After nandtest, all the NAND blocks are marked as bad
Other Parts Discussed in Thread: AM3359, TPS65910, TPS65217
My board is using Micron MT29F4G16ABADAWP-IT with AM3359. I've divided the NAND FLASH of 512MiB to two partitions, 256MiB each. So the first NAND partition address is 0 - 0FFFFFFF (/dev/mtd11), the second is 10000000 - 1FFFFFFF (/dev/mtd12). I'm using HW ECC BCH8 in u-boot and Linux.
In Linux , run "nandtest -m -p 1 /dev/mtd12", do nothing, reboot to u-boot, "nand bad" shows that all the NAND blocks of /dev/mtd12 are marked as bad.  But if I run "flash_erase /dev/mtd12 0 0" , "nand bad" in u-boot doesn't show any bad block. Please help on this issue. Thank you!
Test log without "flash_erase /dev/mtd12 0 0"
In u-boot:
MPU-001# nand scrub 10000000 10000000                // scrub /dev/mtd12
NAND scrub: device 0 offset 0x10000000, size 0x10000000
Warning: scrub option will erase all factory set bad blocks!
There is no reliable way to recover them.
Use this command only for testing purposes if you
are sure of what you are doing!
Really scrub this NAND flash? <y/N>
Erasing at 0x1ffe0000 -- 100% complete.
OK
In Linux
root@MPU-001:~# nandtest -m -p 1 /dev/mtd12
ECC corrections: 0
ECC failures : 0
Bad blocks : 0
BBT blocks : 0
002c0000: reading...
1 bit(s) ECC corrected at 002c0000
00380000: reading...
1 bit(s) ECC corrected at 00380000
00740000: reading...
1 bit(s) ECC corrected at 00740000
00c20000: reading...
1 bit(s) ECC corrected at 00c20000
01380000: reading...
1 bit(s) ECC corrected at 01380000
01b40000: reading...
1 bit(s) ECC corrected at 01b40000
01b80000: reading...
1 bit(s) ECC corrected at 01b80000
02520000: reading...
1 bit(s) ECC corrected at 02520000
035c0000: reading...
1 bit(s) ECC corrected at 035c0000
04240000: reading...
1 bit(s) ECC corrected at 04240000
06200000: reading...
1 bit(s) ECC corrected at 06200000
09460000: reading...
1 bit(s) ECC corrected at 09460000
09680000: reading...
1 bit(s) ECC corrected at 09680000
09ea0000: reading...
1 bit(s) ECC corrected at 09ea0000
0b1a0000: reading...
1 bit(s) ECC corrected at 0b1a0000
0b6a0000: reading...
1 bit(s) ECC corrected at 0b6a0000
0c820000: reading...
1 bit(s) ECC corrected at 0c820000
0d360000: reading...
1 bit(s) ECC corrected at 0d360000
0d4c0000: reading...
1 bit(s) ECC corrected at 0d4c0000
0e020000: reading...
1 bit(s) ECC corrected at 0e020000
0e7c0000: reading...
1 bit(s) ECC corrected at 0e7c0000
0ebc0000: reading...
1 bit(s) ECC corrected at 0ebc0000
0f600000: reading...
1 bit(s) ECC corrected at 0f600000
0ffe0000: checking...
Finished pass 1 successfully
root@MPU-001:~# reboot
Stopping System Logging Service...
Stopping Login Service...
Stopping Serial Getty on ttyO0...
Stopping D-Bus System Message Bus...
Stopping Avahi mDNS/DNS-SD Stack...
Starting Save Random Seed...
Stopped Login Service [ OK ]
Starting Syslog Kernel Log Buffer Bridge...
Started Syslog Kernel Log Buffer Bridge [ OK ]
Stopped Serial Getty on ttyO0 [ OK ]
Stopped D-Bus System Message Bus [ OK ]
Stopped Avahi mDNS/DNS-SD Stack [ OK ]
[ 444.959594] avahi-daemon[875]: Got SIGTERM, quitting.
Stopped System L[ 444.968719] avahi-daemon[875]: Leaving mDNS multicast group on interface eth0.IPv4 with address 192.168.6.18.
ogging Service [ 444.980194] avahi-daemon[875]: avahi-daemon 0.6.30 exiting.
[ OK ]
Started Save Random Seed [ OK ]
Stopping Permit User Sessions...
Stopped Permit User Sessions [ OK ]
Starting Notify Audit System and Update UTMP about System Shutdown...
Stopping /tmp...
Stopping Runtime Directory...
Stopping Media Directory...
Stopping Lock Directory...
[ 445.174530] umount[1301]: umount: /var/run: device is busy.
Stopped /tmp [ OK ]
[ 445.203857] umount[1301]: (In some cases useful info about processes that use
[ 445.211334] umount[1301]: the device is found by lsof(8) or fuser(1))
[ 445.218872] systemd[1]: var-run.mount mount process exited, code=exited status=1
Stopped Runtime Directory [ OK ]
Stopped Media Directory [ OK ]
Stopped Lock Directory [ OK ]
Stopping Remount API VFS...
Stopped Remount API VFS [ OK ]
Stopping Remount Root FS...
Stopped Remount Root FS [ OK ]
[ 445.422149] systemd[1]: Shutting down.
[ 445.479400] systemd-cgroups-agent[1311]: Failed to get D-Bus connection: Failed to connect to socket /org/freedesktop/systemd1/private: Connection refused
Sending SIGTERM to remaining processes...
Sending SIGKILL to remaining processes...
Unmounting file systems.
Unmounted /sys/kernel/security.
Unmounted /dev/mqueue.
Unmounted /sys/kernel/debug.
Unmounted /var/run.
Disabling swaps.
Detachin[ 445.536468] musb-hdrc musb-hdrc.1: remove, state 1
[ 445.541564] usb usb1: USB disconnect, device number 1
Detaching DM de[ 445.549072] musb-hdrc musb-hdrc.1: USB bus 1 deregistered
vices.
[ 445.555572] Restarting system.
In u-boot
U-Boot SPL 2011.09-local (Aug 23 2012 - 14:04:22)
Texas Instruments Revision detection unimplemented
BOOTEE: U-Boot boots on [0].[0].
Programming BOOTEE passed.
==[SPI][0B]==
SF: Detected W25Q128 with page size 4 KiB, total 16 MiB
U-Boot 2011.09-local (Aug 23 2012 - 14:04:22)
I2C: ready
DRAM: 256 MiB
WARNING: Caches not enabled
NAND: HW ECC Hamming Code selected
512 MiB
MMC: OMAP SD/MMC: 0
HW ECC BCH8 Selected
==[SPI][0B]==
BOOTEE: U-Boot boots on [0].[0] SUCCESS.
Net: cpsw
Hit any key to stop autoboot: 0
MPU-001# nand bad
Device 0 bad blocks:
10000000
10020000
10040000
10060000
10080000
100a0000
100c0000
100e0000
10100000
10120000
10140000
10160000
10180000
101a0000
101c0000
101e0000
10200000
10220000
10240000
10260000
10280000
102a0000
102c0000
102e0000
10300000
10320000
10340000
10360000
10380000
103a0000
103c0000
103e0000
10400000
10420000
10440000
10460000
10480000
104a0000
104c0000
104e0000
10500000
10520000
10540000
10560000
10580000
105a0000
105c0000
105e0000
10600000
10620000
10640000
10660000
10680000
106a0000
106c0000
106e0000
10700000
10720000
10740000
10760000
10780000
107a0000
107c0000
107e0000
10800000
10820000
10840000
10860000
10880000
108a0000
108c0000
108e0000
10900000
10920000
10940000
10960000
10980000
109a0000
109c0000
109e0000
10a00000
10a20000
10a40000
10a60000
10a80000
10aa0000
10ac0000
10ae0000
10b00000
10b20000
10b40000
10b60000
10b80000
10ba0000
10bc0000
10be0000
10c00000
10c20000
10c40000
10c60000
10c80000
10ca0000
10cc0000
10ce0000
10d00000
10d20000
10d40000
10d60000
10d80000
10da0000
10dc0000
10de0000
10e00000
10e20000
10e40000
10e60000
10e80000
10ea0000
10ec0000
10ee0000
10f00000
10f20000
10f40000
10f60000
10f80000
10fa0000
10fc0000
10fe0000
11000000
11020000
11040000
11060000
11080000
110a0000
110c0000
110e0000
11100000
11120000
11140000
11160000
11180000
111a0000
111c0000
111e0000
11200000
11220000
11240000
11260000
11280000
112a0000
112c0000
112e0000
11300000
11320000
11340000
11360000
11380000
113a0000
113c0000
113e0000
11400000
11420000
11440000
11460000
11480000
114a0000
114c0000
114e0000
11500000
11520000
11540000
11560000
11580000
115a0000
115c0000
115e0000
11600000
11620000
11640000
11660000
11680000
116a0000
116c0000
116e0000
11700000
11720000
11740000
11760000
11780000
117a0000
117c0000
117e0000
11800000
11820000
11840000
11860000
11880000
118a0000
118c0000
118e0000
11900000
11920000
11940000
11960000
11980000
119a0000
119c0000
119e0000
11a00000
11a20000
11a40000
11a60000
11a80000
11aa0000
11ac0000
11ae0000
11b00000
11b20000
11b40000
11b60000
11b80000
11ba0000
11bc0000
11be0000
11c00000
11c20000
11c40000
11c60000
11c80000
11ca0000
11cc0000
11ce0000
11d00000
11d20000
11d40000
11d60000
11d80000
11da0000
11dc0000
11de0000
11e00000
11e20000
11e40000
11e60000
11e80000
11ea0000
11ec0000
11ee0000
11f00000
11f20000
11f40000
11f60000
11f80000
11fa0000
11fc0000
11fe0000
12000000
12020000
12040000
12060000
12080000
120a0000
120c0000
120e0000
12100000
12120000
12140000
12160000
12180000
121a0000
121c0000
121e0000
12200000
12220000
12240000
12260000
12280000
122a0000
122c0000
122e0000
12300000
12320000
12340000
12360000
12380000
123a0000
123c0000
123e0000
12400000
12420000
12440000
12460000
12480000
124a0000
124c0000
124e0000
12500000
12520000
12540000
12560000
12580000
125a0000
125c0000
125e0000
12600000
12620000
12640000
12660000
12680000
126a0000
126c0000
126e0000
12700000
12720000
12740000
12760000
12780000
127a0000
127c0000
127e0000
12800000
12820000
12840000
12860000
12880000
128a0000
128c0000
128e0000
12900000
12920000
12940000
12960000
12980000
129a0000
129c0000
129e0000
12a00000
12a20000
12a40000
12a60000
12a80000
12aa0000
12ac0000
12ae0000
12b00000
12b20000
12b40000
12b60000
12b80000
12ba0000
12bc0000
12be0000
12c00000
12c20000
12c40000
12c60000
12c80000
12ca0000
12cc0000
12ce0000
12d00000
12d20000
12d40000
12d60000
12d80000
12da0000
12dc0000
12de0000
12e00000
12e20000
12e40000
12e60000
12e80000
12ea0000
12ec0000
12ee0000
12f00000
12f20000
12f40000
12f60000
12f80000
12fa0000
12fc0000
12fe0000
13000000
13020000
13040000
13060000
13080000
130a0000
130c0000
130e0000
13100000
13120000
13140000
13160000
13180000
131a0000
131c0000
131e0000
13200000
13220000
13240000
13260000
13280000
132a0000
132c0000
132e0000
13300000
13320000
13340000
13360000
13380000
133a0000
133c0000
133e0000
13400000
13420000
13440000
13460000
13480000
134a0000
134c0000
134e0000
13500000
13520000
13540000
13560000
13580000
135a0000
135c0000
135e0000
13600000
13620000
13640000
13660000
13680000
136a0000
136c0000
136e0000
13700000
13720000
13740000
13760000
13780000
137a0000
137c0000
137e0000
13800000
13820000
13840000
13860000
13880000
138a0000
138c0000
138e0000
13900000
13920000
13940000
13960000
13980000
139a0000
139c0000
139e0000
13a00000
13a20000
13a40000
13a60000
13a80000
13aa0000
13ac0000
13ae0000
13b00000
13b20000
13b40000
13b60000
13b80000
13ba0000
13bc0000
13be0000
13c00000
13c20000
13c40000
13c60000
13c80000
13ca0000
13cc0000
13ce0000
13d00000
13d20000
13d40000
13d60000
13d80000
13da0000
13dc0000
13de0000
13e00000
13e20000
13e40000
13e60000
13e80000
13ea0000
13ec0000
13ee0000
13f00000
13f20000
13f40000
13f60000
13f80000
13fa0000
13fc0000
13fe0000
14000000
14020000
14040000
14060000
14080000
140a0000
140c0000
140e0000
14100000
14120000
14140000
14160000
14180000
141a0000
141c0000
141e0000
14200000
14220000
14240000
14260000
14280000
142a0000
142c0000
142e0000
14300000
14320000
14340000
14360000
14380000
143a0000
143c0000
143e0000
14400000
14420000
14440000
14460000
14480000
144a0000
144c0000
144e0000
14500000
14520000
14540000
14560000
14580000
145a0000
145c0000
145e0000
14600000
14620000
14640000
14660000
14680000
146a0000
146c0000
146e0000
14700000
14720000
14740000
14760000
14780000
147a0000
147c0000
147e0000
14800000
14820000
14840000
14860000
14880000
148a0000
148c0000
148e0000
14900000
14920000
14940000
14960000
14980000
149a0000
149c0000
149e0000
14a00000
14a20000
14a40000
14a60000
14a80000
14aa0000
14ac0000
14ae0000
14b00000
14b20000
14b40000
14b60000
14b80000
14ba0000
14bc0000
14be0000
14c00000
14c20000
14c40000
14c60000
14c80000
14ca0000
14cc0000
14ce0000
14d00000
14d20000
14d40000
14d60000
14d80000
14da0000
14dc0000
14de0000
14e00000
14e20000
14e40000
14e60000
14e80000
14ea0000
14ec0000
14ee0000
14f00000
14f20000
14f40000
14f60000
14f80000
14fa0000
14fc0000
14fe0000
15000000
15020000
15040000
15060000
15080000
150a0000
150c0000
150e0000
15100000
15120000
15140000
15160000
15180000
151a0000
151c0000
151e0000
15200000
15220000
15240000
15260000
15280000
152a0000
152c0000
152e0000
15300000
15320000
15340000
15360000
15380000
153a0000
153c0000
153e0000
15400000
15420000
15440000
15460000
15480000
154a0000
154c0000
154e0000
15500000
15520000
15540000
15560000
15580000
155a0000
155c0000
155e0000
15600000
15620000
15640000
15660000
15680000
156a0000
156c0000
156e0000
15700000
15720000
15740000
15760000
15780000
157a0000
157c0000
157e0000
15800000
15820000
15840000
15860000
15880000
158a0000
158c0000
158e0000
15900000
15920000
15940000
15960000
15980000
159a0000
159c0000
159e0000
15a00000
15a20000
15a40000
15a60000
15a80000
15aa0000
15ac0000
15ae0000
15b00000
15b20000
15b40000
15b60000
15b80000
15ba0000
15bc0000
15be0000
15c00000
15c20000
