login:root
//fallows is my uart print message
root@dm816x-evm:~/dvr_rdk/ti816x# ./run_gui.sh //then i type ./run_gui.sh to run the DVR GUI
*** Bootargs Validated for mem param ***
*** Bootargs Validated for notifyk.vpssm3 params ***
Kernel bootargs validated
numid=1,iface=MIXER,name='PCM Playback Volume'
; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
: values=127,127
| dBscale-min=-63.50dB,step=0.50dB,mute=0
[c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[m3video] Remote Debug Shared Memory @ 0xbff05020
[m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
SysLink version : 2.00.04.83
SysLink module created on Date:Dec 31 2011 Time:02:47:31
Trace enabled
Trace SetFailureReason enabled
Setting DMM priority for [DUCATI ] to [0] ( 0x4e000624 = 0x08000000 )
Setting DMM priority for [HDVICP0 ] to [2] ( 0x4e000634 = 0x0000000a )
Setting DMM priority for [HDVICP1 ] to [2] ( 0x4e000634 = 0x000a0000 )
Setting DMM priority for [HDVICP2 ] to [2] ( 0x4e000634 = 0x00a00000 )
Attached to slave procId 2.
Loaded file ../firmware/dvr_rdk_fw_m3vpss.xem3 on slave procId 2.
Started slave procId 2.
[m3vpss ] ***** SYSTEM : Frequency <ORG> - 250000000, <NEW> - 250000000
[m3vpss ] notify_attach rtnVal 0
[m3vpss ] initProxyServer rtnVal 0
[m3vpss ]
[m3vpss ] *** UTILS: CPU KHz = 500000 Khz ***
[m3vpss ]
After Ipc_loadcallback status [0x00000000]
[m3vpss ] 53: SYSTEM : System Common Init in progress !!!
[m3vpss ] 53: SYSTEM: IPC init in progress !!!
[m3vpss ] 53: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 1053: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 1055: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3vpss ] 1055: SYSTEM: Attaching to [DSP] ...
After Ipc_startcallback status [0x097d2000]
Attached to slave procId 1.
Loaded file ../firmware/dvr_rdk_fw_m3video.xem3 on slave procId 1.
Started slave procId 1.
[m3video] ***** SYSTEM : Frequency <ORG> - 250000000, <NEW> - 250000000
[m3vpss ] 2055: SYSTEM: Attaching to [DSP] ...
[m3video]
[m3video] *** UTILS: CPU KHz = 500000 Khz ***
[m3video]
[m3video] 1224: SYSTEM : System Common Init in progress !!!
[m3video] 1224: SYSTEM: IPC init in progress !!!
[m3video] 1224: SYSTEM: Attaching to [HOST] ...
[m3video] 2224: SYSTEM: Attaching to [HOST] ...
[m3video] 2226: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3video] 2226: SYSTEM: Attaching to [DSP] ...
After Ipc_startcallback status [0x00000000]
Attached to slave procId 0.
Loaded file ../firmware/dvr_rdk_fw_c6xdsp.xe674 on slave procId 0.
Started slave procId 0.
[c6xdsp ] ***** SYSTEM : Frequency <ORG> - 800000000, <NEW> - 800000000
[m3video] 3226: SYSTEM: Attaching to [DSP] ...
[m3vpss ] 3055: SYSTEM: Attaching to [DSP] ...
[c6xdsp ]
[c6xdsp ] *** UTILS: CPU KHz = 800000 Khz ***
[c6xdsp ]
[c6xdsp ] 5: SYSTEM : System Common Init in progress !!!
[c6xdsp ] 5: SYSTEM: IPC init in progress !!!
[c6xdsp ] 5: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 1029: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 1031: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[c6xdsp ] 1031: SYSTEM: Attaching to [VIDEO-M3] ...
[m3vpss ] 4055: SYSTEM: Attaching to [DSP] ...
[m3video] 4226: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2055: SYSTEM: Attaching to [VIDEO-M3] ...
[m3vpss ] 5055: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2980: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3video] 5226: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2980: SYSTEM: Attaching to [VPSS-M3] ...
[m3video] 5226: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3video] 5226: SYSTEM: Attaching to [VPSS-M3] ...
[m3vpss ] 6055: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 4003: SYSTEM: Attaching to [VPSS-M3] ...
[m3video] 6226: SYSTEM: Attaching to [VPSS-M3] ...
[c6xdsp ] 4862: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 7055: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 4862: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 7055: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3vpss ] 7055: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 7226: SYSTEM: Attaching to [VPSS-M3] ...
[c6xdsp ] 5886: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3video] 8055: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 8055: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 8055: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 8055: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3video] 8056: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[m3vpss ] 8055: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3video] 8056: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[m3vpss ] 8056: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[m3vpss ] 8056: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[m3video] 8058: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[m3vpss ] 8058: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[m3video] 8058: SYSTEM: Notify register to [DSP] line 0, event 12 ...
