720p capture_dei_encode OMTB Script
So I am trying to convert /usr/share/ti/ti-omtb/capture_dei_encode.oms to work with a 720p component source. I have made all the obvious changes such as changing the resolution values from 1920 --> 1280 and 1080 --> 720 and changing the buffer sizes proportionately. I have also changed the display resolution to 720p60 and verified it via:
root@dm816x-evm:/usr/share/ti/ti-omtb# cat /sys/devices/platform/vpss/display0/mode
720p-60
When I run the script I only get a grey image displayed on the HDMI output port and a black image on the component output port, but I am expecting to see a bluray movie playing on the HDMI output port. Can someone take a look at my script and tell me what is wrong with it?
Mike
#omx omtb_dbg_lvl 0x00
#omx omtb_dbg_lvl 0x04
#omx omtb_dbg_lvl 0x08
#omx omtb_dbg_lvl 0x10
#omx omtb_dbg_lvl 0x80
omx api init
omx setp 0 vfcc compname OMX.TI.VPSSM3.VFCC
omx setp 0 tvp compname OMX.TI.VPSSM3.CTRL.TVP
omx setp 0 dc insmod_hdmi disable
#I/P Port or O/P Port Params for VFCC
omx setp 0 vfcc numoutbuf 6
omx setp 0 vfcc frame_width 1280
omx setp 0 vfcc frame_height 720
omx setp 0 vfcc op_chromat_format 420SP
omx setp 0 vfcc outbufalign 0
omx setp 0 vfcc outbuf_contig disable
omx setp 0 vfcc outbufsize 1382400
omx setp 0 vfcc data_opmode driver
omx setp 0 vfcc outbuf allocate
omx setp 0 vfcc outbufsize_flag disable
omx setp 0 dei frame_width 1280
omx setp 0 dei frame_height 720
omx setp 0 dei op_chromat_format 420SP
omx setp 0 dei ip_chromat_format 420SP
omx setp 0 dei numinbuf 6
omx setp 0 dei inbufalign 0
omx setp 0 dei inbuf_contig disable
omx setp 0 dei inbufsize_flag disable
omx setp 0 dei inbufsize 1382400
omx setp 0 dei numoutbuf 8
omx setp 0 dei outbufalign 0
omx setp 0 dei outbuf_contig disable
omx setp 0 dei outbufsize_flag enable
omx setp 0 dei outbufsize 1843200
omx setp 0 dei data_opmode driver
omx setp 0 dei inbuf use
omx setp 0 dei outbuf allocate
omx setp 0 h264venc numinbuf 8
omx setp 0 h264venc frame_width 1280
omx setp 0 h264venc frame_height 720
omx setp 0 h264venc inbufsize 1843200
omx setp 0 h264venc numoutbuf 4
omx setp 0 h264venc outbufsize_flag enable
omx setp 0 h264venc outbufsize 1382400
omx setp 0 h264venc data_opmode driver
#To enable write to SD card change mode to file
omx setp 0 h264venc data_opmode file
omx setp 0 h264venc outfile /usr/share/ti/data/videos/dm816x_1080p60_encode.264
omx setp 0 vfdc frame_width 1280
omx setp 0 vfdc frame_height 720
omx setp 0 vfdc ip_chromat_format 422YUYV
omx setp 0 vfdc numinbuf 8
omx setp 0 vfdc inbufalign 0
omx setp 0 vfdc inbuf_contig disable
omx setp 0 vfdc inbufsize 1843200
omx setp 0 vfdc inbuf use
omx setp 0 vfdc graphics_flag disable
#omx setp 0 vfdc vcdemo_flag enable
omx setp 0 vfdc mosaic_window_config vs
omx api gethandle tvp 0 0
omx api gethandle vfcc 0 0
omx api gethandle dei 0 0
omx api gethandle h264venc 0 0
omx api gethandle vfdc 0 0
omx api gethandle dc 0 0
#SET ALL THE PARAMS FOR TVP
omx setp 0 tvp OMX_TI_IndexParamVFCCHwPortID eHwPortId vip1_porta
omx api setparam tvp 0 0 0 OMX_TI_IndexParamVFCCHwPortID
omx setp 0 tvp OMX_TI_IndexParamVFCCHwPortProperties eCaptMode sc_non_mux
omx setp 0 tvp OMX_TI_IndexParamVFCCHwPortProperties eVifMode 16_bit
omx setp 0 tvp OMX_TI_IndexParamVFCCHwPortProperties eInColorFormat 422YUYV
omx setp 0 tvp OMX_TI_IndexParamVFCCHwPortProperties eScanType progressive
omx setp 0 tvp OMX_TI_IndexParamVFCCHwPortProperties nMaxWidth 1280
omx setp 0 tvp OMX_TI_IndexParamVFCCHwPortProperties nMaxHeight 720
omx setp 0 tvp OMX_TI_IndexParamVFCCHwPortProperties nMaxChnlsPerHwPort 1
omx api setparam tvp 0 0 0 OMX_TI_IndexParamVFCCHwPortProperties
omx setp 0 tvp OMX_TI_IndexParamCTRLVidDecInfo videoStandard 720P60
omx setp 0 tvp OMX_TI_IndexParamCTRLVidDecInfo videoDecoderId tvp7002
omx setp 0 tvp OMX_TI_IndexParamCTRLVidDecInfo videoSystemId auto_detect
omx api setparam tvp 0 0 0 OMX_TI_IndexParamCTRLVidDecInfo
#SET ALL THE PARAMS FOR VFCC