15c40000
15c60000
15c80000
15ca0000
15cc0000
15ce0000
15d00000
15d20000
15d40000
15d60000
15d80000
15da0000
15dc0000
15de0000
15e00000
15e20000
15e40000
15e60000
15e80000
15ea0000
15ec0000
15ee0000
15f00000
15f20000
15f40000
15f60000
15f80000
15fa0000
15fc0000
15fe0000
16000000
16020000
16040000
16060000
16080000
160a0000
160c0000
160e0000
16100000
16120000
16140000
16160000
16180000
161a0000
161c0000
161e0000
16200000
16220000
16240000
16260000
16280000
162a0000
162c0000
162e0000
16300000
16320000
16340000
16360000
16380000
163a0000
163c0000
163e0000
16400000
16420000
16440000
16460000
16480000
164a0000
164c0000
164e0000
16500000
16520000
16540000
16560000
16580000
165a0000
165c0000
165e0000
16600000
16620000
16640000
16660000
16680000
166a0000
166c0000
166e0000
16700000
16720000
16740000
16760000
16780000
167a0000
167c0000
167e0000
16800000
16820000
16840000
16860000
16880000
168a0000
168c0000
168e0000
16900000
16920000
16940000
16960000
16980000
169a0000
169c0000
169e0000
16a00000
16a20000
16a40000
16a60000
16a80000
16aa0000
16ac0000
16ae0000
16b00000
16b20000
16b40000
16b60000
16b80000
16ba0000
16bc0000
16be0000
16c00000
16c20000
16c40000
16c60000
16c80000
16ca0000
16cc0000
16ce0000
16d00000
16d20000
16d40000
16d60000
16d80000
16da0000
16dc0000
16de0000
16e00000
16e20000
16e40000
16e60000
16e80000
16ea0000
16ec0000
16ee0000
16f00000
16f20000
16f40000
16f60000
16f80000
16fa0000
16fc0000
16fe0000
17000000
17020000
17040000
17060000
17080000
170a0000
170c0000
170e0000
17100000
17120000
17140000
17160000
17180000
171a0000
171c0000
171e0000
17200000
17220000
17240000
17260000
17280000
172a0000
172c0000
172e0000
17300000
17320000
17340000
17360000
17380000
173a0000
173c0000
173e0000
17400000
17420000
17440000
17460000
17480000
174a0000
174c0000
174e0000
17500000
17520000
17540000
17560000
17580000
175a0000
175c0000
175e0000
17600000
17620000
17640000
17660000
17680000
176a0000
176c0000
176e0000
17700000
17720000
17740000
17760000
17780000
177a0000
177c0000
177e0000
17800000
17820000
17840000
17860000
17880000
178a0000
178c0000
178e0000
17900000
17920000
17940000
17960000
17980000
179a0000
179c0000
179e0000
17a00000
17a20000
17a40000
17a60000
17a80000
17aa0000
17ac0000
17ae0000
17b00000
17b20000
17b40000
17b60000
17b80000
17ba0000
17bc0000
17be0000
17c00000
17c20000
17c40000
17c60000
17c80000
17ca0000
17cc0000
17ce0000
17d00000
17d20000
17d40000
17d60000
17d80000
17da0000
17dc0000
17de0000
17e00000
17e20000
17e40000
17e60000
17e80000
17ea0000
17ec0000
17ee0000
17f00000
17f20000
17f40000
17f60000
17f80000
17fa0000
17fc0000
17fe0000
18000000
18020000
18040000
18060000
18080000
180a0000
180c0000
180e0000
18100000
18120000
18140000
18160000
18180000
181a0000
181c0000
181e0000
18200000
18220000
18240000
18260000
18280000
182a0000
182c0000
182e0000
18300000
18320000
18340000
18360000
18380000
183a0000
183c0000
183e0000
18400000
18420000
18440000
18460000
18480000
184a0000
184c0000
184e0000
18500000
18520000
18540000
18560000
18580000
185a0000
185c0000
185e0000
18600000
18620000
18640000
18660000
18680000
186a0000
186c0000
186e0000
18700000
18720000
18740000
18760000
18780000
187a0000
187c0000
187e0000
18800000
18820000
18840000
18860000
18880000
188a0000
188c0000
188e0000
18900000
18920000
18940000
18960000
18980000
189a0000
189c0000
189e0000
18a00000
18a20000
18a40000
18a60000
18a80000
18aa0000
18ac0000
18ae0000
18b00000
18b20000
18b40000
18b60000
18b80000
18ba0000
18bc0000
18be0000
18c00000
18c20000
18c40000
18c60000
18c80000
18ca0000
18cc0000
18ce0000
18d00000
18d20000
18d40000
18d60000
18d80000
18da0000
18dc0000
18de0000
18e00000
18e20000
18e40000
18e60000
18e80000
18ea0000
18ec0000
18ee0000
18f00000
18f20000
18f40000
18f60000
18f80000
18fa0000
18fc0000
18fe0000
19000000
19020000
19040000
19060000
19080000
190a0000
190c0000
190e0000
19100000
19120000
19140000
19160000
19180000
191a0000
191c0000
191e0000
19200000
19220000
19240000
19260000
19280000
192a0000
192c0000
192e0000
19300000
19320000
19340000
19360000
19380000
193a0000
193c0000
193e0000
19400000
19420000
19440000
19460000
19480000
194a0000
194c0000
194e0000
19500000
19520000
19540000
19560000
19580000
195a0000
195c0000
195e0000
19600000
19620000
19640000
19660000
19680000
196a0000
196c0000
196e0000
19700000
19720000
19740000
19760000
19780000
197a0000
197c0000
197e0000
19800000
19820000
19840000
19860000
19880000
198a0000
198c0000
198e0000
19900000
19920000
19940000
19960000
19980000
199a0000
199c0000
199e0000
19a00000
19a20000
19a40000
19a60000
19a80000
19aa0000
19ac0000
19ae0000
19b00000
19b20000
19b40000
19b60000
19b80000
19ba0000
19bc0000
19be0000
19c00000
19c20000
19c40000
19c60000
19c80000
19ca0000
19cc0000
19ce0000
19d00000
19d20000
19d40000
19d60000
19d80000
19da0000
19dc0000
19de0000
19e00000
19e20000
19e40000
19e60000
19e80000
19ea0000
19ec0000
19ee0000
19f00000
19f20000
19f40000
19f60000
19f80000
19fa0000
19fc0000
19fe0000
1a000000
1a020000
1a040000
1a060000
1a080000
1a0a0000
1a0c0000
1a0e0000
1a100000
1a120000
1a140000
1a160000
1a180000
1a1a0000
1a1c0000
1a1e0000
1a200000
1a220000
1a240000
1a260000
1a280000
1a2a0000
1a2c0000
1a2e0000
1a300000
1a320000
1a340000
1a360000
1a380000
1a3a0000
1a3c0000
1a3e0000
1a400000
1a420000
1a440000
1a460000
1a480000
1a4a0000
1a4c0000
1a4e0000
1a500000
1a520000
1a540000
1a560000
1a580000
1a5a0000
1a5c0000
1a5e0000
1a600000
1a620000
1a640000
1a660000
1a680000
1a6a0000
1a6c0000
1a6e0000
1a700000
1a720000
1a740000
1a760000
1a780000
1a7a0000
1a7c0000
1a7e0000
1a800000
1a820000
1a840000
1a860000
1a880000
1a8a0000
1a8c0000
1a8e0000
1a900000
1a920000
1a940000
1a960000
1a980000
1a9a0000
1a9c0000
1a9e0000
1aa00000
1aa20000
1aa40000
1aa60000
1aa80000
1aaa0000
1aac0000
1aae0000
1ab00000
1ab20000
1ab40000
1ab60000
1ab80000
1aba0000
1abc0000
1abe0000
1ac00000
1ac20000
1ac40000
1ac60000
1ac80000
1aca0000
1acc0000
1ace0000
1ad00000
1ad20000
1ad40000
1ad60000
1ad80000
1ada0000
1adc0000
1ade0000
1ae00000
1ae20000
1ae40000
1ae60000
1ae80000
1aea0000
1aec0000
1aee0000
1af00000
1af20000
1af40000
1af60000
1af80000
1afa0000
1afc0000
1afe0000
1b000000
1b020000
1b040000
1b060000
1b080000
1b0a0000
1b0c0000
1b0e0000
1b100000
1b120000
1b140000
1b160000
1b180000
1b1a0000
1b1c0000
1b1e0000
1b200000
1b220000
1b240000
1b260000
1b280000
1b2a0000
1b2c0000
1b2e0000
1b300000
1b320000
1b340000
1b360000
1b380000
1b3a0000
1b3c0000
1b3e0000
1b400000
1b420000
1b440000
1b460000
1b480000
1b4a0000
1b4c0000
1b4e0000
1b500000
1b520000
1b540000
1b560000
1b580000
1b5a0000
1b5c0000
1b5e0000
1b600000
1b620000
1b640000
1b660000
1b680000
1b6a0000
1b6c0000
1b6e0000
1b700000
1b720000
1b740000
1b760000
1b780000
1b7a0000
1b7c0000
1b7e0000
1b800000
1b820000
1b840000
1b860000
1b880000
1b8a0000
1b8c0000
1b8e0000
1b900000
1b920000
1b940000
1b960000
1b980000
1b9a0000
1b9c0000
1b9e0000
1ba00000
1ba20000
1ba40000
1ba60000
1ba80000
1baa0000
1bac0000
1bae0000
1bb00000
1bb20000
1bb40000
1bb60000
1bb80000
1bba0000
1bbc0000
1bbe0000
1bc00000
1bc20000
1bc40000
1bc60000
1bc80000
1bca0000
1bcc0000
1bce0000
1bd00000
1bd20000
1bd40000
1bd60000
1bd80000
1bda0000
1bdc0000
1bde0000
1be00000
1be20000
1be40000
1be60000
1be80000
1bea0000
1bec0000
1bee0000
1bf00000
1bf20000
1bf40000
1bf60000
1bf80000
1bfa0000
1bfc0000
1bfe0000
1c000000
1c020000
1c040000
1c060000
1c080000
1c0a0000
1c0c0000
1c0e0000
1c100000
1c120000
1c140000
1c160000
1c180000
1c1a0000
1c1c0000
1c1e0000
1c200000
1c220000
1c240000
1c260000
1c280000
1c2a0000
1c2c0000
1c2e0000
1c300000
1c320000
1c340000
1c360000
1c380000
1c3a0000
1c3c0000
1c3e0000
1c400000
1c420000
1c440000
1c460000
1c480000
1c4a0000
1c4c0000
1c4e0000
1c500000
1c520000
1c540000
1c560000
1c580000
1c5a0000
1c5c0000
1c5e0000
1c600000
1c620000
1c640000
1c660000
1c680000
1c6a0000
1c6c0000
1c6e0000
1c700000
1c720000
1c740000
1c760000
1c780000
1c7a0000
1c7c0000
1c7e0000
1c800000
1c820000
1c840000
1c860000
1c880000
1c8a0000
1c8c0000
1c8e0000
1c900000
1c920000
1c940000
1c960000
1c980000
1c9a0000
1c9c0000
1c9e0000
1ca00000
1ca20000
1ca40000
1ca60000
1ca80000
1caa0000
1cac0000
1cae0000
1cb00000
1cb20000
1cb40000
1cb60000
1cb80000
1cba0000
1cbc0000
1cbe0000
1cc00000
1cc20000
1cc40000
1cc60000
1cc80000
1cca0000
1ccc0000
1cce0000
1cd00000
1cd20000
1cd40000
1cd60000
1cd80000
1cda0000
1cdc0000
1cde0000
1ce00000
1ce20000
1ce40000
1ce60000
1ce80000
1cea0000
1cec0000
1cee0000
1cf00000
1cf20000
1cf40000
1cf60000
1cf80000
1cfa0000
1cfc0000
1cfe0000
1d000000
1d020000
1d040000
1d060000
1d080000
1d0a0000
1d0c0000
1d0e0000
1d100000
1d120000
1d140000
1d160000
1d180000
1d1a0000
1d1c0000
1d1e0000
1d200000
1d220000
1d240000
1d260000
1d280000
1d2a0000
1d2c0000
1d2e0000
1d300000
1d320000
1d340000
1d360000
1d380000
1d3a0000
1d3c0000
1d3e0000
1d400000
1d420000
1d440000
1d460000
1d480000
1d4a0000
1d4c0000
1d4e0000
1d500000
1d520000
1d540000
1d560000
1d580000
1d5a0000
1d5c0000
1d5e0000
1d600000
1d620000
1d640000
1d660000
1d680000
1d6a0000
1d6c0000
1d6e0000
1d700000
1d720000
1d740000
1d760000
1d780000
1d7a0000
1d7c0000
1d7e0000
1d800000
1d820000
1d840000
1d860000
1d880000
1d8a0000
1d8c0000
1d8e0000
1d900000
1d920000
1d940000
1d960000
1d980000
1d9a0000
1d9c0000
1d9e0000
1da00000
1da20000
1da40000
1da60000
1da80000
1daa0000
1dac0000
1dae0000
1db00000
1db20000
1db40000
1db60000
1db80000
1dba0000
1dbc0000
1dbe0000
1dc00000
1dc20000
1dc40000
1dc60000
1dc80000
1dca0000
1dcc0000
1dce0000
1dd00000
1dd20000
1dd40000
1dd60000
1dd80000
1dda0000
1ddc0000
1dde0000
1de00000
1de20000
1de40000
1de60000
1de80000
1dea0000
1dec0000
1dee0000
1df00000
1df20000
1df40000
1df60000
1df80000
1dfa0000
1dfc0000
1dfe0000
1e000000
1e020000
1e040000
1e060000
1e080000
1e0a0000
1e0c0000
1e0e0000
1e100000
1e120000
1e140000
1e160000
1e180000
1e1a0000
1e1c0000
1e1e0000
1e200000
1e220000
1e240000
1e260000
1e280000
1e2a0000
1e2c0000
1e2e0000
1e300000
1e320000
1e340000
1e360000
1e380000
1e3a0000
1e3c0000
1e3e0000
1e400000
1e420000
1e440000
1e460000
1e480000
1e4a0000
1e4c0000
1e4e0000
1e500000
1e520000
1e540000
1e560000
1e580000
1e5a0000
1e5c0000
1e5e0000
1e600000
1e620000
1e640000
1e660000
1e680000
1e6a0000
1e6c0000
1e6e0000
1e700000
1e720000
1e740000
1e760000
1e780000
1e7a0000
1e7c0000
1e7e0000
1e800000
1e820000
1e840000
1e860000
1e880000
1e8a0000
1e8c0000
1e8e0000
1e900000
1e920000
1e940000
1e960000
1e980000
1e9a0000
1e9c0000
1e9e0000
1ea00000
1ea20000
1ea40000
1ea60000
1ea80000
1eaa0000
1eac0000
1eae0000
1eb00000
1eb20000
1eb40000
1eb60000
1eb80000
1eba0000
1ebc0000
1ebe0000
1ec00000
1ec20000
1ec40000
1ec60000
1ec80000
1eca0000
1ecc0000
1ece0000
1ed00000
1ed20000
1ed40000
1ed60000
1ed80000
1eda0000
1edc0000
1ede0000
1ee00000
1ee20000
1ee40000
1ee60000
1ee80000
1eea0000
1eec0000
1eee0000
1ef00000
1ef20000
1ef40000
1ef60000
1ef80000
1efa0000
1efc0000
1efe0000
1f000000
1f020000
1f040000
1f060000
1f080000
1f0a0000
1f0c0000
1f0e0000
1f100000
1f120000
1f140000
1f160000
1f180000
1f1a0000
1f1c0000
1f1e0000
1f200000
1f220000
1f240000
1f260000
1f280000
1f2a0000
1f2c0000
1f2e0000
1f300000
1f320000
1f340000
1f360000
1f380000
1f3a0000
1f3c0000
1f3e0000
1f400000
1f420000
1f440000
1f460000
1f480000
1f4a0000
1f4c0000
1f4e0000
1f500000
1f520000
1f540000
1f560000
1f580000
1f5a0000
1f5c0000
1f5e0000
1f600000
1f620000
1f640000
1f660000
1f680000
1f6a0000
1f6c0000
1f6e0000
1f700000
1f720000
1f740000
1f760000
1f780000
1f7a0000
1f7c0000
1f7e0000
1f800000
1f820000
1f840000
1f860000
1f880000
1f8a0000
1f8c0000
1f8e0000
1f900000
1f920000
1f940000
1f960000
1f980000
1f9a0000
1f9c0000
1f9e0000
1fa00000
1fa20000
1fa40000
1fa60000
1fa80000
1faa0000
1fac0000
1fae0000
1fb00000
1fb20000
1fb40000
1fb60000
1fb80000
1fba0000
1fbc0000
1fbe0000
1fc00000
1fc20000
1fc40000
1fc60000
1fc80000
1fca0000
1fcc0000
1fce0000
1fd00000
1fd20000
1fd40000
1fd60000
1fd80000
1fda0000
1fdc0000
1fde0000
1fe00000
1fe20000
1fe40000
1fe60000
1fe80000
1fea0000
1fec0000
1fee0000
1ff00000
1ff20000
1ff40000
1ff60000
1ff80000
1ffa0000
1ffc0000
1ffe0000
MPU-001#
  • Frisky,
    Can you do a "nand dump 101e0000" or any of the failing offsets from u-boot, before running nand test, after running nand test? Please send the logs after that.
