I have no idea what should i do
Other Parts Discussed in Thread: AM1808, DA8XX
I use AM1808.Its log looks like the sys is running,but it is died finally.And I try to make the kernel and fs many times.The log is:
logcat
--------- beginning of /dev/log/main
I/DEBUG   (  689): debuggerd: Jul 11 201
2 00:38:45
I/Netd    (  688): Netd 1.0 starting
--------- beginning of /dev/log/system
I/Vold    (  687): Vold 2.1 (the revenge) firing up
D/Vold    (  687): Volume sdcard state changing -1 (Initializing) -> 0 (No-Media)
W/Vold    (  687): No UMS switch available
D/AndroidRuntime(  691):
D/AndroidRuntime(  691): >>>>>>>>>>>>>> AndroidRuntime START <<<<<<<<<<<<<<
D/AndroidRuntime(  691): CheckJNI is ON
D/AndroidRuntime(  691): --- registering native functions ---
I/        (  692): ServiceManager: 0xacd0
E/ALSALib (  692): external/alsa-lib/src/control/control.c:909:(snd_ctl_open_nou
pdate) Invalid CTL AndroidPlayback
W/AudioHardwareALSA(  692): Unable to attach mixer to device AndroidPlayback: No such file or directory
E/ALSALib (  692): external/alsa-lib/src/control/control.c:909:(snd_ctl_open_noupdate) Invalid CTL AndroidCapture
W/AudioHardwareALSA(  692): Unable to attach mixer to device AndroidCapture: No such file or directory
I/CameraService(  692): CameraService started: pid=692
D/AudioHardwareALSA(  692): openOutputStream called for devices: 0x00000002
D/ALSAModule(  692): open called for devices 00000002 in mode 0...
E/ALSALib (  692): external/alsa-lib/src/pcm/pcm.c:2201:(snd_pcm_open_noupdate) Unknown PCM
AndroidPlayback_Speaker_normal
E/ALSALib (  692): external/alsa-lib/src/pcm/pcm.c:2201:(snd_pcm_open_noupdate) Unknown PCM AndroidPlayback_Speaker
I/ALSAModule(  692): Initialized ALSA PLAYBACK device default
I/AudioFl
inger(  692): AudioFlinger's thread 0x3d588 ready to run
D/ALSAModule(  692): route called for devices 00000002 in mode 0...
E/AudioHardwareALSA(  692): CALLING STANDBY
I/ethernet(  691): Loading ethernet jni class
I/SamplingProfilerIntegration(  691): Profiler is disabled.
I/Zygote  (  691): Preloading classes...
D/dalvikvm(  691): GC_EXPLICIT f
reed 818 objects / 47336 bytes in 6ms
D/dalvikvm(  691): GC_EXPLICIT freed 219 objects / 13568 bytes in 7ms
D/dalvikvm(  691): GC_EXPLICIT freed 253 objects / 14352 bytes i
n 9ms
D/dalvikvm(  691): GC_EXPLICIT freed 466 objects / 28904 bytes in 10ms
D/dalvikvm(  691): GC_EXPLICIT freed 2090 objects / 108424 bytes in 13ms
W/MediaProfiles(  691): could not find media config xml file
D/dalvikvm(  691): GC_EXPLICIT freed 279 objects / 15984 bytes in 13ms
D/dalvikvm(  691): GC_FOR_MALLOC freed 5081 objects / 225496 bytes in 28ms
D/dalvikvm(  691): GC_FOR_MALLOC freed 11259 objects / 382816 by
tes in 35ms
D/dalvikvm(  691): GC_FOR_MALLOC freed 9839 objects / 462800 bytes in 39
ms
D/dalvikvm(  691): GC_FOR_MALLOC freed 8657 objects / 421680 byt
es in 42ms
D/dalvikvm(  691): GC_FOR_MALLOC freed 8091 objects / 462936 bytes in 43
ms
D/dalvikvm(  691): GC_FOR_MALLOC freed 7616 objects / 461328 bytes in 44ms
D/dalvikvm(  691): GC_FOR_MALLOC freed 7403 objects / 456800 bytes in 45
ms
D/dalvikvm(  691): GC_FOR_MALLOC freed 7859 objects / 503672 bytes in 45
ms
D/dalvikvm(  691): GC_EXPLICIT freed 414 objects / 37208 bytes in 39ms
D/dalvikvm(  691): GC_EXPLICIT freed 596 objects / 29344 bytes in 40ms
D/dalvikvm(  691): GC_EXPLICIT freed 449 objects / 25360 bytes in 43ms
D/dalvikvm(  691): GC_EXPLICIT freed 308 objects / 35128 bytes i
n 60ms
D/dalvikvm(  691): GC_EXPLICIT freed 279 objects / 19000 bytes in 60ms
D/dalvikvm(  691): GC_EXPLICIT freed 341 objects / 18392 bytes i
n 61ms
D/dalvikvm(  691): GC_EXPLICIT freed 449 objects / 28224 bytes in 62ms
D/dalvikvm(  691): GC_EXPLICIT freed 529 objects / 53104 bytes in 67ms
D/dalvikvm(  691): GC_EXPLICIT freed 623 objects / 34008 bytes in 68ms
D/dalvikvm(  691): GC_EXPLICIT freed 861 objects / 46808 bytes i
n 69ms
D/dalvikvm(  691): GC_EXPLICIT freed 1747 objects / 85504 bytes in 71ms
D/dalvikvm(  691): GC_EXPLICIT freed 447 objects / 29336 bytes in 73ms
D/dalvikvm(  691): GC_EXPLICIT freed 315 objects / 20112 bytes in 73ms
I/Zygote  (  691): ...preloaded 1265 classes in 12430ms.
