Other Parts Discussed in Thread: TVP7002
Howdy all,
I'm having an initial play with omtb .oms scripts using EZSDK 5.03.00.09. I am using a camera that cannot output 1080p60 but can do 720p60 so I am trying to modify the provided scripts to work with that. By combining a couple of provided scripts and also some posted on this forum, I have a script that is giving mixed results (see below). I have found that if I have the video formats still set to 1080p60, the script runs, shows glitchy video and then exits. If I change all the formats to 720p60 (the main triger seems to be the tvp videoStandard) then when the script runs it will show a few frames of good video, then the screen goes blank and the OMTB prompt hangs when trying to change the state of the vfdc. Anyone had any similar issues or had any success? I've tried rebuilding omtb as suggested here http://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/717/p/138349/498644.aspx#498644 with no success. I am currently downloading the latest EZSDK to see if that makes any difference (but got bored while it downloaded so thought I'd post here in the meantime!)
G
#omx omtb_dbg_lvl 0x00
#omx omtb_dbg_lvl 0x04
#omx omtb_dbg_lvl 0x08
#omx omtb_dbg_lvl 0x10
#omx omtb_dbg_lvl 0x80
omx api init
omx setp 0 vfcc compname OMX.TI.VPSSM3.VFCC
omx setp 0 tvp compname OMX.TI.VPSSM3.CTRL.TVP
omx setp 0 dc insmod_hdmi disable
#I/P Port or O/P Port Params for VFCC
omx setp 0 vfcc numoutbuf 6
omx setp 0 vfcc frame_width 1280
omx setp 0 vfcc frame_height 720
omx setp 0 vfcc op_chromat_format 422YUYV
omx setp 0 vfcc outbufalign 0
omx setp 0 vfcc outbuf_contig disable
omx setp 0 vfcc outbufsize 1843200
omx setp 0 vfcc data_opmode driver
omx setp 0 vfcc outbuf allocate
omx setp 0 vfcc outbufsize_flag disable
omx setp 0 vfdc frame_width 1280
omx setp 0 vfdc frame_height 720
omx setp 0 vfdc ip_chromat_format 422YUYV
omx setp 0 vfdc numinbuf 6
omx setp 0 vfdc inbufalign 0
omx setp 0 vfdc inbuf_contig disable
omx setp 0 vfdc inbufsize 1843200
omx setp 0 vfdc inbuf use
omx setp 0 vfdc graphics_flag disable
#omx setp 0 vfdc vcdemo_flag enable
omx setp 0 vfdc mosaic_window_config vs
omx api gethandle tvp 0 0
omx api gethandle vfcc 0 0
omx api gethandle vfdc 0 0
omx api gethandle dc 0 0
#SET ALL THE PARAMS FOR TVP
omx setp 0 tvp OMX_TI_IndexParamVFCCHwPortID eHwPortId vip1_porta
omx api setparam tvp 0 0 0 OMX_TI_IndexParamVFCCHwPortID
omx setp 0 tvp OMX_TI_IndexParamVFCCHwPortProperties eCaptMode sc_non_mux
omx setp 0 tvp OMX_TI_IndexParamVFCCHwPortProperties eVifMode 16_bit
omx setp 0 tvp OMX_TI_IndexParamVFCCHwPortProperties eInColorFormat 422YUYV
omx setp 0 tvp OMX_TI_IndexParamVFCCHwPortProperties eScanType progressive
omx setp 0 tvp OMX_TI_IndexParamVFCCHwPortProperties nMaxWidth 1280
omx setp 0 tvp OMX_TI_IndexParamVFCCHwPortProperties nMaxHeight 720
omx setp 0 tvp OMX_TI_IndexParamVFCCHwPortProperties nMaxChnlsPerHwPort 1
omx api setparam tvp 0 0 0 OMX_TI_IndexParamVFCCHwPortProperties
omx setp 0 tvp OMX_TI_IndexParamCTRLVidDecInfo videoStandard 1080p60
omx setp 0 tvp OMX_TI_IndexParamCTRLVidDecInfo videoDecoderId tvp7002
omx setp 0 tvp OMX_TI_IndexParamCTRLVidDecInfo videoSystemId auto_detect
omx api setparam tvp 0 0 0 OMX_TI_IndexParamCTRLVidDecInfo
#SET ALL THE PARAMS FOR VFCC
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortID eHwPortId vip1_porta
omx api setparam vfcc 0 0 0 OMX_TI_IndexParamVFCCHwPortID
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortProperties eCaptMode sc_non_mux
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortProperties eVifMode 16_bit
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortProperties eInColorFormat 422YUYV
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortProperties eScanType progressive
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortProperties nMaxWidth 1280
