Other Parts Discussed in Thread: DM3730, ADS7846, TVP5146M2
Texas Instruments X-Loader 1.46 (Mar 24 2011 - 20:21:25)
Starting X-loader on MMC
Reading boot sector
216572 Bytes Read from MMC
Starting OS Bootloader from MMC...
Starting OS Bootloader...
U-Boot 2009.11 (Mar 24 2011 - 20:27:06)
AM37x/DM37x-GP ES2.1, CPU-OPP2 L3-165MHz
OMAP3 EVM board + LPDDR/NAND
I2C: ready
DRAM: 256 MB
NAND: 512 MiB
In: serial
Out: serial
Err: serial
Read back SMSC id 0x92200000
Die ID #1eea00229ff80000015f26ad0f02b01c
Net: smc911x-0
Hit any key to stop autoboot: 0
mmc1 is available
reading uImage
2412992 bytes read
## Booting kernel from Legacy Image at 82000000 ...
Image Name: Arago/2.6.32-psp03.00.01.06.sdk/
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2412928 Bytes = 2.3 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux.............................................................
Linux version 2.6.32 (sdk@nemo) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-201
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: OMAP3 EVM
Memory policy: ECC disabled, Data cache writeback
OMAP3630/DM3730 ES1.0 (l2cache iva sgx neon isp 192mhz_clk )
SRAM: Mapped pa 0x40200000 to va 0xfe400000 size: 0x100000
Reserving 4194304 bytes SDRAM for VRAM
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 46336
Kernel command line: console=ttyS0,115200n8 rw mem=55M@0x80000000 mpurate=1000 f
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 55MB 128MB = 183MB total
Memory: 176384KB available (4216K code, 373K data, 172K init, 0K highmem)
Hierarchical RCU implementation.
NR_IRQS:402
Clocking rate (Crystal/Core/MPU): 26.0/400/600 MHz
Reprogramming SDRC clock to 400000000 Hz
GPMC revision 5.0
IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts
Total of 96 interrupts on 1 active controller
OMAP GPIO hardware version 2.5
OMAP clockevent source: GPTIMER1 at 32768 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 597.64 BogoMIPS (lpj=2334720)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
regulator: core version 0.5
NET: Registered protocol family 16
Target VDD1 OPP = 4, VDD2 OPP = 2
omap3evmdc: Driver registration complete
OMAP DMA hardware revision 5.0
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
i2c_omap i2c_omap.1: bus 1 rev4.0 at 2600 kHz
twl4030: PIH (irq 7) chaining IRQs 368..375
twl4030: power (irq 373) chaining IRQs 376..383
twl4030: gpio (irq 368) chaining IRQs 384..401
regulator: VMMC1: 1850 <--> 3150 mV normal standby
regulator: VDAC: 1800 mV normal standby
regulator: VAUX2_4030: 2800 mV normal standby
regulator: VPLL2: 1800 mV normal standby
regulator: VSIM: 1800 <--> 3000 mV normal standby
i2c_omap i2c_omap.2: bus 2 rev4.0 at 400 kHz
i2c_omap i2c_omap.3: bus 3 rev4.0 at 400 kHz
Switching to clocksource 32k_counter
musb_hdrc: version 6.0, musb-dma, otg (peripheral+host), debug=0
musb_hdrc: USB OTG mode controller at fa0ab000 using DMA, IRQ 92
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
omap-iommu omap-iommu.0: isp registered
AM37x/DM37x Linux PSP version 03.00.01.06 (OMAP3EVM)
NetWinder Floating Point Emulator V0.97 (double precision)
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
JFFS2 version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
msgmni has been set to 345
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
OMAP DSS rev 2.0
OMAP DISPC rev 3.0
OMAP VENC rev 2
OMAP DSI rev 1.0
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654
console [ttyS0] enabled
serial8250.1: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654
serial8250.2: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654
brd: module loaded
loop: module loaded
omap2-nand driver initializing
NAND device: Manufacturer ID: 0xad, Chip ID: 0xbc (Hynix NAND 512MiB 1,8V 16-bi)
Creating 5 MTD partitions on "omap2-nand.0":
0x000000000000-0x000000080000 : "xloader-nand"
0x000000080000-0x000000240000 : "uboot-nand"
0x000000240000-0x000000280000 : "params-nand"
0x000000280000-0x000000780000 : "linux-nand"
0x000000780000-0x000020000000 : "jffs2-nand"
OneNAND driver initializing
omap2-onenand omap2-onenand: Cannot request GPMC CS
omap2-onenand: probe of omap2-onenand failed with error -16
smsc911x: Driver version 2008-10-21.
