hi,
I am using AM1808 . But it stopped and the lcd shows "android".The log is:
logcat
--------- beginning of /dev/log/main
I/DEBUG ( 689): debuggerd: Fe
b 11 2012 02:09:31
E/keystore( 696): chdir: /data/misc/keystore: Permission denied
I/Netd ( 688): Netd 1.0 starting
--------- beginning of /dev/log/system
I/Vold ( 687): Vold 2.1 (the revenge) firing up
D/Vold ( 687): Volume sdcard state changing -1 (Initializing) -> 0 (No-Media)
W/Vold ( 687): No UMS switch available
D/AndroidRuntime( 691):
D/AndroidRuntime( 691): >>>>>>>>>>>>>> AndroidRuntime START <<<<<<<<<<<<<<
D/AndroidRuntime( 691): CheckJNI is ON
D/AndroidRuntime( 691): --- registering native functions ---
I/ ( 692): ServiceManager: 0xacd0
E/keystore( 709): chdir: /data/misc/keystore: Permission denied
E/ALSALib ( 692): external/alsa-lib/src/control/control.c:909:(snd_ctl_open_noupdate) Invalid CTL AndroidPlayback
W/AudioHardwareALSA( 692): Unable to attach mixer to device AndroidPlayback: No such file or directory
E/ALSALib ( 692): external/alsa-lib/src/control/control.c:909:(snd_ctl_open_noupdate) Invalid CTL AndroidCapture
W/AudioHardwareALSA( 692): Unable to attach mixer to device AndroidCapture: No such file or directory
I/CameraService( 692): CameraService started: pid=692
D/AudioHardwareALSA( 692): openOutputStream called for devices: 0x00000002
D/ALSAModule( 692): open called for devices 00000002 in mode 0...
E/ALSALib ( 692): external/alsa-lib/src/pcm/pcm.c:2201:(snd_pcm_open_noupdate) Unknown PCM
AndroidPlayback_Speaker_normal
E/ALSALib ( 692): external/alsa-lib/src/pcm/pcm.c:2201:(snd_pcm_open_noupdate) Unknown PCM AndroidPlayback_Speaker
I/ALSAModule( 692): Initialized ALSA PLAYBACK device default
I/AudioFlinger( 692): AudioFlinger's thread 0x3d598 ready to run
D/ALSAModule( 692): route called for devices 00000002 in mode 0...
E/AudioHardwareALSA( 692): CALLING STANDBY
I/ethernet( 691): Loading ethernet jni class
I/SamplingProfilerIntegration( 691): Profiler is disabled.
I/Zygote ( 691): Preloading classes...
D/dalvikvm( 691): GC_EXPLICIT freed 818 objects / 47336 bytes in 6ms
D/dalvikvm( 691): GC_EXPLICIT freed 219 objects / 13568 bytes in 7ms
D/dalvikvm( 691): GC_EXPLICIT freed 253 objects / 14352 bytes in 9ms
D/dalvikvm( 691): GC_EXPLICIT freed 466 objects / 28904 bytes in 10ms
D/dalvikvm( 691): GC_EXPLICIT freed 2090 objects / 108424 bytes in 13ms
W/MediaProfiles( 691): could not find media config xml file
D/dalvikvm( 691): GC_EXPLICIT freed 279 objects / 15984 bytes in 13ms
D/dalvikvm( 691): GC_FOR_MALLOC freed 5090 objects / 225704 bytes in 26ms
E/keystore( 717): chdir: /data/misc/keystore: Permission denied
D/dalvikvm( 691): GC_FOR_MALLOC freed 11260 objects / 382968 bytes in 3
4ms
D/dalvikvm( 691): GC_FOR_MALLOC freed 9845 objects / 462880 bytes in 39
ms
D/dalvikvm( 691): GC_FOR_MALLOC freed 8651 objects / 421608 bytes in 42ms
D/dalvikvm( 691): GC_FOR_MALLOC freed 7703 objects / 462120 byt
es in 43ms
D/dalvikvm( 691): GC_FOR_MALLOC freed 7236 objects / 460432 bytes in 44
ms
D/dalvikvm( 691): GC_FOR_MALLOC freed 7571 objects / 461400 bytes in 45
ms
D/dalvikvm( 691): GC_FOR_MALLOC freed 7594 objects / 458184 bytes in 46
ms
D/dalvikvm( 691): GC_EXPLICIT freed 1269 objects / 80872 bytes in 40ms
D/dalvikvm( 691): GC_EXPLICIT freed 596 objects / 29184 bytes in 40ms
D/dalvikvm( 691): GC_EXPLICIT freed 449 objects / 25024 bytes in 43ms
D/dalvikvm( 691): GC_EXPLICIT freed 308 objects / 35168 bytes i
n 59ms
D/dalvikvm( 691): GC_EXPLICIT freed 279 objects / 19016 bytes in 59ms
E/keystore( 720): chdir: /data/misc/keystore: Permission denied
D/dalvikvm( 691): GC_EXPLICIT freed 341 objects / 18480 bytes in 60ms
D/dalvikvm( 691): GC_EXPLICIT freed 449 objects / 28352 bytes in 61ms
D/dalvikvm( 691): GC_EXPLICIT freed 529 objects / 53240 bytes in 67ms
D/dalvikvm( 691): GC_EXPLICIT freed 623 objects / 34016 bytes in 68ms
D/dalvikvm( 691): GC_EXPLICIT freed 861 objects / 46968 bytes i
n 68ms
D/dalvikvm( 691): GC_EXPLICIT freed 1747 objects / 85480 bytes in 71ms
D/dalvikvm( 691): GC_EXPLICIT freed 447 objects / 29408 bytes in 72ms
D/dalvikvm( 691): GC_EXPLICIT freed 315 objects / 20232 bytes i
n 73ms
I/Zygote ( 691): ...preloaded 1265 classes in 12494ms.
