Other Parts Discussed in Thread: TPS65910
I had been trying to make few minor modifications but after those modifications, the camera did not boot. So I have reverted the changes to previous version but still camera does not boot properly. Everytime I load the filesystem after doing tftp of jffs2_ipnc.bin, it boots for the first time but when I switch off camera and restart, it starts giving error messages as below. Can someone pls help with this issue?
Date: 2011-03-17 (Thursday) Time: 10:26:04
Net: Detected MACID:0:c:c:a0:9:13
cpsw
Hit any key to stop autoboot: 0
Loading from nand0, offset 0x280000
Image Name: Linux-2.6.37_DM8127_IPNC_3.00.00
Created: 2012-07-30 3:29:10 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2338816 Bytes = 2.2 MiB
Load Address: 80008000
Entry Point: 80008000
## Booting kernel from Legacy Image at 81000000 ...
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.37_DM8127_IPNC_3.00.00 (chandar@chandar-laptop) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #1 Mon Jul 30 08:58:57 IST 2012
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: ti8148ipnc
vram size = 4194304 at 0x0
bootconsole [earlycon0] enabled
reserved size = 4194304 at 0x0
FB: Reserving 4194304 bytes SDRAM for VRAM
Memory policy: ECC disabled, Data cache writeback
OMAP chip is TI8148 2.0
SRAM: Mapped pa 0x402f1000 to va 0xfe400000 size: 0xf000
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 19296
Kernel command line: console=ttyO0,115200n8 noinitrd mem=80M vram=4M notifyk.vpssm3_sva=0xBFD00000 root=/dev/mtdblock4 rw rootfstype=jffs2 eth=00:0C:0C:A0:09:13 ip=192.168.1.168 cmemk.phys_start=0x85000000 cmemk.phys_end=0x89000000 cmemk.allowOverlap=1 earlyprintk
cpsw: kernel boot params Ethernet address: 00:0C:0C:A0:09:13
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 76MB = 76MB total
Memory: 72024k/72024k available, 9896k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xc5800000 - 0xf8000000 ( 808 MB)
lowmem : 0xc0000000 - 0xc5000000 ( 80 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.init : 0xc0008000 - 0xc0038000 ( 192 kB)
.text : 0xc0038000 - 0xc046d000 (4308 kB)
.data : 0xc046e000 - 0xc04ab400 ( 245 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:375
IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
Total of 128 interrupts on 1 active controller
GPMC revision 6.0
Trying to install interrupt handler for IRQ368
Trying to install interrupt handler for IRQ369
Trying to install interrupt handler for IRQ370
Trying to install interrupt handler for IRQ371
Trying to install interrupt handler for IRQ372
Trying to install interrupt handler for IRQ373
Trying to install interrupt handler for IRQ374
Trying to install type control for IRQ375
Trying to set irq flags for IRQ375
OMAP clockevent source: GPTIMER1 at 20000000 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 599.65 BogoMIPS (lpj=2998272)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
omap_voltage_early_init: voltage driver support not added
regulator: core version 0.5
regulator: dummy:
NET: Registered protocol family 16
omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting!
omap_voltage_add_dev: VDD specified does not exist!
OMAP GPIO hardware version 0.1
omap_mux_init: Add partition: #1: core, flags: 4
_omap_mux_init_gpio: Could not set gpio79
_omap_mux_init_gpio: Could not set gpio80
NAND ecc use OMAP_ECC_HAMMING_CODE_HW
Debugfs: Only enabling/disabling deep sleep and wakeup timer is supported now
registered ti81xx_vpss device
registered ti81xx_vidout device
registered ti81xx on-chip HDMI device
registered ti81xx_fb device
PWM0 init success.
