My linux boot for dm37xx get hangs after "File /home/david/hd-codec/xm_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/sdma/src/module/sdmak.c" message.
Boot use to work before i did make clean, make components, make all, it looks like these commands have changed my config files.
does any body know which part of the code runs after "File /home/david/hd-codec/xm_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/sdma/src/module/sdmak.c" this message, so that i can put some debug.
i have attached my boot log.
Texas Instruments X-Loader 1.4.4ss (Aug 9 2012 - 14:25:51)
Beagle xM Rev A
Memory Config [Micron DDR 256MB 200Mhz]
MMC Regs: MMC1 MMC2 MMC3
SysConfig: 00000015 00000015 deaddead
SysStatus: 00000001 00000001 deaddead
CSRE : 00000000 00000000 deaddead
SysTest : 00000000 00000000 deaddead
Con : 00000000 00000600 deaddead
Pwcnt : 00000000 00000000 deaddead
Blk : 00000200 00000000 deaddead
Arg : 000ada00 00000000 deaddead
Cmd : 113a0010 00000000 deaddead
RSP10 : 00000900 00000000 deaddead
RSP32 : f6dbff9f 00000000 deaddead
RSP54 : 5b5a83c7 00000000 deaddead
RSP76 : 00260132 00000000 deaddead
DATA : 00000000 00000000 deaddead
PSTATE : 00070000 00070000 deaddead
HCTL : 00000d00 00000000 deaddead
SYSCTL : 000e0207 00000000 deaddead
STAT : 20008000 00000000 deaddead
IE : 307f0033 00000000 deaddead
ISE : 00000000 00000000 deaddead
AC12 : 00000000 00000000 deaddead
CAPA : 02e10080 00e10080 deaddead
CUR_CAPA : 00000000 00000000 deaddead
REV : 26000000 26000000 deaddead
MMC2 Clk feedback mode 0
Pin MMC1 Clk Mux Mode 0 Pullup Enable 1 Pullup Type 1 Input enable 0 off enable 0 off out enable 0 off out value 0
Pin MM1 Cmd Mux Mode 0 Pullup Enable 1 Pullup Type 1 Input enable 1 off enable 0 off out enable 0 off out value 0
Pin MMC1 DA0 Mux Mode 0 Pullup Enable 1 Pullup Type 1 Input enable 1 off enable 0 off out enable 0 off out value 0
Pin MM1 DA1 Mux Mode 0 Pullup Enable 1 Pullup Type 1 Input enable 1 off enable 0 off out enable 0 off out value 0
Pin MMC1 DA2 Mux Mode 0 Pullup Enable 1 Pullup Type 1 Input enable 1 off enable 0 off out enable 0 off out value 0
Pin MM1 DA3 Mux Mode 0 Pullup Enable 1 Pullup Type 1 Input enable 1 off enable 0 off out enable 0 off out value 0
Pin MMC2 Clk Mux Mode 7 Pullup Enable 1 Pullup Type 0 Input enable 1 off enable 0 off out enable 0 off out value 0
Pin MM2 Cmd Mux Mode 7 Pullup Enable 1 Pullup Type 1 Input enable 1 off enable 0 off out enable 0 off out value 0
Pin MMC2 DA0 Mux Mode 7 Pullup Enable 1 Pullup Type 1 Input enable 1 off enable 0 off out enable 0 off out value 0
Pin MM2 DA1 Mux Mode 7 Pullup Enable 1 Pullup Type 1 Input enable 1 off enable 0 off out enable 0 off out value 0
Pin MMC2 DA2 Mux Mode 7 Pullup Enable 1 Pullup Type 1 Input enable 1 off enable 0 off out enable 0 off out value 0
Pin MM2 DA3 Mux Mode 7 Pullup Enable 1 Pullup Type 1 Input enable 1 off enable 0 off out enable 0 off out value 0
Pin MMC2 DA4 Mux Mode 7 Pullup Enable 1 Pullup Type 0 Input enable 1 off enable 0 off out enable 0 off out value 0
Pin MM2 DA5 Mux Mode 7 Pullup Enable 1 Pullup Type 0 Input enable 1 off enable 0 off out enable 0 off out value 0
Pin MMC2 DA6 Mux Mode 7 Pullup Enable 1 Pullup Type 0 Input enable 1 off enable 0 off out enable 0 off out value 0
Pin MM2 DA7 Mux Mode 7 Pullup Enable 1 Pullup Type 0 Input enable 1 off enable 0 off out enable 0 off out value 0
Tracing vector is 00000001 40200dcc
Boot Device from R0 at boot 00000006
Saving Boot Device 6 in Location 40200800 now set to 6
Loading uboot to address 80008000
