Other Parts Discussed in Thread: TPS65910
I am trying to run the mcfw without system_server etc. RDK version is 2.8
What I have changed:
1. in /etc/init.d/finish.sh, replaced call of system_server with ipnc_rdk_mcfw.out
2. in /opt/ipnc/init.sh added cmemk after loading syslink
3. running ubuntu11.10 armel instead of Arago rootfs
4. uboot/kernel/rootfs are all in the SD card
The result:
1. I see live video on the monitor, except that the color is way off(looks like negative) and constantly changing in dramatic fashion. I suspect the AEWB is working properly.
2. I don't see the periodic print on the console.
Here's the whole boot log:
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.37_DM812x_IPNC_2.80.00 (hongfeng@ubuntu) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #1 PREEMPT Tue Jul 3 16:09:43 CDT 2012
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: ti8148ipnc
vram size = 4194304 at 0x0
reserved size = 4194304 at 0x0
FB: Reserving 4194304 bytes SDRAM for VRAM
Memory policy: ECC disabled, Data cache writeback
OMAP chip is TI8148 2.0
SRAM: Mapped pa 0x402f1000 to va 0xfe400000 size: 0xf000
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 19296
Kernel command line: console=ttyO0,115200n8 noinitrd mem=80M vram=4M notifyk.vpssm3_sva=0xBFD00000 root=/dev/mmcblk0p2 ip=192.168.1.168 earlyprink
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 76MB = 76MB total
Memory: 72048k/72048k available, 9872k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xc5800000 - 0xf8000000 ( 808 MB)
lowmem : 0xc0000000 - 0xc5000000 ( 80 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.init : 0xc0008000 - 0xc0037000 ( 188 kB)
.text : 0xc0037000 - 0xc0467000 (4288 kB)
.data : 0xc0468000 - 0xc04a4f00 ( 244 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:375
IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
Total of 128 interrupts on 1 active controller
GPMC revision 6.0
Trying to install interrupt handler for IRQ368
Trying to install interrupt handler for IRQ369
Trying to install interrupt handler for IRQ370
Trying to install interrupt handler for IRQ371
Trying to install interrupt handler for IRQ372
Trying to install interrupt handler for IRQ373
Trying to install interrupt handler for IRQ374
Trying to install type control for IRQ375
Trying to set irq flags for IRQ375
OMAP clockevent source: GPTIMER1 at 20000000 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 598.01 BogoMIPS (lpj=2990080)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
omap_voltage_early_init: voltage driver support not added
regulator: core version 0.5
regulator: dummy:
NET: Registered protocol family 16
omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting!
omap_voltage_add_dev: VDD specified does not exist!
OMAP GPIO hardware version 0.1
omap_mux_init: Add partition: #1: core, flags: 4
_omap_mux_init_gpio: Could not set gpio79
_omap_mux_init_gpio: Could not set gpio80
Debugfs: Only enabling/disabling deep sleep and wakeup timer is supported now
registered ti81xx_vpss device
registered ti81xx_vidout device
registered ti81xx on-chip HDMI device
registered ti81xx_fb device
PWM0 init success.
PWM1 init success.
bio: create slab <bio-0> at 0
SCSI subsystem initialized
USBSS revision 4ea2080b
registerd cppi-dma Intr @ IRQ 17
Cppi41 Init Done
omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
regulator: VRTC: 1800 mV
regulator: VIO: 1500 mV
regulator: VDD1: 600 <--> 1500 mV at 1100 mV
regulator: VDD2: 600 <--> 1500 mV at 1350 mV
regulator: VDDCTRL: 600 <--> 1400 mV at 1100 mV
regulator: LDO1: 1100 <--> 3300 mV at 1800 mV
regulator: LDO2: 1100 <--> 3300 mV at 1800 mV
regulator: LDO3: 1100 <--> 3300 mV at 3300 mV
regulator: LDO4: 1100 <--> 3300 mV at 1800 mV
regulator: LDO5: 1100 <--> 3300 mV at 3300 mV
regulator: LDO6: 1100 <--> 3300 mV at 3300 mV
regulator: LDO7: 1100 <--> 3300 mV at 3300 mV
regulator: LDO8: 1100 <--> 3300 mV at 1800 mV
tps65911-rtc tps65911-rtc: rtc core: registered tps65911-rtc as rtc0
tps65910 1-002d: No interrupt support, no core IRQ
Advanced Linux Sound Architecture Driver Version 1.0.23.
