]                           [c61c4000] dsscomp_mgr_delayed_cb on DISPLAYED
[  109.331573] [  108.197]  [c6296080] --refs=0 on RELEASED
[  109.331573] [  108.197]  [c6296080] calling dsscomp_proxy_cmdcomplete [c73f6900]
[  109.331573] [  108.197]                           [c61c4000] dsscomp_mgr_delayed_cb on RELEASED
[  109.331604] [  108.197]                     [c71efc00] dsscomp_mgr_delayed_cb on PROGRAMMED
[  109.361358] [  108.215]                     [c71efc00] dsscomp_mgr_delayed_cb on DISPLAYED
[  109.361358] ACTIVE COMPOSITIONS on lcd
[  109.361358]
[  109.361358]   [c71efc00]: DISPLAYED
[  109.361358]     sync_id=0, flags=AD-
[  109.361358]     ovl0={ON z0 ARGB32-8888 premult *100% 864*480:0,0+864,480 rot0 => 0,0+864,480 7f9ac000/  (null)|3456}
[  109.394195]     gsync=[c61b2660] dsscomp_gralloc_cb
[  109.394195]
[  109.394226]   DISPC pipeline:
[  109.394226]
[  109.394226]     info:        clean (none)
[  109.394226]     cache:       clean (none)
[  109.394226]     shadow:  ACT clean (none)
[  109.394226]     dispc:   DISPLAYED mask=---R [c71efc00] dsscomp_mgr_callback
[  109.430114]
[  109.430114] ACTIVE COMPOSITIONS on tv
[  109.430114]
[  109.430114]   DISPC pipeline:
[  109.430114]
[  109.430114]     info:        clean (none)
[  109.430114]     cache:       clean (none)
[  109.430145]     shadow:  off clean (none)
[  109.430145]     dispc:   DISPLAYED (none)
[  109.430145]
[  109.430145] ACTIVE COMPOSITIONS on lcd2
[  109.430145]
[  109.430145]   DISPC pipeline:
[  109.430145]
[  109.430145]     info:        clean (none)
[  109.476715]     cache:       clean (none)
[  109.476715]     shadow:  off clean (none)
[  109.476745]     dispc:             (none)
[  109.476745]
[  109.476745] ACTIVE GRALLOC FLIPS
[  109.476745]
[  109.476745]   [c61b2660] (refs=1)
[  109.476745]     slots=[7f9ac000]
[  109.476745]     cmdcb=[c73f6480] dsscomp_proxy_cmdcomplete
[  109.476745]
[  109.476745]   |           lcd
[  109.476745]   | [c71efc00] DISPL'D
[  109.518768]   |    108.176  ACTIVE
[  109.518768]   |    108.176 APPLY'N
[  109.518768]   |    108.176 APPLIED
[  109.518768]   |    108.197 PROGR'D
[  109.518768]   |    108.215 DISPL'D
[  109.518768]
[  109.518768]
[  109.541442] PVR_K: SGX debug (blaze_android_sgx_ogles1_ogles2_GPL sgxddk 18 1.8@869593)
[  109.549957] PVR_K:(Error): SGX Register Base Address (Linear):   0xC8B20000 [0, ]
[  109.557983] PVR_K:(Error): SGX Register Base Address (Physical): 0x56000000 [0, ]
[  109.566009] PVR_K: (P0) EUR_CR_CORE_ID:          01140000
[  109.571777] PVR_K: (P0) EUR_CR_CORE_REVISION:    00010200
[  109.577606] PVR_K: (P0) EUR_CR_EVENT_STATUS:     20000000
[  109.583343] PVR_K: (P0) EUR_CR_EVENT_STATUS2:    00000008
[  109.589141] PVR_K: (P0) EUR_CR_BIF_CTRL:         00000000
[  109.594909] PVR_K: (P0) EUR_CR_BIF_INT_STAT:     00008000
[  109.600677] PVR_K: (P0) EUR_CR_BIF_FAULT:        00000000
[  109.606445] PVR_K: (P0) EUR_CR_BIF_MEM_REQ_STAT: 00000000
[  109.612213] PVR_K: (P0) EUR_CR_CLKGATECTL:       000AAA6A
[  109.618011] PVR_K: (P0) EUR_CR_PDS_PC_BASE:      00004008
[  109.623779] PVR_K: Flip Command Complete Data 0 for display device 1:
[  109.630676] PVR_K:   SRC 0: ROC DevVAddr:0xD800474 ROP:0x14 ROC:0x13, WOC DevVAddr:0xD800464 WOP:0x14 WOC:0x13
[  109.641296] PVR_K: Flip Command Complete Data 1 for display device 1:
[  109.648162] PVR_K:   SRC 0: (Not in use)
[  109.652282] PVR_K: SGX Host control:
[  109.656127] PVR_K:   (HC-0) 0x00000001 0x00000000 0x00000000 0x00000001
[  109.663146] PVR_K:   (HC-10) 0x00000013 0x0000000A 0x0005DC00 0x00000003
[  109.670166] PVR_K:   (HC-20) 0x00000000 0x00000001 0x00000000 0x0000001A
[  109.677276] PVR_K:   (HC-30) 0x00000E76 0xF4917AE4 0x00000000 0x00000000
[  109.684356] PVR_K:   (HC-40) 0x00000000 0x087BF500 0x087C6300 0x087C3100
[  109.691436] PVR_K: SGX TA/3D control:
[  109.695373] PVR_K:   (T3C-0) 0x0F003000 0x0F003120 0x0F002000 0x0F06F180
[  109.702453] PVR_K:   (T3C-10) 0x00000001 0x00000002 0x00000001 0x0F00DFA0
[  109.709594] PVR_K:   (T3C-20) 0x00000000 0x00000000 0x00000000 0x00000000
[  109.716735] PVR_K:   (T3C-30) 0x00000000 0x00000000 0x00000000 0x00000000
[  109.723907] PVR_K:   (T3C-40) 0x00000000 0x00000000 0x00000000 0x0F00DA60
[  109.731048] PVR_K:   (T3C-50) 0x0F00DD00 0x00000000 0x0F00DA60 0x0F00DD00
[  109.740356] PVR_K:   (T3C-60) 0x00000000 0x00000000 0x0F00DD00 0x00000000
[  109.747528] PVR_K:   (T3C-70) 0x00000000 0x0F00DD00 0x00000000 0x0F004000
[  109.754730] PVR_K:   (T3C-80) 0x00000126 0x0001120F 0x00000000 0x0F00DEB8
[  109.762237] PVR_K:   (T3C-90) 0x00000000 0x0F000000 0xAB600000 0x0F043800
[  109.769378] PVR_K:   (T3C-A0) 0x00000000 0x0F010BE0 0x0F00DD00 0x0F00DEB8
[  109.776702] PVR_K:   (T3C-B0) 0x0F010760 0x00000000 0x00000000 0x00000000
[  109.784606] PVR_K:   (T3C-C0) 0x00000000 0x00000000 0x00000000 0x00000000
[  109.791839] PVR_K:   (T3C-D0) 0x00000000 0x00000026 0x00000025 0x0F007000
[  109.799041] PVR_K:   (T3C-E0) 0x0F00D420 0x0F00E000 0x0F010720 0x0F010720
[  109.806182] PVR_K:   (T3C-F0) 0x00000000 0x000000B5 0x000000B5 0x00000000
[  109.813385] PVR_K:   (T3C-100) 0x00000003 0x00000001 0x00000000 0x00000000
[  109.820617] PVR_K:   (T3C-110) 0xB50C565C 0x0872E100 0x08787B00 0x08787B00
[  109.827911] PVR_K: Last SGX microkernel status code: AD000104
[  109.834075] PVR_K:   (MKT-0) 0000661B 001008A8 0100131F AD000104
[  109.840393] PVR_K:   (MKT-1) 00006650 00000808 0100141E AD000100
[  109.846740] PVR_K:   (MKT-2) 0000673A 00000808 0100141E AD000501
[  109.853057] PVR_K:   (MKT-3) 0000677A 0010082B 0100141E AD000104
[  109.859436] PVR_K:   (MKT-4) 00006EE4 00100828 0100151F AD000101
[  109.865722] PVR_K:   (MKT-5) 00006F33 00100828 0100151F AD000104
[  109.872100] PVR_K:   (MKT-6) 00006FAC 00000808 0100161F AD000100
[  109.878448] PVR_K:   (MKT-7) 00007034 00000808 0100161F AD000502
[  109.884826] PVR_K:   (MKT-8) 0000707D 00000808 0100161F AD000C01
[  109.891143] PVR_K:   (MKT-9) 000070A5 00000808 0100161F 0D8006E4
[  109.897521] PVR_K:   (MKT-A) 000070BD 00000808 0100161F 00000001
[  109.903808] PVR_K:   (MKT-B) 0000735C 00000808 0000161F AD00030E
[  109.910186] PVR_K:   (MKT-C) 00007374 00000808 0000161F 0D800494
[  109.916503] PVR_K:   (MKT-D) 0000738C 00000808 0000161F 00000010
[  109.922851] PVR_K:   (MKT-E) 000073B0 00000808 0000161F 00000011
[  109.929168] PVR_K:   (MKT-F) 00007447 00000808 0000161F AD000104
[  109.935516] PVR_K:   (MKT-10) 000074AE 00000C08 0100171E AD000281
[  109.941925] PVR_K:   (MKT-11) 000075AF 00000808 0100171E AD000E02
[  109.948364] PVR_K:   (MKT-12) 0000761F 00000808 0100171E AD000282
[  109.954772] PVR_K:   (MKT-13) 0000D151 00000808 0100191F AD00000A
[  109.961242] PVR_K:   (MKT-14) 0000D1BB 00000808 0100191F AD000906
[  109.967987] PVR_K:   (MKT-15) 0000D27A 00000808 0000191F AD000901
[  109.974365] PVR_K:   (MKT-16) 0000D2E4 00000808 00001A1E AD000183
[  109.980834] PVR_K:   (MKT-17) 0000D43A 00000808 00001A1E AD000302
[  109.987243] PVR_K:   (MKT-18) 0000D5C3 00000808 00001A1E AD000D06
[  109.993713] PVR_K:   (MKT-19) 0000D6AC 00000808 00001A1E AD000D07
[  110.000122] PVR_K:   (MKT-1A) 0000D6E9 00000808 00001A1E AD001306
[  110.006561] PVR_K:   (MKT-1B) 0000D72D 00000808 00001A1E AD001307
[  110.012969] PVR_K:   (MKT-1C) 0000D752 00000808 00001A1E AD001304
[  110.019439] PVR_K:   (MKT-1D) 0000D82F 00000808 00001A1E AD001305
[  110.025848] PVR_K:   (MKT-1E) 0000D93E 00000888 00001A1E AD000404
[  110.032287] PVR_K:   (MKT-1F) 0000DA02 00000808 00001A1E AD000402
[  110.038757] PVR_K:   (MKT-20) 0000DA4C 0010082B 00001A1E AD000184
[  110.045196] PVR_K:   (MKT-21) 0000DAF2 00119DA9 00001B1D AD000281
[  110.051605] PVR_K:   (MKT-22) 0000DC7C 001199AD 00001B1D AD000E02
[  110.058074] PVR_K:   (MKT-23) 0000DCDD 001009AF 00001B1D AD000282
[  110.064544] PVR_K:   (MKT-24) 00010317 00000808 00001D1F AD000101
[  110.070922] PVR_K:   (MKT-25) 0001038D 00000808 00001D1F AD000104
[  110.077392] PVR_K:   (MKT-26) 000103C9 00000808 01001E1E AD000100
[  110.083801] PVR_K:   (MKT-27) 000104CE 00000808 01001E1E AD000501
[  110.090270] PVR_K:   (MKT-28) 0001050D 0010082B 01001E1E AD000104
[  110.096679] PVR_K:   (MKT-29) 00012823 00100828 0100201F AD000101
[  110.103149] PVR_K:   (MKT-2A) 0001289D 00100828 0100201F AD000104
[  110.109558] PVR_K:   (MKT-2B) 00012952 00000808 0100211F AD000100
[  110.115997] PVR_K:   (MKT-2C) 00012A44 00000808 0100211F AD000501
[  110.122406] PVR_K:   (MKT-2D) 00012A83 00100829 0100211F AD000104
[  110.128875] PVR_K:   (MKT-2E) 00014FD0 00100828 0100221F AD000101
[  110.135284] PVR_K:   (MKT-2F) 00015016 00100828 0100221F AD000104
[  110.141723] PVR_K:   (MKT-30) 000150A9 00000808 0100231F AD000100
[  110.148132] PVR_K:   (MKT-31) 00015172 00000808 0100231F AD000501
[  110.154571] PVR_K:   (MKT-32) 0001519E 00100829 0100231F AD000104
[  110.160980] PVR_K:   (MKT-33) 079FC442 00100808 0100031F AD000B00
[  110.167449] PVR_K:   (MKT-34) 079FC47C 00100808 0100031F AD000B02
[  110.173889] PVR_K:   (MKT-35) 079FC4F0 00100808 0100031F AD000B02
[  110.180297] PVR_K:   (MKT-36) 079FC52E 00100808 0100031F AD000B02
[  110.186767] PVR_K:   (MKT-37) 079FC590 00100808 0100031F AD000B02
[  110.193176] PVR_K:   (MKT-38) 079FC5CD 00100808 0100031F AD000B02
[  110.199615] PVR_K:   (MKT-39) 079FC60A 00100808 0100031F AD000B02
[  110.206024] PVR_K:   (MKT-3A) 079FC647 00100808 0100031F AD000B02
[  110.212493] PVR_K:   (MKT-3B) 079FC686 00100808 0100031F AD000B02
[  110.218902] PVR_K:   (MKT-3C) 079FC6C4 00100808 0100031F AD000B02
[  110.225341] PVR_K:   (MKT-3D) 079FC703 00100808 0100031F AD000B02
[  110.231750] PVR_K:   (MKT-3E) 079FC742 00100808 0100031F AD000B03
[  110.238189] PVR_K:   (MKT-3F) 079FC7FA 00100808 0100031F AD000B05
[  110.244598] PVR_K:   (MKT-40) 079FC851 00100808 0100031F AD000B06
[  110.251068] PVR_K:   (MKT-41) 079FC880 00100808 0100031F AD000B06
[  110.257476] PVR_K:   (MKT-42) 079FC8C4 00100808 0100031F AD000B07
[  110.263916] PVR_K:   (MKT-43) 079FC8EA 00100808 0100031F AD000B09
[  110.270355] PVR_K:   (MKT-44) 079FC93F 00100808 0100031F AD000B01
[  110.276763] PVR_K:   (MKT-45) 079FC97D 00100808 0100031F AD002300
[  110.283203] PVR_K:   (MKT-46) 079FCE66 00100808 0100041F AD00000A
[  110.289642] PVR_K:   (MKT-47) 079FCEA9 00100808 0100041F AD001100
[  110.296112] PVR_K:   (MKT-48) 079FCF30 00100808 0100041F AD000906
[  110.302520] PVR_K:   (MKT-49) 079FCFE4 00100808 0000041F AD000901
[  110.308959] PVR_K:   (MKT-4A) 079FD061 00100808 0000051E AD000183
[  110.315368] PVR_K:   (MKT-4B) 079FD397 0010088F 0000051E AD002401
[  110.321807] PVR_K:   (MKT-4C) 079FD3DB 0016EC8F 0000051E AD000184
[  110.328216] PVR_K:   (MKT-4D) 079FD45B 0017FF8F 0000061D AD000281
[  110.334655] PVR_K:   (MKT-4E) 079FD5C5 0017FB8F 0000061D AD000E02
[  110.341064] PVR_K:   (MKT-4F) 079FD81D 0016E98F 0000061D AD00080A
[  110.347503] PVR_K:   (MKT-50) 079FD838 0017F98F 0000061D 0F05D300
[  110.353912] PVR_K:   (MKT-51) 079FD854 0017FB8F 0000061D 00000061
[  110.360382] PVR_K:   (MKT-52) 079FD921 0017FB8F 0000061D AD001300
[  110.366790] PVR_K:   (MKT-53) 07A02AA8 00100808 0000061D AD001301
[  110.373229] PVR_K:   (MKT-54) 07A02BA9 00100808 0000061D AD000802
[  110.379669] PVR_K:   (MKT-55) 07A02D08 00100808 0000061D AD000803
[  110.386047] PVR_K:   (MKT-56) 07A02D50 00184AC8 0000061D AD000282
[  110.392517] PVR_K:   (MKT-57) 07A02DFC 00184CF8 0000081E AD000101
[  110.398925] PVR_K:   (MKT-58) 07A02EF9 001808F8 0000081E AD001601
[  110.405364] PVR_K:   (MKT-59) 07A02F25 001808F8 0000081E 0D800784
[  110.411834] PVR_K:   (MKT-5A) 07A02F3D 001808F8 0000081E 00000002
[  110.418273] PVR_K:   (MKT-5B) 07A03311 001808FF 0000081E AD002401
[  110.424682] PVR_K:   (MKT-5C) 07A03375 001FFBFF 0000081E AD000104
[  110.431121] PVR_K:   (MKT-5D) 07A03589 001FFFFF 00000B1F AD000281
[  110.437530] PVR_K:   (MKT-5E) 07A035F0 001FFBFF 00000B1F AD000282
[  110.443969] PVR_K:   (MKT-5F) 07A03AB4 001808F8 01000D1F AD000101
[  110.450378] PVR_K:   (MKT-60) 07A03BA2 001808F8 01000D1F AD001601
[  110.456817] PVR_K:   (MKT-61) 07A03BC9 001808F8 01000D1F 0D800784
[  110.463226] PVR_K:   (MKT-62) 07A03BE1 001808F8 01000D1F 00000003
[  110.469696] PVR_K:   (MKT-63) 07A03F65 001808FE 00000D1F AD002401
[  110.476135] PVR_K:   (MKT-64) 07A03FD0 001FFBFE 00000D1F AD000104
[  110.482543] PVR_K:   (MKT-65) 07A04083 001FFFF8 00000E1E AD000281
[  110.488983] PVR_K:   (MKT-66) 07A040FF 001808F8 00000E1E AD000282
[  110.495422] PVR_K:   (MKT-67) 07A04183 001808F8 0100101F AD000101
[  110.501892] PVR_K:   (MKT-68) 07A0426D 001808F8 0100101F AD001601
[  110.508300] PVR_K:   (MKT-69) 07A04291 001808F8 0100101F 0D800844
[  110.514739] PVR_K:   (MKT-6A) 07A042AA 001808F8 0100101F 00000001
[  110.521118] PVR_K:   (MKT-6B) 07A04638 001808FE 0000101F AD002401
[  110.527557] PVR_K:   (MKT-6C) 07A0469D 001FFBFE 0000101F AD000104
[  110.533966] PVR_K:   (MKT-6D) 07A04776 00180DF8 0000111E AD000281
[  110.540435] PVR_K:   (MKT-6E) 07A047D4 001808F8 0000111E AD000282
[  110.546813] PVR_K:   (MKT-6F) 07A04859 001808F8 0100131F AD000101
[  110.553283] PVR_K:   (MKT-70) 07A0493F 001808F8 0100131F AD001601
[  110.559692] PVR_K:   (MKT-71) 07A04964 001808F8 0100131F 0D800864
[  110.566131] PVR_K:   (MKT-72) 07A0497D 001808F8 0100131F 00000001
[  110.572540] PVR_K:   (MKT-73) 07A04D03 001808FC 0000131F AD002401
[  110.579010] PVR_K:   (MKT-74) 07A04D70 00188CF8 0000131F AD000104
[  110.585449] PVR_K:   (MKT-75) 07A04DF0 00180C38 0000141E AD000281
[  110.591857] PVR_K:   (MKT-76) 07A04E46 00180838 0000141E AD000282
[  110.598297] PVR_K:   (MKT-77) 07A04ECE 00180838 0100161A AD000101
[  110.604736] PVR_K:   (MKT-78) 07A04FC7 00180838 0100161A AD001601
[  110.611175] PVR_K:   (MKT-79) 07A04FEC 00180838 0100161A 0D8008A4
[  110.617584] PVR_K:   (MKT-7A) 07A05004 00180838 0100161A 00000001
[  110.624053] PVR_K:   (MKT-7B) 07A05386 0010088C 0000161A AD002401
[  110.630432] PVR_K:   (MKT-7C) 07A053EE 0007FF8C 0000161A AD000104
[  110.636901] PVR_K:   (MKT-7D) 07A0547A 00000C08 0000171F AD000281
[  110.643310] PVR_K:   (MKT-7E) 07A054D0 00000808 0000171F AD000282
[  110.649749] PVR_K:   (MKT-7F) 07A0552D 00000808 0000191D AD000200
[  110.656158] PVR_K:   (MKT-80) 07A05780 00000808 0000191D AD000202
[  110.662597] PVR_K:   (MKT-81) 07A057E5 00000808 00001A1C AD000101