  • Renjith,
    Thank you for the quick reply. This is my test log:
    MPU-001#
    ==[SPI][0B]==
    I2C: ready
    DRAM: 256 MiB
    512 MiB
    MMC: OMAP SD/MMC: 0
    ==[SPI][0B]==
    Net: cpsw
    Hit any key to stop autoboot: 3 0
    ynand_erase: attempt to erase a bad block at page 0x00020000
    nand0: MTD Erase failure: -5
    nand_erase: attempt to erase a bad block at page 0x00020040
    nand_erase: attempt to erase a bad block at page 0x00020080
    nand_erase: attempt to erase a bad block at page 0x000200c0
    nand_erase: attempt to erase a bad block at page 0x00020100
    nand_erase: attempt to erase a bad block at page 0x00020140
    nand_erase: attempt to erase a bad block at page 0x00020180
    nand_erase: attempt to erase a bad block at page 0x000201c0
    Erasing at 0x10100000 -- 0% complete. Erasing at 0x10280000 -- 1% complete. Erasing at 0x10500000 -- 2% complete. Erasing at 0x107a0000 -- 3% complete. Erasing at 0x10a20000 -- 4% complete. Erasing at 0x10cc0000 -- 5% complete. Erasing at 0x10f40000 -- 6% complete. Erasing at 0x111e0000 -- 7% complete. Erasing at 0x11460000 -- 8% complete. Erasing at 0x11700000 -- 9% complete. Erasing at 0x11980000 -- 10% complete. Erasing at 0x11c20000 -- 11% complete. Erasing at 0x11ea0000 -- 12% complete. Erasing at 0x12140000 -- 13% complete. Erasing at 0x123c0000 -- 14% complete. Erasing at 0x12660000 -- 15% complete. Erasing at 0x128e0000 -- 16% complete. Erasing at 0x12b80000 -- 17% complete. Erasing at 0x12e00000 -- 18% complete. Erasing at 0x130a0000 -- 19% complete. Erasing at 0x13320000 -- 20% complete. Erasing at 0x135c0000 -- 21% complete. Erasing at 0x13840000 -- 22% complete. Erasing at 0x13ae0000 -- 23% complete. Erasing at 0x13d60000 -- 24% complete. Erasing at 0x13fe0000 -- 25% complete. Erasing at 0x14280000 -- 26% complete. Erasing at 0x14500000 -- 27% complete. Erasing at 0x147a0000 -- 28% complete. Erasing at 0x14a20000 -- 29% complete. Erasing at 0x14cc0000 -- 30% complete. Erasing at 0x14f40000 -- 31% complete. Erasing at 0x151e0000 -- 32% complete. Erasing at 0x15460000 -- 33% complete. Erasing at 0x15700000 -- 34% complete. Erasing at 0x15980000 -- 35% complete. Erasing at 0x15c20000 -- 36% complete. Erasing at 0x15ea0000 -- 37% complete. Erasing at 0x16140000 -- 38% complete. Erasing at 0x163c0000 -- 39% complete. Erasing at 0x16660000 -- 40% complete. Erasing at 0x168e0000 -- 41% complete. Erasing at 0x16b80000 -- 42% complete. Erasing at 0x16e00000 -- 43% complete. Erasing at 0x170a0000 -- 44% complete. Erasing at 0x17320000 -- 45% complete. Erasing at 0x175c0000 -- 46% complete. Erasing at 0x17840000 -- 47% complete. Erasing at 0x17ae0000 -- 48% complete. Erasing at 0x17d60000 -- 49% complete. Erasing at 0x17fe0000 -- 50% complete. Erasing at 0x18280000 -- 51% complete. Erasing at 0x18500000 -- 52% complete. Erasing at 0x187a0000 -- 53% complete. Erasing at 0x18a20000 -- 54% complete. Erasing at 0x18cc0000 -- 55% complete. Erasing at 0x18f40000 -- 56% complete. Erasing at 0x191e0000 -- 57% complete. Erasing at 0x19460000 -- 58% complete. Erasing at 0x19700000 -- 59% complete. Erasing at 0x19980000 -- 60% complete. Erasing at 0x19c20000 -- 61% complete. Erasing at 0x19ea0000 -- 62% complete. Erasing at 0x1a140000 -- 63% complete. Erasing at 0x1a3c0000 -- 64% complete. Erasing at 0x1a660000 -- 65% complete. Erasing at 0x1a8e0000 -- 66% complete. Erasing at 0x1ab80000 -- 67% complete. Erasing at 0x1ae00000 -- 68% complete. Erasing at 0x1b0a0000 -- 69% complete. Erasing at 0x1b320000 -- 70% complete. Erasing at 0x1b5c0000 -- 71% complete. Erasing at 0x1b840000 -- 72% complete. Erasing at 0x1bae0000 -- 73% complete. Erasing at 0x1bd60000 -- 74% complete. Erasing at 0x1bfe0000 -- 75% complete. Erasing at 0x1c280000 -- 76% complete. Erasing at 0x1c500000 -- 77% complete. Erasing at 0x1c7a0000 -- 78% complete. Erasing at 0x1ca20000 -- 79% complete. Erasing at 0x1ccc0000 -- 80% complete. Erasing at 0x1cf40000 -- 81% complete. Erasing at 0x1d1e0000 -- 82% complete. Erasing at 0x1d460000 -- 83% complete. Erasing at 0x1d700000 -- 84% complete. Erasing at 0x1d980000 -- 85% complete. Erasing at 0x1dc20000 -- 86% complete. Erasing at 0x1dea0000 -- 87% complete. Erasing at 0x1e140000 -- 88% complete. Erasing at 0x1e3c0000 -- 89% complete. Erasing at 0x1e660000 -- 90% complete. Erasing at 0x1e8e0000 -- 91% complete. Erasing at 0x1eb80000 -- 92% complete. Erasing at 0x1ee00000 -- 93% complete. Erasing at 0x1f0a0000 -- 94% complete. Erasing at 0x1f320000 -- 95% complete. Erasing at 0x1f5c0000 -- 96% complete. Erasing at 0x1f840000 -- 97% complete. Erasing at 0x1fae0000 -- 98% complete. Erasing at 0x1fd60000 -- 99% complete. Erasing at 0x1ffe0000 -- 100% complete.
    OK
    MPU-001#
    y Erasing at 0x10000000 -- 0% complete. Erasing at 0x10280000 -- 1% complete. Erasing at 0x10500000 -- 2% complete. Erasing at 0x107a0000 -- 3% complete. Erasing at 0x10a20000 -- 4% complete. Erasing at 0x10cc0000 -- 5% complete. Erasing at 0x10f40000 -- 6% complete. Erasing at 0x111e0000 -- 7% complete. Erasing at 0x11460000 -- 8% complete. Erasing at 0x11700000 -- 9% complete. Erasing at 0x11980000 -- 10% complete. Erasing at 0x11c20000 -- 11% complete. Erasing at 0x11ea0000 -- 12% complete. Erasing at 0x12140000 -- 13% complete. Erasing at 0x123c0000 -- 14% complete. Erasing at 0x12660000 -- 15% complete. Erasing at 0x128e0000 -- 16% complete. Erasing at 0x12b80000 -- 17% complete. Erasing at 0x12e00000 -- 18% complete. Erasing at 0x130a0000 -- 19% complete. Erasing at 0x13320000 -- 20% complete. Erasing at 0x135c0000 -- 21% complete. Erasing at 0x13840000 -- 22% complete. Erasing at 0x13ae0000 -- 23% complete. Erasing at 0x13d60000 -- 24% complete. Erasing at 0x13fe0000 -- 25% complete. Erasing at 0x14280000 -- 26% complete. Erasing at 0x14500000 -- 27% complete. Erasing at 0x147a0000 -- 28% complete. Erasing at 0x14a20000 -- 29% complete. Erasing at 0x14cc0000 -- 30% complete. Erasing at 0x14f40000 -- 31% complete. Erasing at 0x151e0000 -- 32% complete. Erasing at 0x15460000 -- 33% complete. Erasing at 0x15700000 -- 34% complete. Erasing at 0x15980000 -- 35% complete. Erasing at 0x15c20000 -- 36% complete. Erasing at 0x15ea0000 -- 37% complete. Erasing at 0x16140000 -- 38% complete. Erasing at 0x163c0000 -- 39% complete. Erasing at 0x16660000 -- 40% complete. Erasing at 0x168e0000 -- 41% complete. Erasing at 0x16b80000 -- 42% complete. Erasing at 0x16e00000 -- 43% complete. Erasing at 0x170a0000 -- 44% complete. Erasing at 0x17320000 -- 45% complete. Erasing at 0x175c0000 -- 46% complete. Erasing at 0x17840000 -- 47% complete. Erasing at 0x17ae0000 -- 48% complete. Erasing at 0x17d60000 -- 49% complete. Erasing at 0x17fe0000 -- 50% complete. Erasing at 0x18280000 -- 51% complete. Erasing at 0x18500000 -- 52% complete. Erasing at 0x187a0000 -- 53% complete. Erasing at 0x18a20000 -- 54% complete. Erasing at 0x18cc0000 -- 55% complete. Erasing at 0x18f40000 -- 56% complete. Erasing at 0x191e0000 -- 57% complete. Erasing at 0x19460000 -- 58% complete. Erasing at 0x19700000 -- 59% complete. Erasing at 0x19980000 -- 60% complete. Erasing at 0x19c20000 -- 61% complete. Erasing at 0x19ea0000 -- 62% complete. Erasing at 0x1a140000 -- 63% complete. Erasing at 0x1a3c0000 -- 64% complete. Erasing at 0x1a660000 -- 65% complete. Erasing at 0x1a8e0000 -- 66% complete. Erasing at 0x1ab80000 -- 67% complete. Erasing at 0x1ae00000 -- 68% complete. Erasing at 0x1b0a0000 -- 69% complete. Erasing at 0x1b320000 -- 70% complete. Erasing at 0x1b5c0000 -- 71% complete. Erasing at 0x1b840000 -- 72% complete. Erasing at 0x1bae0000 -- 73% complete. Erasing at 0x1bd60000 -- 74% complete. Erasing at 0x1bfe0000 -- 75% complete. Erasing at 0x1c280000 -- 76% complete. Erasing at 0x1c500000 -- 77% complete. Erasing at 0x1c7a0000 -- 78% complete. Erasing at 0x1ca20000 -- 79% complete. Erasing at 0x1ccc0000 -- 80% complete. Erasing at 0x1cf40000 -- 81% complete. Erasing at 0x1d1e0000 -- 82% complete. Erasing at 0x1d460000 -- 83% complete. Erasing at 0x1d700000 -- 84% complete. Erasing at 0x1d980000 -- 85% complete. Erasing at 0x1dc20000 -- 86% complete. Erasing at 0x1dea0000 -- 87% complete. Erasing at 0x1e140000 -- 88% complete. Erasing at 0x1e3c0000 -- 89% complete. Erasing at 0x1e660000 -- 90% complete. Erasing at 0x1e8e0000 -- 91% complete. Erasing at 0x1eb80000 -- 92% complete. Erasing at 0x1ee00000 -- 93% complete. Erasing at 0x1f0a0000 -- 94% complete. Erasing at 0x1f320000 -- 95% complete. Erasing at 0x1f5c0000 -- 96% complete. Erasing at 0x1f840000 -- 97% complete. Erasing at 0x1fae0000 -- 98% complete. Erasing at 0x1fd60000 -- 99% complete. Erasing at 0x1ffe0000 -- 100% complete.