PWM1 init success.
bio: create slab <bio-0> at 0
SCSI subsystem initialized
USBSS revision 4ea2080b
registerd cppi-dma Intr @ IRQ 17
Cppi41 Init Done
omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
regulator: VRTC: 1800 mV
regulator: VIO: 1500 mV
regulator: VDD1: 600 <--> 1500 mV at 1100 mV
regulator: VDD2: 600 <--> 1500 mV at 1350 mV
regulator: VDDCTRL: 600 <--> 1400 mV at 1200 mV
regulator: LDO1: 1100 <--> 3300 mV at 1800 mV
regulator: LDO2: 1100 <--> 3300 mV at 1800 mV
regulator: LDO3: 1100 <--> 3300 mV at 3300 mV
regulator: LDO4: 1100 <--> 3300 mV at 1800 mV
regulator: LDO5: 1100 <--> 3300 mV at 3300 mV
regulator: LDO6: 1100 <--> 3300 mV at 3300 mV
regulator: LDO7: 1100 <--> 3300 mV at 3300 mV
regulator: LDO8: 1100 <--> 3300 mV at 1800 mV
tps65911-rtc tps65911-rtc: rtc core: registered tps65911-rtc as rtc0
tps65910 1-002d: No interrupt support, no core IRQ
Advanced Linux Sound Architecture Driver Version 1.0.23.
Switching to clocksource gp timer
musb-hdrc: version 6.0, peripheral, debug=0
musb-hdrc musb-hdrc.0: dma type: dma-cppi41
MUSB controller-0 revision 4ea20800
musb-hdrc musb-hdrc.0: USB Peripheral mode controller at c581e000 using DMA, IRQ 18
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NetWinder Floating Point Emulator V0.97 (double precision)
PMU: registered new PMU device of type 0
omap-iommu omap-iommu.0: ducati registered
omap-iommu omap-iommu.1: sys registered
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 140
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
CMEMK module: built on Jul 30 2012 at 08:50:38
Reference Linux version 2.6.37
File /mnt/work/3.0/Source/ti_tools/linuxutils_3_22_00_02/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
allocated heap buffer 0xc7000000 of size 0x4000000
cmemk initialized
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
console [ttyO0] enabled, bootconsole disabled
omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
brd: module loaded
loop: module loaded
omap2-nand driver initializing
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xca (Micron )
Creating 7 MTD partitions on "omap2-nand.0":
0x000000000000-0x000000020000 : "U-Boot-min"
0x000000020000-0x000000260000 : "U-Boot"
0x000000260000-0x000000280000 : "U-Boot Env"
0x000000280000-0x0000006c0000 : "Kernel"
0x0000006c0000-0x00000c000000 : "File System"
0x00000c000000-0x00000cc00000 : "Data"
0x00000cc00000-0x000010000000 : "Reserved"
davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
davinci_mdio davinci_mdio.0: detected phy mask fffffffe
davinci_mdio.0: probed
davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
mice: PS/2 mouse device common for all mice
i2c /dev entries driver
Linux video capture interface: v2.00
OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
notify_init : notify drivercreated for remote proc id 2 at physical Address 0xbfd00000
asoc: tlv320aic3x-hifi <-> davinci-mcasp.2 mapping ok
asoc: HDMI-DAI-CODEC <-> hdmi-dai mapping ok
ALSA device list:
#0: TI8148 IPNC
TCP cubic registered
NET: Registered protocol family 17
Registering the dns_resolver key type
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
omap_voltage_late_init: Voltage driver support not added
Power Management for TI81XX.
Detected MACID=0:c:c:a0:9:13
tps65911-rtc tps65911-rtc: setting system clock to 2011-03-17 10:26:12 UTC (1300357572)
CPSW phy found : id is : 0x4dd074
PHY 0:01 not found
IP-Config: Guessing netmask 255.255.255.0
IP-Config: Complete:
device=eth0, addr=192.168.1.168, mask=255.255.255.0, gw=255.255.255.255,
host=192.168.1.168, domain=, nis-domain=(none),
bootserver=255.255.255.255, rootserver=255.255.255.255, rootpath=
PHY: 0:00 - Link is Up - 100/Full
mtd->read(0x1fe50 bytes from 0x20c01b0) returned ECC error
mtd->read(0xee88 bytes from 0x20d1178) returned ECC error
Empty flash at 0x020d1174 ends at 0x020d1800
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x020d19bc: 0x198d instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x020d19c0: 0x0044 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x020d19c4: 0xfb1d instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x020d19c8: 0x1963 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x020d19cc: 0x0001 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x020d19d0: 0x81a4 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x020d19dc: 0xdcef instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x020d19e0: 0xdcef instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x020d19e4: 0xdcef instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x020d19fc: 0x7220 instead
Further such events for this erase block will not be printed
jffs2_scan_inode_node(): CRC failed on node at 0x020d1a30: Read 0x10d0ab87, calculated 0x10d0eb87
jffs2_scan_inode_node(): CRC failed on node at 0x020d29d0: Read 0x7e925ac6, calculated 0x18c75a89
VFS: Mounted root (jffs2 filesystem) on device 31:4.