E/Zygote ( 691): setreuid() failed. errno: 17
D/dalvikvm( 691): GC_EXPLICIT freed 104 objects / 14208 bytes in 71ms
I/Zygote ( 691): Preloading resources...
W/Zygote ( 691): Preloaded drawable resource #0x108009
3 (res/drawable-mdpi/sym_def_app_icon.png) that varies with configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x1080002 (res/drawable-mdpi/arrow_down_float.png) that varies with
configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x10800b3 (res/drawable/btn_check.xml) that varies with configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x10800b6 (res/drawable-mdpi/btn_check_label_background.9.png) that
W/Zygote ( 691): Preloaded drawable resource #0x10800b7 (res/drawable-mdpi/btn_check_off.png) that varies with
configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x10800bc (res/drawable-mdpi/btn_check_on.png) that varies with
configuration!!
E/keystore( 723): chdir: /data/misc/keystore: Permission denied
W/Zygote ( 691): Preloaded drawable resource #0x1080004 (res/drawable/btn_default.xml) that varies with configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x1080005 (res/drawable/btn_default_small.xml) that varies with
configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x1080006 (res/drawable/btn_dropdown.xml) that varies with configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x1080008 (res/drawable/btn_plus.xml) that varies with configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x1080007 (res/drawable/btn_minus.xml) that varies with configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x1080009 (res/drawable/btn_radio.xml) that varies with configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x108000a (res/drawable/btn_star.xml) that varies with configuration!!
D/dalvikvm( 691): GC_EXPLICIT freed 421 objects / 25848 bytes in 73ms
W/Zygote ( 691): Preloaded drawable resource #0x1080131 (res/drawable/btn_toggle.xml) that varies with configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x1080197 (res/drawable-mdpi/ic_emergency.png) that varies with
configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x1080012 (res/drawable-mdpi/divider_horizontal_bright.9.png) that varies
W/Zygote ( 691): Preloaded drawable resource #0x1080014 (res/drawable-mdpi/divider_horizontal_dark.9.png) that varies with
configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x1080016 (res/drawable/edit_text.xml) that varies with configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x1080170 (res/drawable/expander_group.xml) that varies with configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x1080062 (res/drawable/list_selector_background.xml) that varies with
configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x108022a (res/drawable-mdpi/menu_background.9.png) that varies with
configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x108022b (res/drawable-mdpi/menu_background_fill_parent_width.9.png)
W/Zygote ( 691): Preloaded drawable resource #0x108022c (res/drawable/menu_selector.xml) that varies with configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x1080237 (res/drawable-mdpi/panel_background.9.png) that varies with
configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x108023e (res/drawable-mdpi/popup_bottom_bright.9.png) that varies with
configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x108023f (res/drawable-mdpi/popup_bottom_dark.9.png) that varies with
configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x1080240 (res/drawable-mdpi/popup_bottom_medium.9.png) that varies with
configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x1080241 (res/drawable-mdpi/popup_center_bright.9.png) that varies with
configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x1080242 (res/drawable-mdpi/popup_center_dark.9.png) that varies with
configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x1080245 (res/drawable-mdpi/popup_full_dark.9.png) that varies with
configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x1080248 (res/drawable-mdpi/popup_top_bright.9.png) that varies with
configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x1080249 (res/drawable-mdpi/popup_top_dark.9.png) that varies with
configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x108006d (res/drawable/progress_indeterminate_horizontal.xml) that varies
W/Zygote ( 691): Preloaded drawable resource #0x108024f (res/drawable/progress_small.xml) that varies with configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x1080250 (res/drawable/progress_small_titlebar.xml) that varies with
configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x1080273 (res/drawable-mdpi/scrollbar_handle_horizontal.9.png) that varies
W/Zygote ( 691): Preloaded drawable resource #0x1080274 (res/drawable-mdpi/scrollbar_handle_vertical.9.png) that varies
D/dalvikvm( 691): GC_EXPLICIT freed 477 objects / 32616 bytes in 74ms
W/Zygote ( 691): Preloaded drawable resource #0x1080071 (res/drawable/spinner_dropdown_background.xml) that varies with
configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x1080357 (res/drawable-mdpi/title_bar_shadow.9.png) that varies with
configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x10801d9 (res/drawable-
mdpi/indicator_code_lock_drag_direction_green_up.png) that varies with configuration!!