    OK
    MPU-001# nand dump 100e0000
    Page 100e0000 dump:
    ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
    OOB:
    MPU-001# boot
    Booting from network ...
    link up on port 0, speed 100, full duplex
    BOOTP broadcast 1
    DHCP client bound to address 192.168.6.18
    Using cpsw device
    TFTP from server 192.168.6.168; our IP address is 192.168.6.18
    Filename 'uImage'.
    Load address: 0x80007fc0
    Loading: *#################################################################
    done
    Bytes transferred = 3173736 (306d68 hex)
    ## Booting kernel from Legacy Image at 80007fc0 ...
    Image Name: Linux-3.2.0
    Image Type: ARM Linux Kernel Image (uncompressed)
    Data Size: 3173672 Bytes = 3 MiB
    Load Address: 80008000
    Entry Point: 80008000
    Verifying Checksum ... OK
    XIP Kernel Image ... OK
    OK
    Starting kernel ...
    Uncompressing Linux... done, booting the kernel.
    [ 0.000000] Initializing cgroup subsys cpuset
    [ 0.000000] Linux version 3.2.0 (lizq@ubuntu10044) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #6 Thu Aug 23 17:37:11 CST 2012
    [ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d
    [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [ 0.000000] Machine: am335xevm
    [ 0.000000] Memory policy: ECC disabled, Data cache writeback
    [ 0.000000] AM335X ES1.0 (sgx neon )
    [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
    [ 0.000000] Kernel command line: console=ttyO0,115200n8 run_hardware_tests spi_autoboot_flag=0 root=/dev/nfs nfsroot=192.168.6.168:/local/tftpboot/rootfs_full,nolock rw ip=dhcp
    [ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
    [ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
    [ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
    [ 0.000000] allocated 1048576 bytes of page_cgroup
    [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
    [ 0.000000] Memory: 256MB = 256MB total
    [ 0.000000] Memory: 252252k/252252k available, 9892k reserved, 0K highmem
    [ 0.000000] Virtual kernel memory layout:
    [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
    [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
    [ 0.000000] vmalloc : 0xd0800000 - 0xff000000 ( 744 MB)
    [ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
    [ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
    [ 0.000000] .text : 0xc0008000 - 0xc059b000 (5708 kB)
    [ 0.000000] .init : 0xc059b000 - 0xc05d9000 ( 248 kB)
    [ 0.000000] .data : 0xc05da000 - 0xc063ddd0 ( 400 kB)
    [ 0.000000] .bss : 0xc063ddf4 - 0xc066c0ac ( 185 kB)
    [ 0.000000] NR_IRQS:396
    [ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
    [ 0.000000] Total of 128 interrupts on 1 active controller
    [ 0.000000] OMAP clockevent source: GPTIMER2 at 24000000 Hz
    [ 0.000000] OMAP clocksource: GPTIMER1 at 32768 Hz
    [ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms
    [ 0.000000] Console: colour dummy device 80x30
    [ 0.000152] Calibrating delay loop... 718.02 BogoMIPS (lpj=3590144)
    [ 0.058929] pid_max: default: 32768 minimum: 301
    [ 0.059051] Security Framework initialized
    [ 0.059143] Mount-cache hash table entries: 512
    [ 0.059539] Initializing cgroup subsys debug
    [ 0.059539] Initializing cgroup subsys cpuacct
    [ 0.059570] Initializing cgroup subsys memory
    [ 0.059600] Initializing cgroup subsys devices
    [ 0.059631] Initializing cgroup subsys freezer
    [ 0.059631] Initializing cgroup subsys blkio
    [ 0.059692] CPU: Testing write buffer coherency: ok
    [ 0.060546] devtmpfs: initialized
    [ 0.079986] omap_hwmod: pruss: failed to hardreset
    [ 0.081176] print_constraints: dummy:
    [ 0.081542] NET: Registered protocol family 16
    [ 0.083770] OMAP GPIO hardware version 0.1
    [ 0.086273] omap_mux_init: Add partition: #1: core, flags: 0
    [ 0.088500] omap_i2c.1: alias fck already exists
    [ 0.089538] omap2_mcspi.1: alias fck already exists
    [ 0.089782] omap2_mcspi.2: alias fck already exists
    [ 0.089965] omap_init_sham: platform not supported
    [ 0.089996] omap_init_aes: platform not supported
    [ 0.090057] edma.0: alias fck already exists
    [ 0.090087] edma.0: alias fck already exists
    [ 0.090118] edma.0: alias fck already exists
    [ 0.111328] bio: create slab <bio-0> at 0
    [ 0.113555] SCSI subsystem initialized
    [ 0.115264] usbcore: registered new interface driver usbfs
    [ 0.115600] usbcore: registered new interface driver hub
    [ 0.115814] usbcore: registered new device driver usb
    [ 0.115966] musb-ti81xx musb-ti81xx: musb0, board_mode=0x13, plat_mode=0x3
    [ 0.116271] musb-ti81xx musb-ti81xx: musb1, board_mode=0x13, plat_mode=0x1
    [ 0.128997] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz
    [ 0.130065] tps65910 1-002d: could not be detected
    [ 0.132171] Switching to clocksource gp timer
    [ 0.151306] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
    [ 0.151489] musb-hdrc musb-hdrc.0: dma type: pio
    [ 0.151824] MUSB0 controller's USBSS revision = 4ea20800
    [ 0.152526] musb-hdrc musb-hdrc.0: USB OTG mode controller at d083c000 using PIO, IRQ 18
    [ 0.152709] musb-hdrc musb-hdrc.1: dma type: pio
    [ 0.153015] MUSB1 controller's USBSS revision = 4ea20800
    [ 0.153137] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
    [ 0.153228] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
    [ 0.153350] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    [ 0.153350] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 0.153381] usb usb1: Product: MUSB HDRC host driver
    [ 0.153381] usb usb1: Manufacturer: Linux 3.2.0 musb-hcd
    [ 0.153411] usb usb1: SerialNumber: musb-hdrc.1
    [ 0.154357] hub 1-0:1.0: USB hub found
    [ 0.154388] hub 1-0:1.0: 1 port detected
    [ 0.155029] musb-hdrc musb-hdrc.1: USB Host mode controller at d083e800 using PIO, IRQ 19
    [ 0.155456] NET: Registered protocol family 2
    [ 0.155670] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
    [ 0.156066] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
    [ 0.156219] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
    [ 0.156311] TCP: Hash tables configured (established 8192 bind 8192)
    [ 0.156341] TCP reno registered
    [ 0.156341] UDP hash table entries: 256 (order: 0, 4096 bytes)
    [ 0.156372] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
    [ 0.156524] NET: Registered protocol family 1
    [ 0.156829] RPC: Registered named UNIX socket transport module.
    [ 0.156829] RPC: Registered udp transport module.
    [ 0.156860] RPC: Registered tcp transport module.
    [ 0.156860] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [ 0.157073] NetWinder Floating Point Emulator V0.97 (double precision)
    [ 0.169372] VFS: Disk quotas dquot_6.5.2
    [ 0.169433] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [ 0.170623] msgmni has been set to 492
    [ 0.174041] alg: No test for stdrng (krng)
    [ 0.174133] io scheduler noop registered
    [ 0.174163] io scheduler deadline registered
    [ 0.174255] io scheduler cfq registered (default)
    [ 0.175567] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
    [ 0.780944] console [ttyO0] enabled
    [ 0.785369] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
    [ 0.793304] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
    [ 0.801116] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
    [ 0.808990] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
    [ 0.816802] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
    [ 0.834930] brd: module loaded
    [ 0.843658] loop: module loaded
    [ 0.847106] i2c-core: driver [tsl2550] using legacy suspend method
    [ 0.853576] i2c-core: driver [tsl2550] using legacy resume method
    [ 0.860015] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
    [ 0.869781] ID EEPROM: detected.
    [ 0.873168] ID EEPROM: TAG not valid
    [ 0.877777] tps65217 1-0024: TPS65217 ID 0xf version 1.1
    [ 0.885467] print_constraints: DCDC1: 900 <--> 1800 mV at 1800 mV
    [ 0.894073] print_constraints: DCDC2: 900 <--> 3300 mV at 1275 mV
    [ 0.902618] print_constraints: DCDC3: 900 <--> 1500 mV at 1100 mV
    [ 0.911224] print_constraints: LDO1: 1000 <--> 3300 mV at 1800 mV
    [ 0.919799] print_constraints: LDO2: 900 <--> 3300 mV at 3300 mV
    [ 0.928253] print_constraints: LDO3: 1800 <--> 3300 mV at 3300 mV
    [ 0.936798] print_constraints: LDO4: 1800 <--> 3300 mV at 3300 mV
    [ 0.943878] Configure SYSBOOT Enable pin...
    [ 0.948242] Configure NANDBOOT Control pin...
    [ 0.952789] Configure NAND_WPn pin...
    [ 0.957061] omap_hsmmc.0: alias fck already exists
    [ 0.964263] omap-gpmc omap-gpmc: GPMC revision 6.0
    [ 0.969268] Registering NAND on CS0
    [ 0.973663] d_can.0: alias fck already exists
    [ 0.979461] at24 1-0051: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
    [ 0.987609] BOOT EEPROM: detected.
    [ 0.993469] mtdoops: mtd device (mtddev=name/number) must be supplied
    [ 1.000366] m25p80 spi1.0: w25q128 (16384 Kbytes)
    [ 1.005554] Creating 10 MTD partitions on "spi_flash":
    [ 1.010925] 0x000000000000-0x000000080000 : "SPL/MLO(Golden,RO)"
    [ 1.018859] 0x000000080000-0x000000100000 : "U-Boot (Golden,RO)"
    [ 1.026641] 0x000000100000-0x000000500000 : "Kernel (Golden,RO)"
    [ 1.034393] 0x000000500000-0x000000580000 : "U-Boot (Bank-A)"
    [ 1.041839] 0x000000580000-0x000000600000 : "U-Boot (Bank-B)"
    [ 1.049591] 0x000000600000-0x000000680000 : "U-Boot Env (Bank-A)"
    [ 1.057434] 0x000000680000-0x000000700000 : "U-Boot Env (Bank-B)"
    [ 1.065185] 0x000000700000-0x000000b00000 : "Kernel (Bank-A)"
    [ 1.072570] 0x000000b00000-0x000000f00000 : "Kernel (Bank-B)"
    [ 1.080047] 0x000000f00000-0x000001000000 : "Reserved (not used)"
    [ 1.088043] m25p80 spi2.0: w25q128 (16384 Kbytes)
    [ 1.093231] Creating 1 MTD partitions on "spi_flash":
    [ 1.098510] 0x000000000000-0x000001000000 : "RAMDISK"
    [ 1.105865] omap2-nand driver initializing
    [ 1.110534] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xcc (Micron NAND 512MiB 3,3V 16-bit)
    [ 1.119567] chipsize = 512 MB, writesize = 2048, busw = 2, oobsize = 64, erasesize = 131072
    [ 1.128295] >>> chip->ecc.mode = 2, mtd->oobsize = 64
    [ 1.133789] Creating 2 MTD partitions on "omap2-nand.0":
    [ 1.139312] 0x000000000000-0x000010000000 : "UBIFS (Bank-A)"
    [ 1.253234] 0x000010000000-0x000020000000 : "UBIFS (Bank-B)"
    [ 1.367187] OneNAND driver initializing
    [ 1.372711] CAN device driver interface
    [ 1.376770] CAN bus driver for Bosch D_CAN controller 1.0
    [ 1.383270] d_can d_can.0: device registered (irq=52, irq_obj=53)
    [ 1.432830] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
    [ 1.439270] davinci_mdio davinci_mdio.0: detected phy mask fffffffc
    [ 1.447113] davinci_mdio.0: probed
    [ 1.450683] davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver SMSC LAN8710/LAN8720
    [ 1.459228] davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver SMSC LAN8710/LAN8720
    [ 1.468109] usbcore: registered new interface driver zd1201
    [ 1.474121] usbcore: registered new interface driver cdc_ether
    [ 1.480377] usbcore: registered new interface driver cdc_eem
    [ 1.486450] usbcore: registered new interface driver dm9601
    [ 1.492279] cdc_ncm: 04-Aug-2011
    [ 1.495819] usbcore: registered new interface driver cdc_ncm
    [ 1.501708] Initializing USB Mass Storage driver...
    [ 1.507049] usbcore: registered new interface driver usb-storage
    [ 1.513305] USB Mass Storage support registered.
