[dm8168] Run dvrrdk_03.00.00.00 mcfw VCAP + VENC + VDEC + VDIS demo, get error message
Other Parts Discussed in Thread: TVP5158
Hi all
   When run the VCAP + VENC + VDEC + VDIS demo, got the following error message:
12276: MSGQ: MsgQ Ack get from [VIDEO-M3] failed for link 33, cmdId 0x5004 !!! (retrying - 998 times)
 13276: MSGQ: MsgQ Ack get from [VIDEO-M3] failed for link 33, cmdId 0x5004 !!! (retrying - 997 times)
 14276: MSGQ: MsgQ Ack get from [VIDEO-M3] failed for link 33, cmdId 0x5004 !!! (retrying - 996 times)
 15277: MSGQ: MsgQ Ack get from [VIDEO-M3] failed for link 33, cmdId 0x5004 !!! (retrying - 995 times)
 16276: MSGQ: MsgQ Ack get from [VIDEO-M3] failed for link 33, cmdId 0x5004 !!! (retrying - 994 times)
 17276: MSGQ: MsgQ Ack get from [VIDEO-M3] failed for link 33, cmdId 0x5004 !!! (retrying - 993 times)
 18276: MSGQ: MsgQ Ack get from [VIDEO-M3] failed for link 33, cmdId 0x5004 !!! (retrying - 992 times)
 19276: MSGQ: MsgQ Ack get from [VIDEO-M3] failed for link 33, cmdId 0x5004 !!! (retrying - 991 times)
 20276: MSGQ: MsgQ Ack get from [VIDEO-M3] failed for link 33, cmdId 0x5004 !!! (retrying - 990 times)
e 21276: MSGQ: MsgQ Ack get from [VIDEO-M3] failed for link 33, cmdId 0x5004 !!! (retrying - 989 times)
 How to fix the problem?
 Thanks in advance!
 Eric
  • Hi Eric,
    Could you share the complete log (right from point where kernel boot completes). It looks like either video-M3 is not initialized or M3-video has hit an issue.
    Sujith
  • Hi Sujith
    root@dvr:/opt/dvr_rdk/ti816x# ./init.sh ; ./load.sh [J
    *** Bootargs Validated for mem param ***
    *** Bootargs Validated for notifyk.vpssm3 params ***
    Kernel bootargs validated
    numid=101,iface=MIXER,name='Left DAC Mux'
      ; type=ENUMERATED,access=rw------,values=1,items=3
      ; Item #0 'DAC_L1'
      ; Item #1 'DAC_L3'
      ; Item #2 'DAC_L2'
      : values=2
    numid=99,iface=MIXER,name='Right DAC Mux'
      ; Item #0 'DAC_R1'
      ; Item #1 'DAC_R3'
      ; Item #2 'DAC_R2'
      : values=2
     [c6xdsp ] RemotDebug Shared Memory @ 0xbf000000
     [m3video] Remote Debug Shared Memory @ 0xbf005020
     [m3vpss ] Remote Debug Shared Memory @ 0xbf00a040
    SysLink version : 2.10.02.17
    SysLink module created on Date:Aug 21 2012 Time:12:13:42
    Trace enabled
    Trace SetFailureReason enabled
     Setting DMM priority for [DUCATI  ] to [0] ( 0x4e000624 = 0x08000000 )
     Setting DMM priority for [HDVICP0 ] to [2] ( 0x4e000634 = 0x0000000a )
     Setting DMM priority for [HDVICP1 ] to [2] ( 0x4e000634 = 0x000a0000 )
     Setting DMM priority for [HDVICP2 ] to [2] ( 0x4e000634 = 0x00a00000 )
     *** TVP5158 probe : START ***
     TI VS EVM : TVP5158 device address : 0x58, 0x5a, 0x5c, 0x5e
     TI DVR    : TVP5158 device address : 0x5c, 0x5d, 0x5e, 0x5f
     Device found     : I2C (0xXX): 0x08 = 0x51
                        I2C (0xXX): 0x09 = 0x58
     Device NOT found : I2C (0xXX): Read ERROR !!! (reg[0x08], count = 2)
     I2C (0x58): Read ERROR !!! (reg[0x08], count = 2)
     I2C (0x5a): Read ERROR !!! (reg[0x08], count = 2)
     I2C (0x5c): 0x08 = 0x51
     I2C (0x5c): 0x09 = 0x58
     I2C (0x5d): 0x08 = 0x51
     I2C (0x5d): 0x09 = 0x58
     I2C (0x5e): 0x08 = 0x51
     I2C (0x5e): 0x09 = 0x58
     I2C (0x5f): 0x08 = 0x51
     I2C (0x5f): 0x09 = 0x58
     *** TVP5158 probe : END ***
    /opt/dvr_rdk/ti816x
    Attached to slave procId 2.
    Loaded file ../firmware/dvr_rdk_fw_m3vpss.xem3 on slave procId 2.
    Started slave procId 2.
    After Ipc_loadcallback status [0x00000000]
     [m3vpss ] ***** SYSTEM  : Frequency <ORG> - 250000000, <NEW> - 280000000
     [m3vpss ] notify_attach  rtnVal  0
     [m3vpss ] initProxyServer  rtnVal  0
     [m3vpss ]
     [m3vpss ]  *** UTILS: CPU KHz = 560000 Khz ***
     [m3vpss ]
     [m3vpss ]  42: SYSTEM  : System Common Init in progress !!!
     [m3vpss ]  42: SYSTEM: IPC init in progress !!!
     [m3vpss ]  42: SYSTEM: Attaching to [HOST] ...
     [m3vpss ]  1042: SYSTEM: Attaching to [HOST] ...
     [m3vpss ]  1043: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
     [m3vpss ]  1043: SYSTEM: Attaching to [DSP] ...
    After Ipc_startcallback status [0x097d2000]
    Attached to slave procId 1.
    Loaded file ../firmware/dvr_rdk_fw_m3video.xem3 on slave procId 1.
    Started slave procId 1.
     [m3video] ***** SYSTEM  : Frequency <ORG> - 250000000, <NEW> - 280000000
     [m3vpss ]  2043: SYSTEM: Attaching to [DSP] ...
     [m3video]
     [m3video]  *** UTILS: CPU KHz = 560000 Khz ***
     [m3video]
     [m3video]  1265: SYSTEM  : System Common Init in progress !!!
     [m3video]  1265: SYSTEM: IPC init in progress !!!
     [m3video]  1265: SYSTEM: Attaching to [HOST] ...
     [m3video]  2265: SYSTEM: Attaching to [HOST] ...
     [m3video]  2267: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
     [m3video]  2267: SYSTEM: Attaching to [DSP] ...
    After Ipc_startcallback status [0x00000000]
    Attached to slave procId 0.
    Loaded file ../firmware/dvr_rdk_fw_c6xdsp.xe674 on slave procId 0.
    Started slave procId 0.
     [c6xdsp ] ***** SYSTEM  : Frequency <ORG> - 800000000, <NEW> - 800000000
     [c6xdsp ]
     [c6xdsp ]  *** UTILS: CPU KHz = 800000 Khz ***
     [c6xdsp ]
     [c6xdsp ]  5: SYSTEM  : System Common Init in progress !!!
     [c6xdsp ]  5: SYSTEM: IPC init in progress !!!
     [c6xdsp ]  5: SYSTEM: Attaching to [HOST] ...
     [c6xdsp ]  8: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
     [c6xdsp ]  8: SYSTEM: Attaching to [VIDEO-M3] ...
    DMA: Module install successful, device major num = 251
    DRV: Module install successful
    DRV: Module built on Sep 13 2012 14:00:53
     [c6xdsp ] Remote Debug Shared Memory @ 0xbf000000
     [m3vpss ]  3043: SYSTEM: Attaching to [DSP] ...
     [c6xdsp ]  1031: SYSTEM: Attaching to [VIDEO-M3] ...
     [m3video]  3267: SYSTEM: Attaching to [DSP] ...
     [m3vpss ]  4043: SYSTEM: Attaching to [DSP] ...
     [c6xdsp ]  2055: SYSTEM: Attaching to [VIDEO-M3] ...
     [c6xdsp ]  2188: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
     [m3video]  4267: SYSTEM: Attaching to [DSP] ...
     [c6xdsp ]  2188: SYSTEM: Attaching to [VPSS-M3] ...
     [m3video]  4267: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
     [m3video]  4267: SYSTEM: Attaching to [VPSS-M3] ...
     [m3vpss ]  5043: SYSTEM: Attaching to [DSP] ...
     [c6xdsp ]  3211: SYSTEM: Attaching to [VPSS-M3] ...
     [m3video]  5267: SYSTEM: Attaching to [VPSS-M3] ...