Switching to clocksource gp timer
musb-hdrc: version 6.0, peripheral, debug=0
musb-hdrc musb-hdrc.0: dma type: dma-cppi41
MUSB controller-0 revision 4ea20800
musb-hdrc musb-hdrc.0: USB Peripheral mode controller at c581e000 using DMA, IRQ 18
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NetWinder Floating Point Emulator V0.97 (double precision)
PMU: registered new PMU device of type 0
omap-iommu omap-iommu.0: ducati registered
omap-iommu omap-iommu.1: sys registered
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 140
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
console [ttyO0] enabled
omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
brd: module loaded
loop: module loaded
omap2-nand driver initializing
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xca (Micron )
Creating 7 MTD partitions on "omap2-nand.0":
0x000000000000-0x000000020000 : "U-Boot-min"
0x000000020000-0x000000260000 : "U-Boot"
0x000000260000-0x000000280000 : "U-Boot Env"
0x000000280000-0x0000006c0000 : "Kernel"
0x0000006c0000-0x00000c000000 : "File System"
0x00000c000000-0x00000cc00000 : "Data"
0x00000cc00000-0x000010000000 : "Reserved"
davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
davinci_mdio davinci_mdio.0: detected phy mask fffffffe
davinci_mdio.0: probed
davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
CAN device driver interface
CAN bus driver for Bosch D_CAN controller 1.0
d_can d_can: d_can device registered (irq=52, irq_obj=53)
mice: PS/2 mouse device common for all mice
i2c /dev entries driver
Linux video capture interface: v2.00
OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
notify_init : notify drivercreated for remote proc id 2 at physical Address 0xbfd00000
asoc: tlv320aic3x-hifi <-> davinci-mcasp.2 mapping ok
asoc: HDMI-DAI-CODEC <-> hdmi-dai mapping ok
ALSA device list:
#0: TI8148 IPNC
TCP cubic registered
NET: Registered protocol family 17
can: controller area network core (rev 20090105 abi 8)
NET: Registered protocol family 29
can: raw protocol (rev 20090105)
can: broadcast manager protocol (rev 20090105 t)
Registering the dns_resolver key type
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
omap_voltage_late_init: Voltage driver support not added
Power Management for TI81XX.
mmc0: new high speed SD card at address b368
Detected MACID=0:18:32:39:19:d7
mmcblk0: mmc0:b368 AF UD 1.89 GiB
mmcblk0: p1 p2
tps65911-rtc tps65911-rtc: setting system clock to 2011-03-17 09:36:04 UTC (1300354564)
CPSW phy found : id is : 0x4dd074
PHY 0:01 not found
IP-Config: Guessing netmask 255.255.255.0
IP-Config: Complete:
device=eth0, addr=192.168.1.168, mask=255.255.255.0, gw=255.255.255.255,
host=192.168.1.168, domain=, nis-domain=(none),
bootserver=255.255.255.255, rootserver=255.255.255.255, rootpath=
EXT3-fs: barriers not enabled
EXT3-fs (mmcblk0p2): warning: maximal mount count reached, running e2fsck is recommended
kjournald starting. Commit interval 5 seconds
EXT3-fs (mmcblk0p2): using internal journal
EXT3-fs (mmcblk0p2): recovery complete
EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode
VFS: Mounted root (ext3 filesystem) on device 179:2.
devtmpfs: mounted
Freeing init memory: 188K
init: ureadahead main process (45) terminated with status 5
udevd[109]: error changing net interface name eth0 to eth1: Device or resource busy
inside finish.sh
ALSA lib conf.c:3601:(snd_config_update_r) Cannot access file /usr/share/alsa/alsa.conf
ALSA lib control.c:902:(snd_ctl_open_noupdate) Invalid CTL default
amixer: Control default open error: No such file or directory
ERROR: Module cmemk does not exist in /proc/modules
[c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[m3video] Remote Debug Shared Memory @ 0xbff05020
[m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
SysLink version : 2.10.02.17
SysLink module created on Date:Jul 3 2012 Time:16:10:34
Trace enabled
Trace SetFailureReason enabled
/dev/mem opened.
