DM8107: What are these merge links for?
Other Parts Discussed in Thread: DM8107
 I am using DM8107 to implement my car's application. In the top comments section of DVRRDK_03.00.00.00/dvr_rdk/mcfw/src_linux/mcfw_api/usecases/ti810x, it describes the system flow for this use case. I wonder what are these merge links for.
D1_CIF_MERGE_LINK_IDX: merge DEI-SC YUV420 , VIP-SC YUV420 and VIP-SC1 YUV420?
LIVE_DECODE_MERGE_LINK_IDX: merge DEI-SC YUV422I and IPCM3IN(VPSS)?
Are there any documents for it?
Thank you in advance.
 * Copyright (c) 2009 Texas Instruments Incorporated - http://www.ti.com/      *
 *                        ALL RIGHTS RESERVED                                  *
/* This usecase assumes that all 3 outputs - D1 <h.264> + CIF <h.264> + D1 <MJPEG> are enabled */
/*------------------------------ D1 <h.264> + CIF <h.264> + D1 <MJPEG> -------------------------------------
                  Capture (YUV422I) 4CH D1 60fps
                              DEI
                       (DEI-SC YUV422I)                              (VIP-SC YUV420 )            (VIP-SC1 YUV420 )
                              D1                                        D1 |                        CIF|
                         D1_DUP_LINK_IDX                                   |                           |
                              |    NSF                                     |                           |
                              |  (YUV420)                                  |                           |
                              |                      <D1-MJPEG> 2|         |0         | 1
                              |                                  |         |<D1-H.264>| <CIF-H.264>
                              |                                     FRAMESOUT(VPSS)---------------<<<processLink>>>----FramesInDSP--------ALG_LINK <OSD, SCD Algs>
                              |                                       IPCM3OUT(VPSS)------IPCM3IN(VID)----ENC-----IPCBITS_RTOSOUT(VID)-----IPCBITS_HLOSIN(HOST)-----FILEOUT
                              |+--------------------------IPCM3IN(VPSS)---------IPCM3OUT(VID)---------DEC---------------IPCBITS_RTOSIN(VID)-----------IPCBITS_HLOSOUT(HOST)
                        LIVE_DECODE_DUP_LINK_IDX
          SW Mosaic 1                       SW Mosaic 0
         (SC2 YUV422I)                     (SC5 YUV422I)
          DISPLAY 1                           DISPLAY 0
       -------------                       -------------   <tied>
          <SDTV>                          <On-Chip HDMI> --------- <Off-Chip HDMI>
         PAL/NTSC                            1080p60                 1080p60
#include "mcfw/src_linux/mcfw_api/usecases/multich_common.h"
#include "mcfw/src_linux/mcfw_api/usecases/multich_ipcbits.h"
// Keeping TILER disabled for encs 4D1 usecase
#define TILER_ENABLE_ENC  TRUE
#define TILER_ENABLE_DEC  TRUE
 * Use case code
static SystemVideo_Ivahd2ChMap_Tbl systemVid_encDecIvaChMapTbl =
    .isPopulated = 1,
    .ivaMap[0] =
        .EncNumCh  = 16,
        .EncChList = {0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13 , 14, 15},
        .DecNumCh  = 16,
        .DecChList = {0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13 , 14, 15},
#define     ADD_NSF_AFTER_CAPTURE
#define     NUM_MERGE_LINK                          2
#define     D1_CIF_MERGE_LINK_IDX                  0
#define     LIVE_DECODE_MERGE_LINK_IDX             1
#define     NUM_DUP_LINK                            2
#define     D1_DUP_LINK_IDX                         0
#define     LIVE_DECODE_DUP_LINK_IDX                1
#define     NUM_CAPTURE_BUFFERS          5
#define     NUM_NSF_BUFFERS              5
#define     NUM_ENCODE_D1_BUFFERS        4
#define     NUM_ENCODE_CIF_BUFFERS       4
#define     NUM_DECODE_BUFFERS           4
#define     NUM_IPC_OUT_BUFFERS          4
#define     NUM_SWMS_MAX_BUFFERS_HD      5
#define     NUM_SWMS_MAX_BUFFERS_SD      7
#define     NUM_DEI_ENC_BUFFERS          3
#define     NUM_CAPTURE_DEVICES          1
static void set_DEI_VIP0_SC_DEI_SC_outputFPS(UInt32 inputFPS, UInt32 outputFPS)
    UInt32 deiId, chId;
    DeiLink_ChFpsParams deiFrameRate;
    deiId = gVcapModuleContext.deiId[0];
    for(chId=0; chId<4; chId++)
        deiFrameRate.chId = chId;
        deiFrameRate.streamId = DEI_LINK_OUT_QUE_DEI_SC;
        deiFrameRate.inputFrameRate = inputFPS;
        deiFrameRate.outputFrameRate = outputFPS;
        System_linkControl(
            deiId,
            DEI_LINK_CMD_SET_FRAME_RATE,
            &deiFrameRate,
            sizeof(deiFrameRate),
            TRUE
/* This usecase assumes CIF <secondary out>, MJPEG are enabled */