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortID eHwPortId vip1_porta
omx api setparam vfcc 0 0 0 OMX_TI_IndexParamVFCCHwPortID
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortProperties eCaptMode sc_non_mux
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortProperties eVifMode 16_bit
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortProperties eInColorFormat 422YUYV
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortProperties eScanType progressive
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortProperties nMaxWidth 1280
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortProperties nMaxHeight 720
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortProperties nMaxChnlsPerHwPort 1
omx api setparam vfcc 0 0 0 OMX_TI_IndexParamVFCCHwPortProperties
omx setp 0 vfcc OMX_TI_IndexParamBuffMemType eBufMemoryType default
omx api setparam  vfcc 0 0 0  OMX_TI_IndexParamBuffMemType
omx setp 0 vfcc OMX_IndexParamCompBufferSupplier eBufferSupplier unspecified
#omx api setparam  vfcc 0 0 0  OMX_IndexParamCompBufferSupplier
omx setp 0 vfcc OMX_TI_IndexConfigVFCCFrameSkip frameSkipMask 0
#omx api setconfig  vfcc 0 0 0  OMX_TI_IndexConfigVFCCFrameSkip
omx setp 0 vfcc OMX_IndexParamVideoInit nPorts 16
omx setp 0 vfcc OMX_IndexParamVideoInit nStartPortNumber 0
#omx api setparam  vfcc 0 0 0  OMX_IndexParamVideoInit
omx setp 0 dei OMX_TI_IndexParamVFPCNumChPerHandle nNumChannelsPerHandle 1
omx api setparam dei 0 0 0 OMX_TI_IndexParamVFPCNumChPerHandle
omx setp 0 dei OMX_TI_IndexConfigAlgEnable bAlgBypass enable
omx setp 0 dei OMX_TI_IndexConfigAlgEnable nChId 0
omx api setconfig dei 0 0 0 OMX_TI_IndexConfigAlgEnable
omx setp 0 dei OMX_TI_IndexConfigSubSamplingFactor nSubSamplingFactor 1
omx api setconfig dei 0 0 0 OMX_TI_IndexConfigSubSamplingFactor
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm0Width  1280
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm0Height 720
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm0Pitch  1280
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm1Width  0
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm1Height 0
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm1Pitch  0
omx setp 0 dei OMX_TI_IndexConfigVidChResolution FrmStartX  0
omx setp 0 dei OMX_TI_IndexConfigVidChResolution FrmStartY  0
omx setp 0 dei OMX_TI_IndexConfigVidChResolution FrmCropWidth 1280
omx setp 0 dei OMX_TI_IndexConfigVidChResolution FrmCropHeight 720
omx setp 0 dei OMX_TI_IndexConfigVidChResolution eDir input
omx setp 0 dei OMX_TI_IndexConfigVidChResolution nChId 0
omx api setconfig dei 0 0 0  OMX_TI_IndexConfigVidChResolution
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm0Pitch  2560
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm1Width  1280
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm1Height 720
omx setp 0 dei OMX_TI_IndexConfigVidChResolution Frm1Pitch  1280
omx setp 0 dei OMX_TI_IndexConfigVidChResolution eDir output
omx api setconfig dei 0 0 16  OMX_TI_IndexConfigVidChResolution
omx setp 0 dei OMX_TI_IndexParamBuffMemType eBufMemoryType default
omx api setparam  dei  0 0 0  OMX_TI_IndexParamBuffMemType
omx api setparam  dei 0 0 16  OMX_TI_IndexParamBuffMemType
omx api setparam  dei 0 0 17  OMX_TI_IndexParamBuffMemType
omx setp 0 dei OMX_TI_IndexParamCompPortNotifyType eNotifyType always
#omx api setparam  dei  0 0 0  OMX_TI_IndexParamCompPortNotifyType
#omx api setparam  dei  0 0 16  OMX_TI_IndexParamCompPortNotifyType
#omx api setparam dei 0 0 17   OMX_TI_IndexParamCompPortNotifyType
omx setp 0 dei OMX_IndexParamCompBufferSupplier eBufferSupplier unspecified
omx setp 0 dei OMX_IndexParamVideoInit nPorts 3
omx setp 0 dei OMX_IndexParamVideoInit nStartPortNumber 0
omx api getparam  dei 0 0 0 OMX_IndexParamPortDefinition
omx setp 0 dei OMX_IndexParamPortDefinition video.nStride 1280
omx api setparam  dei 0 0 0 OMX_IndexParamPortDefinition
omx api getparam  h264venc 0 0 0 OMX_IndexParamPortDefinition
omx setp 0 h264venc OMX_IndexParamPortDefinition video.nStride 1280