data 2
BW Phy Addr : 0x48180d00 Data : 0x00030000
AW Phy Addr : 0x48180d00 Data : 0x00030002
data 3
BW Phy Addr : 0x48180d10 Data : 0x00000007
AW Phy Addr : 0x48180d10 Data : 0x00000003
data 2
BW Phy Addr : 0x48180700 Data : 0x00000001
AW Phy Addr : 0x48180700 Data : 0x00000002
data 2
BW Phy Addr : 0x48180720 Data : 0x00070000
AW Phy Addr : 0x48180720 Data : 0x00070002
data 2
BW Phy Addr : 0x48180724 Data : 0x00030000
AW Phy Addr : 0x48180724 Data : 0x00000002
data 60020
BW Phy Addr : 0x48140924 Data : 0x000e0020
AW Phy Addr : 0x48140924 Data : 0x000e0020
data 60020
BW Phy Addr : 0x48140928 Data : 0x000c0040
AW Phy Addr : 0x48140928 Data : 0x000c0040
data 60001
BW Phy Addr : 0x48140c18 Data : 0x000e0001
AW Phy Addr : 0x48140c18 Data : 0x000e0001
data 60001
BW Phy Addr : 0x48140c1c Data : 0x000e0001
AW Phy Addr : 0x48140c1c Data : 0x000e0001
data 2
BW Phy Addr : 0x48181564 Data : 0x00000002
AW Phy Addr : 0x48181564 Data : 0x00000002
data 2
BW Phy Addr : 0x48181568 Data : 0x00030000
AW Phy Addr : 0x48181568 Data : 0x00000002
Phy Addr : 0x48181560 Data : 0x00000002
data 2
BW Phy Addr : 0x48181560 Data : 0x00000002
AW Phy Addr : 0x48181560 Data : 0x00000002
data 60002
BW Phy Addr : 0x48140aac Data : 0x00040002
AW Phy Addr : 0x48140aac Data : 0x00040002
data 60002
BW Phy Addr : 0x48140ab0 Data : 0x00060002
AW Phy Addr : 0x48140ab0 Data : 0x00060002
data 60002
BW Phy Addr : 0x48140ab8 Data : 0x00040002
AW Phy Addr : 0x48140ab8 Data : 0x00040002
data 60020
BW Phy Addr : 0x48140a58 Data : 0x000c0080
AW Phy Addr : 0x48140a58 Data : 0x000c0080
data 60080
BW Phy Addr : 0x48140a60 Data : 0x000c0080
AW Phy Addr : 0x48140a60 Data : 0x000c0080
data 60020
BW Phy Addr : 0x48140a64 Data : 0x000c0080
AW Phy Addr : 0x48140a64 Data : 0x000c0080
data 60020
BW Phy Addr : 0x48140a68 Data : 0x000c0080
AW Phy Addr : 0x48140a68 Data : 0x000c0080
data 60002
BW Phy Addr : 0x48140aa8 Data : 0x00040002
AW Phy Addr : 0x48140aa8 Data : 0x00040002
data 60002
BW Phy Addr : 0x48140aa4 Data : 0x00040002
AW Phy Addr : 0x48140aa4 Data : 0x00040002
data 60002
BW Phy Addr : 0x48140aa0 Data : 0x00040002
AW Phy Addr : 0x48140aa0 Data : 0x00040002
data 60002
BW Phy Addr : 0x48140a9c Data : 0x00060002
AW Phy Addr : 0x48140a9c Data : 0x00060002
data 60002
BW Phy Addr : 0x48140a98 Data : 0x00060002
AW Phy Addr : 0x48140a98 Data : 0x00060002
data 60002
BW Phy Addr : 0x48140a94 Data : 0x00060002
AW Phy Addr : 0x48140a94 Data : 0x00060002
data 60002
BW Phy Addr : 0x48140a90 Data : 0x00060002
AW Phy Addr : 0x48140a90 Data : 0x00060002
data 60002
BW Phy Addr : 0x48140a8c Data : 0x00060002
AW Phy Addr : 0x48140a8c Data : 0x00060002
data 60002
BW Phy Addr : 0x48140a6c Data : 0x000e0002
AW Phy Addr : 0x48140a6c Data : 0x000e0002
data 60002
BW Phy Addr : 0x48140a70 Data : 0x000c0002
AW Phy Addr : 0x48140a70 Data : 0x000c0002
data 60002
BW Phy Addr : 0x48140a74 Data : 0x000e0002
AW Phy Addr : 0x48140a74 Data : 0x000e0002
data 60002
BW Phy Addr : 0x48140a78 Data : 0x000e0002
AW Phy Addr : 0x48140a78 Data : 0x000e0002
data 0
BW Phy Addr : 0x411f4004 Data : 0x0000000e