Void MultiCh_createProgressive4D1VcapVencVdecVdis()
    CaptureLink_CreateParams    capturePrm;
    NsfLink_CreateParams        nsfPrm;
    DeiLink_CreateParams        deiPrm;
    MergeLink_CreateParams      mergePrm[NUM_MERGE_LINK];
    DupLink_CreateParams        dupPrm[NUM_DUP_LINK];
    static SwMsLink_CreateParams       swMsPrm[VDIS_DEV_MAX];
    DisplayLink_CreateParams    displayPrm[VDIS_DEV_MAX];
    IpcLink_CreateParams        ipcOutVpssPrm;
    IpcLink_CreateParams        ipcInVpssPrm;
    IpcLink_CreateParams        ipcOutVideoPrm;
    IpcLink_CreateParams        ipcInVideoPrm;
    EncLink_CreateParams        encPrm;
    DecLink_CreateParams        decPrm;
    IpcBitsOutLinkHLOS_CreateParams   ipcBitsOutHostPrm;
    IpcBitsOutLinkRTOS_CreateParams   ipcBitsOutVideoPrm;
    IpcBitsInLinkHLOS_CreateParams    ipcBitsInHostPrm[2];
    IpcBitsInLinkRTOS_CreateParams    ipcBitsInVideoPrm;
    CaptureLink_VipInstParams         *pCaptureInstPrm;
    CaptureLink_OutParams             *pCaptureOutPrm;
    IpcFramesInLinkRTOS_CreateParams  ipcFramesInDspPrm;
    IpcFramesOutLinkRTOS_CreateParams ipcFramesOutVpssPrm;
    AlgLink_CreateParams              dspAlgPrm;
//    System_LinkInfo                   bitsProducerLinkInfo;
    UInt32 mergeId[NUM_MERGE_LINK];
    UInt32 dupId[NUM_DUP_LINK];
    UInt32 ipcOutVpssId, ipcInVpssId;
    UInt32 ipcOutVideoId, ipcInVideoId;
    IpcBitsOutLinkRTOS_CreateParams   ipcBitsOutDspPrm;
    VCAP_VIDDEC_PARAMS_S vidDecVideoModeArgs[NUM_CAPTURE_DEVICES];
    UInt32 vipInstId;
    UInt32 i, j;
    Bool   enableAlgLink;
    Bool   enableScd     = gVsysModuleContext.vsysConfig.enableScd;
    Bool   enableOsd     = gVsysModuleContext.vsysConfig.enableOsd;
 #ifdef     ADD_NSF_AFTER_CAPTURE
    NsfLink_CreateParams        nsfPrm2;
#endif
    enableScd = TRUE;
    enableAlgLink = FALSE;
    if(enableOsd||enableScd)
        enableAlgLink = TRUE;
    MULTICH_INIT_STRUCT(IpcLink_CreateParams,ipcOutVpssPrm);
    MULTICH_INIT_STRUCT(IpcLink_CreateParams,ipcInVpssPrm);
    MULTICH_INIT_STRUCT(IpcLink_CreateParams,ipcOutVideoPrm);
    MULTICH_INIT_STRUCT(IpcLink_CreateParams,ipcInVideoPrm);
    MULTICH_INIT_STRUCT(IpcBitsOutLinkHLOS_CreateParams,ipcBitsOutHostPrm);
    MULTICH_INIT_STRUCT(IpcBitsOutLinkRTOS_CreateParams,ipcBitsOutVideoPrm);
    MULTICH_INIT_STRUCT(IpcBitsOutLinkRTOS_CreateParams,ipcBitsOutDspPrm);
    MULTICH_INIT_STRUCT(IpcBitsInLinkHLOS_CreateParams,ipcBitsInHostPrm[0]);
    MULTICH_INIT_STRUCT(IpcBitsInLinkHLOS_CreateParams,ipcBitsInHostPrm[1]);
    MULTICH_INIT_STRUCT(IpcBitsInLinkRTOS_CreateParams,ipcBitsInVideoPrm);
    MULTICH_INIT_STRUCT(DecLink_CreateParams, decPrm);
    MULTICH_INIT_STRUCT(IpcFramesInLinkRTOS_CreateParams,ipcFramesInDspPrm);
    MULTICH_INIT_STRUCT(IpcFramesOutLinkRTOS_CreateParams,ipcFramesOutVpssPrm);
    MULTICH_INIT_STRUCT(EncLink_CreateParams, encPrm);
    MULTICH_INIT_STRUCT(AlgLink_CreateParams, dspAlgPrm);
    for (i = 0; i < VDIS_DEV_MAX;i++)
        MULTICH_INIT_STRUCT(DisplayLink_CreateParams,
                            displayPrm[i]);
        MULTICH_INIT_STRUCT(SwMsLink_CreateParams ,swMsPrm[i]);
    MULTICH_INIT_STRUCT(NsfLink_CreateParams, nsfPrm);
    MULTICH_INIT_STRUCT(DeiLink_CreateParams, deiPrm);
    printf("\n********* Entered usecase 4CH <814x> Enc/Dec OSD %s SCD %s \n\n",
            enableOsd == TRUE ? "Enabled" : "Disabled",
            enableScd == TRUE ? "Enabled" : "Disabled"
    MultiCh_detectBoard();
    System_linkControl(
        SYSTEM_LINK_ID_M3VPSS,
        SYSTEM_M3VPSS_CMD_RESET_VIDEO_DEVICES,
        NULL,
        0,
        TRUE
    System_linkControl(
        SYSTEM_LINK_ID_M3VIDEO,
        SYSTEM_COMMON_CMD_SET_CH2IVAHD_MAP_TBL,
        &systemVid_encDecIvaChMapTbl,
        sizeof(SystemVideo_Ivahd2ChMap_Tbl),
        TRUE
    vipInstId = 0;
    gVcapModuleContext.captureId    = SYSTEM_LINK_ID_CAPTURE;
    if(enableAlgLink)
        gVcapModuleContext.dspAlgId[0] = SYSTEM_LINK_ID_VIDEO_ALG_0  ;
    gVcapModuleContext.nsfId[0]     = SYSTEM_LINK_ID_NSF_0;
    gVcapModuleContext.nsfId[1]     =SYSTEM_LINK_ID_NSF_1;
#endif
    gVcapModuleContext.deiId[0]     = SYSTEM_LINK_ID_DEI_0;
    gVencModuleContext.encId        = SYSTEM_LINK_ID_VENC_0;
    gVdecModuleContext.decId        = SYSTEM_LINK_ID_VDEC_0;
    gVdisModuleContext.swMsId[0]      = SYSTEM_LINK_ID_SW_MS_MULTI_INST_0;
    gVdisModuleContext.swMsId[1]      = SYSTEM_LINK_ID_SW_MS_MULTI_INST_1;
    swMsPrm[0].numSwMsInst = 1;
    swMsPrm[1].numSwMsInst = 1;
    #if defined (TI_814X_BUILD) || defined (TI_8107_BUILD)
    /* use AUX scaler (SC2), since SC1 is used for DEI */