devtmpfs: mounted
Freeing init memory: 192K
mtd->read(0x7bc bytes from 0x20d2844) returned ECC error
mtd->read(0x800 bytes from 0x20d2800) returned ECC error
mtd->read(0x7bc bytes from 0x20d2044) returned ECC error
mtd->read(0x800 bytes from 0x20d2000) returned ECC error
mtd->read(0x7bc bytes from 0x20d1844) returned ECC error
mtd->read(0x800 bytes from 0x20d1800) returned ECC error
INIT: version 2.86 booting
mtd->read(0x484 bytes from 0x20d237c) returned ECC error
mtd->read(0x600 bytes from 0x20d2200) returned ECC error
mtd->read(0x708 bytes from 0x20d20f8) returned ECC error
JFFS2 notice: (50) jffs2_get_inode_nodes: Wrong magic bitmask 0x0000 in node header at 0x1223ec0.
Please wait: booting...
Error opening /dev/fb0: No such file or directory
Starting udev
mtd->read(0x708 bytes from 0x20d28f8) returned ECC error
mtd->read(0x74c bytes from 0x20d28b4) returned ECC error
mtd->read(0x6d8 bytes from 0x20d2128) returned ECC error
mtd->read(0x74c bytes from 0x20d20b4) returned ECC error
mtd->read(0x674 bytes from 0x20d298c) returned ECC error
mtd->read(0x5d0 bytes from 0x20d2230) returned ECC error
mtd->read(0x644 bytes from 0x20d21bc) returned ECC error
mtd->read(0x528 bytes from 0x20d2ad8) returned ECC error
mtd->read(0x4c8 bytes from 0x20d2338) returned ECC error
JFFS2 error: (70) jffs2_do_read_inode_internal: CRC failed for read_inode of inode 6508 at physical location 0x6040294
iget() failed for ino #6508
touch: /tmp/atags: Input/output error
Remounting root file system...
Caching udev devnodes
Populating dev cachemtd->read(0x6d8 bytes from 0x20d1928) returned ECC error
mtd->read(0x74c bytes from 0x20d18b4) returned ECC error
JFFS2 error: (93) jffs2_do_read_inode_internal: CRC failed for read_inode of inode 6498 at physical location 0x5fe00e4
Unable to handle kernel paging request at virtual address 00100108
pgd = c4790000
[00100108] *pgd=83c1b031, *pte=00000000, *ppte=00000000
Internal error: Oops: 17 [#1]
last sysfs file:
Modules linked in:
CPU: 0 Not tainted (2.6.37_DM8127_IPNC_3.00.00 #1)
PC is at jffs2_kill_fragtree+0x24/0xc4
LR is at jffs2_kill_fragtree+0xb8/0xc4
pc : [<c016f25c>] lr : [<c016f2f0>] psr: 20000013
sp : c3c2fc60 ip : c3c2fc60 fp : c3c2fc74
r10: c40bd930 r9 : c4717380 r8 : c471b200
r7 : c40c2d20 r6 : c471b200 r5 : 00000000 r4 : 00100100
r3 : 00100100 r2 : c3c2e000 r1 : c055ede0 r0 : 00000000
Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Control: 10c5387d Table: 84790019 DAC: 00000015
Process mv (pid: 93, stack limit = 0xc3c2e2e8)
Stack: (0xc3c2fc60 to 0xc3c30000)
fc60: 00000000 c40c2d20 c3c2fc94 c3c2fc78 c01711b0 c016f244 c40c2d48 c471b200