    [ 1.518310] gadget: Mass Storage Function, version: 2009/09/11
    [ 1.524505] gadget: Number of LUNs=1
    [ 1.528320] lun0: LUN: removable file: (no medium)
    [ 1.533447] gadget: Mass Storage Gadget, version: 2009/09/11
    [ 1.539428] gadget: userspace failed to provide iSerialNumber
    [ 1.545532] gadget: g_mass_storage ready
    [ 1.549713] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
    [ 1.555297] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 2
    [ 1.563140] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
    [ 1.570220] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 1.577758] usb usb2: Product: MUSB HDRC host driver
    [ 1.582946] usb usb2: Manufacturer: Linux 3.2.0 musb-hcd
    [ 1.588470] usb usb2: SerialNumber: musb-hdrc.0
    [ 1.594177] hub 2-0:1.0: USB hub found
    [ 1.598114] hub 2-0:1.0: 1 port detected
    [ 1.603515] mousedev: PS/2 mouse device common for all mice
    [ 1.610565] omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
    [ 1.617279] omap_rtc: already running
    [ 1.621276] i2c /dev entries driver
    [ 1.627502] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    [ 1.635284] cpuidle: using governor ladder
    [ 1.640045] cpuidle: using governor menu
    [ 1.647460] omap_sham_mod_init: loading omap-sham driver
    [ 1.653015] omap_sham_mod_init: Unsupported cpu
    [ 1.657745] omap_aes_mod_init: loading omap-aes driver
    [ 1.663116] omap_aes_mod_init: Unsupported cpu
    [ 1.670501] usbcore: registered new interface driver usbhid
    [ 1.676361] usbhid: USB HID core driver
    [ 1.680358] oprofile: hardware counters not available
    [ 1.685638] oprofile: using timer interrupt.
    [ 1.690246] Netfilter messages via NETLINK v0.30.
    [ 1.695281] nf_conntrack version 0.5.0 (3941 buckets, 15764 max)
    [ 1.701782] ctnetlink v0.93: registering with nfnetlink.
    [ 1.707550] ip_tables: (C) 2000-2006 Netfilter Core Team
    [ 1.713226] TCP cubic registered
    [ 1.716583] Initializing XFRM netlink socket
    [ 1.721191] NET: Registered protocol family 10
    [ 1.726593] Mobile IPv6
    [ 1.729187] ip6_tables: (C) 2000-2006 Netfilter Core Team
    [ 1.735107] IPv6 over IPv4 tunneling driver
    [ 1.741363] NET: Registered protocol family 17
    [ 1.746063] can: controller area network core (rev 20090105 abi 8)
    [ 1.752655] NET: Registered protocol family 29
    [ 1.757324] can: raw protocol (rev 20090105)
    [ 1.761779] can: broadcast manager protocol (rev 20090105 t)
    [ 1.767730] Registering the dns_resolver key type
    [ 1.772705] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
    [ 1.780700] ThumbEE CPU extension supported.
    [ 1.785217] mux: Failed to setup hwmod io irq -22
    [ 1.790802] Power Management for AM33XX family
    [ 1.795654] Trying to load am335x-pm-firmware.bin (60 secs timeout)
    [ 1.802307] Copied the M3 firmware to UMEM
    [ 1.810150] clock: disabling unused clocks to save power
    [ 1.821166] Detected MACID=0:18:31:89:59:bf
    [ 1.827575] omap_rtc omap_rtc: setting system clock to 2000-01-01 01:25:20 UTC (946689920)
    [ 1.839294] net eth0: CPSW phy found : id is : 0x7c0f1
    [ 1.845855] net eth0: CPSW phy found : id is : 0x7c0f1
    [ 1.852691] ADDRCONF(NETDEV_UP): eth0: link is not ready
    [ 1.883819] mmc0: host does not support reading read-only switch. assuming write-enable.
    [ 1.894775] mmc0: new high speed SDHC card at address 1234
    [ 1.901214] mmcblk0: mmc0:1234 SA04G 3.63 GiB
    [ 1.908386] mmcblk0: p1 p2
    [ 3.834014] PHY: 0:01 - Link is Up - 0/Half
    [ 3.844024] PHY: 0:01 - Link is Down
    [ 4.833984] PHY: 0:00 - Link is Up - 100/Full
    [ 4.853576] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [ 4.873657] Sending DHCP requests ., OK
    [ 6.013916] IP-Config: Got DHCP answer from 192.168.6.1, my address is 192.168.6.18
    [ 6.022125] IP-Config: Complete:
    [ 6.025512] device=eth0, addr=192.168.6.18, mask=255.255.255.0, gw=192.168.6.1,
    [ 6.033325] host=192.168.6.18, domain=, nis-domain=(none),
    [ 6.039489] bootserver=192.168.6.1, rootserver=192.168.6.168, rootpath=
    [ 6.064544] VFS: Mounted root (nfs filesystem) on device 0:15.
    [ 6.071014] devtmpfs: mounted
    [ 6.074493] Freeing init memory: 248K
    [ 6.288116] systemd[1]: systemd 37 running in system mode. (+PAM +LIBWRAP -AUDIT -SELINUX +SYSVINIT -LIBCRYPTSETUP; angstrom)
    Welcome to [1;35mThe Ångström Distribution[0m!
    [ 6.324981] systemd[1]: Set hostname to <MPU-001>.
    Starting Runtime Directory...
    Starting Media Directory...
    Starting Remount API VFS...
    Starting Lock Directory...
    Starting Debug File System...
    Starting POSIX Message Queue File System...
    Started Load Kernel Modules [[1;32m OK [0m]
    Started FUSE Control File System [[1;32m OK [0m]
    Started Set Up Additional Binary Formats [[1;32m OK [0m]
    Started Configuration File System [[1;32m OK [0m]
    Starting udev Coldplug all Devices...
    Starting udev Kernel Device Manager...
    Started Syslog Kernel Log Buffer Bridge [[1;32m OK [0m]
    Starting File System Check on Root Device...
    [ 6.852325] udevd[651]: starting version 175
    Started Huge Pages File System [[1;32m OK [0m]
    Starting Security File System...
    Started Apply Kernel Variables [[1;32m OK [0m]
    Started udev Kernel Device Manager [[1;32m OK [0m]
    Started Runtime Directory [[1;32m OK [0m]
    Started Media Directory [[1;32m OK [0m]
    Started Remount API VFS [[1;32m OK [0m]
    Started Lock Directory [[1;32m OK [0m]
    Started Debug File System [[1;32m OK [0m]
    Started POSIX Message Queue File System [[1;32m OK [0m]
    Started File System Check on Root Device [[1;32m OK [0m]
    Started Security File System [[1;32m OK [0m]
    Starting Remount Root FS...
    Starting STDOUT Syslog Bridge...
    Started STDOUT Syslog Bridge [[1;32m OK [0m]
    Started Remount Root FS [[1;32m OK [0m]
    Started Opkg first boot configure [[1;32m OK [0m]
    Starting /tmp...
    Started Machine ID first boot configure [[1;32m OK [0m]
    Started /tmp [[1;32m OK [0m]
    Starting Recreate Volatile Files and Directories...
    Starting Load Random Seed...
    Started Load Random Seed [[1;32m OK [0m]
    Started Recreate Volatile Files and Directories [[1;32m OK [0m]
    Started SSH Key Generation [[1;32m OK [0m]
    Starting System Logging Service...
    Starting Login Service...
    Starting Permit User Sessions...
    Starting D-Bus System Message Bus...
    Starting Avahi mDNS/DNS-SD Stack...
    Started Permit User Sessions [[1;32m OK [0m]
    Stopping Syslog Kernel Log Buffer Bridge...
    Stopped Syslog Kernel Log Buffer Bridge [[1;32m OK [0m]
    Started System Logging Service [[1;32m OK [0m]
    Started D-Bus System Message Bus [[1;32m OK [0m]
    Started Avahi mDNS/DNS-SD Stack [[1;32m OK [0m]
    Started Login Service [[1;32m OK [0m]
    Started udev Coldplug all Devices [[1;32m OK [0m]
    Starting Serial Getty on ttyO0...
    Started Serial Getty on ttyO0 [[1;32m OK [0m]
    Starting Boot Status Update Daemon...
    Started Boot Status Update Daemon [[1;32m OK [0m]
    [ 9.439270] systemd[1]: Startup finished in 6s 334ms 911us (kernel) + 3s 100ms 372us (userspace) = 9s 435ms 283us.
    .---O---.
    | | .-. o o
    | | | __ | ---'| '--.| .-'| | |
    The Angstrom Distribution MPU-001 ttyO0
    Angstrom v2012.01-core - Kernel 3.2.0
    MPU-001 login: root
    Password:
    Last login: Sat Jan 1 01:21:01 GMT 2000 on ttyO0
    root@MPU-001:~# nandtest -m -p 1 -o 0 -l 0x100000 /dev/mtd12
    ECC corrections: 0
    ECC failures : 0
    Bad blocks : 0
    BBT blocks : 0
    00000000: erasing... 00000000: writing... 00000000: reading... 00000000: checking... 00020000: erasing... 00020000: writing... 00020000: reading... 00020000: checking... 00040000: erasing... 00040000: writing... 00040000: reading... 00040000: checking... 00060000: erasing... 00060000: writing... 00060000: reading... 00060000: checking... 00080000: erasing... 00080000: writing... 00080000: reading... 00080000: checking... 000a0000: erasing... 000a0000: writing... 000a0000: reading... 000a0000: checking... 000c0000: erasing... 000c0000: writing... 000c0000: reading... 000c0000: checking... 000e0000: erasing... 000e0000: writing... 000e0000: reading... 000e0000: checking...
    Stopped Login Service [[1;32m OK [0m]
    Stopped Serial Getty on ttyO0 [[1;32m OK [0m]
    Stopped Avahi mDNS/DNS-SD Stack [[1;32m OK [0m]
    Stopped System Logging Service [[1;32m OK [0m]
    [ 33.900054] avahi-daemon[867]: Got SIGTERM, quitting.
    Stopped D-Bus System Message Bus [[1;32m[ 33.914093] avahi-daemon[867]: Leaving mDNS multicast group on interface eth0.IPv4 with address 192.168.6.18.
    OK [0m]
    [ 33.926269] avahi-daemon[867]: avahi-daemon 0.6.30 exiting.
    Started Save Random Seed [[1;32m OK [0m]
    Stopped Permit User Sessions [[1;32m OK [0m]
    Stopping /tmp...
    [ 34.103271] umount[1295]: umount: /var/run: device is busy.
    [ 34.123107] umount[1295]: (In some cases useful info about processes that use
    Stopped /tmp [[1;32m OK [0m]
    [ 34.169281] umount[1295]: the device is found by lsof(8) or fuser(1))
    [ 34.176910] systemd[1]: var-run.mount mount process exited, code=exited status=1
    Stopped Runtime Directory [[1;32m OK [0m]
    Stopped Media Directory [[1;32m OK [0m]
    Stopped Lock Directory [[1;32m OK [0m]
    Stopped Remount API VFS [[1;32m OK [0m]
    Stopped Remount Root FS [[1;32m OK [0m]
    [ 34.382385] systemd[1]: Shutting down.
    [ 34.442474] systemd-cgroups-agent[1305]: Failed to get D-Bus connection: Failed to connect to socket /org/freedesktop/systemd1/private: Connection refused
    Unmounted /var/run.
    Disabling swaps.
    Detachin[ 34.495666] musb-hdrc musb-hdrc.1: remove, state 1
    g loop devices. [ 34.500762] usb usb1: USB disconnect, device number 1
    Detaching DM de[ 34.508270] musb-hdrc musb-hdrc.1: USB bus 1 deregistered
    vices.
    [ 34.514770] Restarting system.