     [c6xdsp ]  4236: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
     [m3vpss ]  6043: SYSTEM: Attaching to [DSP] ...
     [c6xdsp ]  4236: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
     [m3vpss ]  6043: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
     [m3vpss ]  6043: SYSTEM: Attaching to [VIDEO-M3] ...
     [m3video]  6267: SYSTEM: Attaching to [VPSS-M3] ...
     [c6xdsp ]  5259: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
     [m3video]  7043: SYSTEM: AttachSS-M3] ... SUCCESS !!!
     [m3vpss ]  7043: SYSTEM: Attaching to [VIDEO-M3] ...
     [m3video]  7043: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
     [m3vpss ]  7043: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
     [m3video]  7044: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
     [m3vpss ]  7043: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
     [m3video]  7044: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
     [m3vpss ]  7043: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
     [m3video]  7045: SYSTEM: Notify register to [HOST] line 0, event 15 ...
     [m3vpss ]  7044: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
     [m3vpss ]  7045: SYSTEM: Notify register to [HOST] line 0, event 15 ...
     [m3vpss ]  7045: SYSTEM: Notify register to [DSP] line 0, event 15 ...
     [m3video]  7045: SYSTEM: Notify register to [DSP] line 0, event 15 ...
     [m3vpss ]  7046: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
     [m3video]  7046: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
     [m3vpss ]  7046: SYSTEM: IPC init DONE !!!
     [m3video]  7046: SYSTEM: IPC init DONE !!!
     [m3vpss ]  7051: MEM: Shared Region 2: Base = 0b000 Leng0x0e9 (233 MB)
     [m3video]  7051: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e9c0000 (233 MB)
     [m3vpss ]  7051: MEM: Shared Region 1: Base = 0x90000000, Length = 0x0d000000 (208 MB)
     [m3video]  7052: MEM: Shared Region 1: Base = 0x90000000, Length = 0x0d000000 (208 MB)
     [m3vpss ]  7053: SYSTEM  : System Common Init Done !!!
     [m3video]  7053: SYSTEM  : System Common Init Done !!!
     [m3vpss ]  7053: SYSTEM  : System VPSS Init in progress !!!
     [m3video]  7053: SYSTEM  : System Video Init in progress !!!
     [m3video]  7053: SYSTEM  : System Video Init Done !!!
     [m3video]  7054: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
     [m3video]  7054: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
     [m3video]  7054: SYSTEM: ListElem Shared Addr = 0xbf18b680
     [m3video]  7056: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
     [m3vpss ] === HDVPSS Clocks are enabled ===
     [m3video]  7056: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
     [m3vpss ] === HDVPSS is fully functional ===
     [m3video]  7056: SYSTEM: ListElem Shared Addr = 0xbf18eb80
     [m3vpss ] === HDVPSS module is not in standby ===
     [m3video]  7061: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_19] in region 0 ...
     [m3vpss ] === I2C1 Clk is active ===
     [m3video]  7061: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_19] in region 0 ...
     [m3vpss ]  7059: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
     [m3video]  7062: SYSTEM: ListElem Shared Addr = 0xbf195880
     [m3vpss ]  7059: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
     [m3video]  7064: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_20] in region 0 ...
     [m3vpss ]  7060: SYSTEM: ListElem Shared Addr = 0xbf192080
     [m3vpss ]  7061: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
     [m3vpss ]  7062: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
     [m3vpss ]  7062: SYSTEM: ListElem Shared Addr = 0xbf1b4f80
     [m3video]  7064: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_20] in region 0 ...
     [m3vpss ]  7072: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_19] in region 0 ...
     [m3video]  7064: SYSTEM: ListElem Shared Addr = 0xbf1b8480
     [m3vpss ]  7073: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_19] in region 0 ...
     [m3video]  7066: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_21] in region 0 ...
     [m3video]  7066: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_21] in region 0 ...
     [m3video]  7066: SYSTEM: ListElem Shared Addr = 0xbf1d7e80
     [m3vpss ]  7073: SYSTEM: ListElem Shared Addr = 0xbf1f7880
     [m3video]  7076: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_24] in region 0 ...
     [m3vpss ]  7075: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_20] in region 0 ...
     [m3video]  7077: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_24] in region 0 ...
     [m3vpss ]  7075: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_20] in region 0 ...
     [m3video]  7077: SYSTEM: ListElem Shared Addr = 0xbf236c80
     [m3vpss ]  7075: SYSTEM: ListElem Shared Addr = 0xbf217280
     [m3video]  7079: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_25] in region 0 ...
     [m3vpss ]  7077: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_21] in region 0 ...
     [m3video]  7079: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_25] in region 0 ...
     [m3vpss ]  7077: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_21] in region 0 ...
     [m3video]  7079: SYSTEM: ListElem Shared Addr = 0xbf274180
     [m3vpss ]  7077: SYSTEM: ListElem Shared Addr = 0xbf254780
     [m3video]  7081: HDVICP: Doing PRCM for IVAHD[0] ...
     [m3vpss ]  7079: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
     [m3video]  7086: HDVICP: WARNING: RM_IVAHD_RSTST Timed OUT [0x7]
     [m3vpss ]  7079: SYSTEM  : FVID2 Init in progress !!!
     [m3video]  7086: HDVICP: PRCM for IVAHD[0] ... DONE.
     [m3vpss ]  7161: SYSTEM  : FVID2 Init in progress DONE !!!
     [m3video]  7086: HDVICP: Doing PRCM for IVAHD[1] ...
     [m3vpss ]  7161: SYSTEM  : Device Init in progress !!!
     [m3video]  7092: HDVICP: WARNING: RM_IVAHD_RSTST Timed OUT [0x7]
     [m3video]  7092: HDVICP: PRCM for IVAHD[1] ... DONE.
     [m3vpss ] initPrms.isI2cInitReq = 0
     [m3video]  7092: HDVICP: Doing PRCM for IVAHD[2] ...
     [m3video]  7097: HDVICP: WARNING: RM_IVAHD_RSTST Timed OUT [0x7]
     [m3video]  7097: HDVICP: PRCM for IVAHD[2] ... DONE.
     [m3vpss ]  7164: SYSTEM  : Device Init in progress DONE !!!
     [m3video]  7098: SYSTEM  : Initializing Links !!!
     [m3vpss ]  7282: SYSTEM  : System VPSS Init Done !!!
     [m3vpss ]  7283: UTILS: DMA: HWI Create for INT63 !!!
     [m3video]  7098: SYSTEM  : FREE SPACE : System Heap      = 6280232 B, Mbx = 10240 msgs)
     [m3vpss ]  7283: SYSTEM  : Initializing Links !!!
     [m3video]  7098: SYSTEM  : FREE SPACE : SR0 Heap         = 14084480 B (13 MB)
     [m3vpss ]  7283: SYSTEM  : FREE SPACE : System Heap      = 13024 B, Mbx = 10240 msgs)
     [m3vpss ] Received character 's'
     [m3video]  7098: SYSTEM  : FREE SPACE : Frame Buffer     = 245104512 B (233 MB)
     [m3vpss ]  7283: SYSTEM  : FREE SPACE : SR0 Heap         = 14084480 B (13 MB)
     [m3video] Received character 's'
     [m3video]  7098: SYSTEM  : FREE SPACE : Bitstream Buffer = 218103680 B (207 MB)
     [m3vpss ]  7283: SYSTEM  : FREE SPACE : Frame Buffer     = 240794496 B (229 MB)
     [m3video]  7098: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
     [m3vpss ]  7283: SYSTEM  : FREE SPACE : Bitstream Buffer = 218103680 B (207 MB)
     [m3video]  7099: SYSTEM  : FREE SPACE : Tiler 8-bit      = 134217728 B (128 MB)  - TILER ON
     [m3vpss ]  7283: SYSTEM  : FREE SPACE : Tiler 8-bit      = 134217728 B (128 MB)  - TILER ON
     [m3video]  7099: SYSTEM  : FREE SPACE : Tiler 16-bit     = 134217728 B (128 MB)  - TILER ON
     [m3vpss ]  7283: SYSTEM  : FREE SPACE : Tiler 16-bit     = 134217728 B (128 MB)  - TILER ON
     [m3video]  7128: SYSTEM  : Initializing Links ... DONE !!!
     [m3vpss ]  7380: SYSTEM  : Initializing Links ... DONE !!!
     [m3vpss ]  7380: SYSTEM  : Set Static L3 pressure for HDVPSS as High
     [c6xdsp ]  6282: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
     [c6xdsp ]  6283: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
     [c6xdsp ]  6283: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
     [c6xdsp ]  6283: SYSTEM: Notify register to [HOST] line 0, event 15 ...