omx api setparam  h264venc 0 0 0 OMX_IndexParamPortDefinition
omx setp 0 vfdc OMX_TI_IndexParamVFDCDriverInstId nDrvInstID 0
omx setp 0 vfdc OMX_TI_IndexParamVFDCDriverInstId eDispVencMode 720p60
omx api setparam  vfdc 0 0 0 OMX_TI_IndexParamVFDCDriverInstId
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout winStartX 0
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout winStartY 0
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout winWidth 1280
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout winHeight 720
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout pitch.VFDC_YUV_INT_ADDR_IDX 2560
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout pitch.VFDC_YUV_SP_Y_ADDR_IDX 2560
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout pitch.VFDC_YUV_SP_CBCR_ADDR_IDX 2560
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout dataFormat 422I_YUYV
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout bpp bits16
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout priority 0
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout nLayoutId 0
omx setp 0 vfdc mosaicNumRows 1
omx setp 0 vfdc mosaicNumCols 1
omx setp 0 vfdc mosaicDispWindowWidth 1280
omx setp 0 vfdc mosaicDispWindowHeight 720
omx api setparam  vfdc 0 0 0 OMX_TI_IndexParamVFDCCreateMosaicLayout
omx setp 0 vfdc OMX_TI_IndexConfigVFDCMosaicPort2WinMap nLayoutId 0
omx api setconfig vfdc 0 0 0 OMX_TI_IndexConfigVFDCMosaicPort2WinMap 1 0
omx setp 0 vfdc OMX_TI_IndexParamBuffMemType eBufMemoryType default
omx setp 0 vfdc OMX_IndexParamCompBufferSupplier eBufferSupplier unspecified
omx setp 0 vfdc OMX_IndexParamVideoInit nPorts 1
omx setp 0 vfdc OMX_IndexParamVideoInit nStartPortNumber 0
omx api getparam  vfdc 0 0 0 OMX_IndexParamPortDefinition
omx setp 0 vfdc OMX_IndexParamPortDefinition video.nStride 2560
omx api setparam  vfdc 0 0 0 OMX_IndexParamPortDefinition
#SET ALL THE PARAMS FOR DC#0
omx setp 0 dc OMX_TI_IndexParamVFDCDriverInstId nDrvInstID 0
omx setp 0 dc OMX_TI_IndexParamVFDCDriverInstId eDispVencMode 720p60
omx api setparam  dc 0 0 0 OMX_TI_IndexParamVFDCDriverInstId
omx api sendcommand port vfcc 0 enable 0
omx api sendcommand port vfcc 0 waitforsem 0
omx api sendcommand port dei 0 enable 0
omx api sendcommand port dei 0 waitforsem 0
omx api sendcommand port dei 0 enable 16
omx api sendcommand port dei 0 waitforsem 16
omx api sendcommand port dei 0 enable 17
omx api sendcommand port dei 0 waitforsem 17
omx api sendcommand port vfdc 0 enable 0
omx api sendcommand port vfdc 0 waitforsem 0
omx api sendcommand port h264venc 0 enable 0
omx api sendcommand port h264venc 0 waitforsem 0
omx api sendcommand port h264venc 0 enable 1
omx api sendcommand port h264venc 0 waitforsem 1
omx api connect vfcc 0 0 dei 0 0
omx api connect dei 0 16 vfdc 0 0
omx api connect dei 0 17 h264venc 0 0
omx api sendcommand state vfcc 0 idle
omx api sendcommand state vfcc 0 waitforsem
omx api sendcommand state tvp 0 idle
omx api sendcommand state tvp 0 waitforsem
omx api sendcommand state dei 0 idle
omx api sendcommand state dei 0 waitforsem
omx api sendcommand state dc 0 idle
omx api sendcommand state dc 0 waitforsem
omx api sendcommand state vfdc 0 idle
omx api sendcommand state vfdc 0 waitforsem
omx api sendcommand state h264venc 0 idle
omx api sendcommand state h264venc 0 waitforsem
omx api sendcommand state dc 0 exec
omx api sendcommand state vfdc 0 exec
omx api sendcommand state vfcc 0 exec
omx api sendcommand state dei 0 exec
omx api sendcommand state h264venc 0 exec
omx api sendcommand state tvp 0 exec
sleep 60000
omx api sendcommand state h264venc 0 loaded
omx api sendcommand state vfcc 0 loaded
omx api sendcommand state tvp 0 loaded
omx api sendcommand state dei 0 loaded
omx api sendcommand state dc 0 loaded
omx api sendcommand state vfdc 0 loaded
omx api freehandle vfcc 0
omx api freehandle tvp 0
omx api freehandle dei 0
omx api freehandle dc 0
omx api freehandle vfdc 0
omx api freehandle h264venc 0
omx api uninit
