wvdial cross compilation issue
I am trying to cross compile wvdial with arm-none-linux on ubuntu linux 11.04. its giving below msg at the time of giving make command and make install command.
MSG:
raghava@raghava-HCL-Notebook:~/CodeSourcery/Sourcery_G++_Lite/wvdial-1.61$ make
* Generating CC
mv: try to overwrite `CC', overriding mode 0755 (rwxr-xr-x)?
* Generating CXX
mv: try to overwrite `CXX', overriding mode 0755 (rwxr-xr-x)?
./CXX -c wvdialer
linking wvdial.a...
ar: creating wvdial.a
./CXX -c wvdial
linking wvdial...
./CXX -c wvdialconf
linking wvdialconf...
linking pppmon...
linking papchaptest...
and
raghava@raghava-HCL-Notebook:~/CodeSourcery/Sourcery_G++_Lite/wvdial-1.61$ make install
* Generating CC
* Generating CXX
[ -d /usr/local/bin ] || install -d /usr/local/bin
[ -d /etc/ppp/peers ] || install -d /etc/ppp/peers
install -m 0755 wvdial wvdialconf /usr/local/bin
install: cannot remove `/usr/local/bin/wvdial': Permission denied
install: cannot remove `/usr/local/bin/wvdialconf': Permission denied
make: *** [install-bin] Error 1
pls help.
rgds
raghava
    You try install wvdial in your system, you must have root access for this.
    Because you use cross-compile I think you build programm for another system. What prefix you set on configure step? Plese post here your configure line.
  • HI,
    here i am pasting the given configure step, and i am given sudo make install for root permission, then i am getting below error.
    raghava@raghava-HCL-Notebook:~/CodeSourcery/Sourcery_G++_Lite/wvdial-1.61$ ./configure --prefix=/home/workspace CC=arm-none-linux-gnueabi-gcc --host=arm-linux
    * Generating CC
    * Generating CXX
    ./CXX -c wvdialer
    linking wvdial.a...
    ./CXX -c wvdial
    linking wvdial...
    ./CXX -c wvdialconf
    linking pppmon...
    raghava@raghava-HCL-Notebook:~/CodeSourcery/Sourcery_G++_Lite/wvdial-1.61$ sudo make install
    [sudo] password for raghava:
    * Generating CC
    * Generating CXX
    cp ppp.provider /etc/ppp/peers/wvdial
    cp ppp.provider-pipe /etc/ppp/peers/wvdial-pipe
    [ -d /usr/local/share/man/man1 ] || install -d /usr/local/share/man/man1
    [ -d /usr/local/share/man/man5 ] || install -d /usr/local/share/man/man5
    install -m 0644 wvdial.1 wvdialconf.1 /usr/local/share/man/man1
    install -m 0644 wvdial.conf.5 /usr/local/share/man/man5
    pls help
    Rgds,
    raghava
  • Please attache config.log
    P.S. You can use ppp for VPN, wvdial is a wrapper for ppp.