fc80: fffffffb c40c2d20 c3c2fcac c3c2fc98 c0179adc c0171130 c40c2d48 c471b000
fca0: c3c2fcc4 c3c2fcb0 c00d5e54 c0179aac c40c2d48 c471b000 c3c2fcdc c3c2fcc8
fcc0: c00d6830 c00d5e38 c40c2d48 00001962 c3c2fcf4 c3c2fce0 c00d7aa8 c00d6660
fce0: c40c2d48 00001962 c3c2fd6c c3c2fcf8 c01794c0 c00d7a90 c00a1efc c009f9d8
fd00: 00000000 00000000 00000000 00000000 29189efc e0011985 0000002d 584d313a
fd20: 00000011 000003f7 00001962 4d81dcef ffff0805 3f9be257 4e55cea5 6d616e75
fd40: ffffff65 c3c2fd50 c47c7680 00001962 c40bb400 c47c75d5 c40bd958 c40bd930
fd60: c3c2fd94 c3c2fd70 c016e3d8 c0179440 c40bb400 c40bd958 c3c2fe88 c3c2fe88
fd80: c3c2fdf4 c3c2fe00 c3c2fdb4 c3c2fd98 c00cc030 c016e318 00000000 c40bb480
fda0: c40bd9d0 c3c2fe88 c3c2fde4 c3c2fdb8 c00cc10c c00cbff0 00000073 c3c2fe88
fdc0: c40bd958 00000000 c3c2fe38 c3c7300a 00000001 c3c2e000 c3c2fe34 c3c2fde8
fde0: c00cde58 c00cc058 c3c2fe0c c3c2fe9c c009c854 b3c36a4f 0000000b c3c7300a
fe00: c4717380 c40bb480 c00b084c c3c2fe88 c3c2fe88 c3c2e000 c3c2fe38 c3c73000
fe20: c3c2e000 00000000 c3c2fe64 c3c2fe38 c00ce394 c00cd86c c4717380 c40b2180
fe40: c3c2fe88 c3c73000 00000000 ffffff9c c3c2ff08 00000000 c3c2fe84 c3c2fe68
fe60: c00ce414 c00ce350 00000001 c3c73000 c3c2fe88 ffffff9c c3c2ff04 c3c2fe88
fe80: c00cedfc c00ce3f4 c4717380 c40bb480 00000000 c3c53480 00000200 c4717380
fea0: c40b2180 00000001 00000001 00000000 c0084e64 c01ce104 c3c2fefc c3c2fec8
fec0: c035a40c c0084e60 00000000 c3c2ff74 c3c2fef4 c04723a0 c0472410 00000007
fee0: c3c2ffb0 bed45bd8 c3c2ff40 c3c2ff08 000000c3 c0042fa8 c3c2ff2c c3c2ff08
ff00: c00c7214 c00ceda8 00000000 00000073 400dc000 bed45bd8 c3c2ff40 000a1917
ff20: c3c2ff3c c3c2ff30 c00c733c c00c71ec c3c2ffa4 c3c2ff40 c00c7360 c00c7328
ff40: c3c2ff5c c3c2ff50 c0084e50 c01cdfc4 c3c2ffa4 c3c2ff60 c00b7544 c0084e4c
ff60: 08100871 c01cdfc4 c3c2ffa4 00000001 c00b6f78 c3c0bcb8 00000022 40044000
ff80: 400442c8 ffffffff 0000007d ffffffff bed45bd8 bed45f14 00000000 c3c2ffa8
ffa0: c0042e00 c00c734c bed45bd8 bed45f14 bed45f14 bed45bd8 bed45bd8 c0000001
ffc0: bed45bd8 bed45f14 000a1917 000000c3 bed45e18 bed45f14 00000000 bed45bd8
ffe0: 4027e700 bed45b58 0006b9d0 4027e714 60000010 bed45f14 ffffffff fffff7ff
Backtrace:
[<c016f238>] (jffs2_kill_fragtree+0x0/0xc4) from [<c01711b0>] (jffs2_do_clear_inode+0x8c/0x108)
r5:c40c2d20 r4:00000000
[<c0171124>] (jffs2_do_clear_inode+0x0/0x108) from [<c0179adc>] (jffs2_evict_inode+0x3c/0x40)
r7:c40c2d20 r6:fffffffb r5:c471b200 r4:c40c2d48
[<c0179aa0>] (jffs2_evict_inode+0x0/0x40) from [<c00d5e54>] (evict+0x28/0x9c)
r5:c471b000 r4:c40c2d48
[<c00d5e2c>] (evict+0x0/0x9c) from [<c00d6830>] (iput+0x1dc/0x220)
[<c00d6654>] (iput+0x0/0x220) from [<c00d7aa8>] (iget_failed+0x24/0x28)