AW Phy Addr : 0x411f4004 Data : 0x00000000
data 0
BW Phy Addr : 0x411f2004 Data : 0x00000001
AW Phy Addr : 0x411f2004 Data : 0x00000000
data 1
BW Phy Addr : 0x41140084 Data : 0x00000001
AW Phy Addr : 0x41140084 Data : 0x00000001
data 1
BW Phy Addr : 0x411a0084 Data : 0x00000001
AW Phy Addr : 0x411a0084 Data : 0x00000001
data 1
BW Phy Addr : 0x41160034 Data : 0x00000001
AW Phy Addr : 0x41160034 Data : 0x00000001
data 1
BW Phy Addr : 0x41121ff0 Data : 0x00000001
AW Phy Addr : 0x41121ff0 Data : 0x00000001
data 1
BW Phy Addr : 0x41131fe4 Data : 0x00000000
AW Phy Addr : 0x41131fe4 Data : 0x00000001
data 1
BW Phy Addr : 0x411e002c Data : 0x00000000
AW Phy Addr : 0x411e002c Data : 0x00000001
data 1
BW Phy Addr : 0x481c52ec Data : 0x00000001
AW Phy Addr : 0x481c52ec Data : 0x00000001
secss put in low power state
data 1
BW Phy Addr : 0x48180900 Data : 0x00000001
AW Phy Addr : 0x48180900 Data : 0x00000001
data 0
BW Phy Addr : 0x48180f00 Data : 0x00030000
AW Phy Addr : 0x48180f00 Data : 0x00030000
Phy Addr : 0x48180f10 Data : 0x00000000
data 2
BW Phy Addr : 0x4818052c Data : 0x00000002
AW Phy Addr : 0x4818052c Data : 0x00000002
data 2
BW Phy Addr : 0x48180508 Data : 0x00000302
AW Phy Addr : 0x48180508 Data : 0x00000302
data 2
BW Phy Addr : 0x48180520 Data : 0x00000002
AW Phy Addr : 0x48180520 Data : 0x00000002
data 2
BW Phy Addr : 0x48180524 Data : 0x00000002
AW Phy Addr : 0x48180524 Data : 0x00000002
data 2
BW Phy Addr : 0x48180528 Data : 0x00000002
AW Phy Addr : 0x48180528 Data : 0x00000002
Phy Addr : 0x4c0000e4 Data : 0x00173209
data 173209
BW Phy Addr : 0x4c0000e4 Data : 0x00173209
AW Phy Addr : 0x4c0000e4 Data : 0x00173209
Phy Addr : 0x4d0000e4 Data : 0x00173209
data 173209
BW Phy Addr : 0x4d0000e4 Data : 0x00173209
AW Phy Addr : 0x4d0000e4 Data : 0x00173209
data 173209
data 173209
DDR IOs RX is shutdown
Setting L3 bandwidth regulator for [HDVICP0 ] to [press=[0,0] BW=900, WM Cycles=2500]
Setting DMM priority for [ISS ] to [0] ( 0x4e000634 = 0x00800000 )
Setting DMM priority for [HDVICP0 ] to [1] ( 0x4e000634 = 0x00000009 )
Attached to slave procId 2.
Loaded file ./firmware/ipnc_rdk_fw_m3vpss.xem3 on slave procId 2.
Started slave procId 2.
After Ipc_loadcallback status [0x00000000]
[m3vpss ] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[m3vpss ] notify_attach rtnVal 0
[m3vpss ] initProxyServer rtnVal 0
[m3vpss ]
[m3vpss ] *** UTILS: CPU KHz = 400000 Khz ***
[m3vpss ]
[m3vpss ] 92: SYSTEM : System Common Init in progress !!!
[m3vpss ] 92: SYSTEM: IPC init in progress !!!
[m3vpss ] 92: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 1092: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 1095: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3vpss ] 1095: SYSTEM: Attaching to [DSP] ...
After Ipc_startcallback status [0x097d2000]
Attached to slave procId 1.
Loaded file ./firmware/ipnc_rdk_fw_m3video.xem3 on slave procId 1.
Started slave procId 1.
[m3video] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[m3video]
[m3video] *** UTILS: CPU KHz = 400000 Khz ***
[m3video]
[m3video] 1279: SYSTEM : System Common Init in progress !!!
