Other Parts Discussed in Thread: TWL6030
Hello All,
I am working with a custom OMAP4460 based platform using the TWL6030 PMIC chip.
The PMIC has a primary watchdog timer which times out every 32 seconds (by default). It can also be programmed with a time out up to 127 seconds by loading a suitable value in PRIMARY_WATCHDOG_CFG. This Primary WDT cannot be disabled.
I am programming the PRIMARY_WATCHDOG_CFG register of PMIC to set the timeout at 127 seconds. The documentation for the TWL6030 that I have says that programming this register will automatically restart the WDT. However, inpsite of having programmed the time out to 127 seconds, I am seeing that the board powers off (PMIC cuts off power to OMAP) after 32 seconds.
- Has anyone worked with the PMIC with the primary WDT?
- How can I ensure that the WDT restarts itself without cutting off power to OMAP or sending a reset to OMAP?
Any pointers on this issue will be very helpful.
Thank you for your time.
Warm regards,
Sanjay
