In recovery mode HDMI can work?
Dear SIR,
i use 4470 tablet2 platform and try this function in 4AI.1.3.
HDMI can work fine in normal mode but not work in recovery mode.
In recovery mode .When  HDMI cable insert we can see some log about EDID.
below log is "normal mode log".
[ 1649.631072] hpd 1
[ 1649.672088] in hpd work 1, state=0
[ 1649.675903] omapdss HDMI: ENTER hdmi_display_enable
[ 1649.681396] omapdss HDMI: Set c-state constraint for HDMI
[ 1649.681427]
[ 1649.689300] HDCP: invalid AKSV
[ 1649.692749] omapdss HDMI error: *** INVALID AKSV: 0 Do not perform HDCP AUTHENTICATION
[ 1649.757080] in hpd work 2, state=1
[ 1650.413818] edid[000] = 00 ff ff ff ff ff ff 00 04 69 f7 27 bc 39 01 00
[ 1650.421295] edid[010] = 14 15 01 03 80 3c 22 78 2a ee d5 a5 55 48 9b 26
[ 1650.428436] edid[020] = 12 50 54 b7 ef 00 71 4f 81 c0 81 40 81 80 95 00
[ 1650.435638] edid[030] = b3 00 d1 c0 01 01 02 3a 80 18 71 38 2d 40 58 2c
[ 1650.442810] edid[040] = 45 00 56 50 21 00 00 1e 00 00 00 ff 00 42 35 4c
[ 1650.450012] edid[050] = 4d 54 46 30 38 30 33 31 36 0a 00 00 00 fd 00 32
[ 1650.457244] edid[060] = 55 18 5c 11 00 0a 20 20 20 20 20 20 00 00 00 fc
[ 1650.464324] edid[070] = 00 41 53 55 53 20 56 4b 32 37 38 0a 20 20 01 e3
[ 1650.471466] edid[080] = 02 03 22 71 4f 01 02 03 11 12 13 04 14 05 0e 0f
[ 1650.478546] edid[090] = 1d 1e 1f 10 23 09 07 01 83 01 00 00 65 03 0c 00
[ 1650.485687] edid[0a0] = 10 00 8c 0a d0 8a 20 e0 2d 10 10 3e 96 00 56 50
[ 1650.492797] edid[0b0] = 21 00 00 18 01 1d 00 72 51 d0 1e 20 6e 28 55 00
[ 1650.499877] edid[0c0] = 56 50 21 00 00 1e 01 1d 00 bc 52 d0 1e 20 b8 28
[ 1650.507019] edid[0d0] = 55 40 56 50 21 00 00 1e 8c 0a d0 90 20 40 31 20
[ 1650.514099] edid[0e0] = 0c 40 55 00 56 50 21 00 00 18 00 00 00 00 00 00
[ 1650.521240] edid[0f0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 93
[ 1650.528381] edid[100] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 1650.535461] edid[110] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 1650.542602] edid[120] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 1650.549774] edid[130] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 1650.556915] edid[140] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 1650.563995] edid[150] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 1650.571136] edid[160] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 1650.578277] edid[170] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 1650.585357] edid[180] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 1650.592498] edid[190] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 1650.599578] edid[1a0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 1650.606719] edid[1b0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 1650.613861] edid[1c0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 1650.620971] edid[1d0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 1650.628112] edid[1e0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 1650.635223] edid[1f0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 1650.642486] panel size 60 by 34
[ 1650.647064] omapdss HDMI: Enter omapdss_hdmi_display_set_mode
[ 1650.662750] omapdss HDMI: Enter hdmi_display_disable
[ 1650.668121] omapdss HDMI: Release c-state constraint for HDMI
[ 1650.668121]
[ 1650.675994] hdmi: clearing EDID info
[ 1650.679870] omapdss HDMI: ENTER hdmi_display_enable
[ 1650.685150] omapdss HDMI: Set c-state constraint for HDMI
[ 1650.685150]
[ 1650.692626] HDCP: invalid AKSV
[ 1650.695953] hdcp_3des_cb: hdcp_keys not loaded = 0
[ 1650.700927] omapdss HDMI error: *** INVALID AKSV: 0 Do not perform HDCP AUTHENTICATION
 We compare log between recovery and normal mode when HDMI cable insert.
In recovery mode.there are lose "omapdss HDMI: Enter omapdss_hdmi_display_set_mode".
this function seems trigger by high level function.
Can you help to check HDMI can or can not work in recovery mode in 4AI.1.3.
Or which version software can support hdmi output in recovery mode.
thanks