[  110.669006] PVR_K:   (MKT-82) 07A058D0 00000808 00001A1C AD001601
[  110.676025] PVR_K:   (MKT-83) 07A058F3 00000808 00001A1C 0D8008E4
[  110.682495] PVR_K:   (MKT-84) 07A0590B 00000808 00001A1C 00000001
[  110.688903] PVR_K:   (MKT-85) 07A05AEB 00000808 00001A1C AD000302
[  110.695373] PVR_K:   (MKT-86) 07A05B3D 00000808 00001A1C AD000303
[  110.701812] PVR_K:   (MKT-87) 07A05BBF 00000808 00001A1C AD000C01
[  110.708251] PVR_K:   (MKT-88) 07A05BE3 00000808 00001A1C 0D800484
[  110.714660] PVR_K:   (MKT-89) 07A05BFC 00000808 00001A1C 00000012
[  110.721099] PVR_K:   (MKT-8A) 07A05E3A 00000808 00001A1C AD00030E
[  110.727508] PVR_K:   (MKT-8B) 07A05E53 00000808 00001A1C 0D800474
[  110.733947] PVR_K:   (MKT-8C) 07A05E6B 00000808 00001A1C 00000012
[  110.740356] PVR_K:   (MKT-8D) 07A05E8F 00000808 00001A1C 00000013
[  110.746795] PVR_K:   (MKT-8E) 07A05F25 00000808 00001A1C AD000104
[  110.753234] PVR_K:   (MKT-8F) 07A05F81 00000808 00001B1F AD000183
[  110.759674] PVR_K:   (MKT-90) 07A06037 00000808 00001B1F AD00030E
[  110.766235] PVR_K:   (MKT-91) 07A06050 00000808 00001B1F 0D800474
[  110.772705] PVR_K:   (MKT-92) 07A06069 00000808 00001B1F 00000012
[  110.779083] PVR_K:   (MKT-93) 07A06082 00000808 00001B1F 00000013
[  110.785552] PVR_K:   (MKT-94) 07A060E1 00000808 00001B1F AD000184
[  110.791992] PVR_K:   (MKT-95) 07A06139 00000C08 01001C1E AD000281
[  110.798400] PVR_K:   (MKT-96) 07A06286 00000808 01001C1E AD000E0F
[  110.804840] PVR_K:   (MKT-97) 07A0629F 00000808 01001C1E 0D800494
[  110.811248] PVR_K:   (MKT-98) 07A062B7 00000808 01001C1E 00000011
[  110.817687] PVR_K:   (MKT-99) 07A062D0 00000808 01001C1E 00000012
[  110.824127] PVR_K:   (MKT-9A) 07A063D6 00000808 01001C1E AD00080A
[  110.830566] PVR_K:   (MKT-9B) 07A063EE 00000808 01001C1E 0F05D600
[  110.836975] PVR_K:   (MKT-9C) 07A06407 00000808 01001C1E 00000070
[  110.843414] PVR_K:   (MKT-9D) 07A066C1 00000808 00001C1E AD000803
[  110.849792] PVR_K:   (MKT-9E) 07A06705 00184EC8 00001C1E AD000282
[  110.856231] PVR_K:   (MKT-9F) 07A06AE9 00000808 01001E1F AD000200
[  110.862640] PVR_K:   (MKT-A0) 07A06D1C 00000808 00001E1F AD000202
[  110.869110] PVR_K:   (MKT-A1) 07A06D9B 00000808 00001F1E AD000183
[  110.875518] PVR_K:   (MKT-A2) 07A06E85 00000808 00001F1E AD00030E
[  110.881958] PVR_K:   (MKT-A3) 07A06E9D 00000808 00001F1E 0D800474
[  110.888397] PVR_K:   (MKT-A4) 07A06EB6 00000808 00001F1E 00000012
[  110.894805] PVR_K:   (MKT-A5) 07A06EDA 00000808 00001F1E 00000013
[  110.901275] PVR_K:   (MKT-A6) 07A06F44 00000808 00001F1E AD000184
[  110.907714] PVR_K:   (MKT-A7) 07A06FA8 00000C08 0100201D AD000281
[  110.914154] PVR_K:   (MKT-A8) 07A070FC 00000808 0100201D AD000E0F
[  110.920562] PVR_K:   (MKT-A9) 07A07115 00000808 0100201D 0D800494
[  110.927001] PVR_K:   (MKT-AA) 07A0712D 00000808 0100201D 00000011
[  110.933410] PVR_K:   (MKT-AB) 07A07146 00000808 0100201D 00000012
[  110.939880] PVR_K:   (MKT-AC) 07A0724A 00000808 0100201D AD00080A
[  110.946289] PVR_K:   (MKT-AD) 07A07262 00000808 0100201D 0F05D900
[  110.952728] PVR_K:   (MKT-AE) 07A0727A 00000808 0100201D 00000060
[  110.959136] PVR_K:   (MKT-AF) 07A0752A 00000808 0000201D AD000803
[  110.965576] PVR_K:   (MKT-B0) 07A07570 00184EC8 0000201D AD000282
[  110.971984] PVR_K:   (MKT-B1) 07A07F41 00000808 0100221F AD000200
[  110.978454] PVR_K:   (MKT-B2) 07A08167 00000808 0000221F AD000202
[  110.984863] PVR_K:   (MKT-B3) 07A081E8 00000808 0000231E AD000183
[  110.991943] PVR_K:   (MKT-B4) 07A082D1 00000808 0000231E AD00030E
[  110.998474] PVR_K:   (MKT-B5) 07A082E9 00000808 0000231E 0D800474
[  111.004974] PVR_K:   (MKT-B6) 07A08302 00000808 0000231E 00000012
[  111.011505] PVR_K:   (MKT-B7) 07A08325 00000808 0000231E 00000013
[  111.017974] PVR_K:   (MKT-B8) 07A08393 00000808 0000231E AD000184
[  111.024414] PVR_K:   (MKT-B9) 07A083F7 00000C08 0100241D AD000281
[  111.030822] PVR_K:   (MKT-BA) 07A0854A 00000808 0000241D AD000E0F
[  111.037261] PVR_K:   (MKT-BB) 07A08563 00000808 0000241D 0D800494
[  111.043762] PVR_K:   (MKT-BC) 07A0857B 00000808 0000241D 00000011
[  111.050384] PVR_K:   (MKT-BD) 07A08594 00000808 0000241D 00000012
[  111.056793] PVR_K:   (MKT-BE) 07A08699 00000808 0000241D AD00080A
[  111.063323] PVR_K:   (MKT-BF) 07A086B1 00000808 0000241D 0F05DC00
[  111.069824] PVR_K:   (MKT-C0) 07A086C9 00000808 0000241D 00000062
[  111.076324] PVR_K:   (MKT-C1) 07A0897A 00000808 0000241D AD000803
[  111.082794] PVR_K:   (MKT-C2) 07A089BF 00180C88 0000241D AD000282
[  111.089263] PVR_K:   (MKT-C3) 07A09528 00000C08 0100271F AD000200
[  111.095733] PVR_K:   (MKT-C4) 07A0964D 00000808 0100271F AD001703
[  111.102142] PVR_K:   (MKT-C5) 07A09862 00000808 0000271F AD000202
[  111.108612] PVR_K:   (MKT-C6) 07A098DF 00000808 0000281E AD000183
[  111.115020] PVR_K:   (MKT-C7) 07A099CC 00000808 0000281E AD00030E
[  111.121490] PVR_K:   (MKT-C8) 07A099E4 00000808 0000281E 0D800474
[  111.127899] PVR_K:   (MKT-C9) 07A099FD 00000808 0000281E 00000012
[  111.134338] PVR_K:   (MKT-CA) 07A09A20 00000808 0000281E 00000013
[  111.140747] PVR_K:   (MKT-CB) 07A09B13 00000808 0000281E AD000302
[  111.147186] PVR_K:   (MKT-CC) 07A09D46 00000808 0000281E AD000404
[  111.153594] PVR_K:   (MKT-CD) 07A09E07 00000808 0000281E AD000402
[  111.160064] PVR_K:   (MKT-CE) 07A09E43 0010082B 0000281E AD000184
[  111.166473] PVR_K:   (MKT-CF) 07A09EB7 00108DAB 0000291D AD000281
[  111.172912] PVR_K:   (MKT-D0) 07A0A081 001089AB 0000291D AD000E0F
[  111.179321] PVR_K:   (MKT-D1) 07A0A09F 001089AB 0000291D 0D800494
[  111.185760] PVR_K:   (MKT-D2) 07A0A0BE 0010082B 0000291D 00000011
[  111.192169] PVR_K:   (MKT-D3) 07A0A0D9 001089AB 0000291D 00000012
[  111.198608] PVR_K:   (MKT-D4) 07A0A14B 001089AB 0000291D AD000282
[  111.205078] PVR_K:   (MKT-D5) 07A0D458 00000808 00002B1F AD000101
[  111.211486] PVR_K:   (MKT-D6) 07A0D4CD 00000808 00002B1F AD000104
[  111.217956] PVR_K:   (MKT-D7) 07A0D509 00000808 01002C1E AD000100
[  111.224334] PVR_K:   (MKT-D8) 07A0D60A 00000808 01002C1E AD000501
[  111.230804] PVR_K:   (MKT-D9) 07A0D648 0010082B 01002C1E AD000104
[  111.237182] PVR_K:   (MKT-DA) 07A0F451 00000808 00002E1F AD000101
[  111.243652] PVR_K:   (MKT-DB) 07A0F4C5 00000808 00002E1F AD000104
[  111.250061] PVR_K:   (MKT-DC) 07A0F4FA 00000808 01002F1E AD000100
[  111.256500] PVR_K:   (MKT-DD) 07A0F5D7 00000808 01002F1E AD000501
[  111.262908] PVR_K:   (MKT-DE) 07A0F616 0010082B 01002F1E AD000104
[  111.269378] PVR_K:   (MKT-DF) 07A124E4 00100828 0100301F AD000101
[  111.275787] PVR_K:   (MKT-E0) 07A1253C 00100828 0100301F AD000104
[  111.282226] PVR_K:   (MKT-E1) 07A125CF 00000808 0100311F AD000100
[  111.288635] PVR_K:   (MKT-E2) 07A1269C 00000808 0100311F AD000501
[  111.295074] PVR_K:   (MKT-E3) 07A126D1 00100829 0100311F AD000104
[  111.301544] PVR_K:   (MKT-E4) 07A1433B 00100828 0100331F AD000101
[  111.307952] PVR_K:   (MKT-E5) 07A143B4 00000808 0000331F AD000104
[  111.314422] PVR_K:   (MKT-E6) 07A143F1 00000808 0100341E AD000100
[  111.320861] PVR_K:   (MKT-E7) 07A1447F 00000808 0100341E AD000502
[  111.327301] PVR_K:   (MKT-E8) 07A144D1 00000808 0100341E AD000C01
[  111.333709] PVR_K:   (MKT-E9) 07A144F4 00000808 0100341E 0D800824
[  111.340148] PVR_K:   (MKT-EA) 07A1450D 00000808 0100341E 00000001
[  111.346557] PVR_K:   (MKT-EB) 07A147CD 00000808 0000341E AD00030E
[  111.353027] PVR_K:   (MKT-EC) 07A147E6 00000808 0000341E 0D800474
[  111.359436] PVR_K:   (MKT-ED) 07A147FE 00000808 0000341E 00000012
[  111.365875] PVR_K:   (MKT-EE) 07A14822 00000808 0000341E 00000013
[  111.372283] PVR_K:   (MKT-EF) 07A148B8 00000808 0000341E AD000104
[  111.378723] PVR_K:   (MKT-F0) 07A1492B 00000C08 0100351F AD000281
[  111.385131] PVR_K:   (MKT-F1) 07A14AA1 00000808 0100351F AD00080A
[  111.391601] PVR_K:   (MKT-F2) 07A14ABA 00000808 0100351F 0F042300
[  111.398010] PVR_K:   (MKT-F3) 07A14AD2 00000808 0100351F 00000061
[  111.404449] PVR_K:   (MKT-F4) 07A14B58 00000808 0100351F AD001302
[  111.410919] PVR_K:   (MKT-F5) 07A14BA1 00000808 0100351F AD001303
[  111.417327] PVR_K:   (MKT-F6) 07A14C44 00000C88 0100351F AD001300
[  111.423767] PVR_K:   (MKT-F7) 07A19DD0 00000808 0000351F AD001301
[  111.430175] PVR_K:   (MKT-F8) 07A19EF7 00000808 0000351F AD000802
[  111.436645] PVR_K:   (MKT-F9) 07A1A060 00000808 0000351F AD000803
[  111.443023] PVR_K:   (MKT-FA) 07A1A0AC 00184AC8 0000351F AD000282
[  111.449462] PVR_K:   (MKT-FB) 07A1C04E 00000C08 0100391F AD000200
[  111.455871] PVR_K:   (MKT-FC) 07A1C2A2 00000808 0000391F AD000202
[  111.462341] PVR_K:   (MKT-FD) 07A1C33C 00000808 00003A1E AD000183
[  111.468749] PVR_K:   (MKT-FE) 07A1C43E 00000808 00003A1E AD00030E
[  111.475189] PVR_K:   (MKT-FF) 07A1C456 00000808 00003A1E 0D800474
[  111.481597] PVR_K:   (MKT-100) 07A1C46F 00000808 00003A1E 00000012
[  111.488128] PVR_K:   (MKT-101) 07A1C493 00000808 00003A1E 00000013
[  111.494628] PVR_K:   (MKT-102) 07A1C4FF 00000808 00003A1E AD000184
[  111.501190] PVR_K:   (MKT-103) 07A1C56D 00000C08 01003B1D AD000281
[  111.507751] PVR_K:   (MKT-104) 07A1C6DB 00000808 01003B1D AD00080A
[  111.514221] PVR_K:   (MKT-105) 07A1C6F4 00000808 01003B1D 0F042600
[  111.520812] PVR_K:   (MKT-106) 07A1C70C 00000808 01003B1D 00000060
[  111.527313] PVR_K:   (MKT-107) 07A1C9BC 00000808 00003B1D AD000803
[  111.533843] PVR_K:   (MKT-108) 07A1CA01 00180CC8 00003B1D AD000282
[  111.540344] PVR_K:   (MKT-109) 07A1CAA1 00000808 01003D1F AD000200
[  111.546905] PVR_K:   (MKT-10A) 07A1CCBB 00000808 00003D1F AD000202
[  111.553375] PVR_K:   (MKT-10B) 07A1CD3B 00000808 00003E1E AD000183
[  111.559906] PVR_K:   (MKT-10C) 07A1CE26 00000808 00003E1E AD00030E
[  111.566436] PVR_K:   (MKT-10D) 07A1CE3E 00000808 00003E1E 0D800474
[  111.572967] PVR_K:   (MKT-10E) 07A1CE57 00000808 00003E1E 00000012
[  111.579467] PVR_K:   (MKT-10F) 07A1CE7B 00000808 00003E1E 00000013
[  111.586029] PVR_K:   (MKT-110) 07A1CEE6 00000808 00003E1E AD000184
[  111.592559] PVR_K:   (MKT-111) 07A1CF4A 00000C08 01003F1D AD000281
[  111.599060] PVR_K:   (MKT-112) 07A1D0B7 00000808 01003F1D AD00080A
[  111.605590] PVR_K:   (MKT-113) 07A1D0CF 00000808 01003F1D 0F042900
[  111.612121] PVR_K:   (MKT-114) 07A1D0E7 00000808 01003F1D 00000060
[  111.618682] PVR_K:   (MKT-115) 07A1D397 00000808 00003F1D AD000803
[  111.625152] PVR_K:   (MKT-116) 07A1D3DD 00180CC8 00003F1D AD000282
[  111.631713] PVR_K:   (MKT-117) 07A1D4C1 00000808 0100411F AD000200
[  111.638214] PVR_K:   (MKT-118) 07A1D6DF 00000808 0000411F AD000202
[  111.644744] PVR_K:   (MKT-119) 07A1D762 00000808 0000421E AD000183
[  111.651245] PVR_K:   (MKT-11A) 07A1D852 00000808 0000421E AD00030E
[  111.657775] PVR_K:   (MKT-11B) 07A1D86A 00000808 0000421E 0D800474
[  111.664276] PVR_K:   (MKT-11C) 07A1D883 00000808 0000421E 00000012
[  111.670837] PVR_K:   (MKT-11D) 07A1D8A6 00000808 0000421E 00000013
[  111.677368] PVR_K:   (MKT-11E) 07A1D910 00000808 0000421E AD000184
[  111.683868] PVR_K:   (MKT-11F) 07A1D975 00000C08 0100431D AD000281
[  111.690399] PVR_K:   (MKT-120) 07A1DADE 00000808 0100431D AD00080A
[  111.696899] PVR_K:   (MKT-121) 07A1DAF6 00000808 0100431D 0F042C00
[  111.703460] PVR_K:   (MKT-122) 07A1DB0F 00000808 0100431D 00000062
[  111.709960] PVR_K:   (MKT-123) 07A1DDC1 00000808 0000431D AD000803
[  111.716522] PVR_K:   (MKT-124) 07A1DE06 00180C88 0000431D AD000282
[  111.723022] PVR_K:   (MKT-125) 07A1E90D 00000808 0100451F AD000200
[  111.729583] PVR_K:   (MKT-126) 07A1EA2C 00000808 0100451F AD001703
[  111.736053] PVR_K:   (MKT-127) 07A1EBFE 00000808 0000451F AD000202
[  111.742614] PVR_K:   (MKT-128) 07A1EC7A 00000808 0100461E AD000183
[  111.749114] PVR_K:   (MKT-129) 07A1ED69 00000808 0100461E AD00030E
[  111.755584] PVR_K:   (MKT-12A) 07A1ED82 00000808 0100461E 0D800474
[  111.762145] PVR_K:   (MKT-12B) 07A1ED9A 00000808 0100461E 00000012
[  111.768615] PVR_K:   (MKT-12C) 07A1EDBE 00000808 0100461E 00000013
[  111.775177] PVR_K:   (MKT-12D) 07A1EE4B 00000808 0100461E AD000184
[  111.781677] PVR_K:   (MKT-12E) 07A2B7AB 00000808 0100491F AD001A00
[  111.788208] PVR_K:   (MKT-12F) 07A2E2A1 00000808 01004A1F AD00000A
[  111.794708] PVR_K:   (MKT-130) 07A2E306 00000808 01004A1F AD000905
[  111.801239] PVR_K:   (MKT-131) 07A2E42E 00000808 00004A1F AD000901
[  111.807739] PVR_K:   (MKT-132) 07A2E498 00000808 00004B1E AD000183
[  111.814300] PVR_K:   (MKT-133) 07A2E58D 00000808 00004B1E AD00030E
[  111.820800] PVR_K:   (MKT-134) 07A2E5A5 00000808 00004B1E 0D800474
[  111.827362] PVR_K:   (MKT-135) 07A2E5BE 00000808 00004B1E 00000012
[  111.833892] PVR_K:   (MKT-136) 07A2E5E2 00000808 00004B1E 00000013
[  111.840393] PVR_K:   (MKT-137) 07A2E64F 00000808 00004B1E AD000184
[  111.846923] PVR_K:   (MKT-138) 07A2E6B6 00000C08 01004C1D AD000281
[  111.853424] PVR_K:   (MKT-139) 07A2E7D5 00000808 01004C1D AD000E02
[  111.859985] PVR_K:   (MKT-13A) 07A2E84B 00000808 01004C1D AD000282
[  111.866485] PVR_K:   (MKT-13B) 07A2EB05 00000808 01004D1F AD00000A
[  111.873016] PVR_K:   (MKT-13C) 07A2EB70 00000808 01004D1F AD000905
[  111.879516] PVR_K:   (MKT-13D) 07A2EC7C 00000808 00004D1F AD000901
[  111.886047] PVR_K:   (MKT-13E) 07A2ECE6 00000808 00004E1E AD000183
[  111.892547] PVR_K:   (MKT-13F) 07A2EDD5 00000808 00004E1E AD00030E
[  111.899108] PVR_K:   (MKT-140) 07A2EDEE 00000808 00004E1E 0D800474
[  111.905609] PVR_K:   (MKT-141) 07A2EE07 00000808 00004E1E 00000012
[  111.912139] PVR_K:   (MKT-142) 07A2EE2A 00000808 00004E1E 00000013
[  111.918701] PVR_K:   (MKT-143) 07A2EE97 00000808 00004E1E AD000184
[  111.925231] PVR_K:   (MKT-144) 07A2EEFD 00000C08 01004F1D AD000281
[  111.931762] PVR_K:   (MKT-145) 07A2EFFA 00000808 00004F1D AD000E02
[  111.938262] PVR_K:   (MKT-146) 07A2F06E 00000808 00004F1D AD000282
[  111.944824] PVR_K:   (MKT-147) 07A2F120 00000808 0100501F AD00000A
[  111.951293] PVR_K:   (MKT-148) 07A2F18E 00000808 0100501F AD000905
[  111.957855] PVR_K:   (MKT-149) 07A2F2A0 00000808 0000501F AD000901
[  111.964355] PVR_K:   (MKT-14A) 07A2F30D 00000808 0000511E AD000183
[  111.970886] PVR_K:   (MKT-14B) 07A2F3FC 00000808 0000511E AD00030E
[  111.977386] PVR_K:   (MKT-14C) 07A2F415 00000808 0000511E 0D800474
[  111.983917] PVR_K:   (MKT-14D) 07A2F42D 00000808 0000511E 00000012
[  111.990417] PVR_K:   (MKT-14E) 07A2F451 00000808 0000511E 00000013
[  111.996978] PVR_K:   (MKT-14F) 07A2F4BE 00000808 0000511E AD000184