    swMsPrm[0].swMsInstId[0] = SYSTEM_SW_MS_SC_INST_DEI_SC_NO_DEI;
    #else
    /* use MAIN scaler (SC1), since SC2 is used for DEI */
    swMsPrm[0].swMsInstId[0] = SYSTEM_SW_MS_SC_INST_DEIHQ_SC_NO_DEI;
    #endif
    swMsPrm[1].swMsInstId[0] = SYSTEM_SW_MS_SC_INST_SC5;
    gVdisModuleContext.displayId[0] = SYSTEM_LINK_ID_DISPLAY_0; /* ON AND OFF CHIP HDMI */
    gVdisModuleContext.displayId[1] = SYSTEM_LINK_ID_DISPLAY_2; /* SDTV */
    mergeId[LIVE_DECODE_MERGE_LINK_IDX]     = SYSTEM_VPSS_LINK_ID_MERGE_0;
    mergeId[D1_CIF_MERGE_LINK_IDX]          = SYSTEM_VPSS_LINK_ID_MERGE_1;
    dupId[D1_DUP_LINK_IDX]              = SYSTEM_VPSS_LINK_ID_DUP_0;
    dupId[LIVE_DECODE_DUP_LINK_IDX]     = SYSTEM_VPSS_LINK_ID_DUP_1;
    ipcOutVpssId = SYSTEM_VPSS_LINK_ID_IPC_OUT_M3_0;
    ipcInVideoId = SYSTEM_VIDEO_LINK_ID_IPC_IN_M3_0;
    ipcOutVideoId= SYSTEM_VIDEO_LINK_ID_IPC_OUT_M3_0;
    ipcInVpssId  = SYSTEM_VPSS_LINK_ID_IPC_IN_M3_0;
    gVencModuleContext.ipcBitsOutRTOSId  = SYSTEM_VIDEO_LINK_ID_IPC_BITS_OUT_0;
    gVencModuleContext.ipcBitsInHLOSId   = SYSTEM_HOST_LINK_ID_IPC_BITS_IN_0;
    gVdecModuleContext.ipcBitsOutHLOSId  = SYSTEM_HOST_LINK_ID_IPC_BITS_OUT_0;
    gVdecModuleContext.ipcBitsInRTOSId  = SYSTEM_VIDEO_LINK_ID_IPC_BITS_IN_0;
    CaptureLink_CreateParams_Init(&capturePrm);
    capturePrm.outQueParams[0].nextLink   = gVcapModuleContext.nsfId[1];
#else
    capturePrm.outQueParams[0].nextLink   = gVcapModuleContext.deiId[0];
#endif
    capturePrm.numVipInst                 = 1;
    capturePrm.tilerEnable                = FALSE;
    capturePrm.numBufsPerCh               = NUM_CAPTURE_BUFFERS;
    pCaptureInstPrm                     = &capturePrm.vipInst[0];
    pCaptureInstPrm->vipInstId          = (SYSTEM_CAPTURE_INST_VIP0_PORTA+
                                          vipInstId)%SYSTEM_CAPTURE_INST_MAX;
    pCaptureInstPrm->videoDecoderId     = SYSTEM_DEVICE_VID_DEC_TVP5158_DRV;
    pCaptureInstPrm->inDataFormat       = SYSTEM_DF_YUV422P;
    pCaptureInstPrm->standard           = SYSTEM_STD_MUX_4CH_D1;
    pCaptureInstPrm->numOutput          = 1;
    pCaptureOutPrm                      = &pCaptureInstPrm->outParams[0];
    pCaptureOutPrm->dataFormat          = SYSTEM_DF_YUV422I_YUYV;
    pCaptureOutPrm->scEnable            = FALSE;
    pCaptureOutPrm->scOutWidth          = 0;
    pCaptureOutPrm->scOutHeight         = 0;
    pCaptureOutPrm->outQueId            = 0;
    for(i = 0; i < NUM_CAPTURE_DEVICES; i++)
        vidDecVideoModeArgs[i].videoIfMode        = DEVICE_CAPT_VIDEO_IF_MODE_8BIT;
        vidDecVideoModeArgs[i].videoDataFormat    = SYSTEM_DF_YUV422P;
        vidDecVideoModeArgs[i].standard           = SYSTEM_STD_MUX_4CH_D1;
        vidDecVideoModeArgs[i].videoCaptureMode   =
                    DEVICE_CAPT_VIDEO_CAPTURE_MODE_MULTI_CH_PIXEL_MUX_EMBEDDED_SYNC;
        vidDecVideoModeArgs[i].videoSystem        =
                                      DEVICE_VIDEO_DECODER_VIDEO_SYSTEM_AUTO_DETECT;
        vidDecVideoModeArgs[i].videoCropEnable    = FALSE;
        vidDecVideoModeArgs[i].videoAutoDetectTimeout = -1;
    Vcap_configVideoDecoder(vidDecVideoModeArgs, NUM_CAPTURE_DEVICES);
    nsfPrm2.bypassNsf                          = TRUE;
    nsfPrm2.tilerEnable                          = FALSE;
    nsfPrm2.inQueParams.prevLinkId          = gVcapModuleContext.captureId;
    nsfPrm2.inQueParams.prevLinkQueId     = 0;
    nsfPrm2.numOutQue                        = 1;
    nsfPrm2.outQueParams[0].nextLink      = gVcapModuleContext.deiId[0];
    nsfPrm2.numBufsPerCh                     = NUM_NSF_BUFFERS;
    nsfPrm2.inputFrameRate                    = 30;
    nsfPrm2.outputFrameRate                  = 30;
    deiPrm.inQueParams.prevLinkId = gVcapModuleContext.nsfId[1];
#else
    deiPrm.inQueParams.prevLinkId = gVcapModuleContext.captureId;
#endif
    deiPrm.inQueParams.prevLinkQueId  = 0;
    /* Set Output Scaling at DEI based on ratio */
    deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_DEI_SC][0].scaleMode = DEI_SCALE_MODE_RATIO;
    deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_DEI_SC][0].ratio.widthRatio.numerator = 1;
    deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_DEI_SC][0].ratio.widthRatio.denominator = 1;
    deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_DEI_SC][0].ratio.heightRatio.numerator = 1;
    deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_DEI_SC][0].ratio.heightRatio.denominator = 1;
    for (i=1; i < DEI_LINK_MAX_CH; i++)
        deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_DEI_SC][i] = deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_DEI_SC][0];
    deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0].scaleMode = DEI_SCALE_MODE_RATIO;
    deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0].ratio.heightRatio.numerator = 1;
    deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0].ratio.heightRatio.denominator = 1;
    deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0].ratio.widthRatio.numerator = 1;
    deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0].ratio.widthRatio.denominator = 1;
        deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][i] = deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0];
    deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC_SECONDARY_OUT][0].scaleMode = DEI_SCALE_MODE_RATIO;
    deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC_SECONDARY_OUT][0].ratio.heightRatio.numerator = 1;
    deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC_SECONDARY_OUT][0].ratio.heightRatio.denominator = 2;
    deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC_SECONDARY_OUT][0].ratio.widthRatio.numerator = 1;
    deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC_SECONDARY_OUT][0].ratio.widthRatio.denominator = 2;
        deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC_SECONDARY_OUT][i] = deiPrm.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC_SECONDARY_OUT][0];
    deiPrm.enableOut[DEI_LINK_OUT_QUE_DEI_SC]                        = TRUE;
    deiPrm.enableOut[DEI_LINK_OUT_QUE_VIP_SC]                        = TRUE;
    deiPrm.enableOut[DEI_LINK_OUT_QUE_VIP_SC_SECONDARY_OUT]          = TRUE;
    deiPrm.outQueParams[DEI_LINK_OUT_QUE_DEI_SC].nextLink                   = dupId[D1_DUP_LINK_IDX];
    deiPrm.outQueParams[DEI_LINK_OUT_QUE_VIP_SC].nextLink                   = mergeId[D1_CIF_MERGE_LINK_IDX];
    deiPrm.outQueParams[DEI_LINK_OUT_QUE_VIP_SC_SECONDARY_OUT].nextLink     = mergeId[D1_CIF_MERGE_LINK_IDX];
    deiPrm.tilerEnable[DEI_LINK_OUT_QUE_VIP_SC]          = TILER_ENABLE_ENC;
    deiPrm.comprEnable                                   = FALSE;
    deiPrm.setVipScYuv422Format                          = FALSE;
    deiPrm.numBufsPerCh[DEI_LINK_OUT_QUE_VIP_SC] = NUM_DEI_ENC_BUFFERS;
    deiPrm.numBufsPerCh[DEI_LINK_OUT_QUE_VIP_SC_SECONDARY_OUT] = NUM_DEI_ENC_BUFFERS;
    dupPrm[D1_DUP_LINK_IDX].inQueParams.prevLinkId         = gVcapModuleContext.deiId[0];
    dupPrm[D1_DUP_LINK_IDX].inQueParams.prevLinkQueId      = DEI_LINK_OUT_QUE_DEI_SC;
    dupPrm[D1_DUP_LINK_IDX].numOutQue                      = 2;
    dupPrm[D1_DUP_LINK_IDX].outQueParams[0].nextLink       = mergeId[LIVE_DECODE_MERGE_LINK_IDX];
    dupPrm[D1_DUP_LINK_IDX].outQueParams[1].nextLink       = gVcapModuleContext.nsfId[0];
    dupPrm[D1_DUP_LINK_IDX].notifyNextLink                 = TRUE;
    nsfPrm.bypassNsf                        = TRUE;
    nsfPrm.tilerEnable                      = FALSE;
    nsfPrm.inQueParams.prevLinkId           = dupId[D1_DUP_LINK_IDX];
    nsfPrm.inQueParams.prevLinkQueId        = 1;
    nsfPrm.numOutQue                        = 1;
    nsfPrm.outQueParams[0].nextLink         = mergeId[D1_CIF_MERGE_LINK_IDX];
    nsfPrm.numBufsPerCh                     = 1;
    nsfPrm.inputFrameRate = 30;
    nsfPrm.outputFrameRate = 1;
    /* Merge Q0 - D1 <from VIP-SC>, Q1 - CIF <from VIP-SC_SECONDARY>, Q2 -D1 for MJPEG <from DEI-SC>  */
    mergePrm[D1_CIF_MERGE_LINK_IDX].inQueParams[0].prevLinkId       = gVcapModuleContext.deiId[0];
    mergePrm[D1_CIF_MERGE_LINK_IDX].inQueParams[0].prevLinkQueId    = DEI_LINK_OUT_QUE_VIP_SC;
    mergePrm[D1_CIF_MERGE_LINK_IDX].inQueParams[1].prevLinkId       = gVcapModuleContext.deiId[0];
    mergePrm[D1_CIF_MERGE_LINK_IDX].inQueParams[1].prevLinkQueId    = DEI_LINK_OUT_QUE_VIP_SC_SECONDARY_OUT;
    mergePrm[D1_CIF_MERGE_LINK_IDX].inQueParams[2].prevLinkId       = gVcapModuleContext.nsfId[0];
    mergePrm[D1_CIF_MERGE_LINK_IDX].inQueParams[2].prevLinkQueId    = 0;
    mergePrm[D1_CIF_MERGE_LINK_IDX].notifyNextLink                  = TRUE;
    mergePrm[D1_CIF_MERGE_LINK_IDX].numInQue = 3;
    ipcOutVpssPrm.inQueParams.prevLinkQueId    = 0;
        mergePrm[D1_CIF_MERGE_LINK_IDX].outQueParams.nextLink  = ipcOutVpssId;
        ipcOutVpssPrm.inQueParams.prevLinkId                   = mergeId[D1_CIF_MERGE_LINK_IDX];
    ipcOutVpssPrm.numOutQue = 1;
    ipcOutVpssPrm.outQueParams[0].nextLink     = ipcInVideoId;
    ipcOutVpssPrm.notifyNextLink               = TRUE;
    ipcOutVpssPrm.notifyPrevLink               = TRUE;
    ipcOutVpssPrm.noNotifyMode                 = FALSE;
    ipcInVideoPrm.inQueParams.prevLinkId       = ipcOutVpssId;
    ipcInVideoPrm.inQueParams.prevLinkQueId    = 0;
    ipcInVideoPrm.numOutQue                    = 1;
