I2S LRClock settling time?
We are using a McBSP as an I2S interface to send data to an audio chip.
The audio chip and the McBSP share the same 8 MHz clock.
The McBSP sample rate generator is configured to divide down the external clock providing the LR clock as wekk as the bit clock.
Currently I mm enabling and disabling the clocks before and after I2S transmission.
Lately we have seen (actually heard) some heat related problems.
Does the McBSP Sample Rate Generator require a settling time before transmitting data?
Thanks.
    I'm not aware of any need for settling time.  The McBSP Sample Rate Generator is a series of dividers.  There is no PLL (Phase Locked Loop) circuit inside that would require some lock time.
  • Thanks.
    We have found a hardware issu with the bit clock that caused our problem.