D/dalvikvm(  691): GC_EXPLICIT freed 99 objects / 13928 bytes in 71ms
I/Zygote  (  691): Preloading resources...
W/Zygote  (  691): Preloaded drawable resource #0x108009
3 (res/drawable-mdpi/sym_def_app_icon.png) that varies with configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x1080002 (res/drawable-mdpi/arrow_down_float.png) that varies with
configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x10800b3 (res/drawable/btn_check.xml) that varies with configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x10800b6 (res/drawable-mdpi/btn_check_label_background.9.png) that
W/Zygote  (  691): Preloaded drawable resource #0x10800b7 (res/drawable-mdpi/btn_check_off.png) that varies with
configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x10800bc (res/drawable-mdpi/btn_check_on.png) that varies with
configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x1080004 (res/drawable/btn_default.xml) that varies with configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x1080005 (res/drawable/btn_default_small.xml) that varies with
configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x1080006 (res/drawable/btn_dropdown.xml) that varies with configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x1080008 (res/drawable/btn_plus.xml) that varies with configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x1080007 (res/drawable/btn_minus.xml) that varies with configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x1080009 (res/drawable/btn_radio.xml) that varies with configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x108000a (res/drawable/btn_star.xml) that varies with configuration!!
D/dalvikvm(  691): GC_EXPLICIT freed 421 objects / 25896 bytes in 73ms
W/Zygote  (  691): Preloaded drawable resource #0x1080131 (res/drawable/btn_toggle.xml) that varies with configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x1080197 (res/drawable-mdpi/ic_emergency.png) that varies with
configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x1080012 (res/drawable-mdpi/divider_horizontal_bright.9.png) that varies
W/Zygote  (  691): Preloaded drawable resource #0x1080014 (res/drawable-mdpi/divider_horizontal_dark.9.png) that varies with
configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x1080016 (res/drawable/edit_text.xml) that varies with configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x1080170 (res/drawable/expander_group.xml) that varies with configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x1080062 (res/drawable/list_selector_background.xml) that varies with
configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x108022a (res/drawable-mdpi/menu_background.9.png) that varies with
configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x108022b (res/drawable-mdpi/menu_background_fill_parent_width.9.png)
W/Zygote  (  691): Preloaded drawable resource #0x108022c (res/drawable/menu_selector.xml) that varies with configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x1080237 (res/drawable-mdpi/panel_background.9.png) that varies with
configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x108023e (res/drawable-mdpi/popup_bottom_bright.9.png) that varies with
configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x108023f (res/drawable-mdpi/popup_bottom_dark.9.png) that varies with
configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x1080240 (res/drawable-mdpi/popup_bottom_medium.9.png) that varies with
configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x1080241 (res/drawable-mdpi/popup_center_bright.9.png) that varies with
configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x1080242 (res/drawable-mdpi/popup_center_dark.9.png) that varies with
configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x1080245 (res/drawable-mdpi/popup_full_dark.9.png) that varies with
configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x1080248 (res/drawable-mdpi/popup_top_bright.9.png) that varies with
configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x1080249 (res/drawable-mdpi/popup_top_dark.9.png) that varies with
configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x108006d (res/drawable/progress_indeterminate_horizontal.xml) that varies
W/Zygote  (  691): Preloaded drawable resource #0x108024f (res/drawable/progress_small.xml) that varies with configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x1080250 (res/drawable/progress_small_titlebar.xml) that varies with
configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x1080273 (res/drawable-mdpi/scrollbar_handle_horizontal.9.png) that varies
W/Zygote  (  691): Preloaded drawable resource #0x1080274 (res/drawable-mdpi/scrollbar_handle_vertical.9.png) that varies
D/dalvikvm(  691): GC_EXPLICIT freed 477 objects / 32640 bytes in 74ms
W/Zygote  (  691): Preloaded drawable resource #0x1080071 (res/drawable/spinner_dropdown_background.xml) that varies with
configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x1080357 (res/drawable-mdpi/title_bar_shadow.9.png) that varies with
configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x10801d9 (res/drawable-
mdpi/indicator_code_lock_drag_direction_green_up.png) that varies with configuration!!
W/Zygote
 (  691): Preloaded drawable resource #0x10801da (res/drawable-mdpi/indicator_code_lock_drag_direction_red_up.png) that
W/Zygote  (  691): Preloaded drawable resource #0x10801db (res/drawable-mdpi/indicator_code_lock_point_area_default.png)
W/Zygote  (  691): Preloaded drawable resource #0x10801dc (res/drawable-mdpi/indicator_code_lock_point_area_green.png)
W/Zygote  (  691): Preloaded drawable resource #0x10801dd (res/drawable-mdpi/indicator_code_lock_point_area_red.png) that
W/Zygote  (  691): Preloaded drawable resource #0x10801eb (res/drawable-mdpi/jog_tab_bar_left_end_confirm_gray.9.png) that
W/Zygote  (  691): Preloaded drawable resource #0x10801ef (res/drawable-mdpi/jog_tab_bar_left_end_normal.9.png) that varies
W/Zygote  (  691): Preloaded drawable resource #0x10801f0 (res/drawable-mdpi/jog_tab_bar_left_end_pressed.9.png) that
W/Zygote  (  691): Preloaded drawable resource #0x10801f4 (res/drawable-mdpi/jog_tab_bar_right_end_confirm_gray.9.png)
W/Zygote  (  691): Preloaded drawable resource #0x10801f8 (res/drawable-mdpi/jog_tab_bar_right_end_normal.9.png) that
W/Zygote  (  691): Preloaded drawable resource #0x10801f9 (res/drawable-mdpi/jog_tab_bar_right_end_pressed.9.png) that
W/Zygote  (  691): Preloaded drawable resource #0x10801fe (res/drawable-mdpi/jog_tab_left_confirm_gray.png) that varies with
configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x1080203 (res/drawable-mdpi/jog_tab_left_normal.png) that varies with
configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x1080204 (res/drawable-mdpi/jog_tab_left_pressed.png) that varies with
configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x1080206 (res/drawable-mdpi/jog_tab_right_confirm_gray.png) that varies
W/Zygote  (  691): Preloaded drawable resource #0x108020c (res/drawable-mdpi/jog_tab_right_normal.png) that varies with
configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x108020d (res/drawable-mdpi/jog_tab_right_pressed.png) that varies with
configuration!!