    if (enableAlgLink)
		ipcInVideoPrm.outQueParams[0].nextLink     = gVcapModuleContext.dspAlgId[0];
		dspAlgPrm.inQueParams.prevLinkId           = ipcInVideoId;
		dspAlgPrm.inQueParams.prevLinkQueId        = 0;
		dspAlgPrm.outQueParams[ALG_LINK_FRAMES_OUT_QUE].nextLink = gVencModuleContext.encId;
	else {
		ipcInVideoPrm.outQueParams[0].nextLink     = gVencModuleContext.encId;
    ipcInVideoPrm.notifyNextLink               = TRUE;
    ipcInVideoPrm.notifyPrevLink               = TRUE;
    ipcInVideoPrm.noNotifyMode                 = FALSE;
        EncLink_ChCreateParams *pLinkChPrm;
        EncLink_ChDynamicParams *pLinkDynPrm;
        VENC_CHN_DYNAMIC_PARAM_S *pDynPrm;
        VENC_CHN_PARAMS_S *pChPrm;
        EncLink_CreateParams_Init(&encPrm);
        encPrm.numBufPerCh[0] = NUM_ENCODE_D1_BUFFERS;
        encPrm.numBufPerCh[1] = NUM_ENCODE_CIF_BUFFERS;
        /* Primary Stream Params - D1 */
        for (i=0; i<gVencModuleContext.vencConfig.numPrimaryChn; i++)
            pLinkChPrm  = &encPrm.chCreateParams[i];
            pLinkDynPrm = &pLinkChPrm->defaultDynamicParams;
            pChPrm      = &gVencModuleContext.vencConfig.encChannelParams[i];
            pDynPrm     = &pChPrm->dynamicParam;
            pLinkChPrm->format                  = IVIDEO_H264HP;
            pLinkChPrm->profile                 = gVencModuleContext.vencConfig.h264Profile[i];
            pLinkChPrm->dataLayout              = IVIDEO_FIELD_SEPARATED;
            pLinkChPrm->fieldMergeEncodeEnable  = FALSE;
            pLinkChPrm->enableAnalyticinfo      = pChPrm->enableAnalyticinfo;
            pLinkChPrm->enableWaterMarking      = pChPrm->enableWaterMarking;
            pLinkChPrm->maxBitRate              = pChPrm->maxBitRate;
            pLinkChPrm->encodingPreset          = pChPrm->encodingPreset;
            pLinkChPrm->rateControlPreset       = pChPrm->rcType;
            pLinkChPrm->enableSVCExtensionFlag  = pChPrm->enableSVCExtensionFlag;
            pLinkChPrm->numTemporalLayer        = pChPrm->numTemporalLayer;
            pLinkDynPrm->intraFrameInterval     = pDynPrm->intraFrameInterval;
            pLinkDynPrm->targetBitRate          = pDynPrm->targetBitRate;
            pLinkDynPrm->interFrameInterval     = 1;
            pLinkDynPrm->mvAccuracy             = IVIDENC2_MOTIONVECTOR_QUARTERPEL;
            pLinkDynPrm->inputFrameRate         = pDynPrm->inputFrameRate;
            pLinkDynPrm->rcAlg                  = pDynPrm->rcAlg;
            pLinkDynPrm->qpMin                  = pDynPrm->qpMin;
            pLinkDynPrm->qpMax                  = pDynPrm->qpMax;
            pLinkDynPrm->qpInit                 = pDynPrm->qpInit;
            pLinkDynPrm->vbrDuration            = pDynPrm->vbrDuration;
            pLinkDynPrm->vbrSensitivity         = pDynPrm->vbrSensitivity;
        /* Secondary Out <CIF> Params */
        for (i=gVencModuleContext.vencConfig.numPrimaryChn, j=VENC_PRIMARY_CHANNELS;
              i<(gVencModuleContext.vencConfig.numPrimaryChn
                       + gVencModuleContext.vencConfig.numSecondaryChn);
                i++, j++)
            pChPrm      = &gVencModuleContext.vencConfig.encChannelParams[j];
        /* MJPEG  Params */
        for (i=gVencModuleContext.vencConfig.numPrimaryChn + gVencModuleContext.vencConfig.numSecondaryChn;
                  i<(VENC_CHN_MAX); i++)
             pLinkChPrm->format                 = IVIDEO_MJPEG;
             pLinkChPrm->profile                = 0;
             pLinkChPrm->enableAnalyticinfo     = 0;
             pLinkChPrm->enableWaterMarking     = 0;
             pLinkChPrm->maxBitRate             = 0;
             pLinkChPrm->encodingPreset         = 0;
             pLinkChPrm->rateControlPreset      = 0;
             pLinkChPrm->enableSVCExtensionFlag = 0;
             pLinkChPrm->numTemporalLayer       = 0;
             pLinkDynPrm->intraFrameInterval    = 0;
             pLinkDynPrm->targetBitRate         = 100*1000;
             pLinkDynPrm->interFrameInterval    = 0;
             pLinkDynPrm->mvAccuracy            = 0;
             pLinkDynPrm->qpMin                 = 0;
             pLinkDynPrm->qpMax                 = 0;
             pLinkDynPrm->qpInit                = -1;
             pLinkDynPrm->vbrDuration           = 0;
             pLinkDynPrm->vbrSensitivity        = 0;
	    if (enableAlgLink)
			encPrm.inQueParams.prevLinkId    = gVcapModuleContext.dspAlgId[0];
			encPrm.inQueParams.prevLinkQueId = ALG_LINK_FRAMES_OUT_QUE;
		else {
			encPrm.inQueParams.prevLinkId    = ipcInVideoId;
			encPrm.inQueParams.prevLinkQueId = 0;
        encPrm.outQueParams.nextLink     = gVencModuleContext.ipcBitsOutRTOSId;
