No callbacks being executed in capture_encode
Guru 10685 points
Hi, I'm trying to get the capture_encode demo to work with my bespoke DM8168-based board.
I modified the demo as per this post by Archith John Bency:
http://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/717/p/138320/500087.aspx#500087
Unfortunately, I am finding that no callbacks at all are being executed in capture_encode OpenMAX demo, using 24bit RGB direct input from an FPGA with discrete sync (specifically I'm looking at the capture component's callbacks).
I'm getting slight deja vu here as I had similar problems with the V4L2 input capture driver.
I attach my source code for the main 2 source files of the demo and would be really grateful if someone could help me to get the capture component to take in frames.
Ralph
  • I can only attach 1 file per post so here is the other significant source file.
    While I'm here, here is the relevant section of my "arch/arm/mach-omap2/ti81xx_vpss.c" file which tells you about my input signal setup (I know that this is only relevant if you use the V4L2 driver which I am not, but the idea is to show you what I've had working elsewhere):
    .vip_port_cfg = {
                // Control Channel Selection. It describes channels numbers from extract control code and Vertical Ancillary Data.
                .ctrlChanSel = VPS_VIP_CTRL_CHAN_SEL_15_8,
                // Gives the imformation in 8b interface mode from where to extract Vertical Ancillary data.
                .ancChSel8b = VPS_VIP_ANC_CH_SEL_DONT_CARE,
                // Pixel clock edge polarity
                .pixClkEdgePol = VPS_VIP_PIX_CLK_EDGE_POL_RISING,
                // FALSE: Keep FID as found, TRUE: Invert Value of FID
                .invertFidPol = 0,      // Irrelevant because no interlacing
                // Configuration parameter specific to Embedded Sync mode
                .embConfig =
                          .errCorrEnable = 1,
                          // In embedded sync for 2x/4x mux mode there are two ways to extract source number, one is from least significant nibble of the XV/fvh codew$
                          .srcNumPos = VPS_VIP_SRC_NUM_POS_DONT_CARE,
                          .isMaxChan3Bits = 0,
                // Configuration parameter specific to Discrete Sync mode
                .disConfig =
                          // Post count value when using vsync skew in FID determination
                          .fidSkewPostCnt = 0,
                          // Pre count value when using vsync skew in FID determination
                          .fidSkewPreCnt = 0,
                          .lineCaptureStyle =
                                     // Rest of these only for discrete sync
                                     VPS_VIP_LINE_CAPTURE_STYLE_ACTVID,
                          .fidDetectMode =
                                     VPS_VIP_FID_DETECT_MODE_PIN,    // MODE_PIN selected for future use when we do interlacing
                          .actvidPol = VPS_VIP_POLARITY_HIGH,
                          .vsyncPol = VPS_VIP_POLARITY_HIGH,
                          .hsyncPol = VPS_VIP_POLARITY_HIGH,
     .video_capture_mode =  VPS_CAPT_VIDEO_CAPTURE_MODE_SINGLE_CH_NON_MUX_DISCRETE_SYNC_HSYNC_VSYNC,
     .video_if_mode = VPS_CAPT_VIDEO_IF_MODE_24BIT,
     .input_data_format = FVID2_DF_RGB24_888,
    Ralph
    I don't think vip_port_cfg structure is getting passed to VIP Capture driver on M3 side. As far as I know there is not indexing done for that structure to be initialized i IL client. So this structure will remains uninitialized in M3 drivers and because of this it will not work.
    Hardik Shah
  • I'm not using the V4L2 driver as I said. I only put the vip_port_cfg structure in my post so you could see what my capture settings might look like in capture_encode.
    So do you know why capture_encode is not working?
    Ralph
  • Anyone?
    Is there any way I can get more debug information from the OpenMAX framework?
    Ralph
  • Still waiting to hear back from TI on this....
  • Ralph,
    Did you try dumping Media Controller traces, and/or increasing debug levels,
    as noted here:
         http://processors.wiki.ti.com/index.php/OMX_Viewing_Media_Controller_Traces
    In your case, the vpss trace would probably be most useful.
    John Whittington
  • Hi John,
    Thanks for the reply.
    I ran
    ./loggerSMDump.out 0x9E400000 0x200000 all &
    followed by
    ./capture_encode_a8host_debug.xv5T -o sample.h264 -m 1080p -f 60 -b 1000000 -d 0 -n 1000
    However the .bin file that is produced by the logger program was empty. Also, there were no debug messages on screen.
    What did you do to get your debugging working? I have literally copied across the capture_encode and loggSMDump.out programs from the EZSDK. I have run /usr/local/share/ti/ti-media-controller-utils/load-hd-firmware.sh immediately after booting in order to get the video firmware running.
    Can someone help me get some logging output?
    Ralph
  • I've got it working by using the argument for "size" as 0x100000. The linked webpage was wrong about what the "size" command line argument should be.
    Ralph
  • Okay, here's the output for both VPSS and video at DEBUG_LEVEL0. It ends with the ominous line "VIP-0 PORT-A Dropped Frame Count :1 Total Capture Frame Count 0". :-S
    Opened loggerSM.bin to store encoded records
    N:Video P:1 #:00000 T:00000000019c3a07 S:Enabling Status Logger
    N:VPSS  P:2 #:00000 T:000000001e8cc8e1 S:Enabling Status Logger
    N:Video P:1 #:00001 T:00000000019c749b S:Enabling User1 Logs
    N:VPSS  P:2 #:00001 T:000000001e8d009f S:Enabling User1 Logs
    N:Video P:1 #:00002 T:00000000019cc5b9 S:Disabling User1 Logs
    N:VPSS  P:2 #:00002 T:000000001e8d50a7 S:Disabling User1 Logs
    N:Video P:1 #:00003 T:00000000019d0c5b S:Disabling User1 Logs
    N:VPSS  P:2 #:00003 T:000000001e8d9605 S:Disabling User1 Logs
    N:Video P:1 #:00004 T:00000000019d530d S:Disabling User1 Logs
    N:VPSS  P:2 #:00004 T:000000001e8ddae5 S:Disabling User1 Logs
    N:Video P:1 #:00005 T:00000000019d995d S:Disabling User1 Logs
    N:VPSS  P:2 #:00005 T:000000001e8e2017 S:Disabling User1 Logs
    N:Video P:1 #:00006 T:00000000019de201 S:Enabling Analysis Logs
    N:VPSS  P:2 #:00006 T:000000001e8e6983 S:Enabling Analysis Logs
    N:Video P:1 #:00007 T:0000000001a07af1 S:Module<ti.omx> Entering<DomxCore_procAttach> @line<151>
    N:VPSS  P:2 #:00007 T:000000001e941925 S:edma3init() Passed
    N:Video P:1 #:00008 T:0000000001f6af65 S:Module<ti.omx> @<DomxCore_procAttach> @line<177> msg<Before Ipc_attach>
    N:VPSS  P:2 #:00008 T:00000000205dcfc5 S:isI2cInitReq is 0
    N:Video P:1 #:00009 T:000000000816438b S:Module<ti.omx> @<DomxCore_procAttach> @line<184> msg<After Ipc_attach>
    N:VPSS  P:2 #:00009 T:00000000212ce66f S:Module<ti.omx> Entering<DomxCore_procAttach> @line<151>
    N:Video P:1 #:00010 T:000000000816acc5 S:Module<ti.omx> @<DomxCore_procAttach> @line<186> msg<Ipc_attach successful>
    N:VPSS  P:2 #:00010 T:0000000021832dcb S:Module<ti.omx> @<DomxCore_procAttach> @line<191> msg<Before Ipc_attach>
    N:Video P:1 #:00011 T:0000000008170513 S:Module<ti.omx> Leaving<DomxCore_procAttach> @line<233> with error<0:ErrorNone>
    N:VPSS  P:2 #:00011 T:0000000027e33e35 S:Module<ti.omx> @<DomxCore_procAttach> @line<198> msg<After Ipc_attach>
    N:Video P:1 #:00012 T:00000000081bd997 S:Module<ti.omx> Entering<DomxCore_procInit> @line<250>
    N:VPSS  P:2 #:00012 T:0000000027e3aeed S:Module<ti.omx> @<DomxCore_procAttach> @line<200> msg<Ipc_attach successful>
    N:Video P:1 #:00013 T:00000000081c3449 S:Module<ti.omx> Entering<DomxCore_procMsgQInit> @line<115>
    N:VPSS  P:2 #:00013 T:0000000027e40a59 S:Module<ti.omx> Leaving<DomxCore_procAttach> @line<233> with error<0:ErrorNone>
    N:Video P:1 #:00014 T:00000000081cd765 S:Module<ti.omx> @<OmxRpc_moduleRegisterMsgqHeap> @line<927> msg<Before MessageQ_registerHeap>
    N:VPSS  P:2 #:00014 T:0000000027e8d802 S:Module<ti.omx> Entering<DomxCore_procInit> @line<250>
    N:Video P:1 #:00015 T:00000000081d458f S:Module<ti.omx> @<OmxRpc_moduleRegisterMsgqHeap> @line<932> msg<After MessageQ_registerHeap>
    N:VPSS  P:2 #:00015 T:0000000027e92799 S:Module<ti.omx> Entering<DomxCore_procMsgQInit> @line<115>
    N:Video P:1 #:00016 T:00000000081dab09 S:Module<ti.omx> Leaving<DomxCore_procMsgQInit> @line<142> with error<0:ErrorNone>
    N:VPSS  P:2 #:00016 T:0000000027e9c953 S:Module<ti.omx> @<OmxRpc_moduleRegisterMsgqHeap> @line<927> msg<Before MessageQ_registerHeap>
    N:Video P:1 #:00017 T:00000000081e3699 S:Module<ti.omx> Leaving<DomxCore_procInit> @line<346> with error<0:ErrorNone>
    N:VPSS  P:2 #:00017 T:0000000027ea3583 S:Module<ti.omx> @<OmxRpc_moduleRegisterMsgqHeap> @line<932> msg<After MessageQ_registerHeap>
    N:Video P:1 #:00018 T:00000000081eb6e3 S:@ omxrpc_rcm_server_create: rcmServerName OmxRpcRcmServer_1, priority 8
    N:VPSS  P:2 #:00018 T:0000000027ea9e37 S:Module<ti.omx> Leaving<DomxCore_procMsgQInit> @line<142> with error<0:ErrorNone>
    N:Video P:1 #:00019 T:00000000081f0af1 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<225> msg<Before RcmServer_Params_init>
    N:VPSS  P:2 #:00019 T:0000000027eb2843 S:Module<ti.omx> Leaving<DomxCore_procInit> @line<346> with error<0:ErrorNone>
    N:Video P:1 #:00020 T:00000000081f6e19 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<229> msg<After RcmServer_Params_init>
    N:VPSS  P:2 #:00020 T:0000000027ebabf7 S:@ omxrpc_rcm_server_create: rcmServerName OmxRpcRcmServer_2, priority 8
    N:Video P:1 #:00021 T:00000000081fcb73 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<232> msg<Before RcmServer_create>
    N:VPSS  P:2 #:00021 T:0000000027ec01df S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<225> msg<Before RcmServer_Params_init>
    N:Video P:1 #:00022 T:0000000008250ec9 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<240> msg<After RcmServer_create>
    N:VPSS  P:2 #:00022 T:0000000027ec6235 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<229> msg<After RcmServer_Params_init>
    N:Video P:1 #:00023 T:000000000825a291 S:@ omxrpc_rcm_server_remote_fxn_register regFxnCategory 0
    N:VPSS  P:2 #:00023 T:0000000027ecc1b9 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<232> msg<Before RcmServer_create>
    N:Video P:1 #:00024 T:000000000825f6a7 S:Calling RcmServer_addSymbol(OmxRpcGetHandle)
    N:VPSS  P:2 #:00024 T:0000000027f22465 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<240> msg<After RcmServer_create>
    N:Video P:1 #:00025 T:0000000008267799 S:Calling RcmServer_addSymbol(OmxRpcFreeHandle)
    N:VPSS  P:2 #:00025 T:0000000027f2b513 S:@ omxrpc_rcm_server_remote_fxn_register regFxnCategory 0
    N:Video P:1 #:00026 T:000000000826d8ed S:Calling RcmServer_addSymbol(OmxRpcCreateProxyLite)
    N:VPSS  P:2 #:00026 T:0000000027f2ff01 S:Calling RcmServer_addSymbol(OmxRpcGetHandle)
    N:Video P:1 #:00027 T:00000000082733e3 S:Calling RcmServer_addSymbol(OmxRpcGetHeapMemStats)
    N:VPSS  P:2 #:00027 T:0000000027f3796d S:Calling RcmServer_addSymbol(OmxRpcFreeHandle)
    N:Video P:1 #:00028 T:0000000008278f6f S:Calling RcmServer_addSymbol(OmxRpcDeleteProxyLite)
    N:VPSS  P:2 #:00028 T:0000000027f3d3ef S:Calling RcmServer_addSymbol(OmxRpcCreateProxyLite)
    N:Video P:1 #:00029 T:000000000827efbd S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<256> msg<Before RcmServer_start>
    N:VPSS  P:2 #:00029 T:0000000027f42c8b S:Calling RcmServer_addSymbol(OmxRpcGetHeapMemStats)
    N:Video P:1 #:00030 T:0000000008285971 S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<258> msg<After RcmServer_start>
    N:VPSS  P:2 #:00030 T:0000000027f48475 S:Calling RcmServer_addSymbol(OmxRpcDeleteProxyLite)
    N:VPSS  P:2 #:00031 T:0000000027f4e325 S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<256> msg<Before RcmServer_start>
    N:VPSS  P:2 #:00032 T:0000000027f54e5b S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<258> msg<After RcmServer_start>
    N:Video P:1 #:00031 T:00000024c82219f9 S:Enabling Status Logger
    N:VPSS  P:2 #:00033 T:00000024c8155991 S:Enabling Status Logger
    N:Video P:1 #:00032 T:00000024c8226635 S:Enabling User1 Logs
    N:VPSS  P:2 #:00034 T:00000024c815a28f S:Enabling User1 Logs
    N:Video P:1 #:00033 T:00000024c822cfeb S:Disabling User1 Logs
    N:VPSS  P:2 #:00035 T:00000024c81620c1 S:Disabling User1 Logs
    N:Video P:1 #:00034 T:00000024c8231e83 S:Disabling User1 Logs
    N:VPSS  P:2 #:00036 T:00000024c816678b S:Disabling User1 Logs
    N:Video P:1 #:00035 T:00000024c8236c63 S:Disabling User1 Logs
    N:VPSS  P:2 #:00037 T:00000024c816ad6f S:Disabling User1 Logs
    N:Video P:1 #:00036 T:00000024c823b993 S:Disabling User1 Logs
    N:VPSS  P:2 #:00038 T:00000024c816f3e5 S:Disabling User1 Logs
    N:Video P:1 #:00037 T:00000024c82408b3 S:Disabling Analysis Logs
    N:VPSS  P:2 #:00039 T:00000024c8173d63 S:Disabling Analysis Logs
    N:VPSS  P:2 #:00040 T:00000024c8ec389f S:OmxRpc_rcmIfGetHandle:ComponentName:OMX.TI.VPSSM3.VFCC
    N:VPSS  P:2 #:00041 T:00000024c8ecd94b S:Entered function:omxrpc_module_init_client (3)
    N:VPSS  P:2 #:00042 T:00000024c8ed6179 S:Entered function:OmxRpc_rcmClientCreate (0x9f186bfc, OmxRpcRcmServer_3, 5)
    N:VPSS  P:2 #:00043 T:00000024c8edbbb9 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<983> msg<Before RcmClient_Params_init>
    N:VPSS  P:2 #:00044 T:00000024c8ee18f3 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<985> msg<After RcmClient_Params_init>
    N:VPSS  P:2 #:00045 T:00000024c8ee77a1 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<990> msg<Before RcmClient_create>
    N:VPSS  P:2 #:00046 T:00000024c8f2e6d1 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<992> msg<After RcmClient_create>
    N:VPSS  P:2 #:00047 T:00000024c8f375d7 S:omxrpc_module_init_client: Located the remoteCoreRcmServer
    N:VPSS  P:2 #:00048 T:00000024c8f3cd47 S:main: calling RcmClient_getSymbolIndex(OmxRpcGetHandle)
    N:VPSS  P:2 #:00049 T:00000024c8f64d53 S:main: calling RcmClient_getSymbolIndex(OmxRpcFreeHandle)
    N:VPSS  P:2 #:00050 T:00000024c8f85823 S:main: calling RcmClient_getSymbolIndex(OmxRpcCreateProxyLite)
    N:VPSS  P:2 #:00051 T:00000024c901fd5f S:main: calling RcmClient_getSymbolIndex(OmxRpcGetHeapMemStats)
    N:VPSS  P:2 #:00052 T:00000024c90442f1 S:main: calling RcmClient_getSymbolIndex(OmxRpcDeleteProxyLite)
    N:VPSS  P:2 #:00053 T:00000024c9063d29 S:LayerId: 2
    N:VPSS  P:2 #:00054 T:00000024c906ccc1 S:@ omxrpc_rcm_server_create: rcmServerName OmxRpcRcmServer_OMX.TI.VPSSM3.VFCC_Ctrl_2_0, priority 14
    N:VPSS  P:2 #:00055 T:00000024c9073ad3 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<225> msg<Before RcmServer_Params_init>
    N:VPSS  P:2 #:00056 T:00000024c9079fed S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<229> msg<After RcmServer_Params_init>
    N:VPSS  P:2 #:00057 T:00000024c907fe47 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<232> msg<Before RcmServer_create>
    N:VPSS  P:2 #:00058 T:00000024c90e05c9 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<240> msg<After RcmServer_create>
    N:VPSS  P:2 #:00059 T:00000024c90e7347 S:@ omxrpc_rcm_server_remote_fxn_register regFxnCategory 1
    N:VPSS  P:2 #:00060 T:00000024c90ec233 S:Calling RcmServer_addSymbol(OmxRpcSetParameter)
    N:VPSS  P:2 #:00061 T:00000024c90f4545 S:Calling RcmServer_addSymbol(OmxRpcGetParameter)
    N:VPSS  P:2 #:00062 T:00000024c90f9b41 S:Calling RcmServer_addSymbol(OmxRpcSetConfig)
    N:VPSS  P:2 #:00063 T:00000024c90ff23b S:Calling RcmServer_addSymbol(OmxRpcGetConfig)
    N:VPSS  P:2 #:00064 T:00000024c91046cb S:Calling RcmServer_addSymbol(OmxRpcGetComponentVersion)
    N:VPSS  P:2 #:00065 T:00000024c910a38d S:Calling RcmServer_addSymbol(OmxRpcGetExtensionIndex)
    N:VPSS  P:2 #:00066 T:00000024c9110087 S:Calling RcmServer_addSymbol(OmxRpcGetState)
    N:VPSS  P:2 #:00067 T:00000024c9115a3f S:Calling RcmServer_addSymbol(OmxRpcSendCommand)
    N:VPSS  P:2 #:00068 T:00000024c911d4af S:Calling RcmServer_addSymbol(OmxRpcUseBuffer)
    N:VPSS  P:2 #:00069 T:00000024c9122a11 S:Calling RcmServer_addSymbol(OmxRpcAllocBuffer)
    N:VPSS  P:2 #:00070 T:00000024c9128015 S:Calling RcmServer_addSymbol(OmxRpcFreeBuffer)
    N:VPSS  P:2 #:00071 T:00000024c912d589 S:Calling RcmServer_addSymbol(OmxRpcEmptyThisBuffer)
    N:VPSS  P:2 #:00072 T:00000024c9132f49 S:Calling RcmServer_addSymbol(OmxRpcFillThisBuffer)
    N:VPSS  P:2 #:00073 T:00000024c9138a0d S:Calling RcmServer_addSymbol(OmxRpcTunnelRequest)
    N:VPSS  P:2 #:00074 T:00000024c913e831 S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<256> msg<Before RcmServer_start>
    N:VPSS  P:2 #:00075 T:00000024c9147fe9 S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<258> msg<After RcmServer_start>
    N:VPSS  P:2 #:00076 T:00000024c914e2ab S:Instance Register with omxRpc Module.Cnt = 1
    N:VPSS  P:2 #:00077 T:00000024c915208d S:L_create: OmxRpc create: Component:OMX.TI.VPSSM3.VFCC, Layer:2
    N:VPSS  P:2 #:00078 T:00000024c9158065 S:Component OMX.TI.VPSSM3.VFCC In table OMX.TI.VPSSM3.VFCC idx 0
    N:VPSS  P:2 #:00079 T:00000024c915d71b S:Component OMX.TI.VPSSM3.VFCC found idx: 0
    N:VPSS  P:2 #:00080 T:00000024c9163409 S:In OMX_GetHandle, component OMX.TI.VPSSM3.VFCC, omxhandle 0x9f1f8ca8
