Hi folks,
in my application I create multiple GateMP instances, one for each FIFO communication channel I use. However, if there are more then about 28 channels GateMP_create() function starts to produces the following error:
"ti.sdo.ipc.GateMP: line 1384: E_gateUnavailable: No gates of requested type are available"
Is there a limit for the amount of Gates that can be created? Do I need more memory in shared region 0?
for creation of FIFO communication channels I initialize the Gate:
Char fifo_gate_name[] = "edma_\0\0";
System_sprintf(&fifo_gate_name[5], "%d", fifo->id);
/* Create the gate needed for mutual exclusion */
GateMP_Params_init(&gparams);
gparams.name = (String)fifo_gate_name;
gparams.regionId = 0;
gparams.localProtect = GateMP_LocalProtect_THREAD;
gparams.remoteProtect = GateMP_RemoteProtect_SYSTEM;
gate = GateMP_create(&gparams);
I'm using the latest CCS 5.2.1 with MCSDK 2.0.9
My platform configuration file is attached, the debugging is done with an XSD510 USB Plus.
Platform config:
/* ============= XDC Runtime Configuration ============= */
var Memory = xdc.useModule('xdc.runtime.Memory');
var Log = xdc.useModule('xdc.runtime.Log');
var Error = xdc.useModule('xdc.runtime.Error');
var Diags = xdc.useModule('xdc.runtime.Diags');
var Timestamp = xdc.useModule('xdc.runtime.Timestamp');
var Startup = xdc.useModule('xdc.runtime.Startup');
var System = xdc.useModule('xdc.runtime.System');
var SysStd = xdc.useModule('xdc.runtime.SysStd');
System.SupportProxy = SysStd;
/* ================ BIOS Configuration ================ */
var BIOS = xdc.useModule('ti.sysbios.BIOS');
var Task = xdc.useModule('ti.sysbios.knl.Task');
var Clock = xdc.useModule('ti.sysbios.knl.Clock');
var Sem = xdc.useModule('ti.sysbios.knl.Semaphore');
var Hwi = xdc.useModule('ti.sysbios.hal.Hwi');
var Ecm = xdc.useModule('ti.sysbios.family.c64p.EventCombiner');
var BiosCache = xdc.useModule('ti.sysbios.hal.Cache');
var Idle = xdc.useModule('ti.sysbios.knl.Idle');
var HeapBuf = xdc.useModule('ti.sysbios.heaps.HeapBuf');
var HeapMem = xdc.useModule('ti.sysbios.heaps.HeapMem');
var Exc = xdc.useModule('ti.sysbios.family.c64p.Exception');
var Cache = xdc.useModule('ti.sysbios.family.c66.Cache');
var Load = xdc.useModule('ti.sysbios.utils.Load');
var CpIntc = xdc.useModule('ti.sysbios.family.c66.tci66xx.CpIntc');
var ECM = xdc.useModule ("ti.sysbios.family.c64p.EventCombiner");
Idle.addFunc('&myIdleFunc');
//Cache.setMarMeta(0x80000000, 0x20000000, Cache.PC | Cache.PCX | Cache.PFX | Cache.WTE );
ECM.eventGroupHwiNum[0] = 7;
ECM.eventGroupHwiNum[1] = 8;
ECM.eventGroupHwiNum[2] = 9;
ECM.eventGroupHwiNum[3] = 10;
/* Create a default system heap using ti.bios.HeapMem. */
Memory.defaultHeapSize = 0x20000;
Program.heap = 0x20000;
/* Load and configure NDK */
//var Global = xdc.useModule('ti.ndk.config.Global');
/* ================ IPC Configuration ================ */
/* Modules explicitly used in the application */
var Ipc = xdc.useModule('ti.sdo.ipc.Ipc');
var MessageQ = xdc.useModule('ti.sdo.ipc.MessageQ');
var GateMP = xdc.useModule('ti.sdo.ipc.GateMP');
var HeapBufMP = xdc.useModule('ti.sdo.ipc.heaps.HeapBufMP');
var HeapMemMP = xdc.useModule('ti.sdo.ipc.heaps.HeapMemMP');
var SharedRegio = xdc.useModule('ti.sdo.ipc.SharedRegion');
var MultiProc = xdc.useModule('ti.sdo.utils.MultiProc');
MultiProc.setConfig(null, ["CORE0", "CORE1", "CORE2", "CORE3", "CORE4", "CORE5", "CORE6", "CORE7"]);
/* Synchronize all processors (this will be done in Ipc_start) */
Ipc.procSync = Ipc.ProcSync_ALL;
/* Shared Memory base address and length */
var SHAREDMEM0 = 0x0C200000;
var SHAREDMEMSIZE0 = 0x00110000;
var SHAREDMEM1 = 0x0C310000;
var SHAREDMEMSIZE1 = 0x00070000;
var SHAREDMEM2 = 0x98000000;
var SHAREDMEMSIZE2 = 0x04000000;
* Need to define the shared region. The IPC modules use this
* to make portable pointers. All processors need to add this
* call with their base address of the shared memory region.