smsc911x-mdio: probed
eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=ffffffff:01, irq=-1)
net eth0: MAC Address: 00:50:c2:7e:97:69
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver dm9601
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: OMAP-EHCI Host Controller
usb usb1: Manufacturer: Linux 2.6.32 ehci_hcd
usb usb1: SerialNumber: ehci-omap.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 3 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver usbtest
g_ether gadget: using random self ethernet address
g_ether gadget: using random host ethernet address
usb0: MAC 82:30:6b:bc:bf:8b
usb0: HOST MAC 12:dd:00:6d:a5:56
g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
g_ether gadget: g_ether ready
musb_hdrc musb_hdrc: MUSB HDRC host driver
musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 2
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: MUSB HDRC host driver
usb usb2: Manufacturer: Linux 2.6.32 musb-hcd
usb usb2: SerialNumber: musb_hdrc
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
mice: PS/2 mouse device common for all mice
input: TWL4030 Keypad as /devices/platform/i2c_omap.1/i2c-1/1-004a/twl4030_keyp0
ads7846 spi1.0: touchscreen, irq 335
input: ADS7846 Touchscreen as /devices/platform/omap2_mcspi.1/spi1.0/input/inpu1
twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
twl_rtc twl_rtc: Power up reset detected.
twl_rtc twl_rtc: Enabling TWL-RTC.
i2c /dev entries driver
Linux video capture interface: v2.00
tvp514x 3-005c: Registered to v4l2 master omap34xxcam!!
omap-iommu omap-iommu.0: isp: version 1.1
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v0.1.0)
OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
Advanced Linux Sound Architecture Driver Version 1.0.21.
usbcore: registered new interface driver snd-usb-audio
No device for DAI omap-mcbsp-dai-0
No device for DAI omap-mcbsp-dai-1
No device for DAI omap-mcbsp-dai-2
No device for DAI omap-mcbsp-dai-3
No device for DAI omap-mcbsp-dai-4
OMAP3 EVM SoC init
asoc: twl4030 <-> omap-mcbsp-dai-0 mapping ok
ALSA device list:
#0: omap3evm (twl4030)
TCP cubic registered
NET: Registered protocol family 17
NET: Registered protocol family 15
Power Management for TI OMAP3.
Compensating OPP4 for 63mV Orig nvalue:0xaa978a New nvalue:0xab8afb
Compensating OPP3 for 63mV Orig nvalue:0xaab9a5 New nvalue:0xaaa693
Compensating OPP2 for 50mV Orig nvalue:0x9a82e6 New nvalue:0xaae6cb
Compensating OPP1 for 50mV Orig nvalue:0x99ceb7 New nvalue:0x99ab97
Switched to new clocking rate (Crystal/Core/MPU): 26.0/400/1000 MHz
IVA2 clocking rate: 800 MHz
SmartReflex driver initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
twl_rtc twl_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
tvp514x 3-005c: tvp5146m2 found at 0xb8 (OMAP I2C adapter)
omapdss DPI error: display already enabled
omap_vout omap_vout: 'lcd' Display already enabled
omap_vout omap_vout: Buffer Size = 3686400
omap_vout omap_vout: : registered and initialized video device 1
mmc0: new high speed SDHC card at address 1234
omap_vout omap_vout: : registered and initialized video device 2
mmcblk0: mmc0:1234 SA08G 7.28 GiB
mmcblk0: p1 p2
kjournald starting. Commit interval 5 seconds
EXT3-fs (mmcblk0p2): warning: maximal mount count reached, running e2fsck is red
EXT3-fs (mmcblk0p2): using internal journal
EXT3-fs (mmcblk0p2): recovery complete
EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode
VFS: Mounted root (ext3 filesystem) on device 179:2.
Freeing init memory: 172K
INIT: version 2.86 booting
Please wait: booting...
Starting udev
udev: starting version 141
Remounting root file system...
Caching udev devnodes
Populating dev cachemv: cannot rename '/tmp/devices': No such file or directory
logger: mount: mount point /proc/bus/usb does not exist
ALSA: Restoring mixer settings...
Configuring network interfaces... No state is present for card omap3evm
Unknown hardware: "twl4030" "" "" "" ""
Hardware is initialized using a guess method
net eth0: SMSC911x/921x identified at 0xd0860000, IRQ: 336
udhcpc (v1.13.2) started
Sending discover...
Sending discover...
Sending select for 192.168.1.101...
Lease of 192.168.1.101 obtained, lease time 7200
adding dns 192.168.200.1
adding dns 192.168.1.1
done.
Setting up IP spoofing protection: rp_filter.
