/* module-specific initialization */
iStat = ti_sysbios_family_msp430_Hwi_Instance_init__F(obj, args->intNum, args->hwiFxn, &prms, eb);
Code executed:
char UART3_received_char;
Swi_Handle swi0_buffer_uart3;
Hwi_Handle hwi0_UART3;
void receiver_init()
{ Error_Block eb;
Error_init(&eb);
Swi_Params swi0Params;
Swi_Params_init(&swi0Params);
//swi0Params.instance->name = "swi0_buffer_uart3";
swi0Params.priority = 14;
swi0_buffer_uart3 = Swi_create((Swi_FuncPtr)save_in_uart3_buffer, &swi0Params, &eb);
if(swi0_buffer_uart3==NULL)
{return;}
Hwi_Params hwi0USBParams;
Hwi_Params_init(&hwi0USBParams);
//hwi0USBParams.instance->name = "hwi0_UART3";
hwi0USBParams.maskSetting = ti_sysbios_interfaces_IHwi_MaskingOption_ALL;
hwi0USBParams.priority= 0;
Error_init(&eb);
hwi0_UART3 = Hwi_create(44, (Hwi_FuncPtr)Uart3_Hwi_handler, &hwi0USBParams, &eb);
if(hwi0_UART3==NULL)
{return;}
void Uart3_Hwi_handler(void)
UART3_received_char=UCA3RXBUF;
Swi_post((Swi_Handle)swi0_buffer_uart3);
//Swi_post(save_in_uart3_buffer);
#ifdef ECHO
UART3_Transmit(UART3_received_char);
#endif
char uart3_buffer[BUFFER_SIZE];
unsigned int write_uart3_buffer=0;
char is_entered=4;
void save_in_uart3_buffer(void)
/* uart3_buffer[write_uart3_buffer]=UART3_received_char;
write_uart3_buffer++;
if(write_uart3_buffer>=BUFFER_SIZE)
write_uart3_buffer=0;*/
is_entered=1;
Void main()
Led_Init();
Led1_On();
P11DIR = P11DIR | 0x02 | 0x04 |0x01 ; //set P11.1 & P11.2 as output
P11SEL = P11SEL | 0x02 | 0x04 |0x01 ; //set P11.1 & P11.2 as MCLK/SMCLK/aclk function
UART3_Init(ACLK, 9600);//function that configure baudrate
USB_receiver_init();
BIOS_start(); /* enable interrupts and start SYS/BIOS */
This is the Error I get on my Console:
ti.sysbios.family.msp430.Hwi: line 210: E_notImplemented: Function not implemented: Hwi_create
xdc.runtime.Error.raise: terminating execution
Application Configuration file:
var Defaults = xdc.useModule('xdc.runtime.Defaults');
var Diags = xdc.useModule('xdc.runtime.Diags');
var Error = xdc.useModule('xdc.runtime.Error');
var Log = xdc.useModule('xdc.runtime.Log');
var LoggerBuf = xdc.useModule('xdc.runtime.LoggerBuf');
var Main = xdc.useModule('xdc.runtime.Main');
var Memory = xdc.useModule('xdc.runtime.Memory')
var SysMin = xdc.useModule('xdc.runtime.SysMin');
var System = xdc.useModule('xdc.runtime.System');
var Text = xdc.useModule('xdc.runtime.Text');
var BIOS = xdc.useModule('ti.sysbios.BIOS');
var Clock = xdc.useModule('ti.sysbios.knl.Clock');
var Swi = xdc.useModule('ti.sysbios.knl.Swi');
var Task = xdc.useModule('ti.sysbios.knl.Task');
var Semaphore = xdc.useModule('ti.sysbios.knl.Semaphore');
var Hwi = xdc.useModule('ti.sysbios.family.msp430.Hwi');
var Agent = xdc.useModule('ti.sysbios.rta.Agent');
var Timestamp = xdc.useModule('xdc.runtime.Timestamp');
var Idle = xdc.useModule('ti.sysbios.knl.Idle');
//var ClockFreqs = xdc.useModule('ti.sysbios.family.msp430.ClockFreqs'); //ce l'ho aggiunta io
* Program.argSize sets the size of the .args section.
* The examples don't use command line args so argSize is set to 0.
Program.argSize = 0x0;
* Uncomment this line to globally disable Asserts.
* All modules inherit the default from the 'Defaults' module. You
* can override these defaults on a per-module basis using Module.common$.
* Disabling Asserts will save code space and improve runtime performance.
Defaults.common$.diags_ASSERT = Diags.ALWAYS_OFF;
* Uncomment this line to keep module names from being loaded on the target.
* The module name strings are placed in the .const section. Setting this
* parameter to false will save space in the .const section. Error and
* Assert messages will contain an "unknown module" prefix instead
* of the actual module name.
Defaults.common$.namedModule = false;
* Minimize exit handler array in System. The System module includes
* an array of functions that are registered with System_atexit() to be
* called by System_exit().
System.maxAtexitHandlers = 4;
* Uncomment this line to disable the Error print function.
* We lose error information when this is disabled since the errors are
* not printed. Disabling the raiseHook will save some code space if
* your app is not using System_printf() since the Error_print() function
* calls System_printf().
Error.raiseHook = null;
* Uncomment this line to keep Error, Assert, and Log strings from being
* loaded on the target. These strings are placed in the .const section.
* Setting this parameter to false will save space in the .const section.
* Error, Assert and Log message will print raw ids and args instead of
* a formatted message.
Text.isLoaded = false;
* Uncomment this line to disable the output of characters by SysMin
* when the program exits. SysMin writes characters to a circular buffer.
* This buffer can be viewed using the SysMin Output view in ROV.
SysMin.flushAtExit = false;
* The BIOS module will create the default heap for the system.
* Specify the size of this default heap.
BIOS.heapSize = 4096;
/* System stack size (used by ISRs and Swis) */
Program.stack = 0x800;
/* Circular buffer size for System_printf() */
SysMin.bufSize = 512;
* Create and install logger for the whole system
var loggerBufParams = new LoggerBuf.Params();
loggerBufParams.numEntries = 32;
var logger0 = LoggerBuf.create(loggerBufParams);
Defaults.common$.logger = logger0;
Main.common$.diags_INFO = Diags.ALWAYS_ON;
System.SupportProxy = SysMin;
Clock.tickPeriod = 1000000;
Clock.tickSource = Clock.TickSource_TIMER;
Agent.sysbiosSwiLogging = true;
Hwi.common$.namedInstance = false;
BIOS.taskEnabled = true;
BIOS.swiEnabled = true;
BIOS.clockEnabled = true;