W/Zygote  (  691): Preloaded drawable resource #0x1080210 (res/drawable-mdpi/jog_tab_target_gray.png) that varies with
configuration!!
I/Zygote  (  691): ...preloaded 61 resources in 951ms.
I/Zygote  (  691): ...preloaded 15 resources in 33ms.
D/dalvikvm(  691): GC_EXPLICIT freed 503 objects / 37800 bytes in 74ms
D/dalvikvm(  691): GC_EXPLICIT freed 150 objects / 5800 bytes in
 74ms
D/dalvikvm(  691): GC_EXPLICIT freed 2 objects / 48 bytes in 72ms
I/dalvikvm(  691): System server process 713 has been created
I/Zygote  (  691): Accepting command socket connections
warning: `zygote' uses 32-bit capabilities (legacy support in use)
E/BatteryService(  713): acOnlinePath not found
E/BatteryServic
e(  713): usbOnlinePath not found
E/BatteryService(  713): batteryStatusPath not found
E/BatteryService(  713): batteryHealthPath not found
E/BatteryService(  713): batteryPresentPath not found
E/BatteryService(  713): batteryCapacityPath not found
E/BatteryService(  713): batteryVoltagePath not found
E/BatteryService(  713): batteryTemperaturePath not found
E/BatteryService(  713): batteryTechnologyPath not found
I/sysproc (  713): Entered system_init()
I/sysproc (  713): ServiceManager: 0x122bd0
I/SurfaceFlinger(  713): SurfaceFlinger is starting
I/SurfaceFlinger(  713): SurfaceFlinger's main thread ready to run. Initializing graphics H/W...
I/gralloc (  713): using (fd=24)
I/gralloc (  713): id           = DA8xx FB Drv
I/gralloc (  713): xres         = 800 px
I/gralloc (  713): yres         = 600 px
I/gralloc (  713): xres_virtual = 800 px
I/gralloc (  713): yres_virtual = 1200 px
I/gralloc (  713): bpp          = 16
I/gralloc (  713): r            = 11:5
I/gralloc (  713): g            =  5:6
I/gralloc (  713): b            =  0:5
I/gralloc (  713): width        = 127 mm (160.000000 dpi)
I/gralloc (  713): height       = 95 mm (160.421051 dpi)
I/gralloc (  713): refresh rate = 11.77 Hz
D/libEGL  (  713): egl.cfg not found, using default config
D/libEGL  (  713): loaded /system/lib/egl/libGLES_android.so
I/SurfaceFlinger(  713): EGL informations:
I/SurfaceFlinger(  713): # of configs : 8
I/SurfaceFlinger(  713): vendor    : Android
I/SurfaceFlinger(  713): version   : 1.4 Android META-EGL
I/SurfaceFlinger(  713): extensions: EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap
EGL_ANDROID_image_native_buffer EGL_ANDROID_swap_rectangle EGL_ANDROID_get_render_buffer
I/SurfaceFlinger(  713): Client API: OpenGL ES
I/SurfaceFlinger(  713): EGLSurface: 5-6-5-0, config=0x1000000
I/SurfaceFlinger(  713): flags     : 001c0000
W/SurfaceFlinger(  713): ro.sf.lcd_density not defined, using 160 dpi by default.
I/SurfaceFlinger(  713): OpenGL informations:
I/SurfaceFlinger(  713): renderer  : Android PixelFlinger 1.3
I/SurfaceFlinger(  713): version   : OpenGL ES-CM 1.0
I/SurfaceFlinger(  713): extensions: GL_OES_byte_coordinates GL_OES_fixed_point GL_OES_single_precision GL_OES_read_format
GL_OES_compressed_paletted_texture GL_OES_draw_texture GL_OES_matrix_get GL_OES_query_matrix GL_OES_EGL_image
GL_OES_compressed_ETC1_RGB8_texture GL_ARB_texture_compression GL_ARB_texture_non_power_of_two
GL_ANDROID_user_clip_plane GL_ANDROID_vertex_buffer_object GL_ANDROID_generate_mipmap
I/SurfaceFlinger(  713): GL_MAX_TEXTURE_SIZE = 4096
I/SurfaceFlinger(  713): GL_MAX_VIEWPORT_DIMS = 4096
I/sysproc (  713): System server: starting Android runtime.
I/sysproc (  713): System server: starting Android services.
I/sysproc (  713): System server: entering thread pool.
I/SystemServer(  713): Entered the Android system server!
I/SystemServer(  713): Entropy Service
I/SystemServer(  713): Power Manager
I/SystemServer(  713): Activity Manager
D/libEGL  (  725): egl.cfg not found, using default config
D/libEGL  (  725): loaded /system/lib/egl/libGLES_android.so
W/zipro   (  725): Unable to open zip '/data/local/bootanimation.zip': No such file or directory
W/zipro   (  725): Unable to open zip '/system/media/bootanimation.zip': No such file or directory
I/ActivityManager(  713): Memory class: 16
I/ARMAssembler(  713): generated scanline__00000077:03010104_00000004_00000000 [ 22 ipp] (41 ins) at
[0x1f68f0:0x1f6994] in 0 ns
I/ARMAssembler(  725): generated scanline__00000077:03545404_00000A01_00000000 [ 30 ipp] (51 ins) at
[0x1c5e8:0x1c6b4] in 0 ns
I/SystemServer(  713): Telephony Registry
I/SystemServer(  713): Package Manager
I/installd(  694): new connection
I/Installer(  713): connecting...