     [c6xdsp ]  6283: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
     [c6xdsp ]  6283: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
     [c6xdsp ]  6283: SYSTEM: IPC init DONE !!!
     [c6xdsp ]  6285: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e9c0000 (233 MB)
     [c6xdsp ]  6285: MEM: Shared Region 1: Base = 0x90000000, Length = 0x0d000000 (208 MB)
     [c6xdsp ]  6286: SYSTEM  : System Common Init Done !!!
     [c6x[module] vpss probe done.
    dsp ]  6135: SYSTEM  : System DSP Init in progress !!!
     [c6xdsp ]  6135: SYSTEM  : RpeServer_init() done... Ret Val 0!!!
     [c6xdsp ]  6288: SYSTEM: Creating ListMP [DSP_IPC_OUT_19] in region 0 ...
     [c6xdsp ]  6289: SYSTEM: Creating ListMP [DSP_IPC_IN_19] in region 0 ...
     [c6xdsp ]  6289: SYSTEM: ListElem Shared Addr = 0xbf291c80
     [c6xdsp ]  6289: SYSTEM: Creatin[module] ti81xxfb probe done.
    g ListMP [DSP_IPC_OUT_20] in region 0 ...
     [c6xdsp ]  6289: SYSTEM: Creating ListMP [DSP_IPC_IN_20] in region 0 ...
     [c6xdsp ]  6289: SYSTEM: ListElem Shared Addr = 0xbf2b1680
     [c6xdsp ]  6290: SYSTEM: Creating ListMP [DSP_IPC_OUT_21] in region 0 ...
     HDMI W1 rev 2.0
    [c6xdsp ]  6290: SYSTEM: Creating ListMP [DSP_IPC_IN_21] in regi[module] ti81xx_hdmi probe done.
    on 0 ...
     [c6xdsp ]  6290: SYSTEM: ListElem Shared Addr = 0xbf2d1080
     [c6xdsp ]  6291: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
     [c6xdsp ]  6291: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
     [c6xdsp ]  6291: SYSTEM: ListElem Shared Addr = 0xbf2f0a80
     [c6xdsp ]  6292: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
     [c6xdsp ]  6292: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
     [c6xdsp ]  6292: SYSTEM: ListElem Shared Addr = 0xbf30e580
     [c6xdsp ] !!WARNING.Resource already registered:2
     [c6xdsp ]  6141: SYSTEM  : Initializing Links !!!
     [c6xdsp ] Received character 's'
    /opt/dvr_rdk/ti816x
     [c6xdsp ]  6292: SYSTEM  : FREE SPACE : System Heap      = 10268448 B, Mbx = 10240 msgs)
     [c6xdsp ]  6150: SYSTEM  : Initializing Links ... DONE !!!
     [c6xdsp ]  6150: SYSTEM  : System DSP Init Done !!!
    I2C No Ack
     ORG 0x46c00524: 0
     NEW 0x46c00524: 2
    root@dvr:/opt/dvr_rdk/ti816x# ./r
    root@dvr:/opt/dvr_rdk/ti816x# ./run[J.[6D
    root@dvr:/opt/dvr_rdk/ti816x# ./run.sh [J
     Main Menu
     1: VCAP + VENC + VDEC + VDIS  - Progressive SD Encode + Decode
     2: VCAP + VENC        + VDIS  - SD Encode ONLY
     3: VCAP + VENC        + VDIS  - HD Encode ONLY
     4:               VDEC + VDIS  - SD/HD Decode ONLY
     5: VCAP               + VDIS  - NO Encode or Decode
     a: 16CH Hybrid DVR usecase
     b: 36CH Hybrid enc usecase
     c: 4CH Car DVR usecase
     e: Exit
     Enter Choice: 1
    --------------- CHANNEL DETAILS-------------
    Capture Channels => 16
    Enc Channels => Primary 16, Secondary 16
    Dec Channels => 16
    Disp Channels => 32
     0: SYSTEM: System Common Init in progress !!!
     0: SYSTEM: IPC init in progress !!!
     12: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
     13: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
     14: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
     16: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
     16: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
     17: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
     18: SYSTEM: Notify register to [DSP] line 0, event 15 ...
     18: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
     18: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
     19: SYSTEM: IPC init DONE !!!
     20: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
     22: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
     23: SYSTEM: ListElem Shared Addr = 0x2b18e080
     24: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
     26: SYSTEM: Creating List [HOST_IPC_IN_25] in region 0 ...
     28: SYSTEM: ListElem Shared Addr = 0x2b1abb80
     29: SYSTEM: Creating ListMP [HOST_IPC_OUT_19] in region 0 ...
     31: SYSTEM: Creating ListMP [HOST_IPC_IN_19] in region 0 ...
     33: SYSTEM: ListElem Shared Addr = 0x2b1c9680
     33: SYSTEM: Creating ListMP [HOST_IPC_OUT_20] in region 0 ...
     35: SYSTEM: Creating ListMP [HOST_IPC_IN_20] in region 0 ...
     37: SYSTEM: ListElem Shared Addr = 0x2b1e9080
     38: SYSTEM: Creating ListMP [HOST_IPC_OUT_21] in region 0 ...
     40: SYSTEM: Creating ListMP [HOST_IPC_IN_21] in region 0 ...
     41: SYSTEM: ListElem Shared Addr = 0x2b208a80
     60: SYSTEM: System Common Init Done !!!
     86: MSGQ: MsgQ get failed !!!
     Enable file write (YES - y / NO - n) : n
     File write DISABLED !!!
     [host] MCFW_IPCBITS:VcapVencVdecVdis_ipcBitsSendFxn:Entered... [FBDEV]
     [FBDEV] FB: Starting !!!
     [FBDEV] FB: Opened device [/dev/fb0] (fd=22) !!!
     [FBDEV]
     [FBDEV] Fix Screen Info
     [FBDEV] ---------------
     [FBDEV] Line Length - 2560
     [FBDEV] Physical Address = 8ce00000
     [FBDEV] Buffer Length = 8294400
     [FBDEV]
     [FBDEV]
     [FBDEV] Var Screen Info
     [FBDEV] Xres - 1280
     [FBDEV] Yres - 720
     [FBDEV] Xres Virtual - 1280
     [FBDEual - its Per Pixel - 16
     [FBDEV] Pixel Clk - 6734
     [FBDEV] Rotation - 0
     [FBDEV]
     [FBDEV]
     [FBDEV] Reg Params Info
     [FBDEV] region 0, postion 0 x 0, prioirty 1
     [FBDEV] first 1, last 1
     [FBDEV] sc en 0, sten en 0
     [FBDEV] tran en 0, type 0, key 0
     [FBDEV] blend 0, alpha 0
     [FBDEV] bb en 0, alpha 0
     [FBDEV]
     [FBDEV]
     [FBDEV] ### BUF SIZE = 1843200 Bytes !!!
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV] Xres - 1280
     [FBDEV] Yres - 720
     [FBDEV] Yres Virtual - 720
     [FBDEV] Bits Per Pixel - 16
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV] grpx_fb_draw ...
     [FBDEV] grpx_fb_draw ... Done !!!
     [FBDEV] FB: Start DONE !!!
     [FBDEV]
     [host]
     Enable SCD block Motion Tracking On Display (Only On ON-CHIP HDMI)
     Enable Motion Tracking On Display (YES - y / NO - n) : n
     Motion Tracking DISABLED !!!
    ********* Entered usecase 16CH Progressive <816x> Cap/Enc/Dec/Dis
     2339: MCFW  : CPU Revision [ES1.1] !!!
     2339: MCFW  : Detected [(null)] Board !!!
     2339: MCFW  : Base Board Revision [DVR] !!!
     2339: MCFW  : Daughter Card Revision [DVR] !!!
     VCAP: TVP5158-0 (0x5c): Detected video (720x288@50Hz, 1) !!!
     VCAP: TVP5158-1 (0x5d):  NO Video Detected !!!
     VCAP: TVP5158-2 (0x5e):  NO Video Detected !!!
     VCAP: TVP5158-3 (0x5f):  NO Video Detected !!!
     TVP5158: 0x5c: Downloading patch ...
     TVP5158: 0x5c: Downloading patch ... DONE !!!
     TVP5158: 0x5c: 5158:0002:0302
     TVP5158: 0x5d: Downloading patch ...
     TVP5158: 0x5d: Download ... DONE !!!
     TVP5158: 0x5d: 5158:0002:0302
     TVP5158: 0x5e: Downloading patch ...
     TVP5158: 0x5e: Downloading patch ... DONE !!!
     TVP5158: 0x5e: 5158:0002:0302
     TVP5158: 0x5f: Downloading patch ...
     TVP5158: 0x5f: Downloading patch ... DONE !!!
