DM8168 warning
HI
i've got the following warning, could please help me under stand it and how to remove it
Thanks, Gilad
configuring VpsAppMain.pem3 from package/cfg/VpsAppMain_pem3.cfg ...
warning: ti.platforms.generic.Platform: "./package/cfg/VpsAppMain_pem3.cfg", line 593: (xdc.platform.IPlatform.Instance)ti.platforms.generic.Platform.Instance#0 DucatiPlatform_Core1: The parameter 'mem' is passed to this platform instance through Build.platformTable, but the instance does not have a configuration parameter with that name.
  • Gilad Ambar,
    Looking at this month-old post with no response, yet. Have you solved your problem here?
    I suspect more information would be required to get help for you, such as what software package are you building from and have you updated to the latest versions of all the software libraries and tools.
    This sounds like a compatibility issue.
    RandyP
  • Hi RandyP
    Thank you for your time and effort
    I haven't solved it yet and it still an open issue for me
    Below are the netra-tools packages we are using in our application.
    Based on ezsdk 5 02 01 59 (omx version is from this one)
    arm_a8_codegen-2009q1_203/
    arm_m3_codegen-4.9.0b1/
    bios-6.32.01.38/
    codec_engine-3.21.00.19/
    dsp_c6x_codegen-7.2.5/
    edma3lld-02.11.02.04_plcm1/
    framework_components-3.21.01.26_rmx1/
    hdvpss-01.00.01.32/
    ipc-1.23.03.31/
    linuxutils-3.21.00.04_rmx1/
    osal-1.21.01.08_rmx1/
    syslink-02.00.06.87_rmx1/
    uia-1.00.01.17_rmx1/
    xdais-7.21.00.02/
    xdctools-3.22.01.21/
    Thanks again, Gilad