Non HdCodec Using MMC 1 to load from
mmc_clock_config(unsigned int iclk 0, unsigned short clk_div 0)
mmc_clock_config(unsigned int iclk 1, unsigned short clk_div 0)
MmcClockConfig Err7:1
OCRValue1 :0, OCRRecieved: 0
OCRValue2 :ff8000, OCRRecieved: 0
MmcSendCmd Err1:1
MmcSendCmd Err2:1
MmcSendCmd Err3:1
SD Card Config
MmcSendCmd Err4:1
OCRValue3 :40ff8000, OCRRecieved: ff8000
MmcSendCmd Err5:1
OCRValue4 :40ff8000, OCRRecieved: 80ff8000, Retries: 1999
MmcSendCmd Err6:1
MmcSendCmd Err8:1
mmc_clock_config(unsigned int iclk 2, unsigned short clk_div 8)
Reading boot sector
Loading u-boot.bin from mmc Size: 214988
ea000012 e59ff014 e59ff014 e59ff014 e59ff014 e59ff014 e59ff014 e59ff01480e80140 80e801a0 80e80200 80e80260 80e802c0 80e80320 80e80380 1234567880e80000 80e80000 80eb47cc 80ee5f14 e10f0000 e3c0001f e38000d3 e129f000e24f0068 e2800004 e3a02040 e0802002 e3a01101 e3a03602 e0811003 e3a03b3ee0811003 e8b007f8 e8a107f8 e1500002 1afffffb eb00072c eb000019 e24f00a4e51f1068 e1500001 0a000007 e51f2070 e51f3070 e0432002
CheckSum 605297c7
CheckSum 1c0b8d82
CheckSum edab623f
CheckSum 6d2a25d3
CheckSum 3e2f8b40
CheckSum 04cee9c3
CheckSum b4101d54
CheckSum 4afa82f0
CheckSum 81cf5052
CheckSum 268b5cba
CheckSum 2a360c87
U-Boot 2010.03-00014-gc2d1201-dirty (Aug 09 2012 - 14:15:39)
OMAP3630/3730-GP ES2.1, CPU-OPP2, L3-165MHz,
OMAP3 Beagle board + LPDDR/NAND
I2C: i2c_init Speed 100000 slave 1
ready
DRAM: 256 MB
NAND: NAND: Unable to find NAND settings in GPMC Configuration - quitting
0 MiB
*** Warning - bad CRC or NAND, using default environment
twl4030_usb_ulpi_init()
twl4030_usb_ldo_init()
++++twl4030_usb_ldo_init() Activate LDO
++twl4030_usb_ldo_init() select vbat
++twl4030_usb_ldo_init() 3.1v on
++++twl4030_usb_ldo_init() 1v5 on
++++twl4030_usb_ldo_init() 1v8 on
++++twl4030_usb_ldo_init() disable config mode
++twl4030_usb_ldo_init() Complete
twl4030_phy_power()
+@+!+++@+!+++@+!+++@+!+@+!Select USB on the Go
+++@+!+++++++@+!++In: serial
Out: serial
Err: serial
Boot device 00000006
Overriding beagle board revision to XM and settign HdCodec Flag Clocks Add 48004a00 = 3fffe01
Tracing vector is 00000001 8000a1dc
Probing for expansion boards, if none are connected you'll see a harmless I2C error.
No EEPROM on expansion board
Beagle Revision code 0x00
Suitcase TV HdCodec Rev 1.0
Hd Codec Using MMC 1 to load from
Fixing Memory config for hdcodec
Current Boot args NULL
++++Die ID #178800029e3800000163810d0302b022
BootCmd is [if mmc init ${mmcdev}; then if userbutton; then setenv bootscr user.scr;if run loadbootscript; then run bootscript; else if run loaduimage; then if run loadramdisk; then run ramboot; else run mmcboot; fi; fi; fi; else setenv bootscr boot.scr; if run loadbootscript; then run bootscript; else if run loaduimage; then run mmcboot; else run nandboot; fi; fi; fi; else run nandboot; fi]
Hit any key to stop autoboot: 0
mmc_legacy_init Device 1
mmc_set_dev select device 1
configure_mmc
mmc_init_setup
mmc_board_init
mmc power Init
++++mmc_board_init A
mmc_board_init B
mmc_board_init C
mmc_board_init D
mmc_board_init E
mmc_board_init F
sysconfig for mmc is 4809c010
Detecting Card
mmc_detect_card
Calling it an SD card
mmc_detect_done
mmc1 is available
The user button is currently NOT pressed.
fatload mmc 1 0x80200000 boot.scr
Requested device 1
Fat loading from device 1
Fat load A
Fat load B dev 1 part 1
Fat load C
Fat load D Offset 80200000 Count 0
reading boot.scr
Fat load E result 538
538 bytes read
Running bootscript from mmc ...