I/PackageManager(  713): Libs: android.test.runner:/system/framework/android.test.runner.jar javax.obex:
/system/framework/javax.obex.jar
I/PackageManager(  713): Features:
I/PackageManager(  713): No current settings file!
W/PackageManager(  713): Running ENG build: no pre-dexopt!
D/PackageManager(  713): Scanning app dir /system/framework
I/PackageManager(  713): /system/framework/framework-res.apk changed; collecting certs
D/dalvikvm(  713): GC_FOR_MALLOC freed 5103 objects / 218936 bytes in 13
1ms
Unable to handle kernel paging request at virtual address d746b920
pgd = c71cc0
00
[d746b920] *pgd=00000000
Internal error: Oops: 805 [#1] PREEMPT
last sysfs file: /sys/power/wait_for_fb_sleep
Modules linked in:
CPU: 0    Tainted: G        W   (2.6.32 #3)
PC is at __slab_free+0x48/0x354
LR is at kmem_cache_free+0x78/0x88
pc : [<c00a0cb0>]    lr : [<c00a24c0>]    psr: 60000093
sp : c723beb0  ip : c723bed0  fp : c723becc
r10: c722f9b0  r9 : 00000009  r8 : 00000000
r7 : c005e448  r6 : c722f900  r5 : c0428094  r4 : c05c95e0
r3 : 00000000  r2 : 4408f008  r1 : c05c95e0  r0 : c0428094
Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment user
Control: 0005317f  Table: c71cc000  DAC: 00000015
PC: 0xc00a0c30:
0c30  e3a03000 ebfffd79 e3a02000 e1a00004 e1a01005 e1a03002 ebfffd74 e5943040
0c50  e3530000 089da830 e1a00005 e12fff33 e89da830 80010400 e1a0c00d e92dd8f0
0c70  e24cb004 e1a06002 e1a0200d e1a07003 e3c23d7f e3c3303f e5932004 e1a05000
0c90  e2822001 e5832004 e1a04001 e5913000 e3130002 1a000046 e5943014 e59b2004
0cb0  e7863102 e1d420b8 e5941000 e2422001 e1a02802 e1a02822 e3110040 e5846014
0cd0  e1c420b8 1a000007 e3520000 0a000010 e3530000 1a000003 e2850014 e1a01004
0cf0  e3a02001 ebfffa64 e1a0200d e3c23d7f e3c3303f e5932004 e2422001 e5832004
0d10  e5933000 e3130002 089da8f0 eb0a23f1 e89da8f0 e3530000 0a000017 e1a0200d
LR: 0xc00a2440:
2440  c03ca32d 00000b71 e1a0c00d e92dd810 e24cb004 e24dd00c e1a02001 e1a04621
2460  e59f1064 e2444703 e591c000 e1a0300e e08c1284 e79cc284 e31c0902 1591100c
2480  e10f4000 e384c080 e121f00c e590c084 e151000c 1a000006 e590c088 e35c0000
24a0  a5901080 a590308c a7821103 a5802080 aa000002 e590c08c e58dc000 ebfff9e9
24c0  e121f004 e24bd010 e89da810 c0458aec e1a0c00d e92dd8f0 e24cb004 e24dd008
24e0  e59fc084 e1a0300e e59c6000 e0016006 e10f4000 e3841080 e121f001 e5907080
2500  e5905090 e3570000 1590308c 17973103 15803080 1a000005 e2802080 e58d2000
2520  e1a01006 e3e02000 ebfffe26 e1a07000 e121f004 e1a067a6 e3570000 03a06000
SP: 0xc723be30:
be30  c723bea0 c04572a0 00001614 00000027 00000000 00000027 ffffffff c723be9c
be50  c722f900 c005e448 c723becc c723be68 c002baac c002b2ac c0428094 c05c95e0
be70  4408f008 00000000 c05c95e0 c0428094 c722f900 c005e448 00000000 00000009
be90  c722f9b0 c723becc c723bed0 c723beb0 c00a24c0 c00a0cb0 60000093 ffffffff
beb0  40000013 c722f900 c0435a94 c722fa10 c723beec c723bed0 c00a24c0 c00a0c78
bed0  4408f008 c722f950 c722f900 c722f950 c723bf04 c723bef0 c005e448 c00a2458
bef0  c0435bd4 c0435bec c723bf34 c723bf08 c0075284 c005e3d8 c00753a4 c0435bd4
bf10  c0435a94 00000024 00000102 c0455da0 00000009 0000000a c723bf4c c723bf38
IP: 0xc723be50:
bf30  c00753c4 c0074fb0 c723a000 00000001 c723bf84 c723bf50 c00466a8 c00753b4
FP: 0xc723be4c:
be4c  c723be9c c722f900 c005e448 c723becc c723be68 c002baac c002b2ac c0428094
be6c  c05c95e0 4408f008 00000000 c05c95e0 c0428094 c722f900 c005e448 00000000
be8c  00000009 c722f9b0 c723becc c723bed0 c723beb0 c00a24c0 c00a0cb0 60000093
beac  ffffffff 40000013 c722f900 c0435a94 c722fa10 c723beec c723bed0 c00a24c0
becc  c00a0c78 4408f008 c722f950 c722f900 c722f950 c723bf04 c723bef0 c005e448
beec  c00a2458 c0435bd4 c0435bec c723bf34 c723bf08 c0075284 c005e3d8 c00753a4
bf0c  c0435bd4 c0435a94 00000024 00000102 c0455da0 00000009 0000000a c723bf4c
bf2c  c723bf38 c00753c4 c0074fb0 c723a000 00000001 c723bf84 c723bf50 c00466a8
R0: 0xc0428014:
8014  4408f090 00000000 00007d19 b601fe5d 00000000 002ac173 00000000 000002bc