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortProperties nMaxHeight 720
omx setp 0 vfcc OMX_TI_IndexParamVFCCHwPortProperties nMaxChnlsPerHwPort 1
omx api setparam vfcc 0 0 0 OMX_TI_IndexParamVFCCHwPortProperties
omx setp 0 vfcc OMX_TI_IndexParamBuffMemType eBufMemoryType default
omx api setparam vfcc 0 0 0 OMX_TI_IndexParamBuffMemType
omx setp 0 vfcc OMX_IndexParamCompBufferSupplier eBufferSupplier unspecified
#omx api setparam vfcc 0 0 0 OMX_IndexParamCompBufferSupplier
omx setp 0 vfcc OMX_TI_IndexConfigVFCCFrameSkip frameSkipMask 0
#omx api setconfig vfcc 0 0 0 OMX_TI_IndexConfigVFCCFrameSkip
omx setp 0 vfcc OMX_IndexParamVideoInit nPorts 16
omx setp 0 vfcc OMX_IndexParamVideoInit nStartPortNumber 0
#omx api setparam vfcc 0 0 0 OMX_IndexParamVideoInit
omx setp 0 vfdc OMX_TI_IndexParamVFDCDriverInstId nDrvInstID 0
omx setp 0 vfdc OMX_TI_IndexParamVFDCDriverInstId eDispVencMode 1080p60
omx api setparam vfdc 0 0 0 OMX_TI_IndexParamVFDCDriverInstId
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout winStartX 0
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout winStartY 0
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout winWidth 1280
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout winHeight 720
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout pitch.VFDC_YUV_INT_ADDR_IDX 2560
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout pitch.VFDC_YUV_SP_Y_ADDR_IDX 2560
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout pitch.VFDC_YUV_SP_CBCR_ADDR_IDX 2560
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout dataFormat 422I_YUYV
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout bpp bits16
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout priority 0
omx setp 0 vfdc OMX_TI_IndexParamVFDCCreateMosaicLayout nLayoutId 0
omx setp 0 vfdc mosaicNumRows 1
omx setp 0 vfdc mosaicNumCols 1
omx setp 0 vfdc mosaicDispWindowWidth 1280
omx setp 0 vfdc mosaicDispWindowHeight 720
omx api setparam vfdc 0 0 0 OMX_TI_IndexParamVFDCCreateMosaicLayout
omx setp 0 vfdc OMX_TI_IndexConfigVFDCMosaicPort2WinMap nLayoutId 0
omx api setconfig vfdc 0 0 0 OMX_TI_IndexConfigVFDCMosaicPort2WinMap 1 0
omx setp 0 vfdc OMX_TI_IndexParamBuffMemType eBufMemoryType default
omx setp 0 vfdc OMX_IndexParamCompBufferSupplier eBufferSupplier unspecified
omx setp 0 vfdc OMX_IndexParamVideoInit nPorts 1
omx setp 0 vfdc OMX_IndexParamVideoInit nStartPortNumber 0
omx api getparam vfdc 0 0 0 OMX_IndexParamPortDefinition
omx setp 0 vfdc OMX_IndexParamPortDefinition video.nStride 2560
omx setp 0 vfdc OMX_IndexParamPortDefinition video.nFrameWidth 1280
omx setp 0 vfdc OMX_IndexParamPortDefinition video.nFrameHeight 720
omx api setparam vfdc 0 0 0 OMX_IndexParamPortDefinition
#SET ALL THE PARAMS FOR DC#0
omx setp 0 dc OMX_TI_IndexParamVFDCDriverInstId nDrvInstID 0
omx setp 0 dc OMX_TI_IndexParamVFDCDriverInstId eDispVencMode 1080p60
omx api setparam dc 0 0 0 OMX_TI_IndexParamVFDCDriverInstId
omx api sendcommand port vfcc 0 enable 0
omx api sendcommand port vfcc 0 waitforsem 0
omx api sendcommand port vfdc 0 enable 0
omx api sendcommand port vfdc 0 waitforsem 0
omx api connect vfcc 0 0 vfdc 0 0
omx api sendcommand state vfcc 0 idle
omx api sendcommand state vfcc 0 waitforsem
omx api sendcommand state tvp 0 idle
omx api sendcommand state tvp 0 waitforsem
omx api sendcommand state dc 0 idle
omx api sendcommand state dc 0 waitforsem
omx api sendcommand state vfdc 0 idle
omx api sendcommand state vfdc 0 waitforsem
omx api sendcommand state dc 0 exec
omx api sendcommand state vfdc 0 exec
omx api sendcommand state vfcc 0 exec
omx api sendcommand state tvp 0 exec
sleep 5000
omx api sendcommand state vfcc 0 loaded
omx api sendcommand state tvp 0 loaded
omx api sendcommand state dc 0 loaded
omx api sendcommand state vfdc 0 loaded
omx api freehandle vfcc 0
omx api freehandle tvp 0
omx api freehandle dc 0
omx api freehandle vfdc 0
omx api uninit