## Executing script at 80200000
fatload mmc 0 80200000 hdcodec.rbf
Requested device 0
Fat loading from device 0
Fat load A
Fat load B dev 0 part 1
Fat load C
reading hdcodec.rbf
Fat load E result 199428
199428 bytes read
fatload mmc 0 80300000 wdhd.rbf
Requested device 0
Fat load A
Fat load C
Fat load D Offset 80300000 Count 0
reading wdhd.rbf
Fat load E result 355240
355240 bytes read
HdCodec Mem Address 80200000 WdHd Mem Address 80300000
Fpga serial programming PADCONF mux states
Pin MMC2 DA4 - DCLK Mux Mode 4 Pullup Enable 1 Pullup Type 1 Input enable 1 off enable 0 off out enable 0 off out value 0
Pin MM2 DA5 - DAT0 Mux Mode 4 Pullup Enable 1 Pullup Type 1 Input enable 1 off enable 0 off out enable 0 off out value 0
Pin MMC2 DA6 - nSTATUS Mux Mode 4 Pullup Enable 1 Pullup Type 1 Input enable 1 off enable 0 off out enable 0 off out value 0
Pin MM2 DA7 - CONF_DONE Mux Mode 4 Pullup Enable 1 Pullup Type 1 Input enable 1 off enable 0 off out enable 0 off out value 0
Pin CAM_WEN - nCONFIG Mux Mode 4 Pullup Enable 1 Pullup Type 1 Input enable 1 off enable 0 off out enable 0 off out value 0
Pin CAM_STROBE Mux Mode 4 Pullup Enable 1 Pullup Type 1 Input enable 1 off enable 0 off out enable 0 off out value 0
Programming device is open toggling nCONFIG
nSTATUS 1, CONF_DONE 0
nSTATUS 0, CONF_DONE 0
Bytes Written to HdCodec Fpga 199866 CheckSum 008f7756
Bytes Written to Wdhd Fpga 355678 CheckSum 01785160
Fpgas report prgramming complete
Setting bus to 1
++Fixing Memory config for hdcodec
Current Boot args console=ttyS2,115200n8 root=/dev/mmcblk0p2 rw ip=off mem=55M@0x80000000 mpurate=1000 omap_vout.vid1_static_vrfb_alloc=y omapfb.vram=0:8M mem=384M@0x88000000 omapfb.mode=dvi:hd720 omapdss.def_disp=dvi rootwait vram=8M
Current Boot args console=ttyS2,115200n8 root=/dev/mmcblk0p2 rw ip=off mem=55M@0x80000000 mpurate=1000 omap_vout.vid1_static_vrfb_alloc=y omapfb.vram=0:8M mem=128M@0x88000000 omapfb.mode=dvi:hd720 omapdss.def_disp=dvi rootwait vram=8M
fatload mmc 0 80200000 uImage
Requested device 0
Fat load A
Fat load C
reading uImage
Fat load E result 3158140
3158140 bytes read
## Booting kernel from Legacy Image at 80200000 ...
Image Name: Linux-2.6.32
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3158076 Bytes = 3 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
MemStart 80000000
MemStart 10000000
MemStart 90000000
MemStart 00000000
Starting kernel ...
Uncompressing Linux............................................................................................................................................................................................................. done, booting the kernel.