[  112.003509] PVR_K:   (MKT-150) 07A2F525 00000C08 0000521D AD000281
[  112.010009] PVR_K:   (MKT-151) 07A2F624 00000808 0000521D AD000E02
[  112.016571] PVR_K:   (MKT-152) 07A2F696 00000808 0000521D AD000282
[  112.023071] PVR_K:   (MKT-153) 07A2F74D 00000808 0100531F AD00000A
[  112.029602] PVR_K:   (MKT-154) 07A2F7B7 00000808 0100531F AD000905
[  112.036102] PVR_K:   (MKT-155) 07A2F8C9 00000808 0000531F AD000901
[  112.042633] PVR_K:   (MKT-156) 07A2F93B 00000808 0000541E AD000183
[  112.049133] PVR_K:   (MKT-157) 07A2FA31 00000808 0000541E AD00030E
[  112.055664] PVR_K:   (MKT-158) 07A2FA4D 00000808 0000541E 0D800474
[  112.062164] PVR_K:   (MKT-159) 07A2FA66 00000808 0000541E 00000012
[  112.068725] PVR_K:   (MKT-15A) 07A2FA8A 00000808 0000541E 00000013
[  112.075225] PVR_K:   (MKT-15B) 07A2FAF6 00000808 0000541E AD000184
[  112.081756] PVR_K:   (MKT-15C) 07A2FB60 00000C08 0100551D AD000281
[  112.088317] PVR_K:   (MKT-15D) 07A2FC65 00000808 0100551D AD000E02
[  112.094787] PVR_K:   (MKT-15E) 07A2FCD8 00000808 0100551D AD000282
[  112.101348] PVR_K:   (MKT-15F) 07A3203A 00000808 0100571F AD00000A
[  112.107849] PVR_K:   (MKT-160) 07A320A4 00000808 0100571F AD000906
[  112.114379] PVR_K:   (MKT-161) 07A3215F 00000808 0000571F AD000901
[  112.120880] PVR_K:   (MKT-162) 07A321CD 00000808 0000581E AD000183
[  112.127471] PVR_K:   (MKT-163) 07A32325 00000808 0000581E AD000302
[  112.133972] PVR_K:   (MKT-164) 07A3237A 00000808 0000581E AD000303
[  112.140502] PVR_K:   (MKT-165) 07A32400 00000808 0000581E AD000C01
[  112.147003] PVR_K:   (MKT-166) 07A32426 00000808 0000581E 0D800464
[  112.153533] PVR_K:   (MKT-167) 07A3243F 00000808 0000581E 00000013
[  112.160034] PVR_K:   (MKT-168) 07A32693 00000808 0000581E AD00030E
[  112.166595] PVR_K:   (MKT-169) 07A326AB 00000808 0000581E 0D800494
[  112.173126] PVR_K:   (MKT-16A) 07A326C3 00000808 0000581E 00000011
[  112.179626] PVR_K:   (MKT-16B) 07A326E8 00000808 0000581E 00000012
[  112.186157] PVR_K:   (MKT-16C) 07A32761 00000808 0000581E AD000184
[  112.192657] PVR_K:   (MKT-16D) 07A327CA 00000C08 0100591D AD000281
[  112.199218] PVR_K:   (MKT-16E) 07A32930 00000808 0100591D AD00080A
[  112.205718] PVR_K:   (MKT-16F) 07A32949 00000808 0100591D 0F042F00
[  112.212249] PVR_K:   (MKT-170) 07A32961 00000808 0100591D 00000061
[  112.218780] PVR_K:   (MKT-171) 07A32AEB 00000808 0000591D AD000802
[  112.225311] PVR_K:   (MKT-172) 07A32C45 00000808 0000591D AD000803
[  112.231811] PVR_K:   (MKT-173) 07A32C8B 00184EC8 0000591D AD000282
[  112.238372] PVR_K:   (MKT-174) 07A341AA 00180838 01005B1F AD00000A
[  112.244873] PVR_K:   (MKT-175) 07A34216 00180838 01005B1F AD000905
[  112.251403] PVR_K:   (MKT-176) 07A34313 00180838 00005B1F AD000901
[  112.257965] PVR_K:   (MKT-177) 07A34384 00180838 00005C1E AD000183
[  112.264434] PVR_K:   (MKT-178) 07A3447A 00180838 00005C1E AD00030E
[  112.270996] PVR_K:   (MKT-179) 07A34495 00180838 00005C1E 0D800494
[  112.277465] PVR_K:   (MKT-17A) 07A344AD 00180838 00005C1E 00000011
[  112.284027] PVR_K:   (MKT-17B) 07A344D1 00180838 00005C1E 00000012
[  112.290527] PVR_K:   (MKT-17C) 07A34540 00180838 00005C1E AD000184
[  112.297058] PVR_K:   (MKT-17D) 07A345AC 00180C38 00005D1D AD000281
[  112.303558] PVR_K:   (MKT-17E) 07A34606 00180838 00005D1D AD000282
[  112.310089] PVR_K:   (MKT-17F) 07A346C4 00180838 01005E1F AD00000A
[  112.316589] PVR_K:   (MKT-180) 07A3472F 00180838 01005E1F AD000905
[  112.323150] PVR_K:   (MKT-181) 07A3482C 00180838 00005E1F AD000901
[  112.329650] PVR_K:   (MKT-182) 07A3489D 00180838 00005F1E AD00000A
[  112.336212] PVR_K:   (MKT-183) 07A34901 00180838 00005F1E AD000905
[  112.342742] PVR_K:   (MKT-184) 07A349A8 00180838 00005F1E AD000901
[  112.349243] PVR_K:   (MKT-185) 07A34A12 00180838 0000601D AD000183
[  112.355804] PVR_K:   (MKT-186) 07A34B08 00180838 0000601D AD00030E
[  112.362304] PVR_K:   (MKT-187) 07A34B21 00180838 0000601D 0D800494
[  112.368835] PVR_K:   (MKT-188) 07A34B3C 00180838 0000601D 00000011
[  112.375335] PVR_K:   (MKT-189) 07A34B63 00180838 0000601D 00000012
[  112.381896] PVR_K:   (MKT-18A) 07A34BD1 00180838 0000601D AD000184
[  112.388366] PVR_K:   (MKT-18B) 07A34C3C 00100C28 0000611C AD000281
[  112.394927] PVR_K:   (MKT-18C) 07A34C97 00100828 0000611C AD000282
[  112.401428] PVR_K:   (MKT-18D) 07A34D51 00000808 0000621F AD00000A
[  112.407958] PVR_K:   (MKT-18E) 07A34DBE 00000808 0000621F AD000905
[  112.414459] PVR_K:   (MKT-18F) 07A34EB6 00000808 0000621F AD000901
[  112.421020] PVR_K:   (MKT-190) 07A34EED 00000C08 0000631E AD000200
[  112.427551] PVR_K:   (MKT-191) 07A35134 00000808 0000631E AD000202
[  112.434051] PVR_K:   (MKT-192) 07A351BE 00000808 0000641D AD000183
[  112.440582] PVR_K:   (MKT-193) 07A352AA 00000808 0000641D AD00030E
[  112.447082] PVR_K:   (MKT-194) 07A352C2 00000808 0000641D 0D800494
[  112.453613] PVR_K:   (MKT-195) 07A352DC 00000808 0000641D 00000011
[  112.460113] PVR_K:   (MKT-196) 07A352FF 00000808 0000641D 00000012
[  112.466644] PVR_K:   (MKT-197) 07A3536B 00000808 0000641D AD000184
[  112.473144] PVR_K:   (MKT-198) 07A353D1 00000C08 0100651C AD000281
[  112.479705] PVR_K:   (MKT-199) 07A35542 00000808 0100651C AD00080A
[  112.486206] PVR_K:   (MKT-19A) 07A3555B 00000808 0100651C 0F043200
[  112.492736] PVR_K:   (MKT-19B) 07A35573 00000808 0100651C 00000060
[  112.499237] PVR_K:   (MKT-19C) 07A35834 00000808 0000651C AD000803
[  112.505767] PVR_K:   (MKT-19D) 07A35881 00188CC8 0000651C AD000282
[  112.512298] PVR_K:   (MKT-19E) 07A3592F 00000808 0100671F AD000200
[  112.518798] PVR_K:   (MKT-19F) 07A35B54 00000808 0000671F AD000202
[  112.525360] PVR_K:   (MKT-1A0) 07A35BE0 00000808 0000681E AD000183
[  112.531860] PVR_K:   (MKT-1A1) 07A35CCF 00000808 0000681E AD00030E
[  112.538421] PVR_K:   (MKT-1A2) 07A35CE9 00000808 0000681E 0D800494
[  112.544891] PVR_K:   (MKT-1A3) 07A35D02 00000808 0000681E 00000011
[  112.551452] PVR_K:   (MKT-1A4) 07A35D27 00000808 0000681E 00000012
[  112.557952] PVR_K:   (MKT-1A5) 07A35D94 00000808 0000681E AD000184
[  112.564514] PVR_K:   (MKT-1A6) 07A35DFC 00000C08 0100691D AD000281
[  112.571014] PVR_K:   (MKT-1A7) 07A35F77 00000808 0100691D AD00080A
[  112.577545] PVR_K:   (MKT-1A8) 07A35F8F 00000808 0100691D 0F043500
[  112.584014] PVR_K:   (MKT-1A9) 07A35FA8 00000808 0100691D 00000060
[  112.590515] PVR_K:   (MKT-1AA) 07A36266 00000808 0000691D AD000803
[  112.597076] PVR_K:   (MKT-1AB) 07A362B0 00180CC8 0000691D AD000282
[  112.603576] PVR_K:   (MKT-1AC) 07A3639A 00000808 01006B1F AD000200
[  112.610107] PVR_K:   (MKT-1AD) 07A365BC 00000808 00006B1F AD000202
[  112.616607] PVR_K:   (MKT-1AE) 07A36640 00000808 00006C1E AD000183
[  112.623138] PVR_K:   (MKT-1AF) 07A36730 00000808 00006C1E AD00030E
[  112.629669] PVR_K:   (MKT-1B0) 07A36748 00000808 00006C1E 0D800494
[  112.636199] PVR_K:   (MKT-1B1) 07A36763 00000808 00006C1E 00000011
[  112.642730] PVR_K:   (MKT-1B2) 07A36787 00000808 00006C1E 00000012
[  112.649261] PVR_K:   (MKT-1B3) 07A367F1 00000808 00006C1E AD000184
[  112.655731] PVR_K:   (MKT-1B4) 07A36859 00000C08 01006D1D AD000281
[  112.662292] PVR_K:   (MKT-1B5) 07A369C3 00000808 01006D1D AD00080A
[  112.668823] PVR_K:   (MKT-1B6) 07A369DC 00000808 01006D1D 0F043800
[  112.675292] PVR_K:   (MKT-1B7) 07A369F4 00000808 01006D1D 00000062
[  112.681854] PVR_K:   (MKT-1B8) 07A36CB3 00000808 00006D1D AD000803
[  112.688354] PVR_K:   (MKT-1B9) 07A36CFC 00180C88 00006D1D AD000282
[  112.694885] PVR_K:   (MKT-1BA) 07A3785F 00000C08 0100701F AD000200
[  112.701385] PVR_K:   (MKT-1BB) 07A3798B 00000808 0100701F AD001703
[  112.707916] PVR_K:   (MKT-1BC) 07A37BA5 00000808 0000701F AD000202
[  112.714416] PVR_K:   (MKT-1BD) 07A37C25 00000808 0000711E AD000183
[  112.720947] PVR_K:   (MKT-1BE) 07A37D11 00000808 0000711E AD00030E
[  112.727478] PVR_K:   (MKT-1BF) 07A37D2E 00000808 0000711E 0D800494
[  112.734039] PVR_K:   (MKT-1C0) 07A37D46 00000808 0000711E 00000011
[  112.740539] PVR_K:   (MKT-1C1) 07A37D71 00000808 0000711E 00000012
[  112.747070] PVR_K:   (MKT-1C2) 07A37DDE 00000808 0000711E AD000184
[  112.753631] PVR_K:   (MKT-1C3) 07A37E48 00000C08 0100721D AD000281
[  112.760131] PVR_K:   (MKT-1C4) 07A37F62 00000808 0100721D AD000E02
[  112.766662] PVR_K:   (MKT-1C5) 07A37FD6 00000808 0100721D AD000282
[  112.773162] PVR_K:   (MKT-1C6) 07A48C6C 00000808 0100751F AD001A00
[  112.779724] PVR_K:   (MKT-1C7) 07A49093 00000808 0100761F AD00000A
[  112.786224] PVR_K:   (MKT-1C8) 07A490F4 00000808 0100761F AD000909
[  112.792755] PVR_K:   (MKT-1C9) 07A49143 00000808 0100761F AD001A05
[  112.799255] PVR_K:   (MKT-1CA) 07A49174 00000808 0100761F AD001302
[  112.805786] PVR_K:   (MKT-1CB) 07A491B5 00000808 0100761F AD001303
[  112.812286] PVR_K:   (MKT-1CC) 07A4924F 00000808 0100761F AD000D04
[  112.818817] PVR_K:   (MKT-1CD) 07A49320 00000808 0100761F AD000D05
[  112.825317] PVR_K:   (MKT-1CE) 07A4937A 00000808 0100761F AD000D04
[  112.831878] PVR_K:   (MKT-1CF) 07A493FF 00000808 0100761F AD000D05
[  112.838439] PVR_K:   (MKT-1D0) 07A4945B 00000808 0100761F AD001A06
[  112.844940] PVR_K:   (MKT-1D1) 00000480 00100808 0100031F AD002300
[  112.851470] PVR_K:   (MKT-1D2) 00000991 00100808 0100041F AD00000A
[  112.857971] PVR_K:   (MKT-1D3) 00000A03 00100808 0100041F AD000905
[  112.864501] PVR_K:   (MKT-1D4) 00000B3F 00100808 0000041F AD000901
[  112.871002] PVR_K:   (MKT-1D5) 00000BB8 00100808 0000051E AD000183
[  112.877532] PVR_K:   (MKT-1D6) 00000CCA 00100808 0000051E AD00030E
[  112.884033] PVR_K:   (MKT-1D7) 00000CE4 00100808 0000051E 0D800494
[  112.890594] PVR_K:   (MKT-1D8) 00000D00 00100808 0000051E 00000011
[  112.897094] PVR_K:   (MKT-1D9) 00000D24 00100808 0000051E 00000012
[  112.903625] PVR_K:   (MKT-1DA) 00000D90 00100808 0000051E AD000184
[  112.910125] PVR_K:   (MKT-1DB) 00000E12 00100C08 0100061D AD000281
[  112.916656] PVR_K:   (MKT-1DC) 00001014 00100808 0100061D AD000E0E
[  112.923217] PVR_K:   (MKT-1DD) 0000102D 00100808 0100061D 0D800464
[  112.929718] PVR_K:   (MKT-1DE) 00001045 00100808 0100061D 00000013
[  112.936279] PVR_K:   (MKT-1DF) 0000105F 00100808 0100061D 00000014
[  112.942779] PVR_K:   (MKT-1E0) 00001100 00100808 0100061D AD000E02
[  112.949340] PVR_K:   (MKT-1E1) 00001176 00100808 0100061D AD000282
[  112.955841] PVR_K:   (MKT-1E2) 00011DC9 00100808 0100091F AD001A00
[  112.962371] PVR_K:   (MKT-1E3) 00012079 00100808 01000A1F AD00000A
[  112.968872] PVR_K:   (MKT-1E4) 000120DB 00100808 01000A1F AD000909
[  112.975402] PVR_K:   (MKT-1E5) 00012126 00100808 01000A1F AD001A05
[  112.981903] PVR_K:   (MKT-1E6) 000121D5 00100808 01000A1F AD001A06
[  112.988464] PVR_K:   (MKT-1E7) 00000458 00100808 0100031F AD002300
[  112.994964] PVR_K:   (MKT-1E8) 0000092C 00100808 0100041F AD00000A
[  113.001495] PVR_K:   (MKT-1E9) 000009AB 00100808 0100041F AD000906
[  113.008026] PVR_K:   (MKT-1EA) 00000A73 00100808 0000041F AD000901
[  113.014556] PVR_K:   (MKT-1EB) 00000AEF 00100808 0000051E AD000183
[  113.021087] PVR_K:   (MKT-1EC) 00000C65 00100808 0000051E AD000302
[  113.027618] PVR_K:   (MKT-1ED) 00000DF1 00100808 0000051E AD000D06
[  113.034179] PVR_K:   (MKT-1EE) 00000EDD 00100808 0000051E AD000D07
[  113.040679] PVR_K:   (MKT-1EF) 00000F29 00100808 0000051E AD001304
[  113.047210] PVR_K:   (MKT-1F0) 00001016 00100808 0000051E AD001305
[  113.053710] PVR_K:   (MKT-1F1) 0000112D 00100888 0000051E AD000404
[  113.060241] PVR_K:   (MKT-1F2) 000011F2 00100808 0000051E AD000402
[  113.066741] PVR_K:   (MKT-1F3) 0000123A 0010082B 0000051E AD000184
[  113.073272] PVR_K:   (MKT-1F4) 000012C5 00100D2B 0000061D AD000281
[  113.079803] PVR_K:   (MKT-1F5) 00001545 00108DAD 0000061D AD000E0E
[  113.086334] PVR_K:   (MKT-1F6) 00001563 001199AB 0000061D 0D800464
[  113.092895] PVR_K:   (MKT-1F7) 00001580 001089AB 0000061D 00000013
[  113.099365] PVR_K:   (MKT-1F8) 0000159B 001199AD 0000061D 00000014
[  113.105926] PVR_K:   (MKT-1F9) 00001657 001089AF 0000061D AD000E02
[  113.112426] PVR_K:   (MKT-1FA) 000016BD 001089AB 0000061D AD000282
[  113.118988] PVR_K:   (MKT-1FB) 00003ABF 00100808 0000081F AD000101
[  113.125457] PVR_K:   (MKT-1FC) 00003B35 00100808 0000081F AD000104
[  113.132019] PVR_K:   (MKT-1FD) 00003B72 00100808 0100091E AD000100
[  113.138549] PVR_K:   (MKT-1FE) 00003C79 00100808 0100091E AD000501
[  113.145080] PVR_K:   (MKT-1FF) 00003CBB 0010082B 0100091E AD000104
[  113.151580] PVR_K: SGX Kernel CCB WO:0x3 RO:0x3
[  113.157836] adc_to_temp_conversion:Temp read is invalid 0
[  113.163696] thermal_lookup_temp: getting temp is not supported for domain pcb
[  113.172180] adc_to_temp_conversion:Temp read is invalid 0
[  113.177917] thermal_lookup_temp: getting temp is not supported for domain pcb
[  113.201049] adc_to_temp_conversion:Temp read is invalid 0
[  113.219360] thermal_lookup_temp: getting temp is not supported for domain pcb
[  113.373962] PVR_K:(Error): SGXOSTimer() detected SGX lockup (0x12 tasks) [0, ]
[  113.394439] PVR_K: HWRecoveryResetSGX: SGX Hardware Recovery triggered
[  113.402221] [  102.822]  [c602d0c0] --refs=1 on RELEASED
[  113.402221] [  102.822]                        [c6f10400] dsscomp_apply
[  113.402221] [  102.823]    [c6edb880] --refs=0 on RELEASED
[  113.402221] [  102.823]    [c6edb880] calling dsscomp_proxy_cmdcomplete [c73f6480]
[  113.402221] [  102.823]                          [c6f10800] dsscomp_mgr_delayed_cb on RELEASED
[  113.444274] [  102.823]                        [c6f10400] dsscomp_mgr_delayed_cb on PROGRAMMED
[  113.444274] [  102.823]     [c602d420] new in dsscomp_gralloc_queue (refs=1)
[  113.444305] [  102.823]                          [c6f10800] dsscomp_new
[  113.492004] [  102.823]     [c602d420] ++refs=2 for [c6f10800]
[  113.492004] [  102.823]                          [c6f10800] dsscomp_delayed_apply
[  113.492004] [  102.823]     [c602d420] --refs=1 on RELEASED
[  113.492034] [  102.823]                          [c6f10800] dsscomp_apply
[  113.492034] [  102.839]                        [c6f10400] dsscomp_mgr_delayed_cb on DISPLAYED
[  113.590576] [  102.839]  [c602d0c0] --refs=0 on RELEASED
[  113.590576] [  102.839]  [c602d0c0] calling dsscomp_proxy_cmdcomplete [c73f6900]
[  113.590576] [  102.839]                        [c6f10400] dsscomp_mgr_delayed_cb on RELEASED
