in another thread I came across the phrase " This can be done using the Linux usermode I2C utilities. "
where might I find these ?
I usually cobble together just enough code to satisfy my project requirements. The Linux kernel itself has a file called dev-interface that decribes the userspace interface as accessed from C code. The online version:
http://www.kernel.org/doc/Documentation/i2c/dev-interface
I think the I2C utilities noted by most references is here:
http://www.lm-sensors.org/wiki/I2CTools
It's a set of command line utilities. It is much more generic and quite a bit more complicated.
Check out i2c-tools, from http://www.lm-sensors.org/wiki/I2CTools, downloads at http://dl.lm-sensors.org/i2c-tools/releases/. In particular, the "i2cget" and "i2cset" programs. Of course, they only work if some kernel module doesn't already have the I2C bus blocked off.
It's a standard in buildroot, and perhaps it's in Arago too, if you are into that kind of thing. Otherwise I'm sure it can be cross-compiled by passing the correct variables to make.