    N:VPSS  P:2 #:00081 T:00000024c91a395b S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_SetDefaultProperties> @line<1238>
    N:VPSS  P:2 #:00082 T:00000024c91abc91 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_SetDefaultProperties> @line<1280> with error<0:ErrorNone>
    N:VPSS  P:2 #:00083 T:00000024c91b26cb S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_ComponentInit> @line<133>
    N:VPSS  P:2 #:00084 T:00000024c91cfeeb S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_InitializePorts> @line<115>
    N:VPSS  P:2 #:00085 T:00000024c928087f S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_InitializePorts> @line<217> with error<0:ErrorNone>
    N:VPSS  P:2 #:00086 T:00000024c951d94f S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_ComponentInit> @line<247> with error<0:ErrorNone>
    N:VPSS  P:2 #:00087 T:00000024c952d353 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00088 T:00000024c9532d41 S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00089 T:00000024c9539c57 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00090 T:00000024c9540b21 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00091 T:00000024c9547f23 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00092 T:00000024c954d131 S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00093 T:00000024c95538bb S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00094 T:00000024c955a665 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00095 T:00000024c9561773 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00096 T:00000024c9568bb5 S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00097 T:00000024c956f6ad S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00098 T:00000024c957656f S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00099 T:00000024c957d7c5 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00100 T:00000024c9582abd S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00101 T:00000024c95892eb S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00102 T:00000024c959005f S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00103 T:00000024c9596f5f S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00104 T:00000024c959c129 S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00105 T:00000024c95a2883 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00106 T:00000024c95a9639 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00107 T:00000024c95b048d S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00108 T:00000024c95b5645 S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00109 T:00000024c95bbd79 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00110 T:00000024c95c2b2f S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00111 T:00000024c95c995d S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00112 T:00000024c95ceaef S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00113 T:00000024c95d524d S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00114 T:00000024c95dc04b S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00115 T:00000024c95e4c9d S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00116 T:00000024c95ea03e S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00117 T:00000024c95f09f3 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00118 T:00000024c95f7807 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00119 T:00000024c95fe7a7 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00120 T:00000024c9603981 S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00121 T:00000024c960a10f S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00122 T:00000024c9610f29 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00123 T:00000024c9617dc9 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00124 T:00000024c961cf7d S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00125 T:00000024c9623687 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00126 T:00000024c962a57f S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00127 T:00000024c96315c5 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00128 T:00000024c9636845 S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00129 T:00000024c963cfe3 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00130 T:00000024c9643e6b S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00131 T:00000024c964ad71 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00132 T:00000024c964ff29 S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00133 T:00000024c96566f9 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00134 T:00000024c965f011 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00135 T:00000024c96663bb S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00136 T:00000024c966b675 S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00137 T:00000024c9671e2f S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00138 T:00000024c9678c21 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00139 T:00000024c967fb17 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00140 T:00000024c9684ced S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00141 T:00000024c968b427 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00142 T:00000024c969219b S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00143 T:00000024c96991a1 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00144 T:00000024c969e38f S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00145 T:00000024c96a4b36 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00146 T:00000024c96ab8cd S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00147 T:00000024c96b29b3 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00148 T:00000024c96b7b31 S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00149 T:00000024c96be273 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00150 T:00000024c96c5091 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00151 T:00000024c96cbb0b S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_SetCallbacks> @line<267>
    N:VPSS  P:2 #:00152 T:00000024c96d3323 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_SetCallbacks> @line<308> with error<0:ErrorNone>
    N:VPSS  P:2 #:00153 T:00000024c96d9c1b S:Result of pComponentInit: ErrorNone
    N:VPSS  P:2 #:00154 T:00000024c96dd6af S:Registering the component OMX.TI.VPSSM3.VFCC with TunnelMgr
    N:VPSS  P:2 #:00155 T:00000024c96e2085 S:Entered: DomxTunnelMgr_registerHandle (0x9f1f8ca8, 0x9f704f54)
    N:VPSS  P:2 #:00156 T:00000024c96ebb07 S:Entered function:OmxRpc_rcmClientCreate (0x9f1f3e48, OmxRpcRcmServer_OMX.TI.VPSSM3.VFCC_Cb_3_0, 5)
    N:VPSS  P:2 #:00157 T:00000024c96f21cf S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<983> msg<Before RcmClient_Params_init>
    N:VPSS  P:2 #:00158 T:00000024c96f80b1 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<985> msg<After RcmClient_Params_init>
    N:VPSS  P:2 #:00159 T:00000024c96fdf79 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<990> msg<Before RcmClient_create>
    N:VPSS  P:2 #:00160 T:00000024c9760891 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<992> msg<After RcmClient_create>
    N:VPSS  P:2 #:00161 T:00000024c976904d S:main: calling RcmClient_getSymbolIndex(OmxRpcCbEventHandler)
    N:VPSS  P:2 #:00162 T:00000024c978f1cd S:main: calling RcmClient_getSymbolIndex(OmxRpcCbEmptyBufferDone)
    N:VPSS  P:2 #:00163 T:00000024c97b4889 S:main: calling RcmClient_getSymbolIndex(OmxRpcCbFillBufferDone)
    N:VPSS  P:2 #:00164 T:00000024c97d72ab S:Module<ti.omx> @<domxtmgr_register_skelinfo> @line<417> msg<OmxRpcRcmServer_OMX.TI.VPSSM3.VFCC_Ctrl_2_0>
    N:VPSS  P:2 #:00165 T:00000024c97e1509 S:OmxRpc_rcmIfGetHandle:ComponentName:OmxRpcRcmServer_OMX.TI.VPSSM3.VFCC_Ctrl_2_0.Exiting..
    N:VPSS  P:2 #:00166 T:00000024c9c6c4ff S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_GetParameter> @line<695>
    N:VPSS  P:2 #:00167 T:00000024c9c73cdf S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_GetParameter> @line<858> with error<0:ErrorNone>
    N:VPSS  P:2 #:00168 T:00000024c9ca0c8d S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_SetParameter> @line<890>
    N:VPSS  P:2 #:00169 T:00000024c9ca7ec9 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_SetParameter> @line<1163> with error<0:ErrorNone>
    N:VPSS  P:2 #:00170 T:00000024c9ccaf0d S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_SetParameter> @line<890>
    N:VPSS  P:2 #:00171 T:00000024c9cd1995 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_SetParameter> @line<1163> with error<0:ErrorNone>
    N:VPSS  P:2 #:00172 T:00000024c9d2f243 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_SendCommand> @line<499>
    N:VPSS  P:2 #:00173 T:00000024c9d39e6b S:OMX_BASE_SendCommand:OMX_CommandPortEnable, nParam1: 0
    N:VPSS  P:2 #:00174 T:00000024c9d427ed S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_SendCommand> @line<669> with error<0:ErrorNone>
    N:VPSS  P:2 #:00175 T:00000024c9d52807 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS  P:2 #:00176 T:00000024c9d5aced S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS  P:2 #:00177 T:00000024c9d60737 S:Module<OMX.TI.VPSSM3.VFCC> @<OMX_BASE_PROCESS_CmdEvent> @line<631> msg<Processing OMX_CommandPortEnable>
    N:VPSS  P:2 #:00178 T:00000024c9d67893 S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_EnablePort> @line<777>
    N:VPSS  P:2 #:00179 T:00000024c9d6d1a3 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_EnablePort> @line<815> with error<0:ErrorNone>
    N:VPSS  P:2 #:00180 T:00000024c9d7419f S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:VPSS  P:2 #:00181 T:00000024c9d7a225 S:Module<OMX.TI.VPSSM3.VFCC> @<OMX_BASE_CB_ReturnEventNotify> @line<121> msg<Notify client for port enable>
    N:VPSS  P:2 #:00182 T:00000024c9d84bd9 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<224> with error<0:ErrorNone>
    N:VPSS  P:2 #:00183 T:00000024c9d8b4ed S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:VPSS  P:2 #:00184 T:00000024c9d91bf3 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS  P:2 #:00185 T:00000024c9d98a8d S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS  P:2 #:00186 T:00000024c9d9e77b S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS  P:2 #:00187 T:00000024c9da4175 S:Module<OMX.TI.VPSSM3.VFCC> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<869> msg<Processing OMX_CommandPortEnable>
    N:VPSS  P:2 #:00188 T:00000024c9dab041 S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_EventNotifyToClient> @line<881>
    N:VPSS  P:2 #:00189 T:00000024c9de00bb S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:VPSS  P:2 #:00190 T:00000024c9de767d S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS  P:2 #:00191 T:00000024c9dee50f S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS  P:2 #:00192 T:00000024c9df5781 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS  P:2 #:00193 T:00000024c9dfe7bb S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS  P:2 #:00194 T:00000024c9ec953c S:OmxRpc_rcmIfGetHandle:ComponentName:OMX.TI.VPSSM3.VFPC.DEIMDUALOUT
    N:VPSS  P:2 #:00195 T:00000024c9ed3263 S:Entered function:omxrpc_module_init_client (3)
    N:VPSS  P:2 #:00196 T:00000024c9ed7d81 S:LayerId: 2
    N:VPSS  P:2 #:00197 T:00000024c9ee081f S:@ omxrpc_rcm_server_create: rcmServerName OmxRpcRcmServer_OMX.TI.VPSSM3.VFPC.DEIMDUALOUT_Ctrl_2_1, priority 14
    N:VPSS  P:2 #:00198 T:00000024c9ee7d2d S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<225> msg<Before RcmServer_Params_init>
    N:VPSS  P:2 #:00199 T:00000024c9ef1061 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<229> msg<After RcmServer_Params_init>
    N:VPSS  P:2 #:00200 T:00000024c9ef6fef S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<232> msg<Before RcmServer_create>
    N:VPSS  P:2 #:00201 T:00000024c9f54585 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<240> msg<After RcmServer_create>
    N:VPSS  P:2 #:00202 T:00000024c9f5b107 S:@ omxrpc_rcm_server_remote_fxn_register regFxnCategory 1
    N:VPSS  P:2 #:00203 T:00000024c9f60109 S:Calling RcmServer_addSymbol(OmxRpcSetParameter)
    N:VPSS  P:2 #:00204 T:00000024c9f6b789 S:Calling RcmServer_addSymbol(OmxRpcGetParameter)
    N:VPSS  P:2 #:00205 T:00000024c9f70f17 S:Calling RcmServer_addSymbol(OmxRpcSetConfig)
    N:VPSS  P:2 #:00206 T:00000024c9f76481 S:Calling RcmServer_addSymbol(OmxRpcGetConfig)
    N:VPSS  P:2 #:00207 T:00000024c9f7b921 S:Calling RcmServer_addSymbol(OmxRpcGetComponentVersion)
    N:VPSS  P:2 #:00208 T:00000024c9f81769 S:Calling RcmServer_addSymbol(OmxRpcGetExtensionIndex)
    N:VPSS  P:2 #:00209 T:00000024c9f8735f S:Calling RcmServer_addSymbol(OmxRpcGetState)
    N:VPSS  P:2 #:00210 T:00000024c9f8c7ed S:Calling RcmServer_addSymbol(OmxRpcSendCommand)
    N:VPSS  P:2 #:00211 T:00000024c9f91d1b S:Calling RcmServer_addSymbol(OmxRpcUseBuffer)
    N:VPSS  P:2 #:00212 T:00000024c9f96fbd S:Calling RcmServer_addSymbol(OmxRpcAllocBuffer)
    N:VPSS  P:2 #:00213 T:00000024c9f9c603 S:Calling RcmServer_addSymbol(OmxRpcFreeBuffer)
    N:VPSS  P:2 #:00214 T:00000024c9fa1bd1 S:Calling RcmServer_addSymbol(OmxRpcEmptyThisBuffer)
    N:VPSS  P:2 #:00215 T:00000024c9fa754b S:Calling RcmServer_addSymbol(OmxRpcFillThisBuffer)
    N:VPSS  P:2 #:00216 T:00000024c9fad069 S:Calling RcmServer_addSymbol(OmxRpcTunnelRequest)
    N:VPSS  P:2 #:00217 T:00000024c9fb2e23 S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<256> msg<Before RcmServer_start>
    N:VPSS  P:2 #:00218 T:00000024c9fbcc45 S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<258> msg<After RcmServer_start>
    N:VPSS  P:2 #:00219 T:00000024c9fc2c2b S:Instance Register with omxRpc Module.Cnt = 2
    N:VPSS  P:2 #:00220 T:00000024c9fc6b8f S:L_create: OmxRpc create: Component:OMX.TI.VPSSM3.VFPC.DEIMDUALOUT, Layer:2
    N:VPSS  P:2 #:00221 T:00000024c9fcd58f S:Component OMX.TI.VPSSM3.VFPC.DEIMDUALOUT In table OMX.TI.VPSSM3.VFCC idx 0
    N:VPSS  P:2 #:00222 T:00000024c9fd3461 S:Component OMX.TI.VPSSM3.VFPC.DEIMDUALOUT In table OMX.TI.VPSSM3.VFDC idx 1
    N:VPSS  P:2 #:00223 T:00000024c9fd8cb1 S:Component OMX.TI.VPSSM3.VFPC.DEIMDUALOUT In table OMX.TI.VPSSM3.VFPC.DEIHDUALOUT idx 2
    N:VPSS  P:2 #:00224 T:00000024c9fdf29f S:Component OMX.TI.VPSSM3.VFPC.DEIMDUALOUT In table OMX.TI.VPSSM3.VFPC.DEIMDUALOUT idx 3
    N:VPSS  P:2 #:00225 T:00000024c9fe79cf S:Component OMX.TI.VPSSM3.VFPC.DEIMDUALOUT found idx: 3
    N:VPSS  P:2 #:00226 T:00000024c9fee28b S:In OMX_GetHandle, component OMX.TI.VPSSM3.VFPC.DEIMDUALOUT, omxhandle 0x9f226a50
    N:VPSS  P:2 #:00227 T:00000024ca03fa89 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_SetDefaultProperties> @line<1238>
    N:VPSS  P:2 #:00228 T:00000024ca04998f S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_SetDefaultProperties> @line<1280> with error<0:ErrorNone>
    N:VPSS  P:2 #:00229 T:00000024ca054779 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_ComponentInit> @line<133>
    N:VPSS  P:2 #:00230 T:00000024ca075bb3 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_InitializePorts> @line<115>
    N:VPSS  P:2 #:00231 T:00000024ca1c1337 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_InitializePorts> @line<217> with error<0:ErrorNone>
    N:VPSS  P:2 #:00232 T:00000024ca321dcd S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_ComponentInit> @line<247> with error<0:ErrorNone>
    N:VPSS  P:2 #:00233 T:00000024ca48247f S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00234 T:00000024ca488ff1 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00235 T:00000024ca4909ef S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00236 T:00000024ca49827b S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00237 T:00000024ca49ff6b S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00238 T:00000024ca4b519b S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00239 T:00000024ca4bccaf S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00240 T:00000024ca4c4411 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00241 T:00000024ca4cc63f S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00242 T:00000024ca4d2097 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00243 T:00000024ca4d9069 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00244 T:00000024ca4e05d9 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00245 T:00000024ca4e7aab S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00246 T:00000024ca4ed4ad S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00247 T:00000024ca4f4355 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00248 T:00000024ca4fb8bb S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00249 T:00000024ca502dd9 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00250 T:00000024ca50875b S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00251 T:00000024ca50f74d S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00252 T:00000024ca516c77 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00253 T:00000024ca51e979 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00254 T:00000024ca526ab7 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00255 T:00000024ca52dc41 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00256 T:00000024ca53522b S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00257 T:00000024ca53c8fb S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00258 T:00000024ca542239 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00259 T:00000024ca549159 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00260 T:00000024ca5506ad S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00261 T:00000024ca557b55 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00262 T:00000024ca55d469 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00263 T:00000024ca5642e3 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00264 T:00000024ca56b805 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00265 T:00000024ca572b9b S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:Video P:1 #:00038 T:00000024cb929e03 S:OmxRpc_rcmIfGetHandle:ComponentName:OMX.TI.DUCATI.VIDENC