[m3vpss ] 8058: SYSTEM: Notify register to [DSP] line 0, event 12 ...
[m3video] 8058: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[m3vpss ] 8058: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[m3video] 8058: SYSTEM: IPC init DONE !!!
[m3vpss ] 8058: SYSTEM: IPC init DONE !!!
[m3video] 8066: MEM: Shared Region 2: Base = 0xa8000000, Length = 0x16900000 (361 MB)
[m3vpss ] 8066: MEM: Shared Region 2: Base = 0xa8000000, Length = 0x16900000 (361 MB)
[m3video] 8066: MEM: ERROR: SharedRegion_setEntry (2, 0x95dc4348) FAILED !!! (status=-1)
[m3vpss ] 8066: MEM: Shared Region 1: Base = 0x8fe00000, Length = 0x05900000 (89 MB)
[m3video] 8076: MEM: Shared Region 1: Base = 0x8fe00000, Length = 0x05900000 (89 MB)
[m3vpss ] 8068: SYSTEM : System Common Init Done !!!
[m3vpss ] 8068: SYSTEM : System VPSS Init in progress !!!
[m3vpss ] === HDVPSS Clocks are enabled ===
[m3vpss ] === HDVPSS is fully functional ===
[m3vpss ] === HDVPSS module is not in standby ===
[m3vpss ] === I2C1 Clk is active ===
[m3vpss ] 8073: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[m3vpss ] 8073: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[m3vpss ] 8073: SYSTEM: ListElem Shared Addr = 0xbe98b280
[m3vpss ] 8076: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[m3vpss ] 8076: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[m3vpss ] 8076: SYSTEM: ListElem Shared Addr = 0xbe98e380
[m3video] 8078: SYSTEM : System Common Init Done !!!
[m3vpss ] 8087: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
[m3video] 8078: SYSTEM : System Video Init in progress !!!
[m3video] 8078: SYSTEM : System Video Init Done !!!
[m3video] 8078: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[m3video] 8079: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[m3video] 8079: SYSTEM: ListElem Shared Addr = 0xbe991480
[m3vpss ] 8088: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
[m3video] 8081: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[m3video] 8081: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[m3video] 8081: SYSTEM: ListElem Shared Addr = 0xbe994580
[m3video] 8089: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
[m3vpss ] 8088: SYSTEM: ListElem Shared Addr = 0xbe997680
[m3video] 8089: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
[m3vpss ] 8090: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
[m3video] 8089: SYSTEM: ListElem Shared Addr = 0xbe9b6c80
[m3vpss ] 8090: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
[m3video] 8091: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_30] in region 0 ...
[m3vpss ] 8091: SYSTEM: ListElem Shared Addr = 0xbe9ce580
[m3video] 8091: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_30] in region 0 ...
[m3vpss ] 8093: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_26] in region 0 ...
[m3video] 8091: SYSTEM: ListElem Shared Addr = 0xbe9edb80
[m3vpss ] 8093: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_26] in region 0 ...
[m3video] 8093: HDVICP: Doing PRCM for IVAHD[0] ...
[m3vpss ] 8093: SYSTEM: ListElem Shared Addr = 0xbea05480
[m3video] 8093: HDVICP: PRCM for IVAHD[0] ... DONE.
[m3vpss ] 8095: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_35
[m3video] 8094: HDVICP: Doing PRCM for IVAHD[1] ...
[m3vpss ] 8095: SYSTEM : FVID2 Init in progress !!!
[m3video] 8094: HDVICP: PRCM for IVAHD[1] ... DONE.
[m3video] 8094: HDVICP: Doing PRCM for IVAHD[2] ...
[m3video] 8094: HDVICP: PRCM for IVAHD[2] ... DONE.
[m3video] 8095: SYSTEM : Initializing Links !!!
[m3vpss ] 8150: SYSTEM : FVID2 Init in progress DONE !!!
[m3vpss ] 8150: SYSTEM : Device Init in progress !!!
[m3video] 8095: SYSTEM : Heap Free Space (System = 2088104 bytes, SR0 = 15579008 bytes, FrmBuf = 378535808 bytes,
[m3video] BitBuf = 93323136 bytes, Mbx = 10240 msgs)
[m3video] 8104: SYSTEM : Initializing Links ... DONE !!!
[m3vpss ] I2C1: Passed for address 0x20 !!!
[m3vpss ] I2C1: Passed for address 0x21 !!!
[c6xdsp ] 6910: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[c6xdsp ] 6910: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
[c6xdsp ] 6910: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
[c6xdsp ] 6911: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[c6xdsp ] 6911: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[c6xdsp ] 6911: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[c6xdsp ] 6911: SYSTEM: IPC init DONE !!!