    ipcBitsOutVideoPrm.baseCreateParams.inQueParams.prevLinkId = gVencModuleContext.encId;
    ipcBitsOutVideoPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
    ipcBitsOutVideoPrm.baseCreateParams.numOutQue                 = 1;
    ipcBitsOutVideoPrm.baseCreateParams.outQueParams[0].nextLink = gVencModuleContext.ipcBitsInHLOSId;
    MultiCh_ipcBitsInitCreateParams_BitsOutRTOS(&ipcBitsOutVideoPrm,
                                               TRUE);
    ipcBitsInHostPrm[0].baseCreateParams.inQueParams.prevLinkId = gVencModuleContext.ipcBitsOutRTOSId;
    ipcBitsInHostPrm[0].baseCreateParams.inQueParams.prevLinkQueId = 0;
    MultiCh_ipcBitsInitCreateParams_BitsInHLOS(&ipcBitsInHostPrm[0]);
    dspAlgPrm.enableOSDAlg = enableOsd;
    if(enableOsd)
        int chId;
        for(chId = 0; chId < ALG_LINK_OSD_MAX_CH; chId++)
            AlgLink_OsdChWinParams * chWinPrm = &dspAlgPrm.osdChCreateParams[chId].chDefaultParams;
            /* set osd window max width and height */
            dspAlgPrm.osdChCreateParams[chId].maxWidth  = EXAMPLE_OSD_WIN_MAX_WIDTH;
            dspAlgPrm.osdChCreateParams[chId].maxHeight = EXAMPLE_OSD_WIN_MAX_HEIGHT;
            chWinPrm->chId = chId;
            chWinPrm->numWindows = 0;
    dspAlgPrm.enableSCDAlg              = enableScd;
    dspAlgPrm.outQueParams[ALG_LINK_SCD_OUT_QUE].nextLink     = SYSTEM_LINK_ID_INVALID;
    if (enableScd)
        UInt32 i, startChId;
        AlgLink_ScdCreateParams *pScdCreatePrm;
        AlgLink_ScdChParams *pScdChPrm;
        pScdCreatePrm = &dspAlgPrm.scdCreateParams;
        pScdCreatePrm->maxWidth               = 352;
        pScdCreatePrm->maxHeight              = 288;
        pScdCreatePrm->maxStride              = 352;
        pScdCreatePrm->numValidChForSCD       = 4;
        pScdCreatePrm->numSecs2WaitB4Init     = 3;
        pScdCreatePrm->numSecs2WaitB4FrmAlert = 1;
        pScdCreatePrm->inputFrameRate         = 30;
        pScdCreatePrm->outputFrameRate        = 5;
        pScdCreatePrm->numSecs2WaitAfterFrmAlert = 1;
        pScdCreatePrm->enableTamperNotify = FALSE;
        /* enable SCD only for CIF CHs */
        startChId = 4;
        for(i=0; i<pScdCreatePrm->numValidChForSCD; i++)
            pScdChPrm = &pScdCreatePrm->chDefaultParams[i];
            pScdChPrm->chId = startChId;
            pScdChPrm->mode                = ALG_LINK_SCD_DETECTMODE_MONITOR_FULL_FRAME;
            pScdChPrm->frmIgnoreLightsON   = FALSE;
            pScdChPrm->frmIgnoreLightsOFF  = FALSE;
            pScdChPrm->frmSensitivity      = ALG_LINK_SCD_SENSITIVITY_VERYHIGH;
            pScdChPrm->frmEdgeThreshold    = 0;
            pScdChPrm->blkNumBlksInFrame   = 0;
            startChId++;
#ifndef SYSTEM_USE_VIDEO_DECODER
    capturePrm.isPalMode = Vcap_isPalMode();
#endif
    System_linkCreate (gVcapModuleContext.captureId, &capturePrm, sizeof(capturePrm));
    System_linkCreate(gVcapModuleContext.nsfId[1], &nsfPrm2, sizeof(nsfPrm2));
#endif
    System_linkCreate(gVcapModuleContext.deiId[0], &deiPrm, sizeof(deiPrm));
    System_linkCreate(dupId[D1_DUP_LINK_IDX], &dupPrm[D1_DUP_LINK_IDX], sizeof(dupPrm[D1_DUP_LINK_IDX]));
    System_linkCreate(gVcapModuleContext.nsfId[0] , &nsfPrm, sizeof(nsfPrm));
    System_linkCreate(mergeId[D1_CIF_MERGE_LINK_IDX], &mergePrm[D1_CIF_MERGE_LINK_IDX], sizeof(mergePrm[D1_CIF_MERGE_LINK_IDX]));
    System_linkCreate(ipcOutVpssId , &ipcOutVpssPrm , sizeof(ipcOutVpssPrm) );
    System_linkCreate(ipcInVideoId , &ipcInVideoPrm , sizeof(ipcInVideoPrm) );
    if(enableAlgLink)
        /* only create OSD alg */
        System_linkCreate(gVcapModuleContext.dspAlgId[0] , &dspAlgPrm, sizeof(dspAlgPrm));
    ipcBitsOutHostPrm.baseCreateParams.outQueParams[0].nextLink = gVdecModuleContext.ipcBitsInRTOSId;
    set_DEI_VIP0_SC_DEI_SC_outputFPS (60, 60);
    // DONT use bitsProducerLinkInfo
    MultiCh_ipcBitsInitCreateParams_BitsOutHLOS(&ipcBitsOutHostPrm,
                                               &bitsProducerLinkInfo.queInfo[0]);
    ipcBitsOutHostPrm.baseCreateParams.notifyNextLink = FALSE;
    ipcBitsOutHostPrm.baseCreateParams.notifyPrevLink = FALSE;
    ipcBitsOutHostPrm.numBufPerCh[0]  = NUM_IPC_OUT_BUFFERS;
        /* use channel info provided by user instead of from encoder */
        UInt32 chId;
        System_LinkChInfo *pChInfo;
        ipcBitsOutHostPrm.inQueInfo.numCh = 4;
        for(chId=0; chId<ipcBitsOutHostPrm.inQueInfo.numCh; chId++)
            pChInfo = &ipcBitsOutHostPrm.inQueInfo.chInfo[chId];
            /* Not Used - Start */
            pChInfo->bufType        = 0;
            pChInfo->codingformat   = 0;
            pChInfo->dataFormat     = 0;