    N:VPSS  P:2 #:00266 T:00000024ca5784b7 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:Video P:1 #:00039 T:00000024cb9349eb S:Entered function:omxrpc_module_init_client (3)
    N:VPSS  P:2 #:00267 T:00000024ca57f343 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:Video P:1 #:00040 T:00000024cb93d54d S:Entered function:OmxRpc_rcmClientCreate (0x9dae6bfc, OmxRpcRcmServer_3, 4)
    N:VPSS  P:2 #:00268 T:00000024ca586835 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:Video P:1 #:00041 T:00000024cb94356f S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<983> msg<Before RcmClient_Params_init>
    N:VPSS  P:2 #:00269 T:00000024ca58dd13 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:Video P:1 #:00042 T:00000024cb949707 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<985> msg<After RcmClient_Params_init>
    N:VPSS  P:2 #:00270 T:00000024ca5936f7 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:Video P:1 #:00043 T:00000024cb94f497 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<990> msg<Before RcmClient_create>
    N:VPSS  P:2 #:00271 T:00000024ca59bda9 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:Video P:1 #:00044 T:00000024cb992319 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<992> msg<After RcmClient_create>
    N:VPSS  P:2 #:00272 T:00000024ca5a37c1 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:Video P:1 #:00045 T:00000024cb999201 S:omxrpc_module_init_client: Located the remoteCoreRcmServer
    N:VPSS  P:2 #:00273 T:00000024ca5aafb9 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:Video P:1 #:00046 T:00000024cb9a14e9 S:main: calling RcmClient_getSymbolIndex(OmxRpcGetHandle)
    N:VPSS  P:2 #:00274 T:00000024ca5b0985 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:Video P:1 #:00047 T:00000024cb9c9c93 S:main: calling RcmClient_getSymbolIndex(OmxRpcFreeHandle)
    N:VPSS  P:2 #:00275 T:00000024ca5b77f3 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:Video P:1 #:00048 T:00000024cb9ec109 S:main: calling RcmClient_getSymbolIndex(OmxRpcCreateProxyLite)
    N:VPSS  P:2 #:00276 T:00000024ca5bedc7 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:Video P:1 #:00049 T:00000024cba0d17b S:main: calling RcmClient_getSymbolIndex(OmxRpcGetHeapMemStats)
    N:VPSS  P:2 #:00277 T:00000024ca5c61d5 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:Video P:1 #:00050 T:00000024cba319e1 S:main: calling RcmClient_getSymbolIndex(OmxRpcDeleteProxyLite)
    N:VPSS  P:2 #:00278 T:00000024ca5cbacd S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:Video P:1 #:00051 T:00000024cba575c5 S:LayerId: 2
    N:VPSS  P:2 #:00279 T:00000024ca5d2999 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00280 T:00000024ca5d9e85 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:Video P:1 #:00052 T:00000024cba613f7 S:@ omxrpc_rcm_server_create: rcmServerName OmxRpcRcmServer_OMX.TI.DUCATI.VIDENC_Ctrl_1_0, priority 14
    N:VPSS  P:2 #:00281 T:00000024ca5e139f S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:Video P:1 #:00053 T:00000024cba67da1 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<225> msg<Before RcmServer_Params_init>
    N:VPSS  P:2 #:00282 T:00000024ca5e6d4f S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:Video P:1 #:00054 T:00000024cba6e19f S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<229> msg<After RcmServer_Params_init>
    N:VPSS  P:2 #:00283 T:00000024ca5edcb7 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:Video P:1 #:00055 T:00000024cba7419b S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<232> msg<Before RcmServer_create>
    N:VPSS  P:2 #:00284 T:00000024ca5f522d S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:Video P:1 #:00056 T:00000024cbad3e9d S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<240> msg<After RcmServer_create>
    N:VPSS  P:2 #:00285 T:00000024ca5fc6b3 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:Video P:1 #:00057 T:00000024cbadb379 S:@ omxrpc_rcm_server_remote_fxn_register regFxnCategory 1
    N:VPSS  P:2 #:00286 T:00000024ca602047 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:Video P:1 #:00058 T:00000024cbae0327 S:Calling RcmServer_addSymbol(OmxRpcSetParameter)
    N:VPSS  P:2 #:00287 T:00000024ca608f13 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:Video P:1 #:00059 T:00000024cbae8ac5 S:Calling RcmServer_addSymbol(OmxRpcGetParameter)
    N:VPSS  P:2 #:00288 T:00000024ca610613 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:Video P:1 #:00060 T:00000024cbaeeacd S:Calling RcmServer_addSymbol(OmxRpcSetConfig)
    N:VPSS  P:2 #:00289 T:00000024ca6193f7 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:Video P:1 #:00061 T:00000024cbaf4813 S:Calling RcmServer_addSymbol(OmxRpcGetConfig)
    N:VPSS  P:2 #:00290 T:00000024ca61f023 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:Video P:1 #:00062 T:00000024cbafa191 S:Calling RcmServer_addSymbol(OmxRpcGetComponentVersion)
    N:VPSS  P:2 #:00291 T:00000024ca626167 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:Video P:1 #:00063 T:00000024cbb00355 S:Calling RcmServer_addSymbol(OmxRpcGetExtensionIndex)
    N:VPSS  P:2 #:00292 T:00000024ca62d761 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:Video P:1 #:00064 T:00000024cbb06467 S:Calling RcmServer_addSymbol(OmxRpcGetState)
    N:VPSS  P:2 #:00293 T:00000024ca634be9 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:Video P:1 #:00065 T:00000024cbb0ee09 S:Calling RcmServer_addSymbol(OmxRpcSendCommand)
    N:VPSS  P:2 #:00294 T:00000024ca63a525 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:Video P:1 #:00066 T:00000024cbb15cb3 S:Calling RcmServer_addSymbol(OmxRpcUseBuffer)
    N:VPSS  P:2 #:00295 T:00000024ca6413af S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:Video P:1 #:00067 T:00000024cbb1bb31 S:Calling RcmServer_addSymbol(OmxRpcAllocBuffer)
    N:VPSS  P:2 #:00296 T:00000024ca6488c1 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:Video P:1 #:00068 T:00000024cbb2183b S:Calling RcmServer_addSymbol(OmxRpcFreeBuffer)
    N:VPSS  P:2 #:00297 T:00000024ca64fe1d S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:Video P:1 #:00069 T:00000024cbb27569 S:Calling RcmServer_addSymbol(OmxRpcEmptyThisBuffer)
    N:VPSS  P:2 #:00298 T:00000024ca65575b S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:Video P:1 #:00070 T:00000024cbb2d4ff S:Calling RcmServer_addSymbol(OmxRpcFillThisBuffer)
    N:VPSS  P:2 #:00299 T:00000024ca65c671 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:Video P:1 #:00071 T:00000024cbb3337b S:Calling RcmServer_addSymbol(OmxRpcTunnelRequest)
    N:VPSS  P:2 #:00300 T:00000024ca663b73 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:Video P:1 #:00072 T:00000024cbb39ac5 S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<256> msg<Before RcmServer_start>
    N:VPSS  P:2 #:00301 T:00000024ca66af47 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:Video P:1 #:00073 T:00000024cbb43c43 S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<258> msg<After RcmServer_start>
    N:VPSS  P:2 #:00302 T:00000024ca67083b S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:Video P:1 #:00074 T:00000024cbb4a0e5 S:Instance Register with omxRpc Module.Cnt = 1
    N:VPSS  P:2 #:00303 T:00000024ca6776dd S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:Video P:1 #:00075 T:00000024cbb4e20f S:L_create: OmxRpc create: Component:OMX.TI.DUCATI.VIDENC, Layer:2
    N:VPSS  P:2 #:00304 T:00000024ca67ebe1 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:Video P:1 #:00076 T:00000024cbb54449 S:Component OMX.TI.DUCATI.VIDENC In table OMX.TI.VPSSM3.VFCC idx 0
    N:VPSS  P:2 #:00305 T:00000024ca6860af S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:Video P:1 #:00077 T:00000024cbb598cd S:Component OMX.TI.DUCATI.VIDENC In table OMX.TI.VPSSM3.VFDC idx 1
    N:VPSS  P:2 #:00306 T:00000024ca68bb2f S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:Video P:1 #:00078 T:00000024cbb5e707 S:Component OMX.TI.DUCATI.VIDENC In table OMX.TI.VPSSM3.VFPC.DEIHDUALOUT idx 2
    N:VPSS  P:2 #:00307 T:00000024ca6943f5 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:Video P:1 #:00079 T:00000024cbb63db9 S:Component OMX.TI.DUCATI.VIDENC In table OMX.TI.VPSSM3.VFPC.DEIMDUALOUT idx 3
    N:VPSS  P:2 #:00308 T:00000024ca69b9dd S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:Video P:1 #:00080 T:00000024cbb6925b S:Component OMX.TI.DUCATI.VIDENC In table OMX.TI.VPSSM3.VFPC.NF idx 4
    N:VPSS  P:2 #:00309 T:00000024ca6a30db S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:Video P:1 #:00081 T:00000024cbb6e3d7 S:Component OMX.TI.DUCATI.VIDENC In table OMX.TI.VPSSM3.VFPC.INDTXSCWB idx 5
    N:VPSS  P:2 #:00310 T:00000024ca6a8a65 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:Video P:1 #:00082 T:00000024cbb73b65 S:Component OMX.TI.DUCATI.VIDENC In table OMX.TI.VPSSM3.CTRL.TVP idx 6
    N:VPSS  P:2 #:00311 T:00000024ca6af90d S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:Video P:1 #:00083 T:00000024cbb78ee9 S:Component OMX.TI.DUCATI.VIDENC In table OMX.TI.VPSSM3.CTRL.DC idx 7
    N:VPSS  P:2 #:00312 T:00000024ca6b6e19 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:Video P:1 #:00084 T:00000024cbb7e1d1 S:Component OMX.TI.DUCATI.VIDENC In table OMX.TI.VPSSM3.VSWMOSAIC idx 8
    N:VPSS  P:2 #:00313 T:00000024ca6be281 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:Video P:1 #:00085 T:00000024cbb85a51 S:Component OMX.TI.DUCATI.VIDENC In table OMX.TI.DUCATI.VIDENC idx 9
    N:VPSS  P:2 #:00314 T:00000024ca6c3cfb S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:Video P:1 #:00086 T:00000024cbb8b9df S:Component OMX.TI.DUCATI.VIDENC found idx: 9
    N:VPSS  P:2 #:00315 T:00000024ca6cabfd S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00316 T:00000024ca6d20df S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:Video P:1 #:00087 T:00000024cbb91faf S:In OMX_GetHandle, component OMX.TI.DUCATI.VIDENC, omxhandle 0x9dc337e8
    N:VPSS  P:2 #:00317 T:00000024ca6d9559 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:Video P:1 #:00088 T:00000024cbba3417 S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_SetDefaultProperties> @line<1238>
    N:VPSS  P:2 #:00318 T:00000024ca6dee87 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:Video P:1 #:00089 T:00000024cbbaa0c7 S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_SetDefaultProperties> @line<1280> with error<0:ErrorNone>
    N:VPSS  P:2 #:00319 T:00000024ca6e5d79 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:Video P:1 #:00090 T:00000024cbbb2147 S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_ComponentInit> @line<133>
    N:VPSS  P:2 #:00320 T:00000024ca6ed2cb S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:Video P:1 #:00091 T:00000024cbbcfa53 S:Module<OMX.TI.DUCATI.VIDENC> Entering<_OMX_BASE_InitializePorts> @line<115>
    N:VPSS  P:2 #:00321 T:00000024ca6f487d S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:Video P:1 #:00092 T:00000024cbbee20d S:Module<OMX.TI.DUCATI.VIDENC> Leaving<_OMX_BASE_InitializePorts> @line<217> with error<0:ErrorNone>
    N:VPSS  P:2 #:00322 T:00000024ca6fa199 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00323 T:00000024ca701041 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:Video P:1 #:00093 T:00000024cbe7476b S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_ComponentInit> @line<247> with error<0:ErrorNone>
    N:VPSS  P:2 #:00324 T:00000024ca709ed7 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00325 T:00000024ca71198b S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00326 T:00000024ca717335 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00327 T:00000024ca71e3dd S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00328 T:00000024ca7259c1 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00329 T:00000024ca72cd51 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00330 T:00000024ca7326cb S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00331 T:00000024ca739525 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00332 T:00000024ca740a11 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00333 T:00000024ca747e5d S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00334 T:00000024ca74d7e1 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00335 T:00000024ca754699 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00336 T:00000024ca75bbf9 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00337 T:00000024ca763059 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00338 T:00000024ca768977 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00339 T:00000024ca76f823 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00340 T:00000024ca776e81 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00341 T:00000024ca77e659 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:Video P:1 #:00094 T:00000024cbf65a87 S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00342 T:00000024ca785739 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:Video P:1 #:00095 T:00000024cbf6c755 S:Module<OMX.TI.DUCATI.VIDENC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00343 T:00000024ca78cb93 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:Video P:1 #:00096 T:00000024cbf73a2d S:Module<OMX.TI.DUCATI.VIDENC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00344 T:00000024ca794109 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:Video P:1 #:00097 T:00000024cbf7af97 S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00345 T:00000024ca79b691 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:Video P:1 #:00098 T:00000024cbf86c13 S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_SetCallbacks> @line<267>
    N:VPSS  P:2 #:00346 T:00000024ca7a0ff5 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:Video P:1 #:00099 T:00000024cbf8cebb S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_SetCallbacks> @line<308> with error<0:ErrorNone>
    N:VPSS  P:2 #:00347 T:00000024ca7a7f39 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:Video P:1 #:00100 T:00000024cbf9377f S:Result of pComponentInit: ErrorNone
    N:VPSS  P:2 #:00348 T:00000024ca7af425 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00349 T:00000024ca7b683f S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:Video P:1 #:00101 T:00000024cbf972ff S:Registering the component OMX.TI.DUCATI.VIDENC with TunnelMgr
    N:VPSS  P:2 #:00350 T:00000024ca7bc169 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:Video P:1 #:00102 T:00000024cbf9bef9 S:Entered: DomxTunnelMgr_registerHandle (0x9dc337e8, 0x9f704f54)
    N:VPSS  P:2 #:00351 T:00000024ca7c30b3 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:Video P:1 #:00103 T:00000024cbfa548b S:Entered function:OmxRpc_rcmClientCreate (0x9dc2e988, OmxRpcRcmServer_OMX.TI.DUCATI.VIDENC_Cb_3_2, 4)
    N:VPSS  P:2 #:00352 T:00000024ca7ca59b S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:Video P:1 #:00104 T:00000024cbfabaa5 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<983> msg<Before RcmClient_Params_init>
    N:VPSS  P:2 #:00353 T:00000024ca7d1a5d S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:Video P:1 #:00105 T:00000024cbfb1b5b S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<985> msg<After RcmClient_Params_init>
    N:VPSS  P:2 #:00354 T:00000024ca7d73a3 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:Video P:1 #:00106 T:00000024cbfb7b3f S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<990> msg<Before RcmClient_create>
    N:VPSS  P:2 #:00355 T:00000024ca7de203 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:Video P:1 #:00107 T:00000024cc01689f S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<992> msg<After RcmClient_create>
    N:VPSS  P:2 #:00356 T:00000024ca7e56ef S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:Video P:1 #:00108 T:00000024cc01f69f S:main: calling RcmClient_getSymbolIndex(OmxRpcCbEventHandler)
    N:VPSS  P:2 #:00357 T:00000024ca7eca7b S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Util> @line<546>
    N:Video P:1 #:00109 T:00000024cc045bb3 S:main: calling RcmClient_getSymbolIndex(OmxRpcCbEmptyBufferDone)
    N:VPSS  P:2 #:00358 T:00000024ca7f23ad S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:Video P:1 #:00110 T:00000024cc06b753 S:main: calling RcmClient_getSymbolIndex(OmxRpcCbFillBufferDone)
    N:VPSS  P:2 #:00359 T:00000024ca7f92c5 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:Video P:1 #:00111 T:00000024cc08ea29 S:Module<ti.omx> @<domxtmgr_register_skelinfo> @line<417> msg<OmxRpcRcmServer_OMX.TI.DUCATI.VIDENC_Ctrl_1_0>
    N:VPSS  P:2 #:00360 T:00000024ca801f31 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:Video P:1 #:00112 T:00000024cc098db5 S:OmxRpc_rcmIfGetHandle:ComponentName:OmxRpcRcmServer_OMX.TI.DUCATI.VIDENC_Ctrl_1_0.Exiting..
