Hi all,
Me ne to the Lua and i want to port lua onto OMAP AM37 EVM .
And i want to call c functions from LUa.
How to run LUA programms on EVM..LEt me know if any things about LUA on OMAP to move fother..
Hi all,
Cross compile Lua like:
$ make linux CC="path-to-arm-gcc" AR="path-to-arm-ar rcu" RANLIB="path-to-arm-ranlib"
(Not sure why Lua authors were opposed to $(CROSS_COMPILE) in their makefile.)
To call C functions from Lua, there are good references online:
http://www.lua.org/pil/26.html
or
http://lua-users.org/wiki/SimpleLuaApiExample
HTH
Hi
Thanks For u r support.
I done following steps. Please assest me . How can i copy cross compiled Lua suite onto the tha target with our compiled image and target filesystem.
1. Compiled as per u r lines.
2. Compilation does not give any error
3. Next how to add these compiled Lus5.1.4(what am using) into the target. I mean porting.
4. I have compiled kernel image and target file system
Please Help us to make success.
-Gopi
Hi Below is the my comipilation command
# sudo make linux CC=arm-arago-linux-gnueabi- AR=arm-arago-linux-gnueabi-ar RANLIB=arm-arago-linux-gnueabi-ranlib
Here cross tool chain env is already set.
So could u plase help me to load it onto the Omap Target. and run lua scripts
-Gopi
I am unable to compile lua5.1.4 code on ubuntu 10.04 machine with crosscompiler commnd below:
any one, Please help me to which lua source code to download , and how to compile that source code. and hot to load it onto OMap processor.
Currently we are using OMap processors. It was urgent. Please guide me.
-Gopi
Here's a crazy thought ... maybe you should show people the compilation errors you are getting? You might also want to think of an alternate plan, because copying executables to your target is fairly basic. Maybe you need some consulting support.
I am compiling lua5.2.1 with folowing command. Then all .o files are created but it was struck up ar arm-arago-linux-gnueabi-ar rcu,
Please tell me whats wrong wioth me.
gpravada@ubuntu:~/Downloads/lua-5.2.1$ make linux CC=arm-arago-linux-gnueabi-gcc AR=arm-arago-linux-gnueabi-ar rcu RANLIB=arm-arago-linux-gnueabi-ranlib
No emulation specific options
arm-arago-linux-gnueabi-ar: supported targets: elf32-littlearm elf32-bigarm elf32-little elf32-big srec symbolsrec tekhex binary ihex
make[2]: *** [liblua.a] Error 1
make[2]: Leaving directory `/home/gpravada/Downloads/lua-5.2.1/src'
make[1]: *** [linux] Error 2
make[1]: Leaving directory `/home/gpravada/Downloads/lua-5.2.1/src' make: *** [linux] Error 2
Please help me here
Try with quotes around your AR definition, i.e.: AR="arm-arago-linux-gnueabi-ar rcu" . Otherwise, you will lose the "rcu".
Compilation report:
gpravada@ubuntu:~/Downloads/lua-5.2.1$ make linux CC=arm-arago-linux-gnueabi-gcc AR="arm-arago-linux-gnueabi-ar rcu" RANLIB=arm-arago-linux-gnueabi-ranlib
cd src && make linux
make[1]: Entering directory `/home/gpravada/Downloads/lua-5.2.1/src'
make all SYSCFLAGS="-DLUA_USE_LINUX" SYSLIBS="-Wl,-E -ldl -lreadline -lncurses"
make[2]: Entering directory `/home/gpravada/Downloads/lua-5.2.1/src'
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o lapi.o lapi.c
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o lcode.o lcode.c
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o lctype.o lctype.c
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o ldebug.o ldebug.c
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o ldo.o ldo.c
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o ldump.o ldump.c
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o lfunc.o lfunc.c
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o lgc.o lgc.c
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o llex.o llex.c
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o lmem.o lmem.c
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o lobject.o lobject.c
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o lopcodes.o lopcodes.c
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o lparser.o lparser.c
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o lstate.o lstate.c
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o lstring.o lstring.c
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o ltable.o ltable.c
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o ltm.o ltm.c
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o lundump.o lundump.c
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o lvm.o lvm.c
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o lzio.o lzio.c