[m3video] 1279: SYSTEM: IPC init in progress !!!
[m3video] 1279: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 2095: SYSTEM: Attaching to [DSP] ...
[m3video] 2278: SYSTEM: Attaching to [HOST] ...
After Ipc_startcallback status [0x00000000]
[m3video] 2282: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3video] 2282: SYSTEM: Attaching to [DSP] ...
Attached to slave procId 0.
Loaded file ./firmware/ipnc_rdk_fw_c6xdsp.xe674 on slave procId 0.
Started slave procId 0.
[c6xdsp ] ***** SYSTEM : Frequency <ORG> - 500000000, <NEW> - 500000000
[c6xdsp ]
[c6xdsp ] *** UTILS: CPU KHz = 500000 Khz ***
[c6xdsp ]
[c6xdsp ] 1: SYSTEM : System Common Init in progress !!!
[c6xdsp ] 1: SYSTEM: IPC init in progress !!!
[c6xdsp ] 1: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 3095: SYSTEM: Attaching to [DSP] ...
[m3video] 3281: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 1001: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 1004: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[c6xdsp ] 1004: SYSTEM: Attaching to [VIDEO-M3] ...
[m3vpss ] 4095: SYSTEM: Attaching to [DSP] ...
[m3video] 4281: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2004: SYSTEM: Attaching to [VIDEO-M3] ...
[m3vpss ] 5095: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2851: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3video] 5281: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2851: SYSTEM: Attaching to [VPSS-M3] ...
[m3video] 5282: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3video] 5282: SYSTEM: Attaching to [VPSS-M3] ...
[m3vpss ] 6095: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 3850: SYSTEM: Attaching to [VPSS-M3] ...
[m3video] 6281: SYSTEM: Attaching to [VPSS-M3] ...
[c6xdsp ] 4664: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 7095: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 4664: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 7095: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3vpss ] 7095: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 7281: SYSTEM: Attaching to [VPSS-M3] ...
[c6xdsp ] 5664: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3video] 8096: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 8096: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 8097: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 8096: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3video] 8097: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[m3vpss ] 8096: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3video] 8097: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[m3vpss ] 8097: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[m3video] 8100: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[m3vpss ] 8097: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[m3video] 8100: SYSTEM: Notify register to [DSP] line 0, event 12 ...
[m3vpss ] 8099: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[m3video] 8100: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[m3vpss ] 8100: SYSTEM: Notify register to [DSP] line 0, event 12 ...
[m3video] 8100: SYSTEM: IPC init DONE !!!
[m3vpss ] 8100: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[m3vpss ] 8100: SYSTEM: IPC init DONE !!!
[m3video] 8110: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[m3vpss ] 8110: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[m3video] 8111: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03800000 (56 MB)
[m3vpss ] 8110: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03800000 (56 MB)
[m3video] 8113: SYSTEM : System Common Init Done !!!
[m3vpss ] 8113: SYSTEM : System Common Init Done !!!
[m3video] 8113: SYSTEM : System Video Init in progress !!!
[m3vpss ] 8113: SYSTEM : System VPSS Init in progress !!!
[m3video] 8113: SYSTEM : System Video Init Done !!!
[m3video] 8114: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[m3video] 8114: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[m3video] 8114: SYSTEM: ListElem Shared Addr = 0xbe98b280
[m3video] 8117: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[m3video] 8117: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[m3video] 8117: SYSTEM: ListElem Shared Addr = 0xbe98e380
[m3video] 8129: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_28] in region 0 ...
[m3vpss ] === I2C0/2 Clk is active ===
[m3video] 8129: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_28] in region 0 ...
[m3vpss ] 8131: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[m3video] 8129: SYSTEM: ListElem Shared Addr = 0xbe991480
[m3vpss ] 8131: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[m3video] 8132: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
[m3vpss ] 8132: SYSTEM: ListElem Shared Addr = 0xbe9aad00
[m3video] 8132: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
[m3vpss ] 8134: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[m3video] 8133: SYSTEM: ListElem Shared Addr = 0xbe9ade00
[m3vpss ] 8135: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[m3video] 8135: HDVICP: Doing PRCM for IVAHD[0] ...
[m3video] 8135: HDVICP: PRCM for IVAHD[0] ... DONE.
[m3vpss ] 8135: SYSTEM: ListElem Shared Addr = 0xbe9c7680
[m3video] 8136: SYSTEM : Initializing Links !!!
