Other Parts Discussed in Thread: CCSTUDIO
Running CCSv5.2 on Windows I encountered the exception at the end of the post, when double-clicking on a .cfg-File in the Project Explorer.
Please forward this error to the developers.
Thank you in advance, Clemens Eisserer
java.lang.NullPointerException
at org.eclipse.rtsc.xdctools.
model.ui.jobs.RepositoryViewJob.initialize(RepositoryViewJob.java:119)
at org.eclipse.rtsc.xdctools.model.ui.views.CombinedViewContentProvider.initialize(CombinedViewContentProvider.java:181)
at org.eclipse.rtsc.xdctools.model.viewer.ModelObjectViewerContentProvider.getElements(ModelObjectViewerContentProvider.java:176)
at org.eclipse.jface.viewers.StructuredViewer.getRawChildren(StructuredViewer.java:1010)
at org.eclipse.jface.viewers.ColumnViewer.getRawChildren(ColumnViewer.java:703)
at org.eclipse.jface.viewers.AbstractTreeViewer.getRawChildren(AbstractTreeViewer.java:1336)
at org.eclipse.jface.viewers.TreeViewer.getRawChildren(TreeViewer.java:391)
at org.eclipse.jface.viewers.StructuredViewer.getFilteredChildren(StructuredViewer.java:917)
at org.eclipse.jface.viewers.AbstractTreeViewer.getSortedChildren(AbstractTreeViewer.java:605)
at org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractTreeViewer.java:805)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:782)
at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeViewer.java:644)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:753)
at org.eclipse.jface.viewers.AbstractTreeViewer.internalInitializeTree(AbstractTreeViewer.java:1533)
at org.eclipse.jface.viewers.TreeViewer.internalInitializeTree(TreeViewer.java:833)
at org.eclipse.jface.viewers.AbstractTreeViewer$5.run(AbstractTreeViewer.java:1517)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1443)
at org.eclipse.jface.viewers.TreeViewer.preservingSelection(TreeViewer.java:403)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1404)
at org.eclipse.jface.viewers.AbstractTreeViewer.inputChanged(AbstractTreeViewer.java:1510)
at org.eclipse.ui.dialogs.FilteredTree$NotifyingTreeViewer.inputChanged(FilteredTree.java:1187)
at org.eclipse.jface.viewers.ContentViewer.setInput(ContentViewer.java:280)
at org.eclipse.jface.viewers.StructuredViewer.setInput(StructuredViewer.java:1690)
at org.eclipse.rtsc.xdctools.model.ui.views.AvailableModulesPage.createControl(AvailableModulesPage.java:324)
at org.eclipse.rtsc.xdctools.model.ui.views.PackageView.doCreatePage(PackageView.java:52)
at org.eclipse.ui.part.PageBookView.createPage(PageBookView.java:408)
at org.eclipse.ui.part.PageBookView.partActivated(PageBookView.java:751)
at org.eclipse.ui.part.PageBookView.showBootstrapPart(PageBookView.java:920)
at org.eclipse.ui.part.PageBookView.createPartControl(PageBookView.java:491)
at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewReference.java:375)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:229)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.Perspective.showView(Perspective.java:2245)
at org.eclipse.ui.internal.WorkbenchPage.busyShowView(WorkbenchPage.java:1145)
at org.eclipse.ui.internal.WorkbenchPage$20.run(WorkbenchPage.java:3921)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage.java:3918)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage.java:3894)
at org.eclipse.rtsc.xdctools.model.ui.editors.ProgramConfigurationEditor.showOutlineViews(ProgramConfigurationEditor.java:2038)
at org.eclipse.rtsc.xdctools.model.ui.editors.ProgramConfigurationEditor.access$6(ProgramConfigurationEditor.java:2005)
at org.eclipse.rtsc.xdctools.model.ui.editors.ProgramConfigurationEditor$1.run(ProgramConfigurationEditor.java:786)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
