Other Parts Discussed in Thread: THS7353
Here my log:
root@10.0.1.38:/opt/dm365/encodedecode# ./encodedecode
Encodedecode demo started.
davincifb davincifb.0: check_fb_var: calling convert_fb_var_to_osd, var->bits_per_pixel: 4
davincifb davincifb.0: convert_fb_var_to_osd: bits per pixel: 4
davincifb davincifb.0: davincifb_set_par: calling convert_fb_info_to_osd bpp: 4
davincifb davincifb.0: convert_fb_info_to_osd: var->bits_per_pixel: 4
Division by zero in kernel.
Before finishing with S_FMT:
layer.pix_fmt.bytesperline = 32
layer.pix_fmt.width = 32
layer.pix_fmt.height = 2
layer.pix_fmt.sizeimage =96
pixfmt->width = 32
layer->layer_info.config.line_length = 32
DavinciDisplay DavinciDisplay.1: Not MMAP
ths7353_setvalue -start
ths7353_setvalue -end
i2c_adapter i2c-0: tvp514x_setinput:lost lock]
i2c_adapter i2c-0: tvp514x: no input connected
i2c_adapter i2c-0: Set input failed, err = ffffffed
vpfe ccdc capture vpfe ccdc capture.1: vpfe_doioctl:error in setting input in decoder
Error: Failed to detect video standard, video input connected?
Error: Failed to create video decoder: mpeg4dec
root@10.0.1.38:/opt/dm365/encodedecode# nfs: server 10.0.1.39 not responding, still trying
nfs: server 10.0.1.39 OK
root@10.0.1.38:/opt/dm365/encodedecode# cd ..
root@10.0.1.38:/opt/dm365# ./loadmodules.sh
irqk unregistered
CMEMK module: built on Aug 20 2012 at 14:20:21
Reference Linux version 2.6.18
File /home/Pavlov/dvsdk_2_10_01_18/linuxutils_2_24_02/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
ioremap_nocache(0x85000000, 50331648)=0xd6000000
allocated heap buffer 0xd6000000 of size 0x134000
cmem initialized 20 pools between 0x85000000 and 0x88000000
CMEM Range Overlaps Kernel Physical - allowing overlap
CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x84c00000)
ioremap_nocache(0x1000, 28672)=0xc5070000
no remaining memory for heap, no heap created for memory block 1
cmem initialized 1 pools between 0x1000 and 0x8000
IRQK module: built on Aug 20 2012 at 14:20:41
File /home/Pavlov/dvsdk_2_10_01_18/linuxutils_2_24_02/packages/ti/sdo/linuxutils/irq/src/module/irqk.c
irqk initialized
EDMAK module: built on Aug 20 2012 at 14:21:16
root@10.0.1.38:/opt/dm365/encodedecode# ./encodedecode -v mpeg4 -k
pixfmt->width = 32
Error: Failed toDavinciDisplay DavinciDisplay.1: Not MMAP
detect video stDavinciDisplay DavinciDisplay.1: Not MMAP
andard, video inDavinciDisplay DavinciDisplay.1: Not MMAP
put connected?
create video deDavinciDisplay DavinciDisplay.1: Not MMAP
Command [ 'helpDavinciDisplay DavinciDisplay.1: Not MMAP
' for usage ] > DavinciDisplay DavinciDisplay.1: Not MMAP
Why? I did everything that wrote in mans.. And plug 3 composite video inputs as wrote in Quickstrart quide. Why it can capture video?