    N:VPSS  P:2 #:00361 T:00000024ca809379 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_SetCallbacks> @line<267>
    N:VPSS  P:2 #:00362 T:00000024ca8106d9 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_SetCallbacks> @line<308> with error<0:ErrorNone>
    N:VPSS  P:2 #:00363 T:00000024ca817719 S:Result of pComponentInit: ErrorNone
    N:Video P:1 #:00113 T:00000024cc595efb S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_GetParameter> @line<695>
    N:VPSS  P:2 #:00364 T:00000024ca81b2e5 S:Registering the component OMX.TI.VPSSM3.VFPC.DEIMDUALOUT with TunnelMgr
    N:Video P:1 #:00114 T:00000024cc59dc23 S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_GetParameter> @line<858> with error<0:ErrorNone>
    N:VPSS  P:2 #:00365 T:00000024ca82056d S:Entered: DomxTunnelMgr_registerHandle (0x9f226a50, 0x9f704f54)
    N:Video P:1 #:00115 T:00000024cc5edb85 S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_GetParameter> @line<695>
    N:VPSS  P:2 #:00366 T:00000024ca82ad8f S:Entered function:OmxRpc_rcmClientCreate (0x9f221de0, OmxRpcRcmServer_OMX.TI.VPSSM3.VFPC.DEIMDUALOUT_Cb_3_1, 5)
    N:Video P:1 #:00116 T:00000024cc5f4db7 S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_GetParameter> @line<858> with error<0:ErrorNone>
    N:VPSS  P:2 #:00367 T:00000024ca831d11 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<983> msg<Before RcmClient_Params_init>
    N:VPSS  P:2 #:00368 T:00000024ca837b4f S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<985> msg<After RcmClient_Params_init>
    N:VPSS  P:2 #:00369 T:00000024ca83d9f7 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<990> msg<Before RcmClient_create>
    N:VPSS  P:2 #:00370 T:00000024ca8bfea7 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<992> msg<After RcmClient_create>
    N:VPSS  P:2 #:00371 T:00000024ca8c8aaf S:main: calling RcmClient_getSymbolIndex(OmxRpcCbEventHandler)
    N:VPSS  P:2 #:00372 T:00000024ca8eefd5 S:main: calling RcmClient_getSymbolIndex(OmxRpcCbEmptyBufferDone)
    N:VPSS  P:2 #:00373 T:00000024ca91beef S:main: calling RcmClient_getSymbolIndex(OmxRpcCbFillBufferDone)
    N:VPSS  P:2 #:00374 T:00000024ca94994d S:Module<ti.omx> @<domxtmgr_register_skelinfo> @line<417> msg<OmxRpcRcmServer_OMX.TI.VPSSM3.VFPC.DEIMDUALOUT_Ctrl_2_1>
    N:VPSS  P:2 #:00375 T:00000024ca954595 S:OmxRpc_rcmIfGetHandle:ComponentName:OmxRpcRcmServer_OMX.TI.VPSSM3.VFPC.DEIMDUALOUT_Ctrl_2_1.Exiting..
    N:VPSS  P:2 #:00376 T:00000024caf79887 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_SetParameter> @line<890>
    N:VPSS  P:2 #:00377 T:00000024caf81bf1 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_SetParameter> @line<1163> with error<0:ErrorNone>
    N:VPSS  P:2 #:00378 T:00000024cafa6981 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_SetParameter> @line<890>
    N:VPSS  P:2 #:00379 T:00000024cafadce3 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_SetParameter> @line<1163> with error<0:ErrorNone>
    N:VPSS  P:2 #:00380 T:00000024cafd00a1 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_SetParameter> @line<890>
    N:VPSS  P:2 #:00381 T:00000024cafd708b S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_SetParameter> @line<1163> with error<0:ErrorNone>
    N:VPSS  P:2 #:00382 T:00000024caffb631 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_GetParameter> @line<695>
    N:VPSS  P:2 #:00383 T:00000024cb00283b S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_GetParameter> @line<858> with error<0:ErrorNone>
    N:VPSS  P:2 #:00384 T:00000024cb02a689 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_SetParameter> @line<890>
    N:VPSS  P:2 #:00385 T:00000024cb031cdb S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_SetParameter> @line<1163> with error<0:ErrorNone>
    N:VPSS  P:2 #:00386 T:00000024cb0542a3 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_GetParameter> @line<695>
    N:VPSS  P:2 #:00387 T:00000024cb05aeb1 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_GetParameter> @line<858> with error<0:ErrorNone>
    N:VPSS  P:2 #:00388 T:00000024cb07d719 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_SetParameter> @line<890>
    N:VPSS  P:2 #:00389 T:00000024cb0844b9 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_SetParameter> @line<1163> with error<0:ErrorNone>
    N:VPSS  P:2 #:00390 T:00000024cb0a6407 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_GetParameter> @line<695>
    N:VPSS  P:2 #:00391 T:00000024cb0ad479 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_GetParameter> @line<858> with error<0:ErrorNone>
    N:VPSS  P:2 #:00392 T:00000024cb1f00c1 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_SetParameter> @line<890>
    N:VPSS  P:2 #:00393 T:00000024cb1f75a1 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_SetParameter> @line<1163> with error<0:ErrorNone>
    N:VPSS  P:2 #:00394 T:00000024cb2a4595 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_SendCommand> @line<499>
    N:VPSS  P:2 #:00395 T:00000024cb2b0419 S:OMX_BASE_SendCommand:OMX_CommandPortEnable, nParam1: 0
    N:VPSS  P:2 #:00396 T:00000024cb2b8d51 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_SendCommand> @line<669> with error<0:ErrorNone>
    N:VPSS  P:2 #:00397 T:00000024cb2caa93 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS  P:2 #:00398 T:00000024cb2d339f S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS  P:2 #:00399 T:00000024cb2d96eb S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> @<OMX_BASE_PROCESS_CmdEvent> @line<631> msg<Processing OMX_CommandPortEnable>
    N:VPSS  P:2 #:00400 T:00000024cb2e0fff S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_EnablePort> @line<777>
    N:VPSS  P:2 #:00401 T:00000024cb2e7007 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_EnablePort> @line<815> with error<0:ErrorNone>
    N:VPSS  P:2 #:00402 T:00000024cb2ee8db S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:VPSS  P:2 #:00403 T:00000024cb2f8b41 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> @<OMX_BASE_CB_ReturnEventNotify> @line<121> msg<Notify client for port enable>
    N:VPSS  P:2 #:00404 T:00000024cb300d5d S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<224> with error<0:ErrorNone>
    N:VPSS  P:2 #:00405 T:00000024cb307c21 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:VPSS  P:2 #:00406 T:00000024cb30eb53 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS  P:2 #:00407 T:00000024cb316427 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS  P:2 #:00408 T:00000024cb31c933 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS  P:2 #:00409 T:00000024cb3229d5 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<869> msg<Processing OMX_CommandPortEnable>
    N:VPSS  P:2 #:00410 T:00000024cb32a00b S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_EventNotifyToClient> @line<881>
    N:VPSS  P:2 #:00411 T:00000024cb35ddf1 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_SendCommand> @line<499>
    N:VPSS  P:2 #:00412 T:00000024cb369813 S:OMX_BASE_SendCommand:OMX_CommandPortEnable, nParam1: 16
    N:VPSS  P:2 #:00413 T:00000024cb373843 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_SendCommand> @line<669> with error<0:ErrorNone>
    N:VPSS  P:2 #:00414 T:00000024cb38bb80 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:VPSS  P:2 #:00415 T:00000024cb393a87 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS  P:2 #:00416 T:00000024cb39aca9 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS  P:2 #:00417 T:00000024cb3a1f7a S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS  P:2 #:00418 T:00000024cb3aa58f S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS  P:2 #:00419 T:00000024cb3b01c5 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> @<OMX_BASE_PROCESS_CmdEvent> @line<631> msg<Processing OMX_CommandPortEnable>
    N:VPSS  P:2 #:00420 T:00000024cb3b750d S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_EnablePort> @line<777>
    N:VPSS  P:2 #:00421 T:00000024cb3bcf0a S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_EnablePort> @line<815> with error<0:ErrorNone>
    N:VPSS  P:2 #:00422 T:00000024cb3c4871 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:VPSS  P:2 #:00423 T:00000024cb3cb131 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> @<OMX_BASE_CB_ReturnEventNotify> @line<121> msg<Notify client for port enable>
    N:VPSS  P:2 #:00424 T:00000024cb3d2aa7 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<224> with error<0:ErrorNone>
    N:VPSS  P:2 #:00425 T:00000024cb3d9ca1 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:VPSS  P:2 #:00426 T:00000024cb3e0e01 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS  P:2 #:00427 T:00000024cb3ebab5 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS  P:2 #:00428 T:00000024cb3f1f89 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS  P:2 #:00429 T:00000024cb3f842b S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<869> msg<Processing OMX_CommandPortEnable>
    N:VPSS  P:2 #:00430 T:00000024cb3fff31 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_EventNotifyToClient> @line<881>
    N:VPSS  P:2 #:00431 T:00000024cb430cfb S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_SendCommand> @line<499>
    N:VPSS  P:2 #:00432 T:00000024cb43c921 S:OMX_BASE_SendCommand:OMX_CommandPortEnable, nParam1: 17
    N:VPSS  P:2 #:00433 T:00000024cb4441a3 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_SendCommand> @line<669> with error<0:ErrorNone>
    N:VPSS  P:2 #:00434 T:00000024cb45ba79 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:VPSS  P:2 #:00435 T:00000024cb4666bf S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS  P:2 #:00436 T:00000024cb46ddb9 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS  P:2 #:00437 T:00000024cb47569f S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS  P:2 #:00438 T:00000024cb47dd7f S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS  P:2 #:00439 T:00000024cb483ea7 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> @<OMX_BASE_PROCESS_CmdEvent> @line<631> msg<Processing OMX_CommandPortEnable>
    N:VPSS  P:2 #:00440 T:00000024cb48b73f S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_EnablePort> @line<777>
    N:VPSS  P:2 #:00441 T:00000024cb4914a7 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_EnablePort> @line<815> with error<0:ErrorNone>
    N:VPSS  P:2 #:00442 T:00000024cb498d07 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:VPSS  P:2 #:00443 T:00000024cb49f71c S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> @<OMX_BASE_CB_ReturnEventNotify> @line<121> msg<Notify client for port enable>
    N:VPSS  P:2 #:00444 T:00000024cb4a73ff S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<224> with error<0:ErrorNone>
    N:VPSS  P:2 #:00445 T:00000024cb4ae3af S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:VPSS  P:2 #:00446 T:00000024cb4b5019 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS  P:2 #:00447 T:00000024cb4bc9a3 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS  P:2 #:00448 T:00000024cb4c2ceb S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS  P:2 #:00449 T:00000024cb4c8e4f S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<869> msg<Processing OMX_CommandPortEnable>
    N:VPSS  P:2 #:00450 T:00000024cb4d0495 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_EventNotifyToClient> @line<881>
    N:VPSS  P:2 #:00451 T:00000024cb4ffe86 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:VPSS  P:2 #:00452 T:00000024cb507deb S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS  P:2 #:00453 T:00000024cb50f2ed S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS  P:2 #:00454 T:00000024cb516aff S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS  P:2 #:00455 T:00000024cb51d6c7 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS  P:2 #:00456 T:00000024cb524ed1 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS  P:2 #:00457 T:00000024cb52ae17 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS  P:2 #:00458 T:00000024ccb90e85 S:OmxRpc_rcmIfGetHandle:ComponentName:OMX.TI.VPSSM3.VFDC
    N:VPSS  P:2 #:00459 T:00000024ccb9b613 S:Entered function:omxrpc_module_init_client (3)
    N:VPSS  P:2 #:00460 T:00000024ccba0067 S:LayerId: 2
    N:VPSS  P:2 #:00461 T:00000024ccba8899 S:@ omxrpc_rcm_server_create: rcmServerName OmxRpcRcmServer_OMX.TI.VPSSM3.VFDC_Ctrl_2_2, priority 14
    N:VPSS  P:2 #:00462 T:00000024ccbaf657 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<225> msg<Before RcmServer_Params_init>
    N:VPSS  P:2 #:00463 T:00000024ccbb5e49 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<229> msg<After RcmServer_Params_init>
    N:VPSS  P:2 #:00464 T:00000024ccbbbb09 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<232> msg<Before RcmServer_create>
    N:VPSS  P:2 #:00465 T:00000024ccc1bb93 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<240> msg<After RcmServer_create>
    N:VPSS  P:2 #:00466 T:00000024ccc22831 S:@ omxrpc_rcm_server_remote_fxn_register regFxnCategory 1
    N:VPSS  P:2 #:00467 T:00000024ccc27731 S:Calling RcmServer_addSymbol(OmxRpcSetParameter)
    N:VPSS  P:2 #:00468 T:00000024ccc2fab7 S:Calling RcmServer_addSymbol(OmxRpcGetParameter)
    N:VPSS  P:2 #:00469 T:00000024ccc35841 S:Calling RcmServer_addSymbol(OmxRpcSetConfig)
    N:VPSS  P:2 #:00470 T:00000024ccc3dc43 S:Calling RcmServer_addSymbol(OmxRpcGetConfig)
    N:VPSS  P:2 #:00471 T:00000024ccc43365 S:Calling RcmServer_addSymbol(OmxRpcGetComponentVersion)
    N:VPSS  P:2 #:00472 T:00000024ccc49259 S:Calling RcmServer_addSymbol(OmxRpcGetExtensionIndex)
    N:VPSS  P:2 #:00473 T:00000024ccc4ee6d S:Calling RcmServer_addSymbol(OmxRpcGetState)
    N:VPSS  P:2 #:00474 T:00000024ccc54321 S:Calling RcmServer_addSymbol(OmxRpcSendCommand)
    N:VPSS  P:2 #:00475 T:00000024ccc59919 S:Calling RcmServer_addSymbol(OmxRpcUseBuffer)
    N:VPSS  P:2 #:00476 T:00000024ccc5ed3b S:Calling RcmServer_addSymbol(OmxRpcAllocBuffer)
    N:VPSS  P:2 #:00477 T:00000024ccc64211 S:Calling RcmServer_addSymbol(OmxRpcFreeBuffer)
    N:VPSS  P:2 #:00478 T:00000024ccc69689 S:Calling RcmServer_addSymbol(OmxRpcEmptyThisBuffer)
    N:VPSS  P:2 #:00479 T:00000024ccc6f05d S:Calling RcmServer_addSymbol(OmxRpcFillThisBuffer)
    N:VPSS  P:2 #:00480 T:00000024ccc74b2d S:Calling RcmServer_addSymbol(OmxRpcTunnelRequest)
    N:VPSS  P:2 #:00481 T:00000024ccc7aa39 S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<256> msg<Before RcmServer_start>
    N:VPSS  P:2 #:00482 T:00000024ccc845a1 S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<258> msg<After RcmServer_start>
    N:VPSS  P:2 #:00483 T:00000024ccc8aad9 S:Instance Register with omxRpc Module.Cnt = 3
    N:VPSS  P:2 #:00484 T:00000024ccc8e8e5 S:L_create: OmxRpc create: Component:OMX.TI.VPSSM3.VFDC, Layer:2
    N:VPSS  P:2 #:00485 T:00000024ccc94915 S:Component OMX.TI.VPSSM3.VFDC In table OMX.TI.VPSSM3.VFCC idx 0
    N:VPSS  P:2 #:00486 T:00000024ccc99e5f S:Component OMX.TI.VPSSM3.VFDC In table OMX.TI.VPSSM3.VFDC idx 1
    N:VPSS  P:2 #:00487 T:00000024ccc9ef55 S:Component OMX.TI.VPSSM3.VFDC found idx: 1
    N:VPSS  P:2 #:00488 T:00000024ccca4a4f S:In OMX_GetHandle, component OMX.TI.VPSSM3.VFDC, omxhandle 0x9f253ff8
    N:VPSS  P:2 #:00489 T:00000024cccf8c5d S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_SetDefaultProperties> @line<1238>
    N:VPSS  P:2 #:00490 T:00000024ccd01703 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_SetDefaultProperties> @line<1280> with error<0:ErrorNone>
    N:VPSS  P:2 #:00491 T:00000024ccd07e8b S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_ComponentInit> @line<133>
    N:VPSS  P:2 #:00492 T:00000024ccd2543f S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_InitializePorts> @line<115>
    N:VPSS  P:2 #:00493 T:00000024cce02f0d S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_InitializePorts> @line<217> with error<0:ErrorNone>
    N:VPSS  P:2 #:00494 T:00000024ccf56843 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_ComponentInit> @line<247> with error<0:ErrorNone>
    N:VPSS  P:2 #:00495 T:00000024ccf62dcb S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00496 T:00000024ccf68908 S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00497 T:00000024ccf6f769 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00498 T:00000024ccf76643 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00499 T:00000024ccf7da3f S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00500 T:00000024ccf82c09 S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00501 T:00000024ccf892d7 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00502 T:00000024ccf92041 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00503 T:00000024ccf99897 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00504 T:00000024ccf9eab3 S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00505 T:00000024ccfa52e5 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00506 T:00000024ccfac0cb S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00507 T:00000024ccfb2f7d S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00508 T:00000024ccfb812b S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00509 T:00000024ccfbe7eb S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00510 T:00000024ccfc5537 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00511 T:00000024ccfcc469 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00512 T:00000024ccfd163d S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00513 T:00000024ccfd7e7b S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00514 T:00000024ccfdebc7 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00515 T:00000024ccfe5a97 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00516 T:00000024ccfeac65 S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00517 T:00000024ccff1310 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00518 T:00000024ccff80bf S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00519 T:00000024ccfff077 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00520 T:00000024cd004227 S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00521 T:00000024cd00c4a1 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00522 T:00000024cd013673 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00523 T:00000024cd01aa8f S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00524 T:00000024cd01fc89 S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00525 T:00000024cd026375 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00526 T:00000024cd02d191 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00527 T:00000024cd034183 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00528 T:00000024cd039487 S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00529 T:00000024cd03fbd5 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00530 T:00000024cd046979 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00531 T:00000024cd04d8f7 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00532 T:00000024cd052bf1 S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00533 T:00000024cd059383 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00534 T:00000024cd060119 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00535 T:00000024cd067117 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00536 T:00000024cd06c411 S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00537 T:00000024cd072ad5 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00538 T:00000024cd079861 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00539 T:00000024cd080a37 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00540 T:00000024cd0875a4 S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00541 T:00000024cd08e2a5 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00542 T:00000024cd09514d S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00543 T:00000024cd09c461 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00544 T:00000024cd0a17d1 S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00545 T:00000024cd0a7f31 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00546 T:00000024cd0aecc7 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00547 T:00000024cd0b5cc5 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00548 T:00000024cd0bafbf S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00549 T:00000024cd0c175d S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00550 T:00000024cd0c84ff S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00551 T:00000024cd0cf531 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00552 T:00000024cd0d49d7 S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00553 T:00000024cd0db119 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00554 T:00000024cd0e1ea7 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00555 T:00000024cd0e8f3b S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00556 T:00000024cd0ee2dd S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00557 T:00000024cd0f4ab5 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00558 T:00000024cd0fb917 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00559 T:00000024cd104685 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00560 T:00000024cd109b87 S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00561 T:00000024cd1104ff S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00562 T:00000024cd1173d5 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00563 T:00000024cd11e477 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00564 T:00000024cd12364d S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00565 T:00000024cd129d93 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00566 T:00000024cd130b2b S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00567 T:00000024cd137a51 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00568 T:00000024cd13cc5b S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00569 T:00000024cd143339 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00570 T:00000024cd14a0ef S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00571 T:00000024cd150fb7 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Util> @line<546>
    N:VPSS  P:2 #:00572 T:00000024cd156159 S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<626>
    N:VPSS  P:2 #:00573 T:00000024cd15c81d S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_DIO_DefaultGetTotalBufferSize> @line<690> with error<0:ErrorNone>
    N:VPSS  P:2 #:00574 T:00000024cd1635a9 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Util> @line<574> with error<0:ErrorNone>
    N:VPSS  P:2 #:00575 T:00000024cdba6f81 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_SetCallbacks> @line<267>
    N:VPSS  P:2 #:00576 T:00000024cdbae681 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_SetCallbacks> @line<308> with error<0:ErrorNone>
    N:VPSS  P:2 #:00577 T:00000024cdbb4fed S:Result of pComponentInit: ErrorNone
    N:VPSS  P:2 #:00578 T:00000024cdbb8b5b S:Registering the component OMX.TI.VPSSM3.VFDC with TunnelMgr
    N:VPSS  P:2 #:00579 T:00000024cdbbd569 S:Entered: DomxTunnelMgr_registerHandle (0x9f253ff8, 0x9f704f54)
    N:VPSS  P:2 #:00580 T:00000024cdbc7649 S:Entered function:OmxRpc_rcmClientCreate (0x9f24f388, OmxRpcRcmServer_OMX.TI.VPSSM3.VFDC_Cb_3_3, 5)
    N:VPSS  P:2 #:00581 T:00000024cdbcddc5 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<983> msg<Before RcmClient_Params_init>
    N:VPSS  P:2 #:00582 T:00000024cdbd3d5d S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<985> msg<After RcmClient_Params_init>
    N:VPSS  P:2 #:00583 T:00000024cdbd9bcf S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<990> msg<Before RcmClient_create>
    N:VPSS  P:2 #:00584 T:00000024cdc4d669 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<992> msg<After RcmClient_create>
    N:VPSS  P:2 #:00585 T:00000024cdc56173 S:main: calling RcmClient_getSymbolIndex(OmxRpcCbEventHandler)
    N:VPSS  P:2 #:00586 T:00000024cdc7f375 S:main: calling RcmClient_getSymbolIndex(OmxRpcCbEmptyBufferDone)
    N:VPSS  P:2 #:00587 T:00000024cdca88f7 S:main: calling RcmClient_getSymbolIndex(OmxRpcCbFillBufferDone)
    N:VPSS  P:2 #:00588 T:00000024cdccac7d S:Module<ti.omx> @<domxtmgr_register_skelinfo> @line<417> msg<OmxRpcRcmServer_OMX.TI.VPSSM3.VFDC_Ctrl_2_2>
    N:VPSS  P:2 #:00589 T:00000024cdcd4f7f S:OmxRpc_rcmIfGetHandle:ComponentName:OmxRpcRcmServer_OMX.TI.VPSSM3.VFDC_Ctrl_2_2.Exiting..