     TVP5158: 0x5f: 5158:0002:0302
     [m3vpss ]  18888: CAPTURE: Create in progress !!!
     [m3vpss ]  18918: CAPTURE: VIP0 PortA capture mode is [ 8-bit, Pixel-mux Embedded Sync] !!!
     [m3vpss ]  18996: CAPTURE: VIP0 PortB capture mode is [ 8-bit, Pixel-mux Embedded Sync] !!!
     [m3vpss ]  19074: CAPTURE: VIP1 PortA capture mode is [ 8-bit, Pixel-mux Embedded Sync] !!!
     [m3vpss ]  19153: CAPTURE: VIP1 PortB capture mode is [ 8-bit, Pixel-mux Embedded Sync] !!!
     [m3vpss ]  19243: CAPTURE: 0: 0xb48c0c80, 736 x 288, 00067800 B --> Extra Frames
     [m3vpss ]  19243: CAPTURE: 1: 0xb4928480, 736 x 288, 00067800 B --> Extra Frames
     [m3vpss ]  19243: CAPTURE: 2: 0xb498fc80, 736 x 288, 00067800 B --> Extra Frames
     [m3vpss ]  19243: CAPTURE: 3: 0xb49f7480, 736 x 288, 00067800 B --> Extra Frames
     [m3vpss ]  19243: CAPTURE: 4: 0xb4a5ec80, 736 x 288, 00067800 B --> Extra Frames
     [m3vpss ]  19243: CAPTURE: 5: 0xb4ac6480, 736 x 288, 00067800 B --> Extra Frames
     [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 58 (58)
     [m3vpss ] CAPTURE::HEAPID:0 USED:1136
     [m3vpss ] CAPTURE::HEAPID:4 USED:74520576
     [m3vpss ]  19244: CAPTURE: Create Done !!!
     [m3vpss ]  19247: DUP   : Create Done !!!
     [m3vpss ]  19248: SELECT: OUT QUE0: OUT CH0: IN CH0: 704 x 288, pitch = (1472, 1472) [INTERLACED ] [NON-TILED  ]
     [m3vpss ]  19248: SELECT: OUT QUE0: OUT CH1: IN CH1: 704 x 288, pitch = (1472, 1472) [INTERLACED ] [NON-TILED  ]
     [m3vpss ]  19248: SELECT: OUT QUE0: OUT CH2: IN CH2: 704 x 288, pitch = (1472, 1472) [INTERLACED ] [NON-TILED  ]
     [m3vpss ]  19248: SELECT: OUT QUE0: OUT CH3: IN CH3: 704 x 288, pitch = (1472, 1472) [INTERLACED ] [NON-TILED  ]
     [m3vpss ]  19248: SELECT: OUT QUE0: OUT CH4: IN CH4: 704 x 288, pitch = (1472, 1472) [INTERLACED ] [NON-TILED  ]
     [m3vpss ]  19249: SELECT: OUT QUE0: OUT CH5: IN CH5: 704 x 288, pitch = (1472, 1472) [INTERLACED ] [NON-TILED  ]
     [m3vpss ]  19249: SELECT: OUT QUE0: OUT CH6: IN CH6: 704 x 288, pitch = (1472, 1472) [INTERLACED ] [NON-TILED  ]
     [m3vpss ]  19249: SELECT: OUT QUE0: OUT CH7: IN CH7: 704 x 288, pitch = (1472, 1472) [INTERLACED ] [NON-TILED  ]
     [m3vpss ]  19249: SELECT: OUT QUE1: OUT CH0: IN CH8: 704 x 288, pitch = (1472, 1472) [INTERLACED ] [NON-TILED  ]
     [m3vpss ]  19249: SELECT: OUT QUE1: OUT CH1: IN CH9: 704 x 288, pitch = (1472, 1472) [INTERLACED ] [NON-TILED  ]
     [m3vpss ]  19250: SELECT: OUT QUE1: OUT CH2:N CH10: 704 x 288, pitch = (1472, 1472) [INTERLACED ] [NON-TILED  ]
     [m3vpss ]  19250: SELECT: OUT QUE1: OUT CH3: IN CH11: 704 x 288, pitch = (1472, 1472) [INTERLACED ] [NON-TILED  ]
     [m3vpss ]  19250: SELECT: OUT QUE1: OUT CH4: IN CH12: 704 x 288, pitch = (1472, 1472) [INTERLACED ] [NON-TILED  ]
     [m3vpss ]  19250: SELECT: OUT QUE1: OUT CH5: IN CH13: 704 x 288, pitch = (1472, 1472) [INTERLACED ] [NON-TILED  ]
     [m3vpss ]  19250: SELECT: OUT QUE1: OUT CH6: IN CH14: 704 x 288, pitch = (1472, 1472) [INTERLACED ] [NON-TILED  ]
     [m3vpss ]  19250: SELECT: OUT QUE1: OUT CH7: IN CH15: 704 x 288, pitch = (1472, 1472) [INTERLACED ] [NON-TILED  ]
     [m3vpss ]  19251: SELECT   : Create Done !!!
     [m3vpss ]  19251: DEI    : Create in progress !!!
     [m3vpss ]  19557: DEI     : Loading Up-scaling Co-effs
     [m3vpss ]  19558: DEI     : Co-effs Loading ... DONE !!!
     [m3vpss ] DEI:HEAPID:0 USED:64
     [m3vpss ] DEI:HEAPID:1 USED:17472
     [m3vpss ] DEI:HEAPID:4 USED:65286144
     [m3vpss ]  19558: DEI    : Create Done !!!
     [m3vpss ]  19558: DEI    : Create in progress !!!
     [m3vpss ]  19865: DEI     : Loading Up-scaling Co-effs
     [m3vpss ]  19865: DEI     : Co-effs Loading ... DONE !!!
     [c6xdsp ]  20175: IPC_FRAMES_IN   : Create in progress !!!
     [c6xdsp ]  20175: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_19] ...
     [c6xdsp ]  20176: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_19] ...
     [m3vpss ] DEI:HEAPID:1 USED:16448
     [c6xdsp ]  20176: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
     [m3vpss ]  19865: DEI    : Create Done !!!
     [m3vpss ]  19866: MERGE   : Create Done !!!
     [c6xdsp ] IPC_FRAMES_IN:HEAPID:0 USED:304
     [m3vpss ]  19866: IPC_FRAMES_OUT   : Create in progress !!!
     [c6xdsp ]  20177: IPC_FRAMES_IN   : Createone !!!
     [c6xdsp ]  20179: ALG : Create in progress !!!
     [m3vpss ]  19868: IPC_FRAMES_OUT   : Create Done !!!
     [m3vpss ]  19882: DUP   : Create Done !!!
     [m3vpss ]  19883: MERGE   : Create Done !!!
     [c6xdsp ] ALGLINK:HEAPID:0 USED:2616
     [c6xdsp ] ALGLINK:HEAPID:1 USED:5904
     [c6xdsp ]  20186: ALG : Create Done !!!
     [m3vpss ]  19886: DUP   : Create Done !!!
     [m3vpss ]  19886: SCLR: Create in progress !!!
     [m3vpss ]  19919: SCLR    : Loading Up-scaling Co-effs ...
     [m3vpss ]  19919: SCLR    : Co-effs Loading ... DONE !!!
     [m3vpss ] SCLR:HEAPID:0 USED:64
     [m3vpss ] SCLR:HEAPID:1 USED:42432
     [m3vpss ] SCLR:HEAPID:4 USED:6488064
     [m3vpss ]  19920: SCLR: Create Done !!!
     [m3vpss ]  19920: NSF: Create in progress !!!
     [c6xdsp ]  20266: IPC_FRAMES_IN   : Create in progress !!!
     [c6xdsp ]  20266: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_20] ...
     [m3vpss ] NSF::HEAPID:0 USED:128
     [m3vpss ] NSF::HEAPID:1 USED:26048
     [m3vpss ] NSF::HEAPID:4 USED:4866048
     [m3vpss ]  19945: NSF: Create Done !!!
     [m3vpss ]  19945: IPC_FRAMES_OUT   : Create in progress !!!
     [c6xdsp ]  20266: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_20] ...
     [m3vpss ]  19946: IPC_FRAMES_OUT   : Create Done !!!
     [c6xdsp ]  20267: IPC_FRAMES_IN   : Create Done !!!
     [c6xdsp ]  20269: ALG : Create in progress !!!
     [c6xdsp ]  20275: UTILS: EDMA RM Opened
     [c6xdsp ]  20275: SCD    : Create in progress !!!
     [c6xdsp ]  20275: SCD    : Max WxH = 352 x 288, Max CH = 16, FPS = 2 !!!