W/Zygote ( 691)
: Preloaded drawable resource #0x10801da (res/drawable-mdpi/indicator_code_lock_drag_direction_red_up.png) that varies
W/Zygote ( 691): Preloaded drawable resource #0x10801db (res/drawable-mdpi/indicator_code_lock_point_area_default.png)
W/Zygote ( 691): Preloaded drawable resource #0x10801dc (res/drawable-mdpi/indicator_code_lock_point_area_green.png)
W/Zygote ( 691): Preloaded drawable resource #0x10801dd (res/drawable-mdpi/indicator_code_lock_point_area_red.png) that
W/Zygote ( 691): Preloaded drawable resource #0x10801eb (res/drawable-mdpi/jog_tab_bar_left_end_confirm_gray.9.png) that
W/Zygote ( 691): Preloaded drawable resource #0x10801ef (res/drawable-mdpi/jog_tab_bar_left_end_normal.9.png) that varies
W/Zygote ( 691): Preloaded drawable resource #0x10801f0 (res/drawable-mdpi/jog_tab_bar_left_end_pressed.9.png) that
W/Zygote ( 691): Preloaded drawable resource #0x10801f4 (res/drawable-mdpi/jog_tab_bar_right_end_confirm_gray.9.png)
W/Zygote ( 691): Preloaded drawable resource #0x10801f8 (res/drawable-mdpi/jog_tab_bar_right_end_normal.9.png) that
W/Zygote ( 691): Preloaded drawable resource #0x10801f9 (res/drawable-mdpi/jog_tab_bar_right_end_pressed.9.png) that
W/Zygote ( 691): Preloaded drawable resource #0x10801fe (res/drawable-mdpi/jog_tab_left_confirm_gray.png) that varies with
configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x1080203 (res/drawable-mdpi/jog_tab_left_normal.png) that varies with
configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x1080204 (res/drawable-mdpi/jog_tab_left_pressed.png) that varies with
configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x1080206 (res/drawable-mdpi/jog_tab_right_confirm_gray.png) that varies
W/Zygote ( 691): Preloaded drawable resource #0x108020c (res/drawable-mdpi/jog_tab_right_normal.png) that varies with
configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x108020d (res/drawable-mdpi/jog_tab_right_pressed.png) that varies with
configuration!!
W/Zygote ( 691): Preloaded drawable resource #0x1080210 (res/drawable-mdpi/jog_tab_target_gray.png) that varies with
configuration!!
I/Zygote ( 691): ...preloaded 61 resources in 986ms.
I/Zygote ( 691): ...preloaded 15 resources in 32ms.
D/dalvikvm( 691): GC_EXPLICIT freed 503 objects / 37808 bytes in 75ms
D/dalvikvm( 691): GC_EXPLICIT freed 150 objects / 5808 bytes in 74ms
D/dalvikvm( 691): GC_EXPLICIT freed 2 objects / 48 bytes in 75ms
I/dalvikvm( 691): System server process 726 has been created
I/Zygote ( 691): Accepting command socket connections
warning: `zygote' uses 32-bit capabilities (legacy support in use)
E/BatteryService( 726): acOnlinePath not found
E/BatteryService( 726): usbOnlinePath
not found
E/BatteryService( 726): batteryStatusPath not found
E/BatteryService( 726): batteryHealthPath not found
E/BatteryService( 726): batteryPresentPath not found
E/BatteryService( 726): batteryCapacityPath not found
E/BatteryService( 726): batteryVoltagePath not found
E/BatteryService( 726): batteryTemperaturePath not found
E/BatteryService( 726): batteryTechnologyPath not found
I/sysproc ( 726): Entered system_init()
I/sysproc ( 726): ServiceManager: 0x11c5a0
I/SurfaceFlinger( 726): SurfaceFlinger is starting
I/SurfaceFlinger( 726): SurfaceFlinger's main thread ready to run. Initializing graphics H/W...