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o lauxlib.o lauxlib.c
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o lbaselib.o lbaselib.c
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o lbitlib.o lbitlib.c
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o lcorolib.o lcorolib.c
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o ldblib.o ldblib.c
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o liolib.o liolib.c
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o lmathlib.o lmathlib.c
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o loslib.o loslib.c
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o lstrlib.o lstrlib.c
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o ltablib.o ltablib.c
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o loadlib.o loadlib.c
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o linit.o linit.c
arm-arago-linux-gnueabi-ar rcu liblua.a lapi.o lcode.o lctype.o ldebug.o ldo.o ldump.o lfunc.o lgc.o llex.o lmem.o lobject.o lopcodes.o lparser.o lstate.o lstring.o ltable.o ltm.o lundump.o lvm.o lzio.o lauxlib.o lbaselib.o lbitlib.o lcorolib.o ldblib.o liolib.o lmathlib.o loslib.o lstrlib.o ltablib.o loadlib.o linit.o
arm-arago-linux-gnueabi-ranlib liblua.a
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o lua.o lua.c
arm-arago-linux-gnueabi-gcc -o lua lua.o liblua.a -lm -Wl,-E -ldl -lreadline -lncurses
arm-arago-linux-gnueabi-gcc -O2 -Wall -DLUA_COMPAT_ALL -DLUA_USE_LINUX -c -o luac.o luac.c
arm-arago-linux-gnueabi-gcc -o luac luac.o liblua.a -lm -Wl,-E -ldl -lreadline -lncurses
Install Report:
gpravada@ubuntu:~/Downloads/lua-5.2.1$ sudo make linux CC=arm-arago-linux-gnueabi-gcc AR="arm-arago-linux-gnueabi-ar rcu" RANLIB=arm-arago-linux-gnueabi-ranlib install
make[2]: Nothing to be done for `all'.
cd src && mkdir -p /usr/local/bin /usr/local/include /usr/local/lib /usr/local/man/man1 /usr/local/share/lua/5.2 /usr/local/lib/lua/5.2
cd src && install -p -m 0755 lua luac /usr/local/bin
cd src && install -p -m 0644 lua.h luaconf.h lualib.h lauxlib.h lua.hpp /usr/local/include
cd src && install -p -m 0644 liblua.a /usr/local/lib
cd doc && install -p -m 0644 lua.1 luac.1 /usr/local/man/man1
Thanks FOr u r Help. above is my compilation an dinstallation ouput.
Make sure me that this is corret or wrong. If it is wrong guide me if any other way is to do cross compiling lua.
If compilation and instyallation output is OK then plaese tell me how to add this to our kernel image which is used to run on Omap Target alogn with lua.
I want to load this cross compiled lua onto OMAP EVM so please guide me . I KNOW KERENL COMPILATION AND LOADNG ONTO THE TARGET(SUCCESSFULL).
But i dont know how to add this to OMAP Target. Guide me please
-GOpi
Hello all,
Ay one can help me please its delayed to my work i tried in above way
.-Gopi
I cross compiled lua for arm architecture by doing folloing command. We use lua5.2.1 source code.
1. Copied lua5.2.1 into path on ubuntu machine: /home/gpravada/Downloads/lua-5.2.1,
2. Went to /home/gpravada/Downloads/lua-5.2.1,
3. gpravada@ubuntu:~/Downloads/lua-5.2.1$ make linux CC=arm-arago-linux-gnueabi-gcc AR="arm-arago-linux-gnueabi-ar rcu" RANLIB=arm-arago-linux-gnueabi-ranlib
4. And i copied liblua.a , lua and luac files into SD Card file system into /home/root folder.
5. i inserted sd card which having immage and filesystem in it.
6. After booting successfully . i went to the /home/root directory and executed following:
7. root@dm37x-evm:/# cd home/root/
8. root@dm37x-evm:~# cd lua-5.2.1/
9. root@dm37x-evm:~/lua-5.2.1# ./lua
I got belllow error:
./lua: error while loading shared libraries: libreadline.so.5: cannot open shared object file: No such file or directory
Please tell me the solution to run lua engine on arm architeture . Currently i am using DM3737 Omap based EVM..
Thanks & REgards,
-Gopi
The error is telling you exactly what's wrong -- you don't have the readline library installed on the target. It is optional, in src/luaconf.h comment out the lines that have "LUA_USE_READLINE" and in src/Makefile remove "-lreadline".
Thanks, I Got it. This is the small excerice on OMAP Target.
root@dm37x-evm:~# ./lua
Lua 5.2.1 Copyright (C) 1994-2012 Lua.org, PUC-Rio
> a = 10
> b = 20
> print(a+b)
30
> print(a+b)
30
> print(a+b) stdin:1: syntax error near char(8)
> a=10
> b=20
> print(a/b)
0.5
> print(a+b)
30
Now i will do some practices on Target. I will in touch with u if any probs.. Once agaon thanks....
-Gop