8034  00000000 000002bc 00000000 00000027 0000388f 00000000 00000043 4000f1f0
8054  00000000 00000027 00000000 2f736572 77617264 656c6261 70646d2d 74732f69
8074  735f7461 735f7379 616e6769 2e315f6c 00676e70 00000000 00000023 4000d1c8
8094  00000000 4408f0b0 20d7d6f3 00000000 00000000 00000000 0000006b 00000000
80b4  00000000 00000000 00000000 00650072 002f0073 00720064 00770061 00620061
80d4  0065006c 006d002d 00700064 002f0069 00740073 00740061 0073005f 00730079
80f4  0073005f 00670069 0061006e 005f006c 002e0031 006e0070 00000067 00000000
R1: 0xc05c9560:
9560  00000080 00000001 00150015 c0428128 00000000 00000000 00100100 00200200
9580  00000000
00000001 ffffffff 00000000 00000000 00000000 00100100 00200200
95a0  000000c0 00000001 00080008 c0428534 00000000 00000000 00100100 00200200
95c0  00000000 00000001 ffffffff 00000000 00000000 00000000 00100100 00200200
95e0  000000c0 00000001 002a002a c0428094 00000000 00000000 00100100 00200200
9600  00000000 00000001 ffffffff 00000000 00000000 00000000 00100100 00200200
9620  00000000 00000000 ffffffff 00000000 00000000 00000000 c05c9638 c05c9638
9640  00000000 00000001 ffffffff 00000000 00000000 00000000 00100100 00200200
R4: 0xc05c9560:
9580  00000000 00000001 ffffffff 00000000 00000000 00000000 00100100 00200200
R5: 0xc0428014:
R6: 0xc722f880:
f880  ffffffff ffffffff c78a4780 c70810c0 c722f950 c005e3c8 bbffefff 7febbffa
f8a0  c722f6c0 000003e8 000003e8 000003e8 000003e8 000003e8 000003e8 000003e8
f8c0  000003e8 00000010 00000000 00000000 07c13c20 00000000 00000000 00000000
f8e0  ffffffff ffffffff c78a4780 c70810c0 c722fa10 c005e3c8 fbfeaffb eafefbbe
f900  00000000 000003e8 000003e8 000003e8 000003e8 000003e8 000003e8 000003e8
f920  000003e8 00000010 00000000 00000000 07c13c20 00000000 00000000 00000000
f940  ffffffff ffffffff c78a4780 c70810c0 c722f9b0 c005e3c8 feeffefb bffef7ff
f960  00000000 000003e8 000003e8 000003e8 000003e8 000003e8 000003e8 000003e8
R7: 0xc005e3c8:
e3c8  e1a0c00d e92dd830 e24cb004 e5103050 e1a04000 e3530000 e2405050 0a000003
e3e8  e5102050 e1a01005 e59f0054 eb0b2c53 e5103004 e3530000 0a00000a e10f1000
e408  e3812080 e121f002 e5932000 e2422001 e5832000 e121f001 e3520000 1a000001
e428  e5100004 eb0002b3 e5140008 ebffba3d e59f3010 e1a01005 e5930000 eb010fff
e448  e89da830 c03c6263 c0457290 e1a0c00d e92dd870 e24cb004 e24dd01c e1a0300d
e468  e3c35d7f e24b4030 e3c5503f e1a00004 e3a01000 e3a02014 e595600c eb044635
e488  e59f30b4 e59f00b4 e1a01004 e50b602c e50b3028 ebffe793 ea00001e e595300c
e4a8  e3a02001 e5832000 e59f3094 e5934004 e5936008 ea000013 e59f0088 e3a01000
R10: 0xc722f930:
f930  07c13c20 00000000 00000000 00000000 ffffffff ffffffff c78a4780 c70810c0
f950  c722f9b0 c005e3c8 feeffefb bffef7ff 00000000 000003e8 000003e8 000003e8
f970  000003e8 000003e8 000003e8 000003e8 000003e8 00000010 00000000 00000000
f990  07c13c20 00000000 00000000 00000000 ffffffff ffffffff c78a4780 c70810c0
f9b0  c722fa10 c005e3c8 bbfefffe fbffbfaf 00000000 000003e8 000003e8 000003e8
f9d0  000003e8 000003e8 000003e8 000003e8 000003e8 00000010 00000000 00000000
f9f0  07c13c20 00000000 00000000 00000000 ffffffff ffffffff c78a4780 c70810c0
fa10  00000000 c005e3c8 fffbaa2f effeaffa c722f840 000003e8 000003e8 000003e8
Process er.ServerThread (pid: 724, stack limit = 0xc723a270)
Stack: (0xc723beb0 to 0xc723c000)
bea0:                                     40000013 c722f900 c0435a94 c722fa10
bec0: c723beec c723bed0 c00a24c0 c00a0c78 4408f008 c722f950 c722f900 c722f950
bee0: c723bf04 c723bef0 c005e448 c00a2458 c0435bd4 c0435bec c723bf34 c723bf08
bf00: c0075284 c005e3d8 c00753a4 c0435bd4 c0435a94 00000024 00000102 c0455da0
bf20: 00000009 0000000a c723bf4c c723bf38 c00753c4 c0074fb0 c723a000 00000001
bf40: c723bf84 c723bf50 c00466a8 c00753b4 00000000 c04313c4 00000015 00000015
bf60: 00000000 00200000 00000001 00000000 c723a000 40034d08 c723bf94 c723bf88
bf80: c0046788 c0046638 c723bfac c723bf98 c002b074 c004674c ffffffff febfd000