[ 0.000000] Linux version 2.6.32 (david@Speedy-Ubuntu) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #1 PREEMPT Thu Aug 9 14:04:56 BST 2012
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: OMAP3 Beagle Board
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] OMAP3630/DM3730 ES1.0 (l2cache iva sgx neon isp 192mhz_clk )
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xfe400000 size: 0x100000
[ 0.000000] Reserving 8388608 bytes SDRAM for VRAM
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 46336
[ 0.000000] Kernel command line: console=ttyS2,115200n8 root=/dev/mmcblk0p2 rw ip=off mem=55M@0x80000000 mpurate=1000 omap_vout.vid1_static_vrfb_alloc=y omapfb.vram=0:8M mem=128M@0x88000000 omapfb.mode=dvi:hd720 omapdss.def_disp=dvi rootwait vram=8M
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 55MB 128MB = 183MB total
[ 0.000000] Memory: 170368KB available (5812K code, 676K data, 184K init, 0K highmem)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:402
[ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/332/600 MHz
[ 0.000000] Reprogramming SDRC clock to 332000000 Hz
[ 0.000000] clock: clksel_round_rate_div: dpll3_m2_ck target_rate 332000000
[ 0.000000] GPMC revision 5.0
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] OMAP GPIO hardware version 2.5
[ 0.000000] OMAP clockevent source: GPTIMER12 at 32768 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Calibrating delay loop... 521.97 BogoMIPS (lpj=2035712)
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] tmpfs: No value for mount option 'mode'
[ 0.000000] devtmpfs: initialized
[ 0.000000] Device name [platform]
[ 0.000000] regulator: core version 0.5
[ 0.000000] NET: Registered protocol family 16
[ 0.000000] Beagle Init Code
[ 0.000000] Unable to get DVI reset GPIO
[ 0.000000] omap_init_mbox: platform not supported
[ 0.000000] omap2_mcbsp_init
[ 0.000000] Target VDD1 OPP = 4, VDD2 OPP = 2
[ 0.000000] File:Func= arch/arm/mach-omap2/board-omap3evm-camera.c:omap3evmdc_init
[ 0.000000] File:Func= arch/arm/mach-omap2/board-omap3evm-camera.c:omap3evmdc_mdc_config
[ 0.000000] TVP Configs
[ 0.000000] TVP slave address 5d
[ 0.000000] evm video in regstered tvp stv
[ 0.000000] omap3evmdc: Driver registration complete
[ 18.112152] OMAP DMA hardware revision 5.0
[ 18.118530] bio: create slab <bio-0> at 0
[ 18.119781] SCSI subsystem initialized
[ 18.121093] usbcore: registered new interface driver usbfs
[ 18.121246] usbcore: registered new interface driver hub
[ 18.121398] usbcore: registered new device driver usb
[ 18.121429] RETVAL = 0
[ 18.121643] File:Func= drivers/i2c/busses/i2c-omap.c:omap_i2c_init_driver
[ 18.121704] File:Func= drivers/i2c/busses/i2c-omap.c:omap_i2c_probe
[ 18.121765] File:Func= drivers/i2c/busses/i2c-omap.c:omap_i2c_init
[ 18.121795] i2c_omap i2c_omap.1: bus 1 rev4.0 at 2600 kHz
[ 18.122192] File:Func= drivers/i2c/i2c-core.c:i2c_device_probe
[ 18.122222] client [dummy] registered with bus id 1-0049
[ 18.122222] File:Func= drivers/i2c/i2c-core.c:i2c_new_device
[ 18.122314] File:Func= drivers/i2c/i2c-core.c:i2c_device_probe
[ 18.122344] client [dummy] registered with bus id 1-004a
[ 18.122375] File:Func= drivers/i2c/i2c-core.c:i2c_new_device
[ 18.122467] File:Func= drivers/i2c/i2c-core.c:i2c_device_probe
[ 18.122467] client [dummy] registered with bus id 1-004b
[ 18.122497] File:Func= drivers/i2c/i2c-core.c:i2c_new_device
[ 18.124664] twl4030: PIH (irq 7) chaining IRQs 368..375
[ 18.124725] twl4030: power (irq 373) chaining IRQs 376..383
[ 18.125000] twl4030: gpio (irq 368) chaining IRQs 384..401