I/gralloc ( 726): using (fd=24)
I/gralloc ( 726): id = DA8xx FB Drv
I/gralloc ( 726): xres = 800 px
I/gralloc ( 726): yres = 600 px
I/gralloc ( 726): xres_virtual = 800 px
I/gralloc ( 726): yres_virtual = 1200 px
I/gralloc ( 726): bpp = 16
I/gralloc ( 726): r = 11:5
I/gralloc ( 726): g = 5:6
I/gralloc ( 726): b = 0:5
I/gralloc ( 726): width = 127 mm (160.000000 dpi)
I/gralloc ( 726): height = 95 mm (160.421051 dpi)
I/gralloc ( 726): refresh rate = 11.77 Hz
D/libEGL ( 726): egl.cfg not found, using default config
D/libEGL ( 726): loaded /system/lib/egl/libGLES_android.so
I/SurfaceFlinger( 726): EGL informations:
I/SurfaceFlinger( 726): # of configs : 8
I/SurfaceFlinger( 726): vendor : Android
I/SurfaceFlinger( 726): version : 1.4 Android META-EGL
I/SurfaceFlinger( 726): extensions: EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap
EGL_ANDROID_image_native_buffer EGL_ANDROID_swap_rectangle EGL_ANDROID_get_render_buffer
I/SurfaceFlinger( 726): Client API: OpenGL ES
I/SurfaceFlinger( 726): EGLSurface: 5-6-5-0, config=0x1000000
I/SurfaceFlinger( 726): flags : 001c0000
W/SurfaceFlinger( 726): ro.sf.lcd_density not defined, using 160 dpi by default.
I/SurfaceFlinger( 726): OpenGL informations:
I/SurfaceFlinger( 726): renderer : Android PixelFlinger 1.3
I/SurfaceFlinger( 726): version : OpenGL ES-CM 1.0
I/SurfaceFlinger( 726): extensions: GL_OES_byte_coordinates GL_OES_fixed_point GL_OES_single_precision GL_OES_read_format
GL_OES_compressed_paletted_texture GL_OES_draw_texture GL_OES_matrix_get GL_OES_query_matrix GL_OES_EGL_image
GL_OES_compressed_ETC1_RGB8_texture GL_ARB_texture_compression GL_ARB_texture_non_power_of_two
GL_ANDROID_user_clip_plane GL_ANDROID_vertex_buffer_object GL_ANDROID_generate_mipmap
I/SurfaceFlinger( 726): GL_MAX_TEXTURE_SIZE = 4096
I/SurfaceFlinger( 726): GL_MAX_VIEWPORT_DIMS = 4096
I/sysproc ( 726): System server: starting Android runtime.
I/sysproc ( 726): System server: starting Android services.
I/sysproc ( 726): System server: entering thread pool.
I/SystemServer( 726): Entered the Android system server!
I/SystemServer( 726): Entropy Service
W/EntropyService( 726): unable to load initial entropy (first boot?)