[m3vpss ] 8150: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_23] in region 0 ...
[m3vpss ] 8151: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_23] in region 0 ...
[m3vpss ] 8151: SYSTEM: ListElem Shared Addr = 0xbe9ca780
[m3vpss ] 8154: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
[m3vpss ] 8154: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
[m3vpss ] 8154: SYSTEM: ListElem Shared Addr = 0xbe9e9d80
[m3vpss ] 8157: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
[m3vpss ] 8158: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
[m3vpss ] 8158: SYSTEM: ListElem Shared Addr = 0xbea09380
[m3vpss ] 8165: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_28] in region 0 ...
[m3vpss ] 8166: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_28] in region 0 ...
[m3vpss ] 8166: SYSTEM: ListElem Shared Addr = 0xbea28980
[m3vpss ] 8169: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_29] in region 0 ...
[m3vpss ] 8169: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_29] in region 0 ...
[m3vpss ] 8169: SYSTEM: ListElem Shared Addr = 0xbea42200
[m3vpss ] 8172: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
[m3vpss ] 8172: SYSTEM : FVID2 Init in progress !!!
[m3video] 8190: SYSTEM : Initializing Links ... DONE !!!
[m3vpss ] 8232: SYSTEM : FVID2 Init in progress DONE !!!
[m3vpss ] 8232: SYSTEM : Device Init in progress !!!
[m3vpss ] Iss_init called !!!!!!
[m3vpss ] CPIS_init DONE !!!!!!
[m3vpss ] initPrms.isI2cInitReq = 1
[m3vpss ] Vps_deviceInit Daughter card not detected/connected!
[m3vpss ]
[m3vpss ] 8418: SYSTEM : Device Init in progress DONE !!!
[m3vpss ] 8445: SYSTEM : System VPSS Init Done !!!
[m3vpss ] 8445: SYSTEM : Initializing Links !!!
[m3vpss ] 8563: SYSTEM : Initializing Links ... DONE !!!
[m3vpss ] Received character 's'
[m3video] Received character 's'
[c6xdsp ] 6664: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[c6xdsp ] 6664: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
[c6xdsp ] 6665: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
[c6xdsp ] 6665: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[c6xdsp ] 6665: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[c6xdsp ] 6665: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[c6xdsp ] 6665: SYSTEM: IPC init DONE !!!
[c6xdsp ] 6669: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[c6xdsp ] 6669: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03800000 (56 MB)
[c6xdsp ] 6669: SYSTEM : System Common Init Done !!!
[c6xdsp ] 6668: SYSTEM : System DSP Init in progress !!!
[c6xdsp ] 6674: SYSTEM: Creating ListMP [DSP_IPC_OUT_23] in region 0 ...
[c6xdsp ] 6674: SYSTEM: Creating ListMP [DSP_IPC_IN_23] in region 0 ...
[c6xdsp ] 6674: SYSTEM: ListElem Shared Addr = 0xbea5ba80
[c6xdsp ] 6675: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
[c6xdsp ] 6675: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
[c6xdsp ] 6675: SYSTEM: ListElem Shared Addr = 0xbea7b080
[c6xdsp ] 6676: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
[c6xdsp ] 6677: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
[c6xdsp ] 6677: SYSTEM: ListElem Shared Addr = 0xbea9a680
[c6xdsp ] 6678: SYSTEM: Creating ListMP [DSP_IPC_OUT_28] in region 0 ...
[c6xdsp ] 6678: SYSTEM: Creating ListMP [DSP_IPC_IN_28] in region 0 ...
[c6xdsp ] 6678: SYSTEM: ListElem Shared Addr = 0xbeab9c80
[c6xdsp ] 6679: SYSTEM: Creating ListMP [DSP_IPC_OUT_29] in region 0 ...
[c6xdsp ] 6679: SYSTEM: Creating ListMP [DSP_IPC_IN_29] in region 0 ...
[c6xdsp ] 6679: SYSTEM: ListElem Shared Addr = 0xbead3500
[c6xdsp ] !!WARNING.Resource already registered:2
[c6xdsp ] 6678: SYSTEM : Initializing Links !!!
[c6xdsp ] Received character 's'
[c6xdsp ] 6693: SYSTEM : Initializing Links ... DONE !!!
[c6xdsp ] 6693: SYSTEM : System DSP Init Done !!!