* If the processor cannot access the memory, do not add it.
var SharedRegion = xdc.useModule('ti.sdo.ipc.SharedRegion');
SharedRegion.numEntries = 3;
SharedRegion.translate = false;
SharedRegion.setEntryMeta(0,
{ base: SHAREDMEM0,
len: SHAREDMEMSIZE0,
ownerProcId: 0,
isValid: true,
cacheLineSize: 128,
SharedRegion.setEntryMeta(1,
{ base: SHAREDMEM1,
len: SHAREDMEMSIZE1,
ownerProcId: 0,
isValid: true,
cacheLineSize: 128,
SharedRegion.setEntryMeta(2,
{ base: SHAREDMEM2,
len: SHAREDMEMSIZE2,
ownerProcId: 0,
isValid: true,
cacheEnable: true,
createHeap: true,
cacheLineSize: 128,
/* =========== CPPI and QMSS Configuration =========== */
var Cppi = xdc.loadPackage('ti.drv.cppi');
var Qmss = xdc.loadPackage('ti.drv.qmss');
/* Use the CSL module and indicate that INTC library will be used. */
var cslSettings = xdc.useModule ('ti.csl.Settings');
cslSettings.useCSLIntcLib = true;
/* ================ Logger configuration ================ */
var LoggerCircBuf = xdc.useModule('ti.uia.runtime.LoggerCircBuf');
var Defaults = xdc.useModule('xdc.runtime.Defaults');
var Main = xdc.useModule('xdc.runtime.Main');
Load.windowInMs = 50;
CpuTimestamp = xdc.useModule('ti.uia.family.c66.TimestampC66XLocal');
GlobalTimestamp = xdc.useModule('ti.uia.family.c66.TimestampC66XGlobal');
LogSync = xdc.useModule('ti.uia.runtime.LogSync');
LogSync.enableEventCorrelationForJTAG = true;
LogSync.GlobalTimestampProxy = GlobalTimestamp;
LogSync.CpuTimestampProxy = CpuTimestamp;
CpuTimestamp.maxTimerClockFreq = {lo:1000000000,hi:0};
CpuTimestamp.maxBusClockFreq = {lo:1000000000,hi:0};
GlobalTimestamp.maxTimerClockFreq = {lo:250000000,hi:0};
GlobalTimestamp.maxBusClockFreq = {lo:1000000000,hi:0};
GlobalTimestamp.cpuCyclesPerTick = 4;
Exc.common$.logger = Main.common$.logger;
Exc.enablePrint = true;
var LoggingSetup = xdc.useModule('ti.uia.sysbios.LoggingSetup');
// Increase the sysbios logger and turn Hwi and Swi logging off
LoggingSetup.sysbiosLoggerSize = 32768;
LoggingSetup.mainLoggerSize = 8*1024;
LoggingSetup.loadLoggerSize = 32768;
LoggingSetup.loadLogging = true; // true
LoggingSetup.sysbiosTaskLogging = false; // true
LoggingSetup.sysbiosSwiLogging = false;
LoggingSetup.sysbiosHwiLogging = false;
//LoggingSetup.eventUploadMode = LoggingSetup.UploadMode_NONJTAGTRANSPORT;
LoggingSetup.eventUploadMode = LoggingSetup.UploadMode_JTAGRUNMODE; // C66xx JTAG
// ================ UIA configuration ================
var UIABenchmark = xdc.useModule('ti.uia.events.UIABenchmark');
/* ========= General Sections Configuration ========== */
Program.sectMap["systemHeap"] = Program.platform.stackMemory;
Program.sectMap[".fifoTable"] = new Program.SectionSpec();
Program.sectMap[".fifoTable"].loadAddress = 0x0C380000;
Program.sectMap[".fifoTable"].fill = 0x00000000;
Program.sectMap[".qmss"] = "SL2SRAM_SHARED";
Program.sectMap[".cppi"] = "SL2SRAM_SHARED";
Program.sectMap[".csl_vect"] = "LL2SRAM";
Program.sectMap[".ppdata"] = "LL2SRAM";
Program.sectMap[".dataLL2SRAM"] = "LL2SRAM";
Program.sectMap[".dataDDRShared"] = "DDR3_SHARED";
Program.sectMap[".dataSL2SRAMShared"] = "SL2SRAM_SHARED";