r5:00001962 r4:c40c2d48
[<c00d7a84>] (iget_failed+0x0/0x28) from [<c01794c0>] (jffs2_iget+0x8c/0x320)
[<c0179434>] (jffs2_iget+0x0/0x320) from [<c016e3d8>] (jffs2_lookup+0xcc/0x100)
[<c016e30c>] (jffs2_lookup+0x0/0x100) from [<c00cc030>] (d_alloc_and_lookup+0x4c/0x68)
[<c00cbfe4>] (d_alloc_and_lookup+0x0/0x68) from [<c00cc10c>] (do_lookup+0xc0/0x134)
r7:c3c2fe88 r6:c40bd9d0 r5:c40bb480 r4:00000000
[<c00cc04c>] (do_lookup+0x0/0x134) from [<c00cde58>] (link_path_walk+0x5f8/0xa4c)
[<c00cd860>] (link_path_walk+0x0/0xa4c) from [<c00ce394>] (path_walk+0x50/0xa4)
[<c00ce344>] (path_walk+0x0/0xa4) from [<c00ce414>] (do_path_lookup+0x2c/0x54)
[<c00ce3e8>] (do_path_lookup+0x0/0x54) from [<c00cedfc>] (user_path_at+0x60/0x94)
r7:ffffff9c r6:c3c2fe88 r5:c3c73000 r4:00000001
[<c00ced9c>] (user_path_at+0x0/0x94) from [<c00c7214>] (vfs_fstatat+0x34/0x64)
r8:c0042fa8 r7:000000c3 r6:c3c2ff08 r5:c3c2ff40 r4:bed45bd8
[<c00c71e0>] (vfs_fstatat+0x0/0x64) from [<c00c733c>] (vfs_stat+0x20/0x24)
r6:000a1917 r5:c3c2ff40 r4:bed45bd8
[<c00c731c>] (vfs_stat+0x0/0x24) from [<c00c7360>] (sys_stat64+0x20/0x3c)
[<c00c7340>] (sys_stat64+0x0/0x3c) from [<c0042e00>] (ret_fast_syscall+0x0/0x30)
r5:bed45f14 r4:bed45bd8
Code: e3500000 11a04000 1a000025 e89da830 (e5943008)
---[ end trace 00b6094edf825aa6 ]---
Segmentation fault
Unable to handle kernel NULL pointer dereference at virtual address 00000001
pgd = c4788000
[00000001] *pgd=84759031, *pte=00000000, *ppte=00000000
Internal error: Oops: 17 [#2]
last sysfs file:
Modules linked in:
CPU: 0 Tainted: G D (2.6.37_DM8127_IPNC_3.00.00 #1)
PC is at kmem_cache_alloc+0x34/0x84
LR is at anon_vma_clone+0x28/0x78
pc : [<c00c0630>] lr : [<c00b9524>] psr: 20000093
sp : c3c3be28 ip : c05880cc fp : c3c3be4c
r10: c3c0b9c0 r9 : c04abba8 r8 : c3c53600
r7 : 000000d0 r6 : c4404480 r5 : 80000013 r4 : 00000001
r3 : 00000000 r2 : 00000000 r1 : 000000d0 r0 : c4404480
Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user
Control: 10c5387d Table: 84788019 DAC: 00000015
Process rc (pid: 44, stack limit = 0xc3c3a2e8)
Stack: (0xc3c3be28 to 0xc3c3c000)
be20: c3c0b478 c3c53600 c3c0ce70 c3c0bb58 c3c0b5b8 c3c0b580
be40: c3c3be6c c3c3be50 c00b9524 c00c0608 c3c0bb58 c3c0bb58 c3c0b580 c3c0b580
be60: c3c3be94 c3c3be70 c00b959c c00b9508 c3c0bb58 c3c53480 c3c0b580 00000023
be80: c3c53600 c04abba8 c3c3bedc c3c3be98 c0067afc c00b9580 c4718788 c3c0b9bc
bea0: c3c0b9ac c3c534b4 c3c53634 c3c0b9a0 c46449d8 c45d5d40 c04abba8 00000000
bec0: c46449d0 c4644840 c3c3a000 01200011 c3c3bf2c c3c3bee0 c0068388 c0067968
bee0: 00001000 00000000 00000000 c3c3bfb0 bec23448 c4644930 c3c3bf50 00000000