ORG 0x46c00524: 0
NEW 0x46c00524: 2
[host] Application Load Completed
Vsys_allocBuf - addr = 0x40b8a000,size = 65011712
[host] MCFW_IPCBITS:App_streamSysInit:virt addr of 85000000 cir buffer is 40b8a000
##########pInfo->totalsize 61865984
MemMng_memcpy_open:OSA_dmaOpen passed with ch id = 4
CacheMng_MemCpy_open:OSA_dmaOpen passed with ch id = 9
Creat queue id:0
queue id:0
Creat queue id:32769
queue id:32769
[host] MCFW_IPCBITS:App_ipcBitsRecvStreamFxn:Entered...Vsys_allocBuf - addr = 0x40a9d000,size = 682
DCC Default File Intialization Done!
0: SYSTEM: System Common Init in progress !!!
19: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
21: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
22: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
24: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
24: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
25: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
26: SYSTEM: Notify register to [DSP] line 0, event 12 ...
26: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
27: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
27: SYSTEM: IPC init DONE !!!
29: SYSTEM: Creating ListMP [HOST_IPC_OUT_28] in region 0 ...
31: SYSTEM: Creating ListMP [HOST_IPC_IN_28] in region 0 ...
32: SYSTEM: ListElem Shared Addr = 0x45385d80
33: SYSTEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ...
35: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ...
37: SYSTEM: ListElem Shared Addr = 0x4539f600
38: SYSTEM: Creating ListMP [HOST_IPC_OUT_23] in region 0 ...
40: SYSTEM: Creating ListMP [HOST_IPC_IN_23] in region 0 ...
42: SYSTEM: ListElem Shared Addr = 0x453b8e80
43: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
45: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
47: SYSTEM: ListElem Shared Addr = 0x453d8480
48: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
50: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
51: SYSTEM: ListElem Shared Addr = 0x453f7a80
52: SYSTEM: System Common Init Done !!!
[host]
********** FULL FEATURE USECASE ********
[host] ********* Entered Tri Streaming usecase - H264 1080p @60fps + H264 D1 @30fps + MJPEG 1080p @5fps ********
52: MCFW : CPU Revision [ES2.1] !!!
52: MCFW : Detected [UNKNOWN] Board !!!
52: MCFW : Base Board Revision [REV A] !!!
[m3vpss ] 10562: CAMERA: Create in progress !!!
[m3vpss ] 10563: CAMERA: VIP0 PortA camera mode is [ 8-bit, Non-mux Embedded Sync] !!!
[m3vpss ] 10573: CAMERA: VIP 0: VID DEC 268436736 (0x36): 0002:8f296ecc:8f296efc, AUD_STATUS 0
[m3vpss ] Stream ID 0: chId = 0 VpsUtils_queCreate.
[m3vpss ] 10788: CAMERA: Create Done !!!
[m3vpss ] DCC server task running
[m3vpss ] 10898: CAMERA: Detect video in progress !!!
[m3vpss ] 10899: CAMERA: Detect video Done !!!
[m3vpss ] ROI dimensions of 1920 x 1088 are optimal for performance. Optimal dimension is 1920 x 1088 with processsing block= 32 x 16. Num horz table= 19, vert table= 11, localBlockWidth= 96.
[m3vpss ] 11726: ISP : FVID2 Create Done !!!
[m3vpss ] 11726: ISP : Create Done !!!
[m3vpss ] 11823: DUP : Create Done !!!
[m3vpss ] 11824: NSF: Create in progress !!!
[m3vpss ] NSF::HEAPID:0 USED:128
[m3vpss ] NSF::HEAPID:1 USED:4928
[m3vpss ] 11925: NSF: Create Done !!!
[m3vpss ] 11931: DUP : Create Done !!!
[m3vpss ] 11937: DUP : Create Done !!!
[m3vpss ] 11939: MERGE : Create Done !!!
[m3vpss ] 11908: SWOSD : Create Done !!!
[m3vpss ] 11999: SCLR: Create in progress !!!
[m3vpss ] 12005: SCLR : Loading Up-scaling Co-effs ...
[m3vpss ] 12005: SCLR : Co-effs Loading ... DONE !!!
[m3video] 12013: IPC_IN_M3 : Create in progress !!!
[m3video] 12013: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
[m3vpss ] SCLR:HEAPID:0 USED:64
[m3video] 12014: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
[m3vpss ] SCLR:HEAPID:1 USED:5952
[m3video] 12015: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[m3vpss ] 12006: SCLR: Create Done !!!