[  113.590576] [  102.839]                          [c6f10800] dsscomp_mgr_delayed_cb on PROGRAMMED
[  113.631713] [  102.856]                          [c6f10800] dsscomp_mgr_delayed_cb on DISPLAYED
[  113.631713] [  108.175]  [c6296080] new in dsscomp_gralloc_queue (refs=1)
[  113.631866] PVR_K: User requested SGX debug info
[  113.632354] [  102.822]  [c602d0c0] --refs=1 on RELEASED
[  113.632354] [  102.822]                        [c6f10400] dsscomp_apply
[  113.632354] [  102.823]    [c6edb880] --refs=0 on RELEASED
[  113.632354] [  102.823]    [c6edb880] calling dsscomp_proxy_cmdcomplete [c73f6480]
[  113.632354] [  102.823]                          [c6f10800] dsscomp_mgr_delayed_cb on RELEASED
[  113.632354] [  102.823]                        [c6f10400] dsscomp_mgr_delayed_cb on PROGRAMMED
[  113.632385] [  102.823]     [c602d420] new in dsscomp_gralloc_queue (refs=1)
[  113.632385] [  102.823]                          [c6f10800] dsscomp_new
[  113.632385] [  102.823]     [c602d420] ++refs=2 for [c6f10800]
[  113.632385] [  102.823]                          [c6f10800] dsscomp_delayed_apply
[  113.632385] [  102.823]     [c602d420] --refs=1 on RELEASED
[  113.632385] [  102.823]                          [c6f10800] dsscomp_apply
[  113.632385] [  102.839]                        [c6f10400] dsscomp_mgr_delayed_cb on DISPLAYED
[  113.632415] [  102.839]  [c602d0c0] --refs=0 on RELEASED
[  113.632415] [  102.839]  [c602d0c0] calling dsscomp_proxy_cmdcomplete [c73f6900]
[  113.632415] [  102.839]                        [c6f10400] dsscomp_mgr_delayed_cb on RELEASED
[  113.632415] [  102.839]                          [c6f10800] dsscomp_mgr_delayed_cb on PROGRAMMED
[  113.632415] [  102.856]                          [c6f10800] dsscomp_mgr_delayed_cb on DISPLAYED
[  113.632415] [  108.175]  [c6296080] new in dsscomp_gralloc_queue (refs=1)
[  113.632446] [  108.175]                           [c61c4000] dsscomp_new
[  113.632446] [  108.175]  [c6296080] ++refs=2 for [c61c4000]
[  113.632446] [  108.175]                           [c61c4000] dsscomp_delayed_apply
[  113.632446] [  108.175]  [c6296080] --refs=1 on RELEASED
[  113.632446] [  108.175]                           [c61c4000] dsscomp_apply
[  113.632446] [  108.176]     [c602d420] --refs=0 on RELEASED
[  113.632446] [  108.176]     [c602d420] calling dsscomp_proxy_cmdcomplete [c73f6480]
[  113.632446] [  108.176]                          [c6f10800] dsscomp_mgr_delayed_cb on RELEASED
[  113.632476] [  108.176]                           [c61c4000] dsscomp_mgr_delayed_cb on PROGRAMMED
[  113.632476] [  108.176]    [c61b2660] new in dsscomp_gralloc_queue (refs=1)
[  113.632476] [  108.176]                     [c71efc00] dsscomp_new
[  113.632476] [  108.176]    [c61b2660] ++refs=2 for [c71efc00]
[  113.632476] [  108.176]                     [c71efc00] dsscomp_delayed_apply
[  113.632476] [  108.176]    [c61b2660] --refs=1 on RELEASED
[  113.632507] [  108.176]                     [c71efc00] dsscomp_apply
[  113.632507] [  108.197]                           [c61c4000] dsscomp_mgr_delayed_cb on DISPLAYED
[  113.632507] [  108.197]  [c6296080] --refs=0 on RELEASED
[  113.632507] [  108.197]  [c6296080] calling dsscomp_proxy_cmdcomplete [c73f6900]
[  113.632507] [  108.197]                           [c61c4000] dsscomp_mgr_delayed_cb on RELEASED
[  113.632507] [  108.197]                     [c71efc00] dsscomp_mgr_delayed_cb on PROGRAMMED
[  113.632507] [  108.215]                     [c71efc00] dsscomp_mgr_delayed_cb on DISPLAYED
[  113.632537] [  113.150]  [c6296080] new in dsscomp_gralloc_queue (refs=1)
[  113.632537] [  113.150]                           [c61c4000] dsscomp_new
[  113.632537] [  113.150]  [c6296080] ++refs=2 for [c61c4000]
[  113.632537] [  113.150]                           [c61c4000] dsscomp_delayed_apply
[  113.632537] [  113.150]  [c6296080] --refs=1 on RELEASED
[  113.632537] [  113.150]                           [c61c4000] dsscomp_apply
[  113.632537] [  113.150]    [c61b2660] --refs=0 on RELEASED
[  113.632568] [  113.150]    [c61b2660] calling dsscomp_proxy_cmdcomplete [c73f6480]
[  113.632568] [  113.150]                     [c71efc00] dsscomp_mgr_delayed_cb on RELEASED
[  113.632568] [  113.150]      [c6296180] new in dsscomp_gralloc_queue (refs=1)
[  113.632568] [  113.150]                      [c61c6000] dsscomp_new
[  113.632568] [  113.150]      [c6296180] ++refs=2 for [c61c6000]
[  113.632568] [  113.150]                      [c61c6000] dsscomp_delayed_apply
[  113.632568] [  113.150]      [c6296180] --refs=1 on RELEASED
[  113.632598] [  113.150]                           [c61c4000] dsscomp_mgr_delayed_cb on PROGRAMMED
[  113.632598] [  113.150]                      [c61c6000] dsscomp_apply
[  113.632598] [  113.179]                           [c61c4000] dsscomp_mgr_delayed_cb on DISPLAYED
[  113.632598] [  113.180]  [c6296080] --refs=0 on RELEASED
[  113.632598] [  113.180]  [c6296080] calling dsscomp_proxy_cmdcomplete [c73f6900]
[  113.632598] [  113.180]                           [c61c4000] dsscomp_mgr_delayed_cb on RELEASED
[  113.632629] [  113.180]   [c62961a0] new in dsscomp_gralloc_queue (refs=1)
[  113.632629] [  113.180]                           [c61c4000] dsscomp_new
[  113.632629] [  113.180]   [c62961a0] ++refs=2 for [c61c4000]
[  113.632629] [  113.180]                           [c61c4000] dsscomp_delayed_apply
[  113.632629] [  113.180]   [c62961a0] --refs=1 on RELEASED
[  113.632629] [  113.180]                      [c61c6000] dsscomp_mgr_delayed_cb on PROGRAMMED
[  113.632629] [  113.180]                           [c61c4000] dsscomp_apply
[  113.632629] [  113.201]                      [c61c6000] dsscomp_mgr_delayed_cb on DISPLAYED
[  113.632659] [  113.211]      [c6296180] --refs=0 on RELEASED
[  113.632659] [  113.211]      [c6296180] calling dsscomp_proxy_cmdcomplete [c73f6480]
[  113.632659] [  113.211]                      [c61c6000] dsscomp_mgr_delayed_cb on RELEASED
[  113.632659] [  113.211]    [c62961e0] new in dsscomp_gralloc_queue (refs=1)
[  113.632659] [  113.211]                      [c61c6000] dsscomp_new
[  113.632659] [  113.211]    [c62961e0] ++refs=2 for [c61c6000]
[  113.632659] [  113.211]                      [c61c6000] dsscomp_delayed_apply
[  113.632690] [  113.211]    [c62961e0] --refs=1 on RELEASED
[  113.632690] [  113.211]                           [c61c4000] dsscomp_mgr_delayed_cb on PROGRAMMED
[  113.632690] [  113.211]                      [c61c6000] dsscomp_apply
[  113.632690] [  113.231]                           [c61c4000] dsscomp_mgr_delayed_cb on DISPLAYED
[  113.632690] [  113.231]   [c62961a0] --refs=0 on RELEASED
[  113.632690] [  113.231]   [c62961a0] calling dsscomp_proxy_cmdcomplete [c73f6900]
[  113.632720] [  113.231]                           [c61c4000] dsscomp_mgr_delayed_cb on RELEASED
[  113.632720] [  113.232]      [c6296260] new in dsscomp_gralloc_queue (refs=1)
[  113.632720] [  113.232]                           [c61c4000] dsscomp_new
[  113.632720] [  113.232]      [c6296260] ++refs=2 for [c61c4000]
[  113.632720] [  113.232]                           [c61c4000] dsscomp_delayed_apply
[  113.632720] [  113.232]      [c6296260] --refs=1 on RELEASED
[  113.632720] [  113.232]                      [c61c6000] dsscomp_mgr_delayed_cb on PROGRAMMED
[  113.632751] [  113.232]                           [c61c4000] dsscomp_apply
[  113.632751] [  113.250]                      [c61c6000] dsscomp_mgr_delayed_cb on DISPLAYED
[  113.632751] [  113.257]    [c62961e0] --refs=0 on RELEASED
[  113.632751] [  113.257]    [c62961e0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[  113.632751] [  113.257]                      [c61c6000] dsscomp_mgr_delayed_cb on RELEASED
[  113.632751] [  113.258]      [c6296180] new in dsscomp_gralloc_queue (refs=1)
[  113.632751] [  113.258]                      [c61c6000] dsscomp_new
[  113.632781] [  113.258]      [c6296180] ++refs=2 for [c61c6000]
[  113.632781] [  113.258]                      [c61c6000] dsscomp_delayed_apply
[  113.632781] [  113.258]      [c6296180] --refs=1 on RELEASED
[  113.632781] [  113.258]                           [c61c4000] dsscomp_mgr_delayed_cb on PROGRAMMED
[  113.632781] [  113.258]                      [c61c6000] dsscomp_apply
[  113.632781] [  113.283]                           [c61c4000] dsscomp_mgr_delayed_cb on DISPLAYED
[  113.632781] [  113.283]      [c6296260] --refs=0 on RELEASED
[  113.632812] [  113.283]      [c6296260] calling dsscomp_proxy_cmdcomplete [c73f6900]
[  113.632812] [  113.284]                           [c61c4000] dsscomp_mgr_delayed_cb on RELEASED
[  113.632812] [  113.284]   [c62961a0] new in dsscomp_gralloc_queue (refs=1)
[  113.632812] [  113.284]                           [c61c4000] dsscomp_new
[  113.632812] [  113.284]   [c62961a0] ++refs=2 for [c61c4000]
[  113.632812] [  113.284]                           [c61c4000] dsscomp_delayed_apply
[  113.632843] [  113.284]   [c62961a0] --refs=1 on RELEASED
[  113.632843] [  113.284]                      [c61c6000] dsscomp_mgr_delayed_cb on PROGRAMMED
[  113.632843] [  113.284]                           [c61c4000] dsscomp_apply
[  113.632843] [  113.301]                      [c61c6000] dsscomp_mgr_delayed_cb on DISPLAYED
[  113.632843] [  113.301]      [c6296180] --refs=0 on RELEASED
[  113.632843] [  113.301]      [c6296180] calling dsscomp_proxy_cmdcomplete [c73f6480]
[  113.632843] [  113.301]                      [c61c6000] dsscomp_mgr_delayed_cb on RELEASED
[  113.632873] [  113.301]    [c62961e0] new in dsscomp_gralloc_queue (refs=1)
[  113.632873] [  113.301]                      [c61c6000] dsscomp_new
[  113.632873] [  113.301]    [c62961e0] ++refs=2 for [c61c6000]
[  113.632873] [  113.301]                      [c61c6000] dsscomp_delayed_apply
[  113.632873] [  113.301]    [c62961e0] --refs=1 on RELEASED
[  113.632873] [  113.301]                           [c61c4000] dsscomp_mgr_delayed_cb on PROGRAMMED
[  113.632873] [  113.301]                      [c61c6000] dsscomp_apply
[  113.632904] [  113.318]                           [c61c4000] dsscomp_mgr_delayed_cb on DISPLAYED
[  113.632904] [  113.318]   [c62961a0] --refs=0 on RELEASED
[  113.632904] [  113.318]   [c62961a0] calling dsscomp_proxy_cmdcomplete [c73f6900]
[  113.632904] [  113.318]                           [c61c4000] dsscomp_mgr_delayed_cb on RELEASED
[  113.632904] [  113.318]                      [c61c6000] dsscomp_mgr_delayed_cb on PROGRAMMED
[  113.632904] [  113.335]                      [c61c6000] dsscomp_mgr_delayed_cb on DISPLAYED
[  113.632904] ACTIVE COMPOSITIONS on lcd
[  113.632934]
[  113.632934]   [c61c6000]: DISPLAYED
[  113.632934]     sync_id=0, flags=AD-
[  113.632934]     ovl0={ON z0 xRGB24-8888 *100% 864*38:0,0+864,38 rot0 => 0,0+864,38 7f9ac000/  (null)|3456}
[  113.632934]     ovl1={ON z1 ARGB32-8888 premult *100% 864*480:0,0+864,480 rot0 => 0,0+864,480 7f9cd000/  (null)|3456}
[  113.632934]     gsync=[c62961e0] dsscomp_gralloc_cb
[  113.632934]
[  113.632934]   DISPC pipeline:
[  113.632934]
[  113.632965]     info:        clean (none)
[  113.632965]     cache:       clean (none)
[  113.632965]     shadow:  ACT clean (none)
[  113.632965]     dispc:   DISPLAYED mask=---R [c61c6000] dsscomp_mgr_callback
[  113.632965]
[  113.632965] ACTIVE COMPOSITIONS on tv
[  113.632965]
[  113.632965]   DISPC pipeline:
[  113.632965]
[  113.632995]     shadow:  off clean (none)
[  113.632995]     dispc:   DISPLAYED (none)
[  113.632995]
[  113.632995] ACTIVE COMPOSITIONS on lcd2
[  113.632995]
[  113.632995]   DISPC pipeline:
[  113.632995]
[  113.632995]     info:        clean (none)
[  113.632995]     cache:       clean (none)
[  113.632995]     dispc:             (none)
[  113.632995]
[  113.633026] ACTIVE GRALLOC FLIPS
[  113.633026]
[  113.633026]   [c62961e0] (refs=1)
[  113.633026]     slots=[7f9ac000]
[  113.633026]     cmdcb=[c73f6480] dsscomp_proxy_cmdcomplete
[  113.633026]
[  113.633026]   |           lcd
[  113.633026]   | [c61c6000] DISPL'D
[  113.633026]   |    113.301  ACTIVE
[  113.633026]   |    113.301 APPLY'N
[  113.633026]   |    113.301 APPLIED
[  113.633056]   |    113.318 PROGR'D
[  113.633056]   |    113.335 DISPL'D
[  113.633056]
[  113.633056]
[  113.633056] PVR_K: SGX debug (blaze_android_sgx_ogles1_ogles2_GPL sgxddk 18 1.8@869593)
[  113.633056] PVR_K: Flip Command Complete Data 0 for display device 1:
[  113.633087] PVR_K:   SRC 0: ROC DevVAddr:0xD8006F4 ROP:0x7 ROC:0x6, WOC DevVAddr:0xD8006E4 WOP:0x1 WOC:0x1
[  113.633087] PVR_K:   SRC 1: ROC DevVAddr:0xD800494 ROP:0x1a ROC:0x19, WOC DevVAddr:0xD800484 WOP:0x14 WOC:0x13
[  113.633117] PVR_K: Flip Command Complete Data 1 for display device 1:
[  113.633117] PVR_K:   SRC 0: (Not in use)
[  113.633117] PVR_K:   SRC 1: (Not in use)
[  113.633117] PVR_K: SGX Host control:
[  113.633148] PVR_K:   (HC-0) 0x00000001 0x00000000 0x00000000 0x00000001
[  113.633148] PVR_K:   (HC-10) 0x00000014 0x0000000A 0x0005DC00 0x00000003
[  113.633148] PVR_K:   (HC-20) 0x00000000 0x00000003 0x00000000 0x0000001A
[  113.633178] PVR_K:   (HC-30) 0x00000E79 0xF4DD0DCC 0x00000000 0x00000000
[  113.633178] PVR_K:   (HC-40) 0x00000000 0x087BF500 0x087C6300 0x087C3100
[  113.633178] PVR_K: SGX TA/3D control:
[  113.633209] PVR_K:   (T3C-0) 0x0F003000 0x0F003120 0x0F002000 0x0F06F180
[  113.633209] PVR_K:   (T3C-10) 0x00000001 0x00000002 0x00000001 0x0F00DFA0
[  113.633209] PVR_K:   (T3C-20) 0x00000000 0x00000000 0x00000000 0x00000000
[  113.633239] PVR_K:   (T3C-30) 0x00000000 0x00000000 0x00000000 0x00000000
[  113.633239] PVR_K:   (T3C-40) 0x00000000 0x00000000 0x00000000 0x0F00DA60
[  113.633239] PVR_K:   (T3C-50) 0x0F00DD00 0x00000000 0x0F00DA60 0x0F00DD00
[  113.633239] PVR_K:   (T3C-60) 0x00000000 0x00000000 0x0F00DD00 0x00000000
[  113.633270] PVR_K:   (T3C-70) 0x00000000 0x0F00DD00 0x00000000 0x0F004000
[  113.633270] PVR_K:   (T3C-80) 0x00000126 0x0001120F 0x00000000 0x0F00DC18
[  113.633270] PVR_K:   (T3C-90) 0x00000000 0x0F000000 0xAB600000 0x0F011300
[  113.633300] PVR_K:   (T3C-A0) 0x00000000 0x0F0104E0 0x0F00DA60 0x0F00DC18
[  113.633300] PVR_K:   (T3C-B0) 0x0F0104E0 0x00000000 0x00000000 0x00000000
[  113.633300] PVR_K:   (T3C-C0) 0x00000000 0x00000000 0x00000000 0x00000000
[  113.633331] PVR_K:   (T3C-D0) 0x00000000 0x00000001 0x00000001 0x0F007000