bfa0: 00000000 c723bfb0 c002bd14 c002b010 410d6e50 00000010 410d70f8 0000000a
bfc0: 418d944e 428babc8 4581fe30 000010f8 80213b00 418
d9442 40034d08 00116058
bfe0: 000000f8 4581fdf0 80218758 80217928 20000010 ffffffff fffafaff fbfbafbe
Backtrace:
[<c00a0c68>] (__slab_free+0x0/0x354) from [<c00a24c0>] (kmem_cache_free+0x78/0x88)
 r7:c722fa10 r6:c0435a94 r5:c722f900 r4:40000013
[<c00a2448>] (kmem_cache_free+0x0/0x88) from [<c005e448>] (put_cred_rcu+0x80/0x8c)
 r4:c722f950
[<c005e3c8>] (put_cred_rcu+0x0/0x8c) from [<c0075284>] (__rcu_process_callbacks+0x2e4/0x404)
 r5:c0435bec r4:c0435bd4
[<c0074fa0>] (__rcu_process_callbacks+0x0/0x404) from [<c00753c4>] (rcu_process_callbacks+0x20/0x38)
[<c00753a4>] (rcu_process_callbacks+0x0/0x38) from [<c00466a8>] (__do_softirq+0x80/0x114)
 r5:00000001 r4:c723a000
[<c0046628>] (__do_softirq+0x0/0x114) from [<c0046788>] (irq_exit+0x4c/0xb0)
[<c004673c>] (irq_exit+0x0/0xb0) from [<c002b074>] (asm_do_IRQ+0x74/0x90)
[<c002b000>] (asm_do_IRQ+0x0/0x90) from [<c002bd14>] (__irq_usr+0x54/0xa0)
Exception stack(0xc723bfb0 to 0xc723bff8)
bfa0:                                     410d6e50 00000010 410d70f8 0000000a
bfc0: 418d944e 428babc8 4581fe30 000010f8 80213b00 418d9442 40034d08 00116058
 r5:febfd000 r4:ffffffff
Code: e3130002 1a000046 e5943014 e59b2004 (e7863102)
---[ end trace 525b5d57c501bdbe ]---
Kernel panic - not syncing: Fatal exception in interrupt
Backtrace:
[<c00302bc>] (dump_backtrace+0x0/0x110) from [<c0329544>] (dump_stack+0x18/0x1c)
 r6:00000001 r5:c723bd3c r4:c0451478 r3:00000002
[<c032952c>] (dump_stack+0x0/0x1c) from [<c03295a8>] (panic+0x60/0x12c)
[<c0329548>] (panic+0x0/0x12c) from [<c0030730>] (die+0x28c/0x2c8)
 r3:00000100 r2:c723bd10 r1:c723bc48 r0:c03c0ead
[<c00304a4>] (die+0x0/0x2c8) from [<c0032710>] (__do_kernel_fault+0x6c/0x7c)
 r7:c723be68
[<c00326a4>] (__do_kernel_fault+0x0/0x7c) from [<c0032970>] (do_bad_area+0x68/0x74)
 r7:c723be68 r6:c71cc000 r5:c00075d0 r4:00000000
[<c0032908>] (do_bad_area+0x0/0x74) from [<c0032a00>] (do_translation_fault+0x6c/0x78)
[<c0032994>] (do_translation_fault+0x0/0x78) from [<c002b2d8>] (do_DataAbort+0x3c/0xa0)
 r6:d746b920 r5:c042a6dc r4:00000805 r3:c0032994
[<c002b29c>] (do_DataAbort+0x0/0xa0) from [<c002baac>] (__dabt_svc+0x4c/0x60)
Exception stack(0xc723be68 to 0xc723beb0)
be60:                   c0428094 c05c95e0 4408f008 00000000 c05c95e0 c0428094
be80: c722f900 c005e448 00000000 00000009 c722f9b0 c723becc c723bed0 c723beb0
bea0: c00a24c0 c00a0cb0 60000093 ffffffff
 r7:c005e448 r6:c722f900 r5:c723be9c r4:ffffffff
 r4:c722f950
And sometimes the log is:
logcat
I/DEBUG   (  689): debuggerd: Jul 11 2012 00:38:
45
D/AndroidRuntime(  692):
D/AndroidRuntime(  692): >>>>>>>>>>>>
D/AndroidRuntime(  692): CheckJNI is ON
D/AndroidRuntime(  692): --- registering native functions ---
I/        (  693): ServiceManager: 0xacd0
E/ALSALib (  693): external/alsa-lib/src/control/control.c:909:(snd_ctl_open_noupdate) Invalid CTL Andro
idPlayback
W/AudioHardwareALSA(  693): Unable to attach mixer to device AndroidPlayback: No such file or directory
E/ALSALib (  693): external/alsa-lib/src/control/control.c:909:(snd_ctl_open_noupdate) Invalid CTL AndroidCapture
W/AudioHardwareALSA(  693): Unable to attach mixer to device AndroidCapture: No such file or directory
I/CameraService(  693): CameraService started: pid=693
D/AudioHardwareALSA(  693): openOutputStream called for devices: 0x00000002
D/ALSAModule(  693): open called for devices 00000002 in mode 0...
E/ALSALib (  693): external/alsa-lib/src/pcm/pcm.c:2201:(snd_pcm_open_noupdate) Unknown PCM
E/ALSALib (  693): external/alsa-lib/src/pcm/pcm.c:2201:(snd_pcm_open_noupdate) Unknown PCM AndroidPlayback_Speaker
I/ALSAModule(  693): Initialized ALSA PLAYBACK device default
I/AudioFlinger(  693): AudioFlinger's thr
ead 0x3ceb0 ready to run
D/ALSAModule(  693): route called for devices 00000002 in mode 0...