    ==[SPI][0B]==
    I2C: ready
    DRAM: 256 MiB
    512 MiB
    MMC: OMAP SD/MMC: 0
    ==[SPI][0B]==
    Net: cpsw
    Page 100e0000 dump:
    a9 d0 56 e7 a0 e7 28 a2 47 12 c0 40 78 15 9c 89
    e5 d1 d4 36 f1 db cc 09 46 b7 a9 d2 ef de 11 98
    ae 67 7f 4e 4f a7 f1 96 b9 b1 d6 31 c7 73 bb ac
    44 8f e2 35 6a ae 3e b1 66 e7 83 55 c5 94 ed 74
    fc 6c c2 4b 13 b3 e1 cc 65 b8 fe 2c 2b b9 d8 6f
    48 bb a4 b3 69 e2 64 cf c9 e7 24 8f 7c 11 03 78
    7d c5 c3 90 79 a4 5d de 5c 5b 0a 87 14 e2 f6 5c
    9d 9a 0f 07 7c 73 d6 46 5b fb d5 d7 0c d8 4f 8a
    9d 12 1a 16 b6 77 f4 13 d2 fe 9a e6 e1 91 43 7e
    2b 52 85 a8 c6 5c ee 21 57 c3 f8 63 9b 47 ed 38
    59 08 4f 0f 7f 43 22 52 42 bd 38 23 4e 7b a1 79
    ce 27 21 94 83 0f b5 da d2 ad 3d 6d f4 2b a6 4d
    33 f5 5c b2 38 7f 04 7a 3c 3d 9d 8a b8 3f 03 86
    66 25 1a e9 34 cf c3 07 7c 00 74 70 2b 1a bd 5e
    0f 1a 11 48 99 15 c2 d5 52 60 5f 0b 9f 62 91 05
    87 ac ee bc 7b b1 c3 f8 b1 37 68 dd 52 26 3b 61
    40 4c a9 d9 62 6c ae b4 cc 0d bf 6b 6f 51 70 f7
    fd 5e b3 78 0f 76 70 c0 ad d9 9d ff ff d9 61 3f
    25 0a 18 87 76 c6 3c 42 d3 fb ad 42 4c 1d 39 49
    7b ec c2 8a 62 32 4b 10 0b e8 0f 0a c1 70 49 e7
    7b 61 6e f1 27 aa 34 fa a6 e1 3d f2 ff 76 3c 7a
    63 fe 05 c5 30 50 d5 3c 38 e5 46 fa 55 90 e1 d0
    f1 4f c2 19 fa f6 13 a0 d7 50 92 d6 c7 ce 51 2a
    cc 56 ef fd a6 c5 39 de aa 7f d8 ff 0f b9 d0 01
    09 92 1a 03 88 2d a3 5f 7e 35 36 45 04 87 6f d0
    dd 5e cd 83 23 06 61 cd 86 3a cd 95 f3 9d 96 fc
    2f b0 ff b7 de a2 16 5c d8 4c a1 dc d3 10 ac b0
    6e 7a 33 92 80 95 5f 06 cf 2c 9c c2 c9 32 bf f8
    e3 be af c1 61 c6 1d 39 12 be 15 e6 ce c1 96 3c
    3b ca ce bc 5f 2e c2 2e 5a 5e f0 24 91 af 1c 74
    6e cc 35 cf 92 52 08 a4 10 1d 8a de de 21 1a 1a
    eb e9 d6 4a 17 98 78 71 f7 68 95 88 18 b2 fc 86
    7e 31 55 10 83 5d b4 93 7a 3f 71 58 60 8b 72 4b
    74 48 95 8b e1 0d fd d8 75 92 60 8d 44 5c 13 c2
    8d 68 d2 10 c5 87 a3 3f c6 14 98 26 9f 0a 71 14
    53 06 9f 34 13 9c 0c 88 2f 6c 16 73 c8 29 36 55
    92 08 65 57 8f 08 97 55 1c 2f 7b bb 39 ec cf 8c
    f2 6f c0 05 0b cc 8e 3a 38 a4 ae 00 cd e4 55 5f
    ec ba b7 7c c2 4e d1 de 7d 4d 9a b6 39 69 43 2c
    d8 03 31 e4 d0 bf 1e 08 63 cc 09 31 b0 5e 90 9d
    19 47 19 db 95 ea ba 12 37 54 c9 71 bd 0c 9d 96
    0f ce 7a df 8e 98 e8 f1 65 f1 22 15 4f b3 b2 68
    fa cb 44 90 b6 fe a2 ed 52 6b 5e 0f 77 fb a5 87
    ca 1f 66 58 b8 4e 49 1d 3f 6c 32 8f 1f e5 f7 19
    b0 3b a9 66 39 4c 54 8b b7 b2 9b 2f ae 40 b6 78
    60 1c d0 18 6b 19 35 aa 85 67 39 a4 4c 31 be fd
    6c 67 63 a6 b3 b7 31 6b 6a cc 9a 18 0d 50 90 6d
    6c 60 85 d7 79 ba 82 ff 21 bb a3 6e ec 61 6b 59
    c9 ce ff 7c 86 30 e7 f0 fd 81 08 0a d1 98 77 3e
    f8 fc 15 71 b6 97 70 d7 53 14 45 3f 75 b0 98 3e
    7f 97 bb 05 c8 a2 f5 c5 24 fd cf f5 95 46 33 8d
    42 49 fe f8 e0 6f cf 33 83 15 73 f8 c5 0b 37 44
    a3 f2 49 6b 94 3e 30 b8 3b ff ae d0 45 e1 5d 87
    2a 5c 7f 0b cb 4e 3e 4e 63 b1 46 29 bd 7d 6d 60
    6f b7 cb 04 f5 fb bc 31 fa 6a 01 3f 4c 5f c6 76
    bb 45 81 86 93 c0 d4 f7 71 1a 20 2e 98 8d 8e 07
    44 59 0b 3a 54 c8 6b 4e 32 6c 8d 7e cb 53 f5 86
    98 76 0c 2c 36 e0 23 a8 fb 43 d6 93 d0 65 9a 15
    be a6 4f 13 6e ba 61 a0 26 ef 1f f2 42 14 78 db
    8a 85 07 c1 65 2a 69 60 6d 3f f3 3d a4 8e 52 63
    34 a1 76 a2 5b d7 42 82 c6 61 74 09 75 ec e4 00
    71 eb c1 d7 15 2a 37 82 69 2b bf 0e b9 12 71 ed
    b3 e7 8f 0f be d1 91 85 33 05 8e a8 f1 72 a8 63
    5d 69 3a 72 93 71 f4 fd 9c b3 0b 55 c5 7c 42 79
    63 d1 88 21 a3 19 a6 d6 1e 34 7e 0f a6 27 72 03
    90 ac 75 24 1e 69 21 ba 1d 2c 10 e2 a8 52 5b 0b
    24 e3 2c c7 fc d3 9d 1a 07 1b 2a ae 42 9c b1 d3
    49 27 f7 67 90 18 21 ad 44 31 90 ec 84 eb f7 a8
    cf 23 6f cb f6 0c e6 fe 27 10 ac 6a ac 5d 3d f5
    84 34 5c 15 4c 7e c2 90 af 52 7c 33 3e 73 db 0d
    96 4a d8 8d 56 be 8b 7e ce 37 e8 7b 94 25 70 19
    59 cd 2e a5 4b f0 35 fa 43 b1 2e 81 24 09 8e ba
    54 66 47 aa 25 d2 28 f3 09 10 6e 9e 35 df b7 8e
    ac e5 33 f7 d5 68 f1 18 19 1f 99 3d 29 27 f8 7d
    8e 3f 27 b3 12 50 a6 1b 60 15 b9 96 f4 70 24 a0
    55 58 97 2b c0 88 43 da a8 dd 17 d1 04 0f 4e 92
    4f 75 45 61 c5 ec 7c 26 01 36 bc f5 a6 e0 95 fc
    38 2c 27 f9 b4 6a d3 5c 47 ea 2d 4c fa 7b de 49
    f1 24 aa b6 10 26 dc 11 5c 98 06 03 79 9b ff b1
    c7 26 aa 7b 90 7d d8 d8 68 05 24 62 81 02 ab 72
    26 55 28 36 7b 05 47 d8 9d 4d db 16 e8 da c8 af
    00 72 2b 90 f0 03 68 58 08 8c ba 89 8f 65 fb b5
    ba 24 ec 35 29 33 0d c6 81 e8 dd 69 c2 a5 19 c2
    17 44 53 07 47 bb 5f 4f 48 19 d9 d7 7e d4 8c 38
    f8 78 6e 21 ac 7b e8 2d 64 c5 96 26 6a af e9 81
    f3 3c 89 3a f7 e8 8a 3f 02 63 16 80 37 a3 b9 30
    1b 27 51 c7 a2 39 f4 06 fe 8b 2d 68 3a 16 ea 2e
    52 73 68 49 5b f2 89 5d 55 9f de 8d 42 97 bd 5e
    be 0e 25 60 48 1a 67 46 a5 94 af df aa 99 0d fc
    0c 76 45 67 68 ce c5 be 6e a3 4b b0 3a 08 0e f8
    16 34 58 5e 4e bf a5 f3 53 54 d2 fd ed e0 f9 f9
    56 3f 60 be 0d 25 7c 7b c8 c7 2c 02 cf 3a fa e6
    6e 53 44 bc 12 e9 af 66 3d 82 63 2a 62 5d 23 b8
    9c 84 76 a9 a9 f3 25 72 ba 51 74 8a 8b 6f 70 fa
    c2 b4 b6 d4 9e 66 3a db e8 9e 06 4a fb 29 02 97
    ad 78 40 57 6b 65 c9 26 b6 3d b0 42 ac 20 3c 6e
    d4 f2 43 72 58 7d 4e 40 1b 54 8a 16 7d 8c ad 2b
    05 ee 82 70 53 4b 96 0a 88 46 4c 35 66 88 a3 3b
    7a e6 ad d3 64 fb 13 7f 4f 9e 96 cd 2a 43 f8 2f
    31 7a a0 85 c5 36 8f 4d 7d db 82 e3 63 26 1e dd
    0c cc b0 70 c7 c4 f0 17 62 86 e4 8c c9 dc bc fb
    56 5c 80 1b 92 0f 68 0f ea eb f3 4d 11 11 2a 1d
    dd db 8e a5 9f 7e bc 01 04 a0 8d cd 7c 49 c8 d2
    a5 48 ed 38 57 55 47 41 40 3a 8e 51 4c b9 6f 29
    94 fd ce 33 7b 8a 34 7f 2a c1 4c a6 0b 15 78 b0
    5d 65 e8 b5 bb 30 f6 fb 6a 85 4d b6 3e bc e0 d2
    b9 ae 05 34 39 39 b3 63 fa ff 0a 05 14 82 b6 72
    e8 9e 27 a3 ce 1d 9e 39 a2 eb ef e0 a7 cf b2 60
    7e b7 94 b7 f0 47 1a eb 47 24 f0 5b a7 a6 cd 8f
    45 f4 32 13 12 d0 4c b4 bc 3c 95 63 0b 47 c4 89
    ff 58 40 ef a0 5b da e7 7f cb 42 26 71 10 b5 b6
    04 e7 ca 16 b8 16 cb 74 52 60 d7 5e a7 9b e7 a6
    f4 28 96 94 83 70 7b 02 3b bd 29 ad cd de 63 d2
    c6 2d e8 7e 44 b3 f2 96 13 c9 f4 bb 65 dc 61 59
    04 f7 ed 87 68 68 89 a3 25 b2 50 f3 91 b4 c5 57
    e1 ad d5 25 61 c7 bc 74 90 b0 2f f5 8c 91 4e 90
    88 3b 17 f0 a3 a1 94 c9 53 e4 bc e4 98 81 3b 7a
    2e 10 9f 8f d7 5b 04 68 0c 33 5d 98 c4 ac 29 4d
    e7 40 3d 8b e1 d1 54 35 b6 10 19 4e 91 55 c8 bf
    65 68 4f 3d c3 53 a5 cf 86 02 68 4b ae 91 98 96
    d1 d5 21 b3 a7 75 e8 5d 85 01 ab 16 56 74 d5 bc
    dc 24 f9 9f 77 9e 6f fe a0 d7 49 4f 68 e1 e5 39
    b6 06 ec 5d 7b d4 ba 00 d6 66 16 2c da eb e8 b6
    10 e1 55 87 7f c4 85 20 9b ce 6f 03 af 54 3d 66
    5a 29 c3 d5 fe 7e d5 d4 e4 eb 00 be d6 e9 74 e6
    ca c9 6e 4a 8e f3 6a 29 c2 d9 2d 71 2d 6a d7 87
    93 9b 5c 91 19 31 65 fd 1c 66 bb f2 4f 2f d9 19
    f8 47 63 86 3a cd b0 fc a6 dd 6e d3 47 45 5a da
    OOB:
    ff ff a7 93 00 a5 3c 4c
    86 38 0b 52 ab 66 22 00
    31 a8 fc 0e a1 c2 00 3d
    1e 8e a5 d9 bb 00 0c a5
    d7 bc 4c 27 f1 8b 01 ef
    c7 d8 89 00 9b 1a 75 23
    3b 95 b8 c2 76 86 88 21
    78 00 ff ff ff ff ff ff
    MPU-001# nand bad
    10000000
    10020000
    10040000
    10060000
    10080000
    100a0000
    100c0000
    100e0000
    MPU-001#
    MPU-001#
  • Frisky,
    Can you do another experiment? Can you try writing one 2K data(random data ) to the page after erasing and send me the dump?
  • Hi Renjith,
    This is my test log in u-boot:
    I2C: ready
    DRAM: 256 MiB
    512 MiB
    MMC: OMAP SD/MMC: 0
    ==[SPI][0B]==
    Net: cpsw
    OK
    Erasing at 0x100e0000 -- 100% complete.
    OK
    Page 100e0000 dump:
    OOB:
    MPU-001# print updspiubootg
    updspiubootg=echo Upgrading u-boot(G) on SPI FLASH ...; tftpboot ${loadaddr} ${ubootbinfile}; run sf_probe_bootdev; sf erase ${spi_uboot_golden_addr} +${filesize}; sf write ${loadaddr} ${spi_uboot_golden_addr} ${filesize};
    MPU-001# run netauto
    BOOTP broadcast 1
    MPU-001# tftpboot ${loadaddr} ${ubootbinfile}
    Using cpsw device
    Filename 'u-boot.bin'.
    Load address: 0x82000000
    Loading: ####################################################
    done
    Bytes transferred = 265032 (40b48 hex)
    MPU-001# nand
    nand - NAND sub-system
    Usage:
    nand info - show available NAND devices
    nand device [dev] - show or set current device
    nand read - addr off|partition size
    nand write - addr off|partition size
    read/write 'size' bytes starting at offset 'off'
    to/from memory address 'addr', skipping bad blocks.
    nand erase[.spread] [clean] off size - erase 'size' bytes from offset 'off'
    With '.spread', erase enough for given file size, otherwise,
    'size' includes skipped bad blocks.