[c6xdsp ] 6913: MEM: Shared Region 2: Base = 0xa8000000, Length = 0x16900000 (361 MB)
[c6xdsp ] 6913: MEM: Shared Region 1: Base = 0x8fe00000, Length = 0x05900000 (89 MB)
[c6xdsp ] 6913: SYSTEM : System Common Init Done !!!
[c6xdsp ] 6748: SYSTEM : System DSP Init in progress !!!
[c6xdsp ] 6916: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
[c6xdsp ] 6916: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
[c6xdsp ] 6916: SYSTEM: ListElem Shared Addr = 0xbea24a80
[c6xdsp ] 6917: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
[c6xdsp ] 6917: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
[c6xdsp ] 6917: SYSTEM: ListElem Shared Addr = 0xbea44080
[c6xdsp ] 6918: SYSTEM: Creating ListMP [DSP_IPC_OUT_26] in region 0 ...
[c6xdsp ] 6918: SYSTEM: Creating ListMP [DSP_IPC_IN_26] in region 0 ...
[c6xdsp ] 6918: SYSTEM: ListElem Shared Addr = 0xbea63680
[c6xdsp ] !!WARNING.Resource already registered:2
[c6xdsp ] 6753: SYSTEM : Initializing Links !!!
[c6xdsp ] 6918: SYSTEM : Heap Free Space (System = 9429472 bytes, SR0 = 15193472 bytes, FrmBuf = 378535808 bytes,
[c6xdsp ] BitBuf = 93323136 bytes, Mbx = 10240 msgs)
[c6xdsp ] 6758: SYSTEM : Initializing Links ... DONE !!!
[c6xdsp ] 6759: SYSTEM : System DSP Init Done !!!
[m3vpss ] I2C1: Passed for address 0x39 !!!
[m3vpss ] I2C1: Passed for address 0x3d !!!
[m3vpss ] I2C1: Passed for address 0x58 !!!
[m3vpss ] I2C1: Passed for address 0x5a !!!
[m3vpss ] I2C1: Passed for address 0x5c !!!
[m3vpss ] I2C1: Passed for address 0x5e !!!
[m3vpss ] I2C1: Passed for address 0x60 !!!
[m3vpss ] 10644: SYSTEM : Device Init in progress DONE !!!
[m3vpss ] 10666: SYSTEM : System VPSS Init Done !!!
[m3vpss ] 10667: SYSTEM : Initializing Links !!!
[m3vpss ] 10667: SYSTEM : Heap Free Space (System = 25544 bytes, SR0 = 15193472 bytes, FrmBuf = 374225792 bytes,
[m3vpss ] BitBuf = 93323136 bytes, Mbx = 10240 msgs)
[m3vpss ] Received character 's'
[m3vpss ] 12249: SYSTEM : Initializing Links ... DONE !!!
[m3video] Received character 's'
[c6xdsp ] Received character 's'
/home/root/dvr_rdk/ti816x
VPSS_FVID2: M3 firmware version 0x1000135 is newer,driver may not work properly.
[module] vpss probe done.
[module] ti81xxfb probe done.
HDMI W1 rev 2.0
[module] ti81xx_hdmi probe done.
ORG 0x46c00524: 0
NEW 0x46c00524: 2
[dvrmain info]
main: HDMI0, sub: HDMI1, video_in: NTSC, video_out: 1080p60gVIDEOMOTION_ctrl.bufSize = 21120
gVIDEOMOTION_ctrl.bufNum = 16
app_pb: app_playback_init ... success
[host] APP_WRITER:WRITER_videoRecvFxn:Entered...
[host] APP_WRITER:WRITER_recordFxn:Entered... 0: SYSTEM: System Common Init in progress !!!
0: SYSTEM: IPC init in progress !!!
9: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
11: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
12: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
14: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
14: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
15: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
16: SYSTEM: Notify register to [DSP] line 0, event 12 ...
16: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
17: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
17: SYSTEM: IPC init DONE !!!
19: SYSTEM: Creating ListMP [HOST_IPC_OUT_28] in region 0 ...
21: SYSTEM: Creating ListMP [HOST_IPC_IN_28] in region 0 ...
23: SYSTEM: ListElem Shared Addr = 0x4cd55c80
24: SYSTEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ...
26: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ...
28: SYSTEM: ListElem Shared Addr = 0x4cd6d580
30: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
32: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
34: SYSTEM: ListElem Shared Addr = 0x4cd84e80
35: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
37: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
39: SYSTEM: ListElem Shared Addr = 0x4cda4480
39: SYSTEM: System Common Init Done !!!
AVSYNC_Init start
I don't fine any wrong,but why my screen is black (no single is blue),that means it has HDMI out single but nothing?
can anybody help?thx~