     [c6xdsp ] > SCD: Algorithm memory requirements queried ::
     [c6xdsp ] >       Processing Frame Resolution = 352x288
     [c6xdsp ] >                 Number of buffers = 11
     [c6xdsp ] >      Number of channels supported = 16
     [c6xdsp ] >      Persistent Internal Memory   = 11204 bytes
     [c6xdsp ] >      Persistent External Memory   = 10205184 bytes
     [c6xdsp ] >      Scratch Internal Memory      = 61248 bytes
     [c6xdsp ] > SCD: Initializing Scene Change Detection Algorithm...
     [c6xdsp ]  20309: SCD    : Chan ID 0: Resolution 352 x 288, In FPS = 2, Out FPS = 2!!!
     [c6xdsp ]  20310: SCD    : Chan ID 1: Resolution 352 x 288, In FPS = 2, Out FPS = 2!!!
     [c6xdsp ]  20311: SCD    : Chan ID 2: Resolution 352 x 288, In FPS = 2, Out FPS = 2!!!
     [c6xdsp ]  20311: SCD    : Chan ID 3: Resolution 352 x 288, In FPS = 2, Out FPS = 2!!!
     [c6xdsp ]  20312: SCD    : Chan ID 4: Resolution 352 x 288, In FPS = 2, Out FPS = 2!!!
     [c6xdsp ]  20313: SCD    : Chan ID 5: Resolution 352 x 288, In FPS = 2, Out FPS = 2!!!
     [c6xdsp ]  20314: SCD    : Chan ID 6: Resolution 352 x 288, In FPS = 2, Out FPS = 2!!!
     [c6xdsp ]  20314: SCD    : Chan ID 7: Resolution 352 x 288, In FPS = 2, Out FPS = 2!!!
     [c6xdsp ]  20315: SCD    : Chan ID 8: Resolution 352 x 288, In FPS = 2, Out FPS = 2!!!
     [c6xdsp ]  20316: SCD    : Chan ID 9: Resolution 352 x 288, In FPS = 2, Out FPS = 2!!!
     [c6xdsp ]  20316: SCD    : Chan ID 10: Resolution 352 x 288, In FPS = 2, Out FPS = 2!!!
     [c6xdsp ]  20317: SCD    : Chan ID 11: Resolution 352 x 288, In FPS = 2, Out FPS = 2!!!
     [c6xdsp ]  20318: SCD    : Chan ID 12: Resolution 352 x 288, In FPS = 2, Out FPS = 2!!!
     [c6xdsp ]  20319: SCD    : Chan ID 13: Resolution 352 x 288, In FPS = 2, Out FPS = 2!!!
     [c6xdsp ]  20319: SCD    : Chan ID 14: Resolution 352 x 288, In FPS = 2, Out FPS = 2!!!
     [c6xdsp ]  20320: SCD    : Chan ID 15: Resolution 352 x 288, In FPS = 2, Out FPS = 2!!!
     [c6xdsp ]  20321: SCD   : VA ALG Init Done of Channel - 0!!!
     [c6xdsp ]  20322: SCD   : VA MEMALLOC 512768 bytes for DMVAL internal memory at addr 0xBD59FC80!!!
     [c6xdsp ]  20322: SCD   : VA MEMALLOC 3968 bytes for DMVAL output memory at addr 0xBD61CF80!!!
     [c6xdsp ]  20323: SCD   : VA ALG Create Done of Channel - 0!!!
     [c6xdsp ]  20323: SCD   : VA ALG Init Done of Channel - 1!!!
     [c6xdsp ]  20324: SCD   : VA MEMALLOC 512768 bytes for DMVAL internal memory at addr 0xBD61DF00!!!
     [c6xdsp ]  20324: SCD   : VA MEMALLOC 3968 bytes for DMVAL output memory at addr 0xBD69B200!!!
     [c6xdsp ]  20324: SCD   : VA ALG Create Done of Channel - 1!!!
     [c6xdsp ]  20324: SCD   : VA ALG Init Done of Channel - 2!!!
     [c6xdsp ]  20326: SCD   : VA MEMALLOC 512768 bytes for DMVAL internal memory at addr 0xBD69C180!!!
     [c6xdsp ]  20326: SCD   : VA MEMALLOC 3968 bytes for DMVAL output memory at addr 0xBD719480!!!
     [c6xdsp ]  20326: SCD   : VA ALG Create Done of Channel - 2!!!
     [c6xdsp ]  20326: SCD   : VA ALG Init Done of Channel - 3!!!
     [c6xdsp ]  20328: SCD   : VA MEMALLOC 512768 bytes for DMVAL internal memory at addr 0xBD71A400!!!
     [c6xdsp ]  20328: SCD   : VA MEMALLOC 3968 bytes for DMVAL output memory at addr 0xBD797700!!!
     [c6xdsp ]  20328: SCD   : VA ALG Create Done of Channel - 3!!!
     [c6xdsp ]  20328: SCD   : VA ALG Init Done of Channel - 4!!!
     [c6xdsp ]  20329: SCD   : VA MEMALLOC 512768 bytes for DMVAL internal memory at addr 0xBD798680!!!
     [c6xdsp ]  20329: SCD   : VA MEMALLOC 3968 bytes for DMVAL output memory at addr 0xBD815980!!!
     [c6xdsp ]  20330: SCD   : VA ALG Create Done of Channel - 4!!!
     [c6xdsp ]  20330: SCD   : VA ALG Init Done of Channel - 5!!!
     [c6xdsp ]  20331: SCD   : VA MEMALLOC 512768 bytes for DMVAL internal memory at addr 0xBD816900!!!
     [c6xdsp ]  20331: SCD   : VA MEMALLOC 3968 bytes for DMVAL output memory at addr 0xBD893C00!!!
     [host] IpcBitsInLink_tskMain:Entered
     [host]  9129: IPC_BITS_IN   : Create in progress !!!
     [host]  9129: IPC_BITS_IN   : ListMPOpen start !!!
     [host]  9129: SYSTEM: Opening ListMP [DSP_IPC_OUT_24] ...
     9131: SYSTEM: Opening ListMP [DSP_IPC_IN_24] ...
     [host]  9132: IPC_BITS_IN   : ListMPOpen done !!!
     [c6xdsp ]  20331: SCD   : VA ALG Create Done of Channel - 5!!!
     [c6xdsp ]  20331: SCD   : VA ALG Init Done of Channel - 6!!!
     [c6xdsp ]  20333: SCD   : VA MEMALLOC 512768 bytes for DMVAL internal memory at addr 0xBD894B80!!!
     [c6xdsp ]  20333: SCD   : VA MEMALLOC 3968 bytes for DMVAL output memory at addr 0xBD911E80!!!
     [c6xdsp ]  20333: SCD   : VA ALG Create Done of Channel - 6!!!
     [c6xdsp ]  20333: SCD   : VA ALG Init Done of Channel - 7!!!
     [host]  9133: IPC_BITS_IN   : System_linkGetInfo done !!!
     [host]  9133: IPC_BITS_IN   : Create Done !!!
     [c6xdsp ]  20335: SCD   : VA MEMALLOC 512768 bytes for DMVAL internal memory at addr 0xBD912E00!!!
     [c6xdsp ]  20335: SCD   : VA MEMALLOC 3968 bytes for DMVAL output memory at addr 0xBD990100!!!
     [c6xdsp ]  20335: SCD   : VA ALG Create Done of Channel - 7!!!
     [c6xdsp ]  20335: SCD   : VA ALG Init Done of Channel - 8!!!
     [c6xdsp ]  20336: SCD   : VA MEMALLOC 512768 bytes for DMVAL internal memory at addr 0xBD991080!!!
     [c6xdsp ]  20336: SCD   : VA MEMALLOC 3968 bytes for DMVAL output memory at addr 0xBDA0E380!!!
     [c6xdsp ]  20337: SCD   : VA ALG Create Done of Channel - 8!!!
     [c6xdsp ]  20337: SCD   : VA ALG Init Done of Channel - 9!!!
     [c6xdsp ]  20338: SCD   : VA MEMALLOC 512768 bytes for DMVAL internal memory at addr 0xBDA0F300!!!
     [c6xdsp ]  20338: SCD   : VA MEMALLOC 3968 bytes for DMVAL output memory at addr 0xBDA8C600!!!
     [c6xdsp ]  20338: SCD   : VA ALG Create Done of Channel - 9!!!
     [c6xdsp ]  20338: SCD   : VA ALG Init Done of Channel - 10!!!
     [c6xdsp ]  20340: SCD   : VA MEMALLOC 512768 bytes for DMVAL internal memory at addr 0xBDA8D580!!!
     [c6xdsp ]  20340: SCD   : VA MEMALLOC 3968 bytes for DMVAL output memory at addr 0xBDB0A880!!!
