I have several questions as below.(take the TCI6614 for example)
1. When the dsp cores running sys/bios, is each core running a bios entity? I think it will be 4 bios entity, and just share one bios code?
2. About the task scheduling, can the tasks which running on certain core be scheduled to other cores ? Is one task possible running on different cores?
3. Hwi_disable, will it disable the HW interrupt of certain core, or all dsp cores?
4. Can the semaphore be only used between the tasks running on same core, not inter-cores?
5.If I want create the applications independent on each core, will I setup the four ccs projects for each core (TCI6614)?
I'm looking forward to your reply, and thanks in advance.
BR,//Bin