bf00: c3c3bf68 40283048 01200011 00000000 00000000 bec23448 00000000 00000000
bf20: c3c3bf8c c3c3bf30 c0068aec c0067d64 40283048 00000000 00000000 00000000
bf40: c3c3bfa4 c3c3bf50 c006c400 c007d6a4 00000003 00000005 00000000 00000000
bf60: bec2349c 40283048 0000002c bec23448 00000078 c0042fa8 c3c3a000 00000000
bf80: c3c3bfa4 c3c3bf90 c0046714 c0068998 00000000 40283048 00000000 c3c3bfa8
bfa0: c0042e00 c00466ec 40283048 c3c3bfb0 01200011 00000000 00000000 00000000
bfc0: 40283048 0000002c bec23448 00000078 4027f000 40283000 00000000 bec2347c
bfe0: 402834a0 bec23448 00000000 401e9ff8 60000010 01200011 ffffffff ffffffff
Backtrace:
[<c00c05fc>] (kmem_cache_alloc+0x0/0x84) from [<c00b9524>] (anon_vma_clone+0x28/0x78)
r7:c3c0b580 r6:c3c0b5b8 r5:c3c0bb58 r4:c3c0ce70
[<c00b94fc>] (anon_vma_clone+0x0/0x78) from [<c00b959c>] (anon_vma_fork+0x28/0xa0)
r7:c3c0b580 r6:c3c0b580 r5:c3c0bb58 r4:c3c0bb58
[<c00b9574>] (anon_vma_fork+0x0/0xa0) from [<c0067afc>] (dup_mm+0x1a0/0x3b4)
r9:c04abba8 r8:c3c53600 r7:00000023 r6:c3c0b580 r5:c3c53480
r4:c3c0bb58
[<c006795c>] (dup_mm+0x0/0x3b4) from [<c0068388>] (copy_process+0x630/0xc34)
[<c0067d58>] (copy_process+0x0/0xc34) from [<c0068aec>] (do_fork+0x160/0x328)
[<c006898c>] (do_fork+0x0/0x328) from [<c0046714>] (sys_clone+0x34/0x3c)
[<c00466e0>] (sys_clone+0x0/0x3c) from [<c0042e00>] (ret_fast_syscall+0x0/0x30)
Code: e590c000 e59c4000 e3540000 15903010 (17943003)
---[ end trace 00b6094edf825aa7 ]---
pgd = c0004000
[00000001] *pgd=00000000
Internal error: Oops: 17 [#3]
last sysfs file:
Modules linked in:
LR is at jffs2_alloc_node_frag+0x1c/0x24
pc : [<c00c0630>] lr : [<c016fbbc>] psr: 20000193
sp : c3c25c98 ip : c05880cc fp : c3c25cbc
r10: c47e09c0 r9 : c471b200 r8 : c47c1400
r7 : 000000d0 r6 : c4404480 r5 : 20000113 r4 : 00000001
r3 : 00000000 r2 : 00000009 r1 : 000000d0 r0 : c4404480
Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 10c5387d Table: 84788019 DAC: 00000017
Process jffs2_gcd_mtd4 (pid: 86, stack limit = 0xc3c242e8)
Stack: (0xc3c25c98 to 0xc3c26000)
5c80: 00000000 00000000
5ca0: c460d140 00000000 00000009 c47e09c0 c3c25ccc c3c25cc0 c016fbbc c00c0608
5cc0: c3c25cec c3c25cd0 c016f484 c016fbac c460d140 00000001 00000000 00000000
5ce0: c3c25d1c c3c25cf0 c016f4f8 c016f474 c47498d0 c460d140 00000001 00000000
5d00: 00000000 00000000 c471b200 c3c25db4 c3c25dac c3c25d20 c0172914 c016f4d4
5d20: 0000050c c3c25d78 c3c70000 0000002a c47c1400 c3c70044 c3c70028 c3c24000
5d40: 0000050c 00000000 00000000 00069af4 0000ffff 00000000 00000000 00000001
5d60: 00000000 00000000 00000000 c47498d0 00000000 c3c25d80 0000050c c47c1400
5d80: c3c25dac c47c1400 c474a318 c471b200 c0178eb0 00000000 c471b200 00000000