W/EntropyService( 726): java.io.FileNotFoundException: /data/system/entropy.dat (Permission denied)
W/EntropyService( 726): \0x09at org.apache.harmony.luni.platform.OSFileSystem.openImpl(Native Method)
W/EntropyService( 726): \0x09at org.apache.harmony.luni.platform.OSFileSystem.open(OSFileSystem.java:152)
W/EntropyService( 726): \0x09at java.io.FileInputStream.<init>(FileInputStream.java:82)
W/EntropyService( 726): \0x09at java.io.FileInputStream.<init>(FileInputStream.java:134)
W/EntropyService( 726): \0x09at com.android.server.RandomBlock.fromFile(RandomBlock.java:45)
W/EntropyService( 726): \0x09at com.android.server.EntropyService.loadInitialEntropy(EntropyService.java:99)
W/EntropyService( 726): \0x09at com.android.server.EntropyService.<init>(EntropyService.java:86)
W/EntropyService( 726): \0x09at com.android.server.EntropyService.<init>(EntropyService.java:76)
W/EntropyService( 726): \0x09at com.android.server.ServerThread.run(SystemServer.java:107)
W/EntropyService( 726): unable to write entropy
W/EntropyService( 726): \0x09at java.io.RandomAccessFile.<init>(RandomAccessFile.java:145)
W/EntropyService( 726): \0x09at java.io.RandomAccessFile.<init>(RandomAccessFile.java:186)
lock.toFile(RandomBlock.java:69)
W/EntropyService( 726): \0x09at com.android.server.EntropyService.writeEntropy(EntropyService.java:107)
W/EntropyService( 726): \0x09at com.android.server.EntropyService.<init>(EntropyService.java:88)
I/SystemServer( 726): Power Manager
I/SystemServer( 726): Activity Manager
I/ActivityManager( 726): Memory class: 16
D/libEGL ( 738): egl.cfg not found, using default config
D/libEGL ( 738): loaded /system/lib/egl/libGLES_android.so
W/zipro ( 738): Unable to open zip '/data/local/bootanimation.zip': No such file or directory
W/zipro ( 738): Unable to open zip '/system/media/bootanimation.zip': No such file or directory
E/BatteryStats( 726): Error reading battery statistics
E/BatteryStats( 726): java.io.FileNotFoundException: /data/system/batterystats.bin (Permission denied)
E/BatteryStats( 726): \0x09at org.apache.harmony.luni.platform.OSFileSystem.openImpl(Native Method)
E/BatteryStats( 726): \0x09at org.apache.harmony.luni.platform.OSFileSystem.open(OSFileSystem.java:152)
E/BatteryStats( 726): \0x09at java.io.FileInputStream.<init>(FileInputStream.java:82)
E/BatteryStats( 726): \0x09at com.android.internal.os.BatteryStatsImpl.readLocked(BatteryStatsImpl.java:3131)
E/BatteryStats( 726): \0x09at com.android.server.am.ActivityManagerService.<init>(ActivityManagerService.java:1429)
E/BatteryStats( 726): \0x09at com.android.server.am.ActivityManagerService.<init>(ActivityManagerService.java:129)
E/BatteryStats( 726): \0x09at com.android.server.am.ActivityManagerService$AThread.run(ActivityManagerService.java:1338)
W/BatteryStats( 726): Error writing battery statistics
W/BatteryStats( 726): java.io.FileNotFoundException: /data/system/batterystats.bin.tmp (Permission denied)
W/BatteryStats( 726): \0x09at org.apache.harmony.luni.platform.OSFileSystem.openImpl(Native Method)
W/BatteryStats( 726): \0x09at org.apache.harmony.luni.platform.OSFileSystem.open(OSFileSystem.java:152)
W/BatteryStats( 726): \0x09at java.io.FileOutputStream.<init>(FileOutputStream.java:97)
W/BatteryStats( 726): \0x09at java.io.FileOutputStream.<init>(FileOutputStream.java:69)
W/BatteryStats( 726): \0x09at com.android.internal.os.BatteryStatsImpl.writeLocked(BatteryStatsImpl.java:3077)
W/BatteryStats( 726): \0x09at com.android.server.am.ActivityManagerService.<init>(ActivityManagerService.java:1430)
W/BatteryStats( 726): \0x09at com.android.server.am.ActivityManagerService.<init>(ActivityManagerService.java:129)
W/BatteryStats( 726): \0x09at com.android.server.am.ActivityManagerService$AThread.run(ActivityManagerService.java:1338)
W/UsageStats( 726): Error : java.io.IOException: Permission denied reading data from file:/data/system/usagestats/usage-
20101010
I/ARMAssembler( 726): generated scanline__00000077:03010104_00000004_00000000 [ 22 ipp] (41 ins) at
[0x1f9130:0x1f91d4] in 0 ns
I/ARMAssembler( 738): generated scanline__00000077:03545404_00000A01_00000000 [ 30 ipp] (51 ins) at
[0x1c5e8:0x1c6b4] in 0 ns
I/SystemServer( 726): Telephony Registry
I/SystemServer( 726): Package Manager
I/Installer( 726): connecting...
I/installd( 694): new connection
I/PackageManager( 726): Libs: android.test.runner:/system/framework/android.test.runner.jar
javax.obex:/system/framework/javax.obex.jar
I/PackageManager( 726): Features:
D/dalvikvm( 726): GC_FOR_MALLOC freed 6088 objects / 286696 bytes in 11
1ms
W/PackageManager( 726): Running ENG build: no pre-dexopt!
D/PackageManager( 726): Scanning app dir /system/framework
I/PackageManager( 726): /system/framework/framework-res.apk changed; collecting certs
What should I do?help me,piease.
Thanks.