    N:VPSS  P:2 #:00590 T:00000024ce4f1187 S:OmxRpc_rcmIfGetHandle:ComponentName:OMX.TI.VPSSM3.CTRL.DC
    N:VPSS  P:2 #:00591 T:00000024ce4fba3b S:Entered function:omxrpc_module_init_client (3)
    N:VPSS  P:2 #:00592 T:00000024ce500791 S:LayerId: 2
    N:VPSS  P:2 #:00593 T:00000024ce50c35d S:@ omxrpc_rcm_server_create: rcmServerName OmxRpcRcmServer_OMX.TI.VPSSM3.CTRL.DC_Ctrl_2_3, priority 14
    N:VPSS  P:2 #:00594 T:00000024ce513361 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<225> msg<Before RcmServer_Params_init>
    N:VPSS  P:2 #:00595 T:00000024ce519b8d S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<229> msg<After RcmServer_Params_init>
    N:VPSS  P:2 #:00596 T:00000024ce51f925 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<232> msg<Before RcmServer_create>
    N:VPSS  P:2 #:00597 T:00000024ce57d7bb S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<240> msg<After RcmServer_create>
    N:VPSS  P:2 #:00598 T:00000024ce58699d S:@ omxrpc_rcm_server_remote_fxn_register regFxnCategory 1
    N:VPSS  P:2 #:00599 T:00000024ce58b911 S:Calling RcmServer_addSymbol(OmxRpcSetParameter)
    N:VPSS  P:2 #:00600 T:00000024ce593f11 S:Calling RcmServer_addSymbol(OmxRpcGetParameter)
    N:VPSS  P:2 #:00601 T:00000024ce5995c9 S:Calling RcmServer_addSymbol(OmxRpcSetConfig)
    N:VPSS  P:2 #:00602 T:00000024ce59ebb9 S:Calling RcmServer_addSymbol(OmxRpcGetConfig)
    N:VPSS  P:2 #:00603 T:00000024ce5a41d5 S:Calling RcmServer_addSymbol(OmxRpcGetComponentVersion)
    N:VPSS  P:2 #:00604 T:00000024ce5a9fc1 S:Calling RcmServer_addSymbol(OmxRpcGetExtensionIndex)
    N:VPSS  P:2 #:00605 T:00000024ce5afcb5 S:Calling RcmServer_addSymbol(OmxRpcGetState)
    N:VPSS  P:2 #:00606 T:00000024ce5b510b S:Calling RcmServer_addSymbol(OmxRpcSendCommand)
    N:VPSS  P:2 #:00607 T:00000024ce5ba553 S:Calling RcmServer_addSymbol(OmxRpcUseBuffer)
    N:VPSS  P:2 #:00608 T:00000024ce5bf8cf S:Calling RcmServer_addSymbol(OmxRpcAllocBuffer)
    N:VPSS  P:2 #:00609 T:00000024ce5c4ecf S:Calling RcmServer_addSymbol(OmxRpcFreeBuffer)
    N:VPSS  P:2 #:00610 T:00000024ce5ca43f S:Calling RcmServer_addSymbol(OmxRpcEmptyThisBuffer)
    N:VPSS  P:2 #:00611 T:00000024ce5cfecf S:Calling RcmServer_addSymbol(OmxRpcFillThisBuffer)
    N:VPSS  P:2 #:00612 T:00000024ce5d5933 S:Calling RcmServer_addSymbol(OmxRpcTunnelRequest)
    N:VPSS  P:2 #:00613 T:00000024ce5db75f S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<256> msg<Before RcmServer_start>
    N:VPSS  P:2 #:00614 T:00000024ce5e4cc7 S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<258> msg<After RcmServer_start>
    N:VPSS  P:2 #:00615 T:00000024ce5eade1 S:Instance Register with omxRpc Module.Cnt = 4
    N:VPSS  P:2 #:00616 T:00000024ce5eec01 S:L_create: OmxRpc create: Component:OMX.TI.VPSSM3.CTRL.DC, Layer:2
    N:VPSS  P:2 #:00617 T:00000024ce5f4e67 S:Component OMX.TI.VPSSM3.CTRL.DC In table OMX.TI.VPSSM3.VFCC idx 0
    N:VPSS  P:2 #:00618 T:00000024ce5fc751 S:Component OMX.TI.VPSSM3.CTRL.DC In table OMX.TI.VPSSM3.VFDC idx 1
    N:VPSS  P:2 #:00619 T:00000024ce601bed S:Component OMX.TI.VPSSM3.CTRL.DC In table OMX.TI.VPSSM3.VFPC.DEIHDUALOUT idx 2
    N:VPSS  P:2 #:00620 T:00000024ce60720f S:Component OMX.TI.VPSSM3.CTRL.DC In table OMX.TI.VPSSM3.VFPC.DEIMDUALOUT idx 3
    N:VPSS  P:2 #:00621 T:00000024ce60cba5 S:Component OMX.TI.VPSSM3.CTRL.DC In table OMX.TI.VPSSM3.VFPC.NF idx 4
    N:VPSS  P:2 #:00622 T:00000024ce611ded S:Component OMX.TI.VPSSM3.CTRL.DC In table OMX.TI.VPSSM3.VFPC.INDTXSCWB idx 5
    N:VPSS  P:2 #:00623 T:00000024ce6172a7 S:Component OMX.TI.VPSSM3.CTRL.DC In table OMX.TI.VPSSM3.CTRL.TVP idx 6
    N:VPSS  P:2 #:00624 T:00000024ce61c92b S:Component OMX.TI.VPSSM3.CTRL.DC In table OMX.TI.VPSSM3.CTRL.DC idx 7
    N:VPSS  P:2 #:00625 T:00000024ce621b0f S:Component OMX.TI.VPSSM3.CTRL.DC found idx: 7
    N:VPSS  P:2 #:00626 T:00000024ce627b1f S:In OMX_GetHandle, component OMX.TI.VPSSM3.CTRL.DC, omxhandle 0x9f27c868
    N:VPSS  P:2 #:00627 T:00000024ce63864f S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_SetDefaultProperties> @line<1238>
    N:VPSS  P:2 #:00628 T:00000024ce63e871 S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_SetDefaultProperties> @line<1280> with error<0:ErrorNone>
    N:VPSS  P:2 #:00629 T:00000024ce64823f S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_ComponentInit> @line<133>
    N:VPSS  P:2 #:00630 T:00000024ce665b23 S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<_OMX_BASE_InitializePorts> @line<115>
    N:VPSS  P:2 #:00631 T:00000024ce66e61f S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<_OMX_BASE_InitializePorts> @line<217> with error<0:ErrorNone>
    N:VPSS  P:2 #:00632 T:00000024ce6c5aa1 S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_ComponentInit> @line<247> with error<0:ErrorNone>
    N:VPSS  P:2 #:00633 T:00000024ce71d7d1 S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_SetCallbacks> @line<267>
    N:VPSS  P:2 #:00634 T:00000024ce7239e3 S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_SetCallbacks> @line<308> with error<0:ErrorNone>
    N:VPSS  P:2 #:00635 T:00000024ce72a2d9 S:Result of pComponentInit: ErrorNone
    N:VPSS  P:2 #:00636 T:00000024ce72dc09 S:Registering the component OMX.TI.VPSSM3.CTRL.DC with TunnelMgr
    N:VPSS  P:2 #:00637 T:00000024ce732365 S:Entered: DomxTunnelMgr_registerHandle (0x9f27c868, 0x9f704f54)
    N:VPSS  P:2 #:00638 T:00000024ce73cea9 S:Entered function:OmxRpc_rcmClientCreate (0x9f277bf8, OmxRpcRcmServer_OMX.TI.VPSSM3.CTRL.DC_Cb_3_4, 5)
    N:VPSS  P:2 #:00639 T:00000024ce74383d S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<983> msg<Before RcmClient_Params_init>
    N:VPSS  P:2 #:00640 T:00000024ce749a87 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<985> msg<After RcmClient_Params_init>
    N:VPSS  P:2 #:00641 T:00000024ce74f735 S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<990> msg<Before RcmClient_create>
    N:VPSS  P:2 #:00642 T:00000024ce7c725d S:Module<ti.omx> @<OmxRpc_rcmClientCreate> @line<992> msg<After RcmClient_create>
    N:VPSS  P:2 #:00643 T:00000024ce7cf747 S:main: calling RcmClient_getSymbolIndex(OmxRpcCbEventHandler)
    N:VPSS  P:2 #:00644 T:00000024ce7f8611 S:main: calling RcmClient_getSymbolIndex(OmxRpcCbEmptyBufferDone)
    N:VPSS  P:2 #:00645 T:00000024ce819e19 S:main: calling RcmClient_getSymbolIndex(OmxRpcCbFillBufferDone)
    N:VPSS  P:2 #:00646 T:00000024ce83cb0f S:Module<ti.omx> @<domxtmgr_register_skelinfo> @line<417> msg<OmxRpcRcmServer_OMX.TI.VPSSM3.CTRL.DC_Ctrl_2_3>
    N:VPSS  P:2 #:00647 T:00000024ce846b4d S:OmxRpc_rcmIfGetHandle:ComponentName:OmxRpcRcmServer_OMX.TI.VPSSM3.CTRL.DC_Ctrl_2_3.Exiting..
    N:VPSS  P:2 #:00648 T:00000024cedbe7bb S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_GetParameter> @line<695>
    N:VPSS  P:2 #:00649 T:00000024cedc6483 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_GetParameter> @line<858> with error<0:ErrorNone>
    N:VPSS  P:2 #:00650 T:00000024cedeed05 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_SetParameter> @line<890>
    N:VPSS  P:2 #:00651 T:00000024cedf6037 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_SetParameter> @line<1163> with error<0:ErrorNone>
    N:VPSS  P:2 #:00652 T:00000024cee83a47 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_SetParameter> @line<890>
    N:VPSS  P:2 #:00653 T:00000024cee8ac0d S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_SetParameter> @line<1163> with error<0:ErrorNone>
    N:VPSS  P:2 #:00654 T:00000024ceeb18dd S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_SendCommand> @line<499>
    N:VPSS  P:2 #:00655 T:00000024ceebc617 S:OMX_BASE_SendCommand:OMX_CommandPortEnable, nParam1: 0
    N:VPSS  P:2 #:00656 T:00000024ceec4bff S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_SendCommand> @line<669> with error<0:ErrorNone>
    N:VPSS  P:2 #:00657 T:00000024ceed4bf7 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS  P:2 #:00658 T:00000024ceedd6d9 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS  P:2 #:00659 T:00000024ceee2d51 S:Module<OMX.TI.VPSSM3.VFDC> @<OMX_BASE_PROCESS_CmdEvent> @line<631> msg<Processing OMX_CommandPortEnable>
    N:VPSS  P:2 #:00660 T:00000024ceee9a11 S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_EnablePort> @line<777>
    N:VPSS  P:2 #:00661 T:00000024ceeeef0f S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_EnablePort> @line<815> with error<0:ErrorNone>
    N:VPSS  P:2 #:00662 T:00000024ceef604d S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:VPSS  P:2 #:00663 T:00000024ceefbbf5 S:Module<OMX.TI.VPSSM3.VFDC> @<OMX_BASE_CB_ReturnEventNotify> @line<121> msg<Notify client for port enable>
    N:VPSS  P:2 #:00664 T:00000024cef02eff S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<224> with error<0:ErrorNone>
    N:VPSS  P:2 #:00665 T:00000024cef0c9c7 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:VPSS  P:2 #:00666 T:00000024cef135e7 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS  P:2 #:00667 T:00000024cef1ab41 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS  P:2 #:00668 T:00000024cef20855 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS  P:2 #:00669 T:00000024cef26661 S:Module<OMX.TI.VPSSM3.VFDC> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<869> msg<Processing OMX_CommandPortEnable>
    N:VPSS  P:2 #:00670 T:00000024cef2d995 S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_EventNotifyToClient> @line<881>
    N:VPSS  P:2 #:00671 T:00000024cef642a9 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_SendCommand> @line<499>
    N:VPSS  P:2 #:00672 T:00000024cef6f2ec S:OMX_BASE_SendCommand:OMX_CommandStateSet, nParam1: 2
    N:VPSS  P:2 #:00673 T:00000024cef77e3b S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_SendCommand> @line<669> with error<0:ErrorNone>
    N:VPSS  P:2 #:00674 T:00000024cef9065d S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:VPSS  P:2 #:00676 T:00000024cefa8180 S:Entered Function :omxrpc_skel_allocbuffer
    N:VPSS  P:2 #:00677 T:00000024cefbf3fb S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Init> @line<120>
    N:VPSS  P:2 #:00678 T:00000024cefc5129 S:Entered: OMX_BASE_DIO_Init (0x9f1f8ca8, 0, OMX.DIO.NONTUNNEL, 0x9f1f8634)
    N:VPSS  P:2 #:00679 T:00000024cefd06ad S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Init> @line<172> with error<0:ErrorNone>
    N:VPSS  P:2 #:00680 T:00000024cefd68b5 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Open> @line<252>
    N:VPSS  P:2 #:00681 T:00000024cf0a1635 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Open> @line<258> with error<0:ErrorNone>
    N:VPSS  P:2 #:00675 T:00000024cef98261 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS  P:2 #:00682 T:00000024cf0b6d1d S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS  P:2 #:00684 T:00000024cf0cd6ab S:Entered Function :omxrpc_skel_allocbuffer
    N:VPSS  P:2 #:00683 T:00000024cf0bdd0d S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS  P:2 #:00685 T:00000024cf0f006f S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS  P:2 #:00686 T:00000024cf0fc34b S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS  P:2 #:00687 T:00000024cf103a63 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS  P:2 #:00688 T:00000024cf109697 S:Module<OMX.TI.VPSSM3.VFCC> @<OMX_BASE_PROCESS_CmdEvent> @line<538> msg<Processing OMX_CommandStateSet>
    N:Video P:1 #:00117 T:00000024cf8e3b1f S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_SendCommand> @line<499>
    N:VPSS  P:2 #:00689 T:00000024cf110329 S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_HandleStateTransition> @line<316>
    N:Video P:1 #:00118 T:00000024cf8f003b S:OMX_BASE_SendCommand:OMX_CommandStateSet, nParam1: 2
    N:VPSS  P:2 #:00690 T:00000024cf116019 S:Module<OMX.TI.VPSSM3.VFCC> @<_OMX_BASE_HandleStateTransition> @line<339> msg<Loaded to Idle Transition>
    N:Video P:1 #:00119 T:00000024cf8f9fa3 S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_SendCommand> @line<669> with error<0:ErrorNone>
    N:VPSS  P:2 #:00691 T:00000024cf133123 S:Entered Function :omxrpc_skel_allocbuffer
    N:Video P:1 #:00120 T:00000024cf912431 S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS  P:2 #:00692 T:00000024cf175a81 S:Entered Function :omxrpc_skel_allocbuffer
    N:Video P:1 #:00121 T:00000024cf9295fb S:Entered Function :omxrpc_skel_usebuffer
    N:VPSS  P:2 #:00693 T:00000024cf1b1675 S:Entered Function :omxrpc_skel_allocbuffer
    N:Video P:1 #:00122 T:00000024cf940b49 S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_DIO_Init> @line<120>
    N:VPSS  P:2 #:00694 T:00000024cf1e9ef9 S:Entered Function :omxrpc_skel_allocbuffer
    N:Video P:1 #:00123 T:00000024cf946d71 S:Entered: OMX_BASE_DIO_Init (0x9dc337e8, 0, OMX.DIO.NONTUNNEL, 0x9dc3315c)
    N:VPSS  P:2 #:00695 T:00000024cf211763 S: OMX_VFCC_DriverCreate - DONE !!!