[ 18.125305] arch/arm/mach-omap2/mmc-twl4030.c:412 twl4030_mmc_init:
[ 18.125305] arch/arm/mach-omap2/mmc-twl4030.c:423 twl4030_mmc_init: b
[ 18.125335] arch/arm/mach-omap2/mmc-twl4030.c:430 twl4030_mmc_init: b
[ 18.125366] arch/arm/mach-omap2/mmc-twl4030.c:459 twl4030_mmc_init: c
[ 18.125366] arch/arm/mach-omap2/mmc-twl4030.c:479 twl4030_mmc_init: d
[ 18.125396] arch/arm/mach-omap2/mmc-twl4030.c:505 twl4030_mmc_init: e
[ 18.125427] arch/arm/mach-omap2/mmc-twl4030.c:430 twl4030_mmc_init: b
[ 18.125457] arch/arm/mach-omap2/mmc-twl4030.c:459 twl4030_mmc_init: c
[ 18.125457] arch/arm/mach-omap2/mmc-twl4030.c:479 twl4030_mmc_init: d
[ 18.125488] arch/arm/mach-omap2/mmc-twl4030.c:505 twl4030_mmc_init: e
[ 18.125518] arch/arm/mach-omap2/mmc-twl4030.c:538 twl4030_mmc_init: f
[ 18.125701] arch/arm/mach-omap2/mmc-twl4030.c:542 twl4030_mmc_init: g
[ 18.125732] arch/arm/mach-omap2/mmc-twl4030.c:549 twl4030_mmc_init: h
[ 18.125762] arch/arm/mach-omap2/mmc-twl4030.c:556 twl4030_mmc_init: i
[ 18.126953] regulator: VUSB1V5: 1500 mV normal standby
[ 18.127197] regulator: VUSB1V8: 1800 mV normal standby
[ 18.127410] regulator: VUSB3V1: 3100 mV normal standby
[ 18.131042] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[ 18.131439] regulator: VMMC1: 1850 <--> 3150 mV normal standby
[ 18.131683] regulator: VDAC: 1800 mV normal standby
[ 18.131927] regulator: VPLL2: 1800 mV normal standby
[ 18.132171] regulator: VSIM: 1800 <--> 3000 mV normal standby
[ 18.132507] regulator: VAUX3: 1800 mV normal standby
[ 18.132873] regulator: VAUX4: 1800 mV normal standby
[ 18.132934] File:Func= drivers/i2c/i2c-core.c:i2c_device_probe
[ 18.132934] client [twl4030] registered with bus id 1-0048
[ 18.132965] File:Func= drivers/i2c/i2c-core.c:i2c_new_device
[ 18.132995] File:Func= drivers/i2c/busses/i2c-omap.c:omap_i2c_probe
[ 18.142242] File:Func= drivers/i2c/busses/i2c-omap.c:omap_i2c_init
[ 18.142303] i2c_omap i2c_omap.2: bus 2 rev4.0 at 400 kHz
[ 18.142517] client [tvp5146m2] registered with bus id 2-005d
[ 18.142517] File:Func= drivers/i2c/i2c-core.c:i2c_new_device
[ 18.142578] File:Func= drivers/i2c/busses/i2c-omap.c:omap_i2c_probe
[ 18.142608] File:Func= drivers/i2c/busses/i2c-omap.c:omap_i2c_init
[ 18.142669] i2c_omap i2c_omap.3: bus 3 rev4.0 at 100 kHz
[ 18.143859] Switching to clocksource 32k_counter
[ 18.153045] musb_hdrc: version 6.0, musb-dma, otg (peripheral+host), debug=0
[ 18.153320] musb_hdrc: USB OTG mode controller at fa0ab000 using DMA, IRQ 92
[ 18.153350] musb_hdrc musb_hdrc: MUSB HDRC host driver
[ 18.153472] musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
[ 18.153594] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 18.153625] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 18.153656] usb usb1: Product: MUSB HDRC host driver
[ 18.153656] usb usb1: Manufacturer: Linux 2.6.32 musb-hcd
[ 18.153656] usb usb1: SerialNumber: musb_hdrc
[ 18.154296] hub 1-0:1.0: USB hub found
[ 18.154327] hub 1-0:1.0: 1 port detected
[ 18.155426] NET: Registered protocol family 2
[ 18.155639] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 18.156158] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 18.156402] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[ 18.156555] TCP: Hash tables configured (established 8192 bind 8192)
[ 18.156555] TCP reno registered
[ 18.156585] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 18.156616] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 18.156829] NET: Registered protocol family 1
[ 18.157257] RPC: Registered udp transport module.
[ 18.157287] RPC: Registered tcp transport module.