E/AudioHardwareALSA(  693): CALLING STANDBY
I/ethernet(  692): Loading ethernet jni class
I/SamplingProfilerIntegration(  692): Profiler is disabled.
I/Zygote  (  692): Preloading classes...
D/dalvikvm(  692): GC_EXPLICIT freed 818
D/dalvikvm(  692): GC_EXPLICIT freed 219 objects / 13568 bytes i
n 7ms
D/dalvikvm(  692): GC_EXPLICIT freed 253 objects / 14352 bytes in 9ms
D/dalvikvm(  692): GC_EXPLICIT freed 466 objects / 28904 bytes in 10ms
D/dalvikvm(  692): GC_EXPLICIT freed 2090 objects / 108424 bytes in 13ms
W/MediaProfiles(  692): could not find media config xml file
D/dalvikvm(  692): GC_EXPLICIT freed 279 objects / 15984 bytes in 13ms
D/dalvikvm(  692): GC_FOR_MALLOC freed 5081 objects / 225496 byt
es in 26ms
D/dalvikvm(  692): GC_FOR_MALLOC freed 11259 objects / 382816 bytes in 3
4ms
D/dalvikvm(  692): GC_FOR_MALLOC freed 9839 objects / 462800 bytes in 38
ms
D/dalvikvm(  692): GC_FOR_MALLOC freed 8657 objects / 421680 bytes in 42
ms
D/dalvikvm(  692): GC_FOR_MALLOC freed 8091 objects / 462936 byt
es in 43ms
D/dalvikvm(  692): GC_FOR_MALLOC freed 7616 objects / 461328 bytes in 43
ms
D/dalvikvm(  692): GC_FOR_MALLOC freed 7403 objects / 456800 bytes in 45
ms
D/dalvikvm(  692): GC_FOR_MALLOC freed 7859 objects / 503672 bytes in 45
ms
D/dalvikvm(  692): GC_EXPLICIT freed 414 objects / 37208 bytes in 38ms
D/dalvikvm(  692): GC_EXPLICIT freed 596 objects / 29344 bytes in 40ms
D/dalvikvm(  692): GC_EXPLICIT freed 449 objects / 25360 bytes in 42ms
D/dalvikvm(  692): GC_EXPLICIT freed 308 objects / 35128 bytes i
n 59ms
D/dalvikvm(  692): GC_EXPLICIT freed 279 objects / 19000 bytes in 59ms
D/dalvikvm(  692): GC_EXPLICIT freed 341 objects / 18392 bytes i
n 61ms
D/dalvikvm(  692): GC_EXPLICIT freed 449 objects / 28224 bytes in 62ms
D/dalvikvm(  692): GC_EXPLICIT freed 529 objects / 53104 bytes in 66ms
D/dalvikvm(  692): GC_EXPLICIT freed 623 objects / 34008 bytes i
n 68ms
D/dalvikvm(  692): GC_EXPLICIT freed 861 objects / 46808 bytes in 68ms
D/dalvikvm(  692): GC_EXPLICIT freed 1747 objects / 85504 bytes in 71ms
D/dalvikvm(  692): GC_EXPLICIT freed 447 objects / 29336 bytes in 72ms
D/dalvikvm(  692): GC_EXPLICIT freed 315 objects / 20112 bytes in 73ms
I/Zygote  (  692): ...preloaded 1265 classes in 12243ms.
D/dalvikvm(  692): GC_EXPLICIT freed 99 objects / 13928 bytes in 70ms
I/Zygote  (  692): Preloading resources...
W/Zygote  (  692): Preloaded dra
wable resource #0x1080093 (res/drawable-mdpi/sym_def_app_icon.png) that varies with configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x1080002 (res/drawable-mdpi/arrow_down_float.png) that varies with
configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x10800b3 (res/drawable/btn_check.xml) that varies with configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x10800b6 (res/drawable-mdpi/btn_check_label_background.9.png) that
W/Zygote  (  692): Preloaded drawable resource #0x10800b7 (res/drawable-mdpi/btn_check_off.png) that varies with
configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x10800bc (res/drawable-mdpi/btn_check_on.png) that varies with
configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x1080004 (res/drawable/btn_default.xml) that varies with configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x1080005 (res/drawable/btn_default_small.xml) that varies with
configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x1080006 (res/drawable/btn_dropdown.xml) that varies with configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x1080008 (res/drawable/btn_plus.xml) that varies with configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x1080007 (res/drawable/btn_minus.xml) that varies with configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x1080009 (res/drawable/btn_radio.xml) that varies with configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x108000a (res/drawable/btn_star.xml) that varies with configuration!!