[  113.633331] PVR_K:   (T3C-E0) 0x0F00D420 0x0F00E000 0x0F010000 0x0F010000
[  113.633331] PVR_K:   (T3C-F0) 0x00000000 0x0000007A 0x0000007A 0x00000000
[  113.633361] PVR_K:   (T3C-100) 0x00000003 0x00000002 0x00000000 0x00000001
[  113.633361] PVR_K:   (T3C-110) 0xB50C565C 0x0872E100 0x08787B00 0x08787B00
[  113.633361] PVR_K: Last SGX microkernel status code: AD000282
[  113.633392] PVR_K:   (MKT-0) 079FC880 00100808 0100031F AD000B06
[  113.633392] PVR_K:   (MKT-1) 079FC8C4 00100808 0100031F AD000B07
[  113.633392] PVR_K:   (MKT-2) 079FC8EA 00100808 0100031F AD000B09
[  113.633392] PVR_K:   (MKT-3) 079FC93F 00100808 0100031F AD000B01
[  113.633422] PVR_K:   (MKT-4) 079FC97D 00100808 0100031F AD002300
[  113.633422] PVR_K:   (MKT-5) 079FCE66 00100808 0100041F AD00000A
[  113.633422] PVR_K:   (MKT-6) 079FCEA9 00100808 0100041F AD001100
[  113.633453] PVR_K:   (MKT-7) 079FCF30 00100808 0100041F AD000906
[  113.633453] PVR_K:   (MKT-8) 079FCFE4 00100808 0000041F AD000901
[  113.633453] PVR_K:   (MKT-9) 079FD061 00100808 0000051E AD000183
[  113.633483] PVR_K:   (MKT-A) 079FD397 0010088F 0000051E AD002401
[  113.633483] PVR_K:   (MKT-B) 079FD3DB 0016EC8F 0000051E AD000184
[  113.633483] PVR_K:   (MKT-C) 079FD45B 0017FF8F 0000061D AD000281
[  113.633514] PVR_K:   (MKT-D) 079FD5C5 0017FB8F 0000061D AD000E02
[  113.633514] PVR_K:   (MKT-E) 079FD81D 0016E98F 0000061D AD00080A
[  113.633514] PVR_K:   (MKT-F) 079FD838 0017F98F 0000061D 0F05D300
[  113.633514] PVR_K:   (MKT-10) 079FD854 0017FB8F 0000061D 00000061
[  113.633544] PVR_K:   (MKT-11) 079FD921 0017FB8F 0000061D AD001300
[  113.633544] PVR_K:   (MKT-12) 07A02AA8 00100808 0000061D AD001301
[  113.633544] PVR_K:   (MKT-13) 07A02BA9 00100808 0000061D AD000802
[  113.633575] PVR_K:   (MKT-14) 07A02D08 00100808 0000061D AD000803
[  113.633575] PVR_K:   (MKT-15) 07A02D50 00184AC8 0000061D AD000282
[  113.633575] PVR_K:   (MKT-16) 07A02DFC 00184CF8 0000081E AD000101
[  113.633605] PVR_K:   (MKT-17) 07A02EF9 001808F8 0000081E AD001601
[  113.633605] PVR_K:   (MKT-18) 07A02F25 001808F8 0000081E 0D800784
[  113.633605] PVR_K:   (MKT-19) 07A02F3D 001808F8 0000081E 00000002
[  113.633636] PVR_K:   (MKT-1A) 07A03311 001808FF 0000081E AD002401
[  113.633636] PVR_K:   (MKT-1B) 07A03375 001FFBFF 0000081E AD000104
[  113.633636] PVR_K:   (MKT-1C) 07A03589 001FFFFF 00000B1F AD000281
[  113.633666] PVR_K:   (MKT-1D) 07A035F0 001FFBFF 00000B1F AD000282
[  113.633666] PVR_K:   (MKT-1E) 07A03AB4 001808F8 01000D1F AD000101
[  113.633666] PVR_K:   (MKT-1F) 07A03BA2 001808F8 01000D1F AD001601
[  113.633666] PVR_K:   (MKT-20) 07A03BC9 001808F8 01000D1F 0D800784
[  113.633697] PVR_K:   (MKT-21) 07A03BE1 001808F8 01000D1F 00000003
[  113.633697] PVR_K:   (MKT-22) 07A03F65 001808FE 00000D1F AD002401
[  113.633697] PVR_K:   (MKT-23) 07A03FD0 001FFBFE 00000D1F AD000104
[  113.633728] PVR_K:   (MKT-24) 07A04083 001FFFF8 00000E1E AD000281
[  113.633728] PVR_K:   (MKT-25) 07A040FF 001808F8 00000E1E AD000282
[  113.633728] PVR_K:   (MKT-26) 07A04183 001808F8 0100101F AD000101
[  113.633758] PVR_K:   (MKT-27) 07A0426D 001808F8 0100101F AD001601
[  113.633758] PVR_K:   (MKT-28) 07A04291 001808F8 0100101F 0D800844
[  113.633758] PVR_K:   (MKT-29) 07A042AA 001808F8 0100101F 00000001
[  113.633789] PVR_K:   (MKT-2A) 07A04638 001808FE 0000101F AD002401
[  113.633789] PVR_K:   (MKT-2B) 07A0469D 001FFBFE 0000101F AD000104
[  113.633789] PVR_K:   (MKT-2C) 07A04776 00180DF8 0000111E AD000281
[  113.633789] PVR_K:   (MKT-2D) 07A047D4 001808F8 0000111E AD000282
[  113.633819] PVR_K:   (MKT-2E) 07A04859 001808F8 0100131F AD000101
[  113.633819] PVR_K:   (MKT-2F) 07A0493F 001808F8 0100131F AD001601
[  113.633819] PVR_K:   (MKT-30) 07A04964 001808F8 0100131F 0D800864
[  113.633850] PVR_K:   (MKT-31) 07A0497D 001808F8 0100131F 00000001
[  113.633850] PVR_K:   (MKT-32) 07A04D03 001808FC 0000131F AD002401
[  113.633850] PVR_K:   (MKT-33) 07A04D70 00188CF8 0000131F AD000104
[  113.633880] PVR_K:   (MKT-34) 07A04DF0 00180C38 0000141E AD000281
[  113.633880] PVR_K:   (MKT-35) 07A04E46 00180838 0000141E AD000282
[  113.633880] PVR_K:   (MKT-36) 07A04ECE 00180838 0100161A AD000101
[  113.633911] PVR_K:   (MKT-37) 07A04FC7 00180838 0100161A AD001601
[  113.633911] PVR_K:   (MKT-38) 07A04FEC 00180838 0100161A 0D8008A4
[  113.633911] PVR_K:   (MKT-39) 07A05004 00180838 0100161A 00000001
[  113.633911] PVR_K:   (MKT-3A) 07A05386 0010088C 0000161A AD002401
[  113.633941] PVR_K:   (MKT-3B) 07A053EE 0007FF8C 0000161A AD000104
[  113.633941] PVR_K:   (MKT-3C) 07A0547A 00000C08 0000171F AD000281
[  113.633941] PVR_K:   (MKT-3D) 07A054D0 00000808 0000171F AD000282
[  113.633972] PVR_K:   (MKT-3E) 07A0552D 00000808 0000191D AD000200
[  113.633972] PVR_K:   (MKT-3F) 07A05780 00000808 0000191D AD000202
[  113.633972] PVR_K:   (MKT-40) 07A057E5 00000808 00001A1C AD000101
[  113.634002] PVR_K:   (MKT-41) 07A058D0 00000808 00001A1C AD001601
[  113.634002] PVR_K:   (MKT-42) 07A058F3 00000808 00001A1C 0D8008E4
[  113.634002] PVR_K:   (MKT-43) 07A0590B 00000808 00001A1C 00000001
[  113.634033] PVR_K:   (MKT-44) 07A05AEB 00000808 00001A1C AD000302
[  113.634033] PVR_K:   (MKT-45) 07A05B3D 00000808 00001A1C AD000303
[  113.634033] PVR_K:   (MKT-46) 07A05BBF 00000808 00001A1C AD000C01
[  113.634033] PVR_K:   (MKT-47) 07A05BE3 00000808 00001A1C 0D800484
[  113.634063] PVR_K:   (MKT-48) 07A05BFC 00000808 00001A1C 00000012
[  113.634063] PVR_K:   (MKT-49) 07A05E3A 00000808 00001A1C AD00030E
[  113.634063] PVR_K:   (MKT-4A) 07A05E53 00000808 00001A1C 0D800474
[  113.634094] PVR_K:   (MKT-4B) 07A05E6B 00000808 00001A1C 00000012
[  113.634094] PVR_K:   (MKT-4C) 07A05E8F 00000808 00001A1C 00000013
[  113.634094] PVR_K:   (MKT-4D) 07A05F25 00000808 00001A1C AD000104
[  113.634124] PVR_K:   (MKT-4E) 07A05F81 00000808 00001B1F AD000183
[  113.634124] PVR_K:   (MKT-4F) 07A06037 00000808 00001B1F AD00030E
[  113.634124] PVR_K:   (MKT-50) 07A06050 00000808 00001B1F 0D800474
[  113.634155] PVR_K:   (MKT-51) 07A06069 00000808 00001B1F 00000012
[  113.634155] PVR_K:   (MKT-52) 07A06082 00000808 00001B1F 00000013
[  113.634155] PVR_K:   (MKT-53) 07A060E1 00000808 00001B1F AD000184
[  113.634155] PVR_K:   (MKT-54) 07A06139 00000C08 01001C1E AD000281
[  113.634185] PVR_K:   (MKT-55) 07A06286 00000808 01001C1E AD000E0F
[  113.634185] PVR_K:   (MKT-56) 07A0629F 00000808 01001C1E 0D800494
[  113.634185] PVR_K:   (MKT-57) 07A062B7 00000808 01001C1E 00000011
[  113.634216] PVR_K:   (MKT-58) 07A062D0 00000808 01001C1E 00000012
[  113.634216] PVR_K:   (MKT-59) 07A063D6 00000808 01001C1E AD00080A
[  113.634216] PVR_K:   (MKT-5A) 07A063EE 00000808 01001C1E 0F05D600
[  113.634246] PVR_K:   (MKT-5B) 07A06407 00000808 01001C1E 00000070
[  113.634246] PVR_K:   (MKT-5C) 07A066C1 00000808 00001C1E AD000803
[  113.634246] PVR_K:   (MKT-5D) 07A06705 00184EC8 00001C1E AD000282
[  113.634277] PVR_K:   (MKT-5E) 07A06AE9 00000808 01001E1F AD000200
[  113.634277] PVR_K:   (MKT-5F) 07A06D1C 00000808 00001E1F AD000202
[  113.634277] PVR_K:   (MKT-60) 07A06D9B 00000808 00001F1E AD000183
[  113.634277] PVR_K:   (MKT-61) 07A06E85 00000808 00001F1E AD00030E
[  113.634307] PVR_K:   (MKT-62) 07A06E9D 00000808 00001F1E 0D800474
[  113.634307] PVR_K:   (MKT-63) 07A06EB6 00000808 00001F1E 00000012
[  113.634307] PVR_K:   (MKT-64) 07A06EDA 00000808 00001F1E 00000013
[  113.634338] PVR_K:   (MKT-65) 07A06F44 00000808 00001F1E AD000184
[  113.634338] PVR_K:   (MKT-66) 07A06FA8 00000C08 0100201D AD000281
[  113.634338] PVR_K:   (MKT-67) 07A070FC 00000808 0100201D AD000E0F
[  113.634368] PVR_K:   (MKT-68) 07A07115 00000808 0100201D 0D800494
[  113.634368] PVR_K:   (MKT-69) 07A0712D 00000808 0100201D 00000011
[  113.634368] PVR_K:   (MKT-6A) 07A07146 00000808 0100201D 00000012
[  113.634399] PVR_K:   (MKT-6B) 07A0724A 00000808 0100201D AD00080A
[  113.634399] PVR_K:   (MKT-6C) 07A07262 00000808 0100201D 0F05D900
[  113.634399] PVR_K:   (MKT-6D) 07A0727A 00000808 0100201D 00000060
[  113.634399] PVR_K:   (MKT-6E) 07A0752A 00000808 0000201D AD000803
[  113.634429] PVR_K:   (MKT-6F) 07A07570 00184EC8 0000201D AD000282
[  113.634429] PVR_K:   (MKT-70) 07A07F41 00000808 0100221F AD000200
[  113.634429] PVR_K:   (MKT-71) 07A08167 00000808 0000221F AD000202
[  113.634460] PVR_K:   (MKT-72) 07A081E8 00000808 0000231E AD000183
[  113.634460] PVR_K:   (MKT-73) 07A082D1 00000808 0000231E AD00030E
[  113.634460] PVR_K:   (MKT-74) 07A082E9 00000808 0000231E 0D800474
[  113.634490] PVR_K:   (MKT-75) 07A08302 00000808 0000231E 00000012
[  113.634490] PVR_K:   (MKT-76) 07A08325 00000808 0000231E 00000013
[  113.634490] PVR_K:   (MKT-77) 07A08393 00000808 0000231E AD000184
[  113.634521] PVR_K:   (MKT-78) 07A083F7 00000C08 0100241D AD000281
[  113.634521] PVR_K:   (MKT-79) 07A0854A 00000808 0000241D AD000E0F
[  113.634521] PVR_K:   (MKT-7A) 07A08563 00000808 0000241D 0D800494
[  113.634521] PVR_K:   (MKT-7B) 07A0857B 00000808 0000241D 00000011
[  113.634552] PVR_K:   (MKT-7C) 07A08594 00000808 0000241D 00000012
[  113.634552] PVR_K:   (MKT-7D) 07A08699 00000808 0000241D AD00080A
[  113.634552] PVR_K:   (MKT-7E) 07A086B1 00000808 0000241D 0F05DC00
[  113.634582] PVR_K:   (MKT-7F) 07A086C9 00000808 0000241D 00000062
[  113.634582] PVR_K:   (MKT-80) 07A0897A 00000808 0000241D AD000803
[  113.634582] PVR_K:   (MKT-81) 07A089BF 00180C88 0000241D AD000282
[  113.634613] PVR_K:   (MKT-82) 07A09528 00000C08 0100271F AD000200
[  113.634613] PVR_K:   (MKT-83) 07A0964D 00000808 0100271F AD001703
[  113.634613] PVR_K:   (MKT-84) 07A09862 00000808 0000271F AD000202
[  113.634643] PVR_K:   (MKT-85) 07A098DF 00000808 0000281E AD000183
[  113.634643] PVR_K:   (MKT-86) 07A099CC 00000808 0000281E AD00030E
[  113.634643] PVR_K:   (MKT-87) 07A099E4 00000808 0000281E 0D800474
[  113.634643] PVR_K:   (MKT-88) 07A099FD 00000808 0000281E 00000012
[  113.634674] PVR_K:   (MKT-89) 07A09A20 00000808 0000281E 00000013
[  113.634674] PVR_K:   (MKT-8A) 07A09B13 00000808 0000281E AD000302
[  113.634674] PVR_K:   (MKT-8B) 07A09D46 00000808 0000281E AD000404
[  113.634704] PVR_K:   (MKT-8C) 07A09E07 00000808 0000281E AD000402
[  113.634704] PVR_K:   (MKT-8D) 07A09E43 0010082B 0000281E AD000184
[  113.634704] PVR_K:   (MKT-8E) 07A09EB7 00108DAB 0000291D AD000281
[  113.634735] PVR_K:   (MKT-8F) 07A0A081 001089AB 0000291D AD000E0F
[  113.634735] PVR_K:   (MKT-90) 07A0A09F 001089AB 0000291D 0D800494
[  113.634735] PVR_K:   (MKT-91) 07A0A0BE 0010082B 0000291D 00000011
[  113.634765] PVR_K:   (MKT-92) 07A0A0D9 001089AB 0000291D 00000012
[  113.634765] PVR_K:   (MKT-93) 07A0A14B 001089AB 0000291D AD000282
[  113.634765] PVR_K:   (MKT-94) 07A0D458 00000808 00002B1F AD000101
[  113.634765] PVR_K:   (MKT-95) 07A0D4CD 00000808 00002B1F AD000104
[  113.634796] PVR_K:   (MKT-96) 07A0D509 00000808 01002C1E AD000100
[  113.634796] PVR_K:   (MKT-97) 07A0D60A 00000808 01002C1E AD000501
[  113.634796] PVR_K:   (MKT-98) 07A0D648 0010082B 01002C1E AD000104
[  113.634826] PVR_K:   (MKT-99) 07A0F451 00000808 00002E1F AD000101
[  113.634826] PVR_K:   (MKT-9A) 07A0F4C5 00000808 00002E1F AD000104
[  113.634826] PVR_K:   (MKT-9B) 07A0F4FA 00000808 01002F1E AD000100
[  113.634857] PVR_K:   (MKT-9C) 07A0F5D7 00000808 01002F1E AD000501
[  113.634857] PVR_K:   (MKT-9D) 07A0F616 0010082B 01002F1E AD000104
[  113.634857] PVR_K:   (MKT-9E) 07A124E4 00100828 0100301F AD000101
[  113.634887] PVR_K:   (MKT-9F) 07A1253C 00100828 0100301F AD000104
[  113.634887] PVR_K:   (MKT-A0) 07A125CF 00000808 0100311F AD000100
[  113.634887] PVR_K:   (MKT-A1) 07A1269C 00000808 0100311F AD000501
[  113.634918] PVR_K:   (MKT-A2) 07A126D1 00100829 0100311F AD000104
[  113.634918] PVR_K:   (MKT-A3) 07A1433B 00100828 0100331F AD000101
[  113.634918] PVR_K:   (MKT-A4) 07A143B4 00000808 0000331F AD000104
[  113.634918] PVR_K:   (MKT-A5) 07A143F1 00000808 0100341E AD000100
[  113.634948] PVR_K:   (MKT-A6) 07A1447F 00000808 0100341E AD000502
[  113.634948] PVR_K:   (MKT-A7) 07A144D1 00000808 0100341E AD000C01
[  113.634948] PVR_K:   (MKT-A8) 07A144F4 00000808 0100341E 0D800824
[  113.634979] PVR_K:   (MKT-A9) 07A1450D 00000808 0100341E 00000001
[  113.634979] PVR_K:   (MKT-AA) 07A147CD 00000808 0000341E AD00030E
[  113.634979] PVR_K:   (MKT-AB) 07A147E6 00000808 0000341E 0D800474
[  113.635009] PVR_K:   (MKT-AC) 07A147FE 00000808 0000341E 00000012
[  113.635009] PVR_K:   (MKT-AD) 07A14822 00000808 0000341E 00000013
[  113.635009] PVR_K:   (MKT-AE) 07A148B8 00000808 0000341E AD000104
[  113.635040] PVR_K:   (MKT-AF) 07A1492B 00000C08 0100351F AD000281
[  113.635040] PVR_K:   (MKT-B0) 07A14AA1 00000808 0100351F AD00080A
[  113.635040] PVR_K:   (MKT-B1) 07A14ABA 00000808 0100351F 0F042300
[  113.635040] PVR_K:   (MKT-B2) 07A14AD2 00000808 0100351F 00000061
[  113.635070] PVR_K:   (MKT-B3) 07A14B58 00000808 0100351F AD001302
[  113.635070] PVR_K:   (MKT-B4) 07A14BA1 00000808 0100351F AD001303
[  113.635070] PVR_K:   (MKT-B5) 07A14C44 00000C88 0100351F AD001300
[  113.635101] PVR_K:   (MKT-B6) 07A19DD0 00000808 0000351F AD001301
[  113.635101] PVR_K:   (MKT-B7) 07A19EF7 00000808 0000351F AD000802
[  113.635101] PVR_K:   (MKT-B8) 07A1A060 00000808 0000351F AD000803
[  113.635131] PVR_K:   (MKT-B9) 07A1A0AC 00184AC8 0000351F AD000282
[  113.635131] PVR_K:   (MKT-BA) 07A1C04E 00000C08 0100391F AD000200
[  113.635131] PVR_K:   (MKT-BB) 07A1C2A2 00000808 0000391F AD000202
[  113.635162] PVR_K:   (MKT-BC) 07A1C33C 00000808 00003A1E AD000183
[  113.635162] PVR_K:   (MKT-BD) 07A1C43E 00000808 00003A1E AD00030E
[  113.635162] PVR_K:   (MKT-BE) 07A1C456 00000808 00003A1E 0D800474
[  113.635162] PVR_K:   (MKT-BF) 07A1C46F 00000808 00003A1E 00000012
[  113.635192] PVR_K:   (MKT-C0) 07A1C493 00000808 00003A1E 00000013
[  113.635192] PVR_K:   (MKT-C1) 07A1C4FF 00000808 00003A1E AD000184
[  113.635192] PVR_K:   (MKT-C2) 07A1C56D 00000C08 01003B1D AD000281
[  113.635223] PVR_K:   (MKT-C3) 07A1C6DB 00000808 01003B1D AD00080A
[  113.635223] PVR_K:   (MKT-C4) 07A1C6F4 00000808 01003B1D 0F042600
[  113.635223] PVR_K:   (MKT-C5) 07A1C70C 00000808 01003B1D 00000060
[  113.635253] PVR_K:   (MKT-C6) 07A1C9BC 00000808 00003B1D AD000803
[  113.635253] PVR_K:   (MKT-C7) 07A1CA01 00180CC8 00003B1D AD000282
[  113.635253] PVR_K:   (MKT-C8) 07A1CAA1 00000808 01003D1F AD000200