[ 18.157287] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 18.158142] omap-iommu omap-iommu.0: isp registered
[ 18.158294] AM37x/DM37x Linux PSP version 03.00.01.06 (OMAP3EVM)
[ 18.160003] VFS: Disk quotas dquot_6.5.2
[ 18.160095] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 18.161132] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 18.161926] JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 18.162719] msgmni has been set to 333
[ 18.166290] alg: No test for stdrng (krng)
[ 18.166625] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
[ 18.166656] io scheduler noop registered
[ 18.166687] io scheduler deadline registered
[ 18.166809] io scheduler cfq registered (default)
[ 18.222167] OMAP DSS rev 2.0
[ 18.222229] OMAP DISPC rev 3.0
[ 18.222290] OMAP VENC rev 2
[ 18.222534] OMAP DSI rev 1.0
[ 18.559356] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 18.577911] serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654
[ 18.595794] serial8250.1: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654
[ 18.613677] serial8250.2: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654
[ 19.439331] console [ttyS2] enabled
[ 19.449645] brd: module loaded
[ 19.455932] loop: module loaded
[ 19.460357] omap_nand_init()
[ 19.463256] omap2-nand driver initializing
[ 19.467559] omap_nand_init() platform_driver_register 0
[ 19.473571] enc28j60_init
[ 19.476348] usbcore: registered new interface driver catc
[ 19.481811] catc: v2.8:CATC EL1210A NetMate USB Ethernet driver
[ 19.487884] usbcore: registered new interface driver kaweth
[ 19.493469] pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB Ethernet driver
[ 19.501068] usbcore: registered new interface driver pegasus
[ 19.506774] rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet driver
[ 19.513763] usbcore: registered new interface driver rtl8150
[ 19.519531] usbcore: registered new interface driver asix
[ 19.525024] usbcore: registered new interface driver cdc_ether
[ 19.530975] usbcore: registered new interface driver cdc_eem
[ 19.536743] usbcore: registered new interface driver dm9601
[ 19.542449] usbcore: registered new interface driver smsc95xx
[ 19.548278] usbcore: registered new interface driver gl620a
[ 19.553985] usbcore: registered new interface driver net1080
[ 19.559753] usbcore: registered new interface driver plusb
[ 19.565307] usbcore: registered new interface driver rndis_host
[ 19.571380] usbcore: registered new interface driver cdc_subset
[ 19.577423] usbcore: registered new interface driver zaurus
[ 19.583099] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 19.591156] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 19.597961] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 19.603912] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 2
[ 19.611511] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 19.628387] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 19.634277] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 19.641113] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 19.648376] usb usb2: Product: OMAP-EHCI Host Controller
[ 19.653717] usb usb2: Manufacturer: Linux 2.6.32 ehci_hcd
[ 19.659149] usb usb2: SerialNumber: ehci-omap.0
[ 19.664367] hub 2-0:1.0: USB hub found
[ 19.668212] hub 2-0:1.0: 3 ports detected
[ 19.698791] Initializing USB Mass Storage driver...
[ 19.703857] usbcore: registered new interface driver usb-storage
[ 19.709930] USB Mass Storage support registered.
[ 19.714935] mice: PS/2 mouse device common for all mice
[ 19.720550] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 19.728393] input: twl4030_pwrbutton as /devices/platform/i2c_omap.1/i2c-1/1-0049/twl4030_pwrbutton/input/input1
[ 19.739074] i2c /dev entries driver
[ 19.743164] Linux video capture interface: v2.00
[ 19.748107] omap-iommu omap-iommu.0: isp: version 1.1
[ 19.753631] File:Func= drivers/media/video/isp/omap_previewer.c:omap_previewer_init
[ 19.761352] Console Log level 7
[ 19.765380] vpfe_init Davids
[ 19.768859] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 19.775726] drivers/mmc/core/bus.c:212 mmc_register_driver:
[ 19.781616] omap_hsmmc_init()
[ 19.784698] omap_hsmmc_probe()
[ 19.787750] omap_hsmmc_probe(A)
[ 19.790924] omap_hsmmc_probe(B)
[ 19.794158] omap_hsmmc_probe(C)
[ 19.797393] omap_hsmmc_probe(D)
[ 19.800567] omap_hsmmc_probe(E)
[ 19.803710] omap_hsmmc_probe(F)
[ 19.806884] omap_hsmmc_probe(G)
[ 19.811218] omap_hsmmc_probe(H)
[ 19.814392] omap_hsmmc_probe(I)
[ 19.817749] mmc0: clock 0Hz busmode 1 powermode 0 cs 0 Vdd 0 width 0 timing 0
[ 19.933105] omap_hsmmc_probe(K)
[ 19.936248] omap_hsmmc_probe(L)
[ 19.939422] omap_hsmmc_probe()
[ 19.942535] omap_hsmmc_probe(A)
[ 19.945709] omap_hsmmc_probe(B)
[ 19.948913] omap_hsmmc_probe(C)
[ 19.952178] omap_hsmmc_probe(D)
[ 19.955322] omap_hsmmc_probe(E)
[ 19.958496] omap_hsmmc_probe(F)
[ 19.961669] omap_hsmmc_probe(G)
[ 19.964843] mmci-omap-hs mmci-omap-hs.1: err -16 configuring card detect
[ 19.971862] Registered led device: beagleboard::usr0
[ 19.976989] Registered led device: beagleboard::usr1
[ 19.982391] mmc0: clock 0Hz busmode 1 powermode 1 cs 0 Vdd 19 width 0 timing 0
[ 19.990325] Registered led device: beagleboard::pmu_stat
[ 19.997497] usbcore: registered new interface driver usbhid
[ 20.003112] usbhid: USB HID core driver
[ 20.007171] Advanced Linux Sound Architecture Driver Version 1.0.21.