5da0: c3c25e14 c3c25db0 c01731cc c01716f8 c3c25de4 e0021985 00000000 60000113
5dc0: c3c24000 c471b200 c0178eb0 00000000 c471b200 00000000 c3c25e04 c3c25de8
5de0: c0064970 c00648dc 00000000 00000000 00000022 00000140 c3c25e18 c474a318
5e00: c3c24000 c471b200 c3c25f1c c3c25e18 c017673c c017316c c0487a48 00000001
5e20: c4645370 00000000 c4644000 c4644000 00000000 00000000 c471b22c 00000000
5e40: c3c25e74 c3c25e50 c035a58c c003e1c4 c3c3601c c4644000 00000015 c4644840
5e60: c3c24000 00000000 c3c25e8c c3c25e78 c035a5ec c035a564 00000000 c3c25e88
5e80: c3c25ea4 c3c25e90 c035a614 c035a5dc c3c53a80 c4644000 c3c25ecc c3c25ea8
5ea0: c0356d24 c0066e38 ffff8e14 00000005 ffff8e0f c0178eb0 00000000 ffff8e14
5ec0: c3c25f0c c3c25ed0 c035702c c0073638 00000000 00200200 ffff8e14 c04cc740
5ee0: c0073efc c3c24000 c3c25f0c c3c25ef8 c007475c 40000013 c3c24000 c471b200
5f00: c0178eb0 00000000 00000000 00000000 c3c25fbc c3c25f20 c0178fdc c01765f0
5f20: 00000001 00000000 00000080 00000000 00000000 000000ff 00000000 00000001
5f40: c3c0601c c4644000 00000015 c4645340 c3c24000 00000000 c3c25f7c c3c25f68
5f60: c035a5ec c035a564 00000000 c3c25f78 c3c25f94 c3c25f80 c035a614 c035a5dc
5f80: c3c53780 c4644000 c3c25fbc c3c25f98 c0356d24 c0066e38 c3c25fcc c3c07e70
5fa0: c471b200 c3c25fcc c3c07e70 c471b200 c3c25ff4 c3c25fc0 c00806a8 c0178ebc
5fc0: c3c07e70 00000000 c471b200 00000000 c3c25fd0 c3c25fd0 c3c07e70 c008061c
5fe0: c006c550 00000013 00000000 c3c25ff8 c006c550 c0080628 ffffffff ffffffff
Backtrace:
[<c00c05fc>] (kmem_cache_alloc+0x0/0x84) from [<c016fbbc>] (jffs2_alloc_node_frag+0x1c/0x24)
r7:c47e09c0 r6:00000009 r5:00000000 r4:c460d140
[<c016fba0>] (jffs2_alloc_node_frag+0x0/0x24) from [<c016f484>] (new_fragment+0x1c/0x60)
[<c016f468>] (new_fragment+0x0/0x60) from [<c016f4f8>] (jffs2_add_full_dnode_to_inode+0x30/0x3f8)
r7:00000000 r6:00000000 r5:00000001 r4:c460d140
[<c016f4c8>] (jffs2_add_full_dnode_to_inode+0x0/0x3f8) from [<c0172914>] (jffs2_do_read_inode_internal+0x1228/0x1a74)
[<c01716ec>] (jffs2_do_read_inode_internal+0x0/0x1a74) from [<c01731cc>] (jffs2_do_crccheck_inode+0x6c/0xa8)
[<c0173160>] (jffs2_do_crccheck_inode+0x0/0xa8) from [<c017673c>] (jffs2_garbage_collect_pass+0x158/0x1618)
r6:c471b200 r5:c3c24000 r4:c474a318
[<c01765e4>] (jffs2_garbage_collect_pass+0x0/0x1618) from [<c0178fdc>] (jffs2_garbage_collect_thread+0x12c/0x150)
[<c0178eb0>] (jffs2_garbage_collect_thread+0x0/0x150) from [<c00806a8>] (kthread+0x8c/0x94)
r6:c471b200 r5:c3c07e70 r4:c3c25fcc
[<c008061c>] (kthread+0x0/0x94) from [<c006c550>] (do_exit+0x0/0x5e4)
r7:00000013 r6:c006c550 r5:c008061c r4:c3c07e70
---[ end trace 00b6094edf825aa8 ]---
kernel BUG at mm/mmap.c:2270!