[  113.635284] PVR_K:   (MKT-C9) 07A1CCBB 00000808 00003D1F AD000202
[  113.635284] PVR_K:   (MKT-CA) 07A1CD3B 00000808 00003E1E AD000183
[  113.635284] PVR_K:   (MKT-CB) 07A1CE26 00000808 00003E1E AD00030E
[  113.635284] PVR_K:   (MKT-CC) 07A1CE3E 00000808 00003E1E 0D800474
[  113.635314] PVR_K:   (MKT-CD) 07A1CE57 00000808 00003E1E 00000012
[  113.635314] PVR_K:   (MKT-CE) 07A1CE7B 00000808 00003E1E 00000013
[  113.635314] PVR_K:   (MKT-CF) 07A1CEE6 00000808 00003E1E AD000184
[  113.635345] PVR_K:   (MKT-D0) 07A1CF4A 00000C08 01003F1D AD000281
[  113.635345] PVR_K:   (MKT-D1) 07A1D0B7 00000808 01003F1D AD00080A
[  113.635345] PVR_K:   (MKT-D2) 07A1D0CF 00000808 01003F1D 0F042900
[  113.635375] PVR_K:   (MKT-D3) 07A1D0E7 00000808 01003F1D 00000060
[  113.635375] PVR_K:   (MKT-D4) 07A1D397 00000808 00003F1D AD000803
[  113.635375] PVR_K:   (MKT-D5) 07A1D3DD 00180CC8 00003F1D AD000282
[  113.635406] PVR_K:   (MKT-D6) 07A1D4C1 00000808 0100411F AD000200
[  113.635406] PVR_K:   (MKT-D7) 07A1D6DF 00000808 0000411F AD000202
[  113.635406] PVR_K:   (MKT-D8) 07A1D762 00000808 0000421E AD000183
[  113.635406] PVR_K:   (MKT-D9) 07A1D852 00000808 0000421E AD00030E
[  113.635437] PVR_K:   (MKT-DA) 07A1D86A 00000808 0000421E 0D800474
[  113.635437] PVR_K:   (MKT-DB) 07A1D883 00000808 0000421E 00000012
[  113.635437] PVR_K:   (MKT-DC) 07A1D8A6 00000808 0000421E 00000013
[  113.635467] PVR_K:   (MKT-DD) 07A1D910 00000808 0000421E AD000184
[  113.635467] PVR_K:   (MKT-DE) 07A1D975 00000C08 0100431D AD000281
[  113.635467] PVR_K:   (MKT-DF) 07A1DADE 00000808 0100431D AD00080A
[  113.635498] PVR_K:   (MKT-E0) 07A1DAF6 00000808 0100431D 0F042C00
[  113.635498] PVR_K:   (MKT-E1) 07A1DB0F 00000808 0100431D 00000062
[  113.635498] PVR_K:   (MKT-E2) 07A1DDC1 00000808 0000431D AD000803
[  113.635528] PVR_K:   (MKT-E3) 07A1DE06 00180C88 0000431D AD000282
[  113.635528] PVR_K:   (MKT-E4) 07A1E90D 00000808 0100451F AD000200
[  113.635528] PVR_K:   (MKT-E5) 07A1EA2C 00000808 0100451F AD001703
[  113.635528] PVR_K:   (MKT-E6) 07A1EBFE 00000808 0000451F AD000202
[  113.635559] PVR_K:   (MKT-E7) 07A1EC7A 00000808 0100461E AD000183
[  113.635559] PVR_K:   (MKT-E8) 07A1ED69 00000808 0100461E AD00030E
[  113.635559] PVR_K:   (MKT-E9) 07A1ED82 00000808 0100461E 0D800474
[  113.635589] PVR_K:   (MKT-EA) 07A1ED9A 00000808 0100461E 00000012
[  113.635589] PVR_K:   (MKT-EB) 07A1EDBE 00000808 0100461E 00000013
[  113.635589] PVR_K:   (MKT-EC) 07A1EE4B 00000808 0100461E AD000184
[  113.635620] PVR_K:   (MKT-ED) 07A2B7AB 00000808 0100491F AD001A00
[  113.635620] PVR_K:   (MKT-EE) 07A2E2A1 00000808 01004A1F AD00000A
[  113.635620] PVR_K:   (MKT-EF) 07A2E306 00000808 01004A1F AD000905
[  113.635650] PVR_K:   (MKT-F0) 07A2E42E 00000808 00004A1F AD000901
[  113.635650] PVR_K:   (MKT-F1) 07A2E498 00000808 00004B1E AD000183
[  113.635650] PVR_K:   (MKT-F2) 07A2E58D 00000808 00004B1E AD00030E
[  113.635650] PVR_K:   (MKT-F3) 07A2E5A5 00000808 00004B1E 0D800474
[  113.635681] PVR_K:   (MKT-F4) 07A2E5BE 00000808 00004B1E 00000012
[  113.635681] PVR_K:   (MKT-F5) 07A2E5E2 00000808 00004B1E 00000013
[  113.635681] PVR_K:   (MKT-F6) 07A2E64F 00000808 00004B1E AD000184
[  113.635711] PVR_K:   (MKT-F7) 07A2E6B6 00000C08 01004C1D AD000281
[  113.635711] PVR_K:   (MKT-F8) 07A2E7D5 00000808 01004C1D AD000E02
[  113.635711] PVR_K:   (MKT-F9) 07A2E84B 00000808 01004C1D AD000282
[  113.635742] PVR_K:   (MKT-FA) 07A2EB05 00000808 01004D1F AD00000A
[  113.635742] PVR_K:   (MKT-FB) 07A2EB70 00000808 01004D1F AD000905
[  113.635742] PVR_K:   (MKT-FC) 07A2EC7C 00000808 00004D1F AD000901
[  113.635772] PVR_K:   (MKT-FD) 07A2ECE6 00000808 00004E1E AD000183
[  113.635772] PVR_K:   (MKT-FE) 07A2EDD5 00000808 00004E1E AD00030E
[  113.635772] PVR_K:   (MKT-FF) 07A2EDEE 00000808 00004E1E 0D800474
[  113.635772] PVR_K:   (MKT-100) 07A2EE07 00000808 00004E1E 00000012
[  113.635803] PVR_K:   (MKT-101) 07A2EE2A 00000808 00004E1E 00000013
[  113.635803] PVR_K:   (MKT-102) 07A2EE97 00000808 00004E1E AD000184
[  113.635803] PVR_K:   (MKT-103) 07A2EEFD 00000C08 01004F1D AD000281
[  113.635833] PVR_K:   (MKT-104) 07A2EFFA 00000808 00004F1D AD000E02
[  113.635833] PVR_K:   (MKT-105) 07A2F06E 00000808 00004F1D AD000282
[  113.635833] PVR_K:   (MKT-106) 07A2F120 00000808 0100501F AD00000A
[  113.635864] PVR_K:   (MKT-107) 07A2F18E 00000808 0100501F AD000905
[  113.635864] PVR_K:   (MKT-108) 07A2F2A0 00000808 0000501F AD000901
[  113.635864] PVR_K:   (MKT-109) 07A2F30D 00000808 0000511E AD000183
[  113.635894] PVR_K:   (MKT-10A) 07A2F3FC 00000808 0000511E AD00030E
[  113.635894] PVR_K:   (MKT-10B) 07A2F415 00000808 0000511E 0D800474
[  113.635894] PVR_K:   (MKT-10C) 07A2F42D 00000808 0000511E 00000012
[  113.635894] PVR_K:   (MKT-10D) 07A2F451 00000808 0000511E 00000013
[  113.635925] PVR_K:   (MKT-10E) 07A2F4BE 00000808 0000511E AD000184
[  113.635925] PVR_K:   (MKT-10F) 07A2F525 00000C08 0000521D AD000281
[  113.635925] PVR_K:   (MKT-110) 07A2F624 00000808 0000521D AD000E02
[  113.635955] PVR_K:   (MKT-111) 07A2F696 00000808 0000521D AD000282
[  113.635955] PVR_K:   (MKT-112) 07A2F74D 00000808 0100531F AD00000A
[  113.635955] PVR_K:   (MKT-113) 07A2F7B7 00000808 0100531F AD000905
[  113.635986] PVR_K:   (MKT-114) 07A2F8C9 00000808 0000531F AD000901
[  113.635986] PVR_K:   (MKT-115) 07A2F93B 00000808 0000541E AD000183
[  113.635986] PVR_K:   (MKT-116) 07A2FA31 00000808 0000541E AD00030E
[  113.636016] PVR_K:   (MKT-117) 07A2FA4D 00000808 0000541E 0D800474
[  113.636016] PVR_K:   (MKT-118) 07A2FA66 00000808 0000541E 00000012
[  113.636016] PVR_K:   (MKT-119) 07A2FA8A 00000808 0000541E 00000013
[  113.636047] PVR_K:   (MKT-11A) 07A2FAF6 00000808 0000541E AD000184
[  113.636047] PVR_K:   (MKT-11B) 07A2FB60 00000C08 0100551D AD000281
[  113.636047] PVR_K:   (MKT-11C) 07A2FC65 00000808 0100551D AD000E02
[  113.636047] PVR_K:   (MKT-11D) 07A2FCD8 00000808 0100551D AD000282
[  113.636077] PVR_K:   (MKT-11E) 07A3203A 00000808 0100571F AD00000A
[  113.636077] PVR_K:   (MKT-11F) 07A320A4 00000808 0100571F AD000906
[  113.636077] PVR_K:   (MKT-120) 07A3215F 00000808 0000571F AD000901
[  113.636108] PVR_K:   (MKT-121) 07A321CD 00000808 0000581E AD000183
[  113.636108] PVR_K:   (MKT-122) 07A32325 00000808 0000581E AD000302
[  113.636108] PVR_K:   (MKT-123) 07A3237A 00000808 0000581E AD000303
[  113.636138] PVR_K:   (MKT-124) 07A32400 00000808 0000581E AD000C01
[  113.636138] PVR_K:   (MKT-125) 07A32426 00000808 0000581E 0D800464
[  113.636138] PVR_K:   (MKT-126) 07A3243F 00000808 0000581E 00000013
[  113.636169] PVR_K:   (MKT-127) 07A32693 00000808 0000581E AD00030E
[  113.636169] PVR_K:   (MKT-128) 07A326AB 00000808 0000581E 0D800494
[  113.636169] PVR_K:   (MKT-129) 07A326C3 00000808 0000581E 00000011
[  113.636169] PVR_K:   (MKT-12A) 07A326E8 00000808 0000581E 00000012
[  113.636199] PVR_K:   (MKT-12B) 07A32761 00000808 0000581E AD000184
[  113.636199] PVR_K:   (MKT-12C) 07A327CA 00000C08 0100591D AD000281
[  113.636199] PVR_K:   (MKT-12D) 07A32930 00000808 0100591D AD00080A
[  113.636230] PVR_K:   (MKT-12E) 07A32949 00000808 0100591D 0F042F00
[  113.636230] PVR_K:   (MKT-12F) 07A32961 00000808 0100591D 00000061
[  113.636230] PVR_K:   (MKT-130) 07A32AEB 00000808 0000591D AD000802
[  113.636260] PVR_K:   (MKT-131) 07A32C45 00000808 0000591D AD000803
[  113.636260] PVR_K:   (MKT-132) 07A32C8B 00184EC8 0000591D AD000282
[  113.636260] PVR_K:   (MKT-133) 07A341AA 00180838 01005B1F AD00000A
[  113.636291] PVR_K:   (MKT-134) 07A34216 00180838 01005B1F AD000905
[  113.636291] PVR_K:   (MKT-135) 07A34313 00180838 00005B1F AD000901
[  113.636291] PVR_K:   (MKT-136) 07A34384 00180838 00005C1E AD000183
[  113.636291] PVR_K:   (MKT-137) 07A3447A 00180838 00005C1E AD00030E
[  113.636322] PVR_K:   (MKT-138) 07A34495 00180838 00005C1E 0D800494
[  113.636322] PVR_K:   (MKT-139) 07A344AD 00180838 00005C1E 00000011
[  113.636322] PVR_K:   (MKT-13A) 07A344D1 00180838 00005C1E 00000012
[  113.636352] PVR_K:   (MKT-13B) 07A34540 00180838 00005C1E AD000184
[  113.636352] PVR_K:   (MKT-13C) 07A345AC 00180C38 00005D1D AD000281
[  113.636352] PVR_K:   (MKT-13D) 07A34606 00180838 00005D1D AD000282
[  113.636383] PVR_K:   (MKT-13E) 07A346C4 00180838 01005E1F AD00000A
[  113.636383] PVR_K:   (MKT-13F) 07A3472F 00180838 01005E1F AD000905
[  113.636383] PVR_K:   (MKT-140) 07A3482C 00180838 00005E1F AD000901
[  113.636413] PVR_K:   (MKT-141) 07A3489D 00180838 00005F1E AD00000A
[  113.636413] PVR_K:   (MKT-142) 07A34901 00180838 00005F1E AD000905
[  113.636413] PVR_K:   (MKT-143) 07A349A8 00180838 00005F1E AD000901
[  113.636444] PVR_K:   (MKT-144) 07A34A12 00180838 0000601D AD000183
[  113.636444] PVR_K:   (MKT-145) 07A34B08 00180838 0000601D AD00030E
[  113.636444] PVR_K:   (MKT-146) 07A34B21 00180838 0000601D 0D800494
[  113.636444] PVR_K:   (MKT-147) 07A34B3C 00180838 0000601D 00000011
[  113.636474] PVR_K:   (MKT-148) 07A34B63 00180838 0000601D 00000012
[  113.636474] PVR_K:   (MKT-149) 07A34BD1 00180838 0000601D AD000184
[  113.636474] PVR_K:   (MKT-14A) 07A34C3C 00100C28 0000611C AD000281
[  113.636505] PVR_K:   (MKT-14B) 07A34C97 00100828 0000611C AD000282
[  113.636505] PVR_K:   (MKT-14C) 07A34D51 00000808 0000621F AD00000A
[  113.636505] PVR_K:   (MKT-14D) 07A34DBE 00000808 0000621F AD000905
[  113.636535] PVR_K:   (MKT-14E) 07A34EB6 00000808 0000621F AD000901
[  113.636535] PVR_K:   (MKT-14F) 07A34EED 00000C08 0000631E AD000200
[  113.636535] PVR_K:   (MKT-150) 07A35134 00000808 0000631E AD000202
[  113.636566] PVR_K:   (MKT-151) 07A351BE 00000808 0000641D AD000183
[  113.636566] PVR_K:   (MKT-152) 07A352AA 00000808 0000641D AD00030E
[  113.636566] PVR_K:   (MKT-153) 07A352C2 00000808 0000641D 0D800494
[  113.636596] PVR_K:   (MKT-154) 07A352DC 00000808 0000641D 00000011
[  113.636596] PVR_K:   (MKT-155) 07A352FF 00000808 0000641D 00000012
[  113.636596] PVR_K:   (MKT-156) 07A3536B 00000808 0000641D AD000184
[  113.636596] PVR_K:   (MKT-157) 07A353D1 00000C08 0100651C AD000281
[  113.636627] PVR_K:   (MKT-158) 07A35542 00000808 0100651C AD00080A
[  113.636627] PVR_K:   (MKT-159) 07A3555B 00000808 0100651C 0F043200
[  113.636627] PVR_K:   (MKT-15A) 07A35573 00000808 0100651C 00000060
[  113.636657] PVR_K:   (MKT-15B) 07A35834 00000808 0000651C AD000803
[  113.636657] PVR_K:   (MKT-15C) 07A35881 00188CC8 0000651C AD000282
[  113.636657] PVR_K:   (MKT-15D) 07A3592F 00000808 0100671F AD000200
[  113.636688] PVR_K:   (MKT-15E) 07A35B54 00000808 0000671F AD000202
[  113.636688] PVR_K:   (MKT-15F) 07A35BE0 00000808 0000681E AD000183
[  113.636688] PVR_K:   (MKT-160) 07A35CCF 00000808 0000681E AD00030E
[  113.636718] PVR_K:   (MKT-161) 07A35CE9 00000808 0000681E 0D800494
[  113.636718] PVR_K:   (MKT-162) 07A35D02 00000808 0000681E 00000011
[  113.636718] PVR_K:   (MKT-163) 07A35D27 00000808 0000681E 00000012
[  113.636718] PVR_K:   (MKT-164) 07A35D94 00000808 0000681E AD000184
[  113.636749] PVR_K:   (MKT-165) 07A35DFC 00000C08 0100691D AD000281
[  113.636749] PVR_K:   (MKT-166) 07A35F77 00000808 0100691D AD00080A
[  113.636749] PVR_K:   (MKT-167) 07A35F8F 00000808 0100691D 0F043500
[  113.636779] PVR_K:   (MKT-168) 07A35FA8 00000808 0100691D 00000060
[  113.636779] PVR_K:   (MKT-169) 07A36266 00000808 0000691D AD000803
[  113.636779] PVR_K:   (MKT-16A) 07A362B0 00180CC8 0000691D AD000282
[  113.636810] PVR_K:   (MKT-16B) 07A3639A 00000808 01006B1F AD000200
[  113.636810] PVR_K:   (MKT-16C) 07A365BC 00000808 00006B1F AD000202
[  113.636810] PVR_K:   (MKT-16D) 07A36640 00000808 00006C1E AD000183
[  113.636840] PVR_K:   (MKT-16E) 07A36730 00000808 00006C1E AD00030E
[  113.636840] PVR_K:   (MKT-16F) 07A36748 00000808 00006C1E 0D800494
[  113.636840] PVR_K:   (MKT-170) 07A36763 00000808 00006C1E 00000011
[  113.636840] PVR_K:   (MKT-171) 07A36787 00000808 00006C1E 00000012
[  113.636871] PVR_K:   (MKT-172) 07A367F1 00000808 00006C1E AD000184
[  113.636871] PVR_K:   (MKT-173) 07A36859 00000C08 01006D1D AD000281
[  113.636871] PVR_K:   (MKT-174) 07A369C3 00000808 01006D1D AD00080A
[  113.636901] PVR_K:   (MKT-175) 07A369DC 00000808 01006D1D 0F043800
[  113.636901] PVR_K:   (MKT-176) 07A369F4 00000808 01006D1D 00000062
[  113.636901] PVR_K:   (MKT-177) 07A36CB3 00000808 00006D1D AD000803
[  113.636932] PVR_K:   (MKT-178) 07A36CFC 00180C88 00006D1D AD000282
[  113.636932] PVR_K:   (MKT-179) 07A3785F 00000C08 0100701F AD000200
[  113.636932] PVR_K:   (MKT-17A) 07A3798B 00000808 0100701F AD001703
[  113.636962] PVR_K:   (MKT-17B) 07A37BA5 00000808 0000701F AD000202
[  113.636962] PVR_K:   (MKT-17C) 07A37C25 00000808 0000711E AD000183
[  113.636962] PVR_K:   (MKT-17D) 07A37D11 00000808 0000711E AD00030E
[  113.636993] PVR_K:   (MKT-17E) 07A37D2E 00000808 0000711E 0D800494
[  113.636993] PVR_K:   (MKT-17F) 07A37D46 00000808 0000711E 00000011
[  113.636993] PVR_K:   (MKT-180) 07A37D71 00000808 0000711E 00000012
[  113.636993] PVR_K:   (MKT-181) 07A37DDE 00000808 0000711E AD000184
[  113.637023] PVR_K:   (MKT-182) 07A37E48 00000C08 0100721D AD000281
[  113.637023] PVR_K:   (MKT-183) 07A37F62 00000808 0100721D AD000E02
[  113.637023] PVR_K:   (MKT-184) 07A37FD6 00000808 0100721D AD000282
[  113.637054] PVR_K:   (MKT-185) 07A48C6C 00000808 0100751F AD001A00
[  113.637054] PVR_K:   (MKT-186) 07A49093 00000808 0100761F AD00000A
[  113.637054] PVR_K:   (MKT-187) 07A490F4 00000808 0100761F AD000909
[  113.637084] PVR_K:   (MKT-188) 07A49143 00000808 0100761F AD001A05
[  113.637084] PVR_K:   (MKT-189) 07A49174 00000808 0100761F AD001302
[  113.637084] PVR_K:   (MKT-18A) 07A491B5 00000808 0100761F AD001303
[  113.637115] PVR_K:   (MKT-18B) 07A4924F 00000808 0100761F AD000D04
[  113.637115] PVR_K:   (MKT-18C) 07A49320 00000808 0100761F AD000D05
[  113.637115] PVR_K:   (MKT-18D) 07A4937A 00000808 0100761F AD000D04
[  113.637115] PVR_K:   (MKT-18E) 07A493FF 00000808 0100761F AD000D05
[  113.637145] PVR_K:   (MKT-18F) 07A4945B 00000808 0100761F AD001A06
[  113.637145] PVR_K:   (MKT-190) 00000480 00100808 0100031F AD002300
[  113.637145] PVR_K:   (MKT-191) 00000991 00100808 0100041F AD00000A
[  113.637176] PVR_K:   (MKT-192) 00000A03 00100808 0100041F AD000905
[  113.637176] PVR_K:   (MKT-193) 00000B3F 00100808 0000041F AD000901
[  113.637176] PVR_K:   (MKT-194) 00000BB8 00100808 0000051E AD000183
[  113.637207] PVR_K:   (MKT-195) 00000CCA 00100808 0000051E AD00030E
