Updating Uboot from Uboot prompt for dm365
HI,
We have designed our board with DM365 processor and we are in the production mode.
We want to update Uboot in our DM365 based board from U-boot serial port prompt.
We have hardwired the nand boot mode and we can only update ubl/uboot using JTAG Emulator.  We have a production lot of 100 boards with uboot, which does not have Ethernet support. We have recently added the Ethernet support in updated U-boot and we want to update all 100 boards without JTAG Emulator.
We tried following script to create an uboot.bin image with header  but the resulted image does not solve our problem. The U-boot is written at 0x19 block
#!/bin/bash -e
PAGESIZE=2048
FIRSTBLOCK=25
MAGIC=0xA1ACED66
SIZE=$(stat --format '%s' u-boot.bin)
ENTRYPOINT=$(readelf -h u-boot | grep "Entry point" | cut -d : -f 2)
binary() {
printf '\\x%02x' $(( $1 & 0xff ))
printf '\\x%02x' $(( ($1 >> 8) & 0xff ))
printf '\\x%02x' $(( ($1 >> 16) & 0xff ))
printf '\\x%02x' $(( ($1 >> 24) & 0xff ))
printf $(binary $MAGIC) > u-boot.ubl
printf $(binary $ENTRYPOINT) >> u-boot.ubl
printf $(binary $(( ($SIZE / $PAGESIZE)+1 ))) >> u-boot.ubl
printf $(binary FIRSTBLOCK) >> u-boot.ubl
printf $(binary 1) >> u-boot.ubl
dd if=u-boot.bin of=u-boot.ubl bs=$PAGESIZE seek=1
echo "Created u-boot.ubl"
After updating the image using following command
loady 0x80700000
nand write 0x320000 0x40000
When we reboot the system using reset command it gives following error
DM36x initialization passed!
TI UBL Version: 1.50
Booting Catalog Boot Loader
BootMode = NAND
Starting NAND Copy...
No valid boot image found!
NAND Boot failed.
Aborting...
Can anyone  please suggest us the solution for this problem?
Jagdish
  • Hi Jagdish,
    I am also trying to update Uboot from uboot prompt on dm365.I have followed your steps but I got stucked.
    UBL and UBOOT are in HW ECC.
    I have used same script file to generate binary which contains Header+Uboot .I have attached log after doing tftpboot new Uboot binary and
    hex dump from address 0x320000 after and before dumping Uboot Image.
    Below log suggests that UBL is able to read magic number,called Nandboot_copy() function of UBL but unable to read next page.
    MINICOM LOG:-
    I2C: ready
    DRAM: 256 MB
    NAND: NAND device: Manufacturer ID: 0x2c, Chip ID: 0xf1 (Micron NAND 128MiB 3,3V 8-bit)
    128 MiB
    UBL Version: 0.5.0
    BootMode = NAND
    Valid magicnum, 0xA1ACED66, found in block 0x00000019.
    DONE
    Jumping to entry point at 0x81080000.
    HERE IT GOT STUCKED
    NAND DUMP:BEFORE
    nand dump 0x320000
    Page 00320000 dump:
    66 ed ac a1 00 00 08 81 4f 00 00 00 19 00 00 00
    01 00 00 00 00 00 08 81 ff ff ff ff ff ff ff ff
    ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
    OOB:
    ff ff ff ff ff ff 27 ed
    b0 ae 55 bd 65 03 21 00
    ff ff ff ff ff ff 3f 27
    56 f5 29 d8 61 d9 9d 14
    NAND DUMP AFTER:
    nand dump 0x320000
    Page 00320000 dump:
    66 ed ac a1 00 00 08 81 00 00 00 00 19 00 00 00
    OOB:
    ff ff ff ff ff ff 5e 90
    26 fb d6 56 56 5f b5 c1
    Script code to generate header_uboot image
    #usage to bring up new u-boot--->ubl calls
    #!/bin/bash -e
    #FIRSTBLOCK=0x19 as per UBL CODE
    #PAGESIZE 2048 as per UBL CODE
    #MAGIC NUMBER GIVEN BY ((magicNum & 0xFFFFFF00) == MAGIC_NUMBER_VALID) /Common/ubl/src/nandboot.c
    #ENTRY POINT IS 0x81080000 hard coded in UBL
    PAGESIZE=2048
    FIRSTBLOCK=25
    MAGIC=0xA1ACED66
    SIZE=$(stat --format '%s' u-boot-1.3.4-dm365_dvr.bin)
    echo $ENTRYPOINT
    echo $SIZE
    binary() {
    printf $(binary $MAGIC) > header
    printf $(binary $ENTRYPOINT) >> header
    printf $(binary $(( ($SIZE / $PAGESIZE)+1 ))) >> header
    printf $(binary FIRSTBLOCK) >> header
    printf $(binary 1) >> header
    tr "\000" "\377" < /dev/zero | dd ibs=1k count=384 of=paddedfile.bin
    dd if=u-boot-1.3.4-dm365_dvr.bin of=paddedfile.bin bs=2048 seek=1 conv=notrunc
    dd if=header of=paddedfile.bin bs=2048 conv=notrunc
    STEPS FOLLOWING TO UPLOAD NEW UBOOT IMAGE:-
    1. tftpboot 0x80700000 paddedfile.bin
    2. nand erase 0x320000 0x60000
    3 nand write 0x80700000 0x320000 0x60000
    4. reset
    Please suggest on the same.
    Thanks/Regards.,
    Sanket & Team