            pChInfo->memType        = 0;
            pChInfo->startX         = 0;
            pChInfo->startY         = 0;
            pChInfo->pitch[0]       = 0;
            pChInfo->pitch[1]       = 0;
            pChInfo->pitch[2]       = 0;
            /* Not Used - End */
            pChInfo->width          = 720;
            pChInfo->height         = 576;
            pChInfo->scanFormat     = SYSTEM_SF_PROGRESSIVE;
    ipcBitsInVideoPrm.baseCreateParams.inQueParams.prevLinkId       = gVdecModuleContext.ipcBitsOutHLOSId;
    ipcBitsInVideoPrm.baseCreateParams.inQueParams.prevLinkQueId    = 0;
    ipcBitsInVideoPrm.baseCreateParams.numOutQue                    = 1;
    ipcBitsInVideoPrm.baseCreateParams.outQueParams[0].nextLink     = gVdecModuleContext.decId;
    MultiCh_ipcBitsInitCreateParams_BitsInRTOS(&ipcBitsInVideoPrm, TRUE);
    for (i=0; i<gVdecModuleContext.vdecConfig.numChn; i++) {
        decPrm.chCreateParams[i].format                 = IVIDEO_H264HP;
        decPrm.chCreateParams[i].profile                = IH264VDEC_PROFILE_ANY;
        decPrm.chCreateParams[i].fieldMergeDecodeEnable = FALSE;
        decPrm.chCreateParams[i].targetMaxWidth         = ipcBitsOutHostPrm.inQueInfo.chInfo[i].width;
        decPrm.chCreateParams[i].targetMaxHeight        = ipcBitsOutHostPrm.inQueInfo.chInfo[i].height;
        decPrm.chCreateParams[i].defaultDynamicParams.targetFrameRate = gVdecModuleContext.vdecConfig.decChannelParams[i].dynamicParam.frameRate;
        decPrm.chCreateParams[i].defaultDynamicParams.targetBitRate   = gVdecModuleContext.vdecConfig.decChannelParams[i].dynamicParam.targetBitRate;
        /* Max ref frames is only 2 as this is closed loop decoder */
        decPrm.chCreateParams[i].dpbBufSizeInFrames                   = 2;
        decPrm.chCreateParams[i].numBufPerCh = NUM_DECODE_BUFFERS;
    decPrm.inQueParams.prevLinkId    = gVdecModuleContext.ipcBitsInRTOSId;
    decPrm.inQueParams.prevLinkQueId = 0;
    decPrm.outQueParams.nextLink  = ipcOutVideoId;
    decPrm.tilerEnable = TILER_ENABLE_DEC;
    ipcOutVideoPrm.inQueParams.prevLinkId    = gVdecModuleContext.decId;
    ipcOutVideoPrm.inQueParams.prevLinkQueId = 0;
    ipcOutVideoPrm.numOutQue                 = 1;
    ipcOutVideoPrm.outQueParams[0].nextLink  = ipcInVpssId;
    ipcOutVideoPrm.notifyNextLink            = TRUE;
    ipcOutVideoPrm.notifyPrevLink            = TRUE;
    ipcOutVideoPrm.noNotifyMode              = FALSE;
    ipcInVpssPrm.inQueParams.prevLinkId    = ipcOutVideoId;
    ipcInVpssPrm.inQueParams.prevLinkQueId = 0;
    ipcInVpssPrm.numOutQue                 = 1;
    ipcInVpssPrm.outQueParams[0].nextLink  = mergeId[LIVE_DECODE_MERGE_LINK_IDX];
    ipcInVpssPrm.notifyNextLink            = TRUE;
    ipcInVpssPrm.notifyPrevLink            = TRUE;
    ipcInVpssPrm.noNotifyMode              = FALSE;
    mergePrm[LIVE_DECODE_MERGE_LINK_IDX].numInQue                     = 2;
    mergePrm[LIVE_DECODE_MERGE_LINK_IDX].inQueParams[0].prevLinkId    = dupId[D1_DUP_LINK_IDX];
    mergePrm[LIVE_DECODE_MERGE_LINK_IDX].inQueParams[0].prevLinkQueId = 0;
    mergePrm[LIVE_DECODE_MERGE_LINK_IDX].inQueParams[1].prevLinkId    = ipcInVpssId;
    mergePrm[LIVE_DECODE_MERGE_LINK_IDX].inQueParams[1].prevLinkQueId = 0;
    mergePrm[LIVE_DECODE_MERGE_LINK_IDX].outQueParams.nextLink        = dupId[LIVE_DECODE_DUP_LINK_IDX];
    mergePrm[LIVE_DECODE_MERGE_LINK_IDX].notifyNextLink               = TRUE;
    dupPrm[LIVE_DECODE_DUP_LINK_IDX].inQueParams.prevLinkId         = mergeId[LIVE_DECODE_MERGE_LINK_IDX];
    dupPrm[LIVE_DECODE_DUP_LINK_IDX].inQueParams.prevLinkQueId      = 0;
    dupPrm[LIVE_DECODE_DUP_LINK_IDX].numOutQue                      = 2;
    dupPrm[LIVE_DECODE_DUP_LINK_IDX].outQueParams[0].nextLink       = gVdisModuleContext.swMsId[0];
    dupPrm[LIVE_DECODE_DUP_LINK_IDX].outQueParams[1].nextLink       = gVdisModuleContext.swMsId[1];
    dupPrm[LIVE_DECODE_DUP_LINK_IDX].notifyNextLink                 = TRUE;
    for(i=0; i<2; i++)
        swMsPrm[i].inQueParams.prevLinkId    = dupId[LIVE_DECODE_DUP_LINK_IDX];
        swMsPrm[i].inQueParams.prevLinkQueId = i;
        swMsPrm[i].outQueParams.nextLink     = gVdisModuleContext.displayId[i];
        swMsPrm[i].maxInputQueLen            = 6; // KC: changed to 4 to make the display smooth
        swMsPrm[i].maxOutRes                 = VSYS_STD_1080P_60;
        swMsPrm[i].initOutRes                = gVdisModuleContext.vdisConfig.deviceParams[i].resolution;
        swMsPrm[i].numOutBuf                 = NUM_SWMS_MAX_BUFFERS_HD;
        if (i == 1)
            swMsPrm[i].initOutRes                = gVdisModuleContext.vdisConfig.deviceParams[VDIS_DEV_SD].resolution;