[  113.637207] PVR_K:   (MKT-196) 00000CE4 00100808 0000051E 0D800494
[  113.637207] PVR_K:   (MKT-197) 00000D00 00100808 0000051E 00000011
[  113.637237] PVR_K:   (MKT-198) 00000D24 00100808 0000051E 00000012
[  113.637237] PVR_K:   (MKT-199) 00000D90 00100808 0000051E AD000184
[  113.637237] PVR_K:   (MKT-19A) 00000E12 00100C08 0100061D AD000281
[  113.637268] PVR_K:   (MKT-19B) 00001014 00100808 0100061D AD000E0E
[  113.637268] PVR_K:   (MKT-19C) 0000102D 00100808 0100061D 0D800464
[  113.637268] PVR_K:   (MKT-19D) 00001045 00100808 0100061D 00000013
[  113.637268] PVR_K:   (MKT-19E) 0000105F 00100808 0100061D 00000014
[  113.637298] PVR_K:   (MKT-19F) 00001100 00100808 0100061D AD000E02
[  113.637298] PVR_K:   (MKT-1A0) 00001176 00100808 0100061D AD000282
[  113.637298] PVR_K:   (MKT-1A1) 00011DC9 00100808 0100091F AD001A00
[  113.637329] PVR_K:   (MKT-1A2) 00012079 00100808 01000A1F AD00000A
[  113.637329] PVR_K:   (MKT-1A3) 000120DB 00100808 01000A1F AD000909
[  113.637329] PVR_K:   (MKT-1A4) 00012126 00100808 01000A1F AD001A05
[  113.637359] PVR_K:   (MKT-1A5) 000121D5 00100808 01000A1F AD001A06
[  113.637359] PVR_K:   (MKT-1A6) 00000458 00100808 0100031F AD002300
[  113.637359] PVR_K:   (MKT-1A7) 0000092C 00100808 0100041F AD00000A
[  113.637390] PVR_K:   (MKT-1A8) 000009AB 00100808 0100041F AD000906
[  113.637390] PVR_K:   (MKT-1A9) 00000A73 00100808 0000041F AD000901
[  113.637390] PVR_K:   (MKT-1AA) 00000AEF 00100808 0000051E AD000183
[  113.637390] PVR_K:   (MKT-1AB) 00000C65 00100808 0000051E AD000302
[  113.637420] PVR_K:   (MKT-1AC) 00000DF1 00100808 0000051E AD000D06
[  113.637420] PVR_K:   (MKT-1AD) 00000EDD 00100808 0000051E AD000D07
[  113.637420] PVR_K:   (MKT-1AE) 00000F29 00100808 0000051E AD001304
[  113.637451] PVR_K:   (MKT-1AF) 00001016 00100808 0000051E AD001305
[  113.637451] PVR_K:   (MKT-1B0) 0000112D 00100888 0000051E AD000404
[  113.637451] PVR_K:   (MKT-1B1) 000011F2 00100808 0000051E AD000402
[  113.637481] PVR_K:   (MKT-1B2) 0000123A 0010082B 0000051E AD000184
[  113.637481] PVR_K:   (MKT-1B3) 000012C5 00100D2B 0000061D AD000281
[  113.637481] PVR_K:   (MKT-1B4) 00001545 00108DAD 0000061D AD000E0E
[  113.637512] PVR_K:   (MKT-1B5) 00001563 001199AB 0000061D 0D800464
[  113.637512] PVR_K:   (MKT-1B6) 00001580 001089AB 0000061D 00000013
[  113.637512] PVR_K:   (MKT-1B7) 0000159B 001199AD 0000061D 00000014
[  113.637542] PVR_K:   (MKT-1B8) 00001657 001089AF 0000061D AD000E02
[  113.637542] PVR_K:   (MKT-1B9) 000016BD 001089AB 0000061D AD000282
[  113.637542] PVR_K:   (MKT-1BA) 00003ABF 00100808 0000081F AD000101
[  113.637542] PVR_K:   (MKT-1BB) 00003B35 00100808 0000081F AD000104
[  113.637573] PVR_K:   (MKT-1BC) 00003B72 00100808 0100091E AD000100
[  113.637573] PVR_K:   (MKT-1BD) 00003C79 00100808 0100091E AD000501
[  113.637573] PVR_K:   (MKT-1BE) 00003CBB 0010082B 0100091E AD000104
[  113.637603] PVR_K:   (MKT-1BF) 07158C6C 00100808 0100031F AD000B00
[  113.637603] PVR_K:   (MKT-1C0) 07158CB1 00100808 0100031F AD000B03
[  113.637603] PVR_K:   (MKT-1C1) 07158D67 00100808 0100031F AD000B05
[  113.637634] PVR_K:   (MKT-1C2) 07158DBB 00100808 0100031F AD000B06
[  113.637634] PVR_K:   (MKT-1C3) 07158DE9 00100808 0100031F AD000B06
[  113.637634] PVR_K:   (MKT-1C4) 07158E2E 00100808 0100031F AD000B07
[  113.637664] PVR_K:   (MKT-1C5) 07158E53 00100808 0100031F AD000B09
[  113.637664] PVR_K:   (MKT-1C6) 07158EA8 00100808 0100031F AD000B01
[  113.637664] PVR_K:   (MKT-1C7) 07158EE4 00100808 0100031F AD002300
[  113.637664] PVR_K:   (MKT-1C8) 071591BB 00100808 0100041F AD00000A
[  113.637695] PVR_K:   (MKT-1C9) 07159239 00100808 0100041F AD000906
[  113.637695] PVR_K:   (MKT-1CA) 071592EE 00100808 0000041F AD000901
[  113.637695] PVR_K:   (MKT-1CB) 0715936A 00100808 0000051E AD000183
[  113.637725] PVR_K:   (MKT-1CC) 071594DB 00100808 0000051E AD000302
[  113.637725] PVR_K:   (MKT-1CD) 07159532 00100808 0000051E AD000303
[  113.637725] PVR_K:   (MKT-1CE) 071595B9 00100808 0000051E AD000C01
[  113.637756] PVR_K:   (MKT-1CF) 071595E0 00100808 0000051E 0D800484
[  113.637756] PVR_K:   (MKT-1D0) 071595FB 00100808 0000051E 00000013
[  113.637756] PVR_K:   (MKT-1D1) 07159844 00100808 0000051E AD00030E
[  113.637786] PVR_K:   (MKT-1D2) 0715985D 00100808 0000051E 0D800474
[  113.637786] PVR_K:   (MKT-1D3) 07159875 00100808 0000051E 00000013
[  113.637786] PVR_K:   (MKT-1D4) 0715989D 00100808 0000051E 00000014
[  113.637817] PVR_K:   (MKT-1D5) 07159913 00100808 0000051E AD000184
[  113.637817] PVR_K:   (MKT-1D6) 07159990 00100C08 0100061D AD000281
[  113.637817] PVR_K:   (MKT-1D7) 07159B8D 00100808 0100061D AD000E0E
[  113.637817] PVR_K:   (MKT-1D8) 07159BA6 00100808 0100061D 0D800464
[  113.637847] PVR_K:   (MKT-1D9) 07159BBE 00100808 0100061D 00000013
[  113.637847] PVR_K:   (MKT-1DA) 07159BD7 00100808 0100061D 00000014
[  113.637847] PVR_K:   (MKT-1DB) 07159CBC 00100808 0100061D AD000E0F
[  113.637878] PVR_K:   (MKT-1DC) 07159CD4 00100808 0100061D 0D800494
[  113.637878] PVR_K:   (MKT-1DD) 07159CEC 00100808 0100061D 00000012
[  113.637878] PVR_K:   (MKT-1DE) 07159D05 00100808 0100061D 0000001A
[  113.637908] PVR_K:   (MKT-1DF) 07159D76 00100808 0100061D AD000282
[  113.637908] PVR_K:   (MKT-1E0) 0715BD26 00100808 0100071F AD00000A
[  113.637908] PVR_K:   (MKT-1E1) 0715BD9B 00100808 0100071F AD000906
[  113.637939] PVR_K:   (MKT-1E2) 0715BE5B 00100808 0000071F AD000901
[  113.637939] PVR_K:   (MKT-1E3) 0715BEC3 00100808 0000081E AD000183
[  113.637939] PVR_K:   (MKT-1E4) 0715C011 00100808 0000081E AD000302
[  113.637939] PVR_K:   (MKT-1E5) 0715C05C 00100808 0000081E AD000303
[  113.637969] PVR_K:   (MKT-1E6) 0715C0D3 00100808 0000081E AD000C01
[  113.637969] PVR_K:   (MKT-1E7) 0715C0F8 00100808 0000081E 0D800464
[  113.637969] PVR_K:   (MKT-1E8) 0715C111 00100808 0000081E 00000014
[  113.638000] PVR_K:   (MKT-1E9) 0715C309 00100808 0000081E AD000184
[  113.638000] PVR_K:   (MKT-1EA) 0715C36D 00100C08 0100091D AD000281
[  113.638000] PVR_K:   (MKT-1EB) 0715C5B0 00100808 0100091D AD00080A
[  113.638031] PVR_K:   (MKT-1EC) 0715C5C9 00100808 0100091D 0F011300
[  113.638031] PVR_K:   (MKT-1ED) 0715C5E1 00100808 0100091D 00000073
[  113.638031] PVR_K:   (MKT-1EE) 0715C6F5 00100C88 0100091D AD001300
[  113.638061] PVR_K:   (MKT-1EF) 071618FF 00100808 0000091D AD001301
[  113.638061] PVR_K:   (MKT-1F0) 07161A2B 00100808 0000091D AD000802
[  113.638061] PVR_K:   (MKT-1F1) 07161BB1 00100808 0000091D AD000803
[  113.638092] PVR_K:   (MKT-1F2) 07161BFE 00184AC8 0000091D AD000282
[  113.638092] PVR_K:   (MKT-1F3) 0716761A 00000C08 01000E1F AD000200
[  113.638092] PVR_K:   (MKT-1F4) 07167776 00000808 01000E1F AD001703
[  113.638092] PVR_K:   (MKT-1F5) 071678E8 00000808 00000E1F AD000202
[  113.638122] PVR_K:   (MKT-1F6) 07167975 00000808 00000F1E AD000183
[  113.638122] PVR_K:   (MKT-1F7) 07167B21 00000808 00000F1E AD000302
[  113.638122] PVR_K:   (MKT-1F8) 07167DDA 00000808 00000F1E AD000402
[  113.638153] PVR_K:   (MKT-1F9) 07167E17 0010082B 00000F1E AD000184
[  113.638153] PVR_K:   (MKT-1FA) 07167EAE 0017FFAF 0000101D AD000281
[  113.638153] PVR_K:   (MKT-1FB) 071680D9 0016EBAF 0000101D AD000E0F
[  113.638183] PVR_K:   (MKT-1FC) 071680F4 0017FBAF 0000101D 0D800494
[  113.638183] PVR_K:   (MKT-1FD) 0716811B 001089AF 0000101D 00000012
[  113.638183] PVR_K:   (MKT-1FE) 07168135 0017FBAF 0000101D 0000001A
[  113.638214] PVR_K:   (MKT-1FF) 071681C6 001089AF 0000101D AD000282
[  113.638214] PVR_K: SGX Kernel CCB WO:0xC RO:0x5
[  118.342620]            [c61c4000] dsscomp_new
[  118.342620] [  108.175]  [c6296080] ++refs=2 for [c61c4000]
[  118.342651] [  108.175]                           [c61c4000] dsscomp_delayed_apply
[  118.342651] [  108.175]  [c6296080] --refs=1 on RELEASED
[  118.342651] [  108.175]                           [c61c4000] dsscomp_apply
[  118.377288] [  108.176]     [c602d420] --refs=0 on RELEASED
[  118.377288] [  108.176]     [c602d420] calling dsscomp_proxy_cmdcomplete [c73f6480]
[  118.377288] [  108.176]                          [c6f10800] dsscomp_mgr_delayed_cb on RELEASED
[  118.377288] [  108.176]                           [c61c4000] dsscomp_mgr_delayed_cb on PROGRAMMED
[  118.407135] [  108.176]    [c61b2660] new in dsscomp_gralloc_queue (refs=1)
[  118.407135] [  108.176]                     [c71efc00] dsscomp_new
[  118.407165] [  108.176]    [c61b2660] ++refs=2 for [c71efc00]
[  118.407165] [  108.176]                     [c71efc00] dsscomp_delayed_apply
[  118.436889] [  108.176]    [c61b2660] --refs=1 on RELEASED
[  118.436889] [  108.176]                     [c71efc00] dsscomp_apply
[  118.436889] [  108.197]                           [c61c4000] dsscomp_mgr_delayed_cb on DISPLAYED
[  118.436889] [  108.197]  [c6296080] --refs=0 on RELEASED
[  118.436889] [  108.197]  [c6296080] calling dsscomp_proxy_cmdcomplete [c73f6900]
[  118.468200] [  108.197]                           [c61c4000] dsscomp_mgr_delayed_cb on RELEASED
[  118.468200] [  108.197]                     [c71efc00] dsscomp_mgr_delayed_cb on PROGRAMMED
[  118.468200] [  108.215]                     [c71efc00] dsscomp_mgr_delayed_cb on DISPLAYED
[  118.496429] [  113.150]  [c6296080] new in dsscomp_gralloc_queue (refs=1)
[  118.496429] [  113.150]                           [c61c4000] dsscomp_new
[  118.496429] [  113.150]  [c6296080] ++refs=2 for [c61c4000]
[  118.496429] [  113.150]                           [c61c4000] dsscomp_delayed_apply
[  118.526214] [  113.150]  [c6296080] --refs=1 on RELEASED
[  118.526214] [  113.150]                           [c61c4000] dsscomp_apply
[  118.526214] [  113.150]    [c61b2660] --refs=0 on RELEASED
[  118.526214] [  113.150]    [c61b2660] calling dsscomp_proxy_cmdcomplete [c73f6480]
[  118.555999] [  113.150]                     [c71efc00] dsscomp_mgr_delayed_cb on RELEASED
[  118.555999] [  113.150]      [c6296180] new in dsscomp_gralloc_queue (refs=1)
[  118.555999] [  113.150]                      [c61c6000] dsscomp_new
[  118.555999] [  113.150]      [c6296180] ++refs=2 for [c61c6000]
[  118.585815] [  113.150]                      [c61c6000] dsscomp_delayed_apply
[  118.585815] [  113.150]      [c6296180] --refs=1 on RELEASED
[  118.585815] [  113.150]                           [c61c4000] dsscomp_mgr_delayed_cb on PROGRAMMED
[  118.585815] [  113.150]                      [c61c6000] dsscomp_apply
[  118.615570] [  113.179]                           [c61c4000] dsscomp_mgr_delayed_cb on DISPLAYED
[  118.615570] [  113.180]  [c6296080] --refs=0 on RELEASED
[  118.615570] [  113.180]  [c6296080] calling dsscomp_proxy_cmdcomplete [c73f6900]
[  118.615570] [  113.180]                           [c61c4000] dsscomp_mgr_delayed_cb on RELEASED
[  118.645568] [  113.180]   [c62961a0] new in dsscomp_gralloc_queue (refs=1)
[  118.645568] [  113.180]                           [c61c4000] dsscomp_new
[  118.645568] [  113.180]   [c62961a0] ++refs=2 for [c61c4000]
[  118.645568] [  113.180]                           [c61c4000] dsscomp_delayed_apply
[  118.675506] [  113.180]   [c62961a0] --refs=1 on RELEASED
[  118.675537] [  113.180]                      [c61c6000] dsscomp_mgr_delayed_cb on PROGRAMMED
[  118.675537] [  113.180]                           [c61c4000] dsscomp_apply
[  118.675537] [  113.201]                      [c61c6000] dsscomp_mgr_delayed_cb on DISPLAYED
[  118.717620] [  113.211]      [c6296180] --refs=0 on RELEASED
[  118.717620] [  113.211]      [c6296180] calling dsscomp_proxy_cmdcomplete [c73f6480]
[  118.717651] [  113.211]                      [c61c6000] dsscomp_mgr_delayed_cb on RELEASED
[  118.717651] [  113.211]    [c62961e0] new in dsscomp_gralloc_queue (refs=1)
[  118.749145] [  113.211]                      [c61c6000] dsscomp_new
[  118.749145] [  113.211]    [c62961e0] ++refs=2 for [c61c6000]
[  118.749145] [  113.211]                      [c61c6000] dsscomp_delayed_apply
[  118.749145] [  113.211]    [c62961e0] --refs=1 on RELEASED
[  118.778930] [  113.211]                           [c61c4000] dsscomp_mgr_delayed_cb on PROGRAMMED
[  118.778930] [  113.211]                      [c61c6000] dsscomp_apply
[  118.778930] [  113.231]                           [c61c4000] dsscomp_mgr_delayed_cb on DISPLAYED
[  118.778961] [  113.231]   [c62961a0] --refs=0 on RELEASED
[  118.808776] [  113.231]   [c62961a0] calling dsscomp_proxy_cmdcomplete [c73f6900]
[  118.808776] [  113.231]                           [c61c4000] dsscomp_mgr_delayed_cb on RELEASED
[  118.808776] [  113.232]      [c6296260] new in dsscomp_gralloc_queue (refs=1)
[  118.808776] [  113.232]                           [c61c4000] dsscomp_new
[  118.838531] [  113.232]      [c6296260] ++refs=2 for [c61c4000]
[  118.838531] [  113.232]                           [c61c4000] dsscomp_delayed_apply
[  118.838531] [  113.232]      [c6296260] --refs=1 on RELEASED
[  118.838531] [  113.232]                      [c61c6000] dsscomp_mgr_delayed_cb on PROGRAMMED
[  118.868255] [  113.232]                           [c61c4000] dsscomp_apply
[  118.868286] [  113.250]                      [c61c6000] dsscomp_mgr_delayed_cb on DISPLAYED
[  118.868286] [  113.257]    [c62961e0] --refs=0 on RELEASED
[  118.868286] [  113.257]    [c62961e0] calling dsscomp_proxy_cmdcomplete [c73f6480]
[  118.898040] [  113.257]                      [c61c6000] dsscomp_mgr_delayed_cb on RELEASED
[  118.898040] [  113.258]      [c6296180] new in dsscomp_gralloc_queue (refs=1)
[  118.898040] [  113.258]                      [c61c6000] dsscomp_new
[  118.898040] [  113.258]      [c6296180] ++refs=2 for [c61c6000]
[  118.927825] [  113.258]                      [c61c6000] dsscomp_delayed_apply
[  118.927856] [  113.258]      [c6296180] --refs=1 on RELEASED
[  118.927856] [  113.258]                           [c61c4000] dsscomp_mgr_delayed_cb on PROGRAMMED
[  118.927856] [  113.258]                      [c61c6000] dsscomp_apply
[  118.957580] [  113.283]                           [c61c4000] dsscomp_mgr_delayed_cb on DISPLAYED
[  118.957580] [  113.283]      [c6296260] --refs=0 on RELEASED
[  118.957580] [  113.283]      [c6296260] calling dsscomp_proxy_cmdcomplete [c73f6900]
[  118.985992] [  113.284]                           [c61c4000] dsscomp_mgr_delayed_cb on RELEASED