    N:Video P:1 #:00124 T:00000024cf952407 S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_DIO_Init> @line<172> with error<0:ErrorNone>
    N:VPSS  P:2 #:00696 T:00000024cf2160d1 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:Video P:1 #:00125 T:00000024cf95917b S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_DIO_Open> @line<252>
    N:VPSS  P:2 #:00697 T:00000024cf21c2dd S:Module<OMX.TI.VPSSM3.VFCC> @<OMX_BASE_CB_ReturnEventNotify> @line<115> msg<Notify client for state transition>
    N:Video P:1 #:00126 T:00000024cf97c5fd S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_DIO_Open> @line<258> with error<0:ErrorNone>
    N:VPSS  P:2 #:00698 T:00000024cf223fa1 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<224> with error<0:ErrorNone>
    N:Video P:1 #:00127 T:00000024cf9939e7 S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS  P:2 #:00699 T:00000024cf22ac13 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_HandleStateTransition> @line<483> with error<0:ErrorNone>
    N:Video P:1 #:00129 T:00000024cf9aa85d S:Entered Function :omxrpc_skel_usebuffer
    N:VPSS  P:2 #:00700 T:00000024cf231887 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:Video P:1 #:00128 T:00000024cf99aac1 S:Module<OMX.TI.DUCATI.VIDENC> @<OMX_BASE_PROCESS_CmdEvent> @line<538> msg<Processing OMX_CommandStateSet>
    N:VPSS  P:2 #:00701 T:00000024cf2382df S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:Video P:1 #:00130 T:00000024cf9cab29 S:Module<OMX.TI.DUCATI.VIDENC> Entering<_OMX_BASE_HandleStateTransition> @line<316>
    N:VPSS  P:2 #:00702 T:00000024cf23fad3 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:Video P:1 #:00132 T:00000024cf9e08a1 S:Entered Function :omxrpc_skel_usebuffer
    N:VPSS  P:2 #:00703 T:00000024cf2455df S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:Video P:1 #:00131 T:00000024cf9d1a43 S:Module<OMX.TI.DUCATI.VIDENC> @<_OMX_BASE_HandleStateTransition> @line<339> msg<Loaded to Idle Transition>
    N:VPSS  P:2 #:00704 T:00000024cf24b357 S:Module<OMX.TI.VPSSM3.VFCC> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<821> msg<Processing OMX_CommandStateSet>
    N:Video P:1 #:00134 T:00000024cfa1672f S:Entered Function :omxrpc_skel_usebuffer
    N:VPSS  P:2 #:00705 T:00000024cf25250e S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_HandleStateTransitionComplete> @line<506>
    N:Video P:1 #:00133 T:00000024cfa067f7 S:OMX_TI_VIDENC_CommandNotifyFromBase::Line 3502::VENC->Loaded to Idle Transition Begin
    N:VPSS  P:2 #:00706 T:00000024cf2587fd S:Module<OMX.TI.VPSSM3.VFCC> @<_OMX_BASE_HandleStateTransitionComplete> @line<535> msg<Loaded to Idle Transition>
    N:Video P:1 #:00135 T:00000024cfa37aa7 S:OMX_TI_VIDENC_CommandNotifyFromBase::Line 3506::VENC->Before VIDENC2_Create
    N:VPSS  P:2 #:00707 T:00000024cf263813 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_RestoreDioGroupInfo> @line<1398>
    N:Video P:1 #:00136 T:00000024cfa3dd5d S:Calling VIDENC2_create for ivahd_h264enc_0
    N:VPSS  P:2 #:00708 T:00000024cf269ae1 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_RestoreDioGroupInfo> @line<1453> with error<0:ErrorNone>
    N:Video P:1 #:00137 T:00000024cfa4dcbb S:Entered Function :omxrpc_skel_allocbuffer
    N:VPSS  P:2 #:00709 T:00000024cf2706d1 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_HandleStateTransitionComplete> @line<704> with error<0:ErrorNone>
    N:Video P:1 #:00138 T:00000024cfa64597 S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_DIO_Init> @line<120>
    N:VPSS  P:2 #:00710 T:00000024cf27763f S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_EventNotifyToClient> @line<881>
    N:Video P:1 #:00139 T:00000024cfa6a6e1 S:Entered: OMX_BASE_DIO_Init (0x9dc337e8, 1, OMX.DIO.NONTUNNEL, 0x9dc33154)
    N:VPSS  P:2 #:00711 T:00000024cf2ab4a7 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_SendCommand> @line<499>
    N:Video P:1 #:00140 T:00000024cfa7803f S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_DIO_Init> @line<172> with error<0:ErrorNone>
    N:VPSS  P:2 #:00712 T:00000024cf2b6fd1 S:OMX_BASE_SendCommand:OMX_CommandStateSet, nParam1: 2
    N:Video P:1 #:00141 T:00000024cfa7f2ef S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_DIO_Open> @line<252>
    N:VPSS  P:2 #:00713 T:00000024cf2bfe45 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_SendCommand> @line<669> with error<0:ErrorNone>
    N:Video P:1 #:00142 T:00000024cfb08211 S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_DIO_Open> @line<258> with error<0:ErrorNone>
    N:VPSS  P:2 #:00715 T:00000024cf2ec645 S:Entered Function :omxrpc_skel_usebuffer
    N:Video P:1 #:00143 T:00000024cfb342b5 S:Entered Function :omxrpc_skel_allocbuffer
    N:VPSS  P:2 #:00716 T:00000024cf3028fb S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Init> @line<120>
    N:Video P:1 #:00144 T:00000024cfb6d333 S:Entered Function :omxrpc_skel_allocbuffer
    N:VPSS  P:2 #:00717 T:00000024cf308b25 S:Entered: OMX_BASE_DIO_Init (0x9f226a50, 0, OMX.DIO.NONTUNNEL, 0x9f2263ec)
    N:Video P:1 #:00145 T:00000024cfba3bb3 S:Entered Function :omxrpc_skel_allocbuffer
    N:VPSS  P:2 #:00718 T:00000024cf3141d3 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Init> @line<172> with error<0:ErrorNone>
    N:VPSS  P:2 #:00719 T:00000024cf31aa31 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Open> @line<252>
    N:VPSS  P:2 #:00720 T:00000024cf341791 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Open> @line<258> with error<0:ErrorNone>
    N:VPSS  P:2 #:00714 T:00000024cf2d809d S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:VPSS  P:2 #:00722 T:00000024cf369715 S:Entered Function :omxrpc_skel_usebuffer
    N:VPSS  P:2 #:00721 T:00000024cf358729 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS  P:2 #:00723 T:00000024cf389efb S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS  P:2 #:00725 T:00000024cf39e0d9 S:Entered Function :omxrpc_skel_usebuffer
    N:VPSS  P:2 #:00724 T:00000024cf391477 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS  P:2 #:00727 T:00000024cf3d32db S:Entered Function :omxrpc_skel_usebuffer
    N:VPSS  P:2 #:00726 T:00000024cf3c0967 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS  P:2 #:00729 T:00000024cf406945 S:Entered Function :omxrpc_skel_usebuffer
    N:VPSS  P:2 #:00728 T:00000024cf3f6275 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS  P:2 #:00731 T:00000024cf438793 S:Entered Function :omxrpc_skel_usebuffer
    N:VPSS  P:2 #:00730 T:00000024cf4283b1 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS  P:2 #:00732 T:00000024cf45c2ad S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> @<OMX_BASE_PROCESS_CmdEvent> @line<538> msg<Processing OMX_CommandStateSet>
    N:VPSS  P:2 #:00734 T:00000024cf473acf S:Entered Function :omxrpc_skel_allocbuffer
    N:Video P:1 #:00146 T:00000024cfc87b85 S:IRESMAN_TILEDMEMORY_getHandles_Plugin 285
    N:VPSS  P:2 #:00735 T:00000024cf48a309 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Init> @line<120>
    N:Video P:1 #:00147 T:00000024cfc8db3d S:accessDimension = 0, accessUnit = 1 sizeDim0 = 69376 sizeDim1 = 0 alignment = 32
    N:VPSS  P:2 #:00736 T:00000024cf490567 S:Entered: OMX_BASE_DIO_Init (0x9f226a50, 16, OMX.DIO.NONTUNNEL, 0x9f2263dc)
    N:Video P:1 #:00148 T:00000024cfc98f95 S:IRESMAN_TILEDMEMORY_getHandles_Plugin 285
    N:VPSS  P:2 #:00737 T:00000024cf49b471 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Init> @line<172> with error<0:ErrorNone>
    N:Video P:1 #:00149 T:00000024cfc9d341 S:accessDimension = 0, accessUnit = 1 sizeDim0 = 2992 sizeDim1 = 0 alignment = 32
    N:VPSS  P:2 #:00738 T:00000024cf4a20b7 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Open> @line<252>
    N:Video P:1 #:00150 T:00000024cfca646d S:IRESMAN_TILEDMEMORY_getHandles_Plugin 285
    N:VPSS  P:2 #:00739 T:00000024cf5502b5 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Open> @line<258> with error<0:ErrorNone>
    N:Video P:1 #:00151 T:00000024cfcaa7ad S:accessDimension = 0, accessUnit = 1 sizeDim0 = 36 sizeDim1 = 0 alignment = 32
    N:VPSS  P:2 #:00733 T:00000024cf463fef S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_HandleStateTransition> @line<316>
    N:Video P:1 #:00152 T:00000024cfcb36eb S:IRESMAN_TILEDMEMORY_getHandles_Plugin 285
    N:VPSS  P:2 #:00741 T:00000024cf578cbd S:Entered Function :omxrpc_skel_allocbuffer
    N:Video P:1 #:00153 T:00000024cfcb7a2f S:accessDimension = 1, accessUnit = 2 sizeDim0 = 2048 sizeDim1 = 1152 alignment = 32
    N:VPSS  P:2 #:00740 T:00000024cf566d69 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> @<_OMX_BASE_HandleStateTransition> @line<339> msg<Loaded to Idle Transition>
    N:Video P:1 #:00154 T:00000024cfcc0e6f S:IRESMAN_TILEDMEMORY_getHandles_Plugin 285
    N:VPSS  P:2 #:00742 T:00000024cf5adb81 S:Entered Function :omxrpc_skel_allocbuffer
    N:Video P:1 #:00155 T:00000024cfcc4f59 S:accessDimension = 1, accessUnit = 3 sizeDim0 = 2048 sizeDim1 = 576 alignment = 32
    N:VPSS  P:2 #:00743 T:00000024cf5e7a89 S:Entered Function :omxrpc_skel_allocbuffer
    N:Video P:1 #:00156 T:00000024cfccec83 S:IRESMAN_TILEDMEMORY_getHandles_Plugin 285
    N:VPSS  P:2 #:00744 T:00000024cf61dfe1 S:Entered Function :omxrpc_skel_allocbuffer
    N:Video P:1 #:00157 T:00000024cfcd2f33 S:accessDimension = 1, accessUnit = 2 sizeDim0 = 2048 sizeDim1 = 1152 alignment = 32
    N:VPSS  P:2 #:00745 T:00000024cf65a4c3 S:Entered Function :omxrpc_skel_allocbuffer
    N:Video P:1 #:00158 T:00000024cfce1233 S:IRESMAN_TILEDMEMORY_getHandles_Plugin 285
    N:VPSS  P:2 #:00746 T:00000024cf671ee3 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Init> @line<120>
    N:Video P:1 #:00159 T:00000024cfce606f S:accessDimension = 1, accessUnit = 3 sizeDim0 = 2048 sizeDim1 = 576 alignment = 32
    N:VPSS  P:2 #:00747 T:00000024cf67835f S:Entered: OMX_BASE_DIO_Init (0x9f226a50, 17, OMX.DIO.NONTUNNEL, 0x9f2263dc)
    N:Video P:1 #:00160 T:00000024cfcfea0d S:VIDENC2_control(XDM_GETSTATUS) after VIDENC2_create returned errorcode = 0x0
    N:VPSS  P:2 #:00748 T:00000024cf683efd S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Init> @line<172> with error<0:ErrorNone>
    N:Video P:1 #:00161 T:00000024cfd1a375 S:VIDENC2_control(XDM_GETSTATUS) returned errorcode = 0x0
    N:VPSS  P:2 #:00749 T:00000024cf68aaa3 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Open> @line<252>
    N:Video P:1 #:00162 T:00000024cfd1f841 S:OMX_TI_VIDENC_CommandNotifyFromBase::Line 3513::VENC->VIDENC2_Create Successful
    N:VPSS  P:2 #:00750 T:00000024cf720e93 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Open> @line<258> with error<0:ErrorNone>
    N:Video P:1 #:00163 T:00000024cfd25305 S:OMX_TI_VIDENC_CommandNotifyFromBase::Line 3545::VENC->Before IvaServer_registerInstance
    N:VPSS  P:2 #:00751 T:00000024cf74f395 S:Entered Function :omxrpc_skel_allocbuffer
    N:Video P:1 #:00164 T:00000024cfd2df63 S:IvaScheduler_registerInstance::Line 665::Width 1920::Height 1080::Resolution 4
    N:VPSS  P:2 #:00752 T:00000024cf786f77 S:Entered Function :omxrpc_skel_allocbuffer
    N:Video P:1 #:00165 T:00000024cfd356bb S:IvaScheduler_asssignStaticResource::Line 356::CodecId 0::Allocated IVAHD 1::Estimated IVAHD Load of Codec(MHz) 500::Total IVAHD load(MHz) 500
    N:VPSS  P:2 #:00753 T:00000024cf7c17ef S:Entered Function :omxrpc_skel_allocbuffer
    N:Video P:1 #:00166 T:00000024cfd3db4f S:IvaScheduler_registerInstance::Line 816::Scheduling Scheme 0
    N:VPSS  P:2 #:00754 T:00000024cf834703 S:M2M Driver DEI-DualOut Opened!!