[ 20.014068] usbcore: registered new interface driver snd-usb-audio
[ 20.022033] i2c_omap i2c_omap.1: Arbitration lost
[ 20.042449] File:Func= drivers/i2c/busses/i2c-omap.c:omap_i2c_init
[ 20.048645] twl: i2c_write failed to transfer all messages
[ 20.147705] No device for DAI omap-mcbsp-dai-0
[ 20.152191] No device for DAI omap-mcbsp-dai-1
[ 20.156646] No device for DAI omap-mcbsp-dai-2
[ 20.161132] No device for DAI omap-mcbsp-dai-3
[ 20.165588] No device for DAI omap-mcbsp-dai-4
[ 20.170074] OMAP3 Beagle SoC init
[ 20.174194] asoc: twl4030 <-> omap-mcbsp-dai-0 mapping ok
[ 20.185729] ALSA device list:
[ 20.188720] #0: omap3beagle (twl4030)
[ 20.192687] oprofile: using arm/armv7
[ 20.196594] TCP cubic registered
[ 20.199890] NET: Registered protocol family 17
[ 20.204376] NET: Registered protocol family 15
[ 20.208953] lib80211: common routines for IEEE802.11 drivers
[ 20.214660] ThumbEE CPU extension supported.
[ 20.218963] Power Management for TI OMAP3.
[ 20.223419] mmc0: clock 400000Hz busmode 1 powermode 2 cs 0 Vdd 19 width 0 timing 0
[ 20.232299] clock: clksel_round_rate_div: dpll3_m2_ck target_rate 400000000
[ 20.239288] Unable to set L3 frequency (400000000)
[ 20.244171] Switched to new clocking rate (Crystal/Core/MPU): 26.0/332/1000 MHz
[ 20.251525] IVA2 clocking rate: 800 MHz
[ 20.440979] SmartReflex driver initialized
[ 20.450592] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 20.458801] registered taskstats version 1
[ 20.471008] mmc0: clock 400000Hz busmode 1 powermode 2 cs 1 Vdd 19 width 0 timing 0
[ 20.480926] mmc0: clock 400000Hz busmode 1 powermode 2 cs 0 Vdd 19 width 0 timing 0
[ 20.491851] mmc0: clock 400000Hz busmode 1 powermode 2 cs 0 Vdd 16 width 0 timing 0
[ 20.499572] mmc0: clock 400000Hz busmode 1 powermode 2 cs 1 Vdd 16 width 0 timing 0
[ 20.509460] mmc0: clock 400000Hz busmode 1 powermode 2 cs 0 Vdd 16 width 0 timing 0
[ 20.534851] Console: switching to colour frame buffer device 160x45
[ 20.555664] regulator_init_complete: incomplete constraints, leaving VAUX3 on
[ 20.563232] mmc0: clock 400000Hz busmode 2 powermode 2 cs 0 Vdd 16 width 0 timing 0
[ 20.570922] regulator_init_complete: incomplete constraints, leaving VDAC on
[ 20.578094] File:Func= drivers/media/video/omap34xxcam.c:omap34xxcam_init
[ 20.584899] omap34xxcam_init STV
[ 20.588165] omap34xxcam_init STV got memory
[ 20.592376] omap34xxcam_init STV 0 A
[ 20.595947] About to regsiter v4l2 device
[ 20.599975] File:Func= drivers/media/video/v4l2-int-device.c:__v4l2_int_device_try_attach_all
[ 20.608551] File:Func= drivers/media/video/v4l2-int-device.c:v4l2_int_device_register
[ 20.616424] regsiter complete v4l2 device
[ 20.620452] omap34xxcam_init STV 1 A
[ 20.624023] About to regsiter v4l2 device
[ 20.628051] File:Func= drivers/media/video/v4l2-int-device.c:__v4l2_int_device_try_attach_all
[ 20.636627] File:Func= drivers/media/video/v4l2-int-device.c:v4l2_int_device_register
[ 20.644500] regsiter complete v4l2 device
[ 20.648498] omap34xxcam_init STV 2 A
[ 20.652099] About to regsiter v4l2 device
[ 20.656127] File:Func= drivers/media/video/v4l2-int-device.c:__v4l2_int_device_try_attach_all
[ 20.664672] File:Func= drivers/media/video/v4l2-int-device.c:v4l2_int_device_register
[ 20.672546] regsiter complete v4l2 device
[ 20.676574] omap34xxcam_init STV 3 A
[ 20.680175] About to regsiter v4l2 device
[ 20.684204] File:Func= drivers/media/video/v4l2-int-device.c:__v4l2_int_device_try_attach_all
[ 20.692779] File:Func= drivers/media/video/v4l2-int-device.c:v4l2_int_device_register
[ 20.700622] regsiter complete v4l2 device
[ 20.704650] omap34xxcam_init STV end
[ 20.708343] omap_vout omap_vout: probed for an unknown device
[ 20.714508] Waiting for root device /dev/mmcblk0p2...