[  118.985992] [  113.284]   [c62961a0] new in dsscomp_gralloc_queue (refs=1)
[  118.985992] [  113.284]                           [c61c4000] dsscomp_new
[  118.985992] [  113.284]   [c62961a0] ++refs=2 for [c61c4000]
[  119.015747] [  113.284]                           [c61c4000] dsscomp_delayed_apply
[  119.015747] [  113.284]   [c62961a0] --refs=1 on RELEASED
[  119.015747] [  113.284]                      [c61c6000] dsscomp_mgr_delayed_cb on PROGRAMMED
[  119.015777] [  113.284]                           [c61c4000] dsscomp_apply
[  119.045562] [  113.301]                      [c61c6000] dsscomp_mgr_delayed_cb on DISPLAYED
[  119.045562] [  113.301]      [c6296180] --refs=0 on RELEASED
[  119.045562] [  113.301]      [c6296180] calling dsscomp_proxy_cmdcomplete [c73f6480]
[  119.045562] [  113.301]                      [c61c6000] dsscomp_mgr_delayed_cb on RELEASED
[  119.075317] [  113.301]    [c62961e0] new in dsscomp_gralloc_queue (refs=1)
[  119.075317] [  113.301]                      [c61c6000] dsscomp_new
[  119.075347] [  113.301]    [c62961e0] ++refs=2 for [c61c6000]
[  119.075347] [  113.301]                      [c61c6000] dsscomp_delayed_apply
[  119.105133] [  113.301]    [c62961e0] --refs=1 on RELEASED
[  119.105133] [  113.301]                           [c61c4000] dsscomp_mgr_delayed_cb on PROGRAMMED
[  119.105133] [  113.301]                      [c61c6000] dsscomp_apply
[  119.105133] [  113.318]                           [c61c4000] dsscomp_mgr_delayed_cb on DISPLAYED
[  119.134918] [  113.318]   [c62961a0] --refs=0 on RELEASED
[  119.134918] [  113.318]   [c62961a0] calling dsscomp_proxy_cmdcomplete [c73f6900]
[  119.134918] [  113.318]                           [c61c4000] dsscomp_mgr_delayed_cb on RELEASED
[  119.134918] [  113.318]                      [c61c6000] dsscomp_mgr_delayed_cb on PROGRAMMED
[  119.164733] [  113.335]                      [c61c6000] dsscomp_mgr_delayed_cb on DISPLAYED
[  119.164733] ACTIVE COMPOSITIONS on lcd
[  119.164733]
[  119.164733]   [c61c6000]: DISPLAYED
[  119.164764]     sync_id=0, flags=AD-
[  119.164764]     ovl0={ON z0 xRGB24-8888 *100% 864*38:0,0+864,38 rot0 => 0,0+864,38 7f9ac000/  (null)|3456}
[  119.197631]     ovl1={ON z1 ARGB32-8888 premult *100% 864*480:0,0+864,480 rot0 => 0,0+864,480 7f9cd000/  (null)|3456}
[  119.197631]     gsync=[c62961e0] dsscomp_gralloc_cb
[  119.197631]
[  119.197631]   DISPC pipeline:
[  119.197631]
[  119.197631]     info:        clean (none)
[  119.197662]     cache:       clean (none)
[  119.232025]     shadow:  ACT clean (none)
[  119.232025]     dispc:   DISPLAYED mask=---R [c61c6000] dsscomp_mgr_callback
[  119.232025]
[  119.232025] ACTIVE COMPOSITIONS on tv
[  119.232025]
[  119.232025]   DISPC pipeline:
[  119.232025]
[  119.232025]     info:        clean (none)
[  119.232025]     cache:       clean (none)
[  119.232025]     shadow:  off clean (none)
[  119.270935]     dispc:   DISPLAYED (none)
[  119.270965]
[  119.270965] ACTIVE COMPOSITIONS on lcd2
[  119.270965]
[  119.270965]   DISPC pipeline:
[  119.270965]
[  119.270965]     info:        clean (none)
[  119.270965]     cache:       clean (none)
[  119.270965]     shadow:  off clean (none)
[  119.270965]     dispc:             (none)
[  119.270965]
[  119.270965] ACTIVE GRALLOC FLIPS
[  119.270965]
[  119.270965]   [c62961e0] (refs=1)
[  119.270996]     slots=[7f9ac000]
[  119.317565]     cmdcb=[c73f6480] dsscomp_proxy_cmdcomplete
[  119.317565]
[  119.317565]   |           lcd
[  119.317565]   | [c61c6000] DISPL'D
[  119.317565]   |    113.301  ACTIVE
[  119.317565]   |    113.301 APPLY'N
[  119.317596]   |    113.301 APPLIED
[  119.317596]   |    113.318 PROGR'D
[  119.317596]   |    113.335 DISPL'D
[  119.317596]
[  119.317596]
[  119.355651] PVR_K: SGX debug (blaze_android_sgx_ogles1_ogles2_GPL sgxddk 18 1.8@869593)
[  119.364227] PVR_K:(Error): SGX Register Base Address (Linear):   0xC8B20000 [0, ]
[  119.372222] PVR_K:(Error): SGX Register Base Address (Physical): 0x56000000 [0, ]
[  119.380218] PVR_K: (P0) EUR_CR_CORE_ID:          01140000
[  119.386016] PVR_K: (P0) EUR_CR_CORE_REVISION:    00010200
[  119.391845] PVR_K: (P0) EUR_CR_EVENT_STATUS:     20000000
[  119.397583] PVR_K: (P0) EUR_CR_EVENT_STATUS2:    00000008
[  119.403411] PVR_K: (P0) EUR_CR_BIF_CTRL:         00000000
[  119.409210] PVR_K: (P0) EUR_CR_BIF_INT_STAT:     00008000
[  119.415039] PVR_K: (P0) EUR_CR_BIF_FAULT:        00000000
[  119.420806] PVR_K: (P0) EUR_CR_BIF_MEM_REQ_STAT: 00000000
[  119.426635] PVR_K: (P0) EUR_CR_CLKGATECTL:       000AAA6A
[  119.432373] PVR_K: (P0) EUR_CR_PDS_PC_BASE:      00000CF8
[  119.438201] PVR_K: Flip Command Complete Data 0 for display device 1:
[  119.445068] PVR_K:   SRC 0: ROC DevVAddr:0xD8006F4 ROP:0x7 ROC:0x6, WOC DevVAddr:0xD8006E4 WOP:0x1 WOC:0x1
[  119.455261] PVR_K:   SRC 1: ROC DevVAddr:0xD800494 ROP:0x1a ROC:0x19, WOC DevVAddr:0xD800484 WOP:0x14 WOC:0x13
[  119.465850] PVR_K: Flip Command Complete Data 1 for display device 1:
[  119.472747] PVR_K:   SRC 0: (Not in use)
[  119.476867] PVR_K:   SRC 1: (Not in use)
[  119.480957] PVR_K: SGX Host control:
[  119.484863] PVR_K:   (HC-0) 0x00000001 0x00000000 0x00000000 0x00000001
[  119.491821] PVR_K:   (HC-10) 0x00000014 0x0000000A 0x0005DC00 0x00000003
[  119.498901] PVR_K:   (HC-20) 0x00000000 0x00000003 0x00000000 0x0000001A
[  119.505950] PVR_K:   (HC-30) 0x00000E79 0xF4DD0DCC 0x00000000 0x00000000
[  119.513031] PVR_K:   (HC-40) 0x00000000 0x087BF500 0x087C6300 0x087C3100
[  119.520111] PVR_K: SGX TA/3D control:
[  119.524047] PVR_K:   (T3C-0) 0x0F003000 0x0F003120 0x0F002000 0x0F06F180
[  119.531097] PVR_K:   (T3C-10) 0x00000001 0x00000002 0x00000001 0x0F00DFA0
[  119.538269] PVR_K:   (T3C-20) 0x00000000 0x00000000 0x00000000 0x00000000
[  119.545471] PVR_K:   (T3C-30) 0x00000000 0x00000000 0x00000000 0x00000000
[  119.552581] PVR_K:   (T3C-40) 0x00000000 0x00000000 0x00000000 0x0F00DA60
[  119.559783] PVR_K:   (T3C-50) 0x0F00DD00 0x00000000 0x0F00DA60 0x0F00DD00
[  119.566925] PVR_K:   (T3C-60) 0x00000000 0x00000000 0x0F00DD00 0x00000000
[  119.574096] PVR_K:   (T3C-70) 0x00000000 0x0F00DD00 0x00000000 0x0F004000
[  119.581298] PVR_K:   (T3C-80) 0x00000126 0x0001120F 0x00000000 0x0F00DC18
[  119.588409] PVR_K:   (T3C-90) 0x00000000 0x0F000000 0xAB600000 0x0F011300
[  119.595611] PVR_K:   (T3C-A0) 0x00000000 0x0F0104E0 0x0F00DA60 0x0F00DC18
[  119.602752] PVR_K:   (T3C-B0) 0x0F0104E0 0x00000000 0x00000000 0x00000000
[  119.609954] PVR_K:   (T3C-C0) 0x00000000 0x00000000 0x00000000 0x00000000
[  119.617126] PVR_K:   (T3C-D0) 0x00000000 0x00000001 0x00000001 0x0F007000
[  119.624267] PVR_K:   (T3C-E0) 0x0F00D420 0x0F00E000 0x0F010000 0x0F010000
[  119.631439] PVR_K:   (T3C-F0) 0x00000000 0x0000007A 0x0000007A 0x00000000
[  119.638580] PVR_K:   (T3C-100) 0x00000003 0x00000002 0x00000000 0x00000001
[  119.645843] PVR_K:   (T3C-110) 0xB50C565C 0x0872E100 0x08787B00 0x08787B00
[  119.653137] PVR_K: Last SGX microkernel status code: AD000282
[  119.659271] PVR_K:   (MKT-0) 079FC880 00100808 0100031F AD000B06
[  119.665618] PVR_K:   (MKT-1) 079FC8C4 00100808 0100031F AD000B07
[  119.671936] PVR_K:   (MKT-2) 079FC8EA 00100808 0100031F AD000B09
[  119.678283] PVR_K:   (MKT-3) 079FC93F 00100808 0100031F AD000B01
[  119.684600] PVR_K:   (MKT-4) 079FC97D 00100808 0100031F AD002300
[  119.690948] PVR_K:   (MKT-5) 079FCE66 00100808 0100041F AD00000A
[  119.697265] PVR_K:   (MKT-6) 079FCEA9 00100808 0100041F AD001100
[  119.703643] PVR_K:   (MKT-7) 079FCF30 00100808 0100041F AD000906
[  119.709960] PVR_K:   (MKT-8) 079FCFE4 00100808 0000041F AD000901
[  119.716308] PVR_K:   (MKT-9) 079FD061 00100808 0000051E AD000183
[  119.722625] PVR_K:   (MKT-A) 079FD397 0010088F 0000051E AD002401
[  119.728973] PVR_K:   (MKT-B) 079FD3DB 0016EC8F 0000051E AD000184
[  119.735290] PVR_K:   (MKT-C) 079FD45B 0017FF8F 0000061D AD000281
[  119.741638] PVR_K:   (MKT-D) 079FD5C5 0017FB8F 0000061D AD000E02
[  119.747955] PVR_K:   (MKT-E) 079FD81D 0016E98F 0000061D AD00080A
[  119.754302] PVR_K:   (MKT-F) 079FD838 0017F98F 0000061D 0F05D300
[  119.760620] PVR_K:   (MKT-10) 079FD854 0017FB8F 0000061D 00000061
[  119.767059] PVR_K:   (MKT-11) 079FD921 0017FB8F 0000061D AD001300
[  119.773529] PVR_K:   (MKT-12) 07A02AA8 00100808 0000061D AD001301
[  119.779907] PVR_K:   (MKT-13) 07A02BA9 00100808 0000061D AD000802
[  119.786376] PVR_K:   (MKT-14) 07A02D08 00100808 0000061D AD000803
[  119.792755] PVR_K:   (MKT-15) 07A02D50 00184AC8 0000061D AD000282
[  119.799224] PVR_K:   (MKT-16) 07A02DFC 00184CF8 0000081E AD000101
[  119.805633] PVR_K:   (MKT-17) 07A02EF9 001808F8 0000081E AD001601
[  119.812103] PVR_K:   (MKT-18) 07A02F25 001808F8 0000081E 0D800784
[  119.818481] PVR_K:   (MKT-19) 07A02F3D 001808F8 0000081E 00000002
[  119.824951] PVR_K:   (MKT-1A) 07A03311 001808FF 0000081E AD002401
[  119.831359] PVR_K:   (MKT-1B) 07A03375 001FFBFF 0000081E AD000104
[  119.837799] PVR_K:   (MKT-1C) 07A03589 001FFFFF 00000B1F AD000281
[  119.844207] PVR_K:   (MKT-1D) 07A035F0 001FFBFF 00000B1F AD000282
[  119.850646] PVR_K:   (MKT-1E) 07A03AB4 001808F8 01000D1F AD000101
[  119.857055] PVR_K:   (MKT-1F) 07A03BA2 001808F8 01000D1F AD001601
[  119.863494] PVR_K:   (MKT-20) 07A03BC9 001808F8 01000D1F 0D800784
[  119.869903] PVR_K:   (MKT-21) 07A03BE1 001808F8 01000D1F 00000003
[  119.876373] PVR_K:   (MKT-22) 07A03F65 001808FE 00000D1F AD002401
[  119.882812] PVR_K:   (MKT-23) 07A03FD0 001FFBFE 00000D1F AD000104
[  119.889221] PVR_K:   (MKT-24) 07A04083 001FFFF8 00000E1E AD000281
[  119.895660] PVR_K:   (MKT-25) 07A040FF 001808F8 00000E1E AD000282
[  119.902038] PVR_K:   (MKT-26) 07A04183 001808F8 0100101F AD000101
[  119.908508] PVR_K:   (MKT-27) 07A0426D 001808F8 0100101F AD001601
[  119.914916] PVR_K:   (MKT-28) 07A04291 001808F8 0100101F 0D800844
[  119.921356] PVR_K:   (MKT-29) 07A042AA 001808F8 0100101F 00000001
[  119.927764] PVR_K:   (MKT-2A) 07A04638 001808FE 0000101F AD002401
[  119.934234] PVR_K:   (MKT-2B) 07A0469D 001FFBFE 0000101F AD000104
[  119.940734] PVR_K:   (MKT-2C) 07A04776 00180DF8 0000111E AD000281
[  119.947174] PVR_K:   (MKT-2D) 07A047D4 001808F8 0000111E AD000282
[  119.953613] PVR_K:   (MKT-2E) 07A04859 001808F8 0100131F AD000101
[  119.960083] PVR_K:   (MKT-2F) 07A0493F 001808F8 0100131F AD001601
[  119.966461] PVR_K:   (MKT-30) 07A04964 001808F8 0100131F 0D800864
[  119.972930] PVR_K:   (MKT-31) 07A0497D 001808F8 0100131F 00000001
[  119.979400] PVR_K:   (MKT-32) 07A04D03 001808FC 0000131F AD002401
[  119.985809] PVR_K:   (MKT-33) 07A04D70 00188CF8 0000131F AD000104
[  119.992248] PVR_K:   (MKT-34) 07A04DF0 00180C38 0000141E AD000281
[  119.998687] PVR_K:   (MKT-35) 07A04E46 00180838 0000141E AD000282
[  120.005126] PVR_K:   (MKT-36) 07A04ECE 00180838 0100161A AD000101
[  120.011535] PVR_K:   (MKT-37) 07A04FC7 00180838 0100161A AD001601
[  120.018066] PVR_K:   (MKT-38) 07A04FEC 00180838 0100161A 0D8008A4
[  120.024475] PVR_K:   (MKT-39) 07A05004 00180838 0100161A 00000001
[  120.030944] PVR_K:   (MKT-3A) 07A05386 0010088C 0000161A AD002401
[  120.037353] PVR_K:   (MKT-3B) 07A053EE 0007FF8C 0000161A AD000104
[  120.043853] PVR_K:   (MKT-3C) 07A0547A 00000C08 0000171F AD000281
[  120.050292] PVR_K:   (MKT-3D) 07A054D0 00000808 0000171F AD000282
[  120.056762] PVR_K:   (MKT-3E) 07A0552D 00000808 0000191D AD000200
[  120.063171] PVR_K:   (MKT-3F) 07A05780 00000808 0000191D AD000202
[  120.069641] PVR_K:   (MKT-40) 07A057E5 00000808 00001A1C AD000101
[  120.076049] PVR_K:   (MKT-41) 07A058D0 00000808 00001A1C AD001601
[  120.082489] PVR_K:   (MKT-42) 07A058F3 00000808 00001A1C 0D8008E4
[  120.088958] PVR_K:   (MKT-43) 07A0590B 00000808 00001A1C 00000001
[  120.095367] PVR_K:   (MKT-44) 07A05AEB 00000808 00001A1C AD000302
[  120.101837] PVR_K:   (MKT-45) 07A05B3D 00000808 00001A1C AD000303
[  120.109893] PVR_K:   (MKT-46) 07A05BBF 00000808 00001A1C AD000C01
[  120.116516] PVR_K:   (MKT-47) 07A05BE3 00000808 00001A1C 0D800484
[  120.123748] PVR_K:   (MKT-48) 07A05BFC 00000808 00001A1C 00000012
[  120.131683] PVR_K:   (MKT-49) 07A05E3A 00000808 00001A1C AD00030E
[  120.138214] PVR_K:   (MKT-4A) 07A05E53 00000808 00001A1C 0D800474
[  120.145172] PVR_K:   (MKT-4B) 07A05E6B 00000808 00001A1C 00000012
[  120.151947] PVR_K:   (MKT-4C) 07A05E8F 00000808 00001A1C 00000013
[  120.158843] PVR_K:   (MKT-4D) 07A05F25 00000808 00001A1C AD000104
[  120.165679] PVR_K:   (MKT-4E) 07A05F81 00000808 00001B1F AD000183
[  120.172241] PVR_K:   (MKT-4F) 07A06037 00000808 00001B1F AD00030E
[  120.178985] PVR_K:   (MKT-50) 07A06050 00000808 00001B1F 0D800474
[  120.185852] PVR_K:   (MKT-51) 07A06069 00000808 00001B1F 00000012
[  120.192749] PVR_K:   (MKT-52) 07A06082 00000808 00001B1F 00000013
[  120.199493] PVR_K:   (MKT-53) 07A060E1 00000808 00001B1F AD000184
[  120.206512] PVR_K:   (MKT-54) 07A06139 00000C08 01001C1E AD000281
[  120.213256] PVR_K:   (MKT-55) 07A06286 00000808 01001C1E AD000E0F
[  120.219757] PVR_K:   (MKT-56) 07A0629F 00000808 01001C1E 0D800494
[  120.226196] PVR_K:   (MKT-57) 07A062B7 00000808 01001C1E 00000011
[  120.232849] PVR_K:   (MKT-58) 07A062D0 00000808 01001C1E 00000012
[  120.240020] PVR_K:   (MKT-59) 07A063D6 00000808 01001C1E AD00080A
[  120.246520] PVR_K:   (MKT-5A) 07A063EE 00000808 01001C1E 0F05D600
[  120.252929] PVR_K:   (MKT-5B) 07A06407 00000808 01001C1E 00000070
[  120.260925] PVR_K:   (MKT-5C) 07A066C1 00000808 00001C1E AD000803
[  120.268035] PVR_K:   (MKT-5D) 07A06705 00184EC8 00001C1E AD000282
[  120.275543] PVR_K:   (MKT-5E) 07A06AE9 00000808 01001E1F AD000200
[  120.282226] PVR_K:   (MKT-5F) 07A06D1C 00000808 00001E1F AD000202
[  120.288726] PVR_K:   (MKT-60) 07A06D9B 00000808 00001F1E AD000183
[  120.297180] PVR_K:   (MKT-61) 07A06E85 00000808 00001F1E AD00030E
[  120.304656] PVR_K:   (MKT-62) 07A06E9D 00000808 00001F1E 0D800474
[  120.311126] PVR_K:   (MKT-63) 07A06EB6 00000808 00001F1E 00000012
[  120.317535] PVR_K:   (MKT-64) 07A06EDA 00000808 00001F1E 00000013
[  120.324096] PVR_K:   (MKT-65) 07A06F44 00000808 00001F1E AD000184
[  120.330505] PVR_K:   (MKT-66) 07A06FA8 00000C08 0100201D AD000281
[  120.336975] PVR_K:   (MKT-67) 07A070FC 00000808 0100201D AD000E0F
[  120.343383] PVR_K:   (MKT-68) 07A07115 00000808 0100201D 0D800494
[  120.349822] PVR_K:   (MKT-69) 07A0712D 00000808 0100201D 00000011
