Hi all,
I am working on sobel 3x3 kernel (picked up from TI's IMGLIB) and I wanted to use DMAs since my data was stored in DDR3. To start off I tried building the sample edma3 lld project at /opt/ti/edma3_lld_02_11_05_02/examples/edma3_driver/evm6678/sample_app/ and I get the following errors when I build it:
undefined first referenced
symbol in file
ti_sysbios_BIOS_start__E ./main.obj
ti_sysbios_family_c64p_EventCombiner_disableEvent__E /opt/ti/edma3_lld_02_11_05_02/packages/ti/sdo/edma3/drv/sample/lib/c6678-evm/66/debug/edma3_lld_drv_sample.ae66<sample_cs.oe66>
ti_sysbios_family_c64p_EventCombiner_dispatchPlug__E /opt/ti/edma3_lld_02_11_05_02/packages/ti/sdo/edma3/drv/sample/lib/c6678-evm/66/debug/edma3_lld_drv_sample.ae66<sample_c6678_int_reg.oe66>
ti_sysbios_family_c64p_EventCombiner_enableEvent__E /opt/ti/edma3_lld_02_11_05_02/packages/ti/sdo/edma3/drv/sample/lib/c6678-evm/66/debug/edma3_lld_drv_sample.ae66<sample_cs.oe66>
ti_sysbios_family_c64p_Hwi_enableInterrupt__E /opt/ti/edma3_lld_02_11_05_02/packages/ti/sdo/edma3/drv/sample/lib/c6678-evm/66/debug/edma3_lld_drv_sample.ae66<sample_c6678_int_reg.oe66>
ti_sysbios_family_c66_tci66xx_CpIntc_disableHostInt__E /opt/ti/edma3_lld_02_11_05_02/packages/ti/sdo/edma3/drv/sample/lib/c6678-evm/66/debug/edma3_lld_drv_sample.ae66<sample_c6678_int_reg.oe66>
ti_sysbios_family_c66_tci66xx_CpIntc_dispatchPlug__E /opt/ti/edma3_lld_02_11_05_02/packages/ti/sdo/edma3/drv/sample/lib/c6678-evm/66/debug/edma3_lld_drv_sample.ae66<sample_c6678_int_reg.oe66>
ti_sysbios_family_c66_tci66xx_CpIntc_dispatch__E /opt/ti/edma3_lld_02_11_05_02/packages/ti/sdo/edma3/drv/sample/lib/c6678-evm/66/debug/edma3_lld_drv_sample.ae66<sample_c6678_int_reg.oe66>
ti_sysbios_family_c66_tci66xx_CpIntc_enableAllHostInts__E /opt/ti/edma3_lld_02_11_05_02/packages/ti/sdo/edma3/drv/sample/lib/c6678-evm/66/debug/edma3_lld_drv_sample.ae66<sample_c6678_int_reg.oe66>
ti_sysbios_family_c66_tci66xx_CpIntc_enableHostInt__E /opt/ti/edma3_lld_02_11_05_02/packages/ti/sdo/edma3/drv/sample/lib/c6678-evm/66/debug/edma3_lld_drv_sample.ae66<sample_c6678_int_reg.oe66>
ti_sysbios_family_c66_tci66xx_CpIntc_getEventId__E /opt/ti/edma3_lld_02_11_05_02/packages/ti/sdo/edma3/drv/sample/lib/c6678-evm/66/debug/edma3_lld_drv_sample.ae66<sample_c6678_int_reg.oe66>
ti_sysbios_family_c66_tci66xx_CpIntc_mapSysIntToHostInt__E /opt/ti/edma3_lld_02_11_05_02/packages/ti/sdo/edma3/drv/sample/lib/c6678-evm/66/debug/edma3_lld_drv_sample.ae66<sample_c6678_int_reg.oe66>
ti_sysbios_hal_Cache_inv__E /opt/ti/edma3_lld_02_11_05_02/packages/ti/sdo/edma3/drv/sample/lib/c6678-evm/66/debug/edma3_lld_drv_sample.ae66<sample_cs.oe66>
ti_sysbios_hal_Cache_wb__E /opt/ti/edma3_lld_02_11_05_02/packages/ti/sdo/edma3/drv/sample/lib/c6678-evm/66/debug/edma3_lld_drv_sample.ae66<sample_cs.oe66>
>> Compilation failure
ti_sysbios_knl_Semaphore_Object__create__S /opt/ti/edma3_lld_02_11_05_02/packages/ti/sdo/edma3/drv/sample/lib/c6678-evm/66/debug/edma3_lld_drv_sample.ae66<sample_cs.oe66>
ti_sysbios_knl_Semaphore_Object__delete__S /opt/ti/edma3_lld_02_11_05_02/packages/ti/sdo/edma3/drv/sample/lib/c6678-evm/66/debug/edma3_lld_drv_sample.ae66<sample_cs.oe66>
ti_sysbios_knl_Semaphore_Params__init__S /opt/ti/edma3_lld_02_11_05_02/packages/ti/sdo/edma3/drv/sample/lib/c6678-evm/66/debug/edma3_lld_drv_sample.ae66<sample_init.oe66>
ti_sysbios_knl_Semaphore_pend__E /opt/ti/edma3_lld_02_11_05_02/packages/ti/sdo/edma3/drv/sample/lib/c6678-evm/66/debug/edma3_lld_drv_sample.ae66<sample_cs.oe66>
ti_sysbios_knl_Semaphore_post__E /opt/ti/edma3_lld_02_11_05_02/packages/ti/sdo/edma3/drv/sample/lib/c6678-evm/66/debug/edma3_lld_drv_sample.ae66<sample_cs.oe66>
ti_sysbios_knl_Task_Object__create__S ./main.obj
ti_sysbios_knl_Task_disable__E /opt/ti/edma3_lld_02_11_05_02/packages/ti/sdo/edma3/drv/sample/lib/c6678-evm/66/debug/edma3_lld_drv_sample.ae66<sample_cs.oe66>
ti_sysbios_knl_Task_enable__E /opt/ti/edma3_lld_02_11_05_02/packages/ti/sdo/edma3/drv/sample/lib/c6678-evm/66/debug/edma3_lld_drv_sample.ae66<sample_cs.oe66>
error: unresolved symbols remain
error: errors encountered during linking; "edma3_drv_bios6_c6678_st_sample.out"
not built
gmake: *** [edma3_drv_bios6_c6678_st_sample.out] Error 1
gmake: Target `all' not remade because of errors.
**** Build Finished ****
I am a newbie to TI DSPs, all I can guess at the moment is I am missing few ti_sysbios libraries in my build. I would really appreciate your help in building the sample project successfully which should get me started on DMAs.
Please correct me if you feel that my approach for my problem is incorrect.
Thank you in advance
regards,
Barath Ramesh