[ 20.724670] mmc0: clock 400000Hz busmode 2 powermode 2 cs 0 Vdd 16 width 0 timing 2
[ 20.732360] mmc0: clock 50000000Hz busmode 2 powermode 2 cs 0 Vdd 16 width 0 timing 2
[ 20.753417] mmc0: clock 50000000Hz busmode 2 powermode 2 cs 0 Vdd 16 width 2 timing 2
[ 20.761322] mmc0: new high speed SD card at address 0001
[ 20.766754] Devidx 0
[ 20.769195] Capacity in bytes 2030043136
[ 20.773162] mmcblk0: mmc0:0001 00000 1.89 GiB
[ 20.777648] mmcblk0: mmc0:0001 00000 1.89 GiB
[ 20.782348] mmcblk0: p1 p2
[ 20.827087] kjournald starting. Commit interval 5 seconds
[ 20.834014] EXT3-fs (mmcblk0p2): using internal journal
[ 20.839324] EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode
[ 20.846435] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 20.854064] devtmpfs: mounted
[ 20.857116] Freeing init memory: 184K
INIT: version 2.86 booting
Please wait: booting...
Starting udev bhupesh tar
enter else not first boot
exit else not first boot
Remounting root file system...
Caching udev devnodes
Populating dev cachemv: cannot rename '/tmp/devices': No such file or directory
ALSA: Restoring mixer settings...
/usr/sbin/alsactl: load_state:1610: No soundcards found...
Configuring network interfaces... ifconfig: SIOCGIFFLAGS: No such device
done.
Setting up IP spoofing protection: rp_filter.
hwclock: can't open '/dev/misc/rtc': No such file or directory
Thu Mar 24 22:54:00 UTC 2011
Configuring dbus.
Adding system startup for /etc/init.d/dbus-1.
Configuring qt4-embedded-demos.
Configuring update-modules.
Configuring omap3-sgx-modules.
Configuring ti-dsplink-module.
Configuring ti-lpm-module.
Configuring ti-cmem-module.
Configuring kernel-module-pcbc.
Configuring kernel-module-ecb.
Configuring kernel-module-cryptodev.
Configuring kernel-module-cryptosoft.
Configuring kernel-module-scsi-wait-scan.
Configuring kernel-module-output.
Configuring ti-dvsdk-demos.
Configuring ti-dvtb.
Configuring ti-sdma-module.
Configuring ti-dmai-apps.
Configuring ti-ocf-crypto-module.
Configuring kernel-image-2.6.32.
[ 33.808105] NET: Registered protocol family 10
[ 33.926696] CMEMK module: built on Aug 9 2012 at 14:07:29
[ 33.932220] Reference Linux version 2.6.32
[ 33.937042] File /home/david/hd-codec/xm_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
[ 33.949035] CMEM Range Overlaps Kernel Physical - allowing overlap
[ 33.955230] CMEM phys_start (0x83700000) overlaps kernel (0x80000000 -> 0x8b700000)
[ 33.964843] allocated heap buffer 0xd2000000 of size 0x2200000
[ 33.970703] heap fallback enabled - will try heap if pool buffer is not available
[ 33.978668] cmemk initialized
[ 34.004516] DSPLINK Module (1.65.00.02) created on Date: Aug 9 2012 Time: 14:13:40
[ 34.045776] SDMAK module: built on Aug 9 2012 at 14:07:30
[ 34.051757] Reference Linux version 2.6.32
[ 34.056030] File /home/david/hd-codec/xm_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/sdma/src/module/sdmak.c
[ 34.068115] enter mod init return 0 bhupesh