[m3video] 12018: IPC_IN_M3 : Create Done !!!
[m3vpss ] 11920: FD : Alg Create Done !!!
[m3video] 12018: ENCODE: Create in progress ... !!!
[m3vpss ] 11920: FD : Create Done !!!
[m3video] ENCLINK:INFO: !!!Number of output buffers for ch[2] set to [1]
[m3vpss ] 12011: IPC_OUT_M3 : Create in progress !!!
[m3vpss ] 12013: IPC_OUT_M3 : Create Done !!!
[m3video] 12102: ENCODE: Creating CH0 of 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED ], bitrate = 2000 Kbps ...
[m3video] ENCLINK_H264:HEAPID:0 USED:128584
[m3video] 12219: ENCODE: Creating CH1 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [NON-TILED ], bitrate = 2000 Kbps ...
[host] IpcBitsInLink_tskMain:Entered
[host] 1810: IPC_BITS_IN : Create in progress !!!
[host] 1810: IPC_BITS_IN : ListMPOpen start !!!
[host] 1810: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_28] ...
1812: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_28] ...
[host] 1813: IPC_BITS_IN : ListMPOpen done !!!
[host] 1815: IPC_BITS_IN : System_linkGetInfo done !!!
[host] 1815: IPC_BITS_IN : Create Done !!!
[host] USECASE SETUP DONE
[m3vpss ] 12349: DISPLAY: Create in progress !!!
[m3video] ENCLINK_H264:HEAPID:0 USED:126688
[m3vpss ] 12350: DISPLAY: Create Done !!!
[m3video] 12336: ENCODE: Creating CH2 of 1920 x 1080, pitch = (2048, 2048) [PROGRESSIVE] [NON-TILED ], bitrate = 100 Kbps ...
[m3vpss ] 12351: DISPLAY: Create in progress !!!
[m3vpss ] 12352: DISPLAY: Create Done !!!
[m3vpss ] 12353: DISPLAY: Start in progress !!!
[m3video] ENCLINK_JPEG:HEAPID:0 USED:2064
[m3video] 12336: ENCODE: All CH Create ... DONE !!!
[m3video] ENCLINK:HEAPID:0 USED:257496
[m3video] 12339: ENCODE: Create ... DONE !!!
[m3video] 12340: IPC_BITS_OUT : Create in progress !!!
[m3video] 12342: IPC_BITS_OUT : Create Done !!!
[m3vpss ] 12420: DISPLAY: Start Done !!!
[m3vpss ] 12420: DISPLAY: HDDAC(BP0) : 29 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
[m3vpss ] 12420: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 1, HDDAC(BP0) 0, DVO2(BP1) 1, SDDAC(SEC1) 1
[m3vpss ] 12421: DISPLAY: Start in progress !!!
[m3vpss ] 12482: DISPLAY: Start Done !!!
[m3vpss ] 12482: DISPLAY: SDDAC(SEC1): 16 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
[m3vpss ] 12394: CAMERA: Start in progress !!!
[m3vpss ] 12394: CAMERA: Start Done !!!
[host]
Application Run Completed
[m3vpss ] 12538: CAMERA: Fields = 1 (fps = 0), Total Resets = 0 (Avg 0 ms per reset)
ITT server task running !!!
ITT ittServer_run
ITT Server Message initialization successful
ITT capture task created
DCC server Message ques is open succefully
Setting cmd <1> in message <451a4100>
Posting message <451a4100> in QId <20002>
[m3vpss ] Command 1 recived from HOST A8
Response from M3 is : 1
Server Socket created with ID <22>
[host] MCFW_IPCBITS: Callback function:App_ipcBitsInCbFxn
[host] MCFW_IPCBITS:App_ipcBitsRecvStreamFxn:INFO: periodic print.. [m3video] Channel:1 inputframerate:30 targetfps:60
[m3video] Channel:0 inputframerate:60 targetfps:60
[m3video] Channel:2 inputframerate:60 targetfps:5
inside autorun
Creat queue id:65538
queue id:65538
* Loading cpufreq kernel modules... [ OK ]
* CPUFreq Utilities: Setting ondemand CPUFreq governor... * disabled, governor not available... [ OK ]
Checking for running unattended-upgrades:
Ubuntu 11.10 omap ttyO0
Did I forget to initialize something?
Thanks for your input.
