Porting JB on Panboard and related issues
     We are trying to port Jelly bean on Panda board. We tried with linux mainline kernel 3.4.4. In panda, JB is successfully booted and We got the console.But we are getting few errors.
Logcat :
D/AndroidRuntime( 1185):
D/AndroidRuntime( 1185): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<<<<
D/AndroidRuntime( 1185): CheckJNI is ON
I/AudioFlinger( 1136): loadHwModule() Loaded a2dp audio interface from A2DP Audio HW HAL (audio) handle 1
E/AudioPolicyManagerBase( 1136): Not output found for attached devices 00000003
E/AudioPolicyManagerBase( 1136): Failed to open primary output
E/AudioPolicyManagerBase( 1136): getDeviceForStrategy() speaker device not found for STRATEGY_SONIFICATION
E/AudioPolicyService( 1136): couldn't init_check the audio policy (No such device)
E/dalvikvm( 1185): Could not stat dex cache directory '/data/dalvik-cache': No such file or directory
I/dalvikvm( 1185): Unable to open or create cache for /system/framework/core.jar (/data/dalvik-cache/system@framework@core.jar@classes.dex)
D/dalvikvm( 1185): Unable to process classpath element '/system/framework/core.jar'
I/dalvikvm( 1185): Unable to open or create cache for /system/framework/core-junit.jar (/data/dalvik-cache/system@framework@core-junit.jar@classes.dex)
D/dalvikvm( 1185): Unable to process classpath element '/system/framework/core-junit.jar'
I/dalvikvm( 1185): Unable to open or create cache for /system/framework/bouncycastle.jar (/data/dalvik-cache/system@framework@bouncycastle.jar@classes.dex)
D/dalvikvm( 1185): Unable to process classpath element '/system/framework/bouncycastle.jar'
I/dalvikvm( 1185): Unable to open or create cache for /system/framework/ext.jar (/data/dalvik-cache/system@framework@ext.jar@classes.dex)
D/dalvikvm( 1185): Unable to process classpath element '/system/framework/ext.jar'
I/dalvikvm( 1185): Unable to open or create cache for /system/framework/framework.jar (/data/dalvik-cache/system@framework@framework.jar@classes.dex)
D/dalvikvm( 1185): Unable to process classpath element '/system/framework/framework.jar'
I/dalvikvm( 1185): Unable to open or create cache for /system/framework/android.policy.jar (/data/dalvik-cache/system@framework@android.policy.jar@classes.dex)
D/dalvikvm( 1185): Unable to process classpath element '/system/framework/android.policy.jar'
I/dalvikvm( 1185): Unable to open or create cache for /system/framework/services.jar (/data/dalvik-cache/system@framework@services.jar@classes.dex)
D/dalvikvm( 1185): Unable to process classpath element '/system/framework/services.jar'
I/dalvikvm( 1185): Unable to open or create cache for /system/framework/apache-xml.jar (/data/dalvik-cache/system@framework@apache-xml.jar@classes.dex)
D/dalvikvm( 1185): Unable to process classpath element '/system/framework/apache-xml.jar'
E/dalvikvm( 1185): No valid entries found in bootclasspath '/system/framework/core.jar:/system/framework/core-junit.jar:/system/framework/bouncycastle.jar:/system/framework/ext.jar:/system/framework/framewor'
E/dalvikvm( 1185): VM aborting
We are getting above red marked errors.Can anyone help us to resolve.
Thanks in advance
Bhimesh