    nand erase.part [clean] partition - erase entire mtd partition'
    nand erase.chip [clean] - erase entire chip'
    nand bad - show bad blocks
    nand dump[.oob] off - dump page
    nand scrub off size | scrub.part partition | scrub.chip
    really clean NAND erasing bad blocks (UNSAFE)
    nand markbad off [...] - mark bad block(s) at offset (UNSAFE)
    nand biterr off - make a bit error at offset (UNSAFE)
    MPU-001# nand write 82000000 100e0000 800
    NAND write: device 0 offset 0x100e0000, size 0x800
    2048 bytes written: OK
    Page 100e0000 dump:
    14 00 00 ea 14 f0 9f e5 14 f0 9f e5 14 f0 9f e5
    14 f0 9f e5 14 f0 9f e5 14 f0 9f e5 14 f0 9f e5
    a0 01 10 80 00 02 10 80 60 02 10 80 c0 02 10 80
    20 03 10 80 80 03 10 80 e0 03 10 80 78 56 34 12
    00 00 10 80 f8 aa 03 00 f8 aa 03 00 34 18 07 00
    48 0b 04 00 de c0 ad 0b c8 01 00 eb 00 00 0f e1
    1f 00 c0 e3 d3 00 80 e3 00 f0 29 e1 b4 d3 9f e5
    07 d0 cd e3 00 00 a0 e3 7e 04 00 eb 00 40 a0 e1
    01 50 a0 e1 02 60 a0 e1 04 d0 a0 e1 94 00 4f e2
    06 00 50 e1 00 90 a0 03 26 00 00 0a 06 10 a0 e1
    60 30 1f e5 03 20 80 e0 00 06 b0 e8 00 06 a1 e8
    02 00 50 e1 fb ff ff 3a 80 00 1f e5 00 90 46 e0
    6c a0 9f e5 00 a0 8a e0 5c 20 9f e5 00 20 82 e0
    58 30 9f e5 00 30 83 e0 00 00 92 e5 09 00 80 e0
    04 10 92 e5 ff 70 01 e2 17 00 57 e3 07 00 00 0a
    02 00 57 e3 00 00 00 0a 06 00 00 ea 21 12 a0 e1
    01 10 8a e0 04 10 91 e5 09 10 81 e0 01 00 00 ea
    00 10 90 e5 09 10 81 e0 00 10 80 e5 08 20 82 e2
    03 00 52 e1 eb ff ff 3a 02 00 00 ea f8 aa 03 00
    88 0a 04 00 88 0a 04 00 fc 00 1f e5 f8 10 1f e5
    06 40 a0 e1 04 00 80 e0 04 10 81 e0 00 20 a0 e3
    00 20 80 e5 04 00 80 e2 01 00 50 e1 fb ff ff 1a
    15 0f 07 ee 9a 0f 07 ee 95 0f 07 ee 14 00 9f e5
    5e 1f 4f e2 01 e0 80 e0 09 e0 8e e0 05 00 a0 e1
    06 10 a0 e1 0e f0 a0 e1 54 11 00 00 00 00 a0 e1
    00 00 a0 e1 00 00 a0 e1 00 00 a0 e1 00 00 a0 e1
    54 d1 1f e5 00 e0 8d e5 00 e0 4f e1 04 e0 8d e5
    13 d0 a0 e3 0d f0 69 e1 0f e0 a0 e1 0e f0 b0 e1
    48 d0 4d e2 ff 1f 8d e8 7c 21 1f e5 0c 00 92 e8
    48 00 8d e2 34 50 8d e2 0e 10 a0 e1 0f 00 85 e8
    0d 00 a0 e1 9b 05 00 eb 00 00 a0 e1 00 00 a0 e1
    04 d0 4d e2 00 00 8d e5 bc 01 1f e5 00 e0 80 e5
    00 00 4f e1 04 e0 80 e5 00 00 9d e5 04 d0 8d e2
    48 d0 4d e2 ff 1f 8d e8 dc 21 1f e5 0c 00 92 e8
    0d 00 a0 e1 8c 05 00 eb 00 00 a0 e1 00 00 a0 e1
    14 d2 1f e5 00 e0 8d e5 00 e0 4f e1 04 e0 8d e5
    48 d0 4d e2 ff 1f 8d e8 3c 22 1f e5 0c 00 92 e8
    0d 00 a0 e1 7d 05 00 eb 00 00 a0 e1 00 00 a0 e1
    74 d2 1f e5 00 e0 8d e5 00 e0 4f e1 04 e0 8d e5
    48 d0 4d e2 ff 1f 8d e8 9c 22 1f e5 0c 00 92 e8
    0d 00 a0 e1 6e 05 00 eb 00 00 a0 e1 00 00 a0 e1
    d4 d2 1f e5 00 e0 8d e5 00 e0 4f e1 04 e0 8d e5
    48 d0 4d e2 ff 1f 8d e8 fc 22 1f e5 0c 00 92 e8
    0d 00 a0 e1 5f 05 00 eb 00 00 a0 e1 00 00 a0 e1
    34 d3 1f e5 00 e0 8d e5 00 e0 4f e1 04 e0 8d e5
    48 d0 4d e2 ff 1f 8d e8 5c 23 1f e5 0c 00 92 e8
    0d 00 a0 e1 59 05 00 eb 00 00 a0 e1 00 00 a0 e1
    94 d3 1f e5 00 e0 8d e5 00 e0 4f e1 04 e0 8d e5
    48 d0 4d e2 ff 1f 8d e8 bc 23 1f e5 0c 00 92 e8
    0d 00 a0 e1 38 05 00 eb 80 b7 30 40 00 00 a0 e1
    f3 4e 2d e9 30 1f 30 ee 00 30 a0 e3 04 10 8d e5
    03 c0 a0 e1 03 50 a0 e1 04 10 9d e5 31 23 a0 e1
    07 20 02 e2 02 20 42 e2 02 00 52 e3 2d 00 00 8a
    8c 40 a0 e1 10 4f 40 ee 10 1f 30 ee b8 20 9f e5
    b8 70 9f e5 02 20 01 e0 a2 21 a0 e1 07 60 01 e2
    07 70 01 e0 01 90 82 e2 04 60 86 e2 a7 76 a0 e1
    09 10 a0 e1 00 a0 e0 e3 a1 10 b0 e1 01 a0 8a e2
    fc ff ff 1a 02 00 19 e1 01 a0 8a 12 01 00 50 e3
    20 a0 6a e2 0a 00 00 1a 12 ba 84 e1 07 10 a0 e1
    04 90 a0 e1 11 46 8b e1 56 4f 07 ee 01 10 51 e2
    fb ff ff 2a 01 20 52 e2 09 40 a0 e1 f5 ff ff 2a
    0b 00 00 ea 02 00 50 e3 0a 00 00 1a 12 ba 84 e1
    07 10 a0 e1 04 90 a0 e1 11 46 8b e1 5e 4f 07 ee
    01 10 51 e2 fb ff ff 2a 01 20 52 e2 09 40 a0 e1
    f5 ff ff 2a 9a 5f 07 ee 12 00 53 e3 01 c0 8c e2
    03 30 83 12 c7 ff ff 1a fc 8e bd e8 f8 1f 00 00
    00 e0 ff 0f f8 40 2d e9 00 40 a0 e1 01 60 a0 e1
    10 5f 30 ee 07 50 05 e2 04 50 85 e2 01 30 a0 e3
    03 00 52 e3 13 55 a0 e1 09 00 00 0a 04 00 52 e3
    00 30 65 02 00 40 03 00 1d 00 00 1a 01 00 00 ea
    3e 4f 07 ee 05 40 84 e0 06 00 54 e1 fb ff ff 3a
    17 00 00 ea 01 70 45 e2 00 00 17 e1 07 00 00 0a
    04 20 a0 e1 54 00 9f e5 54 10 9f e5 01 40 44 e2
    84 23 00 eb 05 40 84 e0 00 30 65 e2 04 40 03 e0
    06 00 17 e1 08 00 00 0a 06 20 a0 e1 34 00 9f e5
    2c 10 9f e5 7b 23 00 eb 00 30 65 e2 03 60 06 e0
    01 00 00 ea 36 4f 07 ee 05 40 84 e0 06 00 54 e1
    fb ff ff 3a 00 30 a0 e3 9a 3f 07 ee f8 80 bd e8
    d6 f3 12 80 8f f3 12 80 09 f4 12 80 10 40 2d e9
    01 00 a0 e3 89 ff ff eb 10 40 bd e8 2b 00 00 ea
    10 40 2d e9 02 00 a0 e3 84 ff ff eb 10 40 bd e8
    25 00 00 ea 70 40 2d e9 03 20 a0 e3 00 50 a0 e1
    01 40 a0 e1 be ff ff eb 05 00 a0 e1 04 10 a0 e1
    70 40 bd e8 1f 00 00 ea 70 40 2d e9 04 20 a0 e3
    00 50 a0 e1 01 40 a0 e1 b5 ff ff eb 05 00 a0 e1
    04 10 a0 e1 70 40 bd e8 15 00 00 ea 08 40 2d e9
    0f 00 00 eb e0 ff ff eb 00 30 a0 e3 17 3f 08 ee
    16 3f 08 ee 15 3f 08 ee 9a 3f 07 ee 95 3f 07 ee
    08 80 bd e8 00 10 81 e0 ea ff ff ea 00 30 a0 e3
    15 3f 07 ee d5 3f 07 ee 9a 3f 07 ee 95 3f 07 ee
    1e ff 2f e1 1e ff 2f e1 1e ff 2f e1 1e ff 2f e1
    08 40 2d e9 05 04 00 eb ec 03 00 eb ee ff ff eb
    f3 03 00 eb c4 ff ff eb 00 00 a0 e3 08 80 bd e8
    01 00 50 e2 fd ff ff 1a 1e ff 2f e1 01 c0 a0 e3
    10 40 2d e9 1c c2 a0 e1 00 40 90 e5 01 c0 4c e2
    1c c1 c4 e1 13 11 8c e1 00 10 80 e5 10 80 bd e8
    10 40 2d e9 00 c0 a0 e3 00 40 92 e5 00 40 04 e0
    01 00 54 e1 04 00 00 0a 01 c0 8c e2 03 00 5c e1
    f8 ff ff 1a 00 00 a0 e3 10 80 bd e8 01 00 a0 e3
    10 80 bd e8 0c 10 9f e5 0c 30 9f e5 00 30 81 e5
    00 00 a0 e1 fe ff ff ea 00 0f e0 44 01 00 00 00
    30 20 9f e5 00 00 52 e1 09 00 00 ca 28 20 9f e5
    00 00 52 e1 06 00 00 ba 00 00 50 e3 04 00 00 0a
    18 10 9f e5 00 00 81 e5 0a 20 d0 e5 0c 30 9f e5
    0a 20 c3 e5 1e ff 2f e1 00 40 30 40 00 e0 30 40
    ac 7d 13 80 38 40 2d e9 2c 30 9f e5 00 40 a0 e3
    00 40 83 e5 2b 20 a0 e3 08 20 03 e5 04 00 13 e5
    08 50 a0 e1 14 10 9f e5 2f a5 00 eb 30 00 85 e5
    20 40 88 e5 04 00 a0 e1 38 80 bd e8 40 00 04 48
    OOB:
    ff ff bd 95 da b7 04 de
    70 e1 6c ef 5e 20 17 00
    4d 6c 7f 71 24 87 6b e9
    4c 18 20 df 51 00 ab f4
    02 b9 d4 ed 0d d8 7d 17
    5a b5 10 00 4f 6a 28 42
    8d e0 9d 40 0d c8 36 4a
    a7 00 ff ff ff ff ff ff
    MPU-001# nand bad
    Device 0 bad blocks:
    MPU-001# md 82000000
    82000000: ea000014 e59ff014 e59ff014 e59ff014 ................
    82000010: e59ff014 e59ff014 e59ff014 e59ff014 ................
    82000020: 801001a0 80100200 80100260 801002c0 ........`.......
    82000030: 80100320 80100380 801003e0 12345678 ...........xV4.
    82000040: 80100000 0003aaf8 0003aaf8 00071834 ............4...
    82000050: 00040b48 0badc0de eb0001c8 e10f0000 H...............
    82000060: e3c0001f e38000d3 e129f000 e59fd3b4 ..........).....
    82000070: e3cdd007 e3a00000 eb00047e e1a04000 ........~....@..
    82000080: e1a05001 e1a06002 e1a0d004 e24f0094 .P...`........O.
    82000090: e1500006 03a09000 0a000026 e1a01006 ..P.....&.......
    820000a0: e51f3060 e0802003 e8b00600 e8a10600 `0... ..........
    820000b0: e1500002 3afffffb e51f0080 e0469000 ..P....:......F.
    820000c0: e59fa06c e08aa000 e59f205c e0822000 l.......\ ... ..
    820000d0: e59f3058 e0833000 e5920000 e0800009 X0...0..........
    820000e0: e5921004 e20170ff e3570017 0a000007 .....p....W.....
    820000f0: e3570002 0a000000 ea000006 e1a01221 ..W.........!...
    MPU-001#
  • Hi Renjith,
    This is the test log (written in linux and dump it in u-boot). It seems that the u-boot has issue when it detects whether the block is bad?