    N:Video P:1 #:00167 T:00000024cfd42995 S:IvaScheduler_registerInstance::Line 818::Number of IVAHDs 3
    N:Video P:1 #:00168 T:00000024cfd476ff S:IvaScheduler_registerInstance::Line 820::Number of registered channels 1
    N:VPSS  P:2 #:00755 T:00000024cf839da7 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:Video P:1 #:00169 T:00000024cfd4cceb S:IvaScheduler_registerInstance::Line 825::IVAHD Queue 0::Number of channels 0
    N:VPSS  P:2 #:00756 T:00000024cf8405c9 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> @<OMX_BASE_CB_ReturnEventNotify> @line<115> msg<Notify client for state transition>
    N:Video P:1 #:00170 T:00000024cfd55654 S:IvaScheduler_registerInstance::Line 827::IVAHD Queue 0::Number of frames 0
    N:VPSS  P:2 #:00757 T:00000024cf848d83 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<224> with error<0:ErrorNone>
    N:Video P:1 #:00171 T:00000024cfd5bb6f S:IvaScheduler_registerInstance::Line 829::IVAHD Queue 0::Number of commands 0
    N:VPSS  P:2 #:00758 T:00000024cf8501bf S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_HandleStateTransition> @line<483> with error<0:ErrorNone>
    N:Video P:1 #:00172 T:00000024cfd61589 S:IvaScheduler_registerInstance::Line 831::IVAHD Queue 0::Last Codec Id 0
    N:VPSS  P:2 #:00759 T:00000024cf85771f S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:Video P:1 #:00173 T:00000024cfd6688f S:IvaScheduler_registerInstance::Line 833::IVAHD Queue 0::Load(MHz) 0
    N:VPSS  P:2 #:00760 T:00000024cf85e687 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:Video P:1 #:00174 T:00000024cfd6bd2f S:IvaScheduler_registerInstance::Line 825::IVAHD Queue 1::Number of channels 1
    N:VPSS  P:2 #:00761 T:00000024cf866489 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:Video P:1 #:00175 T:00000024cfd71375 S:IvaScheduler_registerInstance::Line 827::IVAHD Queue 1::Number of frames 0
    N:VPSS  P:2 #:00762 T:00000024cf86cbbf S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:Video P:1 #:00176 T:00000024cfd766ed S:IvaScheduler_registerInstance::Line 829::IVAHD Queue 1::Number of commands 0
    N:VPSS  P:2 #:00763 T:00000024cf872e67 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<821> msg<Processing OMX_CommandStateSet>
    N:Video P:1 #:00177 T:00000024cfd7bb7d S:IvaScheduler_registerInstance::Line 831::IVAHD Queue 1::Last Codec Id 0
    N:VPSS  P:2 #:00764 T:00000024cf87a3a3 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_HandleStateTransitionComplete> @line<506>
    N:Video P:1 #:00178 T:00000024cfd80f3d S:IvaScheduler_registerInstance::Line 833::IVAHD Queue 1::Load(MHz) 500
    N:VPSS  P:2 #:00765 T:00000024cf880cf1 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> @<_OMX_BASE_HandleStateTransitionComplete> @line<535> msg<Loaded to Idle Transition>
    N:Video P:1 #:00179 T:00000024cfd864f7 S:IvaScheduler_registerInstance::Line 825::IVAHD Queue 2::Number of channels 0
    N:VPSS  P:2 #:00766 T:00000024cf8897fb S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_RestoreDioGroupInfo> @line<1398>
    N:Video P:1 #:00180 T:00000024cfd8bb39 S:IvaScheduler_registerInstance::Line 827::IVAHD Queue 2::Number of frames 0
    N:VPSS  P:2 #:00767 T:00000024cf890707 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_RestoreDioGroupInfo> @line<1453> with error<0:ErrorNone>
    N:Video P:1 #:00181 T:00000024cfd90eb1 S:IvaScheduler_registerInstance::Line 829::IVAHD Queue 2::Number of commands 0
    N:VPSS  P:2 #:00768 T:00000024cf89b1bb S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_HandleStateTransitionComplete> @line<704> with error<0:ErrorNone>
    N:Video P:1 #:00182 T:00000024cfd96341 S:IvaScheduler_registerInstance::Line 831::IVAHD Queue 2::Last Codec Id 0
    N:VPSS  P:2 #:00769 T:00000024cf8a2e67 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_EventNotifyToClient> @line<881>
    N:Video P:1 #:00183 T:00000024cfd9b701 S:IvaScheduler_registerInstance::Line 833::IVAHD Queue 2::Load(MHz) 0
    N:VPSS  P:2 #:00770 T:00000024cf8d95ab S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:Video P:1 #:00184 T:00000024cfda10f1 S:OMX_TI_VIDENC_CommandNotifyFromBase::Line 3553::VENC->IvaServer_registerInstance Successful
    N:VPSS  P:2 #:00771 T:00000024cf8e2769 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:Video P:1 #:00185 T:00000024cfdaa337 S:OMX_TI_VIDENC_CommandNotifyFromBase::Line 3623::VENC->Loaded to Idle Transition End
    N:VPSS  P:2 #:00772 T:00000024cf8ea3f1 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:Video P:1 #:00186 T:00000024cfdaffdd S:OMX_TI_VIDENC_CommandNotifyFromBase::Line 3913::VENC->Before OMX_EventCmdComplete Notify
    N:VPSS  P:2 #:00773 T:00000024cf8f242d S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:Video P:1 #:00187 T:00000024cfdb5e73 S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:VPSS  P:2 #:00774 T:00000024cf8fa86d S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:Video P:1 #:00188 T:00000024cfdbbad3 S:Module<OMX.TI.DUCATI.VIDENC> @<OMX_BASE_CB_ReturnEventNotify> @line<115> msg<Notify client for state transition>
    N:VPSS  P:2 #:00775 T:00000024cfe60e63 S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_SendCommand> @line<499>
    N:Video P:1 #:00189 T:00000024cfdc38f5 S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<224> with error<0:ErrorNone>
    N:VPSS  P:2 #:00776 T:00000024cfe6d2f3 S:OMX_BASE_SendCommand:OMX_CommandStateSet, nParam1: 2
    N:Video P:1 #:00190 T:00000024cfdcc689 S:OMX_TI_VIDENC_CommandNotifyFromBase::Line 3919::VENC->OMX_EventCmdComplete Notify Done
    N:VPSS  P:2 #:00777 T:00000024cfe76f45 S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_SendCommand> @line<669> with error<0:ErrorNone>
    N:Video P:1 #:00191 T:00000024cfdd483f S:Module<OMX.TI.DUCATI.VIDENC> Leaving<_OMX_BASE_HandleStateTransition> @line<483> with error<0:ErrorNone>
    N:VPSS  P:2 #:00778 T:00000024cfe8ac67 S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:Video P:1 #:00192 T:00000024cfddb9bf S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:VPSS  P:2 #:00779 T:00000024cfe93c67 S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:Video P:1 #:00193 T:00000024cfde2653 S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS  P:2 #:00780 T:00000024cfe99a69 S:Module<OMX.TI.VPSSM3.CTRL.DC> @<OMX_BASE_PROCESS_CmdEvent> @line<538> msg<Processing OMX_CommandStateSet>
    N:Video P:1 #:00194 T:00000024cfde9d8f S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS  P:2 #:00781 T:00000024cfea064f S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<_OMX_BASE_HandleStateTransition> @line<316>
    N:Video P:1 #:00195 T:00000024cfdefefd S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS  P:2 #:00782 T:00000024cfea64bf S:Module<OMX.TI.VPSSM3.CTRL.DC> @<_OMX_BASE_HandleStateTransition> @line<339> msg<Loaded to Idle Transition>
    N:Video P:1 #:00196 T:00000024cfdf5d4d S:Module<OMX.TI.DUCATI.VIDENC> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<821> msg<Processing OMX_CommandStateSet>
    N:VPSS  P:2 #:00783 T:00000024cfec2d29 S:Display Controller Path configured for 0!!
    N:Video P:1 #:00197 T:00000024cfdfc9e3 S:Module<OMX.TI.DUCATI.VIDENC> Entering<_OMX_BASE_HandleStateTransitionComplete> @line<506>
    N:Video P:1 #:00198 T:00000024cfe02b11 S:Module<OMX.TI.DUCATI.VIDENC> @<_OMX_BASE_HandleStateTransitionComplete> @line<535> msg<Loaded to Idle Transition>
    N:VPSS  P:2 #:00784 T:00000024cfecaeeb S: Display Controller Driver Create - DONE !!!
    N:Video P:1 #:00199 T:00000024cfe09f68 S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_RestoreDioGroupInfo> @line<1398>
    N:VPSS  P:2 #:00785 T:00000024cfecf32b S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:Video P:1 #:00200 T:00000024cfe103e7 S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_RestoreDioGroupInfo> @line<1453> with error<0:ErrorNone>
    N:VPSS  P:2 #:00786 T:00000024cfed5797 S:Module<OMX.TI.VPSSM3.CTRL.DC> @<OMX_BASE_CB_ReturnEventNotify> @line<115> msg<Notify client for state transition>
    N:Video P:1 #:00201 T:00000024cfe173d7 S:Module<OMX.TI.DUCATI.VIDENC> Leaving<_OMX_BASE_HandleStateTransitionComplete> @line<704> with error<0:ErrorNone>
    N:VPSS  P:2 #:00787 T:00000024cfedd309 S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<224> with error<0:ErrorNone>
    N:Video P:1 #:00202 T:00000024cfe1eb21 S:Module<OMX.TI.DUCATI.VIDENC> Entering<_OMX_BASE_EventNotifyToClient> @line<881>
    N:VPSS  P:2 #:00788 T:00000024cfee4233 S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<_OMX_BASE_HandleStateTransition> @line<483> with error<0:ErrorNone>
    N:Video P:1 #:00203 T:00000024cfe55263 S:Module<OMX.TI.DUCATI.VIDENC> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:VPSS  P:2 #:00789 T:00000024cfeeab17 S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:Video P:1 #:00204 T:00000024cfe5e1f1 S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS  P:2 #:00790 T:00000024cfef17b9 S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:Video P:1 #:00205 T:00000024cfe65a05 S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS  P:2 #:00791 T:00000024cfef89cf S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:Video P:1 #:00206 T:00000024cfe6cd45 S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS  P:2 #:00792 T:00000024cfefe577 S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:Video P:1 #:00207 T:00000024cfe7442f S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS  P:2 #:00793 T:00000024cff0435d S:Module<OMX.TI.VPSSM3.CTRL.DC> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<821> msg<Processing OMX_CommandStateSet>
    N:VPSS  P:2 #:00794 T:00000024cff0b6d5 S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<_OMX_BASE_HandleStateTransitionComplete> @line<506>
    N:VPSS  P:2 #:00795 T:00000024cff116c9 S:Module<OMX.TI.VPSSM3.CTRL.DC> @<_OMX_BASE_HandleStateTransitionComplete> @line<535> msg<Loaded to Idle Transition>
    N:VPSS  P:2 #:00796 T:00000024cff18b89 S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_RestoreDioGroupInfo> @line<1398>
    N:VPSS  P:2 #:00797 T:00000024cff1ef0b S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_RestoreDioGroupInfo> @line<1453> with error<0:ErrorNone>
    N:VPSS  P:2 #:00798 T:00000024cff256cf S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<_OMX_BASE_HandleStateTransitionComplete> @line<704> with error<0:ErrorNone>
    N:VPSS  P:2 #:00799 T:00000024cff2c9e7 S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<_OMX_BASE_EventNotifyToClient> @line<881>
    N:VPSS  P:2 #:00800 T:00000024cff62fe5 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_SendCommand> @line<499>
    N:VPSS  P:2 #:00801 T:00000024cff6e7e7 S:OMX_BASE_SendCommand:OMX_CommandStateSet, nParam1: 2
    N:VPSS  P:2 #:00802 T:00000024cff779a7 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_SendCommand> @line<669> with error<0:ErrorNone>
    N:VPSS  P:2 #:00804 T:00000024cff9f35d S:Entered Function :omxrpc_skel_usebuffer
    N:VPSS  P:2 #:00805 T:00000024cffb5b7f S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Init> @line<120>
    N:VPSS  P:2 #:00806 T:00000024cffbe32d S:Entered: OMX_BASE_DIO_Init (0x9f253ff8, 0, OMX.DIO.NONTUNNEL, 0x9f253994)
    N:VPSS  P:2 #:00807 T:00000024cffca6f3 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Init> @line<172> with error<0:ErrorNone>
    N:VPSS  P:2 #:00808 T:00000024cffd0c25 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Open> @line<252>
    N:VPSS  P:2 #:00809 T:00000024cfff7239 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Open> @line<258> with error<0:ErrorNone>
    N:VPSS  P:2 #:00803 T:00000024cff8e1e1 S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:VPSS  P:2 #:00810 T:00000024d000ae0d S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS  P:2 #:00812 T:00000024d001fb8d S:Entered Function :omxrpc_skel_usebuffer
    N:VPSS  P:2 #:00811 T:00000024d0012bad S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS  P:2 #:00814 T:00000024d005653f S:Entered Function :omxrpc_skel_usebuffer
    N:VPSS  P:2 #:00813 T:00000024d00480df S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS  P:2 #:00815 T:00000024d007647d S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS  P:2 #:00816 T:00000024d00888ad S:Entered Function :omxrpc_skel_usebuffer
    N:VPSS  P:2 #:00817 T:00000024d00a78e3 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS  P:2 #:00818 T:00000024d00bb11d S:Entered Function :omxrpc_skel_usebuffer
    N:VPSS  P:2 #:00819 T:00000024d00dc01b S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS  P:2 #:00820 T:00000024d00e269d S:Module<OMX.TI.VPSSM3.VFDC> @<OMX_BASE_PROCESS_CmdEvent> @line<538> msg<Processing OMX_CommandStateSet>
    N:VPSS  P:2 #:00821 T:00000024d00f42ef S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_HandleStateTransition> @line<316>
    N:VPSS  P:2 #:00822 T:00000024d00fa82f S:Module<OMX.TI.VPSSM3.VFDC> @<_OMX_BASE_HandleStateTransition> @line<339> msg<Loaded to Idle Transition>
    N:VPSS  P:2 #:00823 T:00000024d0117a11 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:VPSS  P:2 #:00824 T:00000024d011dc0f S:Module<OMX.TI.VPSSM3.VFDC> @<OMX_BASE_CB_ReturnEventNotify> @line<115> msg<Notify client for state transition>
    N:VPSS  P:2 #:00825 T:00000024d0125bb3 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<224> with error<0:ErrorNone>
    N:VPSS  P:2 #:00826 T:00000024d012fcf9 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_HandleStateTransition> @line<483> with error<0:ErrorNone>
    N:VPSS  P:2 #:00827 T:00000024d013667d S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:VPSS  P:2 #:00828 T:00000024d013cde9 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS  P:2 #:00829 T:00000024d0144069 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS  P:2 #:00830 T:00000024d0149dbf S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS  P:2 #:00831 T:00000024d014f6fb S:Module<OMX.TI.VPSSM3.VFDC> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<821> msg<Processing OMX_CommandStateSet>
    N:VPSS  P:2 #:00832 T:00000024d01562d5 S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_HandleStateTransitionComplete> @line<506>
    N:VPSS  P:2 #:00833 T:00000024d015c1b7 S:Module<OMX.TI.VPSSM3.VFDC> @<_OMX_BASE_HandleStateTransitionComplete> @line<535> msg<Loaded to Idle Transition>
    N:VPSS  P:2 #:00834 T:00000024d0163ed5 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_RestoreDioGroupInfo> @line<1398>
    N:VPSS  P:2 #:00835 T:00000024d016a3c1 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_RestoreDioGroupInfo> @line<1453> with error<0:ErrorNone>
    N:VPSS  P:2 #:00836 T:00000024d01713d7 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_HandleStateTransitionComplete> @line<704> with error<0:ErrorNone>
    N:VPSS  P:2 #:00837 T:00000024d01784ed S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_EventNotifyToClient> @line<881>
    N:VPSS  P:2 #:00838 T:00000024d01aeb03 S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_SendCommand> @line<499>
    N:VPSS  P:2 #:00839 T:00000024d01ba9b1 S:OMX_BASE_SendCommand:OMX_CommandStateSet, nParam1: 3
    N:VPSS  P:2 #:00840 T:00000024d01c3b11 S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_SendCommand> @line<669> with error<0:ErrorNone>
    N:VPSS  P:2 #:00841 T:00000024d01db29d S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:VPSS  P:2 #:00842 T:00000024d01e29fb S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS  P:2 #:00843 T:00000024d01e93af S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS  P:2 #:00844 T:00000024d01f00eb S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS  P:2 #:00845 T:00000024d01f656b S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS  P:2 #:00846 T:00000024d01febdf S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS  P:2 #:00847 T:00000024d020631f S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS  P:2 #:00848 T:00000024d020befb S:Module<OMX.TI.VPSSM3.CTRL.DC> @<OMX_BASE_PROCESS_CmdEvent> @line<538> msg<Processing OMX_CommandStateSet>
    N:VPSS  P:2 #:00849 T:00000024d02128cd S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<_OMX_BASE_HandleStateTransition> @line<316>
    N:VPSS  P:2 #:00850 T:00000024d0218c39 S:Module<OMX.TI.VPSSM3.CTRL.DC> @<_OMX_BASE_HandleStateTransition> @line<376> msg<Idle to Executing Transition>
    N:VPSS  P:2 #:00851 T:00000024d0223a0d S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:VPSS  P:2 #:00852 T:00000024d0229e03 S:Module<OMX.TI.VPSSM3.CTRL.DC> @<OMX_BASE_CB_ReturnEventNotify> @line<115> msg<Notify client for state transition>
    N:VPSS  P:2 #:00853 T:00000024d023174b S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<224> with error<0:ErrorNone>
    N:VPSS  P:2 #:00854 T:00000024d023861b S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<_OMX_BASE_HandleStateTransition> @line<483> with error<0:ErrorNone>
    N:VPSS  P:2 #:00855 T:00000024d023f0d7 S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:VPSS  P:2 #:00856 T:00000024d0245ad5 S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS  P:2 #:00857 T:00000024d024c869 S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS  P:2 #:00858 T:00000024d0252373 S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS  P:2 #:00859 T:00000024d0257da7 S:Module<OMX.TI.VPSSM3.CTRL.DC> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<821> msg<Processing OMX_CommandStateSet>
    N:VPSS  P:2 #:00860 T:00000024d025efd3 S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<_OMX_BASE_HandleStateTransitionComplete> @line<506>
    N:VPSS  P:2 #:00861 T:00000024d026508f S:Module<OMX.TI.VPSSM3.CTRL.DC> @<_OMX_BASE_HandleStateTransitionComplete> @line<614> msg<Idle to Executing Transition>
    N:VPSS  P:2 #:00862 T:00000024d026c682 S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<_OMX_BASE_HandleStateTransitionComplete> @line<704> with error<0:ErrorNone>
    N:VPSS  P:2 #:00863 T:00000024d0273803 S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<_OMX_BASE_EventNotifyToClient> @line<881>
    N:VPSS  P:2 #:00864 T:00000024d02a6a33 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_SendCommand> @line<499>
    N:VPSS  P:2 #:00865 T:00000024d02b1e3d S:OMX_BASE_SendCommand:OMX_CommandStateSet, nParam1: 3
    N:VPSS  P:2 #:00866 T:00000024d02baaa3 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_SendCommand> @line<669> with error<0:ErrorNone>
    N:VPSS  P:2 #:00867 T:00000024d02d1edd S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:VPSS  P:2 #:00868 T:00000024d02d90ff S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS  P:2 #:00869 T:00000024d02dfcbb S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS  P:2 #:00870 T:00000024d02e6ffb S:Module<OMX.TI.VPSSM3.CTRL.DC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS  P:2 #:00871 T:00000024d02ed6f5 S:Module<OMX.TI.VPSSM3.CTRL.DC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS  P:2 #:00872 T:00000024d02f63cd S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS  P:2 #:00873 T:00000024d02fd67d S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS  P:2 #:00874 T:00000024d0302e25 S:Module<OMX.TI.VPSSM3.VFDC> @<OMX_BASE_PROCESS_CmdEvent> @line<538> msg<Processing OMX_CommandStateSet>
    N:VPSS  P:2 #:00875 T:00000024d030984b S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_HandleStateTransition> @line<316>
    N:VPSS  P:2 #:00876 T:00000024d0312bf5 S:Module<OMX.TI.VPSSM3.VFDC> @<_OMX_BASE_HandleStateTransition> @line<376> msg<Idle to Executing Transition>
    N:VPSS  P:2 #:00877 T:00000024d033d3ef S:Mosaic configuration DONE!!
