Other Parts Discussed in Thread: CCSTUDIO
using CCS v3.3, trying out tutorial "Developing a simple program" from the Help menu
i can't even compile, and the error message as follows:
---------------------------- volume1.pjt - Debug ----------------------------
[Configuration5.cdb] "C:\CCStudio_v3.3\bios_5_31_02\xdctools\tconf" -b -Dconfig.importPath="C:/CCStudio_v3.3/bios_5_31_02/packages" Configuration5.cdb
js: "./Configuration5.cdb", line 4: missing ; before statement
js: object BIOSREGS :: MEM {
js: ...............^
js: "./Configuration5.cdb", line 5: missing name after :: operator
js: param iComment :: "This object defines space for the BIOS on-chip registers and can't be deleted"
js: ....................................................................................................^
js: "./Configuration5.cdb", line 6: missing name after :: operator
js: param iIsUsed :: 1
js: .....................^
js: "./Configuration5.cdb", line 7: missing name after :: operator
js: param iId :: 0
js: .................^
js: "./Configuration5.cdb", line 8: missing name after :: operator
js: param iDelUser :: "USER"
js: ...........................^
js: "./Configuration5.cdb", line 9: missing name after :: operator
js: param iDelMsg :: "This object defines space for the BIOS on-chip registers and can't be deleted"
js: ...................................................................................................^
js: "./Configuration5.cdb", line 10: missing name after :: operator
js: param base :: 124
js: ....................^
js: "./Configuration5.cdb", line 11: missing name after :: operator
js: param len :: 4
js: "./Configuration5.cdb", line 12: missing name after :: operator
js: param iAllocHeap :: 0
js: ........................^
js: "./Configuration5.cdb", line 13: missing name after :: operator
js: param iHeapSize :: 1024
js: ..........................^
js: "./Configuration5.cdb", line 14: missing name after :: operator
js: param iUserHeapId :: 0
js: .........................^
js: "./Configuration5.cdb", line 15: missing name after :: operator
js: param iHeapId :: @segment_name
js: "./Configuration5.cdb", line 16: missing name after :: operator
js: param iReqHeapCount :: 0
js: "./Configuration5.cdb", line 17: missing name after :: operator
js: param space :: "data"
js: "./Configuration5.cdb", line 18: missing name after :: operator
js: param dynamicLoading :: 0
js: ............................^
js: "./Configuration5.cdb", line 19: missing name after :: operator
js: param iIsModifiable :: 1
js: "./Configuration5.cdb", line 22: missing ; before statement
js: object CSLREGS :: MEM {
js: ..............^
js: "./Configuration5.cdb", line 23: missing name after :: operator
js: param iComment :: "This object defines space for the CSL on-chip registers and can't be deleted"
js: "./Configuration5.cdb", line 24: missing name after :: operator
js: "./Configuration5.cdb", line 25: missing name after :: operator
js: param iId :: 0
js: "./Configuration5.cdb", line 26: missing name after :: operator
js: "./Configuration5.cdb", line 27: missing name after :: operator
js: param iDelMsg :: "This object defines space for the CSL on-chip registers and can't be deleted"
js: ..................................................................................................^
js: "./Configuration5.cdb", line 28: missing name after :: operator
js: param base :: 122
js: "./Configuration5.cdb", line 29: missing name after :: operator
js: param len :: 2
js: "./Configuration5.cdb", line 30: missing name after :: operator
js: "./Configuration5.cdb", line 31: missing name after :: operator
js: "./Configuration5.cdb", line 32: missing name after :: operator
js: "./Configuration5.cdb", line 33: missing name after :: operator
js: "./Configuration5.cdb", line 34: missing name after :: operator
js: "./Configuration5.cdb", line 35: missing name after :: operator
js: "./Configuration5.cdb", line 36: missing name after :: operator
js: "./Configuration5.cdb", line 37: missing name after :: operator
js: ...........................................................................................^
js: "./Configuration5.cdb", line 2770: missing ( before function parameters.
js: param function :: @PRD_F_swi
js: "./Configuration5.cdb", line 1: Compilation produced 2337 syntax errors.
[load.asm] "C:\CCStudio_v3.3\C5400\cgtools\bin\cl500" -g -pdsw225 -fr"C:/CCStudio_v3.3/MyProjects/volume1/Debug" -d"_DEBUG" -@"Debug.lkf" "load.asm"
"load.asm", ERROR! at line 23: [E0002] Invalid mnemonic specification
ADDB SP,#1
"load.asm", ERROR! at line 24: [E0002] Invalid mnemonic specification
CMPB AL,#0 ; |3|
"load.asm", ERROR! at line 25: [E0002] Invalid mnemonic specification
MOV *-SP[1],AL ; |2|
"load.asm", WARNING! at line 26: [W0000] Trailing operands ignored
B L2,EQ ; |3|
"load.asm", ERROR! at line 29: [E0002] Invalid mnemonic specification
DEC *-SP[1] ; |4|
"load.asm", ERROR! at line 30: [E0002] Invalid mnemonic specification
MOV AL,*-SP[1] ; |4|
"load.asm", WARNING! at line 31: [W0000] Trailing operands ignored
B L1,NEQ ; |4|
"load.asm", ERROR! at line 34: [E0004] Not expecting immediate value - Operand
2
SUBB SP,#1
"load.asm", ERROR! at line 35: [E0002] Invalid mnemonic specification
LRETR
7 Assembly Errors, 2 Assembly Warnings
Errors in Source - Assembler Aborted
>> Compilation failure
[vectors.asm] "C:\CCStudio_v3.3\C5400\cgtools\bin\cl500" -g -pdsw225 -fr"C:/CCStudio_v3.3/MyProjects/volume1/Debug" -d"_DEBUG" -@"Debug.lkf" "vectors.asm"
[volume.c] "C:\CCStudio_v3.3\C5400\cgtools\bin\cl500" -g -pdsw225 -fr"C:/CCStudio_v3.3/MyProjects/volume1/Debug" -d"_DEBUG" -@"Debug.lkf" "volume.c"
Build Complete,
2345 Errors, 2Warnings, 0 Remarks.
please help me. why is it so hard :(