reed 421 objects / 25896 bytes in 72ms
W/Zygote  (  692): Preloaded drawable resource #0x1080131 (res/drawable/btn_toggle.xml) that varies with configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x1080197 (res/drawable-mdpi/ic_emergency.png) that varies with
configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x1080012 (res/drawable-mdpi/divider_horizontal_bright.9.png) that varies
W/Zygote  (  692): Preloaded drawable resource #0x1080014 (res/drawable-mdpi/divider_horizontal_dark.9.png) that varies with
configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x1080016 (res/drawable/edit_text.xml) that varies with configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x1080170 (res/drawable/expander_group.xml) that varies with configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x1080062 (res/drawable/list_selector_background.xml) that varies with
configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x108022a (res/drawable-mdpi/menu_background.9.png) that varies with
configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x108022b (res/drawable-mdpi/menu_background_fill_parent_width.9.png)
W/Zygote  (  692): Preloaded drawable resource #0x108022c (res/drawable/menu_selector.xml) that varies with configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x1080237 (res/drawable-mdpi/panel_background.9.png) that varies with
configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x108023e (res/drawable-mdpi/popup_bottom_bright.9.png) that varies with
configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x108023f (res/drawable-mdpi/popup_bottom_dark.9.png) that varies with
configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x1080240 (res/drawable-mdpi/popup_bottom_medium.9.png) that varies with
configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x1080241 (res/drawable-mdpi/popup_center_bright.9.png) that varies with
configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x1080242 (res/drawable-mdpi/popup_center_dark.9.png) that varies with
configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x1080245 (res/drawable-mdpi/popup_full_dark.9.png) that varies with
configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x1080248 (res/drawable-mdpi/popup_top_bright.9.png) that varies with
configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x1080249 (res/drawable-mdpi/popup_top_dark.9.png) that varies with
configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x108006d (res/drawable/progress_indeterminate_horizontal.xml) that varies
W/Zygote  (  692): Preloaded drawable resource #0x108024f (res/drawable/progress_small.xml) that varies with configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x1080250 (res/drawable/progress_small_titlebar.xml) that varies with
configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x1080273 (res/drawable-mdpi/scrollbar_handle_horizontal.9.png) that varies
W/Zygote  (  692): Preloaded drawable resource #0x1080274 (res/drawable-mdpi/scrollbar_handle_vertical.9.png) that varies
D/dalvikvm(  692): GC_EXPLICIT freed 477 objects / 32640 bytes in 74ms
W/Zygote  (  692): Preloaded drawable resource #0x1080071 (res/drawable/spinner_dropdown_background.xml) that varies with
configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x1080357 (res/drawable-mdpi/title_bar_shadow.9.png) that varies with
configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x10801d9 (res/drawable-
nfiguration!!
W/Zygote  (  692): Preloaded drawable resource #0x10801da (res/drawable-
mdpi/indicator_code_lock_drag_direction_red_up.png) that varies with configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x10801db (res/drawable-mdpi/indicator_code_lock_point_area_default.png)
W/Zygote  (  692): Preloaded drawable resource #0x10801dc (res/drawable-mdpi/indicator_code_lock_point_area_green.png)
W/Zygote  (  692): Preloaded drawable resource #0x10801dd (res/drawable-mdpi/indicator_code_lock_point_area_red.png) that
W/Zygote  (  692): Preloaded drawable resource #0x10801eb (res/drawable-mdpi/jog_tab_bar_left_end_confirm_gray.9.png) that
W/Zygote  (  692): Preloaded drawable resource #0x10801ef (res/drawable-mdpi/jog_tab_bar_left_end_normal.9.png) that varies
W/Zygote  (  692): Preloaded drawable resource #0x10801f0 (res/drawable-mdpi/jog_tab_bar_left_end_pressed.9.png) that
W/Zygote  (  692): Preloaded drawable resource #0x10801f4 (res/drawable-mdpi/jog_tab_bar_right_end_confirm_gray.9.png)
W/Zygote  (  692): Preloaded drawable resource #0x10801f8 (res/drawable-mdpi/jog_tab_bar_right_end_normal.9.png) that
W/Zygote  (  692): Preloaded drawable resource #0x10801f9 (res/drawable-mdpi/jog_tab_bar_right_end_pressed.9.png) that
W/Zygote  (  692): Preloaded drawable resource #0x10801fe (res/drawable-mdpi/jog_tab_left_confirm_gray.png) that varies with
configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x1080203 (res/drawable-mdpi/jog_tab_left_normal.png) that varies with
configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x1080204 (res/drawable-mdpi/jog_tab_left_pressed.png) that varies with
configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x1080206 (res/drawable-mdpi/jog_tab_right_confirm_gray.png) that varies
W/Zygote  (  692): Preloaded drawable resource #0x108020c (res/drawable-mdpi/jog_tab_right_normal.png) that varies with
configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x108020d (res/drawable-mdpi/jog_tab_right_pressed.png) that varies with
configuration!!
W/Zygote  (  692): Preloaded drawable resource #0x1080210 (res/drawable-mdpi/jog_tab_target_gray.png) that varies with
configuration!!
I/Zygote  (  692): ...preloaded 61 resources in 946ms.
I/Zygote  (  692): ...preloaded 15 resources in 33ms.
D/dalvikvm(  692): GC_EXPLICIT freed 503 objects / 37800 bytes in 74ms
D/dalvikvm(  692): GC_EXPLICIT freed 150 objects / 5800 bytes in 73ms
D/dalvikvm(  692): GC_EXPLICIT freed 2 objects / 48 bytes in 72ms
I/dalvikvm(  692): System server process 713 has been created
I/Zygote  (  692): Accepting command socket connections
rt in use)
16
D/libEGL  (  724): egl.cfg not found, using default config
D/libEGL  (  724): loaded /system/lib/egl/libGLES_android.so
W/zipro   (  724): Unable to open zip '/data/local/bootanimation.zip': No such file or directory
W/zipro   (  724): Unable to open zip '/system/media/bootanimation.zip': No such file or directory
W/UsageStats(  713): Usage stats version changed; dropping
[0x1ff238:0x1ff2dc] in 0 ns
I/ARMAssembler(  724): generated scanline__00000077:03545404_00000A01_00000000 [ 30 ipp] (51 ins) at
I/installd(  695): new connection
g...
javax.obex:/system/framework/javax.obex.jar
D/dalvikvm(  713): GC_FOR_MALLOC freed 5099 objects / 218760 bytes in 11
5ms
And it is died.I wait for half an hour and the word "android" on the LCD is not rolling.
what should I do ?Please help me.
  thanks.