    root@MPU-001:~# flash_erase /dev/mtd12 0 0
    Erasing 128 Kibyte @ ffe0000 -- 100 % complete
    root@MPU-001:~# cat /etc/passwd
    root:x:0:0:root:/root:/bin/sh
    daemon:x:1:1:daemon:/usr/sbin:/bin/sh
    bin:x:2:2:bin:/bin:/bin/sh
    sys:x:3:3:sys:/dev:/bin/sh
    sync:x:4:65534:sync:/bin:/bin/sync
    games:x:5:60:games:/usr/games:/bin/sh
    man:x:6:12:man:/var/cache/man:/bin/sh
    lp:x:7:7:lp:/var/spool/lpd:/bin/sh
    mail:x:8:8:mail:/var/mail:/bin/sh
    news:x:9:9:news:/var/spool/news:/bin/sh
    uucp:x:10:10:uucp:/var/spool/uucp:/bin/sh
    proxy:x:13:13:proxy:/bin:/bin/sh
    www-data:x:33:33:www-data:/var/www:/bin/sh
    backup:x:34:34:backup:/var/backups:/bin/sh
    list:x:38:38:Mailing List Manager:/var/list:/bin/sh
    irc:x:39:39:ircd:/var/run/ircd:/bin/sh
    gnats:x:41:41:Gnats Bug-Reporting System (admin):/var/lib/gnats:/bin/sh
    nobody:x:65534:65534:nobody:/nonexistent:/bin/sh
    messagebus:x:999:997::/var/lib/dbus:/bin/false
    avahi:x:998:996::/var/run/avahi-daemon:/bin/false
    xuser:x:997:995::/home/xuser:/bin/false
    root@MPU-001:~# nandwrite -s 0x000e0000 /dev/mtd12 /etc/passwd -p
    Writing data to block 7 at offset 0xe0000
    Page 100e0000 dump:
    72 6f 6f 74 3a 78 3a 30 3a 30 3a 72 6f 6f 74 3a
    2f 72 6f 6f 74 3a 2f 62 69 6e 2f 73 68 0a 64 61
    65 6d 6f 6e 3a 78 3a 31 3a 31 3a 64 61 65 6d 6f
    6e 3a 2f 75 73 72 2f 73 62 69 6e 3a 2f 62 69 6e
    2f 73 68 0a 62 69 6e 3a 78 3a 32 3a 32 3a 62 69
    6e 3a 2f 62 69 6e 3a 2f 62 69 6e 2f 73 68 0a 73
    79 73 3a 78 3a 33 3a 33 3a 73 79 73 3a 2f 64 65
    76 3a 2f 62 69 6e 2f 73 68 0a 73 79 6e 63 3a 78
    3a 34 3a 36 35 35 33 34 3a 73 79 6e 63 3a 2f 62
    69 6e 3a 2f 62 69 6e 2f 73 79 6e 63 0a 67 61 6d
    65 73 3a 78 3a 35 3a 36 30 3a 67 61 6d 65 73 3a
    2f 75 73 72 2f 67 61 6d 65 73 3a 2f 62 69 6e 2f
    73 68 0a 6d 61 6e 3a 78 3a 36 3a 31 32 3a 6d 61
    6e 3a 2f 76 61 72 2f 63 61 63 68 65 2f 6d 61 6e
    3a 2f 62 69 6e 2f 73 68 0a 6c 70 3a 78 3a 37 3a
    37 3a 6c 70 3a 2f 76 61 72 2f 73 70 6f 6f 6c 2f
    6c 70 64 3a 2f 62 69 6e 2f 73 68 0a 6d 61 69 6c
    3a 78 3a 38 3a 38 3a 6d 61 69 6c 3a 2f 76 61 72
    2f 6d 61 69 6c 3a 2f 62 69 6e 2f 73 68 0a 6e 65
    77 73 3a 78 3a 39 3a 39 3a 6e 65 77 73 3a 2f 76
    61 72 2f 73 70 6f 6f 6c 2f 6e 65 77 73 3a 2f 62
    69 6e 2f 73 68 0a 75 75 63 70 3a 78 3a 31 30 3a
    31 30 3a 75 75 63 70 3a 2f 76 61 72 2f 73 70 6f
    6f 6c 2f 75 75 63 70 3a 2f 62 69 6e 2f 73 68 0a
    70 72 6f 78 79 3a 78 3a 31 33 3a 31 33 3a 70 72
    6f 78 79 3a 2f 62 69 6e 3a 2f 62 69 6e 2f 73 68
    0a 77 77 77 2d 64 61 74 61 3a 78 3a 33 33 3a 33
    33 3a 77 77 77 2d 64 61 74 61 3a 2f 76 61 72 2f
    77 77 77 3a 2f 62 69 6e 2f 73 68 0a 62 61 63 6b
    75 70 3a 78 3a 33 34 3a 33 34 3a 62 61 63 6b 75
    70 3a 2f 76 61 72 2f 62 61 63 6b 75 70 73 3a 2f
    62 69 6e 2f 73 68 0a 6c 69 73 74 3a 78 3a 33 38
    3a 33 38 3a 4d 61 69 6c 69 6e 67 20 4c 69 73 74
    20 4d 61 6e 61 67 65 72 3a 2f 76 61 72 2f 6c 69
    73 74 3a 2f 62 69 6e 2f 73 68 0a 69 72 63 3a 78
    3a 33 39 3a 33 39 3a 69 72 63 64 3a 2f 76 61 72
    2f 72 75 6e 2f 69 72 63 64 3a 2f 62 69 6e 2f 73
    68 0a 67 6e 61 74 73 3a 78 3a 34 31 3a 34 31 3a
    47 6e 61 74 73 20 42 75 67 2d 52 65 70 6f 72 74
    69 6e 67 20 53 79 73 74 65 6d 20 28 61 64 6d 69
    6e 29 3a 2f 76 61 72 2f 6c 69 62 2f 67 6e 61 74
    73 3a 2f 62 69 6e 2f 73 68 0a 6e 6f 62 6f 64 79
    3a 78 3a 36 35 35 33 34 3a 36 35 35 33 34 3a 6e
    6f 62 6f 64 79 3a 2f 6e 6f 6e 65 78 69 73 74 65
    6e 74 3a 2f 62 69 6e 2f 73 68 0a 6d 65 73 73 61
    67 65 62 75 73 3a 78 3a 39 39 39 3a 39 39 37 3a
    3a 2f 76 61 72 2f 6c 69 62 2f 64 62 75 73 3a 2f
    62 69 6e 2f 66 61 6c 73 65 0a 61 76 61 68 69 3a
    78 3a 39 39 38 3a 39 39 36 3a 3a 2f 76 61 72 2f
    72 75 6e 2f 61 76 61 68 69 2d 64 61 65 6d 6f 6e
    3a 2f 62 69 6e 2f 66 61 6c 73 65 0a 78 75 73 65
    72 3a 78 3a 39 39 37 3a 39 39 35 3a 3a 2f 68 6f
    6d 65 2f 78 75 73 65 72 3a 2f 62 69 6e 2f 66 61
    6c 73 65 0a ff ff ff ff ff ff ff ff ff ff ff ff
    OOB:
    ff ff 11 65 13 06 b9 b5
    31 b5 1f e2 c2 32 d7 00
    7d c4 0a 59 96 3d 06 65
    65 85 31 96 02 00 10 ae
    d1 f6 12 6c 65 3d 68 86
    1a db 4a 00 10 ae d1 f6
    12 6c 65 3d 68 86 1a db
    4a 00 ff ff ff ff ff ff
    MPU-001#
    Page 100e0800 dump:
    OOB:
    MPU-001# nand bad
    100e0000
    MPU-001#
  • Renjith,
    After written in Linux, u-boot will show the block is bad!!!
  • Frisky,
    1. Can you erase the page, and mark it as bad using "nand markbad offset" command and do a nand dump?
    2. Can you write the same file from u-boot and kernel and do a nand dump from both send the logs?
  • A quick try for the first test, it seems that the bad flag pos is wrong
    MPU-001# nand markbad 20000
    block 0x00020000 successfully marked as bad
    MPU-001# nand dump 20000
    Page 00020000 dump:
    OOB:
    00 00 ff ff ff ff ff ff
    MPU-001#
  • I've written 4096 bytes into /dev/mtd11 (partition 0,  first 2 pages of block0) in linux, and dump it in u-boot, and found that u-boot says that block 0 is bad. It seems that u-boot considers offset 56 in OOB is the bad block flag, but Linux considers the flag offset is 0? we can conclude this when i run 'nand markbad 0' and see the OOB:(
    MPU-001# nand dump 0
    Page 00000000 dump:
    30 31 32 33 34 35 36 37 38 39 30 31 32 33 34 35
    36 37 38 39 30 31 32 33 34 35 36 37 38 39 30 31
    32 33 34 35 36 37 38 39 30 31 32 33 34 35 36 37
    38 39 30 31 32 33 34 35 36 37 38 39 30 31 32 33
    34 35 36 37 38 39 30 31 32 33 34 35 36 37 38 39
    OOB:
    ff ff 5a 1f 29 21 57 71
    9a a3 d2 3a 06 bc 9a 00
    42 be 3a 12 ae 71 fc 06
    60 a7 dc 3a 40 00 25 25
    b5 62 b5 45 c5 71 ab ca
    98 32 2a 00 a7 10 e5 a0
    46 02 b7 84 04 27 08 54
    a1 00 ff ff ff ff ff ff
    MPU-001# nand dump 800
    Page 00000800 dump:
    OOB:
    ff ff 93 5a 00 9d d2 5f
    df 3c f9 ee 18 7e ba 00
    5a 1f 29 21 57 71 9a a3
    d2 3a 06 bc 9a 00 42 be
    3a 12 ae 71 fc 06 60 a7
    dc 3a 40 00 25 25 b5 62
    b5 45 c5 71 ab ca 98 32
    2a 00 ff ff ff ff ff ff
    MPU-001# nand bad
    00000000
  • Hi Frisky,
    Can you see any error is reporting on reading nand page in Linux.
    You can continue with the above experiment & dump it from Linux using
    nanddump -l 0x1000 /dev/mtd11 -p
    If no errors reported, Linux part is correct.
    Now in U-boot can you check the write size set for nand part.
    Or please confirm how offset 56 is considered for Bad block check.
    -Thanks Avinash
  • Frisky,
    You got it right! Its the position 56 and 57 creating the trouble. I think you might have to change the position info for nand bad block identification in u-boot. Go through the code drivers/mtd/nand/nand_base.c. You'll get it :)
  • Renjith,
    thank you!
    i found that 'nand markbad e0000' will cause nand_write_oob_syndrome() to write the bad block flag. The "pos = steps * (eccsize + chunk);" is set to 0x00000838 (that is, flag will be written in 0x838 - 0x800 and 0x839 - 0x800 ). I'm looking through why it is set to this value.
    static int nand_write_oob_syndrome(struct mtd_info *mtd,
    struct nand_chip *chip, int page)
    int chunk = chip->ecc.bytes + chip->ecc.prepad + chip->ecc.postpad;
    int eccsize = chip->ecc.size, length = mtd->oobsize;
    int i, len, pos, status = 0, sndcmd = 0, steps = chip->ecc.steps;
    const uint8_t *bufpoi = chip->oob_poi;
    printf("nand_write_oob_syndrome mtd->writesize = %08x\n", mtd->writesize);
    * data-ecc-data-ecc ... ecc-oob
    * or
    * data-pad-ecc-pad-data-pad .... ecc-pad-oob
    printf("steps=%d eccsize=%d chunk=%d\n", steps, eccsize, chunk);
    if (!chip->ecc.prepad && !chip->ecc.postpad) {
    steps = 0;
    } else
    pos = eccsize;
  • Frisky,
    Can you print the values of the following variables?
    chip->ecc.bytes
    chip->ecc.prepad (assuming 0)
    chip->ecc.postpad (assuming 0)
    Also change this line
    to
    int chunk = chip->ecc.bytes; and try.
    Ideally bad block markers has to be within the first six (if I remember correctly) bytes. So putting it at 0 and 1 offsets might be more correct.
    Also can you search the NAND datasheet, how the factory bad blocks are marked by the vendor? It might be at 0 and 1 as well. So, if both of them fall at the same place, it will be useful later when you for mass production..
  • Hi Renjith,
    I've printed the values:
    chip->ecc.bytes = 14
    chip->ecc.prepad  = 0
    chip->ecc.postpad = 0
    I've two options to fix the bad block issue, Renjith, which one should I take? :
    Option #1. (nandecc hw 2)
    * __ti81xx_nand_switch_ecc - switch the ECC operation ib/w h/w ecc
    * (i.e. hamming / bch) and s/w ecc.
    * The default is to come up on s/w ecc
    * @nand: NAND chip datastructure
    * @hardware: NAND_ECC_HW -switch to h/w ecc
    * NAND_ECC_SOFT -switch to s/w ecc
    * @mode: 0 - hamming code
    * 1 - bch4
    * 2 - bch8
    * 3 - bch16
    void __ti81xx_nand_switch_ecc(struct nand_chip *nand,
    nand_ecc_modes_t hardware, int32_t mode)
    struct nand_bch_priv *bch;
    bch = nand->priv;
    nand->options |= NAND_OWN_BUFFERS;
    /* Reset ecc interface */
    nand->ecc.read_page = NULL;
    nand->ecc.write_page = NULL;
    nand->ecc.read_oob = NULL;
    nand->ecc.write_oob = NULL;
    nand->ecc.hwctl = NULL;
    nand->ecc.correct = NULL;
    nand->ecc.calculate = NULL;
    nand->ecc.mode = hardware;
    /* Setup the ecc configurations again */
    if (hardware == NAND_ECC_HW) {
    if (mode) {
    bch->mode = NAND_ECC_HW_BCH;
    /* -1 for converting mode to bch type */
    bch->type = mode - 1;
    printf("HW ECC BCH");
    switch (bch->type) {
    case ECC_BCH4:
    nand->ecc.layout = &hw_bch4_nand_oob;
    bch->nibbles = ECC_BCH4_NIBBLES;
    nand->ecc.bytes = 8;
    printf("4 not supported\n");
    goto no_support;
    break;
    case ECC_BCH16:
    nand->ecc.bytes = 26;
    nand->ecc.layout = &hw_bch16_nand_oob;
    bch->nibbles = ECC_BCH16_NIBBLES;
    printf("16 not supported\n");
    goto no_support;
    break;
    case ECC_BCH8:
    default:
    nand->ecc.bytes = 14;
    nand->ecc.layout = &hw_bch8_nand_oob;
    bch->nibbles = ECC_BCH8_NIBBLES;
    printf("8 Selected\n");
    break;
    bch->mode = NAND_ECC_HW;
    nand->ecc.mode = NAND_ECC_HW_SYNDROME;        ///////////////////nand->ecc.mode is being changed again in this function !!!! Remove this line!!!
    nand->ecc.steps = 4;
    nand->ecc.size = 512;
    nand->ecc.total = (nand->ecc.steps * nand->ecc.bytes);
    nand->ecc.write_page = ti81xx_write_page_bch;
    nand->ecc.read_page = ti81xx_read_page_bch;
    nand->ecc.hwctl = ti81xx_enable_ecc_bch;
    nand->ecc.correct = ti81xx_correct_data_bch;
    nand->ecc.calculate = ti81xx_calculate_ecc_bch;
    ti81xx_hwecc_init_bch(nand, NAND_ECC_READ);
    } else {
    nand->ecc.layout = &hw_nand_oob;
    nand->ecc.bytes = 3;
    nand->ecc.hwctl = ti81xx_enable_ecc;
    nand->ecc.correct = ti81xx_correct_data;
    nand->ecc.calculate = ti81xx_calculate_ecc;
    ti81xx_hwecc_init(nand);
    printf("HW ECC Hamming Code selected\n");
    } else if(hardware == NAND_ECC_SOFT) {
    /* Use mtd default settings */
    nand->ecc.layout = NULL;
    printf("SW ECC selected\n");
    } else {
    printf("ECC Disabled\n");
    no_support:
    return;
    Option #2:
    * nand_scan_tail - [NAND Interface] Scan for the NAND device
    * @mtd: MTD device structure
    * This is the second phase of the normal nand_scan() function. It
    * fills out all the uninitialized function pointers with the defaults
    * and scans for a bad block table if appropriate.
    int nand_scan_tail(struct mtd_info *mtd)
    case NAND_ECC_HW_SYNDROME:
    if ((!chip->ecc.calculate || !chip->ecc.correct ||
    !chip->ecc.hwctl) &&
    (!chip->ecc.read_page ||
    chip->ecc.read_page == nand_read_page_hwecc ||
    !chip->ecc.write_page ||
    chip->ecc.write_page == nand_write_page_hwecc)) {
    printk(KERN_WARNING "No ECC functions supplied, "
    "Hardware ECC not possible\n");
    BUG();
    /* Use standard syndrome read/write page function ? */
    if (!chip->ecc.read_page)
    chip->ecc.read_page = nand_read_page_syndrome;
    if (!chip->ecc.write_page)
    chip->ecc.write_page = nand_write_page_syndrome;
    if (!chip->ecc.read_page_raw)
    chip->ecc.read_page_raw = nand_read_page_raw_syndrome;
    if (!chip->ecc.write_page_raw)
    chip->ecc.write_page_raw = nand_write_page_raw_syndrome;
    if (!chip->ecc.read_oob)
    chip->ecc.read_oob = nand_read_oob_std; //chip->ecc.read_oob = nand_read_oob_syndrome;
    if (!chip->ecc.write_oob)
    chip->ecc.write_oob = nand_write_oob_std; //chip->ecc.write_oob = nand_write_oob_syndrome;
    return 0;
  • Frisky,
    I made a mistake in my previous reply. Can you make the following change and try?
    to
    int chunk = 0;
    I'll go through the changes that you've proposed in detail and let you know. Mean while you let me know whether this change works for you or not?
  • Renjith,
    Yes, this works for me:)
  • Cool. I assume all your NAND issues are solved..