Thu Mar 24 22:54:00 UTC 2011
INIT: Entering runlevel: 5
Starting system message bus: dbus.
Starting Dropbear SSH server: dropbear.
Starting telnet daemon.
Starting syslogd/klogd: done
Starting thttpd.
Starting PVR
CMEMK module: built on Mar 24 2011 at 20:50:56
Reference Linux version 2.6.32
File /sdk/build/DVSDK_4_02/4_02_00_06/arago-install/arago-tmp/work/dm37x-evm-c
CMEM Range Overlaps Kernel Physical - allowing overlap
CMEM phys_start (0x83700000) overlaps kernel (0x80000000 -> 0x8b700000)
allocated heap buffer 0xd2000000 of size 0x2200000
heap fallback enabled - will try heap if pool buffer is not available
cmemk initialized
DSPLINK Module (1.65.00.02) created on Date: Mar 24 2011 Time: 20:53:34
SDMAK module: built on Mar 24 2011 at 20:51:03
Starting Matrix GUI application.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org dm37x-evm ttyS0
Arago 2011.02 dm37x-evm ttyS0
dm37x-evm login: root
root@dm37x-evm:~# cd /usr/share/ti/ti-dmai-apps/
root@dm37x-evm:/usr/share/ti/ti-dmai-apps# ls
Output.jpeg output.264
aac_test_output.pcm output.m4v
audio_decode1_dm3730.x470MV speech_decode_io1_dm3730.x470MV
audio_decode_io1_dm3730.x470MV speech_encode_io1_dm3730.x470MV
cs.x64P video_decode_io2_dm3730.x470MV
h264_test_output.yuv video_display_dm3730.x470MV
image_decode_io1_dm3730.x470MV video_encode_io1_dm3730.x470MV
image_encode_io1_dm3730.x470MV video_loopback_copy_dm3730.x470MV
jpeg_test_output.yuv video_loopback_dm3730.x470MV
mpeg2_test_output.yuv video_loopback_resize_dm3730.x470MV
mpeg4_test_output.yuv
root@dm37x-evm:/usr/share/ti/ti-dmai-apps# ./video_loopback_dm3730.x470MV -O lcd
-I composite
Failed to detect input video standard, input connected?
-I composite
root@dm37x-evm:/usr/share/ti/ti-dmai-apps# ./video_loopback_copy_dm3730.x470MV -
O lcd _I composite
Usage: video_loopback_copy_<platform> [options]
Options:
-a | --fcopy_accel Use hardware acceleration if available for
copying frames
--capture_ualloc User allocates buffers for capture driver
--display_ualloc User allocates buffers for display driver
--position Output position ('x-offset'x'y-offset')
position origin [Default: 0x0] is the
upper-left corner of the screen
Only used with --resolution.
-r | --resolution Image resolution ('width'x'height')
[Defaults to same as display standard]
--input_position Input position ('x-offset'x'y-offset')
upper-left corner of the screen.
Only used with --input_resolution.
--smooth Enable the smooth module instead of a
normal copy.
--crop If -r is set, use cropping on the video
input to set this resolution.
(crop not supported for DM6467)
--benchmark Print benchmarking information
-O | --display_output Video output to use (see below)
-I | --capture_input Video input to use (see below)
--display_standard Display standard to use (see below)
--display_device Display device to use (e.g /dev/fb3)
--display_num_bufs Number of display buffer to use by driver
-h | --help Print usage information (this message)
-n | --numframes Number of frames to process [Default: 0 (infinite)]
Video output available:
composite [Default]
svideo
component
lcd
dvi
auto (select video output by reading sysfs)
Video inputs available:
composite [Default]
s-video
component
Display Standard:
1 fbdev
2 v4l2
O lcd -I composite
Failed to detect capture video standard
-I composite
root@dm37x-evm:/usr/share/ti/ti-dmai-apps# export DMAI_DEBUG=1
-I composite
@0x000dca82:[T:0x4001f050] ti.sdo.dmai - [Capture] Failed VIDIOC_S_INPUT to ind)
root@dm37x-evm:/usr/share/ti/ti-dmai-apps# cat /sys/devices/platform/omapdss/di
splay0/timings
19200,480/1/28/2,640/1/1/1
root@dm37x-evm:/usr/share/ti/ti-dmai-apps# fbs
fbset fbset.real fbsplash
root@dm37x-evm:/usr/share/ti/ti-dmai-apps# fbset
mode "480x640-58"
# D: 19.200 MHz, H: 37.574 kHz, V: 58.435 Hz
geometry 480 640 480 1920 16
timings 52083 1 28 1 1 2 1
rgba 5/11,6/5,5/0,0/0
endmode