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = c0004000
[00000000] *pgd=00000000
Internal error: Oops: 817 [#4]
last sysfs file:
Modules linked in:
PC is at __bug+0x20/0x2c
LR is at release_console_sem+0x198/0x1ac
pc : [<c004691c>] lr : [<c0069c64>] psr: 60000113
sp : c3c2fdd0 ip : c3c2fd08 fp : c3c2fddc
r10: c4780544 r9 : c3c2ffb0 r8 : c45d5200
r7 : c3c53a80 r6 : c3c53a80 r5 : 00000000 r4 : c3c53a74
r3 : 00000000 r2 : c0487fb0 r1 : 00008ac3 r0 : 00000024
Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Control: 10c5387d Table: 8478c019 DAC: 00000015
Process rc (pid: 94, stack limit = 0xc3c2e2e8)
Stack: (0xc3c2fdd0 to 0xc3c30000)
fdc0: c3c2fe14 c3c2fde0 c00b50f8 c0046908
fde0: c00862f4 c009b1e8 00000000 c3c2fdf8 c3c53a80 00000000 c3c53a80 c3c53ab4
fe00: c45d5200 c4780544 c3c2fe2c c3c2fe18 c0067654 c00b4f7c 00000000 c4644b00
fe20: c3c2fe54 c3c2fe30 c006b074 c0067624 0000000b c3c2fee0 0000000b c3c2fee0
fe40: c4644b00 c3c2ff60 c3c2fe7c c3c2fe58 c006c710 c006af40 c3c2fe9c 00000001
fe60: c035a494 c0049500 00000001 0000000b c3c2fe94 c3c2fe80 c006cbb8 c006c55c
fe80: 0000000b c3c2fee0 c3c2fec4 c3c2fe98 c0077c48 c006cb40 00000000 00000000
fea0: c3c2ffb0 bec224e0 00000078 00000000 c3c2e000 00000001 c3c2ffac c3c2fec8
fec0: c0045a24 c0077980 00030002 c3c2ffb0 c3c2fef4 00000001 c0472410 00000007
fee0: 0000000b 00000000 00030002 401e9ff8 c4644b00 c3c53a80 c3c53ab4 00000817
ff20: c3c2ff3c c3c2ff30 c00c733c ffffffff c3c2ff84 00000000 00000000 00000000
ff40: c3c2ffac c3c2ff50 c035846c c0038274 40283048 c04895cc 0000005e c4644b00
ff60: c3c2e000 00000000 00000000 00000000 00000000 00000000 00000000 c3c2ffac
ff80: c3c2ff80 ffffffff 0000002c bec224e0 00000078 00000000 c3c2e000 00000001
ffa0: 00000000 c3c2ffb0 c0042e58 c00459b4 00000000 00000000 00000000 00000000
ffc0: 40283048 0000002c bec224e0 00000078 4027f000 40283000 00000001 bec22514
ffe0: 402834a0 bec224e0 00000000 401e9ff8 60000010 ffffffff ffffffff fffff7ff
Backtrace:
[<c00468fc>] (__bug+0x0/0x2c) from [<c00b50f8>] (exit_mmap+0x188/0x1a0)
[<c00b4f70>] (exit_mmap+0x0/0x1a0) from [<c0067654>] (mmput+0x3c/0xbc)
[<c0067618>] (mmput+0x0/0xbc) from [<c006b074>] (exit_mm+0x140/0x14c)
r5:c4644b00 r4:00000000
[<c006af34>] (exit_mm+0x0/0x14c) from [<c006c710>] (do_exit+0x1c0/0x5e4)
r7:c3c2ff60 r6:c4644b00 r5:c3c2fee0 r4:0000000b
[<c006c550>] (do_exit+0x0/0x5e4) from [<c006cbb8>] (do_group_exit+0x84/0xb4)
[<c006cb34>] (do_group_exit+0x0/0xb4) from [<c0077c48>] (get_signal_to_deliver+0x2d4/0x304)
[<c0077974>] (get_signal_to_deliver+0x0/0x304) from [<c0045a24>] (do_notify_resume+0x7c/0x654)
[<c00459a8>] (do_notify_resume+0x0/0x654) from [<c0042e58>] (work_pending+0x24/0x28)
Code: e1a01000 e59f000c eb0c3f33 e3a03000 (e5833000)
---[ end trace 00b6094edf825aa9 ]---
Fixing recursive fault but reboot is needed!