     [c6xdsp ]  20340: SCD   : VA ALG Create Done of Channel - 10!!!
     [c6xdsp ]  20340: SCD   : VA ALG Init Done of Channel - 11!!!
     [c6xdsp ]  20342: SCD   : VA MEMALLOC 512768 bytes for DMVAL internal memory at addr 0xBDB0B800!!!
     [c6xdsp ]  20342: SCD   : VA MEMALLOC 3968 bytes for DMVAL output memory at addr 0xBDB88B00!!!
     [c6xdsp ]  20342: SCD   : VA ALG Create Done of Channel - 11!!!
     [c6xdsp ]  20342: SCD   : VA ALG Init Done of Channel - 12!!!
     [c6xdsp ]  20343: SCD   : VA MEMALLOC 512768 bytes for DMVAL internal memory at addr 0xBDB89A80!!!
     [c6xdsp ]  20343: SCD   : VA MEMALLOC 3968 bytes for DMVAL output memory at addr 0xBDC06D80!!!
     [c6xdsp ]  20344: SCD   : VA ALG Create Done of Channel - 12!!!
     [c6xdsp ]  20344: SCD   : VA ALG Init Done of Channel - 13!!!
     [c6xdsp ]  20345: SCD   : VA MEMALLOC 512768 bytes for DMVAL internal memory at addr 0xBDC07D00!!!
     [c6xdsp ]  20345: SCD   : VA MEMALLOC 3968 bytes for DMVAL output memory at addr 0xBDC85000!!!
     [c6xdsp ]  20345: SCD   : VA ALG Create Done of Channel - 13!!!
     [c6xdsp ]  20345: SCD   : VA ALG Init Done of Channel - 14!!!
     [c6xdsp ]  20347: SCD   : VA MEMALLOC 512768 bytes for DMVAL internal memory at addr 0xBDC85F80!!!
     [c6xdsp ]  20347: SCD   : VA MEMALLOC 3968 bytes for DMVAL output memory at addr 0xBDD03280!!!
     [c6xdsp ]  20347: SCD   : VA ALG Create Done of Channel - 14!!!
     [c6xdsp ]  20347: SCD   : VA ALG Init Done of Channel - 15!!!
     [c6xdsp ]  20349: SCD   : VA MEMALLOC 512768 bytes for DMVAL internal memory at addr 0xBDD04200!!!
     [c6xdsp ]  20349: SCD   : VA MEMALLOC 3968 bytes for DMVAL output memory at addr 0xBDD81500!!!
     [c6xdsp ]  20349: SCD   : VA ALG Create Done of Channel - 15!!!
     [c6xdsp ]  UTILS: DSP  Channle Alloc: EDMA3_RM_allocLogicalChannel call Successful
     [host]  9469: IPC_BITS_IN   : Create in progress !!!
     [host]  9469: IPC_BITS_IN   : ListMPOpen start !!!
     [host]  9469: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_24] ...
     [m3video]  20312: IPC_IN_M3   : Create in progress !!!
     [m3vpss ]  20310: MERGE   : Create Done !!!
     [c6xdsp ] Allocated Chanel 30, Param 30 and TC is 30
     9471: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_24] ...
     [m3video]  20312: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
     [m3vpss ]  20310: IPC_OUT_M3   : Create in progress !!!
     [host]  9472: IPC_BITS_IN   : ListMPOpen done !!!
     [c6xdsp ]  20350: SCD: Process Tsk Started !!!
     [m3video]  20312: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
     [m3vpss ]  20311: IPC_OUT_M3   : Create Done !!!
     [c6xdsp ]  20350: SCD    : Create Done !!!
     [m3video]  20314: IPC_IN_M3   : Create Done !!!
     [m3video]  20314: ENCODE: Create in progress ... !!!
     [m3video] ENCLINK:INFO: !!!Number of output buffers for ch[32] set to [1]
     [m3video]  20455: ENCODE: Creating CH0 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     [c6xdsp ] ALGLINK:HEAPID:0 USED:10205696
     [c6xdsp ] ALGLINK:HEAPID:1 USED:72456
     [c6xdsp ] ALGLINK:HEAPID:3 USED:278528
     [m3video] ENCLINK_H264:HEAPID:0 USED:13808
     [c6xdsp ] ALGLINK:HEAPID:4 USED:11511808
     [m3video] ENCLINK_H264:HEAPID:3 USED:49152
     [c6xdsp ]  20350: ALG : Create Done !!!
     [host]  9474: IPC_BITS_IN   : System_linkGetInfo done !!!
     [host]  9474: IPC_BITS_IN   : Create Done !!!
    Reducing bitsProducerLinkInfo.numCh to 16
     [m3video]  20458: ENCODE: Creating CH1 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     [c6xdsp ]  20353: IPC_BITS_OUT   : Create in progress !!!
     [host]  9476: IPC_BITS_OUT   : Create in progress !!!
    ###Bit buff of size from the SR # 1 : 53084160
     [host] IPC_BITSOUT:BitBuffer Alloc.PoolID:0,Size:0x32A0000
     [host] IPCBITSOUTLINK:Translated Addr Virt:0x2dc59480 To Phy:0x91d6b480
     [host]  9477: IPC_BITS_OUT   : Create Done !!!
     [m3video] ENCLINK_H264:HEAPID:0 USED:11912
     [c6xdsp ]  20353: IPC_BITS_OUT   : Create Done !!!
     [m3video]  20460: ENCODE: Creating CH2 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     [m3video]  20462: ENCODE: Creating CH3 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     [m3video]  20464: ENCODE: Creating CH4 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     [m3video]  20466: ENCODE: Creating CH5 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     [m3video]  20469: ENCODE: Creating CH6 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     [m3video]  20471: ENCODE: Creating CH7 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     [m3video]  20473: ENCODE: Creating CH8 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     [m3video]  20475: ENCODE: Creating CH9 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     [m3video]  20477: ENCODE: Creating CH10 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     [m3video]  20480: ENCODE: Creating CH11 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     [m3video]  20482: ENCODE: Creating CH12 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     [m3video]  20484: ENCODE: Creating CH13 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     [m3video]  20486: ENCODE: Creating CH14 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     [m3video]  20488: ENCODE: Creating CH15 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 2000 Kbps ...
     [m3video]  20491: ENCODE: Creating CH16 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video] ENCLINK_H264:HEAPID:3 USED:577536
     [m3video]  20495: ENCODE: Creating CH17 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  20498: ENCODE: Creating CH18 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  20502: ENCODE: Creating CH19 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  20506: ENCODE: Creating CH20 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  20510: ENCODE: Creating CH21 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  20513: ENCODE: Creating CH22 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  20517: ENCODE: Creating CH23 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  20521: ENCODE: Creating CH24 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  20525: ENCODE: Creating CH25 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3vpss ]  21038: IPC_IN_M3   : Create in progress !!!
     [m3vpss ]  21038: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
     [m3video]  20529: ENCODE: Creating CH26 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3vpss ]  21038: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
     [m3vpss ]  21039: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
     [m3vp]  21040: IPC_IN_M3   : Create Done !!!
     [m3vpss ]  21042: MERGE   : Create Done !!!
     [m3vpss ]  21045: DUP   : Create Done !!!
     [m3video]  20532: ENCODE: Creating CH27 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3vpss ]  21045: SWMS: Create in progress !!!
     [m3video]  20536: ENCODE: Creating CH28 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  20540: ENCODE: Creating CH29 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  20544: ENCODE: Creating CH30 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  20548: ENCODE: Creating CH31 of 352 x 288, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  20551: ENCODE: Creating CH32 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 100 Kbps ...
     [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 59 (59)
     [m3video] ENCLINK_JPEG:HEAPID:0 USED:2064
     [m3video]  20552: ENCODE: Creating CH33 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 100 Kbps ...
     [m3vpss ] SWMS: instance 0, sc id 5, start win 0 end win 17
     [m3vpss ]  21149: SWMS0    : Loading Vertical Co-effs (UPSCALE)x ...
     [m3video]  20553: ENCODE: Creating CH34 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 100 Kbps ...
     [m3vpss ]  21149: SWMS0    : Loading Horizontal Co-effs (UPSCALE)x ...
     [m3vpss ]  21149: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]  21149: SWMS    : ******* Configuring clock 32 secs...
     [m3vpss ]  21150: SWMS0    : Loading Vertical Co-effs (UPSCALE)x ...
     [m3video]  20553: ENCODE: Creating CH35 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 100 Kbps ...
     [m3vpss ]  21150: SWMS0    : Loading Horizontal Co-effs (UPSCALE)x ...