            swMsPrm[i].maxOutRes                 = VSYS_STD_PAL;
            swMsPrm[i].numOutBuf                 = NUM_SWMS_MAX_BUFFERS_SD;
        swMsPrm[i].lineSkipMode = FALSE; // NOT USED
        swMsPrm[i].enableLayoutGridDraw = gVdisModuleContext.vdisConfig.enableLayoutGridDraw;
        MultiCh_swMsGetDefaultLayoutPrm(VDIS_DEV_HDMI, &swMsPrm[0], TRUE);
        MultiCh_swMsGetDefaultLayoutPrm(VDIS_DEV_SD, &swMsPrm[1], TRUE);
        displayPrm[i].inQueParams[0].prevLinkId    = gVdisModuleContext.swMsId[i];
        displayPrm[i].inQueParams[0].prevLinkQueId = 0;
        displayPrm[i].displayRes                = swMsPrm[i].initOutRes;
        if (i == 1)
            displayPrm[i].displayRes            = gVdisModuleContext.vdisConfig.deviceParams[VDIS_DEV_SD].resolution;
            displayPrm[i].forceFieldSeparatedInputMode = TRUE;
    System_linkCreate(gVdecModuleContext.ipcBitsOutHLOSId,&ipcBitsOutHostPrm,sizeof(ipcBitsOutHostPrm));
    System_linkCreate(gVdecModuleContext.ipcBitsInRTOSId,&ipcBitsInVideoPrm,sizeof(ipcBitsInVideoPrm));
    System_linkCreate(gVdecModuleContext.decId, &decPrm, sizeof(decPrm));
    System_linkCreate(gVencModuleContext.encId, &encPrm, sizeof(encPrm));
    System_linkCreate(gVencModuleContext.ipcBitsOutRTOSId, &ipcBitsOutVideoPrm, sizeof(ipcBitsOutVideoPrm));
    System_linkCreate(gVencModuleContext.ipcBitsInHLOSId, &ipcBitsInHostPrm[0], sizeof(ipcBitsInHostPrm[0]));
    System_linkCreate(ipcOutVideoId, &ipcOutVideoPrm, sizeof(ipcOutVideoPrm));
    System_linkCreate(ipcInVpssId  , &ipcInVpssPrm  , sizeof(ipcInVpssPrm)  );
    System_linkCreate(mergeId[LIVE_DECODE_MERGE_LINK_IDX], &mergePrm[LIVE_DECODE_MERGE_LINK_IDX], sizeof(mergePrm[LIVE_DECODE_MERGE_LINK_IDX]));
    System_linkCreate(dupId[LIVE_DECODE_DUP_LINK_IDX], &dupPrm[LIVE_DECODE_DUP_LINK_IDX], sizeof(dupPrm[LIVE_DECODE_DUP_LINK_IDX]));
    for(i=0; i<2; i++)
        System_linkCreate(gVdisModuleContext.swMsId[i]  , &swMsPrm[i], sizeof(swMsPrm[i]));
    for(i=0; i<2; i++)  /* Both tied VENCs HDMI and DVO2 are handled by single link instance */
        System_linkCreate(gVdisModuleContext.displayId[i], &displayPrm[i], sizeof(displayPrm[i]));
        MergeLink_InLinkChInfo inChInfo;
        MergeLink_InLinkChInfo_Init(&inChInfo);
        inChInfo.inLinkID = ipcInVpssId;
        System_linkControl(mergeId[LIVE_DECODE_MERGE_LINK_IDX],
                           MERGE_LINK_CMD_GET_INPUT_LINK_CHINFO,
                           &inChInfo,
                           sizeof(inChInfo),
                           TRUE);
        OSA_assert(inChInfo.numCh == gVdecModuleContext.vdecConfig.numChn);
        MultiCh_setDec2DispMap(VDIS_DEV_HDMI,gVdecModuleContext.vdecConfig.numChn,0,inChInfo.startChNum);
        MultiCh_setDec2DispMap(VDIS_DEV_SD,gVdecModuleContext.vdecConfig.numChn,0,inChInfo.startChNum);
Void MultiCh_deleteProgressive4D1VcapVencVdecVdis()
    UInt32 i;
    Bool enableAlgLink = gVsysModuleContext.vsysConfig.enableOsd;
    System_linkDelete(gVcapModuleContext.captureId);
    System_linkDelete(gVcapModuleContext.nsfId[1]);
#endif
    System_linkDelete(gVcapModuleContext.deiId[0]);
    System_linkDelete(gVcapModuleContext.nsfId[0]);
    System_linkDelete(ipcOutVpssId );
    System_linkDelete(ipcInVideoId );
    if(enableAlgLink)
        System_linkDelete(gVcapModuleContext.dspAlgId[0]);
    System_linkDelete(gVencModuleContext.encId);
    System_linkDelete(gVencModuleContext.ipcBitsOutRTOSId);
    System_linkDelete(gVencModuleContext.ipcBitsInHLOSId);
    System_linkDelete(gVdecModuleContext.ipcBitsOutHLOSId);
    System_linkDelete(gVdecModuleContext.ipcBitsInRTOSId);
    System_linkDelete(gVdecModuleContext.decId);
    System_linkDelete(ipcOutVideoId);
    System_linkDelete(ipcInVpssId  );
    for(i=0; i<2; i++)
        System_linkDelete(gVdisModuleContext.swMsId[i] );
    for(i=0; i<2; i++)
        System_linkDelete(gVdisModuleContext.displayId[i]);
    for(i=0; i<NUM_DUP_LINK; i++)
        System_linkDelete(dupId[i]);
    for(i=0; i<NUM_MERGE_LINK; i++)
        if (mergeId[i] != SYSTEM_LINK_ID_INVALID )
           System_linkDelete(mergeId[i]);
    /* Print the HWI, SWI and all tasks load */
    /* Reset the accumulated timer ticks */
    MultiCh_prfLoadCalcEnable(FALSE, TRUE, FALSE);
  • Eric,
    A merge link doesn't modify the video streams in any way. It just takes multiple video streams on different link IDs and combines them together into one link ID with multiple sub-IDs (queues). This is done, as I understand it, to reduce the number of link IDs required to implement the use case (there are a max of 64 link IDs, IIRC).