    N:Video P:1 #:00208 T:00000024d1915131 S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_SendCommand> @line<499>
    N:VPSS  P:2 #:00878 T:00000024d18887ab S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:Video P:1 #:00209 T:00000024d1921cbb S:OMX_BASE_SendCommand:OMX_CommandStateSet, nParam1: 3
    N:VPSS  P:2 #:00879 T:00000024d188f875 S:Module<OMX.TI.VPSSM3.VFDC> @<OMX_BASE_CB_ReturnEventNotify> @line<115> msg<Notify client for state transition>
    N:Video P:1 #:00210 T:00000024d192b6c7 S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_SendCommand> @line<669> with error<0:ErrorNone>
    N:VPSS  P:2 #:00880 T:00000024d18974a5 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<224> with error<0:ErrorNone>
    N:Video P:1 #:00211 T:00000024d193fc97 S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS  P:2 #:00881 T:00000024d189de23 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_HandleStateTransition> @line<483> with error<0:ErrorNone>
    N:Video P:1 #:00212 T:00000024d1948d03 S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS  P:2 #:00882 T:00000024d18a4663 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:Video P:1 #:00213 T:00000024d194f0bb S:Module<OMX.TI.DUCATI.VIDENC> @<OMX_BASE_PROCESS_CmdEvent> @line<538> msg<Processing OMX_CommandStateSet>
    N:VPSS  P:2 #:00883 T:00000024d18aad4b S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:Video P:1 #:00214 T:00000024d195652b S:Module<OMX.TI.DUCATI.VIDENC> Entering<_OMX_BASE_HandleStateTransition> @line<316>
    N:VPSS  P:2 #:00884 T:00000024d18b2227 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:Video P:1 #:00215 T:00000024d195cbc1 S:Module<OMX.TI.DUCATI.VIDENC> @<_OMX_BASE_HandleStateTransition> @line<376> msg<Idle to Executing Transition>
    N:VPSS  P:2 #:00885 T:00000024d18b7f9d S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:Video P:1 #:00216 T:00000024d1968259 S:OMX_TI_VIDENC_CommandNotifyFromBase::Line 3634::VENC->Idle to Executing Transition Begin
    N:VPSS  P:2 #:00886 T:00000024d18bdb60 S:Module<OMX.TI.VPSSM3.VFDC> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<821> msg<Processing OMX_CommandStateSet>
    N:Video P:1 #:00217 T:00000024d196e6a9 S:_OMX_TI_VIDENC_EnablePeriodicDataProcess::Line 5342::VENC->Enabled Notification based data processing
    N:VPSS  P:2 #:00887 T:00000024d18c491f S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_HandleStateTransitionComplete> @line<506>
    N:Video P:1 #:00218 T:00000024d1978abd S:OMX_TI_VIDENC_CommandNotifyFromBase::Line 3648::VENC->Idle to Executing Transition End
    N:VPSS  P:2 #:00888 T:00000024d18ca945 S:Module<OMX.TI.VPSSM3.VFDC> @<_OMX_BASE_HandleStateTransitionComplete> @line<614> msg<Idle to Executing Transition>
    N:Video P:1 #:00219 T:00000024d197f2cd S:OMX_TI_VIDENC_CommandNotifyFromBase::Line 3913::VENC->Before OMX_EventCmdComplete Notify
    N:VPSS  P:2 #:00889 T:00000024d18d1669 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_HandleStateTransitionComplete> @line<704> with error<0:ErrorNone>
    N:Video P:1 #:00220 T:00000024d1985327 S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:VPSS  P:2 #:00890 T:00000024d18d82d1 S:Module<OMX.TI.VPSSM3.VFDC> Entering<_OMX_BASE_EventNotifyToClient> @line<881>
    N:Video P:1 #:00221 T:00000024d198b50b S:Module<OMX.TI.DUCATI.VIDENC> @<OMX_BASE_CB_ReturnEventNotify> @line<115> msg<Notify client for state transition>
    N:VPSS  P:2 #:00891 T:00000024d190fd71 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_DIO_Control> @line<455>
    N:Video P:1 #:00222 T:00000024d199355d S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<224> with error<0:ErrorNone>
    N:VPSS  P:2 #:00892 T:00000024d192882f S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_DIO_Control> @line<463> with error<0:ErrorNone>
    N:Video P:1 #:00223 T:00000024d199a1fb S:OMX_TI_VIDENC_CommandNotifyFromBase::Line 3919::VENC->OMX_EventCmdComplete Notify Done
    N:VPSS  P:2 #:00893 T:00000024d193094d S:Module<OMX.TI.VPSSM3.VFDC> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:Video P:1 #:00224 T:00000024d19a21cf S:Module<OMX.TI.DUCATI.VIDENC> Leaving<_OMX_BASE_HandleStateTransition> @line<483> with error<0:ErrorNone>
    N:VPSS  P:2 #:00894 T:00000024d1938435 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:Video P:1 #:00225 T:00000024d19a95fd S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:VPSS  P:2 #:00895 T:00000024d193fec9 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:Video P:1 #:00226 T:00000024d19b02d7 S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS  P:2 #:00896 T:00000024d1952c11 S:Module<OMX.TI.VPSSM3.VFDC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:Video P:1 #:00227 T:00000024d19b7d15 S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS  P:2 #:00897 T:00000024d1959ff3 S:Module<OMX.TI.VPSSM3.VFDC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:Video P:1 #:00228 T:00000024d19bd9f5 S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS  P:2 #:00898 T:00000024d1a20689 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_SendCommand> @line<499>
    N:Video P:1 #:00229 T:00000024d19c3bf9 S:Module<OMX.TI.DUCATI.VIDENC> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<821> msg<Processing OMX_CommandStateSet>
    N:VPSS  P:2 #:00899 T:00000024d1a2cdb5 S:OMX_BASE_SendCommand:OMX_CommandStateSet, nParam1: 3
    N:Video P:1 #:00230 T:00000024d19cad4f S:Module<OMX.TI.DUCATI.VIDENC> Entering<_OMX_BASE_HandleStateTransitionComplete> @line<506>
    N:VPSS  P:2 #:00900 T:00000024d1a36f97 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_SendCommand> @line<669> with error<0:ErrorNone>
    N:Video P:1 #:00231 T:00000024d19d1109 S:Module<OMX.TI.DUCATI.VIDENC> @<_OMX_BASE_HandleStateTransitionComplete> @line<614> msg<Idle to Executing Transition>
    N:VPSS  P:2 #:00901 T:00000024d1a4b07f S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:Video P:1 #:00232 T:00000024d19d8643 S:Module<OMX.TI.DUCATI.VIDENC> Leaving<_OMX_BASE_HandleStateTransitionComplete> @line<704> with error<0:ErrorNone>
    N:VPSS  P:2 #:00902 T:00000024d1a54b3f S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:Video P:1 #:00233 T:00000024d19dfbcb S:Module<OMX.TI.DUCATI.VIDENC> Entering<_OMX_BASE_EventNotifyToClient> @line<881>
    N:VPSS  P:2 #:00903 T:00000024d1a5b613 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> @<OMX_BASE_PROCESS_CmdEvent> @line<538> msg<Processing OMX_CommandStateSet>
    N:Video P:1 #:00234 T:00000024d1a142a5 S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_DIO_Control> @line<455>
    N:VPSS  P:2 #:00904 T:00000024d1a6304d S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_HandleStateTransition> @line<316>
    N:Video P:1 #:00235 T:00000024d1a2dc3b S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_DIO_Control> @line<463> with error<0:ErrorNone>
    N:VPSS  P:2 #:00905 T:00000024d1a69b31 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> @<_OMX_BASE_HandleStateTransition> @line<376> msg<Idle to Executing Transition>
    N:Video P:1 #:00236 T:00000024d1a35b13 S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_DIO_Control> @line<455>
    N:VPSS  P:2 #:00906 T:00000024d1a98a51 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:Video P:1 #:00237 T:00000024d1a4c9fd S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_DIO_Control> @line<463> with error<0:ErrorNone>
    N:VPSS  P:2 #:00907 T:00000024d1aa057f S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> @<OMX_BASE_CB_ReturnEventNotify> @line<115> msg<Notify client for state transition>
    N:Video P:1 #:00238 T:00000024d1a541f3 S:Module<OMX.TI.DUCATI.VIDENC> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:VPSS  P:2 #:00908 T:00000024d1aa8f09 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<224> with error<0:ErrorNone>
    N:Video P:1 #:00239 T:00000024d1a5bcfb S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS  P:2 #:00909 T:00000024d1ab06df S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_HandleStateTransition> @line<483> with error<0:ErrorNone>
    N:Video P:1 #:00240 T:00000024d1a6315b S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS  P:2 #:00910 T:00000024d1ab7fc9 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:Video P:1 #:00241 T:00000024d1a6eb55 S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS  P:2 #:00911 T:00000024d1abf2ad S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:Video P:1 #:00242 T:00000024d1a76823 S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS  P:2 #:00912 T:00000024d1ac733f S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS  P:2 #:00913 T:00000024d1acd769 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS  P:2 #:00914 T:00000024d1ad3c6d S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<821> msg<Processing OMX_CommandStateSet>
    N:VPSS  P:2 #:00915 T:00000024d1adb42f S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_HandleStateTransitionComplete> @line<506>
    N:VPSS  P:2 #:00916 T:00000024d1ae1f47 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> @<_OMX_BASE_HandleStateTransitionComplete> @line<614> msg<Idle to Executing Transition>
    N:VPSS  P:2 #:00917 T:00000024d1aed19f S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_HandleStateTransitionComplete> @line<704> with error<0:ErrorNone>
    N:VPSS  P:2 #:00918 T:00000024d1af4d75 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<_OMX_BASE_EventNotifyToClient> @line<881>
    N:VPSS  P:2 #:00919 T:00000024d1b29cd5 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_SendCommand> @line<499>
    N:VPSS  P:2 #:00920 T:00000024d1b35573 S:OMX_BASE_SendCommand:OMX_CommandStateSet, nParam1: 3
    N:VPSS  P:2 #:00921 T:00000024d1b3e1bd S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_SendCommand> @line<669> with error<0:ErrorNone>
    N:VPSS  P:2 #:00922 T:00000024d1b53e5b S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Control> @line<455>
    N:VPSS  P:2 #:00923 T:00000024d1b6de37 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Control> @line<463> with error<0:ErrorNone>
    N:VPSS  P:2 #:00924 T:00000024d1b75917 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Control> @line<455>
    N:VPSS  P:2 #:00925 T:00000024d1b88a69 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Control> @line<463> with error<0:ErrorNone>
    N:VPSS  P:2 #:00926 T:00000024d1b8f085 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_DIO_Control> @line<455>
    N:VPSS  P:2 #:00927 T:00000024d1ba16a9 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_DIO_Control> @line<463> with error<0:ErrorNone>
    N:VPSS  P:2 #:00928 T:00000024d1ba8681 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:VPSS  P:2 #:00929 T:00000024d1bafaa9 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS  P:2 #:00930 T:00000024d1bb6a89 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS  P:2 #:00931 T:00000024d1bbdf53 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS  P:2 #:00932 T:00000024d1bc4b5d S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS  P:2 #:00933 T:00000024d1bce58b S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS  P:2 #:00934 T:00000024d1bd6535 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_PROCESS_CmdEvent> @line<526>
    N:VPSS  P:2 #:00935 T:00000024d1bde5c1 S:Module<OMX.TI.VPSSM3.VFCC> @<OMX_BASE_PROCESS_CmdEvent> @line<538> msg<Processing OMX_CommandStateSet>
    N:VPSS  P:2 #:00936 T:00000024d1be510f S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_HandleStateTransition> @line<316>
    N:VPSS  P:2 #:00937 T:00000024d1beab93 S:Module<OMX.TI.VPSSM3.VFCC> @<_OMX_BASE_HandleStateTransition> @line<376> msg<Idle to Executing Transition>
    N:VPSS  P:2 #:00938 T:00000024d1bf2eb9 S:Starting Capture Driver
    N:VPSS  P:2 #:00939 T:00000024d1bf6fcb S:RESET Count:: 1 , curTime:: 315250
    N:VPSS  P:2 #:00940 T:00000024d1bfb02e S:VFCC VIP Id:0
    N:VPSS  P:2 #:00941 T:00000024d22985d5 S:RESET Count:: 1 , curTime:: 315264
    N:VPSS  P:2 #:00942 T:00000024d229d9ed S:Capture Driver Started!!
    N:Video P:1 #:00243 T:00000024d23cebc1 S:Module<OMX.TI.DUCATI.VIDENC> Entering<OMX_BASE_GetParameter> @line<695>
    N:VPSS  P:2 #:00943 T:00000024d22a4511 S:Priming the buffers to the Capture Driver
    N:Video P:1 #:00244 T:00000024d23d7303 S:Module<OMX.TI.DUCATI.VIDENC> Leaving<OMX_BASE_GetParameter> @line<858> with error<0:ErrorNone>
    N:VPSS  P:2 #:00944 T:00000024d22a8e0b S:Priming the buffers to the Capture Driver
    N:VPSS  P:2 #:00945 T:00000024d22ad10f S:Priming the buffers to the Capture Driver
    N:VPSS  P:2 #:00946 T:00000024d22b1585 S:Priming the buffers to the Capture Driver
    N:VPSS  P:2 #:00947 T:00000024d22b5797 S:Priming the buffers to the Capture Driver
    N:VPSS  P:2 #:00948 T:00000024d22b9bfd S:Priming the buffers to the Capture Driver
    N:VPSS  P:2 #:00949 T:00000024d22bdb09 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CB_ReturnEventNotify> @line<100>
    N:VPSS  P:2 #:00950 T:00000024d22c3ffb S:Module<OMX.TI.VPSSM3.VFCC> @<OMX_BASE_CB_ReturnEventNotify> @line<115> msg<Notify client for state transition>
    N:VPSS  P:2 #:00951 T:00000024d22cc103 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CB_ReturnEventNotify> @line<224> with error<0:ErrorNone>
    N:VPSS  P:2 #:00952 T:00000024d22d2d29 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_HandleStateTransition> @line<483> with error<0:ErrorNone>
    N:VPSS  P:2 #:00953 T:00000024d22d9a6d S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_PROCESS_CmdEvent> @line<784> with error<0:ErrorNone>
    N:VPSS  P:2 #:00954 T:00000024d22e06a3 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS  P:2 #:00955 T:00000024d22e78ed S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CmdCompleteEventHandler> @line<483>
    N:VPSS  P:2 #:00956 T:00000024d22ed3c3 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_PROCESS_CmdCompleteEvent> @line<809>
    N:VPSS  P:2 #:00957 T:00000024d22f314a S:Module<OMX.TI.VPSSM3.VFCC> @<OMX_BASE_PROCESS_CmdCompleteEvent> @line<821> msg<Processing OMX_CommandStateSet>
    N:VPSS  P:2 #:00958 T:00000024d22fa257 S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_HandleStateTransitionComplete> @line<506>
    N:VPSS  P:2 #:00959 T:00000024d2300751 S:Module<OMX.TI.VPSSM3.VFCC> @<_OMX_BASE_HandleStateTransitionComplete> @line<614> msg<Idle to Executing Transition>
    N:VPSS  P:2 #:00960 T:00000024d2310e82 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_HandleStateTransitionComplete> @line<704> with error<0:ErrorNone>
    N:VPSS  P:2 #:00961 T:00000024d2318191 S:Module<OMX.TI.VPSSM3.VFCC> Entering<_OMX_BASE_EventNotifyToClient> @line<881>
    N:VPSS  P:2 #:00962 T:00000024d234d597 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_DIO_Control> @line<455>
    N:VPSS  P:2 #:00963 T:00000024d2364ff5 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_DIO_Control> @line<463> with error<0:ErrorNone>
    N:VPSS  P:2 #:00964 T:00000024d236c363 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<_OMX_BASE_EventNotifyToClient> @line<1172> with error<0:ErrorNone>
    N:VPSS  P:2 #:00965 T:00000024d2373197 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_PROCESS_CmdCompleteEvent> @line<930> with error<0:ErrorNone>
    N:VPSS  P:2 #:00966 T:00000024d237a157 S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CmdCompleteEventHandler> @line<496> with error<0:ErrorNone>
    N:VPSS  P:2 #:00967 T:00000024d2383f27 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_CmdEventHandler> @line<434>
    N:VPSS  P:2 #:00968 T:00000024d238a67b S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_CmdEventHandler> @line<466> with error<0:ErrorNone>
    N:VPSS  P:2 #:00969 T:00000024d23af9a5 S:Module<OMX.TI.VPSSM3.VFCC> Entering<OMX_BASE_GetParameter> @line<695>
    N:VPSS  P:2 #:00970 T:00000024d23b76fd S:Module<OMX.TI.VPSSM3.VFCC> Leaving<OMX_BASE_GetParameter> @line<858> with error<0:ErrorNone>
    N:VPSS  P:2 #:00971 T:00000024d23cda59 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_GetParameter> @line<695>
    N:VPSS  P:2 #:00972 T:00000024d23d5c75 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_GetParameter> @line<858> with error<0:ErrorNone>
    N:VPSS  P:2 #:00973 T:00000024d2533753 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Entering<OMX_BASE_GetParameter> @line<695>
    N:VPSS  P:2 #:00974 T:00000024d253bb53 S:Module<OMX.TI.VPSSM3.VFPC.DEIMDUALOUT> Leaving<OMX_BASE_GetParameter> @line<858> with error<0:ErrorNone>
    N:VPSS  P:2 #:00975 T:00000024d2aad5e7 S:VIP-0 PORT-A Dropped Frame Count :1 Total Capture Frame Count 0
  • Please would someone be nice enough to post some debug output for a working version of capture_encode with the "recommended" settings (those that are suggested to you when you don't give it any arguments)?
    If you could use debug for both VPSS and video at DEBUG_LEVEL0 that would be super.
    Thanks in advance,
    Ralph
  • Okay, I've got it working now. I had to set sHwPortParam.eCaptMode to OMX_VIDEO_CaptureModeSC_DISCRETESYNC_ACTVID_VSYNC.
    Ralph
  • Hello Ralph,
    I am having a very similar problem as you had.
    Data in my card's inputs is captured:
    - through vip port 0: YUV422 embedded sync
    - through vip port 1: RGB24 discrete sync
    For the second input (RGB24, vip 1), the OMX Capture component does not return with callbacks calls (it works for vip 0).
    So I thought that RGB24 will not be supported but I see that you made it work... I will be grateful for any suggestions.
    In my source for IL_ClientSetCaptureParams I set the following for vip 1:
    sHwPortParam.eCaptMode = OMX_VIDEO_CaptureModeSC_DISCRETESYNC_ACTVID_VSYNC;
    sHwPortParam.eVifMode = OMX_VIDEO_CaptureVifMode_24BIT;
    sHwPortParam.eInColorFormat = OMX_COLOR_Format24bitRGB888;
    Thank you,
    Przemek