     [m3vpss ]  21150: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]
     [m3vpss ]  *** [SWMS0] Mosaic Parameters ***
     [m3vpss ]
     [m3vpss ]  Output FPS: 29
     [m3vpss ]
     [m3vpss ]  Win | Ch  | Input      | Input          | Input         | Input       | Output     |  Output         | Output        | Output      | Low Cost | SWMS | Data  | Blank |
     [m3vpss ]  Num | Num | Start X, Y | Width x Height | Pitch Y / C   | Memory Type | Start X, Y |  Width x Height | Pitch Y / C   | Memory Type | ON / OFF | Inst | Format| Frame |
     [m3vpss ]  ----------------------------------------------------------------------------------------------------------------------------------------------------------------------
     [m3vpss ]    0 |  32 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |    0,    0   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3video]  20554: ENCODE: Creating CH36 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 100 Kbps ...
     [m3vpss ]    1 |  33 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |  480,    0 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]    2 |  34 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |  960,    0 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]    3 |  35 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   | 1440,    0 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]    4 |  36 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |    0,  270 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3video]  20554: ENCODE: Creating CH37 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 100 Kbps ...
     [m3vpss ]    5 |  37 |    0 0 |   352 x    288 |   352 /   352 | NON-TILED   |  480,  270 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]    6 |  38 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |  960,  270 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]    7 |  39 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   | 1440,  270 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]    8 |  40 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |    0,  540 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3video]  20555: ENCODE: Creating CH38 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 100 Kbps ...
     [m3vpss ]    9 |  41 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |  480,  540 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]   10 |  42 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |  960,  540 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]   11 |  43 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   | 1440,  540 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]   12 |  44 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |    0,  810 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3video]  20556: ENCODE: Creating CH39 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 100 Kbps ...
     [m3vpss ]   13 |  45 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |  480,  810 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]   14 |  46 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   |  960,  810 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]   15 |  47 |    0,    0 |   352 x    288 |   352 /   352 | NON-TILED   | 1440,  810 |   480 x    270 |  3840 /      0 | NON-TILED   |      OFF |    0 |  420SP |   OFF |
     [m3vpss ]
     [m3video]  20556: ENCODE: Creating CH40 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 100 Kbps ...
     Audio capture task created
     [m3vpss ] SWMS:HEAPID:0 USED:360
     [m3vpss ] SWMS:HEAPID:1 USED:43776
     [m3video]  20557: ENCODE: Creating CH41 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 100 Kbps ...
     [m3vpss ] SWMS:HEAPID:3 USED:20736000
     [m3vpss ]  21156: SWMS: Create Done !!!
     [m3vpss ]  21156: SWMS: Create in progress !!!
     [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 60 (60)
     [m3video]  20557: ENCODE: Creating CH42 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 100 Kbps ...
     [m3vpss ]  21260: SWMS1    : Loading Vertical Co-effs (UPSCALE)x ...
     [m3vpss ]  21260: SWMS1    : Loading Horizontal Co-effs (UPSCALE)x ...
     [m3vpss ]  21260: SWMS    : Co-effs Loading ... DONE !!!
     [m3video]  20558: ENCODE: Creating CH43 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 100 Kbps ...
     [m3vpss ]  21260: SWMS    : ******* Configuring clock 32 secs...
     [m3vpss ]  21261: SWMS    : Co-effs Loading ... DONE !!!
     [m3video]  20559: ENCODE: Creating CH44 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 100 Kbps ...
     [m3vpss ]
     [m3vpss ]  *** [SWMS1] Mosaic Parameters ***
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]    0 |  16 |    0,    0 |   704 x    576 | 16384 / 32768 | TILED       |    0,    0 |   480 x    270 |  3840 /      0 | NON-TILED   |      ON  |    0 |  420SP |   OFF |
     [m3vpss ]    1 |  17 |    0,    0 |   704 x    576 | 16384 / 32768 | TILED       |  480,    0 |   480 x    270 |  3840 /      0 | NON-TILED   |      ON  |    0 |  420SP |   OFF |
     [m3vpss ]    2 |  18 |    0,    0 |   704 x    576 | 16384 / 32768 | TILED       |  960,    0 |   480 x    270 |  3840 /      0 | NON-TILED   |      ON  |    0 |  420SP |   OFF |
     [m3video]  20559: ENCODE: Creating CH45 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 100 Kbps ...
     [m3vpss ]    3 |  19 |    0,    0 |   704 x    576 | 16384 / 32768 | TILED       | 1440,    0 |   480 x    270 |  3840 /      0 | NON-TILED   |      ON  |    0 |  420SP |   OFF |
     [m3vpss ]    4 |  20 |    0,    0 |   704 x    576 | 16384 / 32768 | TILED       |    0,  270 |   480 x    270 |  3840 /      0 | NON-TILED   |      ON  |    0 |  420SP |   OFF |
     [m3vpss ]    5 |  21 |    0,    0 |   704 x    576 | 16384 / 32768 | TILED       |  480,  270 |   480 x    270 |  3840 /      0 | NON-TILED   |      ON  |    0 |  420SP |   OFF |
     [m3vpss ]    6 |  22 |    0,    0 |   704 x    576 | 16384 / 32768 | TILED       |  960,  270 |   480 x    270 |  3840 /      0 | NON-TILED   |      ON  |    0 |  420SP |   OFF |
     [m3video]  20560: ENCODE: Creating CH46 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 100 Kbps ...
     [m3vpss ]    7 |  23 |    0,    0 |   704 x    576 | 16384 / 32768 | TILED       | 1440,  270 |   480 x    270 |  3840 /      0 | NON-TILED   |      ON  |    0 |  420SP |   OFF |
     [m3vpss ]    8 |  24 |    0,    0 |   704 x    576 | 16384 / 32768 | TILED       |    0,  540 |   480 x    270 |  3840 /      0 | NON-TILED   |      ON  |    0 |  420SP |   OFF |
     [m3vpss ]    9 |  25 |    0,    0 |   704 x    576 | 16384 / 32768 | TILED       |  480,  540 |   480 x    270 |  3840 /      0 | NON-TILED   |      ON  |    0 |  420SP |   OFF |
     [m3vid] ENCLINK_JPEG:HEAPID:0 USED:2064
     [m3vpss ]   10 |  26 |    0,    0 |   704 x    576 | 16384 / 32768 | TILED       |  960,  540 |   480 x    270 |  3840 /      0 | NON-TILED   |      ON  |    0 |  420SP |   OFF |
     [m3video]  20560: ENCODE: Creating CH47 of 704 x 576, pitch = (16384, 32768) [PROGRESSIVE] [TILED      ], bitrate = 100 Kbps ...
     [m3vpss ]   11 |  27 |    0,    0 |   704 x    576 | 16384 / 32768 | TILED       | 1440,  540 |   480 x    270 |  3840 /      0 | NON-TILED   |      ON  |    0 |  420SP |   OFF |
     [m3vpss ]   12 |  28 |    0,    0 |   704 x    576 | 16384 / 32768 | TILED       |    0,  810 |   480 x    270 |  3840 /      0 | NON-TILED   |      ON  |    0 |  420SP |   OFF |
     [m3vpss ]   13 |  29 |    0,    0 |   704 x    576 | 16384 / 32768 | TILED       |  480,  810 |   480 x    270 |  3840 /      0 | NON-TILED   |      ON  |    0 |  420SP |   OFF |
     [m3vpss ]   14 |  30 |    0,    0 |   704 x    576 | 16384 / 32768 | TILED       |  960,  810 |   480 x    270 |  3840 /      0 | NON-TILED   |      ON  |    0 |  420SP |   OFF |
     [m3video]  20561: ENCODE: All CH Create ... DONE !!!
     [m3vpss ]   15 |  31 |    0,    0 |   704 x    576 | 16384 / 32768 | TILED       | 1440,  810 |   480 x    270 |  3840 /      0 | NON-TILED   |      ON  |    0 |  420SP |   OFF |
     [m3vpss ]
     [m3video] ENCLINK:HEAPID:0 USED:416224
     [m3video] ENCLINK:HEAPID:2 USED:30569472
     [m3video] ENCLINK:HEAPID:3 USED:10027008
     [m3video]  20563: ENCODE: Create ... DONE !!!
     [m3video]  20563: IPC_BITS_OUT   : Create in progress !!!
     [m3vpss ]  21267: SWMS: Create Done !!!
     [m3vpss ]  21267: DISPLAY: Create in progress !!!
     [m3vpss ] ==============FVID2_SETFMT STARTING===================
     [m3video]  20564: IPC_BITS_OUT   : Create Done !!!
     [m3vpss ] ==============FVID2_SETFMT STARTED===================
     [m3video]  20612: IPC_BITS_IN   : Create in progress !!!
     [m3vpss ]  21268: DISPLAY: Create Done !!!
     [m3video]  20612: SYSTEM: Opening ListMP [HOST_IPC_OUT_24] ...
     [m3vpss ]  21268: DISPLAY: Create in progress !!!
     [m3video]  20613: SYSTEM: Opening ListMP [HOST_IPC_IN_24] ...
     [m3video]  20613: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
     [m3video]  20615: IPC_BITS_IN   : Create Done !!!
     [m3vpss ]  21269: DISPLAY: Create Done !!!
     [m3video]  20615: DECODE: Create in progress ... !!!
     [m3vpss ]  21269: DISPLAY: Create in progress !!!
     [m3vpss ]  21270: DISPLAY: 44: Field Separate Mode ENABLED for Que 0 !!!
     [m3video] DECLINK_H264:HEAPID:0 USED:2368
     [m3video] DECLINK_H264:HEAPID:2 USED:4075520
     [m3vpss ]  21271: DISPLAY: Create Done !!!
     [m3video] DECLINK_H264:HEAPID:3 USED:417792
     [m3vpss ]  21761: DISPLAY: Start in progress !!!
     [m3video]  20640: DECODE: Creating CH0 of 704 x 576 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     [m3vpss ]  21805: DISPLAY: Start Done !!!
     [m3vpss ]  21805: DISPLAY: HDDAC(BP0) : 45 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
     Audio playback task created 11279: MSGQ: MsgQ Ack get from [VIDEO-M3] failed for link 33, cmdId 0x5004 !!! (retrying - 999 times)
     ## AVERAGE: ENCODE [  13.6] FPS, DECODE [   5.8] FPS, ENC+DEC [  19.4] FPS ... in 10.0 secs,
     [m3vpss ]  21806: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 1, HDDAC(BP0) 1, DVO2(BP1) 0, SDDAC(SEC1) 1
     [m3vpss ]  21806: SYSTEM  : FREE SPACE : System Heap      = 4464 B, Mbx = 10238 msgs)
     [m3video]  20664: DECODE: Creating CH1 of 704 x 576 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     [m3vpss ]  21806: SYSTEM  : FREE SPACE : SR0 Heap         = 10304768 B (9 MB)
     [m3vpss ]  21806: SYSTEM  : FREE SPACE : Frame Buffer     = 2944 B (0 MB)
     [m3vpss ]  21806: SYSTEM  : FREE SPACE : Bitstream Buffer = 23612288 B (22 MB)
     [m3video]  20688: DECODE: Creating CH2 of 704 x 576 [PROGRESSIVE] [TILED      ],target bitrate = Kbps
     [m3vpss ]  21806: DISPLAY: Start in progress !!!
     [m3vpss ]  21807: SYSTEM  : FREE SPACE : Tiler 8-bit      = 19243008 B (18 MB)  - TILER ON
     [m3vpss ]  21807: SYSTEM  : FREE SPACE : Tiler 16-bit     = 76816384 B (73 MB)  - TILER ON
     [m3vpss ]  21856: DISPLAY: Start Done !!!
     [m3video]  20712: DECODE: Creating CH3 of 704 x 576 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     [m3vpss ]  21856: DISPLAY: DVO2(BP1)  : 40 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
     [m3vpss ]  21856: DISPLAY: Start in progress !!!
     [m3vpss ]  21893: DISPLAY: Start Done !!!
     [m3vpss ]  21893: DISPLAY: SDDAC(SEC1): 27 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
     [m3video]  20736: DECODE: Creating CH4 of 704 x 576 [PROGRESSIVE] [TILED      ],targitrate = 2000 Kbps ...
     [m3vpss ]  21893: SWMS: Start in Progress !!!
     [m3vpss ]  21894: SWMS: Start Done !!!
     [m3vpss ]  21894: SWMS: Start in Progress !!!
     [m3vpss ]  21898: CAPTURE: Start in progress !!!
     [m3vpss ]  21898: CAPTURE: Start Done !!!
     [m3video]  20760: DECODE: Creating CH5 of 704 x 576 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[0],ChID[16],FirstPTS[0]
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[1],ChID[16],FirstPTS[0]
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS faileddue to invalid cfg
     [m3vpss ] Config:DisplayID[2],ChID[-1]
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[0],ChID[17],FirstPTS[0]
     [m3video] DECLINK_H264:HEAPID:2 USED:4194304
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[1],ChID[17],FirstPTS[0]
     [m3video] DECLINK_H264:HEAPID:3 USED:299008
     [m3video]  20785: DECODE: Creating CH6 of 704 x 576 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[0],ChID[18],FirstPTS[0]
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[1],ChID[18],FirstPTS[0]
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[0],ChID[19],FirstPTS[0]
     [m3video] DECLINK_H264:HEAPID:2 USED:4493312
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[1],ChID[19],FirstPTS[0]
     [m3video]  20813: DECODE: Creating CH7 of 704 x 576 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[0],ChID[22],FirstPTS[0]
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[1],ChID[22],FirstPTS[0]
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[0],ChID[21],FirstPTS[0]
     [m3video]  20840: DECODE: Creating CH8 of 704 x 576 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[1],ChID[21],FirstPTS[0]
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[0],ChID[20],FirstPTS[0]
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[1],ChID[20],FirstPTS[0]
     [m3vpss  AVSYNVSYNC_LINK_CMD_SET_FIRST_VIDPTS faileddue to invalid cfg
     [m3video]  20868: DECODE: Creating CH9 of 704 x 576 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[0],ChID[23],FirstPTS[0]
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[1],ChID[23],FirstPTS[0]
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[0],ChID[28],FirstPTS[0]
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[1],ChID[28],FirstPTS[0]
     [m3video]  20895: DECODE: Creating CH10 of 704 x 576 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[0],ChID[29],FirstPTS[0]
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[1],ChID[29],FirstPTS[0]
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[0],ChID[30],FirstPTS[0]
     [m3video]  20923: DECODE: Creating CH11 of 704 x 576 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[1],ChID[30],FirstPTS[0]
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[0],ChID[31],FirstPTS[0]
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[1],ChID[31],FirstPTS[0]
     [m3video]  20950: DECODE: Creating CH12 of 704 x 576 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[0],ChID[25],FirstPTS[0]
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[1],ChID[25],FirstPTS[0]
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[0],ChID[26],FirstPTS[0]
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[1],ChID[26],FirstPTS[0]
     [m3video]  20977: DECODE: Creating CH13 of 704 x 576 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[0],ChID[24],FirstPTS[0]
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[1],ChID[24],FirstPTS[0]
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[0],ChID[27],FirstPTS[0]
     [m3video]  21005: DECODE: Creating CH14 of 704 x 576 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     [m3vpss ] AVSYNC:AVSYNC_LINK_CMD_SET_FIRST_VIDPTS successConfig:DisplayID[1],ChID[27],FirstPTS[0]
     [m3video]  21032: DECODE: Creating CH15 of 704 x 576 [PROGRESSIVE] [TILED      ],target bitrate = 2000 Kbps ...
     [m3video]  21034: DECODE: All CH Create ... DONE !!!
     [m3video] DECLINK:HEAPID:0 USED:38008
     [m3video] DECLINK:HEAPID:2 USED:69087232
     [m3video] DECLINK:HEAPID:3 USED:2805760
     [m3video]  21037: DECODE: Create ... DONE !!!
     [m3video]  21037: IPC_OUT_M3   : Create in progress !!!
     [m3video]  21038: IPC_OUT_M3   : Create Done !!!
     ## AVERAGE: ENCODE [ 839.7] FPS, DECODE [ 424.2] FPS, ENC+DEC [1263.9] FPS ... in 10.0 secs,
     22276: MSGQ: MsgQ Ack get from [VIDEO-M3] failed for link 33, cmdId 0x5004 !!! (retrying - 988 times)
     23276: MSGQ: MsgQ Ack get from [VIDEO-M3] failed for link 33, cmdId 0x5004 !!! (retrying - 987 times)
     24276: MSGQ: MsgQ Ack get from [VIDEO-M3] failed for link 33, cmdId 0x5004 !!! (retrying - 986 times)
     25276: MSGQ: MsgQ Ack get from [VIDEO-M3] failed for link 33, cmdId 0x5004 !!! (retrying - 985 times)
     26276: MSGQ: MsgQ Ack get from [VIDEO-M3] failed for link 33, cmdId 0x5004 !!! (retrying - 984 times)
  • Hi
    This is strange behavior, Are you running pre-build binaries along with the release or not? what is the HW platform you are using, EVM or UDworks DVR?
    if you are not using the pre-built binaries, can you try with these pre-built binaries first?
    regards, shiju
  • Hi shiju
       Sorry for reply late。 Last week, I was on my holiday.
       I use the pre-build binaries.  UDworks DVR
       I solve the problem.
       The problem is because i didn't connect the HDMI0 port.
